Please pull u-boot-marvell/master
Hi Tom,
please pull the first batch of mostly Marvell related patches:
---------------------------------------------------------------- - kirkwood: Switch to using upstream dts/dtsi files (Tony) - mvebu: Turris Omnia - New board revision support (Marek) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=343&view=resu...
Thanks, Stefan
The following changes since commit cdfcc37428e06f4730ab9a17cc084eeb7676ea1a:
Merge tag 'u-boot-dfu-next-20240402' of https://source.denx.de/u-boot/custodians/u-boot-dfu (2024-04-02 22:37:23 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 53bdcd1e9eacd6992d990b288fd6d48f43d94a0b:
arm: mvebu: turris_omnia: Enable rng command in defconfig (2024-04-04 10:45:27 +0200)
---------------------------------------------------------------- Marek Behún (18): arm: mvebu: turris_omnia: Enable LTO by default on Turris Omnia arm: mvebu: turris_omnia: Add header containing MCU command interface and use it arm: mvebu: turris_{omnia, mox}: Don't print model two times arm: mvebu: turris_omnia: Update MCU status and features reading arm: mvebu: turris_omnia: Implement getting board information from MCU arm: mvebu: turris_omnia: Print board ECDSA public key if available arm: mvebu: turris_omnia: Disable Atmel SHA node if not present arm: mvebu: spl: Do not build mvebu-reset in SPL arm: mvebu: system-controller: Rework to use UCLASS_SYSCON arm: mvebu: system-controller: Select mvebu-reset if DM_RESET && PCI_MVEBU arm: mvebu: system-controller: Add support for SYSRESET gpio: turris_omnia_mcu: Use byteorder conversion functions gpio: turris_omnia_mcu: Update firmware features reading gpio: turris_omnia_mcu: Add support for system power off via sysreset arm: mvebu: turris_omnia: Enable poweroff command via sysreset in defconfig cmd: rng: Print "Abort" on -EINTR misc: turris_omnia_mcu: Add support for rng provided by MCU arm: mvebu: turris_omnia: Enable rng command in defconfig
Tony Dinh (2): arm: dts: kirkwood: Enable upstream DT on Kirkwood boards arm: dts: kirkwood: Remove DTS files for Kirkwood boards
arch/arm/dts/Makefile | 28 +- arch/arm/dts/kirkwood-6192.dtsi | 88 --- arch/arm/dts/kirkwood-6281.dtsi | 90 --- arch/arm/dts/kirkwood-6282.dtsi | 161 ----- arch/arm/dts/kirkwood-98dx4122.dtsi | 53 -- arch/arm/dts/kirkwood-blackarmor-nas220.dts | 172 ----- arch/arm/dts/kirkwood-d2net.dts | 45 -- arch/arm/dts/kirkwood-dns325.dts | 63 -- arch/arm/dts/kirkwood-dnskw.dtsi | 235 ------- arch/arm/dts/kirkwood-dockstar.dts | 110 ---- arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi | 7 + arch/arm/dts/kirkwood-dreamplug.dts | 131 ---- arch/arm/dts/kirkwood-ds109.dts | 40 -- arch/arm/dts/kirkwood-goflexnet.dts | 190 ------ arch/arm/dts/kirkwood-guruplug-server-plus.dts | 133 ---- arch/arm/dts/kirkwood-ib62x0.dts | 146 ----- arch/arm/dts/kirkwood-iconnect.dts | 195 ------ arch/arm/dts/kirkwood-is2.dts | 40 -- arch/arm/dts/kirkwood-lschlv2-u-boot.dtsi | 6 +- arch/arm/dts/kirkwood-lschlv2.dts | 20 - arch/arm/dts/kirkwood-lsxhl-u-boot.dtsi | 6 +- arch/arm/dts/kirkwood-lsxhl.dts | 20 - arch/arm/dts/kirkwood-lsxl.dtsi | 241 ------- arch/arm/dts/kirkwood-net2big.dts | 63 -- arch/arm/dts/kirkwood-netxbig.dtsi | 232 ------- arch/arm/dts/kirkwood-ns2-common.dtsi | 97 --- arch/arm/dts/kirkwood-ns2.dts | 40 -- arch/arm/dts/kirkwood-ns2lite.dts | 35 - arch/arm/dts/kirkwood-ns2max.dts | 59 -- arch/arm/dts/kirkwood-ns2mini.dts | 60 -- arch/arm/dts/kirkwood-nsa310s.dts | 319 --------- arch/arm/dts/kirkwood-nsa325-u-boot.dtsi | 7 + arch/arm/dts/kirkwood-nsa325.dts | 231 ------- arch/arm/dts/kirkwood-nsa3x0-common.dtsi | 157 ----- arch/arm/dts/kirkwood-openrd-base.dts | 39 -- arch/arm/dts/kirkwood-openrd-client.dts | 73 --- arch/arm/dts/kirkwood-openrd-ultimate.dts | 55 -- arch/arm/dts/kirkwood-openrd.dtsi | 122 ---- arch/arm/dts/kirkwood-pogo_e02.dts | 132 ---- arch/arm/dts/kirkwood-pogoplug-series-4.dts | 180 ------ arch/arm/dts/kirkwood-sheevaplug-common.dtsi | 104 --- arch/arm/dts/kirkwood-sheevaplug.dts | 42 -- arch/arm/dts/kirkwood-synology.dtsi | 855 ------------------------- arch/arm/dts/kirkwood.dtsi | 393 ------------ arch/arm/mach-kirkwood/Kconfig | 2 + arch/arm/mach-mvebu/Kconfig | 25 + arch/arm/mach-mvebu/Makefile | 3 +- arch/arm/mach-mvebu/cpu.c | 2 + arch/arm/mach-mvebu/system-controller.c | 145 ++++- board/CZ.NIC/turris_atsha_otp.c | 27 +- board/CZ.NIC/turris_common.c | 42 ++ board/CZ.NIC/turris_common.h | 10 + board/CZ.NIC/turris_mox/turris_mox.c | 5 +- board/CZ.NIC/turris_omnia/Makefile | 2 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 310 ++++++--- cmd/rng.c | 7 +- configs/SBx81LIFKW_defconfig | 1 + configs/SBx81LIFXCAT_defconfig | 1 + configs/d2net_v2_defconfig | 2 +- configs/dns325_defconfig | 2 +- configs/dockstar_defconfig | 2 +- configs/dreamplug_defconfig | 2 +- configs/ds109_defconfig | 2 +- configs/goflexhome_defconfig | 2 +- configs/guruplug_defconfig | 2 +- configs/ib62x0_defconfig | 2 +- configs/iconnect_defconfig | 2 +- configs/inetspace_v2_defconfig | 2 +- configs/lschlv2_defconfig | 2 +- configs/lsxhl_defconfig | 2 +- configs/nas220_defconfig | 2 +- configs/net2big_v2_defconfig | 2 +- configs/netspace_lite_v2_defconfig | 2 +- configs/netspace_max_v2_defconfig | 2 +- configs/netspace_mini_v2_defconfig | 2 +- configs/netspace_v2_defconfig | 2 +- configs/nsa310s_defconfig | 2 +- configs/nsa325_defconfig | 2 +- configs/openrd_base_defconfig | 2 +- configs/openrd_client_defconfig | 2 +- configs/openrd_ultimate_defconfig | 2 +- configs/pogo_e02_defconfig | 2 +- configs/pogo_v4_defconfig | 2 +- configs/sheevaplug_defconfig | 2 +- configs/turris_omnia_defconfig | 6 + drivers/gpio/Kconfig | 7 - drivers/gpio/Makefile | 1 - drivers/gpio/turris_omnia_mcu.c | 316 --------- drivers/misc/Kconfig | 11 + drivers/misc/Makefile | 1 + drivers/misc/turris_omnia_mcu.c | 411 ++++++++++++ include/turris-omnia-mcu-interface.h | 248 +++++++ 92 files changed, 1150 insertions(+), 6000 deletions(-) delete mode 100644 arch/arm/dts/kirkwood-6192.dtsi delete mode 100644 arch/arm/dts/kirkwood-6281.dtsi delete mode 100644 arch/arm/dts/kirkwood-6282.dtsi delete mode 100644 arch/arm/dts/kirkwood-98dx4122.dtsi delete mode 100644 arch/arm/dts/kirkwood-blackarmor-nas220.dts delete mode 100644 arch/arm/dts/kirkwood-d2net.dts delete mode 100644 arch/arm/dts/kirkwood-dns325.dts delete mode 100644 arch/arm/dts/kirkwood-dnskw.dtsi delete mode 100644 arch/arm/dts/kirkwood-dockstar.dts create mode 100644 arch/arm/dts/kirkwood-dreamplug-u-boot.dtsi delete mode 100644 arch/arm/dts/kirkwood-dreamplug.dts delete mode 100644 arch/arm/dts/kirkwood-ds109.dts delete mode 100644 arch/arm/dts/kirkwood-goflexnet.dts delete mode 100644 arch/arm/dts/kirkwood-guruplug-server-plus.dts delete mode 100644 arch/arm/dts/kirkwood-ib62x0.dts delete mode 100644 arch/arm/dts/kirkwood-iconnect.dts delete mode 100644 arch/arm/dts/kirkwood-is2.dts delete mode 100644 arch/arm/dts/kirkwood-lschlv2.dts delete mode 100644 arch/arm/dts/kirkwood-lsxhl.dts delete mode 100644 arch/arm/dts/kirkwood-lsxl.dtsi delete mode 100644 arch/arm/dts/kirkwood-net2big.dts delete mode 100644 arch/arm/dts/kirkwood-netxbig.dtsi delete mode 100644 arch/arm/dts/kirkwood-ns2-common.dtsi delete mode 100644 arch/arm/dts/kirkwood-ns2.dts delete mode 100644 arch/arm/dts/kirkwood-ns2lite.dts delete mode 100644 arch/arm/dts/kirkwood-ns2max.dts delete mode 100644 arch/arm/dts/kirkwood-ns2mini.dts delete mode 100644 arch/arm/dts/kirkwood-nsa310s.dts create mode 100644 arch/arm/dts/kirkwood-nsa325-u-boot.dtsi delete mode 100644 arch/arm/dts/kirkwood-nsa325.dts delete mode 100644 arch/arm/dts/kirkwood-nsa3x0-common.dtsi delete mode 100644 arch/arm/dts/kirkwood-openrd-base.dts delete mode 100644 arch/arm/dts/kirkwood-openrd-client.dts delete mode 100644 arch/arm/dts/kirkwood-openrd-ultimate.dts delete mode 100644 arch/arm/dts/kirkwood-openrd.dtsi delete mode 100644 arch/arm/dts/kirkwood-pogo_e02.dts delete mode 100644 arch/arm/dts/kirkwood-pogoplug-series-4.dts delete mode 100644 arch/arm/dts/kirkwood-sheevaplug-common.dtsi delete mode 100644 arch/arm/dts/kirkwood-sheevaplug.dts delete mode 100644 arch/arm/dts/kirkwood-synology.dtsi delete mode 100644 arch/arm/dts/kirkwood.dtsi create mode 100644 board/CZ.NIC/turris_common.c create mode 100644 board/CZ.NIC/turris_common.h delete mode 100644 drivers/gpio/turris_omnia_mcu.c create mode 100644 drivers/misc/turris_omnia_mcu.c create mode 100644 include/turris-omnia-mcu-interface.h
Stefan Roese
