[PATCH v2 00/32] Qualcomm generic board support
Historically, Qualcomm boards in U-Boot have all had their own board/qualcomm/xyz directory, their own CONFIG_TARGET_XYZ option, their own hardcoded sysmap-xyz.c file, and their own U-Boot specific devicetree with little/no compatibility with upstream DT.
This series makes a few final prepatory changes, and then replaces almost all of the board specific code with generic alternatives. The end result is that all Qualcomm boards both current and future (with the exception of the db410c and db820c) can be supported by a single U-Boot binary by just providing the correct DT. New boards can be added without introducing any addition mach/ or board/ code or config options.
Due to the nature of this change, the patch ("mach-snapdragon: generalise board support") has become pretty big, I tried a few different ways to represent this in git history, but the other methods (e.g. adding a stub "generic" target and removing it again) were more confusing and made for much messier git history. The current patch is mostly atomic, but requires regenerating the config.
The QCS404 EVB board had some code to enable the USB VBUS regulator, this is dropped in favour of a adding a new vbus-supply property to the dwc3-generic driver. This will also be used by the dragonboard845c in a future patch. This handles the common case of a board requiring some regulator be enabled for USB host mode.
A more detailed description of the changes is below.
== Memory map ==
The memory map was historically hardcoded into U-Boot, this meant that U-Boot had to be built for a specific variant of a device. This is changed to instead read the memory map from the DT /memory node.
Additionally, most boards mapped addresss 0x0 as valid, as a result if a null pointer access happens then it will cause a bus stall (and board hang). This is fixed so that null pointer accesses will now correctly throw an exception.
== DT loading ==
Previously, boards used the FDT blob embedded into U-Boot (via OF_SEPARATE). However, most Qualcomm boards run U-Boot as a secondary bootloader, so we can instead rely on the first-stage bootloader to populate some useful FDT properties for us (notably the /memory node and KASLR seed) and fetch the DTB that it provides. Combined with the memory map changes above, this let's us entirely avoid configuring the memory map explicitly.
== defconfig ==
Most of the board defconfigs and config headers were quite similar, to simplify maintenance going forward, all the fully generic boards (sdm845 and qcs404-evb so far) are adapted to use the new qcom_defconfig. Going forward, all new Qualcomm boards should be supported by this defconfig. A notable exception is for specific usecases (like U-Boot as the primary bootloader).
== The older dragonboards ==
The db410c and db820c both have some custom board init code, as a result they aren't yet binary compatible. mach-snapdragon is adjusted so that all the necessary config options (e.g. CONFIG_SYS_BOARD) can be set from their defconfigs, this makes it possible to enable support for new boards without introducing additional config options.
The db410c can run U-Boot either chainloaded like the other boards, or as a first-stage bootloader replacing aboot. However it was hardcoded to only build for the latter option. This series introduces a new "chainloaded" defconfig to enable easier testing via fastboot.
== dynamic environment variables ==
This series also introduces runtime-allocated load addresses via the lmb allocator. This allows for booting on boards with vastly different memory layouts without any pre-calculation or macro magic in the config header. This feature is based on similar code in mach-apple.
The soc, board, and fdtfile environment variables are also generated automatically. Many Qualcomm boards follow a similar scheme for DTB naming such that the name can often be derived from the root compatible properties. This is intended to cover the most common cases and be a simple solution for booting generic distro images without having to explicitly choose the right DTB. The U-Boot DTS can be tweaked if necessary to produce the correct name, the variable can be overwritten, or a bootloader like GRUB can load the devicetree instead.
== Upstream DT ==
All Qualcomm boards have had their devicetree files replaced with the upstream versions. Previous patch series made the necessary driver adjustments to fully support the upstream DT format. All future Qualcomm boards should use upstream DTS by default.
Once Sumit's work to import dt-rebasing has been merged, we will drop the imported DT and bindings again.
--- I have tested this series on the Dragonboard410c, Dragonboard820c, and Dragonboard845c. I unfortunately don't have access to a QCS404 EVB board to test.
This series is based on the qcom-next branch [1] and depends on my PMIC fixes series [2], an integration branch for testing can be found at [3]. The non-qualcomm-specific changes (patches 1 and 2) don't have any dependencies.
[1]: https://source.denx.de/u-boot/custodians/u-boot-snapdragon [2]: https://lore.kernel.org/u-boot/20231114-b4-qcom-dt-compat-v3-0-88a92f8f00ba@... [3]: https://source.denx.de/u-boot/custodians/u-boot-snapdragon/-/tree/b4/qcom-co...
--- Changes in v2: - Split DTS changes to reduce patch size. - Import full board DTS files from Linux too, and introduce -u-boot.dtsi files where necessary to make any U-Boot specific changes. - Add a pinctrl driver for qcom PMIC GPIOs - Always enable LINUX_KERNEL_IMAGE_HEADER - Link to v1: https://lore.kernel.org/r/20231121-b4-qcom-common-target-v1-0-9492198e0c15@l...
To: Neil Armstrong neil.armstrong@linaro.org To: Sumit Garg sumit.garg@linaro.org To: Ramon Fried rfried.dev@gmail.com Cc: Marek Vasut marex@denx.de To: Dzmitry Sankouski dsankouski@gmail.com To: Caleb Connolly caleb.connolly@linaro.org To: Peng Fan peng.fan@nxp.com To: Jaehoon Chung jh80.chung@samsung.com To: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com To: Lukasz Majewski lukma@denx.de To: Sean Anderson seanga2@gmail.com To: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com To: Stephan Gerhold stephan@gerhold.net Cc: u-boot@lists.denx.de
--- Caleb Connolly (32): arm: init: export prev_bl_fdt_addr usb: dwc3-generic: support external vbus regulator mmc: msm_sdhci: use modern clock handling dt-bindings: drop msm_sdhci binding clk/qcom: use upstream compatible properties serial: msm: add debug UART serial: msm: fix clock handling gpio: qcom_pmic: 1-based GPIOs gpio: qcom_pmic: add a quirk to skip GPIO configuration gpio: qcom_pmic: add pinctrl driver board: dragonboard410c: add chainloaded config fragment board: dragonboard410c: upstream DT compat board: dragonboard410c: import board code from mach-snapdragon board: dragonboard820c: use LINUX_KERNEL_IMAGE_HEADER mach-snapdragon: generalise board support mach-snapdragon: dynamic load addresses mach-snapdragon: generate fdtfile automatically doc: board/qualcomm: document generic targets dt-bindings: import headers for SDM845 dts: sdm845: import supporting dtsi files dts: sdm845: replace with upstream DTS dt-bindings: import headers for MSM8916 dts: msm8916: import PMIC dtsi files dts: msm8916: replace with upstream DTS dt-bindings: import headers for MSM8996 dts: msm8996: import PMIC dtsi files dts: dragonboard820c: use correct bindings for clocks dts: msm8996: replace with upstream DTS dt-bindings: import headers for qcs404 dts: qcs404-evb: replace with upstream DT board: qcs404-evb: drop board code MAINTAINERS: Qualcomm: add some missing paths
MAINTAINERS | 12 +- arch/arm/Kconfig | 4 + arch/arm/dts/Makefile | 9 +- arch/arm/dts/apq8016-sbc.dts | 729 +++ arch/arm/dts/apq8096-db820c-u-boot.dtsi | 10 + arch/arm/dts/apq8096-db820c.dts | 1137 ++++ arch/arm/dts/dragonboard410c-uboot.dtsi | 44 - arch/arm/dts/dragonboard410c.dts | 199 +- arch/arm/dts/dragonboard820c-uboot.dtsi | 32 - arch/arm/dts/dragonboard820c.dts | 151 - arch/arm/dts/dragonboard845c-uboot.dtsi | 26 - arch/arm/dts/dragonboard845c.dts | 48 - arch/arm/dts/msm8916-pm8916.dtsi | 157 + arch/arm/dts/msm8916.dtsi | 2702 +++++++++ arch/arm/dts/msm8996.dtsi | 3884 +++++++++++++ arch/arm/dts/pm8916.dtsi | 178 + arch/arm/dts/pm8994.dtsi | 152 + arch/arm/dts/pm8998.dtsi | 130 + arch/arm/dts/pmi8994.dtsi | 65 + arch/arm/dts/pmi8998.dtsi | 98 + arch/arm/dts/pms405.dtsi | 149 + arch/arm/dts/qcs404-evb-4000-u-boot.dtsi | 26 + arch/arm/dts/qcs404-evb-4000.dts | 96 + arch/arm/dts/qcs404-evb-uboot.dtsi | 30 - arch/arm/dts/qcs404-evb.dts | 390 -- arch/arm/dts/qcs404-evb.dtsi | 389 ++ arch/arm/dts/qcs404.dtsi | 1829 ++++++ arch/arm/dts/sdm845-db845c.dts | 1190 ++++ .../arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi | 16 + arch/arm/dts/sdm845-samsung-starqltechn.dts | 624 +++ arch/arm/dts/sdm845-wcd9340.dtsi | 86 + arch/arm/dts/sdm845.dtsi | 5801 +++++++++++++++++++- arch/arm/dts/starqltechn-uboot.dtsi | 27 - arch/arm/dts/starqltechn.dts | 68 - arch/arm/lib/save_prev_bl_data.c | 5 + arch/arm/mach-snapdragon/Kconfig | 95 +- arch/arm/mach-snapdragon/Makefile | 8 +- arch/arm/mach-snapdragon/board.c | 304 + arch/arm/mach-snapdragon/include/mach/dram.h | 12 - arch/arm/mach-snapdragon/init_sdm845.c | 73 - arch/arm/mach-snapdragon/misc.c | 55 - arch/arm/mach-snapdragon/sysmap-apq8016.c | 31 - arch/arm/mach-snapdragon/sysmap-apq8096.c | 31 - arch/arm/mach-snapdragon/sysmap-qcs404.c | 43 - arch/arm/mach-snapdragon/sysmap-sdm845.c | 31 - board/qualcomm/dragonboard410c/Kconfig | 15 - board/qualcomm/dragonboard410c/Makefile | 3 +- .../dragonboard410c/configs/chainloaded.config | 7 + board/qualcomm/dragonboard410c/dragonboard410c.c | 109 +- .../qualcomm/dragonboard410c/misc.c | 51 +- .../mach => board/qualcomm/dragonboard410c}/misc.h | 1 + board/qualcomm/dragonboard820c/Kconfig | 15 - board/qualcomm/dragonboard820c/Makefile | 1 - board/qualcomm/dragonboard820c/dragonboard820c.c | 39 +- board/qualcomm/dragonboard820c/head.S | 33 - board/qualcomm/dragonboard820c/u-boot.lds | 111 - board/qualcomm/dragonboard845c/Kconfig | 12 - board/qualcomm/qcs404-evb/Kconfig | 15 - board/qualcomm/qcs404-evb/Makefile | 6 - board/qualcomm/qcs404-evb/qcs404-evb.c | 62 - configs/dragonboard410c_defconfig | 8 +- configs/dragonboard820c_defconfig | 8 +- configs/dragonboard845c_defconfig | 29 - configs/qcom_defconfig | 73 + configs/qcs404evb_defconfig | 55 - configs/starqltechn_defconfig | 41 - doc/board/qualcomm/board.rst | 119 + doc/board/qualcomm/debugging.rst | 61 + doc/board/qualcomm/index.rst | 4 +- doc/board/qualcomm/qcs404.rst | 79 - doc/board/qualcomm/sdm845.rst | 162 - doc/device-tree-bindings/mmc/msm_sdhci.txt | 25 - doc/device-tree-bindings/usb/ehci-msm.txt | 10 - drivers/clk/qcom/clock-apq8016.c | 9 +- drivers/clk/qcom/clock-apq8096.c | 7 +- drivers/gpio/qcom_pmic_gpio.c | 232 +- drivers/mmc/msm_sdhci.c | 69 +- drivers/phy/qcom/msm8916-usbh-phy.c | 4 +- drivers/pinctrl/qcom/pinctrl-apq8016.c | 2 +- drivers/serial/Kconfig | 8 + drivers/serial/serial_msm.c | 56 +- drivers/usb/dwc3/dwc3-generic.c | 12 + drivers/usb/host/ehci-msm.c | 24 +- include/configs/dragonboard845c.h | 20 - include/configs/qcom.h | 21 + include/configs/qcs404-evb.h | 20 - include/configs/sdm845.h | 26 - include/dt-bindings/arm/coresight-cti-dt.h | 37 + include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 + include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 + include/dt-bindings/clock/qcom,gcc-msm8916.h | 179 + include/dt-bindings/clock/qcom,gcc-msm8996.h | 360 ++ include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 + include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 + include/dt-bindings/clock/qcom,mmcc-msm8996.h | 295 + include/dt-bindings/clock/qcom,rpmcc.h | 174 + include/dt-bindings/clock/qcom,rpmh.h | 37 + include/dt-bindings/clock/qcom,turingcc-qcs404.h | 15 + include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 + include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 18 + include/dt-bindings/iio/qcom,spmi-vadc.h | 300 + include/dt-bindings/interconnect/qcom,msm8916.h | 100 + .../dt-bindings/interconnect/qcom,msm8996-cbf.h | 12 + include/dt-bindings/interconnect/qcom,msm8996.h | 163 + include/dt-bindings/interconnect/qcom,osm-l3.h | 15 + include/dt-bindings/interconnect/qcom,sdm845.h | 150 + include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/phy/phy-qcom-qusb2.h | 37 + include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 + include/dt-bindings/pinctrl/qcom,pmic-mpp.h | 106 + include/dt-bindings/power/qcom-rpmpd.h | 412 ++ include/dt-bindings/qcom,q6asm.h | 26 + .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 + include/dt-bindings/reset/qcom,gcc-msm8916.h | 100 + include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 + include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 + include/dt-bindings/soc/qcom,apr.h | 28 + include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + include/dt-bindings/sound/apq8016-lpass.h | 9 + include/dt-bindings/sound/qcom,lpass.h | 46 + include/dt-bindings/sound/qcom,q6afe.h | 9 + include/dt-bindings/sound/qcom,q6asm.h | 26 + include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 + include/dt-bindings/sound/qcom,wcd9335.h | 15 + include/init.h | 11 + 126 files changed, 23909 insertions(+), 2375 deletions(-) --- base-commit: bcb4a9ddbd21a61b5b421ba374a785757bd28c80
// Caleb (they/them)
When booting U-Boot on board with a locked down first-stage bootloader, we emulate the Linux boot header. By passing the U-Boot FDT through this first-stage bootloader and retrieving it afterwards we can pre-populate the memory nodes and other info like the KASLR address.
Add a function to export the FDT addr so that boards can use it over the built-in FDT.
Don't check is_addr_accessible() here because we might not yet have a valid mem_map if it's going to be populated from the FDT, let the board do their own validation instead.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- This patch has no dependencies
Cc: Simon Glass sjg@chromium.org --- arch/arm/lib/save_prev_bl_data.c | 5 +++++ include/init.h | 11 +++++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/lib/save_prev_bl_data.c b/arch/arm/lib/save_prev_bl_data.c index f7b23faf0d66..b286bac9bf00 100644 --- a/arch/arm/lib/save_prev_bl_data.c +++ b/arch/arm/lib/save_prev_bl_data.c @@ -45,6 +45,11 @@ bool is_addr_accessible(phys_addr_t addr) return false; }
+phys_addr_t get_prev_bl_fdt_addr(void) +{ + return reg0; +} + int save_prev_bl_data(void) { struct fdt_header *fdt_blob; diff --git a/include/init.h b/include/init.h index d57a24fd00dd..7a3ab152b65f 100644 --- a/include/init.h +++ b/include/init.h @@ -168,6 +168,17 @@ defined(CONFIG_SAVE_PREV_BL_FDT_ADDR) * Return: 0 if ok; -ENODATA on error */ int save_prev_bl_data(void); + +/** + * get_prev_bl_fdt_addr - When u-boot is chainloaded, get the address + * of the FDT passed by the previous bootloader. + * + * Return: the address of the FDT passed by the previous bootloader + * or 0 if not found. + */ +phys_addr_t get_prev_bl_fdt_addr(void); +#else +#define get_prev_bl_fdt_addr() 0LLU #endif
Add support for a vbus-supply regulator specified in devicetree. This provides generic support to avoid hardcoded GPIO configuration in board init code.
Cc: Marek Vasut marex@denx.de --- drivers/usb/dwc3/dwc3-generic.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 744fde806948..e66e7961c70f 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -21,6 +21,7 @@ #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> #include <malloc.h> +#include <power/regulator.h> #include <usb.h> #include "core.h" #include "gadget.h" @@ -47,6 +48,7 @@ struct dwc3_generic_priv { struct dwc3_generic_host_priv { struct xhci_ctrl xhci_ctrl; struct dwc3_generic_priv gen_priv; + struct udevice *vbus_dev; };
static int dwc3_generic_probe(struct udevice *dev, @@ -240,6 +242,13 @@ static int dwc3_generic_host_probe(struct udevice *dev) if (rc) return rc;
+ rc = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_dev); + if (rc) + debug("%s: No vbus regulator found: %d\n", dev->name, rc); + + if (priv->vbus_dev) + regulator_set_enable(priv->vbus_dev, true); + hccr = (struct xhci_hccr *)priv->gen_priv.base; hcor = (struct xhci_hcor *)(priv->gen_priv.base + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase))); @@ -256,6 +265,9 @@ static int dwc3_generic_host_remove(struct udevice *dev) if (rc) return rc;
+ if (priv->vbus_dev) + regulator_set_enable(priv->vbus_dev, false); + return dwc3_generic_remove(dev, &priv->gen_priv); }
- rc = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_dev);
- if (rc)
- if (priv->vbus_dev)
- hccr = (struct xhci_hccr *)priv->gen_priv.base; hcor = (struct xhci_hcor *)(priv->gen_priv.base + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase)));
- return dwc3_generic_remove(dev, &priv->gen_priv); }
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Use the clk_* helper functions and the correct property name for clocks.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/mmc/msm_sdhci.c | 69 ++++++++++++++++++++++++++++++++----------------- 1 file changed, 46 insertions(+), 23 deletions(-)
diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index 604f9c3ff99c..863e6007a905 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -44,6 +44,7 @@ struct msm_sdhc_plat { struct msm_sdhc { struct sdhci_host host; void *base; + struct clk_bulk clks; };
struct msm_sdhc_variant_info { @@ -54,36 +55,56 @@ DECLARE_GLOBAL_DATA_PTR;
static int msm_sdc_clk_init(struct udevice *dev) { - int node = dev_of_offset(dev); - uint clk_rate = fdtdec_get_uint(gd->fdt_blob, node, "clock-frequency", - 400000); - uint clkd[2]; /* clk_id and clk_no */ - int clk_offset; - struct udevice *clk_dev; - struct clk clk; - int ret; + struct msm_sdhc *prv = dev_get_priv(dev); + ofnode node = dev_ofnode(dev); + uint clk_rate; + int ret, i = 0, n_clks; + const char *clk_name;
- ret = fdtdec_get_int_array(gd->fdt_blob, node, "clock", clkd, 2); + ret = ofnode_read_u32(node, "clock-frequency", &clk_rate); if (ret) - return ret; + clk_rate = 400000;
- clk_offset = fdt_node_offset_by_phandle(gd->fdt_blob, clkd[0]); - if (clk_offset < 0) - return clk_offset; - - ret = uclass_get_device_by_of_offset(UCLASS_CLK, clk_offset, &clk_dev); - if (ret) + ret = clk_get_bulk(dev, &prv->clks); + if (ret) { + debug("Couldn't get mmc clocks: %d\n", ret); return ret; + }
- clk.id = clkd[1]; - ret = clk_request(clk_dev, &clk); - if (ret < 0) + ret = clk_enable_bulk(&prv->clks); + if (ret) { + debug("Couldn't enable mmc clocks: %d\n", ret); return ret; + }
- ret = clk_set_rate(&clk, clk_rate); - clk_free(&clk); - if (ret < 0) - return ret; + /* If clock-names is unspecified, then the first clock is the core clock */ + if (!ofnode_get_property(node, "clock-names", &n_clks)) { + if (!clk_set_rate(&prv->clks.clks[0], clk_rate)) { + printf("Couldn't set core clock rate: %d\n", ret); + return -EINVAL; + } + } + + /* Find the index of the "core" clock */ + while (i < n_clks) { + ofnode_read_string_index(node, "clock-names", i, &clk_name); + if (!strcmp(clk_name, "core")) + break; + i++; + } + + if (i >= prv->clks.count) { + printf("Couldn't find core clock (index %d but only have %d clocks)\n", i, + prv->clks.count); + return -EINVAL; + } + + /* The clock is already enabled by the clk_bulk above */ + ret = clk_set_rate(&prv->clks.clks[i], clk_rate); + if (!ret) { + printf("Couldn't set core clock rate: %d\n", ret); + return -EINVAL; + }
return 0; } @@ -188,6 +209,8 @@ static int msm_sdc_remove(struct udevice *dev) if (!var_info->mci_removed) writel(0, priv->base + SDCC_MCI_HC_MODE);
+ clk_release_bulk(&priv->clks); + return 0; }
400000);
- int clk_offset;
- struct clk clk;
- int ret;
- struct msm_sdhc *prv = dev_get_priv(dev);
- ofnode node = dev_ofnode(dev);
- uint clk_rate;
- int ret, i = 0, n_clks;
- const char *clk_name;
- ret = ofnode_read_u32(node, "clock-frequency", &clk_rate); if (ret)
return ret;
clk_rate = 400000;
return clk_offset;
- if (ret)
- ret = clk_get_bulk(dev, &prv->clks);
- if (ret) {
return ret;debug("Couldn't get mmc clocks: %d\n", ret);
- clk.id = clkd[1];
- if (ret < 0)
- ret = clk_enable_bulk(&prv->clks);
- if (ret) {
return ret;debug("Couldn't enable mmc clocks: %d\n", ret);
- clk_free(&clk);
- if (ret < 0)
return ret;
return -EINVAL;
break;
i++;
prv->clks.count);
return -EINVAL;
if (!ret) {
return -EINVAL;
return 0; }
- clk_release_bulk(&priv->clks);
- return 0; }
Looks better like this!
On Tue, Dec 19, 2023 at 6:04 PM Caleb Connolly caleb.connolly@linaro.org wrote:
400000);
int clk_offset;
struct clk clk;
int ret;
uint clk_rate;
return ret;
clk_rate = 400000;
if (clk_offset < 0)
return clk_offset;
if (ret)
if (ret) {
clk.id = clkd[1];
if (ret < 0)
if (ret) {
clk_free(&clk);
if (ret < 0)
return ret;
return -EINVAL;
break;
i++;
prv->clks.count);
return -EINVAL;
if (!ret) {
return -EINVAL;
} return 0;
-- 2.42.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
The upstream DT is supported here, so drop the U-Boot specific binding docs.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- doc/device-tree-bindings/mmc/msm_sdhci.txt | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/doc/device-tree-bindings/mmc/msm_sdhci.txt b/doc/device-tree-bindings/mmc/msm_sdhci.txt deleted file mode 100644 index 08a290c66931..000000000000 --- a/doc/device-tree-bindings/mmc/msm_sdhci.txt +++ /dev/null @@ -1,25 +0,0 @@ -Qualcomm Snapdragon SDHCI controller - -Required properties: -- compatible : "qcom,sdhci-msm-v4" -- reg: Base address and length of registers: - - Host controller registers (SDHCI) - - SD Core registers -- clock: interface clock (must accept SD bus clock as a frequency) - -Optional properties: -- index: If there is more than one controller - controller index (required - by generic SDHCI code). -- bus_width: Width of SD/eMMC bus (default 4) -- clock-frequency: Frequency of SD/eMMC bus (default 400 kHz) - -Example: - -sdhci@07864000 { - compatible = "qcom,sdhci-msm-v4"; - reg = <0x7864900 0x11c 0x7864000 0x800>; - index = <0x1>; - bus-width = <0x4>; - clock = <&clkc 1>; - clock-frequency = <200000000>; -};
- SD Core registers
-Example:
-sdhci@07864000 {
- index = <0x1>;
Adjust the apq8016 and apq8096 drivers to use the upstream compatible properties, and adjust the associated dts files in U-Boot.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/dragonboard410c.dts | 2 +- drivers/clk/qcom/clock-apq8016.c | 2 +- drivers/clk/qcom/clock-apq8096.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 6a4e3ccf17b1..02c824d0226c 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -75,7 +75,7 @@ }; }; clkc: qcom,gcc@1800000 { - compatible = "qcom,gcc-apq8016"; + compatible = "qcom,gcc-msm8916"; reg = <0x1800000 0x80000>; #address-cells = <0x1>; #size-cells = <0x0>; diff --git a/drivers/clk/qcom/clock-apq8016.c b/drivers/clk/qcom/clock-apq8016.c index c0ce570edc79..0af7191cff52 100644 --- a/drivers/clk/qcom/clock-apq8016.c +++ b/drivers/clk/qcom/clock-apq8016.c @@ -145,7 +145,7 @@ static struct msm_clk_data apq8016_clk_data = {
static const struct udevice_id gcc_apq8016_of_match[] = { { - .compatible = "qcom,gcc-apq8016", + .compatible = "qcom,gcc-msm8916", .data = (ulong)&apq8016_clk_data, }, { } diff --git a/drivers/clk/qcom/clock-apq8096.c b/drivers/clk/qcom/clock-apq8096.c index cf1a347309a5..1e6fdb5cd42d 100644 --- a/drivers/clk/qcom/clock-apq8096.c +++ b/drivers/clk/qcom/clock-apq8096.c @@ -123,7 +123,7 @@ static struct msm_clk_data apq8096_clk_data = {
static const struct udevice_id gcc_apq8096_of_match[] = { { - .compatible = "qcom,gcc-apq8096", + .compatible = "qcom,gcc-msm8996", .data = (ulong)&apq8096_clk_data, }, { }
.data = (ulong)&apq8016_clk_data, }, { }.compatible = "qcom,gcc-msm8916",
.data = (ulong)&apq8096_clk_data, }, { }.compatible = "qcom,gcc-msm8996",
Introduce support for early debugging.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/serial/Kconfig | 8 ++++++++ drivers/serial/serial_msm.c | 32 ++++++++++++++++++++++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 81fdac047824..20713812c839 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -304,6 +304,14 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_MSM + bool "Qualcomm QUP UART debug" + depends on ARCH_SNAPDRAGON + help + Select this to enable a debug UART using the serial_msm driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_MSM_GENI bool "Qualcomm snapdragon" depends on ARCH_SNAPDRAGON diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index a22623c316ed..19a5a3a788f7 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -253,3 +253,35 @@ U_BOOT_DRIVER(serial_msm) = { .probe = msm_serial_probe, .ops = &msm_serial_ops, }; + +#ifdef CONFIG_DEBUG_UART_MSM + +static struct msm_serial_data init_serial_data = { + .base = CONFIG_VAL(DEBUG_UART_BASE), + .clk_bit_rate = UART_DM_CLK_RX_TX_BIT_RATE, +}; + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + uart_dm_init(&init_serial_data); +} + +static inline void _debug_uart_putc(int ch) +{ + struct msm_serial_data *priv = &init_serial_data; + + while (!(readl(priv->base + UARTDM_SR) & UARTDM_SR_TX_EMPTY) && + !(readl(priv->base + UARTDM_ISR) & UARTDM_ISR_TX_READY)) + ; + + writel(UARTDM_CR_CMD_RESET_TX_READY, priv->base + UARTDM_CR); + + writel(1, priv->base + UARTDM_NCF_TX); + writel(ch, priv->base + UARTDM_TF); +} + +DEBUG_UART_FUNCS + +#endif
- bool "Qualcomm QUP UART debug"
- depends on ARCH_SNAPDRAGON
- help
I'm confused, perhaps the config should be named DEBUG_UART_MSM_QUP ?
- config DEBUG_UART_MSM_GENI bool "Qualcomm snapdragon" depends on ARCH_SNAPDRAGON
- .base = CONFIG_VAL(DEBUG_UART_BASE),
- .clk_bit_rate = UART_DM_CLK_RX_TX_BIT_RATE,
- uart_dm_init(&init_serial_data);
- struct msm_serial_data *priv = &init_serial_data;
- while (!(readl(priv->base + UARTDM_SR) & UARTDM_SR_TX_EMPTY) &&
- writel(UARTDM_CR_CMD_RESET_TX_READY, priv->base + UARTDM_CR);
- writel(1, priv->base + UARTDM_NCF_TX);
- writel(ch, priv->base + UARTDM_TF);
+DEBUG_UART_FUNCS
What is QUP ?
help
+DEBUG_UART_FUNCS
-- 2.42.1
What is QUP ?
It's "Qualcomm Universal Peripheral".
help
+DEBUG_UART_FUNCS
-- 2.42.1
Use the modern helpers to fetch the clock and use the correct property ("clocks" instead of "clock")
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/dragonboard410c.dts | 3 ++- arch/arm/dts/dragonboard820c.dts | 3 ++- drivers/serial/serial_msm.c | 24 +++++------------------- 3 files changed, 9 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 02c824d0226c..c395e6cc0427 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -84,7 +84,8 @@ serial@78b0000 { compatible = "qcom,msm-uartdm-v1.4"; reg = <0x78b0000 0x200>; - clock = <&clkc 4>; + clocks = <&clkc 4>; + clock-names = "core"; pinctrl-names = "uart"; pinctrl-0 = <&blsp1_uart>; }; diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts index 146a0af8aafe..86b7f83d36d6 100644 --- a/arch/arm/dts/dragonboard820c.dts +++ b/arch/arm/dts/dragonboard820c.dts @@ -78,7 +78,8 @@ blsp2_uart2: serial@75b0000 { compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; reg = <0x75b0000 0x1000>; - clock = <&gcc 4>; + clocks = <&gcc 4>; + clock-names = "core"; pinctrl-names = "uart"; pinctrl-0 = <&blsp8_uart>; }; diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index 19a5a3a788f7..0148ddb54df6 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -160,29 +160,14 @@ static int msm_uart_clk_init(struct udevice *dev) { uint clk_rate = fdtdec_get_uint(gd->fdt_blob, dev_of_offset(dev), "clock-frequency", 115200); - uint clkd[2]; /* clk_id and clk_no */ - int clk_offset; - struct udevice *clk_dev; struct clk clk; int ret;
- ret = fdtdec_get_int_array(gd->fdt_blob, dev_of_offset(dev), "clock", - clkd, 2); - if (ret) - return ret; - - clk_offset = fdt_node_offset_by_phandle(gd->fdt_blob, clkd[0]); - if (clk_offset < 0) - return clk_offset; - - ret = uclass_get_device_by_of_offset(UCLASS_CLK, clk_offset, &clk_dev); - if (ret) - return ret; - - clk.id = clkd[1]; - ret = clk_request(clk_dev, &clk); - if (ret < 0) + ret = clk_get_by_name(dev, "core", &clk); + if (ret < 0) { + pr_warn("%s: Failed to get clock: %d\n", __func__, ret); return ret; + }
ret = clk_set_rate(&clk, clk_rate); clk_free(&clk); @@ -252,6 +237,7 @@ U_BOOT_DRIVER(serial_msm) = { .priv_auto = sizeof(struct msm_serial_data), .probe = msm_serial_probe, .ops = &msm_serial_ops, + .flags = DM_FLAG_PRE_RELOC, };
clock = <&clkc 4>;
clocks = <&clkc 4>;
};clock-names = "core"; pinctrl-names = "uart"; pinctrl-0 = <&blsp1_uart>;
clock = <&gcc 4>;
clocks = <&gcc 4>;
};clock-names = "core"; pinctrl-names = "uart"; pinctrl-0 = <&blsp8_uart>;
int clk_offset;
clkd, 2);
if (ret)
return ret;
if (clk_offset < 0)
return clk_offset;
if (ret)
return ret;
clk.id = clkd[1];
if (ret < 0)
if (ret < 0) {
return ret;
- .flags = DM_FLAG_PRE_RELOC,
Is this flag introduction related to this particular clock property name change ?
Qualcomm PMICs number their GPIOs starting from 1, implement a custom .xlate method to handle this.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/gpio/qcom_pmic_gpio.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/drivers/gpio/qcom_pmic_gpio.c b/drivers/gpio/qcom_pmic_gpio.c index 6167c8411678..2a4fef8d28cb 100644 --- a/drivers/gpio/qcom_pmic_gpio.c +++ b/drivers/gpio/qcom_pmic_gpio.c @@ -209,12 +209,34 @@ static int qcom_gpio_set_value(struct udevice *dev, unsigned offset, REG_CTL_OUTPUT_MASK, !!value); }
+static int qcom_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, + struct ofnode_phandle_args *args) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + if (args->args_count < 1) + return -EINVAL; + + /* GPIOs in DT are 1-based */ + desc->offset = args->args[0] - 1; + if (desc->offset >= uc_priv->gpio_count) + return -EINVAL; + + if (args->args_count < 2) + return 0; + + desc->flags = gpio_flags_xlate(args->args[1]); + + return 0; +} + static const struct dm_gpio_ops qcom_gpio_ops = { .direction_input = qcom_gpio_direction_input, .direction_output = qcom_gpio_direction_output, .get_value = qcom_gpio_get_value, .set_value = qcom_gpio_set_value, .get_function = qcom_gpio_get_function, + .xlate = qcom_gpio_xlate, };
static int qcom_gpio_probe(struct udevice *dev)
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- if (args->args_count < 1)
return -EINVAL;
- /* GPIOs in DT are 1-based */
- desc->offset = args->args[0] - 1;
- if (desc->offset >= uc_priv->gpio_count)
return -EINVAL;
- if (args->args_count < 2)
- desc->flags = gpio_flags_xlate(args->args[1]);
Some platforms hard reset when attempting to configure PMIC GPIOs. Add support for quirks specified in match data with a single quirk to skip this configuration. We rely on the GPIO already be configured correctly, which is always the case for volume up (the only current user of these GPIOs).
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/gpio/qcom_pmic_gpio.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/qcom_pmic_gpio.c b/drivers/gpio/qcom_pmic_gpio.c index 2a4fef8d28cb..198cd84bc31e 100644 --- a/drivers/gpio/qcom_pmic_gpio.c +++ b/drivers/gpio/qcom_pmic_gpio.c @@ -64,6 +64,15 @@ #define REG_EN_CTL 0x46 #define REG_EN_CTL_ENABLE (1 << 7)
+/** + * pmic_gpio_match_data - platform specific configuration + * + * @PMIC_MATCH_READONLY: treat all GPIOs as readonly, don't attempt to configure them + */ +enum pmic_gpio_quirks { + QCOM_PMIC_QUIRK_READONLY = (1 << 0), +}; + struct qcom_gpio_bank { uint32_t pid; /* Peripheral ID on SPMI bus */ bool lv_mv_type; /* If subtype is GPIO_LV(0x10) or GPIO_MV(0x11) */ @@ -75,7 +84,12 @@ static int qcom_gpio_set_direction(struct udevice *dev, unsigned offset, struct qcom_gpio_bank *priv = dev_get_priv(dev); uint32_t gpio_base = priv->pid + REG_OFFSET(offset); uint32_t reg_ctl_val; - int ret; + ulong quirks = dev_get_driver_data(dev); + int ret = 0; + + /* Some PMICs don't like their GPIOs being configured */ + if (quirks & QCOM_PMIC_QUIRK_READONLY) + return 0;
/* Disable the GPIO */ ret = pmic_clrsetbits(dev->parent, gpio_base + REG_EN_CTL, @@ -304,7 +318,7 @@ static int qcom_gpio_of_to_plat(struct udevice *dev) static const struct udevice_id qcom_gpio_ids[] = { { .compatible = "qcom,pm8916-gpio" }, { .compatible = "qcom,pm8994-gpio" }, /* 22 GPIO's */ - { .compatible = "qcom,pm8998-gpio" }, + { .compatible = "qcom,pm8998-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, { .compatible = "qcom,pms405-gpio" }, { } };
Do you know why this happens in u-boot and not in Linux ?
- pmic_gpio_match_data - platform specific configuration
- @PMIC_MATCH_READONLY: treat all GPIOs as readonly, don't attempt to configure them
- QCOM_PMIC_QUIRK_READONLY = (1 << 0),
- struct qcom_gpio_bank { uint32_t pid; /* Peripheral ID on SPMI bus */ bool lv_mv_type; /* If subtype is GPIO_LV(0x10) or GPIO_MV(0x11) */
- int ret;
int ret = 0;
- { .compatible = "qcom,pm8998-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, { .compatible = "qcom,pms405-gpio" }, { } };
I don't, I did some preliminary debugging but couldn't root-cause this. Writing to any of the GPIO registers seem to cause a crash. It could potentially be a bug in the SPMI arb driver - I'm not sure if there are any SPMI writes done on this platform by U-Boot
diff --git a/drivers/gpio/qcom_pmic_gpio.c b/drivers/gpio/qcom_pmic_gpio.c index 2a4fef8d28cb..198cd84bc31e 100644 --- a/drivers/gpio/qcom_pmic_gpio.c +++ b/drivers/gpio/qcom_pmic_gpio.c @@ -64,6 +64,15 @@ #define REG_EN_CTL 0x46 #define REG_EN_CTL_ENABLE (1 << 7) +/**
to configure them
+ /* Some PMICs don't like their GPIOs being configured */ + if (quirks & QCOM_PMIC_QUIRK_READONLY) + return 0; /* Disable the GPIO */ ret = pmic_clrsetbits(dev->parent, gpio_base + REG_EN_CTL, @@ -304,7 +318,7 @@ static int qcom_gpio_of_to_plat(struct udevice *dev) static const struct udevice_id qcom_gpio_ids[] = { { .compatible = "qcom,pm8916-gpio" }, { .compatible = "qcom,pm8994-gpio" }, /* 22 GPIO's */ - { .compatible = "qcom,pm8998-gpio" }, + { .compatible = "qcom,pm8998-gpio", .data = QCOM_PMIC_QUIRK_READONLY }, { .compatible = "qcom,pms405-gpio" }, { } };
Introduce a basic pinctrl driver for the SPMI PMIC GPIOs. This is necessary to make proper use of upstream DT bindings specifically on the dragonboard410c where they're used to switch between USB host and device modes.
Only support for driving the pins as output low or high is enabled for now.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- drivers/gpio/qcom_pmic_gpio.c | 204 ++++++++++++++++++++++++++++++++++++------ 1 file changed, 177 insertions(+), 27 deletions(-)
diff --git a/drivers/gpio/qcom_pmic_gpio.c b/drivers/gpio/qcom_pmic_gpio.c index 198cd84bc31e..647b5dc1e6f6 100644 --- a/drivers/gpio/qcom_pmic_gpio.c +++ b/drivers/gpio/qcom_pmic_gpio.c @@ -7,10 +7,14 @@
#include <common.h> #include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/pinctrl.h> #include <log.h> #include <power/pmic.h> #include <spmi/spmi.h> #include <asm/io.h> +#include <stdlib.h> #include <asm/gpio.h> #include <linux/bitops.h>
@@ -78,27 +82,22 @@ struct qcom_gpio_bank { bool lv_mv_type; /* If subtype is GPIO_LV(0x10) or GPIO_MV(0x11) */ };
-static int qcom_gpio_set_direction(struct udevice *dev, unsigned offset, - bool input, int value) +struct qcom_pinctrl_data { + u32 pid; + bool lv_mv_type; /* If subtype is GPIO_LV(0x10) or GPIO_MV(0x11) */ + u32 pin_count; +}; + +/* dev can be the GPIO or pinctrl device */ +static int _qcom_gpio_set_direction(struct udevice *dev, u32 pid, bool lv_mv_type, + u32 offset, bool input, int value) { - struct qcom_gpio_bank *priv = dev_get_priv(dev); - uint32_t gpio_base = priv->pid + REG_OFFSET(offset); - uint32_t reg_ctl_val; - ulong quirks = dev_get_driver_data(dev); + u32 gpio_base = pid + REG_OFFSET(offset); + u32 reg_ctl_val; int ret = 0;
- /* Some PMICs don't like their GPIOs being configured */ - if (quirks & QCOM_PMIC_QUIRK_READONLY) - return 0; - - /* Disable the GPIO */ - ret = pmic_clrsetbits(dev->parent, gpio_base + REG_EN_CTL, - REG_EN_CTL_ENABLE, 0); - if (ret < 0) - return ret; - /* Select the mode and output */ - if (priv->lv_mv_type) { + if (lv_mv_type) { if (input) reg_ctl_val = REG_CTL_LV_MV_MODE_INPUT; else @@ -114,7 +113,7 @@ static int qcom_gpio_set_direction(struct udevice *dev, unsigned offset, if (ret < 0) return ret;
- if (priv->lv_mv_type && !input) { + if (lv_mv_type && !input) { ret = pmic_reg_write(dev->parent, gpio_base + REG_LV_MV_OUTPUT_CTL, !!value << REG_LV_MV_OUTPUT_CTL_SHIFT); @@ -122,6 +121,29 @@ static int qcom_gpio_set_direction(struct udevice *dev, unsigned offset, return ret; }
+ return 0; +} + +static int qcom_gpio_set_direction(struct udevice *dev, unsigned int offset, + bool input, int value) +{ + struct qcom_gpio_bank *priv = dev_get_priv(dev); + uint32_t gpio_base = priv->pid + REG_OFFSET(offset); + ulong quirks = dev_get_driver_data(dev); + int ret = 0; + + /* Some PMICs don't like their GPIOs being configured */ + if (quirks & QCOM_PMIC_QUIRK_READONLY) + return 0; + + /* Disable the GPIO */ + ret = pmic_clrsetbits(dev->parent, gpio_base + REG_EN_CTL, + REG_EN_CTL_ENABLE, 0); + if (ret < 0) + return ret; + + _qcom_gpio_set_direction(dev, priv->pid, priv->lv_mv_type, offset, input, value); + /* Set the right pull (no pull) */ ret = pmic_reg_write(dev->parent, gpio_base + REG_DIG_PULL_CTL, REG_DIG_PULL_NO_PU); @@ -315,6 +337,134 @@ static int qcom_gpio_of_to_plat(struct udevice *dev) return 0; }
+U_BOOT_DRIVER(qcom_pmic_gpio) = { + .name = "qcom_pmic_gpio", + .id = UCLASS_GPIO, + .of_to_plat = qcom_gpio_of_to_plat, + .probe = qcom_gpio_probe, + .ops = &qcom_gpio_ops, + .priv_auto = sizeof(struct qcom_gpio_bank), +}; + +static const struct pinconf_param qcom_pmic_pinctrl_conf_params[] = { + { "output-high", PIN_CONFIG_OUTPUT_ENABLE, 1 }, + { "output-low", PIN_CONFIG_OUTPUT, 0 }, +}; + +static int qcom_pmic_pinctrl_get_pins_count(struct udevice *dev) +{ + struct qcom_pinctrl_data *priv = dev_get_priv(dev); + + return priv->pin_count; +} + +static const char *qcom_pmic_pinctrl_get_pin_name(struct udevice *dev, unsigned int selector) +{ + static char name[8]; + + /* DT indexes from 1 */ + snprintf(name, sizeof(name), "gpio%u", selector + 1); + + return name; +} + +static int qcom_pmic_pinctrl_pinconf_set(struct udevice *dev, unsigned int selector, + unsigned int param, unsigned int arg) +{ + struct qcom_pinctrl_data *priv = dev_get_priv(dev); + + /* We only support configuring the pin as an output, either low or high */ + return _qcom_gpio_set_direction(dev, priv->pid, + priv->lv_mv_type, + selector, false, + param == PIN_CONFIG_OUTPUT_ENABLE); +} + +static const char *qcom_pmic_pinctrl_get_function_name(struct udevice *dev, unsigned int selector) +{ + if (!selector) + return "normal"; + return NULL; +} + +static int qcom_pmic_pinctrl_generic_get_functions_count(struct udevice *dev) +{ + return 1; +} + +static int qcom_pmic_pinctrl_generic_pinmux_set_mux(struct udevice *dev, unsigned int selector, + unsigned int func_selector) +{ + return 0; +} + +struct pinctrl_ops qcom_pmic_pinctrl_ops = { + .get_pins_count = qcom_pmic_pinctrl_get_pins_count, + .get_pin_name = qcom_pmic_pinctrl_get_pin_name, + .set_state = pinctrl_generic_set_state, + .pinconf_num_params = ARRAY_SIZE(qcom_pmic_pinctrl_conf_params), + .pinconf_params = qcom_pmic_pinctrl_conf_params, + .pinconf_set = qcom_pmic_pinctrl_pinconf_set, + .get_function_name = qcom_pmic_pinctrl_get_function_name, + .get_functions_count = qcom_pmic_pinctrl_generic_get_functions_count, + .pinmux_set = qcom_pmic_pinctrl_generic_pinmux_set_mux, +}; + +static int qcom_pmic_pinctrl_probe(struct udevice *dev) +{ + printf("%s(%s)\n", __func__, dev->name); + + return 0; +} + +static int qcom_pmic_pinctrl_bind(struct udevice *dev) +{ + struct udevice *gpio; + struct qcom_pinctrl_data *priv; + struct qcom_gpio_bank *gpio_priv; + struct gpio_dev_priv *uc_priv; + struct driver *drv; + int ret; + + drv = lists_driver_lookup_name("qcom_pmic_gpio"); + if (!drv) { + debug("Cannot find driver '%s'\n", "qcom_pmic_gpio"); + return -ENOENT; + } + + ret = device_bind_with_driver_data(dev->parent, drv, + ofnode_get_name(dev_ofnode(dev)), + dev_get_driver_data(dev), dev_ofnode(dev), &gpio); + if (ret) + return log_msg_ret("gpio", ret); + + /* Always probe the GPIO device first */ + device_probe(gpio); + gpio_priv = dev_get_priv(gpio); + uc_priv = dev_get_uclass_priv(gpio); + + /* Copy GPIO private data to pinctrl. + * the device model doesn't allocate priv_auto yet so we just manage + * priv ourselves. + */ + priv = malloc(sizeof(*priv)); + priv->pid = gpio_priv->pid; + priv->lv_mv_type = gpio_priv->lv_mv_type; + priv->pin_count = uc_priv->gpio_count; + dev_set_priv(dev, priv); + + return 0; +} + +static int qcom_pmic_pinctrl_remove(struct udevice *dev) +{ + struct qcom_gpio_bank *priv = dev_get_priv(dev); + + free(priv); + + return 0; +} + static const struct udevice_id qcom_gpio_ids[] = { { .compatible = "qcom,pm8916-gpio" }, { .compatible = "qcom,pm8994-gpio" }, /* 22 GPIO's */ @@ -323,13 +473,13 @@ static const struct udevice_id qcom_gpio_ids[] = { { } };
-U_BOOT_DRIVER(qcom_pmic_gpio) = { - .name = "qcom_pmic_gpio", - .id = UCLASS_GPIO, - .of_match = qcom_gpio_ids, - .of_to_plat = qcom_gpio_of_to_plat, - .probe = qcom_gpio_probe, - .ops = &qcom_gpio_ops, - .priv_auto = sizeof(struct qcom_gpio_bank), -};
+U_BOOT_DRIVER(qcom_pmic_pinctrl) = { + .name = "qcom_pmic_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = qcom_gpio_ids, + .ops = &qcom_pmic_pinctrl_ops, + .bind = qcom_pmic_pinctrl_bind, + .remove = qcom_pmic_pinctrl_remove, + .probe = qcom_pmic_pinctrl_probe, +};
Add a config fragment for building U-Boot such that it can be chainloaded by aboot/LK rather than being flashed directly to the aboot partition.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- board/qualcomm/dragonboard410c/configs/chainloaded.config | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/board/qualcomm/dragonboard410c/configs/chainloaded.config b/board/qualcomm/dragonboard410c/configs/chainloaded.config new file mode 100644 index 000000000000..3fd064924a1f --- /dev/null +++ b/board/qualcomm/dragonboard410c/configs/chainloaded.config @@ -0,0 +1,7 @@ +# CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK is not set +CONFIG_TEXT_BASE=0x0 +# CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR is not set +# CONFIG_REMAKE_ELF is not set +CONFIG_POSITION_INDEPENDENT=y +CONFIG_INIT_SP_RELATIVE=y +CONFIG_SYS_INIT_SP_BSS_OFFSET=524288
Use the root compatible strings from upstream Linux, add missing '#clock-cells' property to the gcc node.
Adjust some of the msm8916/apq8016 drivers to use the correct upstream compatible properties and DT bindings.
This prepares us to switch to upstream DT in a future patch.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/dragonboard410c.dts | 25 +++- board/qualcomm/dragonboard410c/dragonboard410c.c | 93 +++--------- doc/device-tree-bindings/usb/ehci-msm.txt | 10 -- drivers/clk/qcom/clock-apq8016.c | 7 +- drivers/phy/qcom/msm8916-usbh-phy.c | 4 +- drivers/pinctrl/qcom/pinctrl-apq8016.c | 2 +- drivers/usb/host/ehci-msm.c | 24 ++- include/dt-bindings/clock/qcom,gcc-msm8916.h | 179 +++++++++++++++++++++++ 8 files changed, 248 insertions(+), 96 deletions(-)
diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index c395e6cc0427..453642b25705 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -12,7 +12,7 @@
/ { model = "Qualcomm Technologies, Inc. Dragonboard 410c"; - compatible = "qcom,dragonboard", "qcom,apq8016-sbc"; + compatible = "qcom,apq8016-sbc", "qcom,apq8016"; qcom,msm-id = <0xce 0x0 0xf8 0x0 0xf9 0x0 0xfa 0x0 0xf7 0x0>; qcom,board-id = <0x10018 0x0>; #address-cells = <0x2>; @@ -79,6 +79,7 @@ reg = <0x1800000 0x80000>; #address-cells = <0x1>; #size-cells = <0x0>; + #clock-cells = <0x1>; };
serial@78b0000 { @@ -91,15 +92,25 @@ };
ehci@78d9000 { - compatible = "qcom,ehci-host"; + compatible = "qcom,ci-hdrc"; reg = <0x78d9000 0x400>; phys = <&ehci_phy>; - };
- ehci_phy: ehci_phy@78d9000 { - compatible = "qcom,apq8016-usbphy"; - reg = <0x78d9000 0x400>; - #phy-cells = <0>; + ulpi { + usb_hs_phy: phy { + compatible = "qcom,usb-hs-phy-msm8916", + "qcom,usb-hs-phy"; + #phy-cells = <0>; + clocks = <&xo_board>, <&gcc GCC_USB2A_PHY_SLEEP_CLK>; + clock-names = "ref", "sleep"; + resets = <&gcc GCC_USB2A_PHY_BCR>, <&usb 0>; + reset-names = "phy", "por"; + qcom,init-seq = /bits/ 8 <0x0 0x44>, + <0x1 0x6b>, + <0x2 0x24>, + <0x3 0x13>; + }; + }; };
sdhci@07824000 { diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 350e0e9e20aa..1adac07569ae 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -9,6 +9,7 @@ #include <common.h> #include <cpu_func.h> #include <dm.h> +#include <dm/pinctrl.h> #include <env.h> #include <init.h> #include <net.h> @@ -23,84 +24,32 @@
-int dram_init(void) -{ - gd->ram_size = PHYS_SDRAM_1_SIZE; - - return 0; -} - -int dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; -} +#define USB_HUB_RESET_GPIO 2 +#define USB_SW_SELECT_GPIO 3
int board_usb_init(int index, enum usb_init_type init) { - static struct udevice *pmic_gpio; - static struct gpio_desc hub_reset, usb_sel; - int ret = 0, node; + struct udevice *usb; + int ret = 0;
- if (!pmic_gpio) { - ret = uclass_get_device_by_name(UCLASS_GPIO, - "pm8916_gpios@c000", - &pmic_gpio); - if (ret < 0) { - printf("Failed to find pm8916_gpios@c000 node.\n"); - return ret; - } + /* USB device */ + ret = device_find_global_by_ofnode(ofnode_path("/soc/usb"), &usb); + if (ret) { + printf("Cannot find USB device\n"); + return ret; }
- /* Try to request gpios needed to start usb host on dragonboard */ - if (!dm_gpio_is_valid(&hub_reset)) { - node = fdt_subnode_offset(gd->fdt_blob, - dev_of_offset(pmic_gpio), - "usb_hub_reset_pm"); - if (node < 0) { - printf("Failed to find usb_hub_reset_pm dt node.\n"); - return node; - } - ret = gpio_request_by_name_nodev(offset_to_ofnode(node), - "gpios", 0, &hub_reset, 0); - if (ret < 0) { - printf("Failed to request usb_hub_reset_pm gpio.\n"); - return ret; - } - } - - if (!dm_gpio_is_valid(&usb_sel)) { - node = fdt_subnode_offset(gd->fdt_blob, - dev_of_offset(pmic_gpio), - "usb_sw_sel_pm"); - if (node < 0) { - printf("Failed to find usb_sw_sel_pm dt node.\n"); - return 0; - } - ret = gpio_request_by_name_nodev(offset_to_ofnode(node), - "gpios", 0, &usb_sel, 0); - if (ret < 0) { - printf("Failed to request usb_sw_sel_pm gpio.\n"); - return ret; - } - } - - if (init == USB_INIT_HOST) { - /* Start USB Hub */ - dm_gpio_set_dir_flags(&hub_reset, - GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); - mdelay(100); - /* Switch usb to host connectors */ - dm_gpio_set_dir_flags(&usb_sel, - GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); - mdelay(100); - } else { /* Device */ - /* Disable hub */ - dm_gpio_set_dir_flags(&hub_reset, GPIOD_IS_OUT); - /* Switch back to device connector */ - dm_gpio_set_dir_flags(&usb_sel, GPIOD_IS_OUT); + /* Select "default" or "device" pinctrl */ + switch (init) { + case USB_INIT_HOST: + pinctrl_select_state(usb, "default"); + break; + case USB_INIT_DEVICE: + pinctrl_select_state(usb, "device"); + break; + default: + debug("Unknown usb_init_type %d\n", init); + break; }
return 0; diff --git a/doc/device-tree-bindings/usb/ehci-msm.txt b/doc/device-tree-bindings/usb/ehci-msm.txt deleted file mode 100644 index 205bb07220fb..000000000000 --- a/doc/device-tree-bindings/usb/ehci-msm.txt +++ /dev/null @@ -1,10 +0,0 @@ -Chipidea EHCI controller (part of OTG controller) used on Qualcomm devices. - -Required properties: -- compatible: must be "qcom,ehci-host" -- reg: start address and size of the registers - -ehci@78d9000 { - compatible = "qcom,ehci-host"; - reg = <0x78d9000 0x400>; -}; diff --git a/drivers/clk/qcom/clock-apq8016.c b/drivers/clk/qcom/clock-apq8016.c index 0af7191cff52..9de0ad5ed32d 100644 --- a/drivers/clk/qcom/clock-apq8016.c +++ b/drivers/clk/qcom/clock-apq8016.c @@ -13,6 +13,7 @@ #include <errno.h> #include <asm/io.h> #include <linux/bitops.h> +#include <dt-bindings/clock/qcom,gcc-msm8916.h>
#include "clock-qcom.h"
@@ -125,13 +126,13 @@ static ulong apq8016_clk_set_rate(struct clk *clk, ulong rate) struct msm_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { - case 0: /* SDC1 */ + case GCC_SDCC1_APPS_CLK: /* SDC1 */ return clk_init_sdc(priv, 0, rate); break; - case 1: /* SDC2 */ + case GCC_SDCC2_APPS_CLK: /* SDC2 */ return clk_init_sdc(priv, 1, rate); break; - case 4: /* UART2 */ + case GCC_BLSP1_UART2_APPS_CLK: /* UART2 */ return clk_init_uart(priv); break; default: diff --git a/drivers/phy/qcom/msm8916-usbh-phy.c b/drivers/phy/qcom/msm8916-usbh-phy.c index 7c9d030a4d8a..f52046f7cb02 100644 --- a/drivers/phy/qcom/msm8916-usbh-phy.c +++ b/drivers/phy/qcom/msm8916-usbh-phy.c @@ -74,7 +74,7 @@ static int msm_phy_probe(struct udevice *dev) { struct msm_phy_priv *priv = dev_get_priv(dev);
- priv->regs = dev_remap_addr(dev); + priv->regs = dev_remap_addr(dev_get_parent(dev)); if (!priv->regs) return -EINVAL;
@@ -96,7 +96,7 @@ static struct phy_ops msm_phy_ops = { };
static const struct udevice_id msm_phy_ids[] = { - { .compatible = "qcom,apq8016-usbphy" }, + { .compatible = "qcom,usb-hs-phy-msm8916" }, { } };
diff --git a/drivers/pinctrl/qcom/pinctrl-apq8016.c b/drivers/pinctrl/qcom/pinctrl-apq8016.c index 8149ffd83cc4..8e698085d78b 100644 --- a/drivers/pinctrl/qcom/pinctrl-apq8016.c +++ b/drivers/pinctrl/qcom/pinctrl-apq8016.c @@ -29,7 +29,7 @@ static const char * const msm_pinctrl_pins[] = { };
static const struct pinctrl_function msm_pinctrl_functions[] = { - {"blsp1_uart", 2}, + {"blsp_uart2", 2}, };
static const char *apq8016_get_function_name(struct udevice *dev, diff --git a/drivers/usb/host/ehci-msm.c b/drivers/usb/host/ehci-msm.c index dd0d153500cb..25960453beae 100644 --- a/drivers/usb/host/ehci-msm.c +++ b/drivers/usb/host/ehci-msm.c @@ -9,6 +9,7 @@
#include <common.h> #include <dm.h> +#include <dm/lists.h> #include <errno.h> #include <usb.h> #include <usb/ehci-ci.h> @@ -119,6 +120,26 @@ static int ehci_usb_of_to_plat(struct udevice *dev) return 0; }
+static int ehci_usb_of_bind(struct udevice *dev) +{ + ofnode ulpi_node = ofnode_first_subnode(dev_ofnode(dev)); + ofnode phy_node; + + if (!ofnode_valid(ulpi_node)) + return 0; + + phy_node = ofnode_first_subnode(ulpi_node); + if (!ofnode_valid(phy_node)) { + printf("%s: ulpi subnode with no phy\n", __func__); + return -ENOENT; + } + + return device_bind_driver_to_node(dev, "msm8916_usbphy", "msm8916_usbphy", + phy_node, NULL); + + return 0; +} + #if defined(CONFIG_CI_UDC) /* Little quirk that MSM needs with Chipidea controller * Must reinit phy after reset @@ -132,7 +153,7 @@ void ci_init_after_reset(struct ehci_ctrl *ctrl) #endif
static const struct udevice_id ehci_usb_ids[] = { - { .compatible = "qcom,ehci-host", }, + { .compatible = "qcom,ci-hdrc", }, { } };
@@ -141,6 +162,7 @@ U_BOOT_DRIVER(usb_ehci) = { .id = UCLASS_USB, .of_match = ehci_usb_ids, .of_to_plat = ehci_usb_of_to_plat, + .bind = ehci_usb_of_bind, .probe = ehci_usb_probe, .remove = ehci_usb_remove, .ops = &ehci_usb_ops, diff --git a/include/dt-bindings/clock/qcom,gcc-msm8916.h b/include/dt-bindings/clock/qcom,gcc-msm8916.h new file mode 100644 index 000000000000..563034406184 --- /dev/null +++ b/include/dt-bindings/clock/qcom,gcc-msm8916.h @@ -0,0 +1,179 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2015 Linaro Limited + */ + +#ifndef _DT_BINDINGS_CLK_MSM_GCC_8916_H +#define _DT_BINDINGS_CLK_MSM_GCC_8916_H + +#define GPLL0 0 +#define GPLL0_VOTE 1 +#define BIMC_PLL 2 +#define BIMC_PLL_VOTE 3 +#define GPLL1 4 +#define GPLL1_VOTE 5 +#define GPLL2 6 +#define GPLL2_VOTE 7 +#define PCNOC_BFDCD_CLK_SRC 8 +#define SYSTEM_NOC_BFDCD_CLK_SRC 9 +#define CAMSS_AHB_CLK_SRC 10 +#define APSS_AHB_CLK_SRC 11 +#define CSI0_CLK_SRC 12 +#define CSI1_CLK_SRC 13 +#define GFX3D_CLK_SRC 14 +#define VFE0_CLK_SRC 15 +#define BLSP1_QUP1_I2C_APPS_CLK_SRC 16 +#define BLSP1_QUP1_SPI_APPS_CLK_SRC 17 +#define BLSP1_QUP2_I2C_APPS_CLK_SRC 18 +#define BLSP1_QUP2_SPI_APPS_CLK_SRC 19 +#define BLSP1_QUP3_I2C_APPS_CLK_SRC 20 +#define BLSP1_QUP3_SPI_APPS_CLK_SRC 21 +#define BLSP1_QUP4_I2C_APPS_CLK_SRC 22 +#define BLSP1_QUP4_SPI_APPS_CLK_SRC 23 +#define BLSP1_QUP5_I2C_APPS_CLK_SRC 24 +#define BLSP1_QUP5_SPI_APPS_CLK_SRC 25 +#define BLSP1_QUP6_I2C_APPS_CLK_SRC 26 +#define BLSP1_QUP6_SPI_APPS_CLK_SRC 27 +#define BLSP1_UART1_APPS_CLK_SRC 28 +#define BLSP1_UART2_APPS_CLK_SRC 29 +#define CCI_CLK_SRC 30 +#define CAMSS_GP0_CLK_SRC 31 +#define CAMSS_GP1_CLK_SRC 32 +#define JPEG0_CLK_SRC 33 +#define MCLK0_CLK_SRC 34 +#define MCLK1_CLK_SRC 35 +#define CSI0PHYTIMER_CLK_SRC 36 +#define CSI1PHYTIMER_CLK_SRC 37 +#define CPP_CLK_SRC 38 +#define CRYPTO_CLK_SRC 39 +#define GP1_CLK_SRC 40 +#define GP2_CLK_SRC 41 +#define GP3_CLK_SRC 42 +#define BYTE0_CLK_SRC 43 +#define ESC0_CLK_SRC 44 +#define MDP_CLK_SRC 45 +#define PCLK0_CLK_SRC 46 +#define VSYNC_CLK_SRC 47 +#define PDM2_CLK_SRC 48 +#define SDCC1_APPS_CLK_SRC 49 +#define SDCC2_APPS_CLK_SRC 50 +#define APSS_TCU_CLK_SRC 51 +#define USB_HS_SYSTEM_CLK_SRC 52 +#define VCODEC0_CLK_SRC 53 +#define GCC_BLSP1_AHB_CLK 54 +#define GCC_BLSP1_SLEEP_CLK 55 +#define GCC_BLSP1_QUP1_I2C_APPS_CLK 56 +#define GCC_BLSP1_QUP1_SPI_APPS_CLK 57 +#define GCC_BLSP1_QUP2_I2C_APPS_CLK 58 +#define GCC_BLSP1_QUP2_SPI_APPS_CLK 59 +#define GCC_BLSP1_QUP3_I2C_APPS_CLK 60 +#define GCC_BLSP1_QUP3_SPI_APPS_CLK 61 +#define GCC_BLSP1_QUP4_I2C_APPS_CLK 62 +#define GCC_BLSP1_QUP4_SPI_APPS_CLK 63 +#define GCC_BLSP1_QUP5_I2C_APPS_CLK 64 +#define GCC_BLSP1_QUP5_SPI_APPS_CLK 65 +#define GCC_BLSP1_QUP6_I2C_APPS_CLK 66 +#define GCC_BLSP1_QUP6_SPI_APPS_CLK 67 +#define GCC_BLSP1_UART1_APPS_CLK 68 +#define GCC_BLSP1_UART2_APPS_CLK 69 +#define GCC_BOOT_ROM_AHB_CLK 70 +#define GCC_CAMSS_CCI_AHB_CLK 71 +#define GCC_CAMSS_CCI_CLK 72 +#define GCC_CAMSS_CSI0_AHB_CLK 73 +#define GCC_CAMSS_CSI0_CLK 74 +#define GCC_CAMSS_CSI0PHY_CLK 75 +#define GCC_CAMSS_CSI0PIX_CLK 76 +#define GCC_CAMSS_CSI0RDI_CLK 77 +#define GCC_CAMSS_CSI1_AHB_CLK 78 +#define GCC_CAMSS_CSI1_CLK 79 +#define GCC_CAMSS_CSI1PHY_CLK 80 +#define GCC_CAMSS_CSI1PIX_CLK 81 +#define GCC_CAMSS_CSI1RDI_CLK 82 +#define GCC_CAMSS_CSI_VFE0_CLK 83 +#define GCC_CAMSS_GP0_CLK 84 +#define GCC_CAMSS_GP1_CLK 85 +#define GCC_CAMSS_ISPIF_AHB_CLK 86 +#define GCC_CAMSS_JPEG0_CLK 87 +#define GCC_CAMSS_JPEG_AHB_CLK 88 +#define GCC_CAMSS_JPEG_AXI_CLK 89 +#define GCC_CAMSS_MCLK0_CLK 90 +#define GCC_CAMSS_MCLK1_CLK 91 +#define GCC_CAMSS_MICRO_AHB_CLK 92 +#define GCC_CAMSS_CSI0PHYTIMER_CLK 93 +#define GCC_CAMSS_CSI1PHYTIMER_CLK 94 +#define GCC_CAMSS_AHB_CLK 95 +#define GCC_CAMSS_TOP_AHB_CLK 96 +#define GCC_CAMSS_CPP_AHB_CLK 97 +#define GCC_CAMSS_CPP_CLK 98 +#define GCC_CAMSS_VFE0_CLK 99 +#define GCC_CAMSS_VFE_AHB_CLK 100 +#define GCC_CAMSS_VFE_AXI_CLK 101 +#define GCC_CRYPTO_AHB_CLK 102 +#define GCC_CRYPTO_AXI_CLK 103 +#define GCC_CRYPTO_CLK 104 +#define GCC_OXILI_GMEM_CLK 105 +#define GCC_GP1_CLK 106 +#define GCC_GP2_CLK 107 +#define GCC_GP3_CLK 108 +#define GCC_MDSS_AHB_CLK 109 +#define GCC_MDSS_AXI_CLK 110 +#define GCC_MDSS_BYTE0_CLK 111 +#define GCC_MDSS_ESC0_CLK 112 +#define GCC_MDSS_MDP_CLK 113 +#define GCC_MDSS_PCLK0_CLK 114 +#define GCC_MDSS_VSYNC_CLK 115 +#define GCC_MSS_CFG_AHB_CLK 116 +#define GCC_OXILI_AHB_CLK 117 +#define GCC_OXILI_GFX3D_CLK 118 +#define GCC_PDM2_CLK 119 +#define GCC_PDM_AHB_CLK 120 +#define GCC_PRNG_AHB_CLK 121 +#define GCC_SDCC1_AHB_CLK 122 +#define GCC_SDCC1_APPS_CLK 123 +#define GCC_SDCC2_AHB_CLK 124 +#define GCC_SDCC2_APPS_CLK 125 +#define GCC_GTCU_AHB_CLK 126 +#define GCC_JPEG_TBU_CLK 127 +#define GCC_MDP_TBU_CLK 128 +#define GCC_SMMU_CFG_CLK 129 +#define GCC_VENUS_TBU_CLK 130 +#define GCC_VFE_TBU_CLK 131 +#define GCC_USB2A_PHY_SLEEP_CLK 132 +#define GCC_USB_HS_AHB_CLK 133 +#define GCC_USB_HS_SYSTEM_CLK 134 +#define GCC_VENUS0_AHB_CLK 135 +#define GCC_VENUS0_AXI_CLK 136 +#define GCC_VENUS0_VCODEC0_CLK 137 +#define BIMC_DDR_CLK_SRC 138 +#define GCC_APSS_TCU_CLK 139 +#define GCC_GFX_TCU_CLK 140 +#define BIMC_GPU_CLK_SRC 141 +#define GCC_BIMC_GFX_CLK 142 +#define GCC_BIMC_GPU_CLK 143 +#define ULTAUDIO_LPAIF_PRI_I2S_CLK_SRC 144 +#define ULTAUDIO_LPAIF_SEC_I2S_CLK_SRC 145 +#define ULTAUDIO_LPAIF_AUX_I2S_CLK_SRC 146 +#define ULTAUDIO_XO_CLK_SRC 147 +#define ULTAUDIO_AHBFABRIC_CLK_SRC 148 +#define CODEC_DIGCODEC_CLK_SRC 149 +#define GCC_ULTAUDIO_PCNOC_MPORT_CLK 150 +#define GCC_ULTAUDIO_PCNOC_SWAY_CLK 151 +#define GCC_ULTAUDIO_AVSYNC_XO_CLK 152 +#define GCC_ULTAUDIO_STC_XO_CLK 153 +#define GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK 154 +#define GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_LPM_CLK 155 +#define GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK 156 +#define GCC_ULTAUDIO_LPAIF_SEC_I2S_CLK 157 +#define GCC_ULTAUDIO_LPAIF_AUX_I2S_CLK 158 +#define GCC_CODEC_DIGCODEC_CLK 159 +#define GCC_MSS_Q6_BIMC_AXI_CLK 160 + +/* Indexes for GDSCs */ +#define BIMC_GDSC 0 +#define VENUS_GDSC 1 +#define MDSS_GDSC 2 +#define JPEG_GDSC 3 +#define VFE_GDSC 4 +#define OXILI_GDSC 5 + +#endif
- compatible = "qcom,apq8016-sbc", "qcom,apq8016"; qcom,msm-id = <0xce 0x0 0xf8 0x0 0xf9 0x0 0xfa 0x0 0xf7 0x0>; qcom,board-id = <0x10018 0x0>; #address-cells = <0x2>;
serial@78b0000 {
ehci@78d9000 {
#phy-cells = <0>;
ulpi {
usb_hs_phy: phy {
"qcom,usb-hs-phy";
#phy-cells = <0>;
<0x1 0x6b>,
<0x2 0x24>,
<0x3 0x13>;
sdhci@07824000 {
- struct udevice *usb;
- int ret = 0;
- if (!pmic_gpio) {
&pmic_gpio);
if (ret < 0) {
return ret;
- /* USB device */
- ret = device_find_global_by_ofnode(ofnode_path("/soc/usb"), &usb);
- if (ret) {
}return ret;
if (node < 0) {
return node;
if (ret < 0) {
return ret;
"usb_sw_sel_pm");
if (node < 0) {
if (ret < 0) {
return ret;
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
-ehci@78d9000 {
switch (clk->id) {
- case GCC_SDCC1_APPS_CLK: /* SDC1 */ return clk_init_sdc(priv, 0, rate); break;
- case GCC_SDCC2_APPS_CLK: /* SDC2 */ return clk_init_sdc(priv, 1, rate); break;
- case GCC_BLSP1_UART2_APPS_CLK: /* UART2 */ return clk_init_uart(priv); break; default:
- priv->regs = dev_remap_addr(dev_get_parent(dev)); if (!priv->regs) return -EINVAL;
- { .compatible = "qcom,usb-hs-phy-msm8916" }, { } };
- ofnode ulpi_node = ofnode_first_subnode(dev_ofnode(dev));
- ofnode phy_node;
- if (!ofnode_valid(ulpi_node))
- phy_node = ofnode_first_subnode(ulpi_node);
- if (!ofnode_valid(phy_node)) {
return -ENOENT;
- return device_bind_driver_to_node(dev, "msm8916_usbphy", "msm8916_usbphy",
phy_node, NULL);
- #if defined(CONFIG_CI_UDC) /* Little quirk that MSM needs with Chipidea controller
- Must reinit phy after reset
- { .compatible = "qcom,ci-hdrc", }, { } };
- .bind = ehci_usb_of_bind, .probe = ehci_usb_probe, .remove = ehci_usb_remove, .ops = &ehci_usb_ops,
- Copyright 2015 Linaro Limited
On Tue, 19 Dec 2023 at 21:34, Caleb Connolly caleb.connolly@linaro.org wrote:
#clock-cells = <0x1>; }; serial@78b0000 {
ehci@78d9000 {
#phy-cells = <0>;
ulpi {
usb_hs_phy: phy {
"qcom,usb-hs-phy";
#phy-cells = <0>;
<0x1 0x6b>,
<0x2 0x24>,
<0x3 0x13>;
}; }; sdhci@07824000 {
int ret = 0, node;
int ret = 0;
if (!pmic_gpio) {
&pmic_gpio);
if (ret < 0) {
return ret;
/* USB device */
if (ret) {
return ret; }
if (node < 0) {
return node;
if (ret < 0) {
return ret;
"usb_sw_sel_pm");
if (node < 0) {
if (ret < 0) {
return ret;
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
Can this pinctrl configuration move to the corresponding USB driver instead?
-Sumit
} return 0;
-ehci@78d9000 {
switch (clk->id) {
case 0: /* SDC1 */
case 1: /* SDC2 */
case 4: /* UART2 */
{"blsp1_uart", 2},
{"blsp_uart2", 2},
ofnode phy_node;
return -ENOENT;
phy_node, NULL);
-- 2.42.1
Hi Sumit,
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
Possibly, this is definitely something where DT is currently lacking, similar discussions in Linux resulted in the USB onboard_hub driver, it would be nice to add support for that U-Boot at some point.
I don't think putting the pinctrl code directly into the USB driver is the right way to go, as it definitely wouldn't be accepted in upstream DT bindings.
-Sumit
On Fri, 22 Dec 2023 at 21:43, Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Sumit,
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
As discussed in the other thread, arch/arm/mach-snapdragon/board_apq8016.c would be a better place for the time being.
-Sumit
-Sumit
-- // Caleb (they/them)
Hi Sumit,
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
I would instead prefer this go in mach-snapdragon/board.c and include a conditional to check for a named pinctrl on the USB device, using "uclass_find_device_by_seq()" to fetch the device would then make this properly generic.
This is really not relevant to this patch series, but is a change that makes sense when introducing support for new boards, let's limit discussion to the other thread [1].
[1]: https://lore.kernel.org/u-boot/f805111d-106e-4904-ae9d-e63596f7db4e@linaro.o...
-Sumit
-Sumit
Hi Sumit,
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
Yes, that can be a further step and I don't expect that to be part of this series. But since this patch is moving stuff, we should move SoC specific bits to mach-snapdragon/board_apq8016.c rather than its opposite to the db410c specific file.
But why? The USB stuff we are discussing here is relevant to existing board support, right?
-Sumit
-Sumit
-Sumit
Hi Sumit,
/* Start USB Hub */
mdelay(100);
mdelay(100);
/* Disable hub */
switch (init) {
case USB_INIT_HOST:
break;
break;
default:
break;
The reason I moved this board code to the board directory is because with this series I'm enforcing that all mach-snapdragon code be generic and built for all Qualcomm platforms. I also did it because while I don't want to break support for db410c, I don't plan to fix it, so this works as a temporary solution until someone who does care about the board (like you) wants to fix it up.
Right, and the existing board is supported with this series. You're suggesting that I spend significantly more time on this series to make supporting your board (which is NOT yet upstream) easier.
My cover letter is very explicit that this series lays the groundwork such that all future Qualcomm boards can be supported in a fully generic way, with no additional board code. I have support for 3 new Qualcomm SoCs and ~6 devices based on this series, and none of that requires adding new board code because I took the time to come up with proper solutions by fixing drivers or DT.
I carved out exceptions for the db410c and db820c because I cannot test all the usecases they support, and finding proper solutions to allow for dropping their board code is a whole lot of work for boards that - unfortunately - I'm not able to prioritize.
The fact that you are working on a board based on db410c is great, it means that you can put the effort in to find a proper generic solution, and ideally we can drop board/qualcomm/dragonboard410c entirely!
I'm *more than* happy to discuss ideas and figure out the right solutions to the remaining board code with you. There are absolutely areas where U-Boot is missing flexibility, and I see this as a good opportunity for us to fix some of that.
It's clear from other threads that restricting the amount of mach/board code in U-Boot is a good way forward, and I would very much like for Qualcomm to lead the way here. There is no good reason why we shouldn't be able to have a single U-Boot binary for all of our supported boards, and it makes testing *so* much easier.
-Sumit
-Sumit
-Sumit
Some of the db410c board support code was written to be generic and placed in mach-snapdragon. However, as the db410c is the only board using this, move the code out of mach-snapdragon. This makes is more obvious what code is relevant for which targets and helps tidy things up a little more.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/mach-snapdragon/Makefile | 2 - arch/arm/mach-snapdragon/include/mach/dram.h | 12 ----- arch/arm/mach-snapdragon/misc.c | 55 ---------------------- board/qualcomm/dragonboard410c/Makefile | 3 +- board/qualcomm/dragonboard410c/dragonboard410c.c | 4 +- .../qualcomm/dragonboard410c/misc.c | 51 +++++++++++++++++++- .../mach => board/qualcomm/dragonboard410c}/misc.h | 1 + 7 files changed, 54 insertions(+), 74 deletions(-)
diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index 3a3a297c1768..d02432df8b04 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -6,6 +6,4 @@ obj-$(CONFIG_SDM845) += sysmap-sdm845.o obj-$(CONFIG_SDM845) += init_sdm845.o obj-$(CONFIG_TARGET_DRAGONBOARD820C) += sysmap-apq8096.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o -obj-y += misc.o -obj-y += dram.o obj-$(CONFIG_TARGET_QCS404EVB) += sysmap-qcs404.o diff --git a/arch/arm/mach-snapdragon/include/mach/dram.h b/arch/arm/mach-snapdragon/include/mach/dram.h deleted file mode 100644 index 0a9eedda414c..000000000000 --- a/arch/arm/mach-snapdragon/include/mach/dram.h +++ /dev/null @@ -1,12 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Snapdragon DRAM - * Copyright (C) 2018 Ramon Fried ramon.fried@gmail.com - */ - -#ifndef DRAM_H -#define DRAM_H - -int msm_fixup_memory(void *blob); - -#endif diff --git a/arch/arm/mach-snapdragon/misc.c b/arch/arm/mach-snapdragon/misc.c deleted file mode 100644 index 7d452f4529b7..000000000000 --- a/arch/arm/mach-snapdragon/misc.c +++ /dev/null @@ -1,55 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Miscellaneous Snapdragon functionality - * - * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com - * - */ - -#include <common.h> -#include <mmc.h> -#include <asm/arch/misc.h> -#include <asm/unaligned.h> - -/* UNSTUFF_BITS macro taken from Linux Kernel: drivers/mmc/core/sd.c */ -#define UNSTUFF_BITS(resp, start, size) \ - ({ \ - const int __size = size; \ - const u32 __mask = (__size < 32 ? 1 << __size : 0) - 1; \ - const int __off = 3 - ((start) / 32); \ - const int __shft = (start) & 31; \ - u32 __res; \ - \ - __res = resp[__off] >> __shft; \ - if (__size + __shft > 32) \ - __res |= resp[__off - 1] << ((32 - __shft) % 32); \ - __res & __mask; \ - }) - -u32 msm_board_serial(void) -{ - struct mmc *mmc_dev; - - mmc_dev = find_mmc_device(0); - if (!mmc_dev) - return 0; - - if (mmc_init(mmc_dev)) - return 0; - - return UNSTUFF_BITS(mmc_dev->cid, 16, 32); -} - -void msm_generate_mac_addr(u8 *mac) -{ - /* use locally adminstrated pool */ - mac[0] = 0x02; - mac[1] = 0x00; - - /* - * Put the 32-bit serial number in the last 32-bit of the MAC address. - * Use big endian order so it is consistent with the serial number - * written as a hexadecimal string, e.g. 0x1234abcd -> 02:00:12:34:ab:cd - */ - put_unaligned_be32(msm_board_serial(), &mac[2]); -} diff --git a/board/qualcomm/dragonboard410c/Makefile b/board/qualcomm/dragonboard410c/Makefile index 1b99c8b0efef..a3ae1a5f9136 100644 --- a/board/qualcomm/dragonboard410c/Makefile +++ b/board/qualcomm/dragonboard410c/Makefile @@ -2,4 +2,5 @@ # # (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com
-obj-y := dragonboard410c.o +obj-y += dragonboard410c.o +obj-y += misc.o diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 1adac07569ae..eea603a4148d 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -18,10 +18,10 @@ #include <asm/global_data.h> #include <asm/gpio.h> #include <fdt_support.h> -#include <asm/arch/dram.h> -#include <asm/arch/misc.h> #include <linux/delay.h>
+#include "misc.h" + DECLARE_GLOBAL_DATA_PTR;
#define USB_HUB_RESET_GPIO 2 diff --git a/arch/arm/mach-snapdragon/dram.c b/board/qualcomm/dragonboard410c/misc.c similarity index 64% rename from arch/arm/mach-snapdragon/dram.c rename to board/qualcomm/dragonboard410c/misc.c index 499dfdf0da6e..27d51ef78914 100644 --- a/arch/arm/mach-snapdragon/dram.c +++ b/board/qualcomm/dragonboard410c/misc.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Onboard memory detection for Snapdragon boards + * Miscellaneous Snapdragon functionality * * (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com * @@ -9,10 +9,56 @@ #include <common.h> #include <dm.h> #include <log.h> +#include <mmc.h> #include <part.h> #include <smem.h> #include <fdt_support.h> -#include <asm/arch/dram.h> +#include <asm/unaligned.h> + +#include "misc.h" + +/* UNSTUFF_BITS macro taken from Linux Kernel: drivers/mmc/core/sd.c */ +#define UNSTUFF_BITS(resp, start, size) \ + ({ \ + const int __size = size; \ + const u32 __mask = (__size < 32 ? 1 << __size : 0) - 1; \ + const int __off = 3 - ((start) / 32); \ + const int __shft = (start) & 31; \ + u32 __res; \ + \ + __res = resp[__off] >> __shft; \ + if (__size + __shft > 32) \ + __res |= resp[__off - 1] << ((32 - __shft) % 32); \ + __res & __mask; \ + }) + +u32 msm_board_serial(void) +{ + struct mmc *mmc_dev; + + mmc_dev = find_mmc_device(0); + if (!mmc_dev) + return 0; + + if (mmc_init(mmc_dev)) + return 0; + + return UNSTUFF_BITS(mmc_dev->cid, 16, 32); +} + +void msm_generate_mac_addr(u8 *mac) +{ + /* use locally adminstrated pool */ + mac[0] = 0x02; + mac[1] = 0x00; + + /* + * Put the 32-bit serial number in the last 32-bit of the MAC address. + * Use big endian order so it is consistent with the serial number + * written as a hexadecimal string, e.g. 0x1234abcd -> 02:00:12:34:ab:cd + */ + put_unaligned_be32(msm_board_serial(), &mac[2]); +}
#define SMEM_USABLE_RAM_PARTITION_TABLE 402 #define RAM_PART_NAME_LENGTH 16 @@ -97,3 +143,4 @@ int msm_fixup_memory(void *blob)
return 0; } + diff --git a/arch/arm/mach-snapdragon/include/mach/misc.h b/board/qualcomm/dragonboard410c/misc.h similarity index 87% rename from arch/arm/mach-snapdragon/include/mach/misc.h rename to board/qualcomm/dragonboard410c/misc.h index c60e3e472470..fe44caf51b18 100644 --- a/arch/arm/mach-snapdragon/include/mach/misc.h +++ b/board/qualcomm/dragonboard410c/misc.h @@ -9,5 +9,6 @@
u32 msm_board_serial(void); void msm_generate_mac_addr(u8 *mac); +int msm_fixup_memory(void *blob);
#endif
Hi Caleb,
This change will be incompatible with HMIBSC board support being proposed in the other thread. It will lead to further code duplication among boards. You should rather reverse it to keep APQ8016 SoC specific changes in mach-snapdragon and let the derivative boards use them.
-Sumit
- Snapdragon DRAM
- Copyright (C) 2018 Ramon Fried ramon.fried@gmail.com
- Miscellaneous Snapdragon functionality
- (C) Copyright 2018 Ramon Fried ramon.fried@gmail.com
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
+#include "misc.h"
- Onboard memory detection for Snapdragon boards
+#include "misc.h"
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
#endif
-- 2.42.1
On 20/12/2023 13:47, Sumit Garg wrote:
Hi Caleb,
Re-capping our off-list discussion: the HMIBSC board only depends on the usb init code and button handling code.
The usb init code will be moved to mach-snapdragon in the next revision of this series, and the button code will eventually be handled by my proposed "button cmd" patch.
The smem code (msm_fixup_memory()) will be dropped in favour of using DT as the source of truth.
-Sumit
- Snapdragon DRAM
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
+#include "misc.h"
+#include "misc.h"
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
#endif
-- 2.42.1
- Snapdragon DRAM
u32 __res; \
__res & __mask; \
- if (!mmc_dev)
- mac[0] = 0x02;
- mac[1] = 0x00;
+#include "misc.h"
+#include "misc.h"
u32 __res; \
__res & __mask; \
- if (!mmc_dev)
- mac[0] = 0x02;
- mac[1] = 0x00;
return 0; }
Spurious newline
#endif
With this fixed: Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
- Snapdragon DRAM
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
+#include "misc.h"
+#include "misc.h"
u32 __res; \
__res & __mask; \
if (!mmc_dev)
mac[0] = 0x02;
mac[1] = 0x00;
#endif
-- 2.42.1
db820c predated support for prepending the kernel image header automatically, drop it's custom linker script and head.S in favour of this generic support.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/mach-snapdragon/Kconfig | 1 + board/qualcomm/dragonboard820c/Makefile | 1 - board/qualcomm/dragonboard820c/head.S | 33 --------- board/qualcomm/dragonboard820c/u-boot.lds | 111 ------------------------------ 4 files changed, 1 insertion(+), 145 deletions(-)
diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index ad6671081910..f897c393464f 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -45,6 +45,7 @@ config TARGET_DRAGONBOARD410C
config TARGET_DRAGONBOARD820C bool "96Boards Dragonboard 820C" + select LINUX_KERNEL_IMAGE_HEADER imply CLK_QCOM_APQ8096 imply PINCTRL_QCOM_APQ8096 imply BUTTON_QCOM_PMIC diff --git a/board/qualcomm/dragonboard820c/Makefile b/board/qualcomm/dragonboard820c/Makefile index 643311f5b3ba..2ae6d16364aa 100644 --- a/board/qualcomm/dragonboard820c/Makefile +++ b/board/qualcomm/dragonboard820c/Makefile @@ -3,4 +3,3 @@ # (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@gmail.com
obj-y := dragonboard820c.o -extra-y += head.o diff --git a/board/qualcomm/dragonboard820c/head.S b/board/qualcomm/dragonboard820c/head.S deleted file mode 100644 index b052a858fd32..000000000000 --- a/board/qualcomm/dragonboard820c/head.S +++ /dev/null @@ -1,33 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * ARM64 header for proper chain-loading with Little Kernel. - * - * Little Kernel shipped with Dragonboard820C boots standard Linux images for - * ARM64. This file adds header that is required to boot U-Boot properly. - * - * For details see: - * https://www.kernel.org/doc/Documentation/arm64/booting.txt - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - */ - -#include <config.h> - -/* - * per document in linux/Doc/arm64/booting.text - */ -.global _arm64_header -_arm64_header: - b _start - .word 0 - .quad CONFIG_TEXT_BASE-PHYS_SDRAM_1 /* Image load offset, LE */ - .quad 0 /* Effective size of kernel image, little-endian */ - .quad 0 /* kernel flags, little-endian */ - .quad 0 /* reserved */ - .quad 0 /* reserved */ - .quad 0 /* reserved */ - .byte 0x41 /* Magic number, "ARM\x64" */ - .byte 0x52 - .byte 0x4d - .byte 0x64 - .word 0 /* reserved (used for PE COFF offset) */ diff --git a/board/qualcomm/dragonboard820c/u-boot.lds b/board/qualcomm/dragonboard820c/u-boot.lds deleted file mode 100644 index 5251b59fbe76..000000000000 --- a/board/qualcomm/dragonboard820c/u-boot.lds +++ /dev/null @@ -1,111 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Override linker script for fastboot-readable images - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - * - * Based on arch/arm/cpu/armv8/u-boot.lds (Just add header) - */ - -OUTPUT_FORMAT("elf64-littleaarch64", "elf64-littleaarch64", "elf64-littleaarch64") -OUTPUT_ARCH(aarch64) -ENTRY(_arm64_header) -SECTIONS -{ - . = 0x00000000; - - . = ALIGN(8); - .text : - { - *(.__image_copy_start) - board/qualcomm/dragonboard820c/head.o (.text*) - CPUDIR/start.o (.text*) - } - - /* This needs to come before *(.text*) */ - .efi_runtime : { - __efi_runtime_start = .; - *(.text.efi_runtime*) - *(.rodata.efi_runtime*) - *(.data.efi_runtime*) - __efi_runtime_stop = .; - } - - .text_rest : - { - *(.text*) - } - - . = ALIGN(8); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } - - . = ALIGN(8); - .data : { - *(.data*) - } - - . = ALIGN(8); - - . = .; - - . = ALIGN(8); - __u_boot_list : { - KEEP(*(SORT(__u_boot_list*))); - } - - . = ALIGN(8); - - .efi_runtime_rel : { - __efi_runtime_rel_start = .; - *(.rel*.efi_runtime) - *(.rel*.efi_runtime.*) - __efi_runtime_rel_stop = .; - } - - . = ALIGN(8); - - .image_copy_end : - { - *(.__image_copy_end) - } - - . = ALIGN(8); - - .rel_dyn_start : - { - *(.__rel_dyn_start) - } - - .rela.dyn : { - *(.rela*) - } - - .rel_dyn_end : - { - *(.__rel_dyn_end) - } - - _end = .; - - . = ALIGN(8); - - .bss_start : { - KEEP(*(.__bss_start)); - } - - .bss : { - *(.bss*) - . = ALIGN(8); - } - - .bss_end : { - KEEP(*(.__bss_end)); - } - - /DISCARD/ : { *(.dynsym) } - /DISCARD/ : { *(.dynstr*) } - /DISCARD/ : { *(.dynamic*) } - /DISCARD/ : { *(.plt*) } - /DISCARD/ : { *(.interp*) } - /DISCARD/ : { *(.gnu*) } -}
- select LINUX_KERNEL_IMAGE_HEADER imply CLK_QCOM_APQ8096 imply PINCTRL_QCOM_APQ8096 imply BUTTON_QCOM_PMIC
- ARM64 header for proper chain-loading with Little Kernel.
- Little Kernel shipped with Dragonboard820C boots standard Linux images for
- ARM64. This file adds header that is required to boot U-Boot properly.
- For details see:
- (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com
- per document in linux/Doc/arm64/booting.text
- b _start
- .word 0
- .byte 0x52
- .byte 0x4d
- .byte 0x64
- Override linker script for fastboot-readable images
- Based on arch/arm/cpu/armv8/u-boot.lds (Just add header)
- . = 0x00000000;
- . = ALIGN(8);
- .text :
- .efi_runtime : {
- .text_rest :
*(.text*)
- . = ALIGN(8);
- . = ALIGN(8);
- .data : {
*(.data*)
- . = ALIGN(8);
- . = ALIGN(8);
- __u_boot_list : {
- . = ALIGN(8);
- . = ALIGN(8);
- .image_copy_end :
- . = ALIGN(8);
- .rel_dyn_start :
*(.__rel_dyn_start)
- .rela.dyn : {
*(.rela*)
- .rel_dyn_end :
*(.__rel_dyn_end)
- _end = .;
- . = ALIGN(8);
- .bss_start : {
- .bss : {
*(.bss*)
. = ALIGN(8);
- .bss_end : {
Easy code removal!
Historically, Qualcomm boards have relied on heavy hardcoding in U-Boot, in many cases to the specific SoC but also to the board itself (e.g. memory map). This has been largely resolved by modernising the Qualcomm drivers in U-Boot, however the board code still largely follows this model.
This patch removes the board specific memory maps and duplicated board init code, replacing it with generic init code.
The memory map is now built at runtime based on data read from DT, this allows for the memory map to be provided without having to recompile U-Boot. Support is also added for booting with appended DTBs, so that the first-stage bootloader can populate the memory map for us.
The sdm845 specific init code is dropped entirely, it set an environment variable depending on if a button was pressed, but this variable wasn't used in U-Boot, and could be written to use the button command instead.
The KASLR detection is also dropped as with appended dtb, the kaslr seed can be read directly from the DTB passed to U-Boot.
A new qcom_defconfig is added, with the aim of providing a generic U-Boot configuration that will work on as many Qualcomm boards as possible. It replaces the defconfig files for the Dragonboard 845c, Galaxy S9, and QCS404 EVB. For now the db410c and 820c are excluded as they still have some board code left.
Similarly, the config headers for db845c, starqltechn, and qcs404-evb are replaced by a single qcom header.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/Kconfig | 3 + arch/arm/dts/Makefile | 9 +- arch/arm/mach-snapdragon/Kconfig | 96 +++---------- arch/arm/mach-snapdragon/Makefile | 6 +- arch/arm/mach-snapdragon/board.c | 168 +++++++++++++++++++++++ arch/arm/mach-snapdragon/init_sdm845.c | 73 ---------- arch/arm/mach-snapdragon/sysmap-apq8016.c | 31 ----- arch/arm/mach-snapdragon/sysmap-apq8096.c | 31 ----- arch/arm/mach-snapdragon/sysmap-qcs404.c | 43 ------ arch/arm/mach-snapdragon/sysmap-sdm845.c | 31 ----- board/qualcomm/dragonboard410c/Kconfig | 15 -- board/qualcomm/dragonboard410c/dragonboard410c.c | 10 -- board/qualcomm/dragonboard820c/Kconfig | 15 -- board/qualcomm/dragonboard820c/dragonboard820c.c | 39 +----- board/qualcomm/dragonboard845c/Kconfig | 12 -- board/qualcomm/qcs404-evb/Kconfig | 15 -- board/qualcomm/qcs404-evb/qcs404-evb.c | 21 +-- configs/dragonboard410c_defconfig | 6 +- configs/dragonboard820c_defconfig | 6 +- configs/dragonboard845c_defconfig | 29 ---- configs/qcom_defconfig | 73 ++++++++++ configs/qcs404evb_defconfig | 5 +- configs/starqltechn_defconfig | 41 ------ include/configs/dragonboard845c.h | 20 --- include/configs/qcom.h | 21 +++ include/configs/qcs404-evb.h | 20 --- include/configs/sdm845.h | 26 ---- 27 files changed, 304 insertions(+), 561 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index bd48131292e3..e814910cb495 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1075,6 +1075,9 @@ config ARCH_SNAPDRAGON select OF_SEPARATE select SMEM select SPMI + select OF_BOARD + select SAVE_PREV_BL_FDT_ADDR + select LINUX_KERNEL_IMAGE_HEADER imply CMD_DM
config ARCH_SOCFPGA diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 55aceb51cdb0..ec63749fa912 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -600,10 +600,11 @@ dtb-$(CONFIG_TARGET_SL28) += fsl-ls1028a-kontron-sl28.dtb \
dtb-$(CONFIG_TARGET_TEN64) += fsl-ls1088a-ten64.dtb
-dtb-$(CONFIG_TARGET_DRAGONBOARD410C) += dragonboard410c.dtb -dtb-$(CONFIG_TARGET_DRAGONBOARD820C) += dragonboard820c.dtb -dtb-$(CONFIG_TARGET_STARQLTECHN) += starqltechn.dtb -dtb-$(CONFIG_TARGET_QCS404EVB) += qcs404-evb.dtb +dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb \ + dragonboard820c.dtb \ + dragonboard845c.dtb \ + starqltechn.dtb \ + qcs404-evb.dtb
dtb-$(CONFIG_TARGET_STEMMY) += ste-ux500-samsung-stemmy.dtb
diff --git a/arch/arm/mach-snapdragon/Kconfig b/arch/arm/mach-snapdragon/Kconfig index f897c393464f..96e44e2c5491 100644 --- a/arch/arm/mach-snapdragon/Kconfig +++ b/arch/arm/mach-snapdragon/Kconfig @@ -3,6 +3,9 @@ if ARCH_SNAPDRAGON config SYS_SOC default "snapdragon"
+config SYS_VENDOR + default "qualcomm" + config SYS_MALLOC_F_LEN default 0x2000
@@ -12,91 +15,24 @@ config SPL_SYS_MALLOC_F config SPL_SYS_MALLOC_F_LEN default 0x2000
-config SDM845 - bool "Qualcomm Snapdragon 845 SoC" - select LINUX_KERNEL_IMAGE_HEADER - imply CLK_QCOM_SDM845 - imply PINCTRL_QCOM_SDM845 - imply BUTTON_QCOM_PMIC - config LNX_KRNL_IMG_TEXT_OFFSET_BASE default 0x80000000
-choice - prompt "Snapdragon board select" - -config TARGET_DRAGONBOARD410C - bool "96Boards Dragonboard 410C" - select BOARD_LATE_INIT - select ENABLE_ARM_SOC_BOOT0_HOOK - imply CLK_QCOM_APQ8016 - imply PINCTRL_QCOM_APQ8016 - imply BUTTON_QCOM_PMIC +config SYS_BOARD + string "Qualcomm custom board" help - Support for 96Boards Dragonboard 410C. This board complies with - 96Board Open Platform Specifications. Features: - - Qualcomm Snapdragon 410C SoC - APQ8016 (4xCortex A53, Adreno 306) - - 1GiB RAM - - 8GiB eMMC, uSD slot - - WiFi, Bluetooth and GPS module - - 2x Host, 1x Device USB port - - HDMI - - 20-pin low speed and 40-pin high speed expanders, 4 LED, 3 buttons + The Dragonboard 410c and 820c have additional board init + code that isn't shared with other Qualcomm boards. + Based on this option board/qualcomm/<CONFIG_SYS_BOARD> will + be used.
-config TARGET_DRAGONBOARD820C - bool "96Boards Dragonboard 820C" - select LINUX_KERNEL_IMAGE_HEADER - imply CLK_QCOM_APQ8096 - imply PINCTRL_QCOM_APQ8096 - imply BUTTON_QCOM_PMIC +config SYS_CONFIG_NAME + string "Board configuration name" + default SYS_BOARD if SYS_BOARD != "" + default "qcom" help - Support for 96Boards Dragonboard 820C. This board complies with - 96Board Open Platform Specifications. Features: - - Qualcomm Snapdragon 820C SoC - APQ8096 (4xKyro CPU) - - 3GiB RAM - - 32GiB UFS drive - -config TARGET_DRAGONBOARD845C - bool "96Boards Dragonboard 845C" - help - Support for 96Boards Dragonboard 845C aka Robotics RB3 Development - Platform. This board complies with 96Boards Open Platform - Specifications. Features: - - Qualcomm Snapdragon SDA845 SoC - - 4GiB RAM - - 64GiB UFS drive - select MISC_INIT_R - select SDM845 - -config TARGET_STARQLTECHN - bool "Samsung S9 SM-G9600(starqltechn)" - help - Support for Samsung S9 SM-G9600(starqltechn) board. - Features: - - Qualcomm Snapdragon SDM845 SoC - - 4GiB RAM - - 64GiB UFS drive - select MISC_INIT_R - select SDM845 - -config TARGET_QCS404EVB - bool "Qualcomm Technologies, Inc. QCS404 EVB" - select LINUX_KERNEL_IMAGE_HEADER - imply CLK_QCOM_QCS404 - imply PINCTRL_QCOM_QCS404 - help - Support for Qualcomm Technologies, Inc. QCS404 evaluation board. - Features: - - Qualcomm Snapdragon QCS404 SoC - - 1GiB RAM - - 8GiB eMMC, uSD slot - -endchoice - -source "board/qualcomm/dragonboard410c/Kconfig" -source "board/qualcomm/dragonboard820c/Kconfig" -source "board/qualcomm/dragonboard845c/Kconfig" -source "board/samsung/starqltechn/Kconfig" -source "board/qualcomm/qcs404-evb/Kconfig" + This option contains information about board configuration name. + Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header + will be used for board configuration.
endif diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index d02432df8b04..857171e593da 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -2,8 +2,4 @@ # # (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com
-obj-$(CONFIG_SDM845) += sysmap-sdm845.o -obj-$(CONFIG_SDM845) += init_sdm845.o -obj-$(CONFIG_TARGET_DRAGONBOARD820C) += sysmap-apq8096.o -obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o -obj-$(CONFIG_TARGET_QCS404EVB) += sysmap-qcs404.o +obj-y += board.o diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c new file mode 100644 index 000000000000..bf9b57682178 --- /dev/null +++ b/arch/arm/mach-snapdragon/board.c @@ -0,0 +1,168 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Common initialisation for Qualcomm Snapdragon boards. + * + * Copyright (c) 2023 Linaro Ltd. + * Author: Caleb Connolly caleb.connolly@linaro.org + */ + +#define LOG_DEBUG + +#include <asm/armv8/mmu.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/psci.h> +#include <asm/system.h> +#include <dm/device.h> +#include <env.h> +#include <init.h> +#include <linux/arm-smccc.h> +#include <linux/bug.h> +#include <linux/psci.h> +#include <linux/sizes.h> +#include <malloc.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct mm_region rbx_mem_map[CONFIG_NR_DRAM_BANKS + 2] = { { 0 } }; + +struct mm_region *mem_map = rbx_mem_map; + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + int ret; + phys_addr_t start, size; + + ret = fdtdec_setup_memory_banksize(); + if (ret < 0) + return ret; + + if (CONFIG_NR_DRAM_BANKS < 2) + return 0; + + /* Sort our RAM banks -_- */ + start = gd->bd->bi_dram[1].start; + size = gd->bd->bi_dram[1].size; + if (size && start < gd->bd->bi_dram[0].start) { + printf("dram_init_banksize: Sorting DRAM banks\n"); + gd->bd->bi_dram[1].start = gd->bd->bi_dram[0].start; + gd->bd->bi_dram[1].size = gd->bd->bi_dram[0].size; + gd->bd->bi_dram[0].start = start; + gd->bd->bi_dram[0].size = size; + } + + return 0; +} + +static void show_psci_version(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(ARM_PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0, 0, 0, 0, 0, &res); + + debug("PSCI: v%ld.%ld\n", + PSCI_VERSION_MAJOR(res.a0), + PSCI_VERSION_MINOR(res.a0)); +} + +void *board_fdt_blob_setup(int *err) +{ + phys_addr_t fdt; + /* Return DTB pointer passed by ABL */ + *err = 0; + fdt = get_prev_bl_fdt_addr(); + + /* + * If we bail then the board will simply not boot, instead let's + * try and use the FDT built into U-Boot if there is one... + * This avoids having a hard dependency on the previous stage bootloader + */ + if (IS_ENABLED(CONFIG_OF_SEPARATE) && (!fdt || fdt != ALIGN(fdt, SZ_4K))) { + debug("%s: Using built in FDT, bootloader gave us %#llx\n", __func__, fdt); + return (void *)gd->fdt_blob; + } + + return (void *)fdt; +} + +void reset_cpu(void) +{ + psci_system_reset(); +} + +/* + * Some boards still need board specific init code, they can implement that by + * overriding this function. + * + * FIXME: get rid of board specific init code + */ +void __weak qcom_board_init(void) +{ +} + +int board_init(void) +{ + show_psci_version(); + qcom_board_init(); + return 0; +} + +static void build_mem_map(void) +{ + int i; + + /* + * Ensure the peripheral block is sized to correctly cover the address range + * up to the first memory bank. + * Don't map the first page to ensure that we actually trigger an abort on a + * null pointer access rather than just hanging. + * FIXME: we should probably split this into more precise regions + */ + mem_map[0].phys = 0x1000; + mem_map[0].virt = mem_map[0].phys; + mem_map[0].size = gd->bd->bi_dram[0].start - mem_map[0].phys; + mem_map[0].attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN; + + debug("Configured memory map:\n"); + debug(" 0x%016llx - 0x%016llx: Peripheral block\n", + mem_map[0].phys, mem_map[0].phys + mem_map[0].size); + + /* + * Now add memory map entries for each DRAM bank, ensuring we don't + * overwrite the list terminator + */ + for (i = 0; i < ARRAY_SIZE(rbx_mem_map) - 2 && gd->bd->bi_dram[i].size; i++) { + if (i == ARRAY_SIZE(rbx_mem_map) - 1) { + log_warning("Too many DRAM banks!\n"); + break; + } + mem_map[i + 1].phys = gd->bd->bi_dram[i].start; + mem_map[i + 1].virt = mem_map[i + 1].phys; + mem_map[i + 1].size = gd->bd->bi_dram[i].size; + mem_map[i + 1].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE; + + debug(" 0x%016llx - 0x%016llx: DDR bank %d\n", + mem_map[i + 1].phys, mem_map[i + 1].phys + mem_map[i + 1].size, i); + } +} + +u64 get_page_table_size(void) +{ + return SZ_64K; +} + +void enable_caches(void) +{ + build_mem_map(); + + icache_enable(); + dcache_enable(); +} diff --git a/arch/arm/mach-snapdragon/init_sdm845.c b/arch/arm/mach-snapdragon/init_sdm845.c deleted file mode 100644 index 067acc9a6f44..000000000000 --- a/arch/arm/mach-snapdragon/init_sdm845.c +++ /dev/null @@ -1,73 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Common init part for boards based on SDM845 - * - * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com - */ - -#include <button.h> -#include <init.h> -#include <env.h> -#include <common.h> -#include <asm/system.h> -#include <asm/gpio.h> -#include <dm.h> - -DECLARE_GLOBAL_DATA_PTR; - -int dram_init(void) -{ - return fdtdec_setup_mem_size_base(); -} - -void reset_cpu(void) -{ - psci_system_reset(); -} - -__weak int board_init(void) -{ - return 0; -} - -/* Check for vol- and power buttons */ -__weak int misc_init_r(void) -{ - struct udevice *btn; - int ret; - enum button_state_t state; - - ret = button_get_by_label("pwrkey", &btn); - if (ret < 0) { - printf("Couldn't find power button!\n"); - return ret; - } - - state = button_get_state(btn); - if (state == BUTTON_ON) { - env_set("key_power", "1"); - printf("Power button pressed\n"); - } else { - env_set("key_power", "0"); - } - - /* - * search for kaslr address, set by primary bootloader by searching first - * 0x100 relocated bytes at u-boot's initial load address range - */ - uintptr_t start = gd->ram_base; - uintptr_t end = start + 0x800000; - u8 *addr = (u8 *)start; - phys_addr_t *relocaddr = (phys_addr_t *)gd->relocaddr; - u32 block_size = 0x1000; - - while (memcmp(addr, relocaddr, 0x100) && (uintptr_t)addr < end) - addr += block_size; - - if ((uintptr_t)addr >= end) - printf("KASLR not found in range 0x%lx - 0x%lx", start, end); - else - env_set_addr("KASLR", addr); - - return 0; -} diff --git a/arch/arm/mach-snapdragon/sysmap-apq8016.c b/arch/arm/mach-snapdragon/sysmap-apq8016.c deleted file mode 100644 index ffa3f9aa3532..000000000000 --- a/arch/arm/mach-snapdragon/sysmap-apq8016.c +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm APQ8016 memory map - * - * (C) Copyright 2016 Mateusz Kulikowski mateusz.kulikowski@gmail.com - */ - -#include <common.h> -#include <asm/armv8/mmu.h> - -static struct mm_region apq8016_mem_map[] = { - { - .virt = 0x0UL, /* Peripheral block */ - .phys = 0x0UL, /* Peripheral block */ - .size = 0x8000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, /* DDR */ - .phys = 0x80000000UL, /* DDR */ - .size = 0x80000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = apq8016_mem_map; diff --git a/arch/arm/mach-snapdragon/sysmap-apq8096.c b/arch/arm/mach-snapdragon/sysmap-apq8096.c deleted file mode 100644 index 0614f8308d02..000000000000 --- a/arch/arm/mach-snapdragon/sysmap-apq8096.c +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm APQ8096 memory map - * - * (C) Copyright 2017 Jorge Ramirez Ortiz jorge.ramirez-ortiz@linaro.org - */ - -#include <common.h> -#include <asm/armv8/mmu.h> - -static struct mm_region apq8096_mem_map[] = { - { - .virt = 0x0UL, /* Peripheral block */ - .phys = 0x0UL, /* Peripheral block */ - .size = 0x10000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, /* DDR */ - .phys = 0x80000000UL, /* DDR */ - .size = 0xC0000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = apq8096_mem_map; diff --git a/arch/arm/mach-snapdragon/sysmap-qcs404.c b/arch/arm/mach-snapdragon/sysmap-qcs404.c deleted file mode 100644 index 64ca4adf1bd1..000000000000 --- a/arch/arm/mach-snapdragon/sysmap-qcs404.c +++ /dev/null @@ -1,43 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm QCS404 memory map - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -#include <common.h> -#include <asm/armv8/mmu.h> - -static struct mm_region qcs404_mem_map[] = { - { - .virt = 0x0UL, /* Peripheral block */ - .phys = 0x0UL, /* Peripheral block */ - .size = 0x8000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, /* DDR */ - .phys = 0x80000000UL, /* DDR */ - .size = 0x05900000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0x89600000UL, /* DDR */ - .phys = 0x89600000UL, /* DDR */ - .size = 0x162000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - .virt = 0xa0000000UL, /* DDR */ - .phys = 0xa0000000UL, /* DDR */ - .size = 0x20000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = qcs404_mem_map; diff --git a/arch/arm/mach-snapdragon/sysmap-sdm845.c b/arch/arm/mach-snapdragon/sysmap-sdm845.c deleted file mode 100644 index 721ac411665c..000000000000 --- a/arch/arm/mach-snapdragon/sysmap-sdm845.c +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm SDM845 memory map - * - * (C) Copyright 2021 Dzmitry Sankouski dsankousk@gmail.com - */ - -#include <common.h> -#include <asm/armv8/mmu.h> - -static struct mm_region sdm845_mem_map[] = { - { - .virt = 0x0UL, /* Peripheral block */ - .phys = 0x0UL, /* Peripheral block */ - .size = 0x10000000UL, - .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | - PTE_BLOCK_NON_SHARE | - PTE_BLOCK_PXN | PTE_BLOCK_UXN - }, { - .virt = 0x80000000UL, /* DDR */ - .phys = 0x80000000UL, /* DDR */ - .size = 0x200000000UL, /* 8GiB - maximum allowed memory */ - .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | - PTE_BLOCK_INNER_SHARE - }, { - /* List terminator */ - 0, - } -}; - -struct mm_region *mem_map = sdm845_mem_map; diff --git a/board/qualcomm/dragonboard410c/Kconfig b/board/qualcomm/dragonboard410c/Kconfig deleted file mode 100644 index 03bd7ae309cd..000000000000 --- a/board/qualcomm/dragonboard410c/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_DRAGONBOARD410C - -config SYS_BOARD - default "dragonboard410c" - -config SYS_VENDOR - default "qualcomm" - -config SYS_SOC - default "apq8016" - -config SYS_CONFIG_NAME - default "dragonboard410c" - -endif diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index eea603a4148d..e403ecf0ad7c 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -77,11 +77,6 @@ int misc_init_r(void) return 0; }
-int board_init(void) -{ - return 0; -} - int board_late_init(void) { char serial[16]; @@ -126,8 +121,3 @@ int ft_board_setup(void *blob, struct bd_info *bd) "local-bd-address", mac, ARP_HLEN, 1); return 0; } - -void reset_cpu(void) -{ - psci_system_reset(); -} diff --git a/board/qualcomm/dragonboard820c/Kconfig b/board/qualcomm/dragonboard820c/Kconfig deleted file mode 100644 index aff9af527128..000000000000 --- a/board/qualcomm/dragonboard820c/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_DRAGONBOARD820C - -config SYS_BOARD - default "dragonboard820c" - -config SYS_VENDOR - default "qualcomm" - -config SYS_SOC - default "apq8096" - -config SYS_CONFIG_NAME - default "dragonboard820c" - -endif diff --git a/board/qualcomm/dragonboard820c/dragonboard820c.c b/board/qualcomm/dragonboard820c/dragonboard820c.c index 2f0db628368b..ac7de711c588 100644 --- a/board/qualcomm/dragonboard820c/dragonboard820c.c +++ b/board/qualcomm/dragonboard820c/dragonboard820c.c @@ -27,24 +27,6 @@
-int dram_init(void) -{ - gd->ram_size = PHYS_SDRAM_SIZE; - - return 0; -} - -int dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - gd->bd->bi_dram[1].start = PHYS_SDRAM_2; - gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; - - return 0; -} - static void sdhci_power_init(void) { const u32 TLMM_PULL_MASK = 0x3; @@ -113,28 +95,9 @@ static void sdhci_power_init(void) rclk[i].val << rclk[i].bit); }
-static void show_psci_version(void) -{ - struct arm_smccc_res res; - - arm_smccc_smc(ARM_PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0, 0, 0, 0, 0, &res); - - printf("PSCI: v%ld.%ld\n", - PSCI_VERSION_MAJOR(res.a0), - PSCI_VERSION_MINOR(res.a0)); -} - -int board_init(void) +void qcom_board_init(void) { sdhci_power_init(); - show_psci_version(); - - return 0; -} - -void reset_cpu(void) -{ - psci_system_reset(); }
/* Check for vol- button - if pressed - stop autoboot */ diff --git a/board/qualcomm/dragonboard845c/Kconfig b/board/qualcomm/dragonboard845c/Kconfig deleted file mode 100644 index 52fdff288d59..000000000000 --- a/board/qualcomm/dragonboard845c/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_DRAGONBOARD845C - -config SYS_BOARD - default "dragonboard845c" - -config SYS_CONFIG_NAME - default "dragonboard845c" - -config SYS_VENDOR - default "qualcomm" - -endif diff --git a/board/qualcomm/qcs404-evb/Kconfig b/board/qualcomm/qcs404-evb/Kconfig deleted file mode 100644 index 32657c7d5e31..000000000000 --- a/board/qualcomm/qcs404-evb/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_QCS404EVB - -config SYS_BOARD - default "qcs404-evb" - -config SYS_VENDOR - default "qualcomm" - -config SYS_SOC - default "qcs404" - -config SYS_CONFIG_NAME - default "qcs404-evb" - -endif diff --git a/board/qualcomm/qcs404-evb/qcs404-evb.c b/board/qualcomm/qcs404-evb/qcs404-evb.c index 249dca7e72f1..1a4b1f97a3ae 100644 --- a/board/qualcomm/qcs404-evb/qcs404-evb.c +++ b/board/qualcomm/qcs404-evb/qcs404-evb.c @@ -14,16 +14,10 @@ #include <asm/gpio.h> #include <asm/global_data.h> #include <fdt_support.h> -#include <asm/arch/dram.h>
-int dram_init(void) -{ - return fdtdec_setup_mem_size_base(); -} - -int board_init(void) +void qcom_board_init(void) { struct udevice *pmic_gpio; struct gpio_desc usb_vbus_boost_pin; @@ -34,29 +28,22 @@ int board_init(void) &pmic_gpio); if (ret < 0) { printf("Failed to find pms405_gpios@c000 node.\n"); - return ret; + return; }
node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(pmic_gpio), "usb_vbus_boost_pin"); if (node < 0) { printf("Failed to find usb_hub_reset_pm dt node.\n"); - return node; + return; } ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0, &usb_vbus_boost_pin, 0); if (ret < 0) { printf("Failed to request usb_hub_reset_pm gpio.\n"); - return ret; + return; }
dm_gpio_set_dir_flags(&usb_vbus_boost_pin, GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); - - return 0; -} - -void reset_cpu(void) -{ - psci_system_reset(); } diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index b338326e34c0..4274150eebe9 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -1,9 +1,10 @@ CONFIG_ARM=y +CONFIG_SYS_BOARD="dragonboard410c" CONFIG_COUNTER_FREQUENCY=19000000 +CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_TEXT_BASE=0x8f600000 CONFIG_SYS_MALLOC_LEN=0x802000 -CONFIG_NR_DRAM_BANKS=1 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x2000 @@ -38,7 +39,9 @@ CONFIG_CMD_TIMER=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_PART=2 +CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y +CONFIG_CLK_QCOM_APQ8016=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x91000000 CONFIG_FASTBOOT_FLASH=y @@ -52,6 +55,7 @@ CONFIG_MMC_SDHCI_MSM=y CONFIG_PHY=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_PINCTRL_QCOM_APQ8016=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y CONFIG_MSM_SERIAL=y diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index 15d12bb0831d..5a8cfb7d7a25 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y +CONFIG_SYS_BOARD="dragonboard820c" CONFIG_COUNTER_FREQUENCY=19000000 CONFIG_ARCH_SNAPDRAGON=y CONFIG_TEXT_BASE=0x80080000 CONFIG_SYS_MALLOC_LEN=0x804000 -CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x4000 CONFIG_DEFAULT_DEVICE_TREE="dragonboard820c" -CONFIG_TARGET_DRAGONBOARD820C=y CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 820C" CONFIG_SYS_LOAD_ADDR=0x80080000 CONFIG_DISTRO_DEFAULTS=y @@ -35,12 +34,15 @@ CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_EXT4_INTERFACE="mmc" CONFIG_ENV_EXT4_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_BUTTON_QCOM_PMIC=y CONFIG_CLK=y +CONFIG_CLK_QCOM_APQ8096=y CONFIG_QCOM_PMIC_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MSM=y CONFIG_PINCTRL=y CONFIG_PINCONF=y +CONFIG_PINCTRL_QCOM_APQ8096=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y CONFIG_MSM_SERIAL=y diff --git a/configs/dragonboard845c_defconfig b/configs/dragonboard845c_defconfig deleted file mode 100644 index a69d82761a8d..000000000000 --- a/configs/dragonboard845c_defconfig +++ /dev/null @@ -1,29 +0,0 @@ -CONFIG_ARM=y -CONFIG_SKIP_LOWLEVEL_INIT=y -CONFIG_COUNTER_FREQUENCY=19000000 -CONFIG_POSITION_INDEPENDENT=y -CONFIG_ARCH_SNAPDRAGON=y -CONFIG_DEFAULT_DEVICE_TREE="dragonboard845c" -CONFIG_TARGET_DRAGONBOARD845C=y -CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 845C" -CONFIG_SYS_LOAD_ADDR=0x80000000 -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_BOOTDELAY=5 -CONFIG_SAVE_PREV_BL_FDT_ADDR=y -CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_CBSIZE=512 -CONFIG_CMD_GPIO=y -# CONFIG_NET is not set -CONFIG_CLK=y -CONFIG_MSM_GPIO=y -CONFIG_QCOM_PMIC_GPIO=y -CONFIG_PINCTRL=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_QCOM=y -CONFIG_MSM_GENI_SERIAL=y -CONFIG_SPMI_MSM=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig new file mode 100644 index 000000000000..8bd6313d50e4 --- /dev/null +++ b/configs/qcom_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_POSITION_INDEPENDENT=y +CONFIG_ARCH_SNAPDRAGON=y +CONFIG_DEFAULT_DEVICE_TREE="dragonboard845c" +CONFIG_SYS_LOAD_ADDR=0x0 +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_BOOTSTD_FULL=y +# CONFIG_BOOTMETH_EXTLINUX is not set +# CONFIG_BOOTMETH_VBE is not set +# CONFIG_BOOTMETH_SCRIPT is not set +CONFIG_BOOTDELAY=1 +CONFIG_USE_PREBOOT=y +CONFIG_LOG_MAX_LEVEL=9 +CONFIG_LOG_DEFAULT_LEVEL=4 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_SYS_MAXARGS=64 +CONFIG_SYS_CBSIZE=512 +CONFIG_CMD_BOOTMENU=y +CONFIG_CMD_CLK=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_UFS=y +CONFIG_CMD_USB=y +CONFIG_CMD_CAT=y +CONFIG_CMD_BMP=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_LOG=y +CONFIG_EFI_PARTITION=y +# CONFIG_NET is not set +CONFIG_CLK=y +CONFIG_CLK_QCOM_QCS404=y +CONFIG_CLK_QCOM_SDM845=y +CONFIG_MSM_GPIO=y +CONFIG_QCOM_PMIC_GPIO=y +CONFIG_DM_KEYBOARD=y +CONFIG_BUTTON_KEYBOARD=y +CONFIG_BUTTON_QCOM_PMIC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_MSM=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_QCOM_QCS404=y +CONFIG_PINCTRL_QCOM_SDM845=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_QCOM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_MSM_SERIAL=y +CONFIG_MSM_GENI_SERIAL=y +CONFIG_SPMI_MSM=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SMBIOS=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_UFS=y +CONFIG_VIDEO=y +# CONFIG_VIDEO_FONT_8X16 is not set +CONFIG_VIDEO_FONT_16X32=y +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_NO_FB_CLEAR=y +CONFIG_VIDEO_SIMPLE=y +CONFIG_HEXDUMP=y +# CONFIG_GENERATE_SMBIOS_TABLE is not set +CONFIG_LMB_MAX_REGIONS=64 diff --git a/configs/qcs404evb_defconfig b/configs/qcs404evb_defconfig index 9e72f64f7849..7daaa449ffbd 100644 --- a/configs/qcs404evb_defconfig +++ b/configs/qcs404evb_defconfig @@ -1,11 +1,10 @@ CONFIG_ARM=y +CONFIG_SYS_BOARD="qcs404-evb" CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=19000000 CONFIG_POSITION_INDEPENDENT=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_DEFAULT_DEVICE_TREE="qcs404-evb" -CONFIG_DM_RESET=y -CONFIG_TARGET_QCS404EVB=y CONFIG_IDENT_STRING="\nQualcomm QCS404-EVB" CONFIG_SYS_LOAD_ADDR=0x80000000 CONFIG_FIT=y @@ -31,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_NET is not set CONFIG_CLK=y +CONFIG_CLK_QCOM_QCS404=y CONFIG_MSM_GPIO=y CONFIG_QCOM_PMIC_GPIO=y CONFIG_MISC=y @@ -42,6 +42,7 @@ CONFIG_PHY=y CONFIG_PHY_QCOM_USB_HS_28NM=y CONFIG_PHY_QCOM_USB_SS=y CONFIG_PINCTRL=y +CONFIG_PINCTRL_QCOM_QCS404=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y CONFIG_MSM_SERIAL=y diff --git a/configs/starqltechn_defconfig b/configs/starqltechn_defconfig deleted file mode 100644 index 5b85ce5fe96f..000000000000 --- a/configs/starqltechn_defconfig +++ /dev/null @@ -1,41 +0,0 @@ -CONFIG_ARM=y -CONFIG_SKIP_LOWLEVEL_INIT=y -CONFIG_COUNTER_FREQUENCY=19000000 -CONFIG_POSITION_INDEPENDENT=y -CONFIG_ARCH_SNAPDRAGON=y -CONFIG_DEFAULT_DEVICE_TREE="starqltechn" -CONFIG_TARGET_STARQLTECHN=y -CONFIG_IDENT_STRING="\nSamsung S9 SM-G9600" -CONFIG_SYS_LOAD_ADDR=0x80000000 -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_BOOTDELAY=0 -CONFIG_SAVE_PREV_BL_FDT_ADDR=y -CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_CBSIZE=512 -CONFIG_SYS_PBSIZE=532 -CONFIG_CMD_BOOTMENU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_BMP=y -# CONFIG_NET is not set -CONFIG_BUTTON=y -CONFIG_CLK=y -CONFIG_MSM_GPIO=y -CONFIG_QCOM_PMIC_GPIO=y -CONFIG_DM_KEYBOARD=y -CONFIG_BUTTON_KEYBOARD=y -CONFIG_PINCTRL=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_QCOM=y -CONFIG_MSM_GENI_SERIAL=y -CONFIG_SPMI_MSM=y -CONFIG_VIDEO=y -# CONFIG_VIDEO_FONT_8X16 is not set -CONFIG_VIDEO_FONT_16X32=y -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_VIDEO_SIMPLE=y -CONFIG_VIDEO_DT_SIMPLEFB=y -CONFIG_LMB_MAX_REGIONS=64 diff --git a/include/configs/dragonboard845c.h b/include/configs/dragonboard845c.h deleted file mode 100644 index 14a8a2ca049e..000000000000 --- a/include/configs/dragonboard845c.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Configuration file for Dragonboard 845c, based on Qualcomm SDA845 chip - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -#ifndef __CONFIGS_SDM845_H -#define __CONFIGS_SDM845_H - -#include <linux/sizes.h> - -#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600 } - -#define CFG_EXTRA_ENV_SETTINGS \ - "bootm_size=0x5000000\0" \ - "bootm_low=0x80000000\0" \ - "bootcmd=bootm $prevbl_initrd_start_addr\0" - -#endif diff --git a/include/configs/qcom.h b/include/configs/qcom.h new file mode 100644 index 000000000000..e50b3bce5cdd --- /dev/null +++ b/include/configs/qcom.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration file for Qualcomm Snapdragon boards + * + * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com + * (C) Copyright 2023 Linaro Ltd. + */ + +#ifndef __CONFIGS_SNAPDRAGON_H +#define __CONFIGS_SNAPDRAGON_H + +#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600 } + +/* Load addressed are calculated during board_late_init(). See arm/mach-snapdragon/board.c */ +#define CFG_EXTRA_ENV_SETTINGS \ + "stdin=serial,button-kbd\0" \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" \ + "bootcmd=bootm $prevbl_initrd_start_addr\0" + +#endif diff --git a/include/configs/qcs404-evb.h b/include/configs/qcs404-evb.h deleted file mode 100644 index 9501d43665e9..000000000000 --- a/include/configs/qcs404-evb.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Configuration file for QCS404 evaluation board - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -#ifndef __CONFIGS_QCS404EVB_H -#define __CONFIGS_QCS404EVB_H - -#include <linux/sizes.h> - -#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600 } - -#define CFG_EXTRA_ENV_SETTINGS \ - "bootm_size=0x5000000\0" \ - "bootm_low=0x80000000\0" \ - "bootcmd=bootm $prevbl_initrd_start_addr\0" - -#endif diff --git a/include/configs/sdm845.h b/include/configs/sdm845.h deleted file mode 100644 index 5ad8569b2152..000000000000 --- a/include/configs/sdm845.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Configuration file for boards, based on Qualcomm SDM845 chip - * - * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com - */ - -#ifndef __CONFIGS_SDM845_H -#define __CONFIGS_SDM845_H - -#include <linux/sizes.h> - -#define CFG_SYS_BAUDRATE_TABLE { 115200, 230400, 460800, 921600 } - -#define CFG_EXTRA_ENV_SETTINGS \ - "bootm_size=0x4000000\0" \ - "bootm_low=0x80000000\0" \ - "stdin=serial,button-kbd\0" \ - "stdout=serial,vidconsole\0" \ - "stderr=serial,vidconsole\0" \ - "preboot=source $prevbl_initrd_start_addr:prebootscript\0" \ - "bootcmd=source $prevbl_initrd_start_addr:bootscript\0" - -/* Size of malloc() pool */ - -#endif
select OF_BOARD
config ARCH_SOCFPGA
starqltechn.dtb \
qcs404-evb.dtb
+config SYS_VENDOR
- config SYS_MALLOC_F_LEN default 0x2000
-config SDM845
-choice
+config SYS_BOARD
- string "Qualcomm custom board" help
- 1GiB RAM
- HDMI
be used.
- string "Board configuration name"
- default SYS_BOARD if SYS_BOARD != ""
- default "qcom" help
- 3GiB RAM
- 32GiB UFS drive
- help
- 4GiB RAM
- 64GiB UFS drive
- select SDM845
- help
Features:
- 4GiB RAM
- 64GiB UFS drive
- select SDM845
- help
Features:
- 1GiB RAM
-endchoice
endif
- Common initialisation for Qualcomm Snapdragon boards.
- Copyright (c) 2023 Linaro Ltd.
- Author: Caleb Connolly caleb.connolly@linaro.org
+#define LOG_DEBUG
- int ret;
- phys_addr_t start, size;
- ret = fdtdec_setup_memory_banksize();
- if (ret < 0)
return ret;
- if (CONFIG_NR_DRAM_BANKS < 2)
- /* Sort our RAM banks -_- */
- start = gd->bd->bi_dram[1].start;
- size = gd->bd->bi_dram[1].size;
- if (size && start < gd->bd->bi_dram[0].start) {
- debug("PSCI: v%ld.%ld\n",
- phys_addr_t fdt;
- /* Return DTB pointer passed by ABL */
- *err = 0;
- fdt = get_prev_bl_fdt_addr();
- if (IS_ENABLED(CONFIG_OF_SEPARATE) && (!fdt || fdt != ALIGN(fdt, SZ_4K))) {
- return (void *)fdt;
- Some boards still need board specific init code, they can implement that by
- overriding this function.
- FIXME: get rid of board specific init code
- qcom_board_init();
- int i;
- mem_map[0].phys = 0x1000;
- mem_map[0].virt = mem_map[0].phys;
- mem_map[0].size = gd->bd->bi_dram[0].start - mem_map[0].phys;
- mem_map[0].attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) |
- debug("Configured memory map:\n");
- debug(" 0x%016llx - 0x%016llx: Peripheral block\n",
- for (i = 0; i < ARRAY_SIZE(rbx_mem_map) - 2 && gd->bd->bi_dram[i].size; i++) {
break;
- return SZ_64K;
- build_mem_map();
- icache_enable();
- dcache_enable();
- Common init part for boards based on SDM845
- (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com
- int ret;
- if (ret < 0) {
return ret;
- } else {
addr += block_size;
- else
- Qualcomm APQ8016 memory map
- (C) Copyright 2016 Mateusz Kulikowski mateusz.kulikowski@gmail.com
0,
- Qualcomm APQ8096 memory map
- (C) Copyright 2017 Jorge Ramirez Ortiz jorge.ramirez-ortiz@linaro.org
0,
- Qualcomm QCS404 memory map
- (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org
0,
- Qualcomm SDM845 memory map
- (C) Copyright 2021 Dzmitry Sankouski dsankousk@gmail.com
0,
-config SYS_BOARD
-config SYS_VENDOR
-config SYS_SOC
- default "apq8016"
-config SYS_BOARD
-config SYS_VENDOR
-config SYS_SOC
- default "apq8096"
-config SYS_BOARD
-config SYS_VENDOR
-config SYS_BOARD
-config SYS_VENDOR
-config SYS_SOC
- default "qcs404"
return ret;
return;
return node;
} ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0, &usb_vbus_boost_pin, 0); if (ret < 0) { printf("Failed to request usb_hub_reset_pm gpio.\n");return;
return ret;
return;
- Configuration file for Dragonboard 845c, based on Qualcomm SDA845 chip
- Configuration file for Qualcomm Snapdragon boards
- (C) Copyright 2023 Linaro Ltd.
- Configuration file for QCS404 evaluation board
- Configuration file for boards, based on Qualcomm SDM845 chip
-#endif
Nice cleanup, the dynamic memory layout code is neat!
It's looks good overall:
Heavily inspired by Apple board code. Use the LMB allocator to configure load addresses at runtime, and implement a lookup table for selecting a devicetree.
As some Qualcomm RBx boards have different RAM capacities and base addresses, it isn't possible to hardcode these regions.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/Kconfig | 1 + arch/arm/mach-snapdragon/board.c | 35 ++++++++++++++++++++++++ board/qualcomm/dragonboard410c/dragonboard410c.c | 2 +- 3 files changed, 37 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e814910cb495..5ed9cbf378fa 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1075,6 +1075,7 @@ config ARCH_SNAPDRAGON select OF_SEPARATE select SMEM select SPMI + select BOARD_LATE_INIT select OF_BOARD select SAVE_PREV_BL_FDT_ADDR select LINUX_KERNEL_IMAGE_HEADER diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index bf9b57682178..b00f536d38b4 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -20,6 +20,7 @@ #include <linux/bug.h> #include <linux/psci.h> #include <linux/sizes.h> +#include <lmb.h> #include <malloc.h>
DECLARE_GLOBAL_DATA_PTR; @@ -112,6 +113,40 @@ int board_init(void) return 0; }
+void __weak qcom_late_init(void) +{ +} + +#define KERNEL_COMP_SIZE SZ_64M +#define SZ_96M (SZ_64M + SZ_32M) + +#define addr_alloc(lmb, size) lmb_alloc(lmb, size, SZ_2M) + +/* Stolen from arch/arm/mach-apple/board.c */ +int board_late_init(void) +{ + struct lmb lmb; + u32 status = 0; + + lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); + + /* We need to be fairly conservative here as we support boards with just 1G of TOTAL RAM */ + status |= env_set_hex("kernel_addr_r", addr_alloc(&lmb, SZ_128M)); + status |= env_set_hex("ramdisk_addr_r", addr_alloc(&lmb, SZ_96M)); + status |= env_set_hex("kernel_comp_addr_r", addr_alloc(&lmb, KERNEL_COMP_SIZE)); + status |= env_set_hex("kernel_comp_size", KERNEL_COMP_SIZE); + status |= env_set_hex("scriptaddr", addr_alloc(&lmb, SZ_4M)); + status |= env_set_hex("pxefile_addr_r", addr_alloc(&lmb, SZ_4M)); + status |= env_set_hex("fdt_addr_r", addr_alloc(&lmb, SZ_2M)); + + if (status) + log_warning("%s: Failed to set run time variables\n", __func__); + + qcom_late_init(); + + return 0; +} + static void build_mem_map(void) { int i; diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index e403ecf0ad7c..2a502c7c2841 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -77,7 +77,7 @@ int misc_init_r(void) return 0; }
-int board_late_init(void) +int qcom_late_init(void) { char serial[16];
- select BOARD_LATE_INIT select OF_BOARD select SAVE_PREV_BL_FDT_ADDR select LINUX_KERNEL_IMAGE_HEADER
This patch should have been adjusted to use SZ_128M, I already confirmed this to work on all boards. Somehow the old version crept in.
- struct lmb lmb;
- u32 status = 0;
- lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob);
- /* We need to be fairly conservative here as we support boards with just 1G of TOTAL RAM */
- status |= env_set_hex("kernel_addr_r", addr_alloc(&lmb, SZ_128M));
- status |= env_set_hex("ramdisk_addr_r", addr_alloc(&lmb, SZ_96M));
- status |= env_set_hex("kernel_comp_addr_r", addr_alloc(&lmb, KERNEL_COMP_SIZE));
- status |= env_set_hex("kernel_comp_size", KERNEL_COMP_SIZE);
- status |= env_set_hex("scriptaddr", addr_alloc(&lmb, SZ_4M));
- status |= env_set_hex("pxefile_addr_r", addr_alloc(&lmb, SZ_4M));
- status |= env_set_hex("fdt_addr_r", addr_alloc(&lmb, SZ_2M));
- if (status)
- qcom_late_init();
With just a few basic rules, we can generate the $fdtfile environment variable to match the format used in Linux. This uses the root compatible property inside u-boot, with specific handling for the Dragonboard845c which is a special case, and for the qrb robotics boards.
This is known to work on supported platforms, and lets us avoid having a big lookup table.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/mach-snapdragon/board.c | 101 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 101 insertions(+)
diff --git a/arch/arm/mach-snapdragon/board.c b/arch/arm/mach-snapdragon/board.c index b00f536d38b4..752166ea7563 100644 --- a/arch/arm/mach-snapdragon/board.c +++ b/arch/arm/mach-snapdragon/board.c @@ -113,6 +113,106 @@ int board_init(void) return 0; }
+/* Sets up the "board", and "soc" environment variables as well as constructing the devicetree + * path, with a few quirks to handle non-standard dtb filenames. This is not meant to be a + * comprehensive solution to automatically picking the DTB, but aims to be correct for the + * majority case. For most devices it should be possible to make this algorithm work by + * adjusting the root compatible property in the U-Boot DTS. Handling devices with multiple + * variants that are all supported by a single U-Boot image will require implementing device- + * specific detection. + */ +static void configure_env(void) +{ + const char *first_compat, *last_compat; + char *tmp; + char buf[32] = { 0 }; + /* + * Most DTB filenames follow the scheme: qcom/<soc>-[vendor]-<board>.dtb + * The vendor is skipped when it's a Qualcomm reference board, or the + * db845c. + */ + char dt_path[64] = { 0 }; + int compat_count, ret; + ofnode root; + + root = ofnode_root(); + /* This is almost always 2, but be explicit that we want the first and last compatibles + * not the first and second. + */ + compat_count = ofnode_read_string_count(root, "compatible"); + if (compat_count < 2) { + log_warning("%s: only one root compatible bailing!\n", __func__); + return; + } + + /* The most specific device compatible (e.g. "thundercomm,db845c") */ + ret = ofnode_read_string_index(root, "compatible", 0, &first_compat); + if (ret < 0) { + log_warning("Can't read first compatible\n"); + return; + } + + /* The last compatible is always the SoC compatible */ + ret = ofnode_read_string_index(root, "compatible", compat_count - 1, &last_compat); + if (ret < 0) { + log_warning("Can't read second compatible\n"); + return; + } + + /* Copy the second compat (e.g. "qcom,sdm845") into buf */ + strlcpy(buf, last_compat, sizeof(buf) - 1); + tmp = buf; + + /* strsep() is destructive, it replaces the comma with a \0 */ + if (!strsep(&tmp, ",")) { + log_warning("second compatible '%s' has no ','\n", buf); + return; + } + + /* tmp now points to just the "sdm845" part of the string */ + env_set("soc", tmp); + + /* Now figure out the "board" part from the first compatible */ + memset(buf, 0, sizeof(buf)); + strlcpy(buf, first_compat, sizeof(buf) - 1); + tmp = buf; + + /* The Qualcomm reference boards (RBx, HDK, etc) */ + if (!strncmp("qcom", buf, strlen("qcom"))) { + /* + * They all have the first compatible as "qcom,<soc>-<board>" + * (e.g. "qcom,qrb5165-rb5"). We extract just the part after + * the dash. + */ + if (!strsep(&tmp, "-")) { + log_warning("compatible '%s' has no '-'\n", buf); + return; + } + /* tmp is now "rb5" */ + env_set("board", tmp); + } else { + if (!strsep(&tmp, ",")) { + log_warning("compatible '%s' has no ','\n", buf); + return; + } + /* for thundercomm we just want the bit after the comma (e.g. "db845c"), + * for all other boards we replace the comma with a '-' and take both + * (e.g. "oneplus-enchilada") + */ + if (!strncmp("thundercomm", buf, strlen("thundercomm"))) { + env_set("board", tmp); + } else { + *(tmp - 1) = '-'; + env_set("board", buf); + } + } + + /* Now build the full path name */ + snprintf(dt_path, sizeof(dt_path), "qcom/%s-%s.dtb", + env_get("soc"), env_get("board")); + env_set("fdtfile", dt_path); +} + void __weak qcom_late_init(void) { } @@ -142,6 +242,7 @@ int board_late_init(void) if (status) log_warning("%s: Failed to set run time variables\n", __func__);
+ configure_env(); qcom_late_init();
- path, with a few quirks to handle non-standard dtb filenames. This is not meant to be a
- comprehensive solution to automatically picking the DTB, but aims to be correct for the
- majority case. For most devices it should be possible to make this algorithm work by
- adjusting the root compatible property in the U-Boot DTS. Handling devices with multiple
- variants that are all supported by a single U-Boot image will require implementing device-
- specific detection.
- const char *first_compat, *last_compat;
- char *tmp;
- char buf[32] = { 0 };
* db845c.
- char dt_path[64] = { 0 };
- int compat_count, ret;
- ofnode root;
- root = ofnode_root();
- /* This is almost always 2, but be explicit that we want the first and last compatibles
- compat_count = ofnode_read_string_count(root, "compatible");
- if (compat_count < 2) {
return;
- /* The most specific device compatible (e.g. "thundercomm,db845c") */
- ret = ofnode_read_string_index(root, "compatible", 0, &first_compat);
- if (ret < 0) {
return;
- /* The last compatible is always the SoC compatible */
- ret = ofnode_read_string_index(root, "compatible", compat_count - 1, &last_compat);
- if (ret < 0) {
return;
- /* Copy the second compat (e.g. "qcom,sdm845") into buf */
- strlcpy(buf, last_compat, sizeof(buf) - 1);
- tmp = buf;
- /* strsep() is destructive, it replaces the comma with a \0 */
- if (!strsep(&tmp, ",")) {
return;
- /* tmp now points to just the "sdm845" part of the string */
- env_set("soc", tmp);
- /* Now figure out the "board" part from the first compatible */
- memset(buf, 0, sizeof(buf));
- strlcpy(buf, first_compat, sizeof(buf) - 1);
- tmp = buf;
- /* The Qualcomm reference boards (RBx, HDK, etc) */
- if (!strncmp("qcom", buf, strlen("qcom"))) {
* the dash.
return;
- } else {
return;
} else {
*(tmp - 1) = '-';
- /* Now build the full path name */
- snprintf(dt_path, sizeof(dt_path), "qcom/%s-%s.dtb",
- env_set("fdtfile", dt_path);
- void __weak qcom_late_init(void) { }
Nice, hope it will still fit for all future boards!
Replace the board specific docs with a generic board.rst file which documents the build/boot process for the sdm845 and qcs404 boards now that the only differences are the DTB in use.
At the same time, create a debugging page to document some useful snippets and tips for working with Qualcomm platforms.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- doc/board/qualcomm/board.rst | 119 ++++++++++++++++++++++++++++ doc/board/qualcomm/debugging.rst | 61 +++++++++++++++ doc/board/qualcomm/index.rst | 4 +- doc/board/qualcomm/qcs404.rst | 79 ------------------- doc/board/qualcomm/sdm845.rst | 162 --------------------------------------- 5 files changed, 182 insertions(+), 243 deletions(-)
diff --git a/doc/board/qualcomm/board.rst b/doc/board/qualcomm/board.rst new file mode 100644 index 000000000000..093048eee0a6 --- /dev/null +++ b/doc/board/qualcomm/board.rst @@ -0,0 +1,119 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Dzmitry Sankouski dsankouski@gmail.com + +Qualcomm generic boards +======================= + +About this +---------- +This document describes how to build and run U-Boot for Qualcomm generic +boards. Right now the generic target supports the Snapdragon 845 SoC, however +it's expected to support more SoCs going forward. + +SDM845 - hi-end qualcomm chip, introduced in late 2017. +Mostly used in flagship phones and tablets of 2018. + +The current boot flow support loading u-boot as an Android boot image via +Qualcomm's UEFI-based ABL (Android) Bootloader. The DTB used by U-Boot will +be appended to the U-Boot image the same way as when booting Linux. U-Boot +will then retrieve the DTB during init. This way the memory layout and KASLR +offset will be populated by ABL. + +Installation +------------ +Build +^^^^^ +Setup ``CROSS_COMPILE`` for aarch64 and build U-Boot for your board:: + + $ export CROSS_COMPILE=<aarch64 toolchain prefix> + $ make <your board name here, see Boards section>_defconfig + $ make + +This will build ``u-boot-nodtb.bin`` in the configured output directory. + +Generate FIT image +^^^^^^^^^^^^^^^^^^ +See doc/uImage.FIT for more details + +Pack android boot image +^^^^^^^^^^^^^^^^^^^^^^^ +We'll assemble android boot image with ``u-boot-nodtb.bin`` instead of linux kernel, +and FIT image instead of ``initramfs``. Android bootloader expect gzipped kernel +with appended dtb, so let's mimic linux to satisfy stock bootloader. + +Boards +------ + +starqlte +^^^^^^^^ + +The starqltechn is a production board for Samsung S9 (SM-G9600) phone, +based on the Qualcomm SDM845 SoC. + +This device is supported by the common qcom_defconfig. + +The DTB is called "sdm845-samsung-starqltechn.dtb" + +More information can be found on the `Samsung S9 page`_. + +dragonboard845c +^^^^^^^^^^^^^^^ + +The dragonboard845c is a Qualcomm Robotics RB3 Development Platform, based on +the Qualcomm SDM845 SoC. + +This device is supported by the common qcom_defconfig + +The DTB is called "sdm845-db845c.dtb" + +More information can be found on the `DragonBoard 845c page`_. + +qcs404-evb +^^^^^^^^^^ + +The QCS404 EvB is a Qualcomm Development Platform, based on the Qualcomm QCS404 SoC. + +This device is supported by the common qcom_defconfig + +The DTB is called "qcs404-evb-4000.dtb" + +Building steps +-------------- + +Steps: + +- Build u-boot:: + + $ export CROSS_COMPILE=<aarch64 toolchain prefix> + $ make qcom_defconfig + $ make + +- gzip u-boot:: + + gzip u-boot-nodtb.bin + +- Append dtb to gzipped u-boot:: + + cat u-boot-nodtb.bin.gz arch/arm/dts/your-board.dtb > u-boot-nodtb.bin.gz-dtb + +- A ``qcom.its`` file can be found in ``board/qualcomm/generic/`` + directory. It expects a folder as ``qcom_imgs/`` in the main directory + containing pre-built kernel, dts and ramdisk images. See ``qcom.its`` + for full path to images:: + + mkimage -f qcom.its qcom.itb + +- Now we've got everything to build android boot image:: + + mkbootimg --kernel u-boot-nodtb.bin.gz-dtb --ramdisk db845c.itb \ + --output boot.img --pagesize 4096 --base 0x80000000 + +- Flash boot.img using fastboot and erase dtbo to avoid conflicts with our DTB: + + .. code-block:: bash + + fastboot flash boot boot.img + fastboot erase dtbo + +.. _Samsung S9 page: https://en.wikipedia.org/wiki/Samsung_Galaxy_S9 +.. _DragonBoard 845c page: https://www.96boards.org/product/rb3-platform/ diff --git a/doc/board/qualcomm/debugging.rst b/doc/board/qualcomm/debugging.rst new file mode 100644 index 000000000000..1c35d1909d12 --- /dev/null +++ b/doc/board/qualcomm/debugging.rst @@ -0,0 +1,61 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Caleb Connolly caleb.connolly@linaro.org + +Qualcomm debugging +================== + +About this +---------- + +This page describes how to enable early UART and other debugging techniques +for Qualcomm boards. + +Enable debug UART +----------------- + +Newer boards (SDM845 and newer, those with GENI SE UART) +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Open ``configs/qcom_defconfig`` and add the following snippet to the bottom: + + CONFIG_BAUDRATE=115200 + + # Uncomment to enable UART pre-relocation + CONFIG_DEBUG_UART=y + CONFIG_DEBUG_UART_ANNOUNCE=y + # This is the address of the debug-uart peripheral + # The value here is for SDM845, other platforms will vary + CONFIG_DEBUG_UART_BASE=0xa84000 + # Boards older than ~2018 pre-date the GENI driver and unfortunately + # aren't supported here + CONFIG_DEBUG_UART_MSM_GENI=y + # For sdm845 this is the UART clock rate + CONFIG_DEBUG_UART_CLOCK=7372800 + # Most newer boards have an oversampling value of 16 instead + # of 32, they need the clock rate to be doubled + #CONFIG_DEBUG_UART_CLOCK=14745600 + +Then build as normal (don't forget to ``make qcom_defconfig``` again). + +Older boards (db410c and db820c) +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Open ``configs/dragonboard<BOARD>_defconfig`` + + CONFIG_BAUDRATE=115200 + CONFIG_DEBUG_UART=y + CONFIG_DEBUG_UART_ANNOUNCE=y + # db410c - 0x78b0000 + # db820c - 0x75b0000 + CONFIG_DEBUG_UART_BASE=0x75b0000 + CONFIG_DEBUG_UART_MSM=y + CONFIG_DEBUG_UART_CLOCK=7372800 + #CONFIG_DEBUG_UART_SKIP_INIT=y + + CONFIG_LOG=y + CONFIG_HEXDUMP=y + CONFIG_CMD_LOG=y + CONFIG_LOG_MAX_LEVEL=9 + CONFIG_LOG_DEFAULT_LEVEL=9 + CONFIG_LOGLEVEL=9 + diff --git a/doc/board/qualcomm/index.rst b/doc/board/qualcomm/index.rst index 0f9c4299569a..4955274a39bc 100644 --- a/doc/board/qualcomm/index.rst +++ b/doc/board/qualcomm/index.rst @@ -7,5 +7,5 @@ Qualcomm :maxdepth: 2
dragonboard410c - sdm845 - qcs404 + board + debugging diff --git a/doc/board/qualcomm/qcs404.rst b/doc/board/qualcomm/qcs404.rst deleted file mode 100644 index 0cb71d97c987..000000000000 --- a/doc/board/qualcomm/qcs404.rst +++ /dev/null @@ -1,79 +0,0 @@ -.. SPDX-License-Identifier: GPL-2.0+ -.. sectionauthor:: Sumit Garg sumit.garg@linaro.org - -QCS404 EVB -========== - -About this ----------- -This document describes the information about Qualcomm QCS404 evaluation board -and it's usage steps. - -The current boot flow support loading u-boot as an Android boot image via -Qualcomm's UEFI-based ABL (Android) Bootloader. - -Installation ------------- -Build -^^^^^ -Setup ``CROSS_COMPILE`` for aarch64 and build U-Boot for your board:: - - $ export CROSS_COMPILE=<aarch64 toolchain prefix> - $ make qcs404evb_defconfig - $ make - -This will build ``u-boot.bin`` in the configured output directory. - -Generate FIT image -^^^^^^^^^^^^^^^^^^ -A ``qcs404.its`` file can be found in ``board/qualcomm/qcs404-evb/`` directory. -It expects a folder as ``qcs404_imgs/`` in the main directory containing -pre-built kernel, dts and ramdisk images. See ``qcs404.its`` for full path to -images. - -- Build FIT image:: - - mkimage -f qcs404-evb.its qcs404-evb.itb - -Pack android boot image -^^^^^^^^^^^^^^^^^^^^^^^ -We'll assemble android boot image with ``u-boot.bin`` instead of linux kernel, -and FIT image instead of ``initramfs``. Android bootloader expect gzipped kernel -with appended dtb, so let's mimic linux to satisfy stock bootloader: - -- create dump dtb:: - - workdir=/tmp/prepare_payload - mkdir -p "$workdir" - cd "$workdir" - mock_dtb="$workdir"/payload_mock.dtb - - dtc -I dts -O dtb -o "$mock_dtb" << EOF - /dts-v1/; - / { - model = "Qualcomm Technologies, Inc. QCS404 EVB 4000"; - compatible = "qcom,qcs404-evb-4000", "qcom,qcs404-evb", "qcom,qcs404"; - - #address-cells = <2>; - #size-cells = <2>; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the size */ - reg = <0 0x80000000 0 0>; - }; - - chosen { }; - }; - EOF - -- gzip u-boot ``gzip u-boot.bin`` -- append dtb to gzipped u-boot: ``cat u-boot.bin.gz "$mock_dtb" > u-boot.bin.gz-dtb`` - -Now we've got everything to build android boot image::: - - mkbootimg --kernel u-boot.bin.gz-dtb \ - --ramdisk qcs404-evb.itb --pagesize 4096 \ - --base 0x80000000 --output boot.img - -Flash image on qcs404-evb using fastboot method. diff --git a/doc/board/qualcomm/sdm845.rst b/doc/board/qualcomm/sdm845.rst deleted file mode 100644 index d3f218e835e0..000000000000 --- a/doc/board/qualcomm/sdm845.rst +++ /dev/null @@ -1,162 +0,0 @@ -.. SPDX-License-Identifier: GPL-2.0+ -.. sectionauthor:: Dzmitry Sankouski dsankouski@gmail.com - -Snapdragon 845 -================ - -About this ----------- -This document describes the information about Qualcomm Snapdragon 845 -supported boards and it's usage steps. - -SDM845 - hi-end qualcomm chip, introduced in late 2017. -Mostly used in flagship phones and tablets of 2018. - -The current boot flow support loading u-boot as an Android boot image via -Qualcomm's UEFI-based ABL (Android) Bootloader. - -Installation ------------- -Build -^^^^^ -Setup ``CROSS_COMPILE`` for aarch64 and build U-Boot for your board:: - - $ export CROSS_COMPILE=<aarch64 toolchain prefix> - $ make <your board name here, see Boards section>_defconfig - $ make - -This will build ``u-boot.bin`` in the configured output directory. - -Generate FIT image -^^^^^^^^^^^^^^^^^^ -See doc/uImage.FIT for more details - -Pack android boot image -^^^^^^^^^^^^^^^^^^^^^^^ -We'll assemble android boot image with ``u-boot.bin`` instead of linux kernel, -and FIT image instead of ``initramfs``. Android bootloader expect gzipped kernel -with appended dtb, so let's mimic linux to satisfy stock bootloader. - -Boards ------- - -starqlte -^^^^^^^^ - -The starqltechn is a production board for Samsung S9 (SM-G9600) phone, -based on the Qualcomm SDM845 SoC. - -Steps: - -- Build u-boot:: - - $ export CROSS_COMPILE=<aarch64 toolchain prefix> - $ make starqltechn_defconfig - $ make - -- Create dump dtb:: - - workdir=/tmp/prepare_payload - mkdir -p "$workdir" - cd "$workdir" - mock_dtb="$workdir"/payload_mock.dtb - - dtc -I dts -O dtb -o "$mock_dtb" << EOF - /dts-v1/; - / { - memory { - /* We expect the bootloader to fill in the size */ - reg = <0 0 0 0>; - }; - - chosen { }; - }; - EOF - -- gzip u-boot:: - - gzip u-boot.bin - -- Append dtb to gzipped u-boot:: - - cat u-boot.bin.gz "$mock_dtb" > u-boot.bin.gz-dtb - -- Now we've got everything to build android boot image:: - - mkbootimg --base 0x0 --kernel_offset 0x00008000 \ - --ramdisk_offset 0x02000000 --tags_offset 0x01e00000 \ - --pagesize 4096 --second_offset 0x00f00000 \ - --ramdisk "$fit_image" \ - --kernel u-boot.bin.gz-dtb \ - -o boot.img - -- Flash image with your phone's flashing method. - -More information can be found on the `Samsung S9 page`_. - -dragonboard845c -^^^^^^^^^^^^^^^ - -The dragonboard845c is a Qualcomm Robotics RB3 Development Platform, based on -the Qualcomm SDM845 SoC. - -Steps: - -- Build u-boot:: - - $ export CROSS_COMPILE=<aarch64 toolchain prefix> - $ make dragonboard845c_defconfig - $ make - -- Create dummy dtb:: - - workdir=/tmp/prepare_payload - mkdir -p "$workdir" - mock_dtb="$workdir"/payload_mock.dtb - - dtc -I dts -O dtb -o "$mock_dtb" << EOF - /dts-v1/; - / { - #address-cells = <2>; - #size-cells = <2>; - - memory@80000000 { - device_type = "memory"; - /* We expect the bootloader to fill in the size */ - reg = <0 0x80000000 0 0>; - }; - - chosen { }; - }; - EOF - -- gzip u-boot:: - - gzip u-boot.bin - -- Append dtb to gzipped u-boot:: - - cat u-boot.bin.gz "$mock_dtb" > u-boot.bin.gz-dtb - -- A ``db845c.its`` file can be found in ``board/qualcomm/dragonboard845c/`` - directory. It expects a folder as ``db845c_imgs/`` in the main directory - containing pre-built kernel, dts and ramdisk images. See ``db845c.its`` - for full path to images:: - - mkimage -f db845c.its db845c.itb - -- Now we've got everything to build android boot image:: - - mkbootimg --kernel u-boot.bin.gz-dtb --ramdisk db845c.itb \ - --output boot.img --pagesize 4096 --base 0x80000000 - -- Flash boot.img using db845c fastboot method: - - .. code-block:: bash - - sudo fastboot flash boot boot.img - -More information can be found on the `DragonBoard 845c page`_. - -.. _Samsung S9 page: https://en.wikipedia.org/wiki/Samsung_Galaxy_S9 -.. _DragonBoard 845c page: https://www.96boards.org/product/rb3-platform/
- $ make
Perhaps you could also refer to buildman aswell as alternative to bare make
+Boards +------
+starqlte +^^^^^^^^
+Steps:
+- Build u-boot::
- $ make qcom_defconfig
- $ make
+- gzip u-boot::
- gzip u-boot-nodtb.bin
- directory. It expects a folder as ``qcom_imgs/`` in the main directory
- containing pre-built kernel, dts and ramdisk images. See ``qcom.its``
- mkimage -f qcom.its qcom.itb
- mkbootimg --kernel u-boot-nodtb.bin.gz-dtb --ramdisk db845c.itb \
fastboot erase dtbo
- CONFIG_BAUDRATE=115200
- # Uncomment to enable UART pre-relocation
- CONFIG_DEBUG_UART=y
- CONFIG_DEBUG_UART_ANNOUNCE=y
- # This is the address of the debug-uart peripheral
- # The value here is for SDM845, other platforms will vary
- CONFIG_DEBUG_UART_BASE=0xa84000
- # Boards older than ~2018 pre-date the GENI driver and unfortunately
- # aren't supported here
- CONFIG_DEBUG_UART_MSM_GENI=y
- # For sdm845 this is the UART clock rate
- CONFIG_DEBUG_UART_CLOCK=7372800
- # Most newer boards have an oversampling value of 16 instead
- # of 32, they need the clock rate to be doubled
- #CONFIG_DEBUG_UART_CLOCK=14745600
- # db410c - 0x78b0000
- # db820c - 0x75b0000
- CONFIG_DEBUG_UART_BASE=0x75b0000
- CONFIG_DEBUG_UART_MSM=y
- #CONFIG_DEBUG_UART_SKIP_INIT=y
- CONFIG_LOG=y
- CONFIG_HEXDUMP=y
- CONFIG_CMD_LOG=y
- CONFIG_LOG_MAX_LEVEL=9
- CONFIG_LOG_DEFAULT_LEVEL=9
- CONFIG_LOGLEVEL=9
dragonboard410c
- sdm845
- qcs404
- board
- debugging
-QCS404 EVB
-About this
-Installation
- $ make
- cd "$workdir"
- /dts-v1/;
#size-cells = <2>;
memory@80000000 {
chosen { };
- EOF
-Snapdragon 845
-About this
-Installation
- $ make
-Boards
-starqlte -^^^^^^^^
-Steps:
-- Build u-boot::
- $ make
- cd "$workdir"
- /dts-v1/;
memory {
reg = <0 0 0 0>;
chosen { };
- EOF
-- gzip u-boot::
- gzip u-boot.bin
- -o boot.img
-Steps:
-- Build u-boot::
- $ make
- /dts-v1/;
#size-cells = <2>;
memory@80000000 {
chosen { };
- EOF
-- gzip u-boot::
- gzip u-boot.bin
Overall looks good, the debug hints are nice!
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Import the DT bindings headers that are used by SDM845 from Linux 6.7-rc3
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 ++++++ include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 +++ include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 ++ include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 + include/dt-bindings/clock/qcom,rpmh.h | 37 ++ include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 ++ include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 18 + include/dt-bindings/iio/qcom,spmi-vadc.h | 300 +++++++++++++++ include/dt-bindings/interconnect/qcom,osm-l3.h | 15 + include/dt-bindings/interconnect/qcom,sdm845.h | 150 ++++++++ include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/phy/phy-qcom-qusb2.h | 37 ++ include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 ++++++++ include/dt-bindings/power/qcom-rpmpd.h | 412 +++++++++++++++++++++ include/dt-bindings/qcom,q6asm.h | 26 ++ .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 ++ include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 + include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 ++ include/dt-bindings/soc/qcom,apr.h | 28 ++ include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + include/dt-bindings/sound/qcom,q6afe.h | 9 + include/dt-bindings/sound/qcom,q6asm.h | 26 ++ include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 ++++++++++++ 24 files changed, 1822 insertions(+)
diff --git a/include/dt-bindings/clock/qcom,camcc-sdm845.h b/include/dt-bindings/clock/qcom,camcc-sdm845.h new file mode 100644 index 000000000000..4f7a2d2320bf --- /dev/null +++ b/include/dt-bindings/clock/qcom,camcc-sdm845.h @@ -0,0 +1,116 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_SDM_CAM_CC_SDM845_H +#define _DT_BINDINGS_CLK_SDM_CAM_CC_SDM845_H + +/* CAM_CC clock registers */ +#define CAM_CC_BPS_AHB_CLK 0 +#define CAM_CC_BPS_AREG_CLK 1 +#define CAM_CC_BPS_AXI_CLK 2 +#define CAM_CC_BPS_CLK 3 +#define CAM_CC_BPS_CLK_SRC 4 +#define CAM_CC_CAMNOC_ATB_CLK 5 +#define CAM_CC_CAMNOC_AXI_CLK 6 +#define CAM_CC_CCI_CLK 7 +#define CAM_CC_CCI_CLK_SRC 8 +#define CAM_CC_CPAS_AHB_CLK 9 +#define CAM_CC_CPHY_RX_CLK_SRC 10 +#define CAM_CC_CSI0PHYTIMER_CLK 11 +#define CAM_CC_CSI0PHYTIMER_CLK_SRC 12 +#define CAM_CC_CSI1PHYTIMER_CLK 13 +#define CAM_CC_CSI1PHYTIMER_CLK_SRC 14 +#define CAM_CC_CSI2PHYTIMER_CLK 15 +#define CAM_CC_CSI2PHYTIMER_CLK_SRC 16 +#define CAM_CC_CSI3PHYTIMER_CLK 17 +#define CAM_CC_CSI3PHYTIMER_CLK_SRC 18 +#define CAM_CC_CSIPHY0_CLK 19 +#define CAM_CC_CSIPHY1_CLK 20 +#define CAM_CC_CSIPHY2_CLK 21 +#define CAM_CC_CSIPHY3_CLK 22 +#define CAM_CC_FAST_AHB_CLK_SRC 23 +#define CAM_CC_FD_CORE_CLK 24 +#define CAM_CC_FD_CORE_CLK_SRC 25 +#define CAM_CC_FD_CORE_UAR_CLK 26 +#define CAM_CC_ICP_APB_CLK 27 +#define CAM_CC_ICP_ATB_CLK 28 +#define CAM_CC_ICP_CLK 29 +#define CAM_CC_ICP_CLK_SRC 30 +#define CAM_CC_ICP_CTI_CLK 31 +#define CAM_CC_ICP_TS_CLK 32 +#define CAM_CC_IFE_0_AXI_CLK 33 +#define CAM_CC_IFE_0_CLK 34 +#define CAM_CC_IFE_0_CLK_SRC 35 +#define CAM_CC_IFE_0_CPHY_RX_CLK 36 +#define CAM_CC_IFE_0_CSID_CLK 37 +#define CAM_CC_IFE_0_CSID_CLK_SRC 38 +#define CAM_CC_IFE_0_DSP_CLK 39 +#define CAM_CC_IFE_1_AXI_CLK 40 +#define CAM_CC_IFE_1_CLK 41 +#define CAM_CC_IFE_1_CLK_SRC 42 +#define CAM_CC_IFE_1_CPHY_RX_CLK 43 +#define CAM_CC_IFE_1_CSID_CLK 44 +#define CAM_CC_IFE_1_CSID_CLK_SRC 45 +#define CAM_CC_IFE_1_DSP_CLK 46 +#define CAM_CC_IFE_LITE_CLK 47 +#define CAM_CC_IFE_LITE_CLK_SRC 48 +#define CAM_CC_IFE_LITE_CPHY_RX_CLK 49 +#define CAM_CC_IFE_LITE_CSID_CLK 50 +#define CAM_CC_IFE_LITE_CSID_CLK_SRC 51 +#define CAM_CC_IPE_0_AHB_CLK 52 +#define CAM_CC_IPE_0_AREG_CLK 53 +#define CAM_CC_IPE_0_AXI_CLK 54 +#define CAM_CC_IPE_0_CLK 55 +#define CAM_CC_IPE_0_CLK_SRC 56 +#define CAM_CC_IPE_1_AHB_CLK 57 +#define CAM_CC_IPE_1_AREG_CLK 58 +#define CAM_CC_IPE_1_AXI_CLK 59 +#define CAM_CC_IPE_1_CLK 60 +#define CAM_CC_IPE_1_CLK_SRC 61 +#define CAM_CC_JPEG_CLK 62 +#define CAM_CC_JPEG_CLK_SRC 63 +#define CAM_CC_LRME_CLK 64 +#define CAM_CC_LRME_CLK_SRC 65 +#define CAM_CC_MCLK0_CLK 66 +#define CAM_CC_MCLK0_CLK_SRC 67 +#define CAM_CC_MCLK1_CLK 68 +#define CAM_CC_MCLK1_CLK_SRC 69 +#define CAM_CC_MCLK2_CLK 70 +#define CAM_CC_MCLK2_CLK_SRC 71 +#define CAM_CC_MCLK3_CLK 72 +#define CAM_CC_MCLK3_CLK_SRC 73 +#define CAM_CC_PLL0 74 +#define CAM_CC_PLL0_OUT_EVEN 75 +#define CAM_CC_PLL1 76 +#define CAM_CC_PLL1_OUT_EVEN 77 +#define CAM_CC_PLL2 78 +#define CAM_CC_PLL2_OUT_EVEN 79 +#define CAM_CC_PLL3 80 +#define CAM_CC_PLL3_OUT_EVEN 81 +#define CAM_CC_SLOW_AHB_CLK_SRC 82 +#define CAM_CC_SOC_AHB_CLK 83 +#define CAM_CC_SYS_TMR_CLK 84 + +/* CAM_CC Resets */ +#define TITAN_CAM_CC_CCI_BCR 0 +#define TITAN_CAM_CC_CPAS_BCR 1 +#define TITAN_CAM_CC_CSI0PHY_BCR 2 +#define TITAN_CAM_CC_CSI1PHY_BCR 3 +#define TITAN_CAM_CC_CSI2PHY_BCR 4 +#define TITAN_CAM_CC_MCLK0_BCR 5 +#define TITAN_CAM_CC_MCLK1_BCR 6 +#define TITAN_CAM_CC_MCLK2_BCR 7 +#define TITAN_CAM_CC_MCLK3_BCR 8 +#define TITAN_CAM_CC_TITAN_TOP_BCR 9 + +/* CAM_CC GDSCRs */ +#define BPS_GDSC 0 +#define IPE_0_GDSC 1 +#define IPE_1_GDSC 2 +#define IFE_0_GDSC 3 +#define IFE_1_GDSC 4 +#define TITAN_TOP_GDSC 5 + +#endif diff --git a/include/dt-bindings/clock/qcom,dispcc-sdm845.h b/include/dt-bindings/clock/qcom,dispcc-sdm845.h new file mode 100644 index 000000000000..4016fd1d5b46 --- /dev/null +++ b/include/dt-bindings/clock/qcom,dispcc-sdm845.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018-2019, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_SDM_DISP_CC_SDM845_H +#define _DT_BINDINGS_CLK_SDM_DISP_CC_SDM845_H + +/* DISP_CC clock registers */ +#define DISP_CC_MDSS_AHB_CLK 0 +#define DISP_CC_MDSS_AXI_CLK 1 +#define DISP_CC_MDSS_BYTE0_CLK 2 +#define DISP_CC_MDSS_BYTE0_CLK_SRC 3 +#define DISP_CC_MDSS_BYTE0_INTF_CLK 4 +#define DISP_CC_MDSS_BYTE1_CLK 5 +#define DISP_CC_MDSS_BYTE1_CLK_SRC 6 +#define DISP_CC_MDSS_BYTE1_INTF_CLK 7 +#define DISP_CC_MDSS_ESC0_CLK 8 +#define DISP_CC_MDSS_ESC0_CLK_SRC 9 +#define DISP_CC_MDSS_ESC1_CLK 10 +#define DISP_CC_MDSS_ESC1_CLK_SRC 11 +#define DISP_CC_MDSS_MDP_CLK 12 +#define DISP_CC_MDSS_MDP_CLK_SRC 13 +#define DISP_CC_MDSS_MDP_LUT_CLK 14 +#define DISP_CC_MDSS_PCLK0_CLK 15 +#define DISP_CC_MDSS_PCLK0_CLK_SRC 16 +#define DISP_CC_MDSS_PCLK1_CLK 17 +#define DISP_CC_MDSS_PCLK1_CLK_SRC 18 +#define DISP_CC_MDSS_ROT_CLK 19 +#define DISP_CC_MDSS_ROT_CLK_SRC 20 +#define DISP_CC_MDSS_RSCC_AHB_CLK 21 +#define DISP_CC_MDSS_RSCC_VSYNC_CLK 22 +#define DISP_CC_MDSS_VSYNC_CLK 23 +#define DISP_CC_MDSS_VSYNC_CLK_SRC 24 +#define DISP_CC_PLL0 25 +#define DISP_CC_MDSS_BYTE0_DIV_CLK_SRC 26 +#define DISP_CC_MDSS_BYTE1_DIV_CLK_SRC 27 +#define DISP_CC_MDSS_DP_AUX_CLK 28 +#define DISP_CC_MDSS_DP_AUX_CLK_SRC 29 +#define DISP_CC_MDSS_DP_CRYPTO_CLK 30 +#define DISP_CC_MDSS_DP_CRYPTO_CLK_SRC 31 +#define DISP_CC_MDSS_DP_LINK_CLK 32 +#define DISP_CC_MDSS_DP_LINK_CLK_SRC 33 +#define DISP_CC_MDSS_DP_LINK_INTF_CLK 34 +#define DISP_CC_MDSS_DP_PIXEL1_CLK 35 +#define DISP_CC_MDSS_DP_PIXEL1_CLK_SRC 36 +#define DISP_CC_MDSS_DP_PIXEL_CLK 37 +#define DISP_CC_MDSS_DP_PIXEL_CLK_SRC 38 + +/* DISP_CC Reset */ +#define DISP_CC_MDSS_RSCC_BCR 0 + +/* DISP_CC GDSCR */ +#define MDSS_GDSC 0 + +#endif diff --git a/include/dt-bindings/clock/qcom,gpucc-sdm845.h b/include/dt-bindings/clock/qcom,gpucc-sdm845.h new file mode 100644 index 000000000000..9690d901b50a --- /dev/null +++ b/include/dt-bindings/clock/qcom,gpucc-sdm845.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_SDM_GPU_CC_SDM845_H +#define _DT_BINDINGS_CLK_SDM_GPU_CC_SDM845_H + +/* GPU_CC clock registers */ +#define GPU_CC_CX_GMU_CLK 0 +#define GPU_CC_CXO_CLK 1 +#define GPU_CC_GMU_CLK_SRC 2 +#define GPU_CC_PLL1 3 + +/* GPU_CC Resets */ +#define GPUCC_GPU_CC_CX_BCR 0 +#define GPUCC_GPU_CC_GMU_BCR 1 +#define GPUCC_GPU_CC_XO_BCR 2 + +/* GPU_CC GDSCRs */ +#define GPU_CX_GDSC 0 +#define GPU_GX_GDSC 1 + +#endif diff --git a/include/dt-bindings/clock/qcom,lpass-sdm845.h b/include/dt-bindings/clock/qcom,lpass-sdm845.h new file mode 100644 index 000000000000..659050846f61 --- /dev/null +++ b/include/dt-bindings/clock/qcom,lpass-sdm845.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_SDM_LPASS_SDM845_H +#define _DT_BINDINGS_CLK_SDM_LPASS_SDM845_H + +#define LPASS_Q6SS_AHBM_AON_CLK 0 +#define LPASS_Q6SS_AHBS_AON_CLK 1 +#define LPASS_QDSP6SS_XO_CLK 2 +#define LPASS_QDSP6SS_SLEEP_CLK 3 +#define LPASS_QDSP6SS_CORE_CLK 4 + +#endif diff --git a/include/dt-bindings/clock/qcom,rpmh.h b/include/dt-bindings/clock/qcom,rpmh.h new file mode 100644 index 000000000000..0a7d1be0d124 --- /dev/null +++ b/include/dt-bindings/clock/qcom,rpmh.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, 2020, The Linux Foundation. All rights reserved. */ + + +#ifndef _DT_BINDINGS_CLK_MSM_RPMH_H +#define _DT_BINDINGS_CLK_MSM_RPMH_H + +/* RPMh controlled clocks */ +#define RPMH_CXO_CLK 0 +#define RPMH_CXO_CLK_A 1 +#define RPMH_LN_BB_CLK2 2 +#define RPMH_LN_BB_CLK2_A 3 +#define RPMH_LN_BB_CLK3 4 +#define RPMH_LN_BB_CLK3_A 5 +#define RPMH_RF_CLK1 6 +#define RPMH_RF_CLK1_A 7 +#define RPMH_RF_CLK2 8 +#define RPMH_RF_CLK2_A 9 +#define RPMH_RF_CLK3 10 +#define RPMH_RF_CLK3_A 11 +#define RPMH_IPA_CLK 12 +#define RPMH_LN_BB_CLK1 13 +#define RPMH_LN_BB_CLK1_A 14 +#define RPMH_CE_CLK 15 +#define RPMH_QPIC_CLK 16 +#define RPMH_DIV_CLK1 17 +#define RPMH_DIV_CLK1_A 18 +#define RPMH_RF_CLK4 19 +#define RPMH_RF_CLK4_A 20 +#define RPMH_RF_CLK5 21 +#define RPMH_RF_CLK5_A 22 +#define RPMH_PKA_CLK 23 +#define RPMH_HWKM_CLK 24 +#define RPMH_QLINK_CLK 25 +#define RPMH_QLINK_CLK_A 26 + +#endif diff --git a/include/dt-bindings/clock/qcom,videocc-sdm845.h b/include/dt-bindings/clock/qcom,videocc-sdm845.h new file mode 100644 index 000000000000..1b868165e8ce --- /dev/null +++ b/include/dt-bindings/clock/qcom,videocc-sdm845.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_SDM_VIDEO_CC_SDM845_H +#define _DT_BINDINGS_CLK_SDM_VIDEO_CC_SDM845_H + +/* VIDEO_CC clock registers */ +#define VIDEO_CC_APB_CLK 0 +#define VIDEO_CC_AT_CLK 1 +#define VIDEO_CC_QDSS_TRIG_CLK 2 +#define VIDEO_CC_QDSS_TSCTR_DIV8_CLK 3 +#define VIDEO_CC_VCODEC0_AXI_CLK 4 +#define VIDEO_CC_VCODEC0_CORE_CLK 5 +#define VIDEO_CC_VCODEC1_AXI_CLK 6 +#define VIDEO_CC_VCODEC1_CORE_CLK 7 +#define VIDEO_CC_VENUS_AHB_CLK 8 +#define VIDEO_CC_VENUS_CLK_SRC 9 +#define VIDEO_CC_VENUS_CTL_AXI_CLK 10 +#define VIDEO_CC_VENUS_CTL_CORE_CLK 11 +#define VIDEO_PLL0 12 + +/* VIDEO_CC Resets */ +#define VIDEO_CC_VENUS_BCR 0 +#define VIDEO_CC_VCODEC0_BCR 1 +#define VIDEO_CC_VCODEC1_BCR 2 +#define VIDEO_CC_INTERFACE_BCR 3 + +/* VIDEO_CC GDSCRs */ +#define VENUS_GDSC 0 +#define VCODEC0_GDSC 1 +#define VCODEC1_GDSC 2 + +#endif diff --git a/include/dt-bindings/dma/qcom-gpi.h b/include/dt-bindings/dma/qcom-gpi.h new file mode 100644 index 000000000000..ebda2a37f52a --- /dev/null +++ b/include/dt-bindings/dma/qcom-gpi.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0 OR BSD-2-Clause */ +/* Copyright (c) 2020, Linaro Ltd. */ + +#ifndef __DT_BINDINGS_DMA_QCOM_GPI_H__ +#define __DT_BINDINGS_DMA_QCOM_GPI_H__ + +#define QCOM_GPI_SPI 1 +#define QCOM_GPI_UART 2 +#define QCOM_GPI_I2C 3 + +#endif /* __DT_BINDINGS_DMA_QCOM_GPI_H__ */ diff --git a/include/dt-bindings/firmware/qcom,scm.h b/include/dt-bindings/firmware/qcom,scm.h new file mode 100644 index 000000000000..d1dc09e72923 --- /dev/null +++ b/include/dt-bindings/firmware/qcom,scm.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ +/* + * Copyright (c) 2010-2015, 2018-2019 The Linux Foundation. All rights reserved. + * Copyright (C) 2015 Linaro Ltd. + */ + +#ifndef _DT_BINDINGS_FIRMWARE_QCOM_SCM_H +#define _DT_BINDINGS_FIRMWARE_QCOM_SCM_H + +#define QCOM_SCM_VMID_HLOS 0x3 +#define QCOM_SCM_VMID_SSC_Q6 0x5 +#define QCOM_SCM_VMID_ADSP_Q6 0x6 +#define QCOM_SCM_VMID_MSS_MSA 0xF +#define QCOM_SCM_VMID_WLAN 0x18 +#define QCOM_SCM_VMID_WLAN_CE 0x19 +#define QCOM_SCM_VMID_NAV 0x2B + +#endif diff --git a/include/dt-bindings/iio/qcom,spmi-vadc.h b/include/dt-bindings/iio/qcom,spmi-vadc.h new file mode 100644 index 000000000000..08adfe25964c --- /dev/null +++ b/include/dt-bindings/iio/qcom,spmi-vadc.h @@ -0,0 +1,300 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2012-2014,2018,2020 The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_QCOM_SPMI_VADC_H +#define _DT_BINDINGS_QCOM_SPMI_VADC_H + +/* Voltage ADC channels */ +#define VADC_USBIN 0x00 +#define VADC_DCIN 0x01 +#define VADC_VCHG_SNS 0x02 +#define VADC_SPARE1_03 0x03 +#define VADC_USB_ID_MV 0x04 +#define VADC_VCOIN 0x05 +#define VADC_VBAT_SNS 0x06 +#define VADC_VSYS 0x07 +#define VADC_DIE_TEMP 0x08 +#define VADC_REF_625MV 0x09 +#define VADC_REF_1250MV 0x0a +#define VADC_CHG_TEMP 0x0b +#define VADC_SPARE1 0x0c +#define VADC_SPARE2 0x0d +#define VADC_GND_REF 0x0e +#define VADC_VDD_VADC 0x0f + +#define VADC_P_MUX1_1_1 0x10 +#define VADC_P_MUX2_1_1 0x11 +#define VADC_P_MUX3_1_1 0x12 +#define VADC_P_MUX4_1_1 0x13 +#define VADC_P_MUX5_1_1 0x14 +#define VADC_P_MUX6_1_1 0x15 +#define VADC_P_MUX7_1_1 0x16 +#define VADC_P_MUX8_1_1 0x17 +#define VADC_P_MUX9_1_1 0x18 +#define VADC_P_MUX10_1_1 0x19 +#define VADC_P_MUX11_1_1 0x1a +#define VADC_P_MUX12_1_1 0x1b +#define VADC_P_MUX13_1_1 0x1c +#define VADC_P_MUX14_1_1 0x1d +#define VADC_P_MUX15_1_1 0x1e +#define VADC_P_MUX16_1_1 0x1f + +#define VADC_P_MUX1_1_3 0x20 +#define VADC_P_MUX2_1_3 0x21 +#define VADC_P_MUX3_1_3 0x22 +#define VADC_P_MUX4_1_3 0x23 +#define VADC_P_MUX5_1_3 0x24 +#define VADC_P_MUX6_1_3 0x25 +#define VADC_P_MUX7_1_3 0x26 +#define VADC_P_MUX8_1_3 0x27 +#define VADC_P_MUX9_1_3 0x28 +#define VADC_P_MUX10_1_3 0x29 +#define VADC_P_MUX11_1_3 0x2a +#define VADC_P_MUX12_1_3 0x2b +#define VADC_P_MUX13_1_3 0x2c +#define VADC_P_MUX14_1_3 0x2d +#define VADC_P_MUX15_1_3 0x2e +#define VADC_P_MUX16_1_3 0x2f + +#define VADC_LR_MUX1_BAT_THERM 0x30 +#define VADC_LR_MUX2_BAT_ID 0x31 +#define VADC_LR_MUX3_XO_THERM 0x32 +#define VADC_LR_MUX4_AMUX_THM1 0x33 +#define VADC_LR_MUX5_AMUX_THM2 0x34 +#define VADC_LR_MUX6_AMUX_THM3 0x35 +#define VADC_LR_MUX7_HW_ID 0x36 +#define VADC_LR_MUX8_AMUX_THM4 0x37 +#define VADC_LR_MUX9_AMUX_THM5 0x38 +#define VADC_LR_MUX10_USB_ID 0x39 +#define VADC_AMUX_PU1 0x3a +#define VADC_AMUX_PU2 0x3b +#define VADC_LR_MUX3_BUF_XO_THERM 0x3c + +#define VADC_LR_MUX1_PU1_BAT_THERM 0x70 +#define VADC_LR_MUX2_PU1_BAT_ID 0x71 +#define VADC_LR_MUX3_PU1_XO_THERM 0x72 +#define VADC_LR_MUX4_PU1_AMUX_THM1 0x73 +#define VADC_LR_MUX5_PU1_AMUX_THM2 0x74 +#define VADC_LR_MUX6_PU1_AMUX_THM3 0x75 +#define VADC_LR_MUX7_PU1_AMUX_HW_ID 0x76 +#define VADC_LR_MUX8_PU1_AMUX_THM4 0x77 +#define VADC_LR_MUX9_PU1_AMUX_THM5 0x78 +#define VADC_LR_MUX10_PU1_AMUX_USB_ID 0x79 +#define VADC_LR_MUX3_BUF_PU1_XO_THERM 0x7c + +#define VADC_LR_MUX1_PU2_BAT_THERM 0xb0 +#define VADC_LR_MUX2_PU2_BAT_ID 0xb1 +#define VADC_LR_MUX3_PU2_XO_THERM 0xb2 +#define VADC_LR_MUX4_PU2_AMUX_THM1 0xb3 +#define VADC_LR_MUX5_PU2_AMUX_THM2 0xb4 +#define VADC_LR_MUX6_PU2_AMUX_THM3 0xb5 +#define VADC_LR_MUX7_PU2_AMUX_HW_ID 0xb6 +#define VADC_LR_MUX8_PU2_AMUX_THM4 0xb7 +#define VADC_LR_MUX9_PU2_AMUX_THM5 0xb8 +#define VADC_LR_MUX10_PU2_AMUX_USB_ID 0xb9 +#define VADC_LR_MUX3_BUF_PU2_XO_THERM 0xbc + +#define VADC_LR_MUX1_PU1_PU2_BAT_THERM 0xf0 +#define VADC_LR_MUX2_PU1_PU2_BAT_ID 0xf1 +#define VADC_LR_MUX3_PU1_PU2_XO_THERM 0xf2 +#define VADC_LR_MUX4_PU1_PU2_AMUX_THM1 0xf3 +#define VADC_LR_MUX5_PU1_PU2_AMUX_THM2 0xf4 +#define VADC_LR_MUX6_PU1_PU2_AMUX_THM3 0xf5 +#define VADC_LR_MUX7_PU1_PU2_AMUX_HW_ID 0xf6 +#define VADC_LR_MUX8_PU1_PU2_AMUX_THM4 0xf7 +#define VADC_LR_MUX9_PU1_PU2_AMUX_THM5 0xf8 +#define VADC_LR_MUX10_PU1_PU2_AMUX_USB_ID 0xf9 +#define VADC_LR_MUX3_BUF_PU1_PU2_XO_THERM 0xfc + +/* ADC channels for SPMI PMIC5 */ + +#define ADC5_REF_GND 0x00 +#define ADC5_1P25VREF 0x01 +#define ADC5_VREF_VADC 0x02 +#define ADC5_VREF_VADC5_DIV_3 0x82 +#define ADC5_VPH_PWR 0x83 +#define ADC5_VBAT_SNS 0x84 +#define ADC5_VCOIN 0x85 +#define ADC5_DIE_TEMP 0x06 +#define ADC5_USB_IN_I 0x07 +#define ADC5_USB_IN_V_16 0x08 +#define ADC5_CHG_TEMP 0x09 +#define ADC5_BAT_THERM 0x0a +#define ADC5_BAT_ID 0x0b +#define ADC5_XO_THERM 0x0c +#define ADC5_AMUX_THM1 0x0d +#define ADC5_AMUX_THM2 0x0e +#define ADC5_AMUX_THM3 0x0f +#define ADC5_AMUX_THM4 0x10 +#define ADC5_AMUX_THM5 0x11 +#define ADC5_GPIO1 0x12 +#define ADC5_GPIO2 0x13 +#define ADC5_GPIO3 0x14 +#define ADC5_GPIO4 0x15 +#define ADC5_GPIO5 0x16 +#define ADC5_GPIO6 0x17 +#define ADC5_GPIO7 0x18 +#define ADC5_SBUx 0x99 +#define ADC5_MID_CHG_DIV6 0x1e +#define ADC5_OFF 0xff + +/* 30k pull-up1 */ +#define ADC5_BAT_THERM_30K_PU 0x2a +#define ADC5_BAT_ID_30K_PU 0x2b +#define ADC5_XO_THERM_30K_PU 0x2c +#define ADC5_AMUX_THM1_30K_PU 0x2d +#define ADC5_AMUX_THM2_30K_PU 0x2e +#define ADC5_AMUX_THM3_30K_PU 0x2f +#define ADC5_AMUX_THM4_30K_PU 0x30 +#define ADC5_AMUX_THM5_30K_PU 0x31 +#define ADC5_GPIO1_30K_PU 0x32 +#define ADC5_GPIO2_30K_PU 0x33 +#define ADC5_GPIO3_30K_PU 0x34 +#define ADC5_GPIO4_30K_PU 0x35 +#define ADC5_GPIO5_30K_PU 0x36 +#define ADC5_GPIO6_30K_PU 0x37 +#define ADC5_GPIO7_30K_PU 0x38 +#define ADC5_SBUx_30K_PU 0x39 + +/* 100k pull-up2 */ +#define ADC5_BAT_THERM_100K_PU 0x4a +#define ADC5_BAT_ID_100K_PU 0x4b +#define ADC5_XO_THERM_100K_PU 0x4c +#define ADC5_AMUX_THM1_100K_PU 0x4d +#define ADC5_AMUX_THM2_100K_PU 0x4e +#define ADC5_AMUX_THM3_100K_PU 0x4f +#define ADC5_AMUX_THM4_100K_PU 0x50 +#define ADC5_AMUX_THM5_100K_PU 0x51 +#define ADC5_GPIO1_100K_PU 0x52 +#define ADC5_GPIO2_100K_PU 0x53 +#define ADC5_GPIO3_100K_PU 0x54 +#define ADC5_GPIO4_100K_PU 0x55 +#define ADC5_GPIO5_100K_PU 0x56 +#define ADC5_GPIO6_100K_PU 0x57 +#define ADC5_GPIO7_100K_PU 0x58 +#define ADC5_SBUx_100K_PU 0x59 + +/* 400k pull-up3 */ +#define ADC5_BAT_THERM_400K_PU 0x6a +#define ADC5_BAT_ID_400K_PU 0x6b +#define ADC5_XO_THERM_400K_PU 0x6c +#define ADC5_AMUX_THM1_400K_PU 0x6d +#define ADC5_AMUX_THM2_400K_PU 0x6e +#define ADC5_AMUX_THM3_400K_PU 0x6f +#define ADC5_AMUX_THM4_400K_PU 0x70 +#define ADC5_AMUX_THM5_400K_PU 0x71 +#define ADC5_GPIO1_400K_PU 0x72 +#define ADC5_GPIO2_400K_PU 0x73 +#define ADC5_GPIO3_400K_PU 0x74 +#define ADC5_GPIO4_400K_PU 0x75 +#define ADC5_GPIO5_400K_PU 0x76 +#define ADC5_GPIO6_400K_PU 0x77 +#define ADC5_GPIO7_400K_PU 0x78 +#define ADC5_SBUx_400K_PU 0x79 + +/* 1/3 Divider */ +#define ADC5_GPIO1_DIV3 0x92 +#define ADC5_GPIO2_DIV3 0x93 +#define ADC5_GPIO3_DIV3 0x94 +#define ADC5_GPIO4_DIV3 0x95 +#define ADC5_GPIO5_DIV3 0x96 +#define ADC5_GPIO6_DIV3 0x97 +#define ADC5_GPIO7_DIV3 0x98 +#define ADC5_SBUx_DIV3 0x99 + +/* Current and combined current/voltage channels */ +#define ADC5_INT_EXT_ISENSE 0xa1 +#define ADC5_PARALLEL_ISENSE 0xa5 +#define ADC5_CUR_REPLICA_VDS 0xa7 +#define ADC5_CUR_SENS_BATFET_VDS_OFFSET 0xa9 +#define ADC5_CUR_SENS_REPLICA_VDS_OFFSET 0xab +#define ADC5_EXT_SENS_OFFSET 0xad + +#define ADC5_INT_EXT_ISENSE_VBAT_VDATA 0xb0 +#define ADC5_INT_EXT_ISENSE_VBAT_IDATA 0xb1 +#define ADC5_EXT_ISENSE_VBAT_VDATA 0xb2 +#define ADC5_EXT_ISENSE_VBAT_IDATA 0xb3 +#define ADC5_PARALLEL_ISENSE_VBAT_VDATA 0xb4 +#define ADC5_PARALLEL_ISENSE_VBAT_IDATA 0xb5 + +#define ADC5_MAX_CHANNEL 0xc0 + +/* ADC channels for ADC for PMIC7 */ + +#define ADC7_REF_GND 0x00 +#define ADC7_1P25VREF 0x01 +#define ADC7_VREF_VADC 0x02 +#define ADC7_DIE_TEMP 0x03 + +#define ADC7_AMUX_THM1 0x04 +#define ADC7_AMUX_THM2 0x05 +#define ADC7_AMUX_THM3 0x06 +#define ADC7_AMUX_THM4 0x07 +#define ADC7_AMUX_THM5 0x08 +#define ADC7_AMUX_THM6 0x09 +#define ADC7_GPIO1 0x0a +#define ADC7_GPIO2 0x0b +#define ADC7_GPIO3 0x0c +#define ADC7_GPIO4 0x0d + +#define ADC7_CHG_TEMP 0x10 +#define ADC7_USB_IN_V_16 0x11 +#define ADC7_VDC_16 0x12 +#define ADC7_CC1_ID 0x13 +#define ADC7_VREF_BAT_THERM 0x15 +#define ADC7_IIN_FB 0x17 + +/* 30k pull-up1 */ +#define ADC7_AMUX_THM1_30K_PU 0x24 +#define ADC7_AMUX_THM2_30K_PU 0x25 +#define ADC7_AMUX_THM3_30K_PU 0x26 +#define ADC7_AMUX_THM4_30K_PU 0x27 +#define ADC7_AMUX_THM5_30K_PU 0x28 +#define ADC7_AMUX_THM6_30K_PU 0x29 +#define ADC7_GPIO1_30K_PU 0x2a +#define ADC7_GPIO2_30K_PU 0x2b +#define ADC7_GPIO3_30K_PU 0x2c +#define ADC7_GPIO4_30K_PU 0x2d +#define ADC7_CC1_ID_30K_PU 0x33 + +/* 100k pull-up2 */ +#define ADC7_AMUX_THM1_100K_PU 0x44 +#define ADC7_AMUX_THM2_100K_PU 0x45 +#define ADC7_AMUX_THM3_100K_PU 0x46 +#define ADC7_AMUX_THM4_100K_PU 0x47 +#define ADC7_AMUX_THM5_100K_PU 0x48 +#define ADC7_AMUX_THM6_100K_PU 0x49 +#define ADC7_GPIO1_100K_PU 0x4a +#define ADC7_GPIO2_100K_PU 0x4b +#define ADC7_GPIO3_100K_PU 0x4c +#define ADC7_GPIO4_100K_PU 0x4d +#define ADC7_CC1_ID_100K_PU 0x53 + +/* 400k pull-up3 */ +#define ADC7_AMUX_THM1_400K_PU 0x64 +#define ADC7_AMUX_THM2_400K_PU 0x65 +#define ADC7_AMUX_THM3_400K_PU 0x66 +#define ADC7_AMUX_THM4_400K_PU 0x67 +#define ADC7_AMUX_THM5_400K_PU 0x68 +#define ADC7_AMUX_THM6_400K_PU 0x69 +#define ADC7_GPIO1_400K_PU 0x6a +#define ADC7_GPIO2_400K_PU 0x6b +#define ADC7_GPIO3_400K_PU 0x6c +#define ADC7_GPIO4_400K_PU 0x6d +#define ADC7_CC1_ID_400K_PU 0x73 + +/* 1/3 Divider */ +#define ADC7_GPIO1_DIV3 0x8a +#define ADC7_GPIO2_DIV3 0x8b +#define ADC7_GPIO3_DIV3 0x8c +#define ADC7_GPIO4_DIV3 0x8d + +#define ADC7_VPH_PWR 0x8e +#define ADC7_VBAT_SNS 0x8f + +#define ADC7_SBUx 0x94 +#define ADC7_VBAT_2S_MID 0x96 + +#endif /* _DT_BINDINGS_QCOM_SPMI_VADC_H */ diff --git a/include/dt-bindings/interconnect/qcom,osm-l3.h b/include/dt-bindings/interconnect/qcom,osm-l3.h new file mode 100644 index 000000000000..61ef649ae565 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,osm-l3.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 The Linux Foundation. All rights reserved. + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_OSM_L3_H + +#define MASTER_OSM_L3_APPS 0 +#define SLAVE_OSM_L3 1 + +#define MASTER_EPSS_L3_APPS 0 +#define SLAVE_EPSS_L3_SHARED 1 + +#endif diff --git a/include/dt-bindings/interconnect/qcom,sdm845.h b/include/dt-bindings/interconnect/qcom,sdm845.h new file mode 100644 index 000000000000..67b500e24915 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,sdm845.h @@ -0,0 +1,150 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Qualcomm SDM845 interconnect IDs + * + * Copyright (c) 2018, Linaro Ltd. + * Author: Georgi Djakov georgi.djakov@linaro.org + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_SDM845_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_SDM845_H + +#define MASTER_A1NOC_CFG 0 +#define MASTER_TSIF 1 +#define MASTER_SDCC_2 2 +#define MASTER_SDCC_4 3 +#define MASTER_UFS_CARD 4 +#define MASTER_UFS_MEM 5 +#define MASTER_PCIE_0 6 +#define SLAVE_A1NOC_SNOC 7 +#define SLAVE_SERVICE_A1NOC 8 +#define SLAVE_ANOC_PCIE_A1NOC_SNOC 9 +#define MASTER_QUP_1 10 + +#define MASTER_A2NOC_CFG 0 +#define MASTER_QDSS_BAM 1 +#define MASTER_CNOC_A2NOC 2 +#define MASTER_CRYPTO 3 +#define MASTER_IPA 4 +#define MASTER_PCIE_1 5 +#define MASTER_QDSS_ETR 6 +#define MASTER_USB3_0 7 +#define MASTER_USB3_1 8 +#define SLAVE_A2NOC_SNOC 9 +#define SLAVE_ANOC_PCIE_SNOC 10 +#define SLAVE_SERVICE_A2NOC 11 +#define MASTER_QUP_2 12 + +#define MASTER_SPDM 0 +#define MASTER_TIC 1 +#define MASTER_SNOC_CNOC 2 +#define MASTER_QDSS_DAP 3 +#define SLAVE_A1NOC_CFG 4 +#define SLAVE_A2NOC_CFG 5 +#define SLAVE_AOP 6 +#define SLAVE_AOSS 7 +#define SLAVE_CAMERA_CFG 8 +#define SLAVE_CLK_CTL 9 +#define SLAVE_CDSP_CFG 10 +#define SLAVE_RBCPR_CX_CFG 11 +#define SLAVE_CRYPTO_0_CFG 12 +#define SLAVE_DCC_CFG 13 +#define SLAVE_CNOC_DDRSS 14 +#define SLAVE_DISPLAY_CFG 15 +#define SLAVE_GLM 16 +#define SLAVE_GFX3D_CFG 17 +#define SLAVE_IMEM_CFG 18 +#define SLAVE_IPA_CFG 19 +#define SLAVE_CNOC_MNOC_CFG 20 +#define SLAVE_PCIE_0_CFG 21 +#define SLAVE_PCIE_1_CFG 22 +#define SLAVE_PDM 23 +#define SLAVE_SOUTH_PHY_CFG 24 +#define SLAVE_PIMEM_CFG 25 +#define SLAVE_PRNG 26 +#define SLAVE_QDSS_CFG 27 +#define SLAVE_BLSP_2 28 +#define SLAVE_BLSP_1 29 +#define SLAVE_SDCC_2 30 +#define SLAVE_SDCC_4 31 +#define SLAVE_SNOC_CFG 32 +#define SLAVE_SPDM_WRAPPER 33 +#define SLAVE_SPSS_CFG 34 +#define SLAVE_TCSR 35 +#define SLAVE_TLMM_NORTH 36 +#define SLAVE_TLMM_SOUTH 37 +#define SLAVE_TSIF 38 +#define SLAVE_UFS_CARD_CFG 39 +#define SLAVE_UFS_MEM_CFG 40 +#define SLAVE_USB3_0 41 +#define SLAVE_USB3_1 42 +#define SLAVE_VENUS_CFG 43 +#define SLAVE_VSENSE_CTRL_CFG 44 +#define SLAVE_CNOC_A2NOC 45 +#define SLAVE_SERVICE_CNOC 46 + +#define MASTER_CNOC_DC_NOC 0 +#define SLAVE_LLCC_CFG 1 +#define SLAVE_MEM_NOC_CFG 2 + +#define MASTER_APPSS_PROC 0 +#define MASTER_GNOC_CFG 1 +#define SLAVE_GNOC_SNOC 2 +#define SLAVE_GNOC_MEM_NOC 3 +#define SLAVE_SERVICE_GNOC 4 + +#define MASTER_TCU_0 0 +#define MASTER_MEM_NOC_CFG 1 +#define MASTER_GNOC_MEM_NOC 2 +#define MASTER_MNOC_HF_MEM_NOC 3 +#define MASTER_MNOC_SF_MEM_NOC 4 +#define MASTER_SNOC_GC_MEM_NOC 5 +#define MASTER_SNOC_SF_MEM_NOC 6 +#define MASTER_GFX3D 7 +#define SLAVE_MSS_PROC_MS_MPU_CFG 8 +#define SLAVE_MEM_NOC_GNOC 9 +#define SLAVE_LLCC 10 +#define SLAVE_MEM_NOC_SNOC 11 +#define SLAVE_SERVICE_MEM_NOC 12 +#define MASTER_LLCC 13 +#define SLAVE_EBI1 14 + +#define MASTER_CNOC_MNOC_CFG 0 +#define MASTER_CAMNOC_HF0 1 +#define MASTER_CAMNOC_HF1 2 +#define MASTER_CAMNOC_SF 3 +#define MASTER_MDP0 4 +#define MASTER_MDP1 5 +#define MASTER_ROTATOR 6 +#define MASTER_VIDEO_P0 7 +#define MASTER_VIDEO_P1 8 +#define MASTER_VIDEO_PROC 9 +#define SLAVE_MNOC_SF_MEM_NOC 10 +#define SLAVE_MNOC_HF_MEM_NOC 11 +#define SLAVE_SERVICE_MNOC 12 +#define MASTER_CAMNOC_HF0_UNCOMP 13 +#define MASTER_CAMNOC_HF1_UNCOMP 14 +#define MASTER_CAMNOC_SF_UNCOMP 15 +#define SLAVE_CAMNOC_UNCOMP 16 + +#define MASTER_SNOC_CFG 0 +#define MASTER_A1NOC_SNOC 1 +#define MASTER_A2NOC_SNOC 2 +#define MASTER_GNOC_SNOC 3 +#define MASTER_MEM_NOC_SNOC 4 +#define MASTER_ANOC_PCIE_SNOC 5 +#define MASTER_PIMEM 6 +#define MASTER_GIC 7 +#define SLAVE_APPSS 8 +#define SLAVE_SNOC_CNOC 9 +#define SLAVE_SNOC_MEM_NOC_GC 10 +#define SLAVE_SNOC_MEM_NOC_SF 11 +#define SLAVE_IMEM 12 +#define SLAVE_PCIE_0 13 +#define SLAVE_PCIE_1 14 +#define SLAVE_PIMEM 15 +#define SLAVE_SERVICE_SNOC 16 +#define SLAVE_QDSS_STM 17 +#define SLAVE_TCU 18 + +#endif diff --git a/include/dt-bindings/phy/phy-qcom-qmp.h b/include/dt-bindings/phy/phy-qcom-qmp.h new file mode 100644 index 000000000000..4edec4c5b224 --- /dev/null +++ b/include/dt-bindings/phy/phy-qcom-qmp.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) */ +/* + * Qualcomm QMP PHY constants + * + * Copyright (C) 2022 Linaro Limited + */ + +#ifndef _DT_BINDINGS_PHY_QMP +#define _DT_BINDINGS_PHY_QMP + +/* QMP USB4-USB3-DP clocks */ +#define QMP_USB43DP_USB3_PIPE_CLK 0 +#define QMP_USB43DP_DP_LINK_CLK 1 +#define QMP_USB43DP_DP_VCO_DIV_CLK 2 + +/* QMP USB4-USB3-DP PHYs */ +#define QMP_USB43DP_USB3_PHY 0 +#define QMP_USB43DP_DP_PHY 1 + +#endif /* _DT_BINDINGS_PHY_QMP */ diff --git a/include/dt-bindings/phy/phy-qcom-qusb2.h b/include/dt-bindings/phy/phy-qcom-qusb2.h new file mode 100644 index 000000000000..5c5e4d800cac --- /dev/null +++ b/include/dt-bindings/phy/phy-qcom-qusb2.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_QCOM_PHY_QUSB2_H_ +#define _DT_BINDINGS_QCOM_PHY_QUSB2_H_ + +/* PHY HSTX TRIM bit values (24mA to 15mA) */ +#define QUSB2_V2_HSTX_TRIM_24_0_MA 0x0 +#define QUSB2_V2_HSTX_TRIM_23_4_MA 0x1 +#define QUSB2_V2_HSTX_TRIM_22_8_MA 0x2 +#define QUSB2_V2_HSTX_TRIM_22_2_MA 0x3 +#define QUSB2_V2_HSTX_TRIM_21_6_MA 0x4 +#define QUSB2_V2_HSTX_TRIM_21_0_MA 0x5 +#define QUSB2_V2_HSTX_TRIM_20_4_MA 0x6 +#define QUSB2_V2_HSTX_TRIM_19_8_MA 0x7 +#define QUSB2_V2_HSTX_TRIM_19_2_MA 0x8 +#define QUSB2_V2_HSTX_TRIM_18_6_MA 0x9 +#define QUSB2_V2_HSTX_TRIM_18_0_MA 0xa +#define QUSB2_V2_HSTX_TRIM_17_4_MA 0xb +#define QUSB2_V2_HSTX_TRIM_16_8_MA 0xc +#define QUSB2_V2_HSTX_TRIM_16_2_MA 0xd +#define QUSB2_V2_HSTX_TRIM_15_6_MA 0xe +#define QUSB2_V2_HSTX_TRIM_15_0_MA 0xf + +/* PHY PREEMPHASIS bit values */ +#define QUSB2_V2_PREEMPHASIS_NONE 0 +#define QUSB2_V2_PREEMPHASIS_5_PERCENT 1 +#define QUSB2_V2_PREEMPHASIS_10_PERCENT 2 +#define QUSB2_V2_PREEMPHASIS_15_PERCENT 3 + +/* PHY PREEMPHASIS-WIDTH bit values */ +#define QUSB2_V2_PREEMPHASIS_WIDTH_FULL_BIT 0 +#define QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT 1 + +#endif diff --git a/include/dt-bindings/pinctrl/qcom,pmic-gpio.h b/include/dt-bindings/pinctrl/qcom,pmic-gpio.h new file mode 100644 index 000000000000..e5df5ce45a0f --- /dev/null +++ b/include/dt-bindings/pinctrl/qcom,pmic-gpio.h @@ -0,0 +1,164 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for the Qualcomm PMIC GPIO binding. + */ + +#ifndef _DT_BINDINGS_PINCTRL_QCOM_PMIC_GPIO_H +#define _DT_BINDINGS_PINCTRL_QCOM_PMIC_GPIO_H + +#define PMIC_GPIO_PULL_UP_30 0 +#define PMIC_GPIO_PULL_UP_1P5 1 +#define PMIC_GPIO_PULL_UP_31P5 2 +#define PMIC_GPIO_PULL_UP_1P5_30 3 + +#define PMIC_GPIO_STRENGTH_NO 0 +#define PMIC_GPIO_STRENGTH_HIGH 1 +#define PMIC_GPIO_STRENGTH_MED 2 +#define PMIC_GPIO_STRENGTH_LOW 3 + +/* + * Note: PM8018 GPIO3 and GPIO4 are supporting + * only S3 and L2 options (1.8V) + */ +#define PM8018_GPIO_L6 0 +#define PM8018_GPIO_L5 1 +#define PM8018_GPIO_S3 2 +#define PM8018_GPIO_L14 3 +#define PM8018_GPIO_L2 4 +#define PM8018_GPIO_L4 5 +#define PM8018_GPIO_VDD 6 + +/* + * Note: PM8038 GPIO7 and GPIO8 are supporting + * only L11 and L4 options (1.8V) + */ +#define PM8038_GPIO_VPH 0 +#define PM8038_GPIO_BB 1 +#define PM8038_GPIO_L11 2 +#define PM8038_GPIO_L15 3 +#define PM8038_GPIO_L4 4 +#define PM8038_GPIO_L3 5 +#define PM8038_GPIO_L17 6 + +#define PM8058_GPIO_VPH 0 +#define PM8058_GPIO_BB 1 +#define PM8058_GPIO_S3 2 +#define PM8058_GPIO_L3 3 +#define PM8058_GPIO_L7 4 +#define PM8058_GPIO_L6 5 +#define PM8058_GPIO_L5 6 +#define PM8058_GPIO_L2 7 + +/* + * Note: PM8916 GPIO1 and GPIO2 are supporting + * only L2(1.15V) and L5(1.8V) options + */ +#define PM8916_GPIO_VPH 0 +#define PM8916_GPIO_L2 2 +#define PM8916_GPIO_L5 3 + +#define PM8917_GPIO_VPH 0 +#define PM8917_GPIO_S4 2 +#define PM8917_GPIO_L15 3 +#define PM8917_GPIO_L4 4 +#define PM8917_GPIO_L3 5 +#define PM8917_GPIO_L17 6 + +#define PM8921_GPIO_VPH 0 +#define PM8921_GPIO_BB 1 +#define PM8921_GPIO_S4 2 +#define PM8921_GPIO_L15 3 +#define PM8921_GPIO_L4 4 +#define PM8921_GPIO_L3 5 +#define PM8921_GPIO_L17 6 + +/* + * Note: PM8941 gpios from 15 to 18 are supporting + * only S3 and L6 options (1.8V) + */ +#define PM8941_GPIO_VPH 0 +#define PM8941_GPIO_L1 1 +#define PM8941_GPIO_S3 2 +#define PM8941_GPIO_L6 3 + +/* + * Note: PMA8084 gpios from 15 to 18 are supporting + * only S4 and L6 options (1.8V) + */ +#define PMA8084_GPIO_VPH 0 +#define PMA8084_GPIO_L1 1 +#define PMA8084_GPIO_S4 2 +#define PMA8084_GPIO_L6 3 + +#define PM8994_GPIO_VPH 0 +#define PM8994_GPIO_S4 2 +#define PM8994_GPIO_L12 3 + +/* To be used with "function" */ +#define PMIC_GPIO_FUNC_NORMAL "normal" +#define PMIC_GPIO_FUNC_PAIRED "paired" +#define PMIC_GPIO_FUNC_FUNC1 "func1" +#define PMIC_GPIO_FUNC_FUNC2 "func2" +#define PMIC_GPIO_FUNC_FUNC3 "func3" +#define PMIC_GPIO_FUNC_FUNC4 "func4" +#define PMIC_GPIO_FUNC_DTEST1 "dtest1" +#define PMIC_GPIO_FUNC_DTEST2 "dtest2" +#define PMIC_GPIO_FUNC_DTEST3 "dtest3" +#define PMIC_GPIO_FUNC_DTEST4 "dtest4" + +#define PM8038_GPIO1_2_LPG_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO3_5V_BOOST_EN PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO4_SSBI_ALT_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO5_6_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO10_11_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO6_7_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO9_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 +#define PM8038_GPIO6_12_KYPD_DRV PMIC_GPIO_FUNC_FUNC2 + +#define PM8058_GPIO7_8_MP3_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO7_8_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC2 +#define PM8058_GPIO9_26_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO21_23_UART_TX PMIC_GPIO_FUNC_FUNC2 +#define PM8058_GPIO24_26_LPG_DRV PMIC_GPIO_FUNC_FUNC2 +#define PM8058_GPIO33_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO34_35_MP3_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO36_BCLK_19P2MHZ PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO37_UPL_OUT PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO37_UART_M_RX PMIC_GPIO_FUNC_FUNC2 +#define PM8058_GPIO38_XO_SLEEP_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO38_39_CLK_32KHZ PMIC_GPIO_FUNC_FUNC2 +#define PM8058_GPIO39_MP3_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8058_GPIO40_EXT_BB_EN PMIC_GPIO_FUNC_FUNC1 + +#define PM8916_GPIO1_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 +#define PM8916_GPIO1_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 +#define PM8916_GPIO2_DIV_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8916_GPIO2_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 +#define PM8916_GPIO3_KEYP_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8916_GPIO4_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 + +#define PM8917_GPIO9_18_KEYP_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8917_GPIO20_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 +#define PM8917_GPIO21_23_UART_TX PMIC_GPIO_FUNC_FUNC2 +#define PM8917_GPIO25_26_EXT_REG_EN PMIC_GPIO_FUNC_FUNC1 +#define PM8917_GPIO37_38_XO_SLEEP_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8917_GPIO37_38_MP3_CLK PMIC_GPIO_FUNC_FUNC2 + +#define PM8941_GPIO9_14_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8941_GPIO15_18_DIV_CLK PMIC_GPIO_FUNC_FUNC1 +#define PM8941_GPIO15_18_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 +#define PM8941_GPIO23_26_KYPD_DRV PMIC_GPIO_FUNC_FUNC1 +#define PM8941_GPIO23_26_LPG_DRV_HI PMIC_GPIO_FUNC_FUNC2 +#define PM8941_GPIO31_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 +#define PM8941_GPIO33_36_LPG_DRV_3D PMIC_GPIO_FUNC_FUNC1 +#define PM8941_GPIO33_36_LPG_DRV_HI PMIC_GPIO_FUNC_FUNC2 + +#define PMA8084_GPIO4_5_LPG_DRV PMIC_GPIO_FUNC_FUNC1 +#define PMA8084_GPIO7_10_LPG_DRV PMIC_GPIO_FUNC_FUNC1 +#define PMA8084_GPIO5_14_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 +#define PMA8084_GPIO19_21_KEYP_DRV PMIC_GPIO_FUNC_FUNC2 +#define PMA8084_GPIO15_18_DIV_CLK PMIC_GPIO_FUNC_FUNC1 +#define PMA8084_GPIO15_18_SLEEP_CLK PMIC_GPIO_FUNC_FUNC2 +#define PMA8084_GPIO22_BAT_ALRM_OUT PMIC_GPIO_FUNC_FUNC1 + +#endif diff --git a/include/dt-bindings/power/qcom-rpmpd.h b/include/dt-bindings/power/qcom-rpmpd.h new file mode 100644 index 000000000000..7f4e2983a4c5 --- /dev/null +++ b/include/dt-bindings/power/qcom-rpmpd.h @@ -0,0 +1,412 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ + +#ifndef _DT_BINDINGS_POWER_QCOM_RPMPD_H +#define _DT_BINDINGS_POWER_QCOM_RPMPD_H + +/* SA8775P Power Domain Indexes */ +#define SA8775P_CX 0 +#define SA8775P_CX_AO 1 +#define SA8775P_DDR 2 +#define SA8775P_EBI 3 +#define SA8775P_GFX 4 +#define SA8775P_LCX 5 +#define SA8775P_LMX 6 +#define SA8775P_MMCX 7 +#define SA8775P_MMCX_AO 8 +#define SA8775P_MSS 9 +#define SA8775P_MX 10 +#define SA8775P_MX_AO 11 +#define SA8775P_MXC 12 +#define SA8775P_MXC_AO 13 +#define SA8775P_NSP0 14 +#define SA8775P_NSP1 15 +#define SA8775P_XO 16 + +/* SDM670 Power Domain Indexes */ +#define SDM670_MX 0 +#define SDM670_MX_AO 1 +#define SDM670_CX 2 +#define SDM670_CX_AO 3 +#define SDM670_LMX 4 +#define SDM670_LCX 5 +#define SDM670_GFX 6 +#define SDM670_MSS 7 + +/* SDM845 Power Domain Indexes */ +#define SDM845_EBI 0 +#define SDM845_MX 1 +#define SDM845_MX_AO 2 +#define SDM845_CX 3 +#define SDM845_CX_AO 4 +#define SDM845_LMX 5 +#define SDM845_LCX 6 +#define SDM845_GFX 7 +#define SDM845_MSS 8 + +/* SDX55 Power Domain Indexes */ +#define SDX55_MSS 0 +#define SDX55_MX 1 +#define SDX55_CX 2 + +/* SDX65 Power Domain Indexes */ +#define SDX65_MSS 0 +#define SDX65_MX 1 +#define SDX65_MX_AO 2 +#define SDX65_CX 3 +#define SDX65_CX_AO 4 +#define SDX65_MXC 5 + +/* SM6350 Power Domain Indexes */ +#define SM6350_CX 0 +#define SM6350_GFX 1 +#define SM6350_LCX 2 +#define SM6350_LMX 3 +#define SM6350_MSS 4 +#define SM6350_MX 5 + +/* SM6350 Power Domain Indexes */ +#define SM6375_VDDCX 0 +#define SM6375_VDDCX_AO 1 +#define SM6375_VDDCX_VFL 2 +#define SM6375_VDDMX 3 +#define SM6375_VDDMX_AO 4 +#define SM6375_VDDMX_VFL 5 +#define SM6375_VDDGX 6 +#define SM6375_VDDGX_AO 7 +#define SM6375_VDD_LPI_CX 8 +#define SM6375_VDD_LPI_MX 9 + +/* SM8150 Power Domain Indexes */ +#define SM8150_MSS 0 +#define SM8150_EBI 1 +#define SM8150_LMX 2 +#define SM8150_LCX 3 +#define SM8150_GFX 4 +#define SM8150_MX 5 +#define SM8150_MX_AO 6 +#define SM8150_CX 7 +#define SM8150_CX_AO 8 +#define SM8150_MMCX 9 +#define SM8150_MMCX_AO 10 + +/* SA8155P is a special case, kept for backwards compatibility */ +#define SA8155P_CX SM8150_CX +#define SA8155P_CX_AO SM8150_CX_AO +#define SA8155P_EBI SM8150_EBI +#define SA8155P_GFX SM8150_GFX +#define SA8155P_MSS SM8150_MSS +#define SA8155P_MX SM8150_MX +#define SA8155P_MX_AO SM8150_MX_AO + +/* SM8250 Power Domain Indexes */ +#define SM8250_CX 0 +#define SM8250_CX_AO 1 +#define SM8250_EBI 2 +#define SM8250_GFX 3 +#define SM8250_LCX 4 +#define SM8250_LMX 5 +#define SM8250_MMCX 6 +#define SM8250_MMCX_AO 7 +#define SM8250_MX 8 +#define SM8250_MX_AO 9 + +/* SM8350 Power Domain Indexes */ +#define SM8350_CX 0 +#define SM8350_CX_AO 1 +#define SM8350_EBI 2 +#define SM8350_GFX 3 +#define SM8350_LCX 4 +#define SM8350_LMX 5 +#define SM8350_MMCX 6 +#define SM8350_MMCX_AO 7 +#define SM8350_MX 8 +#define SM8350_MX_AO 9 +#define SM8350_MXC 10 +#define SM8350_MXC_AO 11 +#define SM8350_MSS 12 + +/* SM8450 Power Domain Indexes */ +#define SM8450_CX 0 +#define SM8450_CX_AO 1 +#define SM8450_EBI 2 +#define SM8450_GFX 3 +#define SM8450_LCX 4 +#define SM8450_LMX 5 +#define SM8450_MMCX 6 +#define SM8450_MMCX_AO 7 +#define SM8450_MX 8 +#define SM8450_MX_AO 9 +#define SM8450_MXC 10 +#define SM8450_MXC_AO 11 +#define SM8450_MSS 12 + +/* SM8550 Power Domain Indexes */ +#define SM8550_CX 0 +#define SM8550_CX_AO 1 +#define SM8550_EBI 2 +#define SM8550_GFX 3 +#define SM8550_LCX 4 +#define SM8550_LMX 5 +#define SM8550_MMCX 6 +#define SM8550_MMCX_AO 7 +#define SM8550_MX 8 +#define SM8550_MX_AO 9 +#define SM8550_MXC 10 +#define SM8550_MXC_AO 11 +#define SM8550_MSS 12 +#define SM8550_NSP 13 + +/* QDU1000/QRU1000 Power Domain Indexes */ +#define QDU1000_EBI 0 +#define QDU1000_MSS 1 +#define QDU1000_CX 2 +#define QDU1000_MX 3 + +/* SC7180 Power Domain Indexes */ +#define SC7180_CX 0 +#define SC7180_CX_AO 1 +#define SC7180_GFX 2 +#define SC7180_MX 3 +#define SC7180_MX_AO 4 +#define SC7180_LMX 5 +#define SC7180_LCX 6 +#define SC7180_MSS 7 + +/* SC7280 Power Domain Indexes */ +#define SC7280_CX 0 +#define SC7280_CX_AO 1 +#define SC7280_EBI 2 +#define SC7280_GFX 3 +#define SC7280_MX 4 +#define SC7280_MX_AO 5 +#define SC7280_LMX 6 +#define SC7280_LCX 7 +#define SC7280_MSS 8 + +/* SC8180X Power Domain Indexes */ +#define SC8180X_CX 0 +#define SC8180X_CX_AO 1 +#define SC8180X_EBI 2 +#define SC8180X_GFX 3 +#define SC8180X_LCX 4 +#define SC8180X_LMX 5 +#define SC8180X_MMCX 6 +#define SC8180X_MMCX_AO 7 +#define SC8180X_MSS 8 +#define SC8180X_MX 9 +#define SC8180X_MX_AO 10 + +/* SC8280XP Power Domain Indexes */ +#define SC8280XP_CX 0 +#define SC8280XP_CX_AO 1 +#define SC8280XP_DDR 2 +#define SC8280XP_EBI 3 +#define SC8280XP_GFX 4 +#define SC8280XP_LCX 5 +#define SC8280XP_LMX 6 +#define SC8280XP_MMCX 7 +#define SC8280XP_MMCX_AO 8 +#define SC8280XP_MSS 9 +#define SC8280XP_MX 10 +#define SC8280XP_MXC 12 +#define SC8280XP_MX_AO 11 +#define SC8280XP_NSP 13 +#define SC8280XP_QPHY 14 +#define SC8280XP_XO 15 + +/* SDM845 Power Domain performance levels */ +#define RPMH_REGULATOR_LEVEL_RETENTION 16 +#define RPMH_REGULATOR_LEVEL_MIN_SVS 48 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D2 52 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D1 56 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_D0 60 +#define RPMH_REGULATOR_LEVEL_LOW_SVS 64 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_P1 72 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_L1 80 +#define RPMH_REGULATOR_LEVEL_LOW_SVS_L2 96 +#define RPMH_REGULATOR_LEVEL_SVS 128 +#define RPMH_REGULATOR_LEVEL_SVS_L0 144 +#define RPMH_REGULATOR_LEVEL_SVS_L1 192 +#define RPMH_REGULATOR_LEVEL_SVS_L2 224 +#define RPMH_REGULATOR_LEVEL_NOM 256 +#define RPMH_REGULATOR_LEVEL_NOM_L0 288 +#define RPMH_REGULATOR_LEVEL_NOM_L1 320 +#define RPMH_REGULATOR_LEVEL_NOM_L2 336 +#define RPMH_REGULATOR_LEVEL_TURBO 384 +#define RPMH_REGULATOR_LEVEL_TURBO_L0 400 +#define RPMH_REGULATOR_LEVEL_TURBO_L1 416 +#define RPMH_REGULATOR_LEVEL_TURBO_L2 432 +#define RPMH_REGULATOR_LEVEL_TURBO_L3 448 +#define RPMH_REGULATOR_LEVEL_SUPER_TURBO 464 +#define RPMH_REGULATOR_LEVEL_SUPER_TURBO_NO_CPR 480 + +/* MDM9607 Power Domains */ +#define MDM9607_VDDCX 0 +#define MDM9607_VDDCX_AO 1 +#define MDM9607_VDDCX_VFL 2 +#define MDM9607_VDDMX 3 +#define MDM9607_VDDMX_AO 4 +#define MDM9607_VDDMX_VFL 5 + +/* MSM8226 Power Domain Indexes */ +#define MSM8226_VDDCX 0 +#define MSM8226_VDDCX_AO 1 +#define MSM8226_VDDCX_VFC 2 + +/* MSM8939 Power Domains */ +#define MSM8939_VDDMDCX 0 +#define MSM8939_VDDMDCX_AO 1 +#define MSM8939_VDDMDCX_VFC 2 +#define MSM8939_VDDCX 3 +#define MSM8939_VDDCX_AO 4 +#define MSM8939_VDDCX_VFC 5 +#define MSM8939_VDDMX 6 +#define MSM8939_VDDMX_AO 7 + +/* MSM8916 Power Domain Indexes */ +#define MSM8916_VDDCX 0 +#define MSM8916_VDDCX_AO 1 +#define MSM8916_VDDCX_VFC 2 +#define MSM8916_VDDMX 3 +#define MSM8916_VDDMX_AO 4 + +/* MSM8909 Power Domain Indexes */ +#define MSM8909_VDDCX MSM8916_VDDCX +#define MSM8909_VDDCX_AO MSM8916_VDDCX_AO +#define MSM8909_VDDCX_VFC MSM8916_VDDCX_VFC +#define MSM8909_VDDMX MSM8916_VDDMX +#define MSM8909_VDDMX_AO MSM8916_VDDMX_AO + +/* MSM8917 Power Domain Indexes */ +#define MSM8917_VDDCX 0 +#define MSM8917_VDDCX_AO 1 +#define MSM8917_VDDCX_VFL 2 +#define MSM8917_VDDMX 3 +#define MSM8917_VDDMX_AO 4 + +/* MSM8937 Power Domain Indexes */ +#define MSM8937_VDDCX MSM8917_VDDCX +#define MSM8937_VDDCX_AO MSM8917_VDDCX_AO +#define MSM8937_VDDCX_VFL MSM8917_VDDCX_VFL +#define MSM8937_VDDMX MSM8917_VDDMX +#define MSM8937_VDDMX_AO MSM8917_VDDMX_AO + +/* QM215 Power Domain Indexes */ +#define QM215_VDDCX MSM8917_VDDCX +#define QM215_VDDCX_AO MSM8917_VDDCX_AO +#define QM215_VDDCX_VFL MSM8917_VDDCX_VFL +#define QM215_VDDMX MSM8917_VDDMX +#define QM215_VDDMX_AO MSM8917_VDDMX_AO + +/* MSM8953 Power Domain Indexes */ +#define MSM8953_VDDMD 0 +#define MSM8953_VDDMD_AO 1 +#define MSM8953_VDDCX 2 +#define MSM8953_VDDCX_AO 3 +#define MSM8953_VDDCX_VFL 4 +#define MSM8953_VDDMX 5 +#define MSM8953_VDDMX_AO 6 + +/* MSM8976 Power Domain Indexes */ +#define MSM8976_VDDCX 0 +#define MSM8976_VDDCX_AO 1 +#define MSM8976_VDDCX_VFL 2 +#define MSM8976_VDDMX 3 +#define MSM8976_VDDMX_AO 4 +#define MSM8976_VDDMX_VFL 5 + +/* MSM8994 Power Domain Indexes */ +#define MSM8994_VDDCX 0 +#define MSM8994_VDDCX_AO 1 +#define MSM8994_VDDCX_VFC 2 +#define MSM8994_VDDMX 3 +#define MSM8994_VDDMX_AO 4 +#define MSM8994_VDDGFX 5 +#define MSM8994_VDDGFX_VFC 6 + +/* MSM8996 Power Domain Indexes */ +#define MSM8996_VDDCX 0 +#define MSM8996_VDDCX_AO 1 +#define MSM8996_VDDCX_VFC 2 +#define MSM8996_VDDMX 3 +#define MSM8996_VDDMX_AO 4 +#define MSM8996_VDDSSCX 5 +#define MSM8996_VDDSSCX_VFC 6 + +/* MSM8998 Power Domain Indexes */ +#define MSM8998_VDDCX 0 +#define MSM8998_VDDCX_AO 1 +#define MSM8998_VDDCX_VFL 2 +#define MSM8998_VDDMX 3 +#define MSM8998_VDDMX_AO 4 +#define MSM8998_VDDMX_VFL 5 +#define MSM8998_SSCCX 6 +#define MSM8998_SSCCX_VFL 7 +#define MSM8998_SSCMX 8 +#define MSM8998_SSCMX_VFL 9 + +/* QCS404 Power Domains */ +#define QCS404_VDDMX 0 +#define QCS404_VDDMX_AO 1 +#define QCS404_VDDMX_VFL 2 +#define QCS404_LPICX 3 +#define QCS404_LPICX_VFL 4 +#define QCS404_LPIMX 5 +#define QCS404_LPIMX_VFL 6 + +/* SDM660 Power Domains */ +#define SDM660_VDDCX 0 +#define SDM660_VDDCX_AO 1 +#define SDM660_VDDCX_VFL 2 +#define SDM660_VDDMX 3 +#define SDM660_VDDMX_AO 4 +#define SDM660_VDDMX_VFL 5 +#define SDM660_SSCCX 6 +#define SDM660_SSCCX_VFL 7 +#define SDM660_SSCMX 8 +#define SDM660_SSCMX_VFL 9 + +/* SM6115 Power Domains */ +#define SM6115_VDDCX 0 +#define SM6115_VDDCX_AO 1 +#define SM6115_VDDCX_VFL 2 +#define SM6115_VDDMX 3 +#define SM6115_VDDMX_AO 4 +#define SM6115_VDDMX_VFL 5 +#define SM6115_VDD_LPI_CX 6 +#define SM6115_VDD_LPI_MX 7 + +/* SM6125 Power Domains */ +#define SM6125_VDDCX 0 +#define SM6125_VDDCX_AO 1 +#define SM6125_VDDCX_VFL 2 +#define SM6125_VDDMX 3 +#define SM6125_VDDMX_AO 4 +#define SM6125_VDDMX_VFL 5 + +/* QCM2290 Power Domains */ +#define QCM2290_VDDCX 0 +#define QCM2290_VDDCX_AO 1 +#define QCM2290_VDDCX_VFL 2 +#define QCM2290_VDDMX 3 +#define QCM2290_VDDMX_AO 4 +#define QCM2290_VDDMX_VFL 5 +#define QCM2290_VDD_LPI_CX 6 +#define QCM2290_VDD_LPI_MX 7 + +/* RPM SMD Power Domain performance levels */ +#define RPM_SMD_LEVEL_RETENTION 16 +#define RPM_SMD_LEVEL_RETENTION_PLUS 32 +#define RPM_SMD_LEVEL_MIN_SVS 48 +#define RPM_SMD_LEVEL_LOW_SVS 64 +#define RPM_SMD_LEVEL_SVS 128 +#define RPM_SMD_LEVEL_SVS_PLUS 192 +#define RPM_SMD_LEVEL_NOM 256 +#define RPM_SMD_LEVEL_NOM_PLUS 320 +#define RPM_SMD_LEVEL_TURBO 384 +#define RPM_SMD_LEVEL_TURBO_NO_CPR 416 +#define RPM_SMD_LEVEL_TURBO_HIGH 448 +#define RPM_SMD_LEVEL_BINNING 512 + +#endif diff --git a/include/dt-bindings/qcom,q6asm.h b/include/dt-bindings/qcom,q6asm.h new file mode 100644 index 000000000000..f59d74f14395 --- /dev/null +++ b/include/dt-bindings/qcom,q6asm.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_Q6_ASM_H__ +#define __DT_BINDINGS_Q6_ASM_H__ + +#define MSM_FRONTEND_DAI_MULTIMEDIA1 0 +#define MSM_FRONTEND_DAI_MULTIMEDIA2 1 +#define MSM_FRONTEND_DAI_MULTIMEDIA3 2 +#define MSM_FRONTEND_DAI_MULTIMEDIA4 3 +#define MSM_FRONTEND_DAI_MULTIMEDIA5 4 +#define MSM_FRONTEND_DAI_MULTIMEDIA6 5 +#define MSM_FRONTEND_DAI_MULTIMEDIA7 6 +#define MSM_FRONTEND_DAI_MULTIMEDIA8 7 +#define MSM_FRONTEND_DAI_MULTIMEDIA9 8 +#define MSM_FRONTEND_DAI_MULTIMEDIA10 9 +#define MSM_FRONTEND_DAI_MULTIMEDIA11 10 +#define MSM_FRONTEND_DAI_MULTIMEDIA12 11 +#define MSM_FRONTEND_DAI_MULTIMEDIA13 12 +#define MSM_FRONTEND_DAI_MULTIMEDIA14 13 +#define MSM_FRONTEND_DAI_MULTIMEDIA15 14 +#define MSM_FRONTEND_DAI_MULTIMEDIA16 15 + +#define Q6ASM_DAI_TX_RX 0 +#define Q6ASM_DAI_TX 1 +#define Q6ASM_DAI_RX 2 + +#endif /* __DT_BINDINGS_Q6_ASM_H__ */ diff --git a/include/dt-bindings/regulator/qcom,rpmh-regulator.h b/include/dt-bindings/regulator/qcom,rpmh-regulator.h new file mode 100644 index 000000000000..86713dcf9e02 --- /dev/null +++ b/include/dt-bindings/regulator/qcom,rpmh-regulator.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* Copyright (c) 2018, The Linux Foundation. All rights reserved. */ + +#ifndef __QCOM_RPMH_REGULATOR_H +#define __QCOM_RPMH_REGULATOR_H + +/* + * These mode constants may be used to specify modes for various RPMh regulator + * device tree properties (e.g. regulator-initial-mode). Each type of regulator + * supports a subset of the possible modes. + * + * %RPMH_REGULATOR_MODE_RET: Retention mode in which only an extremely small + * load current is allowed. This mode is supported + * by LDO and SMPS type regulators. + * %RPMH_REGULATOR_MODE_LPM: Low power mode in which a small load current is + * allowed. This mode corresponds to PFM for SMPS + * and BOB type regulators. This mode is supported + * by LDO, HFSMPS, BOB, and PMIC4 FTSMPS type + * regulators. + * %RPMH_REGULATOR_MODE_AUTO: Auto mode in which the regulator hardware + * automatically switches between LPM and HPM based + * upon the real-time load current. This mode is + * supported by HFSMPS, BOB, and PMIC4 FTSMPS type + * regulators. + * %RPMH_REGULATOR_MODE_HPM: High power mode in which the full rated current + * of the regulator is allowed. This mode + * corresponds to PWM for SMPS and BOB type + * regulators. This mode is supported by all types + * of regulators. + */ +#define RPMH_REGULATOR_MODE_RET 0 +#define RPMH_REGULATOR_MODE_LPM 1 +#define RPMH_REGULATOR_MODE_AUTO 2 +#define RPMH_REGULATOR_MODE_HPM 3 + +#endif diff --git a/include/dt-bindings/reset/qcom,sdm845-aoss.h b/include/dt-bindings/reset/qcom,sdm845-aoss.h new file mode 100644 index 000000000000..476c5fc873b6 --- /dev/null +++ b/include/dt-bindings/reset/qcom,sdm845-aoss.h @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_RESET_AOSS_SDM_845_H +#define _DT_BINDINGS_RESET_AOSS_SDM_845_H + +#define AOSS_CC_MSS_RESTART 0 +#define AOSS_CC_CAMSS_RESTART 1 +#define AOSS_CC_VENUS_RESTART 2 +#define AOSS_CC_GPU_RESTART 3 +#define AOSS_CC_DISPSS_RESTART 4 +#define AOSS_CC_WCSS_RESTART 5 +#define AOSS_CC_LPASS_RESTART 6 + +#endif diff --git a/include/dt-bindings/reset/qcom,sdm845-pdc.h b/include/dt-bindings/reset/qcom,sdm845-pdc.h new file mode 100644 index 000000000000..03a0c0eb8147 --- /dev/null +++ b/include/dt-bindings/reset/qcom,sdm845-pdc.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018 The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_RESET_PDC_SDM_845_H +#define _DT_BINDINGS_RESET_PDC_SDM_845_H + +#define PDC_APPS_SYNC_RESET 0 +#define PDC_SP_SYNC_RESET 1 +#define PDC_AUDIO_SYNC_RESET 2 +#define PDC_SENSORS_SYNC_RESET 3 +#define PDC_AOP_SYNC_RESET 4 +#define PDC_DEBUG_SYNC_RESET 5 +#define PDC_GPU_SYNC_RESET 6 +#define PDC_DISPLAY_SYNC_RESET 7 +#define PDC_COMPUTE_SYNC_RESET 8 +#define PDC_MODEM_SYNC_RESET 9 +#define PDC_WLAN_RF_SYNC_RESET 10 +#define PDC_WPSS_SYNC_RESET 11 + +#endif diff --git a/include/dt-bindings/soc/qcom,apr.h b/include/dt-bindings/soc/qcom,apr.h new file mode 100644 index 000000000000..006362400c0f --- /dev/null +++ b/include/dt-bindings/soc/qcom,apr.h @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_QCOM_APR_H +#define __DT_BINDINGS_QCOM_APR_H + +/* Domain IDs */ +#define APR_DOMAIN_SIM 0x1 +#define APR_DOMAIN_PC 0x2 +#define APR_DOMAIN_MODEM 0x3 +#define APR_DOMAIN_ADSP 0x4 +#define APR_DOMAIN_APPS 0x5 +#define APR_DOMAIN_MAX 0x6 + +/* ADSP service IDs */ +#define APR_SVC_ADSP_CORE 0x3 +#define APR_SVC_AFE 0x4 +#define APR_SVC_VSM 0x5 +#define APR_SVC_VPM 0x6 +#define APR_SVC_ASM 0x7 +#define APR_SVC_ADM 0x8 +#define APR_SVC_ADSP_MVM 0x09 +#define APR_SVC_ADSP_CVS 0x0A +#define APR_SVC_ADSP_CVP 0x0B +#define APR_SVC_USM 0x0C +#define APR_SVC_LSM 0x0D +#define APR_SVC_VIDC 0x16 +#define APR_SVC_MAX 0x17 + +#endif /* __DT_BINDINGS_QCOM_APR_H */ diff --git a/include/dt-bindings/soc/qcom,rpmh-rsc.h b/include/dt-bindings/soc/qcom,rpmh-rsc.h new file mode 100644 index 000000000000..868f998ea998 --- /dev/null +++ b/include/dt-bindings/soc/qcom,rpmh-rsc.h @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2016-2018, The Linux Foundation. All rights reserved. + */ + +#ifndef __DT_QCOM_RPMH_RSC_H__ +#define __DT_QCOM_RPMH_RSC_H__ + +#define SLEEP_TCS 0 +#define WAKE_TCS 1 +#define ACTIVE_TCS 2 +#define CONTROL_TCS 3 + +#endif /* __DT_QCOM_RPMH_RSC_H__ */ diff --git a/include/dt-bindings/sound/qcom,q6afe.h b/include/dt-bindings/sound/qcom,q6afe.h new file mode 100644 index 000000000000..9d5d89cfabcf --- /dev/null +++ b/include/dt-bindings/sound/qcom,q6afe.h @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_Q6_AFE_H__ +#define __DT_BINDINGS_Q6_AFE_H__ + +/* This file exists due to backward compatibility reasons, Please do not DELETE! */ + +#include <dt-bindings/sound/qcom,q6dsp-lpass-ports.h> + +#endif /* __DT_BINDINGS_Q6_AFE_H__ */ diff --git a/include/dt-bindings/sound/qcom,q6asm.h b/include/dt-bindings/sound/qcom,q6asm.h new file mode 100644 index 000000000000..f59d74f14395 --- /dev/null +++ b/include/dt-bindings/sound/qcom,q6asm.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_Q6_ASM_H__ +#define __DT_BINDINGS_Q6_ASM_H__ + +#define MSM_FRONTEND_DAI_MULTIMEDIA1 0 +#define MSM_FRONTEND_DAI_MULTIMEDIA2 1 +#define MSM_FRONTEND_DAI_MULTIMEDIA3 2 +#define MSM_FRONTEND_DAI_MULTIMEDIA4 3 +#define MSM_FRONTEND_DAI_MULTIMEDIA5 4 +#define MSM_FRONTEND_DAI_MULTIMEDIA6 5 +#define MSM_FRONTEND_DAI_MULTIMEDIA7 6 +#define MSM_FRONTEND_DAI_MULTIMEDIA8 7 +#define MSM_FRONTEND_DAI_MULTIMEDIA9 8 +#define MSM_FRONTEND_DAI_MULTIMEDIA10 9 +#define MSM_FRONTEND_DAI_MULTIMEDIA11 10 +#define MSM_FRONTEND_DAI_MULTIMEDIA12 11 +#define MSM_FRONTEND_DAI_MULTIMEDIA13 12 +#define MSM_FRONTEND_DAI_MULTIMEDIA14 13 +#define MSM_FRONTEND_DAI_MULTIMEDIA15 14 +#define MSM_FRONTEND_DAI_MULTIMEDIA16 15 + +#define Q6ASM_DAI_TX_RX 0 +#define Q6ASM_DAI_TX 1 +#define Q6ASM_DAI_RX 2 + +#endif /* __DT_BINDINGS_Q6_ASM_H__ */ diff --git a/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h b/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h new file mode 100644 index 000000000000..39f203256c4f --- /dev/null +++ b/include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h @@ -0,0 +1,234 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_BINDINGS_Q6_AUDIO_PORTS_H__ +#define __DT_BINDINGS_Q6_AUDIO_PORTS_H__ + +/* LPASS Audio virtual ports IDs */ +#define HDMI_RX 1 +#define SLIMBUS_0_RX 2 +#define SLIMBUS_0_TX 3 +#define SLIMBUS_1_RX 4 +#define SLIMBUS_1_TX 5 +#define SLIMBUS_2_RX 6 +#define SLIMBUS_2_TX 7 +#define SLIMBUS_3_RX 8 +#define SLIMBUS_3_TX 9 +#define SLIMBUS_4_RX 10 +#define SLIMBUS_4_TX 11 +#define SLIMBUS_5_RX 12 +#define SLIMBUS_5_TX 13 +#define SLIMBUS_6_RX 14 +#define SLIMBUS_6_TX 15 +#define PRIMARY_MI2S_RX 16 +#define PRIMARY_MI2S_TX 17 +#define SECONDARY_MI2S_RX 18 +#define SECONDARY_MI2S_TX 19 +#define TERTIARY_MI2S_RX 20 +#define TERTIARY_MI2S_TX 21 +#define QUATERNARY_MI2S_RX 22 +#define QUATERNARY_MI2S_TX 23 +#define PRIMARY_TDM_RX_0 24 +#define PRIMARY_TDM_TX_0 25 +#define PRIMARY_TDM_RX_1 26 +#define PRIMARY_TDM_TX_1 27 +#define PRIMARY_TDM_RX_2 28 +#define PRIMARY_TDM_TX_2 29 +#define PRIMARY_TDM_RX_3 30 +#define PRIMARY_TDM_TX_3 31 +#define PRIMARY_TDM_RX_4 32 +#define PRIMARY_TDM_TX_4 33 +#define PRIMARY_TDM_RX_5 34 +#define PRIMARY_TDM_TX_5 35 +#define PRIMARY_TDM_RX_6 36 +#define PRIMARY_TDM_TX_6 37 +#define PRIMARY_TDM_RX_7 38 +#define PRIMARY_TDM_TX_7 39 +#define SECONDARY_TDM_RX_0 40 +#define SECONDARY_TDM_TX_0 41 +#define SECONDARY_TDM_RX_1 42 +#define SECONDARY_TDM_TX_1 43 +#define SECONDARY_TDM_RX_2 44 +#define SECONDARY_TDM_TX_2 45 +#define SECONDARY_TDM_RX_3 46 +#define SECONDARY_TDM_TX_3 47 +#define SECONDARY_TDM_RX_4 48 +#define SECONDARY_TDM_TX_4 49 +#define SECONDARY_TDM_RX_5 50 +#define SECONDARY_TDM_TX_5 51 +#define SECONDARY_TDM_RX_6 52 +#define SECONDARY_TDM_TX_6 53 +#define SECONDARY_TDM_RX_7 54 +#define SECONDARY_TDM_TX_7 55 +#define TERTIARY_TDM_RX_0 56 +#define TERTIARY_TDM_TX_0 57 +#define TERTIARY_TDM_RX_1 58 +#define TERTIARY_TDM_TX_1 59 +#define TERTIARY_TDM_RX_2 60 +#define TERTIARY_TDM_TX_2 61 +#define TERTIARY_TDM_RX_3 62 +#define TERTIARY_TDM_TX_3 63 +#define TERTIARY_TDM_RX_4 64 +#define TERTIARY_TDM_TX_4 65 +#define TERTIARY_TDM_RX_5 66 +#define TERTIARY_TDM_TX_5 67 +#define TERTIARY_TDM_RX_6 68 +#define TERTIARY_TDM_TX_6 69 +#define TERTIARY_TDM_RX_7 70 +#define TERTIARY_TDM_TX_7 71 +#define QUATERNARY_TDM_RX_0 72 +#define QUATERNARY_TDM_TX_0 73 +#define QUATERNARY_TDM_RX_1 74 +#define QUATERNARY_TDM_TX_1 75 +#define QUATERNARY_TDM_RX_2 76 +#define QUATERNARY_TDM_TX_2 77 +#define QUATERNARY_TDM_RX_3 78 +#define QUATERNARY_TDM_TX_3 79 +#define QUATERNARY_TDM_RX_4 80 +#define QUATERNARY_TDM_TX_4 81 +#define QUATERNARY_TDM_RX_5 82 +#define QUATERNARY_TDM_TX_5 83 +#define QUATERNARY_TDM_RX_6 84 +#define QUATERNARY_TDM_TX_6 85 +#define QUATERNARY_TDM_RX_7 86 +#define QUATERNARY_TDM_TX_7 87 +#define QUINARY_TDM_RX_0 88 +#define QUINARY_TDM_TX_0 89 +#define QUINARY_TDM_RX_1 90 +#define QUINARY_TDM_TX_1 91 +#define QUINARY_TDM_RX_2 92 +#define QUINARY_TDM_TX_2 93 +#define QUINARY_TDM_RX_3 94 +#define QUINARY_TDM_TX_3 95 +#define QUINARY_TDM_RX_4 96 +#define QUINARY_TDM_TX_4 97 +#define QUINARY_TDM_RX_5 98 +#define QUINARY_TDM_TX_5 99 +#define QUINARY_TDM_RX_6 100 +#define QUINARY_TDM_TX_6 101 +#define QUINARY_TDM_RX_7 102 +#define QUINARY_TDM_TX_7 103 +#define DISPLAY_PORT_RX 104 +#define WSA_CODEC_DMA_RX_0 105 +#define WSA_CODEC_DMA_TX_0 106 +#define WSA_CODEC_DMA_RX_1 107 +#define WSA_CODEC_DMA_TX_1 108 +#define WSA_CODEC_DMA_TX_2 109 +#define VA_CODEC_DMA_TX_0 110 +#define VA_CODEC_DMA_TX_1 111 +#define VA_CODEC_DMA_TX_2 112 +#define RX_CODEC_DMA_RX_0 113 +#define TX_CODEC_DMA_TX_0 114 +#define RX_CODEC_DMA_RX_1 115 +#define TX_CODEC_DMA_TX_1 116 +#define RX_CODEC_DMA_RX_2 117 +#define TX_CODEC_DMA_TX_2 118 +#define RX_CODEC_DMA_RX_3 119 +#define TX_CODEC_DMA_TX_3 120 +#define RX_CODEC_DMA_RX_4 121 +#define TX_CODEC_DMA_TX_4 122 +#define RX_CODEC_DMA_RX_5 123 +#define TX_CODEC_DMA_TX_5 124 +#define RX_CODEC_DMA_RX_6 125 +#define RX_CODEC_DMA_RX_7 126 +#define QUINARY_MI2S_RX 127 +#define QUINARY_MI2S_TX 128 +#define DISPLAY_PORT_RX_0 DISPLAY_PORT_RX +#define DISPLAY_PORT_RX_1 129 +#define DISPLAY_PORT_RX_2 130 +#define DISPLAY_PORT_RX_3 131 +#define DISPLAY_PORT_RX_4 132 +#define DISPLAY_PORT_RX_5 133 +#define DISPLAY_PORT_RX_6 134 +#define DISPLAY_PORT_RX_7 135 + +#define LPASS_CLK_ID_PRI_MI2S_IBIT 1 +#define LPASS_CLK_ID_PRI_MI2S_EBIT 2 +#define LPASS_CLK_ID_SEC_MI2S_IBIT 3 +#define LPASS_CLK_ID_SEC_MI2S_EBIT 4 +#define LPASS_CLK_ID_TER_MI2S_IBIT 5 +#define LPASS_CLK_ID_TER_MI2S_EBIT 6 +#define LPASS_CLK_ID_QUAD_MI2S_IBIT 7 +#define LPASS_CLK_ID_QUAD_MI2S_EBIT 8 +#define LPASS_CLK_ID_SPEAKER_I2S_IBIT 9 +#define LPASS_CLK_ID_SPEAKER_I2S_EBIT 10 +#define LPASS_CLK_ID_SPEAKER_I2S_OSR 11 +#define LPASS_CLK_ID_QUI_MI2S_IBIT 12 +#define LPASS_CLK_ID_QUI_MI2S_EBIT 13 +#define LPASS_CLK_ID_SEN_MI2S_IBIT 14 +#define LPASS_CLK_ID_SEN_MI2S_EBIT 15 +#define LPASS_CLK_ID_INT0_MI2S_IBIT 16 +#define LPASS_CLK_ID_INT1_MI2S_IBIT 17 +#define LPASS_CLK_ID_INT2_MI2S_IBIT 18 +#define LPASS_CLK_ID_INT3_MI2S_IBIT 19 +#define LPASS_CLK_ID_INT4_MI2S_IBIT 20 +#define LPASS_CLK_ID_INT5_MI2S_IBIT 21 +#define LPASS_CLK_ID_INT6_MI2S_IBIT 22 +#define LPASS_CLK_ID_QUI_MI2S_OSR 23 +#define LPASS_CLK_ID_PRI_PCM_IBIT 24 +#define LPASS_CLK_ID_PRI_PCM_EBIT 25 +#define LPASS_CLK_ID_SEC_PCM_IBIT 26 +#define LPASS_CLK_ID_SEC_PCM_EBIT 27 +#define LPASS_CLK_ID_TER_PCM_IBIT 28 +#define LPASS_CLK_ID_TER_PCM_EBIT 29 +#define LPASS_CLK_ID_QUAD_PCM_IBIT 30 +#define LPASS_CLK_ID_QUAD_PCM_EBIT 31 +#define LPASS_CLK_ID_QUIN_PCM_IBIT 32 +#define LPASS_CLK_ID_QUIN_PCM_EBIT 33 +#define LPASS_CLK_ID_QUI_PCM_OSR 34 +#define LPASS_CLK_ID_PRI_TDM_IBIT 35 +#define LPASS_CLK_ID_PRI_TDM_EBIT 36 +#define LPASS_CLK_ID_SEC_TDM_IBIT 37 +#define LPASS_CLK_ID_SEC_TDM_EBIT 38 +#define LPASS_CLK_ID_TER_TDM_IBIT 39 +#define LPASS_CLK_ID_TER_TDM_EBIT 40 +#define LPASS_CLK_ID_QUAD_TDM_IBIT 41 +#define LPASS_CLK_ID_QUAD_TDM_EBIT 42 +#define LPASS_CLK_ID_QUIN_TDM_IBIT 43 +#define LPASS_CLK_ID_QUIN_TDM_EBIT 44 +#define LPASS_CLK_ID_QUIN_TDM_OSR 45 +#define LPASS_CLK_ID_MCLK_1 46 +#define LPASS_CLK_ID_MCLK_2 47 +#define LPASS_CLK_ID_MCLK_3 48 +#define LPASS_CLK_ID_MCLK_4 49 +#define LPASS_CLK_ID_INTERNAL_DIGITAL_CODEC_CORE 50 +#define LPASS_CLK_ID_INT_MCLK_0 51 +#define LPASS_CLK_ID_INT_MCLK_1 52 +#define LPASS_CLK_ID_MCLK_5 53 +#define LPASS_CLK_ID_WSA_CORE_MCLK 54 +#define LPASS_CLK_ID_WSA_CORE_NPL_MCLK 55 +#define LPASS_CLK_ID_VA_CORE_MCLK 56 +#define LPASS_CLK_ID_TX_CORE_MCLK 57 +#define LPASS_CLK_ID_TX_CORE_NPL_MCLK 58 +#define LPASS_CLK_ID_RX_CORE_MCLK 59 +#define LPASS_CLK_ID_RX_CORE_NPL_MCLK 60 +#define LPASS_CLK_ID_VA_CORE_2X_MCLK 61 +/* Clock ID for MCLK for WSA2 core */ +#define LPASS_CLK_ID_WSA2_CORE_MCLK 62 +/* Clock ID for NPL MCLK for WSA2 core */ +#define LPASS_CLK_ID_WSA2_CORE_2X_MCLK 63 +/* Clock ID for RX Core TX MCLK */ +#define LPASS_CLK_ID_RX_CORE_TX_MCLK 64 +/* Clock ID for RX CORE TX 2X MCLK */ +#define LPASS_CLK_ID_RX_CORE_TX_2X_MCLK 65 +/* Clock ID for WSA core TX MCLK */ +#define LPASS_CLK_ID_WSA_CORE_TX_MCLK 66 +/* Clock ID for WSA core TX 2X MCLK */ +#define LPASS_CLK_ID_WSA_CORE_TX_2X_MCLK 67 +/* Clock ID for WSA2 core TX MCLK */ +#define LPASS_CLK_ID_WSA2_CORE_TX_MCLK 68 +/* Clock ID for WSA2 core TX 2X MCLK */ +#define LPASS_CLK_ID_WSA2_CORE_TX_2X_MCLK 69 +/* Clock ID for RX CORE MCLK2 2X MCLK */ +#define LPASS_CLK_ID_RX_CORE_MCLK2_2X_MCLK 70 + +#define LPASS_HW_AVTIMER_VOTE 101 +#define LPASS_HW_MACRO_VOTE 102 +#define LPASS_HW_DCODEC_VOTE 103 + +#define Q6AFE_MAX_CLK_ID 104 + +#define LPASS_CLK_ATTRIBUTE_INVALID 0x0 +#define LPASS_CLK_ATTRIBUTE_COUPLE_NO 0x1 +#define LPASS_CLK_ATTRIBUTE_COUPLE_DIVIDEND 0x2 +#define LPASS_CLK_ATTRIBUTE_COUPLE_DIVISOR 0x3 + +#endif /* __DT_BINDINGS_Q6_AUDIO_PORTS_H__ */
On 19/12/2023 17:04, Caleb Connolly wrote:
Import the DT bindings headers that are used by SDM845 from Linux 6.7-rc3
I think adding the commit you took the bindings from would be also good
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 ++++++ include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 +++ include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 ++ include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 + include/dt-bindings/clock/qcom,rpmh.h | 37 ++ include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 ++ include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 18 + include/dt-bindings/iio/qcom,spmi-vadc.h | 300 +++++++++++++++ include/dt-bindings/interconnect/qcom,osm-l3.h | 15 + include/dt-bindings/interconnect/qcom,sdm845.h | 150 ++++++++ include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/phy/phy-qcom-qusb2.h | 37 ++ include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 ++++++++ include/dt-bindings/power/qcom-rpmpd.h | 412 +++++++++++++++++++++ include/dt-bindings/qcom,q6asm.h | 26 ++ .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 ++ include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 + include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 ++ include/dt-bindings/soc/qcom,apr.h | 28 ++ include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + include/dt-bindings/sound/qcom,q6afe.h | 9 + include/dt-bindings/sound/qcom,q6asm.h | 26 ++ include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 ++++++++++++ 24 files changed, 1822 insertions(+)
With the commit id:
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Import the PM8998 and PMI8998 PMIC DTSI files from Linux 6.7-rc3 as well as the common audio codec in preperation for replacing board DTS files with upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/pm8998.dtsi | 130 +++++++++++++++++++++++++++++++++++++++ arch/arm/dts/pmi8998.dtsi | 98 +++++++++++++++++++++++++++++ arch/arm/dts/sdm845-wcd9340.dtsi | 86 ++++++++++++++++++++++++++ 3 files changed, 314 insertions(+)
diff --git a/arch/arm/dts/pm8998.dtsi b/arch/arm/dts/pm8998.dtsi new file mode 100644 index 000000000000..3f82715392c6 --- /dev/null +++ b/arch/arm/dts/pm8998.dtsi @@ -0,0 +1,130 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* Copyright 2018 Google LLC. */ + +#include <dt-bindings/iio/qcom,spmi-vadc.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + thermal-zones { + pm8998-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&pm8998_temp>; + + trips { + pm8998_alert0: pm8998-alert0 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + pm8998_crit: pm8998-crit { + temperature = <125000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + }; +}; + +&spmi_bus { + pm8998_lsid0: pmic@0 { + compatible = "qcom,pm8998", "qcom,spmi-pmic"; + reg = <0x0 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pm8998_pon: pon@800 { + compatible = "qcom,pm8998-pon"; + + reg = <0x800>; + mode-bootloader = <0x2>; + mode-recovery = <0x1>; + + pm8998_pwrkey: pwrkey { + compatible = "qcom,pm8941-pwrkey"; + interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + linux,code = <KEY_POWER>; + }; + + pm8998_resin: resin { + compatible = "qcom,pm8941-resin"; + interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + status = "disabled"; + }; + }; + + pm8998_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0x0 0x24 0x0 IRQ_TYPE_EDGE_RISING>; + io-channels = <&pm8998_adc ADC5_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pm8998_coincell: charger@2800 { + compatible = "qcom,pm8998-coincell", "qcom,pm8941-coincell"; + reg = <0x2800>; + + status = "disabled"; + }; + + pm8998_adc: adc@3100 { + compatible = "qcom,spmi-adc-rev2"; + reg = <0x3100>; + interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + + channel@6 { + reg = <ADC5_DIE_TEMP>; + label = "die_temp"; + }; + }; + + pm8998_adc_tm: adc-tm@3400 { + compatible = "qcom,spmi-adc-tm-hc"; + reg = <0x3400>; + interrupts = <0x0 0x34 0x0 IRQ_TYPE_EDGE_RISING>; + #thermal-sensor-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + rtc@6000 { + compatible = "qcom,pm8941-rtc"; + reg = <0x6000>, <0x6100>; + reg-names = "rtc", "alarm"; + interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; + }; + + pm8998_gpios: gpio@c000 { + compatible = "qcom,pm8998-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pm8998_gpios 0 0 26>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + }; + + pm8998_lsid1: pmic@1 { + compatible = "qcom,pm8998", "qcom,spmi-pmic"; + reg = <0x1 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + }; +}; diff --git a/arch/arm/dts/pmi8998.dtsi b/arch/arm/dts/pmi8998.dtsi new file mode 100644 index 000000000000..cd3f0790fd42 --- /dev/null +++ b/arch/arm/dts/pmi8998.dtsi @@ -0,0 +1,98 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> + +&spmi_bus { + pmi8998_lsid0: pmic@2 { + compatible = "qcom,pmi8998", "qcom,spmi-pmic"; + reg = <0x2 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pmi8998_charger: charger@1000 { + compatible = "qcom,pmi8998-charger"; + reg = <0x1000>; + + interrupts = <0x2 0x13 0x4 IRQ_TYPE_EDGE_BOTH>, + <0x2 0x12 0x2 IRQ_TYPE_EDGE_BOTH>, + <0x2 0x16 0x1 IRQ_TYPE_EDGE_RISING>, + <0x2 0x13 0x6 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "usb-plugin", + "bat-ov", + "wdog-bark", + "usbin-icl-change"; + + io-channels = <&pmi8998_rradc 3>, + <&pmi8998_rradc 4>; + io-channel-names = "usbin_i", "usbin_v"; + + status = "disabled"; + }; + + pmi8998_gpios: gpio@c000 { + compatible = "qcom,pmi8998-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pmi8998_gpios 0 0 14>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pmi8998_rradc: adc@4500 { + compatible = "qcom,pmi8998-rradc"; + reg = <0x4500>; + #io-channel-cells = <1>; + }; + }; + + pmi8998_lsid1: pmic@3 { + compatible = "qcom,pmi8998", "qcom,spmi-pmic"; + reg = <0x3 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + labibb { + compatible = "qcom,pmi8998-lab-ibb"; + + ibb: ibb { + interrupts = <0x3 0xdc 0x2 IRQ_TYPE_EDGE_RISING>, + <0x3 0xdc 0x0 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "sc-err", "ocp"; + }; + + lab: lab { + interrupts = <0x3 0xde 0x1 IRQ_TYPE_EDGE_RISING>, + <0x3 0xde 0x0 IRQ_TYPE_LEVEL_LOW>; + interrupt-names = "sc-err", "ocp"; + }; + }; + + pmi8998_lpg: pwm { + compatible = "qcom,pmi8998-lpg"; + + #address-cells = <1>; + #size-cells = <0>; + #pwm-cells = <2>; + + status = "disabled"; + }; + + pmi8998_flash: led-controller@d300 { + compatible = "qcom,pmi8998-flash-led", "qcom,spmi-flash-led"; + reg = <0xd300>; + status = "disabled"; + }; + + pmi8998_wled: leds@d800 { + compatible = "qcom,pmi8998-wled"; + reg = <0xd800>, <0xd900>; + interrupts = <0x3 0xd8 0x1 IRQ_TYPE_EDGE_RISING>, + <0x3 0xd8 0x2 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "ovp", "short"; + label = "backlight"; + + status = "disabled"; + }; + }; +}; diff --git a/arch/arm/dts/sdm845-wcd9340.dtsi b/arch/arm/dts/sdm845-wcd9340.dtsi new file mode 100644 index 000000000000..c15d48860646 --- /dev/null +++ b/arch/arm/dts/sdm845-wcd9340.dtsi @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * SDM845 SoC device tree source + * + * Copyright (c) 2018, The Linux Foundation. All rights reserved. + */ + +&slim { + status = "okay"; + + slim@1 { + reg = <1>; + #address-cells = <2>; + #size-cells = <0>; + + wcd9340_ifd: ifd@0,0 { + compatible = "slim217,250"; + reg = <0 0>; + }; + + wcd9340: codec@1,0 { + compatible = "slim217,250"; + reg = <1 0>; + slim-ifc-dev = <&wcd9340_ifd>; + + #sound-dai-cells = <1>; + + interrupts-extended = <&tlmm 54 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <1>; + + clock-names = "extclk"; + clocks = <&rpmhcc RPMH_LN_BB_CLK2>; + + #clock-cells = <0>; + clock-frequency = <9600000>; + clock-output-names = "mclk"; + + pinctrl-0 = <&wcd_intr_default>; + pinctrl-names = "default"; + + qcom,micbias1-microvolt = <1800000>; + qcom,micbias2-microvolt = <1800000>; + qcom,micbias3-microvolt = <1800000>; + qcom,micbias4-microvolt = <1800000>; + + #address-cells = <1>; + #size-cells = <1>; + + wcdgpio: gpio-controller@42 { + compatible = "qcom,wcd9340-gpio"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x42 0x2>; + }; + + swm: swm@c85 { + compatible = "qcom,soundwire-v1.3.0"; + reg = <0xc85 0x40>; + interrupts-extended = <&wcd9340 20>; + + qcom,dout-ports = <6>; + qcom,din-ports = <2>; + qcom,ports-sinterval-low = /bits/ 8 <0x07 0x1f 0x3f 0x7 0x1f 0x3f 0x0f 0x0f>; + qcom,ports-offset1 = /bits/ 8 <0x01 0x02 0x0c 0x6 0x12 0x0d 0x07 0x0a>; + qcom,ports-offset2 = /bits/ 8 <0x00 0x00 0x1f 0x00 0x00 0x1f 0x00 0x00>; + + #sound-dai-cells = <1>; + clocks = <&wcd9340>; + clock-names = "iface"; + #address-cells = <2>; + #size-cells = <0>; + }; + }; + }; +}; + +&tlmm { + wcd_intr_default: wcd-intr-default-state { + pins = "gpio54"; + function = "gpio"; + + bias-pull-down; + drive-strength = <2>; + }; +};
<snip>
Same as patch 19, with the commit id:
Import sdm845.dtsi from upstream, as well as the upstream DTS files for the db845c and Samsung starqltechn. Delete the old board files.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/Makefile | 4 +- arch/arm/dts/dragonboard845c-uboot.dtsi | 26 - arch/arm/dts/dragonboard845c.dts | 48 - arch/arm/dts/sdm845-db845c.dts | 1190 ++++ .../arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi | 16 + arch/arm/dts/sdm845-samsung-starqltechn.dts | 624 +++ arch/arm/dts/sdm845.dtsi | 5801 +++++++++++++++++++- arch/arm/dts/starqltechn-uboot.dtsi | 27 - arch/arm/dts/starqltechn.dts | 68 - configs/qcom_defconfig | 2 +- 10 files changed, 7550 insertions(+), 256 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ec63749fa912..00d1ce34b7aa 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -602,8 +602,8 @@ dtb-$(CONFIG_TARGET_TEN64) += fsl-ls1088a-ten64.dtb
dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb \ dragonboard820c.dtb \ - dragonboard845c.dtb \ - starqltechn.dtb \ + sdm845-db845c.dtb \ + sdm845-samsung-starqltechn.dtb \ qcs404-evb.dtb
dtb-$(CONFIG_TARGET_STEMMY) += ste-ux500-samsung-stemmy.dtb diff --git a/arch/arm/dts/dragonboard845c-uboot.dtsi b/arch/arm/dts/dragonboard845c-uboot.dtsi deleted file mode 100644 index 775f45c0149f..000000000000 --- a/arch/arm/dts/dragonboard845c-uboot.dtsi +++ /dev/null @@ -1,26 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * U-Boot addition to handle Qualcomm Robotics RB3 Development Platform - * (dragonboard845c) pins - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -/ -{ - soc { - bootph-all; - - serial@a84000 { - bootph-all; - }; - - clock-controller@100000 { - bootph-all; - }; - - pinctrl@3400000 { - bootph-all; - }; - }; -}; diff --git a/arch/arm/dts/dragonboard845c.dts b/arch/arm/dts/dragonboard845c.dts deleted file mode 100644 index 054f253eb32a..000000000000 --- a/arch/arm/dts/dragonboard845c.dts +++ /dev/null @@ -1,48 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm Robotics RB3 Development (dragonboard845c) board device - * tree source - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -/dts-v1/; - -#include "sdm845.dtsi" - -/ { - model = "Thundercomm Dragonboard 845c"; - compatible = "thundercomm,db845c", "qcom,sdm845"; - #address-cells = <2>; - #size-cells = <2>; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - aliases { - serial0 = &uart9; - }; - - memory { - device_type = "memory"; - reg = <0 0x80000000 0 0xfdfa0000>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - soc: soc { - serial@a84000 { - status = "okay"; - }; - }; -}; - -&pm8998_resin { - status = "okay"; -}; - -#include "dragonboard845c-uboot.dtsi" diff --git a/arch/arm/dts/sdm845-db845c.dts b/arch/arm/dts/sdm845-db845c.dts new file mode 100644 index 000000000000..c7eba6c491be --- /dev/null +++ b/arch/arm/dts/sdm845-db845c.dts @@ -0,0 +1,1190 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019, Linaro Ltd. + */ + +/dts-v1/; + +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> +#include <dt-bindings/regulator/qcom,rpmh-regulator.h> +#include <dt-bindings/sound/qcom,q6afe.h> +#include <dt-bindings/sound/qcom,q6asm.h> +#include "sdm845.dtsi" +#include "sdm845-wcd9340.dtsi" +#include "pm8998.dtsi" +#include "pmi8998.dtsi" + +/ { + model = "Thundercomm Dragonboard 845c"; + compatible = "thundercomm,db845c", "qcom,sdm845"; + qcom,msm-id = <341 0x20001>; + qcom,board-id = <8 0>; + + aliases { + serial0 = &uart9; + serial1 = &uart6; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* Fixed crystal oscillator dedicated to MCP2517FD */ + clk40M: can-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <40000000>; + }; + + dc12v: dc12v-regulator { + compatible = "regulator-fixed"; + regulator-name = "DC12V"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + pinctrl-names = "default"; + pinctrl-0 = <&vol_up_pin_a>; + + key-vol-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + gpios = <&pm8998_gpios 6 GPIO_ACTIVE_LOW>; + }; + }; + + leds { + compatible = "gpio-leds"; + + led-0 { + label = "green:user4"; + function = LED_FUNCTION_INDICATOR; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pm8998_gpios 13 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "panic-indicator"; + default-state = "off"; + }; + + led-1 { + label = "yellow:wlan"; + function = LED_FUNCTION_WLAN; + color = <LED_COLOR_ID_YELLOW>; + gpios = <&pm8998_gpios 9 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "phy0tx"; + default-state = "off"; + }; + + led-2 { + label = "blue:bt"; + function = LED_FUNCTION_BLUETOOTH; + color = <LED_COLOR_ID_BLUE>; + gpios = <&pm8998_gpios 5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "bluetooth-power"; + default-state = "off"; + }; + }; + + hdmi-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con: endpoint { + remote-endpoint = <<9611_out>; + }; + }; + }; + + reserved-memory { + /* Cont splash region set up by the bootloader */ + cont_splash_mem: framebuffer@9d400000 { + reg = <0x0 0x9d400000 0x0 0x2400000>; + no-map; + }; + }; + + lt9611_1v8: lt9611-vdd18-regulator { + compatible = "regulator-fixed"; + regulator-name = "LT9611_1V8"; + + vin-supply = <&vdc_5v>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + lt9611_3v3: lt9611-3v3 { + compatible = "regulator-fixed"; + regulator-name = "LT9611_3V3"; + + vin-supply = <&vdc_3v3>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + /* + * TODO: make it possible to drive same GPIO from two clients + * gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; + * enable-active-high; + */ + }; + + pcie0_1p05v: pcie-0-1p05v-regulator { + compatible = "regulator-fixed"; + regulator-name = "PCIE0_1.05V"; + + vin-supply = <&vbat>; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + + /* + * TODO: make it possible to drive same GPIO from two clients + * gpio = <&tlmm 90 GPIO_ACTIVE_HIGH>; + * enable-active-high; + */ + }; + + cam0_dvdd_1v2: cam0-dvdd-1v2-regulator { + compatible = "regulator-fixed"; + regulator-name = "CAM0_DVDD_1V2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + enable-active-high; + gpio = <&pm8998_gpios 12 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&cam0_dvdd_1v2_en_default>; + vin-supply = <&vbat>; + }; + + cam0_avdd_2v8: cam0-avdd-2v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "CAM0_AVDD_2V8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + enable-active-high; + gpio = <&pm8998_gpios 10 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&cam0_avdd_2v8_en_default>; + vin-supply = <&vbat>; + }; + + /* This regulator is enabled when the VREG_LVS1A_1P8 trace is enabled */ + cam3_avdd_2v8: cam3-avdd-2v8-regulator { + compatible = "regulator-fixed"; + regulator-name = "CAM3_AVDD_2V8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-always-on; + vin-supply = <&vbat>; + }; + + pcie0_3p3v_dual: vldo-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "VLDO_3V3"; + + vin-supply = <&vbat>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&tlmm 90 GPIO_ACTIVE_HIGH>; + enable-active-high; + + pinctrl-names = "default"; + pinctrl-0 = <&pcie0_pwren_state>; + }; + + v5p0_hdmiout: v5p0-hdmiout-regulator { + compatible = "regulator-fixed"; + regulator-name = "V5P0_HDMIOUT"; + + vin-supply = <&vdc_5v>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <500000>; + + /* + * TODO: make it possible to drive same GPIO from two clients + * gpio = <&tlmm 89 GPIO_ACTIVE_HIGH>; + * enable-active-high; + */ + }; + + vbat: vbat-regulator { + compatible = "regulator-fixed"; + regulator-name = "VBAT"; + + vin-supply = <&dc12v>; + regulator-min-microvolt = <4200000>; + regulator-max-microvolt = <4200000>; + regulator-always-on; + }; + + vbat_som: vbat-som-regulator { + compatible = "regulator-fixed"; + regulator-name = "VBAT_SOM"; + + vin-supply = <&dc12v>; + regulator-min-microvolt = <4200000>; + regulator-max-microvolt = <4200000>; + regulator-always-on; + }; + + vdc_3v3: vdc-3v3-regulator { + compatible = "regulator-fixed"; + regulator-name = "VDC_3V3"; + vin-supply = <&dc12v>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vdc_5v: vdc-5v-regulator { + compatible = "regulator-fixed"; + regulator-name = "VDC_5V"; + + vin-supply = <&dc12v>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <500000>; + regulator-always-on; + }; + + vreg_s4a_1p8: vreg-s4a-1p8 { + compatible = "regulator-fixed"; + regulator-name = "vreg_s4a_1p8"; + + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vph_pwr: vph-pwr-regulator { + compatible = "regulator-fixed"; + regulator-name = "vph_pwr"; + + vin-supply = <&vbat_som>; + }; +}; + +&adsp_pas { + status = "okay"; + + firmware-name = "qcom/sdm845/adsp.mbn"; +}; + +&apps_rsc { + regulators-0 { + compatible = "qcom,pm8998-rpmh-regulators"; + qcom,pmic-id = "a"; + vdd-s1-supply = <&vph_pwr>; + vdd-s2-supply = <&vph_pwr>; + vdd-s3-supply = <&vph_pwr>; + vdd-s4-supply = <&vph_pwr>; + vdd-s5-supply = <&vph_pwr>; + vdd-s6-supply = <&vph_pwr>; + vdd-s7-supply = <&vph_pwr>; + vdd-s8-supply = <&vph_pwr>; + vdd-s9-supply = <&vph_pwr>; + vdd-s10-supply = <&vph_pwr>; + vdd-s11-supply = <&vph_pwr>; + vdd-s12-supply = <&vph_pwr>; + vdd-s13-supply = <&vph_pwr>; + vdd-l1-l27-supply = <&vreg_s7a_1p025>; + vdd-l2-l8-l17-supply = <&vreg_s3a_1p35>; + vdd-l3-l11-supply = <&vreg_s7a_1p025>; + vdd-l4-l5-supply = <&vreg_s7a_1p025>; + vdd-l6-supply = <&vph_pwr>; + vdd-l7-l12-l14-l15-supply = <&vreg_s5a_2p04>; + vdd-l9-supply = <&vreg_bob>; + vdd-l10-l23-l25-supply = <&vreg_bob>; + vdd-l13-l19-l21-supply = <&vreg_bob>; + vdd-l16-l28-supply = <&vreg_bob>; + vdd-l18-l22-supply = <&vreg_bob>; + vdd-l20-l24-supply = <&vreg_bob>; + vdd-l26-supply = <&vreg_s3a_1p35>; + vin-lvs-1-2-supply = <&vreg_s4a_1p8>; + + vreg_s3a_1p35: smps3 { + regulator-min-microvolt = <1352000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_s5a_2p04: smps5 { + regulator-min-microvolt = <1904000>; + regulator-max-microvolt = <2040000>; + }; + + vreg_s7a_1p025: smps7 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1028000>; + }; + + vreg_l1a_0p875: ldo1 { + regulator-min-microvolt = <880000>; + regulator-max-microvolt = <880000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l5a_0p8: ldo5 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l12a_1p8: ldo12 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l7a_1p8: ldo7 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l13a_2p95: ldo13 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l17a_1p3: ldo17 { + regulator-min-microvolt = <1304000>; + regulator-max-microvolt = <1304000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l20a_2p95: ldo20 { + regulator-min-microvolt = <2960000>; + regulator-max-microvolt = <2968000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l21a_2p95: ldo21 { + regulator-min-microvolt = <2960000>; + regulator-max-microvolt = <2968000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l24a_3p075: ldo24 { + regulator-min-microvolt = <3088000>; + regulator-max-microvolt = <3088000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l25a_3p3: ldo25 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3312000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l26a_1p2: ldo26 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_lvs1a_1p8: lvs1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vreg_lvs2a_1p8: lvs2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + }; + + regulators-1 { + compatible = "qcom,pmi8998-rpmh-regulators"; + qcom,pmic-id = "b"; + + vdd-bob-supply = <&vph_pwr>; + + vreg_bob: bob { + regulator-min-microvolt = <3312000>; + regulator-max-microvolt = <3600000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_AUTO>; + regulator-allow-bypass; + }; + }; +}; + +&camss { + status = "okay"; + + vdda-phy-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l26a_1p2>; +}; + +&cdsp_pas { + status = "okay"; + firmware-name = "qcom/sdm845/cdsp.mbn"; +}; + +&gcc { + protected-clocks = <GCC_QSPI_CORE_CLK>, + <GCC_QSPI_CORE_CLK_SRC>, + <GCC_QSPI_CNOC_PERIPH_AHB_CLK>, + <GCC_LPASS_Q6_AXI_CLK>, + <GCC_LPASS_SWAY_CLK>; +}; + +&gmu { + status = "okay"; +}; + +&gpi_dma0 { + status = "okay"; +}; + +&gpi_dma1 { + status = "okay"; +}; + +&gpu { + status = "okay"; + zap-shader { + memory-region = <&gpu_mem>; + firmware-name = "qcom/sdm845/a630_zap.mbn"; + }; +}; + +&i2c10 { + status = "okay"; + clock-frequency = <400000>; + + lt9611_codec: hdmi-bridge@3b { + compatible = "lontium,lt9611"; + reg = <0x3b>; + #sound-dai-cells = <1>; + + interrupts-extended = <&tlmm 84 IRQ_TYPE_EDGE_FALLING>; + + reset-gpios = <&tlmm 128 GPIO_ACTIVE_HIGH>; + + vdd-supply = <<9611_1v8>; + vcc-supply = <<9611_3v3>; + + pinctrl-names = "default"; + pinctrl-0 = <<9611_irq_pin>, <&dsi_sw_sel>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + lt9611_a: endpoint { + remote-endpoint = <&mdss_dsi0_out>; + }; + }; + + port@1 { + reg = <1>; + + lt9611_b: endpoint { + remote-endpoint = <&mdss_dsi1_out>; + }; + }; + + port@2 { + reg = <2>; + + lt9611_out: endpoint { + remote-endpoint = <&hdmi_con>; + }; + }; + }; + }; +}; + +&i2c11 { + /* On Low speed expansion */ + clock-frequency = <100000>; + status = "okay"; +}; + +&i2c14 { + /* On Low speed expansion */ + clock-frequency = <100000>; + status = "okay"; +}; + +&mdss { + memory-region = <&cont_splash_mem>; + status = "okay"; +}; + +&mdss_dsi0 { + status = "okay"; + vdda-supply = <&vreg_l26a_1p2>; + + qcom,dual-dsi-mode; + qcom,master-dsi; + + ports { + port@1 { + endpoint { + remote-endpoint = <<9611_a>; + data-lanes = <0 1 2 3>; + }; + }; + }; +}; + +&mdss_dsi0_phy { + status = "okay"; + vdds-supply = <&vreg_l1a_0p875>; +}; + +&mdss_dsi1 { + vdda-supply = <&vreg_l26a_1p2>; + + qcom,dual-dsi-mode; + + /* DSI1 is slave, so use DSI0 clocks */ + assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; + + status = "okay"; + + ports { + port@1 { + endpoint { + remote-endpoint = <<9611_b>; + data-lanes = <0 1 2 3>; + }; + }; + }; +}; + +&mdss_dsi1_phy { + vdds-supply = <&vreg_l1a_0p875>; + status = "okay"; +}; + +&mss_pil { + status = "okay"; + firmware-name = "qcom/sdm845/mba.mbn", "qcom/sdm845/modem.mbn"; +}; + +&pcie0 { + status = "okay"; + perst-gpios = <&tlmm 35 GPIO_ACTIVE_LOW>; + enable-gpio = <&tlmm 134 GPIO_ACTIVE_HIGH>; + + vddpe-3v3-supply = <&pcie0_3p3v_dual>; + + pinctrl-names = "default"; + pinctrl-0 = <&pcie0_default_state>; +}; + +&pcie0_phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l26a_1p2>; +}; + +&pcie1 { + status = "okay"; + perst-gpios = <&tlmm 102 GPIO_ACTIVE_LOW>; + + pinctrl-names = "default"; + pinctrl-0 = <&pcie1_default_state>; +}; + +&pcie1_phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l26a_1p2>; +}; + +&pm8998_gpios { + gpio-line-names = + "NC", + "NC", + "WLAN_SW_CTRL", + "NC", + "PM_GPIO5_BLUE_BT_LED", + "VOL_UP_N", + "NC", + "ADC_IN1", + "PM_GPIO9_YEL_WIFI_LED", + "CAM0_AVDD_EN", + "NC", + "CAM0_DVDD_EN", + "PM_GPIO13_GREEN_U4_LED", + "DIV_CLK2", + "NC", + "NC", + "NC", + "SMB_STAT", + "NC", + "NC", + "ADC_IN2", + "OPTION1", + "WCSS_PWR_REQ", + "PM845_GPIO24", + "OPTION2", + "PM845_SLB"; + + cam0_dvdd_1v2_en_default: cam0-dvdd-1v2-en-state { + pins = "gpio12"; + function = "normal"; + + bias-pull-up; + drive-push-pull; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_HIGH>; + }; + + cam0_avdd_2v8_en_default: cam0-avdd-2v8-en-state { + pins = "gpio10"; + function = "normal"; + + bias-pull-up; + drive-push-pull; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_HIGH>; + }; + + vol_up_pin_a: vol-up-active-state { + pins = "gpio6"; + function = "normal"; + input-enable; + bias-pull-up; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; + }; +}; + +&pm8998_resin { + linux,code = <KEY_VOLUMEDOWN>; + status = "okay"; +}; + +&pmi8998_lpg { + status = "okay"; + + qcom,power-source = <1>; + + led@3 { + reg = <3>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + function-enumerator = <3>; + + linux,default-trigger = "heartbeat"; + default-state = "on"; + }; + + led@4 { + reg = <4>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <2>; + }; + + led@5 { + reg = <5>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_INDICATOR; + function-enumerator = <1>; + }; +}; + +/* QUAT I2S Uses 4 I2S SD Lines for audio on LT9611 HDMI Bridge */ +&q6afedai { + dai@22 { + reg = <QUATERNARY_MI2S_RX>; + qcom,sd-lines = <0 1 2 3>; + }; +}; + +&q6asmdai { + dai@0 { + reg = <0>; + }; + + dai@1 { + reg = <1>; + }; + + dai@2 { + reg = <2>; + }; + + dai@3 { + reg = <3>; + direction = <2>; + is-compress-dai; + }; +}; + +&qupv3_id_0 { + status = "okay"; +}; + +&qupv3_id_1 { + status = "okay"; +}; + +&sdhc_2 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&sdc2_default_state &sdc2_card_det_n>; + + vmmc-supply = <&vreg_l21a_2p95>; + vqmmc-supply = <&vreg_l13a_2p95>; + + bus-width = <4>; + cd-gpios = <&tlmm 126 GPIO_ACTIVE_LOW>; +}; + +&sound { + compatible = "qcom,db845c-sndcard", "qcom,sdm845-sndcard"; + pinctrl-0 = <&quat_mi2s_active + &quat_mi2s_sd0_active + &quat_mi2s_sd1_active + &quat_mi2s_sd2_active + &quat_mi2s_sd3_active>; + pinctrl-names = "default"; + model = "DB845c"; + audio-routing = + "RX_BIAS", "MCLK", + "AMIC1", "MIC BIAS1", + "AMIC2", "MIC BIAS2", + "DMIC0", "MIC BIAS1", + "DMIC1", "MIC BIAS1", + "DMIC2", "MIC BIAS3", + "DMIC3", "MIC BIAS3", + "SpkrLeft IN", "SPK1 OUT", + "SpkrRight IN", "SPK2 OUT", + "MM_DL1", "MultiMedia1 Playback", + "MM_DL2", "MultiMedia2 Playback", + "MM_DL4", "MultiMedia4 Playback", + "MultiMedia3 Capture", "MM_UL3"; + + mm1-dai-link { + link-name = "MultiMedia1"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA1>; + }; + }; + + mm2-dai-link { + link-name = "MultiMedia2"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA2>; + }; + }; + + mm3-dai-link { + link-name = "MultiMedia3"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA3>; + }; + }; + + mm4-dai-link { + link-name = "MultiMedia4"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA4>; + }; + }; + + hdmi-dai-link { + link-name = "HDMI Playback"; + cpu { + sound-dai = <&q6afedai QUATERNARY_MI2S_RX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <<9611_codec 0>; + }; + }; + + slim-dai-link { + link-name = "SLIM Playback"; + cpu { + sound-dai = <&q6afedai SLIMBUS_0_RX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <&left_spkr>, <&right_spkr>, <&swm 0>, <&wcd9340 0>; + }; + }; + + slimcap-dai-link { + link-name = "SLIM Capture"; + cpu { + sound-dai = <&q6afedai SLIMBUS_0_TX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <&wcd9340 1>; + }; + }; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi0_default>; + cs-gpios = <&tlmm 3 GPIO_ACTIVE_LOW>; + + can@0 { + compatible = "microchip,mcp2517fd"; + reg = <0>; + clocks = <&clk40M>; + interrupts-extended = <&tlmm 104 IRQ_TYPE_LEVEL_LOW>; + spi-max-frequency = <10000000>; + vdd-supply = <&vdc_5v>; + xceiver-supply = <&vdc_5v>; + }; +}; + +&spi2 { + /* On Low speed expansion */ + status = "okay"; +}; + +&tlmm { + cam0_default: cam0-default-state { + rst-pins { + pins = "gpio9"; + function = "gpio"; + + drive-strength = <16>; + bias-disable; + }; + + mclk0-pins { + pins = "gpio13"; + function = "cam_mclk"; + + drive-strength = <16>; + bias-disable; + }; + }; + + cam3_default: cam3-default-state { + rst-pins { + function = "gpio"; + pins = "gpio21"; + + drive-strength = <16>; + bias-disable; + }; + + mclk3-pins { + function = "cam_mclk"; + pins = "gpio16"; + + drive-strength = <16>; + bias-disable; + }; + }; + + dsi_sw_sel: dsi-sw-sel-state { + pins = "gpio120"; + function = "gpio"; + + drive-strength = <2>; + bias-disable; + output-high; + }; + + lt9611_irq_pin: lt9611-irq-state { + pins = "gpio84"; + function = "gpio"; + bias-disable; + }; + + pcie0_default_state: pcie0-default-state { + clkreq-pins { + pins = "gpio36"; + function = "pci_e0"; + bias-pull-up; + }; + + reset-n-pins { + pins = "gpio35"; + function = "gpio"; + + drive-strength = <2>; + output-low; + bias-pull-down; + }; + + wake-n-pins { + pins = "gpio37"; + function = "gpio"; + + drive-strength = <2>; + bias-pull-up; + }; + }; + + pcie0_pwren_state: pcie0-pwren-state { + pins = "gpio90"; + function = "gpio"; + + drive-strength = <2>; + bias-disable; + }; + + pcie1_default_state: pcie1-default-state { + perst-n-pins { + pins = "gpio102"; + function = "gpio"; + + drive-strength = <16>; + bias-disable; + }; + + clkreq-pins { + pins = "gpio103"; + function = "pci_e1"; + bias-pull-up; + }; + + wake-n-pins { + pins = "gpio11"; + function = "gpio"; + + drive-strength = <2>; + bias-pull-up; + }; + + reset-n-pins { + pins = "gpio75"; + function = "gpio"; + + drive-strength = <16>; + bias-pull-up; + output-high; + }; + }; + + sdc2_default_state: sdc2-default-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; + + /* + * It seems that mmc_test reports errors if drive + * strength is not 16 on clk, cmd, and data pins. + */ + drive-strength = <16>; + }; + + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + + data-pins { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <10>; + }; + }; + + sdc2_card_det_n: sd-card-det-n-state { + pins = "gpio126"; + function = "gpio"; + bias-pull-up; + }; +}; + +&uart3 { + label = "LS-UART0"; + pinctrl-0 = <&qup_uart3_4pin>; + + status = "disabled"; +}; + +&uart6 { + status = "okay"; + + pinctrl-0 = <&qup_uart6_4pin>; + + bluetooth { + compatible = "qcom,wcn3990-bt"; + + vddio-supply = <&vreg_s4a_1p8>; + vddxo-supply = <&vreg_l7a_1p8>; + vddrf-supply = <&vreg_l17a_1p3>; + vddch0-supply = <&vreg_l25a_3p3>; + max-speed = <3200000>; + }; +}; + +&uart9 { + label = "LS-UART1"; + status = "okay"; +}; + +&usb_1 { + status = "okay"; +}; + +&usb_1_dwc3 { + dr_mode = "peripheral"; +}; + +&usb_1_hsphy { + status = "okay"; + + vdd-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l12a_1p8>; + vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; + + qcom,imp-res-offset-value = <8>; + qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_21_6_MA>; + qcom,preemphasis-level = <QUSB2_V2_PREEMPHASIS_5_PERCENT>; + qcom,preemphasis-width = <QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT>; +}; + +&usb_1_qmpphy { + status = "okay"; + + vdda-phy-supply = <&vreg_l26a_1p2>; + vdda-pll-supply = <&vreg_l1a_0p875>; +}; + +&usb_2 { + status = "okay"; +}; + +&usb_2_dwc3 { + dr_mode = "host"; +}; + +&usb_2_hsphy { + status = "okay"; + + vdd-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l12a_1p8>; + vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; + + qcom,imp-res-offset-value = <8>; + qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_22_8_MA>; +}; + +&usb_2_qmpphy { + status = "okay"; + + vdda-phy-supply = <&vreg_l26a_1p2>; + vdda-pll-supply = <&vreg_l1a_0p875>; +}; + +&ufs_mem_hc { + status = "okay"; + + reset-gpios = <&tlmm 150 GPIO_ACTIVE_LOW>; + + vcc-supply = <&vreg_l20a_2p95>; + vcc-max-microamp = <800000>; +}; + +&ufs_mem_phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l1a_0p875>; + vdda-pll-supply = <&vreg_l26a_1p2>; +}; + +&venus { + status = "okay"; +}; + +&wcd9340 { + reset-gpios = <&tlmm 64 GPIO_ACTIVE_HIGH>; + vdd-buck-supply = <&vreg_s4a_1p8>; + vdd-buck-sido-supply = <&vreg_s4a_1p8>; + vdd-tx-supply = <&vreg_s4a_1p8>; + vdd-rx-supply = <&vreg_s4a_1p8>; + vdd-io-supply = <&vreg_s4a_1p8>; + + swm: swm@c85 { + left_spkr: speaker@0,1 { + compatible = "sdw10217201000"; + reg = <0 1>; + powerdown-gpios = <&wcdgpio 1 GPIO_ACTIVE_HIGH>; + #thermal-sensor-cells = <0>; + sound-name-prefix = "SpkrLeft"; + #sound-dai-cells = <0>; + }; + + right_spkr: speaker@0,2 { + compatible = "sdw10217201000"; + powerdown-gpios = <&wcdgpio 1 GPIO_ACTIVE_HIGH>; + reg = <0 2>; + #thermal-sensor-cells = <0>; + sound-name-prefix = "SpkrRight"; + #sound-dai-cells = <0>; + }; + }; +}; + +&wifi { + status = "okay"; + + vdd-0.8-cx-mx-supply = <&vreg_l5a_0p8>; + vdd-1.8-xo-supply = <&vreg_l7a_1p8>; + vdd-1.3-rfa-supply = <&vreg_l17a_1p3>; + vdd-3.3-ch0-supply = <&vreg_l25a_3p3>; + + qcom,snoc-host-cap-8bit-quirk; + qcom,ath10k-calibration-variant = "Thundercomm_DB845C"; +}; + +/* PINCTRL - additions to nodes defined in sdm845.dtsi */ +&qup_spi2_default { + drive-strength = <16>; +}; + +&qup_i2c10_default { + drive-strength = <2>; + bias-disable; +}; + +&qup_uart9_rx { + drive-strength = <2>; + bias-pull-up; +}; + +&qup_uart9_tx { + drive-strength = <2>; + bias-disable; +}; + +/* PINCTRL - additions to nodes defined in sdm845.dtsi */ +&qup_spi0_default { + drive-strength = <6>; + bias-disable; +}; diff --git a/arch/arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi b/arch/arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi new file mode 100644 index 000000000000..c78bd6e92406 --- /dev/null +++ b/arch/arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: GPL-2.0 + +/ { + chosen { + stdout-path = "serial0:921600n8"; + }; +}; + +&tlmm { + muic-i2c-n { + pins = "gpio33", "gpio34"; + drive-strength = <0x2>; + function = "gpio"; + bias-disable; + }; +}; diff --git a/arch/arm/dts/sdm845-samsung-starqltechn.dts b/arch/arm/dts/sdm845-samsung-starqltechn.dts new file mode 100644 index 000000000000..a3b0aff86c8d --- /dev/null +++ b/arch/arm/dts/sdm845-samsung-starqltechn.dts @@ -0,0 +1,624 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * SDM845 Samsung S9 (SM-G9600) (starqltechn / star2qltechn) common device tree source + * + * Copyright (c) 2020, The Linux Foundation. All rights reserved. + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/regulator/qcom,rpmh-regulator.h> +#include "sdm845.dtsi" + +/delete-node/ &rmtfs_mem; + +/ { + chassis-type = "handset"; + model = "Samsung Galaxy S9 SM-G9600"; + compatible = "samsung,starqltechn", "qcom,sdm845"; + + aliases { + serial0 = &uart9; + }; + + chosen { + #address-cells = <2>; + #size-cells = <2>; + ranges; + framebuffer: framebuffer@9d400000 { + compatible = "simple-framebuffer"; + reg = <0 0x9d400000 0 (2960 * 1440 * 4)>;//2400000 + width = <1440>; + height = <2960>; + stride = <(1440 * 4)>; + format = "a8r8g8b8"; + vci-supply = <&s2dos05_ldo4>; + vddr-supply = <&s2dos05_buck1>; + vdd3-supply = <&s2dos05_ldo1>; + }; + }; + + vph_pwr: vph-pwr-regulator { + compatible = "regulator-fixed"; + regulator-name = "vph_pwr"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + }; + + /* + * Apparently RPMh does not provide support for PM8998 S4 because it + * is always-on; model it as a fixed regulator. + */ + vreg_s4a_1p8: pm8998-smps4 { + compatible = "regulator-fixed"; + regulator-name = "vreg_s4a_1p8"; + + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-always-on; + regulator-boot-on; + + vin-supply = <&vph_pwr>; + }; + + reserved-memory { + memory@a1300000 { + compatible = "ramoops"; + reg = <0x0 0xa1300000 0x0 0x100000>; + record-size = <0x40000>; + console-size = <0x40000>; + ftrace-size = <0x40000>; + pmsg-size = <0x40000>; + }; + + /* The rmtfs_mem needs to be guarded due to "XPU limitations" + * it is otherwise possible for an allocation adjacent to the + * rmtfs_mem region to trigger an XPU violation, causing a crash. + */ + rmtfs_lower_guard: memory@fde00000 { + no-map; + reg = <0 0xfde00000 0 0x1000>; + }; + + rmtfs_mem: rmtfs-mem@fde01000 { + compatible = "qcom,rmtfs-mem"; + reg = <0 0xfde01000 0 0x200000>; + no-map; + + qcom,client-id = <1>; + qcom,vmid = <15>; + }; + + rmtfs_upper_guard: rmtfs-upper-guard@fe001000 { + no-map; + reg = <0 0xfe001000 0 0x1000>; + }; + + /* + * It seems like reserving the old rmtfs_mem region is also needed to prevent + * random crashes which are most likely modem related, more testing needed. + */ + removed_region: removed-region@88f00000 { + no-map; + reg = <0 0x88f00000 0 0x1c00000>; + }; + }; + + i2c@21 { + compatible = "i2c-gpio"; + sda-gpios = <&tlmm 127 0x0>; + scl-gpios = <&tlmm 128 0x0>; + i2c-gpio,delay-us = <0x2>; + #address-cells = <0x1>; + #size-cells = <0x0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c21_sda_state &i2c21_scl_state>; + + regulator@60 { + compatible = "samsung,s2dos05"; + reg = <0x60>; + + regulators { + s2dos05_ldo1: s2dos05-ldo1 { + regulator-name = "s2dos05-ldo1"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <2000000>; + regulator-active-discharge = <0x1>; + }; + + s2dos05_ldo2: s2dos05-ldo2 { + regulator-name = "s2dos05-ldo2"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-active-discharge = <0x1>; + regulator-boot-on; + }; + + s2dos05_ldo3: s2dos05-ldo3 { + regulator-name = "s2dos05-ldo3"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-active-discharge = <0x1>; + regulator-boot-on; + }; + + s2dos05_ldo4: s2dos05-ldo4 { + regulator-name = "s2dos05-ldo4"; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <3775000>; + regulator-active-discharge = <0x1>; + }; + + s2dos05_buck1: s2dos05-buck1 { + regulator-name = "s2dos05-buck1"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <2100000>; + regulator-active-discharge = <0x1>; + }; + }; + }; + }; +}; + + +&apps_rsc { + regulators-0 { + compatible = "qcom,pm8998-rpmh-regulators"; + qcom,pmic-id = "a"; + + vdd-s1-supply = <&vph_pwr>; + vdd-s2-supply = <&vph_pwr>; + vdd-s3-supply = <&vph_pwr>; + vdd-s4-supply = <&vph_pwr>; + vdd-s5-supply = <&vph_pwr>; + vdd-s6-supply = <&vph_pwr>; + vdd-s7-supply = <&vph_pwr>; + vdd-s8-supply = <&vph_pwr>; + vdd-s9-supply = <&vph_pwr>; + vdd-s10-supply = <&vph_pwr>; + vdd-s11-supply = <&vph_pwr>; + vdd-s12-supply = <&vph_pwr>; + vdd-s13-supply = <&vph_pwr>; + vdd-l1-l27-supply = <&vreg_s7a_1p025>; + vdd-l2-l8-l17-supply = <&vreg_s3a_1p35>; + vdd-l3-l11-supply = <&vreg_s7a_1p025>; + vdd-l4-l5-supply = <&vreg_s7a_1p025>; + vdd-l6-supply = <&vph_pwr>; + vdd-l7-l12-l14-l15-supply = <&vreg_s5a_2p04>; + vdd-l26-supply = <&vreg_s3a_1p35>; + vin-lvs-1-2-supply = <&vreg_s4a_1p8>; + + vreg_s2a_1p125: smps2 { + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + }; + + vreg_s3a_1p35: smps3 { + regulator-min-microvolt = <1352000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_s5a_2p04: smps5 { + regulator-min-microvolt = <1904000>; + regulator-max-microvolt = <2040000>; + }; + + vreg_s7a_1p025: smps7 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1028000>; + }; + + vdd_qusb_hs0: + vdda_hp_pcie_core: + vdda_mipi_csi0_0p9: + vdda_mipi_csi1_0p9: + vdda_mipi_csi2_0p9: + vdda_mipi_dsi0_pll: + vdda_mipi_dsi1_pll: + vdda_qlink_lv: + vdda_qlink_lv_ck: + vdda_qrefs_0p875: + vdda_pcie_core: + vdda_pll_cc_ebi01: + vdda_pll_cc_ebi23: + vdda_sp_sensor: + vdda_ufs1_core: + vdda_ufs2_core: + vreg_l1a_0p875: ldo1 { + regulator-min-microvolt = <880000>; + regulator-max-microvolt = <880000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vddpx_10: + vreg_l2a_1p2: ldo2 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + regulator-always-on; + }; + + vreg_l3a_1p0: ldo3 { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdda_usb1_ss_core: + vdd_wcss_cx: + vdd_wcss_mx: + vdda_wcss_pll: + vreg_l5a_0p8: ldo5 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vddpx_13: + vreg_l6a_1p8: ldo6 { + regulator-min-microvolt = <1856000>; + regulator-max-microvolt = <1856000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l7a_1p8: ldo7 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l8a_1p2: ldo8 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1248000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l9a_1p8: ldo9 { + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <2928000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l10a_1p8: ldo10 { + regulator-min-microvolt = <1704000>; + regulator-max-microvolt = <2928000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l11a_1p0: ldo11 { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1048000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdd_qfprom: + vdd_qfprom_sp: + vdda_apc1_cs_1p8: + vdda_gfx_cs_1p8: + vdda_qrefs_1p8: + vdda_qusb_hs0_1p8: + vddpx_11: + vreg_l12a_1p8: ldo12 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vddpx_2: + vreg_l13a_2p95: ldo13 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l14a_1p88: ldo14 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l15a_1p8: ldo15 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l16a_2p7: ldo16 { + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2704000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l17a_1p3: ldo17 { + regulator-min-microvolt = <1304000>; + regulator-max-microvolt = <1304000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l18a_2p7: ldo18 { + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l19a_3p0: ldo19 { + regulator-min-microvolt = <2856000>; + regulator-max-microvolt = <3104000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l20a_2p95: ldo20 { + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l21a_2p95: ldo21 { + regulator-min-microvolt = <2704000>; + regulator-max-microvolt = <2960000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l22a_2p85: ldo22 { + regulator-min-microvolt = <2864000>; + regulator-max-microvolt = <3312000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l23a_3p3: ldo23 { + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3312000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdda_qusb_hs0_3p1: + vreg_l24a_3p075: ldo24 { + regulator-min-microvolt = <3088000>; + regulator-max-microvolt = <3088000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l25a_3p3: ldo25 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3312000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vdda_hp_pcie_1p2: + vdda_hv_ebi0: + vdda_hv_ebi1: + vdda_hv_ebi2: + vdda_hv_ebi3: + vdda_mipi_csi_1p25: + vdda_mipi_dsi0_1p2: + vdda_mipi_dsi1_1p2: + vdda_pcie_1p2: + vdda_ufs1_1p2: + vdda_ufs2_1p2: + vdda_usb1_ss_1p2: + vdda_usb2_ss_1p2: + vreg_l26a_1p2: ldo26 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_l28a_3p0: ldo28 { + regulator-min-microvolt = <2856000>; + regulator-max-microvolt = <3008000>; + regulator-initial-mode = <RPMH_REGULATOR_MODE_HPM>; + }; + + vreg_lvs1a_1p8: lvs1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vreg_lvs2a_1p8: lvs2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; + + regulators-1 { + compatible = "qcom,pm8005-rpmh-regulators"; + qcom,pmic-id = "c"; + + vdd-s1-supply = <&vph_pwr>; + vdd-s2-supply = <&vph_pwr>; + vdd-s3-supply = <&vph_pwr>; + vdd-s4-supply = <&vph_pwr>; + + vreg_s3c_0p6: smps3 { + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <600000>; + }; + }; +}; + +&gcc { + protected-clocks = <GCC_QSPI_CORE_CLK>, + <GCC_QSPI_CORE_CLK_SRC>, + <GCC_QSPI_CNOC_PERIPH_AHB_CLK>, + <GCC_LPASS_Q6_AXI_CLK>, + <GCC_LPASS_SWAY_CLK>; +}; + +&i2c10 { + clock-frequency = <400000>; + status = "okay"; +}; + +&qupv3_id_1 { + status = "okay"; +}; + +&gpi_dma1 { + status = "okay"; +}; + +&uart9 { + status = "okay"; +}; + +&ufs_mem_hc { + reset-gpios = <&tlmm 150 GPIO_ACTIVE_LOW>; + vcc-supply = <&vreg_l20a_2p95>; + vcc-max-microamp = <600000>; + status = "okay"; +}; + +&ufs_mem_phy { + vdda-phy-supply = <&vdda_ufs1_core>; + vdda-pll-supply = <&vdda_ufs1_1p2>; + status = "okay"; +}; + +&sdhc_2 { + pinctrl-names = "default"; + pinctrl-0 = <&sdc2_clk_state &sdc2_cmd_state &sdc2_data_state &sd_card_det_n_state>; + cd-gpios = <&tlmm 126 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vreg_l21a_2p95>; + vqmmc-supply = <&vddpx_2>; + status = "okay"; +}; + +&i2c11 { + status = "okay"; + clock-frequency = <400000>; + + touchscreen@48 { + compatible = "samsung,s6sy761"; + reg = <0x48>; + interrupt-parent = <&tlmm>; + interrupts = <120 0x0>; + vdd-supply = <&s2dos05_ldo2>; + avdd-supply = <&s2dos05_ldo3>; + + pinctrl-names = "default"; + pinctrl-0 = <&touch_irq_state>; + }; +}; + +&crypto { + /* FIXME: qce_start triggers an SError */ + status = "disable"; +}; + +/* Modem/wifi*/ +&mss_pil { + status = "okay"; + firmware-name = "qcom/sdm845/starqltechn/mba.mbn", "qcom/sdm845/starqltechn/modem.mbn"; +}; + +&ipa { + qcom,gsi-loader = "self"; + memory-region = <&ipa_fw_mem>; + firmware-name = "qcom/sdm845/starqltechn/ipa_fws.mbn"; + status = "okay"; +}; + +&usb_1 { + status = "okay"; + /* + * disable USB3 clock requirement as the device only supports + * USB2. + */ + qcom,select-utmi-as-pipe-clk; +}; + +&usb_1_dwc3 { + /* Until we have Type C hooked up we'll force this as peripheral. */ + dr_mode = "peripheral"; + + maximum-speed = "high-speed"; +}; + +&usb_1_hsphy { + vdd-supply = <&vdda_usb1_ss_core>; + vdda-pll-supply = <&vdda_qusb_hs0_1p8>; + vdda-phy-dpdm-supply = <&vdda_qusb_hs0_3p1>; + + qcom,imp-res-offset-value = <8>; + qcom,hstx-trim-value = <QUSB2_V2_HSTX_TRIM_21_6_MA>; + qcom,preemphasis-level = <QUSB2_V2_PREEMPHASIS_5_PERCENT>; + qcom,preemphasis-width = <QUSB2_V2_PREEMPHASIS_WIDTH_HALF_BIT>; + status = "okay"; +}; + +&usb_1_qmpphy { + vdda-phy-supply = <&vdda_usb1_ss_1p2>; + vdda-pll-supply = <&vdda_usb1_ss_core>; + status = "okay"; +}; + +&tlmm { + gpio-reserved-ranges = <0 4>, <27 4>, <81 4>, <85 4>; + + sdc2_clk_state: sdc2-clk-state { + pins = "sdc2_clk"; + bias-disable; + + /* + * It seems that mmc_test reports errors if drive + * strength is not 16 on clk, cmd, and data pins. + */ + drive-strength = <16>; + }; + + sdc2_cmd_state: sdc2-cmd-state { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <16>; + }; + + sdc2_data_state: sdc2-data-state { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <16>; + }; + + sd_card_det_n_state: sd-card-det-n-state { + pins = "gpio126"; + function = "gpio"; + bias-pull-up; + }; + + i2c21_sda_state: i2c-sda-state { + pins = "gpio127"; + function = "gpio"; + drive-strength = <0x2>; + bias-disable; + }; + + i2c21_scl_state: i2c-scl-state { + pins = "gpio128"; + function = "gpio"; + drive-strength = <0x2>; + bias-disable; + }; + + touch_irq_state: touch-irq-state { + pins = "gpio120"; + function = "gpio"; + bias-disable; + output-disable; + }; +}; + +&qup_uart9_tx { + drive-strength = <0x2>; + bias-pull-up; +}; + +&qup_uart9_rx { + drive-strength = <0x2>; + bias-pull-up; +}; + +&qup_i2c11_default { + drive-strength = <2>; + bias-disable; +}; diff --git a/arch/arm/dts/sdm845.dtsi b/arch/arm/dts/sdm845.dtsi index 96c9749a52c0..bf5e6eb9d313 100644 --- a/arch/arm/dts/sdm845.dtsi +++ b/arch/arm/dts/sdm845.dtsi @@ -1,119 +1,5752 @@ -// SPDX-License-Identifier: GPL-2.0+ +// SPDX-License-Identifier: GPL-2.0 /* - * Qualcomm SDM845 chip device tree source - * - * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com + * SDM845 SoC device tree source * + * Copyright (c) 2018, The Linux Foundation. All rights reserved. */
-/dts-v1/; - +#include <dt-bindings/clock/qcom,camcc-sdm845.h> +#include <dt-bindings/clock/qcom,dispcc-sdm845.h> #include <dt-bindings/clock/qcom,gcc-sdm845.h> -#include "skeleton64.dtsi" +#include <dt-bindings/clock/qcom,gpucc-sdm845.h> +#include <dt-bindings/clock/qcom,lpass-sdm845.h> +#include <dt-bindings/clock/qcom,rpmh.h> +#include <dt-bindings/clock/qcom,videocc-sdm845.h> +#include <dt-bindings/dma/qcom-gpi.h> +#include <dt-bindings/firmware/qcom,scm.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interconnect/qcom,osm-l3.h> +#include <dt-bindings/interconnect/qcom,sdm845.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/phy/phy-qcom-qmp.h> +#include <dt-bindings/phy/phy-qcom-qusb2.h> +#include <dt-bindings/power/qcom-rpmpd.h> +#include <dt-bindings/reset/qcom,sdm845-aoss.h> +#include <dt-bindings/reset/qcom,sdm845-pdc.h> +#include <dt-bindings/soc/qcom,apr.h> +#include <dt-bindings/soc/qcom,rpmh-rsc.h> +#include <dt-bindings/clock/qcom,gcc-sdm845.h> +#include <dt-bindings/thermal/thermal.h>
/ { - soc: soc { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0xffffffff>; + interrupt-parent = <&intc>; + + #address-cells = <2>; + #size-cells = <2>; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + i2c7 = &i2c7; + i2c8 = &i2c8; + i2c9 = &i2c9; + i2c10 = &i2c10; + i2c11 = &i2c11; + i2c12 = &i2c12; + i2c13 = &i2c13; + i2c14 = &i2c14; + i2c15 = &i2c15; + spi0 = &spi0; + spi1 = &spi1; + spi2 = &spi2; + spi3 = &spi3; + spi4 = &spi4; + spi5 = &spi5; + spi6 = &spi6; + spi7 = &spi7; + spi8 = &spi8; + spi9 = &spi9; + spi10 = &spi10; + spi11 = &spi11; + spi12 = &spi12; + spi13 = &spi13; + spi14 = &spi14; + spi15 = &spi15; + }; + + chosen { }; + + clocks { + xo_board: xo-board { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <38400000>; + clock-output-names = "xo_board"; + }; + + sleep_clk: sleep-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32764>; + }; + }; + + cpus: cpus { + #address-cells = <2>; + #size-cells = <0>; + + CPU0: cpu@0 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x0>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <611>; + dynamic-power-coefficient = <154>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD0>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_0>; + L2_0: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + L3_0: l3-cache { + compatible = "cache"; + cache-level = <3>; + cache-unified; + }; + }; + }; + + CPU1: cpu@100 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x100>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <611>; + dynamic-power-coefficient = <154>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD1>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_100>; + L2_100: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU2: cpu@200 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x200>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <611>; + dynamic-power-coefficient = <154>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD2>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_200>; + L2_200: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU3: cpu@300 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x300>; + clocks = <&cpufreq_hw 0>; + enable-method = "psci"; + capacity-dmips-mhz = <611>; + dynamic-power-coefficient = <154>; + qcom,freq-domain = <&cpufreq_hw 0>; + operating-points-v2 = <&cpu0_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + #cooling-cells = <2>; + power-domains = <&CPU_PD3>; + power-domain-names = "psci"; + next-level-cache = <&L2_300>; + L2_300: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU4: cpu@400 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x400>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <442>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD4>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_400>; + L2_400: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU5: cpu@500 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x500>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <442>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD5>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_500>; + L2_500: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU6: cpu@600 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x600>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <442>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD6>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_600>; + L2_600: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + CPU7: cpu@700 { + device_type = "cpu"; + compatible = "qcom,kryo385"; + reg = <0x0 0x700>; + clocks = <&cpufreq_hw 1>; + enable-method = "psci"; + capacity-dmips-mhz = <1024>; + dynamic-power-coefficient = <442>; + qcom,freq-domain = <&cpufreq_hw 1>; + operating-points-v2 = <&cpu4_opp_table>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_EBI1 3>, + <&osm_l3 MASTER_OSM_L3_APPS &osm_l3 SLAVE_OSM_L3>; + power-domains = <&CPU_PD7>; + power-domain-names = "psci"; + #cooling-cells = <2>; + next-level-cache = <&L2_700>; + L2_700: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + next-level-cache = <&L3_0>; + }; + }; + + cpu-map { + cluster0 { + core0 { + cpu = <&CPU0>; + }; + + core1 { + cpu = <&CPU1>; + }; + + core2 { + cpu = <&CPU2>; + }; + + core3 { + cpu = <&CPU3>; + }; + + core4 { + cpu = <&CPU4>; + }; + + core5 { + cpu = <&CPU5>; + }; + + core6 { + cpu = <&CPU6>; + }; + + core7 { + cpu = <&CPU7>; + }; + }; + }; + + cpu_idle_states: idle-states { + entry-method = "psci"; + + LITTLE_CPU_SLEEP_0: cpu-sleep-0-0 { + compatible = "arm,idle-state"; + idle-state-name = "little-rail-power-collapse"; + arm,psci-suspend-param = <0x40000004>; + entry-latency-us = <350>; + exit-latency-us = <461>; + min-residency-us = <1890>; + local-timer-stop; + }; + + BIG_CPU_SLEEP_0: cpu-sleep-1-0 { + compatible = "arm,idle-state"; + idle-state-name = "big-rail-power-collapse"; + arm,psci-suspend-param = <0x40000004>; + entry-latency-us = <264>; + exit-latency-us = <621>; + min-residency-us = <952>; + local-timer-stop; + }; + }; + + domain-idle-states { + CLUSTER_SLEEP_0: cluster-sleep-0 { + compatible = "domain-idle-state"; + arm,psci-suspend-param = <0x4100c244>; + entry-latency-us = <3263>; + exit-latency-us = <6562>; + min-residency-us = <9987>; + }; + }; + }; + + firmware { + scm { + compatible = "qcom,scm-sdm845", "qcom,scm"; + }; + }; + + memory@80000000 { + device_type = "memory"; + /* We expect the bootloader to fill in the size */ + reg = <0 0x80000000 0 0>; + }; + + cpu0_opp_table: opp-table-cpu0 { + compatible = "operating-points-v2"; + opp-shared; + + cpu0_opp1: opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-peak-kBps = <800000 4800000>; + }; + + cpu0_opp2: opp-403200000 { + opp-hz = /bits/ 64 <403200000>; + opp-peak-kBps = <800000 4800000>; + }; + + cpu0_opp3: opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-peak-kBps = <800000 6451200>; + }; + + cpu0_opp4: opp-576000000 { + opp-hz = /bits/ 64 <576000000>; + opp-peak-kBps = <800000 6451200>; + }; + + cpu0_opp5: opp-652800000 { + opp-hz = /bits/ 64 <652800000>; + opp-peak-kBps = <800000 7680000>; + }; + + cpu0_opp6: opp-748800000 { + opp-hz = /bits/ 64 <748800000>; + opp-peak-kBps = <1804000 9216000>; + }; + + cpu0_opp7: opp-825600000 { + opp-hz = /bits/ 64 <825600000>; + opp-peak-kBps = <1804000 9216000>; + }; + + cpu0_opp8: opp-902400000 { + opp-hz = /bits/ 64 <902400000>; + opp-peak-kBps = <1804000 10444800>; + }; + + cpu0_opp9: opp-979200000 { + opp-hz = /bits/ 64 <979200000>; + opp-peak-kBps = <1804000 11980800>; + }; + + cpu0_opp10: opp-1056000000 { + opp-hz = /bits/ 64 <1056000000>; + opp-peak-kBps = <1804000 11980800>; + }; + + cpu0_opp11: opp-1132800000 { + opp-hz = /bits/ 64 <1132800000>; + opp-peak-kBps = <2188000 13516800>; + }; + + cpu0_opp12: opp-1228800000 { + opp-hz = /bits/ 64 <1228800000>; + opp-peak-kBps = <2188000 15052800>; + }; + + cpu0_opp13: opp-1324800000 { + opp-hz = /bits/ 64 <1324800000>; + opp-peak-kBps = <2188000 16588800>; + }; + + cpu0_opp14: opp-1420800000 { + opp-hz = /bits/ 64 <1420800000>; + opp-peak-kBps = <3072000 18124800>; + }; + + cpu0_opp15: opp-1516800000 { + opp-hz = /bits/ 64 <1516800000>; + opp-peak-kBps = <3072000 19353600>; + }; + + cpu0_opp16: opp-1612800000 { + opp-hz = /bits/ 64 <1612800000>; + opp-peak-kBps = <4068000 19353600>; + }; + + cpu0_opp17: opp-1689600000 { + opp-hz = /bits/ 64 <1689600000>; + opp-peak-kBps = <4068000 20889600>; + }; + + cpu0_opp18: opp-1766400000 { + opp-hz = /bits/ 64 <1766400000>; + opp-peak-kBps = <4068000 22425600>; + }; + }; + + cpu4_opp_table: opp-table-cpu4 { + compatible = "operating-points-v2"; + opp-shared; + + cpu4_opp1: opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + opp-peak-kBps = <800000 4800000>; + }; + + cpu4_opp2: opp-403200000 { + opp-hz = /bits/ 64 <403200000>; + opp-peak-kBps = <800000 4800000>; + }; + + cpu4_opp3: opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-peak-kBps = <1804000 4800000>; + }; + + cpu4_opp4: opp-576000000 { + opp-hz = /bits/ 64 <576000000>; + opp-peak-kBps = <1804000 4800000>; + }; + + cpu4_opp5: opp-652800000 { + opp-hz = /bits/ 64 <652800000>; + opp-peak-kBps = <1804000 4800000>; + }; + + cpu4_opp6: opp-748800000 { + opp-hz = /bits/ 64 <748800000>; + opp-peak-kBps = <1804000 4800000>; + }; + + cpu4_opp7: opp-825600000 { + opp-hz = /bits/ 64 <825600000>; + opp-peak-kBps = <2188000 9216000>; + }; + + cpu4_opp8: opp-902400000 { + opp-hz = /bits/ 64 <902400000>; + opp-peak-kBps = <2188000 9216000>; + }; + + cpu4_opp9: opp-979200000 { + opp-hz = /bits/ 64 <979200000>; + opp-peak-kBps = <2188000 9216000>; + }; + + cpu4_opp10: opp-1056000000 { + opp-hz = /bits/ 64 <1056000000>; + opp-peak-kBps = <3072000 9216000>; + }; + + cpu4_opp11: opp-1132800000 { + opp-hz = /bits/ 64 <1132800000>; + opp-peak-kBps = <3072000 11980800>; + }; + + cpu4_opp12: opp-1209600000 { + opp-hz = /bits/ 64 <1209600000>; + opp-peak-kBps = <4068000 11980800>; + }; + + cpu4_opp13: opp-1286400000 { + opp-hz = /bits/ 64 <1286400000>; + opp-peak-kBps = <4068000 11980800>; + }; + + cpu4_opp14: opp-1363200000 { + opp-hz = /bits/ 64 <1363200000>; + opp-peak-kBps = <4068000 15052800>; + }; + + cpu4_opp15: opp-1459200000 { + opp-hz = /bits/ 64 <1459200000>; + opp-peak-kBps = <4068000 15052800>; + }; + + cpu4_opp16: opp-1536000000 { + opp-hz = /bits/ 64 <1536000000>; + opp-peak-kBps = <5412000 15052800>; + }; + + cpu4_opp17: opp-1612800000 { + opp-hz = /bits/ 64 <1612800000>; + opp-peak-kBps = <5412000 15052800>; + }; + + cpu4_opp18: opp-1689600000 { + opp-hz = /bits/ 64 <1689600000>; + opp-peak-kBps = <5412000 19353600>; + }; + + cpu4_opp19: opp-1766400000 { + opp-hz = /bits/ 64 <1766400000>; + opp-peak-kBps = <6220000 19353600>; + }; + + cpu4_opp20: opp-1843200000 { + opp-hz = /bits/ 64 <1843200000>; + opp-peak-kBps = <6220000 19353600>; + }; + + cpu4_opp21: opp-1920000000 { + opp-hz = /bits/ 64 <1920000000>; + opp-peak-kBps = <7216000 19353600>; + }; + + cpu4_opp22: opp-1996800000 { + opp-hz = /bits/ 64 <1996800000>; + opp-peak-kBps = <7216000 20889600>; + }; + + cpu4_opp23: opp-2092800000 { + opp-hz = /bits/ 64 <2092800000>; + opp-peak-kBps = <7216000 20889600>; + }; + + cpu4_opp24: opp-2169600000 { + opp-hz = /bits/ 64 <2169600000>; + opp-peak-kBps = <7216000 20889600>; + }; + + cpu4_opp25: opp-2246400000 { + opp-hz = /bits/ 64 <2246400000>; + opp-peak-kBps = <7216000 20889600>; + }; + + cpu4_opp26: opp-2323200000 { + opp-hz = /bits/ 64 <2323200000>; + opp-peak-kBps = <7216000 20889600>; + }; + + cpu4_opp27: opp-2400000000 { + opp-hz = /bits/ 64 <2400000000>; + opp-peak-kBps = <7216000 22425600>; + }; + + cpu4_opp28: opp-2476800000 { + opp-hz = /bits/ 64 <2476800000>; + opp-peak-kBps = <7216000 22425600>; + }; + + cpu4_opp29: opp-2553600000 { + opp-hz = /bits/ 64 <2553600000>; + opp-peak-kBps = <7216000 22425600>; + }; + + cpu4_opp30: opp-2649600000 { + opp-hz = /bits/ 64 <2649600000>; + opp-peak-kBps = <7216000 22425600>; + }; + + cpu4_opp31: opp-2745600000 { + opp-hz = /bits/ 64 <2745600000>; + opp-peak-kBps = <7216000 25497600>; + }; + + cpu4_opp32: opp-2803200000 { + opp-hz = /bits/ 64 <2803200000>; + opp-peak-kBps = <7216000 25497600>; + }; + }; + + dsi_opp_table: opp-table-dsi { + compatible = "operating-points-v2"; + + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-180000000 { + opp-hz = /bits/ 64 <180000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-275000000 { + opp-hz = /bits/ 64 <275000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-328580000 { + opp-hz = /bits/ 64 <328580000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-358000000 { + opp-hz = /bits/ 64 <358000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + + qspi_opp_table: opp-table-qspi { + compatible = "operating-points-v2"; + + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-150000000 { + opp-hz = /bits/ 64 <150000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-300000000 { + opp-hz = /bits/ 64 <300000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + + qup_opp_table: opp-table-qup { + compatible = "operating-points-v2"; + + opp-50000000 { + opp-hz = /bits/ 64 <50000000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-75000000 { + opp-hz = /bits/ 64 <75000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-128000000 { + opp-hz = /bits/ 64 <128000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + + pmu { + compatible = "arm,armv8-pmuv3"; + interrupts = <GIC_PPI 5 IRQ_TYPE_LEVEL_HIGH>; + }; + + psci: psci { + compatible = "arm,psci-1.0"; + method = "smc"; + + CPU_PD0: power-domain-cpu0 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD1: power-domain-cpu1 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD2: power-domain-cpu2 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD3: power-domain-cpu3 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&LITTLE_CPU_SLEEP_0>; + }; + + CPU_PD4: power-domain-cpu4 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD5: power-domain-cpu5 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD6: power-domain-cpu6 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CPU_PD7: power-domain-cpu7 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&BIG_CPU_SLEEP_0>; + }; + + CLUSTER_PD: power-domain-cluster { + #power-domain-cells = <0>; + domain-idle-states = <&CLUSTER_SLEEP_0>; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + hyp_mem: hyp-mem@85700000 { + reg = <0 0x85700000 0 0x600000>; + no-map; + }; + + xbl_mem: xbl-mem@85e00000 { + reg = <0 0x85e00000 0 0x100000>; + no-map; + }; + + aop_mem: aop-mem@85fc0000 { + reg = <0 0x85fc0000 0 0x20000>; + no-map; + }; + + aop_cmd_db_mem: aop-cmd-db-mem@85fe0000 { + compatible = "qcom,cmd-db"; + reg = <0x0 0x85fe0000 0 0x20000>; + no-map; + }; + + smem@86000000 { + compatible = "qcom,smem"; + reg = <0x0 0x86000000 0 0x200000>; + no-map; + hwlocks = <&tcsr_mutex 3>; + }; + + tz_mem: tz@86200000 { + reg = <0 0x86200000 0 0x2d00000>; + no-map; + }; + + rmtfs_mem: rmtfs@88f00000 { + compatible = "qcom,rmtfs-mem"; + reg = <0 0x88f00000 0 0x200000>; + no-map; + + qcom,client-id = <1>; + qcom,vmid = <QCOM_SCM_VMID_MSS_MSA>; + }; + + qseecom_mem: qseecom@8ab00000 { + reg = <0 0x8ab00000 0 0x1400000>; + no-map; + }; + + camera_mem: camera-mem@8bf00000 { + reg = <0 0x8bf00000 0 0x500000>; + no-map; + }; + + ipa_fw_mem: ipa-fw@8c400000 { + reg = <0 0x8c400000 0 0x10000>; + no-map; + }; + + ipa_gsi_mem: ipa-gsi@8c410000 { + reg = <0 0x8c410000 0 0x5000>; + no-map; + }; + + gpu_mem: gpu@8c415000 { + reg = <0 0x8c415000 0 0x2000>; + no-map; + }; + + adsp_mem: adsp@8c500000 { + reg = <0 0x8c500000 0 0x1a00000>; + no-map; + }; + + wlan_msa_mem: wlan-msa@8df00000 { + reg = <0 0x8df00000 0 0x100000>; + no-map; + }; + + mpss_region: mpss@8e000000 { + reg = <0 0x8e000000 0 0x7800000>; + no-map; + }; + + venus_mem: venus@95800000 { + reg = <0 0x95800000 0 0x500000>; + no-map; + }; + + cdsp_mem: cdsp@95d00000 { + reg = <0 0x95d00000 0 0x800000>; + no-map; + }; + + mba_region: mba@96500000 { + reg = <0 0x96500000 0 0x200000>; + no-map; + }; + + slpi_mem: slpi@96700000 { + reg = <0 0x96700000 0 0x1400000>; + no-map; + }; + + spss_mem: spss@97b00000 { + reg = <0 0x97b00000 0 0x100000>; + no-map; + }; + + mdata_mem: mpss-metadata { + alloc-ranges = <0 0xa0000000 0 0x20000000>; + size = <0 0x4000>; + no-map; + }; + + fastrpc_mem: fastrpc { + compatible = "shared-dma-pool"; + alloc-ranges = <0x0 0x00000000 0x0 0xffffffff>; + alignment = <0x0 0x400000>; + size = <0x0 0x1000000>; + reusable; + }; + }; + + adsp_pas: remoteproc-adsp { + compatible = "qcom,sdm845-adsp-pas"; + + interrupts-extended = <&intc GIC_SPI 162 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + memory-region = <&adsp_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&adsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; + label = "lpass"; + qcom,remote-pid = <2>; + mboxes = <&apss_shared 8>; + + apr { + compatible = "qcom,apr-v2"; + qcom,glink-channels = "apr_audio_svc"; + qcom,domain = <APR_DOMAIN_ADSP>; + #address-cells = <1>; + #size-cells = <0>; + qcom,intents = <512 20>; + + service@3 { + reg = <APR_SVC_ADSP_CORE>; + compatible = "qcom,q6core"; + qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; + }; + + q6afe: service@4 { + compatible = "qcom,q6afe"; + reg = <APR_SVC_AFE>; + qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; + q6afedai: dais { + compatible = "qcom,q6afe-dais"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <1>; + }; + }; + + q6asm: service@7 { + compatible = "qcom,q6asm"; + reg = <APR_SVC_ASM>; + qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; + q6asmdai: dais { + compatible = "qcom,q6asm-dais"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <1>; + iommus = <&apps_smmu 0x1821 0x0>; + }; + }; + + q6adm: service@8 { + compatible = "qcom,q6adm"; + reg = <APR_SVC_ADM>; + qcom,protection-domain = "avs/audio", "msm/adsp/audio_pd"; + q6routing: routing { + compatible = "qcom,q6adm-routing"; + #sound-dai-cells = <0>; + }; + }; + }; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "adsp"; + qcom,non-secure-domain; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@3 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <3>; + iommus = <&apps_smmu 0x1823 0x0>; + }; + + compute-cb@4 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <4>; + iommus = <&apps_smmu 0x1824 0x0>; + }; + }; + }; + }; + + cdsp_pas: remoteproc-cdsp { + compatible = "qcom,sdm845-cdsp-pas"; + + interrupts-extended = <&intc GIC_SPI 578 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + memory-region = <&cdsp_mem>; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&cdsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 574 IRQ_TYPE_EDGE_RISING>; + label = "turing"; + qcom,remote-pid = <5>; + mboxes = <&apss_shared 4>; + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "cdsp"; + qcom,non-secure-domain; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@1 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <1>; + iommus = <&apps_smmu 0x1401 0x30>; + }; + + compute-cb@2 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <2>; + iommus = <&apps_smmu 0x1402 0x30>; + }; + + compute-cb@3 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <3>; + iommus = <&apps_smmu 0x1403 0x30>; + }; + + compute-cb@4 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <4>; + iommus = <&apps_smmu 0x1404 0x30>; + }; + + compute-cb@5 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <5>; + iommus = <&apps_smmu 0x1405 0x30>; + }; + + compute-cb@6 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <6>; + iommus = <&apps_smmu 0x1406 0x30>; + }; + + compute-cb@7 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <7>; + iommus = <&apps_smmu 0x1407 0x30>; + }; + + compute-cb@8 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <8>; + iommus = <&apps_smmu 0x1408 0x30>; + }; + }; + }; + }; + + smp2p-cdsp { + compatible = "qcom,smp2p"; + qcom,smem = <94>, <432>; + + interrupts = <GIC_SPI 576 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 6>; + + qcom,local-pid = <0>; + qcom,remote-pid = <5>; + + cdsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + cdsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-lpass { + compatible = "qcom,smp2p"; + qcom,smem = <443>, <429>; + + interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apss_shared 10>; + + qcom,local-pid = <0>; + qcom,remote-pid = <2>; + + adsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + adsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-mpss { + compatible = "qcom,smp2p"; + qcom,smem = <435>, <428>; + interrupts = <GIC_SPI 451 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apss_shared 14>; + qcom,local-pid = <0>; + qcom,remote-pid = <1>; + + modem_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + modem_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + interrupt-controller; + #interrupt-cells = <2>; + }; + + ipa_smp2p_out: ipa-ap-to-modem { + qcom,entry-name = "ipa"; + #qcom,smem-state-cells = <1>; + }; + + ipa_smp2p_in: ipa-modem-to-ap { + qcom,entry-name = "ipa"; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-slpi { + compatible = "qcom,smp2p"; + qcom,smem = <481>, <430>; + interrupts = <GIC_SPI 172 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apss_shared 26>; + qcom,local-pid = <0>; + qcom,remote-pid = <3>; + + slpi_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + slpi_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + soc: soc@0 { + #address-cells = <2>; + #size-cells = <2>; + ranges = <0 0 0 0 0x10 0>; + dma-ranges = <0 0 0 0 0x10 0>; compatible = "simple-bus";
gcc: clock-controller@100000 { compatible = "qcom,gcc-sdm845"; - reg = <0x100000 0x1f0000>; + reg = <0 0x00100000 0 0x1f0000>; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&rpmhcc RPMH_CXO_CLK_A>, + <&sleep_clk>, + <&pcie0_phy>, + <&pcie1_phy>; + clock-names = "bi_tcxo", + "bi_tcxo_ao", + "sleep_clk", + "pcie_0_pipe_clk", + "pcie_1_pipe_clk"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + power-domains = <&rpmhpd SDM845_CX>; + }; + + qfprom@784000 { + compatible = "qcom,sdm845-qfprom", "qcom,qfprom"; + reg = <0 0x00784000 0 0x8ff>; + #address-cells = <1>; + #size-cells = <1>; + + qusb2p_hstx_trim: hstx-trim-primary@1eb { + reg = <0x1eb 0x1>; + bits = <1 4>; + }; + + qusb2s_hstx_trim: hstx-trim-secondary@1eb { + reg = <0x1eb 0x2>; + bits = <6 4>; + }; + }; + + rng: rng@793000 { + compatible = "qcom,prng-ee"; + reg = <0 0x00793000 0 0x1000>; + clocks = <&gcc GCC_PRNG_AHB_CLK>; + clock-names = "core"; + }; + + gpi_dma0: dma-controller@800000 { + #dma-cells = <3>; + compatible = "qcom,sdm845-gpi-dma"; + reg = <0 0x00800000 0 0x60000>; + interrupts = <GIC_SPI 244 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 245 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 246 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 247 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 248 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 254 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 255 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 256 IRQ_TYPE_LEVEL_HIGH>; + dma-channels = <13>; + dma-channel-mask = <0xfa>; + iommus = <&apps_smmu 0x0016 0x0>; + status = "disabled"; + }; + + qupv3_id_0: geniqup@8c0000 { + compatible = "qcom,geni-se-qup"; + reg = <0 0x008c0000 0 0x6000>; + clock-names = "m-ahb", "s-ahb"; + clocks = <&gcc GCC_QUPV3_WRAP_0_M_AHB_CLK>, + <&gcc GCC_QUPV3_WRAP_0_S_AHB_CLK>; + iommus = <&apps_smmu 0x3 0x0>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core"; + status = "disabled"; + + i2c0: i2c@880000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00880000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c0_default>; + interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 0 QCOM_GPI_I2C>, + <&gpi_dma0 1 0 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi0: spi@880000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00880000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi0_default>; + interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 0 QCOM_GPI_SPI>, + <&gpi_dma0 1 0 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart0: serial@880000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00880000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart0_default>; + interrupts = <GIC_SPI 601 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c1: i2c@884000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00884000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c1_default>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 1 QCOM_GPI_I2C>, + <&gpi_dma0 1 1 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi1: spi@884000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00884000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi1_default>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 1 QCOM_GPI_SPI>, + <&gpi_dma0 1 1 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart1: serial@884000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00884000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart1_default>; + interrupts = <GIC_SPI 602 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c2: i2c@888000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00888000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c2_default>; + interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 2 QCOM_GPI_I2C>, + <&gpi_dma0 1 2 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi2: spi@888000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00888000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi2_default>; + interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 2 QCOM_GPI_SPI>, + <&gpi_dma0 1 2 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart2: serial@888000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00888000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart2_default>; + interrupts = <GIC_SPI 603 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c3: i2c@88c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x0088c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c3_default>; + interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 3 QCOM_GPI_I2C>, + <&gpi_dma0 1 3 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi3: spi@88c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x0088c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi3_default>; + interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 3 QCOM_GPI_SPI>, + <&gpi_dma0 1 3 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart3: serial@88c000 { + compatible = "qcom,geni-uart"; + reg = <0 0x0088c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart3_default>; + interrupts = <GIC_SPI 604 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c4: i2c@890000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00890000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c4_default>; + interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 4 QCOM_GPI_I2C>, + <&gpi_dma0 1 4 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi4: spi@890000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00890000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi4_default>; + interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 4 QCOM_GPI_SPI>, + <&gpi_dma0 1 4 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart4: serial@890000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00890000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart4_default>; + interrupts = <GIC_SPI 605 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c5: i2c@894000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00894000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c5_default>; + interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 5 QCOM_GPI_I2C>, + <&gpi_dma0 1 5 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi5: spi@894000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00894000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi5_default>; + interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 5 QCOM_GPI_SPI>, + <&gpi_dma0 1 5 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart5: serial@894000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00894000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart5_default>; + interrupts = <GIC_SPI 606 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c6: i2c@898000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00898000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c6_default>; + interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>, + <&aggre1_noc MASTER_QUP_1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma0 0 6 QCOM_GPI_I2C>, + <&gpi_dma0 1 6 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi6: spi@898000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00898000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi6_default>; + interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 6 QCOM_GPI_SPI>, + <&gpi_dma0 1 6 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart6: serial@898000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00898000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart6_default>; + interrupts = <GIC_SPI 607 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c7: i2c@89c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x0089c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c7_default>; + interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + status = "disabled"; + }; + + spi7: spi@89c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x0089c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi7_default>; + interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma0 0 7 QCOM_GPI_SPI>, + <&gpi_dma0 1 7 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart7: serial@89c000 { + compatible = "qcom,geni-uart"; + reg = <0 0x0089c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP0_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart7_default>; + interrupts = <GIC_SPI 608 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre1_noc MASTER_QUP_1 0 &config_noc SLAVE_BLSP_1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_1 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + }; + + gpi_dma1: dma-controller@a00000 { + #dma-cells = <3>; + compatible = "qcom,sdm845-gpi-dma"; + reg = <0 0x00a00000 0 0x60000>; + interrupts = <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 293 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 294 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 295 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 296 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; + dma-channels = <13>; + dma-channel-mask = <0xfa>; + iommus = <&apps_smmu 0x06d6 0x0>; + status = "disabled"; + }; + + qupv3_id_1: geniqup@ac0000 { + compatible = "qcom,geni-se-qup"; + reg = <0 0x00ac0000 0 0x6000>; + clock-names = "m-ahb", "s-ahb"; + clocks = <&gcc GCC_QUPV3_WRAP_1_M_AHB_CLK>, + <&gcc GCC_QUPV3_WRAP_1_S_AHB_CLK>; + iommus = <&apps_smmu 0x6c3 0x0>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core"; + status = "disabled"; + + i2c8: i2c@a80000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a80000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c8_default>; + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 0 QCOM_GPI_I2C>, + <&gpi_dma1 1 0 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi8: spi@a80000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a80000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi8_default>; + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 0 QCOM_GPI_SPI>, + <&gpi_dma1 1 0 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart8: serial@a80000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a80000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S0_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart8_default>; + interrupts = <GIC_SPI 353 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c9: i2c@a84000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a84000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c9_default>; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 1 QCOM_GPI_I2C>, + <&gpi_dma1 1 1 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi9: spi@a84000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a84000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi9_default>; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 1 QCOM_GPI_SPI>, + <&gpi_dma1 1 1 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart9: serial@a84000 { + compatible = "qcom,geni-debug-uart"; + reg = <0 0x00a84000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart9_default>; + interrupts = <GIC_SPI 354 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c10: i2c@a88000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a88000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c10_default>; + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 2 QCOM_GPI_I2C>, + <&gpi_dma1 1 2 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi10: spi@a88000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a88000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi10_default>; + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 2 QCOM_GPI_SPI>, + <&gpi_dma1 1 2 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart10: serial@a88000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a88000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S2_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart10_default>; + interrupts = <GIC_SPI 355 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c11: i2c@a8c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a8c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c11_default>; + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 3 QCOM_GPI_I2C>, + <&gpi_dma1 1 3 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi11: spi@a8c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a8c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi11_default>; + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 3 QCOM_GPI_SPI>, + <&gpi_dma1 1 3 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart11: serial@a8c000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a8c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S3_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart11_default>; + interrupts = <GIC_SPI 356 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c12: i2c@a90000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a90000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c12_default>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 4 QCOM_GPI_I2C>, + <&gpi_dma1 1 4 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi12: spi@a90000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a90000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi12_default>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 4 QCOM_GPI_SPI>, + <&gpi_dma1 1 4 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart12: serial@a90000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a90000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S4_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart12_default>; + interrupts = <GIC_SPI 357 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c13: i2c@a94000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a94000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c13_default>; + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 5 QCOM_GPI_I2C>, + <&gpi_dma1 1 5 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi13: spi@a94000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a94000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi13_default>; + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 5 QCOM_GPI_SPI>, + <&gpi_dma1 1 5 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart13: serial@a94000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a94000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S5_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart13_default>; + interrupts = <GIC_SPI 358 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c14: i2c@a98000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a98000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c14_default>; + interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 6 QCOM_GPI_I2C>, + <&gpi_dma1 1 6 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + spi14: spi@a98000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a98000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi14_default>; + interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 6 QCOM_GPI_SPI>, + <&gpi_dma1 1 6 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart14: serial@a98000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a98000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S6_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart14_default>; + interrupts = <GIC_SPI 359 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + + i2c15: i2c@a9c000 { + compatible = "qcom,geni-i2c"; + reg = <0 0x00a9c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_i2c15_default>; + interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + status = "disabled"; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>, + <&aggre2_noc MASTER_QUP_2 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "qup-core", "qup-config", "qup-memory"; + dmas = <&gpi_dma1 0 7 QCOM_GPI_I2C>, + <&gpi_dma1 1 7 QCOM_GPI_I2C>; + dma-names = "tx", "rx"; + }; + + spi15: spi@a9c000 { + compatible = "qcom,geni-spi"; + reg = <0 0x00a9c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_spi15_default>; + interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + dmas = <&gpi_dma1 0 7 QCOM_GPI_SPI>, + <&gpi_dma1 1 7 QCOM_GPI_SPI>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + uart15: serial@a9c000 { + compatible = "qcom,geni-uart"; + reg = <0 0x00a9c000 0 0x4000>; + clock-names = "se"; + clocks = <&gcc GCC_QUPV3_WRAP1_S7_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&qup_uart15_default>; + interrupts = <GIC_SPI 360 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qup_opp_table>; + interconnects = <&aggre2_noc MASTER_QUP_2 0 &config_noc SLAVE_BLSP_2 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_BLSP_2 0>; + interconnect-names = "qup-core", "qup-config"; + status = "disabled"; + }; + }; + + llcc: system-cache-controller@1100000 { + compatible = "qcom,sdm845-llcc"; + reg = <0 0x01100000 0 0x45000>, <0 0x01180000 0 0x50000>, + <0 0x01200000 0 0x50000>, <0 0x01280000 0 0x50000>, + <0 0x01300000 0 0x50000>; + reg-names = "llcc0_base", "llcc1_base", "llcc2_base", + "llcc3_base", "llcc_broadcast_base"; + interrupts = <GIC_SPI 582 IRQ_TYPE_LEVEL_HIGH>; + }; + + dma@10a2000 { + compatible = "qcom,sdm845-dcc", "qcom,dcc"; + reg = <0x0 0x010a2000 0x0 0x1000>, + <0x0 0x010ae000 0x0 0x2000>; + }; + + pmu@114a000 { + compatible = "qcom,sdm845-llcc-bwmon"; + reg = <0 0x0114a000 0 0x1000>; + interrupts = <GIC_SPI 580 IRQ_TYPE_LEVEL_HIGH>; + interconnects = <&mem_noc MASTER_LLCC 3 &mem_noc SLAVE_EBI1 3>; + + operating-points-v2 = <&llcc_bwmon_opp_table>; + + llcc_bwmon_opp_table: opp-table { + compatible = "operating-points-v2"; + + /* + * The interconnect path bandwidth taken from + * cpu4_opp_table bandwidth for gladiator_noc-mem_noc + * interconnect. This also matches the + * bandwidth table of qcom,llccbw (qcom,bw-tbl, + * bus width: 4 bytes) from msm-4.9 downstream + * kernel. + */ + opp-0 { + opp-peak-kBps = <800000>; + }; + opp-1 { + opp-peak-kBps = <1804000>; + }; + opp-2 { + opp-peak-kBps = <3072000>; + }; + opp-3 { + opp-peak-kBps = <5412000>; + }; + opp-4 { + opp-peak-kBps = <7216000>; + }; + }; + }; + + pmu@1436400 { + compatible = "qcom,sdm845-cpu-bwmon", "qcom,sdm845-bwmon"; + reg = <0 0x01436400 0 0x600>; + interrupts = <GIC_SPI 581 IRQ_TYPE_LEVEL_HIGH>; + interconnects = <&gladiator_noc MASTER_APPSS_PROC 3 &mem_noc SLAVE_LLCC 3>; + + operating-points-v2 = <&cpu_bwmon_opp_table>; + + cpu_bwmon_opp_table: opp-table { + compatible = "operating-points-v2"; + + /* + * The interconnect path bandwidth taken from + * cpu4_opp_table bandwidth for OSM L3 + * interconnect. This also matches the OSM L3 + * from bandwidth table of qcom,cpu4-l3lat-mon + * (qcom,core-dev-table, bus width: 16 bytes) + * from msm-4.9 downstream kernel. + */ + opp-0 { + opp-peak-kBps = <4800000>; + }; + opp-1 { + opp-peak-kBps = <9216000>; + }; + opp-2 { + opp-peak-kBps = <15052800>; + }; + opp-3 { + opp-peak-kBps = <20889600>; + }; + opp-4 { + opp-peak-kBps = <25497600>; + }; + }; + }; + + pcie0: pci@1c00000 { + compatible = "qcom,pcie-sdm845"; + reg = <0 0x01c00000 0 0x2000>, + <0 0x60000000 0 0xf1d>, + <0 0x60000f20 0 0xa8>, + <0 0x60100000 0 0x100000>, + <0 0x01c07000 0 0x1000>; + reg-names = "parf", "dbi", "elbi", "config", "mhi"; + device_type = "pci"; + linux,pci-domain = <0>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + + #address-cells = <3>; + #size-cells = <2>; + + ranges = <0x01000000 0x0 0x00000000 0x0 0x60200000 0x0 0x100000>, + <0x02000000 0x0 0x60300000 0x0 0x60300000 0x0 0xd00000>; + + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 0 0 149 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 0 0 150 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 0 0 151 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 0 0 152 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + clocks = <&gcc GCC_PCIE_0_PIPE_CLK>, + <&gcc GCC_PCIE_0_AUX_CLK>, + <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_Q2A_AXI_CLK>, + <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave", + "slave_q2a", + "tbu"; + + iommu-map = <0x0 &apps_smmu 0x1c10 0x1>, + <0x100 &apps_smmu 0x1c11 0x1>, + <0x200 &apps_smmu 0x1c12 0x1>, + <0x300 &apps_smmu 0x1c13 0x1>, + <0x400 &apps_smmu 0x1c14 0x1>, + <0x500 &apps_smmu 0x1c15 0x1>, + <0x600 &apps_smmu 0x1c16 0x1>, + <0x700 &apps_smmu 0x1c17 0x1>, + <0x800 &apps_smmu 0x1c18 0x1>, + <0x900 &apps_smmu 0x1c19 0x1>, + <0xa00 &apps_smmu 0x1c1a 0x1>, + <0xb00 &apps_smmu 0x1c1b 0x1>, + <0xc00 &apps_smmu 0x1c1c 0x1>, + <0xd00 &apps_smmu 0x1c1d 0x1>, + <0xe00 &apps_smmu 0x1c1e 0x1>, + <0xf00 &apps_smmu 0x1c1f 0x1>; + + resets = <&gcc GCC_PCIE_0_BCR>; + reset-names = "pci"; + + power-domains = <&gcc PCIE_0_GDSC>; + + phys = <&pcie0_phy>; + phy-names = "pciephy"; + + status = "disabled"; + }; + + pcie0_phy: phy@1c06000 { + compatible = "qcom,sdm845-qmp-pcie-phy"; + reg = <0 0x01c06000 0 0x1000>; + clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, + <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_CLKREF_CLK>, + <&gcc GCC_PCIE_PHY_REFGEN_CLK>, + <&gcc GCC_PCIE_0_PIPE_CLK>; + clock-names = "aux", + "cfg_ahb", + "ref", + "refgen", + "pipe"; + + clock-output-names = "pcie_0_pipe_clk"; + #clock-cells = <0>; + + #phy-cells = <0>; + + resets = <&gcc GCC_PCIE_0_PHY_BCR>; + reset-names = "phy"; + + assigned-clocks = <&gcc GCC_PCIE_PHY_REFGEN_CLK>; + assigned-clock-rates = <100000000>; + + status = "disabled"; + }; + + pcie1: pci@1c08000 { + compatible = "qcom,pcie-sdm845"; + reg = <0 0x01c08000 0 0x2000>, + <0 0x40000000 0 0xf1d>, + <0 0x40000f20 0 0xa8>, + <0 0x40100000 0 0x100000>, + <0 0x01c0c000 0 0x1000>; + reg-names = "parf", "dbi", "elbi", "config", "mhi"; + device_type = "pci"; + linux,pci-domain = <1>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + + #address-cells = <3>; + #size-cells = <2>; + + ranges = <0x01000000 0x0 0x00000000 0x0 0x40200000 0x0 0x100000>, + <0x02000000 0x0 0x40300000 0x0 0x40300000 0x0 0x1fd00000>; + + interrupts = <GIC_SPI 307 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 0 0 434 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 0 0 435 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 0 0 438 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 0 0 439 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + clocks = <&gcc GCC_PCIE_1_PIPE_CLK>, + <&gcc GCC_PCIE_1_AUX_CLK>, + <&gcc GCC_PCIE_1_CFG_AHB_CLK>, + <&gcc GCC_PCIE_1_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_1_SLV_AXI_CLK>, + <&gcc GCC_PCIE_1_SLV_Q2A_AXI_CLK>, + <&gcc GCC_PCIE_1_CLKREF_CLK>, + <&gcc GCC_AGGRE_NOC_PCIE_TBU_CLK>; + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave", + "slave_q2a", + "ref", + "tbu"; + + assigned-clocks = <&gcc GCC_PCIE_1_AUX_CLK>; + assigned-clock-rates = <19200000>; + + iommu-map = <0x0 &apps_smmu 0x1c00 0x1>, + <0x100 &apps_smmu 0x1c01 0x1>, + <0x200 &apps_smmu 0x1c02 0x1>, + <0x300 &apps_smmu 0x1c03 0x1>, + <0x400 &apps_smmu 0x1c04 0x1>, + <0x500 &apps_smmu 0x1c05 0x1>, + <0x600 &apps_smmu 0x1c06 0x1>, + <0x700 &apps_smmu 0x1c07 0x1>, + <0x800 &apps_smmu 0x1c08 0x1>, + <0x900 &apps_smmu 0x1c09 0x1>, + <0xa00 &apps_smmu 0x1c0a 0x1>, + <0xb00 &apps_smmu 0x1c0b 0x1>, + <0xc00 &apps_smmu 0x1c0c 0x1>, + <0xd00 &apps_smmu 0x1c0d 0x1>, + <0xe00 &apps_smmu 0x1c0e 0x1>, + <0xf00 &apps_smmu 0x1c0f 0x1>; + + resets = <&gcc GCC_PCIE_1_BCR>; + reset-names = "pci"; + + power-domains = <&gcc PCIE_1_GDSC>; + + phys = <&pcie1_phy>; + phy-names = "pciephy"; + + status = "disabled"; + }; + + pcie1_phy: phy@1c0a000 { + compatible = "qcom,sdm845-qhp-pcie-phy"; + reg = <0 0x01c0a000 0 0x2000>; + clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, + <&gcc GCC_PCIE_1_CFG_AHB_CLK>, + <&gcc GCC_PCIE_1_CLKREF_CLK>, + <&gcc GCC_PCIE_PHY_REFGEN_CLK>, + <&gcc GCC_PCIE_1_PIPE_CLK>; + clock-names = "aux", + "cfg_ahb", + "ref", + "refgen", + "pipe"; + + clock-output-names = "pcie_1_pipe_clk"; + #clock-cells = <0>; + + #phy-cells = <0>; + + resets = <&gcc GCC_PCIE_1_PHY_BCR>; + reset-names = "phy"; + + assigned-clocks = <&gcc GCC_PCIE_PHY_REFGEN_CLK>; + assigned-clock-rates = <100000000>; + + status = "disabled"; + }; + + mem_noc: interconnect@1380000 { + compatible = "qcom,sdm845-mem-noc"; + reg = <0 0x01380000 0 0x27200>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + dc_noc: interconnect@14e0000 { + compatible = "qcom,sdm845-dc-noc"; + reg = <0 0x014e0000 0 0x400>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + config_noc: interconnect@1500000 { + compatible = "qcom,sdm845-config-noc"; + reg = <0 0x01500000 0 0x5080>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + system_noc: interconnect@1620000 { + compatible = "qcom,sdm845-system-noc"; + reg = <0 0x01620000 0 0x18080>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + aggre1_noc: interconnect@16e0000 { + compatible = "qcom,sdm845-aggre1-noc"; + reg = <0 0x016e0000 0 0x15080>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + aggre2_noc: interconnect@1700000 { + compatible = "qcom,sdm845-aggre2-noc"; + reg = <0 0x01700000 0 0x1f300>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + mmss_noc: interconnect@1740000 { + compatible = "qcom,sdm845-mmss-noc"; + reg = <0 0x01740000 0 0x1c100>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + ufs_mem_hc: ufshc@1d84000 { + compatible = "qcom,sdm845-ufshc", "qcom,ufshc", + "jedec,ufs-2.0"; + reg = <0 0x01d84000 0 0x2500>, + <0 0x01d90000 0 0x8000>; + reg-names = "std", "ice"; + interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; + phys = <&ufs_mem_phy_lanes>; + phy-names = "ufsphy"; + lanes-per-direction = <2>; + power-domains = <&gcc UFS_PHY_GDSC>; + #reset-cells = <1>; + resets = <&gcc GCC_UFS_PHY_BCR>; + reset-names = "rst"; + + iommus = <&apps_smmu 0x100 0xf>; + + clock-names = + "core_clk", + "bus_aggr_clk", + "iface_clk", + "core_clk_unipro", + "ref_clk", + "tx_lane0_sync_clk", + "rx_lane0_sync_clk", + "rx_lane1_sync_clk", + "ice_core_clk"; + clocks = + <&gcc GCC_UFS_PHY_AXI_CLK>, + <&gcc GCC_AGGRE_UFS_PHY_AXI_CLK>, + <&gcc GCC_UFS_PHY_AHB_CLK>, + <&gcc GCC_UFS_PHY_UNIPRO_CORE_CLK>, + <&rpmhcc RPMH_CXO_CLK>, + <&gcc GCC_UFS_PHY_TX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_1_CLK>, + <&gcc GCC_UFS_PHY_ICE_CORE_CLK>; + freq-table-hz = + <50000000 200000000>, + <0 0>, + <0 0>, + <37500000 150000000>, + <0 0>, + <0 0>, + <0 0>, + <0 0>, + <75000000 300000000>; + + interconnects = <&aggre1_noc MASTER_UFS_MEM 0 &mem_noc SLAVE_EBI1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_UFS_MEM_CFG 0>; + interconnect-names = "ufs-ddr", "cpu-ufs"; + + status = "disabled"; + }; + + ufs_mem_phy: phy@1d87000 { + compatible = "qcom,sdm845-qmp-ufs-phy"; + reg = <0 0x01d87000 0 0x18c>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + clock-names = "ref", + "ref_aux"; + clocks = <&gcc GCC_UFS_MEM_CLKREF_CLK>, + <&gcc GCC_UFS_PHY_PHY_AUX_CLK>; + + resets = <&ufs_mem_hc 0>; + reset-names = "ufsphy"; + status = "disabled"; + + ufs_mem_phy_lanes: phy@1d87400 { + reg = <0 0x01d87400 0 0x108>, + <0 0x01d87600 0 0x1e0>, + <0 0x01d87c00 0 0x1dc>, + <0 0x01d87800 0 0x108>, + <0 0x01d87a00 0 0x1e0>; + #phy-cells = <0>; + }; + }; + + cryptobam: dma-controller@1dc4000 { + compatible = "qcom,bam-v1.7.4", "qcom,bam-v1.7.0"; + reg = <0 0x01dc4000 0 0x24000>; + interrupts = <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&rpmhcc RPMH_CE_CLK>; + clock-names = "bam_clk"; + #dma-cells = <1>; + qcom,ee = <0>; + qcom,controlled-remotely; + iommus = <&apps_smmu 0x704 0x1>, + <&apps_smmu 0x706 0x1>, + <&apps_smmu 0x714 0x1>, + <&apps_smmu 0x716 0x1>; + }; + + crypto: crypto@1dfa000 { + compatible = "qcom,crypto-v5.4"; + reg = <0 0x01dfa000 0 0x6000>; + clocks = <&gcc GCC_CE1_AHB_CLK>, + <&gcc GCC_CE1_AXI_CLK>, + <&rpmhcc RPMH_CE_CLK>; + clock-names = "iface", "bus", "core"; + dmas = <&cryptobam 6>, <&cryptobam 7>; + dma-names = "rx", "tx"; + iommus = <&apps_smmu 0x704 0x1>, + <&apps_smmu 0x706 0x1>, + <&apps_smmu 0x714 0x1>, + <&apps_smmu 0x716 0x1>; + }; + + ipa: ipa@1e40000 { + compatible = "qcom,sdm845-ipa"; + + iommus = <&apps_smmu 0x720 0x0>, + <&apps_smmu 0x722 0x0>; + reg = <0 0x01e40000 0 0x7000>, + <0 0x01e47000 0 0x2000>, + <0 0x01e04000 0 0x2c000>; + reg-names = "ipa-reg", + "ipa-shared", + "gsi"; + + interrupts-extended = <&intc GIC_SPI 311 IRQ_TYPE_EDGE_RISING>, + <&intc GIC_SPI 432 IRQ_TYPE_LEVEL_HIGH>, + <&ipa_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&ipa_smp2p_in 1 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "ipa", + "gsi", + "ipa-clock-query", + "ipa-setup-ready"; + + clocks = <&rpmhcc RPMH_IPA_CLK>; + clock-names = "core"; + + interconnects = <&aggre2_noc MASTER_IPA 0 &mem_noc SLAVE_EBI1 0>, + <&aggre2_noc MASTER_IPA 0 &system_noc SLAVE_IMEM 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_IPA_CFG 0>; + interconnect-names = "memory", + "imem", + "config"; + + qcom,smem-states = <&ipa_smp2p_out 0>, + <&ipa_smp2p_out 1>; + qcom,smem-state-names = "ipa-clock-enabled-valid", + "ipa-clock-enabled"; + + status = "disabled"; + }; + + tcsr_mutex: hwlock@1f40000 { + compatible = "qcom,tcsr-mutex"; + reg = <0 0x01f40000 0 0x20000>; + #hwlock-cells = <1>; + }; + + tcsr_regs_1: syscon@1f60000 { + compatible = "qcom,sdm845-tcsr", "syscon"; + reg = <0 0x01f60000 0 0x20000>; + }; + + tlmm: pinctrl@3400000 { + compatible = "qcom,sdm845-pinctrl"; + reg = <0 0x03400000 0 0xc00000>; + interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&tlmm 0 0 151>; + wakeup-parent = <&pdc_intc>; + + cci0_default: cci0-default-state { + /* SDA, SCL */ + pins = "gpio17", "gpio18"; + function = "cci_i2c"; + + bias-pull-up; + drive-strength = <2>; /* 2 mA */ + }; + + cci0_sleep: cci0-sleep-state { + /* SDA, SCL */ + pins = "gpio17", "gpio18"; + function = "cci_i2c"; + + drive-strength = <2>; /* 2 mA */ + bias-pull-down; + }; + + cci1_default: cci1-default-state { + /* SDA, SCL */ + pins = "gpio19", "gpio20"; + function = "cci_i2c"; + + bias-pull-up; + drive-strength = <2>; /* 2 mA */ + }; + + cci1_sleep: cci1-sleep-state { + /* SDA, SCL */ + pins = "gpio19", "gpio20"; + function = "cci_i2c"; + + drive-strength = <2>; /* 2 mA */ + bias-pull-down; + }; + + qspi_clk: qspi-clk-state { + pins = "gpio95"; + function = "qspi_clk"; + }; + + qspi_cs0: qspi-cs0-state { + pins = "gpio90"; + function = "qspi_cs"; + }; + + qspi_cs1: qspi-cs1-state { + pins = "gpio89"; + function = "qspi_cs"; + }; + + qspi_data0: qspi-data0-state { + pins = "gpio91"; + function = "qspi_data"; + }; + + qspi_data1: qspi-data1-state { + pins = "gpio92"; + function = "qspi_data"; + }; + + qspi_data23: qspi-data23-state { + pins = "gpio93", "gpio94"; + function = "qspi_data"; + }; + + qup_i2c0_default: qup-i2c0-default-state { + pins = "gpio0", "gpio1"; + function = "qup0"; + }; + + qup_i2c1_default: qup-i2c1-default-state { + pins = "gpio17", "gpio18"; + function = "qup1"; + }; + + qup_i2c2_default: qup-i2c2-default-state { + pins = "gpio27", "gpio28"; + function = "qup2"; + }; + + qup_i2c3_default: qup-i2c3-default-state { + pins = "gpio41", "gpio42"; + function = "qup3"; + }; + + qup_i2c4_default: qup-i2c4-default-state { + pins = "gpio89", "gpio90"; + function = "qup4"; + }; + + qup_i2c5_default: qup-i2c5-default-state { + pins = "gpio85", "gpio86"; + function = "qup5"; + }; + + qup_i2c6_default: qup-i2c6-default-state { + pins = "gpio45", "gpio46"; + function = "qup6"; + }; + + qup_i2c7_default: qup-i2c7-default-state { + pins = "gpio93", "gpio94"; + function = "qup7"; + }; + + qup_i2c8_default: qup-i2c8-default-state { + pins = "gpio65", "gpio66"; + function = "qup8"; + }; + + qup_i2c9_default: qup-i2c9-default-state { + pins = "gpio6", "gpio7"; + function = "qup9"; + }; + + qup_i2c10_default: qup-i2c10-default-state { + pins = "gpio55", "gpio56"; + function = "qup10"; + }; + + qup_i2c11_default: qup-i2c11-default-state { + pins = "gpio31", "gpio32"; + function = "qup11"; + }; + + qup_i2c12_default: qup-i2c12-default-state { + pins = "gpio49", "gpio50"; + function = "qup12"; + }; + + qup_i2c13_default: qup-i2c13-default-state { + pins = "gpio105", "gpio106"; + function = "qup13"; + }; + + qup_i2c14_default: qup-i2c14-default-state { + pins = "gpio33", "gpio34"; + function = "qup14"; + }; + + qup_i2c15_default: qup-i2c15-default-state { + pins = "gpio81", "gpio82"; + function = "qup15"; + }; + + qup_spi0_default: qup-spi0-default-state { + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "qup0"; + }; + + qup_spi1_default: qup-spi1-default-state { + pins = "gpio17", "gpio18", "gpio19", "gpio20"; + function = "qup1"; + }; + + qup_spi2_default: qup-spi2-default-state { + pins = "gpio27", "gpio28", "gpio29", "gpio30"; + function = "qup2"; + }; + + qup_spi3_default: qup-spi3-default-state { + pins = "gpio41", "gpio42", "gpio43", "gpio44"; + function = "qup3"; + }; + + qup_spi4_default: qup-spi4-default-state { + pins = "gpio89", "gpio90", "gpio91", "gpio92"; + function = "qup4"; + }; + + qup_spi5_default: qup-spi5-default-state { + pins = "gpio85", "gpio86", "gpio87", "gpio88"; + function = "qup5"; + }; + + qup_spi6_default: qup-spi6-default-state { + pins = "gpio45", "gpio46", "gpio47", "gpio48"; + function = "qup6"; + }; + + qup_spi7_default: qup-spi7-default-state { + pins = "gpio93", "gpio94", "gpio95", "gpio96"; + function = "qup7"; + }; + + qup_spi8_default: qup-spi8-default-state { + pins = "gpio65", "gpio66", "gpio67", "gpio68"; + function = "qup8"; + }; + + qup_spi9_default: qup-spi9-default-state { + pins = "gpio6", "gpio7", "gpio4", "gpio5"; + function = "qup9"; + }; + + qup_spi10_default: qup-spi10-default-state { + pins = "gpio55", "gpio56", "gpio53", "gpio54"; + function = "qup10"; + }; + + qup_spi11_default: qup-spi11-default-state { + pins = "gpio31", "gpio32", "gpio33", "gpio34"; + function = "qup11"; + }; + + qup_spi12_default: qup-spi12-default-state { + pins = "gpio49", "gpio50", "gpio51", "gpio52"; + function = "qup12"; + }; + + qup_spi13_default: qup-spi13-default-state { + pins = "gpio105", "gpio106", "gpio107", "gpio108"; + function = "qup13"; + }; + + qup_spi14_default: qup-spi14-default-state { + pins = "gpio33", "gpio34", "gpio31", "gpio32"; + function = "qup14"; + }; + + qup_spi15_default: qup-spi15-default-state { + pins = "gpio81", "gpio82", "gpio83", "gpio84"; + function = "qup15"; + }; + + qup_uart0_default: qup-uart0-default-state { + qup_uart0_tx: tx-pins { + pins = "gpio2"; + function = "qup0"; + }; + + qup_uart0_rx: rx-pins { + pins = "gpio3"; + function = "qup0"; + }; + }; + + qup_uart1_default: qup-uart1-default-state { + qup_uart1_tx: tx-pins { + pins = "gpio19"; + function = "qup1"; + }; + + qup_uart1_rx: rx-pins { + pins = "gpio20"; + function = "qup1"; + }; + }; + + qup_uart2_default: qup-uart2-default-state { + qup_uart2_tx: tx-pins { + pins = "gpio29"; + function = "qup2"; + }; + + qup_uart2_rx: rx-pins { + pins = "gpio30"; + function = "qup2"; + }; + }; + + qup_uart3_default: qup-uart3-default-state { + qup_uart3_tx: tx-pins { + pins = "gpio43"; + function = "qup3"; + }; + + qup_uart3_rx: rx-pins { + pins = "gpio44"; + function = "qup3"; + }; + }; + + qup_uart3_4pin: qup-uart3-4pin-state { + qup_uart3_4pin_cts: cts-pins { + pins = "gpio41"; + function = "qup3"; + }; + + qup_uart3_4pin_rts_tx: rts-tx-pins { + pins = "gpio42", "gpio43"; + function = "qup3"; + }; + + qup_uart3_4pin_rx: rx-pins { + pins = "gpio44"; + function = "qup3"; + }; + }; + + qup_uart4_default: qup-uart4-default-state { + qup_uart4_tx: tx-pins { + pins = "gpio91"; + function = "qup4"; + }; + + qup_uart4_rx: rx-pins { + pins = "gpio92"; + function = "qup4"; + }; + }; + + qup_uart5_default: qup-uart5-default-state { + qup_uart5_tx: tx-pins { + pins = "gpio87"; + function = "qup5"; + }; + + qup_uart5_rx: rx-pins { + pins = "gpio88"; + function = "qup5"; + }; + }; + + qup_uart6_default: qup-uart6-default-state { + qup_uart6_tx: tx-pins { + pins = "gpio47"; + function = "qup6"; + }; + + qup_uart6_rx: rx-pins { + pins = "gpio48"; + function = "qup6"; + }; + }; + + qup_uart6_4pin: qup-uart6-4pin-state { + qup_uart6_4pin_cts: cts-pins { + pins = "gpio45"; + function = "qup6"; + bias-pull-down; + }; + + qup_uart6_4pin_rts_tx: rts-tx-pins { + pins = "gpio46", "gpio47"; + function = "qup6"; + drive-strength = <2>; + bias-disable; + }; + + qup_uart6_4pin_rx: rx-pins { + pins = "gpio48"; + function = "qup6"; + bias-pull-up; + }; + }; + + qup_uart7_default: qup-uart7-default-state { + qup_uart7_tx: tx-pins { + pins = "gpio95"; + function = "qup7"; + }; + + qup_uart7_rx: rx-pins { + pins = "gpio96"; + function = "qup7"; + }; + }; + + qup_uart8_default: qup-uart8-default-state { + qup_uart8_tx: tx-pins { + pins = "gpio67"; + function = "qup8"; + }; + + qup_uart8_rx: rx-pins { + pins = "gpio68"; + function = "qup8"; + }; + }; + + qup_uart9_default: qup-uart9-default-state { + qup_uart9_tx: tx-pins { + pins = "gpio4"; + function = "qup9"; + }; + + qup_uart9_rx: rx-pins { + pins = "gpio5"; + function = "qup9"; + }; + }; + + qup_uart10_default: qup-uart10-default-state { + qup_uart10_tx: tx-pins { + pins = "gpio53"; + function = "qup10"; + }; + + qup_uart10_rx: rx-pins { + pins = "gpio54"; + function = "qup10"; + }; + }; + + qup_uart11_default: qup-uart11-default-state { + qup_uart11_tx: tx-pins { + pins = "gpio33"; + function = "qup11"; + }; + + qup_uart11_rx: rx-pins { + pins = "gpio34"; + function = "qup11"; + }; + }; + + qup_uart12_default: qup-uart12-default-state { + qup_uart12_tx: tx-pins { + pins = "gpio51"; + function = "qup0"; + }; + + qup_uart12_rx: rx-pins { + pins = "gpio52"; + function = "qup0"; + }; + }; + + qup_uart13_default: qup-uart13-default-state { + qup_uart13_tx: tx-pins { + pins = "gpio107"; + function = "qup13"; + }; + + qup_uart13_rx: rx-pins { + pins = "gpio108"; + function = "qup13"; + }; + }; + + qup_uart14_default: qup-uart14-default-state { + qup_uart14_tx: tx-pins { + pins = "gpio31"; + function = "qup14"; + }; + + qup_uart14_rx: rx-pins { + pins = "gpio32"; + function = "qup14"; + }; + }; + + qup_uart15_default: qup-uart15-default-state { + qup_uart15_tx: tx-pins { + pins = "gpio83"; + function = "qup15"; + }; + + qup_uart15_rx: rx-pins { + pins = "gpio84"; + function = "qup15"; + }; + }; + + quat_mi2s_sleep: quat-mi2s-sleep-state { + pins = "gpio58", "gpio59"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + quat_mi2s_active: quat-mi2s-active-state { + pins = "gpio58", "gpio59"; + function = "qua_mi2s"; + drive-strength = <8>; + bias-disable; + output-high; + }; + + quat_mi2s_sd0_sleep: quat-mi2s-sd0-sleep-state { + pins = "gpio60"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + quat_mi2s_sd0_active: quat-mi2s-sd0-active-state { + pins = "gpio60"; + function = "qua_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + quat_mi2s_sd1_sleep: quat-mi2s-sd1-sleep-state { + pins = "gpio61"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + quat_mi2s_sd1_active: quat-mi2s-sd1-active-state { + pins = "gpio61"; + function = "qua_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + quat_mi2s_sd2_sleep: quat-mi2s-sd2-sleep-state { + pins = "gpio62"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + quat_mi2s_sd2_active: quat-mi2s-sd2-active-state { + pins = "gpio62"; + function = "qua_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + quat_mi2s_sd3_sleep: quat-mi2s-sd3-sleep-state { + pins = "gpio63"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + quat_mi2s_sd3_active: quat-mi2s-sd3-active-state { + pins = "gpio63"; + function = "qua_mi2s"; + drive-strength = <8>; + bias-disable; + }; + }; + + mss_pil: remoteproc@4080000 { + compatible = "qcom,sdm845-mss-pil"; + reg = <0 0x04080000 0 0x408>, <0 0x04180000 0 0x48>; + reg-names = "qdsp6", "rmb"; + + interrupts-extended = + <&intc GIC_SPI 266 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 3 IRQ_TYPE_EDGE_RISING>, + <&modem_smp2p_in 7 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack", + "shutdown-ack"; + + clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, + <&gcc GCC_MSS_Q6_MEMNOC_AXI_CLK>, + <&gcc GCC_BOOT_ROM_AHB_CLK>, + <&gcc GCC_MSS_GPLL0_DIV_CLK_SRC>, + <&gcc GCC_MSS_SNOC_AXI_CLK>, + <&gcc GCC_MSS_MFAB_AXIS_CLK>, + <&gcc GCC_PRNG_AHB_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "bus", "mem", "gpll0_mss", + "snoc_axi", "mnoc_axi", "prng", "xo"; + + qcom,qmp = <&aoss_qmp>; + + qcom,smem-states = <&modem_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + resets = <&aoss_reset AOSS_CC_MSS_RESTART>, + <&pdc_reset PDC_MODEM_SYNC_RESET>; + reset-names = "mss_restart", "pdc_reset"; + + qcom,halt-regs = <&tcsr_regs_1 0x3000 0x5000 0x4000>; + + power-domains = <&rpmhpd SDM845_CX>, + <&rpmhpd SDM845_MX>, + <&rpmhpd SDM845_MSS>; + power-domain-names = "cx", "mx", "mss"; + + status = "disabled"; + + mba { + memory-region = <&mba_region>; + }; + + mpss { + memory-region = <&mpss_region>; + }; + + metadata { + memory-region = <&mdata_mem>; + }; + + glink-edge { + interrupts = <GIC_SPI 449 IRQ_TYPE_EDGE_RISING>; + label = "modem"; + qcom,remote-pid = <1>; + mboxes = <&apss_shared 12>; + }; + }; + + gpucc: clock-controller@5090000 { + compatible = "qcom,sdm845-gpucc"; + reg = <0 0x05090000 0 0x9000>; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&gcc GCC_GPU_GPLL0_CLK_SRC>, + <&gcc GCC_GPU_GPLL0_DIV_CLK_SRC>; + clock-names = "bi_tcxo", + "gcc_gpu_gpll0_clk_src", + "gcc_gpu_gpll0_div_clk_src"; + }; + + slpi_pas: remoteproc@5c00000 { + compatible = "qcom,sdm845-slpi-pas"; + reg = <0 0x5c00000 0 0x4000>; + + interrupts-extended = <&intc GIC_SPI 494 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "xo"; + + qcom,qmp = <&aoss_qmp>; + + power-domains = <&rpmhpd SDM845_CX>, + <&rpmhpd SDM845_MX>; + power-domain-names = "lcx", "lmx"; + + memory-region = <&slpi_mem>; + + qcom,smem-states = <&slpi_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 170 IRQ_TYPE_EDGE_RISING>; + label = "dsps"; + qcom,remote-pid = <3>; + mboxes = <&apss_shared 24>; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,glink-channels = "fastrpcglink-apps-dsp"; + label = "sdsp"; + qcom,non-secure-domain; + qcom,vmids = <QCOM_SCM_VMID_HLOS QCOM_SCM_VMID_MSS_MSA + QCOM_SCM_VMID_SSC_Q6 QCOM_SCM_VMID_ADSP_Q6>; + memory-region = <&fastrpc_mem>; + #address-cells = <1>; + #size-cells = <0>; + + compute-cb@0 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <0>; + }; + }; + }; + }; + + stm@6002000 { + compatible = "arm,coresight-stm", "arm,primecell"; + reg = <0 0x06002000 0 0x1000>, + <0 0x16280000 0 0x180000>; + reg-names = "stm-base", "stm-stimulus-base"; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + stm_out: endpoint { + remote-endpoint = + <&funnel0_in7>; + }; + }; + }; + }; + + funnel@6041000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06041000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + funnel0_out: endpoint { + remote-endpoint = + <&merge_funnel_in0>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@7 { + reg = <7>; + funnel0_in7: endpoint { + remote-endpoint = <&stm_out>; + }; + }; + }; + }; + + funnel@6043000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06043000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + funnel2_out: endpoint { + remote-endpoint = + <&merge_funnel_in2>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@5 { + reg = <5>; + funnel2_in5: endpoint { + remote-endpoint = + <&apss_merge_funnel_out>; + }; + }; + }; + }; + + funnel@6045000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x06045000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + merge_funnel_out: endpoint { + remote-endpoint = <&etf_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + merge_funnel_in0: endpoint { + remote-endpoint = + <&funnel0_out>; + }; + }; + + port@2 { + reg = <2>; + merge_funnel_in2: endpoint { + remote-endpoint = + <&funnel2_out>; + }; + }; + }; + }; + + replicator@6046000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0 0x06046000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + replicator_out: endpoint { + remote-endpoint = <&etr_in>; + }; + }; + }; + + in-ports { + port { + replicator_in: endpoint { + remote-endpoint = <&etf_out>; + }; + }; + }; + }; + + etf@6047000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0 0x06047000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + etf_out: endpoint { + remote-endpoint = + <&replicator_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@1 { + reg = <1>; + etf_in: endpoint { + remote-endpoint = + <&merge_funnel_out>; + }; + }; + }; + }; + + etr@6048000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0 0x06048000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,scatter-gather; + + in-ports { + port { + etr_in: endpoint { + remote-endpoint = + <&replicator_out>; + }; + }; + }; + }; + + etm@7040000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07040000 0 0x1000>; + + cpu = <&CPU0>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm0_out: endpoint { + remote-endpoint = + <&apss_funnel_in0>; + }; + }; + }; + }; + + etm@7140000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07140000 0 0x1000>; + + cpu = <&CPU1>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm1_out: endpoint { + remote-endpoint = + <&apss_funnel_in1>; + }; + }; + }; + }; + + etm@7240000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07240000 0 0x1000>; + + cpu = <&CPU2>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm2_out: endpoint { + remote-endpoint = + <&apss_funnel_in2>; + }; + }; + }; + }; + + etm@7340000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07340000 0 0x1000>; + + cpu = <&CPU3>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm3_out: endpoint { + remote-endpoint = + <&apss_funnel_in3>; + }; + }; + }; + }; + + etm@7440000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07440000 0 0x1000>; + + cpu = <&CPU4>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm4_out: endpoint { + remote-endpoint = + <&apss_funnel_in4>; + }; + }; + }; + }; + + etm@7540000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07540000 0 0x1000>; + + cpu = <&CPU5>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm5_out: endpoint { + remote-endpoint = + <&apss_funnel_in5>; + }; + }; + }; + }; + + etm@7640000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07640000 0 0x1000>; + + cpu = <&CPU6>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm6_out: endpoint { + remote-endpoint = + <&apss_funnel_in6>; + }; + }; + }; + }; + + etm@7740000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0 0x07740000 0 0x1000>; + + cpu = <&CPU7>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + arm,coresight-loses-context-with-cpu; + + out-ports { + port { + etm7_out: endpoint { + remote-endpoint = + <&apss_funnel_in7>; + }; + }; + }; + }; + + funnel@7800000 { /* APSS Funnel */ + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x07800000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + apss_funnel_out: endpoint { + remote-endpoint = + <&apss_merge_funnel_in>; + }; + }; + }; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + apss_funnel_in0: endpoint { + remote-endpoint = + <&etm0_out>; + }; + }; + + port@1 { + reg = <1>; + apss_funnel_in1: endpoint { + remote-endpoint = + <&etm1_out>; + }; + }; + + port@2 { + reg = <2>; + apss_funnel_in2: endpoint { + remote-endpoint = + <&etm2_out>; + }; + }; + + port@3 { + reg = <3>; + apss_funnel_in3: endpoint { + remote-endpoint = + <&etm3_out>; + }; + }; + + port@4 { + reg = <4>; + apss_funnel_in4: endpoint { + remote-endpoint = + <&etm4_out>; + }; + }; + + port@5 { + reg = <5>; + apss_funnel_in5: endpoint { + remote-endpoint = + <&etm5_out>; + }; + }; + + port@6 { + reg = <6>; + apss_funnel_in6: endpoint { + remote-endpoint = + <&etm6_out>; + }; + }; + + port@7 { + reg = <7>; + apss_funnel_in7: endpoint { + remote-endpoint = + <&etm7_out>; + }; + }; + }; + }; + + funnel@7810000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0 0x07810000 0 0x1000>; + + clocks = <&aoss_qmp>; + clock-names = "apb_pclk"; + + out-ports { + port { + apss_merge_funnel_out: endpoint { + remote-endpoint = + <&funnel2_in5>; + }; + }; + }; + + in-ports { + port { + apss_merge_funnel_in: endpoint { + remote-endpoint = + <&apss_funnel_out>; + }; + }; + }; + }; + + sdhc_2: mmc@8804000 { + compatible = "qcom,sdm845-sdhci", "qcom,sdhci-msm-v5"; + reg = <0 0x08804000 0 0x1000>; + + interrupts = <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + + clocks = <&gcc GCC_SDCC2_AHB_CLK>, + <&gcc GCC_SDCC2_APPS_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "core", "xo"; + iommus = <&apps_smmu 0xa0 0xf>; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&sdhc2_opp_table>; + + status = "disabled"; + + sdhc2_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-9600000 { + opp-hz = /bits/ 64 <9600000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-201500000 { + opp-hz = /bits/ 64 <201500000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + }; + }; + + qspi: spi@88df000 { + compatible = "qcom,sdm845-qspi", "qcom,qspi-v1"; + reg = <0 0x088df000 0 0x600>; + iommus = <&apps_smmu 0x160 0x0>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_QSPI_CNOC_PERIPH_AHB_CLK>, + <&gcc GCC_QSPI_CORE_CLK>; + clock-names = "iface", "core"; + power-domains = <&rpmhpd SDM845_CX>; + operating-points-v2 = <&qspi_opp_table>; + status = "disabled"; + }; + + slim: slim-ngd@171c0000 { + compatible = "qcom,slim-ngd-v2.1.0"; + reg = <0 0x171c0000 0 0x2c000>; + interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; + + dmas = <&slimbam 3>, <&slimbam 4>; + dma-names = "rx", "tx"; + + iommus = <&apps_smmu 0x1806 0x0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + lmh_cluster1: lmh@17d70800 { + compatible = "qcom,sdm845-lmh"; + reg = <0 0x17d70800 0 0x400>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + cpus = <&CPU4>; + qcom,lmh-temp-arm-millicelsius = <65000>; + qcom,lmh-temp-low-millicelsius = <94500>; + qcom,lmh-temp-high-millicelsius = <95000>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + lmh_cluster0: lmh@17d78800 { + compatible = "qcom,sdm845-lmh"; + reg = <0 0x17d78800 0 0x400>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + cpus = <&CPU0>; + qcom,lmh-temp-arm-millicelsius = <65000>; + qcom,lmh-temp-low-millicelsius = <94500>; + qcom,lmh-temp-high-millicelsius = <95000>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + usb_1_hsphy: phy@88e2000 { + compatible = "qcom,sdm845-qusb2-phy", "qcom,qusb2-v2-phy"; + reg = <0 0x088e2000 0 0x400>; + status = "disabled"; + #phy-cells = <0>; + + clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "cfg_ahb", "ref"; + + resets = <&gcc GCC_QUSB2PHY_PRIM_BCR>; + + nvmem-cells = <&qusb2p_hstx_trim>; + }; + + usb_2_hsphy: phy@88e3000 { + compatible = "qcom,sdm845-qusb2-phy", "qcom,qusb2-v2-phy"; + reg = <0 0x088e3000 0 0x400>; + status = "disabled"; + #phy-cells = <0>; + + clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "cfg_ahb", "ref"; + + resets = <&gcc GCC_QUSB2PHY_SEC_BCR>; + + nvmem-cells = <&qusb2s_hstx_trim>; + }; + + usb_1_qmpphy: phy@88e8000 { + compatible = "qcom,sdm845-qmp-usb3-dp-phy"; + reg = <0 0x088e8000 0 0x3000>; + status = "disabled"; + + clocks = <&gcc GCC_USB3_PRIM_PHY_AUX_CLK>, + <&gcc GCC_USB3_PRIM_CLKREF_CLK>, + <&gcc GCC_USB3_PRIM_PHY_COM_AUX_CLK>, + <&gcc GCC_USB3_PRIM_PHY_PIPE_CLK>, + <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>; + clock-names = "aux", + "ref", + "com_aux", + "usb3_pipe", + "cfg_ahb"; + + resets = <&gcc GCC_USB3_PHY_PRIM_BCR>, + <&gcc GCC_USB3_DP_PHY_PRIM_BCR>; + reset-names = "phy", "common"; + + #clock-cells = <1>; + #phy-cells = <1>; + }; + + usb_2_qmpphy: phy@88eb000 { + compatible = "qcom,sdm845-qmp-usb3-uni-phy"; + reg = <0 0x088eb000 0 0x18c>; + status = "disabled"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&gcc GCC_USB3_SEC_PHY_AUX_CLK>, + <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&gcc GCC_USB3_SEC_CLKREF_CLK>, + <&gcc GCC_USB3_SEC_PHY_COM_AUX_CLK>; + clock-names = "aux", "cfg_ahb", "ref", "com_aux"; + + resets = <&gcc GCC_USB3PHY_PHY_SEC_BCR>, + <&gcc GCC_USB3_PHY_SEC_BCR>; + reset-names = "phy", "common"; + + usb_2_ssphy: phy@88eb200 { + reg = <0 0x088eb200 0 0x128>, + <0 0x088eb400 0 0x1fc>, + <0 0x088eb800 0 0x218>, + <0 0x088eb600 0 0x70>; + #clock-cells = <0>; + #phy-cells = <0>; + clocks = <&gcc GCC_USB3_SEC_PHY_PIPE_CLK>; + clock-names = "pipe0"; + clock-output-names = "usb3_uni_phy_pipe_clk_src"; + }; + }; + + usb_1: usb@a6f8800 { + compatible = "qcom,sdm845-dwc3", "qcom,dwc3"; + reg = <0 0x0a6f8800 0 0x400>; + status = "disabled"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + clocks = <&gcc GCC_CFG_NOC_USB3_PRIM_AXI_CLK>, + <&gcc GCC_USB30_PRIM_MASTER_CLK>, + <&gcc GCC_AGGRE_USB3_PRIM_AXI_CLK>, + <&gcc GCC_USB30_PRIM_SLEEP_CLK>, + <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi"; + + assigned-clocks = <&gcc GCC_USB30_PRIM_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_PRIM_MASTER_CLK>; + assigned-clock-rates = <19200000>, <150000000>; + + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 486 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 488 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 489 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hs_phy_irq", "ss_phy_irq", + "dm_hs_phy_irq", "dp_hs_phy_irq"; + + power-domains = <&gcc USB30_PRIM_GDSC>; + + resets = <&gcc GCC_USB30_PRIM_BCR>; + + interconnects = <&aggre2_noc MASTER_USB3_0 0 &mem_noc SLAVE_EBI1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_USB3_0 0>; + interconnect-names = "usb-ddr", "apps-usb"; + + usb_1_dwc3: usb@a600000 { + compatible = "snps,dwc3"; + reg = <0 0x0a600000 0 0xcd00>; + interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x740 0>; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + phys = <&usb_1_hsphy>, <&usb_1_qmpphy QMP_USB43DP_USB3_PHY>; + phy-names = "usb2-phy", "usb3-phy"; + }; + }; + + usb_2: usb@a8f8800 { + compatible = "qcom,sdm845-dwc3", "qcom,dwc3"; + reg = <0 0x0a8f8800 0 0x400>; + status = "disabled"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + dma-ranges; + + clocks = <&gcc GCC_CFG_NOC_USB3_SEC_AXI_CLK>, + <&gcc GCC_USB30_SEC_MASTER_CLK>, + <&gcc GCC_AGGRE_USB3_SEC_AXI_CLK>, + <&gcc GCC_USB30_SEC_SLEEP_CLK>, + <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi"; + + assigned-clocks = <&gcc GCC_USB30_SEC_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_SEC_MASTER_CLK>; + assigned-clock-rates = <19200000>, <150000000>; + + interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 487 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 490 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 491 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hs_phy_irq", "ss_phy_irq", + "dm_hs_phy_irq", "dp_hs_phy_irq"; + + power-domains = <&gcc USB30_SEC_GDSC>; + + resets = <&gcc GCC_USB30_SEC_BCR>; + + interconnects = <&aggre2_noc MASTER_USB3_1 0 &mem_noc SLAVE_EBI1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_USB3_1 0>; + interconnect-names = "usb-ddr", "apps-usb"; + + usb_2_dwc3: usb@a800000 { + compatible = "snps,dwc3"; + reg = <0 0x0a800000 0 0xcd00>; + interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x760 0>; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + phys = <&usb_2_hsphy>, <&usb_2_ssphy>; + phy-names = "usb2-phy", "usb3-phy"; + }; + }; + + venus: video-codec@aa00000 { + compatible = "qcom,sdm845-venus-v2"; + reg = <0 0x0aa00000 0 0xff000>; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&videocc VENUS_GDSC>, + <&videocc VCODEC0_GDSC>, + <&videocc VCODEC1_GDSC>, + <&rpmhpd SDM845_CX>; + power-domain-names = "venus", "vcodec0", "vcodec1", "cx"; + operating-points-v2 = <&venus_opp_table>; + clocks = <&videocc VIDEO_CC_VENUS_CTL_CORE_CLK>, + <&videocc VIDEO_CC_VENUS_AHB_CLK>, + <&videocc VIDEO_CC_VENUS_CTL_AXI_CLK>, + <&videocc VIDEO_CC_VCODEC0_CORE_CLK>, + <&videocc VIDEO_CC_VCODEC0_AXI_CLK>, + <&videocc VIDEO_CC_VCODEC1_CORE_CLK>, + <&videocc VIDEO_CC_VCODEC1_AXI_CLK>; + clock-names = "core", "iface", "bus", + "vcodec0_core", "vcodec0_bus", + "vcodec1_core", "vcodec1_bus"; + iommus = <&apps_smmu 0x10a0 0x8>, + <&apps_smmu 0x10b0 0x0>; + memory-region = <&venus_mem>; + interconnects = <&mmss_noc MASTER_VIDEO_P0 0 &mem_noc SLAVE_EBI1 0>, + <&gladiator_noc MASTER_APPSS_PROC 0 &config_noc SLAVE_VENUS_CFG 0>; + interconnect-names = "video-mem", "cpu-cfg"; + + status = "disabled"; + + video-core0 { + compatible = "venus-decoder"; + }; + + video-core1 { + compatible = "venus-encoder"; + }; + + venus_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-320000000 { + opp-hz = /bits/ 64 <320000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-380000000 { + opp-hz = /bits/ 64 <380000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-444000000 { + opp-hz = /bits/ 64 <444000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + + opp-533000097 { + opp-hz = /bits/ 64 <533000097>; + required-opps = <&rpmhpd_opp_turbo>; + }; + }; + }; + + videocc: clock-controller@ab00000 { + compatible = "qcom,sdm845-videocc"; + reg = <0 0x0ab00000 0 0x10000>; + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "bi_tcxo"; + #clock-cells = <1>; + #power-domain-cells = <1>; + #reset-cells = <1>; + }; + + camss: camss@acb3000 { + compatible = "qcom,sdm845-camss"; + + reg = <0 0x0acb3000 0 0x1000>, + <0 0x0acba000 0 0x1000>, + <0 0x0acc8000 0 0x1000>, + <0 0x0ac65000 0 0x1000>, + <0 0x0ac66000 0 0x1000>, + <0 0x0ac67000 0 0x1000>, + <0 0x0ac68000 0 0x1000>, + <0 0x0acaf000 0 0x4000>, + <0 0x0acb6000 0 0x4000>, + <0 0x0acc4000 0 0x4000>; + reg-names = "csid0", + "csid1", + "csid2", + "csiphy0", + "csiphy1", + "csiphy2", + "csiphy3", + "vfe0", + "vfe1", + "vfe_lite"; + + interrupts = <GIC_SPI 464 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 466 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 468 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 477 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 478 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 479 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 448 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 465 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 467 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 469 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "csid0", + "csid1", + "csid2", + "csiphy0", + "csiphy1", + "csiphy2", + "csiphy3", + "vfe0", + "vfe1", + "vfe_lite"; + + power-domains = <&clock_camcc IFE_0_GDSC>, + <&clock_camcc IFE_1_GDSC>, + <&clock_camcc TITAN_TOP_GDSC>; + + clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, + <&clock_camcc CAM_CC_CPAS_AHB_CLK>, + <&clock_camcc CAM_CC_CPHY_RX_CLK_SRC>, + <&clock_camcc CAM_CC_IFE_0_CSID_CLK>, + <&clock_camcc CAM_CC_IFE_0_CSID_CLK_SRC>, + <&clock_camcc CAM_CC_IFE_1_CSID_CLK>, + <&clock_camcc CAM_CC_IFE_1_CSID_CLK_SRC>, + <&clock_camcc CAM_CC_IFE_LITE_CSID_CLK>, + <&clock_camcc CAM_CC_IFE_LITE_CSID_CLK_SRC>, + <&clock_camcc CAM_CC_CSIPHY0_CLK>, + <&clock_camcc CAM_CC_CSI0PHYTIMER_CLK>, + <&clock_camcc CAM_CC_CSI0PHYTIMER_CLK_SRC>, + <&clock_camcc CAM_CC_CSIPHY1_CLK>, + <&clock_camcc CAM_CC_CSI1PHYTIMER_CLK>, + <&clock_camcc CAM_CC_CSI1PHYTIMER_CLK_SRC>, + <&clock_camcc CAM_CC_CSIPHY2_CLK>, + <&clock_camcc CAM_CC_CSI2PHYTIMER_CLK>, + <&clock_camcc CAM_CC_CSI2PHYTIMER_CLK_SRC>, + <&clock_camcc CAM_CC_CSIPHY3_CLK>, + <&clock_camcc CAM_CC_CSI3PHYTIMER_CLK>, + <&clock_camcc CAM_CC_CSI3PHYTIMER_CLK_SRC>, + <&gcc GCC_CAMERA_AHB_CLK>, + <&gcc GCC_CAMERA_AXI_CLK>, + <&clock_camcc CAM_CC_SLOW_AHB_CLK_SRC>, + <&clock_camcc CAM_CC_SOC_AHB_CLK>, + <&clock_camcc CAM_CC_IFE_0_AXI_CLK>, + <&clock_camcc CAM_CC_IFE_0_CLK>, + <&clock_camcc CAM_CC_IFE_0_CPHY_RX_CLK>, + <&clock_camcc CAM_CC_IFE_0_CLK_SRC>, + <&clock_camcc CAM_CC_IFE_1_AXI_CLK>, + <&clock_camcc CAM_CC_IFE_1_CLK>, + <&clock_camcc CAM_CC_IFE_1_CPHY_RX_CLK>, + <&clock_camcc CAM_CC_IFE_1_CLK_SRC>, + <&clock_camcc CAM_CC_IFE_LITE_CLK>, + <&clock_camcc CAM_CC_IFE_LITE_CPHY_RX_CLK>, + <&clock_camcc CAM_CC_IFE_LITE_CLK_SRC>; + clock-names = "camnoc_axi", + "cpas_ahb", + "cphy_rx_src", + "csi0", + "csi0_src", + "csi1", + "csi1_src", + "csi2", + "csi2_src", + "csiphy0", + "csiphy0_timer", + "csiphy0_timer_src", + "csiphy1", + "csiphy1_timer", + "csiphy1_timer_src", + "csiphy2", + "csiphy2_timer", + "csiphy2_timer_src", + "csiphy3", + "csiphy3_timer", + "csiphy3_timer_src", + "gcc_camera_ahb", + "gcc_camera_axi", + "slow_ahb_src", + "soc_ahb", + "vfe0_axi", + "vfe0", + "vfe0_cphy_rx", + "vfe0_src", + "vfe1_axi", + "vfe1", + "vfe1_cphy_rx", + "vfe1_src", + "vfe_lite", + "vfe_lite_cphy_rx", + "vfe_lite_src"; + + iommus = <&apps_smmu 0x0808 0x0>, + <&apps_smmu 0x0810 0x8>, + <&apps_smmu 0x0c08 0x0>, + <&apps_smmu 0x0c10 0x8>; + + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + }; + + port@1 { + reg = <1>; + }; + + port@2 { + reg = <2>; + }; + + port@3 { + reg = <3>; + }; + }; + }; + + cci: cci@ac4a000 { + compatible = "qcom,sdm845-cci", "qcom,msm8996-cci"; + #address-cells = <1>; + #size-cells = <0>; + + reg = <0 0x0ac4a000 0 0x4000>; + interrupts = <GIC_SPI 460 IRQ_TYPE_EDGE_RISING>; + power-domains = <&clock_camcc TITAN_TOP_GDSC>; + + clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, + <&clock_camcc CAM_CC_SOC_AHB_CLK>, + <&clock_camcc CAM_CC_SLOW_AHB_CLK_SRC>, + <&clock_camcc CAM_CC_CPAS_AHB_CLK>, + <&clock_camcc CAM_CC_CCI_CLK>, + <&clock_camcc CAM_CC_CCI_CLK_SRC>; + clock-names = "camnoc_axi", + "soc_ahb", + "slow_ahb_src", + "cpas_ahb", + "cci", + "cci_src"; + + assigned-clocks = <&clock_camcc CAM_CC_CAMNOC_AXI_CLK>, + <&clock_camcc CAM_CC_CCI_CLK>; + assigned-clock-rates = <80000000>, <37500000>; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&cci0_default &cci1_default>; + pinctrl-1 = <&cci0_sleep &cci1_sleep>; + + status = "disabled"; + + cci_i2c0: i2c-bus@0 { + reg = <0>; + clock-frequency = <1000000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + cci_i2c1: i2c-bus@1 { + reg = <1>; + clock-frequency = <1000000>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + clock_camcc: clock-controller@ad00000 { + compatible = "qcom,sdm845-camcc"; + reg = <0 0x0ad00000 0 0x10000>; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + clocks = <&rpmhcc RPMH_CXO_CLK>; + clock-names = "bi_tcxo"; + }; + + mdss: display-subsystem@ae00000 { + compatible = "qcom,sdm845-mdss"; + reg = <0 0x0ae00000 0 0x1000>; + reg-names = "mdss"; + + power-domains = <&dispcc MDSS_GDSC>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_MDP_CLK>; + clock-names = "iface", "core"; + + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <1>; + + interconnects = <&mmss_noc MASTER_MDP0 0 &mem_noc SLAVE_EBI1 0>, + <&mmss_noc MASTER_MDP1 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "mdp0-mem", "mdp1-mem"; + + iommus = <&apps_smmu 0x880 0x8>, + <&apps_smmu 0xc80 0x8>; + + status = "disabled"; + + #address-cells = <2>; + #size-cells = <2>; + ranges; + + mdss_mdp: display-controller@ae01000 { + compatible = "qcom,sdm845-dpu"; + reg = <0 0x0ae01000 0 0x8f000>, + <0 0x0aeb0000 0 0x2008>; + reg-names = "mdp", "vbif"; + + clocks = <&gcc GCC_DISP_AXI_CLK>, + <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_AXI_CLK>, + <&dispcc DISP_CC_MDSS_MDP_CLK>, + <&dispcc DISP_CC_MDSS_VSYNC_CLK>; + clock-names = "gcc-bus", "iface", "bus", "core", "vsync"; + + assigned-clocks = <&dispcc DISP_CC_MDSS_VSYNC_CLK>; + assigned-clock-rates = <19200000>; + operating-points-v2 = <&mdp_opp_table>; + power-domains = <&rpmhpd SDM845_CX>; + + interrupt-parent = <&mdss>; + interrupts = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + dpu_intf0_out: endpoint { + remote-endpoint = <&dp_in>; + }; + }; + + port@1 { + reg = <1>; + dpu_intf1_out: endpoint { + remote-endpoint = <&mdss_dsi0_in>; + }; + }; + + port@2 { + reg = <2>; + dpu_intf2_out: endpoint { + remote-endpoint = <&mdss_dsi1_in>; + }; + }; + }; + + mdp_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + required-opps = <&rpmhpd_opp_min_svs>; + }; + + opp-171428571 { + opp-hz = /bits/ 64 <171428571>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-344000000 { + opp-hz = /bits/ 64 <344000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-430000000 { + opp-hz = /bits/ 64 <430000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + }; + + mdss_dp: displayport-controller@ae90000 { + status = "disabled"; + compatible = "qcom,sdm845-dp"; + + reg = <0 0x0ae90000 0 0x200>, + <0 0x0ae90200 0 0x200>, + <0 0x0ae90400 0 0x600>, + <0 0x0ae90a00 0 0x600>, + <0 0x0ae91000 0 0x600>; + + interrupt-parent = <&mdss>; + interrupts = <12>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_DP_AUX_CLK>, + <&dispcc DISP_CC_MDSS_DP_LINK_CLK>, + <&dispcc DISP_CC_MDSS_DP_LINK_INTF_CLK>, + <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK>; + clock-names = "core_iface", "core_aux", "ctrl_link", + "ctrl_link_iface", "stream_pixel"; + assigned-clocks = <&dispcc DISP_CC_MDSS_DP_LINK_CLK_SRC>, + <&dispcc DISP_CC_MDSS_DP_PIXEL_CLK_SRC>; + assigned-clock-parents = <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, + <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; + phys = <&usb_1_qmpphy QMP_USB43DP_DP_PHY>; + phy-names = "dp"; + + operating-points-v2 = <&dp_opp_table>; + power-domains = <&rpmhpd SDM845_CX>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + dp_in: endpoint { + remote-endpoint = <&dpu_intf0_out>; + }; + }; + + port@1 { + reg = <1>; + dp_out: endpoint { }; + }; + }; + + dp_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-162000000 { + opp-hz = /bits/ 64 <162000000>; + required-opps = <&rpmhpd_opp_low_svs>; + }; + + opp-270000000 { + opp-hz = /bits/ 64 <270000000>; + required-opps = <&rpmhpd_opp_svs>; + }; + + opp-540000000 { + opp-hz = /bits/ 64 <540000000>; + required-opps = <&rpmhpd_opp_svs_l1>; + }; + + opp-810000000 { + opp-hz = /bits/ 64 <810000000>; + required-opps = <&rpmhpd_opp_nom>; + }; + }; + }; + + mdss_dsi0: dsi@ae94000 { + compatible = "qcom,sdm845-dsi-ctrl", + "qcom,mdss-dsi-ctrl"; + reg = <0 0x0ae94000 0 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <4>; + + clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK>, + <&dispcc DISP_CC_MDSS_BYTE0_INTF_CLK>, + <&dispcc DISP_CC_MDSS_PCLK0_CLK>, + <&dispcc DISP_CC_MDSS_ESC0_CLK>, + <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_AXI_CLK>; + clock-names = "byte", + "byte_intf", + "pixel", + "core", + "iface", + "bus"; + assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE0_CLK_SRC>, <&dispcc DISP_CC_MDSS_PCLK0_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; + + operating-points-v2 = <&dsi_opp_table>; + power-domains = <&rpmhpd SDM845_CX>; + + phys = <&mdss_dsi0_phy>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi0_in: endpoint { + remote-endpoint = <&dpu_intf1_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi0_out: endpoint { + }; + }; + }; + }; + + mdss_dsi0_phy: phy@ae94400 { + compatible = "qcom,dsi-phy-10nm"; + reg = <0 0x0ae94400 0 0x200>, + <0 0x0ae94600 0 0x280>, + <0 0x0ae94a00 0 0x1e0>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "ref"; + + status = "disabled"; + }; + + mdss_dsi1: dsi@ae96000 { + compatible = "qcom,sdm845-dsi-ctrl", + "qcom,mdss-dsi-ctrl"; + reg = <0 0x0ae96000 0 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <5>; + + clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK>, + <&dispcc DISP_CC_MDSS_BYTE1_INTF_CLK>, + <&dispcc DISP_CC_MDSS_PCLK1_CLK>, + <&dispcc DISP_CC_MDSS_ESC1_CLK>, + <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&dispcc DISP_CC_MDSS_AXI_CLK>; + clock-names = "byte", + "byte_intf", + "pixel", + "core", + "iface", + "bus"; + assigned-clocks = <&dispcc DISP_CC_MDSS_BYTE1_CLK_SRC>, <&dispcc DISP_CC_MDSS_PCLK1_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi1_phy 0>, <&mdss_dsi1_phy 1>; + + operating-points-v2 = <&dsi_opp_table>; + power-domains = <&rpmhpd SDM845_CX>; + + phys = <&mdss_dsi1_phy>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi1_in: endpoint { + remote-endpoint = <&dpu_intf2_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi1_out: endpoint { + }; + }; + }; + }; + + mdss_dsi1_phy: phy@ae96400 { + compatible = "qcom,dsi-phy-10nm"; + reg = <0 0x0ae96400 0 0x200>, + <0 0x0ae96600 0 0x280>, + <0 0x0ae96a00 0 0x10e>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&dispcc DISP_CC_MDSS_AHB_CLK>, + <&rpmhcc RPMH_CXO_CLK>; + clock-names = "iface", "ref"; + + status = "disabled"; + }; + }; + + gpu: gpu@5000000 { + compatible = "qcom,adreno-630.2", "qcom,adreno"; + + reg = <0 0x05000000 0 0x40000>, <0 0x509e000 0 0x10>; + reg-names = "kgsl_3d0_reg_memory", "cx_mem"; + + /* + * Look ma, no clocks! The GPU clocks and power are + * controlled entirely by the GMU + */ + + interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; + + iommus = <&adreno_smmu 0>; + + operating-points-v2 = <&gpu_opp_table>; + + qcom,gmu = <&gmu>; + + interconnects = <&mem_noc MASTER_GFX3D 0 &mem_noc SLAVE_EBI1 0>; + interconnect-names = "gfx-mem"; + + status = "disabled"; + + gpu_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-710000000 { + opp-hz = /bits/ 64 <710000000>; + opp-level = <RPMH_REGULATOR_LEVEL_TURBO_L1>; + opp-peak-kBps = <7216000>; + }; + + opp-675000000 { + opp-hz = /bits/ 64 <675000000>; + opp-level = <RPMH_REGULATOR_LEVEL_TURBO>; + opp-peak-kBps = <7216000>; + }; + + opp-596000000 { + opp-hz = /bits/ 64 <596000000>; + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; + opp-peak-kBps = <6220000>; + }; + + opp-520000000 { + opp-hz = /bits/ 64 <520000000>; + opp-level = <RPMH_REGULATOR_LEVEL_NOM>; + opp-peak-kBps = <6220000>; + }; + + opp-414000000 { + opp-hz = /bits/ 64 <414000000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; + opp-peak-kBps = <4068000>; + }; + + opp-342000000 { + opp-hz = /bits/ 64 <342000000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS>; + opp-peak-kBps = <2724000>; + }; + + opp-257000000 { + opp-hz = /bits/ 64 <257000000>; + opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; + opp-peak-kBps = <1648000>; + }; + }; + }; + + adreno_smmu: iommu@5040000 { + compatible = "qcom,sdm845-smmu-v2", "qcom,adreno-smmu", "qcom,smmu-v2"; + reg = <0 0x05040000 0 0x10000>; + #iommu-cells = <1>; + #global-interrupts = <2>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 364 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 365 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 366 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 367 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 368 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 369 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 370 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 371 IRQ_TYPE_EDGE_RISING>; + clocks = <&gcc GCC_GPU_MEMNOC_GFX_CLK>, + <&gcc GCC_GPU_CFG_AHB_CLK>; + clock-names = "bus", "iface"; + + power-domains = <&gpucc GPU_CX_GDSC>; + }; + + gmu: gmu@506a000 { + compatible = "qcom,adreno-gmu-630.2", "qcom,adreno-gmu"; + + reg = <0 0x0506a000 0 0x30000>, + <0 0x0b280000 0 0x10000>, + <0 0x0b480000 0 0x10000>; + reg-names = "gmu", "gmu_pdc", "gmu_pdc_seq"; + + interrupts = <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hfi", "gmu"; + + clocks = <&gpucc GPU_CC_CX_GMU_CLK>, + <&gpucc GPU_CC_CXO_CLK>, + <&gcc GCC_DDRSS_GPU_AXI_CLK>, + <&gcc GCC_GPU_MEMNOC_GFX_CLK>; + clock-names = "gmu", "cxo", "axi", "memnoc"; + + power-domains = <&gpucc GPU_CX_GDSC>, + <&gpucc GPU_GX_GDSC>; + power-domain-names = "cx", "gx"; + + iommus = <&adreno_smmu 5>; + + operating-points-v2 = <&gmu_opp_table>; + + status = "disabled"; + + gmu_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + opp-level = <RPMH_REGULATOR_LEVEL_SVS>; + }; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; + }; + }; + }; + + dispcc: clock-controller@af00000 { + compatible = "qcom,sdm845-dispcc"; + reg = <0 0x0af00000 0 0x10000>; + clocks = <&rpmhcc RPMH_CXO_CLK>, + <&gcc GCC_DISP_GPLL0_CLK_SRC>, + <&gcc GCC_DISP_GPLL0_DIV_CLK_SRC>, + <&mdss_dsi0_phy 0>, + <&mdss_dsi0_phy 1>, + <&mdss_dsi1_phy 0>, + <&mdss_dsi1_phy 1>, + <&usb_1_qmpphy QMP_USB43DP_DP_LINK_CLK>, + <&usb_1_qmpphy QMP_USB43DP_DP_VCO_DIV_CLK>; + clock-names = "bi_tcxo", + "gcc_disp_gpll0_clk_src", + "gcc_disp_gpll0_div_clk_src", + "dsi0_phy_pll_out_byteclk", + "dsi0_phy_pll_out_dsiclk", + "dsi1_phy_pll_out_byteclk", + "dsi1_phy_pll_out_dsiclk", + "dp_link_clk_divsel_ten", + "dp_vco_divided_clk_src_mux"; #clock-cells = <1>; #reset-cells = <1>; #power-domain-cells = <1>; };
- tlmm: pinctrl@3400000 { - compatible = "qcom,sdm845-pinctrl"; - reg = <0x3400000 0xc00000>; - gpio-count = <150>; - gpio-controller; - #gpio-cells = <2>; - gpio-ranges = <&tlmm 0 0 150>; + pdc_intc: interrupt-controller@b220000 { + compatible = "qcom,sdm845-pdc", "qcom,pdc"; + reg = <0 0x0b220000 0 0x30000>; + qcom,pdc-ranges = <0 480 94>, <94 609 15>, <115 630 7>; + #interrupt-cells = <2>; + interrupt-parent = <&intc>; + interrupt-controller; + };
- /* DEBUG UART */ - qup_uart9: qup-uart9-default { - pins = "GPIO_4", "GPIO_5"; - function = "qup9"; + pdc_reset: reset-controller@b2e0000 { + compatible = "qcom,sdm845-pdc-global"; + reg = <0 0x0b2e0000 0 0x20000>; + #reset-cells = <1>; + }; + + tsens0: thermal-sensor@c263000 { + compatible = "qcom,sdm845-tsens", "qcom,tsens-v2"; + reg = <0 0x0c263000 0 0x1ff>, /* TM */ + <0 0x0c222000 0 0x1ff>; /* SROT */ + #qcom,sensors = <13>; + interrupts = <GIC_SPI 506 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 508 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + tsens1: thermal-sensor@c265000 { + compatible = "qcom,sdm845-tsens", "qcom,tsens-v2"; + reg = <0 0x0c265000 0 0x1ff>, /* TM */ + <0 0x0c223000 0 0x1ff>; /* SROT */ + #qcom,sensors = <8>; + interrupts = <GIC_SPI 507 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 509 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + aoss_reset: reset-controller@c2a0000 { + compatible = "qcom,sdm845-aoss-cc"; + reg = <0 0x0c2a0000 0 0x31000>; + #reset-cells = <1>; + }; + + aoss_qmp: power-management@c300000 { + compatible = "qcom,sdm845-aoss-qmp", "qcom,aoss-qmp"; + reg = <0 0x0c300000 0 0x400>; + interrupts = <GIC_SPI 389 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apss_shared 0>; + + #clock-cells = <0>; + + cx_cdev: cx { + #cooling-cells = <2>; + }; + + ebi_cdev: ebi { + #cooling-cells = <2>; }; };
- qupv3_id_1: geniqup@ac0000 { - compatible = "qcom,geni-se-qup"; - reg = <0x00ac0000 0x6000>; + sram@c3f0000 { + compatible = "qcom,sdm845-rpmh-stats"; + reg = <0 0x0c3f0000 0 0x400>; + }; + + spmi_bus: spmi@c440000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0 0x0c440000 0 0x1100>, + <0 0x0c600000 0 0x2000000>, + <0 0x0e600000 0 0x100000>, + <0 0x0e700000 0 0xa0000>, + <0 0x0c40a000 0 0x26000>; + reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; + interrupt-names = "periph_irq"; + interrupts = <GIC_SPI 481 IRQ_TYPE_LEVEL_HIGH>; + qcom,ee = <0>; + qcom,channel = <0>; + #address-cells = <2>; + #size-cells = <0>; + interrupt-controller; + #interrupt-cells = <4>; + }; + + sram@146bf000 { + compatible = "qcom,sdm845-imem", "syscon", "simple-mfd"; + reg = <0 0x146bf000 0 0x1000>; + #address-cells = <1>; #size-cells = <1>; - ranges;
- uart9: serial@a84000 { - compatible = "qcom,geni-debug-uart"; - reg = <0xa84000 0x4000>; - clock-names = "se"; - clocks = <&gcc GCC_QUPV3_WRAP1_S1_CLK>; - pinctrl-names = "default"; - pinctrl-0 = <&qup_uart9>; + ranges = <0 0 0x146bf000 0x1000>; + + pil-reloc@94c { + compatible = "qcom,pil-reloc-info"; + reg = <0x94c 0xc8>; }; };
- spmi@c440000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0xc440000 0x1100>, - <0xc600000 0x2000000>, - <0xe600000 0x100000>; - reg-names = "core", "chnls", "obsrvr"; - #address-cells = <0x1>; - #size-cells = <0x1>; + apps_smmu: iommu@15000000 { + compatible = "qcom,sdm845-smmu-500", "arm,mmu-500"; + reg = <0 0x15000000 0 0x80000>; + #iommu-cells = <2>; + #global-interrupts = <1>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 316 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 317 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 318 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 319 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 322 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 323 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 324 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 325 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 327 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 328 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 331 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 332 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 333 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>; + };
- qcom,revid@100 { - compatible = "qcom,qpnp-revid"; - reg = <0x100 0x100>; + lpasscc: clock-controller@17014000 { + compatible = "qcom,sdm845-lpasscc"; + reg = <0 0x17014000 0 0x1f004>, <0 0x17300000 0 0x200>; + reg-names = "cc", "qdsp6ss"; + #clock-cells = <1>; + status = "disabled"; + }; + + gladiator_noc: interconnect@17900000 { + compatible = "qcom,sdm845-gladiator-noc"; + reg = <0 0x17900000 0 0xd080>; + #interconnect-cells = <2>; + qcom,bcm-voters = <&apps_bcm_voter>; + }; + + watchdog@17980000 { + compatible = "qcom,apss-wdt-sdm845", "qcom,kpss-wdt"; + reg = <0 0x17980000 0 0x1000>; + clocks = <&sleep_clk>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + }; + + apss_shared: mailbox@17990000 { + compatible = "qcom,sdm845-apss-shared"; + reg = <0 0x17990000 0 0x1000>; + #mbox-cells = <1>; + }; + + apps_rsc: rsc@179c0000 { + label = "apps_rsc"; + compatible = "qcom,rpmh-rsc"; + reg = <0 0x179c0000 0 0x10000>, + <0 0x179d0000 0 0x10000>, + <0 0x179e0000 0 0x10000>; + reg-names = "drv-0", "drv-1", "drv-2"; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + qcom,tcs-offset = <0xd00>; + qcom,drv-id = <2>; + qcom,tcs-config = <ACTIVE_TCS 2>, + <SLEEP_TCS 3>, + <WAKE_TCS 3>, + <CONTROL_TCS 1>; + power-domains = <&CLUSTER_PD>; + + apps_bcm_voter: bcm-voter { + compatible = "qcom,bcm-voter"; };
- pmic0: pm8998@0 { - compatible = "qcom,spmi-pmic"; - reg = <0x0 0x1>; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pm8998_pon: pon@800 { - compatible = "qcom,pm8998-pon"; - - reg = <0x800 0x100>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pm8998_pwrkey: pwrkey { - compatible = "qcom,pm8941-pwrkey"; - debounce = <15625>; - bias-pull-up; - }; - - pm8998_resin: resin { - compatible = "qcom,pm8941-resin"; - debounce = <15625>; - bias-pull-up; - status = "disabled"; - }; - }; - - pm8998_gpios: pm8998_gpios@c000 { - compatible = "qcom,pm8998-gpio"; - reg = <0xc000 0x1a00>; - gpio-controller; - gpio-ranges = <&pm8998_gpios 0 0 26>; - #gpio-cells = <2>; - }; + rpmhcc: clock-controller { + compatible = "qcom,sdm845-rpmh-clk"; + #clock-cells = <1>; + clock-names = "xo"; + clocks = <&xo_board>; };
- pmic1: pm8998@1 { - compatible = "qcom,spmi-pmic"; - reg = <0x1 0x0>; - #address-cells = <0x2>; - #size-cells = <0x0>; + rpmhpd: power-controller { + compatible = "qcom,sdm845-rpmhpd"; + #power-domain-cells = <1>; + operating-points-v2 = <&rpmhpd_opp_table>; + + rpmhpd_opp_table: opp-table { + compatible = "operating-points-v2"; + + rpmhpd_opp_ret: opp1 { + opp-level = <RPMH_REGULATOR_LEVEL_RETENTION>; + }; + + rpmhpd_opp_min_svs: opp2 { + opp-level = <RPMH_REGULATOR_LEVEL_MIN_SVS>; + }; + + rpmhpd_opp_low_svs: opp3 { + opp-level = <RPMH_REGULATOR_LEVEL_LOW_SVS>; + }; + + rpmhpd_opp_svs: opp4 { + opp-level = <RPMH_REGULATOR_LEVEL_SVS>; + }; + + rpmhpd_opp_svs_l1: opp5 { + opp-level = <RPMH_REGULATOR_LEVEL_SVS_L1>; + }; + + rpmhpd_opp_nom: opp6 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM>; + }; + + rpmhpd_opp_nom_l1: opp7 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L1>; + }; + + rpmhpd_opp_nom_l2: opp8 { + opp-level = <RPMH_REGULATOR_LEVEL_NOM_L2>; + }; + + rpmhpd_opp_turbo: opp9 { + opp-level = <RPMH_REGULATOR_LEVEL_TURBO>; + }; + + rpmhpd_opp_turbo_l1: opp10 { + opp-level = <RPMH_REGULATOR_LEVEL_TURBO_L1>; + }; + }; + }; + }; + + intc: interrupt-controller@17a00000 { + compatible = "arm,gic-v3"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0 0x17a00000 0 0x10000>, /* GICD */ + <0 0x17a60000 0 0x100000>; /* GICR * 8 */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + + msi-controller@17a40000 { + compatible = "arm,gic-v3-its"; + msi-controller; + #msi-cells = <1>; + reg = <0 0x17a40000 0 0x20000>; + status = "disabled"; + }; + }; + + slimbam: dma-controller@17184000 { + compatible = "qcom,bam-v1.7.4", "qcom,bam-v1.7.0"; + qcom,controlled-remotely; + reg = <0 0x17184000 0 0x2a000>; + num-channels = <31>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + qcom,ee = <1>; + qcom,num-ees = <2>; + iommus = <&apps_smmu 0x1806 0x0>; + }; + + timer@17c90000 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0x20000000>; + compatible = "arm,armv7-timer-mem"; + reg = <0 0x17c90000 0 0x1000>; + + frame@17ca0000 { + frame-number = <0>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17ca0000 0x1000>, + <0x17cb0000 0x1000>; + }; + + frame@17cc0000 { + frame-number = <1>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17cc0000 0x1000>; + status = "disabled"; + }; + + frame@17cd0000 { + frame-number = <2>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17cd0000 0x1000>; + status = "disabled"; + }; + + frame@17ce0000 { + frame-number = <3>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17ce0000 0x1000>; + status = "disabled"; + }; + + frame@17cf0000 { + frame-number = <4>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17cf0000 0x1000>; + status = "disabled"; + }; + + frame@17d00000 { + frame-number = <5>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17d00000 0x1000>; + status = "disabled"; + }; + + frame@17d10000 { + frame-number = <6>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x17d10000 0x1000>; + status = "disabled"; + }; + }; + + osm_l3: interconnect@17d41000 { + compatible = "qcom,sdm845-osm-l3", "qcom,osm-l3"; + reg = <0 0x17d41000 0 0x1400>; + + clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; + clock-names = "xo", "alternate"; + + #interconnect-cells = <1>; + }; + + cpufreq_hw: cpufreq@17d43000 { + compatible = "qcom,sdm845-cpufreq-hw", "qcom,cpufreq-hw"; + reg = <0 0x17d43000 0 0x1400>, <0 0x17d45800 0 0x1400>; + reg-names = "freq-domain0", "freq-domain1"; + + interrupts-extended = <&lmh_cluster0 0>, <&lmh_cluster1 0>; + + clocks = <&rpmhcc RPMH_CXO_CLK>, <&gcc GPLL0>; + clock-names = "xo", "alternate"; + + #freq-domain-cells = <1>; + #clock-cells = <1>; + }; + + wifi: wifi@18800000 { + compatible = "qcom,wcn3990-wifi"; + status = "disabled"; + reg = <0 0x18800000 0 0x800000>; + reg-names = "membase"; + memory-region = <&wlan_msa_mem>; + clock-names = "cxo_ref_clk_pin"; + clocks = <&rpmhcc RPMH_RF_CLK2>; + interrupts = + <GIC_SPI 414 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 415 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 416 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 417 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 418 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 419 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 420 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 422 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 423 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 424 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 425 IRQ_TYPE_LEVEL_HIGH>; + iommus = <&apps_smmu 0x0040 0x1>; + }; + }; + + sound: sound { + }; + + thermal-zones { + cpu0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 1>; + + trips { + cpu0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu0_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu0_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 2>; + + trips { + cpu1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu1_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu1_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 3>; + + trips { + cpu2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu2_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu2_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu3-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 4>; + + trips { + cpu3_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu3_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu3_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu4-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 7>; + + trips { + cpu4_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu4_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu5-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 8>; + + trips { + cpu5_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu5_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu6-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 9>; + + trips { + cpu6_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu6_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + cpu7-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 10>; + + trips { + cpu7_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_alert1: trip-point1 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu7_crit: cpu-crit { + temperature = <110000>; + hysteresis = <1000>; + type = "critical"; + }; + }; + }; + + aoss0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 0>; + + trips { + aoss0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + cluster0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 5>; + + trips { + cluster0_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + cluster0_crit: cluster0_crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + cluster1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 6>; + + trips { + cluster1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + cluster1_crit: cluster1_crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + gpu-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 11>; + + trips { + gpu1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + gpu-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 12>; + + trips { + gpu2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + aoss1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 0>; + + trips { + aoss1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + q6-modem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 1>; + + trips { + q6_modem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + mem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 2>; + + trips { + mem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + wlan-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 3>; + + trips { + wlan_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + q6-hvx-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 4>; + + trips { + q6_hvx_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + camera-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 5>; + + trips { + camera_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + video-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 6>; + + trips { + video_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 7>; + + trips { + modem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; }; }; }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 1 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 2 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 3 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 0 IRQ_TYPE_LEVEL_LOW>; + }; }; diff --git a/arch/arm/dts/starqltechn-uboot.dtsi b/arch/arm/dts/starqltechn-uboot.dtsi deleted file mode 100644 index 55c6d18412ba..000000000000 --- a/arch/arm/dts/starqltechn-uboot.dtsi +++ /dev/null @@ -1,27 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * U-Boot addition to handle Samsung S9 SM-G9600 (starqltechn) pins - * - * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com - * - */ - -/ -{ - framebuffer@9D400000 { - bootph-all; - }; - soc { - bootph-all; - serial@a84000 { - bootph-all; - }; - clock-controller@100000 { - bootph-all; - }; - pinctrl@3400000 { - bootph-all; - }; - }; -}; - diff --git a/arch/arm/dts/starqltechn.dts b/arch/arm/dts/starqltechn.dts deleted file mode 100644 index 0842e19adb60..000000000000 --- a/arch/arm/dts/starqltechn.dts +++ /dev/null @@ -1,68 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Samsung S9 SM-G9600 (starqltechn) board device tree source - * - * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com - * - */ - -/dts-v1/; - -#include "sdm845.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Samsung S9 (SM-G9600)"; - compatible = "qcom,sdm845-mtp", "qcom,sdm845", "qcom,mtp"; - #address-cells = <2>; - #size-cells = <2>; - - chosen { - stdout-path = "serial0:921600n8"; - }; - - aliases { - serial0 = &uart9; - }; - - memory { - device_type = "memory"; - reg = <0 0x80000000 0 0xfe1bffff>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - framebuffer: framebuffer@9D400000 { - compatible = "simple-framebuffer"; - reg = <0 0x9D400000 0 (2960 * 1440 * 4)>;//2400000 - width = <1440>; - height = <2960>; - stride = <(1440 * 4)>; - format = "a8r8g8b8"; - }; - - soc: soc { - serial@a84000 { - status = "okay"; - }; - }; -}; - -&pm8998_resin { - status = "okay"; -}; - -&tlmm { - muic_i2c: muic-i2c-n { - pins = "GPIO_33", "GPIO_34"; - drive-strength = <0x2>; - function = "gpio"; - bias-disable; - }; -}; - -#include "starqltechn-uboot.dtsi" diff --git a/configs/qcom_defconfig b/configs/qcom_defconfig index 8bd6313d50e4..3c6bdc2071b2 100644 --- a/configs/qcom_defconfig +++ b/configs/qcom_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_POSITION_INDEPENDENT=y CONFIG_ARCH_SNAPDRAGON=y -CONFIG_DEFAULT_DEVICE_TREE="dragonboard845c" +CONFIG_DEFAULT_DEVICE_TREE="sdm845-db845c" CONFIG_SYS_LOAD_ADDR=0x0 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y
On 19/12/2023 17:04, Caleb Connolly wrote:
Import sdm845.dtsi from upstream, as well as the upstream DTS files for the db845c and Samsung starqltechn. Delete the old board files.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
arch/arm/dts/Makefile | 4 +- arch/arm/dts/dragonboard845c-uboot.dtsi | 26 - arch/arm/dts/dragonboard845c.dts | 48 - arch/arm/dts/sdm845-db845c.dts | 1190 ++++ .../arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi | 16 + arch/arm/dts/sdm845-samsung-starqltechn.dts | 624 +++ arch/arm/dts/sdm845.dtsi | 5801 +++++++++++++++++++- arch/arm/dts/starqltechn-uboot.dtsi | 27 - arch/arm/dts/starqltechn.dts | 68 - configs/qcom_defconfig | 2 +- 10 files changed, 7550 insertions(+), 256 deletions(-)
<snip>
Same as patch 19, with the commit id:
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Import the dt-bindings headers in preparation for switching to upstream DTS for MSM8916.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/arm/coresight-cti-dt.h | 37 +++++ include/dt-bindings/clock/qcom,rpmcc.h | 174 ++++++++++++++++++++++++ include/dt-bindings/interconnect/qcom,msm8916.h | 100 ++++++++++++++ include/dt-bindings/pinctrl/qcom,pmic-mpp.h | 106 +++++++++++++++ include/dt-bindings/reset/qcom,gcc-msm8916.h | 100 ++++++++++++++ include/dt-bindings/sound/apq8016-lpass.h | 9 ++ include/dt-bindings/sound/qcom,lpass.h | 46 +++++++ 7 files changed, 572 insertions(+)
diff --git a/include/dt-bindings/arm/coresight-cti-dt.h b/include/dt-bindings/arm/coresight-cti-dt.h new file mode 100644 index 000000000000..61e7bdf8ea6e --- /dev/null +++ b/include/dt-bindings/arm/coresight-cti-dt.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for the defined trigger signal + * types on CoreSight CTI. + */ + +#ifndef _DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H +#define _DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H + +#define GEN_IO 0 +#define GEN_INTREQ 1 +#define GEN_INTACK 2 +#define GEN_HALTREQ 3 +#define GEN_RESTARTREQ 4 +#define PE_EDBGREQ 5 +#define PE_DBGRESTART 6 +#define PE_CTIIRQ 7 +#define PE_PMUIRQ 8 +#define PE_DBGTRIGGER 9 +#define ETM_EXTOUT 10 +#define ETM_EXTIN 11 +#define SNK_FULL 12 +#define SNK_ACQCOMP 13 +#define SNK_FLUSHCOMP 14 +#define SNK_FLUSHIN 15 +#define SNK_TRIGIN 16 +#define STM_ASYNCOUT 17 +#define STM_TOUT_SPTE 18 +#define STM_TOUT_SW 19 +#define STM_TOUT_HETE 20 +#define STM_HWEVENT 21 +#define ELA_TSTART 22 +#define ELA_TSTOP 23 +#define ELA_DBGREQ 24 +#define CTI_TRIG_MAX 25 + +#endif /*_DT_BINDINGS_ARM_CORESIGHT_CTI_DT_H */ diff --git a/include/dt-bindings/clock/qcom,rpmcc.h b/include/dt-bindings/clock/qcom,rpmcc.h new file mode 100644 index 000000000000..46309c9953b2 --- /dev/null +++ b/include/dt-bindings/clock/qcom,rpmcc.h @@ -0,0 +1,174 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2015 Linaro Limited + */ + +#ifndef _DT_BINDINGS_CLK_MSM_RPMCC_H +#define _DT_BINDINGS_CLK_MSM_RPMCC_H + +/* RPM clocks */ +#define RPM_PXO_CLK 0 +#define RPM_PXO_A_CLK 1 +#define RPM_CXO_CLK 2 +#define RPM_CXO_A_CLK 3 +#define RPM_APPS_FABRIC_CLK 4 +#define RPM_APPS_FABRIC_A_CLK 5 +#define RPM_CFPB_CLK 6 +#define RPM_CFPB_A_CLK 7 +#define RPM_QDSS_CLK 8 +#define RPM_QDSS_A_CLK 9 +#define RPM_DAYTONA_FABRIC_CLK 10 +#define RPM_DAYTONA_FABRIC_A_CLK 11 +#define RPM_EBI1_CLK 12 +#define RPM_EBI1_A_CLK 13 +#define RPM_MM_FABRIC_CLK 14 +#define RPM_MM_FABRIC_A_CLK 15 +#define RPM_MMFPB_CLK 16 +#define RPM_MMFPB_A_CLK 17 +#define RPM_SYS_FABRIC_CLK 18 +#define RPM_SYS_FABRIC_A_CLK 19 +#define RPM_SFPB_CLK 20 +#define RPM_SFPB_A_CLK 21 +#define RPM_SMI_CLK 22 +#define RPM_SMI_A_CLK 23 +#define RPM_PLL4_CLK 24 +#define RPM_XO_D0 25 +#define RPM_XO_D1 26 +#define RPM_XO_A0 27 +#define RPM_XO_A1 28 +#define RPM_XO_A2 29 +#define RPM_NSS_FABRIC_0_CLK 30 +#define RPM_NSS_FABRIC_0_A_CLK 31 +#define RPM_NSS_FABRIC_1_CLK 32 +#define RPM_NSS_FABRIC_1_A_CLK 33 + +/* SMD RPM clocks */ +#define RPM_SMD_XO_CLK_SRC 0 +#define RPM_SMD_XO_A_CLK_SRC 1 +#define RPM_SMD_PCNOC_CLK 2 +#define RPM_SMD_PCNOC_A_CLK 3 +#define RPM_SMD_SNOC_CLK 4 +#define RPM_SMD_SNOC_A_CLK 5 +#define RPM_SMD_BIMC_CLK 6 +#define RPM_SMD_BIMC_A_CLK 7 +#define RPM_SMD_QDSS_CLK 8 +#define RPM_SMD_QDSS_A_CLK 9 +#define RPM_SMD_BB_CLK1 10 +#define RPM_SMD_BB_CLK1_A 11 +#define RPM_SMD_BB_CLK2 12 +#define RPM_SMD_BB_CLK2_A 13 +#define RPM_SMD_RF_CLK1 14 +#define RPM_SMD_RF_CLK1_A 15 +#define RPM_SMD_RF_CLK2 16 +#define RPM_SMD_RF_CLK2_A 17 +#define RPM_SMD_BB_CLK1_PIN 18 +#define RPM_SMD_BB_CLK1_A_PIN 19 +#define RPM_SMD_BB_CLK2_PIN 20 +#define RPM_SMD_BB_CLK2_A_PIN 21 +#define RPM_SMD_RF_CLK1_PIN 22 +#define RPM_SMD_RF_CLK1_A_PIN 23 +#define RPM_SMD_RF_CLK2_PIN 24 +#define RPM_SMD_RF_CLK2_A_PIN 25 +#define RPM_SMD_PNOC_CLK 26 +#define RPM_SMD_PNOC_A_CLK 27 +#define RPM_SMD_CNOC_CLK 28 +#define RPM_SMD_CNOC_A_CLK 29 +#define RPM_SMD_MMSSNOC_AHB_CLK 30 +#define RPM_SMD_MMSSNOC_AHB_A_CLK 31 +#define RPM_SMD_GFX3D_CLK_SRC 32 +#define RPM_SMD_GFX3D_A_CLK_SRC 33 +#define RPM_SMD_OCMEMGX_CLK 34 +#define RPM_SMD_OCMEMGX_A_CLK 35 +#define RPM_SMD_CXO_D0 36 +#define RPM_SMD_CXO_D0_A 37 +#define RPM_SMD_CXO_D1 38 +#define RPM_SMD_CXO_D1_A 39 +#define RPM_SMD_CXO_A0 40 +#define RPM_SMD_CXO_A0_A 41 +#define RPM_SMD_CXO_A1 42 +#define RPM_SMD_CXO_A1_A 43 +#define RPM_SMD_CXO_A2 44 +#define RPM_SMD_CXO_A2_A 45 +#define RPM_SMD_DIV_CLK1 46 +#define RPM_SMD_DIV_A_CLK1 47 +#define RPM_SMD_DIV_CLK2 48 +#define RPM_SMD_DIV_A_CLK2 49 +#define RPM_SMD_DIFF_CLK 50 +#define RPM_SMD_DIFF_A_CLK 51 +#define RPM_SMD_CXO_D0_PIN 52 +#define RPM_SMD_CXO_D0_A_PIN 53 +#define RPM_SMD_CXO_D1_PIN 54 +#define RPM_SMD_CXO_D1_A_PIN 55 +#define RPM_SMD_CXO_A0_PIN 56 +#define RPM_SMD_CXO_A0_A_PIN 57 +#define RPM_SMD_CXO_A1_PIN 58 +#define RPM_SMD_CXO_A1_A_PIN 59 +#define RPM_SMD_CXO_A2_PIN 60 +#define RPM_SMD_CXO_A2_A_PIN 61 +#define RPM_SMD_AGGR1_NOC_CLK 62 +#define RPM_SMD_AGGR1_NOC_A_CLK 63 +#define RPM_SMD_AGGR2_NOC_CLK 64 +#define RPM_SMD_AGGR2_NOC_A_CLK 65 +#define RPM_SMD_MMAXI_CLK 66 +#define RPM_SMD_MMAXI_A_CLK 67 +#define RPM_SMD_IPA_CLK 68 +#define RPM_SMD_IPA_A_CLK 69 +#define RPM_SMD_CE1_CLK 70 +#define RPM_SMD_CE1_A_CLK 71 +#define RPM_SMD_DIV_CLK3 72 +#define RPM_SMD_DIV_A_CLK3 73 +#define RPM_SMD_LN_BB_CLK 74 +#define RPM_SMD_LN_BB_A_CLK 75 +#define RPM_SMD_BIMC_GPU_CLK 76 +#define RPM_SMD_BIMC_GPU_A_CLK 77 +#define RPM_SMD_QPIC_CLK 78 +#define RPM_SMD_QPIC_CLK_A 79 +#define RPM_SMD_LN_BB_CLK1 80 +#define RPM_SMD_LN_BB_CLK1_A 81 +#define RPM_SMD_LN_BB_CLK2 82 +#define RPM_SMD_LN_BB_CLK2_A 83 +#define RPM_SMD_LN_BB_CLK3_PIN 84 +#define RPM_SMD_LN_BB_CLK3_A_PIN 85 +#define RPM_SMD_RF_CLK3 86 +#define RPM_SMD_RF_CLK3_A 87 +#define RPM_SMD_RF_CLK3_PIN 88 +#define RPM_SMD_RF_CLK3_A_PIN 89 +#define RPM_SMD_MMSSNOC_AXI_CLK 90 +#define RPM_SMD_MMSSNOC_AXI_CLK_A 91 +#define RPM_SMD_CNOC_PERIPH_CLK 92 +#define RPM_SMD_CNOC_PERIPH_A_CLK 93 +#define RPM_SMD_LN_BB_CLK3 94 +#define RPM_SMD_LN_BB_CLK3_A 95 +#define RPM_SMD_LN_BB_CLK1_PIN 96 +#define RPM_SMD_LN_BB_CLK1_A_PIN 97 +#define RPM_SMD_LN_BB_CLK2_PIN 98 +#define RPM_SMD_LN_BB_CLK2_A_PIN 99 +#define RPM_SMD_SYSMMNOC_CLK 100 +#define RPM_SMD_SYSMMNOC_A_CLK 101 +#define RPM_SMD_CE2_CLK 102 +#define RPM_SMD_CE2_A_CLK 103 +#define RPM_SMD_CE3_CLK 104 +#define RPM_SMD_CE3_A_CLK 105 +#define RPM_SMD_QUP_CLK 106 +#define RPM_SMD_QUP_A_CLK 107 +#define RPM_SMD_MMRT_CLK 108 +#define RPM_SMD_MMRT_A_CLK 109 +#define RPM_SMD_MMNRT_CLK 110 +#define RPM_SMD_MMNRT_A_CLK 111 +#define RPM_SMD_SNOC_PERIPH_CLK 112 +#define RPM_SMD_SNOC_PERIPH_A_CLK 113 +#define RPM_SMD_SNOC_LPASS_CLK 114 +#define RPM_SMD_SNOC_LPASS_A_CLK 115 +#define RPM_SMD_HWKM_CLK 116 +#define RPM_SMD_HWKM_A_CLK 117 +#define RPM_SMD_PKA_CLK 118 +#define RPM_SMD_PKA_A_CLK 119 +#define RPM_SMD_CPUSS_GNOC_CLK 120 +#define RPM_SMD_CPUSS_GNOC_A_CLK 121 +#define RPM_SMD_MSS_CFG_AHB_CLK 122 +#define RPM_SMD_MSS_CFG_AHB_A_CLK 123 +#define RPM_SMD_BIMC_FREQ_LOG 124 +#define RPM_SMD_LN_BB_CLK_PIN 125 +#define RPM_SMD_LN_BB_A_CLK_PIN 126 + +#endif diff --git a/include/dt-bindings/interconnect/qcom,msm8916.h b/include/dt-bindings/interconnect/qcom,msm8916.h new file mode 100644 index 000000000000..359a75feb198 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,msm8916.h @@ -0,0 +1,100 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Qualcomm interconnect IDs + * + * Copyright (c) 2019, Linaro Ltd. + * Author: Georgi Djakov georgi.djakov@linaro.org + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8916_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8916_H + +#define BIMC_SNOC_SLV 0 +#define MASTER_JPEG 1 +#define MASTER_MDP_PORT0 2 +#define MASTER_QDSS_BAM 3 +#define MASTER_QDSS_ETR 4 +#define MASTER_SNOC_CFG 5 +#define MASTER_VFE 6 +#define MASTER_VIDEO_P0 7 +#define SNOC_MM_INT_0 8 +#define SNOC_MM_INT_1 9 +#define SNOC_MM_INT_2 10 +#define SNOC_MM_INT_BIMC 11 +#define PCNOC_SNOC_SLV 12 +#define SLAVE_APSS 13 +#define SLAVE_CATS_128 14 +#define SLAVE_OCMEM_64 15 +#define SLAVE_IMEM 16 +#define SLAVE_QDSS_STM 17 +#define SLAVE_SRVC_SNOC 18 +#define SNOC_BIMC_0_MAS 19 +#define SNOC_BIMC_1_MAS 20 +#define SNOC_INT_0 21 +#define SNOC_INT_1 22 +#define SNOC_INT_BIMC 23 +#define SNOC_PCNOC_MAS 24 +#define SNOC_QDSS_INT 25 + +#define BIMC_SNOC_MAS 0 +#define MASTER_AMPSS_M0 1 +#define MASTER_GRAPHICS_3D 2 +#define MASTER_TCU0 3 +#define MASTER_TCU1 4 +#define SLAVE_AMPSS_L2 5 +#define SLAVE_EBI_CH0 6 +#define SNOC_BIMC_0_SLV 7 +#define SNOC_BIMC_1_SLV 8 + +#define MASTER_BLSP_1 0 +#define MASTER_DEHR 1 +#define MASTER_LPASS 2 +#define MASTER_CRYPTO_CORE0 3 +#define MASTER_SDCC_1 4 +#define MASTER_SDCC_2 5 +#define MASTER_SPDM 6 +#define MASTER_USB_HS 7 +#define PCNOC_INT_0 8 +#define PCNOC_INT_1 9 +#define PCNOC_MAS_0 10 +#define PCNOC_MAS_1 11 +#define PCNOC_SLV_0 12 +#define PCNOC_SLV_1 13 +#define PCNOC_SLV_2 14 +#define PCNOC_SLV_3 15 +#define PCNOC_SLV_4 16 +#define PCNOC_SLV_8 17 +#define PCNOC_SLV_9 18 +#define PCNOC_SNOC_MAS 19 +#define SLAVE_BIMC_CFG 20 +#define SLAVE_BLSP_1 21 +#define SLAVE_BOOT_ROM 22 +#define SLAVE_CAMERA_CFG 23 +#define SLAVE_CLK_CTL 24 +#define SLAVE_CRYPTO_0_CFG 25 +#define SLAVE_DEHR_CFG 26 +#define SLAVE_DISPLAY_CFG 27 +#define SLAVE_GRAPHICS_3D_CFG 28 +#define SLAVE_IMEM_CFG 29 +#define SLAVE_LPASS 30 +#define SLAVE_MPM 31 +#define SLAVE_MSG_RAM 32 +#define SLAVE_MSS 33 +#define SLAVE_PDM 34 +#define SLAVE_PMIC_ARB 35 +#define SLAVE_PCNOC_CFG 36 +#define SLAVE_PRNG 37 +#define SLAVE_QDSS_CFG 38 +#define SLAVE_RBCPR_CFG 39 +#define SLAVE_SDCC_1 40 +#define SLAVE_SDCC_2 41 +#define SLAVE_SECURITY 42 +#define SLAVE_SNOC_CFG 43 +#define SLAVE_SPDM 44 +#define SLAVE_TCSR 45 +#define SLAVE_TLMM 46 +#define SLAVE_USB_HS 47 +#define SLAVE_VENUS_CFG 48 +#define SNOC_PCNOC_SLV 49 + +#endif diff --git a/include/dt-bindings/pinctrl/qcom,pmic-mpp.h b/include/dt-bindings/pinctrl/qcom,pmic-mpp.h new file mode 100644 index 000000000000..32e66ee7e830 --- /dev/null +++ b/include/dt-bindings/pinctrl/qcom,pmic-mpp.h @@ -0,0 +1,106 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for the Qualcomm PMIC's + * Multi-Purpose Pin binding. + */ + +#ifndef _DT_BINDINGS_PINCTRL_QCOM_PMIC_MPP_H +#define _DT_BINDINGS_PINCTRL_QCOM_PMIC_MPP_H + +/* power-source */ + +/* Digital Input/Output: level [PM8058] */ +#define PM8058_MPP_VPH 0 +#define PM8058_MPP_S3 1 +#define PM8058_MPP_L2 2 +#define PM8058_MPP_L3 3 + +/* Digital Input/Output: level [PM8901] */ +#define PM8901_MPP_MSMIO 0 +#define PM8901_MPP_DIG 1 +#define PM8901_MPP_L5 2 +#define PM8901_MPP_S4 3 +#define PM8901_MPP_VPH 4 + +/* Digital Input/Output: level [PM8921] */ +#define PM8921_MPP_S4 1 +#define PM8921_MPP_L15 3 +#define PM8921_MPP_L17 4 +#define PM8921_MPP_VPH 7 + +/* Digital Input/Output: level [PM8821] */ +#define PM8821_MPP_1P8 0 +#define PM8821_MPP_VPH 7 + +/* Digital Input/Output: level [PM8018] */ +#define PM8018_MPP_L4 0 +#define PM8018_MPP_L14 1 +#define PM8018_MPP_S3 2 +#define PM8018_MPP_L6 3 +#define PM8018_MPP_L2 4 +#define PM8018_MPP_L5 5 +#define PM8018_MPP_VPH 7 + +/* Digital Input/Output: level [PM8038] */ +#define PM8038_MPP_L20 0 +#define PM8038_MPP_L11 1 +#define PM8038_MPP_L5 2 +#define PM8038_MPP_L15 3 +#define PM8038_MPP_L17 4 +#define PM8038_MPP_VPH 7 + +#define PM8841_MPP_VPH 0 +#define PM8841_MPP_S3 2 + +#define PM8916_MPP_VPH 0 +#define PM8916_MPP_L2 2 +#define PM8916_MPP_L5 3 + +#define PM8941_MPP_VPH 0 +#define PM8941_MPP_L1 1 +#define PM8941_MPP_S3 2 +#define PM8941_MPP_L6 3 + +#define PMA8084_MPP_VPH 0 +#define PMA8084_MPP_L1 1 +#define PMA8084_MPP_S4 2 +#define PMA8084_MPP_L6 3 + +#define PM8994_MPP_VPH 0 +/* Only supported for MPP_05-MPP_08 */ +#define PM8994_MPP_L19 1 +#define PM8994_MPP_S4 2 +#define PM8994_MPP_L12 3 + +/* + * Analog Input - Set the source for analog input. + * To be used with "qcom,amux-route" property + */ +#define PMIC_MPP_AMUX_ROUTE_CH5 0 +#define PMIC_MPP_AMUX_ROUTE_CH6 1 +#define PMIC_MPP_AMUX_ROUTE_CH7 2 +#define PMIC_MPP_AMUX_ROUTE_CH8 3 +#define PMIC_MPP_AMUX_ROUTE_ABUS1 4 +#define PMIC_MPP_AMUX_ROUTE_ABUS2 5 +#define PMIC_MPP_AMUX_ROUTE_ABUS3 6 +#define PMIC_MPP_AMUX_ROUTE_ABUS4 7 + +/* Analog Output: level */ +#define PMIC_MPP_AOUT_LVL_1V25 0 +#define PMIC_MPP_AOUT_LVL_1V25_2 1 +#define PMIC_MPP_AOUT_LVL_0V625 2 +#define PMIC_MPP_AOUT_LVL_0V3125 3 +#define PMIC_MPP_AOUT_LVL_MPP 4 +#define PMIC_MPP_AOUT_LVL_ABUS1 5 +#define PMIC_MPP_AOUT_LVL_ABUS2 6 +#define PMIC_MPP_AOUT_LVL_ABUS3 7 + +/* To be used with "function" */ +#define PMIC_MPP_FUNC_NORMAL "normal" +#define PMIC_MPP_FUNC_PAIRED "paired" +#define PMIC_MPP_FUNC_DTEST1 "dtest1" +#define PMIC_MPP_FUNC_DTEST2 "dtest2" +#define PMIC_MPP_FUNC_DTEST3 "dtest3" +#define PMIC_MPP_FUNC_DTEST4 "dtest4" + +#endif diff --git a/include/dt-bindings/reset/qcom,gcc-msm8916.h b/include/dt-bindings/reset/qcom,gcc-msm8916.h new file mode 100644 index 000000000000..1f9be10872df --- /dev/null +++ b/include/dt-bindings/reset/qcom,gcc-msm8916.h @@ -0,0 +1,100 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2015 Linaro Limited + */ + +#ifndef _DT_BINDINGS_RESET_MSM_GCC_8916_H +#define _DT_BINDINGS_RESET_MSM_GCC_8916_H + +#define GCC_BLSP1_BCR 0 +#define GCC_BLSP1_QUP1_BCR 1 +#define GCC_BLSP1_UART1_BCR 2 +#define GCC_BLSP1_QUP2_BCR 3 +#define GCC_BLSP1_UART2_BCR 4 +#define GCC_BLSP1_QUP3_BCR 5 +#define GCC_BLSP1_QUP4_BCR 6 +#define GCC_BLSP1_QUP5_BCR 7 +#define GCC_BLSP1_QUP6_BCR 8 +#define GCC_IMEM_BCR 9 +#define GCC_SMMU_BCR 10 +#define GCC_APSS_TCU_BCR 11 +#define GCC_SMMU_XPU_BCR 12 +#define GCC_PCNOC_TBU_BCR 13 +#define GCC_PRNG_BCR 14 +#define GCC_BOOT_ROM_BCR 15 +#define GCC_CRYPTO_BCR 16 +#define GCC_SEC_CTRL_BCR 17 +#define GCC_AUDIO_CORE_BCR 18 +#define GCC_ULT_AUDIO_BCR 19 +#define GCC_DEHR_BCR 20 +#define GCC_SYSTEM_NOC_BCR 21 +#define GCC_PCNOC_BCR 22 +#define GCC_TCSR_BCR 23 +#define GCC_QDSS_BCR 24 +#define GCC_DCD_BCR 25 +#define GCC_MSG_RAM_BCR 26 +#define GCC_MPM_BCR 27 +#define GCC_SPMI_BCR 28 +#define GCC_SPDM_BCR 29 +#define GCC_MM_SPDM_BCR 30 +#define GCC_BIMC_BCR 31 +#define GCC_RBCPR_BCR 32 +#define GCC_TLMM_BCR 33 +#define GCC_USB_HS_BCR 34 +#define GCC_USB2A_PHY_BCR 35 +#define GCC_SDCC1_BCR 36 +#define GCC_SDCC2_BCR 37 +#define GCC_PDM_BCR 38 +#define GCC_SNOC_BUS_TIMEOUT0_BCR 39 +#define GCC_PCNOC_BUS_TIMEOUT0_BCR 40 +#define GCC_PCNOC_BUS_TIMEOUT1_BCR 41 +#define GCC_PCNOC_BUS_TIMEOUT2_BCR 42 +#define GCC_PCNOC_BUS_TIMEOUT3_BCR 43 +#define GCC_PCNOC_BUS_TIMEOUT4_BCR 44 +#define GCC_PCNOC_BUS_TIMEOUT5_BCR 45 +#define GCC_PCNOC_BUS_TIMEOUT6_BCR 46 +#define GCC_PCNOC_BUS_TIMEOUT7_BCR 47 +#define GCC_PCNOC_BUS_TIMEOUT8_BCR 48 +#define GCC_PCNOC_BUS_TIMEOUT9_BCR 49 +#define GCC_MMSS_BCR 50 +#define GCC_VENUS0_BCR 51 +#define GCC_MDSS_BCR 52 +#define GCC_CAMSS_PHY0_BCR 53 +#define GCC_CAMSS_CSI0_BCR 54 +#define GCC_CAMSS_CSI0PHY_BCR 55 +#define GCC_CAMSS_CSI0RDI_BCR 56 +#define GCC_CAMSS_CSI0PIX_BCR 57 +#define GCC_CAMSS_PHY1_BCR 58 +#define GCC_CAMSS_CSI1_BCR 59 +#define GCC_CAMSS_CSI1PHY_BCR 60 +#define GCC_CAMSS_CSI1RDI_BCR 61 +#define GCC_CAMSS_CSI1PIX_BCR 62 +#define GCC_CAMSS_ISPIF_BCR 63 +#define GCC_CAMSS_CCI_BCR 64 +#define GCC_CAMSS_MCLK0_BCR 65 +#define GCC_CAMSS_MCLK1_BCR 66 +#define GCC_CAMSS_GP0_BCR 67 +#define GCC_CAMSS_GP1_BCR 68 +#define GCC_CAMSS_TOP_BCR 69 +#define GCC_CAMSS_MICRO_BCR 70 +#define GCC_CAMSS_JPEG_BCR 71 +#define GCC_CAMSS_VFE_BCR 72 +#define GCC_CAMSS_CSI_VFE0_BCR 73 +#define GCC_OXILI_BCR 74 +#define GCC_GMEM_BCR 75 +#define GCC_CAMSS_AHB_BCR 76 +#define GCC_MDP_TBU_BCR 77 +#define GCC_GFX_TBU_BCR 78 +#define GCC_GFX_TCU_BCR 79 +#define GCC_MSS_TBU_AXI_BCR 80 +#define GCC_MSS_TBU_GSS_AXI_BCR 81 +#define GCC_MSS_TBU_Q6_AXI_BCR 82 +#define GCC_GTCU_AHB_BCR 83 +#define GCC_SMMU_CFG_BCR 84 +#define GCC_VFE_TBU_BCR 85 +#define GCC_VENUS_TBU_BCR 86 +#define GCC_JPEG_TBU_BCR 87 +#define GCC_PRONTO_TBU_BCR 88 +#define GCC_SMMU_CATS_BCR 89 + +#endif diff --git a/include/dt-bindings/sound/apq8016-lpass.h b/include/dt-bindings/sound/apq8016-lpass.h new file mode 100644 index 000000000000..dc605c4bc224 --- /dev/null +++ b/include/dt-bindings/sound/apq8016-lpass.h @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_APQ8016_LPASS_H +#define __DT_APQ8016_LPASS_H + +#include <dt-bindings/sound/qcom,lpass.h> + +/* NOTE: Use qcom,lpass.h to define any AIF ID's for LPASS */ + +#endif /* __DT_APQ8016_LPASS_H */ diff --git a/include/dt-bindings/sound/qcom,lpass.h b/include/dt-bindings/sound/qcom,lpass.h new file mode 100644 index 000000000000..a9404c3b8884 --- /dev/null +++ b/include/dt-bindings/sound/qcom,lpass.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef __DT_QCOM_LPASS_H +#define __DT_QCOM_LPASS_H + +#define MI2S_PRIMARY 0 +#define MI2S_SECONDARY 1 +#define MI2S_TERTIARY 2 +#define MI2S_QUATERNARY 3 +#define MI2S_QUINARY 4 + +#define LPASS_DP_RX 5 + +#define LPASS_CDC_DMA_RX0 6 +#define LPASS_CDC_DMA_RX1 7 +#define LPASS_CDC_DMA_RX2 8 +#define LPASS_CDC_DMA_RX3 9 +#define LPASS_CDC_DMA_RX4 10 +#define LPASS_CDC_DMA_RX5 11 +#define LPASS_CDC_DMA_RX6 12 +#define LPASS_CDC_DMA_RX7 13 +#define LPASS_CDC_DMA_RX8 14 +#define LPASS_CDC_DMA_RX9 15 + +#define LPASS_CDC_DMA_TX0 16 +#define LPASS_CDC_DMA_TX1 17 +#define LPASS_CDC_DMA_TX2 18 +#define LPASS_CDC_DMA_TX3 19 +#define LPASS_CDC_DMA_TX4 20 +#define LPASS_CDC_DMA_TX5 21 +#define LPASS_CDC_DMA_TX6 22 +#define LPASS_CDC_DMA_TX7 23 +#define LPASS_CDC_DMA_TX8 24 + +#define LPASS_CDC_DMA_VA_TX0 25 +#define LPASS_CDC_DMA_VA_TX1 26 +#define LPASS_CDC_DMA_VA_TX2 27 +#define LPASS_CDC_DMA_VA_TX3 28 +#define LPASS_CDC_DMA_VA_TX4 29 +#define LPASS_CDC_DMA_VA_TX5 30 +#define LPASS_CDC_DMA_VA_TX6 31 +#define LPASS_CDC_DMA_VA_TX7 32 +#define LPASS_CDC_DMA_VA_TX8 33 + +#define LPASS_MCLK0 0 + +#endif /* __DT_QCOM_LPASS_H */
<snip> Same as patch 19, with the commit id:
Import the supporting pm8916.dtsi and msm8916-pm8916.dtsi files from upstream in preparation for switching boards over.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/msm8916-pm8916.dtsi | 157 ++++++++++++++++++++++++++++++++++ arch/arm/dts/pm8916.dtsi | 178 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 335 insertions(+)
diff --git a/arch/arm/dts/msm8916-pm8916.dtsi b/arch/arm/dts/msm8916-pm8916.dtsi new file mode 100644 index 000000000000..b1a7eafbee31 --- /dev/null +++ b/arch/arm/dts/msm8916-pm8916.dtsi @@ -0,0 +1,157 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * msm8916-pm8916.dtsi describes common properties (e.g. regulator connections) + * that apply to most devices that make use of the MSM8916 SoC and PM8916 PMIC. + * Many regulators have a fixed purpose in the original reference design and + * were rarely re-used for different purposes. Devices that deviate from the + * typical reference design should not make use of this include and instead add + * the necessary properties in the board-specific device tree. + */ + +#include "msm8916.dtsi" +#include "pm8916.dtsi" + +&camss { + vdda-supply = <&pm8916_l2>; +}; + +&mdss_dsi0 { + vdda-supply = <&pm8916_l2>; + vddio-supply = <&pm8916_l6>; +}; + +&mdss_dsi0_phy { + vddio-supply = <&pm8916_l6>; +}; + +&mpss { + pll-supply = <&pm8916_l7>; +}; + +&pm8916_codec { + vdd-cdc-io-supply = <&pm8916_l5>; + vdd-cdc-tx-rx-cx-supply = <&pm8916_l5>; + vdd-micbias-supply = <&pm8916_l13>; +}; + +&sdhc_1 { + vmmc-supply = <&pm8916_l8>; + vqmmc-supply = <&pm8916_l5>; +}; + +&sdhc_2 { + vmmc-supply = <&pm8916_l11>; + vqmmc-supply = <&pm8916_l12>; +}; + +&usb_hs_phy { + v1p8-supply = <&pm8916_l7>; + v3p3-supply = <&pm8916_l13>; +}; + +&wcnss { + vddpx-supply = <&pm8916_l7>; +}; + +&wcnss_iris { + vddxo-supply = <&pm8916_l7>; + vddrfa-supply = <&pm8916_s3>; + vddpa-supply = <&pm8916_l9>; + vdddig-supply = <&pm8916_l5>; +}; + +&rpm_requests { + pm8916_rpm_regulators: regulators { + compatible = "qcom,rpm-pm8916-regulators"; + vdd_l1_l2_l3-supply = <&pm8916_s3>; + vdd_l4_l5_l6-supply = <&pm8916_s4>; + vdd_l7-supply = <&pm8916_s4>; + + /* pm8916_s1 is managed by rpmpd (MSM8916_VDDCX) */ + + pm8916_s3: s3 { + regulator-min-microvolt = <1250000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; /* Needed for L2 */ + }; + + pm8916_s4: s4 { + regulator-min-microvolt = <1850000>; + regulator-max-microvolt = <2150000>; + regulator-always-on; /* Needed for L5/L7 */ + }; + + /* + * Some of the regulators are unused or managed by another + * processor (e.g. the modem). We should still define nodes for + * them to ensure the vote from the application processor can be + * dropped in case the regulators are already on during boot. + * + * The labels for these nodes are omitted on purpose because + * boards should configure a proper voltage before using them. + */ + l1 {}; + + pm8916_l2: l2 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; /* Needed for LPDDR RAM */ + }; + + /* pm8916_l3 is managed by rpmpd (MSM8916_VDDMX) */ + + l4 {}; + + pm8916_l5: l5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; /* Needed for most digital I/O */ + }; + + pm8916_l6: l6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + pm8916_l7: l7 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; /* Needed for CPU PLL */ + }; + + pm8916_l8: l8 { + regulator-min-microvolt = <2900000>; + regulator-max-microvolt = <2900000>; + }; + + pm8916_l9: l9 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + l10 {}; + + pm8916_l11: l11 { + regulator-min-microvolt = <2950000>; + regulator-max-microvolt = <2950000>; + regulator-allow-set-load; + regulator-system-load = <200000>; + }; + + pm8916_l12: l12 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2950000>; + }; + + pm8916_l13: l13 { + regulator-min-microvolt = <3075000>; + regulator-max-microvolt = <3075000>; + }; + + l14 {}; + l15 {}; + l16 {}; + l17 {}; + l18 {}; + }; +}; diff --git a/arch/arm/dts/pm8916.dtsi b/arch/arm/dts/pm8916.dtsi new file mode 100644 index 000000000000..f4de86787743 --- /dev/null +++ b/arch/arm/dts/pm8916.dtsi @@ -0,0 +1,178 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/iio/qcom,spmi-vadc.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> + +&spmi_bus { + + pm8916_0: pmic@0 { + compatible = "qcom,pm8916", "qcom,spmi-pmic"; + reg = <0x0 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pon@800 { + compatible = "qcom,pm8916-pon"; + reg = <0x800>; + mode-bootloader = <0x2>; + mode-recovery = <0x1>; + + pwrkey { + compatible = "qcom,pm8941-pwrkey"; + interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + linux,code = <KEY_POWER>; + }; + + pm8916_resin: resin { + compatible = "qcom,pm8941-resin"; + interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + status = "disabled"; + }; + + watchdog { + compatible = "qcom,pm8916-wdt"; + interrupts = <0x0 0x8 6 IRQ_TYPE_EDGE_RISING>; + timeout-sec = <60>; + }; + }; + + pm8916_usbin: usb-detect@1300 { + compatible = "qcom,pm8941-misc"; + reg = <0x1300>; + interrupts = <0x0 0x13 1 IRQ_TYPE_EDGE_BOTH>; + interrupt-names = "usb_vbus"; + status = "disabled"; + }; + + pm8916_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0 0x24 0 IRQ_TYPE_EDGE_RISING>; + io-channels = <&pm8916_vadc VADC_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pm8916_vadc: adc@3100 { + compatible = "qcom,spmi-vadc"; + reg = <0x3100>; + interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + + channel@0 { + reg = <VADC_USBIN>; + qcom,pre-scaling = <1 10>; + }; + channel@7 { + reg = <VADC_VSYS>; + qcom,pre-scaling = <1 3>; + }; + channel@8 { + reg = <VADC_DIE_TEMP>; + }; + channel@9 { + reg = <VADC_REF_625MV>; + }; + channel@a { + reg = <VADC_REF_1250MV>; + }; + channel@e { + reg = <VADC_GND_REF>; + }; + channel@f { + reg = <VADC_VDD_VADC>; + }; + }; + + rtc@6000 { + compatible = "qcom,pm8941-rtc"; + reg = <0x6000>, <0x6100>; + reg-names = "rtc", "alarm"; + interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; + }; + + pm8916_mpps: mpps@a000 { + compatible = "qcom,pm8916-mpp", "qcom,spmi-mpp"; + reg = <0xa000>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&pm8916_mpps 0 0 4>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pm8916_gpios: gpio@c000 { + compatible = "qcom,pm8916-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pm8916_gpios 0 0 4>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + pm8916_1: pmic@1 { + compatible = "qcom,pm8916", "qcom,spmi-pmic"; + reg = <0x1 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pm8916_pwm: pwm { + compatible = "qcom,pm8916-pwm"; + + #pwm-cells = <2>; + + status = "disabled"; + }; + + pm8916_vib: vibrator@c000 { + compatible = "qcom,pm8916-vib"; + reg = <0xc000>; + status = "disabled"; + }; + + pm8916_codec: audio-codec@f000 { + compatible = "qcom,pm8916-wcd-analog-codec"; + reg = <0xf000>; + interrupt-parent = <&spmi_bus>; + interrupts = <0x1 0xf0 0x0 IRQ_TYPE_NONE>, + <0x1 0xf0 0x1 IRQ_TYPE_NONE>, + <0x1 0xf0 0x2 IRQ_TYPE_NONE>, + <0x1 0xf0 0x3 IRQ_TYPE_NONE>, + <0x1 0xf0 0x4 IRQ_TYPE_NONE>, + <0x1 0xf0 0x5 IRQ_TYPE_NONE>, + <0x1 0xf0 0x6 IRQ_TYPE_NONE>, + <0x1 0xf0 0x7 IRQ_TYPE_NONE>, + <0x1 0xf1 0x0 IRQ_TYPE_NONE>, + <0x1 0xf1 0x1 IRQ_TYPE_NONE>, + <0x1 0xf1 0x2 IRQ_TYPE_NONE>, + <0x1 0xf1 0x3 IRQ_TYPE_NONE>, + <0x1 0xf1 0x4 IRQ_TYPE_NONE>, + <0x1 0xf1 0x5 IRQ_TYPE_NONE>; + interrupt-names = "cdc_spk_cnp_int", + "cdc_spk_clip_int", + "cdc_spk_ocp_int", + "mbhc_ins_rem_det1", + "mbhc_but_rel_det", + "mbhc_but_press_det", + "mbhc_ins_rem_det", + "mbhc_switch_int", + "cdc_ear_ocp_int", + "cdc_hphr_ocp_int", + "cdc_hphl_ocp_det", + "cdc_ear_cnp_int", + "cdc_hphr_cnp_int", + "cdc_hphl_cnp_int"; + #sound-dai-cells = <1>; + status = "disabled"; + }; + }; +};
Drop the U-Boot specific dragonboard410c.dts in favour of the upstream msm8916-sbc.dts. No additional changes are needed to this DTS for U-Boot support.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/Makefile | 2 +- arch/arm/dts/apq8016-sbc.dts | 729 +++++++++ arch/arm/dts/dragonboard410c-uboot.dtsi | 44 - arch/arm/dts/dragonboard410c.dts | 209 +-- arch/arm/dts/msm8916.dtsi | 2702 +++++++++++++++++++++++++++++++ configs/dragonboard410c_defconfig | 2 +- 6 files changed, 3472 insertions(+), 216 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 00d1ce34b7aa..836113eb66e4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -600,7 +600,7 @@ dtb-$(CONFIG_TARGET_SL28) += fsl-ls1028a-kontron-sl28.dtb \
dtb-$(CONFIG_TARGET_TEN64) += fsl-ls1088a-ten64.dtb
-dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb \ +dtb-$(CONFIG_ARCH_SNAPDRAGON) += apq8016-sbc.dtb \ dragonboard820c.dtb \ sdm845-db845c.dtb \ sdm845-samsung-starqltechn.dtb \ diff --git a/arch/arm/dts/apq8016-sbc.dts b/arch/arm/dts/apq8016-sbc.dts new file mode 100644 index 000000000000..9ffad7d1f2b6 --- /dev/null +++ b/arch/arm/dts/apq8016-sbc.dts @@ -0,0 +1,729 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (c) 2015, The Linux Foundation. All rights reserved. + */ + +/dts-v1/; + +#include "msm8916-pm8916.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> +#include <dt-bindings/pinctrl/qcom,pmic-mpp.h> +#include <dt-bindings/sound/apq8016-lpass.h> + +/ { + model = "Qualcomm Technologies, Inc. APQ 8016 SBC"; + compatible = "qcom,apq8016-sbc", "qcom,apq8016"; + + aliases { + mmc0 = &sdhc_1; /* eMMC */ + mmc1 = &sdhc_2; /* SD card */ + serial0 = &blsp_uart2; + serial1 = &blsp_uart1; + usid0 = &pm8916_0; + i2c0 = &blsp_i2c2; + i2c1 = &blsp_i2c6; + i2c3 = &blsp_i2c4; + spi0 = &blsp_spi5; + spi1 = &blsp_spi3; + }; + + chosen { + stdout-path = "serial0"; + }; + + reserved-memory { + ramoops@bff00000 { + compatible = "ramoops"; + reg = <0x0 0xbff00000 0x0 0x100000>; + + record-size = <0x20000>; + console-size = <0x20000>; + ftrace-size = <0x20000>; + }; + }; + + usb2513 { + compatible = "smsc,usb3503"; + reset-gpios = <&pm8916_gpios 3 GPIO_ACTIVE_LOW>; + initial-mode = <1>; + }; + + usb_id: usb-id { + compatible = "linux,extcon-usb-gpio"; + id-gpios = <&tlmm 121 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_id_default>; + }; + + hdmi-out { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con: endpoint { + remote-endpoint = <&adv7533_out>; + }; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + pinctrl-names = "default"; + pinctrl-0 = <&msm_key_volp_n_default>; + + button { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + gpios = <&tlmm 107 GPIO_ACTIVE_LOW>; + }; + }; + + leds { + pinctrl-names = "default"; + pinctrl-0 = <&tlmm_leds>, + <&pm8916_gpios_leds>, + <&pm8916_mpps_leds>; + + compatible = "gpio-leds"; + + led@1 { + label = "apq8016-sbc:green:user1"; + function = LED_FUNCTION_HEARTBEAT; + color = <LED_COLOR_ID_GREEN>; + gpios = <&tlmm 21 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led@2 { + label = "apq8016-sbc:green:user2"; + function = LED_FUNCTION_DISK_ACTIVITY; + color = <LED_COLOR_ID_GREEN>; + gpios = <&tlmm 120 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led@3 { + label = "apq8016-sbc:green:user3"; + function = LED_FUNCTION_DISK_ACTIVITY; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pm8916_gpios 1 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + default-state = "off"; + }; + + led@4 { + label = "apq8016-sbc:green:user4"; + color = <LED_COLOR_ID_GREEN>; + gpios = <&pm8916_gpios 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "none"; + panic-indicator; + default-state = "off"; + }; + + led@5 { + label = "apq8016-sbc:yellow:wlan"; + function = LED_FUNCTION_WLAN; + color = <LED_COLOR_ID_YELLOW>; + gpios = <&pm8916_mpps 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "phy0tx"; + default-state = "off"; + }; + + led@6 { + label = "apq8016-sbc:blue:bt"; + function = LED_FUNCTION_BLUETOOTH; + color = <LED_COLOR_ID_BLUE>; + gpios = <&pm8916_mpps 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "bluetooth-power"; + default-state = "off"; + }; + }; +}; + +&blsp_i2c2 { + /* On Low speed expansion: LS-I2C0 */ + status = "okay"; +}; + +&blsp_i2c4 { + /* On High speed expansion: HS-I2C2 */ + status = "okay"; + + adv_bridge: bridge@39 { + status = "okay"; + + compatible = "adi,adv7533"; + reg = <0x39>; + + interrupt-parent = <&tlmm>; + interrupts = <31 IRQ_TYPE_EDGE_FALLING>; + + adi,dsi-lanes = <4>; + clocks = <&rpmcc RPM_SMD_BB_CLK2>; + clock-names = "cec"; + + pd-gpios = <&tlmm 32 GPIO_ACTIVE_HIGH>; + + avdd-supply = <&pm8916_l6>; + a2vdd-supply = <&pm8916_l6>; + dvdd-supply = <&pm8916_l6>; + pvdd-supply = <&pm8916_l6>; + v1p2-supply = <&pm8916_l6>; + v3p3-supply = <&pm8916_l17>; + + pinctrl-names = "default","sleep"; + pinctrl-0 = <&adv7533_int_active &adv7533_switch_active>; + pinctrl-1 = <&adv7533_int_suspend &adv7533_switch_suspend>; + #sound-dai-cells = <1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + adv7533_in: endpoint { + remote-endpoint = <&mdss_dsi0_out>; + }; + }; + + port@1 { + reg = <1>; + adv7533_out: endpoint { + remote-endpoint = <&hdmi_con>; + }; + }; + }; + }; +}; + +&blsp_i2c6 { + /* On Low speed expansion: LS-I2C1 */ + status = "okay"; +}; + +&blsp_spi3 { + /* On High speed expansion: HS-SPI1 */ + status = "okay"; +}; + +&blsp_spi5 { + /* On Low speed expansion: LS-SPI0 */ + status = "okay"; +}; + +&blsp_uart1 { + status = "okay"; + label = "LS-UART0"; +}; + +&blsp_uart2 { + status = "okay"; + label = "LS-UART1"; +}; + +&camss { + status = "okay"; +}; + +&gpu { + status = "okay"; +}; + +&lpass { + status = "okay"; +}; + +&lpass_codec { + status = "okay"; +}; + +&mba_mem { + status = "okay"; +}; + +&mdss { + status = "okay"; +}; + +&mdss_dsi0_out { + data-lanes = <0 1 2 3>; + remote-endpoint = <&adv7533_in>; +}; + +&mpss { + status = "okay"; + + firmware-name = "qcom/apq8016/mba.mbn", "qcom/apq8016/modem.mbn"; +}; + +&mpss_mem { + status = "okay"; + reg = <0x0 0x86800000 0x0 0x2b00000>; +}; + +&pm8916_codec { + status = "okay"; + qcom,mbhc-vthreshold-low = <75 150 237 450 500>; + qcom,mbhc-vthreshold-high = <75 150 237 450 500>; +}; + +&pm8916_resin { + status = "okay"; + linux,code = <KEY_VOLUMEDOWN>; +}; + +&pm8916_rpm_regulators { + /* + * The 96Boards specification expects a 1.8V power rail on the low-speed + * expansion connector that is able to provide at least 0.18W / 100 mA. + * L15/L16 are connected in parallel to provide 55 mA each. A minimum load + * must be specified to ensure the regulators are not put in LPM where they + * would only provide 5 mA. + */ + pm8916_l15: l15 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-system-load = <50000>; + regulator-allow-set-load; + regulator-always-on; + }; + pm8916_l16: l16 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-system-load = <50000>; + regulator-allow-set-load; + regulator-always-on; + }; + + pm8916_l17: l17 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&sdhc_1 { + status = "okay"; +}; + +&sdhc_2 { + status = "okay"; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc2_default &sdc2_cd_default>; + pinctrl-1 = <&sdc2_sleep &sdc2_cd_default>; + + cd-gpios = <&tlmm 38 GPIO_ACTIVE_LOW>; +}; + +&sound { + status = "okay"; + + pinctrl-0 = <&cdc_pdm_default &sec_mi2s_default>; + pinctrl-1 = <&cdc_pdm_sleep &sec_mi2s_sleep>; + pinctrl-names = "default", "sleep"; + model = "DB410c"; + audio-routing = + "AMIC2", "MIC BIAS Internal2", + "AMIC3", "MIC BIAS External1"; + + quaternary-dai-link { + link-name = "ADV7533"; + cpu { + sound-dai = <&lpass MI2S_QUATERNARY>; + }; + codec { + sound-dai = <&adv_bridge 0>; + }; + }; + + primary-dai-link { + link-name = "WCD"; + cpu { + sound-dai = <&lpass MI2S_PRIMARY>; + }; + codec { + sound-dai = <&lpass_codec 0>, <&pm8916_codec 0>; + }; + }; + + tertiary-dai-link { + link-name = "WCD-Capture"; + cpu { + sound-dai = <&lpass MI2S_TERTIARY>; + }; + codec { + sound-dai = <&lpass_codec 1>, <&pm8916_codec 1>; + }; + }; +}; + +&usb { + status = "okay"; + extcon = <&usb_id>, <&usb_id>; + + pinctrl-names = "default", "device"; + pinctrl-0 = <&usb_sw_sel_pm &usb_hub_reset_pm>; + pinctrl-1 = <&usb_sw_sel_pm_device &usb_hub_reset_pm_device>; +}; + +&usb_hs_phy { + extcon = <&usb_id>; +}; + +&venus { + status = "okay"; +}; + +&venus_mem { + status = "okay"; +}; + +&wcnss { + status = "okay"; + firmware-name = "qcom/apq8016/wcnss.mbn"; +}; + +&wcnss_ctrl { + firmware-name = "qcom/apq8016/WCNSS_qcom_wlan_nv_sbc.bin"; +}; + +&wcnss_iris { + compatible = "qcom,wcn3620"; +}; + +&wcnss_mem { + status = "okay"; +}; + +/* Enable CoreSight */ +&cti0 { status = "okay"; }; +&cti1 { status = "okay"; }; +&cti12 { status = "okay"; }; +&cti13 { status = "okay"; }; +&cti14 { status = "okay"; }; +&cti15 { status = "okay"; }; +&debug0 { status = "okay"; }; +&debug1 { status = "okay"; }; +&debug2 { status = "okay"; }; +&debug3 { status = "okay"; }; +&etf { status = "okay"; }; +&etm0 { status = "okay"; }; +&etm1 { status = "okay"; }; +&etm2 { status = "okay"; }; +&etm3 { status = "okay"; }; +&etr { status = "okay"; }; +&funnel0 { status = "okay"; }; +&funnel1 { status = "okay"; }; +&replicator { status = "okay"; }; +&stm { status = "okay"; }; +&tpiu { status = "okay"; }; + +/* + * 2mA drive strength is not enough when connecting multiple + * I2C devices with different pull up resistors. + */ +&blsp_i2c2_default { + drive-strength = <16>; +}; + +&blsp_i2c4_default { + drive-strength = <16>; +}; + +&blsp_i2c6_default { + drive-strength = <16>; +}; + +/* + * GPIO name legend: proper name = the GPIO line is used as GPIO + * NC = not connected (pin out but not routed from the chip to + * anything the board) + * "[PER]" = pin is muxed for [peripheral] (not GPIO) + * LSEC = Low Speed External Connector + * HSEC = High Speed External Connector + * + * Line names are taken from the schematic "DragonBoard410c" + * dated monday, august 31, 2015. Page 5 in particular. + * + * For the lines routed to the external connectors the + * lines are named after the 96Boards CE Specification 1.0, + * Appendix "Expansion Connector Signal Description". + * + * When the 96Board naming of a line and the schematic name of + * the same line are in conflict, the 96Board specification + * takes precedence, which means that the external UART on the + * LSEC is named UART0 while the schematic and SoC names this + * UART3. This is only for the informational lines i.e. "[FOO]", + * the GPIO named lines "GPIO-A" thru "GPIO-L" are the only + * ones actually used for GPIO. + */ + +&tlmm { + gpio-line-names = + "[UART0_TX]", /* GPIO_0, LSEC pin 5 */ + "[UART0_RX]", /* GPIO_1, LSEC pin 7 */ + "[UART0_CTS_N]", /* GPIO_2, LSEC pin 3 */ + "[UART0_RTS_N]", /* GPIO_3, LSEC pin 9 */ + "[UART1_TX]", /* GPIO_4, LSEC pin 11 */ + "[UART1_RX]", /* GPIO_5, LSEC pin 13 */ + "[I2C0_SDA]", /* GPIO_8, LSEC pin 17 */ + "[I2C0_SCL]", /* GPIO_7, LSEC pin 15 */ + "[SPI1_DOUT]", /* SPI1_MOSI, HSEC pin 1 */ + "[SPI1_DIN]", /* SPI1_MISO, HSEC pin 11 */ + "[SPI1_CS]", /* SPI1_CS_N, HSEC pin 7 */ + "[SPI1_SCLK]", /* SPI1_CLK, HSEC pin 9 */ + "GPIO-B", /* LS_EXP_GPIO_B, LSEC pin 24 */ + "GPIO-C", /* LS_EXP_GPIO_C, LSEC pin 25 */ + "[I2C3_SDA]", /* HSEC pin 38 */ + "[I2C3_SCL]", /* HSEC pin 36 */ + "[SPI0_MOSI]", /* LSEC pin 14 */ + "[SPI0_MISO]", /* LSEC pin 10 */ + "[SPI0_CS_N]", /* LSEC pin 12 */ + "[SPI0_CLK]", /* LSEC pin 8 */ + "HDMI_HPD_N", /* GPIO 20 */ + "USR_LED_1_CTRL", + "[I2C1_SDA]", /* GPIO_22, LSEC pin 21 */ + "[I2C1_SCL]", /* GPIO_23, LSEC pin 19 */ + "GPIO-G", /* LS_EXP_GPIO_G, LSEC pin 29 */ + "GPIO-H", /* LS_EXP_GPIO_H, LSEC pin 30 */ + "[CSI0_MCLK]", /* HSEC pin 15 */ + "[CSI1_MCLK]", /* HSEC pin 17 */ + "GPIO-K", /* LS_EXP_GPIO_K, LSEC pin 33 */ + "[I2C2_SDA]", /* HSEC pin 34 */ + "[I2C2_SCL]", /* HSEC pin 32 */ + "DSI2HDMI_INT_N", + "DSI_SW_SEL_APQ", + "GPIO-L", /* LS_EXP_GPIO_L, LSEC pin 34 */ + "GPIO-J", /* LS_EXP_GPIO_J, LSEC pin 32 */ + "GPIO-I", /* LS_EXP_GPIO_I, LSEC pin 31 */ + "GPIO-A", /* LS_EXP_GPIO_A, LSEC pin 23 */ + "FORCED_USB_BOOT", + "SD_CARD_DET_N", + "[WCSS_BT_SSBI]", + "[WCSS_WLAN_DATA_2]", /* GPIO 40 */ + "[WCSS_WLAN_DATA_1]", + "[WCSS_WLAN_DATA_0]", + "[WCSS_WLAN_SET]", + "[WCSS_WLAN_CLK]", + "[WCSS_FM_SSBI]", + "[WCSS_FM_SDI]", + "[WCSS_BT_DAT_CTL]", + "[WCSS_BT_DAT_STB]", + "NC", + "NC", /* GPIO 50 */ + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", /* GPIO 60 */ + "NC", + "NC", + "[CDC_PDM0_CLK]", + "[CDC_PDM0_SYNC]", + "[CDC_PDM0_TX0]", + "[CDC_PDM0_RX0]", + "[CDC_PDM0_RX1]", + "[CDC_PDM0_RX2]", + "GPIO-D", /* LS_EXP_GPIO_D, LSEC pin 26 */ + "NC", /* GPIO 70 */ + "NC", + "NC", + "NC", + "NC", /* GPIO 74 */ + "NC", + "NC", + "NC", + "NC", + "NC", + "BOOT_CONFIG_0", /* GPIO 80 */ + "BOOT_CONFIG_1", + "BOOT_CONFIG_2", + "BOOT_CONFIG_3", + "NC", + "NC", + "BOOT_CONFIG_5", + "NC", + "NC", + "NC", + "NC", /* GPIO 90 */ + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", /* GPIO 100 */ + "NC", + "NC", + "NC", + "SSBI_GPS", + "NC", + "NC", + "KEY_VOLP_N", + "NC", + "NC", + "[LS_EXP_MI2S_WS]", /* GPIO 110 */ + "NC", + "NC", + "[LS_EXP_MI2S_SCK]", + "[LS_EXP_MI2S_DATA0]", + "GPIO-E", /* LS_EXP_GPIO_E, LSEC pin 27 */ + "NC", + "[DSI2HDMI_MI2S_WS]", + "[DSI2HDMI_MI2S_SCK]", + "[DSI2HDMI_MI2S_DATA0]", + "USR_LED_2_CTRL", /* GPIO 120 */ + "SB_HS_ID"; + + sdc2_cd_default: sdc2-cd-default-state { + pins = "gpio38"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + tlmm_leds: tlmm-leds-state { + pins = "gpio21", "gpio120"; + function = "gpio"; + + output-low; + }; + + usb_id_default: usb-id-default-state { + pins = "gpio121"; + function = "gpio"; + + drive-strength = <8>; + bias-pull-up; + }; + + adv7533_int_active: adv533-int-active-state { + pins = "gpio31"; + function = "gpio"; + + drive-strength = <16>; + bias-disable; + }; + + adv7533_int_suspend: adv7533-int-suspend-state { + pins = "gpio31"; + function = "gpio"; + + drive-strength = <2>; + bias-disable; + }; + + adv7533_switch_active: adv7533-switch-active-state { + pins = "gpio32"; + function = "gpio"; + + drive-strength = <16>; + bias-disable; + }; + + adv7533_switch_suspend: adv7533-switch-suspend-state { + pins = "gpio32"; + function = "gpio"; + + drive-strength = <2>; + bias-disable; + }; + + msm_key_volp_n_default: msm-key-volp-n-default-state { + pins = "gpio107"; + function = "gpio"; + + drive-strength = <8>; + bias-pull-up; + }; +}; + +&pm8916_gpios { + gpio-line-names = + "USR_LED_3_CTRL", + "USR_LED_4_CTRL", + "USB_HUB_RESET_N_PM", + "USB_SW_SEL_PM"; + + usb_hub_reset_pm: usb-hub-reset-pm-state { + pins = "gpio3"; + function = PMIC_GPIO_FUNC_NORMAL; + + input-disable; + output-high; + }; + + usb_hub_reset_pm_device: usb-hub-reset-pm-device-state { + pins = "gpio3"; + function = PMIC_GPIO_FUNC_NORMAL; + + output-low; + }; + + usb_sw_sel_pm: usb-sw-sel-pm-state { + pins = "gpio4"; + function = PMIC_GPIO_FUNC_NORMAL; + + power-source = <PM8916_GPIO_VPH>; + input-disable; + output-high; + }; + + usb_sw_sel_pm_device: usb-sw-sel-pm-device-state { + pins = "gpio4"; + function = PMIC_GPIO_FUNC_NORMAL; + + power-source = <PM8916_GPIO_VPH>; + input-disable; + output-low; + }; + + pm8916_gpios_leds: pm8916-gpios-leds-state { + pins = "gpio1", "gpio2"; + function = PMIC_GPIO_FUNC_NORMAL; + + output-low; + }; +}; + +&pm8916_mpps { + gpio-line-names = + "VDD_PX_BIAS", + "WLAN_LED_CTRL", + "BT_LED_CTRL", + "GPIO-F"; /* LS_EXP_GPIO_F, LSEC pin 28 */ + + pinctrl-names = "default"; + pinctrl-0 = <&ls_exp_gpio_f>; + + ls_exp_gpio_f: pm8916-mpp4-state { + pins = "mpp4"; + function = "digital"; + + output-low; + power-source = <PM8916_MPP_L5>; /* 1.8V */ + }; + + pm8916_mpps_leds: pm8916-mpps-state { + pins = "mpp2", "mpp3"; + function = "digital"; + + output-low; + }; +}; diff --git a/arch/arm/dts/dragonboard410c-uboot.dtsi b/arch/arm/dts/dragonboard410c-uboot.dtsi deleted file mode 100644 index cec64bf80f99..000000000000 --- a/arch/arm/dts/dragonboard410c-uboot.dtsi +++ /dev/null @@ -1,44 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * U-Boot addition to handle Dragonboard 410c pins - * - * (C) Copyright 2015 Mateusz Kulikowski mateusz.kulikowski@gmail.com - */ - -/ { - - smem { - bootph-all; - }; - - soc { - bootph-all; - - pinctrl@1000000 { - bootph-all; - - uart { - bootph-all; - }; - }; - - qcom,gcc@1800000 { - bootph-all; - }; - - serial@78b0000 { - bootph-all; - }; - }; -}; - - -&pm8916_gpios { - usb_hub_reset_pm { - gpios = <&pm8916_gpios 2 0>; - }; - - usb_sw_sel_pm { - gpios = <&pm8916_gpios 3 0>; - }; -}; diff --git a/arch/arm/dts/dragonboard410c.dts b/arch/arm/dts/dragonboard410c.dts index 453642b25705..87f95d3f5827 100644 --- a/arch/arm/dts/dragonboard410c.dts +++ b/arch/arm/dts/dragonboard410c.dts @@ -7,203 +7,41 @@
/dts-v1/;
-#include "skeleton64.dtsi" #include <dt-bindings/gpio/gpio.h>
+#include "msm8916.dtsi" +#include "pm8916.dtsi" + / { model = "Qualcomm Technologies, Inc. Dragonboard 410c"; compatible = "qcom,apq8016-sbc", "qcom,apq8016"; qcom,msm-id = <0xce 0x0 0xf8 0x0 0xf9 0x0 0xfa 0x0 0xf7 0x0>; qcom,board-id = <0x10018 0x0>; - #address-cells = <0x2>; - #size-cells = <0x2>;
aliases { usb0 = "/soc/ehci@78d9000"; + serial0 = &blsp_uart2; };
- memory { + memory@80000000 { device_type = "memory"; reg = <0 0x80000000 0 0x3da00000>; };
- reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - smem_mem: smem_region@86300000 { - reg = <0x0 0x86300000 0x0 0x100000>; - no-map; - }; - }; - chosen { stdout-path = "/soc/serial@78b0000"; };
- smem { - compatible = "qcom,smem"; - memory-region = <&smem_mem>; - qcom,rpm-msg-ram = <&rpm_msg_ram>; - }; - - soc { - #address-cells = <0x1>; - #size-cells = <0x1>; - ranges = <0x0 0x0 0x0 0xffffffff>; - compatible = "simple-bus"; - - rpm_msg_ram: memory@60000 { - compatible = "qcom,rpm-msg-ram"; - reg = <0x60000 0x8000>; - }; - - soc_gpios: pinctrl@1000000 { - compatible = "qcom,msm8916-pinctrl"; - reg = <0x1000000 0x400000>; - gpio-controller; - gpio-count = <122>; - gpio-bank-name="soc"; - #gpio-cells = <2>; - - blsp1_uart: uart { - function = "blsp1_uart"; - pins = "GPIO_4", "GPIO_5"; - drive-strength = <8>; - bias-disable; - }; - }; - clkc: qcom,gcc@1800000 { - compatible = "qcom,gcc-msm8916"; - reg = <0x1800000 0x80000>; - #address-cells = <0x1>; - #size-cells = <0x0>; - #clock-cells = <0x1>; - }; - - serial@78b0000 { - compatible = "qcom,msm-uartdm-v1.4"; - reg = <0x78b0000 0x200>; - clocks = <&clkc 4>; - clock-names = "core"; - pinctrl-names = "uart"; - pinctrl-0 = <&blsp1_uart>; - }; - - ehci@78d9000 { - compatible = "qcom,ci-hdrc"; - reg = <0x78d9000 0x400>; - phys = <&ehci_phy>; - - ulpi { - usb_hs_phy: phy { - compatible = "qcom,usb-hs-phy-msm8916", - "qcom,usb-hs-phy"; - #phy-cells = <0>; - clocks = <&xo_board>, <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ref", "sleep"; - resets = <&gcc GCC_USB2A_PHY_BCR>, <&usb 0>; - reset-names = "phy", "por"; - qcom,init-seq = /bits/ 8 <0x0 0x44>, - <0x1 0x6b>, - <0x2 0x24>, - <0x3 0x13>; - }; - }; - }; - - sdhci@07824000 { - compatible = "qcom,sdhci-msm-v4"; - reg = <0x7824900 0x11c 0x7824000 0x800>; - bus-width = <0x8>; - index = <0x0>; - non-removable; - clock = <&clkc 0>; - clock-frequency = <100000000>; - }; - - sdhci@07864000 { - compatible = "qcom,sdhci-msm-v4"; - reg = <0x7864900 0x11c 0x7864000 0x800>; - index = <0x1>; - bus-width = <0x4>; - clock = <&clkc 1>; - clock-frequency = <200000000>; - cd-gpios = <&soc_gpios 38 GPIO_ACTIVE_LOW>; - }; - - wcnss { - bt { - compatible="qcom,wcnss-bt"; - }; - - wifi { - compatible="qcom,wcnss-wlan"; - }; - }; - - spmi_bus: spmi@200f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x0200f000 0x001000>, - <0x02400000 0x400000>, - <0x02c00000 0x400000>, - <0x03800000 0x200000>, - <0x0200a000 0x002100>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - #address-cells = <0x1>; - #size-cells = <0x1>; - pmic0: pm8916@0 { - compatible = "qcom,spmi-pmic"; - reg = <0x0 0x1>; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pon@800 { - compatible = "qcom,pm8916-pon"; - reg = <0x800 0x100>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pwrkey { - compatible = "qcom,pm8941-pwrkey"; - debounce = <15625>; - bias-pull-up; - }; - - pm8916_resin: resin { - compatible = "qcom,pm8941-resin"; - debounce = <15625>; - bias-pull-up; - }; - }; - - pm8916_gpios: pm8916_gpios@c000 { - compatible = "qcom,pm8916-gpio"; - reg = <0xc000 0x400>; - gpio-controller; - gpio-ranges = <&pm8916_gpios 0 0 4>; - #gpio-cells = <2>; - }; - }; - - pmic1: pm8916@1 { - compatible = "qcom,spmi-pmic"; - reg = <0x1 0x1>; - }; - }; - }; - leds { compatible = "gpio-leds"; user1 { label = "green:user1"; - gpios = <&soc_gpios 21 0>; + gpios = <&tlmm 21 0>; };
user2 { label = "green:user2"; - gpios = <&soc_gpios 120 0>; + gpios = <&tlmm 120 0>; };
user3 { @@ -218,4 +56,35 @@ }; };
-#include "dragonboard410c-uboot.dtsi" +&blsp_uart2 { + status = "okay"; +}; + +&pm8916_gpios { + usb_hub_reset_pm { + gpios = <&pm8916_gpios 2 0>; + }; + + usb_sw_sel_pm { + gpios = <&pm8916_gpios 3 0>; + }; +}; + +&pm8916_resin { + status = "okay"; +}; + +&sdhc_1 { + status = "okay"; + clock-frequency = <100000000>; +}; + +&sdhc_2 { + status = "okay"; + cd-gpios = <&tlmm 38 GPIO_ACTIVE_LOW>; + clock-frequency = <200000000>; +}; + +&usb { + status = "okay"; +}; diff --git a/arch/arm/dts/msm8916.dtsi b/arch/arm/dts/msm8916.dtsi new file mode 100644 index 000000000000..4f799b536a92 --- /dev/null +++ b/arch/arm/dts/msm8916.dtsi @@ -0,0 +1,2702 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (c) 2013-2015, The Linux Foundation. All rights reserved. + */ + +#include <dt-bindings/arm/coresight-cti-dt.h> +#include <dt-bindings/clock/qcom,gcc-msm8916.h> +#include <dt-bindings/clock/qcom,rpmcc.h> +#include <dt-bindings/interconnect/qcom,msm8916.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/power/qcom-rpmpd.h> +#include <dt-bindings/reset/qcom,gcc-msm8916.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + interrupt-parent = <&intc>; + + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + memory@80000000 { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0 0x80000000 0 0>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + tz-apps@86000000 { + reg = <0x0 0x86000000 0x0 0x300000>; + no-map; + }; + + smem@86300000 { + compatible = "qcom,smem"; + reg = <0x0 0x86300000 0x0 0x100000>; + no-map; + + hwlocks = <&tcsr_mutex 3>; + qcom,rpm-msg-ram = <&rpm_msg_ram>; + }; + + hypervisor@86400000 { + reg = <0x0 0x86400000 0x0 0x100000>; + no-map; + }; + + tz@86500000 { + reg = <0x0 0x86500000 0x0 0x180000>; + no-map; + }; + + reserved@86680000 { + reg = <0x0 0x86680000 0x0 0x80000>; + no-map; + }; + + rmtfs@86700000 { + compatible = "qcom,rmtfs-mem"; + reg = <0x0 0x86700000 0x0 0xe0000>; + no-map; + + qcom,client-id = <1>; + }; + + rfsa@867e0000 { + reg = <0x0 0x867e0000 0x0 0x20000>; + no-map; + }; + + mpss_mem: mpss@86800000 { + /* + * The memory region for the mpss firmware is generally + * relocatable and could be allocated dynamically. + * However, many firmware versions tend to fail when + * loaded to some special addresses, so it is hard to + * define reliable alloc-ranges. + * + * alignment = <0x0 0x400000>; + * alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; + */ + reg = <0x0 0x86800000 0x0 0>; /* size is device-specific */ + no-map; + status = "disabled"; + }; + + wcnss_mem: wcnss { + size = <0x0 0x600000>; + alignment = <0x0 0x100000>; + alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; + no-map; + status = "disabled"; + }; + + venus_mem: venus { + size = <0x0 0x500000>; + alignment = <0x0 0x100000>; + alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; + no-map; + status = "disabled"; + }; + + mba_mem: mba { + size = <0x0 0x100000>; + alignment = <0x0 0x100000>; + alloc-ranges = <0x0 0x86800000 0x0 0x8000000>; + no-map; + status = "disabled"; + }; + }; + + clocks { + xo_board: xo-board { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + }; + + sleep_clk: sleep-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + CPU0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + clocks = <&apcs>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; + power-domains = <&CPU_PD0>; + power-domain-names = "psci"; + qcom,acc = <&cpu0_acc>; + qcom,saw = <&cpu0_saw>; + }; + + CPU1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x1>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + clocks = <&apcs>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; + power-domains = <&CPU_PD1>; + power-domain-names = "psci"; + qcom,acc = <&cpu1_acc>; + qcom,saw = <&cpu1_saw>; + }; + + CPU2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x2>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + clocks = <&apcs>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; + power-domains = <&CPU_PD2>; + power-domain-names = "psci"; + qcom,acc = <&cpu2_acc>; + qcom,saw = <&cpu2_saw>; + }; + + CPU3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x3>; + next-level-cache = <&L2_0>; + enable-method = "psci"; + clocks = <&apcs>; + operating-points-v2 = <&cpu_opp_table>; + #cooling-cells = <2>; + power-domains = <&CPU_PD3>; + power-domain-names = "psci"; + qcom,acc = <&cpu3_acc>; + qcom,saw = <&cpu3_saw>; + }; + + L2_0: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + }; + + idle-states { + entry-method = "psci"; + + CPU_SLEEP_0: cpu-sleep-0 { + compatible = "arm,idle-state"; + idle-state-name = "standalone-power-collapse"; + arm,psci-suspend-param = <0x40000002>; + entry-latency-us = <130>; + exit-latency-us = <150>; + min-residency-us = <2000>; + local-timer-stop; + }; + }; + + domain-idle-states { + + CLUSTER_RET: cluster-retention { + compatible = "domain-idle-state"; + arm,psci-suspend-param = <0x41000012>; + entry-latency-us = <500>; + exit-latency-us = <500>; + min-residency-us = <2000>; + }; + + CLUSTER_PWRDN: cluster-gdhs { + compatible = "domain-idle-state"; + arm,psci-suspend-param = <0x41000032>; + entry-latency-us = <2000>; + exit-latency-us = <2000>; + min-residency-us = <6000>; + }; + }; + }; + + cpu_opp_table: opp-table-cpu { + compatible = "operating-points-v2"; + opp-shared; + + opp-200000000 { + opp-hz = /bits/ 64 <200000000>; + }; + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + }; + opp-800000000 { + opp-hz = /bits/ 64 <800000000>; + }; + opp-998400000 { + opp-hz = /bits/ 64 <998400000>; + }; + }; + + firmware { + scm: scm { + compatible = "qcom,scm-msm8916", "qcom,scm"; + clocks = <&gcc GCC_CRYPTO_CLK>, + <&gcc GCC_CRYPTO_AXI_CLK>, + <&gcc GCC_CRYPTO_AHB_CLK>; + clock-names = "core", "bus", "iface"; + #reset-cells = <1>; + + qcom,dload-mode = <&tcsr 0x6100>; + }; + }; + + pmu { + compatible = "arm,cortex-a53-pmu"; + interrupts = <GIC_PPI 7 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + + CPU_PD0: power-domain-cpu0 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&CPU_SLEEP_0>; + }; + + CPU_PD1: power-domain-cpu1 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&CPU_SLEEP_0>; + }; + + CPU_PD2: power-domain-cpu2 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&CPU_SLEEP_0>; + }; + + CPU_PD3: power-domain-cpu3 { + #power-domain-cells = <0>; + power-domains = <&CLUSTER_PD>; + domain-idle-states = <&CPU_SLEEP_0>; + }; + + CLUSTER_PD: power-domain-cluster { + #power-domain-cells = <0>; + domain-idle-states = <&CLUSTER_RET>, <&CLUSTER_PWRDN>; + }; + }; + + rpm: remoteproc { + compatible = "qcom,msm8916-rpm-proc", "qcom,rpm-proc"; + + smd-edge { + interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; + qcom,ipc = <&apcs 8 0>; + qcom,smd-edge = <15>; + + rpm_requests: rpm-requests { + compatible = "qcom,rpm-msm8916"; + qcom,smd-channels = "rpm_requests"; + + rpmcc: clock-controller { + compatible = "qcom,rpmcc-msm8916", "qcom,rpmcc"; + #clock-cells = <1>; + clocks = <&xo_board>; + clock-names = "xo"; + }; + + rpmpd: power-controller { + compatible = "qcom,msm8916-rpmpd"; + #power-domain-cells = <1>; + operating-points-v2 = <&rpmpd_opp_table>; + + rpmpd_opp_table: opp-table { + compatible = "operating-points-v2"; + + rpmpd_opp_ret: opp1 { + opp-level = <1>; + }; + rpmpd_opp_svs_krait: opp2 { + opp-level = <2>; + }; + rpmpd_opp_svs_soc: opp3 { + opp-level = <3>; + }; + rpmpd_opp_nom: opp4 { + opp-level = <4>; + }; + rpmpd_opp_turbo: opp5 { + opp-level = <5>; + }; + rpmpd_opp_super_turbo: opp6 { + opp-level = <6>; + }; + }; + }; + }; + }; + }; + + smp2p-hexagon { + compatible = "qcom,smp2p"; + qcom,smem = <435>, <428>; + + interrupts = <GIC_SPI 27 IRQ_TYPE_EDGE_RISING>; + + qcom,ipc = <&apcs 8 14>; + + qcom,local-pid = <0>; + qcom,remote-pid = <1>; + + hexagon_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + + #qcom,smem-state-cells = <1>; + }; + + hexagon_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-wcnss { + compatible = "qcom,smp2p"; + qcom,smem = <451>, <431>; + + interrupts = <GIC_SPI 143 IRQ_TYPE_EDGE_RISING>; + + qcom,ipc = <&apcs 8 18>; + + qcom,local-pid = <0>; + qcom,remote-pid = <4>; + + wcnss_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + + #qcom,smem-state-cells = <1>; + }; + + wcnss_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smsm { + compatible = "qcom,smsm"; + + #address-cells = <1>; + #size-cells = <0>; + + qcom,ipc-1 = <&apcs 8 13>; + qcom,ipc-3 = <&apcs 8 19>; + + apps_smsm: apps@0 { + reg = <0>; + + #qcom,smem-state-cells = <1>; + }; + + hexagon_smsm: hexagon@1 { + reg = <1>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + + wcnss_smsm: wcnss@6 { + reg = <6>; + interrupts = <GIC_SPI 144 IRQ_TYPE_EDGE_RISING>; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + soc: soc@0 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xffffffff>; + compatible = "simple-bus"; + + rng@22000 { + compatible = "qcom,prng"; + reg = <0x00022000 0x200>; + clocks = <&gcc GCC_PRNG_AHB_CLK>; + clock-names = "core"; + }; + + restart@4ab000 { + compatible = "qcom,pshold"; + reg = <0x004ab000 0x4>; + }; + + qfprom: qfprom@5c000 { + compatible = "qcom,msm8916-qfprom", "qcom,qfprom"; + reg = <0x0005c000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + + tsens_base1: base1@d0 { + reg = <0xd0 0x1>; + bits = <0 7>; + }; + + tsens_s0_p1: s0-p1@d0 { + reg = <0xd0 0x2>; + bits = <7 5>; + }; + + tsens_s0_p2: s0-p2@d1 { + reg = <0xd1 0x2>; + bits = <4 5>; + }; + + tsens_s1_p1: s1-p1@d2 { + reg = <0xd2 0x1>; + bits = <1 5>; + }; + tsens_s1_p2: s1-p2@d2 { + reg = <0xd2 0x2>; + bits = <6 5>; + }; + tsens_s2_p1: s2-p1@d3 { + reg = <0xd3 0x1>; + bits = <3 5>; + }; + + tsens_s2_p2: s2-p2@d4 { + reg = <0xd4 0x1>; + bits = <0 5>; + }; + + // no tsens with hw_id 3 + + tsens_s4_p1: s4-p1@d4 { + reg = <0xd4 0x2>; + bits = <5 5>; + }; + + tsens_s4_p2: s4-p2@d5 { + reg = <0xd5 0x1>; + bits = <2 5>; + }; + + tsens_s5_p1: s5-p1@d5 { + reg = <0xd5 0x2>; + bits = <7 5>; + }; + + tsens_s5_p2: s5-p2@d6 { + reg = <0xd6 0x2>; + bits = <4 5>; + }; + + tsens_base2: base2@d7 { + reg = <0xd7 0x1>; + bits = <1 7>; + }; + + tsens_mode: mode@ef { + reg = <0xef 0x1>; + bits = <5 3>; + }; + }; + + rpm_msg_ram: sram@60000 { + compatible = "qcom,rpm-msg-ram"; + reg = <0x00060000 0x8000>; + }; + + sram@290000 { + compatible = "qcom,msm8916-rpm-stats"; + reg = <0x00290000 0x10000>; + }; + + bimc: interconnect@400000 { + compatible = "qcom,msm8916-bimc"; + reg = <0x00400000 0x62000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_BIMC_CLK>, + <&rpmcc RPM_SMD_BIMC_A_CLK>; + }; + + tsens: thermal-sensor@4a9000 { + compatible = "qcom,msm8916-tsens", "qcom,tsens-v0_1"; + reg = <0x004a9000 0x1000>, /* TM */ + <0x004a8000 0x1000>; /* SROT */ + + // no hw_id 3 + nvmem-cells = <&tsens_mode>, + <&tsens_base1>, <&tsens_base2>, + <&tsens_s0_p1>, <&tsens_s0_p2>, + <&tsens_s1_p1>, <&tsens_s1_p2>, + <&tsens_s2_p1>, <&tsens_s2_p2>, + <&tsens_s4_p1>, <&tsens_s4_p2>, + <&tsens_s5_p1>, <&tsens_s5_p2>; + nvmem-cell-names = "mode", + "base1", "base2", + "s0_p1", "s0_p2", + "s1_p1", "s1_p2", + "s2_p1", "s2_p2", + "s4_p1", "s4_p2", + "s5_p1", "s5_p2"; + #qcom,sensors = <5>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow"; + #thermal-sensor-cells = <1>; + }; + + pcnoc: interconnect@500000 { + compatible = "qcom,msm8916-pcnoc"; + reg = <0x00500000 0x11000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_PCNOC_CLK>, + <&rpmcc RPM_SMD_PCNOC_A_CLK>; + }; + + snoc: interconnect@580000 { + compatible = "qcom,msm8916-snoc"; + reg = <0x00580000 0x14000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_SNOC_CLK>, + <&rpmcc RPM_SMD_SNOC_A_CLK>; + }; + + stm: stm@802000 { + compatible = "arm,coresight-stm", "arm,primecell"; + reg = <0x00802000 0x1000>, + <0x09280000 0x180000>; + reg-names = "stm-base", "stm-stimulus-base"; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + out-ports { + port { + stm_out: endpoint { + remote-endpoint = <&funnel0_in7>; + }; + }; + }; + }; + + /* System CTIs */ + /* CTI 0 - TMC connections */ + cti0: cti@810000 { + compatible = "arm,coresight-cti", "arm,primecell"; + reg = <0x00810000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + status = "disabled"; + }; + + /* CTI 1 - TPIU connections */ + cti1: cti@811000 { + compatible = "arm,coresight-cti", "arm,primecell"; + reg = <0x00811000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + status = "disabled"; + }; + + /* CTIs 2-11 - no information - not instantiated */ + + tpiu: tpiu@820000 { + compatible = "arm,coresight-tpiu", "arm,primecell"; + reg = <0x00820000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + in-ports { + port { + tpiu_in: endpoint { + remote-endpoint = <&replicator_out1>; + }; + }; + }; + }; + + funnel0: funnel@821000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x00821000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + /* + * Not described input ports: + * 0 - connected to Resource and Power Manger CPU ETM + * 1 - not-connected + * 2 - connected to Modem CPU ETM + * 3 - not-connected + * 5 - not-connected + * 6 - connected trought funnel to Wireless CPU ETM + * 7 - connected to STM component + */ + + port@4 { + reg = <4>; + funnel0_in4: endpoint { + remote-endpoint = <&funnel1_out>; + }; + }; + + port@7 { + reg = <7>; + funnel0_in7: endpoint { + remote-endpoint = <&stm_out>; + }; + }; + }; + + out-ports { + port { + funnel0_out: endpoint { + remote-endpoint = <&etf_in>; + }; + }; + }; + }; + + replicator: replicator@824000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0x00824000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + out-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + replicator_out0: endpoint { + remote-endpoint = <&etr_in>; + }; + }; + port@1 { + reg = <1>; + replicator_out1: endpoint { + remote-endpoint = <&tpiu_in>; + }; + }; + }; + + in-ports { + port { + replicator_in: endpoint { + remote-endpoint = <&etf_out>; + }; + }; + }; + }; + + etf: etf@825000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x00825000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + in-ports { + port { + etf_in: endpoint { + remote-endpoint = <&funnel0_out>; + }; + }; + }; + + out-ports { + port { + etf_out: endpoint { + remote-endpoint = <&replicator_in>; + }; + }; + }; + }; + + etr: etr@826000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x00826000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + in-ports { + port { + etr_in: endpoint { + remote-endpoint = <&replicator_out0>; + }; + }; + }; + }; + + funnel1: funnel@841000 { /* APSS funnel only 4 inputs are used */ + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x00841000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + status = "disabled"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + funnel1_in0: endpoint { + remote-endpoint = <&etm0_out>; + }; + }; + port@1 { + reg = <1>; + funnel1_in1: endpoint { + remote-endpoint = <&etm1_out>; + }; + }; + port@2 { + reg = <2>; + funnel1_in2: endpoint { + remote-endpoint = <&etm2_out>; + }; + }; + port@3 { + reg = <3>; + funnel1_in3: endpoint { + remote-endpoint = <&etm3_out>; + }; + }; + }; + + out-ports { + port { + funnel1_out: endpoint { + remote-endpoint = <&funnel0_in4>; + }; + }; + }; + }; + + debug0: debug@850000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x00850000 0x1000>; + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + cpu = <&CPU0>; + status = "disabled"; + }; + + debug1: debug@852000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x00852000 0x1000>; + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + cpu = <&CPU1>; + status = "disabled"; + }; + + debug2: debug@854000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x00854000 0x1000>; + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + cpu = <&CPU2>; + status = "disabled"; + }; + + debug3: debug@856000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x00856000 0x1000>; + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + cpu = <&CPU3>; + status = "disabled"; + }; + + /* Core CTIs; CTIs 12-15 */ + /* CTI - CPU-0 */ + cti12: cti@858000 { + compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", + "arm,primecell"; + reg = <0x00858000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU0>; + arm,cs-dev-assoc = <&etm0>; + + status = "disabled"; + }; + + /* CTI - CPU-1 */ + cti13: cti@859000 { + compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", + "arm,primecell"; + reg = <0x00859000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU1>; + arm,cs-dev-assoc = <&etm1>; + + status = "disabled"; + }; + + /* CTI - CPU-2 */ + cti14: cti@85a000 { + compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", + "arm,primecell"; + reg = <0x0085a000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU2>; + arm,cs-dev-assoc = <&etm2>; + + status = "disabled"; + }; + + /* CTI - CPU-3 */ + cti15: cti@85b000 { + compatible = "arm,coresight-cti-v8-arch", "arm,coresight-cti", + "arm,primecell"; + reg = <0x0085b000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU3>; + arm,cs-dev-assoc = <&etm3>; + + status = "disabled"; + }; + + etm0: etm@85c000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x0085c000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + arm,coresight-loses-context-with-cpu; + + cpu = <&CPU0>; + + status = "disabled"; + + out-ports { + port { + etm0_out: endpoint { + remote-endpoint = <&funnel1_in0>; + }; + }; + }; + }; + + etm1: etm@85d000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x0085d000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + arm,coresight-loses-context-with-cpu; + + cpu = <&CPU1>; + + status = "disabled"; + + out-ports { + port { + etm1_out: endpoint { + remote-endpoint = <&funnel1_in1>; + }; + }; + }; + }; + + etm2: etm@85e000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x0085e000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + arm,coresight-loses-context-with-cpu; + + cpu = <&CPU2>; + + status = "disabled"; + + out-ports { + port { + etm2_out: endpoint { + remote-endpoint = <&funnel1_in2>; + }; + }; + }; + }; + + etm3: etm@85f000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x0085f000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + arm,coresight-loses-context-with-cpu; + + cpu = <&CPU3>; + + status = "disabled"; + + out-ports { + port { + etm3_out: endpoint { + remote-endpoint = <&funnel1_in3>; + }; + }; + }; + }; + + tlmm: pinctrl@1000000 { + compatible = "qcom,msm8916-pinctrl"; + reg = <0x01000000 0x300000>; + interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + gpio-ranges = <&tlmm 0 0 122>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + + blsp_i2c1_default: blsp-i2c1-default-state { + pins = "gpio2", "gpio3"; + function = "blsp_i2c1"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c1_sleep: blsp-i2c1-sleep-state { + pins = "gpio2", "gpio3"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c2_default: blsp-i2c2-default-state { + pins = "gpio6", "gpio7"; + function = "blsp_i2c2"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c2_sleep: blsp-i2c2-sleep-state { + pins = "gpio6", "gpio7"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c3_default: blsp-i2c3-default-state { + pins = "gpio10", "gpio11"; + function = "blsp_i2c3"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c3_sleep: blsp-i2c3-sleep-state { + pins = "gpio10", "gpio11"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c4_default: blsp-i2c4-default-state { + pins = "gpio14", "gpio15"; + function = "blsp_i2c4"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c4_sleep: blsp-i2c4-sleep-state { + pins = "gpio14", "gpio15"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c5_default: blsp-i2c5-default-state { + pins = "gpio18", "gpio19"; + function = "blsp_i2c5"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c5_sleep: blsp-i2c5-sleep-state { + pins = "gpio18", "gpio19"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c6_default: blsp-i2c6-default-state { + pins = "gpio22", "gpio23"; + function = "blsp_i2c6"; + drive-strength = <2>; + bias-disable; + }; + + blsp_i2c6_sleep: blsp-i2c6-sleep-state { + pins = "gpio22", "gpio23"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp_spi1_default: blsp-spi1-default-state { + spi-pins { + pins = "gpio0", "gpio1", "gpio3"; + function = "blsp_spi1"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio2"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi1_sleep: blsp-spi1-sleep-state { + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_spi2_default: blsp-spi2-default-state { + spi-pins { + pins = "gpio4", "gpio5", "gpio7"; + function = "blsp_spi2"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio6"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi2_sleep: blsp-spi2-sleep-state { + pins = "gpio4", "gpio5", "gpio6", "gpio7"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_spi3_default: blsp-spi3-default-state { + spi-pins { + pins = "gpio8", "gpio9", "gpio11"; + function = "blsp_spi3"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio10"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi3_sleep: blsp-spi3-sleep-state { + pins = "gpio8", "gpio9", "gpio10", "gpio11"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_spi4_default: blsp-spi4-default-state { + spi-pins { + pins = "gpio12", "gpio13", "gpio15"; + function = "blsp_spi4"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio14"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi4_sleep: blsp-spi4-sleep-state { + pins = "gpio12", "gpio13", "gpio14", "gpio15"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_spi5_default: blsp-spi5-default-state { + spi-pins { + pins = "gpio16", "gpio17", "gpio19"; + function = "blsp_spi5"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio18"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi5_sleep: blsp-spi5-sleep-state { + pins = "gpio16", "gpio17", "gpio18", "gpio19"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_spi6_default: blsp-spi6-default-state { + spi-pins { + pins = "gpio20", "gpio21", "gpio23"; + function = "blsp_spi6"; + drive-strength = <12>; + bias-disable; + }; + cs-pins { + pins = "gpio22"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp_spi6_sleep: blsp-spi6-sleep-state { + pins = "gpio20", "gpio21", "gpio22", "gpio23"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_uart1_default: blsp-uart1-default-state { + /* TX, RX, CTS_N, RTS_N */ + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "blsp_uart1"; + drive-strength = <16>; + bias-disable; + }; + + blsp_uart1_sleep: blsp-uart1-sleep-state { + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp_uart2_default: blsp-uart2-default-state { + pins = "gpio4", "gpio5"; + function = "blsp_uart2"; + drive-strength = <16>; + bias-disable; + }; + + blsp_uart2_sleep: blsp-uart2-sleep-state { + pins = "gpio4", "gpio5"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + camera_front_default: camera-front-default-state { + pwdn-pins { + pins = "gpio33"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + rst-pins { + pins = "gpio28"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + mclk1-pins { + pins = "gpio27"; + function = "cam_mclk1"; + drive-strength = <16>; + bias-disable; + }; + }; + + camera_rear_default: camera-rear-default-state { + pwdn-pins { + pins = "gpio34"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + rst-pins { + pins = "gpio35"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + mclk0-pins { + pins = "gpio26"; + function = "cam_mclk0"; + drive-strength = <16>; + bias-disable; + }; + }; + + cci0_default: cci0-default-state { + pins = "gpio29", "gpio30"; + function = "cci_i2c"; + drive-strength = <16>; + bias-disable; + }; + + cdc_dmic_default: cdc-dmic-default-state { + clk-pins { + pins = "gpio0"; + function = "dmic0_clk"; + drive-strength = <8>; + }; + data-pins { + pins = "gpio1"; + function = "dmic0_data"; + drive-strength = <8>; + }; + }; + + cdc_dmic_sleep: cdc-dmic-sleep-state { + clk-pins { + pins = "gpio0"; + function = "dmic0_clk"; + drive-strength = <2>; + bias-disable; + }; + data-pins { + pins = "gpio1"; + function = "dmic0_data"; + drive-strength = <2>; + bias-disable; + }; + }; + + cdc_pdm_default: cdc-pdm-default-state { + pins = "gpio63", "gpio64", "gpio65", "gpio66", + "gpio67", "gpio68"; + function = "cdc_pdm0"; + drive-strength = <8>; + bias-disable; + }; + + cdc_pdm_sleep: cdc-pdm-sleep-state { + pins = "gpio63", "gpio64", "gpio65", "gpio66", + "gpio67", "gpio68"; + function = "cdc_pdm0"; + drive-strength = <2>; + bias-pull-down; + }; + + pri_mi2s_default: mi2s-pri-default-state { + pins = "gpio113", "gpio114", "gpio115", "gpio116"; + function = "pri_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + pri_mi2s_sleep: mi2s-pri-sleep-state { + pins = "gpio113", "gpio114", "gpio115", "gpio116"; + function = "pri_mi2s"; + drive-strength = <2>; + bias-disable; + }; + + pri_mi2s_mclk_default: mi2s-pri-mclk-default-state { + pins = "gpio116"; + function = "pri_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + pri_mi2s_mclk_sleep: mi2s-pri-mclk-sleep-state { + pins = "gpio116"; + function = "pri_mi2s"; + drive-strength = <2>; + bias-disable; + }; + + pri_mi2s_ws_default: mi2s-pri-ws-default-state { + pins = "gpio110"; + function = "pri_mi2s_ws"; + drive-strength = <8>; + bias-disable; + }; + + pri_mi2s_ws_sleep: mi2s-pri-ws-sleep-state { + pins = "gpio110"; + function = "pri_mi2s_ws"; + drive-strength = <2>; + bias-disable; + }; + + sec_mi2s_default: mi2s-sec-default-state { + pins = "gpio112", "gpio117", "gpio118", "gpio119"; + function = "sec_mi2s"; + drive-strength = <8>; + bias-disable; + }; + + sec_mi2s_sleep: mi2s-sec-sleep-state { + pins = "gpio112", "gpio117", "gpio118", "gpio119"; + function = "sec_mi2s"; + drive-strength = <2>; + bias-disable; + }; + + sdc1_default: sdc1-default-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <16>; + }; + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <10>; + }; + }; + + sdc1_sleep: sdc1-sleep-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <2>; + }; + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <2>; + }; + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <2>; + }; + }; + + sdc2_default: sdc2-default-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; + drive-strength = <16>; + }; + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + data-pins { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <10>; + }; + }; + + sdc2_sleep: sdc2-sleep-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; + drive-strength = <2>; + }; + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <2>; + }; + data-pins { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <2>; + }; + }; + + wcss_wlan_default: wcss-wlan-default-state { + pins = "gpio40", "gpio41", "gpio42", "gpio43", "gpio44"; + function = "wcss_wlan"; + drive-strength = <6>; + bias-pull-up; + }; + }; + + gcc: clock-controller@1800000 { + compatible = "qcom,gcc-msm8916"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + reg = <0x01800000 0x80000>; + clocks = <&xo_board>, + <&sleep_clk>, + <&mdss_dsi0_phy 1>, + <&mdss_dsi0_phy 0>, + <0>, + <0>, + <0>; + clock-names = "xo", + "sleep_clk", + "dsi0pll", + "dsi0pllbyte", + "ext_mclk", + "ext_pri_i2s", + "ext_sec_i2s"; + }; + + tcsr_mutex: hwlock@1905000 { + compatible = "qcom,tcsr-mutex"; + reg = <0x01905000 0x20000>; + #hwlock-cells = <1>; + }; + + tcsr: syscon@1937000 { + compatible = "qcom,tcsr-msm8916", "syscon"; + reg = <0x01937000 0x30000>; + }; + + mdss: display-subsystem@1a00000 { + status = "disabled"; + compatible = "qcom,mdss"; + reg = <0x01a00000 0x1000>, + <0x01ac8000 0x3000>; + reg-names = "mdss_phys", "vbif_phys"; + + power-domains = <&gcc MDSS_GDSC>; + + clocks = <&gcc GCC_MDSS_AHB_CLK>, + <&gcc GCC_MDSS_AXI_CLK>, + <&gcc GCC_MDSS_VSYNC_CLK>; + clock-names = "iface", + "bus", + "vsync"; + + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + + interrupt-controller; + #interrupt-cells = <1>; + + #address-cells = <1>; + #size-cells = <1>; + ranges; + + mdss_mdp: display-controller@1a01000 { + compatible = "qcom,msm8916-mdp5", "qcom,mdp5"; + reg = <0x01a01000 0x89000>; + reg-names = "mdp_phys"; + + interrupt-parent = <&mdss>; + interrupts = <0>; + + clocks = <&gcc GCC_MDSS_AHB_CLK>, + <&gcc GCC_MDSS_AXI_CLK>, + <&gcc GCC_MDSS_MDP_CLK>, + <&gcc GCC_MDSS_VSYNC_CLK>; + clock-names = "iface", + "bus", + "core", + "vsync"; + + iommus = <&apps_iommu 4>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_mdp_intf1_out: endpoint { + remote-endpoint = <&mdss_dsi0_in>; + }; + }; + }; + }; + + mdss_dsi0: dsi@1a98000 { + compatible = "qcom,msm8916-dsi-ctrl", + "qcom,mdss-dsi-ctrl"; + reg = <0x01a98000 0x25c>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <4>; + + assigned-clocks = <&gcc BYTE0_CLK_SRC>, + <&gcc PCLK0_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi0_phy 0>, + <&mdss_dsi0_phy 1>; + + clocks = <&gcc GCC_MDSS_MDP_CLK>, + <&gcc GCC_MDSS_AHB_CLK>, + <&gcc GCC_MDSS_AXI_CLK>, + <&gcc GCC_MDSS_BYTE0_CLK>, + <&gcc GCC_MDSS_PCLK0_CLK>, + <&gcc GCC_MDSS_ESC0_CLK>; + clock-names = "mdp_core", + "iface", + "bus", + "byte", + "pixel", + "core"; + phys = <&mdss_dsi0_phy>; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi0_in: endpoint { + remote-endpoint = <&mdss_mdp_intf1_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi0_out: endpoint { + }; + }; + }; + }; + + mdss_dsi0_phy: phy@1a98300 { + compatible = "qcom,dsi-phy-28nm-lp"; + reg = <0x01a98300 0xd4>, + <0x01a98500 0x280>, + <0x01a98780 0x30>; + reg-names = "dsi_pll", + "dsi_phy", + "dsi_phy_regulator"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&gcc GCC_MDSS_AHB_CLK>, + <&xo_board>; + clock-names = "iface", "ref"; + }; + }; + + camss: camss@1b0ac00 { + compatible = "qcom,msm8916-camss"; + reg = <0x01b0ac00 0x200>, + <0x01b00030 0x4>, + <0x01b0b000 0x200>, + <0x01b00038 0x4>, + <0x01b08000 0x100>, + <0x01b08400 0x100>, + <0x01b0a000 0x500>, + <0x01b00020 0x10>, + <0x01b10000 0x1000>; + reg-names = "csiphy0", + "csiphy0_clk_mux", + "csiphy1", + "csiphy1_clk_mux", + "csid0", + "csid1", + "ispif", + "csi_clk_mux", + "vfe0"; + interrupts = <GIC_SPI 78 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 79 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 51 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 55 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "csiphy0", + "csiphy1", + "csid0", + "csid1", + "ispif", + "vfe0"; + power-domains = <&gcc VFE_GDSC>; + clocks = <&gcc GCC_CAMSS_TOP_AHB_CLK>, + <&gcc GCC_CAMSS_ISPIF_AHB_CLK>, + <&gcc GCC_CAMSS_CSI0PHYTIMER_CLK>, + <&gcc GCC_CAMSS_CSI1PHYTIMER_CLK>, + <&gcc GCC_CAMSS_CSI0_AHB_CLK>, + <&gcc GCC_CAMSS_CSI0_CLK>, + <&gcc GCC_CAMSS_CSI0PHY_CLK>, + <&gcc GCC_CAMSS_CSI0PIX_CLK>, + <&gcc GCC_CAMSS_CSI0RDI_CLK>, + <&gcc GCC_CAMSS_CSI1_AHB_CLK>, + <&gcc GCC_CAMSS_CSI1_CLK>, + <&gcc GCC_CAMSS_CSI1PHY_CLK>, + <&gcc GCC_CAMSS_CSI1PIX_CLK>, + <&gcc GCC_CAMSS_CSI1RDI_CLK>, + <&gcc GCC_CAMSS_AHB_CLK>, + <&gcc GCC_CAMSS_VFE0_CLK>, + <&gcc GCC_CAMSS_CSI_VFE0_CLK>, + <&gcc GCC_CAMSS_VFE_AHB_CLK>, + <&gcc GCC_CAMSS_VFE_AXI_CLK>; + clock-names = "top_ahb", + "ispif_ahb", + "csiphy0_timer", + "csiphy1_timer", + "csi0_ahb", + "csi0", + "csi0_phy", + "csi0_pix", + "csi0_rdi", + "csi1_ahb", + "csi1", + "csi1_phy", + "csi1_pix", + "csi1_rdi", + "ahb", + "vfe0", + "csi_vfe0", + "vfe_ahb", + "vfe_axi"; + iommus = <&apps_iommu 3>; + status = "disabled"; + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + }; + + port@1 { + reg = <1>; + }; + }; + }; + + cci: cci@1b0c000 { + compatible = "qcom,msm8916-cci", "qcom,msm8226-cci"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x01b0c000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_EDGE_RISING>; + clocks = <&gcc GCC_CAMSS_TOP_AHB_CLK>, + <&gcc GCC_CAMSS_CCI_AHB_CLK>, + <&gcc GCC_CAMSS_CCI_CLK>, + <&gcc GCC_CAMSS_AHB_CLK>; + clock-names = "camss_top_ahb", "cci_ahb", + "cci", "camss_ahb"; + assigned-clocks = <&gcc GCC_CAMSS_CCI_AHB_CLK>, + <&gcc GCC_CAMSS_CCI_CLK>; + assigned-clock-rates = <80000000>, <19200000>; + pinctrl-names = "default"; + pinctrl-0 = <&cci0_default>; + status = "disabled"; + + cci_i2c0: i2c-bus@0 { + reg = <0>; + clock-frequency = <400000>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + gpu: gpu@1c00000 { + compatible = "qcom,adreno-306.0", "qcom,adreno"; + reg = <0x01c00000 0x20000>; + reg-names = "kgsl_3d0_reg_memory"; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "kgsl_3d0_irq"; + clock-names = + "core", + "iface", + "mem", + "mem_iface", + "alt_mem_iface", + "gfx3d"; + clocks = + <&gcc GCC_OXILI_GFX3D_CLK>, + <&gcc GCC_OXILI_AHB_CLK>, + <&gcc GCC_OXILI_GMEM_CLK>, + <&gcc GCC_BIMC_GFX_CLK>, + <&gcc GCC_BIMC_GPU_CLK>, + <&gcc GFX3D_CLK_SRC>; + power-domains = <&gcc OXILI_GDSC>; + operating-points-v2 = <&gpu_opp_table>; + iommus = <&gpu_iommu 1>, <&gpu_iommu 2>; + status = "disabled"; + + gpu_opp_table: opp-table { + compatible = "operating-points-v2"; + + opp-400000000 { + opp-hz = /bits/ 64 <400000000>; + }; + opp-19200000 { + opp-hz = /bits/ 64 <19200000>; + }; + }; + }; + + venus: video-codec@1d00000 { + compatible = "qcom,msm8916-venus"; + reg = <0x01d00000 0xff000>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&gcc VENUS_GDSC>; + clocks = <&gcc GCC_VENUS0_VCODEC0_CLK>, + <&gcc GCC_VENUS0_AHB_CLK>, + <&gcc GCC_VENUS0_AXI_CLK>; + clock-names = "core", "iface", "bus"; + iommus = <&apps_iommu 5>; + memory-region = <&venus_mem>; + status = "disabled"; + + video-decoder { + compatible = "venus-decoder"; + }; + + video-encoder { + compatible = "venus-encoder"; + }; + }; + + apps_iommu: iommu@1ef0000 { + #address-cells = <1>; + #size-cells = <1>; + #iommu-cells = <1>; + compatible = "qcom,msm8916-iommu", "qcom,msm-iommu-v1"; + ranges = <0 0x01e20000 0x20000>; + reg = <0x01ef0000 0x3000>; + clocks = <&gcc GCC_SMMU_CFG_CLK>, + <&gcc GCC_APSS_TCU_CLK>; + clock-names = "iface", "bus"; + qcom,iommu-secure-id = <17>; + + /* VFE */ + iommu-ctx@3000 { + compatible = "qcom,msm-iommu-v1-sec"; + reg = <0x3000 0x1000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + }; + + /* MDP_0 */ + iommu-ctx@4000 { + compatible = "qcom,msm-iommu-v1-ns"; + reg = <0x4000 0x1000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + }; + + /* VENUS_NS */ + iommu-ctx@5000 { + compatible = "qcom,msm-iommu-v1-sec"; + reg = <0x5000 0x1000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + gpu_iommu: iommu@1f08000 { + #address-cells = <1>; + #size-cells = <1>; + #iommu-cells = <1>; + compatible = "qcom,msm8916-iommu", "qcom,msm-iommu-v1"; + ranges = <0 0x01f08000 0x10000>; + clocks = <&gcc GCC_SMMU_CFG_CLK>, + <&gcc GCC_GFX_TCU_CLK>; + clock-names = "iface", "bus"; + qcom,iommu-secure-id = <18>; + + /* GFX3D_USER */ + iommu-ctx@1000 { + compatible = "qcom,msm-iommu-v1-ns"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; + }; + + /* GFX3D_PRIV */ + iommu-ctx@2000 { + compatible = "qcom,msm-iommu-v1-ns"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + spmi_bus: spmi@200f000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0x0200f000 0x001000>, + <0x02400000 0x400000>, + <0x02c00000 0x400000>, + <0x03800000 0x200000>, + <0x0200a000 0x002100>; + reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; + interrupt-names = "periph_irq"; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + qcom,ee = <0>; + qcom,channel = <0>; + #address-cells = <2>; + #size-cells = <0>; + interrupt-controller; + #interrupt-cells = <4>; + }; + + bam_dmux_dma: dma-controller@4044000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x04044000 0x19000>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + qcom,ee = <0>; + + num-channels = <6>; + qcom,num-ees = <1>; + qcom,powered-remotely; + + status = "disabled"; + }; + + mpss: remoteproc@4080000 { + compatible = "qcom,msm8916-mss-pil"; + reg = <0x04080000 0x100>, + <0x04020000 0x040>; + + reg-names = "qdsp6", "rmb"; + + interrupts-extended = <&intc GIC_SPI 24 IRQ_TYPE_EDGE_RISING>, + <&hexagon_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&hexagon_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&hexagon_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&hexagon_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + power-domains = <&rpmpd MSM8916_VDDCX>, + <&rpmpd MSM8916_VDDMX>; + power-domain-names = "cx", "mx"; + + clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, + <&gcc GCC_MSS_Q6_BIMC_AXI_CLK>, + <&gcc GCC_BOOT_ROM_AHB_CLK>, + <&xo_board>; + clock-names = "iface", "bus", "mem", "xo"; + + qcom,smem-states = <&hexagon_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + resets = <&scm 0>; + reset-names = "mss_restart"; + + qcom,halt-regs = <&tcsr 0x18000 0x19000 0x1a000>; + + status = "disabled"; + + mba { + memory-region = <&mba_mem>; + }; + + mpss { + memory-region = <&mpss_mem>; + }; + + bam_dmux: bam-dmux { + compatible = "qcom,bam-dmux"; + + interrupt-parent = <&hexagon_smsm>; + interrupts = <1 IRQ_TYPE_EDGE_BOTH>, <11 IRQ_TYPE_EDGE_BOTH>; + interrupt-names = "pc", "pc-ack"; + + qcom,smem-states = <&apps_smsm 1>, <&apps_smsm 11>; + qcom,smem-state-names = "pc", "pc-ack"; + + dmas = <&bam_dmux_dma 4>, <&bam_dmux_dma 5>; + dma-names = "tx", "rx"; + + status = "disabled"; + }; + + smd-edge { + interrupts = <GIC_SPI 25 IRQ_TYPE_EDGE_RISING>; + + qcom,smd-edge = <0>; + qcom,ipc = <&apcs 8 12>; + qcom,remote-pid = <1>; + + label = "hexagon"; + + fastrpc { + compatible = "qcom,fastrpc"; + qcom,smd-channels = "fastrpcsmd-apps-dsp"; + label = "adsp"; + qcom,non-secure-domain; + + #address-cells = <1>; + #size-cells = <0>; + + cb@1 { + compatible = "qcom,fastrpc-compute-cb"; + reg = <1>; + }; + }; + }; + }; + + sound: sound@7702000 { + status = "disabled"; + compatible = "qcom,apq8016-sbc-sndcard"; + reg = <0x07702000 0x4>, <0x07702004 0x4>; + reg-names = "mic-iomux", "spkr-iomux"; + }; + + lpass: audio-controller@7708000 { + status = "disabled"; + compatible = "qcom,apq8016-lpass-cpu"; + + /* + * Note: Unlike the name would suggest, the SEC_I2S_CLK + * is actually only used by Tertiary MI2S while + * Primary/Secondary MI2S both use the PRI_I2S_CLK. + */ + clocks = <&gcc GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK>, + <&gcc GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK>, + <&gcc GCC_ULTAUDIO_LPAIF_PRI_I2S_CLK>, + <&gcc GCC_ULTAUDIO_LPAIF_SEC_I2S_CLK>, + <&gcc GCC_ULTAUDIO_LPAIF_AUX_I2S_CLK>, + <&gcc GCC_ULTAUDIO_PCNOC_MPORT_CLK>, + <&gcc GCC_ULTAUDIO_PCNOC_SWAY_CLK>; + + clock-names = "ahbix-clk", + "mi2s-bit-clk0", + "mi2s-bit-clk1", + "mi2s-bit-clk2", + "mi2s-bit-clk3", + "pcnoc-mport-clk", + "pcnoc-sway-clk"; + #sound-dai-cells = <1>; + + interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "lpass-irq-lpaif"; + reg = <0x07708000 0x10000>; + reg-names = "lpass-lpaif"; + + #address-cells = <1>; + #size-cells = <0>; + }; + + lpass_codec: audio-codec@771c000 { + compatible = "qcom,msm8916-wcd-digital-codec"; + reg = <0x0771c000 0x400>; + clocks = <&gcc GCC_ULTAUDIO_AHBFABRIC_IXFABRIC_CLK>, + <&gcc GCC_CODEC_DIGCODEC_CLK>; + clock-names = "ahbix-clk", "mclk"; + #sound-dai-cells = <1>; + status = "disabled"; + }; + + sdhc_1: mmc@7824900 { + compatible = "qcom,msm8916-sdhci", "qcom,sdhci-msm-v4"; + reg = <0x07824900 0x11c>, <0x07824000 0x800>; + reg-names = "hc", "core"; + + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + clocks = <&gcc GCC_SDCC1_AHB_CLK>, + <&gcc GCC_SDCC1_APPS_CLK>, + <&xo_board>; + clock-names = "iface", "core", "xo"; + pinctrl-0 = <&sdc1_default>; + pinctrl-1 = <&sdc1_sleep>; + pinctrl-names = "default", "sleep"; + mmc-ddr-1_8v; + bus-width = <8>; + non-removable; + status = "disabled"; + }; + + sdhc_2: mmc@7864900 { + compatible = "qcom,msm8916-sdhci", "qcom,sdhci-msm-v4"; + reg = <0x07864900 0x11c>, <0x07864000 0x800>; + reg-names = "hc", "core"; + + interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + clocks = <&gcc GCC_SDCC2_AHB_CLK>, + <&gcc GCC_SDCC2_APPS_CLK>, + <&xo_board>; + clock-names = "iface", "core", "xo"; + pinctrl-0 = <&sdc2_default>; + pinctrl-1 = <&sdc2_sleep>; + pinctrl-names = "default", "sleep"; + bus-width = <4>; + status = "disabled"; + }; + + blsp_dma: dma-controller@7884000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x07884000 0x23000>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "bam_clk"; + #dma-cells = <1>; + qcom,ee = <0>; + }; + + blsp_uart1: serial@78af000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078af000 0x200>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART1_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 0>, <&blsp_dma 1>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_uart1_default>; + pinctrl-1 = <&blsp_uart1_sleep>; + status = "disabled"; + }; + + blsp_uart2: serial@78b0000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078b0000 0x200>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 2>, <&blsp_dma 3>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_uart2_default>; + pinctrl-1 = <&blsp_uart2_sleep>; + status = "disabled"; + }; + + blsp_i2c1: i2c@78b5000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b5000 0x500>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP1_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 4>, <&blsp_dma 5>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c1_default>; + pinctrl-1 = <&blsp_i2c1_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi1: spi@78b5000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b5000 0x500>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 4>, <&blsp_dma 5>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi1_default>; + pinctrl-1 = <&blsp_spi1_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_i2c2: i2c@78b6000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b6000 0x500>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP2_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 6>, <&blsp_dma 7>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c2_default>; + pinctrl-1 = <&blsp_i2c2_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi2: spi@78b6000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b6000 0x500>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP2_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 6>, <&blsp_dma 7>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi2_default>; + pinctrl-1 = <&blsp_spi2_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_i2c3: i2c@78b7000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b7000 0x500>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 8>, <&blsp_dma 9>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c3_default>; + pinctrl-1 = <&blsp_i2c3_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi3: spi@78b7000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b7000 0x500>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP3_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 8>, <&blsp_dma 9>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi3_default>; + pinctrl-1 = <&blsp_spi3_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_i2c4: i2c@78b8000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b8000 0x500>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP4_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 10>, <&blsp_dma 11>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c4_default>; + pinctrl-1 = <&blsp_i2c4_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi4: spi@78b8000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b8000 0x500>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP4_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 10>, <&blsp_dma 11>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi4_default>; + pinctrl-1 = <&blsp_spi4_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_i2c5: i2c@78b9000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b9000 0x500>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP5_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 12>, <&blsp_dma 13>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c5_default>; + pinctrl-1 = <&blsp_i2c5_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi5: spi@78b9000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b9000 0x500>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP5_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 12>, <&blsp_dma 13>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi5_default>; + pinctrl-1 = <&blsp_spi5_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_i2c6: i2c@78ba000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078ba000 0x500>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP6_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 14>, <&blsp_dma 15>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_i2c6_default>; + pinctrl-1 = <&blsp_i2c6_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp_spi6: spi@78ba000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078ba000 0x500>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP6_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp_dma 14>, <&blsp_dma 15>; + dma-names = "tx", "rx"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp_spi6_default>; + pinctrl-1 = <&blsp_spi6_sleep>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + usb: usb@78d9000 { + compatible = "qcom,ci-hdrc"; + reg = <0x078d9000 0x200>, + <0x078d9200 0x200>; + interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_USB_HS_AHB_CLK>, + <&gcc GCC_USB_HS_SYSTEM_CLK>; + clock-names = "iface", "core"; + assigned-clocks = <&gcc GCC_USB_HS_SYSTEM_CLK>; + assigned-clock-rates = <80000000>; + resets = <&gcc GCC_USB_HS_BCR>; + reset-names = "core"; + phy_type = "ulpi"; + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + ahb-burst-config = <0>; + phy-names = "usb-phy"; + phys = <&usb_hs_phy>; + status = "disabled"; + #reset-cells = <1>; + + ulpi { + usb_hs_phy: phy { + compatible = "qcom,usb-hs-phy-msm8916", + "qcom,usb-hs-phy"; + #phy-cells = <0>; + clocks = <&xo_board>, <&gcc GCC_USB2A_PHY_SLEEP_CLK>; + clock-names = "ref", "sleep"; + resets = <&gcc GCC_USB2A_PHY_BCR>, <&usb 0>; + reset-names = "phy", "por"; + qcom,init-seq = /bits/ 8 <0x0 0x44>, + <0x1 0x6b>, + <0x2 0x24>, + <0x3 0x13>; + }; + }; + }; + + wcnss: remoteproc@a204000 { + compatible = "qcom,pronto-v2-pil", "qcom,pronto"; + reg = <0x0a204000 0x2000>, <0x0a202000 0x1000>, <0x0a21b000 0x3000>; + reg-names = "ccu", "dxe", "pmu"; + + memory-region = <&wcnss_mem>; + + interrupts-extended = <&intc GIC_SPI 149 IRQ_TYPE_EDGE_RISING>, + <&wcnss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&wcnss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&wcnss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&wcnss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", "handover", "stop-ack"; + + power-domains = <&rpmpd MSM8916_VDDCX>, + <&rpmpd MSM8916_VDDMX>; + power-domain-names = "cx", "mx"; + + qcom,smem-states = <&wcnss_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + pinctrl-names = "default"; + pinctrl-0 = <&wcss_wlan_default>; + + status = "disabled"; + + wcnss_iris: iris { + /* Separate chip, compatible is board-specific */ + clocks = <&rpmcc RPM_SMD_RF_CLK2>; + clock-names = "xo"; + }; + + smd-edge { + interrupts = <GIC_SPI 142 IRQ_TYPE_EDGE_RISING>; + + qcom,ipc = <&apcs 8 17>; + qcom,smd-edge = <6>; + qcom,remote-pid = <4>; + + label = "pronto"; + + wcnss_ctrl: wcnss { + compatible = "qcom,wcnss"; + qcom,smd-channels = "WCNSS_CTRL"; + + qcom,mmio = <&wcnss>; + + wcnss_bt: bluetooth { + compatible = "qcom,wcnss-bt"; + }; + + wcnss_wifi: wifi { + compatible = "qcom,wcnss-wlan"; + + interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "tx", "rx"; + + qcom,smem-states = <&apps_smsm 10>, <&apps_smsm 9>; + qcom,smem-state-names = "tx-enable", "tx-rings-empty"; + }; + }; + }; + }; + + intc: interrupt-controller@b000000 { + compatible = "qcom,msm-qgic2"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x0b000000 0x1000>, <0x0b002000 0x2000>, + <0x0b001000 0x1000>, <0x0b004000 0x2000>; + interrupts = <GIC_PPI 0 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + apcs: mailbox@b011000 { + compatible = "qcom,msm8916-apcs-kpss-global", "syscon"; + reg = <0x0b011000 0x1000>; + #mbox-cells = <1>; + clocks = <&a53pll>, <&gcc GPLL0_VOTE>; + clock-names = "pll", "aux"; + #clock-cells = <0>; + }; + + a53pll: clock@b016000 { + compatible = "qcom,msm8916-a53pll"; + reg = <0x0b016000 0x40>; + #clock-cells = <0>; + clocks = <&xo_board>; + clock-names = "xo"; + }; + + timer@b020000 { + #address-cells = <1>; + #size-cells = <1>; + ranges; + compatible = "arm,armv7-timer-mem"; + reg = <0x0b020000 0x1000>; + clock-frequency = <19200000>; + + frame@b021000 { + frame-number = <0>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b021000 0x1000>, + <0x0b022000 0x1000>; + }; + + frame@b023000 { + frame-number = <1>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b023000 0x1000>; + status = "disabled"; + }; + + frame@b024000 { + frame-number = <2>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b024000 0x1000>; + status = "disabled"; + }; + + frame@b025000 { + frame-number = <3>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b025000 0x1000>; + status = "disabled"; + }; + + frame@b026000 { + frame-number = <4>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b026000 0x1000>; + status = "disabled"; + }; + + frame@b027000 { + frame-number = <5>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b027000 0x1000>; + status = "disabled"; + }; + + frame@b028000 { + frame-number = <6>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b028000 0x1000>; + status = "disabled"; + }; + }; + + cpu0_acc: power-manager@b088000 { + compatible = "qcom,msm8916-acc"; + reg = <0x0b088000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu0_saw: power-manager@b089000 { + compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; + reg = <0x0b089000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu1_acc: power-manager@b098000 { + compatible = "qcom,msm8916-acc"; + reg = <0x0b098000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu1_saw: power-manager@b099000 { + compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; + reg = <0x0b099000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu2_acc: power-manager@b0a8000 { + compatible = "qcom,msm8916-acc"; + reg = <0x0b0a8000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu2_saw: power-manager@b0a9000 { + compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; + reg = <0x0b0a9000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu3_acc: power-manager@b0b8000 { + compatible = "qcom,msm8916-acc"; + reg = <0x0b0b8000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + + cpu3_saw: power-manager@b0b9000 { + compatible = "qcom,msm8916-saw2-v3.0-cpu", "qcom,saw2"; + reg = <0x0b0b9000 0x1000>; + status = "reserved"; /* Controlled by PSCI firmware */ + }; + }; + + thermal-zones { + cpu0-1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 5>; + + trips { + cpu0_1_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu0_1_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu0_1_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu2-3-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 4>; + + trips { + cpu2_3_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu2_3_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + + cooling-maps { + map0 { + trip = <&cpu2_3_alert0>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 2>; + + trips { + gpu_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + gpu_crit: gpu-crit { + temperature = <95000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + camera-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 1>; + + trips { + cam_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 0>; + + trips { + modem_alert0: trip-point0 { + temperature = <85000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 2 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 3 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 4 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 1 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; +}; diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 4274150eebe9..453cb9d04c7e 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 -CONFIG_DEFAULT_DEVICE_TREE="dragonboard410c" +CONFIG_DEFAULT_DEVICE_TREE="apq8016-sbc" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 410C" CONFIG_SYS_LOAD_ADDR=0x80080000
On 19/12/2023 17:04, Caleb Connolly wrote:
Drop the U-Boot specific dragonboard410c.dts in favour of the upstream msm8916-sbc.dts. No additional changes are needed to this DTS for U-Boot support.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
arch/arm/dts/Makefile | 2 +- arch/arm/dts/apq8016-sbc.dts | 729 +++++++++ arch/arm/dts/dragonboard410c-uboot.dtsi | 44 - arch/arm/dts/dragonboard410c.dts | 209 +-- arch/arm/dts/msm8916.dtsi | 2702 +++++++++++++++++++++++++++++++ configs/dragonboard410c_defconfig | 2 +- 6 files changed, 3472 insertions(+), 216 deletions(-)
<snip> Same as patch 19, with the commit id:
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Import dt-binding headers for MSM8996/APQ8096 from Linux.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/qcom,gcc-msm8996.h | 360 +++++++++++++++++++++ include/dt-bindings/clock/qcom,mmcc-msm8996.h | 295 +++++++++++++++++ .../dt-bindings/interconnect/qcom,msm8996-cbf.h | 12 + include/dt-bindings/interconnect/qcom,msm8996.h | 163 ++++++++++ include/dt-bindings/sound/qcom,wcd9335.h | 15 + 5 files changed, 845 insertions(+)
diff --git a/include/dt-bindings/clock/qcom,gcc-msm8996.h b/include/dt-bindings/clock/qcom,gcc-msm8996.h new file mode 100644 index 000000000000..45b320503905 --- /dev/null +++ b/include/dt-bindings/clock/qcom,gcc-msm8996.h @@ -0,0 +1,360 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (c) 2015, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_MSM_GCC_8996_H +#define _DT_BINDINGS_CLK_MSM_GCC_8996_H + +#define GPLL0_EARLY 0 +#define GPLL0 1 +#define GPLL1_EARLY 2 +#define GPLL1 3 +#define GPLL2_EARLY 4 +#define GPLL2 5 +#define GPLL3_EARLY 6 +#define GPLL3 7 +#define GPLL4_EARLY 8 +#define GPLL4 9 +#define SYSTEM_NOC_CLK_SRC 10 +// U-Boot: Breaks CI, this clock is unused anyway +/* #define CONFIG_NOC_CLK_SRC 11 */ +#define PERIPH_NOC_CLK_SRC 12 +#define MMSS_BIMC_GFX_CLK_SRC 13 +#define USB30_MASTER_CLK_SRC 14 +#define USB30_MOCK_UTMI_CLK_SRC 15 +#define USB3_PHY_AUX_CLK_SRC 16 +#define USB20_MASTER_CLK_SRC 17 +#define USB20_MOCK_UTMI_CLK_SRC 18 +#define SDCC1_APPS_CLK_SRC 19 +#define SDCC1_ICE_CORE_CLK_SRC 20 +#define SDCC2_APPS_CLK_SRC 21 +#define SDCC3_APPS_CLK_SRC 22 +#define SDCC4_APPS_CLK_SRC 23 +#define BLSP1_QUP1_SPI_APPS_CLK_SRC 24 +#define BLSP1_QUP1_I2C_APPS_CLK_SRC 25 +#define BLSP1_UART1_APPS_CLK_SRC 26 +#define BLSP1_QUP2_SPI_APPS_CLK_SRC 27 +#define BLSP1_QUP2_I2C_APPS_CLK_SRC 28 +#define BLSP1_UART2_APPS_CLK_SRC 29 +#define BLSP1_QUP3_SPI_APPS_CLK_SRC 30 +#define BLSP1_QUP3_I2C_APPS_CLK_SRC 31 +#define BLSP1_UART3_APPS_CLK_SRC 32 +#define BLSP1_QUP4_SPI_APPS_CLK_SRC 33 +#define BLSP1_QUP4_I2C_APPS_CLK_SRC 34 +#define BLSP1_UART4_APPS_CLK_SRC 35 +#define BLSP1_QUP5_SPI_APPS_CLK_SRC 36 +#define BLSP1_QUP5_I2C_APPS_CLK_SRC 37 +#define BLSP1_UART5_APPS_CLK_SRC 38 +#define BLSP1_QUP6_SPI_APPS_CLK_SRC 39 +#define BLSP1_QUP6_I2C_APPS_CLK_SRC 40 +#define BLSP1_UART6_APPS_CLK_SRC 41 +#define BLSP2_QUP1_SPI_APPS_CLK_SRC 42 +#define BLSP2_QUP1_I2C_APPS_CLK_SRC 43 +#define BLSP2_UART1_APPS_CLK_SRC 44 +#define BLSP2_QUP2_SPI_APPS_CLK_SRC 45 +#define BLSP2_QUP2_I2C_APPS_CLK_SRC 46 +#define BLSP2_UART2_APPS_CLK_SRC 47 +#define BLSP2_QUP3_SPI_APPS_CLK_SRC 48 +#define BLSP2_QUP3_I2C_APPS_CLK_SRC 49 +#define BLSP2_UART3_APPS_CLK_SRC 50 +#define BLSP2_QUP4_SPI_APPS_CLK_SRC 51 +#define BLSP2_QUP4_I2C_APPS_CLK_SRC 52 +#define BLSP2_UART4_APPS_CLK_SRC 53 +#define BLSP2_QUP5_SPI_APPS_CLK_SRC 54 +#define BLSP2_QUP5_I2C_APPS_CLK_SRC 55 +#define BLSP2_UART5_APPS_CLK_SRC 56 +#define BLSP2_QUP6_SPI_APPS_CLK_SRC 57 +#define BLSP2_QUP6_I2C_APPS_CLK_SRC 58 +#define BLSP2_UART6_APPS_CLK_SRC 59 +#define PDM2_CLK_SRC 60 +#define TSIF_REF_CLK_SRC 61 +#define CE1_CLK_SRC 62 +#define GCC_SLEEP_CLK_SRC 63 +#define BIMC_CLK_SRC 64 +#define HMSS_AHB_CLK_SRC 65 +#define BIMC_HMSS_AXI_CLK_SRC 66 +#define HMSS_RBCPR_CLK_SRC 67 +#define HMSS_GPLL0_CLK_SRC 68 +#define GP1_CLK_SRC 69 +#define GP2_CLK_SRC 70 +#define GP3_CLK_SRC 71 +#define PCIE_AUX_CLK_SRC 72 +#define UFS_AXI_CLK_SRC 73 +#define UFS_ICE_CORE_CLK_SRC 74 +#define QSPI_SER_CLK_SRC 75 +#define GCC_SYS_NOC_AXI_CLK 76 +#define GCC_SYS_NOC_HMSS_AHB_CLK 77 +#define GCC_SNOC_CNOC_AHB_CLK 78 +#define GCC_SNOC_PNOC_AHB_CLK 79 +#define GCC_SYS_NOC_AT_CLK 80 +#define GCC_SYS_NOC_USB3_AXI_CLK 81 +#define GCC_SYS_NOC_UFS_AXI_CLK 82 +#define GCC_CFG_NOC_AHB_CLK 83 +#define GCC_PERIPH_NOC_AHB_CLK 84 +#define GCC_PERIPH_NOC_USB20_AHB_CLK 85 +#define GCC_TIC_CLK 86 +#define GCC_IMEM_AXI_CLK 87 +#define GCC_MMSS_SYS_NOC_AXI_CLK 88 +#define GCC_MMSS_NOC_CFG_AHB_CLK 89 +#define GCC_MMSS_BIMC_GFX_CLK 90 +#define GCC_USB30_MASTER_CLK 91 +#define GCC_USB30_SLEEP_CLK 92 +#define GCC_USB30_MOCK_UTMI_CLK 93 +#define GCC_USB3_PHY_AUX_CLK 94 +#define GCC_USB3_PHY_PIPE_CLK 95 +#define GCC_USB20_MASTER_CLK 96 +#define GCC_USB20_SLEEP_CLK 97 +#define GCC_USB20_MOCK_UTMI_CLK 98 +#define GCC_USB_PHY_CFG_AHB2PHY_CLK 99 +#define GCC_SDCC1_APPS_CLK 100 +#define GCC_SDCC1_AHB_CLK 101 +#define GCC_SDCC1_ICE_CORE_CLK 102 +#define GCC_SDCC2_APPS_CLK 103 +#define GCC_SDCC2_AHB_CLK 104 +#define GCC_SDCC3_APPS_CLK 105 +#define GCC_SDCC3_AHB_CLK 106 +#define GCC_SDCC4_APPS_CLK 107 +#define GCC_SDCC4_AHB_CLK 108 +#define GCC_BLSP1_AHB_CLK 109 +#define GCC_BLSP1_SLEEP_CLK 110 +#define GCC_BLSP1_QUP1_SPI_APPS_CLK 111 +#define GCC_BLSP1_QUP1_I2C_APPS_CLK 112 +#define GCC_BLSP1_UART1_APPS_CLK 113 +#define GCC_BLSP1_QUP2_SPI_APPS_CLK 114 +#define GCC_BLSP1_QUP2_I2C_APPS_CLK 115 +#define GCC_BLSP1_UART2_APPS_CLK 116 +#define GCC_BLSP1_QUP3_SPI_APPS_CLK 117 +#define GCC_BLSP1_QUP3_I2C_APPS_CLK 118 +#define GCC_BLSP1_UART3_APPS_CLK 119 +#define GCC_BLSP1_QUP4_SPI_APPS_CLK 120 +#define GCC_BLSP1_QUP4_I2C_APPS_CLK 121 +#define GCC_BLSP1_UART4_APPS_CLK 122 +#define GCC_BLSP1_QUP5_SPI_APPS_CLK 123 +#define GCC_BLSP1_QUP5_I2C_APPS_CLK 124 +#define GCC_BLSP1_UART5_APPS_CLK 125 +#define GCC_BLSP1_QUP6_SPI_APPS_CLK 126 +#define GCC_BLSP1_QUP6_I2C_APPS_CLK 127 +#define GCC_BLSP1_UART6_APPS_CLK 128 +#define GCC_BLSP2_AHB_CLK 129 +#define GCC_BLSP2_SLEEP_CLK 130 +#define GCC_BLSP2_QUP1_SPI_APPS_CLK 131 +#define GCC_BLSP2_QUP1_I2C_APPS_CLK 132 +#define GCC_BLSP2_UART1_APPS_CLK 133 +#define GCC_BLSP2_QUP2_SPI_APPS_CLK 134 +#define GCC_BLSP2_QUP2_I2C_APPS_CLK 135 +#define GCC_BLSP2_UART2_APPS_CLK 136 +#define GCC_BLSP2_QUP3_SPI_APPS_CLK 137 +#define GCC_BLSP2_QUP3_I2C_APPS_CLK 138 +#define GCC_BLSP2_UART3_APPS_CLK 139 +#define GCC_BLSP2_QUP4_SPI_APPS_CLK 140 +#define GCC_BLSP2_QUP4_I2C_APPS_CLK 141 +#define GCC_BLSP2_UART4_APPS_CLK 142 +#define GCC_BLSP2_QUP5_SPI_APPS_CLK 143 +#define GCC_BLSP2_QUP5_I2C_APPS_CLK 144 +#define GCC_BLSP2_UART5_APPS_CLK 145 +#define GCC_BLSP2_QUP6_SPI_APPS_CLK 146 +#define GCC_BLSP2_QUP6_I2C_APPS_CLK 147 +#define GCC_BLSP2_UART6_APPS_CLK 148 +#define GCC_PDM_AHB_CLK 149 +#define GCC_PDM_XO4_CLK 150 +#define GCC_PDM2_CLK 151 +#define GCC_PRNG_AHB_CLK 152 +#define GCC_TSIF_AHB_CLK 153 +#define GCC_TSIF_REF_CLK 154 +#define GCC_TSIF_INACTIVITY_TIMERS_CLK 155 +#define GCC_TCSR_AHB_CLK 156 +#define GCC_BOOT_ROM_AHB_CLK 157 +#define GCC_MSG_RAM_AHB_CLK 158 +#define GCC_TLMM_AHB_CLK 159 +#define GCC_TLMM_CLK 160 +#define GCC_MPM_AHB_CLK 161 +#define GCC_SPMI_SER_CLK 162 +#define GCC_SPMI_CNOC_AHB_CLK 163 +#define GCC_CE1_CLK 164 +#define GCC_CE1_AXI_CLK 165 +#define GCC_CE1_AHB_CLK 166 +#define GCC_BIMC_HMSS_AXI_CLK 167 +#define GCC_BIMC_GFX_CLK 168 +#define GCC_HMSS_AHB_CLK 169 +#define GCC_HMSS_SLV_AXI_CLK 170 +#define GCC_HMSS_MSTR_AXI_CLK 171 +#define GCC_HMSS_RBCPR_CLK 172 +#define GCC_GP1_CLK 173 +#define GCC_GP2_CLK 174 +#define GCC_GP3_CLK 175 +#define GCC_PCIE_0_SLV_AXI_CLK 176 +#define GCC_PCIE_0_MSTR_AXI_CLK 177 +#define GCC_PCIE_0_CFG_AHB_CLK 178 +#define GCC_PCIE_0_AUX_CLK 179 +#define GCC_PCIE_0_PIPE_CLK 180 +#define GCC_PCIE_1_SLV_AXI_CLK 181 +#define GCC_PCIE_1_MSTR_AXI_CLK 182 +#define GCC_PCIE_1_CFG_AHB_CLK 183 +#define GCC_PCIE_1_AUX_CLK 184 +#define GCC_PCIE_1_PIPE_CLK 185 +#define GCC_PCIE_2_SLV_AXI_CLK 186 +#define GCC_PCIE_2_MSTR_AXI_CLK 187 +#define GCC_PCIE_2_CFG_AHB_CLK 188 +#define GCC_PCIE_2_AUX_CLK 189 +#define GCC_PCIE_2_PIPE_CLK 190 +#define GCC_PCIE_PHY_CFG_AHB_CLK 191 +#define GCC_PCIE_PHY_AUX_CLK 192 +#define GCC_UFS_AXI_CLK 193 +#define GCC_UFS_AHB_CLK 194 +#define GCC_UFS_TX_CFG_CLK 195 +#define GCC_UFS_RX_CFG_CLK 196 +#define GCC_UFS_TX_SYMBOL_0_CLK 197 +#define GCC_UFS_RX_SYMBOL_0_CLK 198 +#define GCC_UFS_RX_SYMBOL_1_CLK 199 +#define GCC_UFS_UNIPRO_CORE_CLK 200 +#define GCC_UFS_ICE_CORE_CLK 201 +#define GCC_UFS_SYS_CLK_CORE_CLK 202 +#define GCC_UFS_TX_SYMBOL_CLK_CORE_CLK 203 +#define GCC_AGGRE0_SNOC_AXI_CLK 204 +#define GCC_AGGRE0_CNOC_AHB_CLK 205 +#define GCC_SMMU_AGGRE0_AXI_CLK 206 +#define GCC_SMMU_AGGRE0_AHB_CLK 207 +#define GCC_AGGRE1_PNOC_AHB_CLK 208 +#define GCC_AGGRE2_UFS_AXI_CLK 209 +#define GCC_AGGRE2_USB3_AXI_CLK 210 +#define GCC_QSPI_AHB_CLK 211 +#define GCC_QSPI_SER_CLK 212 +#define GCC_USB3_CLKREF_CLK 213 +#define GCC_HDMI_CLKREF_CLK 214 +#define GCC_UFS_CLKREF_CLK 215 +#define GCC_PCIE_CLKREF_CLK 216 +#define GCC_RX2_USB2_CLKREF_CLK 217 +#define GCC_RX1_USB2_CLKREF_CLK 218 +#define GCC_HLOS1_VOTE_LPASS_CORE_SMMU_CLK 219 +#define GCC_HLOS1_VOTE_LPASS_ADSP_SMMU_CLK 220 +#define GCC_EDP_CLKREF_CLK 221 +#define GCC_MSS_CFG_AHB_CLK 222 +#define GCC_MSS_Q6_BIMC_AXI_CLK 223 +#define GCC_MSS_SNOC_AXI_CLK 224 +#define GCC_MSS_MNOC_BIMC_AXI_CLK 225 +#define GCC_DCC_AHB_CLK 226 +#define GCC_AGGRE0_NOC_MPU_CFG_AHB_CLK 227 +#define GCC_MMSS_GPLL0_DIV_CLK 228 +#define GCC_MSS_GPLL0_DIV_CLK 229 + +#define GCC_SYSTEM_NOC_BCR 0 +#define GCC_CONFIG_NOC_BCR 1 +#define GCC_PERIPH_NOC_BCR 2 +#define GCC_IMEM_BCR 3 +#define GCC_MMSS_BCR 4 +#define GCC_PIMEM_BCR 5 +#define GCC_QDSS_BCR 6 +#define GCC_USB_30_BCR 7 +#define GCC_USB_20_BCR 8 +#define GCC_QUSB2PHY_PRIM_BCR 9 +#define GCC_QUSB2PHY_SEC_BCR 10 +#define GCC_USB_PHY_CFG_AHB2PHY_BCR 11 +#define GCC_SDCC1_BCR 12 +#define GCC_SDCC2_BCR 13 +#define GCC_SDCC3_BCR 14 +#define GCC_SDCC4_BCR 15 +#define GCC_BLSP1_BCR 16 +#define GCC_BLSP1_QUP1_BCR 17 +#define GCC_BLSP1_UART1_BCR 18 +#define GCC_BLSP1_QUP2_BCR 19 +#define GCC_BLSP1_UART2_BCR 20 +#define GCC_BLSP1_QUP3_BCR 21 +#define GCC_BLSP1_UART3_BCR 22 +#define GCC_BLSP1_QUP4_BCR 23 +#define GCC_BLSP1_UART4_BCR 24 +#define GCC_BLSP1_QUP5_BCR 25 +#define GCC_BLSP1_UART5_BCR 26 +#define GCC_BLSP1_QUP6_BCR 27 +#define GCC_BLSP1_UART6_BCR 28 +#define GCC_BLSP2_BCR 29 +#define GCC_BLSP2_QUP1_BCR 30 +#define GCC_BLSP2_UART1_BCR 31 +#define GCC_BLSP2_QUP2_BCR 32 +#define GCC_BLSP2_UART2_BCR 33 +#define GCC_BLSP2_QUP3_BCR 34 +#define GCC_BLSP2_UART3_BCR 35 +#define GCC_BLSP2_QUP4_BCR 36 +#define GCC_BLSP2_UART4_BCR 37 +#define GCC_BLSP2_QUP5_BCR 38 +#define GCC_BLSP2_UART5_BCR 39 +#define GCC_BLSP2_QUP6_BCR 40 +#define GCC_BLSP2_UART6_BCR 41 +#define GCC_PDM_BCR 42 +#define GCC_PRNG_BCR 43 +#define GCC_TSIF_BCR 44 +#define GCC_TCSR_BCR 45 +#define GCC_BOOT_ROM_BCR 46 +#define GCC_MSG_RAM_BCR 47 +#define GCC_TLMM_BCR 48 +#define GCC_MPM_BCR 49 +#define GCC_SEC_CTRL_BCR 50 +#define GCC_SPMI_BCR 51 +#define GCC_SPDM_BCR 52 +#define GCC_CE1_BCR 53 +#define GCC_BIMC_BCR 54 +#define GCC_SNOC_BUS_TIMEOUT0_BCR 55 +#define GCC_SNOC_BUS_TIMEOUT2_BCR 56 +#define GCC_SNOC_BUS_TIMEOUT1_BCR 57 +#define GCC_SNOC_BUS_TIMEOUT3_BCR 58 +#define GCC_SNOC_BUS_TIMEOUT_EXTREF_BCR 59 +#define GCC_PNOC_BUS_TIMEOUT0_BCR 60 +#define GCC_PNOC_BUS_TIMEOUT1_BCR 61 +#define GCC_PNOC_BUS_TIMEOUT2_BCR 62 +#define GCC_PNOC_BUS_TIMEOUT3_BCR 63 +#define GCC_PNOC_BUS_TIMEOUT4_BCR 64 +#define GCC_CNOC_BUS_TIMEOUT0_BCR 65 +#define GCC_CNOC_BUS_TIMEOUT1_BCR 66 +#define GCC_CNOC_BUS_TIMEOUT2_BCR 67 +#define GCC_CNOC_BUS_TIMEOUT3_BCR 68 +#define GCC_CNOC_BUS_TIMEOUT4_BCR 69 +#define GCC_CNOC_BUS_TIMEOUT5_BCR 70 +#define GCC_CNOC_BUS_TIMEOUT6_BCR 71 +#define GCC_CNOC_BUS_TIMEOUT7_BCR 72 +#define GCC_CNOC_BUS_TIMEOUT8_BCR 73 +#define GCC_CNOC_BUS_TIMEOUT9_BCR 74 +#define GCC_CNOC_BUS_TIMEOUT_EXTREF_BCR 75 +#define GCC_APB2JTAG_BCR 76 +#define GCC_RBCPR_CX_BCR 77 +#define GCC_RBCPR_MX_BCR 78 +#define GCC_PCIE_0_BCR 79 +#define GCC_PCIE_0_PHY_BCR 80 +#define GCC_PCIE_1_BCR 81 +#define GCC_PCIE_1_PHY_BCR 82 +#define GCC_PCIE_2_BCR 83 +#define GCC_PCIE_2_PHY_BCR 84 +#define GCC_PCIE_PHY_BCR 85 +#define GCC_DCD_BCR 86 +#define GCC_OBT_ODT_BCR 87 +#define GCC_UFS_BCR 88 +#define GCC_SSC_BCR 89 +#define GCC_VS_BCR 90 +#define GCC_AGGRE0_NOC_BCR 91 +#define GCC_AGGRE1_NOC_BCR 92 +#define GCC_AGGRE2_NOC_BCR 93 +#define GCC_DCC_BCR 94 +#define GCC_IPA_BCR 95 +#define GCC_QSPI_BCR 96 +#define GCC_SKL_BCR 97 +#define GCC_MSMPU_BCR 98 +#define GCC_MSS_Q6_BCR 99 +#define GCC_QREFS_VBG_CAL_BCR 100 +#define GCC_PCIE_PHY_COM_BCR 101 +#define GCC_PCIE_PHY_COM_NOCSR_BCR 102 +#define GCC_USB3_PHY_BCR 103 +#define GCC_USB3PHY_PHY_BCR 104 +#define GCC_MSS_RESTART 105 + + +/* Indexes for GDSCs */ +#define AGGRE0_NOC_GDSC 0 +#define HLOS1_VOTE_AGGRE0_NOC_GDSC 1 +#define HLOS1_VOTE_LPASS_ADSP_GDSC 2 +#define HLOS1_VOTE_LPASS_CORE_GDSC 3 +#define USB30_GDSC 4 +#define PCIE0_GDSC 5 +#define PCIE1_GDSC 6 +#define PCIE2_GDSC 7 +#define UFS_GDSC 8 + +#endif diff --git a/include/dt-bindings/clock/qcom,mmcc-msm8996.h b/include/dt-bindings/clock/qcom,mmcc-msm8996.h new file mode 100644 index 000000000000..d51f9ac70566 --- /dev/null +++ b/include/dt-bindings/clock/qcom,mmcc-msm8996.h @@ -0,0 +1,295 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (c) 2015, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_MSM_MMCC_8996_H +#define _DT_BINDINGS_CLK_MSM_MMCC_8996_H + +#define MMPLL0_EARLY 0 +#define MMPLL0_PLL 1 +#define MMPLL1_EARLY 2 +#define MMPLL1_PLL 3 +#define MMPLL2_EARLY 4 +#define MMPLL2_PLL 5 +#define MMPLL3_EARLY 6 +#define MMPLL3_PLL 7 +#define MMPLL4_EARLY 8 +#define MMPLL4_PLL 9 +#define MMPLL5_EARLY 10 +#define MMPLL5_PLL 11 +#define MMPLL8_EARLY 12 +#define MMPLL8_PLL 13 +#define MMPLL9_EARLY 14 +#define MMPLL9_PLL 15 +#define AHB_CLK_SRC 16 +#define AXI_CLK_SRC 17 +#define MAXI_CLK_SRC 18 +#define DSA_CORE_CLK_SRC 19 +#define GFX3D_CLK_SRC 20 +#define RBBMTIMER_CLK_SRC 21 +#define ISENSE_CLK_SRC 22 +#define RBCPR_CLK_SRC 23 +#define VIDEO_CORE_CLK_SRC 24 +#define VIDEO_SUBCORE0_CLK_SRC 25 +#define VIDEO_SUBCORE1_CLK_SRC 26 +#define PCLK0_CLK_SRC 27 +#define PCLK1_CLK_SRC 28 +#define MDP_CLK_SRC 29 +#define EXTPCLK_CLK_SRC 30 +#define VSYNC_CLK_SRC 31 +#define HDMI_CLK_SRC 32 +#define BYTE0_CLK_SRC 33 +#define BYTE1_CLK_SRC 34 +#define ESC0_CLK_SRC 35 +#define ESC1_CLK_SRC 36 +#define CAMSS_GP0_CLK_SRC 37 +#define CAMSS_GP1_CLK_SRC 38 +#define MCLK0_CLK_SRC 39 +#define MCLK1_CLK_SRC 40 +#define MCLK2_CLK_SRC 41 +#define MCLK3_CLK_SRC 42 +#define CCI_CLK_SRC 43 +#define CSI0PHYTIMER_CLK_SRC 44 +#define CSI1PHYTIMER_CLK_SRC 45 +#define CSI2PHYTIMER_CLK_SRC 46 +#define CSIPHY0_3P_CLK_SRC 47 +#define CSIPHY1_3P_CLK_SRC 48 +#define CSIPHY2_3P_CLK_SRC 49 +#define JPEG0_CLK_SRC 50 +#define JPEG2_CLK_SRC 51 +#define JPEG_DMA_CLK_SRC 52 +#define VFE0_CLK_SRC 53 +#define VFE1_CLK_SRC 54 +#define CPP_CLK_SRC 55 +#define CSI0_CLK_SRC 56 +#define CSI1_CLK_SRC 57 +#define CSI2_CLK_SRC 58 +#define CSI3_CLK_SRC 59 +#define FD_CORE_CLK_SRC 60 +#define MMSS_CXO_CLK 61 +#define MMSS_SLEEPCLK_CLK 62 +#define MMSS_MMAGIC_AHB_CLK 63 +#define MMSS_MMAGIC_CFG_AHB_CLK 64 +#define MMSS_MISC_AHB_CLK 65 +#define MMSS_MISC_CXO_CLK 66 +#define MMSS_BTO_AHB_CLK 67 +#define MMSS_MMAGIC_AXI_CLK 68 +#define MMSS_S0_AXI_CLK 69 +#define MMSS_MMAGIC_MAXI_CLK 70 +#define DSA_CORE_CLK 71 +#define DSA_NOC_CFG_AHB_CLK 72 +#define MMAGIC_CAMSS_AXI_CLK 73 +#define MMAGIC_CAMSS_NOC_CFG_AHB_CLK 74 +#define THROTTLE_CAMSS_CXO_CLK 75 +#define THROTTLE_CAMSS_AHB_CLK 76 +#define THROTTLE_CAMSS_AXI_CLK 77 +#define SMMU_VFE_AHB_CLK 78 +#define SMMU_VFE_AXI_CLK 79 +#define SMMU_CPP_AHB_CLK 80 +#define SMMU_CPP_AXI_CLK 81 +#define SMMU_JPEG_AHB_CLK 82 +#define SMMU_JPEG_AXI_CLK 83 +#define MMAGIC_MDSS_AXI_CLK 84 +#define MMAGIC_MDSS_NOC_CFG_AHB_CLK 85 +#define THROTTLE_MDSS_CXO_CLK 86 +#define THROTTLE_MDSS_AHB_CLK 87 +#define THROTTLE_MDSS_AXI_CLK 88 +#define SMMU_ROT_AHB_CLK 89 +#define SMMU_ROT_AXI_CLK 90 +#define SMMU_MDP_AHB_CLK 91 +#define SMMU_MDP_AXI_CLK 92 +#define MMAGIC_VIDEO_AXI_CLK 93 +#define MMAGIC_VIDEO_NOC_CFG_AHB_CLK 94 +#define THROTTLE_VIDEO_CXO_CLK 95 +#define THROTTLE_VIDEO_AHB_CLK 96 +#define THROTTLE_VIDEO_AXI_CLK 97 +#define SMMU_VIDEO_AHB_CLK 98 +#define SMMU_VIDEO_AXI_CLK 99 +#define MMAGIC_BIMC_AXI_CLK 100 +#define MMAGIC_BIMC_NOC_CFG_AHB_CLK 101 +#define GPU_GX_GFX3D_CLK 102 +#define GPU_GX_RBBMTIMER_CLK 103 +#define GPU_AHB_CLK 104 +#define GPU_AON_ISENSE_CLK 105 +#define VMEM_MAXI_CLK 106 +#define VMEM_AHB_CLK 107 +#define MMSS_RBCPR_CLK 108 +#define MMSS_RBCPR_AHB_CLK 109 +#define VIDEO_CORE_CLK 110 +#define VIDEO_AXI_CLK 111 +#define VIDEO_MAXI_CLK 112 +#define VIDEO_AHB_CLK 113 +#define VIDEO_SUBCORE0_CLK 114 +#define VIDEO_SUBCORE1_CLK 115 +#define MDSS_AHB_CLK 116 +#define MDSS_HDMI_AHB_CLK 117 +#define MDSS_AXI_CLK 118 +#define MDSS_PCLK0_CLK 119 +#define MDSS_PCLK1_CLK 120 +#define MDSS_MDP_CLK 121 +#define MDSS_EXTPCLK_CLK 122 +#define MDSS_VSYNC_CLK 123 +#define MDSS_HDMI_CLK 124 +#define MDSS_BYTE0_CLK 125 +#define MDSS_BYTE1_CLK 126 +#define MDSS_ESC0_CLK 127 +#define MDSS_ESC1_CLK 128 +#define CAMSS_TOP_AHB_CLK 129 +#define CAMSS_AHB_CLK 130 +#define CAMSS_MICRO_AHB_CLK 131 +#define CAMSS_GP0_CLK 132 +#define CAMSS_GP1_CLK 133 +#define CAMSS_MCLK0_CLK 134 +#define CAMSS_MCLK1_CLK 135 +#define CAMSS_MCLK2_CLK 136 +#define CAMSS_MCLK3_CLK 137 +#define CAMSS_CCI_CLK 138 +#define CAMSS_CCI_AHB_CLK 139 +#define CAMSS_CSI0PHYTIMER_CLK 140 +#define CAMSS_CSI1PHYTIMER_CLK 141 +#define CAMSS_CSI2PHYTIMER_CLK 142 +#define CAMSS_CSIPHY0_3P_CLK 143 +#define CAMSS_CSIPHY1_3P_CLK 144 +#define CAMSS_CSIPHY2_3P_CLK 145 +#define CAMSS_JPEG0_CLK 146 +#define CAMSS_JPEG2_CLK 147 +#define CAMSS_JPEG_DMA_CLK 148 +#define CAMSS_JPEG_AHB_CLK 149 +#define CAMSS_JPEG_AXI_CLK 150 +#define CAMSS_VFE_AHB_CLK 151 +#define CAMSS_VFE_AXI_CLK 152 +#define CAMSS_VFE0_CLK 153 +#define CAMSS_VFE0_STREAM_CLK 154 +#define CAMSS_VFE0_AHB_CLK 155 +#define CAMSS_VFE1_CLK 156 +#define CAMSS_VFE1_STREAM_CLK 157 +#define CAMSS_VFE1_AHB_CLK 158 +#define CAMSS_CSI_VFE0_CLK 159 +#define CAMSS_CSI_VFE1_CLK 160 +#define CAMSS_CPP_VBIF_AHB_CLK 161 +#define CAMSS_CPP_AXI_CLK 162 +#define CAMSS_CPP_CLK 163 +#define CAMSS_CPP_AHB_CLK 164 +#define CAMSS_CSI0_CLK 165 +#define CAMSS_CSI0_AHB_CLK 166 +#define CAMSS_CSI0PHY_CLK 167 +#define CAMSS_CSI0RDI_CLK 168 +#define CAMSS_CSI0PIX_CLK 169 +#define CAMSS_CSI1_CLK 170 +#define CAMSS_CSI1_AHB_CLK 171 +#define CAMSS_CSI1PHY_CLK 172 +#define CAMSS_CSI1RDI_CLK 173 +#define CAMSS_CSI1PIX_CLK 174 +#define CAMSS_CSI2_CLK 175 +#define CAMSS_CSI2_AHB_CLK 176 +#define CAMSS_CSI2PHY_CLK 177 +#define CAMSS_CSI2RDI_CLK 178 +#define CAMSS_CSI2PIX_CLK 179 +#define CAMSS_CSI3_CLK 180 +#define CAMSS_CSI3_AHB_CLK 181 +#define CAMSS_CSI3PHY_CLK 182 +#define CAMSS_CSI3RDI_CLK 183 +#define CAMSS_CSI3PIX_CLK 184 +#define CAMSS_ISPIF_AHB_CLK 185 +#define FD_CORE_CLK 186 +#define FD_CORE_UAR_CLK 187 +#define FD_AHB_CLK 188 +#define MMSS_SPDM_CSI0_CLK 189 +#define MMSS_SPDM_JPEG_DMA_CLK 190 +#define MMSS_SPDM_CPP_CLK 191 +#define MMSS_SPDM_PCLK0_CLK 192 +#define MMSS_SPDM_AHB_CLK 193 +#define MMSS_SPDM_GFX3D_CLK 194 +#define MMSS_SPDM_PCLK1_CLK 195 +#define MMSS_SPDM_JPEG2_CLK 196 +#define MMSS_SPDM_DEBUG_CLK 197 +#define MMSS_SPDM_VFE1_CLK 198 +#define MMSS_SPDM_VFE0_CLK 199 +#define MMSS_SPDM_VIDEO_CORE_CLK 200 +#define MMSS_SPDM_AXI_CLK 201 +#define MMSS_SPDM_MDP_CLK 202 +#define MMSS_SPDM_JPEG0_CLK 203 +#define MMSS_SPDM_RM_AXI_CLK 204 +#define MMSS_SPDM_RM_MAXI_CLK 205 + +#define MMAGICAHB_BCR 0 +#define MMAGIC_CFG_BCR 1 +#define MISC_BCR 2 +#define BTO_BCR 3 +#define MMAGICAXI_BCR 4 +#define MMAGICMAXI_BCR 5 +#define DSA_BCR 6 +#define MMAGIC_CAMSS_BCR 7 +#define THROTTLE_CAMSS_BCR 8 +#define SMMU_VFE_BCR 9 +#define SMMU_CPP_BCR 10 +#define SMMU_JPEG_BCR 11 +#define MMAGIC_MDSS_BCR 12 +#define THROTTLE_MDSS_BCR 13 +#define SMMU_ROT_BCR 14 +#define SMMU_MDP_BCR 15 +#define MMAGIC_VIDEO_BCR 16 +#define THROTTLE_VIDEO_BCR 17 +#define SMMU_VIDEO_BCR 18 +#define MMAGIC_BIMC_BCR 19 +#define GPU_GX_BCR 20 +#define GPU_BCR 21 +#define GPU_AON_BCR 22 +#define VMEM_BCR 23 +#define MMSS_RBCPR_BCR 24 +#define VIDEO_BCR 25 +#define MDSS_BCR 26 +#define CAMSS_TOP_BCR 27 +#define CAMSS_AHB_BCR 28 +#define CAMSS_MICRO_BCR 29 +#define CAMSS_CCI_BCR 30 +#define CAMSS_PHY0_BCR 31 +#define CAMSS_PHY1_BCR 32 +#define CAMSS_PHY2_BCR 33 +#define CAMSS_CSIPHY0_3P_BCR 34 +#define CAMSS_CSIPHY1_3P_BCR 35 +#define CAMSS_CSIPHY2_3P_BCR 36 +#define CAMSS_JPEG_BCR 37 +#define CAMSS_VFE_BCR 38 +#define CAMSS_VFE0_BCR 39 +#define CAMSS_VFE1_BCR 40 +#define CAMSS_CSI_VFE0_BCR 41 +#define CAMSS_CSI_VFE1_BCR 42 +#define CAMSS_CPP_TOP_BCR 43 +#define CAMSS_CPP_BCR 44 +#define CAMSS_CSI0_BCR 45 +#define CAMSS_CSI0RDI_BCR 46 +#define CAMSS_CSI0PIX_BCR 47 +#define CAMSS_CSI1_BCR 48 +#define CAMSS_CSI1RDI_BCR 49 +#define CAMSS_CSI1PIX_BCR 50 +#define CAMSS_CSI2_BCR 51 +#define CAMSS_CSI2RDI_BCR 52 +#define CAMSS_CSI2PIX_BCR 53 +#define CAMSS_CSI3_BCR 54 +#define CAMSS_CSI3RDI_BCR 55 +#define CAMSS_CSI3PIX_BCR 56 +#define CAMSS_ISPIF_BCR 57 +#define FD_BCR 58 +#define MMSS_SPDM_RM_BCR 59 + +/* Indexes for GDSCs */ +#define MMAGIC_VIDEO_GDSC 0 +#define MMAGIC_MDSS_GDSC 1 +#define MMAGIC_CAMSS_GDSC 2 +#define GPU_GDSC 3 +#define VENUS_GDSC 4 +#define VENUS_CORE0_GDSC 5 +#define VENUS_CORE1_GDSC 6 +#define CAMSS_GDSC 7 +#define VFE0_GDSC 8 +#define VFE1_GDSC 9 +#define JPEG_GDSC 10 +#define CPP_GDSC 11 +#define FD_GDSC 12 +#define MDSS_GDSC 13 +#define GPU_GX_GDSC 14 +#define MMAGIC_BIMC_GDSC 15 + +#endif diff --git a/include/dt-bindings/interconnect/qcom,msm8996-cbf.h b/include/dt-bindings/interconnect/qcom,msm8996-cbf.h new file mode 100644 index 000000000000..aac5e69f6bd5 --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,msm8996-cbf.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ +/* + * Copyright (C) 2023 Linaro Ltd. All rights reserved. + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_CBF_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_CBF_H + +#define MASTER_CBF_M4M 0 +#define SLAVE_CBF_M4M 1 + +#endif diff --git a/include/dt-bindings/interconnect/qcom,msm8996.h b/include/dt-bindings/interconnect/qcom,msm8996.h new file mode 100644 index 000000000000..a0b7c0ec7bed --- /dev/null +++ b/include/dt-bindings/interconnect/qcom,msm8996.h @@ -0,0 +1,163 @@ +/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-3-Clause) */ +/* + * Qualcomm MSM8996 interconnect IDs + * + * Copyright (c) 2021 Yassine Oudjana y.oudjana@protonmail.com + */ + +#ifndef __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_H +#define __DT_BINDINGS_INTERCONNECT_QCOM_MSM8996_H + +/* A0NOC */ +#define MASTER_PCIE_0 0 +#define MASTER_PCIE_1 1 +#define MASTER_PCIE_2 2 + +/* A1NOC */ +#define MASTER_CNOC_A1NOC 0 +#define MASTER_CRYPTO_CORE0 1 +#define MASTER_PNOC_A1NOC 2 + +/* A2NOC */ +#define MASTER_USB3 0 +#define MASTER_IPA 1 +#define MASTER_UFS 2 + +/* BIMC */ +#define MASTER_AMPSS_M0 0 +#define MASTER_GRAPHICS_3D 1 +#define MASTER_MNOC_BIMC 2 +#define MASTER_SNOC_BIMC 3 +#define SLAVE_EBI_CH0 4 +#define SLAVE_HMSS_L3 5 +#define SLAVE_BIMC_SNOC_0 6 +#define SLAVE_BIMC_SNOC_1 7 + +/* CNOC */ +#define MASTER_SNOC_CNOC 0 +#define MASTER_QDSS_DAP 1 +#define SLAVE_CNOC_A1NOC 2 +#define SLAVE_CLK_CTL 3 +#define SLAVE_TCSR 4 +#define SLAVE_TLMM 5 +#define SLAVE_CRYPTO_0_CFG 6 +#define SLAVE_MPM 7 +#define SLAVE_PIMEM_CFG 8 +#define SLAVE_IMEM_CFG 9 +#define SLAVE_MESSAGE_RAM 10 +#define SLAVE_BIMC_CFG 11 +#define SLAVE_PMIC_ARB 12 +#define SLAVE_PRNG 13 +#define SLAVE_DCC_CFG 14 +#define SLAVE_RBCPR_MX 15 +#define SLAVE_QDSS_CFG 16 +#define SLAVE_RBCPR_CX 17 +#define SLAVE_QDSS_RBCPR_APU 18 +#define SLAVE_CNOC_MNOC_CFG 19 +#define SLAVE_SNOC_CFG 20 +#define SLAVE_SNOC_MPU_CFG 21 +#define SLAVE_EBI1_PHY_CFG 22 +#define SLAVE_A0NOC_CFG 23 +#define SLAVE_PCIE_1_CFG 24 +#define SLAVE_PCIE_2_CFG 25 +#define SLAVE_PCIE_0_CFG 26 +#define SLAVE_PCIE20_AHB2PHY 27 +#define SLAVE_A0NOC_MPU_CFG 28 +#define SLAVE_UFS_CFG 29 +#define SLAVE_A1NOC_CFG 30 +#define SLAVE_A1NOC_MPU_CFG 31 +#define SLAVE_A2NOC_CFG 32 +#define SLAVE_A2NOC_MPU_CFG 33 +#define SLAVE_SSC_CFG 34 +#define SLAVE_A0NOC_SMMU_CFG 35 +#define SLAVE_A1NOC_SMMU_CFG 36 +#define SLAVE_A2NOC_SMMU_CFG 37 +#define SLAVE_LPASS_SMMU_CFG 38 +#define SLAVE_CNOC_MNOC_MMSS_CFG 39 + +/* MNOC */ +#define MASTER_CNOC_MNOC_CFG 0 +#define MASTER_CPP 1 +#define MASTER_JPEG 2 +#define MASTER_MDP_PORT0 3 +#define MASTER_MDP_PORT1 4 +#define MASTER_ROTATOR 5 +#define MASTER_VIDEO_P0 6 +#define MASTER_VFE 7 +#define MASTER_SNOC_VMEM 8 +#define MASTER_VIDEO_P0_OCMEM 9 +#define MASTER_CNOC_MNOC_MMSS_CFG 10 +#define SLAVE_MNOC_BIMC 11 +#define SLAVE_VMEM 12 +#define SLAVE_SERVICE_MNOC 13 +#define SLAVE_MMAGIC_CFG 14 +#define SLAVE_CPR_CFG 15 +#define SLAVE_MISC_CFG 16 +#define SLAVE_VENUS_THROTTLE_CFG 17 +#define SLAVE_VENUS_CFG 18 +#define SLAVE_VMEM_CFG 19 +#define SLAVE_DSA_CFG 20 +#define SLAVE_MMSS_CLK_CFG 21 +#define SLAVE_DSA_MPU_CFG 22 +#define SLAVE_MNOC_MPU_CFG 23 +#define SLAVE_DISPLAY_CFG 24 +#define SLAVE_DISPLAY_THROTTLE_CFG 25 +#define SLAVE_CAMERA_CFG 26 +#define SLAVE_CAMERA_THROTTLE_CFG 27 +#define SLAVE_GRAPHICS_3D_CFG 28 +#define SLAVE_SMMU_MDP_CFG 29 +#define SLAVE_SMMU_ROT_CFG 30 +#define SLAVE_SMMU_VENUS_CFG 31 +#define SLAVE_SMMU_CPP_CFG 32 +#define SLAVE_SMMU_JPEG_CFG 33 +#define SLAVE_SMMU_VFE_CFG 34 + +/* PNOC */ +#define MASTER_SNOC_PNOC 0 +#define MASTER_SDCC_1 1 +#define MASTER_SDCC_2 2 +#define MASTER_SDCC_4 3 +#define MASTER_USB_HS 4 +#define MASTER_BLSP_1 5 +#define MASTER_BLSP_2 6 +#define MASTER_TSIF 7 +#define SLAVE_PNOC_A1NOC 8 +#define SLAVE_USB_HS 9 +#define SLAVE_SDCC_2 10 +#define SLAVE_SDCC_4 11 +#define SLAVE_TSIF 12 +#define SLAVE_BLSP_2 13 +#define SLAVE_SDCC_1 14 +#define SLAVE_BLSP_1 15 +#define SLAVE_PDM 16 +#define SLAVE_AHB2PHY 17 + +/* SNOC */ +#define MASTER_HMSS 0 +#define MASTER_QDSS_BAM 1 +#define MASTER_SNOC_CFG 2 +#define MASTER_BIMC_SNOC_0 3 +#define MASTER_BIMC_SNOC_1 4 +#define MASTER_A0NOC_SNOC 5 +#define MASTER_A1NOC_SNOC 6 +#define MASTER_A2NOC_SNOC 7 +#define MASTER_QDSS_ETR 8 +#define SLAVE_A0NOC_SNOC 9 +#define SLAVE_A1NOC_SNOC 10 +#define SLAVE_A2NOC_SNOC 11 +#define SLAVE_HMSS 12 +#define SLAVE_LPASS 13 +#define SLAVE_USB3 14 +#define SLAVE_SNOC_BIMC 15 +#define SLAVE_SNOC_CNOC 16 +#define SLAVE_IMEM 17 +#define SLAVE_PIMEM 18 +#define SLAVE_SNOC_VMEM 19 +#define SLAVE_SNOC_PNOC 20 +#define SLAVE_QDSS_STM 21 +#define SLAVE_PCIE_0 22 +#define SLAVE_PCIE_1 23 +#define SLAVE_PCIE_2 24 +#define SLAVE_SERVICE_SNOC 25 + +#endif diff --git a/include/dt-bindings/sound/qcom,wcd9335.h b/include/dt-bindings/sound/qcom,wcd9335.h new file mode 100644 index 000000000000..f5e9f1db091e --- /dev/null +++ b/include/dt-bindings/sound/qcom,wcd9335.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ + +#ifndef __DT_SOUND_QCOM_WCD9335_H +#define __DT_SOUND_QCOM_WCD9335_H + +#define AIF1_PB 0 +#define AIF1_CAP 1 +#define AIF2_PB 2 +#define AIF2_CAP 3 +#define AIF3_PB 4 +#define AIF3_CAP 5 +#define AIF4_PB 6 +#define NUM_CODEC_DAIS 7 + +#endif
Import PM8994 and PMI8994 DTSI files in preparation for switching MSM8996 boards to upstream DTS.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/pm8994.dtsi | 152 ++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/pmi8994.dtsi | 65 ++++++++++++++++++++ 2 files changed, 217 insertions(+)
diff --git a/arch/arm/dts/pm8994.dtsi b/arch/arm/dts/pm8994.dtsi new file mode 100644 index 000000000000..672094c8ca58 --- /dev/null +++ b/arch/arm/dts/pm8994.dtsi @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/iio/qcom,spmi-vadc.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> + +/ { + thermal-zones { + pm8994-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&pm8994_temp>; + + trips { + pm8994_alert0: pm8994-alert0 { + temperature = <95000>; + hysteresis = <2000>; + type = "passive"; + }; + pm8994_crit: pm8994-crit { + temperature = <125000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + }; +}; + +&spmi_bus { + + pmic@0 { + compatible = "qcom,pm8994", "qcom,spmi-pmic"; + reg = <0x0 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + rtc@6000 { + compatible = "qcom,pm8941-rtc"; + reg = <0x6000>, <0x6100>; + reg-names = "rtc", "alarm"; + interrupts = <0x0 0x61 0x1 IRQ_TYPE_EDGE_RISING>; + }; + + pm8994_pon: pon@800 { + compatible = "qcom,pm8916-pon"; + reg = <0x800>; + mode-bootloader = <0x2>; + mode-recovery = <0x1>; + + pwrkey { + compatible = "qcom,pm8941-pwrkey"; + interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + linux,code = <KEY_POWER>; + }; + + pm8994_resin: resin { + compatible = "qcom,pm8941-resin"; + interrupts = <0x0 0x8 1 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + status = "disabled"; + }; + }; + + pm8994_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0x0 0x24 0x0 IRQ_TYPE_EDGE_RISING>; + io-channels = <&pm8994_vadc VADC_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pm8994_vadc: adc@3100 { + compatible = "qcom,spmi-vadc"; + reg = <0x3100>; + interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + + adc-chan@7 { + reg = <VADC_VSYS>; + qcom,pre-scaling = <1 3>; + label = "vph_pwr"; + }; + adc-chan@8 { + reg = <VADC_DIE_TEMP>; + label = "die_temp"; + }; + adc-chan@9 { + reg = <VADC_REF_625MV>; + label = "ref_625mv"; + }; + adc-chan@a { + reg = <VADC_REF_1250MV>; + label = "ref_1250mv"; + }; + adc-chan@e { + reg = <VADC_GND_REF>; + }; + adc-chan@f { + reg = <VADC_VDD_VADC>; + }; + }; + + pm8994_gpios: gpio@c000 { + compatible = "qcom,pm8994-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pm8994_gpios 0 0 22>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pm8994_mpps: mpps@a000 { + compatible = "qcom,pm8994-mpp", "qcom,spmi-mpp"; + reg = <0xa000>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&pm8994_mpps 0 0 8>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + pmic@1 { + compatible = "qcom,pm8994", "qcom,spmi-pmic"; + reg = <0x1 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pm8994_lpg: pwm { + compatible = "qcom,pm8994-lpg"; + + #address-cells = <1>; + #size-cells = <0>; + #pwm-cells = <2>; + + status = "disabled"; + }; + + pm8994_spmi_regulators: regulators { + compatible = "qcom,pm8994-regulators"; + }; + }; +}; diff --git a/arch/arm/dts/pmi8994.dtsi b/arch/arm/dts/pmi8994.dtsi new file mode 100644 index 000000000000..36d6a1fb553a --- /dev/null +++ b/arch/arm/dts/pmi8994.dtsi @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/spmi/spmi.h> + +&spmi_bus { + + pmic@2 { + compatible = "qcom,pmi8994", "qcom,spmi-pmic"; + reg = <0x2 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pmi8994_gpios: gpio@c000 { + compatible = "qcom,pmi8994-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pmi8994_gpios 0 0 10>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pmi8994_mpps: mpps@a000 { + compatible = "qcom,pmi8994-mpp", "qcom,spmi-mpp"; + reg = <0xa000>; + gpio-controller; + gpio-ranges = <&pmi8994_mpps 0 0 4>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + pmic@3 { + compatible = "qcom,pmi8994", "qcom,spmi-pmic"; + reg = <0x3 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pmi8994_lpg: pwm { + compatible = "qcom,pmi8994-lpg"; + + #address-cells = <1>; + #size-cells = <0>; + #pwm-cells = <2>; + + status = "disabled"; + }; + + pmi8994_spmi_regulators: regulators { + compatible = "qcom,pmi8994-regulators"; + }; + + pmi8994_wled: wled@d800 { + compatible = "qcom,pmi8994-wled"; + reg = <0xd800>, <0xd900>; + interrupts = <0x3 0xd8 0x1 IRQ_TYPE_EDGE_RISING>, + <0x3 0xd8 0x2 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "ovp", "short"; + qcom,cabc; + qcom,external-pfet; + status = "disabled"; + }; + }; +};
Don't use hardcoded clock IDs, use the IDs from the dt-bindings to be compatible with upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/dragonboard820c.dts | 5 +++-- drivers/clk/qcom/clock-apq8096.c | 5 +++-- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts index 86b7f83d36d6..282c37e28f42 100644 --- a/arch/arm/dts/dragonboard820c.dts +++ b/arch/arm/dts/dragonboard820c.dts @@ -8,6 +8,7 @@ /dts-v1/;
#include "skeleton64.dtsi" +#include <dt-bindings/clock/qcom,gcc-msm8996.h>
/ { model = "Qualcomm Technologies, Inc. DB820c"; @@ -78,7 +79,7 @@ blsp2_uart2: serial@75b0000 { compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; reg = <0x75b0000 0x1000>; - clocks = <&gcc 4>; + clocks = <&gcc GCC_BLSP2_UART2_APPS_CLK>; clock-names = "core"; pinctrl-names = "uart"; pinctrl-0 = <&blsp8_uart>; @@ -89,7 +90,7 @@ reg = <0x74a4900 0x314>, <0x74a4000 0x800>; index = <0x0>; bus-width = <4>; - clock = <&gcc 0>; + clock = <&gcc GCC_SDCC1_APPS_CLK>; clock-frequency = <200000000>; };
diff --git a/drivers/clk/qcom/clock-apq8096.c b/drivers/clk/qcom/clock-apq8096.c index 1e6fdb5cd42d..a4731613c5e0 100644 --- a/drivers/clk/qcom/clock-apq8096.c +++ b/drivers/clk/qcom/clock-apq8096.c @@ -13,6 +13,7 @@ #include <errno.h> #include <asm/io.h> #include <linux/bitops.h> +#include <dt-bindings/clock/qcom,gcc-msm8996.h>
#include "clock-qcom.h"
@@ -107,10 +108,10 @@ static ulong apq8096_clk_set_rate(struct clk *clk, ulong rate) struct msm_clk_priv *priv = dev_get_priv(clk->dev);
switch (clk->id) { - case 0: /* SDC1 */ + case GCC_SDCC1_APPS_CLK: /* SDC1 */ return clk_init_sdc(priv, rate); break; - case 4: /*UART2*/ + case GCC_BLSP2_UART2_APPS_CLK: /*UART2*/ return clk_init_uart(priv); default: return 0;
clocks = <&gcc 4>;
clock = <&gcc 0>;
};clock = <&gcc GCC_SDCC1_APPS_CLK>; clock-frequency = <200000000>;
switch (clk->id) {
- case GCC_SDCC1_APPS_CLK: /* SDC1 */ return clk_init_sdc(priv, rate); break;
- case 4: /*UART2*/
- case GCC_BLSP2_UART2_APPS_CLK: /*UART2*/ return clk_init_uart(priv); default: return 0;
Drop the U-Boot specific dragonboard820c.dts file in favour of the upstream apq8096-db820c.dts and an additional -u-boot.dtsi with the U-Boot specific additions.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/Makefile | 2 +- arch/arm/dts/apq8096-db820c-u-boot.dtsi | 10 + arch/arm/dts/apq8096-db820c.dts | 1137 +++++++++ arch/arm/dts/dragonboard820c-uboot.dtsi | 32 - arch/arm/dts/dragonboard820c.dts | 153 -- arch/arm/dts/msm8996.dtsi | 3884 +++++++++++++++++++++++++++++++ configs/dragonboard820c_defconfig | 2 +- 7 files changed, 5033 insertions(+), 187 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 836113eb66e4..95470fd6133b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -601,7 +601,7 @@ dtb-$(CONFIG_TARGET_SL28) += fsl-ls1028a-kontron-sl28.dtb \ dtb-$(CONFIG_TARGET_TEN64) += fsl-ls1088a-ten64.dtb
dtb-$(CONFIG_ARCH_SNAPDRAGON) += apq8016-sbc.dtb \ - dragonboard820c.dtb \ + apq8096-db820c.dtb \ sdm845-db845c.dtb \ sdm845-samsung-starqltechn.dtb \ qcs404-evb.dtb diff --git a/arch/arm/dts/apq8096-db820c-u-boot.dtsi b/arch/arm/dts/apq8096-db820c-u-boot.dtsi new file mode 100644 index 000000000000..6bce5f8d7edf --- /dev/null +++ b/arch/arm/dts/apq8096-db820c-u-boot.dtsi @@ -0,0 +1,10 @@ + +/ { + /* Ensure that the fdtfile variable is generated properly */ + compatible = "qcom,apq8096-db820c", "qcom,apq8096"; +}; + +&sdhc2 { + status = "okay"; + clock-frequency = <100000000>; +}; diff --git a/arch/arm/dts/apq8096-db820c.dts b/arch/arm/dts/apq8096-db820c.dts new file mode 100644 index 000000000000..e8148b3d6c50 --- /dev/null +++ b/arch/arm/dts/apq8096-db820c.dts @@ -0,0 +1,1137 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (c) 2014-2016, The Linux Foundation. All rights reserved. + */ + +/dts-v1/; + +#include "msm8996.dtsi" +#include "pm8994.dtsi" +#include "pmi8994.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> +#include <dt-bindings/sound/qcom,q6afe.h> +#include <dt-bindings/sound/qcom,q6asm.h> +#include <dt-bindings/sound/qcom,wcd9335.h> + +/* + * GPIO name legend: proper name = the GPIO line is used as GPIO + * NC = not connected (pin out but not routed from the chip to + * anything the board) + * "[PER]" = pin is muxed for [peripheral] (not GPIO) + * LSEC = Low Speed External Connector + * P HSEC = Primary High Speed External Connector + * S HSEC = Secondary High Speed External Connector + * J14 = Camera Connector + * TP = Test Points + * + * Line names are taken from the schematic "DragonBoard 820c", + * drawing no: LM25-P2751-1 + * + * For the lines routed to the external connectors the + * lines are named after the 96Boards CE Specification 1.0, + * Appendix "Expansion Connector Signal Description". + * + * When the 96Board naming of a line and the schematic name of + * the same line are in conflict, the 96Board specification + * takes precedence, which means that the external UART on the + * LSEC is named UART0 while the schematic and SoC names this + * UART3. This is only for the informational lines i.e. "[FOO]", + * the GPIO named lines "GPIO-A" thru "GPIO-L" are the only + * ones actually used for GPIO. + */ + +/ { + model = "Qualcomm Technologies, Inc. DB820c"; + compatible = "arrow,apq8096-db820c", "qcom,apq8096-sbc", "qcom,apq8096"; + + aliases { + serial0 = &blsp2_uart2; + serial1 = &blsp2_uart3; + serial2 = &blsp1_uart2; + i2c0 = &blsp1_i2c3; + i2c1 = &blsp2_i2c1; + i2c2 = &blsp2_i2c1; + spi0 = &blsp1_spi1; + spi1 = &blsp2_spi6; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + div1_mclk: divclk1 { + compatible = "gpio-gate-clock"; + pinctrl-0 = <&audio_mclk>; + pinctrl-names = "default"; + clocks = <&rpmcc RPM_SMD_DIV_CLK1>; + #clock-cells = <0>; + enable-gpios = <&pm8994_gpios 15 0>; + }; + + divclk4: divclk4 { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + clock-output-names = "divclk4"; + + pinctrl-names = "default"; + pinctrl-0 = <&divclk4_pin_a>; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + + pinctrl-names = "default"; + pinctrl-0 = <&volume_up_gpio>; + + button { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + gpios = <&pm8994_gpios 2 GPIO_ACTIVE_LOW>; + }; + }; + + usb2_id: usb2-id { + compatible = "linux,extcon-usb-gpio"; + id-gpios = <&pmi8994_gpios 6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb2_vbus_det_gpio>; + }; + + usb3_id: usb3-id { + compatible = "linux,extcon-usb-gpio"; + id-gpios = <&pm8994_gpios 22 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb3_vbus_det_gpio>; + }; + + vph_pwr: vph-pwr-regulator { + compatible = "regulator-fixed"; + regulator-name = "vph_pwr"; + regulator-always-on; + regulator-boot-on; + + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + }; + + wlan_en: wlan-en-1-8v { + pinctrl-names = "default"; + pinctrl-0 = <&wlan_en_gpios>; + compatible = "regulator-fixed"; + regulator-name = "wlan-en-regulator"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + gpio = <&pm8994_gpios 8 0>; + + /* WLAN card specific delay */ + startup-delay-us = <70000>; + enable-active-high; + }; +}; + +&blsp1_i2c3 { + /* On Low speed expansion: LS-I2C0 */ + status = "okay"; +}; + +&blsp1_spi1 { + /* On Low speed expansion */ + status = "okay"; +}; + +&blsp1_uart2 { + label = "BT-UART"; + status = "okay"; + + bluetooth { + compatible = "qcom,qca6174-bt"; + + /* bt_disable_n gpio */ + enable-gpios = <&pm8994_gpios 19 GPIO_ACTIVE_HIGH>; + + clocks = <&divclk4>; + }; +}; + +&adsp_pil { + status = "okay"; + firmware-name = "qcom/apq8096/adsp.mbn"; +}; + +&blsp2_i2c1 { + /* On High speed expansion: HS-I2C2 */ + status = "okay"; +}; + +&blsp2_i2c1 { + /* On Low speed expansion: LS-I2C1 */ + status = "okay"; +}; + +&blsp2_spi6 { + /* On High speed expansion */ + status = "okay"; +}; + +&blsp2_uart2 { + label = "LS-UART1"; + status = "okay"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_uart2_2pins_default>; + pinctrl-1 = <&blsp2_uart2_2pins_sleep>; +}; + +&blsp2_uart3 { + label = "LS-UART0"; + status = "disabled"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_uart3_4pins_default>; + pinctrl-1 = <&blsp2_uart3_4pins_sleep>; +}; + +&camss { + vdda-supply = <&vreg_l2a_1p25>; +}; + +&gpu { + status = "okay"; +}; + +&hsusb_phy1 { + status = "okay"; + + vdd-supply = <&vreg_l28a_0p925>; + vdda-pll-supply = <&vreg_l12a_1p8>; + vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; +}; + +&hsusb_phy2 { + status = "okay"; + + vdd-supply = <&vreg_l28a_0p925>; + vdda-pll-supply = <&vreg_l12a_1p8>; + vdda-phy-dpdm-supply = <&vreg_l24a_3p075>; +}; + +&mdp { + status = "okay"; +}; + +&mdss { + status = "okay"; +}; + +&mdss_hdmi { + status = "okay"; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&hdmi_hpd_active &hdmi_ddc_active>; + pinctrl-1 = <&hdmi_hpd_suspend &hdmi_ddc_suspend>; + + core-vdda-supply = <&vreg_l12a_1p8>; + core-vcc-supply = <&vreg_s4a_1p8>; +}; + +&mdss_hdmi_phy { + status = "okay"; + + vddio-supply = <&vreg_l12a_1p8>; + vcca-supply = <&vreg_l28a_0p925>; + #phy-cells = <0>; +}; + +&mmcc { + vdd-gfx-supply = <&vdd_gfx>; +}; + +&mss_pil { + status = "okay"; + pll-supply = <&vreg_l12a_1p8>; + firmware-name = "qcom/apq8096/mba.mbn", "qcom/apq8096/modem.mbn"; +}; + +&pm8994_resin { + status = "okay"; + linux,code = <KEY_VOLUMEDOWN>; +}; + +&tlmm { + gpio-line-names = + "[SPI0_DOUT]", /* GPIO_0, BLSP1_SPI_MOSI, LSEC pin 14 */ + "[SPI0_DIN]", /* GPIO_1, BLSP1_SPI_MISO, LSEC pin 10 */ + "[SPI0_CS]", /* GPIO_2, BLSP1_SPI_CS_N, LSEC pin 12 */ + "[SPI0_SCLK]", /* GPIO_3, BLSP1_SPI_CLK, LSEC pin 8 */ + "[UART1_TxD]", /* GPIO_4, BLSP8_UART_TX, LSEC pin 11 */ + "[UART1_RxD]", /* GPIO_5, BLSP8_UART_RX, LSEC pin 13 */ + "[I2C1_SDA]", /* GPIO_6, BLSP8_I2C_SDA, LSEC pin 21 */ + "[I2C1_SCL]", /* GPIO_7, BLSP8_I2C_SCL, LSEC pin 19 */ + "GPIO-H", /* GPIO_8, LCD0_RESET_N, LSEC pin 30 */ + "TP93", /* GPIO_9 */ + "GPIO-G", /* GPIO_10, MDP_VSYNC_P, LSEC pin 29 */ + "[MDP_VSYNC_S]", /* GPIO_11, S HSEC pin 55 */ + "NC", /* GPIO_12 */ + "[CSI0_MCLK]", /* GPIO_13, CAM_MCLK0, P HSEC pin 15 */ + "[CAM_MCLK1]", /* GPIO_14, J14 pin 11 */ + "[CSI1_MCLK]", /* GPIO_15, CAM_MCLK2, P HSEC pin 17 */ + "TP99", /* GPIO_16 */ + "[I2C2_SDA]", /* GPIO_17, CCI_I2C_SDA0, P HSEC pin 34 */ + "[I2C2_SCL]", /* GPIO_18, CCI_I2C_SCL0, P HSEC pin 32 */ + "[CCI_I2C_SDA1]", /* GPIO_19, S HSEC pin 38 */ + "[CCI_I2C_SCL1]", /* GPIO_20, S HSEC pin 36 */ + "FLASH_STROBE_EN", /* GPIO_21, S HSEC pin 5 */ + "FLASH_STROBE_TRIG", /* GPIO_22, S HSEC pin 1 */ + "GPIO-K", /* GPIO_23, CAM2_RST_N, LSEC pin 33 */ + "GPIO-D", /* GPIO_24, LSEC pin 26 */ + "GPIO-I", /* GPIO_25, CAM0_RST_N, LSEC pin 31 */ + "GPIO-J", /* GPIO_26, CAM0_STANDBY_N, LSEC pin 32 */ + "BLSP6_I2C_SDA", /* GPIO_27 */ + "BLSP6_I2C_SCL", /* GPIO_28 */ + "GPIO-B", /* GPIO_29, TS0_RESET_N, LSEC pin 24 */ + "GPIO30", /* GPIO_30, S HSEC pin 4 */ + "HDMI_CEC", /* GPIO_31 */ + "HDMI_DDC_CLOCK", /* GPIO_32 */ + "HDMI_DDC_DATA", /* GPIO_33 */ + "HDMI_HOT_PLUG_DETECT", /* GPIO_34 */ + "PCIE0_RST_N", /* GPIO_35 */ + "PCIE0_CLKREQ_N", /* GPIO_36 */ + "PCIE0_WAKE", /* GPIO_37 */ + "SD_CARD_DET_N", /* GPIO_38 */ + "TSIF1_SYNC", /* GPIO_39, S HSEC pin 48 */ + "W_DISABLE_N", /* GPIO_40 */ + "[BLSP9_UART_TX]", /* GPIO_41 */ + "[BLSP9_UART_RX]", /* GPIO_42 */ + "[BLSP2_UART_CTS_N]", /* GPIO_43 */ + "[BLSP2_UART_RFR_N]", /* GPIO_44 */ + "[BLSP3_UART_TX]", /* GPIO_45 */ + "[BLSP3_UART_RX]", /* GPIO_46 */ + "[I2C0_SDA]", /* GPIO_47, LS_I2C0_SDA, LSEC pin 17 */ + "[I2C0_SCL]", /* GPIO_48, LS_I2C0_SCL, LSEC pin 15 */ + "[UART0_TxD]", /* GPIO_49, BLSP9_UART_TX, LSEC pin 5 */ + "[UART0_RxD]", /* GPIO_50, BLSP9_UART_RX, LSEC pin 7 */ + "[UART0_CTS]", /* GPIO_51, BLSP9_UART_CTS_N, LSEC pin 3 */ + "[UART0_RTS]", /* GPIO_52, BLSP9_UART_RFR_N, LSEC pin 9 */ + "[CODEC_INT1_N]", /* GPIO_53 */ + "[CODEC_INT2_N]", /* GPIO_54 */ + "[BLSP7_I2C_SDA]", /* GPIO_55 */ + "[BLSP7_I2C_SCL]", /* GPIO_56 */ + "MI2S_MCLK", /* GPIO_57, S HSEC pin 3 */ + "[PCM_CLK]", /* GPIO_58, QUA_MI2S_SCK, LSEC pin 18 */ + "[PCM_FS]", /* GPIO_59, QUA_MI2S_WS, LSEC pin 16 */ + "[PCM_DO]", /* GPIO_60, QUA_MI2S_DATA0, LSEC pin 20 */ + "[PCM_DI]", /* GPIO_61, QUA_MI2S_DATA1, LSEC pin 22 */ + "GPIO-E", /* GPIO_62, LSEC pin 27 */ + "TP87", /* GPIO_63 */ + "[CODEC_RST_N]", /* GPIO_64 */ + "[PCM1_CLK]", /* GPIO_65 */ + "[PCM1_SYNC]", /* GPIO_66 */ + "[PCM1_DIN]", /* GPIO_67 */ + "[PCM1_DOUT]", /* GPIO_68 */ + "AUDIO_REF_CLK", /* GPIO_69 */ + "SLIMBUS_CLK", /* GPIO_70 */ + "SLIMBUS_DATA0", /* GPIO_71 */ + "SLIMBUS_DATA1", /* GPIO_72 */ + "NC", /* GPIO_73 */ + "NC", /* GPIO_74 */ + "NC", /* GPIO_75 */ + "NC", /* GPIO_76 */ + "TP94", /* GPIO_77 */ + "NC", /* GPIO_78 */ + "TP95", /* GPIO_79 */ + "GPIO-A", /* GPIO_80, MEMS_RESET_N, LSEC pin 23 */ + "TP88", /* GPIO_81 */ + "TP89", /* GPIO_82 */ + "TP90", /* GPIO_83 */ + "TP91", /* GPIO_84 */ + "[SD_DAT0]", /* GPIO_85, BLSP12_SPI_MOSI, P HSEC pin 1 */ + "[SD_CMD]", /* GPIO_86, BLSP12_SPI_MISO, P HSEC pin 11 */ + "[SD_DAT3]", /* GPIO_87, BLSP12_SPI_CS_N, P HSEC pin 7 */ + "[SD_SCLK]", /* GPIO_88, BLSP12_SPI_CLK, P HSEC pin 9 */ + "TSIF1_CLK", /* GPIO_89, S HSEC pin 42 */ + "TSIF1_EN", /* GPIO_90, S HSEC pin 46 */ + "TSIF1_DATA", /* GPIO_91, S HSEC pin 44 */ + "NC", /* GPIO_92 */ + "TSIF2_CLK", /* GPIO_93, S HSEC pin 52 */ + "TSIF2_EN", /* GPIO_94, S HSEC pin 56 */ + "TSIF2_DATA", /* GPIO_95, S HSEC pin 54 */ + "TSIF2_SYNC", /* GPIO_96, S HSEC pin 58 */ + "NC", /* GPIO_97 */ + "CAM1_STANDBY_N", /* GPIO_98 */ + "NC", /* GPIO_99 */ + "NC", /* GPIO_100 */ + "[LCD1_RESET_N]", /* GPIO_101, S HSEC pin 51 */ + "BOOT_CONFIG1", /* GPIO_102 */ + "USB_HUB_RESET", /* GPIO_103 */ + "CAM1_RST_N", /* GPIO_104 */ + "NC", /* GPIO_105 */ + "NC", /* GPIO_106 */ + "NC", /* GPIO_107 */ + "NC", /* GPIO_108 */ + "NC", /* GPIO_109 */ + "NC", /* GPIO_110 */ + "NC", /* GPIO_111 */ + "NC", /* GPIO_112 */ + "PMI8994_BUA", /* GPIO_113 */ + "PCIE2_RST_N", /* GPIO_114 */ + "PCIE2_CLKREQ_N", /* GPIO_115 */ + "PCIE2_WAKE", /* GPIO_116 */ + "SSC_IRQ_0", /* GPIO_117 */ + "SSC_IRQ_1", /* GPIO_118 */ + "SSC_IRQ_2", /* GPIO_119 */ + "NC", /* GPIO_120 */ + "GPIO121", /* GPIO_121, S HSEC pin 2 */ + "NC", /* GPIO_122 */ + "SSC_IRQ_6", /* GPIO_123 */ + "SSC_IRQ_7", /* GPIO_124 */ + "GPIO-C", /* GPIO_125, TS_INT0, LSEC pin 25 */ + "BOOT_CONFIG5", /* GPIO_126 */ + "NC", /* GPIO_127 */ + "NC", /* GPIO_128 */ + "BOOT_CONFIG7", /* GPIO_129 */ + "PCIE1_RST_N", /* GPIO_130 */ + "PCIE1_CLKREQ_N", /* GPIO_131 */ + "PCIE1_WAKE", /* GPIO_132 */ + "GPIO-L", /* GPIO_133, CAM2_STANDBY_N, LSEC pin 34 */ + "NC", /* GPIO_134 */ + "NC", /* GPIO_135 */ + "BOOT_CONFIG8", /* GPIO_136 */ + "NC", /* GPIO_137 */ + "NC", /* GPIO_138 */ + "GPS_SSBI2", /* GPIO_139 */ + "GPS_SSBI1", /* GPIO_140 */ + "NC", /* GPIO_141 */ + "NC", /* GPIO_142 */ + "NC", /* GPIO_143 */ + "BOOT_CONFIG6", /* GPIO_144 */ + "NC", /* GPIO_145 */ + "NC", /* GPIO_146 */ + "NC", /* GPIO_147 */ + "NC", /* GPIO_148 */ + "NC"; /* GPIO_149 */ + + sdc2_cd_on: sdc2-cd-on-state { + pins = "gpio38"; + function = "gpio"; + bias-pull-up; + drive-strength = <16>; + }; + + sdc2_cd_off: sdc2-cd-off-state { + pins = "gpio38"; + function = "gpio"; + bias-pull-up; + drive-strength = <2>; + }; + + hdmi_hpd_active: hdmi-hpd-active-state { + pins = "gpio34"; + function = "hdmi_hot"; + bias-pull-down; + drive-strength = <16>; + }; + + hdmi_hpd_suspend: hdmi-hpd-suspend-state { + pins = "gpio34"; + function = "hdmi_hot"; + bias-pull-down; + drive-strength = <2>; + }; + + hdmi_ddc_active: hdmi-ddc-active-state { + pins = "gpio32", "gpio33"; + function = "hdmi_ddc"; + drive-strength = <2>; + bias-pull-up; + }; + + hdmi_ddc_suspend: hdmi-ddc-suspend-state { + pins = "gpio32", "gpio33"; + function = "hdmi_ddc"; + drive-strength = <2>; + bias-pull-down; + }; +}; + +&pcie0 { + status = "okay"; + perst-gpios = <&tlmm 35 GPIO_ACTIVE_LOW>; + vddpe-3v3-supply = <&wlan_en>; + vdda-supply = <&vreg_l28a_0p925>; +}; + +&pcie1 { + status = "okay"; + perst-gpios = <&tlmm 130 GPIO_ACTIVE_LOW>; + vdda-supply = <&vreg_l28a_0p925>; +}; + +&pcie2 { + status = "okay"; + perst-gpios = <&tlmm 114 GPIO_ACTIVE_LOW>; + vdda-supply = <&vreg_l28a_0p925>; +}; + +&pcie_phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l28a_0p925>; + vdda-pll-supply = <&vreg_l12a_1p8>; +}; + +&pm8994_gpios { + gpio-line-names = + "NC", + "KEY_VOLP_N", + "NC", + "BL1_PWM", + "GPIO-F", /* BL0_PWM, LSEC pin 28 */ + "BL1_EN", + "NC", + "WLAN_EN", + "NC", + "NC", + "NC", + "NC", + "NC", + "NC", + "DIVCLK1", + "DIVCLK2", + "DIVCLK3", + "DIVCLK4", + "BT_EN", + "PMIC_SLB", + "PMIC_BUA", + "USB_VBUS_DET"; + + pinctrl-names = "default"; + pinctrl-0 = <&ls_exp_gpio_f &bt_en_gpios>; + + ls_exp_gpio_f: pm8994-gpio5-state { + pinconf { + pins = "gpio5"; + function = PMIC_GPIO_FUNC_NORMAL; + output-low; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + }; + }; + + bt_en_gpios: bt-en-pios-state { + pinconf { + pins = "gpio19"; + function = PMIC_GPIO_FUNC_NORMAL; + output-low; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + qcom,drive-strength = <PMIC_GPIO_STRENGTH_LOW>; + bias-pull-down; + }; + }; + + wlan_en_gpios: wlan-en-gpios-state { + pinconf { + pins = "gpio8"; + function = PMIC_GPIO_FUNC_NORMAL; + output-low; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + qcom,drive-strength = <PMIC_GPIO_STRENGTH_LOW>; + bias-pull-down; + }; + }; + + audio_mclk: clk-div1-state { + pinconf { + pins = "gpio15"; + function = "func1"; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + }; + }; + + volume_up_gpio: pm8996-gpio2-state { + pinconf { + pins = "gpio2"; + function = "normal"; + input-enable; + drive-push-pull; + bias-pull-up; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + }; + }; + + divclk4_pin_a: divclk4-state { + pinconf { + pins = "gpio18"; + function = PMIC_GPIO_FUNC_FUNC2; + + bias-disable; + power-source = <PM8994_GPIO_S4>; + }; + }; + + usb3_vbus_det_gpio: pm8996-gpio22-state { + pinconf { + pins = "gpio22"; + function = PMIC_GPIO_FUNC_NORMAL; + input-enable; + bias-pull-down; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + }; + }; +}; + +&pm8994_mpps { + gpio-line-names = + "VDDPX_BIAS", + "WIFI_LED", + "NC", + "BT_LED", + "PM_MPP05", + "PM_MPP06", + "PM_MPP07", + "NC"; +}; + +&pm8994_spmi_regulators { + qcom,saw-reg = <&saw3>; + vdd_s11-supply = <&vph_pwr>; + + s9 { + qcom,saw-slave; + }; + s10 { + qcom,saw-slave; + }; + s11 { + qcom,saw-leader; + regulator-name = "VDD_APCC"; + regulator-always-on; + regulator-min-microvolt = <980000>; + regulator-max-microvolt = <980000>; + }; +}; + +&pmi8994_gpios { + gpio-line-names = + "NC", + "SPKR_AMP_EN1", + "SPKR_AMP_EN2", + "TP61", + "NC", + "USB2_VBUS_DET", + "NC", + "NC", + "NC", + "NC"; + + usb2_vbus_det_gpio: pmi8996-gpio6-state { + pinconf { + pins = "gpio6"; + function = PMIC_GPIO_FUNC_NORMAL; + input-enable; + bias-pull-down; + qcom,drive-strength = <PMIC_GPIO_STRENGTH_NO>; + power-source = <PM8994_GPIO_S4>; /* 1.8V */ + }; + }; +}; + +&pmi8994_lpg { + qcom,power-source = <1>; + + pinctrl-names = "default"; + pinctrl-0 = <&pmi8994_mpp2_userled4>; + + qcom,dtest = <0 0>, + <0 0>, + <0 0>, + <4 1>; + + status = "okay"; + + led@1 { + reg = <1>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + function-enumerator = <1>; + + linux,default-trigger = "heartbeat"; + default-state = "on"; + }; + + led@2 { + reg = <2>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + function-enumerator = <0>; + }; + + led@3 { + reg = <3>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + function-enumerator = <2>; + }; + + led@4 { + reg = <4>; + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_HEARTBEAT; + function-enumerator = <3>; + }; +}; + +&pmi8994_mpps { + pmi8994_mpp2_userled4: mpp2-userled4-state { + pins = "mpp2"; + function = "sink"; + + output-low; + qcom,dtest = <4>; + }; +}; + +&pmi8994_spmi_regulators { + vdd_s2-supply = <&vph_pwr>; + + vdd_gfx: s2 { + regulator-name = "VDD_GFX"; + regulator-min-microvolt = <980000>; + regulator-max-microvolt = <980000>; + }; +}; + +&rpm_requests { + regulators-0 { + compatible = "qcom,rpm-pm8994-regulators"; + + vdd_s1-supply = <&vph_pwr>; + vdd_s2-supply = <&vph_pwr>; + vdd_s3-supply = <&vph_pwr>; + vdd_s4-supply = <&vph_pwr>; + vdd_s5-supply = <&vph_pwr>; + vdd_s6-supply = <&vph_pwr>; + vdd_s7-supply = <&vph_pwr>; + vdd_s8-supply = <&vph_pwr>; + vdd_s9-supply = <&vph_pwr>; + vdd_s10-supply = <&vph_pwr>; + vdd_s11-supply = <&vph_pwr>; + vdd_s12-supply = <&vph_pwr>; + vdd_l1-supply = <&vreg_s1b_1p025>; + vdd_l2_l26_l28-supply = <&vreg_s3a_1p3>; + vdd_l3_l11-supply = <&vreg_s3a_1p3>; + vdd_l4_l27_l31-supply = <&vreg_s3a_1p3>; + vdd_l5_l7-supply = <&vreg_s5a_2p15>; + vdd_l6_l12_l32-supply = <&vreg_s5a_2p15>; + vdd_l8_l16_l30-supply = <&vph_pwr>; + vdd_l9_l10_l18_l22-supply = <&vph_pwr_bbyp>; + vdd_l13_l19_l23_l24-supply = <&vph_pwr_bbyp>; + vdd_l14_l15-supply = <&vreg_s5a_2p15>; + vdd_l17_l29-supply = <&vph_pwr_bbyp>; + vdd_l20_l21-supply = <&vph_pwr_bbyp>; + vdd_l25-supply = <&vreg_s3a_1p3>; + vdd_lvs1_2-supply = <&vreg_s4a_1p8>; + + vreg_s3a_1p3: s3 { + regulator-name = "vreg_s3a_1p3"; + regulator-min-microvolt = <1300000>; + regulator-max-microvolt = <1300000>; + }; + + /** + * 1.8v required on LS expansion + * for mezzanine boards + */ + vreg_s4a_1p8: s4 { + regulator-name = "vreg_s4a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + vreg_s5a_2p15: s5 { + regulator-name = "vreg_s5a_2p15"; + regulator-min-microvolt = <2150000>; + regulator-max-microvolt = <2150000>; + }; + vreg_s7a_1p0: s7 { + regulator-name = "vreg_s7a_1p0"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + }; + + vreg_l1a_1p0: l1 { + regulator-name = "vreg_l1a_1p0"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + }; + vreg_l2a_1p25: l2 { + regulator-name = "vreg_l2a_1p25"; + regulator-min-microvolt = <1250000>; + regulator-max-microvolt = <1250000>; + }; + vreg_l3a_0p875: l3 { + regulator-name = "vreg_l3a_0p875"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + }; + vreg_l4a_1p225: l4 { + regulator-name = "vreg_l4a_1p225"; + regulator-min-microvolt = <1225000>; + regulator-max-microvolt = <1225000>; + }; + vreg_l6a_1p2: l6 { + regulator-name = "vreg_l6a_1p2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + vreg_l8a_1p8: l8 { + regulator-name = "vreg_l8a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l9a_1p8: l9 { + regulator-name = "vreg_l9a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l10a_1p8: l10 { + regulator-name = "vreg_l10a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l11a_1p15: l11 { + regulator-name = "vreg_l11a_1p15"; + regulator-min-microvolt = <1150000>; + regulator-max-microvolt = <1150000>; + }; + vreg_l12a_1p8: l12 { + regulator-name = "vreg_l12a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l13a_2p95: l13 { + regulator-name = "vreg_l13a_2p95"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2950000>; + }; + vreg_l14a_1p8: l14 { + regulator-name = "vreg_l14a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l15a_1p8: l15 { + regulator-name = "vreg_l15a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l16a_2p7: l16 { + regulator-name = "vreg_l16a_2p7"; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <2700000>; + }; + vreg_l17a_2p8: l17 { + regulator-name = "vreg_l17a_2p8"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + }; + vreg_l18a_2p85: l18 { + regulator-name = "vreg_l18a_2p85"; + regulator-min-microvolt = <2700000>; + regulator-max-microvolt = <2900000>; + }; + vreg_l19a_2p8: l19 { + regulator-name = "vreg_l19a_2p8"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + }; + vreg_l20a_2p95: l20 { + regulator-name = "vreg_l20a_2p95"; + regulator-min-microvolt = <2950000>; + regulator-max-microvolt = <2950000>; + regulator-allow-set-load; + }; + vreg_l21a_2p95: l21 { + regulator-name = "vreg_l21a_2p95"; + regulator-min-microvolt = <2950000>; + regulator-max-microvolt = <2950000>; + regulator-allow-set-load; + regulator-system-load = <200000>; + }; + vreg_l22a_3p0: l22 { + regulator-name = "vreg_l22a_3p0"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + vreg_l23a_2p8: l23 { + regulator-name = "vreg_l23a_2p8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + vreg_l24a_3p075: l24 { + regulator-name = "vreg_l24a_3p075"; + regulator-min-microvolt = <3075000>; + regulator-max-microvolt = <3075000>; + }; + vreg_l25a_1p2: l25 { + regulator-name = "vreg_l25a_1p2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-allow-set-load; + }; + vreg_l26a_0p8: l27 { + regulator-name = "vreg_l26a_0p8"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + }; + vreg_l28a_0p925: l28 { + regulator-name = "vreg_l28a_0p925"; + regulator-min-microvolt = <925000>; + regulator-max-microvolt = <925000>; + regulator-allow-set-load; + }; + vreg_l29a_2p8: l29 { + regulator-name = "vreg_l29a_2p8"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + }; + vreg_l30a_1p8: l30 { + regulator-name = "vreg_l30a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + vreg_l32a_1p8: l32 { + regulator-name = "vreg_l32a_1p8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vreg_lvs1a_1p8: lvs1 { + regulator-name = "vreg_lvs1a_1p8"; + }; + + vreg_lvs2a_1p8: lvs2 { + regulator-name = "vreg_lvs2a_1p8"; + }; + }; + + regulators-1 { + compatible = "qcom,rpm-pmi8994-regulators"; + + vdd_s1-supply = <&vph_pwr>; + vdd_s2-supply = <&vph_pwr>; + vdd_s3-supply = <&vph_pwr>; + vdd_bst_byp-supply = <&vph_pwr>; + + vph_pwr_bbyp: boost-bypass { + regulator-name = "vph_pwr_bbyp"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vreg_s1b_1p025: s1 { + regulator-name = "vreg_s1b_1p025"; + regulator-min-microvolt = <1025000>; + regulator-max-microvolt = <1025000>; + }; + }; +}; + +&sdhc2 { + /* External SD card */ + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc2_state_on &sdc2_cd_on>; + pinctrl-1 = <&sdc2_state_off &sdc2_cd_off>; + cd-gpios = <&tlmm 38 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vreg_l21a_2p95>; + vqmmc-supply = <&vreg_l13a_2p95>; + status = "okay"; +}; + +&q6asmdai { + dai@0 { + reg = <0>; + }; + + dai@1 { + reg = <1>; + }; + + dai@2 { + reg = <2>; + }; +}; + +&slim_msm { + status = "okay"; + + slim@1 { + reg = <1>; + #address-cells = <2>; + #size-cells = <0>; + + tasha_ifd: tas-ifd@0,0 { + compatible = "slim217,1a0"; + reg = <0 0>; + }; + + wcd9335: codec@1,0 { + compatible = "slim217,1a0"; + reg = <1 0>; + + clock-names = "mclk", "slimbus"; + clocks = <&div1_mclk>, + <&rpmcc RPM_SMD_BB_CLK1>; + interrupt-parent = <&tlmm>; + interrupts = <54 IRQ_TYPE_LEVEL_HIGH>, + <53 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "intr1", "intr2"; + interrupt-controller; + #interrupt-cells = <1>; + + pinctrl-0 = <&cdc_reset_active &wcd_intr_default>; + pinctrl-names = "default"; + + reset-gpios = <&tlmm 64 GPIO_ACTIVE_LOW>; + slim-ifc-dev = <&tasha_ifd>; + + #sound-dai-cells = <1>; + + vdd-buck-supply = <&vreg_s4a_1p8>; + vdd-buck-sido-supply = <&vreg_s4a_1p8>; + vdd-tx-supply = <&vreg_s4a_1p8>; + vdd-rx-supply = <&vreg_s4a_1p8>; + vdd-io-supply = <&vreg_s4a_1p8>; + }; + }; +}; + +&sound { + compatible = "qcom,apq8096-sndcard"; + model = "DB820c"; + audio-routing = "RX_BIAS", "MCLK", + "MM_DL1", "MultiMedia1 Playback", + "MM_DL2", "MultiMedia2 Playback", + "MultiMedia3 Capture", "MM_UL3"; + + mm1-dai-link { + link-name = "MultiMedia1"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA1>; + }; + }; + + mm2-dai-link { + link-name = "MultiMedia2"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA2>; + }; + }; + + mm3-dai-link { + link-name = "MultiMedia3"; + cpu { + sound-dai = <&q6asmdai MSM_FRONTEND_DAI_MULTIMEDIA3>; + }; + }; + + hdmi-dai-link { + link-name = "HDMI"; + cpu { + sound-dai = <&q6afedai HDMI_RX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <&mdss_hdmi 0>; + }; + }; + + slim-dai-link { + link-name = "SLIM Playback"; + cpu { + sound-dai = <&q6afedai SLIMBUS_6_RX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <&wcd9335 AIF4_PB>; + }; + }; + + slimcap-dai-link { + link-name = "SLIM Capture"; + cpu { + sound-dai = <&q6afedai SLIMBUS_0_TX>; + }; + + platform { + sound-dai = <&q6routing>; + }; + + codec { + sound-dai = <&wcd9335 AIF1_CAP>; + }; + }; +}; + +&ufsphy { + status = "okay"; + + vdda-phy-supply = <&vreg_l28a_0p925>; + vdda-pll-supply = <&vreg_l12a_1p8>; +}; + +&ufshc { + status = "okay"; + + vcc-supply = <&vreg_l20a_2p95>; + vccq-supply = <&vreg_l25a_1p2>; + vccq2-supply = <&vreg_s4a_1p8>; + vdd-hba-supply = <&vreg_l25a_1p2>; + + vcc-max-microamp = <600000>; + vccq-max-microamp = <450000>; + vccq2-max-microamp = <450000>; +}; + +&usb2 { + status = "okay"; + extcon = <&usb2_id>; +}; + +&usb2_dwc3 { + extcon = <&usb2_id>; + dr_mode = "otg"; + maximum-speed = "high-speed"; +}; + +&usb3 { + status = "okay"; + extcon = <&usb3_id>; +}; + +&usb3_dwc3 { + extcon = <&usb3_id>; + dr_mode = "otg"; +}; + +&usb3phy { + status = "okay"; + + vdda-phy-supply = <&vreg_l28a_0p925>; + vdda-pll-supply = <&vreg_l12a_1p8>; +}; + +&venus { + status = "okay"; +}; diff --git a/arch/arm/dts/dragonboard820c-uboot.dtsi b/arch/arm/dts/dragonboard820c-uboot.dtsi deleted file mode 100644 index d93c7c1fbdee..000000000000 --- a/arch/arm/dts/dragonboard820c-uboot.dtsi +++ /dev/null @@ -1,32 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * U-Boot addition to handle Dragonboard 820c pins - * - * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org - */ - -/ { - smem { - bootph-all; - }; - - soc { - bootph-all; - - pinctrl@1010000 { - bootph-all; - - uart { - bootph-all; - }; - }; - - clock-controller@300000 { - bootph-all; - }; - - serial@75b0000 { - bootph-all; - }; - }; -}; diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts deleted file mode 100644 index 282c37e28f42..000000000000 --- a/arch/arm/dts/dragonboard820c.dts +++ /dev/null @@ -1,153 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm APQ8096 based Dragonboard 820C board device tree source - * - * (C) Copyright 2017 Jorge Ramirez-Ortiz jorge.ramirez-ortiz@linaro.org - */ - -/dts-v1/; - -#include "skeleton64.dtsi" -#include <dt-bindings/clock/qcom,gcc-msm8996.h> - -/ { - model = "Qualcomm Technologies, Inc. DB820c"; - compatible = "arrow,apq8096-db820c", "qcom,apq8096-sbc"; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - serial0 = &blsp2_uart2; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory { - device_type = "memory"; - reg = <0 0x80000000 0 0xc0000000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - smem_mem: smem_region@86300000 { - reg = <0x0 0x86300000 0x0 0x200000>; - no-map; - }; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - smem { - compatible = "qcom,smem"; - memory-region = <&smem_mem>; - }; - - soc: soc { - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0 0 0xffffffff>; - compatible = "simple-bus"; - - gcc: clock-controller@300000 { - compatible = "qcom,gcc-msm8996"; - #clock-cells = <1>; - #reset-cells = <1>; - #power-domain-cells = <1>; - reg = <0x300000 0x90000>; - }; - - pinctrl: pinctrl@1010000 { - compatible = "qcom,msm8996-pinctrl"; - reg = <0x1010000 0x400000>; - - blsp8_uart: uart { - function = "blsp_uart8"; - pins = "GPIO_4", "GPIO_5"; - drive-strength = <8>; - bias-disable; - }; - }; - - blsp2_uart2: serial@75b0000 { - compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; - reg = <0x75b0000 0x1000>; - clocks = <&gcc GCC_BLSP2_UART2_APPS_CLK>; - clock-names = "core"; - pinctrl-names = "uart"; - pinctrl-0 = <&blsp8_uart>; - }; - - sdhc2: sdhci@74a4900 { - compatible = "qcom,sdhci-msm-v4"; - reg = <0x74a4900 0x314>, <0x74a4000 0x800>; - index = <0x0>; - bus-width = <4>; - clock = <&gcc GCC_SDCC1_APPS_CLK>; - clock-frequency = <200000000>; - }; - - spmi_bus: spmi@400f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x0400f000 0x1000>, - <0x04400000 0x800000>, - <0x04c00000 0x800000>, - <0x05800000 0x200000>, - <0x0400a000 0x002100>; - reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pmic0: pm8994@0 { - compatible = "qcom,spmi-pmic"; - reg = <0x0 0x1>; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pm8994_pon: pon@800 { - compatible = "qcom,pm8916-pon"; - reg = <0x800 0x100>; - mode-bootloader = <0x2>; - mode-recovery = <0x1>; - - pwrkey { - compatible = "qcom,pm8941-pwrkey"; - debounce = <15625>; - bias-pull-up; - }; - - pm8994_resin: resin { - compatible = "qcom,pm8941-resin"; - debounce = <15625>; - bias-pull-up; - }; - }; - - pm8994_gpios: pm8994_gpios@c000 { - compatible = "qcom,pm8994-gpio"; - reg = <0xc000 0x400>; - gpio-controller; - gpio-ranges = <&pm8994_gpios 0 0 22>; - #gpio-cells = <2>; - }; - }; - - pmic1: pm8994@1 { - compatible = "qcom,spmi-pmic"; - reg = <0x1 0x1>; - #address-cells = <0x1>; - #size-cells = <0x1>; - }; - }; - }; - -}; - -#include "dragonboard820c-uboot.dtsi" diff --git a/arch/arm/dts/msm8996.dtsi b/arch/arm/dts/msm8996.dtsi new file mode 100644 index 000000000000..6ba9da9e6a8b --- /dev/null +++ b/arch/arm/dts/msm8996.dtsi @@ -0,0 +1,3884 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (c) 2014-2015, The Linux Foundation. All rights reserved. + */ + +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/qcom,gcc-msm8996.h> +#include <dt-bindings/clock/qcom,mmcc-msm8996.h> +#include <dt-bindings/clock/qcom,rpmcc.h> +#include <dt-bindings/interconnect/qcom,msm8996.h> +#include <dt-bindings/interconnect/qcom,msm8996-cbf.h> +#include <dt-bindings/firmware/qcom,scm.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/power/qcom-rpmpd.h> +#include <dt-bindings/soc/qcom,apr.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + interrupt-parent = <&intc>; + + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + clocks { + xo_board: xo-board { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + clock-output-names = "xo_board"; + }; + + sleep_clk: sleep-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32764>; + clock-output-names = "sleep_clk"; + }; + }; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + CPU0: cpu@0 { + device_type = "cpu"; + compatible = "qcom,kryo"; + reg = <0x0 0x0>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + capacity-dmips-mhz = <1024>; + clocks = <&kryocc 0>; + interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; + operating-points-v2 = <&cluster0_opp>; + #cooling-cells = <2>; + next-level-cache = <&L2_0>; + L2_0: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + }; + }; + + CPU1: cpu@1 { + device_type = "cpu"; + compatible = "qcom,kryo"; + reg = <0x0 0x1>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + capacity-dmips-mhz = <1024>; + clocks = <&kryocc 0>; + interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; + operating-points-v2 = <&cluster0_opp>; + #cooling-cells = <2>; + next-level-cache = <&L2_0>; + }; + + CPU2: cpu@100 { + device_type = "cpu"; + compatible = "qcom,kryo"; + reg = <0x0 0x100>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + capacity-dmips-mhz = <1024>; + clocks = <&kryocc 1>; + interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; + operating-points-v2 = <&cluster1_opp>; + #cooling-cells = <2>; + next-level-cache = <&L2_1>; + L2_1: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + }; + }; + + CPU3: cpu@101 { + device_type = "cpu"; + compatible = "qcom,kryo"; + reg = <0x0 0x101>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + capacity-dmips-mhz = <1024>; + clocks = <&kryocc 1>; + interconnects = <&cbf MASTER_CBF_M4M &cbf SLAVE_CBF_M4M>; + operating-points-v2 = <&cluster1_opp>; + #cooling-cells = <2>; + next-level-cache = <&L2_1>; + }; + + cpu-map { + cluster0 { + core0 { + cpu = <&CPU0>; + }; + + core1 { + cpu = <&CPU1>; + }; + }; + + cluster1 { + core0 { + cpu = <&CPU2>; + }; + + core1 { + cpu = <&CPU3>; + }; + }; + }; + + idle-states { + entry-method = "psci"; + + CPU_SLEEP_0: cpu-sleep-0 { + compatible = "arm,idle-state"; + idle-state-name = "standalone-power-collapse"; + arm,psci-suspend-param = <0x00000004>; + entry-latency-us = <130>; + exit-latency-us = <80>; + min-residency-us = <300>; + }; + }; + }; + + cluster0_opp: opp-table-cluster0 { + compatible = "operating-points-v2-kryo-cpu"; + nvmem-cells = <&speedbin_efuse>; + opp-shared; + + /* Nominal fmax for now */ + opp-307200000 { + opp-hz = /bits/ 64 <307200000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-422400000 { + opp-hz = /bits/ 64 <422400000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-556800000 { + opp-hz = /bits/ 64 <556800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-652800000 { + opp-hz = /bits/ 64 <652800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <384000>; + }; + opp-729600000 { + opp-hz = /bits/ 64 <729600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <460800>; + }; + opp-844800000 { + opp-hz = /bits/ 64 <844800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <537600>; + }; + opp-960000000 { + opp-hz = /bits/ 64 <960000000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <672000>; + }; + opp-1036800000 { + opp-hz = /bits/ 64 <1036800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <672000>; + }; + opp-1113600000 { + opp-hz = /bits/ 64 <1113600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <825600>; + }; + opp-1190400000 { + opp-hz = /bits/ 64 <1190400000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <825600>; + }; + opp-1228800000 { + opp-hz = /bits/ 64 <1228800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <902400>; + }; + opp-1324800000 { + opp-hz = /bits/ 64 <1324800000>; + opp-supported-hw = <0xd>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1056000>; + }; + opp-1363200000 { + opp-hz = /bits/ 64 <1363200000>; + opp-supported-hw = <0x2>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1132800>; + }; + opp-1401600000 { + opp-hz = /bits/ 64 <1401600000>; + opp-supported-hw = <0xd>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1132800>; + }; + opp-1478400000 { + opp-hz = /bits/ 64 <1478400000>; + opp-supported-hw = <0x9>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1190400>; + }; + opp-1497600000 { + opp-hz = /bits/ 64 <1497600000>; + opp-supported-hw = <0x04>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1305600>; + }; + opp-1593600000 { + opp-hz = /bits/ 64 <1593600000>; + opp-supported-hw = <0x9>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1382400>; + }; + }; + + cluster1_opp: opp-table-cluster1 { + compatible = "operating-points-v2-kryo-cpu"; + nvmem-cells = <&speedbin_efuse>; + opp-shared; + + /* Nominal fmax for now */ + opp-307200000 { + opp-hz = /bits/ 64 <307200000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-403200000 { + opp-hz = /bits/ 64 <403200000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-480000000 { + opp-hz = /bits/ 64 <480000000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-556800000 { + opp-hz = /bits/ 64 <556800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-652800000 { + opp-hz = /bits/ 64 <652800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-729600000 { + opp-hz = /bits/ 64 <729600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <307200>; + }; + opp-806400000 { + opp-hz = /bits/ 64 <806400000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <384000>; + }; + opp-883200000 { + opp-hz = /bits/ 64 <883200000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <460800>; + }; + opp-940800000 { + opp-hz = /bits/ 64 <940800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <537600>; + }; + opp-1036800000 { + opp-hz = /bits/ 64 <1036800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <595200>; + }; + opp-1113600000 { + opp-hz = /bits/ 64 <1113600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <672000>; + }; + opp-1190400000 { + opp-hz = /bits/ 64 <1190400000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <672000>; + }; + opp-1248000000 { + opp-hz = /bits/ 64 <1248000000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <748800>; + }; + opp-1324800000 { + opp-hz = /bits/ 64 <1324800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <825600>; + }; + opp-1401600000 { + opp-hz = /bits/ 64 <1401600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <902400>; + }; + opp-1478400000 { + opp-hz = /bits/ 64 <1478400000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <979200>; + }; + opp-1555200000 { + opp-hz = /bits/ 64 <1555200000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1056000>; + }; + opp-1632000000 { + opp-hz = /bits/ 64 <1632000000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1190400>; + }; + opp-1708800000 { + opp-hz = /bits/ 64 <1708800000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1228800>; + }; + opp-1785600000 { + opp-hz = /bits/ 64 <1785600000>; + opp-supported-hw = <0xf>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1305600>; + }; + opp-1804800000 { + opp-hz = /bits/ 64 <1804800000>; + opp-supported-hw = <0xe>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1305600>; + }; + opp-1824000000 { + opp-hz = /bits/ 64 <1824000000>; + opp-supported-hw = <0x1>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1382400>; + }; + opp-1900800000 { + opp-hz = /bits/ 64 <1900800000>; + opp-supported-hw = <0x4>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1305600>; + }; + opp-1920000000 { + opp-hz = /bits/ 64 <1920000000>; + opp-supported-hw = <0x1>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1459200>; + }; + opp-1996800000 { + opp-hz = /bits/ 64 <1996800000>; + opp-supported-hw = <0x1>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1593600>; + }; + opp-2073600000 { + opp-hz = /bits/ 64 <2073600000>; + opp-supported-hw = <0x1>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1593600>; + }; + opp-2150400000 { + opp-hz = /bits/ 64 <2150400000>; + opp-supported-hw = <0x1>; + clock-latency-ns = <200000>; + opp-peak-kBps = <1593600>; + }; + }; + + firmware { + scm { + compatible = "qcom,scm-msm8996", "qcom,scm"; + qcom,dload-mode = <&tcsr_2 0x13000>; + }; + }; + + memory@80000000 { + device_type = "memory"; + /* We expect the bootloader to fill in the reg */ + reg = <0x0 0x80000000 0x0 0x0>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + rpm: remoteproc { + compatible = "qcom,msm8996-rpm-proc", "qcom,rpm-proc"; + + glink-edge { + compatible = "qcom,glink-rpm"; + interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; + qcom,rpm-msg-ram = <&rpm_msg_ram>; + mboxes = <&apcs_glb 0>; + + rpm_requests: rpm-requests { + compatible = "qcom,rpm-msm8996"; + qcom,glink-channels = "rpm_requests"; + + rpmcc: clock-controller { + compatible = "qcom,rpmcc-msm8996", "qcom,rpmcc"; + #clock-cells = <1>; + clocks = <&xo_board>; + clock-names = "xo"; + }; + + rpmpd: power-controller { + compatible = "qcom,msm8996-rpmpd"; + #power-domain-cells = <1>; + operating-points-v2 = <&rpmpd_opp_table>; + + rpmpd_opp_table: opp-table { + compatible = "operating-points-v2"; + + rpmpd_opp1: opp1 { + opp-level = <1>; + }; + + rpmpd_opp2: opp2 { + opp-level = <2>; + }; + + rpmpd_opp3: opp3 { + opp-level = <3>; + }; + + rpmpd_opp4: opp4 { + opp-level = <4>; + }; + + rpmpd_opp5: opp5 { + opp-level = <5>; + }; + + rpmpd_opp6: opp6 { + opp-level = <6>; + }; + }; + }; + }; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + hyp_mem: memory@85800000 { + reg = <0x0 0x85800000 0x0 0x600000>; + no-map; + }; + + xbl_mem: memory@85e00000 { + reg = <0x0 0x85e00000 0x0 0x200000>; + no-map; + }; + + smem_mem: smem-mem@86000000 { + reg = <0x0 0x86000000 0x0 0x200000>; + no-map; + }; + + tz_mem: memory@86200000 { + reg = <0x0 0x86200000 0x0 0x2600000>; + no-map; + }; + + rmtfs_mem: rmtfs { + compatible = "qcom,rmtfs-mem"; + + size = <0x0 0x200000>; + alloc-ranges = <0x0 0xa0000000 0x0 0x2000000>; + no-map; + + qcom,client-id = <1>; + qcom,vmid = <QCOM_SCM_VMID_MSS_MSA>; + }; + + mpss_mem: mpss@88800000 { + reg = <0x0 0x88800000 0x0 0x6200000>; + no-map; + }; + + adsp_mem: adsp@8ea00000 { + reg = <0x0 0x8ea00000 0x0 0x1b00000>; + no-map; + }; + + slpi_mem: slpi@90500000 { + reg = <0x0 0x90500000 0x0 0xa00000>; + no-map; + }; + + gpu_mem: gpu@90f00000 { + compatible = "shared-dma-pool"; + reg = <0x0 0x90f00000 0x0 0x100000>; + no-map; + }; + + venus_mem: venus@91000000 { + reg = <0x0 0x91000000 0x0 0x500000>; + no-map; + }; + + mba_mem: mba@91500000 { + reg = <0x0 0x91500000 0x0 0x200000>; + no-map; + }; + + mdata_mem: mpss-metadata { + alloc-ranges = <0x0 0xa0000000 0x0 0x20000000>; + size = <0x0 0x4000>; + no-map; + }; + }; + + smem { + compatible = "qcom,smem"; + memory-region = <&smem_mem>; + hwlocks = <&tcsr_mutex 3>; + }; + + smp2p-adsp { + compatible = "qcom,smp2p"; + qcom,smem = <443>, <429>; + + interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apcs_glb 10>; + + qcom,local-pid = <0>; + qcom,remote-pid = <2>; + + adsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + adsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-mpss { + compatible = "qcom,smp2p"; + qcom,smem = <435>, <428>; + + interrupts = <GIC_SPI 451 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apcs_glb 14>; + + qcom,local-pid = <0>; + qcom,remote-pid = <1>; + + mpss_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + mpss_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-slpi { + compatible = "qcom,smp2p"; + qcom,smem = <481>, <430>; + + interrupts = <GIC_SPI 178 IRQ_TYPE_EDGE_RISING>; + + mboxes = <&apcs_glb 26>; + + qcom,local-pid = <0>; + qcom,remote-pid = <3>; + + slpi_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + slpi_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + soc: soc@0 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xffffffff>; + compatible = "simple-bus"; + + pcie_phy: phy-wrapper@34000 { + compatible = "qcom,msm8996-qmp-pcie-phy"; + reg = <0x00034000 0x488>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00034000 0x4000>; + + clocks = <&gcc GCC_PCIE_PHY_AUX_CLK>, + <&gcc GCC_PCIE_PHY_CFG_AHB_CLK>, + <&gcc GCC_PCIE_CLKREF_CLK>; + clock-names = "aux", "cfg_ahb", "ref"; + + resets = <&gcc GCC_PCIE_PHY_BCR>, + <&gcc GCC_PCIE_PHY_COM_BCR>, + <&gcc GCC_PCIE_PHY_COM_NOCSR_BCR>; + reset-names = "phy", "common", "cfg"; + + status = "disabled"; + + pciephy_0: phy@1000 { + reg = <0x1000 0x130>, + <0x1200 0x200>, + <0x1400 0x1dc>; + + clocks = <&gcc GCC_PCIE_0_PIPE_CLK>; + clock-names = "pipe0"; + resets = <&gcc GCC_PCIE_0_PHY_BCR>; + reset-names = "lane0"; + + #clock-cells = <0>; + clock-output-names = "pcie_0_pipe_clk_src"; + + #phy-cells = <0>; + }; + + pciephy_1: phy@2000 { + reg = <0x2000 0x130>, + <0x2200 0x200>, + <0x2400 0x1dc>; + + clocks = <&gcc GCC_PCIE_1_PIPE_CLK>; + clock-names = "pipe1"; + resets = <&gcc GCC_PCIE_1_PHY_BCR>; + reset-names = "lane1"; + + #clock-cells = <0>; + clock-output-names = "pcie_1_pipe_clk_src"; + + #phy-cells = <0>; + }; + + pciephy_2: phy@3000 { + reg = <0x3000 0x130>, + <0x3200 0x200>, + <0x3400 0x1dc>; + + clocks = <&gcc GCC_PCIE_2_PIPE_CLK>; + clock-names = "pipe2"; + resets = <&gcc GCC_PCIE_2_PHY_BCR>; + reset-names = "lane2"; + + #clock-cells = <0>; + clock-output-names = "pcie_2_pipe_clk_src"; + + #phy-cells = <0>; + }; + }; + + rpm_msg_ram: sram@68000 { + compatible = "qcom,rpm-msg-ram"; + reg = <0x00068000 0x6000>; + }; + + qfprom@74000 { + compatible = "qcom,msm8996-qfprom", "qcom,qfprom"; + reg = <0x00074000 0x8ff>; + #address-cells = <1>; + #size-cells = <1>; + + qusb2p_hstx_trim: hstx_trim@24e { + reg = <0x24e 0x2>; + bits = <5 4>; + }; + + qusb2s_hstx_trim: hstx_trim@24f { + reg = <0x24f 0x1>; + bits = <1 4>; + }; + + speedbin_efuse: speedbin@133 { + reg = <0x133 0x1>; + bits = <5 3>; + }; + }; + + rng: rng@83000 { + compatible = "qcom,prng-ee"; + reg = <0x00083000 0x1000>; + clocks = <&gcc GCC_PRNG_AHB_CLK>; + clock-names = "core"; + }; + + gcc: clock-controller@300000 { + compatible = "qcom,gcc-msm8996"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + reg = <0x00300000 0x90000>; + + clocks = <&rpmcc RPM_SMD_XO_CLK_SRC>, + <&rpmcc RPM_SMD_LN_BB_CLK>, + <&sleep_clk>, + <&pciephy_0>, + <&pciephy_1>, + <&pciephy_2>, + <&ssusb_phy_0>, + <&ufsphy_lane 0>, + <&ufsphy_lane 1>, + <&ufsphy_lane 2>; + clock-names = "cxo", + "cxo2", + "sleep_clk", + "pcie_0_pipe_clk_src", + "pcie_1_pipe_clk_src", + "pcie_2_pipe_clk_src", + "usb3_phy_pipe_clk_src", + "ufs_rx_symbol_0_clk_src", + "ufs_rx_symbol_1_clk_src", + "ufs_tx_symbol_0_clk_src"; + }; + + bimc: interconnect@408000 { + compatible = "qcom,msm8996-bimc"; + reg = <0x00408000 0x5a000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_BIMC_CLK>, + <&rpmcc RPM_SMD_BIMC_A_CLK>; + }; + + tsens0: thermal-sensor@4a9000 { + compatible = "qcom,msm8996-tsens", "qcom,tsens-v2"; + reg = <0x004a9000 0x1000>, /* TM */ + <0x004a8000 0x1000>; /* SROT */ + #qcom,sensors = <13>; + interrupts = <GIC_SPI 458 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 445 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + tsens1: thermal-sensor@4ad000 { + compatible = "qcom,msm8996-tsens", "qcom,tsens-v2"; + reg = <0x004ad000 0x1000>, /* TM */ + <0x004ac000 0x1000>; /* SROT */ + #qcom,sensors = <8>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 430 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow", "critical"; + #thermal-sensor-cells = <1>; + }; + + cryptobam: dma-controller@644000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x00644000 0x24000>; + interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_CE1_CLK>; + clock-names = "bam_clk"; + #dma-cells = <1>; + qcom,ee = <0>; + qcom,controlled-remotely; + }; + + crypto: crypto@67a000 { + compatible = "qcom,crypto-v5.4"; + reg = <0x0067a000 0x6000>; + clocks = <&gcc GCC_CE1_AHB_CLK>, + <&gcc GCC_CE1_AXI_CLK>, + <&gcc GCC_CE1_CLK>; + clock-names = "iface", "bus", "core"; + dmas = <&cryptobam 6>, <&cryptobam 7>; + dma-names = "rx", "tx"; + }; + + cnoc: interconnect@500000 { + compatible = "qcom,msm8996-cnoc"; + reg = <0x00500000 0x1000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_CNOC_CLK>, + <&rpmcc RPM_SMD_CNOC_A_CLK>; + }; + + snoc: interconnect@524000 { + compatible = "qcom,msm8996-snoc"; + reg = <0x00524000 0x1c000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_SNOC_CLK>, + <&rpmcc RPM_SMD_SNOC_A_CLK>; + }; + + a0noc: interconnect@543000 { + compatible = "qcom,msm8996-a0noc"; + reg = <0x00543000 0x6000>; + #interconnect-cells = <1>; + clock-names = "aggre0_snoc_axi", + "aggre0_cnoc_ahb", + "aggre0_noc_mpu_cfg"; + clocks = <&gcc GCC_AGGRE0_SNOC_AXI_CLK>, + <&gcc GCC_AGGRE0_CNOC_AHB_CLK>, + <&gcc GCC_AGGRE0_NOC_MPU_CFG_AHB_CLK>; + power-domains = <&gcc AGGRE0_NOC_GDSC>; + }; + + a1noc: interconnect@562000 { + compatible = "qcom,msm8996-a1noc"; + reg = <0x00562000 0x5000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_AGGR1_NOC_CLK>, + <&rpmcc RPM_SMD_AGGR1_NOC_A_CLK>; + }; + + a2noc: interconnect@583000 { + compatible = "qcom,msm8996-a2noc"; + reg = <0x00583000 0x7000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a", "aggre2_ufs_axi", "ufs_axi"; + clocks = <&rpmcc RPM_SMD_AGGR2_NOC_CLK>, + <&rpmcc RPM_SMD_AGGR2_NOC_A_CLK>, + <&gcc GCC_AGGRE2_UFS_AXI_CLK>, + <&gcc GCC_UFS_AXI_CLK>; + }; + + mnoc: interconnect@5a4000 { + compatible = "qcom,msm8996-mnoc"; + reg = <0x005a4000 0x1c000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a", "iface"; + clocks = <&rpmcc RPM_SMD_MMAXI_CLK>, + <&rpmcc RPM_SMD_MMAXI_A_CLK>, + <&mmcc AHB_CLK_SRC>; + }; + + pnoc: interconnect@5c0000 { + compatible = "qcom,msm8996-pnoc"; + reg = <0x005c0000 0x3000>; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_PCNOC_CLK>, + <&rpmcc RPM_SMD_PCNOC_A_CLK>; + }; + + tcsr_mutex: hwlock@740000 { + compatible = "qcom,tcsr-mutex"; + reg = <0x00740000 0x20000>; + #hwlock-cells = <1>; + }; + + tcsr_1: syscon@760000 { + compatible = "qcom,tcsr-msm8996", "syscon"; + reg = <0x00760000 0x20000>; + }; + + tcsr_2: syscon@7a0000 { + compatible = "qcom,tcsr-msm8996", "syscon"; + reg = <0x007a0000 0x18000>; + }; + + mmcc: clock-controller@8c0000 { + compatible = "qcom,mmcc-msm8996"; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + reg = <0x008c0000 0x40000>; + clocks = <&xo_board>, + <&gcc GPLL0>, + <&gcc GCC_MMSS_NOC_CFG_AHB_CLK>, + <&mdss_dsi0_phy 1>, + <&mdss_dsi0_phy 0>, + <&mdss_dsi1_phy 1>, + <&mdss_dsi1_phy 0>, + <&mdss_hdmi_phy>; + clock-names = "xo", + "gpll0", + "gcc_mmss_noc_cfg_ahb_clk", + "dsi0pll", + "dsi0pllbyte", + "dsi1pll", + "dsi1pllbyte", + "hdmipll"; + assigned-clocks = <&mmcc MMPLL9_PLL>, + <&mmcc MMPLL1_PLL>, + <&mmcc MMPLL3_PLL>, + <&mmcc MMPLL4_PLL>, + <&mmcc MMPLL5_PLL>; + assigned-clock-rates = <624000000>, + <810000000>, + <980000000>, + <960000000>, + <825000000>; + }; + + mdss: display-subsystem@900000 { + compatible = "qcom,mdss"; + + reg = <0x00900000 0x1000>, + <0x009b0000 0x1040>, + <0x009b8000 0x1040>; + reg-names = "mdss_phys", + "vbif_phys", + "vbif_nrt_phys"; + + power-domains = <&mmcc MDSS_GDSC>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + + interrupt-controller; + #interrupt-cells = <1>; + + clocks = <&mmcc MDSS_AHB_CLK>, + <&mmcc MDSS_MDP_CLK>; + clock-names = "iface", "core"; + + #address-cells = <1>; + #size-cells = <1>; + ranges; + + status = "disabled"; + + mdp: display-controller@901000 { + compatible = "qcom,msm8996-mdp5", "qcom,mdp5"; + reg = <0x00901000 0x90000>; + reg-names = "mdp_phys"; + + interrupt-parent = <&mdss>; + interrupts = <0>; + + clocks = <&mmcc MDSS_AHB_CLK>, + <&mmcc MDSS_AXI_CLK>, + <&mmcc MDSS_MDP_CLK>, + <&mmcc SMMU_MDP_AXI_CLK>, + <&mmcc MDSS_VSYNC_CLK>; + clock-names = "iface", + "bus", + "core", + "iommu", + "vsync"; + + iommus = <&mdp_smmu 0>; + + assigned-clocks = <&mmcc MDSS_MDP_CLK>, + <&mmcc MDSS_VSYNC_CLK>; + assigned-clock-rates = <300000000>, + <19200000>; + + interconnects = <&mnoc MASTER_MDP_PORT0 &bimc SLAVE_EBI_CH0>, + <&mnoc MASTER_MDP_PORT1 &bimc SLAVE_EBI_CH0>, + <&mnoc MASTER_ROTATOR &bimc SLAVE_EBI_CH0>; + interconnect-names = "mdp0-mem", "mdp1-mem", "rotator-mem"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdp5_intf3_out: endpoint { + remote-endpoint = <&mdss_hdmi_in>; + }; + }; + + port@1 { + reg = <1>; + mdp5_intf1_out: endpoint { + remote-endpoint = <&mdss_dsi0_in>; + }; + }; + + port@2 { + reg = <2>; + mdp5_intf2_out: endpoint { + remote-endpoint = <&mdss_dsi1_in>; + }; + }; + }; + }; + + mdss_dsi0: dsi@994000 { + compatible = "qcom,msm8996-dsi-ctrl", + "qcom,mdss-dsi-ctrl"; + reg = <0x00994000 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <4>; + + clocks = <&mmcc MDSS_MDP_CLK>, + <&mmcc MDSS_BYTE0_CLK>, + <&mmcc MDSS_AHB_CLK>, + <&mmcc MDSS_AXI_CLK>, + <&mmcc MMSS_MISC_AHB_CLK>, + <&mmcc MDSS_PCLK0_CLK>, + <&mmcc MDSS_ESC0_CLK>; + clock-names = "mdp_core", + "byte", + "iface", + "bus", + "core_mmss", + "pixel", + "core"; + assigned-clocks = <&mmcc BYTE0_CLK_SRC>, <&mmcc PCLK0_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi0_phy 0>, <&mdss_dsi0_phy 1>; + + phys = <&mdss_dsi0_phy>; + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi0_in: endpoint { + remote-endpoint = <&mdp5_intf1_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi0_out: endpoint { + }; + }; + }; + }; + + mdss_dsi0_phy: phy@994400 { + compatible = "qcom,dsi-phy-14nm"; + reg = <0x00994400 0x100>, + <0x00994500 0x300>, + <0x00994800 0x188>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&mmcc MDSS_AHB_CLK>, <&rpmcc RPM_SMD_XO_CLK_SRC>; + clock-names = "iface", "ref"; + status = "disabled"; + }; + + mdss_dsi1: dsi@996000 { + compatible = "qcom,msm8996-dsi-ctrl", + "qcom,mdss-dsi-ctrl"; + reg = <0x00996000 0x400>; + reg-names = "dsi_ctrl"; + + interrupt-parent = <&mdss>; + interrupts = <5>; + + clocks = <&mmcc MDSS_MDP_CLK>, + <&mmcc MDSS_BYTE1_CLK>, + <&mmcc MDSS_AHB_CLK>, + <&mmcc MDSS_AXI_CLK>, + <&mmcc MMSS_MISC_AHB_CLK>, + <&mmcc MDSS_PCLK1_CLK>, + <&mmcc MDSS_ESC1_CLK>; + clock-names = "mdp_core", + "byte", + "iface", + "bus", + "core_mmss", + "pixel", + "core"; + assigned-clocks = <&mmcc BYTE1_CLK_SRC>, <&mmcc PCLK1_CLK_SRC>; + assigned-clock-parents = <&mdss_dsi1_phy 0>, <&mdss_dsi1_phy 1>; + + phys = <&mdss_dsi1_phy>; + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_dsi1_in: endpoint { + remote-endpoint = <&mdp5_intf2_out>; + }; + }; + + port@1 { + reg = <1>; + mdss_dsi1_out: endpoint { + }; + }; + }; + }; + + mdss_dsi1_phy: phy@996400 { + compatible = "qcom,dsi-phy-14nm"; + reg = <0x00996400 0x100>, + <0x00996500 0x300>, + <0x00996800 0x188>; + reg-names = "dsi_phy", + "dsi_phy_lane", + "dsi_pll"; + + #clock-cells = <1>; + #phy-cells = <0>; + + clocks = <&mmcc MDSS_AHB_CLK>, <&rpmcc RPM_SMD_XO_CLK_SRC>; + clock-names = "iface", "ref"; + status = "disabled"; + }; + + mdss_hdmi: hdmi-tx@9a0000 { + compatible = "qcom,hdmi-tx-8996"; + reg = <0x009a0000 0x50c>, + <0x00070000 0x6158>, + <0x009e0000 0xfff>; + reg-names = "core_physical", + "qfprom_physical", + "hdcp_physical"; + + interrupt-parent = <&mdss>; + interrupts = <8>; + + clocks = <&mmcc MDSS_MDP_CLK>, + <&mmcc MDSS_AHB_CLK>, + <&mmcc MDSS_HDMI_CLK>, + <&mmcc MDSS_HDMI_AHB_CLK>, + <&mmcc MDSS_EXTPCLK_CLK>; + clock-names = + "mdp_core", + "iface", + "core", + "alt_iface", + "extp"; + + phys = <&mdss_hdmi_phy>; + #sound-dai-cells = <1>; + + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + mdss_hdmi_in: endpoint { + remote-endpoint = <&mdp5_intf3_out>; + }; + }; + }; + }; + + mdss_hdmi_phy: phy@9a0600 { + #phy-cells = <0>; + compatible = "qcom,hdmi-phy-8996"; + reg = <0x009a0600 0x1c4>, + <0x009a0a00 0x124>, + <0x009a0c00 0x124>, + <0x009a0e00 0x124>, + <0x009a1000 0x124>, + <0x009a1200 0x0c8>; + reg-names = "hdmi_pll", + "hdmi_tx_l0", + "hdmi_tx_l1", + "hdmi_tx_l2", + "hdmi_tx_l3", + "hdmi_phy"; + + clocks = <&mmcc MDSS_AHB_CLK>, + <&gcc GCC_HDMI_CLKREF_CLK>, + <&xo_board>; + clock-names = "iface", + "ref", + "xo"; + + #clock-cells = <0>; + + status = "disabled"; + }; + }; + + gpu: gpu@b00000 { + compatible = "qcom,adreno-530.2", "qcom,adreno"; + + reg = <0x00b00000 0x3f000>; + reg-names = "kgsl_3d0_reg_memory"; + + interrupts = <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; + + clocks = <&mmcc GPU_GX_GFX3D_CLK>, + <&mmcc GPU_AHB_CLK>, + <&mmcc GPU_GX_RBBMTIMER_CLK>, + <&gcc GCC_BIMC_GFX_CLK>, + <&gcc GCC_MMSS_BIMC_GFX_CLK>; + + clock-names = "core", + "iface", + "rbbmtimer", + "mem", + "mem_iface"; + + interconnects = <&bimc MASTER_GRAPHICS_3D &bimc SLAVE_EBI_CH0>; + interconnect-names = "gfx-mem"; + + power-domains = <&mmcc GPU_GX_GDSC>; + iommus = <&adreno_smmu 0>; + + nvmem-cells = <&speedbin_efuse>; + nvmem-cell-names = "speed_bin"; + + operating-points-v2 = <&gpu_opp_table>; + + status = "disabled"; + + #cooling-cells = <2>; + + gpu_opp_table: opp-table { + compatible = "operating-points-v2"; + + /* + * 624Mhz is only available on speed bins 0 and 3. + * 560Mhz is only available on speed bins 0, 2 and 3. + * All the rest are available on all bins of the hardware. + */ + opp-624000000 { + opp-hz = /bits/ 64 <624000000>; + opp-supported-hw = <0x09>; + }; + opp-560000000 { + opp-hz = /bits/ 64 <560000000>; + opp-supported-hw = <0x0d>; + }; + opp-510000000 { + opp-hz = /bits/ 64 <510000000>; + opp-supported-hw = <0xff>; + }; + opp-401800000 { + opp-hz = /bits/ 64 <401800000>; + opp-supported-hw = <0xff>; + }; + opp-315000000 { + opp-hz = /bits/ 64 <315000000>; + opp-supported-hw = <0xff>; + }; + opp-214000000 { + opp-hz = /bits/ 64 <214000000>; + opp-supported-hw = <0xff>; + }; + opp-133000000 { + opp-hz = /bits/ 64 <133000000>; + opp-supported-hw = <0xff>; + }; + }; + + zap-shader { + memory-region = <&gpu_mem>; + }; + }; + + tlmm: pinctrl@1010000 { + compatible = "qcom,msm8996-pinctrl"; + reg = <0x01010000 0x300000>; + interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + gpio-ranges = <&tlmm 0 0 150>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + + blsp1_spi1_default: blsp1-spi1-default-state { + spi-pins { + pins = "gpio0", "gpio1", "gpio3"; + function = "blsp_spi1"; + drive-strength = <12>; + bias-disable; + }; + + cs-pins { + pins = "gpio2"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp1_spi1_sleep: blsp1-spi1-sleep-state { + pins = "gpio0", "gpio1", "gpio2", "gpio3"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp2_uart2_2pins_default: blsp2-uart2-2pins-state { + pins = "gpio4", "gpio5"; + function = "blsp_uart8"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_uart2_2pins_sleep: blsp2-uart2-2pins-sleep-state { + pins = "gpio4", "gpio5"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp2_i2c2_default: blsp2-i2c2-state { + pins = "gpio6", "gpio7"; + function = "blsp_i2c8"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_i2c2_sleep: blsp2-i2c2-sleep-state { + pins = "gpio6", "gpio7"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp1_i2c6_default: blsp1-i2c6-state { + pins = "gpio27", "gpio28"; + function = "blsp_i2c6"; + drive-strength = <16>; + bias-disable; + }; + + blsp1_i2c6_sleep: blsp1-i2c6-sleep-state { + pins = "gpio27", "gpio28"; + function = "gpio"; + drive-strength = <2>; + bias-pull-up; + }; + + cci0_default: cci0-default-state { + pins = "gpio17", "gpio18"; + function = "cci_i2c"; + drive-strength = <16>; + bias-disable; + }; + + camera0_state_on: + camera_rear_default: camera-rear-default-state { + camera0_mclk: mclk0-pins { + pins = "gpio13"; + function = "cam_mclk"; + drive-strength = <16>; + bias-disable; + }; + + camera0_rst: rst-pins { + pins = "gpio25"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + + camera0_pwdn: pwdn-pins { + pins = "gpio26"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + }; + + cci1_default: cci1-default-state { + pins = "gpio19", "gpio20"; + function = "cci_i2c"; + drive-strength = <16>; + bias-disable; + }; + + camera1_state_on: + camera_board_default: camera-board-default-state { + mclk1-pins { + pins = "gpio14"; + function = "cam_mclk"; + drive-strength = <16>; + bias-disable; + }; + + pwdn-pins { + pins = "gpio98"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + + rst-pins { + pins = "gpio104"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + }; + + camera2_state_on: + camera_front_default: camera-front-default-state { + camera2_mclk: mclk2-pins { + pins = "gpio15"; + function = "cam_mclk"; + drive-strength = <16>; + bias-disable; + }; + + camera2_rst: rst-pins { + pins = "gpio23"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + + pwdn-pins { + pins = "gpio133"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + }; + }; + + pcie0_state_on: pcie0-state-on-state { + perst-pins { + pins = "gpio35"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio36"; + function = "pci_e0"; + drive-strength = <2>; + bias-pull-up; + }; + + wake-pins { + pins = "gpio37"; + function = "gpio"; + drive-strength = <2>; + bias-pull-up; + }; + }; + + pcie0_state_off: pcie0-state-off-state { + perst-pins { + pins = "gpio35"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio36"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + wake-pins { + pins = "gpio37"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + }; + + blsp1_uart2_default: blsp1-uart2-default-state { + pins = "gpio41", "gpio42", "gpio43", "gpio44"; + function = "blsp_uart2"; + drive-strength = <16>; + bias-disable; + }; + + blsp1_uart2_sleep: blsp1-uart2-sleep-state { + pins = "gpio41", "gpio42", "gpio43", "gpio44"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp1_i2c3_default: blsp1-i2c3-default-state { + pins = "gpio47", "gpio48"; + function = "blsp_i2c3"; + drive-strength = <16>; + bias-disable; + }; + + blsp1_i2c3_sleep: blsp1-i2c3-sleep-state { + pins = "gpio47", "gpio48"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp2_uart3_4pins_default: blsp2-uart3-4pins-state { + pins = "gpio49", "gpio50", "gpio51", "gpio52"; + function = "blsp_uart9"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_uart3_4pins_sleep: blsp2-uart3-4pins-sleep-state { + pins = "gpio49", "gpio50", "gpio51", "gpio52"; + function = "blsp_uart9"; + drive-strength = <2>; + bias-disable; + }; + + blsp2_i2c3_default: blsp2-i2c3-state-state { + pins = "gpio51", "gpio52"; + function = "blsp_i2c9"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_i2c3_sleep: blsp2-i2c3-sleep-state { + pins = "gpio51", "gpio52"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + wcd_intr_default: wcd-intr-default-state { + pins = "gpio54"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp2_i2c1_default: blsp2-i2c1-state { + pins = "gpio55", "gpio56"; + function = "blsp_i2c7"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_i2c1_sleep: blsp2-i2c1-sleep-state { + pins = "gpio55", "gpio56"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + blsp2_i2c5_default: blsp2-i2c5-state { + pins = "gpio60", "gpio61"; + function = "blsp_i2c11"; + drive-strength = <2>; + bias-disable; + }; + + /* Sleep state for BLSP2_I2C5 is missing.. */ + + cdc_reset_active: cdc-reset-active-state { + pins = "gpio64"; + function = "gpio"; + drive-strength = <16>; + bias-pull-down; + output-high; + }; + + cdc_reset_sleep: cdc-reset-sleep-state { + pins = "gpio64"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-low; + }; + + blsp2_spi6_default: blsp2-spi6-default-state { + spi-pins { + pins = "gpio85", "gpio86", "gpio88"; + function = "blsp_spi12"; + drive-strength = <12>; + bias-disable; + }; + + cs-pins { + pins = "gpio87"; + function = "gpio"; + drive-strength = <16>; + bias-disable; + output-high; + }; + }; + + blsp2_spi6_sleep: blsp2-spi6-sleep-state { + pins = "gpio85", "gpio86", "gpio87", "gpio88"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + blsp2_i2c6_default: blsp2-i2c6-state { + pins = "gpio87", "gpio88"; + function = "blsp_i2c12"; + drive-strength = <16>; + bias-disable; + }; + + blsp2_i2c6_sleep: blsp2-i2c6-sleep-state { + pins = "gpio87", "gpio88"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + pcie1_state_on: pcie1-on-state { + perst-pins { + pins = "gpio130"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio131"; + function = "pci_e1"; + drive-strength = <2>; + bias-pull-up; + }; + + wake-pins { + pins = "gpio132"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + }; + + pcie1_state_off: pcie1-off-state { + /* Perst is missing? */ + clkreq-pins { + pins = "gpio131"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + wake-pins { + pins = "gpio132"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + }; + + pcie2_state_on: pcie2-on-state { + perst-pins { + pins = "gpio114"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + + clkreq-pins { + pins = "gpio115"; + function = "pci_e2"; + drive-strength = <2>; + bias-pull-up; + }; + + wake-pins { + pins = "gpio116"; + function = "gpio"; + drive-strength = <2>; + bias-pull-down; + }; + }; + + pcie2_state_off: pcie2-off-state { + /* Perst is missing? */ + clkreq-pins { + pins = "gpio115"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + + wake-pins { + pins = "gpio116"; + function = "gpio"; + drive-strength = <2>; + bias-disable; + }; + }; + + sdc1_state_on: sdc1-on-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <16>; + }; + + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <10>; + }; + + rclk-pins { + pins = "sdc1_rclk"; + bias-pull-down; + }; + }; + + sdc1_state_off: sdc1-off-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <2>; + }; + + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <2>; + }; + + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <2>; + }; + + rclk-pins { + pins = "sdc1_rclk"; + bias-pull-down; + }; + }; + + sdc2_state_on: sdc2-on-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; + drive-strength = <16>; + }; + + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + + data-pins { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <10>; + }; + }; + + sdc2_state_off: sdc2-off-state { + clk-pins { + pins = "sdc2_clk"; + bias-disable; + drive-strength = <2>; + }; + + cmd-pins { + pins = "sdc2_cmd"; + bias-pull-up; + drive-strength = <2>; + }; + + data-pins { + pins = "sdc2_data"; + bias-pull-up; + drive-strength = <2>; + }; + }; + }; + + sram@290000 { + compatible = "qcom,rpm-stats"; + reg = <0x00290000 0x10000>; + }; + + spmi_bus: spmi@400f000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0x0400f000 0x1000>, + <0x04400000 0x800000>, + <0x04c00000 0x800000>, + <0x05800000 0x200000>, + <0x0400a000 0x002100>; + reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; + interrupt-names = "periph_irq"; + interrupts = <GIC_SPI 326 IRQ_TYPE_LEVEL_HIGH>; + qcom,ee = <0>; + qcom,channel = <0>; + #address-cells = <2>; + #size-cells = <0>; + interrupt-controller; + #interrupt-cells = <4>; + }; + + bus@0 { + power-domains = <&gcc AGGRE0_NOC_GDSC>; + compatible = "simple-pm-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0xffffffff>; + + pcie0: pcie@600000 { + compatible = "qcom,pcie-msm8996"; + status = "disabled"; + power-domains = <&gcc PCIE0_GDSC>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + + reg = <0x00600000 0x2000>, + <0x0c000000 0xf1d>, + <0x0c000f20 0xa8>, + <0x0c100000 0x100000>; + reg-names = "parf", "dbi", "elbi","config"; + + phys = <&pciephy_0>; + phy-names = "pciephy"; + + #address-cells = <3>; + #size-cells = <2>; + ranges = <0x01000000 0x0 0x00000000 0x0c200000 0x0 0x100000>, + <0x02000000 0x0 0x0c300000 0x0c300000 0x0 0xd00000>; + + device_type = "pci"; + + interrupts = <GIC_SPI 405 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 244 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 245 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 247 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 248 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pcie0_state_on>; + pinctrl-1 = <&pcie0_state_off>; + + linux,pci-domain = <0>; + + clocks = <&gcc GCC_PCIE_0_PIPE_CLK>, + <&gcc GCC_PCIE_0_AUX_CLK>, + <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_AXI_CLK>; + + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave"; + }; + + pcie1: pcie@608000 { + compatible = "qcom,pcie-msm8996"; + power-domains = <&gcc PCIE1_GDSC>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + + status = "disabled"; + + reg = <0x00608000 0x2000>, + <0x0d000000 0xf1d>, + <0x0d000f20 0xa8>, + <0x0d100000 0x100000>; + + reg-names = "parf", "dbi", "elbi","config"; + + phys = <&pciephy_1>; + phy-names = "pciephy"; + + #address-cells = <3>; + #size-cells = <2>; + ranges = <0x01000000 0x0 0x00000000 0x0d200000 0x0 0x100000>, + <0x02000000 0x0 0x0d300000 0x0d300000 0x0 0xd00000>; + + device_type = "pci"; + + interrupts = <GIC_SPI 413 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 272 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 273 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 274 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 275 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pcie1_state_on>; + pinctrl-1 = <&pcie1_state_off>; + + linux,pci-domain = <1>; + + clocks = <&gcc GCC_PCIE_1_PIPE_CLK>, + <&gcc GCC_PCIE_1_AUX_CLK>, + <&gcc GCC_PCIE_1_CFG_AHB_CLK>, + <&gcc GCC_PCIE_1_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_1_SLV_AXI_CLK>; + + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave"; + }; + + pcie2: pcie@610000 { + compatible = "qcom,pcie-msm8996"; + power-domains = <&gcc PCIE2_GDSC>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + status = "disabled"; + reg = <0x00610000 0x2000>, + <0x0e000000 0xf1d>, + <0x0e000f20 0xa8>, + <0x0e100000 0x100000>; + + reg-names = "parf", "dbi", "elbi","config"; + + phys = <&pciephy_2>; + phy-names = "pciephy"; + + #address-cells = <3>; + #size-cells = <2>; + ranges = <0x01000000 0x0 0x00000000 0x0e200000 0x0 0x100000>, + <0x02000000 0x0 0x0e300000 0x0e300000 0x0 0x1d00000>; + + device_type = "pci"; + + interrupts = <GIC_SPI 421 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc 0 142 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc 0 143 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc 0 144 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc 0 145 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pcie2_state_on>; + pinctrl-1 = <&pcie2_state_off>; + + linux,pci-domain = <2>; + clocks = <&gcc GCC_PCIE_2_PIPE_CLK>, + <&gcc GCC_PCIE_2_AUX_CLK>, + <&gcc GCC_PCIE_2_CFG_AHB_CLK>, + <&gcc GCC_PCIE_2_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_2_SLV_AXI_CLK>; + + clock-names = "pipe", + "aux", + "cfg", + "bus_master", + "bus_slave"; + }; + }; + + ufshc: ufshc@624000 { + compatible = "qcom,msm8996-ufshc", "qcom,ufshc", + "jedec,ufs-2.0"; + reg = <0x00624000 0x2500>; + interrupts = <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; + + phys = <&ufsphy_lane>; + phy-names = "ufsphy"; + + power-domains = <&gcc UFS_GDSC>; + + clock-names = + "core_clk_src", + "core_clk", + "bus_clk", + "bus_aggr_clk", + "iface_clk", + "core_clk_unipro_src", + "core_clk_unipro", + "core_clk_ice", + "ref_clk", + "tx_lane0_sync_clk", + "rx_lane0_sync_clk"; + clocks = + <&gcc UFS_AXI_CLK_SRC>, + <&gcc GCC_UFS_AXI_CLK>, + <&gcc GCC_SYS_NOC_UFS_AXI_CLK>, + <&gcc GCC_AGGRE2_UFS_AXI_CLK>, + <&gcc GCC_UFS_AHB_CLK>, + <&gcc UFS_ICE_CORE_CLK_SRC>, + <&gcc GCC_UFS_UNIPRO_CORE_CLK>, + <&gcc GCC_UFS_ICE_CORE_CLK>, + <&rpmcc RPM_SMD_LN_BB_CLK>, + <&gcc GCC_UFS_TX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_RX_SYMBOL_0_CLK>; + freq-table-hz = + <100000000 200000000>, + <0 0>, + <0 0>, + <0 0>, + <0 0>, + <150000000 300000000>, + <0 0>, + <0 0>, + <0 0>, + <0 0>, + <0 0>; + + interconnects = <&a2noc MASTER_UFS &bimc SLAVE_EBI_CH0>, + <&bimc MASTER_AMPSS_M0 &cnoc SLAVE_UFS_CFG>; + interconnect-names = "ufs-ddr", "cpu-ufs"; + + lanes-per-direction = <1>; + #reset-cells = <1>; + status = "disabled"; + }; + + ufsphy: phy@627000 { + compatible = "qcom,msm8996-qmp-ufs-phy"; + reg = <0x00627000 0x1c4>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + clocks = <&gcc GCC_UFS_CLKREF_CLK>; + clock-names = "ref"; + + resets = <&ufshc 0>; + reset-names = "ufsphy"; + status = "disabled"; + + ufsphy_lane: phy@627400 { + reg = <0x627400 0x12c>, + <0x627600 0x200>, + <0x627c00 0x1b4>; + #clock-cells = <1>; + #phy-cells = <0>; + }; + }; + + camss: camss@a34000 { + compatible = "qcom,msm8996-camss"; + reg = <0x00a34000 0x1000>, + <0x00a00030 0x4>, + <0x00a35000 0x1000>, + <0x00a00038 0x4>, + <0x00a36000 0x1000>, + <0x00a00040 0x4>, + <0x00a30000 0x100>, + <0x00a30400 0x100>, + <0x00a30800 0x100>, + <0x00a30c00 0x100>, + <0x00a31000 0x500>, + <0x00a00020 0x10>, + <0x00a10000 0x1000>, + <0x00a14000 0x1000>; + reg-names = "csiphy0", + "csiphy0_clk_mux", + "csiphy1", + "csiphy1_clk_mux", + "csiphy2", + "csiphy2_clk_mux", + "csid0", + "csid1", + "csid2", + "csid3", + "ispif", + "csi_clk_mux", + "vfe0", + "vfe1"; + interrupts = <GIC_SPI 78 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 79 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 80 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 296 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 297 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 298 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 299 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 309 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 314 IRQ_TYPE_EDGE_RISING>, + <GIC_SPI 315 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "csiphy0", + "csiphy1", + "csiphy2", + "csid0", + "csid1", + "csid2", + "csid3", + "ispif", + "vfe0", + "vfe1"; + power-domains = <&mmcc VFE0_GDSC>, + <&mmcc VFE1_GDSC>; + clocks = <&mmcc CAMSS_TOP_AHB_CLK>, + <&mmcc CAMSS_ISPIF_AHB_CLK>, + <&mmcc CAMSS_CSI0PHYTIMER_CLK>, + <&mmcc CAMSS_CSI1PHYTIMER_CLK>, + <&mmcc CAMSS_CSI2PHYTIMER_CLK>, + <&mmcc CAMSS_CSI0_AHB_CLK>, + <&mmcc CAMSS_CSI0_CLK>, + <&mmcc CAMSS_CSI0PHY_CLK>, + <&mmcc CAMSS_CSI0PIX_CLK>, + <&mmcc CAMSS_CSI0RDI_CLK>, + <&mmcc CAMSS_CSI1_AHB_CLK>, + <&mmcc CAMSS_CSI1_CLK>, + <&mmcc CAMSS_CSI1PHY_CLK>, + <&mmcc CAMSS_CSI1PIX_CLK>, + <&mmcc CAMSS_CSI1RDI_CLK>, + <&mmcc CAMSS_CSI2_AHB_CLK>, + <&mmcc CAMSS_CSI2_CLK>, + <&mmcc CAMSS_CSI2PHY_CLK>, + <&mmcc CAMSS_CSI2PIX_CLK>, + <&mmcc CAMSS_CSI2RDI_CLK>, + <&mmcc CAMSS_CSI3_AHB_CLK>, + <&mmcc CAMSS_CSI3_CLK>, + <&mmcc CAMSS_CSI3PHY_CLK>, + <&mmcc CAMSS_CSI3PIX_CLK>, + <&mmcc CAMSS_CSI3RDI_CLK>, + <&mmcc CAMSS_AHB_CLK>, + <&mmcc CAMSS_VFE0_CLK>, + <&mmcc CAMSS_CSI_VFE0_CLK>, + <&mmcc CAMSS_VFE0_AHB_CLK>, + <&mmcc CAMSS_VFE0_STREAM_CLK>, + <&mmcc CAMSS_VFE1_CLK>, + <&mmcc CAMSS_CSI_VFE1_CLK>, + <&mmcc CAMSS_VFE1_AHB_CLK>, + <&mmcc CAMSS_VFE1_STREAM_CLK>, + <&mmcc CAMSS_VFE_AHB_CLK>, + <&mmcc CAMSS_VFE_AXI_CLK>; + clock-names = "top_ahb", + "ispif_ahb", + "csiphy0_timer", + "csiphy1_timer", + "csiphy2_timer", + "csi0_ahb", + "csi0", + "csi0_phy", + "csi0_pix", + "csi0_rdi", + "csi1_ahb", + "csi1", + "csi1_phy", + "csi1_pix", + "csi1_rdi", + "csi2_ahb", + "csi2", + "csi2_phy", + "csi2_pix", + "csi2_rdi", + "csi3_ahb", + "csi3", + "csi3_phy", + "csi3_pix", + "csi3_rdi", + "ahb", + "vfe0", + "csi_vfe0", + "vfe0_ahb", + "vfe0_stream", + "vfe1", + "csi_vfe1", + "vfe1_ahb", + "vfe1_stream", + "vfe_ahb", + "vfe_axi"; + iommus = <&vfe_smmu 0>, + <&vfe_smmu 1>, + <&vfe_smmu 2>, + <&vfe_smmu 3>; + status = "disabled"; + ports { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + cci: cci@a0c000 { + compatible = "qcom,msm8996-cci"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xa0c000 0x1000>; + interrupts = <GIC_SPI 295 IRQ_TYPE_EDGE_RISING>; + power-domains = <&mmcc CAMSS_GDSC>; + clocks = <&mmcc CAMSS_TOP_AHB_CLK>, + <&mmcc CAMSS_CCI_AHB_CLK>, + <&mmcc CAMSS_CCI_CLK>, + <&mmcc CAMSS_AHB_CLK>; + clock-names = "camss_top_ahb", + "cci_ahb", + "cci", + "camss_ahb"; + assigned-clocks = <&mmcc CAMSS_CCI_AHB_CLK>, + <&mmcc CAMSS_CCI_CLK>; + assigned-clock-rates = <80000000>, <37500000>; + pinctrl-names = "default"; + pinctrl-0 = <&cci0_default &cci1_default>; + status = "disabled"; + + cci_i2c0: i2c-bus@0 { + reg = <0>; + clock-frequency = <400000>; + #address-cells = <1>; + #size-cells = <0>; + }; + + cci_i2c1: i2c-bus@1 { + reg = <1>; + clock-frequency = <400000>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + adreno_smmu: iommu@b40000 { + compatible = "qcom,msm8996-smmu-v2", "qcom,adreno-smmu", "qcom,smmu-v2"; + reg = <0x00b40000 0x10000>; + + #global-interrupts = <1>; + interrupts = <GIC_SPI 334 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 329 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 330 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <1>; + + clocks = <&gcc GCC_MMSS_BIMC_GFX_CLK>, + <&mmcc GPU_AHB_CLK>; + clock-names = "bus", "iface"; + + power-domains = <&mmcc GPU_GDSC>; + }; + + venus: video-codec@c00000 { + compatible = "qcom,msm8996-venus"; + reg = <0x00c00000 0xff000>; + interrupts = <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&mmcc VENUS_GDSC>; + clocks = <&mmcc VIDEO_CORE_CLK>, + <&mmcc VIDEO_AHB_CLK>, + <&mmcc VIDEO_AXI_CLK>, + <&mmcc VIDEO_MAXI_CLK>; + clock-names = "core", "iface", "bus", "mbus"; + interconnects = <&mnoc MASTER_VIDEO_P0 &bimc SLAVE_EBI_CH0>, + <&bimc MASTER_AMPSS_M0 &mnoc SLAVE_VENUS_CFG>; + interconnect-names = "video-mem", "cpu-cfg"; + iommus = <&venus_smmu 0x00>, + <&venus_smmu 0x01>, + <&venus_smmu 0x0a>, + <&venus_smmu 0x07>, + <&venus_smmu 0x0e>, + <&venus_smmu 0x0f>, + <&venus_smmu 0x08>, + <&venus_smmu 0x09>, + <&venus_smmu 0x0b>, + <&venus_smmu 0x0c>, + <&venus_smmu 0x0d>, + <&venus_smmu 0x10>, + <&venus_smmu 0x11>, + <&venus_smmu 0x21>, + <&venus_smmu 0x28>, + <&venus_smmu 0x29>, + <&venus_smmu 0x2b>, + <&venus_smmu 0x2c>, + <&venus_smmu 0x2d>, + <&venus_smmu 0x31>; + memory-region = <&venus_mem>; + status = "disabled"; + + video-decoder { + compatible = "venus-decoder"; + clocks = <&mmcc VIDEO_SUBCORE0_CLK>; + clock-names = "core"; + power-domains = <&mmcc VENUS_CORE0_GDSC>; + }; + + video-encoder { + compatible = "venus-encoder"; + clocks = <&mmcc VIDEO_SUBCORE1_CLK>; + clock-names = "core"; + power-domains = <&mmcc VENUS_CORE1_GDSC>; + }; + }; + + mdp_smmu: iommu@d00000 { + compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; + reg = <0x00d00000 0x10000>; + + #global-interrupts = <1>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 320 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <1>; + clocks = <&mmcc SMMU_MDP_AXI_CLK>, + <&mmcc SMMU_MDP_AHB_CLK>; + clock-names = "bus", "iface"; + + power-domains = <&mmcc MDSS_GDSC>; + }; + + venus_smmu: iommu@d40000 { + compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; + reg = <0x00d40000 0x20000>; + #global-interrupts = <1>; + interrupts = <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 335 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 336 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 337 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 338 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 339 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 340 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 341 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&mmcc MMAGIC_VIDEO_GDSC>; + clocks = <&mmcc SMMU_VIDEO_AXI_CLK>, + <&mmcc SMMU_VIDEO_AHB_CLK>; + clock-names = "bus", "iface"; + #iommu-cells = <1>; + status = "okay"; + }; + + vfe_smmu: iommu@da0000 { + compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; + reg = <0x00da0000 0x10000>; + + #global-interrupts = <1>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 343 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 344 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&mmcc MMAGIC_CAMSS_GDSC>; + clocks = <&mmcc SMMU_VFE_AXI_CLK>, + <&mmcc SMMU_VFE_AHB_CLK>; + clock-names = "bus", "iface"; + #iommu-cells = <1>; + }; + + lpass_q6_smmu: iommu@1600000 { + compatible = "qcom,msm8996-smmu-v2", "qcom,smmu-v2"; + reg = <0x01600000 0x20000>; + #iommu-cells = <1>; + power-domains = <&gcc HLOS1_VOTE_LPASS_CORE_GDSC>; + + #global-interrupts = <1>; + interrupts = <GIC_SPI 404 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 393 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 394 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 395 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 396 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 398 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 399 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 400 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 401 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 402 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 403 IRQ_TYPE_LEVEL_HIGH>; + + clocks = <&gcc GCC_HLOS1_VOTE_LPASS_ADSP_SMMU_CLK>, + <&gcc GCC_HLOS1_VOTE_LPASS_CORE_SMMU_CLK>; + clock-names = "bus", "iface"; + }; + + slpi_pil: remoteproc@1c00000 { + compatible = "qcom,msm8996-slpi-pil"; + reg = <0x01c00000 0x4000>; + + interrupts-extended = <&intc 0 390 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&slpi_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", + "fatal", + "ready", + "handover", + "stop-ack"; + + clocks = <&xo_board>, + <&rpmcc RPM_SMD_AGGR2_NOC_CLK>; + clock-names = "xo", "aggre2"; + + memory-region = <&slpi_mem>; + + qcom,smem-states = <&slpi_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + power-domains = <&rpmpd MSM8996_VDDSSCX>; + power-domain-names = "ssc_cx"; + + status = "disabled"; + + smd-edge { + interrupts = <GIC_SPI 176 IRQ_TYPE_EDGE_RISING>; + + label = "dsps"; + mboxes = <&apcs_glb 25>; + qcom,smd-edge = <3>; + qcom,remote-pid = <3>; + }; + }; + + mss_pil: remoteproc@2080000 { + compatible = "qcom,msm8996-mss-pil"; + reg = <0x2080000 0x100>, + <0x2180000 0x020>; + reg-names = "qdsp6", "rmb"; + + interrupts-extended = <&intc 0 448 IRQ_TYPE_EDGE_RISING>, + <&mpss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&mpss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&mpss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&mpss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>, + <&mpss_smp2p_in 7 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack", + "shutdown-ack"; + + clocks = <&gcc GCC_MSS_CFG_AHB_CLK>, + <&gcc GCC_MSS_Q6_BIMC_AXI_CLK>, + <&gcc GCC_BOOT_ROM_AHB_CLK>, + <&xo_board>, + <&gcc GCC_MSS_GPLL0_DIV_CLK>, + <&gcc GCC_MSS_SNOC_AXI_CLK>, + <&gcc GCC_MSS_MNOC_BIMC_AXI_CLK>, + <&rpmcc RPM_SMD_PCNOC_CLK>, + <&rpmcc RPM_SMD_QDSS_CLK>; + clock-names = "iface", "bus", "mem", "xo", "gpll0_mss", + "snoc_axi", "mnoc_axi", "pnoc", "qdss"; + + resets = <&gcc GCC_MSS_RESTART>; + reset-names = "mss_restart"; + + power-domains = <&rpmpd MSM8996_VDDCX>, + <&rpmpd MSM8996_VDDMX>; + power-domain-names = "cx", "mx"; + + qcom,smem-states = <&mpss_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + qcom,halt-regs = <&tcsr_1 0x3000 0x5000 0x4000>; + + status = "disabled"; + + mba { + memory-region = <&mba_mem>; + }; + + mpss { + memory-region = <&mpss_mem>; + }; + + metadata { + memory-region = <&mdata_mem>; + }; + + smd-edge { + interrupts = <GIC_SPI 449 IRQ_TYPE_EDGE_RISING>; + + label = "mpss"; + mboxes = <&apcs_glb 12>; + qcom,smd-edge = <0>; + qcom,remote-pid = <1>; + }; + }; + + stm@3002000 { + compatible = "arm,coresight-stm", "arm,primecell"; + reg = <0x3002000 0x1000>, + <0x8280000 0x180000>; + reg-names = "stm-base", "stm-stimulus-base"; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + out-ports { + port { + stm_out: endpoint { + remote-endpoint = + <&funnel0_in>; + }; + }; + }; + }; + + tpiu@3020000 { + compatible = "arm,coresight-tpiu", "arm,primecell"; + reg = <0x3020000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + port { + tpiu_in: endpoint { + remote-endpoint = + <&replicator_out1>; + }; + }; + }; + }; + + funnel@3021000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3021000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@7 { + reg = <7>; + funnel0_in: endpoint { + remote-endpoint = + <&stm_out>; + }; + }; + }; + + out-ports { + port { + funnel0_out: endpoint { + remote-endpoint = + <&merge_funnel_in0>; + }; + }; + }; + }; + + funnel@3022000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3022000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@6 { + reg = <6>; + funnel1_in: endpoint { + remote-endpoint = + <&apss_merge_funnel_out>; + }; + }; + }; + + out-ports { + port { + funnel1_out: endpoint { + remote-endpoint = + <&merge_funnel_in1>; + }; + }; + }; + }; + + funnel@3023000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3023000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + + out-ports { + port { + funnel2_out: endpoint { + remote-endpoint = + <&merge_funnel_in2>; + }; + }; + }; + }; + + funnel@3025000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3025000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + merge_funnel_in0: endpoint { + remote-endpoint = + <&funnel0_out>; + }; + }; + + port@1 { + reg = <1>; + merge_funnel_in1: endpoint { + remote-endpoint = + <&funnel1_out>; + }; + }; + + port@2 { + reg = <2>; + merge_funnel_in2: endpoint { + remote-endpoint = + <&funnel2_out>; + }; + }; + }; + + out-ports { + port { + merge_funnel_out: endpoint { + remote-endpoint = + <&etf_in>; + }; + }; + }; + }; + + replicator@3026000 { + compatible = "arm,coresight-dynamic-replicator", "arm,primecell"; + reg = <0x3026000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + port { + replicator_in: endpoint { + remote-endpoint = + <&etf_out>; + }; + }; + }; + + out-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + replicator_out0: endpoint { + remote-endpoint = + <&etr_in>; + }; + }; + + port@1 { + reg = <1>; + replicator_out1: endpoint { + remote-endpoint = + <&tpiu_in>; + }; + }; + }; + }; + + etf@3027000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x3027000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + port { + etf_in: endpoint { + remote-endpoint = + <&merge_funnel_out>; + }; + }; + }; + + out-ports { + port { + etf_out: endpoint { + remote-endpoint = + <&replicator_in>; + }; + }; + }; + }; + + etr@3028000 { + compatible = "arm,coresight-tmc", "arm,primecell"; + reg = <0x3028000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + arm,scatter-gather; + + in-ports { + port { + etr_in: endpoint { + remote-endpoint = + <&replicator_out0>; + }; + }; + }; + }; + + debug@3810000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x3810000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU0>; + }; + + etm@3840000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x3840000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + cpu = <&CPU0>; + + out-ports { + port { + etm0_out: endpoint { + remote-endpoint = + <&apss_funnel0_in0>; + }; + }; + }; + }; + + debug@3910000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x3910000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU1>; + }; + + etm@3940000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x3940000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + cpu = <&CPU1>; + + out-ports { + port { + etm1_out: endpoint { + remote-endpoint = + <&apss_funnel0_in1>; + }; + }; + }; + }; + + funnel@39b0000 { /* APSS Funnel 0 */ + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x39b0000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + apss_funnel0_in0: endpoint { + remote-endpoint = <&etm0_out>; + }; + }; + + port@1 { + reg = <1>; + apss_funnel0_in1: endpoint { + remote-endpoint = <&etm1_out>; + }; + }; + }; + + out-ports { + port { + apss_funnel0_out: endpoint { + remote-endpoint = + <&apss_merge_funnel_in0>; + }; + }; + }; + }; + + debug@3a10000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x3a10000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU2>; + }; + + etm@3a40000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x3a40000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + cpu = <&CPU2>; + + out-ports { + port { + etm2_out: endpoint { + remote-endpoint = + <&apss_funnel1_in0>; + }; + }; + }; + }; + + debug@3b10000 { + compatible = "arm,coresight-cpu-debug", "arm,primecell"; + reg = <0x3b10000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>; + clock-names = "apb_pclk"; + + cpu = <&CPU3>; + }; + + etm@3b40000 { + compatible = "arm,coresight-etm4x", "arm,primecell"; + reg = <0x3b40000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + cpu = <&CPU3>; + + out-ports { + port { + etm3_out: endpoint { + remote-endpoint = + <&apss_funnel1_in1>; + }; + }; + }; + }; + + funnel@3bb0000 { /* APSS Funnel 1 */ + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3bb0000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + apss_funnel1_in0: endpoint { + remote-endpoint = <&etm2_out>; + }; + }; + + port@1 { + reg = <1>; + apss_funnel1_in1: endpoint { + remote-endpoint = <&etm3_out>; + }; + }; + }; + + out-ports { + port { + apss_funnel1_out: endpoint { + remote-endpoint = + <&apss_merge_funnel_in1>; + }; + }; + }; + }; + + funnel@3bc0000 { + compatible = "arm,coresight-dynamic-funnel", "arm,primecell"; + reg = <0x3bc0000 0x1000>; + + clocks = <&rpmcc RPM_QDSS_CLK>, <&rpmcc RPM_QDSS_A_CLK>; + clock-names = "apb_pclk", "atclk"; + + in-ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + apss_merge_funnel_in0: endpoint { + remote-endpoint = + <&apss_funnel0_out>; + }; + }; + + port@1 { + reg = <1>; + apss_merge_funnel_in1: endpoint { + remote-endpoint = + <&apss_funnel1_out>; + }; + }; + }; + + out-ports { + port { + apss_merge_funnel_out: endpoint { + remote-endpoint = + <&funnel1_in>; + }; + }; + }; + }; + + kryocc: clock-controller@6400000 { + compatible = "qcom,msm8996-apcc"; + reg = <0x06400000 0x90000>; + + clock-names = "xo", "sys_apcs_aux"; + clocks = <&rpmcc RPM_SMD_XO_A_CLK_SRC>, <&apcs_glb>; + + #clock-cells = <1>; + }; + + usb3: usb@6af8800 { + compatible = "qcom,msm8996-dwc3", "qcom,dwc3"; + reg = <0x06af8800 0x400>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + interrupts = <GIC_SPI 347 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hs_phy_irq", "ss_phy_irq"; + + clocks = <&gcc GCC_SYS_NOC_USB3_AXI_CLK>, + <&gcc GCC_USB30_MASTER_CLK>, + <&gcc GCC_AGGRE2_USB3_AXI_CLK>, + <&gcc GCC_USB30_SLEEP_CLK>, + <&gcc GCC_USB30_MOCK_UTMI_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi"; + + assigned-clocks = <&gcc GCC_USB30_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_MASTER_CLK>; + assigned-clock-rates = <19200000>, <120000000>; + + interconnects = <&a2noc MASTER_USB3 &bimc SLAVE_EBI_CH0>, + <&bimc MASTER_AMPSS_M0 &snoc SLAVE_USB3>; + interconnect-names = "usb-ddr", "apps-usb"; + + power-domains = <&gcc USB30_GDSC>; + status = "disabled"; + + usb3_dwc3: usb@6a00000 { + compatible = "snps,dwc3"; + reg = <0x06a00000 0xcc00>; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; + phys = <&hsusb_phy1>, <&ssusb_phy_0>; + phy-names = "usb2-phy", "usb3-phy"; + snps,hird-threshold = /bits/ 8 <0>; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + snps,is-utmi-l1-suspend; + tx-fifo-resize; + }; + }; + + usb3phy: phy@7410000 { + compatible = "qcom,msm8996-qmp-usb3-phy"; + reg = <0x07410000 0x1c4>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + clocks = <&gcc GCC_USB3_PHY_AUX_CLK>, + <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&gcc GCC_USB3_CLKREF_CLK>; + clock-names = "aux", "cfg_ahb", "ref"; + + resets = <&gcc GCC_USB3_PHY_BCR>, + <&gcc GCC_USB3PHY_PHY_BCR>; + reset-names = "phy", "common"; + status = "disabled"; + + ssusb_phy_0: phy@7410200 { + reg = <0x07410200 0x200>, + <0x07410400 0x130>, + <0x07410600 0x1a8>; + #phy-cells = <0>; + + #clock-cells = <0>; + clock-output-names = "usb3_phy_pipe_clk_src"; + clocks = <&gcc GCC_USB3_PHY_PIPE_CLK>; + clock-names = "pipe0"; + }; + }; + + hsusb_phy1: phy@7411000 { + compatible = "qcom,msm8996-qusb2-phy"; + reg = <0x07411000 0x180>; + #phy-cells = <0>; + + clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&gcc GCC_RX1_USB2_CLKREF_CLK>; + clock-names = "cfg_ahb", "ref"; + + resets = <&gcc GCC_QUSB2PHY_PRIM_BCR>; + nvmem-cells = <&qusb2p_hstx_trim>; + status = "disabled"; + }; + + hsusb_phy2: phy@7412000 { + compatible = "qcom,msm8996-qusb2-phy"; + reg = <0x07412000 0x180>; + #phy-cells = <0>; + + clocks = <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>, + <&gcc GCC_RX2_USB2_CLKREF_CLK>; + clock-names = "cfg_ahb", "ref"; + + resets = <&gcc GCC_QUSB2PHY_SEC_BCR>; + nvmem-cells = <&qusb2s_hstx_trim>; + status = "disabled"; + }; + + sdhc1: mmc@7464900 { + compatible = "qcom,msm8996-sdhci", "qcom,sdhci-msm-v4"; + reg = <0x07464900 0x11c>, <0x07464000 0x800>; + reg-names = "hc", "core"; + + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + + clock-names = "iface", "core", "xo"; + clocks = <&gcc GCC_SDCC1_AHB_CLK>, + <&gcc GCC_SDCC1_APPS_CLK>, + <&rpmcc RPM_SMD_XO_CLK_SRC>; + resets = <&gcc GCC_SDCC1_BCR>; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc1_state_on>; + pinctrl-1 = <&sdc1_state_off>; + + bus-width = <8>; + non-removable; + status = "disabled"; + }; + + sdhc2: mmc@74a4900 { + compatible = "qcom,msm8996-sdhci", "qcom,sdhci-msm-v4"; + reg = <0x074a4900 0x314>, <0x074a4000 0x800>; + reg-names = "hc", "core"; + + interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + + clock-names = "iface", "core", "xo"; + clocks = <&gcc GCC_SDCC2_AHB_CLK>, + <&gcc GCC_SDCC2_APPS_CLK>, + <&rpmcc RPM_SMD_XO_CLK_SRC>; + resets = <&gcc GCC_SDCC2_BCR>; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc2_state_on>; + pinctrl-1 = <&sdc2_state_off>; + + bus-width = <4>; + status = "disabled"; + }; + + blsp1_dma: dma-controller@7544000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x07544000 0x2b000>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "bam_clk"; + qcom,controlled-remotely; + #dma-cells = <1>; + qcom,ee = <0>; + }; + + blsp1_uart2: serial@7570000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x07570000 0x1000>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp1_uart2_default>; + pinctrl-1 = <&blsp1_uart2_sleep>; + dmas = <&blsp1_dma 2>, <&blsp1_dma 3>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + + blsp1_spi1: spi@7575000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x07575000 0x600>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp1_spi1_default>; + pinctrl-1 = <&blsp1_spi1_sleep>; + dmas = <&blsp1_dma 12>, <&blsp1_dma 13>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c3: i2c@7577000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x07577000 0x1000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp1_i2c3_default>; + pinctrl-1 = <&blsp1_i2c3_sleep>; + dmas = <&blsp1_dma 16>, <&blsp1_dma 17>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c6: i2c@757a000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x757a000 0x1000>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP6_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp1_i2c6_default>; + pinctrl-1 = <&blsp1_i2c6_sleep>; + dmas = <&blsp1_dma 22>, <&blsp1_dma 23>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_dma: dma-controller@7584000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x07584000 0x2b000>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "bam_clk"; + qcom,controlled-remotely; + #dma-cells = <1>; + qcom,ee = <0>; + }; + + blsp2_uart2: serial@75b0000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x075b0000 0x1000>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_UART2_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + status = "disabled"; + }; + + blsp2_uart3: serial@75b1000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x075b1000 0x1000>; + interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_UART3_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + status = "disabled"; + }; + + blsp2_i2c1: i2c@75b5000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x075b5000 0x1000>; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP1_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_i2c1_default>; + pinctrl-1 = <&blsp2_i2c1_sleep>; + dmas = <&blsp2_dma 12>, <&blsp2_dma 13>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_i2c2: i2c@75b6000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x075b6000 0x1000>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP2_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_i2c2_default>; + pinctrl-1 = <&blsp2_i2c2_sleep>; + dmas = <&blsp2_dma 14>, <&blsp2_dma 15>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_i2c3: i2c@75b7000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x075b7000 0x1000>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP3_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_i2c3_default>; + pinctrl-1 = <&blsp2_i2c3_sleep>; + dmas = <&blsp2_dma 16>, <&blsp2_dma 17>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_i2c5: i2c@75b9000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x75b9000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP5_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp2_i2c5_default>; + dmas = <&blsp2_dma 20>, <&blsp2_dma 21>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_i2c6: i2c@75ba000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x75ba000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP6_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_i2c6_default>; + pinctrl-1 = <&blsp2_i2c6_sleep>; + dmas = <&blsp2_dma 22>, <&blsp2_dma 23>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_spi6: spi@75ba000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x075ba000 0x600>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP6_SPI_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&blsp2_spi6_default>; + pinctrl-1 = <&blsp2_spi6_sleep>; + dmas = <&blsp2_dma 22>, <&blsp2_dma 23>; + dma-names = "tx", "rx"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + usb2: usb@76f8800 { + compatible = "qcom,msm8996-dwc3", "qcom,dwc3"; + reg = <0x076f8800 0x400>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + interrupts = <GIC_SPI 352 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hs_phy_irq"; + + clocks = <&gcc GCC_PERIPH_NOC_USB20_AHB_CLK>, + <&gcc GCC_USB20_MASTER_CLK>, + <&gcc GCC_USB20_MOCK_UTMI_CLK>, + <&gcc GCC_USB20_SLEEP_CLK>, + <&gcc GCC_USB_PHY_CFG_AHB2PHY_CLK>; + clock-names = "cfg_noc", + "core", + "iface", + "sleep", + "mock_utmi"; + + assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, + <&gcc GCC_USB20_MASTER_CLK>; + assigned-clock-rates = <19200000>, <60000000>; + + power-domains = <&gcc USB30_GDSC>; + qcom,select-utmi-as-pipe-clk; + status = "disabled"; + + usb2_dwc3: usb@7600000 { + compatible = "snps,dwc3"; + reg = <0x07600000 0xcc00>; + interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + phys = <&hsusb_phy2>; + phy-names = "usb2-phy"; + maximum-speed = "high-speed"; + snps,dis_u2_susphy_quirk; + snps,dis_enblslpm_quirk; + }; + }; + + slimbam: dma-controller@9184000 { + compatible = "qcom,bam-v1.7.0"; + qcom,controlled-remotely; + reg = <0x09184000 0x32000>; + num-channels = <31>; + interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + qcom,ee = <1>; + qcom,num-ees = <2>; + }; + + slim_msm: slim-ngd@91c0000 { + compatible = "qcom,slim-ngd-v1.5.0"; + reg = <0x091c0000 0x2c000>; + interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&slimbam 3>, <&slimbam 4>; + dma-names = "rx", "tx"; + #address-cells = <1>; + #size-cells = <0>; + + status = "disabled"; + }; + + adsp_pil: remoteproc@9300000 { + compatible = "qcom,msm8996-adsp-pil"; + reg = <0x09300000 0x80000>; + + interrupts-extended = <&intc 0 162 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&rpmcc RPM_SMD_XO_CLK_SRC>; + clock-names = "xo"; + + memory-region = <&adsp_mem>; + + qcom,smem-states = <&adsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + power-domains = <&rpmpd MSM8996_VDDCX>; + power-domain-names = "cx"; + + status = "disabled"; + + smd-edge { + interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; + + label = "lpass"; + mboxes = <&apcs_glb 8>; + qcom,smd-edge = <1>; + qcom,remote-pid = <2>; + + apr { + power-domains = <&gcc HLOS1_VOTE_LPASS_ADSP_GDSC>; + compatible = "qcom,apr-v2"; + qcom,smd-channels = "apr_audio_svc"; + qcom,domain = <APR_DOMAIN_ADSP>; + #address-cells = <1>; + #size-cells = <0>; + + service@3 { + reg = <APR_SVC_ADSP_CORE>; + compatible = "qcom,q6core"; + }; + + q6afe: service@4 { + compatible = "qcom,q6afe"; + reg = <APR_SVC_AFE>; + q6afedai: dais { + compatible = "qcom,q6afe-dais"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <1>; + dai@1 { + reg = <1>; + }; + }; + }; + + q6asm: service@7 { + compatible = "qcom,q6asm"; + reg = <APR_SVC_ASM>; + q6asmdai: dais { + compatible = "qcom,q6asm-dais"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <1>; + iommus = <&lpass_q6_smmu 1>; + }; + }; + + q6adm: service@8 { + compatible = "qcom,q6adm"; + reg = <APR_SVC_ADM>; + q6routing: routing { + compatible = "qcom,q6adm-routing"; + #sound-dai-cells = <0>; + }; + }; + }; + }; + }; + + apcs_glb: mailbox@9820000 { + compatible = "qcom,msm8996-apcs-hmss-global"; + reg = <0x09820000 0x1000>; + + #mbox-cells = <1>; + #clock-cells = <0>; + }; + + timer@9840000 { + #address-cells = <1>; + #size-cells = <1>; + ranges; + compatible = "arm,armv7-timer-mem"; + reg = <0x09840000 0x1000>; + clock-frequency = <19200000>; + + frame@9850000 { + frame-number = <0>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x09850000 0x1000>, + <0x09860000 0x1000>; + }; + + frame@9870000 { + frame-number = <1>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x09870000 0x1000>; + status = "disabled"; + }; + + frame@9880000 { + frame-number = <2>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x09880000 0x1000>; + status = "disabled"; + }; + + frame@9890000 { + frame-number = <3>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x09890000 0x1000>; + status = "disabled"; + }; + + frame@98a0000 { + frame-number = <4>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x098a0000 0x1000>; + status = "disabled"; + }; + + frame@98b0000 { + frame-number = <5>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x098b0000 0x1000>; + status = "disabled"; + }; + + frame@98c0000 { + frame-number = <6>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x098c0000 0x1000>; + status = "disabled"; + }; + }; + + saw3: syscon@9a10000 { + compatible = "syscon"; + reg = <0x09a10000 0x1000>; + }; + + cbf: clock-controller@9a11000 { + compatible = "qcom,msm8996-cbf"; + reg = <0x09a11000 0x10000>; + clocks = <&rpmcc RPM_SMD_XO_A_CLK_SRC>, <&apcs_glb>; + #clock-cells = <0>; + #interconnect-cells = <1>; + }; + + intc: interrupt-controller@9bc0000 { + compatible = "qcom,msm8996-gic-v3", "arm,gic-v3"; + #interrupt-cells = <3>; + interrupt-controller; + #redistributor-regions = <1>; + redistributor-stride = <0x0 0x40000>; + reg = <0x09bc0000 0x10000>, + <0x09c00000 0x100000>; + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + sound: sound { + }; + + thermal-zones { + cpu0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 3>; + + trips { + cpu0_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu0_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + cpu1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 5>; + + trips { + cpu1_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu1_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + cpu2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 8>; + + trips { + cpu2_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu2_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + cpu3-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 10>; + + trips { + cpu3_alert0: trip-point0 { + temperature = <75000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu3_crit: cpu-crit { + temperature = <110000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + + gpu-top-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 6>; + + trips { + gpu1_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + }; + + cooling-maps { + map0 { + trip = <&gpu1_alert0>; + cooling-device = <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu-bottom-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 7>; + + trips { + gpu2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "passive"; + }; + }; + + cooling-maps { + map0 { + trip = <&gpu2_alert0>; + cooling-device = <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + m4m-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 1>; + + trips { + m4m_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + l3-or-venus-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 2>; + + trips { + l3_or_venus_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + cluster0-l2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 7>; + + trips { + cluster0_l2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + cluster1-l2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens0 12>; + + trips { + cluster1_l2_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + camera-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 1>; + + trips { + camera_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + q6-dsp-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 2>; + + trips { + q6_dsp_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + mem-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 3>; + + trips { + mem_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + modemtx-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens1 4>; + + trips { + modemtx_alert0: trip-point0 { + temperature = <90000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; + }; +}; diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index 5a8cfb7d7a25..b622f309cc48 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -7,7 +7,7 @@ CONFIG_SYS_MALLOC_LEN=0x804000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x4000 -CONFIG_DEFAULT_DEVICE_TREE="dragonboard820c" +CONFIG_DEFAULT_DEVICE_TREE="apq8096-db820c" CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 820C" CONFIG_SYS_LOAD_ADDR=0x80080000 CONFIG_DISTRO_DEFAULTS=y
On 19/12/2023 17:04, Caleb Connolly wrote:
Drop the U-Boot specific dragonboard820c.dts file in favour of the upstream apq8096-db820c.dts and an additional -u-boot.dtsi with the U-Boot specific additions.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
arch/arm/dts/Makefile | 2 +- arch/arm/dts/apq8096-db820c-u-boot.dtsi | 10 + arch/arm/dts/apq8096-db820c.dts | 1137 +++++++++ arch/arm/dts/dragonboard820c-uboot.dtsi | 32 - arch/arm/dts/dragonboard820c.dts | 153 -- arch/arm/dts/msm8996.dtsi | 3884 +++++++++++++++++++++++++++++++ configs/dragonboard820c_defconfig | 2 +- 7 files changed, 5033 insertions(+), 187 deletions(-)
<snip> Same as patch 19, with the commit id:
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
Import the headers needed for QCS404-evb.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/clock/qcom,turingcc-qcs404.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/include/dt-bindings/clock/qcom,turingcc-qcs404.h b/include/dt-bindings/clock/qcom,turingcc-qcs404.h new file mode 100644 index 000000000000..838faef57c67 --- /dev/null +++ b/include/dt-bindings/clock/qcom,turingcc-qcs404.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019, Linaro Ltd + */ + +#ifndef _DT_BINDINGS_CLK_TURING_QCS404_H +#define _DT_BINDINGS_CLK_TURING_QCS404_H + +#define TURING_Q6SS_Q6_AXIM_CLK 0 +#define TURING_Q6SS_AHBM_AON_CLK 1 +#define TURING_WRAPPER_AON_CLK 2 +#define TURING_Q6SS_AHBS_AON_CLK 3 +#define TURING_WRAPPER_QOS_AHBS_AON_CLK 4 + +#endif
- Copyright (c) 2019, Linaro Ltd
Drop the U-Boot specific DTS in favour of upstream. We'll only include the -4000 variant as that is what U-Boot already supported.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- arch/arm/dts/Makefile | 2 +- arch/arm/dts/pms405.dtsi | 149 +++ arch/arm/dts/qcs404-evb-4000-u-boot.dtsi | 26 + arch/arm/dts/qcs404-evb-4000.dts | 96 ++ arch/arm/dts/qcs404-evb-uboot.dtsi | 30 - arch/arm/dts/qcs404-evb.dts | 390 ------- arch/arm/dts/qcs404-evb.dtsi | 389 +++++++ arch/arm/dts/qcs404.dtsi | 1829 ++++++++++++++++++++++++++++++ 8 files changed, 2490 insertions(+), 421 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 95470fd6133b..34c473965bef 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -604,7 +604,7 @@ dtb-$(CONFIG_ARCH_SNAPDRAGON) += apq8016-sbc.dtb \ apq8096-db820c.dtb \ sdm845-db845c.dtb \ sdm845-samsung-starqltechn.dtb \ - qcs404-evb.dtb + qcs404-evb-4000.dtb
dtb-$(CONFIG_TARGET_STEMMY) += ste-ux500-samsung-stemmy.dtb
diff --git a/arch/arm/dts/pms405.dtsi b/arch/arm/dts/pms405.dtsi new file mode 100644 index 000000000000..461ad97032f7 --- /dev/null +++ b/arch/arm/dts/pms405.dtsi @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018, Linaro Limited + */ + +#include <dt-bindings/spmi/spmi.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/iio/qcom,spmi-vadc.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + thermal-zones { + pms405-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&pms405_temp>; + + trips { + pms405_alert0: pms405-alert0 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + pms405_crit: pms405-crit { + temperature = <125000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + }; + }; +}; + +&spmi_bus { + pms405_0: pms405@0 { + compatible = "qcom,pms405", "qcom,spmi-pmic"; + reg = <0x0 SPMI_USID>; + #address-cells = <1>; + #size-cells = <0>; + + pms405_gpios: gpio@c000 { + compatible = "qcom,pms405-gpio", "qcom,spmi-gpio"; + reg = <0xc000>; + gpio-controller; + gpio-ranges = <&pms405_gpios 0 0 12>; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + pon@800 { + compatible = "qcom,pms405-pon"; + reg = <0x0800>; + mode-bootloader = <0x2>; + mode-recovery = <0x1>; + + pwrkey { + compatible = "qcom,pm8941-pwrkey"; + interrupts = <0x0 0x8 0 IRQ_TYPE_EDGE_BOTH>; + debounce = <15625>; + bias-pull-up; + linux,code = <KEY_POWER>; + }; + }; + + pms405_temp: temp-alarm@2400 { + compatible = "qcom,spmi-temp-alarm"; + reg = <0x2400>; + interrupts = <0 0x24 0 IRQ_TYPE_EDGE_RISING>; + io-channels = <&pms405_adc ADC5_DIE_TEMP>; + io-channel-names = "thermal"; + #thermal-sensor-cells = <0>; + }; + + pms405_adc: adc@3100 { + compatible = "qcom,pms405-adc", "qcom,spmi-adc-rev2"; + reg = <0x3100>; + interrupts = <0x0 0x31 0x0 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + #io-channel-cells = <1>; + + channel@0 { + reg = <ADC5_REF_GND>; + qcom,pre-scaling = <1 1>; + label = "ref_gnd"; + }; + + channel@1 { + reg = <ADC5_1P25VREF>; + qcom,pre-scaling = <1 1>; + label = "vref_1p25"; + }; + + channel@131 { + reg = <ADC5_VPH_PWR>; + qcom,pre-scaling = <1 3>; + label = "vph_pwr"; + }; + + channel@6 { + reg = <ADC5_DIE_TEMP>; + qcom,pre-scaling = <1 1>; + label = "die_temp"; + }; + + channel@77 { + reg = <ADC5_AMUX_THM1_100K_PU>; + qcom,ratiometric; + qcom,hw-settle-time = <200>; + qcom,pre-scaling = <1 1>; + label = "pa_therm1"; + }; + + channel@79 { + reg = <ADC5_AMUX_THM3_100K_PU>; + qcom,ratiometric; + qcom,hw-settle-time = <200>; + qcom,pre-scaling = <1 1>; + label = "pa_therm3"; + }; + + channel@76 { + reg = <ADC5_XO_THERM_100K_PU>; + qcom,ratiometric; + qcom,hw-settle-time = <200>; + qcom,pre-scaling = <1 1>; + label = "xo_therm"; + }; + }; + + rtc@6000 { + compatible = "qcom,pm8941-rtc"; + reg = <0x6000>, <0x6100>; + reg-names = "rtc", "alarm"; + interrupts = <0x0 0x61 0x1 IRQ_TYPE_NONE>; + }; + }; + + pms405_1: pms405@1 { + compatible = "qcom,pms405", "qcom,spmi-pmic"; + reg = <0x1 SPMI_USID>; + + pms405_spmi_regulators: regulators { + compatible = "qcom,pms405-regulators"; + }; + }; +}; diff --git a/arch/arm/dts/qcs404-evb-4000-u-boot.dtsi b/arch/arm/dts/qcs404-evb-4000-u-boot.dtsi new file mode 100644 index 000000000000..5f1be85bd834 --- /dev/null +++ b/arch/arm/dts/qcs404-evb-4000-u-boot.dtsi @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <dt-bindings/gpio/gpio.h> + +/delete-node/ &usb3_vbus_reg; +/delete-node/ &usb_vbus_boost_pin; + +/ { + /* U-Boot uses different bindings for GPIO regulators, this + * one is required for USB + */ + usb3_vbus_reg: usb3_vbus_reg { + compatible = "regulator-gpio"; + regulator-name = "usb3_vbus_reg"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-gpios = <&pms405_gpios 3 GPIO_ACTIVE_HIGH>; + enable-active-high; + states = <0 0>, <5000000 1>; + }; +}; + +&usb3_dwc3 { + /* Make sure the VBUS supply is switched on */ + vbus-supply = <&usb3_vbus_reg>; +}; diff --git a/arch/arm/dts/qcs404-evb-4000.dts b/arch/arm/dts/qcs404-evb-4000.dts new file mode 100644 index 000000000000..358827c2fbd3 --- /dev/null +++ b/arch/arm/dts/qcs404-evb-4000.dts @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018, Linaro Limited + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "qcs404-evb.dtsi" + +/ { + model = "Qualcomm Technologies, Inc. QCS404 EVB 4000"; + compatible = "qcom,qcs404-evb-4000", "qcom,qcs404-evb", + "qcom,qcs404"; +}; + +ðernet { + status = "okay"; + + snps,reset-gpio = <&tlmm 60 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 10000>; + + pinctrl-names = "default"; + pinctrl-0 = <ðernet_defaults>; + + phy-handle = <&phy1>; + phy-mode = "rgmii"; + mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy1: phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + device_type = "ethernet-phy"; + reg = <0x4>; + }; + }; +}; + +&tlmm { + ethernet_defaults: ethernet-defaults-state { + int-pins { + pins = "gpio61"; + function = "rgmii_int"; + bias-disable; + drive-strength = <2>; + }; + mdc-pins { + pins = "gpio76"; + function = "rgmii_mdc"; + bias-pull-up; + }; + mdio-pins { + pins = "gpio75"; + function = "rgmii_mdio"; + bias-pull-up; + }; + tx-pins { + pins = "gpio67", "gpio66", "gpio65", "gpio64"; + function = "rgmii_tx"; + bias-pull-up; + drive-strength = <16>; + }; + rx-pins { + pins = "gpio73", "gpio72", "gpio71", "gpio70"; + function = "rgmii_rx"; + bias-disable; + drive-strength = <2>; + }; + tx-ctl-pins { + pins = "gpio68"; + function = "rgmii_ctl"; + bias-pull-up; + drive-strength = <16>; + }; + rx-ctl-pins { + pins = "gpio74"; + function = "rgmii_ctl"; + bias-disable; + drive-strength = <2>; + }; + tx-ck-pins { + pins = "gpio63"; + function = "rgmii_ck"; + bias-pull-up; + drive-strength = <16>; + }; + rx-ck-pins { + pins = "gpio69"; + function = "rgmii_ck"; + bias-disable; + drive-strength = <2>; + }; + }; +}; diff --git a/arch/arm/dts/qcs404-evb-uboot.dtsi b/arch/arm/dts/qcs404-evb-uboot.dtsi deleted file mode 100644 index b4c5f3fa4301..000000000000 --- a/arch/arm/dts/qcs404-evb-uboot.dtsi +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * U-Boot addition to handle QCS404 EVB pre-relocation devices - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -/ { - soc { - bootph-all; - - pinctrl_north@1300000 { - bootph-all; - }; - - clock-controller@1800000 { - bootph-all; - }; - - serial@78b1000 { - bootph-all; - }; - }; -}; - -&pms405_gpios { - usb_vbus_boost_pin { - gpios = <&pms405_gpios 2 0>; - }; -}; diff --git a/arch/arm/dts/qcs404-evb.dts b/arch/arm/dts/qcs404-evb.dts deleted file mode 100644 index 07bf7dd0b32f..000000000000 --- a/arch/arm/dts/qcs404-evb.dts +++ /dev/null @@ -1,390 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Qualcomm QCS404 based evaluation board device tree source - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -/dts-v1/; - -#include "skeleton64.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/clock/qcom,gcc-qcs404.h> - -/ { - model = "Qualcomm Technologies, Inc. QCS404 EVB"; - compatible = "qcom,qcs404-evb", "qcom,qcs404"; - #address-cells = <0x2>; - #size-cells = <0x2>; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - aliases { - serial0 = &debug_uart; - i2c0 = &blsp1_i2c0; - i2c1 = &blsp1_i2c1; - i2c2 = &blsp1_i2c2; - i2c3 = &blsp1_i2c3; - i2c4 = &blsp1_i2c4; - }; - - memory { - device_type = "memory"; - reg = <0 0x80000000 0 0x40000000>; - }; - - soc { - #address-cells = <0x1>; - #size-cells = <0x1>; - ranges = <0x0 0x0 0x0 0xffffffff>; - compatible = "simple-bus"; - - soc_gpios: pinctrl_north@1300000 { - compatible = "qcom,qcs404-pinctrl"; - reg = <0x1300000 0x200000>; - gpio-controller; - gpio-count = <120>; - gpio-bank-name="soc"; - #gpio-cells = <2>; - - blsp1_uart2: uart { - pins = "GPIO_17", "GPIO_18"; - function = "blsp_uart2"; - }; - - blsp1_i2c0_default: blsp1-i2c0-default { - pins = "GPIO_32", "GPIO_33"; - function = "blsp_i2c0"; - }; - - blsp1_i2c1_default: blsp1-i2c1-default { - pins = "GPIO_24", "GPIO_25"; - function = "blsp_i2c1"; - }; - - blsp1_i2c2_default: blsp1-i2c2-default { - sda { - pins = "GPIO_19"; - function = "blsp_i2c_sda_a2"; - }; - - scl { - pins = "GPIO_20"; - function = "blsp_i2c_scl_a2"; - }; - }; - - blsp1_i2c3_default: blsp1-i2c3-default { - pins = "GPIO_84", "GPIO_85"; - function = "blsp_i2c3"; - }; - - blsp1_i2c4_default: blsp1-i2c4-default { - pins = "GPIO_117", "GPIO_118"; - function = "blsp_i2c4"; - }; - - ethernet_defaults: ethernet-defaults { - int { - pins = "GPIO_61"; - function = "rgmii_int"; - bias-disable; - drive-strength = <2>; - }; - mdc { - pins = "GPIO_76"; - function = "rgmii_mdc"; - bias-pull-up; - }; - mdio { - pins = "GPIO_75"; - function = "rgmii_mdio"; - bias-pull-up; - }; - tx { - pins = "GPIO_67", "GPIO_66", "GPIO_65", "GPIO_64"; - function = "rgmii_tx"; - bias-pull-up; - drive-strength = <16>; - }; - rx { - pins = "GPIO_73", "GPIO_72", "GPIO_71", "GPIO_70"; - function = "rgmii_rx"; - bias-disable; - drive-strength = <2>; - }; - tx-ctl { - pins = "GPIO_68"; - function = "rgmii_ctl"; - bias-pull-up; - drive-strength = <16>; - }; - rx-ctl { - pins = "GPIO_74"; - function = "rgmii_ctl"; - bias-disable; - drive-strength = <2>; - }; - tx-ck { - pins = "GPIO_63"; - function = "rgmii_ck"; - bias-pull-up; - drive-strength = <16>; - }; - rx-ck { - pins = "GPIO_69"; - function = "rgmii_ck"; - bias-disable; - drive-strength = <2>; - }; - }; - }; - - blsp1_i2c0: i2c@78b5000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b5000 0x600>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>, - <&gcc GCC_BLSP1_QUP0_I2C_APPS_CLK>; - clock-names = "iface", "core"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c0_default>; - #address-cells = <1>; - #size-cells = <0>; - }; - - blsp1_i2c1: i2c@78b6000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b6000 0x600>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>, - <&gcc GCC_BLSP1_QUP1_I2C_APPS_CLK>; - clock-names = "iface", "core"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c1_default>; - #address-cells = <1>; - #size-cells = <0>; - }; - - blsp1_i2c2: i2c@78b7000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b7000 0x600>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>, - <&gcc GCC_BLSP1_QUP2_I2C_APPS_CLK>; - clock-names = "iface", "core"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c2_default>; - #address-cells = <1>; - #size-cells = <0>; - }; - - blsp1_i2c3: i2c@78b8000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b8000 0x600>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>, - <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>; - clock-names = "iface", "core"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c3_default>; - #address-cells = <1>; - #size-cells = <0>; - }; - - blsp1_i2c4: i2c@78b9000 { - compatible = "qcom,i2c-qup-v2.2.1"; - reg = <0x078b9000 0x600>; - clocks = <&gcc GCC_BLSP1_AHB_CLK>, - <&gcc GCC_BLSP1_QUP4_I2C_APPS_CLK>; - clock-names = "iface", "core"; - pinctrl-names = "default"; - pinctrl-0 = <&blsp1_i2c4_default>; - #address-cells = <1>; - #size-cells = <0>; - }; - - gcc: clock-controller@1800000 { - compatible = "qcom,gcc-qcs404"; - reg = <0x1800000 0x80000>; - #address-cells = <0x1>; - #size-cells = <0x0>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - debug_uart: serial@78b1000 { - compatible = "qcom,msm-uartdm-v1.4"; - reg = <0x78b1000 0x200>; - clock = <&gcc GCC_BLSP1_UART2_APPS_CLK>, - <&gcc GCC_BLSP1_AHB_CLK>; - bit-rate = <0xFF>; - pinctrl-names = "uart"; - pinctrl-0 = <&blsp1_uart2>; - }; - - sdhci@7804000 { - compatible = "qcom,sdhci-msm-v5"; - reg = <0x7804000 0x1000 0x7805000 0x1000>; - clock = <&gcc GCC_SDCC1_APPS_CLK>, - <&gcc GCC_SDCC1_AHB_CLK>; - bus-width = <0x8>; - index = <0x0>; - non-removable; - mmc-ddr-1_8v; - mmc-hs400-1_8v; - }; - - usb3_phy: phy@78000 { - compatible = "qcom,usb-ss-28nm-phy"; - #phy-cells = <0>; - reg = <0x78000 0x400>; - clocks = <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB3_PHY_PIPE_CLK>; - clock-names = "ahb", "pipe"; - resets = <&gcc GCC_USB3_PHY_BCR>, - <&gcc GCC_USB3PHY_PHY_BCR>; - reset-names = "com", "phy"; - }; - - usb2_phy_prim: phy@7a000 { - compatible = "qcom,usb-hs-28nm-femtophy"; - #phy-cells = <0>; - reg = <0x7a000 0x200>; - clocks = <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ahb", "sleep"; - resets = <&gcc GCC_USB_HS_PHY_CFG_AHB_BCR>, - <&gcc GCC_USB2A_PHY_BCR>; - reset-names = "phy", "por"; - }; - - usb2_phy_sec: phy@7c000 { - compatible = "qcom,usb-hs-28nm-femtophy"; - #phy-cells = <0>; - reg = <0x7c000 0x200>; - clocks = <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, - <&gcc GCC_USB2A_PHY_SLEEP_CLK>; - clock-names = "ahb", "sleep"; - resets = <&gcc GCC_QUSB2_PHY_BCR>, - <&gcc GCC_USB2_HS_PHY_ONLY_BCR>; - reset-names = "phy", "por"; - }; - - usb3: usb@7678800 { - compatible = "qcom,dwc3"; - reg = <0x7678800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - clocks = <&gcc GCC_USB30_MASTER_CLK>, - <&gcc GCC_SYS_NOC_USB3_CLK>, - <&gcc GCC_USB30_SLEEP_CLK>, - <&gcc GCC_USB30_MOCK_UTMI_CLK>; - clock-names = "core", "iface", "sleep", "mock_utmi"; - - dwc3@7580000 { - compatible = "snps,dwc3"; - reg = <0x7580000 0xcd00>; - phys = <&usb2_phy_prim>, <&usb3_phy>; - phy-names = "usb2-phy", "usb3-phy"; - dr_mode = "host"; - snps,has-lpm-erratum; - snps,hird-threshold = /bits/ 8 <0x10>; - snps,usb3_lpm_capable; - maximum-speed = "super-speed"; - }; - }; - - usb2: usb@79b8800 { - compatible = "qcom,dwc3"; - reg = <0x79b8800 0x400>; - #address-cells = <1>; - #size-cells = <1>; - ranges; - clocks = <&gcc GCC_USB_HS_SYSTEM_CLK>, - <&gcc GCC_PCNOC_USB2_CLK>, - <&gcc GCC_USB_HS_INACTIVITY_TIMERS_CLK>, - <&gcc GCC_USB20_MOCK_UTMI_CLK>; - clock-names = "core", "iface", "sleep", "mock_utmi"; - - dwc3@78c0000 { - compatible = "snps,dwc3"; - reg = <0x78c0000 0xcc00>; - phys = <&usb2_phy_sec>; - phy-names = "usb2-phy"; - dr_mode = "peripheral"; - snps,has-lpm-erratum; - snps,hird-threshold = /bits/ 8 <0x10>; - snps,usb3_lpm_capable; - maximum-speed = "high-speed"; - }; - }; - - ethernet: ethernet@7a80000 { - compatible = "qcom,qcs404-ethqos"; - reg = <0x07a80000 0x10000>, - <0x07a96000 0x100>; - reg-names = "stmmaceth", "rgmii"; - clock-names = "stmmaceth", "pclk", "ptp_ref", "rgmii"; - clocks = <&gcc GCC_ETH_AXI_CLK>, - <&gcc GCC_ETH_SLAVE_AHB_CLK>, - <&gcc GCC_ETH_PTP_CLK>, - <&gcc GCC_ETH_RGMII_CLK>; - - resets = <&gcc GCC_EMAC_BCR>; - reset-names = "emac"; - - snps,tso; - rx-fifo-depth = <4096>; - tx-fifo-depth = <4096>; - - snps,reset-gpio = <&soc_gpios 60 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 10000>; - - pinctrl-names = "default"; - pinctrl-0 = <ðernet_defaults>; - - phy-handle = <&phy1>; - phy-mode = "rgmii"; - max-speed = <1000>; - - mdio { - #address-cells = <0x1>; - #size-cells = <0x0>; - compatible = "snps,dwmac-mdio"; - phy1: phy@3 { - compatible = "ethernet-phy-ieee802.3-c22"; - device_type = "ethernet-phy"; - reg = <0x3>; - }; - }; - }; - - spmi@200f000 { - compatible = "qcom,spmi-pmic-arb"; - reg = <0x200f000 0x001000>, - <0x2400000 0x800000>, - <0x2c00000 0x800000>; - reg-names = "core", "chnls", "obsrvr"; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pms405_0: pms405@0 { - compatible = "qcom,spmi-pmic"; - reg = <0x0 0x1>; - #address-cells = <0x1>; - #size-cells = <0x1>; - - pms405_gpios: pms405_gpios@c000 { - compatible = "qcom,pms405-gpio"; - reg = <0xc000 0x400>; - gpio-controller; - gpio-ranges = <&pms405_gpios 0 0 12>; - #gpio-cells = <2>; - }; - }; - }; - }; -}; - -#include "qcs404-evb-uboot.dtsi" diff --git a/arch/arm/dts/qcs404-evb.dtsi b/arch/arm/dts/qcs404-evb.dtsi new file mode 100644 index 000000000000..10655401528e --- /dev/null +++ b/arch/arm/dts/qcs404-evb.dtsi @@ -0,0 +1,389 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018, Linaro Limited + */ + +#include <dt-bindings/gpio/gpio.h> +#include "qcs404.dtsi" +#include "pms405.dtsi" +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/qcom,pmic-gpio.h> + +/ { + aliases { + serial0 = &blsp1_uart2; + serial1 = &blsp1_uart3; + }; + + chosen { + stdout-path = "serial0"; + }; + + vph_pwr: vph-pwr-regulator { + compatible = "regulator-fixed"; + regulator-name = "vph_pwr"; + regulator-always-on; + regulator-boot-on; + }; + + vdd_ch0_3p3: + vdd_esmps3_3p3: vdd-esmps3-3p3-regulator { + compatible = "regulator-fixed"; + regulator-name = "eSMPS3_3P3"; + + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + usb3_vbus_reg: regulator-usb3-vbus { + compatible = "regulator-fixed"; + regulator-name = "VBUS_BOOST_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&pms405_gpios 3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&usb_vbus_boost_pin>; + vin-supply = <&vph_pwr>; + enable-active-high; + + /* TODO: Drop this when introducing role switching */ + regulator-always-on; + }; +}; + +&blsp1_uart3 { + status = "okay"; + + bluetooth { + compatible = "qcom,wcn3990-bt"; + vddio-supply = <&vreg_l6_1p8>; + vddxo-supply = <&vreg_l5_1p8>; + vddrf-supply = <&vreg_l1_1p3>; + vddch0-supply = <&vdd_ch0_3p3>; + + local-bd-address = [ 02 00 00 00 5a ad ]; + + max-speed = <3200000>; + }; +}; + +&blsp1_dma { + qcom,controlled-remotely; +}; + +&blsp2_dma { + qcom,controlled-remotely; +}; + +&gcc { + protected-clocks = <GCC_BIMC_CDSP_CLK>, + <GCC_CDSP_CFG_AHB_CLK>, + <GCC_CDSP_BIMC_CLK_SRC>, + <GCC_CDSP_TBU_CLK>, + <141>, /* GCC_WCSS_Q6_AHB_CLK */ + <142>; /* GCC_WCSS_Q6_AXIM_CLK */ +}; + +&pms405_spmi_regulators { + vdd_s3-supply = <&vph_pwr>; + + pms405_s3: s3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vdd_apc"; + regulator-initial-mode = <1>; + regulator-min-microvolt = <1048000>; + regulator-max-microvolt = <1384000>; + }; +}; + +&pcie { + status = "okay"; + + perst-gpios = <&tlmm 43 GPIO_ACTIVE_LOW>; + + pinctrl-names = "default"; + pinctrl-0 = <&perst_state>; +}; + +&pcie_phy { + status = "okay"; + + vdda-vp-supply = <&vreg_l3_1p05>; + vdda-vph-supply = <&vreg_l5_1p8>; +}; + +&remoteproc_adsp { + status = "okay"; +}; + +&remoteproc_cdsp { + status = "okay"; +}; + +&remoteproc_wcss { + status = "okay"; +}; + +&rpm_requests { + regulators { + compatible = "qcom,rpm-pms405-regulators"; + + vdd_s1-supply = <&vph_pwr>; + vdd_s2-supply = <&vph_pwr>; + vdd_s3-supply = <&vph_pwr>; + vdd_s4-supply = <&vph_pwr>; + vdd_s5-supply = <&vph_pwr>; + vdd_l1_l2-supply = <&vreg_s5_1p35>; + vdd_l3_l8-supply = <&vreg_s5_1p35>; + vdd_l4-supply = <&vreg_s5_1p35>; + vdd_l5_l6-supply = <&vreg_s4_1p8>; + vdd_l7-supply = <&vph_pwr>; + vdd_l9-supply = <&vreg_s5_1p35>; + vdd_l10_l11_l12_l13-supply = <&vph_pwr>; + + vreg_s4_1p8: s4 { + regulator-min-microvolt = <1728000>; + regulator-max-microvolt = <1920000>; + }; + + vreg_s5_1p35: s5 { + regulator-min-microvolt = <1352000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_l1_1p3: l1 { + regulator-min-microvolt = <1240000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_l2_1p275: l2 { + regulator-min-microvolt = <1048000>; + regulator-max-microvolt = <1280000>; + }; + + vreg_l3_1p05: l3 { + regulator-min-microvolt = <1048000>; + regulator-max-microvolt = <1160000>; + }; + + vreg_l4_1p2: l4 { + regulator-min-microvolt = <1144000>; + regulator-max-microvolt = <1256000>; + }; + + vreg_l5_1p8: l5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vreg_l6_1p8: l6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vreg_l7_1p8: l7 { + regulator-min-microvolt = <1616000>; + regulator-max-microvolt = <3000000>; + }; + + vreg_l8_1p2: l8 { + regulator-min-microvolt = <1136000>; + regulator-max-microvolt = <1352000>; + }; + + vreg_l10_3p3: l10 { + regulator-min-microvolt = <2936000>; + regulator-max-microvolt = <3088000>; + }; + + vreg_l11_sdc2: l11 { + regulator-min-microvolt = <2696000>; + regulator-max-microvolt = <3304000>; + }; + + vreg_l12_3p3: l12 { + regulator-min-microvolt = <3050000>; + regulator-max-microvolt = <3300000>; + }; + + vreg_l13_3p3: l13 { + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3300000>; + }; + }; +}; + +&sdcc1 { + status = "okay"; + + supports-cqe; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + bus-width = <8>; + non-removable; + + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&sdc1_on>; + pinctrl-1 = <&sdc1_off>; +}; + +&tlmm { + perst_state: perst-state { + pins = "gpio43"; + function = "gpio"; + + drive-strength = <2>; + bias-disable; + output-low; + }; + + sdc1_on: sdc1-on-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <16>; + }; + + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <10>; + }; + + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <10>; + }; + + rclk-pins { + pins = "sdc1_rclk"; + bias-pull-down; + }; + }; + + sdc1_off: sdc1-off-state { + clk-pins { + pins = "sdc1_clk"; + bias-disable; + drive-strength = <2>; + }; + + cmd-pins { + pins = "sdc1_cmd"; + bias-pull-up; + drive-strength = <2>; + }; + + data-pins { + pins = "sdc1_data"; + bias-pull-up; + drive-strength = <2>; + }; + + rclk-pins { + pins = "sdc1_rclk"; + bias-pull-down; + }; + }; + + usb3_id_pin: usb3-id-state { + pins = "gpio116"; + function = "gpio"; + + drive-strength = <2>; + bias-pull-up; + }; +}; + +&pms405_gpios { + usb_vbus_boost_pin: usb-vbus-boost-state { + pinconf { + pins = "gpio3"; + function = PMIC_GPIO_FUNC_NORMAL; + output-low; + power-source = <1>; + }; + }; + usb3_vbus_pin: usb3-vbus-state { + pinconf { + pins = "gpio12"; + function = PMIC_GPIO_FUNC_NORMAL; + input-enable; + bias-pull-down; + power-source = <1>; + }; + }; +}; + +&usb2 { + status = "okay"; +}; + +&usb2_phy_sec { + vdd-supply = <&vreg_l4_1p2>; + vdda1p8-supply = <&vreg_l5_1p8>; + vdda3p3-supply = <&vreg_l12_3p3>; + status = "okay"; +}; + +&usb3 { + status = "okay"; + +}; + +&usb3_dwc3 { + dr_mode = "host"; +}; + +&usb2_phy_prim { + vdd-supply = <&vreg_l4_1p2>; + vdda1p8-supply = <&vreg_l5_1p8>; + vdda3p3-supply = <&vreg_l12_3p3>; + status = "okay"; +}; + +&usb3_phy { + vdd-supply = <&vreg_l3_1p05>; + vdda1p8-supply = <&vreg_l5_1p8>; + status = "okay"; +}; + +&wifi { + status = "okay"; + vdd-0.8-cx-mx-supply = <&vreg_l2_1p275>; + vdd-1.8-xo-supply = <&vreg_l5_1p8>; + vdd-1.3-rfa-supply = <&vreg_l1_1p3>; +}; + +/* PINCTRL - additions to nodes defined in qcs404.dtsi */ + +&blsp1_uart2_default { + rx-pins { + drive-strength = <2>; + bias-disable; + }; + + tx-pins { + drive-strength = <2>; + bias-disable; + }; +}; + +&blsp1_uart3_default { + cts-pins { + bias-disable; + }; + + rts-tx-pins { + drive-strength = <2>; + bias-disable; + }; + + rx-pins { + bias-pull-up; + }; +}; diff --git a/arch/arm/dts/qcs404.dtsi b/arch/arm/dts/qcs404.dtsi new file mode 100644 index 000000000000..2721f32dfb71 --- /dev/null +++ b/arch/arm/dts/qcs404.dtsi @@ -0,0 +1,1829 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018, Linaro Limited + */ + +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/qcom,gcc-qcs404.h> +#include <dt-bindings/clock/qcom,turingcc-qcs404.h> +#include <dt-bindings/clock/qcom,rpmcc.h> +#include <dt-bindings/power/qcom-rpmpd.h> +#include <dt-bindings/thermal/thermal.h> + +/ { + interrupt-parent = <&intc>; + + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + clocks { + xo_board: xo-board { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + }; + + sleep_clk: sleep-clk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + CPU0: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x100>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + next-level-cache = <&L2_0>; + #cooling-cells = <2>; + clocks = <&apcs_glb>; + operating-points-v2 = <&cpu_opp_table>; + power-domains = <&cpr>; + power-domain-names = "cpr"; + }; + + CPU1: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x101>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + next-level-cache = <&L2_0>; + #cooling-cells = <2>; + clocks = <&apcs_glb>; + operating-points-v2 = <&cpu_opp_table>; + power-domains = <&cpr>; + power-domain-names = "cpr"; + }; + + CPU2: cpu@102 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x102>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + next-level-cache = <&L2_0>; + #cooling-cells = <2>; + clocks = <&apcs_glb>; + operating-points-v2 = <&cpu_opp_table>; + power-domains = <&cpr>; + power-domain-names = "cpr"; + }; + + CPU3: cpu@103 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x103>; + enable-method = "psci"; + cpu-idle-states = <&CPU_SLEEP_0>; + next-level-cache = <&L2_0>; + #cooling-cells = <2>; + clocks = <&apcs_glb>; + operating-points-v2 = <&cpu_opp_table>; + power-domains = <&cpr>; + power-domain-names = "cpr"; + }; + + L2_0: l2-cache { + compatible = "cache"; + cache-level = <2>; + cache-unified; + }; + + idle-states { + entry-method = "psci"; + + CPU_SLEEP_0: cpu-sleep-0 { + compatible = "arm,idle-state"; + idle-state-name = "standalone-power-collapse"; + arm,psci-suspend-param = <0x40000003>; + entry-latency-us = <125>; + exit-latency-us = <180>; + min-residency-us = <595>; + local-timer-stop; + }; + }; + }; + + cpu_opp_table: opp-table-cpu { + compatible = "operating-points-v2-kryo-cpu"; + opp-shared; + + opp-1094400000 { + opp-hz = /bits/ 64 <1094400000>; + required-opps = <&cpr_opp1>; + }; + opp-1248000000 { + opp-hz = /bits/ 64 <1248000000>; + required-opps = <&cpr_opp2>; + }; + opp-1401600000 { + opp-hz = /bits/ 64 <1401600000>; + required-opps = <&cpr_opp3>; + }; + }; + + cpr_opp_table: opp-table-cpr { + compatible = "operating-points-v2-qcom-level"; + + cpr_opp1: opp1 { + opp-level = <1>; + qcom,opp-fuse-level = <1>; + }; + cpr_opp2: opp2 { + opp-level = <2>; + qcom,opp-fuse-level = <2>; + }; + cpr_opp3: opp3 { + opp-level = <3>; + qcom,opp-fuse-level = <3>; + }; + }; + + firmware { + scm: scm { + compatible = "qcom,scm-qcs404", "qcom,scm"; + #reset-cells = <1>; + }; + }; + + memory@80000000 { + device_type = "memory"; + /* We expect the bootloader to fill in the size */ + reg = <0 0x80000000 0 0>; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + rpm: remoteproc { + compatible = "qcom,qcs404-rpm-proc", "qcom,rpm-proc"; + + glink-edge { + compatible = "qcom,glink-rpm"; + + interrupts = <GIC_SPI 168 IRQ_TYPE_EDGE_RISING>; + qcom,rpm-msg-ram = <&rpm_msg_ram>; + mboxes = <&apcs_glb 0>; + + rpm_requests: rpm-requests { + compatible = "qcom,rpm-qcs404"; + qcom,glink-channels = "rpm_requests"; + + rpmcc: clock-controller { + compatible = "qcom,rpmcc-qcs404", "qcom,rpmcc"; + #clock-cells = <1>; + clocks = <&xo_board>; + clock-names = "xo"; + }; + + rpmpd: power-controller { + compatible = "qcom,qcs404-rpmpd"; + #power-domain-cells = <1>; + operating-points-v2 = <&rpmpd_opp_table>; + + rpmpd_opp_table: opp-table { + compatible = "operating-points-v2"; + + rpmpd_opp_ret: opp1 { + opp-level = <16>; + }; + + rpmpd_opp_ret_plus: opp2 { + opp-level = <32>; + }; + + rpmpd_opp_min_svs: opp3 { + opp-level = <48>; + }; + + rpmpd_opp_low_svs: opp4 { + opp-level = <64>; + }; + + rpmpd_opp_svs: opp5 { + opp-level = <128>; + }; + + rpmpd_opp_svs_plus: opp6 { + opp-level = <192>; + }; + + rpmpd_opp_nom: opp7 { + opp-level = <256>; + }; + + rpmpd_opp_nom_plus: opp8 { + opp-level = <320>; + }; + + rpmpd_opp_turbo: opp9 { + opp-level = <384>; + }; + + rpmpd_opp_turbo_no_cpr: opp10 { + opp-level = <416>; + }; + + rpmpd_opp_turbo_plus: opp11 { + opp-level = <512>; + }; + }; + }; + }; + }; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + tz_apps_mem: memory@85900000 { + reg = <0 0x85900000 0 0x500000>; + no-map; + }; + + xbl_mem: memory@85e00000 { + reg = <0 0x85e00000 0 0x100000>; + no-map; + }; + + smem_region: memory@85f00000 { + reg = <0 0x85f00000 0 0x200000>; + no-map; + }; + + tz_mem: memory@86100000 { + reg = <0 0x86100000 0 0x300000>; + no-map; + }; + + wlan_fw_mem: memory@86400000 { + reg = <0 0x86400000 0 0x1100000>; + no-map; + }; + + adsp_fw_mem: memory@87500000 { + reg = <0 0x87500000 0 0x1a00000>; + no-map; + }; + + cdsp_fw_mem: memory@88f00000 { + reg = <0 0x88f00000 0 0x600000>; + no-map; + }; + + wlan_msa_mem: memory@89500000 { + reg = <0 0x89500000 0 0x100000>; + no-map; + }; + + uefi_mem: memory@9f800000 { + reg = <0 0x9f800000 0 0x800000>; + no-map; + }; + }; + + smem { + compatible = "qcom,smem"; + + memory-region = <&smem_region>; + qcom,rpm-msg-ram = <&rpm_msg_ram>; + + hwlocks = <&tcsr_mutex 3>; + }; + + soc: soc@0 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xffffffff>; + compatible = "simple-bus"; + + turingcc: clock-controller@800000 { + compatible = "qcom,qcs404-turingcc"; + reg = <0x00800000 0x30000>; + clocks = <&gcc GCC_CDSP_CFG_AHB_CLK>; + + #clock-cells = <1>; + #reset-cells = <1>; + + status = "disabled"; + }; + + rpm_msg_ram: sram@60000 { + compatible = "qcom,rpm-msg-ram"; + reg = <0x00060000 0x6000>; + }; + + usb3_phy: phy@78000 { + compatible = "qcom,usb-ss-28nm-phy"; + reg = <0x00078000 0x400>; + #phy-cells = <0>; + clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, + <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, + <&gcc GCC_USB3_PHY_PIPE_CLK>; + clock-names = "ref", "ahb", "pipe"; + resets = <&gcc GCC_USB3_PHY_BCR>, + <&gcc GCC_USB3PHY_PHY_BCR>; + reset-names = "com", "phy"; + status = "disabled"; + }; + + usb2_phy_prim: phy@7a000 { + compatible = "qcom,usb-hs-28nm-femtophy"; + reg = <0x0007a000 0x200>; + #phy-cells = <0>; + clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, + <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, + <&gcc GCC_USB2A_PHY_SLEEP_CLK>; + clock-names = "ref", "ahb", "sleep"; + resets = <&gcc GCC_USB_HS_PHY_CFG_AHB_BCR>, + <&gcc GCC_USB2A_PHY_BCR>; + reset-names = "phy", "por"; + status = "disabled"; + }; + + usb2_phy_sec: phy@7c000 { + compatible = "qcom,usb-hs-28nm-femtophy"; + reg = <0x0007c000 0x200>; + #phy-cells = <0>; + clocks = <&rpmcc RPM_SMD_LN_BB_CLK>, + <&gcc GCC_USB_HS_PHY_CFG_AHB_CLK>, + <&gcc GCC_USB2A_PHY_SLEEP_CLK>; + clock-names = "ref", "ahb", "sleep"; + resets = <&gcc GCC_QUSB2_PHY_BCR>, + <&gcc GCC_USB2_HS_PHY_ONLY_BCR>; + reset-names = "phy", "por"; + status = "disabled"; + }; + + qfprom: qfprom@a4000 { + compatible = "qcom,qcs404-qfprom", "qcom,qfprom"; + reg = <0x000a4000 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + cpr_efuse_speedbin: speedbin@13c { + reg = <0x13c 0x4>; + bits = <2 3>; + }; + + tsens_s0_p1: s0-p1@1f8 { + reg = <0x1f8 0x1>; + bits = <0 6>; + }; + + tsens_s0_p2: s0-p2@1f8 { + reg = <0x1f8 0x2>; + bits = <6 6>; + }; + + tsens_s1_p1: s1-p1@1f9 { + reg = <0x1f9 0x2>; + bits = <4 6>; + }; + + tsens_s1_p2: s1-p2@1fa { + reg = <0x1fa 0x1>; + bits = <2 6>; + }; + + tsens_s2_p1: s2-p1@1fb { + reg = <0x1fb 0x1>; + bits = <0 6>; + }; + + tsens_s2_p2: s2-p2@1fb { + reg = <0x1fb 0x2>; + bits = <6 6>; + }; + + tsens_s3_p1: s3-p1@1fc { + reg = <0x1fc 0x2>; + bits = <4 6>; + }; + + tsens_s3_p2: s3-p2@1fd { + reg = <0x1fd 0x1>; + bits = <2 6>; + }; + + tsens_s4_p1: s4-p1@1fe { + reg = <0x1fe 0x1>; + bits = <0 6>; + }; + + tsens_s4_p2: s4-p2@1fe { + reg = <0x1fe 0x2>; + bits = <6 6>; + }; + + tsens_s5_p1: s5-p1@200 { + reg = <0x200 0x1>; + bits = <0 6>; + }; + + tsens_s5_p2: s5-p2@200 { + reg = <0x200 0x2>; + bits = <6 6>; + }; + + tsens_s6_p1: s6-p1@201 { + reg = <0x201 0x2>; + bits = <4 6>; + }; + + tsens_s6_p2: s6-p2@202 { + reg = <0x202 0x1>; + bits = <2 6>; + }; + + tsens_s7_p1: s7-p1@203 { + reg = <0x203 0x1>; + bits = <0 6>; + }; + + tsens_s7_p2: s7-p2@203 { + reg = <0x203 0x2>; + bits = <6 6>; + }; + + tsens_s8_p1: s8-p1@204 { + reg = <0x204 0x2>; + bits = <4 6>; + }; + + tsens_s8_p2: s8-p2@205 { + reg = <0x205 0x1>; + bits = <2 6>; + }; + + tsens_s9_p1: s9-p1@206 { + reg = <0x206 0x1>; + bits = <0 6>; + }; + + tsens_s9_p2: s9-p2@206 { + reg = <0x206 0x2>; + bits = <6 6>; + }; + + tsens_mode: mode@208 { + reg = <0x208 1>; + bits = <0 3>; + }; + + tsens_base1: base1@208 { + reg = <0x208 2>; + bits = <3 8>; + }; + + tsens_base2: base2@208 { + reg = <0x209 2>; + bits = <3 8>; + }; + + cpr_efuse_quot_offset1: qoffset1@231 { + reg = <0x231 0x4>; + bits = <4 7>; + }; + cpr_efuse_quot_offset2: qoffset2@232 { + reg = <0x232 0x4>; + bits = <3 7>; + }; + cpr_efuse_quot_offset3: qoffset3@233 { + reg = <0x233 0x4>; + bits = <2 7>; + }; + cpr_efuse_init_voltage1: ivoltage1@229 { + reg = <0x229 0x4>; + bits = <4 6>; + }; + cpr_efuse_init_voltage2: ivoltage2@22a { + reg = <0x22a 0x4>; + bits = <2 6>; + }; + cpr_efuse_init_voltage3: ivoltage3@22b { + reg = <0x22b 0x4>; + bits = <0 6>; + }; + cpr_efuse_quot1: quot1@22b { + reg = <0x22b 0x4>; + bits = <6 12>; + }; + cpr_efuse_quot2: quot2@22d { + reg = <0x22d 0x4>; + bits = <2 12>; + }; + cpr_efuse_quot3: quot3@230 { + reg = <0x230 0x4>; + bits = <0 12>; + }; + cpr_efuse_ring1: ring1@228 { + reg = <0x228 0x4>; + bits = <0 3>; + }; + cpr_efuse_ring2: ring2@228 { + reg = <0x228 0x4>; + bits = <4 3>; + }; + cpr_efuse_ring3: ring3@229 { + reg = <0x229 0x4>; + bits = <0 3>; + }; + cpr_efuse_revision: revision@218 { + reg = <0x218 0x4>; + bits = <3 3>; + }; + }; + + rng: rng@e3000 { + compatible = "qcom,prng-ee"; + reg = <0x000e3000 0x1000>; + clocks = <&gcc GCC_PRNG_AHB_CLK>; + clock-names = "core"; + }; + + bimc: interconnect@400000 { + reg = <0x00400000 0x80000>; + compatible = "qcom,qcs404-bimc"; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_BIMC_CLK>, + <&rpmcc RPM_SMD_BIMC_A_CLK>; + }; + + tsens: thermal-sensor@4a9000 { + compatible = "qcom,qcs404-tsens", "qcom,tsens-v1"; + reg = <0x004a9000 0x1000>, /* TM */ + <0x004a8000 0x1000>; /* SROT */ + nvmem-cells = <&tsens_mode>, + <&tsens_base1>, <&tsens_base2>, + <&tsens_s0_p1>, <&tsens_s0_p2>, + <&tsens_s1_p1>, <&tsens_s1_p2>, + <&tsens_s2_p1>, <&tsens_s2_p2>, + <&tsens_s3_p1>, <&tsens_s3_p2>, + <&tsens_s4_p1>, <&tsens_s4_p2>, + <&tsens_s5_p1>, <&tsens_s5_p2>, + <&tsens_s6_p1>, <&tsens_s6_p2>, + <&tsens_s7_p1>, <&tsens_s7_p2>, + <&tsens_s8_p1>, <&tsens_s8_p2>, + <&tsens_s9_p1>, <&tsens_s9_p2>; + nvmem-cell-names = "mode", + "base1", "base2", + "s0_p1", "s0_p2", + "s1_p1", "s1_p2", + "s2_p1", "s2_p2", + "s3_p1", "s3_p2", + "s4_p1", "s4_p2", + "s5_p1", "s5_p2", + "s6_p1", "s6_p2", + "s7_p1", "s7_p2", + "s8_p1", "s8_p2", + "s9_p1", "s9_p2"; + #qcom,sensors = <10>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "uplow"; + #thermal-sensor-cells = <1>; + }; + + pcnoc: interconnect@500000 { + reg = <0x00500000 0x15080>; + compatible = "qcom,qcs404-pcnoc"; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_PNOC_CLK>, + <&rpmcc RPM_SMD_PNOC_A_CLK>; + }; + + snoc: interconnect@580000 { + reg = <0x00580000 0x23080>; + compatible = "qcom,qcs404-snoc"; + #interconnect-cells = <1>; + clock-names = "bus", "bus_a"; + clocks = <&rpmcc RPM_SMD_SNOC_CLK>, + <&rpmcc RPM_SMD_SNOC_A_CLK>; + }; + + remoteproc_cdsp: remoteproc@b00000 { + compatible = "qcom,qcs404-cdsp-pas"; + reg = <0x00b00000 0x4040>; + + interrupts-extended = <&intc GIC_SPI 229 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&cdsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&xo_board>; + clock-names = "xo"; + + /* + * If the node was using the PIL binding, then include properties: + * clocks = <&xo_board>, + * <&gcc GCC_CDSP_CFG_AHB_CLK>, + * <&gcc GCC_CDSP_TBU_CLK>, + * <&gcc GCC_BIMC_CDSP_CLK>, + * <&turingcc TURING_WRAPPER_AON_CLK>, + * <&turingcc TURING_Q6SS_AHBS_AON_CLK>, + * <&turingcc TURING_Q6SS_AHBM_AON_CLK>, + * <&turingcc TURING_Q6SS_Q6_AXIM_CLK>; + * clock-names = "xo", + * "sway", + * "tbu", + * "bimc", + * "ahb_aon", + * "q6ss_slave", + * "q6ss_master", + * "q6_axim"; + * resets = <&gcc GCC_CDSP_RESTART>; + * reset-names = "restart"; + * qcom,halt-regs = <&tcsr 0x19004>; + */ + + memory-region = <&cdsp_fw_mem>; + + qcom,smem-states = <&cdsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 141 IRQ_TYPE_EDGE_RISING>; + + qcom,remote-pid = <5>; + mboxes = <&apcs_glb 12>; + + label = "cdsp"; + }; + }; + + usb3: usb@7678800 { + compatible = "qcom,qcs404-dwc3", "qcom,dwc3"; + reg = <0x07678800 0x400>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + clocks = <&gcc GCC_USB30_MASTER_CLK>, + <&gcc GCC_SYS_NOC_USB3_CLK>, + <&gcc GCC_USB30_SLEEP_CLK>, + <&gcc GCC_USB30_MOCK_UTMI_CLK>; + clock-names = "core", "iface", "sleep", "mock_utmi"; + assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, + <&gcc GCC_USB30_MASTER_CLK>; + assigned-clock-rates = <19200000>, <200000000>; + status = "disabled"; + + usb3_dwc3: usb@7580000 { + compatible = "snps,dwc3"; + reg = <0x07580000 0xcd00>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + phys = <&usb2_phy_prim>, <&usb3_phy>; + phy-names = "usb2-phy", "usb3-phy"; + snps,has-lpm-erratum; + snps,hird-threshold = /bits/ 8 <0x10>; + snps,usb3_lpm_capable; + dr_mode = "otg"; + }; + }; + + usb2: usb@79b8800 { + compatible = "qcom,qcs404-dwc3", "qcom,dwc3"; + reg = <0x079b8800 0x400>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + clocks = <&gcc GCC_USB_HS_SYSTEM_CLK>, + <&gcc GCC_PCNOC_USB2_CLK>, + <&gcc GCC_USB_HS_INACTIVITY_TIMERS_CLK>, + <&gcc GCC_USB20_MOCK_UTMI_CLK>; + clock-names = "core", "iface", "sleep", "mock_utmi"; + assigned-clocks = <&gcc GCC_USB20_MOCK_UTMI_CLK>, + <&gcc GCC_USB_HS_SYSTEM_CLK>; + assigned-clock-rates = <19200000>, <133333333>; + status = "disabled"; + + usb@78c0000 { + compatible = "snps,dwc3"; + reg = <0x078c0000 0xcc00>; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + phys = <&usb2_phy_sec>; + phy-names = "usb2-phy"; + snps,has-lpm-erratum; + snps,hird-threshold = /bits/ 8 <0x10>; + snps,usb3_lpm_capable; + dr_mode = "peripheral"; + }; + }; + + tlmm: pinctrl@1000000 { + compatible = "qcom,qcs404-pinctrl"; + reg = <0x01000000 0x200000>, + <0x01300000 0x200000>, + <0x07b00000 0x200000>; + reg-names = "south", "north", "east"; + interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; + gpio-ranges = <&tlmm 0 0 120>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + + blsp1_i2c0_default: blsp1-i2c0-default-state { + pins = "gpio32", "gpio33"; + function = "blsp_i2c0"; + }; + + blsp1_i2c1_default: blsp1-i2c1-default-state { + pins = "gpio24", "gpio25"; + function = "blsp_i2c1"; + }; + + blsp1_i2c2_default: blsp1-i2c2-default-state { + sda-pins { + pins = "gpio19"; + function = "blsp_i2c_sda_a2"; + }; + + scl-pins { + pins = "gpio20"; + function = "blsp_i2c_scl_a2"; + }; + }; + + blsp1_i2c3_default: blsp1-i2c3-default-state { + pins = "gpio84", "gpio85"; + function = "blsp_i2c3"; + }; + + blsp1_i2c4_default: blsp1-i2c4-default-state { + pins = "gpio117", "gpio118"; + function = "blsp_i2c4"; + }; + + blsp1_uart0_default: blsp1-uart0-default-state { + pins = "gpio30", "gpio31", "gpio32", "gpio33"; + function = "blsp_uart0"; + }; + + blsp1_uart1_default: blsp1-uart1-default-state { + pins = "gpio22", "gpio23"; + function = "blsp_uart1"; + }; + + blsp1_uart2_default: blsp1-uart2-default-state { + rx-pins { + pins = "gpio18"; + function = "blsp_uart_rx_a2"; + }; + + tx-pins { + pins = "gpio17"; + function = "blsp_uart_tx_a2"; + }; + }; + + blsp1_uart3_default: blsp1-uart3-default-state { + cts-pins { + pins = "gpio84"; + function = "blsp_uart3"; + }; + + rts-tx-pins { + pins = "gpio85", "gpio82"; + function = "blsp_uart3"; + }; + + rx-pins { + pins = "gpio83"; + function = "blsp_uart3"; + }; + }; + + blsp2_i2c0_default: blsp2-i2c0-default-state { + pins = "gpio28", "gpio29"; + function = "blsp_i2c5"; + }; + + blsp1_spi0_default: blsp1-spi0-default-state { + pins = "gpio30", "gpio31", "gpio32", "gpio33"; + function = "blsp_spi0"; + }; + + blsp1_spi1_default: blsp1-spi1-default-state { + mosi-pins { + pins = "gpio22"; + function = "blsp_spi_mosi_a1"; + }; + + miso-pins { + pins = "gpio23"; + function = "blsp_spi_miso_a1"; + }; + + cs-n-pins { + pins = "gpio24"; + function = "blsp_spi_cs_n_a1"; + }; + + clk-pins { + pins = "gpio25"; + function = "blsp_spi_clk_a1"; + }; + }; + + blsp1_spi2_default: blsp1-spi2-default-state { + pins = "gpio17", "gpio18", "gpio19", "gpio20"; + function = "blsp_spi2"; + }; + + blsp1_spi3_default: blsp1-spi3-default-state { + pins = "gpio82", "gpio83", "gpio84", "gpio85"; + function = "blsp_spi3"; + }; + + blsp1_spi4_default: blsp1-spi4-default-state { + pins = "gpio37", "gpio38", "gpio117", "gpio118"; + function = "blsp_spi4"; + }; + + blsp2_spi0_default: blsp2-spi0-default-state { + pins = "gpio26", "gpio27", "gpio28", "gpio29"; + function = "blsp_spi5"; + }; + + blsp2_uart0_default: blsp2-uart0-default-state { + pins = "gpio26", "gpio27", "gpio28", "gpio29"; + function = "blsp_uart5"; + }; + }; + + gcc: clock-controller@1800000 { + compatible = "qcom,gcc-qcs404"; + reg = <0x01800000 0x80000>; + #clock-cells = <1>; + #reset-cells = <1>; + #power-domain-cells = <1>; + + clocks = <&xo_board>, + <&sleep_clk>, + <&pcie_phy>, + <0>, + <0>, + <0>; + + assigned-clocks = <&gcc GCC_APSS_AHB_CLK_SRC>; + assigned-clock-rates = <19200000>; + }; + + tcsr_mutex: hwlock@1905000 { + compatible = "qcom,tcsr-mutex"; + reg = <0x01905000 0x20000>; + #hwlock-cells = <1>; + }; + + tcsr: syscon@1937000 { + compatible = "qcom,qcs404-tcsr", "syscon"; + reg = <0x01937000 0x25000>; + }; + + sram@290000 { + compatible = "qcom,rpm-stats"; + reg = <0x00290000 0x10000>; + }; + + spmi_bus: spmi@200f000 { + compatible = "qcom,spmi-pmic-arb"; + reg = <0x0200f000 0x001000>, + <0x02400000 0x800000>, + <0x02c00000 0x800000>, + <0x03800000 0x200000>, + <0x0200a000 0x002100>; + reg-names = "core", "chnls", "obsrvr", "intr", "cnfg"; + interrupt-names = "periph_irq"; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + qcom,ee = <0>; + qcom,channel = <0>; + #address-cells = <2>; + #size-cells = <0>; + interrupt-controller; + #interrupt-cells = <4>; + }; + + remoteproc_wcss: remoteproc@7400000 { + compatible = "qcom,qcs404-wcss-pas"; + reg = <0x07400000 0x4040>; + + interrupts-extended = <&intc GIC_SPI 153 IRQ_TYPE_EDGE_RISING>, + <&wcss_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&wcss_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&wcss_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&wcss_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&xo_board>; + clock-names = "xo"; + + memory-region = <&wlan_fw_mem>; + + qcom,smem-states = <&wcss_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 156 IRQ_TYPE_EDGE_RISING>; + + qcom,remote-pid = <1>; + mboxes = <&apcs_glb 16>; + + label = "wcss"; + }; + }; + + pcie_phy: phy@7786000 { + compatible = "qcom,qcs404-pcie2-phy", "qcom,pcie2-phy"; + reg = <0x07786000 0xb8>; + + clocks = <&gcc GCC_PCIE_0_PIPE_CLK>; + resets = <&gcc GCC_PCIEPHY_0_PHY_BCR>, + <&gcc GCC_PCIE_0_PIPE_ARES>; + reset-names = "phy", "pipe"; + + clock-output-names = "pcie_0_pipe_clk"; + #clock-cells = <0>; + #phy-cells = <0>; + + status = "disabled"; + }; + + sdcc1: mmc@7804000 { + compatible = "qcom,qcs404-sdhci", "qcom,sdhci-msm-v5"; + reg = <0x07804000 0x1000>, <0x7805000 0x1000>; + reg-names = "hc", "cqhci"; + + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "hc_irq", "pwr_irq"; + + clocks = <&gcc GCC_SDCC1_AHB_CLK>, + <&gcc GCC_SDCC1_APPS_CLK>, + <&xo_board>; + clock-names = "iface", "core", "xo"; + + status = "disabled"; + }; + + blsp1_dma: dma-controller@7884000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x07884000 0x25000>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "bam_clk"; + #dma-cells = <1>; + qcom,ee = <0>; + status = "okay"; + }; + + blsp1_uart0: serial@78af000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078af000 0x200>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART0_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp1_dma 0>, <&blsp1_dma 1>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_uart0_default>; + status = "disabled"; + }; + + blsp1_uart1: serial@78b0000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078b0000 0x200>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART1_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp1_dma 2>, <&blsp1_dma 3>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_uart1_default>; + status = "disabled"; + }; + + blsp1_uart2: serial@78b1000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078b1000 0x200>; + interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART2_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp1_dma 4>, <&blsp1_dma 5>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_uart2_default>; + status = "okay"; + }; + + ethernet: ethernet@7a80000 { + compatible = "qcom,qcs404-ethqos"; + reg = <0x07a80000 0x10000>, + <0x07a96000 0x100>; + reg-names = "stmmaceth", "rgmii"; + clock-names = "stmmaceth", "pclk", "ptp_ref", "rgmii"; + clocks = <&gcc GCC_ETH_AXI_CLK>, + <&gcc GCC_ETH_SLAVE_AHB_CLK>, + <&gcc GCC_ETH_PTP_CLK>, + <&gcc GCC_ETH_RGMII_CLK>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq", "eth_lpi"; + + snps,tso; + rx-fifo-depth = <4096>; + tx-fifo-depth = <4096>; + + status = "disabled"; + }; + + wifi: wifi@a000000 { + compatible = "qcom,wcn3990-wifi"; + reg = <0xa000000 0x800000>; + reg-names = "membase"; + memory-region = <&wlan_msa_mem>; + interrupts = <GIC_SPI 277 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 278 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 279 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 280 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 281 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 282 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 283 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 284 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 287 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 288 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + + blsp1_uart3: serial@78b2000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x078b2000 0x200>; + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_UART3_APPS_CLK>, <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp1_dma 6>, <&blsp1_dma 7>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_uart3_default>; + status = "disabled"; + }; + + blsp1_i2c0: i2c@78b5000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b5000 0x600>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP0_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_i2c0_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_spi0: spi@78b5000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b5000 0x600>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP0_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_spi0_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c1: i2c@78b6000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b6000 0x600>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP1_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_i2c1_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_spi1: spi@78b6000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b6000 0x600>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP1_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_spi1_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c2: i2c@78b7000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b7000 0x600>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP2_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_i2c2_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_spi2: spi@78b7000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b7000 0x600>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP2_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_spi2_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c3: i2c@78b8000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b8000 0x600>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP3_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_i2c3_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_spi3: spi@78b8000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b8000 0x600>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP3_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_spi3_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_i2c4: i2c@78b9000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x078b9000 0x600>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP4_I2C_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_i2c4_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp1_spi4: spi@78b9000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x078b9000 0x600>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP1_QUP4_SPI_APPS_CLK>, + <&gcc GCC_BLSP1_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp1_spi4_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_dma: dma-controller@7ac4000 { + compatible = "qcom,bam-v1.7.0"; + reg = <0x07ac4000 0x17000>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "bam_clk"; + #dma-cells = <1>; + qcom,ee = <0>; + status = "disabled"; + }; + + blsp2_uart0: serial@7aef000 { + compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; + reg = <0x07aef000 0x200>; + interrupts = <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_UART0_APPS_CLK>, <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + dmas = <&blsp2_dma 0>, <&blsp2_dma 1>; + dma-names = "tx", "rx"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp2_uart0_default>; + status = "disabled"; + }; + + blsp2_i2c0: i2c@7af5000 { + compatible = "qcom,i2c-qup-v2.2.1"; + reg = <0x07af5000 0x600>; + interrupts = <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP0_I2C_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp2_i2c0_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + blsp2_spi0: spi@7af5000 { + compatible = "qcom,spi-qup-v2.2.1"; + reg = <0x07af5000 0x600>; + interrupts = <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&gcc GCC_BLSP2_QUP0_SPI_APPS_CLK>, + <&gcc GCC_BLSP2_AHB_CLK>; + clock-names = "core", "iface"; + pinctrl-names = "default"; + pinctrl-0 = <&blsp2_spi0_default>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + sram@8600000 { + compatible = "qcom,qcs404-imem", "syscon", "simple-mfd"; + reg = <0x08600000 0x1000>; + + #address-cells = <1>; + #size-cells = <1>; + + ranges = <0 0x08600000 0x1000>; + + pil-reloc@94c { + compatible = "qcom,pil-reloc-info"; + reg = <0x94c 0xc8>; + }; + }; + + intc: interrupt-controller@b000000 { + compatible = "qcom,msm-qgic2"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x0b000000 0x1000>, + <0x0b002000 0x1000>; + }; + + apcs_glb: mailbox@b011000 { + compatible = "qcom,qcs404-apcs-apps-global", + "qcom,msm8916-apcs-kpss-global", "syscon"; + reg = <0x0b011000 0x1000>; + #mbox-cells = <1>; + clocks = <&apcs_hfpll>, <&gcc GCC_GPLL0_AO_OUT_MAIN>; + clock-names = "pll", "aux"; + #clock-cells = <0>; + }; + + apcs_hfpll: clock-controller@b016000 { + compatible = "qcom,hfpll"; + reg = <0x0b016000 0x30>; + #clock-cells = <0>; + clock-output-names = "apcs_hfpll"; + clocks = <&xo_board>; + clock-names = "xo"; + }; + + watchdog@b017000 { + compatible = "qcom,apss-wdt-qcs404", "qcom,kpss-wdt"; + reg = <0x0b017000 0x1000>; + clocks = <&sleep_clk>; + }; + + cpr: power-controller@b018000 { + compatible = "qcom,qcs404-cpr", "qcom,cpr"; + reg = <0x0b018000 0x1000>; + interrupts = <0 15 IRQ_TYPE_EDGE_RISING>; + clocks = <&xo_board>; + clock-names = "ref"; + vdd-apc-supply = <&pms405_s3>; + #power-domain-cells = <0>; + operating-points-v2 = <&cpr_opp_table>; + acc-syscon = <&tcsr>; + + nvmem-cells = <&cpr_efuse_quot_offset1>, + <&cpr_efuse_quot_offset2>, + <&cpr_efuse_quot_offset3>, + <&cpr_efuse_init_voltage1>, + <&cpr_efuse_init_voltage2>, + <&cpr_efuse_init_voltage3>, + <&cpr_efuse_quot1>, + <&cpr_efuse_quot2>, + <&cpr_efuse_quot3>, + <&cpr_efuse_ring1>, + <&cpr_efuse_ring2>, + <&cpr_efuse_ring3>, + <&cpr_efuse_revision>; + nvmem-cell-names = "cpr_quotient_offset1", + "cpr_quotient_offset2", + "cpr_quotient_offset3", + "cpr_init_voltage1", + "cpr_init_voltage2", + "cpr_init_voltage3", + "cpr_quotient1", + "cpr_quotient2", + "cpr_quotient3", + "cpr_ring_osc1", + "cpr_ring_osc2", + "cpr_ring_osc3", + "cpr_fuse_revision"; + }; + + timer@b120000 { + #address-cells = <1>; + #size-cells = <1>; + ranges; + compatible = "arm,armv7-timer-mem"; + reg = <0x0b120000 0x1000>; + clock-frequency = <19200000>; + + frame@b121000 { + frame-number = <0>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b121000 0x1000>, + <0x0b122000 0x1000>; + }; + + frame@b123000 { + frame-number = <1>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b123000 0x1000>; + status = "disabled"; + }; + + frame@b124000 { + frame-number = <2>; + interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b124000 0x1000>; + status = "disabled"; + }; + + frame@b125000 { + frame-number = <3>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b125000 0x1000>; + status = "disabled"; + }; + + frame@b126000 { + frame-number = <4>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b126000 0x1000>; + status = "disabled"; + }; + + frame@b127000 { + frame-number = <5>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + reg = <0xb127000 0x1000>; + status = "disabled"; + }; + + frame@b128000 { + frame-number = <6>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x0b128000 0x1000>; + status = "disabled"; + }; + }; + + remoteproc_adsp: remoteproc@c700000 { + compatible = "qcom,qcs404-adsp-pas"; + reg = <0x0c700000 0x4040>; + + interrupts-extended = <&intc GIC_SPI 293 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 0 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 1 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 2 IRQ_TYPE_EDGE_RISING>, + <&adsp_smp2p_in 3 IRQ_TYPE_EDGE_RISING>; + interrupt-names = "wdog", "fatal", "ready", + "handover", "stop-ack"; + + clocks = <&xo_board>; + clock-names = "xo"; + + memory-region = <&adsp_fw_mem>; + + qcom,smem-states = <&adsp_smp2p_out 0>; + qcom,smem-state-names = "stop"; + + status = "disabled"; + + glink-edge { + interrupts = <GIC_SPI 289 IRQ_TYPE_EDGE_RISING>; + + qcom,remote-pid = <2>; + mboxes = <&apcs_glb 8>; + + label = "adsp"; + }; + }; + + pcie: pci@10000000 { + compatible = "qcom,pcie-qcs404"; + reg = <0x10000000 0xf1d>, + <0x10000f20 0xa8>, + <0x07780000 0x2000>, + <0x10001000 0x2000>; + reg-names = "dbi", "elbi", "parf", "config"; + device_type = "pci"; + linux,pci-domain = <0>; + bus-range = <0x00 0xff>; + num-lanes = <1>; + #address-cells = <3>; + #size-cells = <2>; + + ranges = <0x81000000 0x0 0x00000000 0x10003000 0x0 0x00010000>, /* I/O */ + <0x82000000 0x0 0x10013000 0x10013000 0x0 0x007ed000>; /* memory */ + + interrupts = <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "msi"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0x7>; + interrupt-map = <0 0 0 1 &intc GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, /* int_a */ + <0 0 0 2 &intc GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>, /* int_b */ + <0 0 0 3 &intc GIC_SPI 267 IRQ_TYPE_LEVEL_HIGH>, /* int_c */ + <0 0 0 4 &intc GIC_SPI 268 IRQ_TYPE_LEVEL_HIGH>; /* int_d */ + clocks = <&gcc GCC_PCIE_0_CFG_AHB_CLK>, + <&gcc GCC_PCIE_0_AUX_CLK>, + <&gcc GCC_PCIE_0_MSTR_AXI_CLK>, + <&gcc GCC_PCIE_0_SLV_AXI_CLK>; + clock-names = "iface", "aux", "master_bus", "slave_bus"; + + resets = <&gcc GCC_PCIE_0_AXI_MASTER_ARES>, + <&gcc GCC_PCIE_0_AXI_SLAVE_ARES>, + <&gcc GCC_PCIE_0_AXI_MASTER_STICKY_ARES>, + <&gcc GCC_PCIE_0_CORE_STICKY_ARES>, + <&gcc GCC_PCIE_0_BCR>, + <&gcc GCC_PCIE_0_AHB_ARES>; + reset-names = "axi_m", + "axi_s", + "axi_m_sticky", + "pipe_sticky", + "pwr", + "ahb"; + + phys = <&pcie_phy>; + phy-names = "pciephy"; + + status = "disabled"; + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 2 0xff08>, + <GIC_PPI 3 0xff08>, + <GIC_PPI 4 0xff08>, + <GIC_PPI 1 0xff08>; + }; + + smp2p-adsp { + compatible = "qcom,smp2p"; + qcom,smem = <443>, <429>; + interrupts = <GIC_SPI 291 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apcs_glb 10>; + qcom,local-pid = <0>; + qcom,remote-pid = <2>; + + adsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + adsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-cdsp { + compatible = "qcom,smp2p"; + qcom,smem = <94>, <432>; + interrupts = <GIC_SPI 143 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apcs_glb 14>; + qcom,local-pid = <0>; + qcom,remote-pid = <5>; + + cdsp_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + cdsp_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + smp2p-wcss { + compatible = "qcom,smp2p"; + qcom,smem = <435>, <428>; + interrupts = <GIC_SPI 158 IRQ_TYPE_EDGE_RISING>; + mboxes = <&apcs_glb 18>; + qcom,local-pid = <0>; + qcom,remote-pid = <1>; + + wcss_smp2p_out: master-kernel { + qcom,entry-name = "master-kernel"; + #qcom,smem-state-cells = <1>; + }; + + wcss_smp2p_in: slave-kernel { + qcom,entry-name = "slave-kernel"; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + thermal-zones { + aoss-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 0>; + + trips { + aoss_alert0: trip-point0 { + temperature = <105000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + q6-hvx-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 1>; + + trips { + q6_hvx_alert0: trip-point0 { + temperature = <105000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + lpass-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 2>; + + trips { + lpass_alert0: trip-point0 { + temperature = <105000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + wlan-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 3>; + + trips { + wlan_alert0: trip-point0 { + temperature = <105000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + + cluster-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 4>; + + trips { + cluster_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + cluster_alert1: trip-point1 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + cluster_crit: cluster-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&cluster_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu0-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 5>; + + trips { + cpu0_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + cpu0_alert1: trip-point1 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu0_crit: cpu-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&cpu0_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu1-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 6>; + + trips { + cpu1_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + cpu1_alert1: trip-point1 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu1_crit: cpu-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&cpu1_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu2-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 7>; + + trips { + cpu2_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + cpu2_alert1: trip-point1 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu2_crit: cpu-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&cpu2_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + cpu3-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 8>; + + trips { + cpu3_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + cpu3_alert1: trip-point1 { + temperature = <105000>; + hysteresis = <2000>; + type = "passive"; + }; + cpu3_crit: cpu-crit { + temperature = <120000>; + hysteresis = <2000>; + type = "critical"; + }; + }; + cooling-maps { + map0 { + trip = <&cpu3_alert1>; + cooling-device = <&CPU0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&CPU3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; + }; + + gpu-thermal { + polling-delay-passive = <250>; + polling-delay = <1000>; + + thermal-sensors = <&tsens 9>; + + trips { + gpu_alert0: trip-point0 { + temperature = <95000>; + hysteresis = <2000>; + type = "hot"; + }; + }; + }; + }; +};
On 19/12/2023 17:04, Caleb Connolly wrote:
Drop the U-Boot specific DTS in favour of upstream. We'll only include the -4000 variant as that is what U-Boot already supported.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org
arch/arm/dts/Makefile | 2 +- arch/arm/dts/pms405.dtsi | 149 +++ arch/arm/dts/qcs404-evb-4000-u-boot.dtsi | 26 + arch/arm/dts/qcs404-evb-4000.dts | 96 ++ arch/arm/dts/qcs404-evb-uboot.dtsi | 30 - arch/arm/dts/qcs404-evb.dts | 390 ------- arch/arm/dts/qcs404-evb.dtsi | 389 +++++++ arch/arm/dts/qcs404.dtsi | 1829 ++++++++++++++++++++++++++++++ 8 files changed, 2490 insertions(+), 421 deletions(-)
<snip> Same as patch 19, with the commit id:
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
This board is entirely supported by the generic arch code and DTS. The board code used to handle turning on the vbus regulator, however this is now handled via DT.
With this, the board specific defconfig is also no longer needed, so drop it as well.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- board/qualcomm/qcs404-evb/Makefile | 6 ---- board/qualcomm/qcs404-evb/qcs404-evb.c | 49 ----------------------------- configs/qcs404evb_defconfig | 56 ---------------------------------- 3 files changed, 111 deletions(-)
diff --git a/board/qualcomm/qcs404-evb/Makefile b/board/qualcomm/qcs404-evb/Makefile deleted file mode 100644 index 4665827e0859..000000000000 --- a/board/qualcomm/qcs404-evb/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org -# - -obj-y += qcs404-evb.o diff --git a/board/qualcomm/qcs404-evb/qcs404-evb.c b/board/qualcomm/qcs404-evb/qcs404-evb.c deleted file mode 100644 index 1a4b1f97a3ae..000000000000 --- a/board/qualcomm/qcs404-evb/qcs404-evb.c +++ /dev/null @@ -1,49 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Board init file for QCS404-EVB - * - * (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org - */ - -#include <common.h> -#include <cpu_func.h> -#include <dm.h> -#include <env.h> -#include <init.h> -#include <asm/cache.h> -#include <asm/gpio.h> -#include <asm/global_data.h> -#include <fdt_support.h> - -DECLARE_GLOBAL_DATA_PTR; - -void qcom_board_init(void) -{ - struct udevice *pmic_gpio; - struct gpio_desc usb_vbus_boost_pin; - int ret, node; - - ret = uclass_get_device_by_name(UCLASS_GPIO, - "pms405_gpios@c000", - &pmic_gpio); - if (ret < 0) { - printf("Failed to find pms405_gpios@c000 node.\n"); - return; - } - - node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(pmic_gpio), - "usb_vbus_boost_pin"); - if (node < 0) { - printf("Failed to find usb_hub_reset_pm dt node.\n"); - return; - } - ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "gpios", 0, - &usb_vbus_boost_pin, 0); - if (ret < 0) { - printf("Failed to request usb_hub_reset_pm gpio.\n"); - return; - } - - dm_gpio_set_dir_flags(&usb_vbus_boost_pin, - GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); -} diff --git a/configs/qcs404evb_defconfig b/configs/qcs404evb_defconfig deleted file mode 100644 index 7daaa449ffbd..000000000000 --- a/configs/qcs404evb_defconfig +++ /dev/null @@ -1,56 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_BOARD="qcs404-evb" -CONFIG_SKIP_LOWLEVEL_INIT=y -CONFIG_COUNTER_FREQUENCY=19000000 -CONFIG_POSITION_INDEPENDENT=y -CONFIG_ARCH_SNAPDRAGON=y -CONFIG_DEFAULT_DEVICE_TREE="qcs404-evb" -CONFIG_IDENT_STRING="\nQualcomm QCS404-EVB" -CONFIG_SYS_LOAD_ADDR=0x80000000 -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_BOOTDELAY=5 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="earlycon ignore_loglevel root= clk_ignore_unused" -CONFIG_SAVE_PREV_BL_FDT_ADDR=y -CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR=y -# CONFIG_DISPLAY_CPUINFO is not set -CONFIG_HUSH_PARSER=y -CONFIG_SYS_MAXARGS=64 -CONFIG_SYS_CBSIZE=512 -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y -CONFIG_CMD_USB=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -# CONFIG_NET is not set -CONFIG_CLK=y -CONFIG_CLK_QCOM_QCS404=y -CONFIG_MSM_GPIO=y -CONFIG_QCOM_PMIC_GPIO=y -CONFIG_MISC=y -CONFIG_MMC_HS400_SUPPORT=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_ADMA=y -CONFIG_MMC_SDHCI_MSM=y -CONFIG_PHY=y -CONFIG_PHY_QCOM_USB_HS_28NM=y -CONFIG_PHY_QCOM_USB_SS=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_QCOM_QCS404=y -CONFIG_DM_PMIC=y -CONFIG_PMIC_QCOM=y -CONFIG_MSM_SERIAL=y -CONFIG_SPMI_MSM=y -CONFIG_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GENERIC=y -CONFIG_USB_STORAGE=y -CONFIG_LMB_MAX_REGIONS=64
- Board init file for QCS404-EVB
- (C) Copyright 2022 Sumit Garg sumit.garg@linaro.org
- int ret, node;
&pmic_gpio);
- if (ret < 0) {
return;
- if (node < 0) {
return;
- if (ret < 0) {
return;
Yeah ! code removal !
Hi Caleb,
On Tue, 19 Dec 2023 at 21:34, Caleb Connolly caleb.connolly@linaro.org wrote:
I would like to understand how the board specific bits are to be handled going forward. One of the examples for QCS404 derived board uses I2C eeprom to save the ethernet MAC address. How should one configure that via this generic target?
Would you expect arch/arm/mach-snapdragon/board.c to hold that code? Or we should have a separate defconfig and board support code for that?
BTW, qcs404-evb does provide networking support but at the time when I added its support the network port was broken. It may very well be the case that someone tries to enable networking on qcs404-evb in the future.
The same holds true for how we should add support for fastboot mode entry on a button press when U-boot starts as a first stage bootloader.
It's always good to see generalization coming in but that should come with alternate methods to support existing board needs.
-Sumit
int ret, node;
&pmic_gpio);
if (ret < 0) {
return;
if (node < 0) {
return;
if (ret < 0) {
return;
-- 2.42.1
Add drivers and DTS files, as well as regex matches for qcom/qualcomm/snapdragon.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- MAINTAINERS | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 8cd102eaa070..b41801078c94 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -571,18 +571,22 @@ M: Caleb Connolly caleb.connolly@linaro.org M: Neil Armstrong neil.armstrong@linaro.org R: Sumit Garg sumit.garg@linaro.org S: Maintained -F: arch/arm/mach-snapdragon/ -F: drivers/button/button-qcom-pmic.c -F: drivers/clk/qcom/ +F: arch/arm/dts/msm8*.dtsi +F: arch/arm/dts/pm8???.dtsi +F: arch/arm/dts/pms405.dtsi +F: arch/arm/dts/sdm845.dtsi +F: drivers/*/*/pm8???-* F: drivers/gpio/msm_gpio.c F: drivers/mmc/msm_sdhci.c F: drivers/phy/msm8916-usbh-phy.c -F: drivers/pinctrl/qcom/ F: drivers/serial/serial_msm.c F: drivers/serial/serial_msm_geni.c F: drivers/smem/msm_smem.c F: drivers/spmi/spmi-msm.c F: drivers/usb/host/ehci-msm.c +N: qcom +N: snapdragon +N: qualcomm
ARM STI M: Patrice Chotard patrice.chotard@foss.st.com
Hi Caleb,
On Tue, 19 Dec 2023 at 09:04, Caleb Connolly caleb.connolly@linaro.org wrote:
== DT loading ==
Previously, boards used the FDT blob embedded into U-Boot (via OF_SEPARATE). However, most Qualcomm boards run U-Boot as a secondary bootloader, so we can instead rely on the first-stage bootloader to populate some useful FDT properties for us (notably the /memory node and KASLR seed) and fetch the DTB that it provides. Combined with the memory map changes above, this let's us entirely avoid configuring the memory map explicitly.
Running U-Boot as a secondary bootloader is the degenerate case. Are there any Qualcomm boards where U-Boot runs first? In that case, perhaps the DT could be used in SPL to determine the memory size as well?
(this series is fine to me, BTW)
On 20/12/2023 04:46, Simon Glass wrote:
Hi Caleb,
== DT loading ==
Yes, I'm totally fine with having memory maps hardcoded in DT, this would be my go-to approach for running U-Boot as a first-stage bootloader.
Hi Caleb,
Historically, Qualcomm boards in U-Boot have all had their own board/qualcomm/xyz directory, their own CONFIG_TARGET_XYZ option, their own hardcoded sysmap-xyz.c file, and their own U-Boot specific devicetree with little/no compatibility with upstream DT.
This series makes a few final prepatory changes, and then replaces almost all of the board specific code with generic alternatives. The end result is that all Qualcomm boards both current and future (with the exception of the db410c and db820c) can be supported by a single U-Boot binary by just providing the correct DT. New boards can be added without introducing any addition mach/ or board/ code or config options.
Due to the nature of this change, the patch ("mach-snapdragon: generalise board support") has become pretty big, I tried a few different ways to represent this in git history, but the other methods (e.g. adding a stub "generic" target and removing it again) were more confusing and made for much messier git history. The current patch is mostly atomic, but requires regenerating the config.
The QCS404 EVB board had some code to enable the USB VBUS regulator, this is dropped in favour of a adding a new vbus-supply property to the dwc3-generic driver. This will also be used by the dragonboard845c in a future patch. This handles the common case of a board requiring some regulator be enabled for USB host mode.
A more detailed description of the changes is below.
== Memory map ==
The memory map was historically hardcoded into U-Boot, this meant that U-Boot had to be built for a specific variant of a device. This is changed to instead read the memory map from the DT /memory node.
Additionally, most boards mapped addresss 0x0 as valid, as a result if a null pointer access happens then it will cause a bus stall (and board hang). This is fixed so that null pointer accesses will now correctly throw an exception.
== DT loading ==
== defconfig ==
Most of the board defconfigs and config headers were quite similar, to simplify maintenance going forward, all the fully generic boards (sdm845 and qcs404-evb so far) are adapted to use the new qcom_defconfig. Going forward, all new Qualcomm boards should be supported by this defconfig. A notable exception is for specific usecases (like U-Boot as the primary bootloader).
== The older dragonboards ==
The db410c and db820c both have some custom board init code, as a result they aren't yet binary compatible. mach-snapdragon is adjusted so that all the necessary config options (e.g. CONFIG_SYS_BOARD) can be set from their defconfigs, this makes it possible to enable support for new boards without introducing additional config options.
The db410c can run U-Boot either chainloaded like the other boards, or as a first-stage bootloader replacing aboot. However it was hardcoded to only build for the latter option. This series introduces a new "chainloaded" defconfig to enable easier testing via fastboot.
== dynamic environment variables ==
This series also introduces runtime-allocated load addresses via the lmb allocator. This allows for booting on boards with vastly different memory layouts without any pre-calculation or macro magic in the config header. This feature is based on similar code in mach-apple.
The soc, board, and fdtfile environment variables are also generated automatically. Many Qualcomm boards follow a similar scheme for DTB naming such that the name can often be derived from the root compatible properties. This is intended to cover the most common cases and be a simple solution for booting generic distro images without having to explicitly choose the right DTB. The U-Boot DTS can be tweaked if necessary to produce the correct name, the variable can be overwritten, or a bootloader like GRUB can load the devicetree instead.
== Upstream DT ==
All Qualcomm boards have had their devicetree files replaced with the upstream versions. Previous patch series made the necessary driver adjustments to fully support the upstream DT format. All future Qualcomm boards should use upstream DTS by default.
Once Sumit's work to import dt-rebasing has been merged, we will drop the imported DT and bindings again.
Since there is consensus building in the U-Boot community to use DT rebasing subtree, I would suggest you rebase your work on top of [1]. You can take an amlogic SoC patch [2] as a reference and see corresponding value-add. I don't see the point of unnecessary churn if there is consensus we agree upon.
[1] https://lore.kernel.org/all/20231214135103.1606605-1-sumit.garg@linaro.org/ [2] https://lore.kernel.org/all/20231214135103.1606605-8-sumit.garg@linaro.org/
I have tested this series on the Dragonboard410c, Dragonboard820c, and Dragonboard845c. I unfortunately don't have access to a QCS404 EVB board to test.
This series is based on the qcom-next branch [1] and depends on my PMIC fixes series [2], an integration branch for testing can be found at [3]. The non-qualcomm-specific changes (patches 1 and 2) don't have any dependencies.
Changes in v2:
- Split DTS changes to reduce patch size.
- Import full board DTS files from Linux too, and introduce -u-boot.dtsi files where necessary to make any U-Boot specific changes.
- Add a pinctrl driver for qcom PMIC GPIOs
- Always enable LINUX_KERNEL_IMAGE_HEADER
- Link to v1: https://lore.kernel.org/r/20231121-b4-qcom-common-target-v1-0-9492198e0c15@l...
To: Neil Armstrong neil.armstrong@linaro.org To: Sumit Garg sumit.garg@linaro.org To: Ramon Fried rfried.dev@gmail.com Cc: Marek Vasut marex@denx.de To: Dzmitry Sankouski dsankouski@gmail.com To: Caleb Connolly caleb.connolly@linaro.org To: Peng Fan peng.fan@nxp.com To: Jaehoon Chung jh80.chung@samsung.com To: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com To: Lukasz Majewski lukma@denx.de To: Sean Anderson seanga2@gmail.com To: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com To: Stephan Gerhold stephan@gerhold.net Cc: u-boot@lists.denx.de
Caleb Connolly (32): arm: init: export prev_bl_fdt_addr usb: dwc3-generic: support external vbus regulator mmc: msm_sdhci: use modern clock handling dt-bindings: drop msm_sdhci binding clk/qcom: use upstream compatible properties serial: msm: add debug UART serial: msm: fix clock handling gpio: qcom_pmic: 1-based GPIOs gpio: qcom_pmic: add a quirk to skip GPIO configuration gpio: qcom_pmic: add pinctrl driver board: dragonboard410c: add chainloaded config fragment board: dragonboard410c: upstream DT compat board: dragonboard410c: import board code from mach-snapdragon board: dragonboard820c: use LINUX_KERNEL_IMAGE_HEADER mach-snapdragon: generalise board support mach-snapdragon: dynamic load addresses mach-snapdragon: generate fdtfile automatically doc: board/qualcomm: document generic targets
dt-bindings: import headers for SDM845 dts: sdm845: import supporting dtsi files dts: sdm845: replace with upstream DTS dt-bindings: import headers for MSM8916 dts: msm8916: import PMIC dtsi files dts: msm8916: replace with upstream DTS dt-bindings: import headers for MSM8996 dts: msm8996: import PMIC dtsi files dts: dragonboard820c: use correct bindings for clocks dts: msm8996: replace with upstream DTS dt-bindings: import headers for qcs404 dts: qcs404-evb: replace with upstream DT
The value being all these DT import patches won't be needed with DT rebasing.
-Sumit
board: qcs404-evb: drop board code MAINTAINERS: Qualcomm: add some missing paths
MAINTAINERS | 12 +- arch/arm/Kconfig | 4 + arch/arm/dts/Makefile | 9 +- arch/arm/dts/apq8016-sbc.dts | 729 +++ arch/arm/dts/apq8096-db820c-u-boot.dtsi | 10 + arch/arm/dts/apq8096-db820c.dts | 1137 ++++ arch/arm/dts/dragonboard410c-uboot.dtsi | 44 - arch/arm/dts/dragonboard410c.dts | 199 +- arch/arm/dts/dragonboard820c-uboot.dtsi | 32 - arch/arm/dts/dragonboard820c.dts | 151 - arch/arm/dts/dragonboard845c-uboot.dtsi | 26 - arch/arm/dts/dragonboard845c.dts | 48 - arch/arm/dts/msm8916-pm8916.dtsi | 157 + arch/arm/dts/msm8916.dtsi | 2702 +++++++++ arch/arm/dts/msm8996.dtsi | 3884 +++++++++++++ arch/arm/dts/pm8916.dtsi | 178 + arch/arm/dts/pm8994.dtsi | 152 + arch/arm/dts/pm8998.dtsi | 130 + arch/arm/dts/pmi8994.dtsi | 65 + arch/arm/dts/pmi8998.dtsi | 98 + arch/arm/dts/pms405.dtsi | 149 + arch/arm/dts/qcs404-evb-4000-u-boot.dtsi | 26 + arch/arm/dts/qcs404-evb-4000.dts | 96 + arch/arm/dts/qcs404-evb-uboot.dtsi | 30 - arch/arm/dts/qcs404-evb.dts | 390 -- arch/arm/dts/qcs404-evb.dtsi | 389 ++ arch/arm/dts/qcs404.dtsi | 1829 ++++++ arch/arm/dts/sdm845-db845c.dts | 1190 ++++ .../arm/dts/sdm845-samsung-starqltechn-u-boot.dtsi | 16 + arch/arm/dts/sdm845-samsung-starqltechn.dts | 624 +++ arch/arm/dts/sdm845-wcd9340.dtsi | 86 + arch/arm/dts/sdm845.dtsi | 5801 +++++++++++++++++++- arch/arm/dts/starqltechn-uboot.dtsi | 27 - arch/arm/dts/starqltechn.dts | 68 - arch/arm/lib/save_prev_bl_data.c | 5 + arch/arm/mach-snapdragon/Kconfig | 95 +- arch/arm/mach-snapdragon/Makefile | 8 +- arch/arm/mach-snapdragon/board.c | 304 + arch/arm/mach-snapdragon/include/mach/dram.h | 12 - arch/arm/mach-snapdragon/init_sdm845.c | 73 - arch/arm/mach-snapdragon/misc.c | 55 - arch/arm/mach-snapdragon/sysmap-apq8016.c | 31 - arch/arm/mach-snapdragon/sysmap-apq8096.c | 31 - arch/arm/mach-snapdragon/sysmap-qcs404.c | 43 - arch/arm/mach-snapdragon/sysmap-sdm845.c | 31 - board/qualcomm/dragonboard410c/Kconfig | 15 - board/qualcomm/dragonboard410c/Makefile | 3 +- .../dragonboard410c/configs/chainloaded.config | 7 + board/qualcomm/dragonboard410c/dragonboard410c.c | 109 +- .../qualcomm/dragonboard410c/misc.c | 51 +- .../mach => board/qualcomm/dragonboard410c}/misc.h | 1 + board/qualcomm/dragonboard820c/Kconfig | 15 - board/qualcomm/dragonboard820c/Makefile | 1 - board/qualcomm/dragonboard820c/dragonboard820c.c | 39 +- board/qualcomm/dragonboard820c/head.S | 33 - board/qualcomm/dragonboard820c/u-boot.lds | 111 - board/qualcomm/dragonboard845c/Kconfig | 12 - board/qualcomm/qcs404-evb/Kconfig | 15 - board/qualcomm/qcs404-evb/Makefile | 6 - board/qualcomm/qcs404-evb/qcs404-evb.c | 62 - configs/dragonboard410c_defconfig | 8 +- configs/dragonboard820c_defconfig | 8 +- configs/dragonboard845c_defconfig | 29 - configs/qcom_defconfig | 73 + configs/qcs404evb_defconfig | 55 - configs/starqltechn_defconfig | 41 - doc/board/qualcomm/board.rst | 119 + doc/board/qualcomm/debugging.rst | 61 + doc/board/qualcomm/index.rst | 4 +- doc/board/qualcomm/qcs404.rst | 79 - doc/board/qualcomm/sdm845.rst | 162 - doc/device-tree-bindings/mmc/msm_sdhci.txt | 25 - doc/device-tree-bindings/usb/ehci-msm.txt | 10 - drivers/clk/qcom/clock-apq8016.c | 9 +- drivers/clk/qcom/clock-apq8096.c | 7 +- drivers/gpio/qcom_pmic_gpio.c | 232 +- drivers/mmc/msm_sdhci.c | 69 +- drivers/phy/qcom/msm8916-usbh-phy.c | 4 +- drivers/pinctrl/qcom/pinctrl-apq8016.c | 2 +- drivers/serial/Kconfig | 8 + drivers/serial/serial_msm.c | 56 +- drivers/usb/dwc3/dwc3-generic.c | 12 + drivers/usb/host/ehci-msm.c | 24 +- include/configs/dragonboard845c.h | 20 - include/configs/qcom.h | 21 + include/configs/qcs404-evb.h | 20 - include/configs/sdm845.h | 26 - include/dt-bindings/arm/coresight-cti-dt.h | 37 + include/dt-bindings/clock/qcom,camcc-sdm845.h | 116 + include/dt-bindings/clock/qcom,dispcc-sdm845.h | 56 + include/dt-bindings/clock/qcom,gcc-msm8916.h | 179 + include/dt-bindings/clock/qcom,gcc-msm8996.h | 360 ++ include/dt-bindings/clock/qcom,gpucc-sdm845.h | 24 + include/dt-bindings/clock/qcom,lpass-sdm845.h | 15 + include/dt-bindings/clock/qcom,mmcc-msm8996.h | 295 + include/dt-bindings/clock/qcom,rpmcc.h | 174 + include/dt-bindings/clock/qcom,rpmh.h | 37 + include/dt-bindings/clock/qcom,turingcc-qcs404.h | 15 + include/dt-bindings/clock/qcom,videocc-sdm845.h | 35 + include/dt-bindings/dma/qcom-gpi.h | 11 + include/dt-bindings/firmware/qcom,scm.h | 18 + include/dt-bindings/iio/qcom,spmi-vadc.h | 300 + include/dt-bindings/interconnect/qcom,msm8916.h | 100 + .../dt-bindings/interconnect/qcom,msm8996-cbf.h | 12 + include/dt-bindings/interconnect/qcom,msm8996.h | 163 + include/dt-bindings/interconnect/qcom,osm-l3.h | 15 + include/dt-bindings/interconnect/qcom,sdm845.h | 150 + include/dt-bindings/phy/phy-qcom-qmp.h | 20 + include/dt-bindings/phy/phy-qcom-qusb2.h | 37 + include/dt-bindings/pinctrl/qcom,pmic-gpio.h | 164 + include/dt-bindings/pinctrl/qcom,pmic-mpp.h | 106 + include/dt-bindings/power/qcom-rpmpd.h | 412 ++ include/dt-bindings/qcom,q6asm.h | 26 + .../dt-bindings/regulator/qcom,rpmh-regulator.h | 36 + include/dt-bindings/reset/qcom,gcc-msm8916.h | 100 + include/dt-bindings/reset/qcom,sdm845-aoss.h | 17 + include/dt-bindings/reset/qcom,sdm845-pdc.h | 22 + include/dt-bindings/soc/qcom,apr.h | 28 + include/dt-bindings/soc/qcom,rpmh-rsc.h | 14 + include/dt-bindings/sound/apq8016-lpass.h | 9 + include/dt-bindings/sound/qcom,lpass.h | 46 + include/dt-bindings/sound/qcom,q6afe.h | 9 + include/dt-bindings/sound/qcom,q6asm.h | 26 + include/dt-bindings/sound/qcom,q6dsp-lpass-ports.h | 234 + include/dt-bindings/sound/qcom,wcd9335.h | 15 + include/init.h | 11 + 126 files changed, 23909 insertions(+), 2375 deletions(-)
base-commit: bcb4a9ddbd21a61b5b421ba374a785757bd28c80
// Caleb (they/them)
On 20/12/2023 13:07, Sumit Garg wrote:
Hi Caleb,
Hi Sumit,
== Upstream DT ==
I designed this so that we can just delete the imported stuff once the dt-rebasing series is merged. Importing a few files and deleting them later is not really a big deal, so please let's not block fixing Qualcomm support on this tangentially related series.
Thanks,
On Thu, 21 Dec 2023 at 21:08, Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Caleb,
Hi Sumit,
== Upstream DT ==
Fair enough, I think I can live with that for the time being. Let me give this series a spin on QCS404.
-Sumit
Thanks,
-- // Caleb (they/them)
Hi Caleb,
Hi Sumit,
== Upstream DT ==
Just to update here, this series doesn't boot on QCS404. Internally I am working with Caleb to fix issues seen. One of the major issues was to not map reserved memory ranges in U-Boot as mapping then leads to a hang on QCS404 (see [1] for details).
[1] https://github.com/u-boot/u-boot/commit/881338a0c6686bbcf043275714d43080b746...
-Sumit
Thanks,
Hi Caleb,
== Memory map ==
== DT loading ==
== defconfig ==
== Upstream DT ==
This series fails to boot (without any U-Boot console print) on db410c. I even added below pinctrl change but without any success:
diff --git a/drivers/pinctrl/qcom/pinctrl-apq8016.c b/drivers/pinctrl/qcom/pinctrl-apq8016.c index 8e698085d78..88518845952 100644 --- a/drivers/pinctrl/qcom/pinctrl-apq8016.c +++ b/drivers/pinctrl/qcom/pinctrl-apq8016.c @@ -42,7 +42,7 @@ static const char *apq8016_get_pin_name(struct udevice *dev, unsigned int selector) { if (selector < 122) { - snprintf(pin_name, MAX_PIN_NAME_LEN, "GPIO_%u", selector); + snprintf(pin_name, MAX_PIN_NAME_LEN, "gpio%u", selector); return pin_name; } else { return msm_pinctrl_pins[selector - 122];
db820c and qcs404 require a similar pinctrl change though.
-Sumit
Changes in v2:
Caleb Connolly (32): arm: init: export prev_bl_fdt_addr usb: dwc3-generic: support external vbus regulator mmc: msm_sdhci: use modern clock handling dt-bindings: drop msm_sdhci binding clk/qcom: use upstream compatible properties serial: msm: add debug UART serial: msm: fix clock handling gpio: qcom_pmic: 1-based GPIOs gpio: qcom_pmic: add a quirk to skip GPIO configuration gpio: qcom_pmic: add pinctrl driver board: dragonboard410c: add chainloaded config fragment board: dragonboard410c: upstream DT compat board: dragonboard410c: import board code from mach-snapdragon board: dragonboard820c: use LINUX_KERNEL_IMAGE_HEADER mach-snapdragon: generalise board support mach-snapdragon: dynamic load addresses mach-snapdragon: generate fdtfile automatically doc: board/qualcomm: document generic targets dt-bindings: import headers for SDM845 dts: sdm845: import supporting dtsi files dts: sdm845: replace with upstream DTS dt-bindings: import headers for MSM8916 dts: msm8916: import PMIC dtsi files dts: msm8916: replace with upstream DTS dt-bindings: import headers for MSM8996 dts: msm8996: import PMIC dtsi files dts: dragonboard820c: use correct bindings for clocks dts: msm8996: replace with upstream DTS dt-bindings: import headers for qcs404 dts: qcs404-evb: replace with upstream DT board: qcs404-evb: drop board code MAINTAINERS: Qualcomm: add some missing paths
On 05/01/2024 13:14, Sumit Garg wrote:
Hi Caleb,
Hi Sumit,
[snip]
Are you chainloading from aboot? Or flashing over it?
I have only been able to validate the chainloading method, following the steps in doc/board/qualcomm/board.rst and generating the config with
make dragonboard410c_defconfig chainloaded.config
do you get any output at all? Can you try enabling debug UART output as documented in doc/board/qualcomm/debugging.rst?
The pinctrl fix shouldn't be needed to boot to a shell.
Thanks,
-Sumit
Changes in v2:
Hi Caleb,
Hi Sumit,
[snip]
I am using the default mode where U-Boot acts as the first stage bootloader. I suppose it worked for you since LK enabled drivers which were just reused by U-Boot.
No output from U-Boot. Last prints from SBL1:
<snip> D - 299022 - SBL1, Delta S - Flash Throughput, 81000 KB/s (1537656 Bytes, 18940 us) S - DDR Frequency, 400 MHz
I did but it didn't help.
While at it, I noticed another pinctrl issue which should be fixed by following diff:
diff --git a/drivers/serial/serial_msm.c b/drivers/serial/serial_msm.c index 0148ddb54df..6fe7bdd1dca 100644 --- a/drivers/serial/serial_msm.c +++ b/drivers/serial/serial_msm.c @@ -204,7 +204,7 @@ static int msm_serial_probe(struct udevice *dev) if (ret) return ret;
- pinctrl_select_state(dev, "uart"); + pinctrl_select_state(dev, "default"); uart_dm_init(priv);
But this still didn't fix the boot problem. As you have the board in your hand, I would suggest you to debug to avoid this back and forth.
-Sumit
Thanks,
-Sumit
Changes in v2:
Hi Caleb,
Hi Sumit,
[snip]
+ Stephan, could you maybe give this a try at some point?
Right, although the lack of any output probably indicates that U-Boot code isn't getting run for some reason. Could you check if disabling LINUX_KERNEL_IMAGE_HEADER (remove the select in arch/arm/Kconfig) helps? It was *theorised* that this shouldn't cause any issues but not tested.
Oh yeah, you should also hardcode the memory layout in DTS, this got lost when moving to upstream DT and it's needed for the case where we don't have ABL/LK to fill it in for us.
Hmm, I doubt SBL turns off the UART clock, so the DEBUG_UART ought to work - but this has not been tested so there could be something missing. Maybe you can try calling msm_uart_clk_init() from _debug_uart_init().
pinctrl_select_state(dev, "default"); uart_dm_init(priv); return 0;
I don't have the board unfortunately, only remote access - hence I can only debug the chainloaded U-Boot and not "u-boot1st" (or however we call it :P). Sorry.
-Sumit
Thanks,
-Sumit
Changes in v2:
Hi Caleb,
Hi Sumit,
[snip]
- Stephan, could you maybe give this a try at some point?
So I did:
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5ed9cbf378f..61192fb4a43 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1077,8 +1077,6 @@ config ARCH_SNAPDRAGON select SPMI select BOARD_LATE_INIT select OF_BOARD - select SAVE_PREV_BL_FDT_ADDR - select LINUX_KERNEL_IMAGE_HEADER imply CMD_DM
config ARCH_SOCFPGA
But it didn't help.
I see you have still preserved arch/arm/dts/dragonboard410c.dts with memory layout. I switched to it via:
diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index a9a48c2212d..600d614643f 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8007fff0 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x0 -CONFIG_DEFAULT_DEVICE_TREE="apq8016-sbc" +CONFIG_DEFAULT_DEVICE_TREE="dragonboard410c" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 410C" CONFIG_SYS_LOAD_ADDR=0x80080000
But that didn't help it to boot, still no U-Boot console log.
The driver model isn't available for DEBUG_UART, so it can directly invoke msm_uart_clk_init().
I can help keep digging in but since this series overhauls db410c support I expected it to be at least tested.
-Sumit
-Sumit
Thanks,
-Sumit
Changes in v2:
On Tue, Jan 9, 2024 at 1:33 PM Caleb Connolly caleb.connolly@linaro.org wrote:
Hi Caleb,
Hi Sumit,
[snip]
If I recall correctly when I initially started working on the direct boot, SBL closes all the clocks and everything must be re-initialized.
-Sumit
Thanks,
-Sumit
Changes in v2:
participants (5)
Caleb Connolly
Neil Armstrong
Ramon Fried
Sumit Garg
