[U-Boot] [PATCH] common: Use command_ret_t enum values instead of values
Use enum command_ret_t types in cmd_process_error(). Also handle USAGE failure separately.
common/command.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/command.c b/common/command.c index 52d47c133c3c..2433a89e0a8e 100644 --- a/common/command.c +++ b/common/command.c @@ -547,10 +547,13 @@ enum command_ret_t cmd_process(int flag, int argc, char * const argv[],
int cmd_process_error(cmd_tbl_t *cmdtp, int err) { + if (err == CMD_RET_USAGE) + return CMD_RET_USAGE; + if (err) { printf("Command '%s' failed: Error %d\n", cmdtp->name, err); - return 1; + return CMD_RET_FAILURE; }
- return 0; + return CMD_RET_SUCCESS; }
- if (err == CMD_RET_USAGE)
This changes the return value of the function (-1 instead of 1). So you would have to change the comments in include/command.h.
Your commit message gives no clue why you do not want to return CMD_RET_FAILURE here and which consequences this has especially in scripts.
Best regards
Heinrich
- if (err) { printf("Command '%s' failed: Error %d\n", cmdtp->name, err);
return 1;
}return CMD_RET_FAILURE;
- return CMD_RET_SUCCESS;
thanks for pointer.
I will improve commit message in v2.
CMD_RET_USAGE is one of 3 return values which should be handled.
These commands are affected by this change. cmd/demo.c cmd/efi.c cmd/gpio.c cmd/qfw.c cmd/x86/fsp.c test/dm/cmd_dm.c
And scripts shouldn't be affected because return value is not 0. But every command implementation can choose what it is correct to pass. I would expect that RET_USAGE is called when parameters are not correctly passed (have incorrect value, missing parameters) and RET_FAILURE when correct parameters are passed but command fails.
Thanks, Michal
Michal Simek
