[U-Boot] [PATCH] Small refactor to remove duplicate serial code
This tidies up duplicate code, and checks that default_serial_console() does in fact produce a device.
Signed-off-by: Simon Glass sjg@chromium.org --- common/serial.c | 64 +++++++++++++++++------------------------------------- 1 files changed, 20 insertions(+), 44 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 995d268..7bfc861 100644 --- a/common/serial.c +++ b/common/serial.c @@ -158,73 +158,49 @@ void serial_reinit_all (void) } }
-int serial_init (void) +static struct serial_device *get_current(void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); + struct serial_device *dev;
- return dev->init (); - } + if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { + dev = default_serial_console(); + + /* We must have a console device */ + if (!dev) + panic("Cannot find console"); + } else + dev = serial_current; + return dev; +}
- return serial_current->init (); +int serial_init(void) +{ + return get_current()->init(); }
void serial_setbrg (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->setbrg (); - return; - } - - serial_current->setbrg (); + get_current()->setbrg(); }
int serial_getc (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - return dev->getc (); - } - - return serial_current->getc (); + return get_current()->getc(); }
int serial_tstc (void) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - return dev->tstc (); - } - - return serial_current->tstc (); + return get_current()->tstc(); }
void serial_putc (const char c) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->putc (c); - return; - } - - serial_current->putc (c); + get_current()->putc(c); }
void serial_puts (const char *s) { - if (!(gd->flags & GD_FLG_RELOC) || !serial_current) { - struct serial_device *dev = default_serial_console (); - - dev->puts (s); - return; - } - - serial_current->puts (s); + get_current()->puts(s); }
#if CONFIG_POST & CONFIG_SYS_POST_UART
Acked-by: Mike Frysinger vapier@gentoo.org -mike
This doesn't seem to apply any more, so I will resend v2.
Dear Simon Glass,
Applied, thanks.
Mike Frysinger
