Re: Increasing stabilization time in sunxi_mmc_core_init
On 21/07/2022 12:03, Da Xue wrote:
Hi Da,
Users were reporting non-boot on our H5 boards (ALL-H3-CC-H5). u-boot gets stuck in SPL with this message for SD/eMMC respectively.
Trying to boot from MMC1 or Trying to boot from MMC2
I tested about 20 MicroSD cards from different brands and some were happy and some were not. Increasing the udelay to 8-10ms in drivers/mmc/sunxi_mmc.c sunxi_mmc_core_init after reset seems to fix the issue for the MicroSD cards.
That's interesting, thanks for the report. I don't remember hearing of issues with MMC before, at least not in the SPL. It's a bit odd that waiting after the *controller* reset should affect SD cards, and 1ms seems plenty for just the reset. I just checked and at least the SOFT_RESET and FIFO_RESET bits are self clearing. Can you try to use wait_for_bit_le32() to wait for those parts to finish? See sun8i_emac_eth_start() for an example.
And since you mentioned it's card related: can you check whether the delay is actually needed somewhere else, later? At some point where we wait to the card to response, for instance?
I am not against taking this patch, if it fixes problems for you, but just want to avoid that it papers over other issues.
Cheers, Andre
Author: Da Xue da@libre.computer Date: Wed Jul 20 19:11:55 2022 -0400
sunxi: raise stabilization time for mmc from 1ms to 8ms
diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c index 1bb7b6d0e9..499e057725 100644 --- a/drivers/mmc/sunxi_mmc.c +++ b/drivers/mmc/sunxi_mmc.c @@ -297,7 +297,7 @@ static int sunxi_mmc_core_init(struct mmc *mmc)
/* Reset controller */ writel(SUNXI_MMC_GCTRL_RESET, &priv->reg->gctrl);
udelay(1000);
udelay(8000); return 0;
I don't know the implications of this change so I am seeking feedback. Are other boards having this issue as well or is it specific to our hardware?
Best, Da
Hi!
Dne četrtek, 21. julij 2022 ob 13:28:59 CEST je Andre Przywara napisal(a):
Hi Da,
I certainly experienced this issue on board in question. I vaguely remember asking about this issue on IRC. I also tried all sorts of tweaks, but it never occured to me that mmc reset timeout would be too short.
Da, how did you find this?
I only test one other H5 board occasionally, namely OrangePi PC2, but I never observed such issue there. I always needed about 5 attempts to boot ALL-H3-CC- H5 board, but once it's cold booted, warm boots always succeed.
Best regards, Jernej
Cheers, Andre
udelay(1000);
Best, Da
On Thu, Jul 21, 2022 at 11:14 AM Jernej Škrabec jernej.skrabec@gmail.com wrote:
Hi!
Hi Da,
Someone on the Armbian forum posted that they had the same problem with eMMC so I got suspicious. I scoped the MicroSD clock line and realized the frequency goes high and then drops to very low as if it never found the card. I had a hunch it was a stabilization delay and got lucky.
I had run into this too so it didn't make any sense. I tried 5ms and it helped on some cards but not others. I know the Orange Pis do not have the series resistor for ESD protection of the SD GPIOs but that shouldn't affect this. So...who knows?
I tested some more and here's the data: sandisk ultra 64gb 9/20 with 1ms, 20/20 with 10ms sandisk ultra 16gb 2/20 with 1ms, 20/20 with 10ms sandisk extreme 16gb 6/20 with 10ms, 20/20 with 20ms Given this, I don't think it's an issue with the bit set delays. Might need more than 10ms even. I didn't change the udelay in probe.
Cheers, Andre
udelay(1000);
udelay(8000);
This might need to be even higher. Like 20ms.
Best, Da
Dne četrtek, 21. julij 2022 ob 21:56:35 CEST je Da Xue napisal(a):
Hi!
Hi Da,
Idea here is that we wouldn't need to determine the appropriate delay, but instead, wait_for_bit_le32() would monitor reset bit and continue only after reset bit would clear itself. Hopefully that happens after everything is stable.
Cheers, Andre
udelay(1000);
udelay(8000);
Best, Da
On Thu, Jul 21, 2022 at 4:05 PM Jernej Škrabec jernej.skrabec@gmail.com wrote:
Hi!
Hi Da,
I changed it to 50ms delay
writel(SUNXI_MMC_GCTRL_RESET, &priv->reg->gctrl); if (wait_for_bit_le32( &priv->reg->gctrl, SUNXI_MMC_GCTRL_RESET, false, 50, false)) { printf("%s: Timeout\n", __func__); return ret; }
and that seems to work. Shall I send the patch?
Cheers, Andre
udelay(1000);
udelay(8000);
Best, Da
Dne četrtek, 21. julij 2022 ob 22:33:09 CEST je Da Xue napisal(a):
Hi!
napisal(a):
Hi Da,
Certainly, that's major improvement. Just 1 small nitpick - you don't need to introduce ret variable, just return error -ETIMEDOUT directly.
Maybe timeout can be raised even to 100 ms, now that it continues as soon as possible. Better to be on the completely safe side. But I'll leave that decision to you and Andre.
Cheers, Andre
udelay(1000);
udelay(8000);
Best, Da
On Thu, Jul 21, 2022 at 4:49 PM Jernej Škrabec jernej.skrabec@gmail.com wrote:
Hi!
napisal(a):
Hi Da,
> Users were reporting non-boot on our H5 boards (ALL-H3-CC-H5). > u-boot > gets stuck in SPL with this message for SD/eMMC respectively. > > Trying to boot from MMC1 or Trying to boot from MMC2 > > I tested about 20 MicroSD cards from different brands and some > were > happy and some were not. Increasing the udelay to 8-10ms in > drivers/mmc/sunxi_mmc.c sunxi_mmc_core_init after reset seems to > fix > the issue for the MicroSD cards.
OK
I'll retest everything and check about changing the probe reset as well. If everything works, I'll submit the patch.
Cheers, Andre
> Author: Da Xue da@libre.computer > Date: Wed Jul 20 19:11:55 2022 -0400 > > sunxi: raise stabilization time for mmc from 1ms to 8ms > > diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c > index 1bb7b6d0e9..499e057725 100644 > --- a/drivers/mmc/sunxi_mmc.c > +++ b/drivers/mmc/sunxi_mmc.c > @@ -297,7 +297,7 @@ static int sunxi_mmc_core_init(struct mmc > *mmc) > > /* Reset controller */ > writel(SUNXI_MMC_GCTRL_RESET, &priv->reg->gctrl); > > - udelay(1000); > + udelay(8000);
> return 0; > > } > > I don't know the implications of this change so I am seeking > feedback. > Are other boards having this issue as well or is it specific to > our > hardware? > > Best, > Da
Hi!
napisal(a):
> On 21/07/2022 12:03, Da Xue wrote: > > Hi Da, > > > Users were reporting non-boot on our H5 boards (ALL-H3-CC-H5). > > u-boot > > gets stuck in SPL with this message for SD/eMMC respectively. > > > > Trying to boot from MMC1 or Trying to boot from MMC2 > > > > I tested about 20 MicroSD cards from different brands and some > > were > > happy and some were not. Increasing the udelay to 8-10ms in > > drivers/mmc/sunxi_mmc.c sunxi_mmc_core_init after reset seems to > > fix > > the issue for the MicroSD cards. > > That's interesting, thanks for the report. I don't remember hearing > of > issues with MMC before, at least not in the SPL.
> It's a bit odd that waiting after the *controller* reset should > affect > SD cards, and 1ms seems plenty for just the reset. > I just checked and at least the SOFT_RESET and FIFO_RESET bits are > self > clearing. Can you try to use wait_for_bit_le32() to wait for those > parts > to finish? See sun8i_emac_eth_start() for an example.
After more extensive testing with 5 MicroSD cards, 2 of them are still inconsistent with waiting for SOFT_RESET and FIFO_RESET vs a hard 20ms delay. I even tried putting a delay of 1ms after they cleared to no avail. I'm curious how larger 1TB MicroSD cards behave now but I don't have any samples.
OK
> And since you mentioned it's card related: can you check whether the > delay is actually needed somewhere else, later? At some point where > we > wait to the card to response, for instance? > > I am not against taking this patch, if it fixes problems for you, > but > just want to avoid that it papers over other issues. > > Cheers, > Andre > > > Author: Da Xue da@libre.computer > > Date: Wed Jul 20 19:11:55 2022 -0400 > > > > sunxi: raise stabilization time for mmc from 1ms to 8ms > > > > diff --git a/drivers/mmc/sunxi_mmc.c b/drivers/mmc/sunxi_mmc.c > > index 1bb7b6d0e9..499e057725 100644 > > --- a/drivers/mmc/sunxi_mmc.c > > +++ b/drivers/mmc/sunxi_mmc.c > > @@ -297,7 +297,7 @@ static int sunxi_mmc_core_init(struct mmc > > *mmc) > > > > /* Reset controller */ > > writel(SUNXI_MMC_GCTRL_RESET, &priv->reg->gctrl); > > > > - udelay(1000); > > + udelay(8000);
> > return 0; > > > > } > > > > I don't know the implications of this change so I am seeking > > feedback. > > Are other boards having this issue as well or is it specific to > > our > > hardware? > > > > Best, > > Da
Dne četrtek, 21. julij 2022 ob 23:23:28 CEST je Da Xue napisal(a):
jernej.skrabec@gmail.com wrote: > Hi! > > Dne četrtek, 21. julij 2022 ob 13:28:59 CEST je Andre Przywara
napisal(a):
> > On 21/07/2022 12:03, Da Xue wrote: > > > > Hi Da, > > > > > Users were reporting non-boot on our H5 boards > > > (ALL-H3-CC-H5). > > > u-boot > > > gets stuck in SPL with this message for SD/eMMC > > > respectively. > > > > > > Trying to boot from MMC1 or Trying to boot from MMC2 > > > > > > I tested about 20 MicroSD cards from different brands and > > > some > > > were > > > happy and some were not. Increasing the udelay to 8-10ms in > > > drivers/mmc/sunxi_mmc.c sunxi_mmc_core_init after reset > > > seems to > > > fix > > > the issue for the MicroSD cards. > > > > That's interesting, thanks for the report. I don't remember > > hearing > > of > > issues with MMC before, at least not in the SPL. > > I certainly experienced this issue on board in question. I > vaguely > remember > asking about this issue on IRC. I also tried all sorts of > tweaks, but > it > never occured to me that mmc reset timeout would be too short. > > Da, how did you find this?
> I only test one other H5 board occasionally, namely OrangePi > PC2, but > I > never observed such issue there. I always needed about 5 > attempts to > boot > ALL-H3-CC- H5 board, but once it's cold booted, warm boots > always > succeed.
> Best regards, > Jernej > > > It's a bit odd that waiting after the *controller* reset > > should > > affect > > SD cards, and 1ms seems plenty for just the reset. > > I just checked and at least the SOFT_RESET and FIFO_RESET bits > > are > > self > > clearing. Can you try to use wait_for_bit_le32() to wait for > > those > > parts > > to finish? See sun8i_emac_eth_start() for an example.
Fixed delay it is, then. Just add a comment with explanation why. People looking for boot time optimization might lower it.
OK
> > And since you mentioned it's card related: can you check > > whether the > > delay is actually needed somewhere else, later? At some point > > where > > we > > wait to the card to response, for instance? > > > > I am not against taking this patch, if it fixes problems for > > you, > > but > > just want to avoid that it papers over other issues. > > > > Cheers, > > Andre > > > > > Author: Da Xue da@libre.computer > > > Date: Wed Jul 20 19:11:55 2022 -0400 > > > > > > sunxi: raise stabilization time for mmc from 1ms to 8ms > > > > > > diff --git a/drivers/mmc/sunxi_mmc.c > > > b/drivers/mmc/sunxi_mmc.c > > > index 1bb7b6d0e9..499e057725 100644 > > > --- a/drivers/mmc/sunxi_mmc.c > > > +++ b/drivers/mmc/sunxi_mmc.c > > > @@ -297,7 +297,7 @@ static int sunxi_mmc_core_init(struct > > > mmc > > > *mmc) > > > > > > /* Reset controller */ > > > writel(SUNXI_MMC_GCTRL_RESET, &priv->reg->gctrl); > > > > > > - udelay(1000); > > > + udelay(8000);
> > > return 0; > > > > > > } > > > > > > I don't know the implications of this change so I am seeking > > > feedback. > > > Are other boards having this issue as well or is it specific > > > to > > > our > > > hardware? > > > > > > Best, > > > Da
Andre Przywara
Da Xue
Jernej Škrabec
