[U-Boot-Users] [PATCH] dbau1x00 corrections
* Patch by Thomas Lange Aug 10 2005 - Fix dbau1x00 boards broken by dbau1550 patch
PLL:s were not set for boards other than 1550. Flash CFI caused card to hang due to undefined CFG_FLASH_BANKS_LIST. Default boot is now bootp for cards other than 1550.
/Thomas
Index: board/dbau1x00/lowlevel_init.S =================================================================== RCS file: /cvsroot/u-boot/u-boot/board/dbau1x00/lowlevel_init.S,v retrieving revision 1.1 diff -p -u -r1.1 lowlevel_init.S --- board/dbau1x00/lowlevel_init.S 2 Apr 2005 23:52:28 -0000 1.1 +++ board/dbau1x00/lowlevel_init.S 10 Aug 2005 13:07:23 -0000 @@ -185,6 +185,8 @@ tlbloop: bne t0, t2, tlbloop nop
+#endif /* CONFIG_DBAU1550 */ + /* First setup pll:s to make serial work ok */ /* We have a 12 MHz crystal */ li t0, SYS_CPUPLL @@ -205,6 +207,7 @@ tlbloop: sw t1, 0(t0) /* aux pll */ sync
+#ifdef CONFIG_DBAU1550 /* Static memory controller */ /* RCE0 - can not change while fetching, do so from icache */ move t2, ra /* Store return address */ @@ -237,7 +240,7 @@ noCacheJump: sw t1, 0(t0) #else /* CONFIG_DBAU1550 */ li t0, MEM_STTIME0 - li t1, 0x00014C0F + li t1, 0x040181D7 sw t1, 0(t0)
/* RCE0 AMD 29LV640M MirrorBit Flash */ Index: include/configs/dbau1x00.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/include/configs/dbau1x00.h,v retrieving revision 1.4 diff -p -u -r1.4 dbau1x00.h --- include/configs/dbau1x00.h 9 Jan 2005 22:29:00 -0000 1.4 +++ include/configs/dbau1x00.h 10 Aug 2005 13:07:24 -0000 @@ -81,8 +81,7 @@ CFG_CMD_MII | CFG_CMD_RUN | CFG_CMD_BDI | CFG_CMD_BEDBUG | \ CFG_CMD_NFS | CFG_CMD_ELF | CFG_CMD_PCMCIA | CFG_CMD_I2C)) #else /* CONFIG_DBAU1550 */ -/* Boot from Compact flash partition 2 as default */ -#define CONFIG_BOOTCOMMAND "ide reset;disk 0x81000000 0:2;bootm" +#define CONFIG_BOOTCOMMAND "bootp;bootm"
#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_IDE | CFG_CMD_DHCP | CFG_CMD_ELF) & \ ~(CFG_CMD_ENV | CFG_CMD_FAT | CFG_CMD_FLASH | CFG_CMD_FPGA | \ @@ -133,8 +132,6 @@ #define PHYS_FLASH_1 0xb8000000 /* Flash Bank #1 */ #define PHYS_FLASH_2 0xbc000000 /* Flash Bank #2 */
-#define CFG_FLASH_BANKS_LIST {PHYS_FLASH_1, PHYS_FLASH_2} - #else /* CONFIG_DBAU1550 */
#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ @@ -145,6 +142,8 @@
+#define CFG_FLASH_BANKS_LIST {PHYS_FLASH_1, PHYS_FLASH_2} + #define CFG_FLASH_CFI 1 #define CFG_FLASH_CFI_DRIVER 1
In message 42FA0094.70701@corelatus.se you wrote:
- Patch by Thomas Lange Aug 10 2005
Previously applied. Ignored. Thanks.
Thomas Lange
