[U-Boot-Users] Query about U-Boot NAND ENV section
I am using U-Boot 1.2.0 release of U-Boot and working on ARM1176 platform. I have ported U-Boot for my platform, which boots from NAND Flash, save ENV variable onto NAND Flash. Almost everything works fine for me till now. But today I came across one issue -
When I set baudrate to different value from U-Boot prompt, and do a "saveenv", and after that if I reboot the system it should boot with new baudrate set. Ideally it should take new baudrate, but it always configures default baudrate.
I tried to dig into this issue, and found that, U-Boot for NAND Flash is designed the same way. The function "nand_init" gets invoked after "env_init" and "serial_init", and sue to this U-Boot always uses the default baudrate.
Do I understand it correctly? Is there any way to resolve this issue?
Thanks,
Vaibhav
In message 91C99CB54D033E469E6D6702BAE5744701CEF3F7@dbde01.ent.ti.com you wrote:
Thjis is a dilemma - U-Boot tries to support porting and debugging by enabling the serial console very, very early, typically long before relocation to RAM. In this state, we have only a verly limited environment - small stack, no writable data segment, no BSS, etc. This is not sufficient for the (pretty complicated) NAND flash driver. So U-Boot cannot read the baudrate setting from the environment in NAND...
Hiremath, Vaibhav
