[U-Boot] [PATCH 2/4] net: sh_eth: add SH_ETH_TYPE_ condition
At the moment, the driver supports the following CPUs: - GETHER (Gigabit Ethernet) : SH7763, SH7734 - ETHER (Fast Ethernet) : SH7724, SH7757
And the driver had the following "#if":
#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) #if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) - Those are for GETHER
#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) - This is for ETHER
So, for clean up the code, this patch adds SH_ETH_TYPE_GETHER and SH_ETH_TYPE_ETHER. And then, the patch modifies the above "#if".
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- drivers/net/sh_eth.c | 22 +++++++++------------- drivers/net/sh_eth.h | 43 +++++++++++++++++++++++-------------------- 2 files changed, 32 insertions(+), 33 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 1825059..262762d 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -1,5 +1,5 @@ /* - * sh_eth.c - Driver for Renesas SH7763's ethernet controler. + * sh_eth.c - Driver for Renesas ethernet controler. * * Copyright (C) 2008, 2011 Renesas Solutions Corp. * Copyright (c) 2008, 2011 Nobuhiro Iwamatsu @@ -138,7 +138,7 @@ int sh_eth_recv(struct eth_device *dev) static int sh_eth_reset(struct sh_eth_dev *eth) { int port = eth->port; -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) int ret = 0, i;
/* Start e-dmac transmitter and receiver */ @@ -208,7 +208,7 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) /* Point the controller to the tx descriptor list. Must use physical addresses */ outl(ADDR_TO_PHY(port_info->tx_desc_base), TDLAR(port)); -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) outl(ADDR_TO_PHY(port_info->tx_desc_base), TDFAR(port)); outl(ADDR_TO_PHY(cur_tx_desc), TDFXR(port)); outl(0x01, TDFFR(port));/* Last discriptor bit */ @@ -276,7 +276,7 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth)
/* Point the controller to the rx descriptor list */ outl(ADDR_TO_PHY(port_info->rx_desc_base), RDLAR(port)); -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) outl(ADDR_TO_PHY(port_info->rx_desc_base), RDFAR(port)); outl(ADDR_TO_PHY(cur_rx_desc), RDFXR(port)); outl(RDFFR_RDLF, RDFFR(port)); @@ -370,7 +370,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl(0, TFTR(port)); outl((FIFO_SIZE_T | FIFO_SIZE_R), FDR(port)); outl(RMCR_RST, RMCR(port)); -#if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) +#if defined(SH_ETH_TYPE_GETHER) outl(0, RPADIR(port)); #endif outl((FIFO_F_D_RFF | FIFO_F_D_RFD), FCFTR(port)); @@ -387,14 +387,10 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl(val, MALR(port));
outl(RFLR_RFL_MIN, RFLR(port)); -#if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) +#if defined(SH_ETH_TYPE_GETHER) outl(0, PIPR(port)); -#endif -#if !defined(CONFIG_CPU_SH7724) && !defined(CONFIG_CPU_SH7757) outl(APR_AP, APR(port)); outl(MPR_MP, MPR(port)); -#endif -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(TPAUSER_TPAUSE, TPAUSER(port)); #endif
@@ -415,7 +411,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) /* Set the transfer speed */ if (phy->speed == 100) { printf(SHETHER_NAME ": 100Base/"); -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) outl(GECMR_100B, GECMR(port)); #elif defined(CONFIG_CPU_SH7757) outl(1, RTRATE(port)); @@ -424,13 +420,13 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) #endif } else if (phy->speed == 10) { printf(SHETHER_NAME ": 10Base/"); -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) outl(GECMR_10B, GECMR(port)); #elif defined(CONFIG_CPU_SH7757) outl(0, RTRATE(port)); #endif } -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) else if (phy->speed == 1000) { printf(SHETHER_NAME ": 1000Base/"); outl(GECMR_1000B, GECMR(port)); diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 5276be3..401ef69 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -99,6 +99,7 @@ struct sh_eth_dev {
/* Register Address */ #ifdef CONFIG_CPU_SH7763 +#define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xfee00000
#define EDSR(port) (BASE_IO_ADDR + 0x800 * (port) + 0x0000) @@ -137,6 +138,7 @@ struct sh_eth_dev { #define MAHR(port) (BASE_IO_ADDR + 0x800 * (port) + 0x05c0)
#elif defined(CONFIG_CPU_SH7757) +#define SH_ETH_TYPE_ETHER #define BASE_IO_ADDR 0xfef00000
#define TDLAR(port) (BASE_IO_ADDR + 0x800 * (port) + 0x0018) @@ -164,6 +166,7 @@ struct sh_eth_dev { #define RTRATE(port) (BASE_IO_ADDR + 0x800 * (port) + 0x01fc)
#elif defined(CONFIG_CPU_SH7724) +#define SH_ETH_TYPE_ETHER #define BASE_IO_ADDR 0xA4600000
#define TDLAR(port) (BASE_IO_ADDR + 0x0018) @@ -190,6 +193,7 @@ struct sh_eth_dev { #define MALR(port) (BASE_IO_ADDR + 0x01c8)
#elif defined(CONFIG_CPU_SH7734) +#define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xFEE00000
#define EDSR(port) (BASE_IO_ADDR) @@ -233,7 +237,7 @@ struct sh_eth_dev { * Register's bits * Copy from Linux driver source code */ -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) /* EDSR */ enum EDSR_BIT { EDSR_ENT = 0x01, EDSR_ENR = 0x02, @@ -244,15 +248,15 @@ enum EDSR_BIT { /* EDMR */ enum DMAC_M_BIT { EDMR_DL1 = 0x20, EDMR_DL0 = 0x10, -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) EDMR_SRST = 0x03, /* Receive/Send reset */ EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ -#elif defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7724) +#elif defined(SH_ETH_TYPE_ETHER) EDMR_SRST = 0x01, EMDR_DESC_R = 0x30, /* Descriptor reserve size */ EDMR_EL = 0x40, /* Litte endian */ -#else /* CONFIG_CPU_SH7763 */ +#else EDMR_SRST = 0x01, #endif }; @@ -262,7 +266,7 @@ enum DMAC_M_BIT {
/* EDTRR */ enum DMAC_T_BIT { -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) EDTRR_TRNS = 0x03, #else EDTRR_TRNS = 0x01, @@ -302,7 +306,7 @@ enum PHY_STATUS_BIT { PHY_ST_LINK = 0x01, }; /* EESR */ enum EESR_BIT {
-#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) +#if defined(SH_ETH_TYPE_ETHER) EESR_TWB = 0x40000000, #else EESR_TWB = 0xC0000000, @@ -312,14 +316,14 @@ enum EESR_BIT { #endif EESR_TABT = 0x04000000, EESR_RABT = 0x02000000, EESR_RFRMER = 0x01000000, -#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) +#if defined(SH_ETH_TYPE_ETHER) EESR_ADE = 0x00800000, #endif EESR_ECI = 0x00400000, EESR_FTC = 0x00200000, EESR_TDE = 0x00100000, EESR_TFE = 0x00080000, EESR_FRC = 0x00040000, EESR_RDE = 0x00020000, EESR_RFE = 0x00010000, -#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) +#if defined(SH_ETH_TYPE_ETHER) EESR_CND = 0x00000800, #endif EESR_DLC = 0x00000400, @@ -331,7 +335,7 @@ enum EESR_BIT { };
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) # define TX_CHECK (EESR_TC1 | EESR_FTC) # define EESR_ERR_CHECK (EESR_TWB | EESR_TABT | EESR_RABT | EESR_RDE \ | EESR_RFRMER | EESR_TFE | EESR_TDE | EESR_ECI) @@ -391,8 +395,7 @@ enum FCFTR_BIT {
/* Transfer descriptor bit */ enum TD_STS_BIT { -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7757) \ - || defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) || defined(SH_ETH_TYPE_ETHER) TD_TACT = 0x80000000, #else TD_TACT = 0x7fffffff, @@ -408,7 +411,7 @@ enum TD_STS_BIT { enum RECV_RST_BIT { RMCR_RST = 0x01, }; /* ECMR */ enum FELIC_MODE_BIT { -#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) ECMR_TRCCM=0x04000000, ECMR_RCSC= 0x00800000, ECMR_DPAD= 0x00200000, ECMR_RZPF = 0x00100000, #endif @@ -423,10 +426,10 @@ enum FELIC_MODE_BIT {
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) #define ECMR_CHG_DM (ECMR_TRCCM | ECMR_RZPF | ECMR_ZPF | ECMR_PFR | ECMR_RXF | \ ECMR_TXF | ECMR_MCT) -#elif CONFIG_CPU_SH7724 || CONFIG_CPU_SH7757 +#elif defined(SH_ETH_TYPE_ETHER) #define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF) #else #define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF | ECMR_MCT) @@ -434,14 +437,14 @@ enum FELIC_MODE_BIT {
/* ECSR */ enum ECSR_STATUS_BIT { -#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) +#if defined(SH_ETH_TYPE_ETHER) ECSR_BRCRX = 0x20, ECSR_PSRTO = 0x10, #endif ECSR_LCHNG = 0x04, ECSR_MPD = 0x02, ECSR_ICD = 0x01, };
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) # define ECSR_INIT (ECSR_ICD | ECSIPR_MPDIP) #else # define ECSR_INIT (ECSR_BRCRX | ECSR_PSRTO | \ @@ -450,10 +453,10 @@ enum ECSR_STATUS_BIT {
/* ECSIPR */ enum ECSIPR_STATUS_MASK_BIT { -#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) +#if defined(SH_ETH_TYPE_ETHER) ECSIPR_BRCRXIP = 0x20, ECSIPR_PSRTOIP = 0x10, -#elif defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#elif defined(SH_ETY_TYPE_GETHER) ECSIPR_PSRTOIP = 0x10, ECSIPR_PHYIP = 0x08, #endif @@ -462,7 +465,7 @@ enum ECSIPR_STATUS_MASK_BIT { ECSIPR_ICDIP = 0x01, };
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) # define ECSIPR_INIT (ECSIPR_LCHNGIP | ECSIPR_ICDIP | ECSIPR_MPDIP) #else # define ECSIPR_INIT (ECSIPR_BRCRXIP | ECSIPR_PSRTOIP | ECSIPR_LCHNGIP | \ @@ -493,7 +496,7 @@ enum RPADIR_BIT { RPADIR_PADR = 0x0003f, };
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) # define RPADIR_INIT (0x00) #else # define RPADIR_INIT (RPADIR_PADS1)
Tested-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Acked-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
2012/6/27 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
- sh_eth.c - Driver for Renesas SH7763's ethernet controler.
- sh_eth.c - Driver for Renesas ethernet controler.
-#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) +#if defined(SH_ETH_TYPE_GETHER) # define RPADIR_INIT (0x00) #else # define RPADIR_INIT (RPADIR_PADS1) -- 1.7.1
Hi Yoshihiro,
On Tue, Jun 26, 2012 at 9:38 PM, Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com wrote:
- This is for ETHER
Applied to next, thanks.
-Joe
Joe Hershberger
Nobuhiro Iwamatsu
Shimoda, Yoshihiro
