[PATCH] Kconfig/fpga_zynq: Depend on FPGA
The zynq FPGA bits require the main FPGA bits to be enabled as we otherwise get the following compiler error:
arch/arm/mach-zynq/cpu.c: In function 'arch_early_init_r': arch/arm/mach-zynq/cpu.c:118:37: error: 'const struct <anonymous>' has no member named 'fpga_size' fpga.size = zynq_fpga_descs[cpu_id].fpga_size; ^
Signed-off-by: Olliver Schinagl oliver@schinagl.nl --- drivers/fpga/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index fe398a1d49..1d2df617d0 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -81,6 +81,7 @@ config FPGA_VIRTEX2 config FPGA_ZYNQPL bool "Enable Xilinx FPGA for Zynq" depends on ARCH_ZYNQ + select FPGA help Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq devices.
Olliver Schinagl
