[U-Boot] [PATCH 1/4] Fix spelling of "multiple".
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
fs/ubifs/ubifs.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index cdc04c6..cc397d6 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -854,7 +854,7 @@ int ubifs_read(const char *filename, void *buf, loff_t offset, *actread = 0;
if (offset & (PAGE_SIZE - 1)) { - printf("ubifs: Error offset must be a multple of %d\n", + printf("ubifs: Error offset must be a multiple of %d\n", PAGE_SIZE); return -1; }
board/sysam/amcore/amcore.c | 2 +- tools/mkimage.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/sysam/amcore/amcore.c b/board/sysam/amcore/amcore.c index b7217c5..77b5000 100644 --- a/board/sysam/amcore/amcore.c +++ b/board/sysam/amcore/amcore.c @@ -93,7 +93,7 @@ phys_size_t initdram(int board_type) out_be32((u32 *)0x00000004, 0xbeaddeed); /* issue AUTOREFRESH */ out_be32(&dc->dacr0, 0x0000b304); - /* let refresh occour */ + /* let refresh occur */ fudelay(1);
out_be32(&dc->dacr0, 0x0000b344); diff --git a/tools/mkimage.c b/tools/mkimage.c index 3c594a0..02f88bb 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -88,7 +88,7 @@ static void usage(const char *msg) params.cmdname); fprintf(stderr, " %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] fit-image\n" - " <dtb> file is used with -f auto, it may occour multiple times.\n", + " <dtb> file is used with -f auto, it may occur multiple times.\n", params.cmdname); fprintf(stderr, " -D => set all options for device tree compiler\n"
Hi Vagrant,
Acked-by: Angelo Dureghello angelo@sysam.it
thanks for the fix,
Best regards, Angelo Dureghello
params.cmdname); fprintf(stderr, " -D => set all options for device tree compiler\n"" <dtb> file is used with -f auto, it may occur multiple times.\n",
On Sun, Oct 23, 2016 at 08:45:17PM -0700, Vagrant Cascadian wrote:
Signed-off-by: Vagrant Cascadian vagrant@debian.org Acked-by: Angelo Dureghello angelo@sysam.it Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot/master (before v2016.11-rc3), thanks!
cmd/bootm.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/bootm.c b/cmd/bootm.c index e02a1c5..083f3d1 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -162,7 +162,7 @@ static char bootm_help_text[] = #endif #if defined(CONFIG_FIT) "\t\nFor the new multi component uImage format (FIT) addresses\n" - "\tmust be extened to include component or configuration unit name:\n" + "\tmust be extended to include component or configuration unit name:\n" "\taddr:<subimg_uname> - direct component image specification\n" "\taddr#<conf_uname> - configuration specification\n" "\tUse iminfo command to get the list of existing component\n"
On Sun, Oct 23, 2016 at 08:45:18PM -0700, Vagrant Cascadian wrote:
Signed-off-by: Vagrant Cascadian vagrant@debian.org Reviewed-by: Simon Glass sjg@chromium.org
Cover-Letter: Fixes several spelling errors for the words "resetting", "extended", "occur", and "multiple".
arch/arm/mach-exynos/dmc_init_ddr3.c | 2 +- arch/arm/mach-socfpga/misc.c | 2 +- arch/mips/mach-au1x00/au1x00_usb_ohci.c | 3 ++- arch/powerpc/cpu/mpc5xxx/usb_ohci.c | 3 ++- arch/powerpc/cpu/ppc4xx/usb_ohci.c | 3 ++- drivers/net/fec_mxc.c | 2 +- drivers/usb/host/ohci-hcd.c | 2 +- drivers/usb/host/ohci-s3c24xx.c | 2 +- include/vsprintf.h | 4 ++-- 9 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-exynos/dmc_init_ddr3.c b/arch/arm/mach-exynos/dmc_init_ddr3.c index 25a9df9..6a5d26c 100644 --- a/arch/arm/mach-exynos/dmc_init_ddr3.c +++ b/arch/arm/mach-exynos/dmc_init_ddr3.c @@ -618,7 +618,7 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int reset) /* * Send NOP, MRS and ZQINIT commands * Sending MRS command will reset the DRAM. We should not be - * reseting the DRAM after resume, this will lead to memory + * resetting the DRAM after resume, this will lead to memory * corruption as DRAM content is lost after DRAM reset */ dmc_config_mrs(mem, &drex0->directcmd); diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index 5cbd8a4..dd6b53b 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -362,7 +362,7 @@ int arch_early_init_r(void) * issuing warm reset. The ancient kernel code expects this * value to be written into the register by the bootloader, so * to support that old code, we write it here instead of in the - * reset_cpu() function just before reseting the CPU. + * reset_cpu() function just before resetting the CPU. */ writel(0xae9efebc, &sysmgr_regs->romcodegrp_warmramgrp_enable);
diff --git a/arch/mips/mach-au1x00/au1x00_usb_ohci.c b/arch/mips/mach-au1x00/au1x00_usb_ohci.c index 42484e5..088e612 100644 --- a/arch/mips/mach-au1x00/au1x00_usb_ohci.c +++ b/arch/mips/mach-au1x00/au1x00_usb_ohci.c @@ -671,7 +671,8 @@ static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buf __u32 info = 0; unsigned int toggle = 0;
- /* OHCI handles the DATA-toggles itself, we just use the USB-toggle bits for reseting */ + /* OHCI handles the DATA-toggles itself, we just use the + USB-toggle bits for resetting */ if(usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { diff --git a/arch/powerpc/cpu/mpc5xxx/usb_ohci.c b/arch/powerpc/cpu/mpc5xxx/usb_ohci.c index b7c1b55..cf36954 100644 --- a/arch/powerpc/cpu/mpc5xxx/usb_ohci.c +++ b/arch/powerpc/cpu/mpc5xxx/usb_ohci.c @@ -670,7 +670,8 @@ static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buf __u32 info = 0; unsigned int toggle = 0;
- /* OHCI handles the DATA-toggles itself, we just use the USB-toggle bits for reseting */ + /* OHCI handles the DATA-toggles itself, we just use the + USB-toggle bits for resetting */ if(usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { diff --git a/arch/powerpc/cpu/ppc4xx/usb_ohci.c b/arch/powerpc/cpu/ppc4xx/usb_ohci.c index 65a0675..27423e3 100644 --- a/arch/powerpc/cpu/ppc4xx/usb_ohci.c +++ b/arch/powerpc/cpu/ppc4xx/usb_ohci.c @@ -673,7 +673,8 @@ static void td_submit_job (struct usb_device *dev, unsigned long pipe, void *buf __u32 info = 0; unsigned int toggle = 0;
- /* OHCI handles the DATA-toggles itself, we just use the USB-toggle bits for reseting */ + /* OHCI handles the DATA-toggles itself, we just use the + USB-toggle bits for resetting */ if(usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 8e3b839..84021ea 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1024,7 +1024,7 @@ static int fec_probe(bd_t *bd, int dev_id, uint32_t base_addr, start = get_timer(0); while (readl(&fec->eth->ecntrl) & FEC_ECNTRL_RESET) { if (get_timer(start) > (CONFIG_SYS_HZ * 5)) { - printf("FEC MXC: Timeout reseting chip\n"); + printf("FEC MXC: Timeout resetting chip\n"); goto err4; } udelay(10); diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index ccbfc02..bd2d9c3 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -963,7 +963,7 @@ static void td_submit_job(ohci_t *ohci, struct usb_device *dev, flush_dcache_buffer(buffer, data_len);
/* OHCI handles the DATA-toggles itself, we just use the USB-toggle - * bits for reseting */ + * bits for resetting */ if (usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { diff --git a/drivers/usb/host/ohci-s3c24xx.c b/drivers/usb/host/ohci-s3c24xx.c index 8bb2275..28b9ab5 100644 --- a/drivers/usb/host/ohci-s3c24xx.c +++ b/drivers/usb/host/ohci-s3c24xx.c @@ -677,7 +677,7 @@ static void td_submit_job(struct usb_device *dev, unsigned long pipe, unsigned int toggle = 0;
/* OHCI handles the DATA-toggles itself, we just - use the USB-toggle bits for reseting */ + use the USB-toggle bits for resetting */ if (usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe))) { toggle = TD_T_TOGGLE; } else { diff --git a/include/vsprintf.h b/include/vsprintf.h index 60e91d1..e38076d 100644 --- a/include/vsprintf.h +++ b/include/vsprintf.h @@ -72,7 +72,7 @@ long trailing_strtoln(const char *str, const char *end); * panic() - Print a message and reset/hang * * Prints a message on the console(s) and then resets. If CONFIG_PANIC_HANG is - * defined, then it will hang instead of reseting. + * defined, then it will hang instead of resetting. * * @param fmt: printf() format string for message, which should not include * \n, followed by arguments @@ -84,7 +84,7 @@ void panic(const char *fmt, ...) * panic_str() - Print a message and reset/hang * * Prints a message on the console(s) and then resets. If CONFIG_PANIC_HANG is - * defined, then it will hang instead of reseting. + * defined, then it will hang instead of resetting. * * This function can be used instead of panic() when your board does not * already use printf(), * to keep code size small.
Angelo Dureghello
Vagrant Cascadian
