[U-Boot] [PATCH v2 0/1] Support for Trenz TE0820 on Sundance EMC2-DP-V2
I updated the patch according to the review of Michal Simek. I understand the concern about the maintenance of the support, so I added people from Sundance and Trenz to this patch serie. If any one of you wants to take over the integration of the patch, feel free to do so.
Changes in v2: - Renamed a lot from Xilinx ZynqMP to Trenz - The device tree for the TE0820 is now a DTSI file included by a carrier board+SOM DTS file
Vladimir Svoboda (1): arm: Add support for Trenz TE0820 on Sundance EMC2-DP-V2
arch/arm/dts/Makefile | 1 + .../sundance-emc2-dp-v2-rev1-te0820-rev2.dts | 19 + arch/arm/dts/trenz-te0820-rev2.dtsi | 213 ++++++ .../zynqmp/trenz-te0820-rev2/psu_init_gpl.c | 623 ++++++++++++++++++ ...ance_emc2-dp-v2_rev1_te0820_rev2_defconfig | 105 +++ include/configs/trenz_te0820.h | 49 ++ 6 files changed, 1010 insertions(+) create mode 100644 arch/arm/dts/sundance-emc2-dp-v2-rev1-te0820-rev2.dts create mode 100644 arch/arm/dts/trenz-te0820-rev2.dtsi create mode 100644 board/xilinx/zynqmp/trenz-te0820-rev2/psu_init_gpl.c create mode 100644 configs/sundance_emc2-dp-v2_rev1_te0820_rev2_defconfig create mode 100644 include/configs/trenz_te0820.h
Add support for Trenz TE0820 revision 2 MPSoC module. The TE0820 is a System-On-Module (SOM). This has been tested with a Sundance EMC2-DP-V2 Revision 1 carrier board.
The tested variant of the TE0820 is TE0820-02-03EG-1EA.
Signed-off-by: Vladimir Svoboda ze.vlad@gmail.com ---
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ac7667b1e8..eb1e070556 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -146,6 +146,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-zturn.dtb \ zynq-zybo.dtb dtb-$(CONFIG_ARCH_ZYNQMP) += \ + sundance-emc2-dp-v2-rev1-te0820-rev2.dtb \ zynqmp-mini-emmc.dtb \ zynqmp-mini-nand.dtb \ zynqmp-zcu100-revC.dtb \ diff --git a/arch/arm/dts/sundance-emc2-dp-v2-rev1-te0820-rev2.dts b/arch/arm/dts/sundance-emc2-dp-v2-rev1-te0820-rev2.dts new file mode 100644 index 0000000000..bea8050ab6 --- /dev/null +++ b/arch/arm/dts/sundance-emc2-dp-v2-rev1-te0820-rev2.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Sundance EMC2-DP-V2 Rev1 carrier board with Trenz TE0820 Rev2 + * SOM + * + * (C) Copyright 2018, HIPPEROS. + * + * Vladimir Svoboda vladimir.svoboda@hipperos.com + */ + +/dts-v1/; + +#include "trenz-te0820-rev2.dtsi" + +/ { + model = "Sundance EMC2-DP-V2 Rev1 Trenz TE0820 Rev2"; + compatible = "trenz,zynqmp-te0820-rev2", "trenz,zynqmp-te0820", + "trenz,zynqmp"; +}; diff --git a/arch/arm/dts/trenz-te0820-rev2.dtsi b/arch/arm/dts/trenz-te0820-rev2.dtsi new file mode 100644 index 0000000000..8eb603550d --- /dev/null +++ b/arch/arm/dts/trenz-te0820-rev2.dtsi @@ -0,0 +1,213 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Trenz TE0820 Rev2 + * + * (C) Copyright 2018, HIPPEROS. + * + * Vladimir Svoboda vladimir.svoboda@hipperos.com + */ + +/dts-v1/; + +/include/ "zynqmp.dtsi" +/include/ "zynqmp-clk-ccf.dtsi" + +/ { + model = "Trenz TE0820 Rev2"; + compatible = "trenz,zynqmp-te0820-rev2", "trenz,zynqmp-te0820", + "trenz,zynqmp"; + + aliases { + ethernet0 = &gem3; + i2c0 = &i2c0; + i2c1 = &i2c1; + rtc0 = &rtc; + serial0 = &uart0; + serial1 = &uart1; + serial2 = &dcc; + }; + + chosen { + bootargs = "earlycon"; + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; +}; + +&can1 { + status = "okay"; +}; + +&dcc { + status = "okay"; +}; + +&fpd_dma_chan1 { + status = "okay"; +}; + +&fpd_dma_chan2 { + status = "okay"; +}; + +&fpd_dma_chan3 { + status = "okay"; +}; + +&fpd_dma_chan4 { + status = "okay"; +}; + +&fpd_dma_chan5 { + status = "okay"; +}; + +&fpd_dma_chan6 { + status = "okay"; +}; + +&fpd_dma_chan7 { + status = "okay"; +}; + +&fpd_dma_chan8 { + status = "okay"; +}; + +&gem3 { + status = "okay"; + phy-handle = <&phy0>; + phy-mode = "rgmii-id"; + phy0: phy@21 { + reg = <21>; + ti,rx-internal-delay = <0x8>; + ti,tx-internal-delay = <0xa>; + ti,fifo-depth = <0x1>; + }; + ethernet_phy0: ethernet-phy@0 { + compatible = "marvell,88e1510"; + device_type = "ethernet-phy"; + reg = <1>; + }; +}; + +&gpio { + status = "okay"; +}; + +&gpu { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; +}; + +&i2c1 { + status = "okay"; + clock-frequency = <400000>; +}; + +&pcie { + status = "okay"; +}; + +&qspi { + #address-cells = <1>; + #size-cells = <0>; + status = "okay"; + flash0: flash@0 { + compatible = "n25q256a"; + reg = <0x0>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&rtc { + status = "okay"; +}; + +/* SD1 with level shifter */ +&sdhci1 { + status = "okay"; + no-1-8-v; + xlnx,mio_bank = <1>; + disable-wp; +}; + +&serdes { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +/* ULPI SMSC USB3320 */ +&usb0 { + status = "okay"; +}; + +&dwc3_0 { + status = "okay"; + dr_mode = "host"; + maximum-speed = "high-speed"; + /delete-property/phy-names; + /delete-property/phys; + /delete-property/snps,usb3_lpm_capable; +}; + +&watchdog0 { + status = "okay"; +}; + +&xilinx_ams { + status = "okay"; +}; + +&ams_ps { + status = "okay"; +}; + +&ams_pl { + status = "okay"; +}; + +&xlnx_dp { + status = "okay"; +}; + +&xlnx_dp_sub { + status = "okay"; + xlnx,vid-clk-pl; +}; + +&xlnx_dp_snd_pcm0 { + status = "okay"; +}; + +&xlnx_dp_snd_pcm1 { + status = "okay"; +}; + +&xlnx_dp_snd_card { + status = "okay"; +}; + +&xlnx_dp_snd_codec0 { + status = "okay"; +}; + +&xlnx_dpdma { + status = "okay"; +}; diff --git a/board/xilinx/zynqmp/trenz-te0820-rev2/psu_init_gpl.c b/board/xilinx/zynqmp/trenz-te0820-rev2/psu_init_gpl.c new file mode 100644 index 0000000000..3b43d3fce6 --- /dev/null +++ b/board/xilinx/zynqmp/trenz-te0820-rev2/psu_init_gpl.c @@ -0,0 +1,623 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (c) Copyright 2015 Xilinx, Inc. All rights reserved. + */ + +#include <asm/arch/psu_init_gpl.h> +#include <xil_io.h> + +static unsigned long psu_pll_init_data(void) +{ + psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E60EC6CU); + psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00013000U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U); + + mask_poll(0xFF5E0040, 0x00000002U); + psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000200U); + psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U); + psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U); + + mask_poll(0xFF5E0040, 0x00000001U); + psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U); + + mask_poll(0xFD1A0044, 0x00000001U); + psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014800U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U); + + mask_poll(0xFD1A0044, 0x00000002U); + psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000300U); + psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U); + psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00013F00U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U); + + mask_poll(0xFD1A0044, 0x00000004U); + psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U); + psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000200U); + + return 1; +} + +static unsigned long psu_clock_init_data(void) +{ + psu_mask_write(0xFF5E005C, 0x063F3F07U, 0x06010C00U); + psu_mask_write(0xFF5E0100, 0x013F3F07U, 0x01010600U); + psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010600U); + psu_mask_write(0xFF5E0068, 0x013F3F07U, 0x01010500U); + psu_mask_write(0xFF5E006C, 0x013F3F07U, 0x01010402U); + psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010402U); + psu_mask_write(0xFF18030C, 0x00020003U, 0x00000000U); + psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U); + psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000300U); + psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000800U); + psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U); + psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U); + psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000302U); + psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010802U); + psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011E02U); + psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U); + psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000104U); + psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U); + psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U); + psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000203U); + psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000203U); + psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000202U); + psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U); + psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U); + psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_init_data(void) +{ + psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U); + psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x81041010U); + psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U); + psu_mask_write(0xFD070020, 0x000003F3U, 0x00000300U); + psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U); + psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U); + psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00409410U); + psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U); + psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U); + psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U); + psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x0092809DU); + psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U); + psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U); + psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U); + psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0048051FU); + psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020126U); + psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U); + psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002705U); + psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x0B340301U); + psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00180200U); + psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U); + psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x000806C0U); + psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U); + psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U); + psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU); + psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x11122813U); + psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004051CU); + psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0608070DU); + psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU); + psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030409U); + psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x07070403U); + psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U); + psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000707U); + psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D07U); + psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002040AU); + psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x4708010EU); + psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U); + psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U); + psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x0201C9C3U); + psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048C8209U); + psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U); + psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U); + psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U); + psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U); + psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00A9007EU); + psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U); + psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000A04U); + psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U); + psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU); + psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0808U); + psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x01010101U); + psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x0F010101U); + psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x060F0606U); + psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x0F060606U); + psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU); + psu_mask_write(0xFD070220, 0x00001F1FU, 0x00001F00U); + psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x06060606U); + psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x06060606U); + psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000006U); + psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x0600060CU); + psu_mask_write(0xFD070244, 0x00003333U, 0x00000001U); + psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U); + psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U); + psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U); + psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070300, 0x00000011U, 0x00000001U); + psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U); + psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U); + psu_mask_write(0xFD070400, 0x00000111U, 0x00000101U); + psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU); + psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U); + psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U); + psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU); + psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U); + psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU); + psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U); + psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU); + psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U); + psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U); + psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U); + psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU); + psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U); + psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U); + psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U); + psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F12098U); + psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U); + psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U); + psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x2C096010U); + psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xA9801460U); + psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A041A1U); + psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x000000D3U); + psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU); + psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x0826100AU); + psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28240008U); + psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x00080300U); + psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U); + psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x01382B08U); + psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00371009U); + psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000C10U); + psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U); + psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U); + psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000300U); + psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000A34U); + psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000301U); + psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000018U); + psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U); + psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x000006C0U); + psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U); + psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U); + psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU); + psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800091C7U); + psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U); + psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U); + psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U); + psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12340400U); + psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U); + psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U); + psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000009U); + psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x0A000000U); + psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU); + psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U); + psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U); + psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U); + psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008B0A58U); + psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU); + psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U); + psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U); + psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x00087BDBU); + psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU); + psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x40800604U); + psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x40800624U); + psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x00007F00U); + psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0E00B03CU); + psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU); + psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU); + psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x2A019FFEU); + psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01264300U); + psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U); + psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70800000U); + psu_mask_write(0xFD0817C4, 0xFFFFFFFFU, 0x000E0000U); + psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U); + + return 1; +} + +static unsigned long psu_mio_init_data(void) +{ + psu_mask_write(0xFF180000, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180004, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180008, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18000C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180010, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180014, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180018, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18001C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180020, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180024, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180028, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18002C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180030, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180034, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180038, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180040, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180044, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180048, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180050, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180054, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180058, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000008U); + psu_mask_write(0xFF180060, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180064, 0x000000FEU, 0x00000000U); + psu_mask_write(0xFF180078, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF18007C, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180098, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF18009C, 0x000000FEU, 0x00000040U); + psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U); + psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U); + psu_mask_write(0xFF180100, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180104, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180108, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180110, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180114, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180118, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180120, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180124, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180128, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000002U); + psu_mask_write(0xFF180130, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180134, 0x000000FEU, 0x000000C0U); + psu_mask_write(0xFF180204, 0xC3FFFFFFU, 0x40000000U); + psu_mask_write(0xFF180208, 0xFFFFC0C0U, 0x00B00000U); + psu_mask_write(0xFF18020C, 0x00003FFFU, 0x00000FC0U); + psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x01F00000U); + psu_mask_write(0xFF180160, 0x000FFFFFU, 0x000FFFFFU); + psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFF03FU); + psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU); + psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x00000000U); + psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U); + + return 1; +} + +static unsigned long psu_peripherals_init_data(void) +{ + psu_mask_write(0xFD1A0100, 0x0000807CU, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U); + psu_mask_write(0xFF5E0230, 0x00000008U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000000U); + psu_mask_write(0xFF180390, 0x00000004U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000000U); + psu_mask_write(0xFF9D0080, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF9D007C, 0x00000001U, 0x00000001U); + psu_mask_write(0xFF5E0238, 0x00000060U, 0x00000000U); + psu_mask_write(0xFF180310, 0x00008001U, 0x00000001U); + psu_mask_write(0xFF180320, 0x33803380U, 0x00801280U); + psu_mask_write(0xFF18031C, 0x00007FFEU, 0x00006450U); + psu_mask_write(0xFF180358, 0x00080000U, 0x00080000U); + psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U); + psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U); + psu_mask_write(0xFF180324, 0x000003C0U, 0x00000000U); + psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000200U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U); + psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U); + psu_mask_write(0xFF000034, 0x000000FFU, 0x00000006U); + psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000007CU); + psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U); + psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U); + psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U); + psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU); + psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U); + psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U); + psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U); + psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x01FCA051U); + psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U); + + return 1; +} + +static unsigned long psu_peripherals_powerdwn_data(void) +{ + return 1; +} + +static unsigned long psu_serdes_init_data(void) +{ + return 1; +} + +static unsigned long psu_resetout_init_data(void) +{ + psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U); + + return 1; +} + +static unsigned long psu_resetin_init_data(void) +{ + return 1; +} + +static unsigned long psu_afi_config(void) +{ + psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U); + psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U); + psu_mask_write(0xFF419000, 0x00000300U, 0x00000000U); + + return 1; +} + +static unsigned long psu_ddr_phybringup_data(void) +{ + unsigned int regval = 0; + + unsigned int pll_retry = 10; + + unsigned int pll_locked = 0; + + while ((pll_retry > 0) && (!pll_locked)) { + Xil_Out32(0xFD080004, 0x00040010); + Xil_Out32(0xFD080004, 0x00040011); + + while ((Xil_In32(0xFD080030) & 0x1) != 1) + ; + + pll_locked = (Xil_In32(0xFD080030) & 0x80000000) >> 31; + pll_locked &= (Xil_In32(0xFD0807E0) & 0x10000) >> 16; + pll_locked &= (Xil_In32(0xFD0809E0) & 0x10000) >> 16; + pll_retry--; + } + Xil_Out32(0xFD0800C0, Xil_In32(0xFD0800C0) | (pll_retry << 16)); + Xil_Out32(0xFD080004U, 0x00040063U); + + while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU) + ; + + prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U); + + while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU) + ; + + Xil_Out32(0xFD0701B0U, 0x00000001U); + Xil_Out32(0xFD070320U, 0x00000001U); + while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U) + ; + + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U); + Xil_Out32(0xFD080004, 0x0004FE01); + regval = Xil_In32(0xFD080030); + while (regval != 0x80000FFF) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD080200U, 0x100091C7U); + Xil_Out32(0xFD080018U, 0x00F02300U); + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U); + + Xil_Out32(0xFD080004, 0x00060001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80004001) != 0x80004001) + regval = Xil_In32(0xFD080030); + + prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U); + prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U); + prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U); + + Xil_Out32(0xFD080200U, 0x800091C7U); + Xil_Out32(0xFD080018U, 0x00F14780U); + + Xil_Out32(0xFD080004, 0x0000C001); + regval = Xil_In32(0xFD080030); + while ((regval & 0x80000C01) != 0x80000C01) + regval = Xil_In32(0xFD080030); + + Xil_Out32(0xFD070180U, 0x01000040U); + Xil_Out32(0xFD070060U, 0x00000000U); + prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U); + + return 1; +} + +static int init_serdes(void) +{ + int status = 1; + + status &= psu_resetin_init_data(); + + status &= psu_serdes_init_data(); + status &= psu_resetout_init_data(); + + return status; +} + +static void init_peripheral(void) +{ + psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU); +} + +int psu_init(void) +{ + int status = 1; + + status &= psu_mio_init_data(); + status &= psu_pll_init_data(); + status &= psu_clock_init_data(); + status &= psu_ddr_init_data(); + status &= psu_ddr_phybringup_data(); + status &= psu_peripherals_init_data(); + status &= init_serdes(); + init_peripheral(); + + status &= psu_peripherals_powerdwn_data(); + status &= psu_afi_config(); + + if (status == 0) + return 1; + return 0; +} diff --git a/configs/sundance_emc2-dp-v2_rev1_te0820_rev2_defconfig b/configs/sundance_emc2-dp-v2_rev1_te0820_rev2_defconfig new file mode 100644 index 0000000000..fcedf9c5a0 --- /dev/null +++ b/configs/sundance_emc2-dp-v2_rev1_te0820_rev2_defconfig @@ -0,0 +1,105 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="trenz_te0820" +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL=y +CONFIG_IDENT_STRING=" Sundance EMC2-DP-V2 Rev1 Trenz TE0820 Rev2" +CONFIG_ZYNQMP_USB=y +CONFIG_DEFAULT_DEVICE_TREE="sundance-emc2-dp-v2-rev1-te0820-rev2" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_ATF=y +CONFIG_SYS_PROMPT="ZynqMP> " +CONFIG_FASTBOOT=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_CMD_THOR_DOWNLOAD=y +CONFIG_CMD_EEPROM=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_CLK_ZYNQMP=y +CONFIG_DFU_RAM=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQMPPL=y +CONFIG_DM_GPIO=y +CONFIG_CMD_PCA953X=y +CONFIG_SYS_I2C_ZYNQ=y +CONFIG_ZYNQ_I2C0=y +CONFIG_ZYNQ_I2C1=y +CONFIG_MISC=y +CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHY_MARVELL=y +CONFIG_PHY_NATSEMI=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_TI=y +CONFIG_PHY_VITESSE=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_ZYNQ=y +CONFIG_DEBUG_UART_BASE=0xff000000 +CONFIG_DEBUG_UART_CLOCK=100000000 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_ZYNQMP=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_USB_FUNCTION_THOR=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/trenz_te0820.h b/include/configs/trenz_te0820.h new file mode 100644 index 0000000000..e374762df3 --- /dev/null +++ b/include/configs/trenz_te0820.h @@ -0,0 +1,49 @@ +/* + * Configuration for Xilinx ZynqMP TE0820 + * + * Inspired from xilinx_zynqmp_zcu102.h + * + * (C) Copyright 2018, HIPPEROS. + * Vladimir Svoboda vladimir.svoboda@hipperos.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ZYNQMP_TE0820_H +#define __CONFIG_ZYNQMP_TE0820_H + +#define CONFIG_ZYNQ_SDHCI1 +#define CONFIG_SYS_I2C_MAX_HOPS 1 +#define CONFIG_SYS_NUM_I2C_BUSES 18 +#define CONFIG_SYS_I2C_BUSES { \ + {0, {I2C_NULL_HOP} }, \ + {0, {{I2C_MUX_PCA9544, 0x75, 0} } }, \ + {0, {{I2C_MUX_PCA9544, 0x75, 1} } }, \ + {0, {{I2C_MUX_PCA9544, 0x75, 2} } }, \ + {1, {I2C_NULL_HOP} }, \ + {1, {{I2C_MUX_PCA9548, 0x74, 0} } }, \ + {1, {{I2C_MUX_PCA9548, 0x74, 1} } }, \ + {1, {{I2C_MUX_PCA9548, 0x74, 2} } }, \ + {1, {{I2C_MUX_PCA9548, 0x74, 3} } }, \ + {1, {{I2C_MUX_PCA9548, 0x74, 4} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 0} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 1} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 2} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 3} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 4} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 5} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 6} } }, \ + {1, {{I2C_MUX_PCA9548, 0x75, 7} } }, \ + } + +#define CONFIG_PCA953X + +#define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR} + +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_ZYNQ_EEPROM_BUS 5 +#define CONFIG_INITRD_TAG /* pass initrd param to kernel */ + +#include <configs/xilinx_zynqmp.h> + +#endif /* __CONFIG_ZYNQMP_TE0820_H */
Changes in v2:
- sundance-emc2-dp-v2-rev1-te0820-rev2.dtb \ zynqmp-mini-emmc.dtb \ zynqmp-mini-nand.dtb \ zynqmp-zcu100-revC.dtb \
- dts file for Sundance EMC2-DP-V2 Rev1 carrier board with Trenz TE0820 Rev2
NIT: remove file and you will fit to 80 chars.
- SOM
- (C) Copyright 2018, HIPPEROS.
- Vladimir Svoboda vladimir.svoboda@hipperos.com
+/dts-v1/;
- model = "Sundance EMC2-DP-V2 Rev1 Trenz TE0820 Rev2";
- compatible = "trenz,zynqmp-te0820-rev2", "trenz,zynqmp-te0820",
"trenz,zynqmp";
This is definitely not enough. This is carrier board which should contain all components which are only on this board. It means a lot of things from SOM below should be moved here.
Also compatible string should contains sundance and record it in vendor-prefix in the linux kernel. These prefixes needs to be at least in linux-next to be able to apply these patches. I would even like to hear Rob's opinion on these SoM division.
- dts file for Trenz TE0820 Rev2
+/dts-v1/;
- model = "Trenz TE0820 Rev2";
"trenz,zynqmp";
you can keep xlnx,zynqmp here too.
- aliases {
ethernet0 = &gem3;
i2c0 = &i2c0;
i2c1 = &i2c1;
rtc0 = &rtc;
serial0 = &uart0;
serial1 = &uart1;
Don't know this module but if there is no hardwired MIOs for these IPs then they should be in sundance dts not here.
serial2 = &dcc;
If jtag is on trenz board you can keep this here.
- chosen {
sundance.
- memory@0 {
This memory is on this module that's why it needs to be here.
+&can1 {
- status = "okay";
I would put this to sundance if there is physical hw for can.
+&dcc {
- status = "okay";
+&fpd_dma_chan1 {
- status = "okay";
+&fpd_dma_chan2 {
- status = "okay";
+&fpd_dma_chan3 {
- status = "okay";
+&fpd_dma_chan4 {
- status = "okay";
+&fpd_dma_chan5 {
- status = "okay";
+&fpd_dma_chan6 {
- status = "okay";
+&fpd_dma_chan7 {
- status = "okay";
+&fpd_dma_chan8 {
- status = "okay";
you can keep these here.
+&gem3 {
- status = "okay";
- phy-handle = <&phy0>;
- phy-mode = "rgmii-id";
- phy0: phy@21 {
reg = <21>;
- ethernet_phy0: ethernet-phy@0 {
This is completely bogus. Do you have there 1 phy or two phys? It should be phy@1.
reg = <1>;
This is not on SOM.
+&gpio {
- status = "okay";
+&gpu {
- status = "okay";
You can keep these two here.
+&i2c0 {
- status = "okay";
- clock-frequency = <400000>;
+&i2c1 {
- status = "okay";
Probably on sundance unless there are dedicated pins where it is exactly said pins XX/YY have to be i2c.
+&pcie {
- status = "okay";
As above.
+&qspi {
- #address-cells = <1>;
- #size-cells = <0>;
- status = "okay";
- flash0: flash@0 {
reg = <0x0>;
#size-cells = <1>;
This is on SOM that's why this is fine.
+&rtc {
- status = "okay";
this is ok.
- status = "okay";
- no-1-8-v;
- xlnx,mio_bank = <1>;
- disable-wp;
Again if no hardwired in spec then sundance.
+&serdes {
- status = "okay";
in SOM is fine.
+&uart0 {
- status = "okay";
+&uart1 {
- status = "okay";
- status = "okay";
+&dwc3_0 {
- status = "okay";
- dr_mode = "host";
- maximum-speed = "high-speed";
- /delete-property/phy-names;
- /delete-property/phys;
- /delete-property/snps,usb3_lpm_capable;
The same for all of these above.
+&watchdog0 {
- status = "okay";
+&xilinx_ams {
- status = "okay";
+&ams_ps {
- status = "okay";
+&ams_pl {
- status = "okay";
These are internal one that's why fine.
+&xlnx_dp {
- status = "okay";
+&xlnx_dp_sub {
- status = "okay";
- xlnx,vid-clk-pl;
- status = "okay";
- status = "okay";
- status = "okay";
- status = "okay";
+&xlnx_dpdma {
- status = "okay";
I can't see DP on SOM that's why if you have there DP then to sundance.
- (c) Copyright 2015 Xilinx, Inc. All rights reserved.
- psu_mask_write(0xFF5E0034, 0xFE7FEDEFU, 0x7E60EC6CU);
- psu_mask_write(0xFF5E0030, 0x00717F00U, 0x00013000U);
- psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0030, 0x00000001U, 0x00000000U);
- mask_poll(0xFF5E0040, 0x00000002U);
- psu_mask_write(0xFF5E0030, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0048, 0x00003F00U, 0x00000200U);
- psu_mask_write(0xFF5E0024, 0xFE7FEDEFU, 0x7E4B0C82U);
- psu_mask_write(0xFF5E0020, 0x00717F00U, 0x00015A00U);
- psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0020, 0x00000001U, 0x00000000U);
- mask_poll(0xFF5E0040, 0x00000001U);
- psu_mask_write(0xFF5E0020, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0044, 0x00003F00U, 0x00000300U);
- psu_mask_write(0xFD1A0024, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A0020, 0x00717F00U, 0x00014800U);
- psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A0020, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000001U);
- psu_mask_write(0xFD1A0020, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A0048, 0x00003F00U, 0x00000300U);
- psu_mask_write(0xFD1A0030, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A002C, 0x00717F00U, 0x00014800U);
- psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A002C, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000002U);
- psu_mask_write(0xFD1A002C, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A004C, 0x00003F00U, 0x00000300U);
- psu_mask_write(0xFD1A003C, 0xFE7FEDEFU, 0x7E4B0C62U);
- psu_mask_write(0xFD1A0038, 0x00717F00U, 0x00013F00U);
- psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD1A0038, 0x00000001U, 0x00000000U);
- mask_poll(0xFD1A0044, 0x00000004U);
- psu_mask_write(0xFD1A0038, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFD1A0050, 0x00003F00U, 0x00000200U);
- return 1;
- psu_mask_write(0xFF5E005C, 0x063F3F07U, 0x06010C00U);
- psu_mask_write(0xFF5E0100, 0x013F3F07U, 0x01010600U);
- psu_mask_write(0xFF5E0060, 0x023F3F07U, 0x02010600U);
- psu_mask_write(0xFF5E0068, 0x013F3F07U, 0x01010500U);
- psu_mask_write(0xFF5E006C, 0x013F3F07U, 0x01010402U);
- psu_mask_write(0xFF5E0070, 0x013F3F07U, 0x01010402U);
- psu_mask_write(0xFF18030C, 0x00020003U, 0x00000000U);
- psu_mask_write(0xFF5E0074, 0x013F3F07U, 0x01010F00U);
- psu_mask_write(0xFF5E0120, 0x013F3F07U, 0x01010F00U);
- psu_mask_write(0xFF5E0090, 0x01003F07U, 0x01000302U);
- psu_mask_write(0xFF5E009C, 0x01003F07U, 0x01000300U);
- psu_mask_write(0xFF5E00A4, 0x01003F07U, 0x01000800U);
- psu_mask_write(0xFF5E00A8, 0x01003F07U, 0x01000302U);
- psu_mask_write(0xFF5E00AC, 0x01003F07U, 0x01000F02U);
- psu_mask_write(0xFF5E00B0, 0x01003F07U, 0x01000602U);
- psu_mask_write(0xFF5E00B8, 0x01003F07U, 0x01000302U);
- psu_mask_write(0xFF5E00C0, 0x013F3F07U, 0x01010802U);
- psu_mask_write(0xFF5E0108, 0x013F3F07U, 0x01011E02U);
- psu_mask_write(0xFF5E0104, 0x00000007U, 0x00000000U);
- psu_mask_write(0xFF5E0128, 0x01003F07U, 0x01000104U);
- psu_mask_write(0xFD1A0060, 0x03003F07U, 0x03000100U);
- psu_mask_write(0xFD1A0068, 0x01003F07U, 0x01000200U);
- psu_mask_write(0xFD1A0080, 0x00003F07U, 0x00000200U);
- psu_mask_write(0xFD1A0084, 0x07003F07U, 0x07000203U);
- psu_mask_write(0xFD1A00B8, 0x01003F07U, 0x01000203U);
- psu_mask_write(0xFD1A00BC, 0x01003F07U, 0x01000203U);
- psu_mask_write(0xFD1A00C0, 0x01003F07U, 0x01000202U);
- psu_mask_write(0xFD1A00C4, 0x01003F07U, 0x01000502U);
- psu_mask_write(0xFD1A00F8, 0x00003F07U, 0x00000200U);
- psu_mask_write(0xFF180380, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD610100, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF180300, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF410050, 0x00000001U, 0x00000000U);
- return 1;
- psu_mask_write(0xFD1A0108, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFD070000, 0xE30FBE3DU, 0x81041010U);
- psu_mask_write(0xFD070010, 0x8000F03FU, 0x00000030U);
- psu_mask_write(0xFD070020, 0x000003F3U, 0x00000300U);
- psu_mask_write(0xFD070024, 0xFFFFFFFFU, 0x00800000U);
- psu_mask_write(0xFD070030, 0x0000007FU, 0x00000000U);
- psu_mask_write(0xFD070034, 0x00FFFF1FU, 0x00409410U);
- psu_mask_write(0xFD070050, 0x00F1F1F4U, 0x00210000U);
- psu_mask_write(0xFD070054, 0x0FFF0FFFU, 0x00000000U);
- psu_mask_write(0xFD070060, 0x00000073U, 0x00000001U);
- psu_mask_write(0xFD070064, 0x0FFF83FFU, 0x0092809DU);
- psu_mask_write(0xFD070070, 0x00000017U, 0x00000010U);
- psu_mask_write(0xFD070074, 0x00000003U, 0x00000000U);
- psu_mask_write(0xFD0700C4, 0x3F000391U, 0x10000200U);
- psu_mask_write(0xFD0700C8, 0x01FF1F3FU, 0x0048051FU);
- psu_mask_write(0xFD0700D0, 0xC3FF0FFFU, 0x00020126U);
- psu_mask_write(0xFD0700D4, 0x01FF7F0FU, 0x00020000U);
- psu_mask_write(0xFD0700D8, 0x0000FF0FU, 0x00002705U);
- psu_mask_write(0xFD0700DC, 0xFFFFFFFFU, 0x0B340301U);
- psu_mask_write(0xFD0700E0, 0xFFFFFFFFU, 0x00180200U);
- psu_mask_write(0xFD0700E4, 0x00FF03FFU, 0x00210004U);
- psu_mask_write(0xFD0700E8, 0xFFFFFFFFU, 0x000806C0U);
- psu_mask_write(0xFD0700EC, 0xFFFF0000U, 0x08190000U);
- psu_mask_write(0xFD0700F0, 0x0000003FU, 0x00000010U);
- psu_mask_write(0xFD0700F4, 0x00000FFFU, 0x0000066FU);
- psu_mask_write(0xFD070100, 0x7F3F7F3FU, 0x11122813U);
- psu_mask_write(0xFD070104, 0x001F1F7FU, 0x0004051CU);
- psu_mask_write(0xFD070108, 0x3F3F3F3FU, 0x0608070DU);
- psu_mask_write(0xFD07010C, 0x3FF3F3FFU, 0x0050400CU);
- psu_mask_write(0xFD070110, 0x1F0F0F1FU, 0x08030409U);
- psu_mask_write(0xFD070114, 0x0F0F3F1FU, 0x07070403U);
- psu_mask_write(0xFD070118, 0x0F0F000FU, 0x01010004U);
- psu_mask_write(0xFD07011C, 0x00000F0FU, 0x00000707U);
- psu_mask_write(0xFD070120, 0x7F7F7F7FU, 0x04040D07U);
- psu_mask_write(0xFD070124, 0x40070F3FU, 0x0002040AU);
- psu_mask_write(0xFD07012C, 0x7F1F031FU, 0x4708010EU);
- psu_mask_write(0xFD070130, 0x00030F1FU, 0x00020608U);
- psu_mask_write(0xFD070180, 0xF7FF03FFU, 0x81000040U);
- psu_mask_write(0xFD070184, 0x3FFFFFFFU, 0x0201C9C3U);
- psu_mask_write(0xFD070190, 0x1FBFBF3FU, 0x048C8209U);
- psu_mask_write(0xFD070194, 0xF31F0F0FU, 0x00030304U);
- psu_mask_write(0xFD070198, 0x0FF1F1F1U, 0x07000101U);
- psu_mask_write(0xFD07019C, 0x000000F1U, 0x00000021U);
- psu_mask_write(0xFD0701A0, 0xC3FF03FFU, 0x00400003U);
- psu_mask_write(0xFD0701A4, 0x00FF00FFU, 0x00A9007EU);
- psu_mask_write(0xFD0701B0, 0x00000007U, 0x00000000U);
- psu_mask_write(0xFD0701B4, 0x00003F3FU, 0x00000A04U);
- psu_mask_write(0xFD0701C0, 0x00000007U, 0x00000001U);
- psu_mask_write(0xFD070200, 0x0000001FU, 0x0000001FU);
- psu_mask_write(0xFD070204, 0x001F1F1FU, 0x001F0808U);
- psu_mask_write(0xFD070208, 0x0F0F0F0FU, 0x01010101U);
- psu_mask_write(0xFD07020C, 0x0F0F0F0FU, 0x0F010101U);
- psu_mask_write(0xFD070210, 0x00000F0FU, 0x00000F0FU);
- psu_mask_write(0xFD070214, 0x0F0F0F0FU, 0x060F0606U);
- psu_mask_write(0xFD070218, 0x8F0F0F0FU, 0x0F060606U);
- psu_mask_write(0xFD07021C, 0x00000F0FU, 0x00000F0FU);
- psu_mask_write(0xFD070220, 0x00001F1FU, 0x00001F00U);
- psu_mask_write(0xFD070224, 0x0F0F0F0FU, 0x06060606U);
- psu_mask_write(0xFD070228, 0x0F0F0F0FU, 0x06060606U);
- psu_mask_write(0xFD07022C, 0x0000000FU, 0x00000006U);
- psu_mask_write(0xFD070240, 0x0F1F0F7CU, 0x0600060CU);
- psu_mask_write(0xFD070244, 0x00003333U, 0x00000001U);
- psu_mask_write(0xFD070250, 0x7FFF3F07U, 0x01002001U);
- psu_mask_write(0xFD070264, 0xFF00FFFFU, 0x08000040U);
- psu_mask_write(0xFD07026C, 0xFF00FFFFU, 0x08000040U);
- psu_mask_write(0xFD070280, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070284, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070288, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD07028C, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD070290, 0x0000FFFFU, 0x00000000U);
- psu_mask_write(0xFD070294, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070300, 0x00000011U, 0x00000001U);
- psu_mask_write(0xFD07030C, 0x80000033U, 0x00000000U);
- psu_mask_write(0xFD070320, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFD070400, 0x00000111U, 0x00000101U);
- psu_mask_write(0xFD070404, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070408, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070490, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070494, 0x0033000FU, 0x0020000BU);
- psu_mask_write(0xFD070498, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD0704B4, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0704B8, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070540, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070544, 0x03330F0FU, 0x02000B03U);
- psu_mask_write(0xFD070548, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD070564, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070568, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0705F0, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD0705F4, 0x03330F0FU, 0x02000B03U);
- psu_mask_write(0xFD0705F8, 0x07FF07FFU, 0x00000000U);
- psu_mask_write(0xFD070614, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070618, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0706A0, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD0706A4, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD0706A8, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD0706AC, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD0706B0, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD0706C4, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD0706C8, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070750, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070754, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070758, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD07075C, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070760, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD070774, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070778, 0x000073FFU, 0x0000200FU);
- psu_mask_write(0xFD070800, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFD070804, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070808, 0x07FF07FFU, 0x0000004FU);
- psu_mask_write(0xFD07080C, 0x0033000FU, 0x00100003U);
- psu_mask_write(0xFD070810, 0x000007FFU, 0x0000004FU);
- psu_mask_write(0xFD070F04, 0x000001FFU, 0x00000000U);
- psu_mask_write(0xFD070F08, 0x000000FFU, 0x00000000U);
- psu_mask_write(0xFD070F0C, 0x000001FFU, 0x00000010U);
- psu_mask_write(0xFD070F10, 0x000000FFU, 0x0000000FU);
- psu_mask_write(0xFD072190, 0x1FBFBF3FU, 0x07828002U);
- psu_mask_write(0xFD1A0108, 0x0000000CU, 0x00000000U);
- psu_mask_write(0xFD080010, 0xFFFFFFFFU, 0x07001E00U);
- psu_mask_write(0xFD080018, 0xFFFFFFFFU, 0x00F12098U);
- psu_mask_write(0xFD08001C, 0xFFFFFFFFU, 0x55AA5480U);
- psu_mask_write(0xFD080024, 0xFFFFFFFFU, 0x010100F4U);
- psu_mask_write(0xFD080040, 0xFFFFFFFFU, 0x2C096010U);
- psu_mask_write(0xFD080044, 0xFFFFFFFFU, 0xA9801460U);
- psu_mask_write(0xFD080068, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD080090, 0xFFFFFFFFU, 0x02A041A1U);
- psu_mask_write(0xFD0800C0, 0xFFFFFFFFU, 0x000000D3U);
- psu_mask_write(0xFD080100, 0xFFFFFFFFU, 0x0800040CU);
- psu_mask_write(0xFD080110, 0xFFFFFFFFU, 0x0826100AU);
- psu_mask_write(0xFD080114, 0xFFFFFFFFU, 0x28240008U);
- psu_mask_write(0xFD080118, 0xFFFFFFFFU, 0x00080300U);
- psu_mask_write(0xFD08011C, 0xFFFFFFFFU, 0x83000800U);
- psu_mask_write(0xFD080120, 0xFFFFFFFFU, 0x01382B08U);
- psu_mask_write(0xFD080124, 0xFFFFFFFFU, 0x00371009U);
- psu_mask_write(0xFD080128, 0xFFFFFFFFU, 0x00000C10U);
- psu_mask_write(0xFD080140, 0xFFFFFFFFU, 0x08400020U);
- psu_mask_write(0xFD080144, 0xFFFFFFFFU, 0x00000C80U);
- psu_mask_write(0xFD080150, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080154, 0xFFFFFFFFU, 0x00000300U);
- psu_mask_write(0xFD080180, 0xFFFFFFFFU, 0x00000A34U);
- psu_mask_write(0xFD080184, 0xFFFFFFFFU, 0x00000301U);
- psu_mask_write(0xFD080188, 0xFFFFFFFFU, 0x00000018U);
- psu_mask_write(0xFD08018C, 0xFFFFFFFFU, 0x00000200U);
- psu_mask_write(0xFD080190, 0xFFFFFFFFU, 0x00000008U);
- psu_mask_write(0xFD080194, 0xFFFFFFFFU, 0x000006C0U);
- psu_mask_write(0xFD080198, 0xFFFFFFFFU, 0x00000819U);
- psu_mask_write(0xFD0801AC, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD0801B0, 0xFFFFFFFFU, 0x0000004DU);
- psu_mask_write(0xFD0801B4, 0xFFFFFFFFU, 0x00000008U);
- psu_mask_write(0xFD0801B8, 0xFFFFFFFFU, 0x0000004DU);
- psu_mask_write(0xFD0801D8, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080200, 0xFFFFFFFFU, 0x800091C7U);
- psu_mask_write(0xFD080204, 0xFFFFFFFFU, 0x00010236U);
- psu_mask_write(0xFD080240, 0xFFFFFFFFU, 0x00141054U);
- psu_mask_write(0xFD080250, 0xFFFFFFFFU, 0x00088000U);
- psu_mask_write(0xFD080414, 0xFFFFFFFFU, 0x12340400U);
- psu_mask_write(0xFD0804F4, 0xFFFFFFFFU, 0x00000005U);
- psu_mask_write(0xFD080500, 0xFFFFFFFFU, 0x30000028U);
- psu_mask_write(0xFD080508, 0xFFFFFFFFU, 0x0A000000U);
- psu_mask_write(0xFD08050C, 0xFFFFFFFFU, 0x00000009U);
- psu_mask_write(0xFD080510, 0xFFFFFFFFU, 0x0A000000U);
- psu_mask_write(0xFD080520, 0xFFFFFFFFU, 0x0300B0CEU);
- psu_mask_write(0xFD080528, 0xFFFFFFFFU, 0xF9032019U);
- psu_mask_write(0xFD08052C, 0xFFFFFFFFU, 0x07F001E3U);
- psu_mask_write(0xFD080544, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080548, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080558, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD08055C, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080560, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080564, 0xFFFFFFFFU, 0x00000000U);
- psu_mask_write(0xFD080680, 0xFFFFFFFFU, 0x008B0A58U);
- psu_mask_write(0xFD080684, 0xFFFFFFFFU, 0x000079DDU);
- psu_mask_write(0xFD080694, 0xFFFFFFFFU, 0x01E10210U);
- psu_mask_write(0xFD080698, 0xFFFFFFFFU, 0x01E10000U);
- psu_mask_write(0xFD0806A4, 0xFFFFFFFFU, 0x00087BDBU);
- psu_mask_write(0xFD080700, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080710, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080714, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080718, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080800, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080810, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080814, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080818, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080900, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080904, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD080910, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080914, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080918, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080A00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080A04, 0xFFFFFFFFU, 0x00007FFFU);
- psu_mask_write(0xFD080A10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080A14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080A18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080B00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080B04, 0xFFFFFFFFU, 0x00007F00U);
- psu_mask_write(0xFD080B10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080B14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080B18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080C00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080C04, 0xFFFFFFFFU, 0x00007F00U);
- psu_mask_write(0xFD080C10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080C14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080C18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080D00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080D04, 0xFFFFFFFFU, 0x00007F00U);
- psu_mask_write(0xFD080D10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080D14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080D18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080E00, 0xFFFFFFFFU, 0x40800604U);
- psu_mask_write(0xFD080E04, 0xFFFFFFFFU, 0x00007F00U);
- psu_mask_write(0xFD080E10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080E14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080E18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD080F00, 0xFFFFFFFFU, 0x40800624U);
- psu_mask_write(0xFD080F04, 0xFFFFFFFFU, 0x00007F00U);
- psu_mask_write(0xFD080F10, 0xFFFFFFFFU, 0x0E00B03CU);
- psu_mask_write(0xFD080F14, 0xFFFFFFFFU, 0x09094F4FU);
- psu_mask_write(0xFD080F18, 0xFFFFFFFFU, 0x09092B2BU);
- psu_mask_write(0xFD081400, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081404, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD08141C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD08142C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081430, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD081440, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081444, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD08145C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD08146C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081470, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD081480, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081484, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD08149C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD0814AC, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD0814B0, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD0814C0, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD0814C4, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD0814DC, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD0814EC, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD0814F0, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD081500, 0xFFFFFFFFU, 0x2A019FFEU);
- psu_mask_write(0xFD081504, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD08151C, 0xFFFFFFFFU, 0x01264300U);
- psu_mask_write(0xFD08152C, 0xFFFFFFFFU, 0x00041800U);
- psu_mask_write(0xFD081530, 0xFFFFFFFFU, 0x70800000U);
- psu_mask_write(0xFD0817C4, 0xFFFFFFFFU, 0x000E0000U);
- psu_mask_write(0xFD0817DC, 0xFFFFFFFFU, 0x012643C4U);
- return 1;
- psu_mask_write(0xFF180000, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180004, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180008, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18000C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180010, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180014, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180018, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18001C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180020, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180024, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180028, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18002C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180030, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180034, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180038, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18003C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180040, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180044, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180048, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18004C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180050, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180054, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180058, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF18005C, 0x000000FEU, 0x00000008U);
- psu_mask_write(0xFF180060, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180064, 0x000000FEU, 0x00000000U);
- psu_mask_write(0xFF180078, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF18007C, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF180098, 0x000000FEU, 0x00000040U);
- psu_mask_write(0xFF18009C, 0x000000FEU, 0x00000040U);
- psu_mask_write(0xFF1800B8, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800BC, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C0, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C4, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800C8, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800CC, 0x000000FEU, 0x00000010U);
- psu_mask_write(0xFF1800D0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800D4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800D8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800DC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800E8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800EC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F0, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F4, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800F8, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF1800FC, 0x000000FEU, 0x00000004U);
- psu_mask_write(0xFF180100, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180104, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180108, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18010C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180110, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180114, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180118, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18011C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180120, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180124, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180128, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF18012C, 0x000000FEU, 0x00000002U);
- psu_mask_write(0xFF180130, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF180134, 0x000000FEU, 0x000000C0U);
- psu_mask_write(0xFF180204, 0xC3FFFFFFU, 0x40000000U);
- psu_mask_write(0xFF180208, 0xFFFFC0C0U, 0x00B00000U);
- psu_mask_write(0xFF18020C, 0x00003FFFU, 0x00000FC0U);
- psu_mask_write(0xFF180138, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18013C, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180140, 0x03FFFFFFU, 0x00000000U);
- psu_mask_write(0xFF180144, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180148, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18014C, 0x03FFFFFFU, 0x00000000U);
- psu_mask_write(0xFF180154, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180158, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF18015C, 0x03FFFFFFU, 0x01F00000U);
- psu_mask_write(0xFF180160, 0x000FFFFFU, 0x000FFFFFU);
- psu_mask_write(0xFF180164, 0x03FFFFFFU, 0x03FFF03FU);
- psu_mask_write(0xFF180168, 0x03FFFFFFU, 0x00000000U);
- psu_mask_write(0xFF180170, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180174, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180178, 0x03FFFFFFU, 0x00000000U);
- psu_mask_write(0xFF18017C, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180180, 0x03FFFFFFU, 0x03FFFFFFU);
- psu_mask_write(0xFF180184, 0x03FFFFFFU, 0x00000000U);
- psu_mask_write(0xFF180200, 0x0000000FU, 0x00000000U);
- return 1;
- psu_mask_write(0xFD1A0100, 0x0000807CU, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x001A0000U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x0093C018U, 0x00000000U);
- psu_mask_write(0xFF5E0230, 0x00000008U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000001U, 0x00000000U);
- psu_mask_write(0xFF180390, 0x00000004U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00000540U, 0x00000000U);
- psu_mask_write(0xFF9D0080, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF9D007C, 0x00000001U, 0x00000001U);
- psu_mask_write(0xFF5E0238, 0x00000060U, 0x00000000U);
- psu_mask_write(0xFF180310, 0x00008001U, 0x00000001U);
- psu_mask_write(0xFF180320, 0x33803380U, 0x00801280U);
- psu_mask_write(0xFF18031C, 0x00007FFEU, 0x00006450U);
- psu_mask_write(0xFF180358, 0x00080000U, 0x00080000U);
- psu_mask_write(0xFF18031C, 0x7FFE0000U, 0x64500000U);
- psu_mask_write(0xFF180358, 0x00000008U, 0x00000008U);
- psu_mask_write(0xFF180324, 0x000003C0U, 0x00000000U);
- psu_mask_write(0xFF180324, 0x03C00000U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000200U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00008000U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00007800U, 0x00000000U);
- psu_mask_write(0xFF5E0238, 0x00000002U, 0x00000000U);
- psu_mask_write(0xFF000034, 0x000000FFU, 0x00000006U);
- psu_mask_write(0xFF000018, 0x0000FFFFU, 0x0000007CU);
- psu_mask_write(0xFF000000, 0x000001FFU, 0x00000017U);
- psu_mask_write(0xFF000004, 0x000003FFU, 0x00000020U);
- psu_mask_write(0xFF5E0238, 0x00040000U, 0x00000000U);
- psu_mask_write(0xFF4B0024, 0x000000FFU, 0x000000FFU);
- psu_mask_write(0xFFCA5000, 0x00001FFFU, 0x00000000U);
- psu_mask_write(0xFD5C0060, 0x000F000FU, 0x00000000U);
- psu_mask_write(0xFFA60040, 0x80000000U, 0x80000000U);
- psu_mask_write(0xFF260020, 0xFFFFFFFFU, 0x01FCA051U);
- psu_mask_write(0xFF260000, 0x00000001U, 0x00000001U);
- return 1;
- return 1;
- return 1;
You don't have any serdes setting. It means above there shouldn't be serdes node, dp, usb3.0 and pcie.
- psu_mask_write(0xFD480064, 0x00000200U, 0x00000200U);
- return 1;
- return 1;
you can remove these empty functions.
- psu_mask_write(0xFD1A0100, 0x00001F80U, 0x00000000U);
- psu_mask_write(0xFF5E023C, 0x00080000U, 0x00000000U);
- psu_mask_write(0xFF419000, 0x00000300U, 0x00000000U);
- return 1;
- unsigned int regval = 0;
nit remove empty line.
- unsigned int pll_retry = 10;
- unsigned int pll_locked = 0;
- while ((pll_retry > 0) && (!pll_locked)) {
pll_retry--;
- Xil_Out32(0xFD0800C0, Xil_In32(0xFD0800C0) | (pll_retry << 16));
- Xil_Out32(0xFD080004U, 0x00040063U);
- while ((Xil_In32(0xFD080030U) & 0x0000000FU) != 0x0000000FU)
- prog_reg(0xFD080004U, 0x00000001U, 0x00000000U, 0x00000001U);
- while ((Xil_In32(0xFD080030U) & 0x000000FFU) != 0x0000001FU)
- Xil_Out32(0xFD0701B0U, 0x00000001U);
- Xil_Out32(0xFD070320U, 0x00000001U);
- while ((Xil_In32(0xFD070004U) & 0x0000000FU) != 0x00000001U)
- prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000001U);
- Xil_Out32(0xFD080004, 0x0004FE01);
- regval = Xil_In32(0xFD080030);
- while (regval != 0x80000FFF)
- Xil_Out32(0xFD080200U, 0x100091C7U);
- Xil_Out32(0xFD080018U, 0x00F02300U);
- prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000003U);
- prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000003U);
- prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000003U);
- Xil_Out32(0xFD080004, 0x00060001);
- while ((regval & 0x80004001) != 0x80004001)
- prog_reg(0xFD08001CU, 0x00000018U, 0x00000003U, 0x00000000U);
- prog_reg(0xFD08142CU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD08146CU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD0814ACU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD0814ECU, 0x00000030U, 0x00000004U, 0x00000000U);
- prog_reg(0xFD08152CU, 0x00000030U, 0x00000004U, 0x00000000U);
- Xil_Out32(0xFD080200U, 0x800091C7U);
- Xil_Out32(0xFD080018U, 0x00F14780U);
- Xil_Out32(0xFD080004, 0x0000C001);
- while ((regval & 0x80000C01) != 0x80000C01)
- Xil_Out32(0xFD070180U, 0x01000040U);
- Xil_Out32(0xFD070060U, 0x00000000U);
- prog_reg(0xFD080014U, 0x00000040U, 0x00000006U, 0x00000000U);
- return 1;
- int status = 1;
- status &= psu_resetin_init_data();
- status &= psu_serdes_init_data();
- status &= psu_resetout_init_data();
- return status;
Not sure what's that one write does without looking at regs but check if you can remove this function completely.
- psu_mask_write(0xFD5F0018, 0x8000001FU, 0x8000001FU);
- int status = 1;
- status &= psu_mio_init_data();
- status &= psu_pll_init_data();
- status &= psu_clock_init_data();
- status &= psu_ddr_init_data();
- status &= psu_ddr_phybringup_data();
- status &= psu_peripherals_init_data();
- status &= init_serdes();
- init_peripheral();
- status &= psu_peripherals_powerdwn_data();
- status &= psu_afi_config();
- if (status == 0)
return 1;
look below.
you don't need to use this string - enable cpuinfo and it will be taken from DT directly.
Did you test sata without serdes?
On Xilinx boards I am enabling all these flashes because Xilinx has these boards with different qspi vendors for testing. You should have this only flash vendor which is used on the SoM or better compatible SoMs.
the same here.
I would use sundance instead of trenz because below is nothing SoM specific but only carrier board specific.
- Configuration for Xilinx ZynqMP TE0820
Trenz? Or better Sundance with Trenz.
- Inspired from xilinx_zynqmp_zcu102.h
if you don't have 2 SDs you can remove this macro.
You didn't list any i2c devices that's why this is most likely just c&p from zcu102.
I didn't see eemprom with mac above that's why likely c&p error.
Are you really going to use ATAGS?
Thanks, Michal
Michal Simek
Vladimir Svoboda
