[U-Boot-Users] [patch #1/11] Auto Complete support
Hello
The following patch adds auto-complete support to the u-boot command line.
Using TAB the parser will try to auto complete all commands and for a few commands it will also try to do the same for their arguments.
The commands that accept auto completion of their arguments are: setenv printenv & run.
To enable just
#define CONFIG_AUTO_COMPLETE
at the board config.h file.
Regards
Pantelis
README | 4 common/command.c | 281 ++++++++++++++++++++++++++++++++++++++++++++++++++++ common/env_common.c | 41 +++++++ common/main.c | 12 ++ include/command.h | 9 + include/common.h | 4 6 files changed, 351 insertions(+)
diff -ruNb u-boot-original/README u-boot-autocomplete/README --- u-boot-original/README 2004-03-30 14:37:28.395972064 +0300 +++ u-boot-autocomplete/README 2004-03-30 15:54:54.321684000 +0300 @@ -1231,6 +1231,10 @@ default value of 5 is used.
- Command Interpreter: + CFG_AUTO_COMPLETE + + Enable auto completion of commands using TAB. + CFG_HUSH_PARSER
Define this variable to enable the "hush" shell (from diff -ruNb u-boot-original/common/command.c u-boot-autocomplete/common/command.c --- u-boot-original/common/command.c 2004-03-30 14:37:28.665931024 +0300 +++ u-boot-autocomplete/common/command.c 2004-03-30 15:42:19.877376968 +0300 @@ -217,3 +217,284 @@
return NULL; /* not found or ambiguous command */ } + +#ifdef CONFIG_AUTO_COMPLETE + +int var_complete(int argc, char *argv[], char last_char, int maxv, char *cmdv[]) +{ + static char tmp_buf[512]; + int space; + + space = last_char == '\0' || last_char == ' ' || last_char == '\t'; + + if (space && argc == 1) + return env_complete("", maxv, cmdv, sizeof(tmp_buf), tmp_buf); + + if (!space && argc == 2) + return env_complete(argv[1], maxv, cmdv, sizeof(tmp_buf), tmp_buf); + + return 0; +} + +static void install_auto_complete_handler(const char *cmd, + int (*complete)(int argc, char *argv[], char last_char, int maxv, char *cmdv[])) +{ + cmd_tbl_t *cmdtp; + + cmdtp = find_cmd(cmd); + if (cmdtp == NULL) + return; + + cmdtp->complete = complete; +} + +void install_auto_complete(void) +{ + install_auto_complete_handler("printenv", var_complete); + install_auto_complete_handler("setenv", var_complete); +#if (CONFIG_COMMANDS & CFG_CMD_RUN) + install_auto_complete_handler("run", var_complete); +#endif +} + +/*************************************************************************************/ + +static int complete_cmdv(int argc, char *argv[], char last_char, int maxv, char *cmdv[]) +{ + cmd_tbl_t *cmdtp; + const char *p; + int len, clen; + int n_found = 0; + const char *cmd; + + /* sanity? */ + if (maxv < 2) + return -2; + + cmdv[0] = NULL; + + if (argc == 0) { + /* output full list of commands */ + for (cmdtp = &__u_boot_cmd_start; cmdtp != &__u_boot_cmd_end; cmdtp++) { + if (n_found >= maxv - 2) { + cmdv[n_found++] = "..."; + break; + } + cmdv[n_found++] = cmdtp->name; + } + cmdv[n_found] = NULL; + return n_found; + } + + /* more than one arg or one but the start of the next */ + if (argc > 1 || (last_char == '\0' || last_char == ' ' || last_char == '\t')) { + cmdtp = find_cmd(argv[0]); + if (cmdtp == NULL || cmdtp->complete == NULL) { + cmdv[0] = NULL; + return 0; + } + return (*cmdtp->complete)(argc, argv, last_char, maxv, cmdv); + } + + cmd = argv[0]; + /* + * Some commands allow length modifiers (like "cp.b"); + * compare command name only until first dot. + */ + p = strchr(cmd, '.'); + if (p == NULL) + len = strlen(cmd); + else + len = p - cmd; + + /* return the partial matches */ + for (cmdtp = &__u_boot_cmd_start; cmdtp != &__u_boot_cmd_end; cmdtp++) { + + clen = strlen(cmdtp->name); + if (clen < len) + continue; + + if (memcmp(cmd, cmdtp->name, len) != 0) + continue; + + /* too many! */ + if (n_found >= maxv - 2) { + cmdv[n_found++] = "..."; + break; + } + + cmdv[n_found++] = cmdtp->name; + } + + cmdv[n_found] = NULL; + return n_found; +} + +static int make_argv(char *s, int argvsz, char *argv[]) +{ + int argc = 0; + + /* split into argv */ + while (argc < argvsz - 1) { + + /* skip any white space */ + while ((*s == ' ') || (*s == '\t')) + ++s; + + if (*s == '\0') /* end of s, no more args */ + break; + + argv[argc++] = s; /* begin of argument string */ + + /* find end of string */ + while (*s && (*s != ' ') && (*s != '\t')) + ++s; + + if (*s == '\0') /* end of s, no more args */ + break; + + *s++ = '\0'; /* terminate current arg */ + } + argv[argc] = NULL; + + return argc; +} + +static void print_argv(const char *banner, const char *leader, const char *sep, int linemax, char *argv[]) +{ + int ll = leader != NULL ? strlen(leader) : 0; + int sl = sep != NULL ? strlen(sep) : 0; + int len, i; + + if (banner) { + puts("\n"); + puts(banner); + } + + i = linemax; /* force leader and newline */ + while (*argv != NULL) { + len = strlen(*argv) + sl; + if (i + len >= linemax) { + puts("\n"); + if (leader) + puts(leader); + i = ll - sl; + } else if (sep) + puts(sep); + puts(*argv++); + i += len; + } + printf("\n"); +} + +static int find_common_prefix(char *argv[]) +{ + int i, len; + char *anchor, *s, *t; + + if (*argv == NULL) + return 0; + + /* begin with max */ + anchor = *argv++; + len = strlen(anchor); + while ((t = *argv++) != NULL) { + s = anchor; + for (i = 0; i < len; i++, t++, s++) + if (*t != *s) + break; + len = s - anchor; + } + return len; +} + +static char tmp_buf[CFG_CBSIZE]; /* copy of console I/O buffer */ + +int cmd_auto_complete(const char *const prompt, char *buf, int *np, int *colp) +{ + int n = *np, col = *colp; + char *argv[CFG_MAXARGS + 1]; /* NULL terminated */ + char *cmdv[20]; + char *s, *t; + const char *sep; + int i, j, k, len, seplen, argc; + int cnt; + char last_char; + + if (strcmp(prompt, CFG_PROMPT) != 0) + return 0; /* not in normal console */ + + cnt = strlen(buf); + if (cnt >= 1) + last_char = buf[cnt - 1]; + else + last_char = '\0'; + + /* copy to secondary buffer which will be affected */ + strcpy(tmp_buf, buf); + + /* separate into argv */ + argc = make_argv(tmp_buf, sizeof(argv)/sizeof(argv[0]), argv); + + /* do the completion and return the possible completions */ + i = complete_cmdv(argc, argv, last_char, sizeof(cmdv)/sizeof(cmdv[0]), cmdv); + + /* no match; bell and out */ + if (i == 0) { + if (argc > 1) /* allow tab for non command */ + return 0; + putc('\a'); + return 1; + } + + s = NULL; + len = 0; + sep = NULL; + seplen = 0; + if (i == 1) { /* one match; perfect */ + k = strlen(argv[argc - 1]); + s = cmdv[0] + k; + len = strlen(s); + sep = " "; + seplen = 1; + } else if (i > 1 && (j = find_common_prefix(cmdv)) != 0) { /* more */ + k = strlen(argv[argc - 1]); + j -= k; + if (j > 0) { + s = cmdv[0] + k; + len = j; + } + } + + if (s != NULL) { + k = len + seplen; + /* make sure it fits */ + if (n + k >= CFG_CBSIZE - 2) { + putc('\a'); + return 1; + } + + t = buf + cnt; + for (i = 0; i < len; i++) + *t++ = *s++; + if (sep != NULL) + for (i = 0; i < seplen; i++) + *t++ = sep[i]; + *t = '\0'; + n += k; + col += k; + puts(t - k); + if (sep == NULL) + putc('\a'); + *np = n; + *colp = col; + } else { + print_argv(NULL, " ", " ", 78, cmdv); + + puts(prompt); + puts(buf); + } + return 1; +} + +#endif diff -ruNb u-boot-original/common/env_common.c u-boot-autocomplete/common/env_common.c --- u-boot-original/common/env_common.c 2004-03-30 14:37:28.668930568 +0300 +++ u-boot-autocomplete/common/env_common.c 2004-03-30 15:42:19.878376816 +0300 @@ -260,3 +260,44 @@ disable_nvram(); #endif } + +#ifdef CONFIG_AUTO_COMPLETE +int env_complete(char *var, int maxv, char *cmdv[], int bufsz, char *buf) +{ + int i, nxt, len, vallen, found; + const char *lval, *rval; + + found = 0; + cmdv[0] = NULL; + + len = strlen(var); + /* now iterate over the variables and select those that match */ + for (i=0; env_get_char(i) != '\0'; i=nxt+1) { + + for (nxt=i; env_get_char(nxt) != '\0'; ++nxt) + ; + + lval = env_get_addr(i); + rval = strchr(lval, '='); + if (rval != NULL) { + vallen = rval - lval; + rval++; + } else + vallen = strlen(lval); + + if (len > 0 && (vallen < len || memcmp(lval, var, len) != 0)) + continue; + + if (found >= maxv - 2 || bufsz < vallen + 1) { + cmdv[found++] = "..."; + break; + } + cmdv[found++] = buf; + memcpy(buf, lval, vallen); buf += vallen; bufsz -= vallen; + *buf++ = '\0'; bufsz--; + } + + cmdv[found] = NULL; + return found; +} +#endif diff -ruNb u-boot-original/common/main.c u-boot-autocomplete/common/main.c --- u-boot-original/common/main.c 2004-03-30 14:37:28.670930264 +0300 +++ u-boot-autocomplete/common/main.c 2004-03-30 15:42:19.879376664 +0300 @@ -365,6 +365,10 @@ u_boot_hush_start (); #endif
+#ifdef CONFIG_AUTO_COMPLETE + install_auto_complete(); +#endif + #ifdef CONFIG_PREBOOT if ((p = getenv ("preboot")) != NULL) { # ifdef CONFIG_AUTOBOOT_KEYED @@ -608,6 +612,14 @@ */ if (n < CFG_CBSIZE-2) { if (c == '\t') { /* expand TABs */ +#ifdef CONFIG_AUTO_COMPLETE + /* if auto completion triggered just continue */ + *p = '\0'; + if (cmd_auto_complete(prompt, console_buffer, &n, &col)) { + p = console_buffer + n; /* reset */ + continue; + } +#endif puts (tab_seq+(col&07)); col += 8 - (col&07); } else { diff -ruNb u-boot-original/include/command.h u-boot-autocomplete/include/command.h --- u-boot-original/include/command.h 2004-03-30 14:37:28.749918256 +0300 +++ u-boot-autocomplete/include/command.h 2004-03-30 15:42:19.880376512 +0300 @@ -46,6 +46,10 @@ #ifdef CFG_LONGHELP char *help; /* Help message (long) */ #endif +#ifdef CONFIG_AUTO_COMPLETE + /* do auto completion on the arguments */ + int (*complete)(int argc, char *argv[], char last_char, int maxv, char *cmdv[]); +#endif };
typedef struct cmd_tbl_s cmd_tbl_t; @@ -57,6 +61,11 @@ /* common/command.c */ cmd_tbl_t *find_cmd(const char *cmd);
+#ifdef CONFIG_AUTO_COMPLETE +extern void install_auto_complete(void); +extern int cmd_auto_complete(const char *const prompt, char *buf, int *np, int *colp); +#endif + /* * Monitor Command * diff -ruNb u-boot-original/include/common.h u-boot-autocomplete/include/common.h --- u-boot-original/include/common.h 2004-03-30 14:37:28.750918104 +0300 +++ u-boot-autocomplete/include/common.h 2004-03-30 15:42:19.880376512 +0300 @@ -196,6 +196,10 @@ # include <asm/u-boot-i386.h> #endif /* CONFIG_I386 */
+#ifdef CONFIG_AUTO_COMPLETE +int env_complete(char *var, int maxv, char *cmdv[], int maxsz, char *buf); +#endif + void pci_init (void); void pci_init_board(void); void pciinfo (int, int);
Cool!
Robert
Anybody using EZ-KIT lite BF533 board? Can you pls let me know the memory map for Ethernet interface? Any document to mention the same. for eg, in BF535 ez-kit board, i think the BASE_ADDRESS for ethernet is 0x2c000300.
regards vidya
Why don't you ask ADI directly?
They should know exactly since they made the EZKit LAN board... although it isn't released officialy yet (o;
But maybe they also have NDA as you do (o;
best regards rick
PS: BF533EZKit Lite isn't the official (uC)Linux platform from ADI
For all EZkit BF-531/2/3/5 the EZ-LAN is mapped with Async Bank3. The BASE_ADDRESS for EZ-LAN card access in the EZkit - BF533 is 0x20300000
Regards Ganapathi C
----- Original Message ----- From: "Vidya S" vidya_s@lgsoftindia.com To: "U-Boot Users" u-boot-users@lists.sourceforge.net Sent: Tuesday, April 06, 2004 6:07 PM Subject: [U-Boot-Users] EZkit bf533 board
memory
regards vidya
This SF.Net email is sponsored by: IBM Linux Tutorials Free Linux tutorial presented by Daniel Robbins, President and CEO of GenToo technologies. Learn everything from fundamentals to system administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
but as far as i know the async mem bank 3 starts from 0x2c000000 in bf535 right? why is it that in 535 u-boot its taken as 0x2c000300. pls let me know
-----Original Message----- From: ganapathi [mailto:ganapathi@isofttech.com] Sent: Tuesday, April 06, 2004 7:36 PM To: Vidya S; U-Boot Users Subject: Re: [U-Boot-Users] EZkit bf533 board
Regards Ganapathi C
memory
regards vidya
Cool. Added, thanks.
participants (6)
ganapathi
Pantelis Antoniou
Richard Klingler
Robert Schwebel
Vidya S
