[PATCH v1] linker_lists:Update the alignment using CONFIG_LINKER_LIST_ALIGN
This patch updates the alignment of linker lists to use the CONFIG_LINKER_LIST_ALIGN macro instead of a hardcoded value. This ensures that the alignment is consistent with the configuration. Replace __attribute__((unused)) with __maybe_unused and __always_unused to eliminate the warning of checkpatch.pl.
Signed-off-by: Liya Huang 1425075683@qq.com ---
Changes in v1: - Due to an error, the patch was resubmitted, leaving the code unchanged
include/linker_lists.h | 21 +++++++++++++-------- 1 file changed, 13 insertions(+), 8 deletions(-)
diff --git a/include/linker_lists.h b/include/linker_lists.h index f9a2ee0c76..e8791430d7 100644 --- a/include/linker_lists.h +++ b/include/linker_lists.h @@ -68,8 +68,9 @@ * }; */ #define ll_entry_declare(_type, _name, _list) \ - _type _u_boot_list_2_##_list##_2_##_name __aligned(4) \ - __attribute__((unused)) \ + _type _u_boot_list_2_##_list##_2_##_name \ + __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __maybe_unused \ __section("__u_boot_list_2_"#_list"_2_"#_name)
/** @@ -91,8 +92,9 @@ * }; */ #define ll_entry_declare_list(_type, _name, _list) \ - _type _u_boot_list_2_##_list##_2_##_name[] __aligned(4) \ - __attribute__((unused)) \ + _type _u_boot_list_2_##_list##_2_##_name[] \ + __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __maybe_unused \ __section("__u_boot_list_2_"#_list"_2_"#_name)
/* @@ -125,7 +127,7 @@ #define ll_entry_start(_type, _list) \ ({ \ static char start[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ - __attribute__((unused)) \ + __always_unused \ __section("__u_boot_list_2_"#_list"_1"); \ _type * tmp = (_type *)&start; \ asm("":"+r"(tmp)); \ @@ -153,7 +155,8 @@ */ #define ll_entry_end(_type, _list) \ ({ \ - static char end[0] __aligned(4) __attribute__((unused)) \ + static char end[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __always_unused \ __section("__u_boot_list_2_"#_list"_3"); \ _type * tmp = (_type *)&end; \ asm("":"+r"(tmp)); \ @@ -249,7 +252,8 @@ */ #define ll_start(_type) \ ({ \ - static char start[0] __aligned(4) __attribute__((unused)) \ + static char start[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __always_unused \ __section("__u_boot_list_1"); \ _type * tmp = (_type *)&start; \ asm("":"+r"(tmp)); \ @@ -274,7 +278,8 @@ */ #define ll_end(_type) \ ({ \ - static char end[0] __aligned(4) __attribute__((unused)) \ + static char end[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __always_unused \ __section("__u_boot_list_3"); \ _type * tmp = (_type *)&end; \ asm("":"+r"(tmp)); \
1425075683@qq.com
