[U-Boot] [PATCH v5 1/1] imx: Get fec mac address from fuse
The patch is to support getting FEC MAC address from fuse bank.
Signed-off-by: Jason Liu r64343@freescale.com
--- Changes for v2: - correct the mac address byte order according to review comments - add memset(edev, 0. sizeof(*edev)) when do fec_probe, - fix some code comments Changes for v3: - rebase - address the comments of Stefano, make the imx_get_mac_from_fuse(), declared independently inside each imx-regs.h to make it specific for each processor, because it accesses to different structures. - address the comments of Wolfgang and Stefano, use struct to access mac_addr fuse. Changes for v4: - Address the comments of Wolfgang, use fuse_regs instead of bank addres and change from fuse1_6 to fuse0_5 naming convention and use fuse_bank0_regs instead of fuse_bank0 to kill misleading. Changes for v5: - Fix the typo error of fuse5_31[0x11] as Wolfgang point out - Change the print message "got MAC address from EEPROM to "got MAC address from fuse" which comply with this commit title. --- arch/arm/cpu/arm926ejs/mx25/generic.c | 12 ++++++++++ arch/arm/cpu/arm926ejs/mx27/generic.c | 12 ++++++++++ arch/arm/cpu/armv7/mx5/soc.c | 14 ++++++++++++ arch/arm/include/asm/arch-mx25/imx-regs.h | 19 +++++++++------ arch/arm/include/asm/arch-mx27/imx-regs.h | 18 ++++++++++----- arch/arm/include/asm/arch-mx5/imx-regs.h | 34 +++++++++++++++++++++++++++++ drivers/net/fec_mxc.c | 17 +------------ 7 files changed, 97 insertions(+), 29 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index b80a389..4ac7bbb 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -260,4 +260,16 @@ void mx25_fec_init_pins (void) writel (outpadctl, &padctl->pad_fec_tdata1);
} + +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[i] = readl(&fuse->mac_addr[i]); +} #endif /* CONFIG_FEC_MXC */ diff --git a/arch/arm/cpu/arm926ejs/mx27/generic.c b/arch/arm/cpu/arm926ejs/mx27/generic.c index ae2ce58..ceaac48 100644 --- a/arch/arm/cpu/arm926ejs/mx27/generic.c +++ b/arch/arm/cpu/arm926ejs/mx27/generic.c @@ -313,6 +313,18 @@ void mx27_fec_init_pins(void) for (i = 0; i < ARRAY_SIZE(mode); i++) imx_gpio_mode(mode[i]); } + +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[6-1-i] = readl(&fuse->mac_addr[i]); +} #endif /* CONFIG_FEC_MXC */
#ifdef CONFIG_MXC_MMC diff --git a/arch/arm/cpu/armv7/mx5/soc.c b/arch/arm/cpu/armv7/mx5/soc.c index 7c7a565..c22d6dc 100644 --- a/arch/arm/cpu/armv7/mx5/soc.c +++ b/arch/arm/cpu/armv7/mx5/soc.c @@ -100,6 +100,20 @@ int cpu_eth_init(bd_t *bis) return rc; }
+#if defined(CONFIG_FEC_MXC) +void imx_get_mac_from_fuse(unsigned char *mac) +{ + int i; + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + struct fuse_bank *bank = &iim->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + + for (i = 0; i < 6; i++) + mac[i] = readl(&fuse->mac_addr[i]); +} +#endif + /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index f5a2929..55ad115 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -36,6 +36,7 @@ #ifndef __ASSEMBLY__ #ifdef CONFIG_FEC_MXC extern void mx25_fec_init_pins(void); +extern void imx_get_mac_from_fuse(unsigned char *mac); #endif
/* Clock Control Module (CCM) registers */ @@ -129,12 +130,17 @@ struct iim_regs { u32 iim_srev; u32 iim_prog_p; u32 res1[0x1f5]; - u32 iim_bank_area0[0x20]; - u32 res2[0xe0]; - u32 iim_bank_area1[0x20]; - u32 res3[0xe0]; - u32 iim_bank_area2[0x20]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[3]; }; + +struct fuse_bank0_regs { + u32 fuse0_25[0x1a]; + u32 mac_addr[6]; +}; + #endif
/* AIPS 1 */ @@ -312,7 +318,4 @@ struct iim_regs { #define WSR_UNLOCK1 0x5555 #define WSR_UNLOCK2 0xAAAA
-/* FUSE bank offsets */ -#define IIM0_MAC 0x1a - #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx27/imx-regs.h b/arch/arm/include/asm/arch-mx27/imx-regs.h index 6ecddaa..3095839 100644 --- a/arch/arm/include/asm/arch-mx27/imx-regs.h +++ b/arch/arm/include/asm/arch-mx27/imx-regs.h @@ -34,6 +34,7 @@ extern void mx27_uart_init_pins(void);
#ifdef CONFIG_FEC_MXC extern void mx27_fec_init_pins(void); +extern void imx_get_mac_from_fuse(unsigned char *mac); #endif /* CONFIG_FEC_MXC */
#ifdef CONFIG_MXC_MMC @@ -203,8 +204,18 @@ struct iim_regs { u32 iim_scs2; u32 iim_scs3; u32 res[0x1F0]; - u32 iim_bank_area0[0x100]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[1]; }; + +struct fuse_bank0_regs { + u32 fuse0_3[4]; + u32 mac_addr[6]; + u32 fuse10_31[0x16]; +}; + #endif
#define IMX_IO_BASE 0x10000000 @@ -512,9 +523,4 @@ struct iim_regs { #define IIM_ERR_SNSE (1 << 2) #define IIM_ERR_PARITYE (1 << 1)
-/* Definitions for i.MX27 TO2 */ -#define IIM0_MAC 5 -#define IIM0_SCC_KEY 11 -#define IIM1_SUID 1 - #endif /* _IMX_REGS_H */ diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 0b6249a..d618bca 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -205,9 +205,13 @@ #define BOARD_REV_1_0 0x0 #define BOARD_REV_2_0 0x1
+#define IMX_IIM_BASE (IIM_BASE_ADDR) + #if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) #include <asm/types.h>
+extern void imx_get_mac_from_fuse(unsigned char *mac); + #define __REG(x) (*((volatile u32 *)(x))) #define __REG16(x) (*((volatile u16 *)(x))) #define __REG8(x) (*((volatile u8 *)(x))) @@ -275,6 +279,36 @@ struct src { u32 sisr; u32 simr; }; + +struct iim_regs { + u32 stat; + u32 statm; + u32 err; + u32 emask; + u32 fctl; + u32 ua; + u32 la; + u32 sdat; + u32 prev; + u32 srev; + u32 preg_p; + u32 scs0; + u32 scs1; + u32 scs2; + u32 scs3; + u32 res0[0x1f1]; + struct fuse_bank { + u32 fuse_regs[0x20]; + u32 fuse_rsvd[0xe0]; + } bank[4]; +}; + +struct fuse_bank1_regs { + u32 fuse0_8[9]; + u32 mac_addr[6]; + u32 fuse15_31[0x11]; +}; + #endif /* __ASSEMBLER__*/
#endif /* __ASM_ARCH_MXC_MX51_H__ */ diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index c17f937..0d0f392 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -312,21 +312,8 @@ static void fec_rbd_clean(int last, struct fec_bd *pRbd)
static int fec_get_hwaddr(struct eth_device *dev, unsigned char *mac) { -/* - * The MX27 can store the mac address in internal eeprom - * This mechanism is not supported now by MX51 or MX25 - */ -#if defined(CONFIG_MX51) || defined(CONFIG_MX25) - return -1; -#else - struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; - int i; - - for (i = 0; i < 6; i++) - mac[6-1-i] = readl(&iim->iim_bank_area0[IIM0_MAC + i]); - + imx_get_mac_from_fuse(mac); return !is_valid_ether_addr(mac); -#endif }
static int fec_set_hwaddr(struct eth_device *dev) @@ -754,7 +741,7 @@ static int fec_probe(bd_t *bd) eth_register(edev);
if (fec_get_hwaddr(edev, ethaddr) == 0) { - printf("got MAC address from EEPROM: %pM\n", ethaddr); + printf("got MAC address from fuse: %pM\n", ethaddr); memcpy(edev->enetaddr, ethaddr, 6); }
Hi Jason,
This works, but implicitely converts the integer to a char. Should we add a mask to make clear that only the LSB of the read value is taken ?
^ |--- missing spaces
+struct iim_regs {
- u32 stat;
- u32 statm;
- u32 err;
- u32 emask;
- u32 fctl;
- u32 ua;
- u32 la;
- u32 sdat;
- u32 prev;
- u32 srev;
- u32 preg_p;
- u32 scs0;
- u32 scs1;
- u32 scs2;
- u32 scs3;
- u32 res0[0x1f1];
- struct fuse_bank {
- } bank[4];
I see a discrepancy between i.mx27 and i.mx51 and it is not clear to me if it is correct. Both processor has the same register map (at least as meaning) until scs3. The offset for this register is for both processors 0x3c. The fuse bank0 starts for both processor at the offset 0x804, as I see in manuals. However, you reserved in one case 0x1f0 integers and in the other case 0x1f1. Is it correct ?
Best regards, Stefano Babic
Hi, Stefano,
2010/11/18 Stefano Babic sbabic@denx.de:
Hi Jason,
- mac[i] = readl(&fuse->mac_addr[i]);
In fact, I think it's not need to add a mask to do it. But for clearance, I can add it per your request.
mac[i] = readl(&fuse->mac_addr[i]) & 0xff;
- mac[6-1-i] = readl(&fuse->mac_addr[i]);
do you mean it need change to mac[6 - 1 - i] ?
+struct iim_regs {
- u32 stat;
- u32 statm;
- u32 err;
- u32 emask;
- u32 fctl;
- u32 ua;
- u32 la;
- u32 sdat;
- u32 prev;
- u32 srev;
- u32 preg_p;
- u32 scs0;
- u32 scs1;
- u32 scs2;
- u32 scs3;
- u32 res0[0x1f1];
- u32 fuse_regs[0x20];
- u32 fuse_rsvd[0xe0];
- } bank[4];
I think that the original mx27 code should be wrong. I will fix it. Thank you for your review.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Yes, this is a coding style issue.
I come with the same conclusion.
Jason Liu
Jason Liu
Stefano Babic
