[PATCH 1/5] moveconfig: Correct operation of the 'imply' feature
This doesn't work anymore, since the Kconfig update. The script has no tests so we did not notice. Fix it.
tools/moveconfig.py | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 373b395fda4..8d059be039d 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1263,7 +1263,7 @@ def find_kconfig_rules(kconf, config, imply_config): sym = kconf.syms.get(imply_config) if sym: for sel, cond in (sym.selects + sym.implies): - if sel == config: + if sel.name == config: return sym return None
@@ -1291,7 +1291,8 @@ def check_imply_rule(kconf, config, imply_config): nodes = sym.nodes if len(nodes) != 1: return '%d locations' % len(nodes) - fname, linenum = nodes[0].filename, nodes[0].linern + node = nodes[0] + fname, linenum = node.filename, node.linenr cwd = os.getcwd() if cwd and fname.startswith(cwd): fname = fname[len(cwd) + 1:] @@ -1382,7 +1383,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, """ kconf = KconfigScanner().conf if check_kconfig else None if add_imply and add_imply != 'all': - add_imply = add_imply.split() + add_imply = add_imply.split(',')
# key is defconfig name, value is dict of (CONFIG_xxx, value) config_db = {} @@ -1414,7 +1415,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, else: # New defconfig defconfig = line
- # Work through each target config option in tern, independently + # Work through each target config option in turn, independently for config in config_list: defconfigs = defconfig_db.get(config) if not defconfigs:
Move this code out into a function so it can be used elsewhere.
tools/moveconfig.py | 78 ++++++++++++++++++++++++++++----------------- 1 file changed, 49 insertions(+), 29 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 8d059be039d..4ad892e2c0c 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1339,6 +1339,54 @@ IMPLY_FLAGS = { 'Allow Kconfig options outside arch/ and /board/ to imply'], };
+ +def read_database(): + """Read in the config database + + Returns: + tuple: + set of all config options seen (each a str) + set of all defconfigs seen (each a str) + dict of configs for each defconfig: + key: defconfig name, e.g. "MPC8548CDS_legacy_defconfig" + value: dict: + key: CONFIG option + value: Value of option + dict of defconfigs for each config: + key: CONFIG option + value: set of boards using that option + + """ + configs = {} + + # key is defconfig name, value is dict of (CONFIG_xxx, value) + config_db = {} + + # Set of all config options we have seen + all_configs = set() + + # Set of all defconfigs we have seen + all_defconfigs = set() + + defconfig_db = collections.defaultdict(set) + with open(CONFIG_DATABASE) as fd: + for line in fd.readlines(): + line = line.rstrip() + if not line: # Separator between defconfigs + config_db[defconfig] = configs + all_defconfigs.add(defconfig) + configs = {} + elif line[0] == ' ': # CONFIG line + config, value = line.strip().split('=', 1) + configs[config] = value + defconfig_db[config].add(defconfig) + all_configs.add(config) + else: # New defconfig + defconfig = line + + return all_configs, all_defconfigs, config_db, defconfig_db + + def do_imply_config(config_list, add_imply, imply_flags, skip_added, check_kconfig=True, find_superset=False): """Find CONFIG options which imply those in the list @@ -1385,35 +1433,7 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, if add_imply and add_imply != 'all': add_imply = add_imply.split(',')
- # key is defconfig name, value is dict of (CONFIG_xxx, value) - config_db = {} - - # Holds a dict containing the set of defconfigs that contain each config - # key is config, value is set of defconfigs using that config - defconfig_db = collections.defaultdict(set) - - # Set of all config options we have seen - all_configs = set() - - # Set of all defconfigs we have seen - all_defconfigs = set() - - # Read in the database - configs = {} - with open(CONFIG_DATABASE) as fd: - for line in fd.readlines(): - line = line.rstrip() - if not line: # Separator between defconfigs - config_db[defconfig] = configs - all_defconfigs.add(defconfig) - configs = {} - elif line[0] == ' ': # CONFIG line - config, value = line.strip().split('=', 1) - configs[config] = value - defconfig_db[config].add(defconfig) - all_configs.add(config) - else: # New defconfig - defconfig = line + all_configs, all_defconfigs, config_db, defconfig_db = read_database()
Put the options in sorted order by their short name so it is easier to find an option.
tools/moveconfig.py | 22 ++++++++++++---------- 1 file changed, 12 insertions(+), 10 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 4ad892e2c0c..369589727cc 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1591,26 +1591,28 @@ def main(): help='a file containing a list of defconfigs to move, ' "one per line (for example 'snow_defconfig') " "or '-' to read from stdin") - parser.add_option('-i', '--imply', action='store_true', default=False, - help='find options which imply others') - parser.add_option('-I', '--imply-flags', type='string', default='', - help="control the -i option ('help' for help") - parser.add_option('-n', '--dry-run', action='store_true', default=False, - help='perform a trial run (show log with no changes)') parser.add_option('-e', '--exit-on-error', action='store_true', default=False, help='exit immediately on any error') - parser.add_option('-s', '--force-sync', action='store_true', default=False, - help='force sync by savedefconfig') - parser.add_option('-S', '--spl', action='store_true', default=False, - help='parse config options defined for SPL build') parser.add_option('-H', '--headers-only', dest='cleanup_headers_only', action='store_true', default=False, help='only cleanup the headers') + parser.add_option('-i', '--imply', action='store_true', default=False, + help='find options which imply others') + parser.add_option('-I', '--imply-flags', type='string', default='', + help="control the -i option ('help' for help") parser.add_option('-j', '--jobs', type='int', default=cpu_count, help='the number of jobs to run simultaneously') + parser.add_option('-n', '--dry-run', action='store_true', default=False, + help='perform a trial run (show log with no changes)') parser.add_option('-r', '--git-ref', type='string', help='the git ref to clone for building the autoconf.mk') + parser.add_option('-s', '--force-sync', action='store_true', default=False, + help='force sync by savedefconfig') + parser.add_option('-S', '--spl', action='store_true', default=False, + help='parse config options defined for SPL build') + parser.add_option('-t', '--test', action='store_true', default=False, + help='run unit tests') parser.add_option('-y', '--yes', action='store_true', default=False, help="respond 'yes' to any prompts") parser.add_option('-v', '--verbose', action='store_true', default=False,
Add a -t option to run unit tests in this program. So far, there is none.
tools/moveconfig.py | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 369589727cc..71a7736ca63 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -14,6 +14,7 @@ import asteval import collections import copy import difflib +import doctest import filecmp import fnmatch import glob @@ -28,6 +29,7 @@ import sys import tempfile import threading import time +import unittest
from buildman import bsettings from buildman import kconfiglib @@ -1621,6 +1623,13 @@ def main():
(options, configs) = parser.parse_args()
+ if options.test: + sys.argv = [sys.argv[0]] + fail, count = doctest.testmod() + if fail: + return 1 + unittest.main() + if len(configs) == 0 and not any((options.force_sync, options.build_db, options.imply)): parser.print_usage()
It is useful to be able to find out which boards define a particular option, or combination of options. This is not as easy as grepping the defconfig files since many options are implied by others.
Add a -f option to the moveconfig tool to permit this. Update the documentation to cover this, including a better title for the doc page.
doc/develop/moveconfig.rst | 25 ++++++++++- tools/moveconfig.py | 86 ++++++++++++++++++++++++++++++++++++-- 2 files changed, 105 insertions(+), 6 deletions(-)
diff --git a/doc/develop/moveconfig.rst b/doc/develop/moveconfig.rst index dcd4d927e40..2f53ea52b71 100644 --- a/doc/develop/moveconfig.rst +++ b/doc/develop/moveconfig.rst @@ -1,7 +1,7 @@ .. SPDX-License-Identifier: GPL-2.0+
-moveconfig -========== +moveconfig - Migrating and querying CONFIG options +==================================================
Since Kconfig was introduced to U-Boot, we have worked on moving config options from headers to Kconfig (defconfig). @@ -129,6 +129,24 @@ To process CONFIG_CMD_FPGAD only for a subset of configs based on path match:: ./tools/moveconfig.py -Cy CONFIG_CMD_FPGAD -d -
+Finding boards with particular CONFIG combinations +-------------------------------------------------- + +You can use `moveconfig.py` to figure out which boards have a CONFIG enabled, or +which do not. To use it, first build a database:: + + ./tools/moveconfig.py -b + +Then you can run queries using the `-f` flag followed by a list of CONFIG terms. +Each term is CONFIG name, with or without a tilde (~) prefix. The tool searches +for boards which match the CONFIG name, or do not match if tilde is used. For +example, to find boards which enabled CONFIG_SCSI but not CONFIG_BLK:: + + tools/moveconfig.py -f SCSI ~BLK + 3 matches + pg_wcom_seli8_defconfig highbank_defconfig pg_wcom_expu1_defconfig + + Finding implied CONFIGs -----------------------
@@ -235,6 +253,9 @@ Available options Specify a file containing a list of defconfigs to move. The defconfig files can be given with shell-style wildcards. Use '-' to read from stdin.
+ -f, --find + Find boards with a given config combination + -n, --dry-run Perform a trial run that does not make any changes. It is useful to see what is going to happen before one actually runs it. diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 71a7736ca63..a86c07caa6e 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -1569,6 +1569,79 @@ def do_imply_config(config_list, add_imply, imply_flags, skip_added, add_imply_rule(config[CONFIG_LEN:], fname, linenum)
+def do_find_config(config_list): + """Find boards with a given combination of CONFIGs + + Params: + config_list: List of CONFIG options to check (each a string consisting + of a config option, with or without a CONFIG_ prefix. If an option + is preceded by a tilde (~) then it must be false, otherwise it must + be true) + """ + all_configs, all_defconfigs, config_db, defconfig_db = read_database() + + # Get the whitelist + with open('scripts/config_whitelist.txt') as inf: + adhoc_configs = set(inf.read().splitlines()) + + # Start with all defconfigs + out = all_defconfigs + + # Work through each config in turn + adhoc = [] + for item in config_list: + # Get the real config name and whether we want this config or not + cfg = item + want = True + if cfg[0] == '~': + want = False + cfg = cfg[1:] + + if cfg in adhoc_configs: + adhoc.append(cfg) + continue + + # Search everything that is still in the running. If it has a config + # that we want, or doesn't have one that we don't, add it into the + # running for the next stage + in_list = out + out = set() + for defc in in_list: + has_cfg = cfg in config_db[defc] + if has_cfg == want: + out.add(defc) + if adhoc: + print(f"Error: Not in Kconfig: %s" % ' '.join(adhoc)) + else: + print(f'{len(out)} matches') + print(' '.join(out)) + + +def prefix_config(cfg): + """Prefix a config with CONFIG_ if needed + + This handles ~ operator, which indicates that the CONFIG should be disabled + + >>> prefix_config('FRED') + 'CONFIG_FRED' + >>> prefix_config('CONFIG_FRED') + 'CONFIG_FRED' + >>> prefix_config('~FRED') + '~CONFIG_FRED' + >>> prefix_config('~CONFIG_FRED') + '~CONFIG_FRED' + >>> prefix_config('A123') + 'CONFIG_A123' + """ + op = '' + if cfg[0] == '~': + op = cfg[0] + cfg = cfg[1:] + if not cfg.startswith('CONFIG_'): + cfg = 'CONFIG_' + cfg + return op + cfg + + def main(): try: cpu_count = multiprocessing.cpu_count() @@ -1596,6 +1669,8 @@ def main(): parser.add_option('-e', '--exit-on-error', action='store_true', default=False, help='exit immediately on any error') + parser.add_option('-f', '--find', action='store_true', default=False, + help='Find boards with a given config combination') parser.add_option('-H', '--headers-only', dest='cleanup_headers_only', action='store_true', default=False, help='only cleanup the headers') @@ -1631,13 +1706,12 @@ def main(): unittest.main()
if len(configs) == 0 and not any((options.force_sync, options.build_db, - options.imply)): + options.imply, options.find)): parser.print_usage() sys.exit(1)
# prefix the option name with CONFIG_ if missing - configs = [ config if config.startswith('CONFIG_') else 'CONFIG_' + config - for config in configs ] + configs = [prefix_config(cfg) for cfg in configs]
check_top_directory()
@@ -1663,6 +1737,10 @@ def main(): options.skip_added) return
+ if options.find: + do_find_config(configs) + return + config_db = {} db_queue = queue.Queue() t = DatabaseThread(config_db, db_queue) @@ -1705,4 +1783,4 @@ def main(): fd.write('\n')
if __name__ == '__main__': - main() + sys.exit(main())
