[U-Boot] [PATCH v2 1/6] zynqmp: Add support for emulation platform - Veloce
Add support for Veloce - zynqmp emulation platform. Platform doesn't support SDHCI.
Changes in v2: None
arch/arm/cpu/armv8/zynqmp/clk.c | 3 +++ arch/arm/cpu/armv8/zynqmp/cpu.c | 2 ++ arch/arm/include/asm/arch-zynqmp/hardware.h | 1 + board/xilinx/zynqmp/zynqmp.c | 8 ++++++-- 4 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/zynqmp/clk.c b/arch/arm/cpu/armv8/zynqmp/clk.c index 0af619d92fde..9147fa749507 100644 --- a/arch/arm/cpu/armv8/zynqmp/clk.c +++ b/arch/arm/cpu/armv8/zynqmp/clk.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h>
@@ -16,6 +17,8 @@ unsigned long get_uart_clk(int dev_id) u32 ver = zynqmp_get_silicon_version();
switch (ver) { + case ZYNQMP_CSU_VERSION_VELOCE: + return 96000; case ZYNQMP_CSU_VERSION_EP108: return 25000000; } diff --git a/arch/arm/cpu/armv8/zynqmp/cpu.c b/arch/arm/cpu/armv8/zynqmp/cpu.c index 11958fea6f11..60d7d20e17c8 100644 --- a/arch/arm/cpu/armv8/zynqmp/cpu.c +++ b/arch/arm/cpu/armv8/zynqmp/cpu.c @@ -20,6 +20,8 @@ unsigned int zynqmp_get_silicon_version(void) gd->cpu_clk = get_tbclk();
switch (gd->cpu_clk) { + case 0 ... 1000000: + return ZYNQMP_CSU_VERSION_VELOCE; case 50000000: return ZYNQMP_CSU_VERSION_QEMU; } diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 3df3147fc4c3..188b5c2144af 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -84,6 +84,7 @@ struct apu_regs { /* Board version value */ #define ZYNQMP_CSU_VERSION_SILICON 0x0 #define ZYNQMP_CSU_VERSION_EP108 0x1 +#define ZYNQMP_CSU_VERSION_VELOCE 0x2 #define ZYNQMP_CSU_VERSION_QEMU 0x3
#endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 1325bca5e552..e38948426d70 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -56,14 +56,18 @@ int board_mmc_init(bd_t *bd) { int ret = 0;
+ u32 ver = zynqmp_get_silicon_version(); + + if (ver != ZYNQMP_CSU_VERSION_VELOCE) { #if defined(CONFIG_ZYNQ_SDHCI) # if defined(CONFIG_ZYNQ_SDHCI0) - ret = zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR0); + ret = zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR0); # endif # if defined(CONFIG_ZYNQ_SDHCI1) - ret |= zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR1); + ret |= zynq_sdhci_init(ZYNQ_SDHCI_BASEADDR1); # endif #endif + }
return ret; }
Add support for EMMC bootmode.
Changes in v2: None
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 ++- board/xilinx/zynqmp/zynqmp.c | 1 + 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 188b5c2144af..87792c21a5d0 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -45,7 +45,8 @@ struct iou_scntr {
/* Bootmode setting values */ #define BOOT_MODES_MASK 0x0000000F -#define SD_MODE 0x00000005 +#define SD_MODE 0x00000003 +#define EMMC_MODE 0x00000006 #define JTAG_MODE 0x00000000
#define ZYNQMP_RPU_BASEADDR 0xFF9A0000 diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index e38948426d70..f5ff64d988e5 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -83,6 +83,7 @@ int board_late_init(void)
switch (bootmode) { case SD_MODE: + case EMMC_MODE: setenv("modeboot", "sdboot"); break; default:
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
Enable the i2c driver for ZynqMP Also enable the eeprom for read and writes to eeprom on ZynqMP ZynqMP uses the same i2c controller as in Zynq
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: None
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 +++ include/configs/xilinx_zynqmp.h | 23 +++++++++++++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 87792c21a5d0..1fedb1bb4b94 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -11,6 +11,9 @@ #define ZYNQ_SERIAL_BASEADDR0 0xFF000000 #define ZYNQ_SERIAL_BASEADDR1 0xFF001000
+#define ZYNQ_I2C_BASEADDR0 0xFF020000 +#define ZYNQ_I2C_BASEADDR1 0xFF030000 + #define ZYNQ_SDHCI_BASEADDR0 0xFF160000 #define ZYNQ_SDHCI_BASEADDR1 0xFF170000
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index d0ec3c066f33..54bca6d47b72 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -119,6 +119,29 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_MAXARGS 64
+#define CONFIG_ZYNQ_I2C0 +#define CONFIG_SYS_I2C_ZYNQ + +/* I2C */ +#if defined(CONFIG_SYS_I2C_ZYNQ) +# define CONFIG_CMD_I2C +# define CONFIG_SYS_I2C +# define CONFIG_SYS_I2C_ZYNQ_SPEED 100000 +# define CONFIG_SYS_I2C_ZYNQ_SLAVE 0 +#endif + +#define CONFIG_ZYNQMP_EEPROM + +/* EEPROM */ +#ifdef CONFIG_ZYNQMP_EEPROM +# define CONFIG_CMD_EEPROM +# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +# define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 +# define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 +# define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +# define CONFIG_SYS_EEPROM_SIZE (64 * 1024) +#endif + #define CONFIG_FIT #define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */
Added the SPI driver support for ZynqMP The controller is same as zynq SPI controller
Changes in v2: - Remove CMD_SPI from header based on Jagan's comment
arch/arm/include/asm/arch-zynqmp/hardware.h | 3 +++ include/configs/xilinx_zynqmp.h | 7 +++++++ 2 files changed, 10 insertions(+)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 1fedb1bb4b94..c9dc49d78317 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -11,6 +11,9 @@ #define ZYNQ_SERIAL_BASEADDR0 0xFF000000 #define ZYNQ_SERIAL_BASEADDR1 0xFF001000
+#define ZYNQ_SPI_BASEADDR0 0xFF040000 +#define ZYNQ_SPI_BASEADDR1 0xFF050000 + #define ZYNQ_I2C_BASEADDR0 0xFF020000 #define ZYNQ_I2C_BASEADDR1 0xFF030000
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 54bca6d47b72..1d8eaa76dfe7 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -71,6 +71,13 @@ #define CONFIG_CMD_ELF #define CONFIG_MP
+/* SPI */ +#ifdef CONFIG_ZYNQ_SPI +# define CONFIG_SPI_FLASH +# define CONFIG_SPI_FLASH_SST +# define CONFIG_CMD_SF +#endif + #if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_MMC # define CONFIG_GENERIC_MMC
Changes in v2:
2.3.5
Applied u-boot-spi/master
thanks!
Changes in v2:
2.3.5
Unable to apply, have dependency with series.
Reviewed-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
Push this along with the series.
thanks!
Provide an option to write filesystem independend commands.
Changes in v2: None
include/configs/xilinx_zynqmp.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 1d8eaa76dfe7..45282ed445e5 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -66,6 +66,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MEMORY #define CONFIG_DOS_PARTITION #define CONFIG_CMD_ELF @@ -99,8 +100,8 @@ "kernel_addr=0x80000\0" \ "fdt_addr=0x7000000\0" \ "fdt_high=0x10000000\0" \ - "sdboot=mmcinfo && fatload mmc 0:0 $fdt_addr system.dtb && " \ - "fatload mmc 0:0 $kernel_addr Image && booti $kernel_addr - $fdt_addr\0" + "sdboot=mmcinfo && load mmc 0:0 $fdt_addr system.dtb && " \ + "load mmc 0:0 $kernel_addr Image && booti $kernel_addr - $fdt_addr\0"
#define CONFIG_BOOTARGS "setenv bootargs console=ttyPS0,${baudrate} " \ "earlycon=cdns,mmio,0xff000000,${baudrate}n8"
Enable SDHCI0 for zynqmp. Add empty gpio.h because of sdhci requirement.
Changes in v2: None
There will be gpio driver anyway that's why it should be fine to add empty file.
--- arch/arm/include/asm/arch-zynqmp/gpio.h | 12 ++++++++++++ include/configs/xilinx_zynqmp.h | 2 ++ 2 files changed, 14 insertions(+) create mode 100644 arch/arm/include/asm/arch-zynqmp/gpio.h
diff --git a/arch/arm/include/asm/arch-zynqmp/gpio.h b/arch/arm/include/asm/arch-zynqmp/gpio.h new file mode 100644 index 000000000000..098bbde06f30 --- /dev/null +++ b/arch/arm/include/asm/arch-zynqmp/gpio.h @@ -0,0 +1,12 @@ +/* + * Copyright 2015 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_ZYNQMP_GPIO_H +#define __ARCH_ZYNQMP_GPIO_H + +/* Empty file - sdhci requires this. */ + +#endif diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 45282ed445e5..880d29ca7157 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -61,6 +61,8 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ { 4800, 9600, 19200, 38400, 57600, 115200 }
+#define CONFIG_ZYNQ_SDHCI0 + /* Command line configuration */ #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2
Jagan Teki
Michal Simek
