[U-Boot] [PATCH] s3c64xx: move reset_cpu to soc and support the soft reset at s3c6410
This patch support the soft reset at s3c6410
Signed-off-by: Minkyu Kang mk7.kang@samsung.com --- cpu/arm1176/cpu.c | 16 ---------------- cpu/arm1176/s3c64xx/interrupts.c | 15 +++++++++++++++ include/s3c6400.h | 5 +++++ 3 files changed, 20 insertions(+), 16 deletions(-)
diff --git a/cpu/arm1176/cpu.c b/cpu/arm1176/cpu.c index 1e94f7d..fe41290 100644 --- a/cpu/arm1176/cpu.c +++ b/cpu/arm1176/cpu.c @@ -107,22 +107,6 @@ int cleanup_before_linux (void) return 0; }
- -/* * reset the cpu by setting up the watchdog timer and let him time out */ -void reset_cpu (ulong ignored) -{ - printf("reset... \n\n\n"); - SW_RST_REG = 0x6400; - /* loop forever and wait for reset to happen */ - while (1) { - if (serial_tstc()) { - serial_getc(); - break; - } - } - /*NOTREACHED*/ -} - int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { disable_interrupts (); diff --git a/cpu/arm1176/s3c64xx/interrupts.c b/cpu/arm1176/s3c64xx/interrupts.c index 83f3806..e68f3ae 100644 --- a/cpu/arm1176/s3c64xx/interrupts.c +++ b/cpu/arm1176/s3c64xx/interrupts.c @@ -175,3 +175,18 @@ void udelay(unsigned long usec) while (get_ticks() < tmp)/* loop till event */ /*NOP*/; } + +/* reset the cpu by setting up the watchdog timer and let him time out */ +void reset_cpu(ulong ignored) +{ + printf("reset... \n\n\n"); + SW_RST_REG = SW_RST_CODE; + /* loop forever and wait for reset to happen */ + while (1) { + if (serial_tstc()) { + serial_getc(); + break; + } + } + /*NOTREACHED*/ +} diff --git a/include/s3c6400.h b/include/s3c6400.h index fd3e99b..4bf5a7f 100644 --- a/include/s3c6400.h +++ b/include/s3c6400.h @@ -203,6 +203,11 @@ #define INF_REG6 (ELFIN_CLOCK_POWER_BASE + INF_REG6_OFFSET) #define INF_REG7 (ELFIN_CLOCK_POWER_BASE + INF_REG7_OFFSET)
+#if defined(CONFIG_S3C6410) +#define SW_RST_CODE 0x6410 +#else +#define SW_RST_CODE 0x6400 +#endif
/* * GPIO
- while (1) {
serial_getc();
break;
- /*NOTREACHED*/
cpu.c will be better because interrupts.c will be rename timer.c with the new timer cleanup work
- SW_RST_REG = SW_RST_CODE;
writel?
- while (1) {
serial_getc();
break;
- /*NOTREACHED*/
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Minkyu Kang
