[U-Boot] [GIT] Pull request: u-boot-dfu
Hi Marek,
The following changes since commit 68bc8b4f2946c3da06c2b05d4f4c7e594cb1fa48:
usb: kbd: Allow "usb reset" to continue when an usb kbd is used (2014-09-21 12:26:19 +0200)
u-boot-denx-usb/master
for you to fetch changes up to 772ca4fe05bf89f77efea80f5a6ff373d1ee92a9:
usb: gadget: fastboot: improve download progress bar (2014-09-24 13:11:35 +0200)
---------------------------------------------------------------- Bo Shen (1): usb: gadget: fastboot: improve download progress bar
Eric Nelson (1): usb: f_mass_storage: set removable flag in do_inquiry based on LUN
Heiko Schocher (2): usb: dfu: add fullspeed support for DFU arm: am335x: siemens board use in DFU mode fullspeed only
Łukasz Majewski (1): usb: dfu: thor: gadget: Remove dead code
drivers/usb/gadget/f_dfu.c | 11 +++-------- drivers/usb/gadget/f_fastboot.c | 14 +++++++++----- drivers/usb/gadget/f_mass_storage.c | 1 + drivers/usb/gadget/f_thor.c | 10 ---------- include/configs/siemens-am33x-common.h | 2 +- 5 files changed, 14 insertions(+), 24 deletions(-)
On Wednesday, September 24, 2014 at 02:24:44 PM, Lukasz Majewski wrote:
Hi Marek,
I know where your repository is, but you should really consider fixing this u- boot-denx-usb/master string above. Just use the full git://.... path when doing git request-pull .
Are you sure this is for master ?
Pulled it into master though, thanks!
Best regards, Marek Vasut
Hi Marek,
Hi Marek,
Aggr.... I will fix this with next PR.
This is what Heiko need for Siemens boards. As fair as I know they need this fullspeed to be able to flash their devices on a production line.
Thanks.
On Thursday, September 25, 2014 at 09:35:09 AM, Lukasz Majewski wrote:
Hi Marek,
wrote:
Hi Marek,
68bc8b4f2946c3da06c2b05d4f4c7e594cb1fa48: usb: kbd: Allow "usb reset" to continue when an usb kbd is used (2014-09-21 12:26:19 +0200)
are available in the git repository at: u-boot-denx-usb/master
Thanks!
772ca4fe05bf89f77efea80f5a6ff373d1ee92a9: usb: gadget: fastboot: improve download progress bar (2014-09-24 13:11:35 +0200)
on LUN
OK then.
Lukasz Majewski
