[U-Boot] [PATCH] Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE references
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- doc/README.PIP405 | 8 -------- include/configs/APC405.h | 1 - include/configs/ASH405.h | 1 - include/configs/B2.h | 1 - include/configs/CATcenter.h | 1 - include/configs/CMS700.h | 1 - include/configs/CPCI2DP.h | 1 - include/configs/CPCI405.h | 1 - include/configs/CPCI4052.h | 1 - include/configs/CPCI405AB.h | 1 - include/configs/CPCI405DT.h | 1 - include/configs/CPCIISER4.h | 1 - include/configs/DP405.h | 1 - include/configs/DU405.h | 1 - include/configs/DU440.h | 1 - include/configs/G2000.h | 1 - include/configs/HH405.h | 1 - include/configs/HUB405.h | 1 - include/configs/MIP405.h | 1 - include/configs/MPC8323ERDB.h | 1 - include/configs/OCRTC.h | 1 - include/configs/ORSG.h | 1 - include/configs/PCI405.h | 1 - include/configs/PIP405.h | 1 - include/configs/PLU405.h | 1 - include/configs/PMC405.h | 1 - include/configs/PMC440.h | 1 - include/configs/PPChameleonEVB.h | 1 - include/configs/TASREG.h | 1 - include/configs/TQM8272.h | 1 - include/configs/TQM834x.h | 1 - include/configs/TQM85xx.h | 1 - include/configs/VOH405.h | 1 - include/configs/VOM405.h | 1 - include/configs/W7OLMC.h | 1 - include/configs/W7OLMG.h | 1 - include/configs/WUH405.h | 1 - include/configs/XPEDITE1K.h | 1 - include/configs/acadia.h | 1 - include/configs/alpr.h | 1 - include/configs/bamboo.h | 1 - include/configs/canyonlands.h | 1 - include/configs/ebony.h | 1 - include/configs/ep82xxm.h | 1 - include/configs/hcu4.h | 1 - include/configs/hcu5.h | 1 - include/configs/hymod.h | 1 - include/configs/katmai.h | 1 - include/configs/luan.h | 1 - include/configs/lwmon5.h | 1 - include/configs/mcu25.h | 1 - include/configs/motionpro.h | 1 - include/configs/muas3001.h | 1 - include/configs/mucmc52.h | 2 -- include/configs/ocotea.h | 1 - include/configs/p3p440.h | 1 - include/configs/pcs440ep.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/stxssa.h | 1 - include/configs/taishan.h | 1 - include/configs/uc101.h | 2 -- include/configs/walnut.h | 1 - include/configs/yosemite.h | 1 - include/configs/zeus.h | 1 - 65 files changed, 0 insertions(+), 74 deletions(-)
diff --git a/doc/README.PIP405 b/doc/README.PIP405 index 610ff21..07756a5 100644 --- a/doc/README.PIP405 +++ b/doc/README.PIP405 @@ -132,14 +132,6 @@ Identify: --------- CONFIG_IDENT_STRING added to the U_BOOT_VERSION String
- -I2C stuff: ----------- -CFG_EEPROM_PAGE_WRITE_ENABLE enables page write of the I2C EEPROM - CFG_EEPROM_PAGE_WRITE_BITS _must_ be - defined. - - Environment / Console: ----------------------
diff --git a/include/configs/APC405.h b/include/configs/APC405.h index 6ee0a36..cd2b79d 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -315,7 +315,6 @@ extern int flash_banks; /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * External Bus Controller (EBC) Setup diff --git a/include/configs/ASH405.h b/include/configs/ASH405.h index 85c6a99..6cd0620 100644 --- a/include/configs/ASH405.h +++ b/include/configs/ASH405.h @@ -256,7 +256,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/B2.h b/include/configs/B2.h index d6ab1ad..8afd08d 100644 --- a/include/configs/B2.h +++ b/include/configs/B2.h @@ -194,7 +194,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* Flash banks JFFS2 should use */ /* diff --git a/include/configs/CATcenter.h b/include/configs/CATcenter.h index 1603c9c..b67fe06 100644 --- a/include/configs/CATcenter.h +++ b/include/configs/CATcenter.h @@ -419,7 +419,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/CMS700.h b/include/configs/CMS700.h index 285cd5c..8da23e6 100644 --- a/include/configs/CMS700.h +++ b/include/configs/CMS700.h @@ -268,7 +268,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#define CFG_EEPROM_WREN 1
diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 58900c3..9770e0b 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -219,7 +219,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
diff --git a/include/configs/CPCI405.h b/include/configs/CPCI405.h index bd43e1d..91dd902 100644 --- a/include/configs/CPCI405.h +++ b/include/configs/CPCI405.h @@ -264,7 +264,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 9ec1721..66e480d 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -283,7 +283,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/CPCI405AB.h b/include/configs/CPCI405AB.h index 7899598..035cc1d 100644 --- a/include/configs/CPCI405AB.h +++ b/include/configs/CPCI405AB.h @@ -259,7 +259,6 @@ /* 32 byte page write mode using*/ /* last 5 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* Use EEPROM for environment variables */
diff --git a/include/configs/CPCI405DT.h b/include/configs/CPCI405DT.h index c173539..52830ff 100644 --- a/include/configs/CPCI405DT.h +++ b/include/configs/CPCI405DT.h @@ -286,7 +286,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/CPCIISER4.h b/include/configs/CPCIISER4.h index 78b754c..8d30ab6 100644 --- a/include/configs/CPCIISER4.h +++ b/include/configs/CPCIISER4.h @@ -198,7 +198,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ #define CFG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ diff --git a/include/configs/DP405.h b/include/configs/DP405.h index 912fb2a..0043453 100644 --- a/include/configs/DP405.h +++ b/include/configs/DP405.h @@ -239,7 +239,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/DU405.h b/include/configs/DU405.h index c8bf67f..1037532 100644 --- a/include/configs/DU405.h +++ b/include/configs/DU405.h @@ -225,7 +225,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ #define CFG_ENV_OFFSET 0x000 /* environment starts at the beginning of the EEPROM */ diff --git a/include/configs/DU440.h b/include/configs/DU440.h index c757523..07527e4 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -183,7 +183,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR 0x54 #define CFG_I2C_EEPROM_ADDR_LEN 2 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 5 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 diff --git a/include/configs/G2000.h b/include/configs/G2000.h index c12ce48..2f48df5 100644 --- a/include/configs/G2000.h +++ b/include/configs/G2000.h @@ -328,7 +328,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/HH405.h b/include/configs/HH405.h index 9bcbfe3..a452819 100644 --- a/include/configs/HH405.h +++ b/include/configs/HH405.h @@ -360,7 +360,6 @@ /* last 5 bits of the address */ #endif #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/HUB405.h b/include/configs/HUB405.h index a389d58..49cf52d 100644 --- a/include/configs/HUB405.h +++ b/include/configs/HUB405.h @@ -255,7 +255,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 66235e3..c86e318 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -110,7 +110,6 @@ #define CFG_EEPROM_PAGE_WRITE_BITS 6 /* The Atmel 24C128/256 has */ /* 64 byte page write mode using*/ /* last 6 bits of the address */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE /* enable Page write */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 94b3d5a..37c5760 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -327,7 +327,6 @@ #define CFG_I2C_EEPROM_ADDR_LEN 2 #define CFG_EEPROM_PAGE_WRITE_BITS 6 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * General PCI diff --git a/include/configs/OCRTC.h b/include/configs/OCRTC.h index 94b5bc9..5a3ef5a 100644 --- a/include/configs/OCRTC.h +++ b/include/configs/OCRTC.h @@ -220,7 +220,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/ORSG.h b/include/configs/ORSG.h index 4e03088..a14fc09 100644 --- a/include/configs/ORSG.h +++ b/include/configs/ORSG.h @@ -218,7 +218,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/PCI405.h b/include/configs/PCI405.h index e70c0d3..2404b1a 100644 --- a/include/configs/PCI405.h +++ b/include/configs/PCI405.h @@ -249,7 +249,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 86ea6c6..2f5ae5a 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -103,7 +103,6 @@ #define CFG_EEPROM_PAGE_WRITE_BITS 6 /* The Atmel 24C128/256 has */ /* 64 byte page write mode using*/ /* last 6 bits of the address */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE /* enable Page write */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 38c495e..8cc0047 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -295,7 +295,6 @@ /* 16 byte page write mode using */ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * External Bus Controller (EBC) Setup diff --git a/include/configs/PMC405.h b/include/configs/PMC405.h index 966bbf9..656371e 100644 --- a/include/configs/PMC405.h +++ b/include/configs/PMC405.h @@ -267,7 +267,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 9140287..6c1af83 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -233,7 +233,6 @@
#define CFG_I2C_EEPROM_ADDR 0x54 #define CFG_I2C_EEPROM_ADDR_LEN 2 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 5 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x01 diff --git a/include/configs/PPChameleonEVB.h b/include/configs/PPChameleonEVB.h index cf98324..d4aa6e9 100644 --- a/include/configs/PPChameleonEVB.h +++ b/include/configs/PPChameleonEVB.h @@ -452,7 +452,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/TASREG.h b/include/configs/TASREG.h index dccdf0c..de21f2e 100644 --- a/include/configs/TASREG.h +++ b/include/configs/TASREG.h @@ -148,7 +148,6 @@ /* 32 byte page write mode using*/ /* last 5 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#if defined (CONFIG_SOFT_I2C) #if 0 /* push-pull */ diff --git a/include/configs/TQM8272.h b/include/configs/TQM8272.h index 039ecf1..df1ac7b 100644 --- a/include/configs/TQM8272.h +++ b/include/configs/TQM8272.h @@ -119,7 +119,6 @@ #define CFG_I2C_EEPROM_ADDR_LEN 2 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE /* necessary for the LM75 chip */ #define CFG_I2C_MULTI_EEPROMS 1 /* more than one eeprom */
/* I2C RTC */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index e8f69f6..53e204d 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -213,7 +213,6 @@ extern int tqm834x_num_flash_banks; #define CFG_I2C_EEPROM_ADDR 0x50 /* 1010000x */ #define CFG_I2C_EEPROM_ADDR_LEN 2 /* 16 bit */ #define CFG_EEPROM_PAGE_WRITE_BITS 5 /* 32 bytes per write */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 12 /* 10ms +/- 20% */ #define CFG_I2C_MULTI_EEPROMS 1 /* more than one eeprom */
diff --git a/include/configs/TQM85xx.h b/include/configs/TQM85xx.h index 5e1cf95..6de8fa2 100644 --- a/include/configs/TQM85xx.h +++ b/include/configs/TQM85xx.h @@ -323,7 +323,6 @@ #define CFG_I2C_EEPROM_ADDR 0x50 /* 1010000x */ #define CFG_I2C_EEPROM_ADDR_LEN 2 #define CFG_EEPROM_PAGE_WRITE_BITS 5 /* =32 Bytes per write */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 20 #define CFG_I2C_MULTI_EEPROMS 1 /* more than one eeprom */
diff --git a/include/configs/VOH405.h b/include/configs/VOH405.h index 3ca928e..d03766a 100644 --- a/include/configs/VOH405.h +++ b/include/configs/VOH405.h @@ -292,7 +292,6 @@ /* 32 byte page write mode using*/ /* last 5 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index f235890..f6b0287 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -214,7 +214,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * External Bus Controller (EBC) Setup diff --git a/include/configs/W7OLMC.h b/include/configs/W7OLMC.h index bb6b6b9..2f5d0ea 100644 --- a/include/configs/W7OLMC.h +++ b/include/configs/W7OLMC.h @@ -279,7 +279,6 @@ #define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ /* mask of address bits that overflow into the "EEPROM chip address" */ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ /* 16 byte page write mode using*/ /* last 4 bits of the address */ diff --git a/include/configs/W7OLMG.h b/include/configs/W7OLMG.h index 3050caf..4d78b34 100644 --- a/include/configs/W7OLMG.h +++ b/include/configs/W7OLMG.h @@ -284,7 +284,6 @@
#define CFG_I2C_EEPROM_ADDR 0x50 /* EEPROM ATMEL 24C04N */ #define CFG_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_I2C_MULTI_EEPROMS /*----------------------------------------------------------------------- diff --git a/include/configs/WUH405.h b/include/configs/WUH405.h index 582d8cf..f756651 100644 --- a/include/configs/WUH405.h +++ b/include/configs/WUH405.h @@ -252,7 +252,6 @@ /* 16 byte page write mode using*/ /* last 4 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * Init Memory Controller: diff --git a/include/configs/XPEDITE1K.h b/include/configs/XPEDITE1K.h index 38ea576..55b5d4e 100644 --- a/include/configs/XPEDITE1K.h +++ b/include/configs/XPEDITE1K.h @@ -156,7 +156,6 @@ extern void out32(unsigned int, unsigned long); #define CFG_ENV_OFFSET 0x100 #define CFG_I2C_EEPROM_ADDR 0x50 /* this is actually the second page of the eeprom */ #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/acadia.h b/include/configs/acadia.h index ed2754d..a32bfe7 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -203,7 +203,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/alpr.h b/include/configs/alpr.h index f342c7a..a19ad7b 100644 --- a/include/configs/alpr.h +++ b/include/configs/alpr.h @@ -133,7 +133,6 @@ /* 8 byte page write mode using */ /* last 3 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 40 /* and takes up to 40 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#define CONFIG_PREBOOT "echo;" \ "echo Type "run kernelx" to boot the system;" \ diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index 41058f8..9c79b7b 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -229,7 +229,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index 3b5b280..5c9a00a 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -243,7 +243,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/ebony.h b/include/configs/ebony.h index df444d8..a561579 100644 --- a/include/configs/ebony.h +++ b/include/configs/ebony.h @@ -143,7 +143,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/ep82xxm.h b/include/configs/ep82xxm.h index ac68c86..d9888d1 100644 --- a/include/configs/ep82xxm.h +++ b/include/configs/ep82xxm.h @@ -220,7 +220,6 @@ #define CFG_I2C_EEPROM_ADDR 0x54 #define CFG_I2C_EEPROM_ADDR_LEN 1 #define CFG_EEPROM_PAGE_WRITE_BITS 3 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
#ifdef CFG_ENV_IS_IN_EEPROM diff --git a/include/configs/hcu4.h b/include/configs/hcu4.h index d99ac53..001e2a7 100644 --- a/include/configs/hcu4.h +++ b/include/configs/hcu4.h @@ -162,7 +162,6 @@ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #undef CFG_I2C_MULTI_EEPROMS
diff --git a/include/configs/hcu5.h b/include/configs/hcu5.h index 54d6721..a049e18 100644 --- a/include/configs/hcu5.h +++ b/include/configs/hcu5.h @@ -163,7 +163,6 @@ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #undef CFG_I2C_MULTI_EEPROMS
diff --git a/include/configs/hymod.h b/include/configs/hymod.h index 264192f..702d535 100644 --- a/include/configs/hymod.h +++ b/include/configs/hymod.h @@ -288,7 +288,6 @@ /* mask of address bits that overflow into the "EEPROM chip address" */ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07
-#define CFG_EEPROM_PAGE_WRITE_ENABLE 1 /* write eeprom in pages */ #define CFG_EEPROM_PAGE_WRITE_BITS 4 /* 16 byte write page size */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
diff --git a/include/configs/katmai.h b/include/configs/katmai.h index 5dcca75..c67aa04 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -132,7 +132,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0x50) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/luan.h b/include/configs/luan.h index 805cc59..645ecbc 100644 --- a/include/configs/luan.h +++ b/include/configs/luan.h @@ -139,7 +139,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 3d135c4..c48b7b4 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -267,7 +267,6 @@ /* 64 byte page write mode using*/ /* last 6 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
#define CONFIG_RTC_PCF8563 1 /* enable Philips PCF8563 RTC */ #define CFG_I2C_RTC_ADDR 0x51 /* Philips PCF8563 RTC address */ diff --git a/include/configs/mcu25.h b/include/configs/mcu25.h index 6adba96..68756b8 100644 --- a/include/configs/mcu25.h +++ b/include/configs/mcu25.h @@ -162,7 +162,6 @@ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #undef CFG_I2C_MULTI_EEPROMS
diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index f2a35ee..e2592cc 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -308,7 +308,6 @@ * EEPROM configuration */ #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE 1 /* DTT driver needs this */ #define CFG_EEPROM_PAGE_WRITE_BITS 1 /* 2 bytes per write cycle */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 5 /* 2ms/cycle + 3ms extra */ #define CFG_I2C_MULTI_EEPROMS 1 /* 2 EEPROMs (addr:50,52) */ diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index a13648b..e2a595c 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -241,7 +241,6 @@ #define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ #define CFG_I2C_SLAVE 0x7F
-#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ diff --git a/include/configs/mucmc52.h b/include/configs/mucmc52.h index 18200ec..75e9be7 100644 --- a/include/configs/mucmc52.h +++ b/include/configs/mucmc52.h @@ -136,8 +136,6 @@ #define CFG_I2C_EEPROM_ADDR_LEN 1 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -/* for LM81 */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * RTC configuration diff --git a/include/configs/ocotea.h b/include/configs/ocotea.h index 407aae7..7272df1 100644 --- a/include/configs/ocotea.h +++ b/include/configs/ocotea.h @@ -157,7 +157,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/p3p440.h b/include/configs/p3p440.h index ac0d83a..bf1492f 100644 --- a/include/configs/p3p440.h +++ b/include/configs/p3p440.h @@ -112,7 +112,6 @@ /* 8 byte page write mode using */ /* last 3 bits of the address */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 40 /* and takes up to 40 msec */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/*----------------------------------------------------------------------- * Default configuration (environment varibles...) diff --git a/include/configs/pcs440ep.h b/include/configs/pcs440ep.h index ba6d932..0c5b2e5 100644 --- a/include/configs/pcs440ep.h +++ b/include/configs/pcs440ep.h @@ -143,7 +143,6 @@
#define CFG_I2C_EEPROM_ADDR (0xa4>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 74f6e3a..63540a0 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -225,7 +225,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index a981a8f..11a6fb0 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -258,7 +258,6 @@ #define CFG_DTT_MAX_TEMP 125 #define CFG_DTT_LOW_TEMP -55 #define CFG_DTT_HYSTERESIS 3 -#define CFG_EEPROM_PAGE_WRITE_ENABLE /* necessary for the LM75 chip */ #define CFG_EEPROM_PAGE_WRITE_BITS 4
/* diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index ac349df..732d676 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -216,7 +216,6 @@ #define CFG_I2C_EEPROM_ADDR 0x51 /* 1010001x */ #define CFG_I2C_EEPROM_ADDR_LEN 2 #define CFG_EEPROM_PAGE_WRITE_BITS 5 /* =32 Bytes per write */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 20
/* diff --git a/include/configs/taishan.h b/include/configs/taishan.h index 81133bb..bb56bd9 100644 --- a/include/configs/taishan.h +++ b/include/configs/taishan.h @@ -139,7 +139,6 @@ #undef CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR 0x50 #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/uc101.h b/include/configs/uc101.h index a186188..f4e38c7 100644 --- a/include/configs/uc101.h +++ b/include/configs/uc101.h @@ -138,8 +138,6 @@ #define CFG_I2C_EEPROM_ADDR_LEN 1 #define CFG_EEPROM_PAGE_WRITE_BITS 4 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 -/* for LM81 */ -#define CFG_EEPROM_PAGE_WRITE_ENABLE
/* * RTC configuration diff --git a/include/configs/walnut.h b/include/configs/walnut.h index e19c5f3..456853c 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -98,7 +98,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index cb2042c..6c4d7fb 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -143,7 +143,6 @@ #define CFG_I2C_MULTI_EEPROMS #define CFG_I2C_EEPROM_ADDR (0xa8>>1) #define CFG_I2C_EEPROM_ADDR_LEN 1 -#define CFG_EEPROM_PAGE_WRITE_ENABLE #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
diff --git a/include/configs/zeus.h b/include/configs/zeus.h index b50cba5..9108afc 100644 --- a/include/configs/zeus.h +++ b/include/configs/zeus.h @@ -175,7 +175,6 @@ /* mask of address bits that overflow into the "EEPROM chip address" */ #define CFG_I2C_EEPROM_ADDR_OVERFLOW 0x07
-#define CFG_EEPROM_PAGE_WRITE_ENABLE 1 /* write eeprom in pages */ #define CFG_EEPROM_PAGE_WRITE_BITS 3 /* 8 byte write page size */ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
Dear Peter Tyser,
Applied, thanks.
Peter Tyser
