[U-Boot] [PATCH v1 0/3] Enable all asynchronous abort exceptions taken to EL3
This patchset allow PSCI exception vectors to handle all external abort and SError exception from all exception levels. This will allow EL3 to handle asynchronous abort exceptions such as ECC DBE (Double Bit Error) taken from OS running at lower exception level.
Chee Hong Ang (3): ARMv8: Enable all asynchronous abort exceptions taken to EL3 ARMv8: Add EL3 exception handling for ARMv8's Kconfig ARMv8: SError exception handling in PSCI exception vectors
arch/arm/cpu/armv8/Kconfig | 7 +++++++ arch/arm/cpu/armv8/psci.S | 26 ++++++++++++++++++++++++++ arch/arm/include/asm/macro.h | 4 ++++ arch/arm/include/asm/system.h | 1 + 4 files changed, 38 insertions(+)
Allow EL3 to handle all the External Abort and SError interrupt exception occur in all exception levels.
Signed-off-by: Chee Hong Ang chee.hong.ang@intel.com --- arch/arm/include/asm/macro.h | 4 ++++ arch/arm/include/asm/system.h | 1 + 2 files changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/macro.h b/arch/arm/include/asm/macro.h index d5a7a8b..bb33b4b 100644 --- a/arch/arm/include/asm/macro.h +++ b/arch/arm/include/asm/macro.h @@ -193,6 +193,10 @@ lr .req x30 SCR_EL3_SMD_DIS | SCR_EL3_RES1 |\ SCR_EL3_NS_EN) #endif + +#ifdef CONFIG_ARMV8_EA_EL3_FIRST + orr \tmp, \tmp, #SCR_EL3_EA_EN +#endif msr scr_el3, \tmp
/* Return to the EL2_SP2 mode from EL3 */ diff --git a/arch/arm/include/asm/system.h b/arch/arm/include/asm/system.h index c1f87f9..aed2e3c 100644 --- a/arch/arm/include/asm/system.h +++ b/arch/arm/include/asm/system.h @@ -29,6 +29,7 @@ #define SCR_EL3_HCE_EN (1 << 8) /* Hypervisor Call enable */ #define SCR_EL3_SMD_DIS (1 << 7) /* Secure Monitor Call disable */ #define SCR_EL3_RES1 (3 << 4) /* Reserved, RES1 */ +#define SCR_EL3_EA_EN (1 << 3) /* External aborts taken to EL3 */ #define SCR_EL3_NS_EN (1 << 0) /* EL0 and EL1 in Non-scure state */
Kconfig option to allow all External Abort and SError exception taken to EL3.
Signed-off-by: Chee Hong Ang chee.hong.ang@intel.com --- arch/arm/cpu/armv8/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index c8bebab..ff42791 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -144,6 +144,13 @@ config ARMV8_PSCI_CPUS_PER_CLUSTER A value 0 or no definition of it works for single cluster system. System with multi-cluster should difine their own exact value.
+config ARMV8_EA_EL3_FIRST + bool "External aborts and SError interrupt exception are taken in EL3" + default n + help + Exception handling at all exception levels for External Abort and + SError interrupt exception are taken in EL3. + if SYS_HAS_ARMV8_SECURE_BASE
config ARMV8_SECURE_BASE
Allow platform vendors to handle SError interrupt exceptions from ARMv8 PSCI exception vectors by overriding this weak function 'plat_error_handler'.
Signed-off-by: Chee Hong Ang chee.hong.ang@intel.com --- arch/arm/cpu/armv8/psci.S | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/arch/arm/cpu/armv8/psci.S b/arch/arm/cpu/armv8/psci.S index 097f91b..358df8f 100644 --- a/arch/arm/cpu/armv8/psci.S +++ b/arch/arm/cpu/armv8/psci.S @@ -236,6 +236,28 @@ handle_sync:
b unhandled_exception
+#ifdef CONFIG_ARMV8_EA_EL3_FIRST +/* + * Override this function if custom error handling is + * needed for asynchronous aborts + */ +ENTRY(plat_error_handler) + ret +ENDPROC(plat_error_handler) +.weak plat_error_handler + +handle_error: + bl psci_get_cpu_id + bl psci_get_cpu_stack_top + mov x9, #1 + msr spsel, x9 + mov sp, x0 + + bl plat_error_handler /* Platform specific error handling */ +deadloop: + b deadloop /* Never return */ +#endif + .align 11 .globl el3_exception_vectors el3_exception_vectors: @@ -261,7 +283,11 @@ el3_exception_vectors: .align 7 b unhandled_exception /* FIQ, Lower EL using AArch64 */ .align 7 +#ifdef CONFIG_ARMV8_EA_EL3_FIRST + b handle_error /* SError, Lower EL using AArch64 */ +#else b unhandled_exception /* SError, Lower EL using AArch64 */ +#endif .align 7 b unhandled_exception /* Sync, Lower EL using AArch32 */ .align 7
