[PATCH 4/8] km/scripts: fix saveenv command syntax
This is most probably a typo, and in older u-uboot versions is same as 'saveenv', in the newer uboot versions there is a separate 'save' command that is different from 'saveenv'.
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com --- board/keymile/scripts/ramfs-common.txt | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/keymile/scripts/ramfs-common.txt b/board/keymile/scripts/ramfs-common.txt index e590a2b..0a4a9c8 100644 --- a/board/keymile/scripts/ramfs-common.txt +++ b/board/keymile/scripts/ramfs-common.txt @@ -3,7 +3,7 @@ boot_bank=-1 altbootcmd=run ${subbootcmds} bootcmd=run ${subbootcmds} subbootcmds=save_and_reset_once tftpfdt tftpkernel setrootfsaddr tftpramfs flashargs add_default addpanic addramfs boot -save_and_reset_once=setenv save_and_reset_once true && save && reset +save_and_reset_once=setenv save_and_reset_once true && saveenv && reset nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} configure=run set_uimage; run set_tftppath; km_setboardid && run try_import_rootfssize && saveenv && reset setrootfsaddr=setexpr value ${pnvramaddr} - ${rootfssize} && setenv rootfsaddr 0x${value}
