[U-Boot] [PATCH] DaVinci: Remove incorrect CONFIG option
The option CONFIG_SOC_DM6447 seems to have ended up in the code by mistake. It is not used anywhere and there is no chip called DM6447.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- arch/arm/cpu/arm926ejs/davinci/cpu.c | 6 ------ 1 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/cpu.c b/arch/arm/cpu/arm926ejs/davinci/cpu.c index 340c5be..8b57205 100644 --- a/arch/arm/cpu/arm926ejs/davinci/cpu.c +++ b/arch/arm/cpu/arm926ejs/davinci/cpu.c @@ -54,12 +54,6 @@ #define DDR_PLLDIV PLLC_PLLDIV2 #endif
-#ifdef CONFIG_SOC_DM6447 -#define ARM_PLLDIV PLLC_PLLDIV2 -#define DSP_PLLDIV PLLC_PLLDIV1 -#define DDR_PLLDIV PLLC_PLLDIV1 -#endif - #ifdef CONFIG_SOC_DM646X #define DSP_PLLDIV PLLC_PLLDIV1 #define ARM_PLLDIV PLLC_PLLDIV2
s-paulraj@ti.com
