[U-Boot] [PATCH] spl: Weed out CONFIG_SYS_TEXT_BASE usage
The SPL loaders assume that the CONFIG_SYS_TEXT_BASE memory location is available and can be corrupted by loading ie. uImage or fitImage headers there. Sometimes it could be beneficial to load the headers elsewhere, ie. if CONFIG_SYS_TEXT_BASE is not yet writable while we still want to parse the image headers in some local onchip memory to ie. extract firmware from that image.
Add the possibility to override the location where the headers get loaded by introducing new function, spl_get_load_buffer() which takes two arguments -- offset from the CONFIG_SYS_TEXT_BASE and size of the data that are to be loaded there -- and returns a valid buffer address or hangs the system. The default behavior is the same as before, add the offset to CONFIG_SYS_TEXT_BASE and return that address. User can override the weak spl_get_load_buffer() function though.
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- common/spl/spl.c | 5 +++++ common/spl/spl_ext.c | 3 +-- common/spl/spl_fat.c | 3 +-- common/spl/spl_fit.c | 6 +++--- common/spl/spl_mmc.c | 6 +++--- common/spl/spl_nand.c | 4 ++-- common/spl/spl_onenand.c | 3 +-- common/spl/spl_ram.c | 5 +++-- common/spl/spl_spi.c | 3 +-- common/spl/spl_ubi.c | 3 +-- include/spl.h | 9 +++++++++ 11 files changed, 30 insertions(+), 20 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index a09ada37d7..eb063189d4 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -122,6 +122,11 @@ __weak void spl_board_prepare_for_boot(void) /* Nothing to do! */ }
+__weak void *spl_get_load_buffer(int offset, size_t size) +{ + return (void *)(CONFIG_SYS_TEXT_BASE + offset); +} + void spl_set_header_raw_uboot(struct spl_image_info *spl_image) { ulong u_boot_pos = binman_sym(ulong, u_boot_any, pos); diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index fd30a61f9a..fe05223605 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -16,8 +16,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image, loff_t filelen, actlen; disk_partition_t part_info = {};
- header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); + header = spl_get_load_buffer(-sizeof(*header), sizeof(*header));
if (part_get_info(block_dev, partition, &part_info)) { printf("spl: no partition table found\n"); diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 87dd553210..58210f11fc 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -63,8 +63,7 @@ int spl_load_image_fat(struct spl_image_info *spl_image, if (err) goto end;
err = file_fat_read(filename, header, sizeof(struct image_header)); if (err <= 0) diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 2321ebb0dd..2821a3e268 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -357,7 +357,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, struct spl_image_info image_info; int node = -1; int images, ret; - int base_offset, align_len = ARCH_DMA_MINALIGN - 1; + int base_offset, hsize, align_len = ARCH_DMA_MINALIGN - 1; int index = 0;
/* @@ -386,8 +386,8 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, * For FIT with data embedded, data is loaded as part of FIT image. * For FIT with external data, data is not loaded in this step. */ - fit = (void *)((CONFIG_SYS_TEXT_BASE - size - info->bl_len - - align_len) & ~align_len); + hsize = (size + info->bl_len + align_len) & ~align_len; + fit = spl_get_load_buffer(-hsize, hsize); sectors = get_aligned_image_size(info, size, 0); count = info->read(info, sector, sectors, fit); debug("fit read sector %lx, sectors=%d, dst=%p, count=%lu\n", diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index db5be3dfa5..65c36d88f4 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -55,13 +55,13 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, { unsigned long count; struct image_header *header; + struct blk_desc *bd = mmc_get_blk_desc(mmc); int ret = 0;
- header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); + header = spl_get_load_buffer(-sizeof(*header), bd->blksz);
/* read image header to find the image size & load address */ - count = blk_dread(mmc_get_blk_desc(mmc), sector, 1, header); + count = blk_dread(bd, sector, 1, header); debug("hdr read sector %lx, count=%lu\n", sector, count); if (count == 0) { ret = -EIO; diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 9a52500614..a0fe263d3c 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -83,8 +83,8 @@ static int spl_nand_load_image(struct spl_image_info *spl_image, #endif nand_init();
- /*use CONFIG_SYS_TEXT_BASE as temporary storage area */ - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE); + header = spl_get_load_buffer(0, sizeof(*header)); + #ifdef CONFIG_SPL_OS_BOOT if (!spl_start_uboot()) { /* diff --git a/common/spl/spl_onenand.c b/common/spl/spl_onenand.c index d32333935a..ee30f328e6 100644 --- a/common/spl/spl_onenand.c +++ b/common/spl/spl_onenand.c @@ -21,8 +21,7 @@ static int spl_onenand_load_image(struct spl_image_info *spl_image,
debug("spl: onenand\n");
- /*use CONFIG_SYS_TEXT_BASE as temporary storage area */ - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE); + header = spl_get_load_buffer(0, CONFIG_SYS_ONENAND_PAGE_SIZE); /* Load u-boot */ onenand_spl_load_image(CONFIG_SYS_ONENAND_U_BOOT_OFFS, CONFIG_SYS_ONENAND_PAGE_SIZE, (void *)header); diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index e8701934b8..e777a1f700 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -63,8 +63,9 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, * No binman support or no information. For now, fix it * to the address pointed to by U-Boot. */ - u_boot_pos = CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header); + header = spl_get_load_buffer(-sizeof(*header), + sizeof(*header)); + } header = (struct image_header *)map_sysmem(u_boot_pos, 0);
diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index df46046729..d92f4f9c17 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -88,8 +88,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return -ENODEV; }
- /* use CONFIG_SYS_TEXT_BASE as temporary storage area */ - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE); + header = spl_get_load_buffer(-sizeof(*header), 0x40);
#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) payload_offs = fdtdec_get_config_int(gd->fdt_blob, diff --git a/common/spl/spl_ubi.c b/common/spl/spl_ubi.c index a7939e9030..67e5fadd7c 100644 --- a/common/spl/spl_ubi.c +++ b/common/spl/spl_ubi.c @@ -61,8 +61,7 @@ int spl_ubi_load_image(struct spl_image_info *spl_image, puts("Loading Linux failed, falling back to U-Boot.\n"); } #endif - header = (struct image_header *) - (CONFIG_SYS_TEXT_BASE - sizeof(struct image_header)); + header = spl_get_load_buffer(-sizeof(*header), sizeof(header)); volumes[0].vol_id = CONFIG_SPL_UBI_LOAD_MONITOR_ID; volumes[0].load_addr = (void *)header;
diff --git a/include/spl.h b/include/spl.h index 8454ea7ad4..e4ae397a48 100644 --- a/include/spl.h +++ b/include/spl.h @@ -296,4 +296,13 @@ void spl_invoke_atf(struct spl_image_info *spl_image); * can implement 'board_return_to_bootrom'. */ void board_return_to_bootrom(void); + +/** + * spl_get_load_buffer() - get buffer for loading partial image data + * + * Returns memory area which can be populated by partial image data, + * ie. uImage or fitImage header. + */ +void *spl_get_load_buffer(int offset, size_t size); + #endif
This adds a number of warnings like: w+(xilinx_zynqmp_zc1275_revA) common/spl/spl.c: In function 'spl_get_load_buffer': w+(xilinx_zynqmp_zc1275_revA) common/spl/spl.c:127:9: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] w+(xilinx_zynqmp_zc1275_revA) common/spl/spl_ram.c: In function 'spl_ram_load_image': w+(xilinx_zynqmp_zc1275_revA) common/spl/spl_ram.c:66:33: warning: overflow in implicit constant conversion [-Woverflow]
Well, yes, since that board didn't exist when I sent this patch over a month ago.
But I'd rather like some feedback on this patch itself.
Well, I was going to push it to master, but I can't because it introduces warnings now and that board has existed since April, FWIW.
