[U-Boot-Users] strange problem on lib_mips/board.c after relocate code
after relcate code and jump into board_init_r()
1.if i use printf to output string, it never put, but serial_puts is ok, and printf in board_init_f is ok.
2. and also in board_init_r(), the serial_puts sometimes put correctly, sometimes not. and in board_init_f, it's fine for every time.
as flollow is my serial.c functions
int serial_init (void) { volatile u32 *uart0_config = (volatile u32*)(UART0_ADDR + UART0_CTL);
/* Set parity, stop bits and word length to 8N1 */ *uart0_config = UART0_CONFIG_VAL; // serial_setbrg(); /*in our fpga board, baurate is fixed at 57600 */
return 0; }
void serial_setbrg (void) { volatile u32 *uart0_clk = (volatile u32*)(ACTIONS_CMUHOSC_ADDR + UART0_CLK_CON);
/* Set uart0_clk_con */ *uart0_clk = (((CORE_CLK_HZ/(CONFIG_BAUDRATE * 8))&0x0000FFFF) | (UART0_50DIV_SEL&0x00070000) | (UART0_CLK_EN&0x00080000));
void serial_putc (const char c) { volatile u32 *uart0_stat = (volatile u32*)(UART0_ADDR + UART0_STAT); volatile u32 *uart0_txdata = (volatile u32*)(UART0_ADDR + UART0_TXDATA);
if (c == '\n') serial_putc ('\r');
/* Wait for fifo to shift out some bytes */ while((*uart0_stat&UART0_STAT_TXFULL)); // the tx full bit means the fifo is full *uart0_txdata = (u32)c; }
void serial_puts (const char *s) { while (*s) { serial_putc (*s++); } }
Hi zhuzhenhua,
this seems to be a RAM related issue. Are you sure that you SDRAM (?)- interface is ok and correctly setup? I had a similiar problem on a PowerPC board.
BTW: zhuzhenhua, it's a friendly gesture to finish a posting with at least your name. So others can address you personally.
Regards Matthias
- and also in board_init_r(), the serial_puts sometimes put
Matthias Fuchs
zhuzhenhua
