[PATCH 00/17] Enable UFS on DragonBoard845c
This patchset enables the UFS controller on DragonBoard845c board which houses Qualcomm SDM845 Snapdragon SoC.
In addition to enabling the UFS HC and UFS QMP PHY found on this SoC this patchset also contains: * Patches to add 'reset' controller support for SDM845 SoC. * Minor UFS core framework fixes. * Patches to sync u-boot UFS driver flow with Linux UFS driver. * Patches which enable RESET, UFS and SCSI config options for DragonBoard845c.
Also since the current UFS maintainer's email bounces, promote myself as the new UFS maintainer to help address this work-area -> review, test and fix UFS issues in u-boot framework.
Bhupesh Sharma (17): reset: qcom: Add support for SDM845 SoC reset table phy: qcom: Import QMP phy related header files from Linux dt-bindings: clock: Import SM6115 and SM8250 related clock header files from Linux phy: qcom: Add QMP UFS PHY driver ufs/ufs.h: Add definition of 'ufshcd_rmwl()' ufs: Clear UECPA once due to LINERESET has happened during LINK_STARTUP ufs: Add support for probing UFS controllers newer than UFSHCI_VERSION_21 ufs: Expose 'ufshcd_ops_dbg_register_dump' vops to allow dumping debug registers ufs: Sync possible UFS Quirks with Linux UFS driver ufs: Add missing memory barriers ufs: Fix debug message in 'ufs_start' ufs: Add Support for Qualcomm UFS HC driver arm: dts: qcom: sdm845: Add 'reset' node arm: dts: qcom: sdm845: Add UFS HC and PHY nodes configs/dragonboard845c_defconfig: Enable DM_RESET by default configs/dragonboard845c_defconfig: Enable UFS + SCSI related configs MAINTAINERS: Update UFS maintainer
MAINTAINERS | 2 +- arch/arm/dts/sdm845.dtsi | 68 ++ configs/dragonboard845c_defconfig | 11 + drivers/phy/qcom/Kconfig | 6 + drivers/phy/qcom/Makefile | 1 + drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h | 25 + drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h | 21 + drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h | 31 + drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h | 32 + drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h | 31 + drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h | 43 + drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h | 145 +++ drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h | 135 +++ .../phy/qcom/phy-qcom-qmp-qserdes-com-v3.h | 111 ++ .../phy/qcom/phy-qcom-qmp-qserdes-com-v4.h | 123 +++ drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h | 140 +++ drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h | 66 ++ .../qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h | 30 + .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h | 68 ++ .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h | 233 ++++ drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h | 205 ++++ drivers/phy/qcom/phy-qcom-qmp-ufs.c | 996 ++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp.h | 115 ++ drivers/reset/reset-qcom.c | 33 + drivers/ufs/Kconfig | 7 + drivers/ufs/Makefile | 1 + drivers/ufs/qcom-ufshcd.c | 880 ++++++++++++++++ drivers/ufs/ufs-qcom.h | 275 +++++ drivers/ufs/ufs.c | 93 +- drivers/ufs/ufs.h | 156 ++- include/dt-bindings/clock/qcom,gcc-sm6115.h | 201 ++++ include/dt-bindings/clock/qcom,gcc-sm8250.h | 271 +++++ 32 files changed, 4539 insertions(+), 16 deletions(-) create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-ufs.c create mode 100644 drivers/phy/qcom/phy-qcom-qmp.h create mode 100644 drivers/ufs/qcom-ufshcd.c create mode 100644 drivers/ufs/ufs-qcom.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm6115.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm8250.h
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/reset/reset-qcom.c | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/drivers/reset/reset-qcom.c b/drivers/reset/reset-qcom.c index 94315e76d5..0d37305e10 100644 --- a/drivers/reset/reset-qcom.c +++ b/drivers/reset/reset-qcom.c @@ -131,6 +131,38 @@ static const struct qcom_reset_map gcc_qcom_resets[] = { }; #endif
+#ifdef CONFIG_SDM845 +#include <dt-bindings/clock/qcom,gcc-sdm845.h> +static const struct qcom_reset_map gcc_qcom_resets[] = { + [GCC_MMSS_BCR] = { 0xb000 }, + [GCC_PCIE_0_BCR] = { 0x6b000 }, + [GCC_PCIE_1_BCR] = { 0x8d000 }, + [GCC_PCIE_PHY_BCR] = { 0x6f000 }, + [GCC_PDM_BCR] = { 0x33000 }, + [GCC_PRNG_BCR] = { 0x34000 }, + [GCC_QUPV3_WRAPPER_0_BCR] = { 0x17000 }, + [GCC_QUPV3_WRAPPER_1_BCR] = { 0x18000 }, + [GCC_QUSB2PHY_PRIM_BCR] = { 0x12000 }, + [GCC_QUSB2PHY_SEC_BCR] = { 0x12004 }, + [GCC_SDCC2_BCR] = { 0x14000 }, + [GCC_SDCC4_BCR] = { 0x16000 }, + [GCC_TSIF_BCR] = { 0x36000 }, + [GCC_UFS_CARD_BCR] = { 0x75000 }, + [GCC_UFS_PHY_BCR] = { 0x77000 }, + [GCC_USB30_PRIM_BCR] = { 0xf000 }, + [GCC_USB30_SEC_BCR] = { 0x10000 }, + [GCC_USB3_PHY_PRIM_BCR] = { 0x50000 }, + [GCC_USB3PHY_PHY_PRIM_BCR] = { 0x50004 }, + [GCC_USB3_DP_PHY_PRIM_BCR] = { 0x50008 }, + [GCC_USB3_PHY_SEC_BCR] = { 0x5000c }, + [GCC_USB3PHY_PHY_SEC_BCR] = { 0x50010 }, + [GCC_USB3_DP_PHY_SEC_BCR] = { 0x50014 }, + [GCC_USB_PHY_CFG_AHB2PHY_BCR] = { 0x6a000 }, + [GCC_PCIE_0_PHY_BCR] = { 0x6c01c }, + [GCC_PCIE_1_PHY_BCR] = { 0x8e01c }, +}; +#endif + static int qcom_reset_assert(struct reset_ctl *rst) { struct qcom_reset_priv *priv = dev_get_priv(rst->dev); @@ -171,6 +203,7 @@ static const struct reset_ops qcom_reset_ops = { static const struct udevice_id qcom_reset_ids[] = { { .compatible = "qcom,gcc-reset-ipq4019" }, { .compatible = "qcom,gcc-reset-qcs404" }, + { .compatible = "qcom,gcc-reset-sdm845" }, { } };
Import Qualcomm QMP phy related header files from Linux.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h | 25 ++ drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h | 21 ++ drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h | 31 +++ drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h | 32 +++ drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h | 31 +++ drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h | 43 ++++ drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h | 145 +++++++++++ drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h | 135 ++++++++++ .../phy/qcom/phy-qcom-qmp-qserdes-com-v3.h | 111 +++++++++ .../phy/qcom/phy-qcom-qmp-qserdes-com-v4.h | 123 +++++++++ drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h | 140 +++++++++++ drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h | 66 +++++ .../qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h | 30 +++ .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h | 68 +++++ .../phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h | 233 ++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h | 205 +++++++++++++++ 16 files changed, 1439 insertions(+) create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h create mode 100644 drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h
diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h new file mode 100644 index 0000000000..a0803a8783 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v2.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_UFS_V2_H_ +#define QCOM_PHY_QMP_PCS_UFS_V2_H_ + +#define QPHY_V2_PCS_UFS_PHY_START 0x000 +#define QPHY_V2_PCS_UFS_POWER_DOWN_CONTROL 0x004 + +#define QPHY_V2_PCS_UFS_TX_LARGE_AMP_DRV_LVL 0x034 +#define QPHY_V2_PCS_UFS_TX_LARGE_AMP_POST_EMP_LVL 0x038 +#define QPHY_V2_PCS_UFS_TX_SMALL_AMP_DRV_LVL 0x03c +#define QPHY_V2_PCS_UFS_TX_SMALL_AMP_POST_EMP_LVL 0x040 + +#define QPHY_V2_PCS_UFS_RX_MIN_STALL_NOCONFIG_TIME_CAP 0x0cc +#define QPHY_V2_PCS_UFS_RX_SYM_RESYNC_CTRL 0x13c +#define QPHY_V2_PCS_UFS_RX_MIN_HIBERN8_TIME 0x140 +#define QPHY_V2_PCS_UFS_RX_SIGDET_CTRL2 0x148 +#define QPHY_V2_PCS_UFS_RX_PWM_GEAR_BAND 0x154 + +#define QPHY_V2_PCS_UFS_READY_STATUS 0x168 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h new file mode 100644 index 0000000000..adea13c3a9 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v3.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_UFS_V3_H_ +#define QCOM_PHY_QMP_PCS_UFS_V3_H_ + +#define QPHY_V3_PCS_UFS_PHY_START 0x000 +#define QPHY_V3_PCS_UFS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V3_PCS_UFS_TX_LARGE_AMP_DRV_LVL 0x02c +#define QPHY_V3_PCS_UFS_TX_SMALL_AMP_DRV_LVL 0x034 +#define QPHY_V3_PCS_UFS_RX_SYM_RESYNC_CTRL 0x134 +#define QPHY_V3_PCS_UFS_RX_MIN_HIBERN8_TIME 0x138 +#define QPHY_V3_PCS_UFS_RX_SIGDET_CTRL1 0x13c +#define QPHY_V3_PCS_UFS_RX_SIGDET_CTRL2 0x140 +#define QPHY_V3_PCS_UFS_READY_STATUS 0x160 +#define QPHY_V3_PCS_UFS_TX_MID_TERM_CTRL1 0x1bc +#define QPHY_V3_PCS_UFS_MULTI_LANE_CTRL1 0x1c4 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h new file mode 100644 index 0000000000..a1c7d3d171 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v4.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_UFS_V4_H_ +#define QCOM_PHY_QMP_PCS_UFS_V4_H_ + +/* Only for QMP V4 PHY - UFS PCS registers */ +#define QPHY_V4_PCS_UFS_PHY_START 0x000 +#define QPHY_V4_PCS_UFS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V4_PCS_UFS_SW_RESET 0x008 +#define QPHY_V4_PCS_UFS_TIMER_20US_CORECLK_STEPS_MSB 0x00c +#define QPHY_V4_PCS_UFS_TIMER_20US_CORECLK_STEPS_LSB 0x010 +#define QPHY_V4_PCS_UFS_PLL_CNTL 0x02c +#define QPHY_V4_PCS_UFS_TX_LARGE_AMP_DRV_LVL 0x030 +#define QPHY_V4_PCS_UFS_TX_SMALL_AMP_DRV_LVL 0x038 +#define QPHY_V4_PCS_UFS_BIST_FIXED_PAT_CTRL 0x060 +#define QPHY_V4_PCS_UFS_TX_HSGEAR_CAPABILITY 0x074 +#define QPHY_V4_PCS_UFS_RX_HSGEAR_CAPABILITY 0x0b4 +#define QPHY_V4_PCS_UFS_DEBUG_BUS_CLKSEL 0x124 +#define QPHY_V4_PCS_UFS_LINECFG_DISABLE 0x148 +#define QPHY_V4_PCS_UFS_RX_MIN_HIBERN8_TIME 0x150 +#define QPHY_V4_PCS_UFS_RX_SIGDET_CTRL2 0x158 +#define QPHY_V4_PCS_UFS_TX_PWM_GEAR_BAND 0x160 +#define QPHY_V4_PCS_UFS_TX_HS_GEAR_BAND 0x168 +#define QPHY_V4_PCS_UFS_READY_STATUS 0x180 +#define QPHY_V4_PCS_UFS_TX_MID_TERM_CTRL1 0x1d8 +#define QPHY_V4_PCS_UFS_MULTI_LANE_CTRL1 0x1e0 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h new file mode 100644 index 0000000000..07959964fc --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v5.h @@ -0,0 +1,32 @@ +/* Only for QMP V5 PHY - UFS PCS registers */ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_UFS_V5_H_ +#define QCOM_PHY_QMP_PCS_UFS_V5_H_ + +/* Only for QMP V5 PHY - UFS PCS registers */ +#define QPHY_V5_PCS_UFS_PHY_START 0x000 +#define QPHY_V5_PCS_UFS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V5_PCS_UFS_SW_RESET 0x008 +#define QPHY_V5_PCS_UFS_TIMER_20US_CORECLK_STEPS_MSB 0x00c +#define QPHY_V5_PCS_UFS_TIMER_20US_CORECLK_STEPS_LSB 0x010 +#define QPHY_V5_PCS_UFS_PLL_CNTL 0x02c +#define QPHY_V5_PCS_UFS_TX_LARGE_AMP_DRV_LVL 0x030 +#define QPHY_V5_PCS_UFS_TX_SMALL_AMP_DRV_LVL 0x038 +#define QPHY_V5_PCS_UFS_BIST_FIXED_PAT_CTRL 0x060 +#define QPHY_V5_PCS_UFS_TX_HSGEAR_CAPABILITY 0x074 +#define QPHY_V5_PCS_UFS_RX_HSGEAR_CAPABILITY 0x0b4 +#define QPHY_V5_PCS_UFS_DEBUG_BUS_CLKSEL 0x124 +#define QPHY_V5_PCS_UFS_RX_MIN_HIBERN8_TIME 0x150 +#define QPHY_V5_PCS_UFS_RX_SIGDET_CTRL1 0x154 +#define QPHY_V5_PCS_UFS_RX_SIGDET_CTRL2 0x158 +#define QPHY_V5_PCS_UFS_TX_PWM_GEAR_BAND 0x160 +#define QPHY_V5_PCS_UFS_TX_HS_GEAR_BAND 0x168 +#define QPHY_V5_PCS_UFS_READY_STATUS 0x180 +#define QPHY_V5_PCS_UFS_TX_MID_TERM_CTRL1 0x1d8 +#define QPHY_V5_PCS_UFS_MULTI_LANE_CTRL1 0x1e0 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h new file mode 100644 index 0000000000..c23d5e41e2 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-ufs-v6.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2023, Linaro Limited + */ + +#ifndef QCOM_PHY_QMP_PCS_UFS_V6_H_ +#define QCOM_PHY_QMP_PCS_UFS_V6_H_ + +/* Only for QMP V6 PHY - UFS PCS registers */ +#define QPHY_V6_PCS_UFS_PHY_START 0x000 +#define QPHY_V6_PCS_UFS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V6_PCS_UFS_SW_RESET 0x008 +#define QPHY_V6_PCS_UFS_TIMER_20US_CORECLK_STEPS_MSB 0x00c +#define QPHY_V6_PCS_UFS_TIMER_20US_CORECLK_STEPS_LSB 0x010 +#define QPHY_V6_PCS_UFS_PLL_CNTL 0x02c +#define QPHY_V6_PCS_UFS_TX_LARGE_AMP_DRV_LVL 0x030 +#define QPHY_V6_PCS_UFS_TX_SMALL_AMP_DRV_LVL 0x038 +#define QPHY_V6_PCS_UFS_BIST_FIXED_PAT_CTRL 0x060 +#define QPHY_V6_PCS_UFS_TX_HSGEAR_CAPABILITY 0x074 +#define QPHY_V6_PCS_UFS_RX_HSGEAR_CAPABILITY 0x0bc +#define QPHY_V6_PCS_UFS_DEBUG_BUS_CLKSEL 0x158 +#define QPHY_V6_PCS_UFS_LINECFG_DISABLE 0x17c +#define QPHY_V6_PCS_UFS_RX_MIN_HIBERN8_TIME 0x184 +#define QPHY_V6_PCS_UFS_RX_SIGDET_CTRL2 0x18c +#define QPHY_V6_PCS_UFS_TX_PWM_GEAR_BAND 0x178 +#define QPHY_V6_PCS_UFS_TX_HS_GEAR_BAND 0x174 +#define QPHY_V6_PCS_UFS_READY_STATUS 0x1a8 +#define QPHY_V6_PCS_UFS_TX_MID_TERM_CTRL1 0x1f4 +#define QPHY_V6_PCS_UFS_MULTI_LANE_CTRL1 0x1fc + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h new file mode 100644 index 0000000000..bf36399d00 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-v2.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_V2_H_ +#define QCOM_PHY_QMP_PCS_V2_H_ + +/* Only for QMP V2 PHY - PCS registers */ +#define QPHY_V2_PCS_SW_RESET 0x000 +#define QPHY_V2_PCS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V2_PCS_START_CONTROL 0x008 +#define QPHY_V2_PCS_TXDEEMPH_M6DB_V0 0x024 +#define QPHY_V2_PCS_TXDEEMPH_M3P5DB_V0 0x028 +#define QPHY_V2_PCS_ENDPOINT_REFCLK_DRIVE 0x054 +#define QPHY_V2_PCS_RX_IDLE_DTCT_CNTRL 0x058 +#define QPHY_V2_PCS_POWER_STATE_CONFIG1 0x060 +#define QPHY_V2_PCS_POWER_STATE_CONFIG2 0x064 +#define QPHY_V2_PCS_POWER_STATE_CONFIG4 0x06c +#define QPHY_V2_PCS_LOCK_DETECT_CONFIG1 0x080 +#define QPHY_V2_PCS_LOCK_DETECT_CONFIG2 0x084 +#define QPHY_V2_PCS_LOCK_DETECT_CONFIG3 0x088 +#define QPHY_V2_PCS_PWRUP_RESET_DLY_TIME_AUXCLK 0x0a0 +#define QPHY_V2_PCS_LP_WAKEUP_DLY_TIME_AUXCLK 0x0a4 +#define QPHY_V2_PCS_PLL_LOCK_CHK_DLY_TIME 0x0a8 +#define QPHY_V2_PCS_FLL_CNTRL1 0x0c0 +#define QPHY_V2_PCS_FLL_CNTRL2 0x0c4 +#define QPHY_V2_PCS_FLL_CNT_VAL_L 0x0c8 +#define QPHY_V2_PCS_FLL_CNT_VAL_H_TOL 0x0cc +#define QPHY_V2_PCS_FLL_MAN_CODE 0x0d0 +#define QPHY_V2_PCS_AUTONOMOUS_MODE_CTRL 0x0d4 +#define QPHY_V2_PCS_LFPS_RXTERM_IRQ_CLEAR 0x0d8 +#define QPHY_V2_PCS_LFPS_RXTERM_IRQ_STATUS 0x178 +#define QPHY_V2_PCS_USB_PCS_STATUS 0x17c /* USB */ +#define QPHY_V2_PCS_PLL_LOCK_CHK_DLY_TIME_AUXCLK_LSB 0x1a8 +#define QPHY_V2_PCS_OSC_DTCT_ACTIONS 0x1ac +#define QPHY_V2_PCS_RX_SIGDET_LVL 0x1d8 +#define QPHY_V2_PCS_L1SS_WAKEUP_DLY_TIME_AUXCLK_LSB 0x1dc +#define QPHY_V2_PCS_L1SS_WAKEUP_DLY_TIME_AUXCLK_MSB 0x1e0 + +#define QPHY_V2_PCS_PCI_PCS_STATUS 0x174 /* PCI */ + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h new file mode 100644 index 0000000000..10dbbb0062 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-v3.h @@ -0,0 +1,145 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_V3_H_ +#define QCOM_PHY_QMP_PCS_V3_H_ + +/* Only for QMP V3 PHY - PCS registers */ +#define QPHY_V3_PCS_SW_RESET 0x000 +#define QPHY_V3_PCS_POWER_DOWN_CONTROL 0x004 +#define QPHY_V3_PCS_START_CONTROL 0x008 +#define QPHY_V3_PCS_TXMGN_V0 0x00c +#define QPHY_V3_PCS_TXMGN_V1 0x010 +#define QPHY_V3_PCS_TXMGN_V2 0x014 +#define QPHY_V3_PCS_TXMGN_V3 0x018 +#define QPHY_V3_PCS_TXMGN_V4 0x01c +#define QPHY_V3_PCS_TXMGN_LS 0x020 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_V0 0x024 +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_V0 0x028 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_V1 0x02c +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_V1 0x030 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_V2 0x034 +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_V2 0x038 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_V3 0x03c +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_V3 0x040 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_V4 0x044 +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_V4 0x048 +#define QPHY_V3_PCS_TXDEEMPH_M6DB_LS 0x04c +#define QPHY_V3_PCS_TXDEEMPH_M3P5DB_LS 0x050 +#define QPHY_V3_PCS_ENDPOINT_REFCLK_DRIVE 0x054 +#define QPHY_V3_PCS_RX_IDLE_DTCT_CNTRL 0x058 +#define QPHY_V3_PCS_RATE_SLEW_CNTRL 0x05c +#define QPHY_V3_PCS_POWER_STATE_CONFIG1 0x060 +#define QPHY_V3_PCS_POWER_STATE_CONFIG2 0x064 +#define QPHY_V3_PCS_POWER_STATE_CONFIG3 0x068 +#define QPHY_V3_PCS_POWER_STATE_CONFIG4 0x06c +#define QPHY_V3_PCS_RCVR_DTCT_DLY_P1U2_L 0x070 +#define QPHY_V3_PCS_RCVR_DTCT_DLY_P1U2_H 0x074 +#define QPHY_V3_PCS_RCVR_DTCT_DLY_U3_L 0x078 +#define QPHY_V3_PCS_RCVR_DTCT_DLY_U3_H 0x07c +#define QPHY_V3_PCS_LOCK_DETECT_CONFIG1 0x080 +#define QPHY_V3_PCS_LOCK_DETECT_CONFIG2 0x084 +#define QPHY_V3_PCS_LOCK_DETECT_CONFIG3 0x088 +#define QPHY_V3_PCS_TSYNC_RSYNC_TIME 0x08c +#define QPHY_V3_PCS_SIGDET_LOW_2_IDLE_TIME 0x090 +#define QPHY_V3_PCS_BEACON_2_IDLE_TIME_L 0x094 +#define QPHY_V3_PCS_BEACON_2_IDLE_TIME_H 0x098 +#define QPHY_V3_PCS_PWRUP_RESET_DLY_TIME_SYSCLK 0x09c +#define QPHY_V3_PCS_PWRUP_RESET_DLY_TIME_AUXCLK 0x0a0 +#define QPHY_V3_PCS_LP_WAKEUP_DLY_TIME_AUXCLK 0x0a4 +#define QPHY_V3_PCS_PLL_LOCK_CHK_DLY_TIME 0x0a8 +#define QPHY_V3_PCS_LFPS_DET_HIGH_COUNT_VAL 0x0ac +#define QPHY_V3_PCS_LFPS_TX_ECSTART_EQTLOCK 0x0b0 +#define QPHY_V3_PCS_LFPS_TX_END_CNT_P2U3_START 0x0b4 +#define QPHY_V3_PCS_RXEQTRAINING_WAIT_TIME 0x0b8 +#define QPHY_V3_PCS_RXEQTRAINING_RUN_TIME 0x0bc +#define QPHY_V3_PCS_TXONESZEROS_RUN_LENGTH 0x0c0 +#define QPHY_V3_PCS_FLL_CNTRL1 0x0c4 +#define QPHY_V3_PCS_FLL_CNTRL2 0x0c8 +#define QPHY_V3_PCS_FLL_CNT_VAL_L 0x0cc +#define QPHY_V3_PCS_FLL_CNT_VAL_H_TOL 0x0d0 +#define QPHY_V3_PCS_FLL_MAN_CODE 0x0d4 +#define QPHY_V3_PCS_AUTONOMOUS_MODE_CTRL 0x0d8 +#define QPHY_V3_PCS_LFPS_RXTERM_IRQ_CLEAR 0x0dc +#define QPHY_V3_PCS_ARCVR_DTCT_EN_PERIOD 0x0e0 +#define QPHY_V3_PCS_ARCVR_DTCT_CM_DLY 0x0e4 +#define QPHY_V3_PCS_ALFPS_DEGLITCH_VAL 0x0e8 +#define QPHY_V3_PCS_INSIG_SW_CTRL1 0x0ec +#define QPHY_V3_PCS_INSIG_SW_CTRL2 0x0f0 +#define QPHY_V3_PCS_INSIG_SW_CTRL3 0x0f4 +#define QPHY_V3_PCS_INSIG_MX_CTRL1 0x0f8 +#define QPHY_V3_PCS_INSIG_MX_CTRL2 0x0fc +#define QPHY_V3_PCS_INSIG_MX_CTRL3 0x100 +#define QPHY_V3_PCS_OUTSIG_SW_CTRL1 0x104 +#define QPHY_V3_PCS_OUTSIG_MX_CTRL1 0x108 +#define QPHY_V3_PCS_CLK_DEBUG_BYPASS_CTRL 0x10c +#define QPHY_V3_PCS_TEST_CONTROL 0x110 +#define QPHY_V3_PCS_TEST_CONTROL2 0x114 +#define QPHY_V3_PCS_TEST_CONTROL3 0x118 +#define QPHY_V3_PCS_TEST_CONTROL4 0x11c +#define QPHY_V3_PCS_TEST_CONTROL5 0x120 +#define QPHY_V3_PCS_TEST_CONTROL6 0x124 +#define QPHY_V3_PCS_TEST_CONTROL7 0x128 +#define QPHY_V3_PCS_COM_RESET_CONTROL 0x12c +#define QPHY_V3_PCS_BIST_CTRL 0x130 +#define QPHY_V3_PCS_PRBS_POLY0 0x134 +#define QPHY_V3_PCS_PRBS_POLY1 0x138 +#define QPHY_V3_PCS_PRBS_SEED0 0x13c +#define QPHY_V3_PCS_PRBS_SEED1 0x140 +#define QPHY_V3_PCS_FIXED_PAT_CTRL 0x144 +#define QPHY_V3_PCS_FIXED_PAT0 0x148 +#define QPHY_V3_PCS_FIXED_PAT1 0x14c +#define QPHY_V3_PCS_FIXED_PAT2 0x150 +#define QPHY_V3_PCS_FIXED_PAT3 0x154 +#define QPHY_V3_PCS_COM_CLK_SWITCH_CTRL 0x158 +#define QPHY_V3_PCS_ELECIDLE_DLY_SEL 0x15c +#define QPHY_V3_PCS_SPARE1 0x160 +#define QPHY_V3_PCS_BIST_CHK_ERR_CNT_L_STATUS 0x164 +#define QPHY_V3_PCS_BIST_CHK_ERR_CNT_H_STATUS 0x168 +#define QPHY_V3_PCS_BIST_CHK_STATUS 0x16c +#define QPHY_V3_PCS_LFPS_RXTERM_IRQ_SOURCE_STATUS 0x170 +#define QPHY_V3_PCS_PCS_STATUS 0x174 +#define QPHY_V3_PCS_PCS_STATUS2 0x178 +#define QPHY_V3_PCS_PCS_STATUS3 0x17c +#define QPHY_V3_PCS_COM_RESET_STATUS 0x180 +#define QPHY_V3_PCS_OSC_DTCT_STATUS 0x184 +#define QPHY_V3_PCS_REVISION_ID0 0x188 +#define QPHY_V3_PCS_REVISION_ID1 0x18c +#define QPHY_V3_PCS_REVISION_ID2 0x190 +#define QPHY_V3_PCS_REVISION_ID3 0x194 +#define QPHY_V3_PCS_DEBUG_BUS_0_STATUS 0x198 +#define QPHY_V3_PCS_DEBUG_BUS_1_STATUS 0x19c +#define QPHY_V3_PCS_DEBUG_BUS_2_STATUS 0x1a0 +#define QPHY_V3_PCS_DEBUG_BUS_3_STATUS 0x1a4 +#define QPHY_V3_PCS_LP_WAKEUP_DLY_TIME_AUXCLK_MSB 0x1a8 +#define QPHY_V3_PCS_OSC_DTCT_ACTIONS 0x1ac +#define QPHY_V3_PCS_SIGDET_CNTRL 0x1b0 +#define QPHY_V3_PCS_IDAC_CAL_CNTRL 0x1b4 +#define QPHY_V3_PCS_CMN_ACK_OUT_SEL 0x1b8 +#define QPHY_V3_PCS_PLL_LOCK_CHK_DLY_TIME_SYSCLK 0x1bc +#define QPHY_V3_PCS_AUTONOMOUS_MODE_STATUS 0x1c0 +#define QPHY_V3_PCS_ENDPOINT_REFCLK_CNTRL 0x1c4 +#define QPHY_V3_PCS_EPCLK_PRE_PLL_LOCK_DLY_SYSCLK 0x1c8 +#define QPHY_V3_PCS_EPCLK_PRE_PLL_LOCK_DLY_AUXCLK 0x1cc +#define QPHY_V3_PCS_EPCLK_DLY_COUNT_VAL_L 0x1d0 +#define QPHY_V3_PCS_EPCLK_DLY_COUNT_VAL_H 0x1d4 +#define QPHY_V3_PCS_RX_SIGDET_LVL 0x1d8 +#define QPHY_V3_PCS_L1SS_WAKEUP_DLY_TIME_AUXCLK_LSB 0x1dc +#define QPHY_V3_PCS_L1SS_WAKEUP_DLY_TIME_AUXCLK_MSB 0x1e0 +#define QPHY_V3_PCS_AUTONOMOUS_MODE_CTRL2 0x1e4 +#define QPHY_V3_PCS_RXTERMINATION_DLY_SEL 0x1e8 +#define QPHY_V3_PCS_LFPS_PER_TIMER_VAL 0x1ec +#define QPHY_V3_PCS_SIGDET_STARTUP_TIMER_VAL 0x1f0 +#define QPHY_V3_PCS_LOCK_DETECT_CONFIG4 0x1f4 +#define QPHY_V3_PCS_RX_SIGDET_DTCT_CNTRL 0x1f8 +#define QPHY_V3_PCS_PCS_STATUS4 0x1fc +#define QPHY_V3_PCS_PCS_STATUS4_CLEAR 0x200 +#define QPHY_V3_PCS_DEC_ERROR_COUNT_STATUS 0x204 +#define QPHY_V3_PCS_COMMA_POS_STATUS 0x208 +#define QPHY_V3_PCS_REFGEN_REQ_CONFIG1 0x20c +#define QPHY_V3_PCS_REFGEN_REQ_CONFIG2 0x210 +#define QPHY_V3_PCS_REFGEN_REQ_CONFIG3 0x214 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h b/drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h new file mode 100644 index 0000000000..a2c1eba2b6 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-pcs-v4.h @@ -0,0 +1,135 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_PCS_V4_H_ +#define QCOM_PHY_QMP_PCS_V4_H_ + +/* Only for QMP V4 PHY - USB/PCIe PCS registers */ +#define QPHY_V4_PCS_SW_RESET 0x000 +#define QPHY_V4_PCS_REVISION_ID0 0x004 +#define QPHY_V4_PCS_REVISION_ID1 0x008 +#define QPHY_V4_PCS_REVISION_ID2 0x00c +#define QPHY_V4_PCS_REVISION_ID3 0x010 +#define QPHY_V4_PCS_PCS_STATUS1 0x014 +#define QPHY_V4_PCS_PCS_STATUS2 0x018 +#define QPHY_V4_PCS_PCS_STATUS3 0x01c +#define QPHY_V4_PCS_PCS_STATUS4 0x020 +#define QPHY_V4_PCS_PCS_STATUS5 0x024 +#define QPHY_V4_PCS_PCS_STATUS6 0x028 +#define QPHY_V4_PCS_PCS_STATUS7 0x02c +#define QPHY_V4_PCS_DEBUG_BUS_0_STATUS 0x030 +#define QPHY_V4_PCS_DEBUG_BUS_1_STATUS 0x034 +#define QPHY_V4_PCS_DEBUG_BUS_2_STATUS 0x038 +#define QPHY_V4_PCS_DEBUG_BUS_3_STATUS 0x03c +#define QPHY_V4_PCS_POWER_DOWN_CONTROL 0x040 +#define QPHY_V4_PCS_START_CONTROL 0x044 +#define QPHY_V4_PCS_INSIG_SW_CTRL1 0x048 +#define QPHY_V4_PCS_INSIG_SW_CTRL2 0x04c +#define QPHY_V4_PCS_INSIG_SW_CTRL3 0x050 +#define QPHY_V4_PCS_INSIG_SW_CTRL4 0x054 +#define QPHY_V4_PCS_INSIG_SW_CTRL5 0x058 +#define QPHY_V4_PCS_INSIG_SW_CTRL6 0x05c +#define QPHY_V4_PCS_INSIG_SW_CTRL7 0x060 +#define QPHY_V4_PCS_INSIG_SW_CTRL8 0x064 +#define QPHY_V4_PCS_INSIG_MX_CTRL1 0x068 +#define QPHY_V4_PCS_INSIG_MX_CTRL2 0x06c +#define QPHY_V4_PCS_INSIG_MX_CTRL3 0x070 +#define QPHY_V4_PCS_INSIG_MX_CTRL4 0x074 +#define QPHY_V4_PCS_INSIG_MX_CTRL5 0x078 +#define QPHY_V4_PCS_INSIG_MX_CTRL7 0x07c +#define QPHY_V4_PCS_INSIG_MX_CTRL8 0x080 +#define QPHY_V4_PCS_OUTSIG_SW_CTRL1 0x084 +#define QPHY_V4_PCS_OUTSIG_MX_CTRL1 0x088 +#define QPHY_V4_PCS_CLAMP_ENABLE 0x08c +#define QPHY_V4_PCS_POWER_STATE_CONFIG1 0x090 +#define QPHY_V4_PCS_POWER_STATE_CONFIG2 0x094 +#define QPHY_V4_PCS_FLL_CNTRL1 0x098 +#define QPHY_V4_PCS_FLL_CNTRL2 0x09c +#define QPHY_V4_PCS_FLL_CNT_VAL_L 0x0a0 +#define QPHY_V4_PCS_FLL_CNT_VAL_H_TOL 0x0a4 +#define QPHY_V4_PCS_FLL_MAN_CODE 0x0a8 +#define QPHY_V4_PCS_TEST_CONTROL1 0x0ac +#define QPHY_V4_PCS_TEST_CONTROL2 0x0b0 +#define QPHY_V4_PCS_TEST_CONTROL3 0x0b4 +#define QPHY_V4_PCS_TEST_CONTROL4 0x0b8 +#define QPHY_V4_PCS_TEST_CONTROL5 0x0bc +#define QPHY_V4_PCS_TEST_CONTROL6 0x0c0 +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG1 0x0c4 +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG2 0x0c8 +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG3 0x0cc +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG4 0x0d0 +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG5 0x0d4 +#define QPHY_V4_PCS_LOCK_DETECT_CONFIG6 0x0d8 +#define QPHY_V4_PCS_REFGEN_REQ_CONFIG1 0x0dc +#define QPHY_V4_PCS_REFGEN_REQ_CONFIG2 0x0e0 +#define QPHY_V4_PCS_REFGEN_REQ_CONFIG3 0x0e4 +#define QPHY_V4_PCS_BIST_CTRL 0x0e8 +#define QPHY_V4_PCS_PRBS_POLY0 0x0ec +#define QPHY_V4_PCS_PRBS_POLY1 0x0f0 +#define QPHY_V4_PCS_FIXED_PAT0 0x0f4 +#define QPHY_V4_PCS_FIXED_PAT1 0x0f8 +#define QPHY_V4_PCS_FIXED_PAT2 0x0fc +#define QPHY_V4_PCS_FIXED_PAT3 0x100 +#define QPHY_V4_PCS_FIXED_PAT4 0x104 +#define QPHY_V4_PCS_FIXED_PAT5 0x108 +#define QPHY_V4_PCS_FIXED_PAT6 0x10c +#define QPHY_V4_PCS_FIXED_PAT7 0x110 +#define QPHY_V4_PCS_FIXED_PAT8 0x114 +#define QPHY_V4_PCS_FIXED_PAT9 0x118 +#define QPHY_V4_PCS_FIXED_PAT10 0x11c +#define QPHY_V4_PCS_FIXED_PAT11 0x120 +#define QPHY_V4_PCS_FIXED_PAT12 0x124 +#define QPHY_V4_PCS_FIXED_PAT13 0x128 +#define QPHY_V4_PCS_FIXED_PAT14 0x12c +#define QPHY_V4_PCS_FIXED_PAT15 0x130 +#define QPHY_V4_PCS_TXMGN_CONFIG 0x134 +#define QPHY_V4_PCS_G12S1_TXMGN_V0 0x138 +#define QPHY_V4_PCS_G12S1_TXMGN_V1 0x13c +#define QPHY_V4_PCS_G12S1_TXMGN_V2 0x140 +#define QPHY_V4_PCS_G12S1_TXMGN_V3 0x144 +#define QPHY_V4_PCS_G12S1_TXMGN_V4 0x148 +#define QPHY_V4_PCS_G12S1_TXMGN_V0_RS 0x14c +#define QPHY_V4_PCS_G12S1_TXMGN_V1_RS 0x150 +#define QPHY_V4_PCS_G12S1_TXMGN_V2_RS 0x154 +#define QPHY_V4_PCS_G12S1_TXMGN_V3_RS 0x158 +#define QPHY_V4_PCS_G12S1_TXMGN_V4_RS 0x15c +#define QPHY_V4_PCS_G3S2_TXMGN_MAIN 0x160 +#define QPHY_V4_PCS_G3S2_TXMGN_MAIN_RS 0x164 +#define QPHY_V4_PCS_G12S1_TXDEEMPH_M6DB 0x168 +#define QPHY_V4_PCS_G12S1_TXDEEMPH_M3P5DB 0x16c +#define QPHY_V4_PCS_G3S2_PRE_GAIN 0x170 +#define QPHY_V4_PCS_G3S2_POST_GAIN 0x174 +#define QPHY_V4_PCS_G3S2_PRE_POST_OFFSET 0x178 +#define QPHY_V4_PCS_G3S2_PRE_GAIN_RS 0x17c +#define QPHY_V4_PCS_G3S2_POST_GAIN_RS 0x180 +#define QPHY_V4_PCS_G3S2_PRE_POST_OFFSET_RS 0x184 +#define QPHY_V4_PCS_RX_SIGDET_LVL 0x188 +#define QPHY_V4_PCS_RX_SIGDET_DTCT_CNTRL 0x18c +#define QPHY_V4_PCS_RCVR_DTCT_DLY_P1U2_L 0x190 +#define QPHY_V4_PCS_RCVR_DTCT_DLY_P1U2_H 0x194 +#define QPHY_V4_PCS_RATE_SLEW_CNTRL1 0x198 +#define QPHY_V4_PCS_RATE_SLEW_CNTRL2 0x19c +#define QPHY_V4_PCS_PWRUP_RESET_DLY_TIME_AUXCLK 0x1a0 +#define QPHY_V4_PCS_P2U3_WAKEUP_DLY_TIME_AUXCLK_L 0x1a4 +#define QPHY_V4_PCS_P2U3_WAKEUP_DLY_TIME_AUXCLK_H 0x1a8 +#define QPHY_V4_PCS_TSYNC_RSYNC_TIME 0x1ac +#define QPHY_V4_PCS_CDR_RESET_TIME 0x1b0 +#define QPHY_V4_PCS_TSYNC_DLY_TIME 0x1b4 +#define QPHY_V4_PCS_ELECIDLE_DLY_SEL 0x1b8 +#define QPHY_V4_PCS_CMN_ACK_OUT_SEL 0x1bc +#define QPHY_V4_PCS_ALIGN_DETECT_CONFIG1 0x1c0 +#define QPHY_V4_PCS_ALIGN_DETECT_CONFIG2 0x1c4 +#define QPHY_V4_PCS_ALIGN_DETECT_CONFIG3 0x1c8 +#define QPHY_V4_PCS_ALIGN_DETECT_CONFIG4 0x1cc +#define QPHY_V4_PCS_PCS_TX_RX_CONFIG 0x1d0 +#define QPHY_V4_PCS_RX_IDLE_DTCT_CNTRL 0x1d4 +#define QPHY_V4_PCS_RX_DCC_CAL_CONFIG 0x1d8 +#define QPHY_V4_PCS_EQ_CONFIG1 0x1dc +#define QPHY_V4_PCS_EQ_CONFIG2 0x1e0 +#define QPHY_V4_PCS_EQ_CONFIG3 0x1e4 +#define QPHY_V4_PCS_EQ_CONFIG4 0x1e8 +#define QPHY_V4_PCS_EQ_CONFIG5 0x1ec + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v3.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v3.h new file mode 100644 index 0000000000..c0bd54e0e7 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v3.h @@ -0,0 +1,111 @@ + +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_COM_V3_H_ +#define QCOM_PHY_QMP_QSERDES_COM_V3_H_ + +/* Only for QMP V3 PHY - QSERDES COM registers */ +#define QSERDES_V3_COM_ATB_SEL1 0x000 +#define QSERDES_V3_COM_ATB_SEL2 0x004 +#define QSERDES_V3_COM_FREQ_UPDATE 0x008 +#define QSERDES_V3_COM_BG_TIMER 0x00c +#define QSERDES_V3_COM_SSC_EN_CENTER 0x010 +#define QSERDES_V3_COM_SSC_ADJ_PER1 0x014 +#define QSERDES_V3_COM_SSC_ADJ_PER2 0x018 +#define QSERDES_V3_COM_SSC_PER1 0x01c +#define QSERDES_V3_COM_SSC_PER2 0x020 +#define QSERDES_V3_COM_SSC_STEP_SIZE1 0x024 +#define QSERDES_V3_COM_SSC_STEP_SIZE2 0x028 +#define QSERDES_V3_COM_POST_DIV 0x02c +#define QSERDES_V3_COM_POST_DIV_MUX 0x030 +#define QSERDES_V3_COM_BIAS_EN_CLKBUFLR_EN 0x034 +#define QSERDES_V3_COM_CLK_ENABLE1 0x038 +#define QSERDES_V3_COM_SYS_CLK_CTRL 0x03c +#define QSERDES_V3_COM_SYSCLK_BUF_ENABLE 0x040 +#define QSERDES_V3_COM_PLL_EN 0x044 +#define QSERDES_V3_COM_PLL_IVCO 0x048 +#define QSERDES_V3_COM_CMN_IETRIM 0x04c +#define QSERDES_V3_COM_CMN_IPTRIM 0x050 +#define QSERDES_V3_COM_EP_CLOCK_DETECT_CTR 0x054 +#define QSERDES_V3_COM_SYSCLK_DET_COMP_STATUS 0x058 +#define QSERDES_V3_COM_CLK_EP_DIV 0x05c +#define QSERDES_V3_COM_CP_CTRL_MODE0 0x060 +#define QSERDES_V3_COM_CP_CTRL_MODE1 0x064 +#define QSERDES_V3_COM_PLL_RCTRL_MODE0 0x068 +#define QSERDES_V3_COM_PLL_RCTRL_MODE1 0x06c +#define QSERDES_V3_COM_PLL_CCTRL_MODE0 0x070 +#define QSERDES_V3_COM_PLL_CCTRL_MODE1 0x074 +#define QSERDES_V3_COM_PLL_CNTRL 0x078 +#define QSERDES_V3_COM_BIAS_EN_CTRL_BY_PSM 0x07c +#define QSERDES_V3_COM_SYSCLK_EN_SEL 0x080 +#define QSERDES_V3_COM_CML_SYSCLK_SEL 0x084 +#define QSERDES_V3_COM_RESETSM_CNTRL 0x088 +#define QSERDES_V3_COM_RESETSM_CNTRL2 0x08c +#define QSERDES_V3_COM_LOCK_CMP_EN 0x090 +#define QSERDES_V3_COM_LOCK_CMP_CFG 0x094 +#define QSERDES_V3_COM_LOCK_CMP1_MODE0 0x098 +#define QSERDES_V3_COM_LOCK_CMP2_MODE0 0x09c +#define QSERDES_V3_COM_LOCK_CMP3_MODE0 0x0a0 +#define QSERDES_V3_COM_LOCK_CMP1_MODE1 0x0a4 +#define QSERDES_V3_COM_LOCK_CMP2_MODE1 0x0a8 +#define QSERDES_V3_COM_LOCK_CMP3_MODE1 0x0ac +#define QSERDES_V3_COM_DEC_START_MODE0 0x0b0 +#define QSERDES_V3_COM_DEC_START_MODE1 0x0b4 +#define QSERDES_V3_COM_DIV_FRAC_START1_MODE0 0x0b8 +#define QSERDES_V3_COM_DIV_FRAC_START2_MODE0 0x0bc +#define QSERDES_V3_COM_DIV_FRAC_START3_MODE0 0x0c0 +#define QSERDES_V3_COM_DIV_FRAC_START1_MODE1 0x0c4 +#define QSERDES_V3_COM_DIV_FRAC_START2_MODE1 0x0c8 +#define QSERDES_V3_COM_DIV_FRAC_START3_MODE1 0x0cc +#define QSERDES_V3_COM_INTEGLOOP_INITVAL 0x0d0 +#define QSERDES_V3_COM_INTEGLOOP_EN 0x0d4 +#define QSERDES_V3_COM_INTEGLOOP_GAIN0_MODE0 0x0d8 +#define QSERDES_V3_COM_INTEGLOOP_GAIN1_MODE0 0x0dc +#define QSERDES_V3_COM_INTEGLOOP_GAIN0_MODE1 0x0e0 +#define QSERDES_V3_COM_INTEGLOOP_GAIN1_MODE1 0x0e4 +#define QSERDES_V3_COM_VCOCAL_DEADMAN_CTRL 0x0e8 +#define QSERDES_V3_COM_VCO_TUNE_CTRL 0x0ec +#define QSERDES_V3_COM_VCO_TUNE_MAP 0x0f0 +#define QSERDES_V3_COM_VCO_TUNE1_MODE0 0x0f4 +#define QSERDES_V3_COM_VCO_TUNE2_MODE0 0x0f8 +#define QSERDES_V3_COM_VCO_TUNE1_MODE1 0x0fc +#define QSERDES_V3_COM_VCO_TUNE2_MODE1 0x100 +#define QSERDES_V3_COM_VCO_TUNE_INITVAL1 0x104 +#define QSERDES_V3_COM_VCO_TUNE_INITVAL2 0x108 +#define QSERDES_V3_COM_VCO_TUNE_MINVAL1 0x10c +#define QSERDES_V3_COM_VCO_TUNE_MINVAL2 0x110 +#define QSERDES_V3_COM_VCO_TUNE_MAXVAL1 0x114 +#define QSERDES_V3_COM_VCO_TUNE_MAXVAL2 0x118 +#define QSERDES_V3_COM_VCO_TUNE_TIMER1 0x11c +#define QSERDES_V3_COM_VCO_TUNE_TIMER2 0x120 +#define QSERDES_V3_COM_CMN_STATUS 0x124 +#define QSERDES_V3_COM_RESET_SM_STATUS 0x128 +#define QSERDES_V3_COM_RESTRIM_CODE_STATUS 0x12c +#define QSERDES_V3_COM_PLLCAL_CODE1_STATUS 0x130 +#define QSERDES_V3_COM_PLLCAL_CODE2_STATUS 0x134 +#define QSERDES_V3_COM_CLK_SELECT 0x138 +#define QSERDES_V3_COM_HSCLK_SEL 0x13c +#define QSERDES_V3_COM_INTEGLOOP_BINCODE_STATUS 0x140 +#define QSERDES_V3_COM_PLL_ANALOG 0x144 +#define QSERDES_V3_COM_CORECLK_DIV_MODE0 0x148 +#define QSERDES_V3_COM_CORECLK_DIV_MODE1 0x14c +#define QSERDES_V3_COM_SW_RESET 0x150 +#define QSERDES_V3_COM_CORE_CLK_EN 0x154 +#define QSERDES_V3_COM_C_READY_STATUS 0x158 +#define QSERDES_V3_COM_CMN_CONFIG 0x15c +#define QSERDES_V3_COM_CMN_RATE_OVERRIDE 0x160 +#define QSERDES_V3_COM_SVS_MODE_CLK_SEL 0x164 +#define QSERDES_V3_COM_DEBUG_BUS0 0x168 +#define QSERDES_V3_COM_DEBUG_BUS1 0x16c +#define QSERDES_V3_COM_DEBUG_BUS2 0x170 +#define QSERDES_V3_COM_DEBUG_BUS3 0x174 +#define QSERDES_V3_COM_DEBUG_BUS_SEL 0x178 +#define QSERDES_V3_COM_CMN_MISC1 0x17c +#define QSERDES_V3_COM_CMN_MISC2 0x180 +#define QSERDES_V3_COM_CMN_MODE 0x184 +#define QSERDES_V3_COM_CMN_VREG_SEL 0x188 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v4.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v4.h new file mode 100644 index 0000000000..b0e3298d99 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com-v4.h @@ -0,0 +1,123 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_COM_V4_H_ +#define QCOM_PHY_QMP_QSERDES_COM_V4_H_ + +/* Only for QMP V4 PHY - QSERDES COM registers */ +#define QSERDES_V4_COM_ATB_SEL1 0x000 +#define QSERDES_V4_COM_ATB_SEL2 0x004 +#define QSERDES_V4_COM_FREQ_UPDATE 0x008 +#define QSERDES_V4_COM_BG_TIMER 0x00c +#define QSERDES_V4_COM_SSC_EN_CENTER 0x010 +#define QSERDES_V4_COM_SSC_ADJ_PER1 0x014 +#define QSERDES_V4_COM_SSC_ADJ_PER2 0x018 +#define QSERDES_V4_COM_SSC_PER1 0x01c +#define QSERDES_V4_COM_SSC_PER2 0x020 +#define QSERDES_V4_COM_SSC_STEP_SIZE1_MODE0 0x024 +#define QSERDES_V4_COM_SSC_STEP_SIZE2_MODE0 0x028 +#define QSERDES_V4_COM_SSC_STEP_SIZE3_MODE0 0x02c +#define QSERDES_V4_COM_SSC_STEP_SIZE1_MODE1 0x030 +#define QSERDES_V4_COM_SSC_STEP_SIZE2_MODE1 0x034 +#define QSERDES_V4_COM_SSC_STEP_SIZE3_MODE1 0x038 +#define QSERDES_V4_COM_POST_DIV 0x03c +#define QSERDES_V4_COM_POST_DIV_MUX 0x040 +#define QSERDES_V4_COM_BIAS_EN_CLKBUFLR_EN 0x044 +#define QSERDES_V4_COM_CLK_ENABLE1 0x048 +#define QSERDES_V4_COM_SYS_CLK_CTRL 0x04c +#define QSERDES_V4_COM_SYSCLK_BUF_ENABLE 0x050 +#define QSERDES_V4_COM_PLL_EN 0x054 +#define QSERDES_V4_COM_PLL_IVCO 0x058 +#define QSERDES_V4_COM_CMN_IETRIM 0x05c +#define QSERDES_V4_COM_CMN_IPTRIM 0x060 +#define QSERDES_V4_COM_EP_CLOCK_DETECT_CTRL 0x064 +#define QSERDES_V4_COM_SYSCLK_DET_COMP_STATUS 0x068 +#define QSERDES_V4_COM_CLK_EP_DIV_MODE0 0x06c +#define QSERDES_V4_COM_CLK_EP_DIV_MODE1 0x070 +#define QSERDES_V4_COM_CP_CTRL_MODE0 0x074 +#define QSERDES_V4_COM_CP_CTRL_MODE1 0x078 +#define QSERDES_V4_COM_PLL_RCTRL_MODE0 0x07c +#define QSERDES_V4_COM_PLL_RCTRL_MODE1 0x080 +#define QSERDES_V4_COM_PLL_CCTRL_MODE0 0x084 +#define QSERDES_V4_COM_PLL_CCTRL_MODE1 0x088 +#define QSERDES_V4_COM_PLL_CNTRL 0x08c +#define QSERDES_V4_COM_BIAS_EN_CTRL_BY_PSM 0x090 +#define QSERDES_V4_COM_SYSCLK_EN_SEL 0x094 +#define QSERDES_V4_COM_CML_SYSCLK_SEL 0x098 +#define QSERDES_V4_COM_RESETSM_CNTRL 0x09c +#define QSERDES_V4_COM_RESETSM_CNTRL2 0x0a0 +#define QSERDES_V4_COM_LOCK_CMP_EN 0x0a4 +#define QSERDES_V4_COM_LOCK_CMP_CFG 0x0a8 +#define QSERDES_V4_COM_LOCK_CMP1_MODE0 0x0ac +#define QSERDES_V4_COM_LOCK_CMP2_MODE0 0x0b0 +#define QSERDES_V4_COM_LOCK_CMP1_MODE1 0x0b4 +#define QSERDES_V4_COM_LOCK_CMP2_MODE1 0x0b8 +#define QSERDES_V4_COM_DEC_START_MODE0 0x0bc +#define QSERDES_V4_COM_DEC_START_MSB_MODE0 0x0c0 +#define QSERDES_V4_COM_DEC_START_MODE1 0x0c4 +#define QSERDES_V4_COM_DEC_START_MSB_MODE1 0x0c8 +#define QSERDES_V4_COM_DIV_FRAC_START1_MODE0 0x0cc +#define QSERDES_V4_COM_DIV_FRAC_START2_MODE0 0x0d0 +#define QSERDES_V4_COM_DIV_FRAC_START3_MODE0 0x0d4 +#define QSERDES_V4_COM_DIV_FRAC_START1_MODE1 0x0d8 +#define QSERDES_V4_COM_DIV_FRAC_START2_MODE1 0x0dc +#define QSERDES_V4_COM_DIV_FRAC_START3_MODE1 0x0e0 +#define QSERDES_V4_COM_INTEGLOOP_INITVAL 0x0e4 +#define QSERDES_V4_COM_INTEGLOOP_EN 0x0e8 +#define QSERDES_V4_COM_INTEGLOOP_GAIN0_MODE0 0x0ec +#define QSERDES_V4_COM_INTEGLOOP_GAIN1_MODE0 0x0f0 +#define QSERDES_V4_COM_INTEGLOOP_GAIN0_MODE1 0x0f4 +#define QSERDES_V4_COM_INTEGLOOP_GAIN1_MODE1 0x0f8 +#define QSERDES_V4_COM_INTEGLOOP_P_PATH_GAIN0 0x0fc +#define QSERDES_V4_COM_INTEGLOOP_P_PATH_GAIN1 0x100 +#define QSERDES_V4_COM_VCOCAL_DEADMAN_CTRL 0x104 +#define QSERDES_V4_COM_VCO_TUNE_CTRL 0x108 +#define QSERDES_V4_COM_VCO_TUNE_MAP 0x10c +#define QSERDES_V4_COM_VCO_TUNE1_MODE0 0x110 +#define QSERDES_V4_COM_VCO_TUNE2_MODE0 0x114 +#define QSERDES_V4_COM_VCO_TUNE1_MODE1 0x118 +#define QSERDES_V4_COM_VCO_TUNE2_MODE1 0x11c +#define QSERDES_V4_COM_VCO_TUNE_INITVAL1 0x120 +#define QSERDES_V4_COM_VCO_TUNE_INITVAL2 0x124 +#define QSERDES_V4_COM_VCO_TUNE_MINVAL1 0x128 +#define QSERDES_V4_COM_VCO_TUNE_MINVAL2 0x12c +#define QSERDES_V4_COM_VCO_TUNE_MAXVAL1 0x130 +#define QSERDES_V4_COM_VCO_TUNE_MAXVAL2 0x134 +#define QSERDES_V4_COM_VCO_TUNE_TIMER1 0x138 +#define QSERDES_V4_COM_VCO_TUNE_TIMER2 0x13c +#define QSERDES_V4_COM_CMN_STATUS 0x140 +#define QSERDES_V4_COM_RESET_SM_STATUS 0x144 +#define QSERDES_V4_COM_RESTRIM_CODE_STATUS 0x148 +#define QSERDES_V4_COM_PLLCAL_CODE1_STATUS 0x14c +#define QSERDES_V4_COM_PLLCAL_CODE2_STATUS 0x150 +#define QSERDES_V4_COM_CLK_SELECT 0x154 +#define QSERDES_V4_COM_HSCLK_SEL 0x158 +#define QSERDES_V4_COM_HSCLK_HS_SWITCH_SEL 0x15c +#define QSERDES_V4_COM_INTEGLOOP_BINCODE_STATUS 0x160 +#define QSERDES_V4_COM_PLL_ANALOG 0x164 +#define QSERDES_V4_COM_CORECLK_DIV_MODE0 0x168 +#define QSERDES_V4_COM_CORECLK_DIV_MODE1 0x16c +#define QSERDES_V4_COM_SW_RESET 0x170 +#define QSERDES_V4_COM_CORE_CLK_EN 0x174 +#define QSERDES_V4_COM_C_READY_STATUS 0x178 +#define QSERDES_V4_COM_CMN_CONFIG 0x17c +#define QSERDES_V4_COM_CMN_RATE_OVERRIDE 0x180 +#define QSERDES_V4_COM_SVS_MODE_CLK_SEL 0x184 +#define QSERDES_V4_COM_DEBUG_BUS0 0x188 +#define QSERDES_V4_COM_DEBUG_BUS1 0x18c +#define QSERDES_V4_COM_DEBUG_BUS2 0x190 +#define QSERDES_V4_COM_DEBUG_BUS3 0x194 +#define QSERDES_V4_COM_DEBUG_BUS_SEL 0x198 +#define QSERDES_V4_COM_CMN_MISC1 0x19c +#define QSERDES_V4_COM_CMN_MISC2 0x1a0 +#define QSERDES_V4_COM_CMN_MODE 0x1a4 +#define QSERDES_V4_COM_VCO_DC_LEVEL_CTRL 0x1a8 +#define QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE1_MODE0 0x1ac +#define QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE2_MODE0 0x1b0 +#define QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE1_MODE1 0x1b4 +#define QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE2_MODE1 0x1b8 +#define QSERDES_V4_COM_BIN_VCOCAL_HSCLK_SEL 0x1bc + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h new file mode 100644 index 0000000000..7fa5363fee --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-com.h @@ -0,0 +1,140 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_COM_H_ +#define QCOM_PHY_QMP_QSERDES_COM_H_ + +/* Only for QMP V2 PHY - QSERDES COM registers */ +#define QSERDES_COM_ATB_SEL1 0x000 +#define QSERDES_COM_ATB_SEL2 0x004 +#define QSERDES_COM_FREQ_UPDATE 0x008 +#define QSERDES_COM_BG_TIMER 0x00c +#define QSERDES_COM_SSC_EN_CENTER 0x010 +#define QSERDES_COM_SSC_ADJ_PER1 0x014 +#define QSERDES_COM_SSC_ADJ_PER2 0x018 +#define QSERDES_COM_SSC_PER1 0x01c +#define QSERDES_COM_SSC_PER2 0x020 +#define QSERDES_COM_SSC_STEP_SIZE1 0x024 +#define QSERDES_COM_SSC_STEP_SIZE2 0x028 +#define QSERDES_COM_POST_DIV 0x02c +#define QSERDES_COM_POST_DIV_MUX 0x030 +#define QSERDES_COM_BIAS_EN_CLKBUFLR_EN 0x034 +#define QSERDES_COM_CLK_ENABLE1 0x038 +#define QSERDES_COM_SYS_CLK_CTRL 0x03c +#define QSERDES_COM_SYSCLK_BUF_ENABLE 0x040 +#define QSERDES_COM_PLL_EN 0x044 +#define QSERDES_COM_PLL_IVCO 0x048 +#define QSERDES_COM_LOCK_CMP1_MODE0 0x04c +#define QSERDES_COM_LOCK_CMP2_MODE0 0x050 +#define QSERDES_COM_LOCK_CMP3_MODE0 0x054 +#define QSERDES_COM_LOCK_CMP1_MODE1 0x058 +#define QSERDES_COM_LOCK_CMP2_MODE1 0x05c +#define QSERDES_COM_LOCK_CMP3_MODE1 0x060 +#define QSERDES_COM_LOCK_CMP1_MODE2 0x064 +#define QSERDES_COM_CMN_RSVD0 0x064 +#define QSERDES_COM_LOCK_CMP2_MODE2 0x068 +#define QSERDES_COM_EP_CLOCK_DETECT_CTRL 0x068 +#define QSERDES_COM_LOCK_CMP3_MODE2 0x06c +#define QSERDES_COM_SYSCLK_DET_COMP_STATUS 0x06c +#define QSERDES_COM_BG_TRIM 0x070 +#define QSERDES_COM_CLK_EP_DIV 0x074 +#define QSERDES_COM_CP_CTRL_MODE0 0x078 +#define QSERDES_COM_CP_CTRL_MODE1 0x07c +#define QSERDES_COM_CP_CTRL_MODE2 0x080 +#define QSERDES_COM_CMN_RSVD1 0x080 +#define QSERDES_COM_PLL_RCTRL_MODE0 0x084 +#define QSERDES_COM_PLL_RCTRL_MODE1 0x088 +#define QSERDES_COM_PLL_RCTRL_MODE2 0x08c +#define QSERDES_COM_CMN_RSVD2 0x08c +#define QSERDES_COM_PLL_CCTRL_MODE0 0x090 +#define QSERDES_COM_PLL_CCTRL_MODE1 0x094 +#define QSERDES_COM_PLL_CCTRL_MODE2 0x098 +#define QSERDES_COM_CMN_RSVD3 0x098 +#define QSERDES_COM_PLL_CNTRL 0x09c +#define QSERDES_COM_PHASE_SEL_CTRL 0x0a0 +#define QSERDES_COM_PHASE_SEL_DC 0x0a4 +#define QSERDES_COM_CORE_CLK_IN_SYNC_SEL 0x0a8 +#define QSERDES_COM_BIAS_EN_CTRL_BY_PSM 0x0a8 +#define QSERDES_COM_SYSCLK_EN_SEL 0x0ac +#define QSERDES_COM_CML_SYSCLK_SEL 0x0b0 +#define QSERDES_COM_RESETSM_CNTRL 0x0b4 +#define QSERDES_COM_RESETSM_CNTRL2 0x0b8 +#define QSERDES_COM_RESTRIM_CTRL 0x0bc +#define QSERDES_COM_RESTRIM_CTRL2 0x0c0 +#define QSERDES_COM_RESCODE_DIV_NUM 0x0c4 +#define QSERDES_COM_LOCK_CMP_EN 0x0c8 +#define QSERDES_COM_LOCK_CMP_CFG 0x0cc +#define QSERDES_COM_DEC_START_MODE0 0x0d0 +#define QSERDES_COM_DEC_START_MODE1 0x0d4 +#define QSERDES_COM_DEC_START_MODE2 0x0d8 +#define QSERDES_COM_VCOCAL_DEADMAN_CTRL 0x0d8 +#define QSERDES_COM_DIV_FRAC_START1_MODE0 0x0dc +#define QSERDES_COM_DIV_FRAC_START2_MODE0 0x0e0 +#define QSERDES_COM_DIV_FRAC_START3_MODE0 0x0e4 +#define QSERDES_COM_DIV_FRAC_START1_MODE1 0x0e8 +#define QSERDES_COM_DIV_FRAC_START2_MODE1 0x0ec +#define QSERDES_COM_DIV_FRAC_START3_MODE1 0x0f0 +#define QSERDES_COM_DIV_FRAC_START1_MODE2 0x0f4 +#define QSERDES_COM_VCO_TUNE_MINVAL1 0x0f4 +#define QSERDES_COM_DIV_FRAC_START2_MODE2 0x0f8 +#define QSERDES_COM_VCO_TUNE_MINVAL2 0x0f8 +#define QSERDES_COM_DIV_FRAC_START3_MODE2 0x0fc +#define QSERDES_COM_CMN_RSVD4 0x0fc +#define QSERDES_COM_INTEGLOOP_INITVAL 0x100 +#define QSERDES_COM_INTEGLOOP_EN 0x104 +#define QSERDES_COM_INTEGLOOP_GAIN0_MODE0 0x108 +#define QSERDES_COM_INTEGLOOP_GAIN1_MODE0 0x10c +#define QSERDES_COM_INTEGLOOP_GAIN0_MODE1 0x110 +#define QSERDES_COM_INTEGLOOP_GAIN1_MODE1 0x114 +#define QSERDES_COM_INTEGLOOP_GAIN0_MODE2 0x118 +#define QSERDES_COM_VCO_TUNE_MAXVAL1 0x118 +#define QSERDES_COM_INTEGLOOP_GAIN1_MODE2 0x11c +#define QSERDES_COM_VCO_TUNE_MAXVAL2 0x11c +#define QSERDES_COM_RES_TRIM_CONTROL2 0x120 +#define QSERDES_COM_VCO_TUNE_CTRL 0x124 +#define QSERDES_COM_VCO_TUNE_MAP 0x128 +#define QSERDES_COM_VCO_TUNE1_MODE0 0x12c +#define QSERDES_COM_VCO_TUNE2_MODE0 0x130 +#define QSERDES_COM_VCO_TUNE1_MODE1 0x134 +#define QSERDES_COM_VCO_TUNE2_MODE1 0x138 +#define QSERDES_COM_VCO_TUNE1_MODE2 0x13c +#define QSERDES_COM_VCO_TUNE_INITVAL1 0x13c +#define QSERDES_COM_VCO_TUNE2_MODE2 0x140 +#define QSERDES_COM_VCO_TUNE_INITVAL2 0x140 +#define QSERDES_COM_VCO_TUNE_TIMER1 0x144 +#define QSERDES_COM_VCO_TUNE_TIMER2 0x148 +#define QSERDES_COM_SAR 0x14c +#define QSERDES_COM_SAR_CLK 0x150 +#define QSERDES_COM_SAR_CODE_OUT_STATUS 0x154 +#define QSERDES_COM_SAR_CODE_READY_STATUS 0x158 +#define QSERDES_COM_CMN_STATUS 0x15c +#define QSERDES_COM_RESET_SM_STATUS 0x160 +#define QSERDES_COM_RESTRIM_CODE_STATUS 0x164 +#define QSERDES_COM_PLLCAL_CODE1_STATUS 0x168 +#define QSERDES_COM_PLLCAL_CODE2_STATUS 0x16c +#define QSERDES_COM_BG_CTRL 0x170 +#define QSERDES_COM_CLK_SELECT 0x174 +#define QSERDES_COM_HSCLK_SEL 0x178 +#define QSERDES_COM_INTEGLOOP_BINCODE_STATUS 0x17c +#define QSERDES_COM_PLL_ANALOG 0x180 +#define QSERDES_COM_CORECLK_DIV 0x184 +#define QSERDES_COM_SW_RESET 0x188 +#define QSERDES_COM_CORE_CLK_EN 0x18c +#define QSERDES_COM_C_READY_STATUS 0x190 +#define QSERDES_COM_CMN_CONFIG 0x194 +#define QSERDES_COM_CMN_RATE_OVERRIDE 0x198 +#define QSERDES_COM_SVS_MODE_CLK_SEL 0x19c +#define QSERDES_COM_DEBUG_BUS0 0x1a0 +#define QSERDES_COM_DEBUG_BUS1 0x1a4 +#define QSERDES_COM_DEBUG_BUS2 0x1a8 +#define QSERDES_COM_DEBUG_BUS3 0x1ac +#define QSERDES_COM_DEBUG_BUS_SEL 0x1b0 +#define QSERDES_COM_CMN_MISC1 0x1b4 +#define QSERDES_COM_CMN_MISC2 0x1b8 +#define QSERDES_COM_CORECLK_DIV_MODE1 0x1bc +#define QSERDES_COM_CORECLK_DIV_MODE2 0x1c0 +#define QSERDES_COM_CMN_RSVD5 0x1c4 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h new file mode 100644 index 0000000000..ad326e301a --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-pll.h @@ -0,0 +1,66 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_PLL_H_ +#define QCOM_PHY_QMP_QSERDES_PLL_H_ + +/* QMP V2 PHY for PCIE gen3 ports - QSERDES PLL registers */ +#define QSERDES_PLL_BG_TIMER 0x00c +#define QSERDES_PLL_SSC_PER1 0x01c +#define QSERDES_PLL_SSC_PER2 0x020 +#define QSERDES_PLL_SSC_STEP_SIZE1_MODE0 0x024 +#define QSERDES_PLL_SSC_STEP_SIZE2_MODE0 0x028 +#define QSERDES_PLL_SSC_STEP_SIZE1_MODE1 0x02c +#define QSERDES_PLL_SSC_STEP_SIZE2_MODE1 0x030 +#define QSERDES_PLL_BIAS_EN_CLKBUFLR_EN 0x03c +#define QSERDES_PLL_CLK_ENABLE1 0x040 +#define QSERDES_PLL_SYS_CLK_CTRL 0x044 +#define QSERDES_PLL_SYSCLK_BUF_ENABLE 0x048 +#define QSERDES_PLL_PLL_IVCO 0x050 +#define QSERDES_PLL_LOCK_CMP1_MODE0 0x054 +#define QSERDES_PLL_LOCK_CMP2_MODE0 0x058 +#define QSERDES_PLL_LOCK_CMP1_MODE1 0x060 +#define QSERDES_PLL_LOCK_CMP2_MODE1 0x064 +#define QSERDES_PLL_BG_TRIM 0x074 +#define QSERDES_PLL_CLK_EP_DIV_MODE0 0x078 +#define QSERDES_PLL_CLK_EP_DIV_MODE1 0x07c +#define QSERDES_PLL_CP_CTRL_MODE0 0x080 +#define QSERDES_PLL_CP_CTRL_MODE1 0x084 +#define QSERDES_PLL_PLL_RCTRL_MODE0 0x088 +#define QSERDES_PLL_PLL_RCTRL_MODE1 0x08c +#define QSERDES_PLL_PLL_CCTRL_MODE0 0x090 +#define QSERDES_PLL_PLL_CCTRL_MODE1 0x094 +#define QSERDES_PLL_BIAS_EN_CTRL_BY_PSM 0x0a4 +#define QSERDES_PLL_SYSCLK_EN_SEL 0x0a8 +#define QSERDES_PLL_RESETSM_CNTRL 0x0b0 +#define QSERDES_PLL_LOCK_CMP_EN 0x0c4 +#define QSERDES_PLL_DEC_START_MODE0 0x0cc +#define QSERDES_PLL_DEC_START_MODE1 0x0d0 +#define QSERDES_PLL_DIV_FRAC_START1_MODE0 0x0d8 +#define QSERDES_PLL_DIV_FRAC_START2_MODE0 0x0dc +#define QSERDES_PLL_DIV_FRAC_START3_MODE0 0x0e0 +#define QSERDES_PLL_DIV_FRAC_START1_MODE1 0x0e4 +#define QSERDES_PLL_DIV_FRAC_START2_MODE1 0x0e8 +#define QSERDES_PLL_DIV_FRAC_START3_MODE1 0x0ec +#define QSERDES_PLL_INTEGLOOP_GAIN0_MODE0 0x100 +#define QSERDES_PLL_INTEGLOOP_GAIN1_MODE0 0x104 +#define QSERDES_PLL_INTEGLOOP_GAIN0_MODE1 0x108 +#define QSERDES_PLL_INTEGLOOP_GAIN1_MODE1 0x10c +#define QSERDES_PLL_VCO_TUNE_MAP 0x120 +#define QSERDES_PLL_VCO_TUNE1_MODE0 0x124 +#define QSERDES_PLL_VCO_TUNE2_MODE0 0x128 +#define QSERDES_PLL_VCO_TUNE1_MODE1 0x12c +#define QSERDES_PLL_VCO_TUNE2_MODE1 0x130 +#define QSERDES_PLL_VCO_TUNE_TIMER1 0x13c +#define QSERDES_PLL_VCO_TUNE_TIMER2 0x140 +#define QSERDES_PLL_CLK_SELECT 0x16c +#define QSERDES_PLL_HSCLK_SEL 0x170 +#define QSERDES_PLL_CORECLK_DIV 0x17c +#define QSERDES_PLL_CORE_CLK_EN 0x184 +#define QSERDES_PLL_CMN_CONFIG 0x18c +#define QSERDES_PLL_SVS_MODE_CLK_SEL 0x194 +#define QSERDES_PLL_CORECLK_DIV_MODE1 0x1b4 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h new file mode 100644 index 0000000000..15bcb4ba91 --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-ufs-v6.h @@ -0,0 +1,30 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2023, Linaro Limited + */ + +#ifndef QCOM_PHY_QMP_QSERDES_TXRX_UFS_V6_H_ +#define QCOM_PHY_QMP_QSERDES_TXRX_UFS_V6_H_ + +#define QSERDES_UFS_V6_TX_RES_CODE_LANE_TX 0x28 +#define QSERDES_UFS_V6_TX_RES_CODE_LANE_RX 0x2c +#define QSERDES_UFS_V6_TX_RES_CODE_LANE_OFFSET_TX 0x30 +#define QSERDES_UFS_V6_TX_RES_CODE_LANE_OFFSET_RX 0x34 + +#define QSERDES_UFS_V6_RX_UCDR_FASTLOCK_FO_GAIN_RATE2 0x08 +#define QSERDES_UFS_V6_RX_UCDR_FASTLOCK_FO_GAIN_RATE4 0x10 +#define QSERDES_UFS_V6_RX_VGA_CAL_MAN_VAL 0x178 +#define QSERDES_UFS_V6_RX_MODE_RATE_0_1_B0 0x208 +#define QSERDES_UFS_V6_RX_MODE_RATE_0_1_B1 0x20c +#define QSERDES_UFS_V6_RX_MODE_RATE_0_1_B3 0x214 +#define QSERDES_UFS_V6_RX_MODE_RATE_0_1_B6 0x220 +#define QSERDES_UFS_V6_RX_MODE_RATE2_B3 0x238 +#define QSERDES_UFS_V6_RX_MODE_RATE2_B6 0x244 +#define QSERDES_UFS_V6_RX_MODE_RATE3_B3 0x25c +#define QSERDES_UFS_V6_RX_MODE_RATE3_B4 0x260 +#define QSERDES_UFS_V6_RX_MODE_RATE3_B5 0x264 +#define QSERDES_UFS_V6_RX_MODE_RATE3_B8 0x270 +#define QSERDES_UFS_V6_RX_MODE_RATE4_B3 0x280 +#define QSERDES_UFS_V6_RX_MODE_RATE4_B6 0x28c + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h new file mode 100644 index 0000000000..161e6df30e --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v3.h @@ -0,0 +1,68 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_TXRX_V3_H_ +#define QCOM_PHY_QMP_QSERDES_TXRX_V3_H_ + +/* Only for QMP V3 PHY - TX registers */ +#define QSERDES_V3_TX_BIST_MODE_LANENO 0x000 +#define QSERDES_V3_TX_CLKBUF_ENABLE 0x008 +#define QSERDES_V3_TX_TX_EMP_POST1_LVL 0x00c +#define QSERDES_V3_TX_TX_DRV_LVL 0x01c +#define QSERDES_V3_TX_RESET_TSYNC_EN 0x024 +#define QSERDES_V3_TX_PRE_STALL_LDO_BOOST_EN 0x028 +#define QSERDES_V3_TX_TX_BAND 0x02c +#define QSERDES_V3_TX_SLEW_CNTL 0x030 +#define QSERDES_V3_TX_INTERFACE_SELECT 0x034 +#define QSERDES_V3_TX_RES_CODE_LANE_TX 0x03c +#define QSERDES_V3_TX_RES_CODE_LANE_RX 0x040 +#define QSERDES_V3_TX_RES_CODE_LANE_OFFSET_TX 0x044 +#define QSERDES_V3_TX_RES_CODE_LANE_OFFSET_RX 0x048 +#define QSERDES_V3_TX_DEBUG_BUS_SEL 0x058 +#define QSERDES_V3_TX_TRANSCEIVER_BIAS_EN 0x05c +#define QSERDES_V3_TX_HIGHZ_DRVR_EN 0x060 +#define QSERDES_V3_TX_TX_POL_INV 0x064 +#define QSERDES_V3_TX_PARRATE_REC_DETECT_IDLE_EN 0x068 +#define QSERDES_V3_TX_LANE_MODE_1 0x08c +#define QSERDES_V3_TX_LANE_MODE_2 0x090 +#define QSERDES_V3_TX_LANE_MODE_3 0x094 +#define QSERDES_V3_TX_RCV_DETECT_LVL_2 0x0a4 +#define QSERDES_V3_TX_TRAN_DRVR_EMP_EN 0x0c0 +#define QSERDES_V3_TX_TX_INTERFACE_MODE 0x0c4 +#define QSERDES_V3_TX_VMODE_CTRL1 0x0f0 + +/* Only for QMP V3 PHY - RX registers */ +#define QSERDES_V3_RX_UCDR_FO_GAIN 0x008 +#define QSERDES_V3_RX_UCDR_SO_GAIN_HALF 0x00c +#define QSERDES_V3_RX_UCDR_SO_GAIN 0x014 +#define QSERDES_V3_RX_UCDR_SVS_SO_GAIN_HALF 0x024 +#define QSERDES_V3_RX_UCDR_SVS_SO_GAIN_QUARTER 0x028 +#define QSERDES_V3_RX_UCDR_SVS_SO_GAIN 0x02c +#define QSERDES_V3_RX_UCDR_FASTLOCK_FO_GAIN 0x030 +#define QSERDES_V3_RX_UCDR_SO_SATURATION_AND_ENABLE 0x034 +#define QSERDES_V3_RX_UCDR_FASTLOCK_COUNT_LOW 0x03c +#define QSERDES_V3_RX_UCDR_FASTLOCK_COUNT_HIGH 0x040 +#define QSERDES_V3_RX_UCDR_PI_CONTROLS 0x044 +#define QSERDES_V3_RX_RX_TERM_BW 0x07c +#define QSERDES_V3_RX_VGA_CAL_CNTRL1 0x0bc +#define QSERDES_V3_RX_VGA_CAL_CNTRL2 0x0c0 +#define QSERDES_V3_RX_RX_EQ_GAIN2_LSB 0x0c8 +#define QSERDES_V3_RX_RX_EQ_GAIN2_MSB 0x0cc +#define QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL1 0x0d0 +#define QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL2 0x0d4 +#define QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL3 0x0d8 +#define QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL4 0x0dc +#define QSERDES_V3_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1 0x0f8 +#define QSERDES_V3_RX_RX_OFFSET_ADAPTOR_CNTRL2 0x0fc +#define QSERDES_V3_RX_SIGDET_ENABLES 0x100 +#define QSERDES_V3_RX_SIGDET_CNTRL 0x104 +#define QSERDES_V3_RX_SIGDET_LVL 0x108 +#define QSERDES_V3_RX_SIGDET_DEGLITCH_CNTRL 0x10c +#define QSERDES_V3_RX_RX_BAND 0x110 +#define QSERDES_V3_RX_RX_INTERFACE_MODE 0x11c +#define QSERDES_V3_RX_RX_MODE_00 0x164 +#define QSERDES_V3_RX_RX_MODE_01 0x168 + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h new file mode 100644 index 0000000000..6ee3bec9ac --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx-v4.h @@ -0,0 +1,233 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_TXRX_V4_H_ +#define QCOM_PHY_QMP_QSERDES_TXRX_V4_H_ + +/* Only for QMP V4 PHY - TX registers */ +#define QSERDES_V4_TX_BIST_MODE_LANENO 0x000 +#define QSERDES_V4_TX_BIST_INVERT 0x004 +#define QSERDES_V4_TX_CLKBUF_ENABLE 0x008 +#define QSERDES_V4_TX_TX_EMP_POST1_LVL 0x00c +#define QSERDES_V4_TX_TX_IDLE_LVL_LARGE_AMP 0x010 +#define QSERDES_V4_TX_TX_DRV_LVL 0x014 +#define QSERDES_V4_TX_TX_DRV_LVL_OFFSET 0x018 +#define QSERDES_V4_TX_RESET_TSYNC_EN 0x01c +#define QSERDES_V4_TX_PRE_STALL_LDO_BOOST_EN 0x020 +#define QSERDES_V4_TX_TX_BAND 0x024 +#define QSERDES_V4_TX_SLEW_CNTL 0x028 +#define QSERDES_V4_TX_INTERFACE_SELECT 0x02c +#define QSERDES_V4_TX_LPB_EN 0x030 +#define QSERDES_V4_TX_RES_CODE_LANE_TX 0x034 +#define QSERDES_V4_TX_RES_CODE_LANE_RX 0x038 +#define QSERDES_V4_TX_RES_CODE_LANE_OFFSET_TX 0x03c +#define QSERDES_V4_TX_RES_CODE_LANE_OFFSET_RX 0x040 +#define QSERDES_V4_TX_PERL_LENGTH1 0x044 +#define QSERDES_V4_TX_PERL_LENGTH2 0x048 +#define QSERDES_V4_TX_SERDES_BYP_EN_OUT 0x04c +#define QSERDES_V4_TX_DEBUG_BUS_SEL 0x050 +#define QSERDES_V4_TX_TRANSCEIVER_BIAS_EN 0x054 +#define QSERDES_V4_TX_HIGHZ_DRVR_EN 0x058 +#define QSERDES_V4_TX_TX_POL_INV 0x05c +#define QSERDES_V4_TX_PARRATE_REC_DETECT_IDLE_EN 0x060 +#define QSERDES_V4_TX_BIST_PATTERN1 0x064 +#define QSERDES_V4_TX_BIST_PATTERN2 0x068 +#define QSERDES_V4_TX_BIST_PATTERN3 0x06c +#define QSERDES_V4_TX_BIST_PATTERN4 0x070 +#define QSERDES_V4_TX_BIST_PATTERN5 0x074 +#define QSERDES_V4_TX_BIST_PATTERN6 0x078 +#define QSERDES_V4_TX_BIST_PATTERN7 0x07c +#define QSERDES_V4_TX_BIST_PATTERN8 0x080 +#define QSERDES_V4_TX_LANE_MODE_1 0x084 +#define QSERDES_V4_TX_LANE_MODE_2 0x088 +#define QSERDES_V4_TX_LANE_MODE_3 0x08c +#define QSERDES_V4_TX_ATB_SEL1 0x090 +#define QSERDES_V4_TX_ATB_SEL2 0x094 +#define QSERDES_V4_TX_RCV_DETECT_LVL 0x098 +#define QSERDES_V4_TX_RCV_DETECT_LVL_2 0x09c +#define QSERDES_V4_TX_PRBS_SEED1 0x0a0 +#define QSERDES_V4_TX_PRBS_SEED2 0x0a4 +#define QSERDES_V4_TX_PRBS_SEED3 0x0a8 +#define QSERDES_V4_TX_PRBS_SEED4 0x0ac +#define QSERDES_V4_TX_RESET_GEN 0x0b0 +#define QSERDES_V4_TX_RESET_GEN_MUXES 0x0b4 +#define QSERDES_V4_TX_TRAN_DRVR_EMP_EN 0x0b8 +#define QSERDES_V4_TX_TX_INTERFACE_MODE 0x0bc +#define QSERDES_V4_TX_PWM_CTRL 0x0c0 +#define QSERDES_V4_TX_PWM_ENCODED_OR_DATA 0x0c4 +#define QSERDES_V4_TX_PWM_GEAR_1_DIVIDER_BAND2 0x0c8 +#define QSERDES_V4_TX_PWM_GEAR_2_DIVIDER_BAND2 0x0cc +#define QSERDES_V4_TX_PWM_GEAR_3_DIVIDER_BAND2 0x0d0 +#define QSERDES_V4_TX_PWM_GEAR_4_DIVIDER_BAND2 0x0d4 +#define QSERDES_V4_TX_PWM_GEAR_1_DIVIDER_BAND0_1 0x0d8 +#define QSERDES_V4_TX_PWM_GEAR_2_DIVIDER_BAND0_1 0x0dc +#define QSERDES_V4_TX_PWM_GEAR_3_DIVIDER_BAND0_1 0x0e0 +#define QSERDES_V4_TX_PWM_GEAR_4_DIVIDER_BAND0_1 0x0e4 +#define QSERDES_V4_TX_VMODE_CTRL1 0x0e8 +#define QSERDES_V4_TX_ALOG_OBSV_BUS_CTRL_1 0x0ec +#define QSERDES_V4_TX_BIST_STATUS 0x0f0 +#define QSERDES_V4_TX_BIST_ERROR_COUNT1 0x0f4 +#define QSERDES_V4_TX_BIST_ERROR_COUNT2 0x0f8 +#define QSERDES_V4_TX_ALOG_OBSV_BUS_STATUS_1 0x0fc +#define QSERDES_V4_TX_LANE_DIG_CONFIG 0x100 +#define QSERDES_V4_TX_PI_QEC_CTRL 0x104 +#define QSERDES_V4_TX_PRE_EMPH 0x108 +#define QSERDES_V4_TX_SW_RESET 0x10c +#define QSERDES_V4_TX_DCC_OFFSET 0x110 +#define QSERDES_V4_TX_DIG_BKUP_CTRL 0x114 +#define QSERDES_V4_TX_DEBUG_BUS0 0x118 +#define QSERDES_V4_TX_DEBUG_BUS1 0x11c +#define QSERDES_V4_TX_DEBUG_BUS2 0x120 +#define QSERDES_V4_TX_DEBUG_BUS3 0x124 +#define QSERDES_V4_TX_READ_EQCODE 0x128 +#define QSERDES_V4_TX_READ_OFFSETCODE 0x12c +#define QSERDES_V4_TX_IA_ERROR_COUNTER_LOW 0x130 +#define QSERDES_V4_TX_IA_ERROR_COUNTER_HIGH 0x134 +#define QSERDES_V4_TX_VGA_READ_CODE 0x138 +#define QSERDES_V4_TX_VTH_READ_CODE 0x13c +#define QSERDES_V4_TX_DFE_TAP1_READ_CODE 0x140 +#define QSERDES_V4_TX_DFE_TAP2_READ_CODE 0x144 +#define QSERDES_V4_TX_IDAC_STATUS_I 0x148 +#define QSERDES_V4_TX_IDAC_STATUS_IBAR 0x14c +#define QSERDES_V4_TX_IDAC_STATUS_Q 0x150 +#define QSERDES_V4_TX_IDAC_STATUS_QBAR 0x154 +#define QSERDES_V4_TX_IDAC_STATUS_A 0x158 +#define QSERDES_V4_TX_IDAC_STATUS_ABAR 0x15c +#define QSERDES_V4_TX_IDAC_STATUS_SM_ON 0x160 +#define QSERDES_V4_TX_IDAC_STATUS_CAL_DONE 0x164 +#define QSERDES_V4_TX_IDAC_STATUS_SIGNERROR 0x168 +#define QSERDES_V4_TX_DCC_CAL_STATUS 0x16c + +/* Only for QMP V4 PHY - RX registers */ +#define QSERDES_V4_RX_UCDR_FO_GAIN_HALF 0x000 +#define QSERDES_V4_RX_UCDR_FO_GAIN_QUARTER 0x004 +#define QSERDES_V4_RX_UCDR_FO_GAIN 0x008 +#define QSERDES_V4_RX_UCDR_SO_GAIN_HALF 0x00c +#define QSERDES_V4_RX_UCDR_SO_GAIN_QUARTER 0x010 +#define QSERDES_V4_RX_UCDR_SO_GAIN 0x014 +#define QSERDES_V4_RX_UCDR_SVS_FO_GAIN_HALF 0x018 +#define QSERDES_V4_RX_UCDR_SVS_FO_GAIN_QUARTER 0x01c +#define QSERDES_V4_RX_UCDR_SVS_FO_GAIN 0x020 +#define QSERDES_V4_RX_UCDR_SVS_SO_GAIN_HALF 0x024 +#define QSERDES_V4_RX_UCDR_SVS_SO_GAIN_QUARTER 0x028 +#define QSERDES_V4_RX_UCDR_SVS_SO_GAIN 0x02c +#define QSERDES_V4_RX_UCDR_FASTLOCK_FO_GAIN 0x030 +#define QSERDES_V4_RX_UCDR_SO_SATURATION_AND_ENABLE 0x034 +#define QSERDES_V4_RX_UCDR_FO_TO_SO_DELAY 0x038 +#define QSERDES_V4_RX_UCDR_FASTLOCK_COUNT_LOW 0x03c +#define QSERDES_V4_RX_UCDR_FASTLOCK_COUNT_HIGH 0x040 +#define QSERDES_V4_RX_UCDR_PI_CONTROLS 0x044 +#define QSERDES_V4_RX_UCDR_PI_CTRL2 0x048 +#define QSERDES_V4_RX_UCDR_SB2_THRESH1 0x04c +#define QSERDES_V4_RX_UCDR_SB2_THRESH2 0x050 +#define QSERDES_V4_RX_UCDR_SB2_GAIN1 0x054 +#define QSERDES_V4_RX_UCDR_SB2_GAIN2 0x058 +#define QSERDES_V4_RX_AUX_CONTROL 0x05c +#define QSERDES_V4_RX_AUX_DATA_TCOARSE_TFINE 0x060 +#define QSERDES_V4_RX_RCLK_AUXDATA_SEL 0x064 +#define QSERDES_V4_RX_AC_JTAG_ENABLE 0x068 +#define QSERDES_V4_RX_AC_JTAG_INITP 0x06c +#define QSERDES_V4_RX_AC_JTAG_INITN 0x070 +#define QSERDES_V4_RX_AC_JTAG_LVL 0x074 +#define QSERDES_V4_RX_AC_JTAG_MODE 0x078 +#define QSERDES_V4_RX_AC_JTAG_RESET 0x07c +#define QSERDES_V4_RX_RX_TERM_BW 0x080 +#define QSERDES_V4_RX_RX_RCVR_IQ_EN 0x084 +#define QSERDES_V4_RX_RX_IDAC_I_DC_OFFSETS 0x088 +#define QSERDES_V4_RX_RX_IDAC_IBAR_DC_OFFSETS 0x08c +#define QSERDES_V4_RX_RX_IDAC_Q_DC_OFFSETS 0x090 +#define QSERDES_V4_RX_RX_IDAC_QBAR_DC_OFFSETS 0x094 +#define QSERDES_V4_RX_RX_IDAC_A_DC_OFFSETS 0x098 +#define QSERDES_V4_RX_RX_IDAC_ABAR_DC_OFFSETS 0x09c +#define QSERDES_V4_RX_RX_IDAC_EN 0x0a0 +#define QSERDES_V4_RX_RX_IDAC_ENABLES 0x0a4 +#define QSERDES_V4_RX_RX_IDAC_SIGN 0x0a8 +#define QSERDES_V4_RX_RX_HIGHZ_HIGHRATE 0x0ac +#define QSERDES_V4_RX_RX_TERM_AC_BYPASS_DC_COUPLE_OFFSET 0x0b0 +#define QSERDES_V4_RX_DFE_1 0x0b4 +#define QSERDES_V4_RX_DFE_2 0x0b8 +#define QSERDES_V4_RX_DFE_3 0x0bc +#define QSERDES_V4_RX_DFE_4 0x0c0 +#define QSERDES_V4_RX_TX_ADAPT_PRE_THRESH1 0x0c4 +#define QSERDES_V4_RX_TX_ADAPT_PRE_THRESH2 0x0c8 +#define QSERDES_V4_RX_TX_ADAPT_POST_THRESH 0x0cc +#define QSERDES_V4_RX_TX_ADAPT_MAIN_THRESH 0x0d0 +#define QSERDES_V4_RX_VGA_CAL_CNTRL1 0x0d4 +#define QSERDES_V4_RX_VGA_CAL_CNTRL2 0x0d8 +#define QSERDES_V4_RX_GM_CAL 0x0dc +#define QSERDES_V4_RX_RX_VGA_GAIN2_LSB 0x0e0 +#define QSERDES_V4_RX_RX_VGA_GAIN2_MSB 0x0e4 +#define QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL1 0x0e8 +#define QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL2 0x0ec +#define QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL3 0x0f0 +#define QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL4 0x0f4 +#define QSERDES_V4_RX_RX_IDAC_TSETTLE_LOW 0x0f8 +#define QSERDES_V4_RX_RX_IDAC_TSETTLE_HIGH 0x0fc +#define QSERDES_V4_RX_RX_IDAC_MEASURE_TIME 0x100 +#define QSERDES_V4_RX_RX_IDAC_ACCUMULATOR 0x104 +#define QSERDES_V4_RX_RX_EQ_OFFSET_LSB 0x108 +#define QSERDES_V4_RX_RX_EQ_OFFSET_MSB 0x10c +#define QSERDES_V4_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1 0x110 +#define QSERDES_V4_RX_RX_OFFSET_ADAPTOR_CNTRL2 0x114 +#define QSERDES_V4_RX_SIGDET_ENABLES 0x118 +#define QSERDES_V4_RX_SIGDET_CNTRL 0x11c +#define QSERDES_V4_RX_SIGDET_LVL 0x120 +#define QSERDES_V4_RX_SIGDET_DEGLITCH_CNTRL 0x124 +#define QSERDES_V4_RX_RX_BAND 0x128 +#define QSERDES_V4_RX_CDR_FREEZE_UP_DN 0x12c +#define QSERDES_V4_RX_CDR_RESET_OVERRIDE 0x130 +#define QSERDES_V4_RX_RX_INTERFACE_MODE 0x134 +#define QSERDES_V4_RX_JITTER_GEN_MODE 0x138 +#define QSERDES_V4_RX_SJ_AMP1 0x13c +#define QSERDES_V4_RX_SJ_AMP2 0x140 +#define QSERDES_V4_RX_SJ_PER1 0x144 +#define QSERDES_V4_RX_SJ_PER2 0x148 +#define QSERDES_V4_RX_PPM_OFFSET1 0x14c +#define QSERDES_V4_RX_PPM_OFFSET2 0x150 +#define QSERDES_V4_RX_SIGN_PPM_PERIOD1 0x154 +#define QSERDES_V4_RX_SIGN_PPM_PERIOD2 0x158 +#define QSERDES_V4_RX_RX_PWM_ENABLE_AND_DATA 0x15c +#define QSERDES_V4_RX_RX_PWM_GEAR1_TIMEOUT_COUNT 0x160 +#define QSERDES_V4_RX_RX_PWM_GEAR2_TIMEOUT_COUNT 0x164 +#define QSERDES_V4_RX_RX_PWM_GEAR3_TIMEOUT_COUNT 0x168 +#define QSERDES_V4_RX_RX_PWM_GEAR4_TIMEOUT_COUNT 0x16c +#define QSERDES_V4_RX_RX_MODE_00_LOW 0x170 +#define QSERDES_V4_RX_RX_MODE_00_HIGH 0x174 +#define QSERDES_V4_RX_RX_MODE_00_HIGH2 0x178 +#define QSERDES_V4_RX_RX_MODE_00_HIGH3 0x17c +#define QSERDES_V4_RX_RX_MODE_00_HIGH4 0x180 +#define QSERDES_V4_RX_RX_MODE_01_LOW 0x184 +#define QSERDES_V4_RX_RX_MODE_01_HIGH 0x188 +#define QSERDES_V4_RX_RX_MODE_01_HIGH2 0x18c +#define QSERDES_V4_RX_RX_MODE_01_HIGH3 0x190 +#define QSERDES_V4_RX_RX_MODE_01_HIGH4 0x194 +#define QSERDES_V4_RX_RX_MODE_10_LOW 0x198 +#define QSERDES_V4_RX_RX_MODE_10_HIGH 0x19c +#define QSERDES_V4_RX_RX_MODE_10_HIGH2 0x1a0 +#define QSERDES_V4_RX_RX_MODE_10_HIGH3 0x1a4 +#define QSERDES_V4_RX_RX_MODE_10_HIGH4 0x1a8 +#define QSERDES_V4_RX_PHPRE_CTRL 0x1ac +#define QSERDES_V4_RX_PHPRE_INITVAL 0x1b0 +#define QSERDES_V4_RX_DFE_EN_TIMER 0x1b4 +#define QSERDES_V4_RX_DFE_CTLE_POST_CAL_OFFSET 0x1b8 +#define QSERDES_V4_RX_DCC_CTRL1 0x1bc +#define QSERDES_V4_RX_DCC_CTRL2 0x1c0 +#define QSERDES_V4_RX_VTH_CODE 0x1c4 +#define QSERDES_V4_RX_VTH_MIN_THRESH 0x1c8 +#define QSERDES_V4_RX_VTH_MAX_THRESH 0x1cc +#define QSERDES_V4_RX_ALOG_OBSV_BUS_CTRL_1 0x1d0 +#define QSERDES_V4_RX_PI_CTRL1 0x1d4 +#define QSERDES_V4_RX_PI_CTRL2 0x1d8 +#define QSERDES_V4_RX_PI_QUAD 0x1dc +#define QSERDES_V4_RX_IDATA1 0x1e0 +#define QSERDES_V4_RX_IDATA2 0x1e4 +#define QSERDES_V4_RX_AUX_DATA1 0x1e8 +#define QSERDES_V4_RX_AUX_DATA2 0x1ec +#define QSERDES_V4_RX_AC_JTAG_OUTP 0x1f0 +#define QSERDES_V4_RX_AC_JTAG_OUTN 0x1f4 +#define QSERDES_V4_RX_RX_SIGDET 0x1f8 +#define QSERDES_V4_RX_ALOG_OBSV_BUS_STATUS_1 0x1fc + +#endif diff --git a/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h new file mode 100644 index 0000000000..d20694513e --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-qserdes-txrx.h @@ -0,0 +1,205 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_QSERDES_TXRX_H_ +#define QCOM_PHY_QMP_QSERDES_TXRX_H_ + +/* Only for QMP V2 PHY - TX registers */ +#define QSERDES_TX_BIST_MODE_LANENO 0x000 +#define QSERDES_TX_BIST_INVERT 0x004 +#define QSERDES_TX_CLKBUF_ENABLE 0x008 +#define QSERDES_TX_CMN_CONTROL_ONE 0x00c +#define QSERDES_TX_CMN_CONTROL_TWO 0x010 +#define QSERDES_TX_CMN_CONTROL_THREE 0x014 +#define QSERDES_TX_TX_EMP_POST1_LVL 0x018 +#define QSERDES_TX_TX_POST2_EMPH 0x01c +#define QSERDES_TX_TX_BOOST_LVL_UP_DN 0x020 +#define QSERDES_TX_HP_PD_ENABLES 0x024 +#define QSERDES_TX_TX_IDLE_LVL_LARGE_AMP 0x028 +#define QSERDES_TX_TX_DRV_LVL 0x02c +#define QSERDES_TX_TX_DRV_LVL_OFFSET 0x030 +#define QSERDES_TX_RESET_TSYNC_EN 0x034 +#define QSERDES_TX_PRE_STALL_LDO_BOOST_EN 0x038 +#define QSERDES_TX_TX_BAND 0x03c +#define QSERDES_TX_SLEW_CNTL 0x040 +#define QSERDES_TX_INTERFACE_SELECT 0x044 +#define QSERDES_TX_LPB_EN 0x048 +#define QSERDES_TX_RES_CODE_LANE_TX 0x04c +#define QSERDES_TX_RES_CODE_LANE_RX 0x050 +#define QSERDES_TX_RES_CODE_LANE_OFFSET 0x054 +#define QSERDES_TX_PERL_LENGTH1 0x058 +#define QSERDES_TX_PERL_LENGTH2 0x05c +#define QSERDES_TX_SERDES_BYP_EN_OUT 0x060 +#define QSERDES_TX_DEBUG_BUS_SEL 0x064 +#define QSERDES_TX_HIGHZ_TRANSCEIVEREN_BIAS_DRVR_EN 0x068 +#define QSERDES_TX_TX_POL_INV 0x06c +#define QSERDES_TX_PARRATE_REC_DETECT_IDLE_EN 0x070 +#define QSERDES_TX_BIST_PATTERN1 0x074 +#define QSERDES_TX_BIST_PATTERN2 0x078 +#define QSERDES_TX_BIST_PATTERN3 0x07c +#define QSERDES_TX_BIST_PATTERN4 0x080 +#define QSERDES_TX_BIST_PATTERN5 0x084 +#define QSERDES_TX_BIST_PATTERN6 0x088 +#define QSERDES_TX_BIST_PATTERN7 0x08c +#define QSERDES_TX_BIST_PATTERN8 0x090 +#define QSERDES_TX_LANE_MODE 0x094 +#define QSERDES_TX_IDAC_CAL_LANE_MODE 0x098 +#define QSERDES_TX_IDAC_CAL_LANE_MODE_CONFIGURATION 0x09c +#define QSERDES_TX_ATB_SEL1 0x0a0 +#define QSERDES_TX_ATB_SEL2 0x0a4 +#define QSERDES_TX_RCV_DETECT_LVL 0x0a8 +#define QSERDES_TX_RCV_DETECT_LVL_2 0x0ac +#define QSERDES_TX_PRBS_SEED1 0x0b0 +#define QSERDES_TX_PRBS_SEED2 0x0b4 +#define QSERDES_TX_PRBS_SEED3 0x0b8 +#define QSERDES_TX_PRBS_SEED4 0x0bc +#define QSERDES_TX_RESET_GEN 0x0c0 +#define QSERDES_TX_RESET_GEN_MUXES 0x0c4 +#define QSERDES_TX_TRAN_DRVR_EMP_EN 0x0c8 +#define QSERDES_TX_TX_INTERFACE_MODE 0x0cc +#define QSERDES_TX_PWM_CTRL 0x0d0 +#define QSERDES_TX_PWM_ENCODED_OR_DATA 0x0d4 +#define QSERDES_TX_PWM_GEAR_1_DIVIDER_BAND2 0x0d8 +#define QSERDES_TX_PWM_GEAR_2_DIVIDER_BAND2 0x0dc +#define QSERDES_TX_PWM_GEAR_3_DIVIDER_BAND2 0x0e0 +#define QSERDES_TX_PWM_GEAR_4_DIVIDER_BAND2 0x0e4 +#define QSERDES_TX_PWM_GEAR_1_DIVIDER_BAND0_1 0x0e8 +#define QSERDES_TX_PWM_GEAR_2_DIVIDER_BAND0_1 0x0ec +#define QSERDES_TX_PWM_GEAR_3_DIVIDER_BAND0_1 0x0f0 +#define QSERDES_TX_PWM_GEAR_4_DIVIDER_BAND0_1 0x0f4 +#define QSERDES_TX_VMODE_CTRL1 0x0f8 +#define QSERDES_TX_VMODE_CTRL2 0x0fc +#define QSERDES_TX_TX_ALOG_INTF_OBSV_CNTL 0x100 +#define QSERDES_TX_BIST_STATUS 0x104 +#define QSERDES_TX_BIST_ERROR_COUNT1 0x108 +#define QSERDES_TX_BIST_ERROR_COUNT2 0x10c +#define QSERDES_TX_TX_ALOG_INTF_OBSV 0x110 + +/* Only for QMP V2 PHY - RX registers */ +#define QSERDES_RX_UCDR_FO_GAIN_HALF 0x000 +#define QSERDES_RX_UCDR_FO_GAIN_QUARTER 0x004 +#define QSERDES_RX_UCDR_FO_GAIN_EIGHTH 0x008 +#define QSERDES_RX_UCDR_FO_GAIN 0x00c +#define QSERDES_RX_UCDR_SO_GAIN_HALF 0x010 +#define QSERDES_RX_UCDR_SO_GAIN_QUARTER 0x014 +#define QSERDES_RX_UCDR_SO_GAIN_EIGHTH 0x018 +#define QSERDES_RX_UCDR_SO_GAIN 0x01c +#define QSERDES_RX_UCDR_SVS_FO_GAIN_HALF 0x020 +#define QSERDES_RX_UCDR_SVS_FO_GAIN_QUARTER 0x024 +#define QSERDES_RX_UCDR_SVS_FO_GAIN_EIGHTH 0x028 +#define QSERDES_RX_UCDR_SVS_FO_GAIN 0x02c +#define QSERDES_RX_UCDR_SVS_SO_GAIN_HALF 0x030 +#define QSERDES_RX_UCDR_SVS_SO_GAIN_QUARTER 0x034 +#define QSERDES_RX_UCDR_SVS_SO_GAIN_EIGHTH 0x038 +#define QSERDES_RX_UCDR_SVS_SO_GAIN 0x03c +#define QSERDES_RX_UCDR_FASTLOCK_FO_GAIN 0x040 +#define QSERDES_RX_UCDR_FD_GAIN 0x044 +#define QSERDES_RX_UCDR_SO_SATURATION_AND_ENABLE 0x048 +#define QSERDES_RX_UCDR_FO_TO_SO_DELAY 0x04c +#define QSERDES_RX_UCDR_FASTLOCK_COUNT_LOW 0x050 +#define QSERDES_RX_UCDR_FASTLOCK_COUNT_HIGH 0x054 +#define QSERDES_RX_UCDR_MODULATE 0x058 +#define QSERDES_RX_UCDR_PI_CONTROLS 0x05c +#define QSERDES_RX_RBIST_CONTROL 0x060 +#define QSERDES_RX_AUX_CONTROL 0x064 +#define QSERDES_RX_AUX_DATA_TCOARSE 0x068 +#define QSERDES_RX_AUX_DATA_TFINE_LSB 0x06c +#define QSERDES_RX_AUX_DATA_TFINE_MSB 0x070 +#define QSERDES_RX_RCLK_AUXDATA_SEL 0x074 +#define QSERDES_RX_AC_JTAG_ENABLE 0x078 +#define QSERDES_RX_AC_JTAG_INITP 0x07c +#define QSERDES_RX_AC_JTAG_INITN 0x080 +#define QSERDES_RX_AC_JTAG_LVL 0x084 +#define QSERDES_RX_AC_JTAG_MODE 0x088 +#define QSERDES_RX_AC_JTAG_RESET 0x08c +#define QSERDES_RX_RX_TERM_BW 0x090 +#define QSERDES_RX_RX_RCVR_IQ_EN 0x094 +#define QSERDES_RX_RX_IDAC_I_DC_OFFSETS 0x098 +#define QSERDES_RX_RX_IDAC_IBAR_DC_OFFSETS 0x09c +#define QSERDES_RX_RX_IDAC_Q_DC_OFFSETS 0x0a0 +#define QSERDES_RX_RX_IDAC_QBAR_DC_OFFSETS 0x0a4 +#define QSERDES_RX_RX_IDAC_A_DC_OFFSETS 0x0a8 +#define QSERDES_RX_RX_IDAC_ABAR_DC_OFFSETS 0x0ac +#define QSERDES_RX_RX_IDAC_EN 0x0b0 +#define QSERDES_RX_RX_IDAC_ENABLES 0x0b4 +#define QSERDES_RX_RX_IDAC_SIGN 0x0b8 +#define QSERDES_RX_RX_HIGHZ_HIGHRATE 0x0bc +#define QSERDES_RX_RX_TERM_AC_BYPASS_DC_COUPLE_OFFSET 0x0c0 +#define QSERDES_RX_RX_EQ_GAIN1_LSB 0x0c4 +#define QSERDES_RX_RX_EQ_GAIN1_MSB 0x0c8 +#define QSERDES_RX_RX_EQ_GAIN2_LSB 0x0cc +#define QSERDES_RX_RX_EQ_GAIN2_MSB 0x0d0 +#define QSERDES_RX_RX_EQU_ADAPTOR_CNTRL1 0x0d4 +#define QSERDES_RX_RX_EQU_ADAPTOR_CNTRL2 0x0d8 +#define QSERDES_RX_RX_EQU_ADAPTOR_CNTRL3 0x0dc +#define QSERDES_RX_RX_EQU_ADAPTOR_CNTRL4 0x0e0 +#define QSERDES_RX_RX_IDAC_CAL_CONFIGURATION 0x0e4 +#define QSERDES_RX_RX_IDAC_TSETTLE_LOW 0x0e8 +#define QSERDES_RX_RX_IDAC_TSETTLE_HIGH 0x0ec +#define QSERDES_RX_RX_IDAC_ENDSAMP_LOW 0x0f0 +#define QSERDES_RX_RX_IDAC_ENDSAMP_HIGH 0x0f4 +#define QSERDES_RX_RX_IDAC_MIDPOINT_LOW 0x0f8 +#define QSERDES_RX_RX_IDAC_MIDPOINT_HIGH 0x0fc +#define QSERDES_RX_RX_EQ_OFFSET_LSB 0x100 +#define QSERDES_RX_RX_EQ_OFFSET_MSB 0x104 +#define QSERDES_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1 0x108 +#define QSERDES_RX_RX_OFFSET_ADAPTOR_CNTRL2 0x10c +#define QSERDES_RX_SIGDET_ENABLES 0x110 +#define QSERDES_RX_SIGDET_CNTRL 0x114 +#define QSERDES_RX_SIGDET_LVL 0x118 +#define QSERDES_RX_SIGDET_DEGLITCH_CNTRL 0x11c +#define QSERDES_RX_RX_BAND 0x120 +#define QSERDES_RX_CDR_FREEZE_UP_DN 0x124 +#define QSERDES_RX_CDR_RESET_OVERRIDE 0x128 +#define QSERDES_RX_RX_INTERFACE_MODE 0x12c +#define QSERDES_RX_JITTER_GEN_MODE 0x130 +#define QSERDES_RX_BUJ_AMP 0x134 +#define QSERDES_RX_SJ_AMP1 0x138 +#define QSERDES_RX_SJ_AMP2 0x13c +#define QSERDES_RX_SJ_PER1 0x140 +#define QSERDES_RX_SJ_PER2 0x144 +#define QSERDES_RX_BUJ_STEP_FREQ1 0x148 +#define QSERDES_RX_BUJ_STEP_FREQ2 0x14c +#define QSERDES_RX_PPM_OFFSET1 0x150 +#define QSERDES_RX_PPM_OFFSET2 0x154 +#define QSERDES_RX_SIGN_PPM_PERIOD1 0x158 +#define QSERDES_RX_SIGN_PPM_PERIOD2 0x15c +#define QSERDES_RX_SSC_CTRL 0x160 +#define QSERDES_RX_SSC_COUNT1 0x164 +#define QSERDES_RX_SSC_COUNT2 0x168 +#define QSERDES_RX_RX_ALOG_INTF_OBSV_CNTL 0x16c +#define QSERDES_RX_RX_PWM_ENABLE_AND_DATA 0x170 +#define QSERDES_RX_RX_PWM_GEAR1_TIMEOUT_COUNT 0x174 +#define QSERDES_RX_RX_PWM_GEAR2_TIMEOUT_COUNT 0x178 +#define QSERDES_RX_RX_PWM_GEAR3_TIMEOUT_COUNT 0x17c +#define QSERDES_RX_RX_PWM_GEAR4_TIMEOUT_COUNT 0x180 +#define QSERDES_RX_PI_CTRL1 0x184 +#define QSERDES_RX_PI_CTRL2 0x188 +#define QSERDES_RX_PI_QUAD 0x18c +#define QSERDES_RX_IDATA1 0x190 +#define QSERDES_RX_IDATA2 0x194 +#define QSERDES_RX_AUX_DATA1 0x198 +#define QSERDES_RX_AUX_DATA2 0x19c +#define QSERDES_RX_AC_JTAG_OUTP 0x1a0 +#define QSERDES_RX_AC_JTAG_OUTN 0x1a4 +#define QSERDES_RX_RX_SIGDET 0x1a8 +#define QSERDES_RX_RX_VDCOFF 0x1ac +#define QSERDES_RX_IDAC_CAL_ON 0x1b0 +#define QSERDES_RX_IDAC_STATUS_I 0x1b4 +#define QSERDES_RX_IDAC_STATUS_IBAR 0x1b8 +#define QSERDES_RX_IDAC_STATUS_Q 0x1bc +#define QSERDES_RX_IDAC_STATUS_QBAR 0x1c0 +#define QSERDES_RX_IDAC_STATUS_A 0x1c4 +#define QSERDES_RX_IDAC_STATUS_ABAR 0x1c8 +#define QSERDES_RX_CALST_STATUS_I 0x1cc +#define QSERDES_RX_CALST_STATUS_Q 0x1d0 +#define QSERDES_RX_CALST_STATUS_A 0x1d4 +#define QSERDES_RX_RX_ALOG_INTF_OBSV 0x1d8 +#define QSERDES_RX_READ_EQCODE 0x1dc +#define QSERDES_RX_READ_OFFSETCODE 0x1e0 +#define QSERDES_RX_IA_ERROR_COUNTER_LOW 0x1e4 +#define QSERDES_RX_IA_ERROR_COUNTER_HIGH 0x1e8 + +#endif
Import SM6115 and SM8250 related clock header files from Linux, which would be included in the Qualcomm QMP PHY driver.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- include/dt-bindings/clock/qcom,gcc-sm6115.h | 201 +++++++++++++++ include/dt-bindings/clock/qcom,gcc-sm8250.h | 271 ++++++++++++++++++++ 2 files changed, 472 insertions(+) create mode 100644 include/dt-bindings/clock/qcom,gcc-sm6115.h create mode 100644 include/dt-bindings/clock/qcom,gcc-sm8250.h
diff --git a/include/dt-bindings/clock/qcom,gcc-sm6115.h b/include/dt-bindings/clock/qcom,gcc-sm6115.h new file mode 100644 index 0000000000..b91a7b4604 --- /dev/null +++ b/include/dt-bindings/clock/qcom,gcc-sm6115.h @@ -0,0 +1,201 @@ +/* SPDX-License-Identifier: (GPL-2.0-only OR BSD-2-Clause) */ +/* + * Copyright (c) 2019-2021, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_QCOM_GCC_SM6115_H +#define _DT_BINDINGS_CLK_QCOM_GCC_SM6115_H + +/* GCC clocks */ +#define GPLL0 0 +#define GPLL0_OUT_AUX2 1 +#define GPLL0_OUT_MAIN 2 +#define GPLL10 3 +#define GPLL10_OUT_MAIN 4 +#define GPLL11 5 +#define GPLL11_OUT_MAIN 6 +#define GPLL3 7 +#define GPLL4 8 +#define GPLL4_OUT_MAIN 9 +#define GPLL6 10 +#define GPLL6_OUT_MAIN 11 +#define GPLL7 12 +#define GPLL7_OUT_MAIN 13 +#define GPLL8 14 +#define GPLL8_OUT_MAIN 15 +#define GPLL9 16 +#define GPLL9_OUT_MAIN 17 +#define GCC_CAMSS_CSI0PHYTIMER_CLK 18 +#define GCC_CAMSS_CSI0PHYTIMER_CLK_SRC 19 +#define GCC_CAMSS_CSI1PHYTIMER_CLK 20 +#define GCC_CAMSS_CSI1PHYTIMER_CLK_SRC 21 +#define GCC_CAMSS_CSI2PHYTIMER_CLK 22 +#define GCC_CAMSS_CSI2PHYTIMER_CLK_SRC 23 +#define GCC_CAMSS_MCLK0_CLK 24 +#define GCC_CAMSS_MCLK0_CLK_SRC 25 +#define GCC_CAMSS_MCLK1_CLK 26 +#define GCC_CAMSS_MCLK1_CLK_SRC 27 +#define GCC_CAMSS_MCLK2_CLK 28 +#define GCC_CAMSS_MCLK2_CLK_SRC 29 +#define GCC_CAMSS_MCLK3_CLK 30 +#define GCC_CAMSS_MCLK3_CLK_SRC 31 +#define GCC_CAMSS_NRT_AXI_CLK 32 +#define GCC_CAMSS_OPE_AHB_CLK 33 +#define GCC_CAMSS_OPE_AHB_CLK_SRC 34 +#define GCC_CAMSS_OPE_CLK 35 +#define GCC_CAMSS_OPE_CLK_SRC 36 +#define GCC_CAMSS_RT_AXI_CLK 37 +#define GCC_CAMSS_TFE_0_CLK 38 +#define GCC_CAMSS_TFE_0_CLK_SRC 39 +#define GCC_CAMSS_TFE_0_CPHY_RX_CLK 40 +#define GCC_CAMSS_TFE_0_CSID_CLK 41 +#define GCC_CAMSS_TFE_0_CSID_CLK_SRC 42 +#define GCC_CAMSS_TFE_1_CLK 43 +#define GCC_CAMSS_TFE_1_CLK_SRC 44 +#define GCC_CAMSS_TFE_1_CPHY_RX_CLK 45 +#define GCC_CAMSS_TFE_1_CSID_CLK 46 +#define GCC_CAMSS_TFE_1_CSID_CLK_SRC 47 +#define GCC_CAMSS_TFE_2_CLK 48 +#define GCC_CAMSS_TFE_2_CLK_SRC 49 +#define GCC_CAMSS_TFE_2_CPHY_RX_CLK 50 +#define GCC_CAMSS_TFE_2_CSID_CLK 51 +#define GCC_CAMSS_TFE_2_CSID_CLK_SRC 52 +#define GCC_CAMSS_TFE_CPHY_RX_CLK_SRC 53 +#define GCC_CAMSS_TOP_AHB_CLK 54 +#define GCC_CAMSS_TOP_AHB_CLK_SRC 55 +#define GCC_CFG_NOC_USB3_PRIM_AXI_CLK 56 +#define GCC_CPUSS_AHB_CLK 57 +#define GCC_CPUSS_GNOC_CLK 60 +#define GCC_DISP_AHB_CLK 61 +#define GCC_DISP_GPLL0_DIV_CLK_SRC 62 +#define GCC_DISP_HF_AXI_CLK 63 +#define GCC_DISP_THROTTLE_CORE_CLK 64 +#define GCC_DISP_XO_CLK 65 +#define GCC_GP1_CLK 66 +#define GCC_GP1_CLK_SRC 67 +#define GCC_GP2_CLK 68 +#define GCC_GP2_CLK_SRC 69 +#define GCC_GP3_CLK 70 +#define GCC_GP3_CLK_SRC 71 +#define GCC_GPU_CFG_AHB_CLK 72 +#define GCC_GPU_GPLL0_CLK_SRC 73 +#define GCC_GPU_GPLL0_DIV_CLK_SRC 74 +#define GCC_GPU_IREF_CLK 75 +#define GCC_GPU_MEMNOC_GFX_CLK 76 +#define GCC_GPU_SNOC_DVM_GFX_CLK 77 +#define GCC_GPU_THROTTLE_CORE_CLK 78 +#define GCC_GPU_THROTTLE_XO_CLK 79 +#define GCC_PDM2_CLK 80 +#define GCC_PDM2_CLK_SRC 81 +#define GCC_PDM_AHB_CLK 82 +#define GCC_PDM_XO4_CLK 83 +#define GCC_PRNG_AHB_CLK 84 +#define GCC_QMIP_CAMERA_NRT_AHB_CLK 85 +#define GCC_QMIP_CAMERA_RT_AHB_CLK 86 +#define GCC_QMIP_DISP_AHB_CLK 87 +#define GCC_QMIP_GPU_CFG_AHB_CLK 88 +#define GCC_QMIP_VIDEO_VCODEC_AHB_CLK 89 +#define GCC_QUPV3_WRAP0_CORE_2X_CLK 90 +#define GCC_QUPV3_WRAP0_CORE_CLK 91 +#define GCC_QUPV3_WRAP0_S0_CLK 92 +#define GCC_QUPV3_WRAP0_S0_CLK_SRC 93 +#define GCC_QUPV3_WRAP0_S1_CLK 94 +#define GCC_QUPV3_WRAP0_S1_CLK_SRC 95 +#define GCC_QUPV3_WRAP0_S2_CLK 96 +#define GCC_QUPV3_WRAP0_S2_CLK_SRC 97 +#define GCC_QUPV3_WRAP0_S3_CLK 98 +#define GCC_QUPV3_WRAP0_S3_CLK_SRC 99 +#define GCC_QUPV3_WRAP0_S4_CLK 100 +#define GCC_QUPV3_WRAP0_S4_CLK_SRC 101 +#define GCC_QUPV3_WRAP0_S5_CLK 102 +#define GCC_QUPV3_WRAP0_S5_CLK_SRC 103 +#define GCC_QUPV3_WRAP_0_M_AHB_CLK 104 +#define GCC_QUPV3_WRAP_0_S_AHB_CLK 105 +#define GCC_SDCC1_AHB_CLK 106 +#define GCC_SDCC1_APPS_CLK 107 +#define GCC_SDCC1_APPS_CLK_SRC 108 +#define GCC_SDCC1_ICE_CORE_CLK 109 +#define GCC_SDCC1_ICE_CORE_CLK_SRC 110 +#define GCC_SDCC2_AHB_CLK 111 +#define GCC_SDCC2_APPS_CLK 112 +#define GCC_SDCC2_APPS_CLK_SRC 113 +#define GCC_SYS_NOC_CPUSS_AHB_CLK 114 +#define GCC_SYS_NOC_UFS_PHY_AXI_CLK 115 +#define GCC_SYS_NOC_USB3_PRIM_AXI_CLK 116 +#define GCC_UFS_PHY_AHB_CLK 117 +#define GCC_UFS_PHY_AXI_CLK 118 +#define GCC_UFS_PHY_AXI_CLK_SRC 119 +#define GCC_UFS_PHY_ICE_CORE_CLK 120 +#define GCC_UFS_PHY_ICE_CORE_CLK_SRC 121 +#define GCC_UFS_PHY_PHY_AUX_CLK 122 +#define GCC_UFS_PHY_PHY_AUX_CLK_SRC 123 +#define GCC_UFS_PHY_RX_SYMBOL_0_CLK 124 +#define GCC_UFS_PHY_TX_SYMBOL_0_CLK 125 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK 126 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK_SRC 127 +#define GCC_USB30_PRIM_MASTER_CLK 128 +#define GCC_USB30_PRIM_MASTER_CLK_SRC 129 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK 130 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK_SRC 131 +#define GCC_USB30_PRIM_MOCK_UTMI_POSTDIV_CLK_SRC 132 +#define GCC_USB30_PRIM_SLEEP_CLK 133 +#define GCC_USB3_PRIM_CLKREF_CLK 134 +#define GCC_USB3_PRIM_PHY_AUX_CLK_SRC 135 +#define GCC_USB3_PRIM_PHY_COM_AUX_CLK 136 +#define GCC_USB3_PRIM_PHY_PIPE_CLK 137 +#define GCC_VCODEC0_AXI_CLK 138 +#define GCC_VENUS_AHB_CLK 139 +#define GCC_VENUS_CTL_AXI_CLK 140 +#define GCC_VIDEO_AHB_CLK 141 +#define GCC_VIDEO_AXI0_CLK 142 +#define GCC_VIDEO_THROTTLE_CORE_CLK 143 +#define GCC_VIDEO_VCODEC0_SYS_CLK 144 +#define GCC_VIDEO_VENUS_CLK_SRC 145 +#define GCC_VIDEO_VENUS_CTL_CLK 146 +#define GCC_VIDEO_XO_CLK 147 +#define GCC_AHB2PHY_CSI_CLK 148 +#define GCC_AHB2PHY_USB_CLK 149 +#define GCC_BIMC_GPU_AXI_CLK 150 +#define GCC_BOOT_ROM_AHB_CLK 151 +#define GCC_CAM_THROTTLE_NRT_CLK 152 +#define GCC_CAM_THROTTLE_RT_CLK 153 +#define GCC_CAMERA_AHB_CLK 154 +#define GCC_CAMERA_XO_CLK 155 +#define GCC_CAMSS_AXI_CLK 156 +#define GCC_CAMSS_AXI_CLK_SRC 157 +#define GCC_CAMSS_CAMNOC_ATB_CLK 158 +#define GCC_CAMSS_CAMNOC_NTS_XO_CLK 159 +#define GCC_CAMSS_CCI_0_CLK 160 +#define GCC_CAMSS_CCI_CLK_SRC 161 +#define GCC_CAMSS_CPHY_0_CLK 162 +#define GCC_CAMSS_CPHY_1_CLK 163 +#define GCC_CAMSS_CPHY_2_CLK 164 +#define GCC_UFS_CLKREF_CLK 165 +#define GCC_DISP_GPLL0_CLK_SRC 166 + +/* GCC resets */ +#define GCC_QUSB2PHY_PRIM_BCR 0 +#define GCC_QUSB2PHY_SEC_BCR 1 +#define GCC_SDCC1_BCR 2 +#define GCC_UFS_PHY_BCR 3 +#define GCC_USB30_PRIM_BCR 4 +#define GCC_USB_PHY_CFG_AHB2PHY_BCR 5 +#define GCC_VCODEC0_BCR 6 +#define GCC_VENUS_BCR 7 +#define GCC_VIDEO_INTERFACE_BCR 8 +#define GCC_USB3PHY_PHY_PRIM_SP0_BCR 9 +#define GCC_USB3_PHY_PRIM_SP0_BCR 10 +#define GCC_SDCC2_BCR 11 + +/* Indexes for GDSCs */ +#define GCC_CAMSS_TOP_GDSC 0 +#define GCC_UFS_PHY_GDSC 1 +#define GCC_USB30_PRIM_GDSC 2 +#define GCC_VCODEC0_GDSC 3 +#define GCC_VENUS_GDSC 4 +#define HLOS1_VOTE_TURING_MMU_TBU1_GDSC 5 +#define HLOS1_VOTE_TURING_MMU_TBU0_GDSC 6 +#define HLOS1_VOTE_MM_SNOC_MMU_TBU_RT_GDSC 7 +#define HLOS1_VOTE_MM_SNOC_MMU_TBU_NRT_GDSC 8 + +#endif diff --git a/include/dt-bindings/clock/qcom,gcc-sm8250.h b/include/dt-bindings/clock/qcom,gcc-sm8250.h new file mode 100644 index 0000000000..7b7abe327e --- /dev/null +++ b/include/dt-bindings/clock/qcom,gcc-sm8250.h @@ -0,0 +1,271 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright (c) 2020, The Linux Foundation. All rights reserved. + */ + +#ifndef _DT_BINDINGS_CLK_QCOM_GCC_SM8250_H +#define _DT_BINDINGS_CLK_QCOM_GCC_SM8250_H + +/* GCC clocks */ +#define GPLL0 0 +#define GPLL0_OUT_EVEN 1 +#define GPLL4 2 +#define GPLL9 3 +#define GCC_AGGRE_NOC_PCIE_TBU_CLK 4 +#define GCC_AGGRE_UFS_CARD_AXI_CLK 5 +#define GCC_AGGRE_UFS_PHY_AXI_CLK 6 +#define GCC_AGGRE_USB3_PRIM_AXI_CLK 7 +#define GCC_AGGRE_USB3_SEC_AXI_CLK 8 +#define GCC_BOOT_ROM_AHB_CLK 9 +#define GCC_CAMERA_AHB_CLK 10 +#define GCC_CAMERA_HF_AXI_CLK 11 +#define GCC_CAMERA_SF_AXI_CLK 12 +#define GCC_CAMERA_XO_CLK 13 +#define GCC_CFG_NOC_USB3_PRIM_AXI_CLK 14 +#define GCC_CFG_NOC_USB3_SEC_AXI_CLK 15 +#define GCC_CPUSS_AHB_CLK 16 +#define GCC_CPUSS_AHB_CLK_SRC 17 +#define GCC_CPUSS_AHB_POSTDIV_CLK_SRC 18 +#define GCC_CPUSS_DVM_BUS_CLK 19 +#define GCC_CPUSS_RBCPR_CLK 20 +#define GCC_DDRSS_GPU_AXI_CLK 21 +#define GCC_DDRSS_PCIE_SF_TBU_CLK 22 +#define GCC_DISP_AHB_CLK 23 +#define GCC_DISP_HF_AXI_CLK 24 +#define GCC_DISP_SF_AXI_CLK 25 +#define GCC_DISP_XO_CLK 26 +#define GCC_GP1_CLK 27 +#define GCC_GP1_CLK_SRC 28 +#define GCC_GP2_CLK 29 +#define GCC_GP2_CLK_SRC 30 +#define GCC_GP3_CLK 31 +#define GCC_GP3_CLK_SRC 32 +#define GCC_GPU_CFG_AHB_CLK 33 +#define GCC_GPU_GPLL0_CLK_SRC 34 +#define GCC_GPU_GPLL0_DIV_CLK_SRC 35 +#define GCC_GPU_IREF_EN 36 +#define GCC_GPU_MEMNOC_GFX_CLK 37 +#define GCC_GPU_SNOC_DVM_GFX_CLK 38 +#define GCC_NPU_AXI_CLK 39 +#define GCC_NPU_BWMON_AXI_CLK 40 +#define GCC_NPU_BWMON_CFG_AHB_CLK 41 +#define GCC_NPU_CFG_AHB_CLK 42 +#define GCC_NPU_DMA_CLK 43 +#define GCC_NPU_GPLL0_CLK_SRC 44 +#define GCC_NPU_GPLL0_DIV_CLK_SRC 45 +#define GCC_PCIE0_PHY_REFGEN_CLK 46 +#define GCC_PCIE1_PHY_REFGEN_CLK 47 +#define GCC_PCIE2_PHY_REFGEN_CLK 48 +#define GCC_PCIE_0_AUX_CLK 49 +#define GCC_PCIE_0_AUX_CLK_SRC 50 +#define GCC_PCIE_0_CFG_AHB_CLK 51 +#define GCC_PCIE_0_MSTR_AXI_CLK 52 +#define GCC_PCIE_0_PIPE_CLK 53 +#define GCC_PCIE_0_SLV_AXI_CLK 54 +#define GCC_PCIE_0_SLV_Q2A_AXI_CLK 55 +#define GCC_PCIE_1_AUX_CLK 56 +#define GCC_PCIE_1_AUX_CLK_SRC 57 +#define GCC_PCIE_1_CFG_AHB_CLK 58 +#define GCC_PCIE_1_MSTR_AXI_CLK 59 +#define GCC_PCIE_1_PIPE_CLK 60 +#define GCC_PCIE_1_SLV_AXI_CLK 61 +#define GCC_PCIE_1_SLV_Q2A_AXI_CLK 62 +#define GCC_PCIE_2_AUX_CLK 63 +#define GCC_PCIE_2_AUX_CLK_SRC 64 +#define GCC_PCIE_2_CFG_AHB_CLK 65 +#define GCC_PCIE_2_MSTR_AXI_CLK 66 +#define GCC_PCIE_2_PIPE_CLK 67 +#define GCC_PCIE_2_SLV_AXI_CLK 68 +#define GCC_PCIE_2_SLV_Q2A_AXI_CLK 69 +#define GCC_PCIE_MDM_CLKREF_EN 70 +#define GCC_PCIE_PHY_AUX_CLK 71 +#define GCC_PCIE_PHY_REFGEN_CLK_SRC 72 +#define GCC_PCIE_WIFI_CLKREF_EN 73 +#define GCC_PCIE_WIGIG_CLKREF_EN 74 +#define GCC_PDM2_CLK 75 +#define GCC_PDM2_CLK_SRC 76 +#define GCC_PDM_AHB_CLK 77 +#define GCC_PDM_XO4_CLK 78 +#define GCC_PRNG_AHB_CLK 79 +#define GCC_QMIP_CAMERA_NRT_AHB_CLK 80 +#define GCC_QMIP_CAMERA_RT_AHB_CLK 81 +#define GCC_QMIP_DISP_AHB_CLK 82 +#define GCC_QMIP_VIDEO_CVP_AHB_CLK 83 +#define GCC_QMIP_VIDEO_VCODEC_AHB_CLK 84 +#define GCC_QUPV3_WRAP0_CORE_2X_CLK 85 +#define GCC_QUPV3_WRAP0_CORE_CLK 86 +#define GCC_QUPV3_WRAP0_S0_CLK 87 +#define GCC_QUPV3_WRAP0_S0_CLK_SRC 88 +#define GCC_QUPV3_WRAP0_S1_CLK 89 +#define GCC_QUPV3_WRAP0_S1_CLK_SRC 90 +#define GCC_QUPV3_WRAP0_S2_CLK 91 +#define GCC_QUPV3_WRAP0_S2_CLK_SRC 92 +#define GCC_QUPV3_WRAP0_S3_CLK 93 +#define GCC_QUPV3_WRAP0_S3_CLK_SRC 94 +#define GCC_QUPV3_WRAP0_S4_CLK 95 +#define GCC_QUPV3_WRAP0_S4_CLK_SRC 96 +#define GCC_QUPV3_WRAP0_S5_CLK 97 +#define GCC_QUPV3_WRAP0_S5_CLK_SRC 98 +#define GCC_QUPV3_WRAP0_S6_CLK 99 +#define GCC_QUPV3_WRAP0_S6_CLK_SRC 100 +#define GCC_QUPV3_WRAP0_S7_CLK 101 +#define GCC_QUPV3_WRAP0_S7_CLK_SRC 102 +#define GCC_QUPV3_WRAP1_CORE_2X_CLK 103 +#define GCC_QUPV3_WRAP1_CORE_CLK 104 +#define GCC_QUPV3_WRAP1_S0_CLK 105 +#define GCC_QUPV3_WRAP1_S0_CLK_SRC 106 +#define GCC_QUPV3_WRAP1_S1_CLK 107 +#define GCC_QUPV3_WRAP1_S1_CLK_SRC 108 +#define GCC_QUPV3_WRAP1_S2_CLK 109 +#define GCC_QUPV3_WRAP1_S2_CLK_SRC 110 +#define GCC_QUPV3_WRAP1_S3_CLK 111 +#define GCC_QUPV3_WRAP1_S3_CLK_SRC 112 +#define GCC_QUPV3_WRAP1_S4_CLK 113 +#define GCC_QUPV3_WRAP1_S4_CLK_SRC 114 +#define GCC_QUPV3_WRAP1_S5_CLK 115 +#define GCC_QUPV3_WRAP1_S5_CLK_SRC 116 +#define GCC_QUPV3_WRAP2_CORE_2X_CLK 117 +#define GCC_QUPV3_WRAP2_CORE_CLK 118 +#define GCC_QUPV3_WRAP2_S0_CLK 119 +#define GCC_QUPV3_WRAP2_S0_CLK_SRC 120 +#define GCC_QUPV3_WRAP2_S1_CLK 121 +#define GCC_QUPV3_WRAP2_S1_CLK_SRC 122 +#define GCC_QUPV3_WRAP2_S2_CLK 123 +#define GCC_QUPV3_WRAP2_S2_CLK_SRC 124 +#define GCC_QUPV3_WRAP2_S3_CLK 125 +#define GCC_QUPV3_WRAP2_S3_CLK_SRC 126 +#define GCC_QUPV3_WRAP2_S4_CLK 127 +#define GCC_QUPV3_WRAP2_S4_CLK_SRC 128 +#define GCC_QUPV3_WRAP2_S5_CLK 129 +#define GCC_QUPV3_WRAP2_S5_CLK_SRC 130 +#define GCC_QUPV3_WRAP_0_M_AHB_CLK 131 +#define GCC_QUPV3_WRAP_0_S_AHB_CLK 132 +#define GCC_QUPV3_WRAP_1_M_AHB_CLK 133 +#define GCC_QUPV3_WRAP_1_S_AHB_CLK 134 +#define GCC_QUPV3_WRAP_2_M_AHB_CLK 135 +#define GCC_QUPV3_WRAP_2_S_AHB_CLK 136 +#define GCC_SDCC2_AHB_CLK 137 +#define GCC_SDCC2_APPS_CLK 138 +#define GCC_SDCC2_APPS_CLK_SRC 139 +#define GCC_SDCC4_AHB_CLK 140 +#define GCC_SDCC4_APPS_CLK 141 +#define GCC_SDCC4_APPS_CLK_SRC 142 +#define GCC_SYS_NOC_CPUSS_AHB_CLK 143 +#define GCC_TSIF_AHB_CLK 144 +#define GCC_TSIF_INACTIVITY_TIMERS_CLK 145 +#define GCC_TSIF_REF_CLK 146 +#define GCC_TSIF_REF_CLK_SRC 147 +#define GCC_UFS_1X_CLKREF_EN 148 +#define GCC_UFS_CARD_AHB_CLK 149 +#define GCC_UFS_CARD_AXI_CLK 150 +#define GCC_UFS_CARD_AXI_CLK_SRC 151 +#define GCC_UFS_CARD_ICE_CORE_CLK 152 +#define GCC_UFS_CARD_ICE_CORE_CLK_SRC 153 +#define GCC_UFS_CARD_PHY_AUX_CLK 154 +#define GCC_UFS_CARD_PHY_AUX_CLK_SRC 155 +#define GCC_UFS_CARD_RX_SYMBOL_0_CLK 156 +#define GCC_UFS_CARD_RX_SYMBOL_1_CLK 157 +#define GCC_UFS_CARD_TX_SYMBOL_0_CLK 158 +#define GCC_UFS_CARD_UNIPRO_CORE_CLK 159 +#define GCC_UFS_CARD_UNIPRO_CORE_CLK_SRC 160 +#define GCC_UFS_PHY_AHB_CLK 161 +#define GCC_UFS_PHY_AXI_CLK 162 +#define GCC_UFS_PHY_AXI_CLK_SRC 163 +#define GCC_UFS_PHY_ICE_CORE_CLK 164 +#define GCC_UFS_PHY_ICE_CORE_CLK_SRC 165 +#define GCC_UFS_PHY_PHY_AUX_CLK 166 +#define GCC_UFS_PHY_PHY_AUX_CLK_SRC 167 +#define GCC_UFS_PHY_RX_SYMBOL_0_CLK 168 +#define GCC_UFS_PHY_RX_SYMBOL_1_CLK 169 +#define GCC_UFS_PHY_TX_SYMBOL_0_CLK 170 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK 171 +#define GCC_UFS_PHY_UNIPRO_CORE_CLK_SRC 172 +#define GCC_USB30_PRIM_MASTER_CLK 173 +#define GCC_USB30_PRIM_MASTER_CLK_SRC 174 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK 175 +#define GCC_USB30_PRIM_MOCK_UTMI_CLK_SRC 176 +#define GCC_USB30_PRIM_MOCK_UTMI_POSTDIV_CLK_SRC 177 +#define GCC_USB30_PRIM_SLEEP_CLK 178 +#define GCC_USB30_SEC_MASTER_CLK 179 +#define GCC_USB30_SEC_MASTER_CLK_SRC 180 +#define GCC_USB30_SEC_MOCK_UTMI_CLK 181 +#define GCC_USB30_SEC_MOCK_UTMI_CLK_SRC 182 +#define GCC_USB30_SEC_MOCK_UTMI_POSTDIV_CLK_SRC 183 +#define GCC_USB30_SEC_SLEEP_CLK 184 +#define GCC_USB3_PRIM_PHY_AUX_CLK 185 +#define GCC_USB3_PRIM_PHY_AUX_CLK_SRC 186 +#define GCC_USB3_PRIM_PHY_COM_AUX_CLK 187 +#define GCC_USB3_PRIM_PHY_PIPE_CLK 188 +#define GCC_USB3_PRIM_PHY_PIPE_CLK_SRC 189 +#define GCC_USB3_SEC_CLKREF_EN 190 +#define GCC_USB3_SEC_PHY_AUX_CLK 191 +#define GCC_USB3_SEC_PHY_AUX_CLK_SRC 192 +#define GCC_USB3_SEC_PHY_COM_AUX_CLK 193 +#define GCC_USB3_SEC_PHY_PIPE_CLK 194 +#define GCC_USB3_SEC_PHY_PIPE_CLK_SRC 195 +#define GCC_VIDEO_AHB_CLK 196 +#define GCC_VIDEO_AXI0_CLK 197 +#define GCC_VIDEO_AXI1_CLK 198 +#define GCC_VIDEO_XO_CLK 199 + +/* GCC resets */ +#define GCC_GPU_BCR 0 +#define GCC_MMSS_BCR 1 +#define GCC_NPU_BWMON_BCR 2 +#define GCC_NPU_BCR 3 +#define GCC_PCIE_0_BCR 4 +#define GCC_PCIE_0_LINK_DOWN_BCR 5 +#define GCC_PCIE_0_NOCSR_COM_PHY_BCR 6 +#define GCC_PCIE_0_PHY_BCR 7 +#define GCC_PCIE_0_PHY_NOCSR_COM_PHY_BCR 8 +#define GCC_PCIE_1_BCR 9 +#define GCC_PCIE_1_LINK_DOWN_BCR 10 +#define GCC_PCIE_1_NOCSR_COM_PHY_BCR 11 +#define GCC_PCIE_1_PHY_BCR 12 +#define GCC_PCIE_1_PHY_NOCSR_COM_PHY_BCR 13 +#define GCC_PCIE_2_BCR 14 +#define GCC_PCIE_2_LINK_DOWN_BCR 15 +#define GCC_PCIE_2_NOCSR_COM_PHY_BCR 16 +#define GCC_PCIE_2_PHY_BCR 17 +#define GCC_PCIE_2_PHY_NOCSR_COM_PHY_BCR 18 +#define GCC_PCIE_PHY_BCR 19 +#define GCC_PCIE_PHY_CFG_AHB_BCR 20 +#define GCC_PCIE_PHY_COM_BCR 21 +#define GCC_PDM_BCR 22 +#define GCC_PRNG_BCR 23 +#define GCC_QUPV3_WRAPPER_0_BCR 24 +#define GCC_QUPV3_WRAPPER_1_BCR 25 +#define GCC_QUPV3_WRAPPER_2_BCR 26 +#define GCC_QUSB2PHY_PRIM_BCR 27 +#define GCC_QUSB2PHY_SEC_BCR 28 +#define GCC_SDCC2_BCR 29 +#define GCC_SDCC4_BCR 30 +#define GCC_TSIF_BCR 31 +#define GCC_UFS_CARD_BCR 32 +#define GCC_UFS_PHY_BCR 33 +#define GCC_USB30_PRIM_BCR 34 +#define GCC_USB30_SEC_BCR 35 +#define GCC_USB3_DP_PHY_PRIM_BCR 36 +#define GCC_USB3_DP_PHY_SEC_BCR 37 +#define GCC_USB3_PHY_PRIM_BCR 38 +#define GCC_USB3_PHY_SEC_BCR 39 +#define GCC_USB3PHY_PHY_PRIM_BCR 40 +#define GCC_USB3PHY_PHY_SEC_BCR 41 +#define GCC_USB_PHY_CFG_AHB2PHY_BCR 42 +#define GCC_VIDEO_AXI0_CLK_ARES 43 +#define GCC_VIDEO_AXI1_CLK_ARES 44 + +/* GCC power domains */ +#define PCIE_0_GDSC 0 +#define PCIE_1_GDSC 1 +#define PCIE_2_GDSC 2 +#define UFS_CARD_GDSC 3 +#define UFS_PHY_GDSC 4 +#define USB30_PRIM_GDSC 5 +#define USB30_SEC_GDSC 6 +#define HLOS1_VOTE_MMNOC_MMU_TBU_HF0_GDSC 7 +#define HLOS1_VOTE_MMNOC_MMU_TBU_HF1_GDSC 8 +#define HLOS1_VOTE_MMNOC_MMU_TBU_SF0_GDSC 9 +#define HLOS1_VOTE_MMNOC_MMU_TBU_SF1_GDSC 10 + +#endif
Add Qualcomm QMP UFS PHY driver which is available on the following Snapdragon SoCs - SDM845, SM6115 and SM8250 SoCs.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/phy/qcom/Kconfig | 6 + drivers/phy/qcom/Makefile | 1 + drivers/phy/qcom/phy-qcom-qmp-ufs.c | 996 ++++++++++++++++++++++++++++ drivers/phy/qcom/phy-qcom-qmp.h | 115 ++++ 4 files changed, 1118 insertions(+) create mode 100644 drivers/phy/qcom/phy-qcom-qmp-ufs.c create mode 100644 drivers/phy/qcom/phy-qcom-qmp.h
diff --git a/drivers/phy/qcom/Kconfig b/drivers/phy/qcom/Kconfig index f4ca174805..38536566ca 100644 --- a/drivers/phy/qcom/Kconfig +++ b/drivers/phy/qcom/Kconfig @@ -12,6 +12,12 @@ config PHY_QCOM_IPQ4019_USB help Support for the USB PHY-s on Qualcomm IPQ40xx SoC-s.
+config PHY_QCOM_QMP_UFS + tristate "Qualcomm QMP UFS PHY driver" + depends on PHY && ARCH_SNAPDRAGON + help + Enable this to support the UFS QMP PHY on various Qualcomm chipsets. + config PHY_QCOM_USB_HS_28NM tristate "Qualcomm 28nm High-Speed PHY" depends on PHY && ARCH_SNAPDRAGON diff --git a/drivers/phy/qcom/Makefile b/drivers/phy/qcom/Makefile index 2113f178c0..e804f127b0 100644 --- a/drivers/phy/qcom/Makefile +++ b/drivers/phy/qcom/Makefile @@ -1,4 +1,5 @@ obj-$(CONFIG_PHY_QCOM_IPQ4019_USB) += phy-qcom-ipq4019-usb.o obj-$(CONFIG_MSM8916_USB_PHY) += msm8916-usbh-phy.o +obj-$(CONFIG_PHY_QCOM_QMP_UFS) += phy-qcom-qmp-ufs.o obj-$(CONFIG_PHY_QCOM_USB_HS_28NM) += phy-qcom-usb-hs-28nm.o obj-$(CONFIG_PHY_QCOM_USB_SS) += phy-qcom-usb-ss.o diff --git a/drivers/phy/qcom/phy-qcom-qmp-ufs.c b/drivers/phy/qcom/phy-qcom-qmp-ufs.c new file mode 100644 index 0000000000..16e95175bb --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp-ufs.c @@ -0,0 +1,996 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Bhupesh Sharma bhupesh.sharma@linaro.org + * + * Based on Linux driver + */ + +#include <clk.h> +#include <clk-uclass.h> +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dm/devres.h> +#include <generic-phy.h> +#include <malloc.h> +#include <reset.h> + +#include <asm/io.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> + +#include <dt-bindings/clock/qcom,gcc-sm6115.h> + +#include "phy-qcom-qmp.h" +#include "phy-qcom-qmp-pcs-ufs-v2.h" +#include "phy-qcom-qmp-pcs-ufs-v3.h" +#include "phy-qcom-qmp-pcs-ufs-v4.h" +#include "phy-qcom-qmp-pcs-ufs-v5.h" +#include "phy-qcom-qmp-pcs-ufs-v6.h" + +#include "phy-qcom-qmp-qserdes-com-v4.h" +#include "phy-qcom-qmp-qserdes-txrx-v4.h" +#include "phy-qcom-qmp-qserdes-txrx-ufs-v6.h" + +/* QPHY_SW_RESET bit */ +#define SW_RESET BIT(0) +/* QPHY_POWER_DOWN_CONTROL */ +#define SW_PWRDN BIT(0) +/* QPHY_START_CONTROL bits */ +#define SERDES_START BIT(0) +#define PCS_START BIT(1) +/* QPHY_PCS_READY_STATUS bit */ +#define PCS_READY BIT(0) + +#define PHY_INIT_COMPLETE_TIMEOUT (200 * 10000) + +struct qmp_ufs_init_tbl { + unsigned int offset; + unsigned int val; + /* + * mask of lanes for which this register is written + * for cases when second lane needs different values + */ + u8 lane_mask; +}; + +#define QMP_PHY_INIT_CFG(o, v) \ + { \ + .offset = o, \ + .val = v, \ + .lane_mask = 0xff, \ + } + +#define QMP_PHY_INIT_CFG_LANE(o, v, l) \ + { \ + .offset = o, \ + .val = v, \ + .lane_mask = l, \ + } + +enum ufs_hs_gear_tag { + UFS_HS_DONT_CHANGE, /* Don't change Gear */ + UFS_HS_G1, /* HS Gear 1 (default for reset) */ + UFS_HS_G2, /* HS Gear 2 */ + UFS_HS_G3, /* HS Gear 3 */ + UFS_HS_G4, /* HS Gear 4 */ + UFS_HS_G5 /* HS Gear 5 */ +}; + +/* set of registers with offsets different per-PHY */ +enum qphy_reg_layout { + /* PCS registers */ + QPHY_SW_RESET, + QPHY_START_CTRL, + QPHY_PCS_READY_STATUS, + QPHY_PCS_POWER_DOWN_CONTROL, + /* Keep last to ensure regs_layout arrays are properly initialized */ + QPHY_LAYOUT_SIZE +}; + +static const unsigned int ufsphy_v2_regs_layout[QPHY_LAYOUT_SIZE] = { + [QPHY_START_CTRL] = QPHY_V2_PCS_UFS_PHY_START, + [QPHY_PCS_READY_STATUS] = QPHY_V2_PCS_UFS_READY_STATUS, + [QPHY_PCS_POWER_DOWN_CONTROL] = QPHY_V2_PCS_UFS_POWER_DOWN_CONTROL, +}; + +static const unsigned int ufsphy_v3_regs_layout[QPHY_LAYOUT_SIZE] = { + [QPHY_START_CTRL] = QPHY_V3_PCS_UFS_PHY_START, + [QPHY_PCS_READY_STATUS] = QPHY_V3_PCS_UFS_READY_STATUS, + [QPHY_PCS_POWER_DOWN_CONTROL] = QPHY_V3_PCS_UFS_POWER_DOWN_CONTROL, +}; + +static const unsigned int ufsphy_v4_regs_layout[QPHY_LAYOUT_SIZE] = { + [QPHY_START_CTRL] = QPHY_V4_PCS_UFS_PHY_START, + [QPHY_PCS_READY_STATUS] = QPHY_V4_PCS_UFS_READY_STATUS, + [QPHY_SW_RESET] = QPHY_V4_PCS_UFS_SW_RESET, + [QPHY_PCS_POWER_DOWN_CONTROL] = QPHY_V4_PCS_UFS_POWER_DOWN_CONTROL, +}; + +static const struct qmp_ufs_init_tbl sdm845_ufsphy_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V3_COM_SYS_CLK_CTRL, 0x02), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_BIAS_EN_CLKBUFLR_EN, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_BG_TIMER, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_PLL_IVCO, 0x07), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_CMN_CONFIG, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_SYSCLK_EN_SEL, 0xd5), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_RESETSM_CNTRL, 0x20), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_CLK_SELECT, 0x30), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_HSCLK_SEL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_LOCK_CMP_EN, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE_CTRL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_CORE_CLK_EN, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE_MAP, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_SVS_MODE_CLK_SEL, 0x05), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE_INITVAL1, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE_INITVAL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_DEC_START_MODE0, 0x82), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_CP_CTRL_MODE0, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_PLL_RCTRL_MODE0, 0x16), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_PLL_CCTRL_MODE0, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_INTEGLOOP_GAIN0_MODE0, 0x3f), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_INTEGLOOP_GAIN1_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE1_MODE0, 0xda), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE2_MODE0, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_LOCK_CMP1_MODE0, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_LOCK_CMP2_MODE0, 0x0c), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_DEC_START_MODE1, 0x98), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_CP_CTRL_MODE1, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_PLL_RCTRL_MODE1, 0x16), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_PLL_CCTRL_MODE1, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_INTEGLOOP_GAIN0_MODE1, 0x3f), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_INTEGLOOP_GAIN1_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE1_MODE1, 0xc1), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE2_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_LOCK_CMP1_MODE1, 0x32), + QMP_PHY_INIT_CFG(QSERDES_V3_COM_LOCK_CMP2_MODE1, 0x0f), +}; + +static const struct qmp_ufs_init_tbl sdm845_ufsphy_hs_b_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V3_COM_VCO_TUNE_MAP, 0x44), +}; + +static const struct qmp_ufs_init_tbl sdm845_ufsphy_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_V3_TX_LANE_MODE_1, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V3_TX_RES_CODE_LANE_OFFSET_TX, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_TX_RES_CODE_LANE_OFFSET_RX, 0x07), +}; + +static const struct qmp_ufs_init_tbl sdm845_ufsphy_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_V3_RX_SIGDET_LVL, 0x24), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_SIGDET_CNTRL, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_SIGDET_DEGLITCH_CNTRL, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_INTERFACE_MODE, 0x40), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_FASTLOCK_FO_GAIN, 0x0b), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_TERM_BW, 0x5b), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL2, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL3, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_EQU_ADAPTOR_CNTRL4, 0x1b), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_SVS_SO_GAIN_HALF, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_SVS_SO_GAIN_QUARTER, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_SVS_SO_GAIN, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_SO_SATURATION_AND_ENABLE, 0x4b), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_PI_CONTROLS, 0x81), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_UCDR_FASTLOCK_COUNT_LOW, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V3_RX_RX_MODE_00, 0x59), +}; + +static const struct qmp_ufs_init_tbl sdm845_ufsphy_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_RX_SIGDET_CTRL2, 0x6e), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_TX_LARGE_AMP_DRV_LVL, 0x0a), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_TX_SMALL_AMP_DRV_LVL, 0x02), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_RX_SYM_RESYNC_CTRL, 0x03), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_TX_MID_TERM_CTRL1, 0x43), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_RX_SIGDET_CTRL1, 0x0f), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_RX_MIN_HIBERN8_TIME, 0x9a), + QMP_PHY_INIT_CFG(QPHY_V3_PCS_UFS_MULTI_LANE_CTRL1, 0x02), +}; + +static const struct qmp_ufs_init_tbl sm6115_ufsphy_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_COM_CMN_CONFIG, 0x0e), + QMP_PHY_INIT_CFG(QSERDES_COM_SYSCLK_EN_SEL, 0x14), + QMP_PHY_INIT_CFG(QSERDES_COM_CLK_SELECT, 0x30), + QMP_PHY_INIT_CFG(QSERDES_COM_SYS_CLK_CTRL, 0x02), + QMP_PHY_INIT_CFG(QSERDES_COM_BIAS_EN_CLKBUFLR_EN, 0x08), + QMP_PHY_INIT_CFG(QSERDES_COM_BG_TIMER, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_COM_HSCLK_SEL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_CORECLK_DIV, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_COM_CORECLK_DIV_MODE1, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP_EN, 0x01), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_CTRL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_RESETSM_CNTRL, 0x20), + QMP_PHY_INIT_CFG(QSERDES_COM_CORE_CLK_EN, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP_CFG, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_TIMER1, 0xff), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_TIMER2, 0x3f), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_MAP, 0x04), + QMP_PHY_INIT_CFG(QSERDES_COM_SVS_MODE_CLK_SEL, 0x05), + QMP_PHY_INIT_CFG(QSERDES_COM_DEC_START_MODE0, 0x82), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START1_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START2_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START3_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_CP_CTRL_MODE0, 0x0b), + QMP_PHY_INIT_CFG(QSERDES_COM_PLL_RCTRL_MODE0, 0x16), + QMP_PHY_INIT_CFG(QSERDES_COM_PLL_CCTRL_MODE0, 0x28), + QMP_PHY_INIT_CFG(QSERDES_COM_INTEGLOOP_GAIN0_MODE0, 0x80), + QMP_PHY_INIT_CFG(QSERDES_COM_INTEGLOOP_GAIN1_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE1_MODE0, 0x28), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE2_MODE0, 0x02), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP1_MODE0, 0xff), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP2_MODE0, 0x0c), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP3_MODE0, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_DEC_START_MODE1, 0x98), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START1_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START2_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_DIV_FRAC_START3_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_CP_CTRL_MODE1, 0x0b), + QMP_PHY_INIT_CFG(QSERDES_COM_PLL_RCTRL_MODE1, 0x16), + QMP_PHY_INIT_CFG(QSERDES_COM_PLL_CCTRL_MODE1, 0x28), + QMP_PHY_INIT_CFG(QSERDES_COM_INTEGLOOP_GAIN0_MODE1, 0x80), + QMP_PHY_INIT_CFG(QSERDES_COM_INTEGLOOP_GAIN1_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE1_MODE1, 0xd6), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE2_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP1_MODE1, 0x32), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP2_MODE1, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_COM_LOCK_CMP3_MODE1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_COM_PLL_IVCO, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_COM_BG_TRIM, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_INITVAL1, 0xff), + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_INITVAL2, 0x00), +}; + +static const struct qmp_ufs_init_tbl sm6115_ufsphy_hs_b_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_COM_VCO_TUNE_MAP, 0x44), +}; + +static const struct qmp_ufs_init_tbl sm6115_ufsphy_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_TX_HIGHZ_TRANSCEIVEREN_BIAS_DRVR_EN, 0x45), + QMP_PHY_INIT_CFG(QSERDES_TX_LANE_MODE, 0x06), +}; + +static const struct qmp_ufs_init_tbl sm6115_ufsphy_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_RX_SIGDET_LVL, 0x24), + QMP_PHY_INIT_CFG(QSERDES_RX_SIGDET_CNTRL, 0x0F), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_INTERFACE_MODE, 0x40), + QMP_PHY_INIT_CFG(QSERDES_RX_SIGDET_DEGLITCH_CNTRL, 0x1E), + QMP_PHY_INIT_CFG(QSERDES_RX_UCDR_FASTLOCK_FO_GAIN, 0x0B), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_TERM_BW, 0x5B), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_EQ_GAIN1_LSB, 0xFF), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_EQ_GAIN1_MSB, 0x3F), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_EQ_GAIN2_LSB, 0xFF), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_EQ_GAIN2_MSB, 0x3F), + QMP_PHY_INIT_CFG(QSERDES_RX_RX_EQU_ADAPTOR_CNTRL2, 0x0D), + QMP_PHY_INIT_CFG(QSERDES_RX_UCDR_SVS_SO_GAIN_HALF, 0x04), + QMP_PHY_INIT_CFG(QSERDES_RX_UCDR_SVS_SO_GAIN_QUARTER, 0x04), + QMP_PHY_INIT_CFG(QSERDES_RX_UCDR_SVS_SO_GAIN, 0x04), + QMP_PHY_INIT_CFG(QSERDES_RX_UCDR_SO_SATURATION_AND_ENABLE, 0x5B), +}; + +static const struct qmp_ufs_init_tbl sm6115_ufsphy_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_RX_PWM_GEAR_BAND, 0x15), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_RX_SIGDET_CTRL2, 0x6d), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_TX_LARGE_AMP_DRV_LVL, 0x0f), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_TX_SMALL_AMP_DRV_LVL, 0x02), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_RX_MIN_STALL_NOCONFIG_TIME_CAP, 0x28), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_RX_SYM_RESYNC_CTRL, 0x03), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_TX_LARGE_AMP_POST_EMP_LVL, 0x12), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_TX_SMALL_AMP_POST_EMP_LVL, 0x0f), + QMP_PHY_INIT_CFG(QPHY_V2_PCS_UFS_RX_MIN_HIBERN8_TIME, 0x9a), /* 8 us */ +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_COM_SYSCLK_EN_SEL, 0xd9), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_HSCLK_SEL, 0x11), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_HSCLK_HS_SWITCH_SEL, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_LOCK_CMP_EN, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_VCO_TUNE_MAP, 0x02), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_PLL_IVCO, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_VCO_TUNE_INITVAL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_BIN_VCOCAL_HSCLK_SEL, 0x11), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_DEC_START_MODE0, 0x82), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_CP_CTRL_MODE0, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_PLL_RCTRL_MODE0, 0x16), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_PLL_CCTRL_MODE0, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_LOCK_CMP1_MODE0, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_LOCK_CMP2_MODE0, 0x0c), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE1_MODE0, 0xac), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE2_MODE0, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_DEC_START_MODE1, 0x98), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_CP_CTRL_MODE1, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_PLL_RCTRL_MODE1, 0x16), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_PLL_CCTRL_MODE1, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_LOCK_CMP1_MODE1, 0x32), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_LOCK_CMP2_MODE1, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE1_MODE1, 0xdd), + QMP_PHY_INIT_CFG(QSERDES_V4_COM_BIN_VCOCAL_CMP_CODE2_MODE1, 0x23), +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_hs_b_serdes[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_COM_VCO_TUNE_MAP, 0x06), +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_TX_PWM_GEAR_1_DIVIDER_BAND0_1, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V4_TX_PWM_GEAR_2_DIVIDER_BAND0_1, 0x03), + QMP_PHY_INIT_CFG(QSERDES_V4_TX_PWM_GEAR_3_DIVIDER_BAND0_1, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V4_TX_PWM_GEAR_4_DIVIDER_BAND0_1, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_TX_LANE_MODE_1, 0x05), + QMP_PHY_INIT_CFG(QSERDES_V4_TX_TRAN_DRVR_EMP_EN, 0x0c), +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_RX_SIGDET_LVL, 0x24), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_SIGDET_CNTRL, 0x0f), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_SIGDET_DEGLITCH_CNTRL, 0x1e), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_BAND, 0x18), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_FASTLOCK_FO_GAIN, 0x0a), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_SO_SATURATION_AND_ENABLE, 0x4b), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_PI_CONTROLS, 0xf1), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_FASTLOCK_COUNT_LOW, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_PI_CTRL2, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_FO_GAIN, 0x0c), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_SO_GAIN, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_TERM_BW, 0x1b), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL2, 0x06), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL3, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL4, 0x1d), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_OFFSET_ADAPTOR_CNTRL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_MEASURE_TIME, 0x10), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_TSETTLE_LOW, 0xc0), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_TSETTLE_HIGH, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_LOW, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH, 0x36), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH2, 0xf6), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH4, 0x3d), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_LOW, 0xe0), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH2, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH4, 0xb1), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_10_LOW, 0xe0), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_10_HIGH, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_10_HIGH2, 0xc8), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_10_HIGH3, 0x3b), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_10_HIGH4, 0xb1), +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_RX_SIGDET_CTRL2, 0x6d), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_TX_LARGE_AMP_DRV_LVL, 0x0a), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_TX_SMALL_AMP_DRV_LVL, 0x02), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_TX_MID_TERM_CTRL1, 0x43), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_DEBUG_BUS_CLKSEL, 0x1f), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_RX_MIN_HIBERN8_TIME, 0xff), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_MULTI_LANE_CTRL1, 0x02), +}; + +static const struct qmp_ufs_init_tbl sm8150_ufsphy_hs_g4_pcs[] = { + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_TX_LARGE_AMP_DRV_LVL, 0x10), + QMP_PHY_INIT_CFG(QPHY_V4_PCS_UFS_BIST_FIXED_PAT_CTRL, 0x0a), +}; + +static const struct qmp_ufs_init_tbl sm8250_ufsphy_hs_g4_tx[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_TX_LANE_MODE_1, 0xe5), +}; + +static const struct qmp_ufs_init_tbl sm8250_ufsphy_hs_g4_rx[] = { + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_SO_SATURATION_AND_ENABLE, 0x5a), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_PI_CTRL2, 0x81), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_UCDR_FO_GAIN, 0x0e), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_TERM_BW, 0x6f), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL1, 0x04), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL2, 0x00), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL3, 0x09), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQU_ADAPTOR_CNTRL4, 0x07), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_EQ_OFFSET_ADAPTOR_CNTRL1, 0x17), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_MEASURE_TIME, 0x20), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_TSETTLE_LOW, 0x80), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_IDAC_TSETTLE_HIGH, 0x01), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_LOW, 0x3f), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH2, 0xff), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH3, 0x7f), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_00_HIGH4, 0x2c), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_LOW, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH, 0x6d), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH2, 0xed), + QMP_PHY_INIT_CFG(QSERDES_V4_RX_RX_MODE_01_HIGH4, 0x3c), +}; + +struct qmp_ufs_offsets { + u16 serdes; + u16 pcs; + u16 tx; + u16 rx; + /* for PHYs with >= 2 lanes */ + u16 tx2; + u16 rx2; +}; + +struct qmp_ufs_cfg_tbls { + /* Init sequence for PHY blocks - serdes, tx, rx, pcs */ + const struct qmp_ufs_init_tbl *serdes; + int serdes_num; + const struct qmp_ufs_init_tbl *tx; + int tx_num; + const struct qmp_ufs_init_tbl *rx; + int rx_num; + const struct qmp_ufs_init_tbl *pcs; + int pcs_num; +}; + +/* struct qmp_ufs_cfg - per-PHY initialization config */ +struct qmp_ufs_cfg { + int lanes; + + const struct qmp_ufs_offsets *offsets; + + /* Main init sequence for PHY blocks - serdes, tx, rx, pcs */ + const struct qmp_ufs_cfg_tbls tbls; + /* Additional sequence for HS Series B */ + const struct qmp_ufs_cfg_tbls tbls_hs_b; + /* Additional sequence for HS G4 */ + const struct qmp_ufs_cfg_tbls tbls_hs_g4; + + /* clock ids to be requested */ + const char * const *clk_list; + int num_clks; + /* regulators to be requested */ + const char * const *vreg_list; + int num_vregs; + /* resets to be requested */ + const char * const *reset_list; + int num_resets; + + /* array of registers with different offsets */ + const unsigned int *regs; + + /* true, if PCS block has no separate SW_RESET register */ + bool no_pcs_sw_reset; +}; + +struct qmp_ufs_priv { + struct phy *phy; + + void __iomem *serdes; + void __iomem *pcs; + void __iomem *pcs_misc; + void __iomem *tx; + void __iomem *rx; + void __iomem *tx2; + void __iomem *rx2; + + struct clk *clks; + unsigned int clk_count; + + struct reset_ctl *resets; + unsigned int reset_count; + + const struct qmp_ufs_cfg *cfg; + + struct udevice *dev; + + u32 mode; + u32 submode; +}; + +static inline void qphy_setbits(void __iomem *base, u32 offset, u32 val) +{ + u32 reg; + + reg = readl(base + offset); + reg |= val; + writel(reg, base + offset); + + /* ensure that above write is through */ + readl(base + offset); +} + +static inline void qphy_clrbits(void __iomem *base, u32 offset, u32 val) +{ + u32 reg; + + reg = readl(base + offset); + reg &= ~val; + writel(reg, base + offset); + + /* ensure that above write is through */ + readl(base + offset); +} + +/* list of clocks required by phy */ +static const char * const sdm845_ufs_phy_clk_l[] = { + "ref", "ref_aux", +}; + +/* list of regulators */ +static const char * const qmp_ufs_vreg_l[] = { + "vdda-phy", "vdda-pll", +}; + +/* list of resets */ +static const char * const qmp_ufs_reset_l[] = { + "ufsphy", +}; + +static const struct qmp_ufs_offsets qmp_ufs_offsets = { + .serdes = 0, + .pcs = 0xc00, + .tx = 0x400, + .rx = 0x600, + .tx2 = 0x800, + .rx2 = 0xa00, +}; + +static const struct qmp_ufs_cfg sdm845_ufsphy_cfg = { + .lanes = 2, + + .tbls = { + .serdes = sdm845_ufsphy_serdes, + .serdes_num = ARRAY_SIZE(sdm845_ufsphy_serdes), + .tx = sdm845_ufsphy_tx, + .tx_num = ARRAY_SIZE(sdm845_ufsphy_tx), + .rx = sdm845_ufsphy_rx, + .rx_num = ARRAY_SIZE(sdm845_ufsphy_rx), + .pcs = sdm845_ufsphy_pcs, + .pcs_num = ARRAY_SIZE(sdm845_ufsphy_pcs), + }, + .tbls_hs_b = { + .serdes = sdm845_ufsphy_hs_b_serdes, + .serdes_num = ARRAY_SIZE(sdm845_ufsphy_hs_b_serdes), + }, + .clk_list = sdm845_ufs_phy_clk_l, + .num_clks = ARRAY_SIZE(sdm845_ufs_phy_clk_l), + .vreg_list = qmp_ufs_vreg_l, + .num_vregs = ARRAY_SIZE(qmp_ufs_vreg_l), + .regs = ufsphy_v3_regs_layout, + + .no_pcs_sw_reset = true, +}; + +static const struct qmp_ufs_cfg sm6115_ufsphy_cfg = { + .lanes = 1, + + .offsets = &qmp_ufs_offsets, + + .tbls = { + .serdes = sm6115_ufsphy_serdes, + .serdes_num = ARRAY_SIZE(sm6115_ufsphy_serdes), + .tx = sm6115_ufsphy_tx, + .tx_num = ARRAY_SIZE(sm6115_ufsphy_tx), + .rx = sm6115_ufsphy_rx, + .rx_num = ARRAY_SIZE(sm6115_ufsphy_rx), + .pcs = sm6115_ufsphy_pcs, + .pcs_num = ARRAY_SIZE(sm6115_ufsphy_pcs), + }, + .tbls_hs_b = { + .serdes = sm6115_ufsphy_hs_b_serdes, + .serdes_num = ARRAY_SIZE(sm6115_ufsphy_hs_b_serdes), + }, + .clk_list = sdm845_ufs_phy_clk_l, + .num_clks = ARRAY_SIZE(sdm845_ufs_phy_clk_l), + .vreg_list = qmp_ufs_vreg_l, + .num_vregs = ARRAY_SIZE(qmp_ufs_vreg_l), + .reset_list = qmp_ufs_reset_l, + .num_resets = ARRAY_SIZE(qmp_ufs_reset_l), + .regs = ufsphy_v2_regs_layout, + + .no_pcs_sw_reset = true, +}; + +static const struct qmp_ufs_cfg sm8250_ufsphy_cfg = { + .lanes = 2, + + .tbls = { + .serdes = sm8150_ufsphy_serdes, + .serdes_num = ARRAY_SIZE(sm8150_ufsphy_serdes), + .tx = sm8150_ufsphy_tx, + .tx_num = ARRAY_SIZE(sm8150_ufsphy_tx), + .rx = sm8150_ufsphy_rx, + .rx_num = ARRAY_SIZE(sm8150_ufsphy_rx), + .pcs = sm8150_ufsphy_pcs, + .pcs_num = ARRAY_SIZE(sm8150_ufsphy_pcs), + }, + .tbls_hs_b = { + .serdes = sm8150_ufsphy_hs_b_serdes, + .serdes_num = ARRAY_SIZE(sm8150_ufsphy_hs_b_serdes), + }, + .tbls_hs_g4 = { + .tx = sm8250_ufsphy_hs_g4_tx, + .tx_num = ARRAY_SIZE(sm8250_ufsphy_hs_g4_tx), + .rx = sm8250_ufsphy_hs_g4_rx, + .rx_num = ARRAY_SIZE(sm8250_ufsphy_hs_g4_rx), + .pcs = sm8150_ufsphy_hs_g4_pcs, + .pcs_num = ARRAY_SIZE(sm8150_ufsphy_hs_g4_pcs), + }, + .clk_list = sdm845_ufs_phy_clk_l, + .num_clks = ARRAY_SIZE(sdm845_ufs_phy_clk_l), + .vreg_list = qmp_ufs_vreg_l, + .num_vregs = ARRAY_SIZE(qmp_ufs_vreg_l), + .reset_list = qmp_ufs_reset_l, + .num_resets = ARRAY_SIZE(qmp_ufs_reset_l), + .regs = ufsphy_v4_regs_layout, + + .no_pcs_sw_reset = false, +}; + +static void qmp_ufs_configure_lane(void __iomem *base, + const struct qmp_ufs_init_tbl tbl[], + int num, + u8 lane_mask) +{ + int i; + const struct qmp_ufs_init_tbl *t = tbl; + + if (!t) + return; + + for (i = 0; i < num; i++, t++) { + if (!(t->lane_mask & lane_mask)) + continue; + + writel(t->val, base + t->offset); + } +} + +static void qmp_ufs_configure(void __iomem *base, + const struct qmp_ufs_init_tbl tbl[], + int num) +{ + qmp_ufs_configure_lane(base, tbl, num, 0xff); +} + +static void qmp_ufs_serdes_init(struct qmp_ufs_priv *qmp, const struct qmp_ufs_cfg_tbls *tbls) +{ + void __iomem *serdes = qmp->serdes; + + qmp_ufs_configure(serdes, tbls->serdes, tbls->serdes_num); +} + +static void qmp_ufs_lanes_init(struct qmp_ufs_priv *qmp, const struct qmp_ufs_cfg_tbls *tbls) +{ + const struct qmp_ufs_cfg *cfg = qmp->cfg; + void __iomem *tx = qmp->tx; + void __iomem *rx = qmp->rx; + + qmp_ufs_configure_lane(tx, tbls->tx, tbls->tx_num, 1); + qmp_ufs_configure_lane(rx, tbls->rx, tbls->rx_num, 1); + + if (cfg->lanes >= 2) { + qmp_ufs_configure_lane(qmp->tx2, tbls->tx, tbls->tx_num, 2); + qmp_ufs_configure_lane(qmp->rx2, tbls->rx, tbls->rx_num, 2); + } +} + +static void qmp_ufs_pcs_init(struct qmp_ufs_priv *qmp, const struct qmp_ufs_cfg_tbls *tbls) +{ + void __iomem *pcs = qmp->pcs; + + qmp_ufs_configure(pcs, tbls->pcs, tbls->pcs_num); +} + +static void qmp_ufs_init_registers(struct qmp_ufs_priv *qmp, const struct qmp_ufs_cfg *cfg) +{ + /* We support 'PHY_MODE_UFS_HS_B' mode & 'UFS_HS_G3' submode for now. */ + qmp_ufs_serdes_init(qmp, &cfg->tbls); + qmp_ufs_serdes_init(qmp, &cfg->tbls_hs_b); + qmp_ufs_lanes_init(qmp, &cfg->tbls); + qmp_ufs_pcs_init(qmp, &cfg->tbls); +} + +static int qmp_ufs_do_reset(struct qmp_ufs_priv *qmp) +{ + int i, ret; + + for (i = 0; i < qmp->reset_count; i++) { + ret = reset_assert(&qmp->resets[i]); + if (ret) + return ret; + } + + udelay(10); + + for (i = 0; i < qmp->reset_count; i++) { + ret = reset_deassert(&qmp->resets[i]); + if (ret) + return ret; + } + + udelay(50); + + return 0; +} + +static int qmp_ufs_power_on(struct phy *phy) +{ + struct qmp_ufs_priv *qmp = dev_get_priv(phy->dev); + const struct qmp_ufs_cfg *cfg = qmp->cfg; + void __iomem *pcs = qmp->pcs; + void __iomem *status; + unsigned int val; + int ret; + + /* Power down PHY */ + qphy_setbits(pcs, cfg->regs[QPHY_PCS_POWER_DOWN_CONTROL], SW_PWRDN); + + qmp_ufs_init_registers(qmp, cfg); + + if (cfg->no_pcs_sw_reset) { + ret = qmp_ufs_do_reset(qmp); + if (ret) { + printf("%s: qmp reset failed\n", __func__); + return ret; + } + } + + /* Pull PHY out of reset state */ + if (!cfg->no_pcs_sw_reset) + qphy_clrbits(pcs, cfg->regs[QPHY_SW_RESET], SW_RESET); + + /* start SerDes */ + qphy_setbits(pcs, cfg->regs[QPHY_START_CTRL], SERDES_START); + + status = pcs + cfg->regs[QPHY_PCS_READY_STATUS]; + ret = readl_poll_timeout(status, val, (val & PCS_READY), PHY_INIT_COMPLETE_TIMEOUT); + if (ret) { + printf("%s: phy initialization timed-out\n", __func__); + return ret; + } + + return 0; +} + +static int qmp_ufs_power_off(struct phy *phy) +{ + struct qmp_ufs_priv *qmp = dev_get_priv(phy->dev); + const struct qmp_ufs_cfg *cfg = qmp->cfg; + + /* PHY reset */ + qphy_setbits(qmp->pcs, cfg->regs[QPHY_SW_RESET], SW_RESET); + + /* stop SerDes and Phy-Coding-Sublayer */ + qphy_clrbits(qmp->pcs, cfg->regs[QPHY_START_CTRL], + SERDES_START | PCS_START); + + /* Put PHY into POWER DOWN state: active low */ + qphy_clrbits(qmp->pcs, cfg->regs[QPHY_PCS_POWER_DOWN_CONTROL], + SW_PWRDN); + + clk_release_all(qmp->clks, qmp->clk_count); + + return 0; +} + +static int qmp_ufs_vreg_init(struct udevice *dev, struct qmp_ufs_priv *qmp) +{ + // TBD: Add regulator support later - if needed + return 0; +} + +static int qmp_ufs_reset_init(struct udevice *dev, struct qmp_ufs_priv *qmp) +{ + const struct qmp_ufs_cfg *cfg = qmp->cfg; + int num = cfg->num_resets; + int i, ret; + + qmp->reset_count = 0; + qmp->resets = devm_kcalloc(dev, num, sizeof(*qmp->resets), GFP_KERNEL); + if (!qmp->resets) + return -ENOMEM; + + for (i = 0; i < num; i++) { + ret = reset_get_by_index(dev, i, &qmp->resets[i]); + if (ret < 0) { + printf("%s: failed to get reset %d\n", __func__, i); + goto reset_get_err; + } + + ++qmp->reset_count; + } + + return 0; + +reset_get_err: + ret = reset_release_all(qmp->resets, qmp->reset_count); + if (ret) + printf("%s: failed to disable all resets\n", __func__); + + return ret; +} + +static int qmp_ufs_clk_init(struct udevice *dev, struct qmp_ufs_priv *qmp) +{ + const struct qmp_ufs_cfg *cfg = qmp->cfg; + int num = cfg->num_clks; + int i, ret; + + qmp->clk_count = 0; + qmp->clks = devm_kcalloc(dev, num, sizeof(*qmp->clks), GFP_KERNEL); + if (!qmp->clks) + return -ENOMEM; + + for (i = 0; i < num; i++) { + ret = clk_get_by_index(dev, i, &qmp->clks[i]); + if (ret < 0) + goto clk_get_err; + + ret = clk_enable(&qmp->clks[i]); + if (ret && ret != -ENOSYS) { + printf("%s: failed to enable clock %d\n", __func__, i); + clk_free(&qmp->clks[i]); + goto clk_get_err; + } + + ++qmp->clk_count; + } + + return 0; + +clk_get_err: + ret = clk_release_all(qmp->clks, qmp->clk_count); + if (ret) + printf("%s: failed to disable all clocks\n", __func__); + + return ret; +} + +static int qmp_ufs_probe_generic_child(struct udevice *dev, + ofnode child) +{ + struct qmp_ufs_priv *qmp = dev_get_priv(dev); + const struct qmp_ufs_cfg *cfg = qmp->cfg; + struct resource res; + int ret; + + /* + * Get memory resources for the PHY: + * Resources are indexed as: tx -> 0; rx -> 1; pcs -> 2. + * For dual lane PHYs: tx2 -> 3, rx2 -> 4, pcs_misc (optional) -> 5 + * For single lane PHYs: pcs_misc (optional) -> 3. + */ + ret = ofnode_read_resource(child, 0, &res); + if (ret) { + dev_err(dev, "can't get reg property of child %s\n", + ofnode_get_name(child)); + return ret; + } + + qmp->tx = (void __iomem *)res.start; + + ret = ofnode_read_resource(child, 1, &res); + if (ret) { + dev_err(dev, "can't get reg property of child %s\n", + ofnode_get_name(child)); + return ret; + } + + qmp->rx = (void __iomem *)res.start; + + ret = ofnode_read_resource(child, 2, &res); + if (ret) { + dev_err(dev, "can't get reg property of child %s\n", + ofnode_get_name(child)); + return ret; + } + + qmp->pcs = (void __iomem *)res.start; + + if (cfg->lanes >= 2) { + ret = ofnode_read_resource(child, 3, &res); + if (ret) { + dev_err(dev, "can't get reg property of child %s\n", + ofnode_get_name(child)); + return ret; + } + + qmp->tx2 = (void __iomem *)res.start; + + ret = ofnode_read_resource(child, 4, &res); + if (ret) { + dev_err(dev, "can't get reg property of child %s\n", + ofnode_get_name(child)); + return ret; + } + + qmp->rx2 = (void __iomem *)res.start; + + ret = ofnode_read_resource(child, 5, &res); + if (ret) + qmp->pcs_misc = NULL; + } else { + ret = ofnode_read_resource(child, 3, &res); + if (ret) + qmp->pcs_misc = NULL; + } + + if (!qmp->pcs_misc) + dev_warn(qmp->dev, "PHY pcs_misc-reg not used\n"); + + return 0; +} + +static int qmp_ufs_probe_dt_children(struct udevice *dev) +{ + int ret; + ofnode child; + + ofnode_for_each_subnode(child, dev_ofnode(dev)) { + ret = qmp_ufs_probe_generic_child(dev, child); + if (ret) { + dev_err(dev, "Cannot parse child %s:%d\n", + ofnode_get_name(child), ret); + return ret; + } + } + + return 0; +} + +static int qmp_ufs_probe(struct udevice *dev) +{ + struct qmp_ufs_priv *qmp = dev_get_priv(dev); + int ret; + + qmp->serdes = (void __iomem *)dev_read_addr(dev); + if (IS_ERR(qmp->serdes)) + return PTR_ERR(qmp->serdes); + + qmp->cfg = (const struct qmp_ufs_cfg *)dev_get_driver_data(dev); + if (!qmp->cfg) + return -EINVAL; + + ret = qmp_ufs_clk_init(dev, qmp); + if (ret) { + printf("%s: failed to get UFS clks\n", __func__); + return ret; + } + + ret = qmp_ufs_vreg_init(dev, qmp); + if (ret) { + printf("%s: failed to get UFS voltage regulators\n", __func__); + return ret; + } + + if (qmp->cfg->no_pcs_sw_reset) { + ret = qmp_ufs_reset_init(dev, qmp); + if (ret) { + printf("%s: failed to get UFS resets\n", __func__); + return ret; + } + } + + qmp->dev = dev; + + ret = qmp_ufs_probe_dt_children(dev); + if (ret) { + printf("%s: failed to get UFS dt regs\n", __func__); + return ret; + } + + return 0; +} + +static struct phy_ops qmp_ufs_ops = { + .power_on = qmp_ufs_power_on, + .power_off = qmp_ufs_power_off, +}; + +static const struct udevice_id qmp_ufs_ids[] = { + { .compatible = "qcom,sdm845-qmp-ufs-phy", .data = (ulong)&sdm845_ufsphy_cfg }, + { .compatible = "qcom,sm6115-qmp-ufs-phy", .data = (ulong)&sm6115_ufsphy_cfg }, + { .compatible = "qcom,sm8250-qmp-ufs-phy", .data = (ulong)&sm8250_ufsphy_cfg }, + { } +}; + +U_BOOT_DRIVER(qcom_qmp_ufs) = { + .name = "qcom-qmp-ufs", + .id = UCLASS_PHY, + .of_match = qmp_ufs_ids, + .ops = &qmp_ufs_ops, + .probe = qmp_ufs_probe, + .priv_auto = sizeof(struct qmp_ufs_priv), +}; diff --git a/drivers/phy/qcom/phy-qcom-qmp.h b/drivers/phy/qcom/phy-qcom-qmp.h new file mode 100644 index 0000000000..99f4d447ca --- /dev/null +++ b/drivers/phy/qcom/phy-qcom-qmp.h @@ -0,0 +1,115 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2017, The Linux Foundation. All rights reserved. + */ + +#ifndef QCOM_PHY_QMP_H_ +#define QCOM_PHY_QMP_H_ + +#include "phy-qcom-qmp-qserdes-com.h" +#include "phy-qcom-qmp-qserdes-txrx.h" + +#include "phy-qcom-qmp-qserdes-com-v3.h" +#include "phy-qcom-qmp-qserdes-txrx-v3.h" + +#include "phy-qcom-qmp-qserdes-pll.h" + +#include "phy-qcom-qmp-pcs-v2.h" + +#include "phy-qcom-qmp-pcs-v3.h" + +/* Only for QMP V3 & V4 PHY - DP COM registers */ +#define QPHY_V3_DP_COM_PHY_MODE_CTRL 0x00 +#define QPHY_V3_DP_COM_SW_RESET 0x04 +#define QPHY_V3_DP_COM_POWER_DOWN_CTRL 0x08 +#define QPHY_V3_DP_COM_SWI_CTRL 0x0c +#define QPHY_V3_DP_COM_TYPEC_CTRL 0x10 +#define QPHY_V3_DP_COM_TYPEC_PWRDN_CTRL 0x14 +#define QPHY_V3_DP_COM_RESET_OVRD_CTRL 0x1c + +/* QSERDES V3 COM bits */ +# define QSERDES_V3_COM_BIAS_EN 0x0001 +# define QSERDES_V3_COM_BIAS_EN_MUX 0x0002 +# define QSERDES_V3_COM_CLKBUF_R_EN 0x0004 +# define QSERDES_V3_COM_CLKBUF_L_EN 0x0008 +# define QSERDES_V3_COM_EN_SYSCLK_TX_SEL 0x0010 +# define QSERDES_V3_COM_CLKBUF_RX_DRIVE_L 0x0020 +# define QSERDES_V3_COM_CLKBUF_RX_DRIVE_R 0x0040 + +/* QSERDES V3 TX bits */ +# define DP_PHY_TXn_TX_EMP_POST1_LVL_MASK 0x001f +# define DP_PHY_TXn_TX_EMP_POST1_LVL_MUX_EN 0x0020 +# define DP_PHY_TXn_TX_DRV_LVL_MASK 0x001f +# define DP_PHY_TXn_TX_DRV_LVL_MUX_EN 0x0020 + +/* QMP PHY - DP PHY registers */ +#define QSERDES_DP_PHY_REVISION_ID0 0x000 +#define QSERDES_DP_PHY_REVISION_ID1 0x004 +#define QSERDES_DP_PHY_REVISION_ID2 0x008 +#define QSERDES_DP_PHY_REVISION_ID3 0x00c +#define QSERDES_DP_PHY_CFG 0x010 +#define QSERDES_DP_PHY_PD_CTL 0x018 +# define DP_PHY_PD_CTL_PWRDN 0x001 +# define DP_PHY_PD_CTL_PSR_PWRDN 0x002 +# define DP_PHY_PD_CTL_AUX_PWRDN 0x004 +# define DP_PHY_PD_CTL_LANE_0_1_PWRDN 0x008 +# define DP_PHY_PD_CTL_LANE_2_3_PWRDN 0x010 +# define DP_PHY_PD_CTL_PLL_PWRDN 0x020 +# define DP_PHY_PD_CTL_DP_CLAMP_EN 0x040 +#define QSERDES_DP_PHY_MODE 0x01c +#define QSERDES_DP_PHY_AUX_CFG0 0x020 +#define QSERDES_DP_PHY_AUX_CFG1 0x024 +#define QSERDES_DP_PHY_AUX_CFG2 0x028 +#define QSERDES_DP_PHY_AUX_CFG3 0x02c +#define QSERDES_DP_PHY_AUX_CFG4 0x030 +#define QSERDES_DP_PHY_AUX_CFG5 0x034 +#define QSERDES_DP_PHY_AUX_CFG6 0x038 +#define QSERDES_DP_PHY_AUX_CFG7 0x03c +#define QSERDES_DP_PHY_AUX_CFG8 0x040 +#define QSERDES_DP_PHY_AUX_CFG9 0x044 + +/* Only for QMP V3 PHY - DP PHY registers */ +#define QSERDES_V3_DP_PHY_AUX_INTERRUPT_MASK 0x048 +# define PHY_AUX_STOP_ERR_MASK 0x01 +# define PHY_AUX_DEC_ERR_MASK 0x02 +# define PHY_AUX_SYNC_ERR_MASK 0x04 +# define PHY_AUX_ALIGN_ERR_MASK 0x08 +# define PHY_AUX_REQ_ERR_MASK 0x10 + +#define QSERDES_V3_DP_PHY_AUX_INTERRUPT_CLEAR 0x04c +#define QSERDES_V3_DP_PHY_AUX_BIST_CFG 0x050 + +#define QSERDES_V3_DP_PHY_VCO_DIV 0x064 +#define QSERDES_V3_DP_PHY_TX0_TX1_LANE_CTL 0x06c +#define QSERDES_V3_DP_PHY_TX2_TX3_LANE_CTL 0x088 + +#define QSERDES_V3_DP_PHY_SPARE0 0x0ac +#define DP_PHY_SPARE0_MASK 0x0f +#define DP_PHY_SPARE0_ORIENTATION_INFO_SHIFT 0x04(0x0004) + +#define QSERDES_V3_DP_PHY_STATUS 0x0c0 + +/* Only for QMP V4 PHY - DP PHY registers */ +#define QSERDES_V4_DP_PHY_CFG_1 0x014 +#define QSERDES_V4_DP_PHY_AUX_INTERRUPT_MASK 0x054 +#define QSERDES_V4_DP_PHY_AUX_INTERRUPT_CLEAR 0x058 +#define QSERDES_V4_DP_PHY_VCO_DIV 0x070 +#define QSERDES_V4_DP_PHY_TX0_TX1_LANE_CTL 0x078 +#define QSERDES_V4_DP_PHY_TX2_TX3_LANE_CTL 0x09c +#define QSERDES_V4_DP_PHY_SPARE0 0x0c8 +#define QSERDES_V4_DP_PHY_AUX_INTERRUPT_STATUS 0x0d8 +#define QSERDES_V4_DP_PHY_STATUS 0x0dc + +/* Only for QMP V4 PHY - PCS_MISC registers */ +#define QPHY_V4_PCS_MISC_TYPEC_CTRL 0x00 +#define QPHY_V4_PCS_MISC_TYPEC_PWRDN_CTRL 0x04 +#define QPHY_V4_PCS_MISC_PCS_MISC_CONFIG1 0x08 +#define QPHY_V4_PCS_MISC_CLAMP_ENABLE 0x0c +#define QPHY_V4_PCS_MISC_TYPEC_STATUS 0x10 +#define QPHY_V4_PCS_MISC_PLACEHOLDER_STATUS 0x14 + +/* Only for QMP V6 PHY - DP PHY registers */ +#define QSERDES_V6_DP_PHY_AUX_INTERRUPT_STATUS 0x0e0 +#define QSERDES_V6_DP_PHY_STATUS 0x0e4 + +#endif
Add definition of 'ufshcd_rmwl()' helper function which would be later used by Qualcomm UFS driver to read-modify-write registers.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.h | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/drivers/ufs/ufs.h b/drivers/ufs/ufs.h index 8a38832b05..c9320a905e 100644 --- a/drivers/ufs/ufs.h +++ b/drivers/ufs/ufs.h @@ -2,6 +2,7 @@ #ifndef __UFS_H #define __UFS_H
+#include <asm/io.h> #include "unipro.h"
struct udevice; @@ -906,6 +907,23 @@ enum { #define ufshcd_readl(hba, reg) \ readl((hba)->mmio_base + (reg))
+/** + * ufshcd_rmwl - perform read/modify/write for a controller register + * @hba: per adapter instance + * @mask: mask to apply on read value + * @val: actual value to write + * @reg: register address + */ +static inline void ufshcd_rmwl(struct ufs_hba *hba, u32 mask, u32 val, u32 reg) +{ + u32 tmp; + + tmp = ufshcd_readl(hba, reg); + tmp &= ~mask; + tmp |= (val & mask); + ufshcd_writel(hba, tmp, reg); +} + /* UTRLRSR - UTP Transfer Request Run-Stop Register 60h */ #define UTP_TRANSFER_REQ_LIST_RUN_STOP_BIT 0x1
Clear UECPA once in u-boot UFS driver due to LINERESET has happened during LINK_STARTUP. This makes the u-boot ufs driver behavior related to UECPA similar to Linux UFS driver.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 3bf1a95e7f..25639a6d24 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -504,6 +504,8 @@ link_startup: if (ret) goto out;
+ /* Clear UECPA once due to LINERESET has happened during LINK_STARTUP */ + ufshcd_readl(hba, REG_UIC_ERROR_CODE_PHY_ADAPTER_LAYER); ret = ufshcd_make_hba_operational(hba); out: if (ret)
UFS Host Controllers on Qualcomm Snapdragon SoCs support versions newer/ greater than UFSHCI_VERSION_21. So, modify the driver to just print the UFS HC version and not bail-out for newer versions.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.c | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 25639a6d24..b2c3af429e 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -1894,12 +1894,7 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops)
/* Get UFS version supported by the controller */ hba->version = ufshcd_get_ufs_version(hba); - if (hba->version != UFSHCI_VERSION_10 && - hba->version != UFSHCI_VERSION_11 && - hba->version != UFSHCI_VERSION_20 && - hba->version != UFSHCI_VERSION_21) - dev_err(hba->dev, "invalid UFS version 0x%x\n", - hba->version); + dev_info(hba->dev, "UFS version : 0x%x\n", hba->version);
/* Get Interrupt bit mask per version */ hba->intr_mask = ufshcd_get_intr_mask(hba);
Add more verbose debug capabilities and vops to allow dumping UFS debug registers / regions, similar to how the UFS Linux driver does it.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.c | 71 +++++++++++++++++++++++++++++++++++++++++++++++ drivers/ufs/ufs.h | 9 ++++++ 2 files changed, 80 insertions(+)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index b2c3af429e..15fa3832b9 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -59,10 +59,81 @@ /* maximum bytes per request */ #define UFS_MAX_BYTES (128 * 256 * 1024)
+#define ufshcd_hex_dump(prefix_str, buf, len) do { \ + size_t __len = (len); \ + print_hex_dump(prefix_str, \ + DUMP_PREFIX_OFFSET, \ + 16, 4, buf, __len, false); \ +} while (0) + static inline bool ufshcd_is_hba_active(struct ufs_hba *hba); static inline void ufshcd_hba_stop(struct ufs_hba *hba); static int ufshcd_hba_enable(struct ufs_hba *hba);
+int ufshcd_dump_regs(struct ufs_hba *hba, size_t offset, size_t len, + const char *prefix) +{ + u32 *regs; + size_t pos; + + if (offset % 4 != 0 || len % 4 != 0) /* keep readl happy */ + return -EINVAL; + + regs = kzalloc(len, GFP_KERNEL); + if (!regs) + return -ENOMEM; + + for (pos = 0; pos < len; pos += 4) { + if (offset == 0 && + pos >= REG_UIC_ERROR_CODE_PHY_ADAPTER_LAYER && + pos <= REG_UIC_ERROR_CODE_DME) + continue; + regs[pos / 4] = ufshcd_readl(hba, offset + pos); + } + + ufshcd_hex_dump(prefix, regs, len); + kfree(regs); + + return 0; +} + +void ufshcd_print_tr(struct ufs_hba *hba, int tag, bool pr_prdt) +{ + int prdt_length; + struct utp_transfer_req_desc *req_desc = hba->utrdl; + + dev_info(hba->dev, + "UPIU[%d] - Transfer Request Descriptor phys@0x%llx\n", + tag, (u64)hba->utrdl); + + ufshcd_hex_dump("UPIU TRD: ", hba->utrdl, + sizeof(struct utp_transfer_req_desc)); + dev_info(hba->dev, "UPIU[%d] - Request UPIU phys@0x%llx\n", tag, + (u64)hba->ucd_req_ptr); + ufshcd_hex_dump("UPIU REQ: ", hba->ucd_req_ptr, + sizeof(struct utp_upiu_req)); + dev_info(hba->dev, "UPIU[%d] - Response UPIU phys@0x%llx\n", tag, + (u64)hba->ucd_rsp_ptr); + ufshcd_hex_dump("UPIU RSP: ", hba->ucd_rsp_ptr, + sizeof(struct utp_upiu_rsp)); + + prdt_length = le16_to_cpu(req_desc->prd_table_length); + + dev_info(hba->dev, + "UPIU[%d] - PRDT - %d entries phys@0x%llx\n", + tag, prdt_length, + (u64)hba->ucd_prdt_ptr); + + if (pr_prdt) + ufshcd_hex_dump("UPIU PRDT: ", hba->ucd_prdt_ptr, + sizeof(struct ufshcd_sg_entry) * prdt_length); +} + +void ufshcd_dbg_register_dump(struct ufs_hba *hba) +{ + ufshcd_ops_dbg_register_dump(hba); +} + /* * ufshcd_wait_for_register - wait for register value to change */ diff --git a/drivers/ufs/ufs.h b/drivers/ufs/ufs.h index c9320a905e..b3d2bd0368 100644 --- a/drivers/ufs/ufs.h +++ b/drivers/ufs/ufs.h @@ -695,6 +695,7 @@ struct ufs_dev_cmd {
struct ufs_hba_ops { int (*init)(struct ufs_hba *hba); + void (*dbg_register_dump)(struct ufs_hba *hba); int (*hce_enable_notify)(struct ufs_hba *hba, enum ufs_notify_change_status); int (*link_startup_notify)(struct ufs_hba *hba, @@ -746,6 +747,12 @@ static inline int ufshcd_ops_init(struct ufs_hba *hba) return 0; }
+static inline void ufshcd_ops_dbg_register_dump(struct ufs_hba *hba) +{ + if (hba->ops && hba->ops->dbg_register_dump) + hba->ops->dbg_register_dump(hba); +} + static inline int ufshcd_ops_hce_enable_notify(struct ufs_hba *hba, bool status) { @@ -931,5 +938,7 @@ static inline void ufshcd_rmwl(struct ufs_hba *hba, u32 mask, u32 val, u32 reg) #define UTP_TASK_REQ_LIST_RUN_STOP_BIT 0x1
int ufshcd_probe(struct udevice *dev, struct ufs_hba_ops *hba_ops); +int ufshcd_dump_regs(struct ufs_hba *hba, size_t offset, size_t len, + const char *prefix);
#endif
- size_t __len = (len); \
- print_hex_dump(prefix_str, \
+} while (0)
- static inline bool ufshcd_is_hba_active(struct ufs_hba *hba); static inline void ufshcd_hba_stop(struct ufs_hba *hba); static int ufshcd_hba_enable(struct ufs_hba *hba);
const char *prefix)
- u32 *regs;
- size_t pos;
- if (offset % 4 != 0 || len % 4 != 0) /* keep readl happy */
return -EINVAL;
- regs = kzalloc(len, GFP_KERNEL);
- if (!regs)
return -ENOMEM;
- for (pos = 0; pos < len; pos += 4) {
if (offset == 0 &&
continue;
- ufshcd_hex_dump(prefix, regs, len);
- kfree(regs);
Why not use variable on stack instead of this malloc-free cycle ?
Sync u-boot UFS driver to add all possible UFS Quirks as supported by Linux UFS driver as well.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.h | 129 +++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 121 insertions(+), 8 deletions(-)
diff --git a/drivers/ufs/ufs.h b/drivers/ufs/ufs.h index b3d2bd0368..cdc88919b4 100644 --- a/drivers/ufs/ufs.h +++ b/drivers/ufs/ufs.h @@ -712,14 +712,127 @@ struct ufs_hba { u32 version; u32 intr_mask; u32 quirks; -/* - * If UFS host controller is having issue in processing LCC (Line - * Control Command) coming from device then enable this quirk. - * When this quirk is enabled, host controller driver should disable - * the LCC transmission on UFS device (by clearing TX_LCC_ENABLE - * attribute of device to 0). - */ -#define UFSHCD_QUIRK_BROKEN_LCC 0x1 + + /* Interrupt aggregation support is broken */ +#define UFSHCD_QUIRK_BROKEN_INTR_AGGR (1 << 0) + + /* + * delay before each dme command is required as the unipro + * layer has shown instabilities + */ +#define UFSHCD_QUIRK_DELAY_BEFORE_DME_CMDS (1 << 1) + + /* + * If UFS host controller is having issue in processing LCC (Line + * Control Command) coming from device then enable this quirk. + * When this quirk is enabled, host controller driver should disable + * the LCC transmission on UFS device (by clearing TX_LCC_ENABLE + * attribute of device to 0). + */ +#define UFSHCD_QUIRK_BROKEN_LCC (1 << 2) + + /* + * The attribute PA_RXHSUNTERMCAP specifies whether or not the + * inbound Link supports unterminated line in HS mode. Setting this + * attribute to 1 fixes moving to HS gear. + */ +#define UFSHCD_QUIRK_BROKEN_PA_RXHSUNTERMCAP (1 << 3) + + /* + * This quirk needs to be enabled if the host controller only allows + * accessing the peer dme attributes in AUTO mode (FAST AUTO or + * SLOW AUTO). + */ +#define UFSHCD_QUIRK_DME_PEER_ACCESS_AUTO_MODE (1 << 4) + + /* + * This quirk needs to be enabled if the host controller doesn't + * advertise the correct version in UFS_VER register. If this quirk + * is enabled, standard UFS host driver will call the vendor specific + * ops (get_ufs_hci_version) to get the correct version. + */ +#define UFSHCD_QUIRK_BROKEN_UFS_HCI_VERSION (1 << 5) + + /* + * Clear handling for transfer/task request list is just opposite. + */ +#define UFSHCI_QUIRK_BROKEN_REQ_LIST_CLR (1 << 6) + + /* + * This quirk needs to be enabled if host controller doesn't allow + * that the interrupt aggregation timer and counter are reset by s/w. + */ +#define UFSHCI_QUIRK_SKIP_RESET_INTR_AGGR (1 << 7) + + /* + * This quirks needs to be enabled if host controller cannot be + * enabled via HCE register. + */ +#define UFSHCI_QUIRK_BROKEN_HCE (1 << 8) + + /* + * This quirk needs to be enabled if the host controller regards + * resolution of the values of PRDTO and PRDTL in UTRD as byte. + */ +#define UFSHCD_QUIRK_PRDT_BYTE_GRAN (1 << 9) + + /* + * This quirk needs to be enabled if the host controller reports + * OCS FATAL ERROR with device error through sense data + */ +#define UFSHCD_QUIRK_BROKEN_OCS_FATAL_ERROR (1 << 10) + + /* + * This quirk needs to be enabled if the host controller has + * auto-hibernate capability but it doesn't work. + */ +#define UFSHCD_QUIRK_BROKEN_AUTO_HIBERN8 (1 << 11) + + /* + * This quirk needs to disable manual flush for write booster + */ +#define UFSHCI_QUIRK_SKIP_MANUAL_WB_FLUSH_CTRL (1 << 12) + + /* + * This quirk needs to disable unipro timeout values + * before power mode change + */ +#define UFSHCD_QUIRK_SKIP_DEF_UNIPRO_TIMEOUT_SETTING (1 << 13) + + /* + * Align DMA SG entries on a 4 KiB boundary. + */ +#define UFSHCD_QUIRK_4KB_DMA_ALIGNMENT (1 << 14) + + /* + * This quirk needs to be enabled if the host controller does not + * support UIC command + */ +#define UFSHCD_QUIRK_BROKEN_UIC_CMD (1 << 15) + + /* + * This quirk needs to be enabled if the host controller cannot + * support physical host configuration. + */ +#define UFSHCD_QUIRK_SKIP_PH_CONFIGURATION (1 << 16) + + /* + * This quirk needs to be enabled if the host controller has + * 64-bit addressing supported capability but it doesn't work. + */ +#define UFSHCD_QUIRK_BROKEN_64BIT_ADDRESS (1 << 17) + + /* + * This quirk needs to be enabled if the host controller has + * auto-hibernate capability but it's FASTAUTO only. + */ +#define UFSHCD_QUIRK_HIBERN_FASTAUTO (1 << 18) + + /* + * This quirk needs to be enabled if the host controller needs + * to reinit the device after switching to maximum gear. + */ +#define UFSHCD_QUIRK_REINIT_AFTER_MAX_GEAR_SWITCH (1 << 19)
/* Virtual memory reference */ struct utp_transfer_cmd_desc *ucdl;
Add missing wmb() and mb() barriers in the u-boot UFS core framework driver to allow registers updates to happen before follow-up read operations.
This makes the barrier placement similar to the Linux UFS driver.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 15fa3832b9..a97c45a530 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -503,6 +503,12 @@ static int ufshcd_make_hba_operational(struct ufs_hba *hba) ufshcd_writel(hba, upper_32_bits((dma_addr_t)hba->utmrdl), REG_UTP_TASK_REQ_LIST_BASE_H);
+ /* + * Make sure base address and interrupt setup are updated before + * enabling the run/stop registers below. + */ + wmb(); + /* * UCRDY, UTMRLDY and UTRLRDY bits must be 1 */ @@ -892,6 +898,9 @@ static int ufshcd_send_command(struct ufs_hba *hba, unsigned int task_tag)
ufshcd_writel(hba, 1 << task_tag, REG_UTP_TRANSFER_REQ_DOOR_BELL);
+ /* Make sure doorbell reg is updated before reading interrupt status */ + wmb(); + start = get_timer(0); do { intr_status = ufshcd_readl(hba, REG_INTERRUPT_STATUS); @@ -1989,6 +1998,8 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops) REG_INTERRUPT_STATUS); ufshcd_writel(hba, 0, REG_INTERRUPT_ENABLE);
+ mb(); + err = ufshcd_hba_enable(hba); if (err) { dev_err(hba->dev, "Host controller enable failed\n");
Minor typo fix and rewording of printf message inside 'ufs_start' which announces the availability of the UFS device.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/ufs.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index a97c45a530..8e507e8378 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -1937,7 +1937,7 @@ int ufs_start(struct ufs_hba *hba) return ret; }
- printf("Device at %s up at:", hba->dev->name); + printf("UFS Device %s is up!\n", hba->dev->name); ufshcd_print_pwr_info(hba); }
Add Support for the Host Controller driver for UFS HC present on Qualcomm Snapdragon SoCs.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- drivers/ufs/Kconfig | 7 + drivers/ufs/Makefile | 1 + drivers/ufs/qcom-ufshcd.c | 880 ++++++++++++++++++++++++++++++++++++++ drivers/ufs/ufs-qcom.h | 275 ++++++++++++ 4 files changed, 1163 insertions(+) create mode 100644 drivers/ufs/qcom-ufshcd.c create mode 100644 drivers/ufs/ufs-qcom.h
diff --git a/drivers/ufs/Kconfig b/drivers/ufs/Kconfig index 69ea18edf8..5dfe8048a8 100644 --- a/drivers/ufs/Kconfig +++ b/drivers/ufs/Kconfig @@ -15,6 +15,13 @@ config CADENCE_UFS This selects the platform driver for the Cadence UFS host controller present on present TI's J721e devices.
+config QCOM_UFS + bool "Qualcomm Host Controller driver for UFS" + depends on UFS && ARCH_SNAPDRAGON + help + This selects the platform driver for the UFS host + controller present on Qualcomm Snapdragon SoCs. + config TI_J721E_UFS bool "Glue Layer driver for UFS on TI J721E devices" help diff --git a/drivers/ufs/Makefile b/drivers/ufs/Makefile index 62ed016608..87944b1a7a 100644 --- a/drivers/ufs/Makefile +++ b/drivers/ufs/Makefile @@ -5,4 +5,5 @@
obj-$(CONFIG_UFS) += ufs.o ufs-uclass.o obj-$(CONFIG_CADENCE_UFS) += cdns-platform.o +obj-$(CONFIG_QCOM_UFS) += qcom-ufshcd.o obj-$(CONFIG_TI_J721E_UFS) += ti-j721e-ufs.o diff --git a/drivers/ufs/qcom-ufshcd.c b/drivers/ufs/qcom-ufshcd.c new file mode 100644 index 0000000000..ca55c3e8f5 --- /dev/null +++ b/drivers/ufs/qcom-ufshcd.c @@ -0,0 +1,880 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2023 Bhupesh Sharma bhupesh.sharma@linaro.org + * + * Based on Linux driver + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <ufs.h> + +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> + +#include "ufs.h" +#include "ufs-qcom.h" + +#define MSEC_PER_SEC (1000L) +#define USEC_PER_SEC (1000000L) +#define NSEC_PER_SEC (1000000000L) + +static int ufs_qcom_set_dme_vs_core_clk_ctrl_clear_div(struct ufs_hba *hba, + u32 clk_cycles); + +static int ufs_qcom_clk_get(struct udevice *dev, + const char *name, struct clk **clk_out, bool optional) +{ + struct clk *clk; + int err = 0; + + clk = devm_clk_get(dev, name); + if (!IS_ERR(clk)) { + *clk_out = clk; + return 0; + } + + err = PTR_ERR(clk); + + if (optional && err == -ENOENT) { + *clk_out = NULL; + return 0; + } + + if (err != -EPROBE_DEFER) + dev_err(dev, "failed to get %s err %d\n", name, err); + + return err; +} + +static int ufs_qcom_clk_enable(struct udevice *dev, + const char *name, struct clk *clk) +{ + int err = 0; + + err = clk_prepare_enable(clk); + if (err) + dev_err(dev, "%s: %s enable failed %d\n", __func__, name, err); + + return err; +} + +static int ufs_qcom_enable_lane_clks(struct ufs_qcom_priv *priv) +{ + int err; + struct udevice *dev = priv->hba->dev; + + if (priv->is_lane_clks_enabled) + return 0; + + err = ufs_qcom_clk_enable(dev, "rx_lane0_sync_clk", + priv->rx_l0_sync_clk); + if (err) + return err; + + err = ufs_qcom_clk_enable(dev, "tx_lane0_sync_clk", + priv->tx_l0_sync_clk); + if (err) + goto disable_rx_l0; + + err = ufs_qcom_clk_enable(dev, "rx_lane1_sync_clk", + priv->rx_l1_sync_clk); + if (err) + goto disable_tx_l0; + + priv->is_lane_clks_enabled = true; + + return 0; + +disable_tx_l0: + clk_disable_unprepare(priv->tx_l0_sync_clk); +disable_rx_l0: + clk_disable_unprepare(priv->rx_l0_sync_clk); + + return err; +} + +static int ufs_qcom_init_lane_clks(struct ufs_qcom_priv *priv) +{ + int err = 0; + struct udevice *dev = priv->hba->dev; + + err = ufs_qcom_clk_get(dev, "rx_lane0_sync_clk", + &priv->rx_l0_sync_clk, false); + if (err) + return err; + + err = ufs_qcom_clk_get(dev, "tx_lane0_sync_clk", + &priv->tx_l0_sync_clk, false); + if (err) + return err; + + err = ufs_qcom_clk_get(dev, "rx_lane1_sync_clk", + &priv->rx_l1_sync_clk, false); + if (err) + return err; + + return 0; +} + +static int ufs_qcom_enable_core_clks(struct ufs_qcom_priv *priv) +{ + int err; + struct udevice *dev = priv->hba->dev; + + if (priv->is_core_clks_enabled) + return 0; + + err = ufs_qcom_clk_enable(dev, "core_clk", priv->core_clk); + if (err) + return err; + + err = ufs_qcom_clk_enable(dev, "bus_aggr_clk", priv->bus_aggr_clk); + if (err) + goto disable_core_clk; + + err = ufs_qcom_clk_enable(dev, "iface_clk", priv->iface_clk); + if (err) + goto disable_bus_aggr_clk; + + err = ufs_qcom_clk_enable(dev, "core_clk_unipro", priv->core_clk_unipro); + if (err) + goto disable_iface_clk; + + priv->is_core_clks_enabled = true; + + return 0; + +disable_iface_clk: + clk_disable_unprepare(priv->iface_clk); +disable_bus_aggr_clk: + clk_disable_unprepare(priv->bus_aggr_clk); +disable_core_clk: + clk_disable_unprepare(priv->core_clk); + + return err; +} + +static int ufs_qcom_init_core_clks(struct ufs_qcom_priv *priv) +{ + int err = 0; + struct udevice *dev = priv->hba->dev; + + err = ufs_qcom_clk_get(dev, "core_clk", + &priv->core_clk, false); + if (err) + return err; + + err = ufs_qcom_clk_get(dev, "bus_aggr_clk", + &priv->bus_aggr_clk, false); + if (err) + return err; + + err = ufs_qcom_clk_get(dev, "iface_clk", &priv->iface_clk, false); + if (err) + return err; + + err = ufs_qcom_clk_get(dev, "core_clk_unipro", &priv->core_clk_unipro, false); + if (err) + return err; + + /* ref_clk is optional */ + + return 0; +} + +static void ufs_qcom_select_unipro_mode(struct ufs_qcom_priv *priv) +{ + ufshcd_rmwl(priv->hba, QUNIPRO_SEL, + ufs_qcom_cap_qunipro(priv) ? QUNIPRO_SEL : 0, + REG_UFS_CFG1); + + if (priv->hw_ver.major == 0x05) + ufshcd_rmwl(priv->hba, QUNIPRO_G4_SEL, 0, REG_UFS_CFG0); + + /* make sure above configuration is applied before we return */ + mb(); +} + +/* + * ufs_qcom_reset - reset host controller and PHY + */ +static int ufs_qcom_reset(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + int ret = 0; + + ret = reset_assert(&priv->core_reset); + if (ret) { + dev_err(hba->dev, "%s: core_reset assert failed, err = %d\n", + __func__, ret); + return ret; + } + + /* + * The hardware requirement for delay between assert/deassert + * is at least 3-4 sleep clock (32.7KHz) cycles, which comes to + * ~125us (4/32768). To be on the safe side add 200us delay. + */ + udelay(210); + + ret = reset_deassert(&priv->core_reset); + if (ret) + dev_err(hba->dev, "%s: core_reset deassert failed, err = %d\n", + __func__, ret); + + udelay(1100); + + return 0; +} + +static void ufs_qcom_set_caps(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + + if (priv->hw_ver.major >= 0x2) { + priv->caps = UFS_QCOM_CAP_QUNIPRO | + UFS_QCOM_CAP_RETAIN_SEC_CFG_AFTER_PWR_COLLAPSE; + } +} + +/** + * ufs_qcom_advertise_quirks - advertise the known QCOM UFS controller quirks + * @hba: host controller instance + * + * QCOM UFS host controller might have some non standard behaviours (quirks) + * than what is specified by UFSHCI specification. Advertise all such + * quirks to standard UFS host controller driver so standard takes them into + * account. + */ +static void ufs_qcom_advertise_quirks(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + + if (priv->hw_ver.major == 0x01) { + hba->quirks |= UFSHCD_QUIRK_DELAY_BEFORE_DME_CMDS + | UFSHCD_QUIRK_BROKEN_PA_RXHSUNTERMCAP + | UFSHCD_QUIRK_DME_PEER_ACCESS_AUTO_MODE; + + if (priv->hw_ver.minor == 0x0001 && priv->hw_ver.step == 0x0001) + hba->quirks |= UFSHCD_QUIRK_BROKEN_INTR_AGGR; + + hba->quirks |= UFSHCD_QUIRK_BROKEN_LCC; + } + + if (priv->hw_ver.major == 0x2) { + hba->quirks |= UFSHCD_QUIRK_BROKEN_UFS_HCI_VERSION; + + if (!ufs_qcom_cap_qunipro(priv)) + /* Legacy UniPro mode still need following quirks */ + hba->quirks |= (UFSHCD_QUIRK_DELAY_BEFORE_DME_CMDS + | UFSHCD_QUIRK_DME_PEER_ACCESS_AUTO_MODE + | UFSHCD_QUIRK_BROKEN_PA_RXHSUNTERMCAP); + } + + if (priv->hw_ver.major > 0x3) + hba->quirks |= UFSHCD_QUIRK_REINIT_AFTER_MAX_GEAR_SWITCH; +} + +static void ufs_qcom_dev_ref_clk_ctrl(struct ufs_hba *hba, bool enable) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + + if (priv->dev_ref_clk_ctrl_mmio && + (enable ^ priv->is_dev_ref_clk_enabled)) { + u32 temp = readl_relaxed(priv->dev_ref_clk_ctrl_mmio); + + if (enable) + temp |= priv->dev_ref_clk_en_mask; + else + temp &= ~priv->dev_ref_clk_en_mask; + + /* + * If we are here to disable this clock it might be immediately + * after entering into hibern8 in which case we need to make + * sure that device ref_clk is active for specific time after + * hibern8 enter. + */ + if (!enable) + udelay(10); + + writel_relaxed(temp, priv->dev_ref_clk_ctrl_mmio); + + /* + * Make sure the write to ref_clk reaches the destination and + * not stored in a Write Buffer (WB). + */ + readl(priv->dev_ref_clk_ctrl_mmio); + + /* + * If we call hibern8 exit after this, we need to make sure that + * device ref_clk is stable for at least 1us before the hibern8 + * exit command. + */ + if (enable) + udelay(1); + + priv->is_dev_ref_clk_enabled = enable; + } +} + +/** + * ufs_qcom_setup_clocks - enables/disable clocks + * @hba: host controller instance + * @on: If true, enable clocks else disable them. + * @status: PRE_CHANGE or POST_CHANGE notify + * + * Returns 0 on success, non-zero on failure. + */ +static int ufs_qcom_setup_clocks(struct ufs_hba *hba, bool on, + enum ufs_notify_change_status status) +{ + switch (status) { + case PRE_CHANGE: + if (!on) { + /* disable device ref_clk */ + ufs_qcom_dev_ref_clk_ctrl(hba, false); + } + break; + case POST_CHANGE: + if (on) { + /* enable the device ref clock for HS mode*/ + ufs_qcom_dev_ref_clk_ctrl(hba, true); + } + break; + } + + return 0; +} + +static int ufs_qcom_power_up_sequence(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + struct phy phy; + int ret; + + /* Reset UFS Host Controller and PHY */ + ret = ufs_qcom_reset(hba); + if (ret) + dev_warn(hba->dev, "%s: host reset returned %d\n", + __func__, ret); + + /* get phy */ + ret = generic_phy_get_by_name(hba->dev, "ufsphy", &phy); + if (ret) { + dev_warn(hba->dev, "%s: Unable to get QMP ufs phy, ret = %d\n", + __func__, ret); + return ret; + } + + /* phy initialization */ + ret = generic_phy_init(&phy); + if (ret) { + dev_err(hba->dev, "%s: phy init failed, ret = %d\n", + __func__, ret); + return ret; + } + + /* power on phy */ + ret = generic_phy_power_on(&phy); + if (ret) { + dev_err(hba->dev, "%s: phy power on failed, ret = %d\n", + __func__, ret); + goto out_disable_phy; + } + + ufs_qcom_select_unipro_mode(priv); + + return 0; + +out_disable_phy: + generic_phy_exit(&phy); + + return ret; +} + +static int ufs_qcom_check_hibern8(struct ufs_hba *hba) +{ + int err, retry_count = 50; + u32 tx_fsm_val = 0; + + do { + err = ufshcd_dme_get(hba, + UIC_ARG_MIB_SEL(MPHY_TX_FSM_STATE, + UIC_ARG_MPHY_TX_GEN_SEL_INDEX(0)), + &tx_fsm_val); + if (err || tx_fsm_val == TX_FSM_HIBERN8) + break; + + /* max. 200us */ + udelay(200); + retry_count--; + } while (retry_count != 0); + + /* + * check the state again. + */ + err = ufshcd_dme_get(hba, + UIC_ARG_MIB_SEL(MPHY_TX_FSM_STATE, + UIC_ARG_MPHY_TX_GEN_SEL_INDEX(0)), + &tx_fsm_val); + + if (err) { + dev_err(hba->dev, "%s: unable to get TX_FSM_STATE, err %d\n", + __func__, err); + } else if (tx_fsm_val != TX_FSM_HIBERN8) { + err = tx_fsm_val; + dev_err(hba->dev, "%s: invalid TX_FSM_STATE = %d\n", + __func__, err); + } + + return err; +} + +/* + * The UTP controller has a number of internal clock gating cells (CGCs). + * Internal hardware sub-modules within the UTP controller control the CGCs. + * Hardware CGCs disable the clock to inactivate UTP sub-modules not involved + * in a specific operation, UTP controller CGCs are by default disabled and + * this function enables them (after every UFS link startup) to save some power + * leakage. + */ +static void ufs_qcom_enable_hw_clk_gating(struct ufs_hba *hba) +{ + ufshcd_writel(hba, + ufshcd_readl(hba, REG_UFS_CFG2) | REG_UFS_CFG2_CGC_EN_ALL, + REG_UFS_CFG2); + + /* Ensure that HW clock gating is enabled before next operations */ + mb(); +} + +static int ufs_qcom_hce_enable_notify(struct ufs_hba *hba, + enum ufs_notify_change_status status) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + int err = 0; + + switch (status) { + case PRE_CHANGE: + ufs_qcom_power_up_sequence(hba); + /* + * The PHY PLL output is the source of tx/rx lane symbol + * clocks, hence, enable the lane clocks only after PHY + * is initialized. + */ + err = ufs_qcom_enable_core_clks(priv); + if (err < 0) + return err; + + err = ufs_qcom_enable_lane_clks(priv); + if (err < 0) + return err; + break; + case POST_CHANGE: + /* check if UFS PHY moved from DISABLED to HIBERN8 */ + err = ufs_qcom_check_hibern8(hba); + ufs_qcom_enable_hw_clk_gating(hba); + break; + default: + dev_err(hba->dev, "%s: invalid status %d\n", __func__, status); + err = -EINVAL; + break; + } + + return err; +} + +/* + * Returns zero for success and non-zero in case of a failure + */ +static int ufs_qcom_cfg_timers(struct ufs_hba *hba, u32 gear, + u32 hs, u32 rate, bool update_link_startup_timer) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + u32 core_clk_period_in_ns; + u32 tx_clk_cycles_per_us = 0; + unsigned long core_clk_rate = 0; + u32 core_clk_cycles_per_us = 0; + + static u32 pwm_fr_table[][2] = { + {UFS_PWM_G1, 0x1}, + {UFS_PWM_G2, 0x1}, + {UFS_PWM_G3, 0x1}, + {UFS_PWM_G4, 0x1}, + }; + + static u32 hs_fr_table_rA[][2] = { + {UFS_HS_G1, 0x1F}, + {UFS_HS_G2, 0x3e}, + {UFS_HS_G3, 0x7D}, + }; + + static u32 hs_fr_table_rB[][2] = { + {UFS_HS_G1, 0x24}, + {UFS_HS_G2, 0x49}, + {UFS_HS_G3, 0x92}, + }; + + /* + * The Qunipro controller does not use following registers: + * SYS1CLK_1US_REG, TX_SYMBOL_CLK_1US_REG, CLK_NS_REG & + * UFS_REG_PA_LINK_STARTUP_TIMER + * But UTP controller uses SYS1CLK_1US_REG register for Interrupt + * Aggregation logic. + */ + if (ufs_qcom_cap_qunipro(priv)) + return 0; + + if (gear == 0) { + dev_err(hba->dev, "%s: invalid gear = %d\n", __func__, gear); + return -EINVAL; + } + + core_clk_rate = clk_get_rate(priv->core_clk); + + /* If frequency is smaller than 1MHz, set to 1MHz */ + if (core_clk_rate < DEFAULT_CLK_RATE_HZ) + core_clk_rate = DEFAULT_CLK_RATE_HZ; + + core_clk_cycles_per_us = core_clk_rate / USEC_PER_SEC; + if (ufshcd_readl(hba, REG_UFS_SYS1CLK_1US) != core_clk_cycles_per_us) { + ufshcd_writel(hba, core_clk_cycles_per_us, REG_UFS_SYS1CLK_1US); + /* + * make sure above write gets applied before we return from + * this function. + */ + mb(); + } + + if (ufs_qcom_cap_qunipro(priv)) + return 0; + + core_clk_period_in_ns = NSEC_PER_SEC / core_clk_rate; + core_clk_period_in_ns <<= OFFSET_CLK_NS_REG; + core_clk_period_in_ns &= MASK_CLK_NS_REG; + + switch (hs) { + case FASTAUTO_MODE: + case FAST_MODE: + if (rate == PA_HS_MODE_A) { + if (gear > ARRAY_SIZE(hs_fr_table_rA)) { + dev_err(hba->dev, + "%s: index %d exceeds table size %zu\n", + __func__, gear, + ARRAY_SIZE(hs_fr_table_rA)); + return -EINVAL; + } + tx_clk_cycles_per_us = hs_fr_table_rA[gear-1][1]; + } else if (rate == PA_HS_MODE_B) { + if (gear > ARRAY_SIZE(hs_fr_table_rB)) { + dev_err(hba->dev, + "%s: index %d exceeds table size %zu\n", + __func__, gear, + ARRAY_SIZE(hs_fr_table_rB)); + return -EINVAL; + } + tx_clk_cycles_per_us = hs_fr_table_rB[gear-1][1]; + } else { + dev_err(hba->dev, "%s: invalid rate = %d\n", + __func__, rate); + return -EINVAL; + } + break; + case SLOWAUTO_MODE: + case SLOW_MODE: + if (gear > ARRAY_SIZE(pwm_fr_table)) { + dev_err(hba->dev, + "%s: index %d exceeds table size %zu\n", + __func__, gear, + ARRAY_SIZE(pwm_fr_table)); + return -EINVAL; + } + tx_clk_cycles_per_us = pwm_fr_table[gear-1][1]; + break; + case UNCHANGED: + default: + dev_err(hba->dev, "%s: invalid mode = %d\n", __func__, hs); + return -EINVAL; + } + + if (ufshcd_readl(hba, REG_UFS_TX_SYMBOL_CLK_NS_US) != + (core_clk_period_in_ns | tx_clk_cycles_per_us)) { + /* this register 2 fields shall be written at once */ + ufshcd_writel(hba, core_clk_period_in_ns | tx_clk_cycles_per_us, + REG_UFS_TX_SYMBOL_CLK_NS_US); + /* + * make sure above write gets applied before we return from + * this function. + */ + mb(); + } + + if (update_link_startup_timer && priv->hw_ver.major != 0x5) { + ufshcd_writel(hba, ((core_clk_rate / MSEC_PER_SEC) * 100), + REG_UFS_CFG0); + /* + * make sure that this configuration is applied before + * we return + */ + mb(); + } + + return 0; +} + +static int ufs_qcom_set_dme_vs_core_clk_ctrl_clear_div(struct ufs_hba *hba, + u32 clk_cycles) +{ + int err; + u32 core_clk_ctrl_reg; + + if (clk_cycles > DME_VS_CORE_CLK_CTRL_MAX_CORE_CLK_1US_CYCLES_MASK) + return -EINVAL; + + err = ufshcd_dme_get(hba, + UIC_ARG_MIB(DME_VS_CORE_CLK_CTRL), + &core_clk_ctrl_reg); + if (err) + return err; + + core_clk_ctrl_reg &= ~DME_VS_CORE_CLK_CTRL_MAX_CORE_CLK_1US_CYCLES_MASK; + core_clk_ctrl_reg |= clk_cycles; + + /* Clear CORE_CLK_DIV_EN */ + core_clk_ctrl_reg &= ~DME_VS_CORE_CLK_CTRL_CORE_CLK_DIV_EN_BIT; + + return ufshcd_dme_set(hba, + UIC_ARG_MIB(DME_VS_CORE_CLK_CTRL), + core_clk_ctrl_reg); +} + +/* TBD: Move this to common framework layer */ +u32 ufshcd_get_local_unipro_ver(struct ufs_hba *hba) +{ + /* HCI version 1.0 and 1.1 supports UniPro 1.41 */ + switch (hba->version) { + case UFSHCI_VERSION_10: + case UFSHCI_VERSION_11: + return UFS_UNIPRO_VER_1_41; + + case UFSHCI_VERSION_20: + case UFSHCI_VERSION_21: + default: + return UFS_UNIPRO_VER_1_6; + } +} + +static int ufs_qcom_link_startup_notify(struct ufs_hba *hba, + enum ufs_notify_change_status status) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + int err = 0; + + switch (status) { + case PRE_CHANGE: + if (ufs_qcom_cfg_timers(hba, UFS_PWM_G1, SLOWAUTO_MODE, + 0, true)) { + dev_err(hba->dev, "%s: ufs_qcom_cfg_timers() failed\n", + __func__); + return -EINVAL; + } + + if (ufs_qcom_cap_qunipro(priv)) + /* + * set unipro core clock cycles to 150 & clear clock + * divider + */ + err = ufs_qcom_set_dme_vs_core_clk_ctrl_clear_div(hba, + 150); + + /* + * Some UFS devices (and may be host) have issues if LCC is + * enabled. So we are setting PA_Local_TX_LCC_Enable to 0 + * before link startup which will make sure that both host + * and device TX LCC are disabled once link startup is + * completed. + */ + if (ufshcd_get_local_unipro_ver(hba) != UFS_UNIPRO_VER_1_41) + err = ufshcd_dme_set(hba, UIC_ARG_MIB(PA_LOCAL_TX_LCC_ENABLE), 0); + + break; + default: + break; + } + + return err; +} + +/** + * ufs_qcom_init - bind phy with controller + * @hba: host controller instance + * + * Powers up PHY enabling clocks and regulators. + * + * Returns -EPROBE_DEFER if binding fails, returns negative error + * on phy power up failure and returns zero on success. + */ +static int ufs_qcom_init(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + int err; + + priv->hba = hba; + + /* setup clocks */ + ufs_qcom_setup_clocks(hba, true, PRE_CHANGE); + ufs_qcom_setup_clocks(hba, true, POST_CHANGE); + + ufs_qcom_get_controller_revision(hba, &priv->hw_ver.major, + &priv->hw_ver.minor, &priv->hw_ver.step); + dev_info(hba->dev, "Qcom UFS HC version: %d.%d.%d\n", priv->hw_ver.major, + priv->hw_ver.minor, priv->hw_ver.step); + + /* + * for newer controllers, device reference clock control bit has + * moved inside UFS controller register address space itself. + */ + if (priv->hw_ver.major >= 0x02) { + priv->dev_ref_clk_ctrl_mmio = hba->mmio_base + REG_UFS_CFG1; + priv->dev_ref_clk_en_mask = BIT(26); + } + + err = ufs_qcom_init_core_clks(priv); + if (err) { + dev_err(hba->dev, "failed to initialize core clocks, err:%d\n", err); + return err; + } + + err = ufs_qcom_init_lane_clks(priv); + if (err) { + dev_err(hba->dev, "failed to initialize lane clocks, err:%d\n", err); + return err; + } + + ufs_qcom_set_caps(hba); + ufs_qcom_advertise_quirks(hba); + ufs_qcom_setup_clocks(hba, true, POST_CHANGE); + + /* Power up the PHY using UFS_HS_G3. */ + priv->hs_gear = UFS_HS_G3; + + return 0; +} + +static void ufshcd_print_clk_freqs(struct ufs_hba *hba) +{ + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + + dev_info(hba->dev, "clk: %s, rate: %lu\n", "bus_aggr_clk", + clk_get_rate(priv->bus_aggr_clk)); + dev_info(hba->dev, "clk: %s, rate: %lu\n", "iface_clk", + clk_get_rate(priv->iface_clk)); + dev_info(hba->dev, "clk: %s, rate: %lu\n", "core_clk_unipro", + clk_get_rate(priv->core_clk_unipro)); +} + +static void ufs_qcom_dump_dbg_regs(struct ufs_hba *hba) +{ + u32 reg; + struct ufs_qcom_priv *priv = dev_get_priv(hba->dev); + + ufshcd_dump_regs(hba, REG_UFS_SYS1CLK_1US, 16 * 4, + "HCI Vendor Specific Registers "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_UFS_DBG_RD_REG_OCSC); + ufshcd_dump_regs(hba, reg, 44 * 4, "UFS_UFS_DBG_RD_REG_OCSC "); + + reg = ufshcd_readl(hba, REG_UFS_CFG1); + reg |= UTP_DBG_RAMS_EN; + ufshcd_writel(hba, reg, REG_UFS_CFG1); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_UFS_DBG_RD_EDTL_RAM); + ufshcd_dump_regs(hba, reg, 32 * 4, "UFS_UFS_DBG_RD_EDTL_RAM "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_UFS_DBG_RD_DESC_RAM); + ufshcd_dump_regs(hba, reg, 128 * 4, "UFS_UFS_DBG_RD_DESC_RAM "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_UFS_DBG_RD_PRDT_RAM); + ufshcd_dump_regs(hba, reg, 64 * 4, "UFS_UFS_DBG_RD_PRDT_RAM "); + + /* clear bit 17 - UTP_DBG_RAMS_EN */ + ufshcd_rmwl(hba, UTP_DBG_RAMS_EN, 0, REG_UFS_CFG1); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_UAWM); + ufshcd_dump_regs(hba, reg, 4 * 4, "UFS_DBG_RD_REG_UAWM "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_UARM); + ufshcd_dump_regs(hba, reg, 4 * 4, "UFS_DBG_RD_REG_UARM "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_TXUC); + ufshcd_dump_regs(hba, reg, 48 * 4, "UFS_DBG_RD_REG_TXUC "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_RXUC); + ufshcd_dump_regs(hba, reg, 27 * 4, "UFS_DBG_RD_REG_RXUC "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_DFC); + ufshcd_dump_regs(hba, reg, 19 * 4, "UFS_DBG_RD_REG_DFC "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_TRLUT); + ufshcd_dump_regs(hba, reg, 34 * 4, "UFS_DBG_RD_REG_TRLUT "); + + reg = ufs_qcom_get_debug_reg_offset(priv, UFS_DBG_RD_REG_TMRLUT); + ufshcd_dump_regs(hba, reg, 9 * 4, "UFS_DBG_RD_REG_TMRLUT "); + + ufshcd_print_clk_freqs(hba); +} + +static struct ufs_hba_ops ufs_qcom_hba_ops = { + .init = ufs_qcom_init, + .dbg_register_dump = ufs_qcom_dump_dbg_regs, + .hce_enable_notify = ufs_qcom_hce_enable_notify, + .link_startup_notify = ufs_qcom_link_startup_notify, +}; + +static int ufs_qcom_probe(struct udevice *dev) +{ + struct ufs_qcom_priv *priv = dev_get_priv(dev); + int ret; + + /* get resets */ + ret = reset_get_by_name(dev, "rst", &priv->core_reset); + if (ret) { + dev_err(dev, "failed to get reset, ret:%d\n", ret); + return ret; + } + + ret = ufshcd_probe(dev, &ufs_qcom_hba_ops); + if (ret) { + dev_err(dev, "ufshcd_probe() failed, ret:%d\n", ret); + return ret; + } + + return 0; +} + +static int ufs_qcom_bind(struct udevice *dev) +{ + struct udevice *scsi_dev; + + return ufs_scsi_bind(dev, &scsi_dev); +} + +static const struct udevice_id ufs_qcom_ids[] = { + { .compatible = "qcom,ufshc" }, + {}, +}; + +U_BOOT_DRIVER(qcom_ufshcd) = { + .name = "qcom-ufshcd", + .id = UCLASS_UFS, + .of_match = ufs_qcom_ids, + .probe = ufs_qcom_probe, + .bind = ufs_qcom_bind, + .priv_auto = sizeof(struct ufs_qcom_priv), +}; diff --git a/drivers/ufs/ufs-qcom.h b/drivers/ufs/ufs-qcom.h new file mode 100644 index 0000000000..be5f558aef --- /dev/null +++ b/drivers/ufs/ufs-qcom.h @@ -0,0 +1,275 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* Copyright (c) 2013-2015, The Linux Foundation. All rights reserved. + */ + +#ifndef UFS_QCOM_H_ +#define UFS_QCOM_H_ + +#include <reset.h> +#include <linux/bitfield.h> + +#define MAX_UFS_QCOM_HOSTS 1 +#define MAX_U32 (~(u32)0) +#define MPHY_TX_FSM_STATE 0x41 +#define TX_FSM_HIBERN8 0x1 +#define HBRN8_POLL_TOUT_MS 100 +#define DEFAULT_CLK_RATE_HZ 1000000 +#define BUS_VECTOR_NAME_LEN 32 +#define MAX_SUPP_MAC 64 + +#define UFS_HW_VER_MAJOR_MASK GENMASK(31, 28) +#define UFS_HW_VER_MINOR_MASK GENMASK(27, 16) +#define UFS_HW_VER_STEP_MASK GENMASK(15, 0) + +/* vendor specific pre-defined parameters */ +#define SLOW 1 +#define FAST 2 + +#define UFS_QCOM_LIMIT_HS_RATE PA_HS_MODE_B + +/* QCOM UFS host controller vendor specific registers */ +enum { + REG_UFS_SYS1CLK_1US = 0xC0, + REG_UFS_TX_SYMBOL_CLK_NS_US = 0xC4, + REG_UFS_LOCAL_PORT_ID_REG = 0xC8, + REG_UFS_PA_ERR_CODE = 0xCC, + /* On older UFS revisions, this register is called "RETRY_TIMER_REG" */ + REG_UFS_PARAM0 = 0xD0, + /* On older UFS revisions, this register is called "REG_UFS_PA_LINK_STARTUP_TIMER" */ + REG_UFS_CFG0 = 0xD8, + REG_UFS_CFG1 = 0xDC, + REG_UFS_CFG2 = 0xE0, + REG_UFS_HW_VERSION = 0xE4, + + UFS_TEST_BUS = 0xE8, + UFS_TEST_BUS_CTRL_0 = 0xEC, + UFS_TEST_BUS_CTRL_1 = 0xF0, + UFS_TEST_BUS_CTRL_2 = 0xF4, + UFS_UNIPRO_CFG = 0xF8, + + /* + * QCOM UFS host controller vendor specific registers + * added in HW Version 3.0.0 + */ + UFS_AH8_CFG = 0xFC, + + REG_UFS_CFG3 = 0x271C, +}; + +/* QCOM UFS host controller vendor specific debug registers */ +enum { + UFS_DBG_RD_REG_UAWM = 0x100, + UFS_DBG_RD_REG_UARM = 0x200, + UFS_DBG_RD_REG_TXUC = 0x300, + UFS_DBG_RD_REG_RXUC = 0x400, + UFS_DBG_RD_REG_DFC = 0x500, + UFS_DBG_RD_REG_TRLUT = 0x600, + UFS_DBG_RD_REG_TMRLUT = 0x700, + UFS_UFS_DBG_RD_REG_OCSC = 0x800, + + UFS_UFS_DBG_RD_DESC_RAM = 0x1500, + UFS_UFS_DBG_RD_PRDT_RAM = 0x1700, + UFS_UFS_DBG_RD_RESP_RAM = 0x1800, + UFS_UFS_DBG_RD_EDTL_RAM = 0x1900, +}; + +enum { + UFS_MEM_CQIS_VS = 0x8, +}; + +#define UFS_CNTLR_2_x_x_VEN_REGS_OFFSET(x) (0x000 + x) +#define UFS_CNTLR_3_x_x_VEN_REGS_OFFSET(x) (0x400 + x) + +/* bit definitions for REG_UFS_CFG0 register */ +#define QUNIPRO_G4_SEL BIT(5) + +/* bit definitions for REG_UFS_CFG1 register */ +#define QUNIPRO_SEL BIT(0) +#define UFS_PHY_SOFT_RESET BIT(1) +#define UTP_DBG_RAMS_EN BIT(17) +#define TEST_BUS_EN BIT(18) +#define TEST_BUS_SEL GENMASK(22, 19) +#define UFS_REG_TEST_BUS_EN BIT(30) + +#define UFS_PHY_RESET_ENABLE 1 +#define UFS_PHY_RESET_DISABLE 0 + +/* bit definitions for REG_UFS_CFG2 register */ +#define UAWM_HW_CGC_EN BIT(0) +#define UARM_HW_CGC_EN BIT(1) +#define TXUC_HW_CGC_EN BIT(2) +#define RXUC_HW_CGC_EN BIT(3) +#define DFC_HW_CGC_EN BIT(4) +#define TRLUT_HW_CGC_EN BIT(5) +#define TMRLUT_HW_CGC_EN BIT(6) +#define OCSC_HW_CGC_EN BIT(7) + +/* bit definitions for REG_UFS_PARAM0 */ +#define MAX_HS_GEAR_MASK GENMASK(6, 4) +#define UFS_QCOM_MAX_GEAR(x) FIELD_GET(MAX_HS_GEAR_MASK, (x)) + +/* bit definition for UFS_UFS_TEST_BUS_CTRL_n */ +#define TEST_BUS_SUB_SEL_MASK GENMASK(4, 0) /* All XXX_SEL fields are 5 bits wide */ + +#define REG_UFS_CFG2_CGC_EN_ALL (UAWM_HW_CGC_EN | UARM_HW_CGC_EN |\ + TXUC_HW_CGC_EN | RXUC_HW_CGC_EN |\ + DFC_HW_CGC_EN | TRLUT_HW_CGC_EN |\ + TMRLUT_HW_CGC_EN | OCSC_HW_CGC_EN) + +/* bit offset */ +#define OFFSET_CLK_NS_REG 0xa + +/* bit masks */ +#define MASK_TX_SYMBOL_CLK_1US_REG GENMASK(9, 0) +#define MASK_CLK_NS_REG GENMASK(23, 10) + +/* QUniPro Vendor specific attributes */ +#define PA_VS_CONFIG_REG1 0x9000 +#define DME_VS_CORE_CLK_CTRL 0xD002 +/* bit and mask definitions for DME_VS_CORE_CLK_CTRL attribute */ +#define DME_VS_CORE_CLK_CTRL_CORE_CLK_DIV_EN_BIT BIT(8) +#define DME_VS_CORE_CLK_CTRL_MAX_CORE_CLK_1US_CYCLES_MASK 0xFF + +static inline void +ufs_qcom_get_controller_revision(struct ufs_hba *hba, + u8 *major, u16 *minor, u16 *step) +{ + u32 ver = ufshcd_readl(hba, REG_UFS_HW_VERSION); + + *major = FIELD_GET(UFS_HW_VER_MAJOR_MASK, ver); + *minor = FIELD_GET(UFS_HW_VER_MINOR_MASK, ver); + *step = FIELD_GET(UFS_HW_VER_STEP_MASK, ver); +}; + +static inline void ufs_qcom_assert_reset(struct ufs_hba *hba) +{ + ufshcd_rmwl(hba, UFS_PHY_SOFT_RESET, FIELD_PREP(UFS_PHY_SOFT_RESET, UFS_PHY_RESET_ENABLE), + REG_UFS_CFG1); + + /* + * Make sure assertion of ufs phy reset is written to + * register before returning + */ + mb(); +} + +static inline void ufs_qcom_deassert_reset(struct ufs_hba *hba) +{ + ufshcd_rmwl(hba, UFS_PHY_SOFT_RESET, FIELD_PREP(UFS_PHY_SOFT_RESET, UFS_PHY_RESET_DISABLE), + REG_UFS_CFG1); + + /* + * Make sure de-assertion of ufs phy reset is written to + * register before returning + */ + mb(); +} + +/* Host controller hardware version: major.minor.step */ +struct ufs_hw_version { + u16 step; + u16 minor; + u8 major; +}; + +struct ufs_qcom_testbus { + u8 select_major; + u8 select_minor; +}; + +struct gpio_desc; + +struct ufs_qcom_priv { + /* + * Set this capability if host controller supports the QUniPro mode + * and if driver wants the Host controller to operate in QUniPro mode. + * Note: By default this capability will be kept enabled if host + * controller supports the QUniPro mode. + */ + #define UFS_QCOM_CAP_QUNIPRO 0x1 + + /* + * Set this capability if host controller can retain the secure + * configuration even after UFS controller core power collapse. + */ + #define UFS_QCOM_CAP_RETAIN_SEC_CFG_AFTER_PWR_COLLAPSE 0x2 + u32 caps; + + struct phy *generic_phy; + struct ufs_hba *hba; + struct ufs_pa_layer_attr dev_req_params; + + struct clk *core_clk; + struct clk *bus_aggr_clk; + struct clk *iface_clk; + struct clk *core_clk_unipro; + struct clk *ref_clk; + bool is_core_clks_enabled; + + struct clk *rx_l0_sync_clk; + struct clk *tx_l0_sync_clk; + struct clk *rx_l1_sync_clk; + struct clk *tx_l1_sync_clk; + bool is_lane_clks_enabled; + + struct ufs_hw_version hw_ver; + + /* Reset control of HCI */ + struct reset_ctl core_reset; + + u32 hs_gear; + + int esi_base; + bool esi_enabled; + + void __iomem *dev_ref_clk_ctrl_mmio; + bool is_dev_ref_clk_enabled; + + u32 dev_ref_clk_en_mask; +}; + +static inline u32 +ufs_qcom_get_debug_reg_offset(struct ufs_qcom_priv *host, u32 reg) +{ + if (host->hw_ver.major <= 0x02) + return UFS_CNTLR_2_x_x_VEN_REGS_OFFSET(reg); + + return UFS_CNTLR_3_x_x_VEN_REGS_OFFSET(reg); +}; + +#define ufs_qcom_is_link_off(hba) ufshcd_is_link_off(hba) +#define ufs_qcom_is_link_active(hba) ufshcd_is_link_active(hba) +#define ufs_qcom_is_link_hibern8(hba) ufshcd_is_link_hibern8(hba) + +int ufs_qcom_testbus_config(struct ufs_qcom_priv *host); + +static inline bool ufs_qcom_cap_qunipro(struct ufs_qcom_priv *host) +{ + return host->caps & UFS_QCOM_CAP_QUNIPRO; +} + +/* ufs-qcom-ice.c */ + +#ifdef CONFIG_SCSI_UFS_CRYPTO +int ufs_qcom_ice_init(struct ufs_qcom_priv *host); +int ufs_qcom_ice_enable(struct ufs_qcom_priv *host); +int ufs_qcom_ice_resume(struct ufs_qcom_priv *host); +int ufs_qcom_ice_program_key(struct ufs_hba *hba, + const union ufs_crypto_cfg_entry *cfg, int slot); +#else +static inline int ufs_qcom_ice_init(struct ufs_qcom_priv *host) +{ + return 0; +} +static inline int ufs_qcom_ice_enable(struct ufs_qcom_priv *host) +{ + return 0; +} +static inline int ufs_qcom_ice_resume(struct ufs_qcom_priv *host) +{ + return 0; +} +#define ufs_qcom_ice_program_key NULL +#endif /* !CONFIG_SCSI_UFS_CRYPTO */ + +#endif /* UFS_QCOM_H_ */
- struct ufs_qcom_priv *priv = dev_get_priv(hba->dev);
- if (priv->dev_ref_clk_ctrl_mmio &&
Invert condition to reduce indent.
if (enable)
else
* hibern8 enter.
if (!enable)
udelay(10);
* exit command.
if (enable)
udelay(1);
- int err, retry_count = 50;
- u32 tx_fsm_val = 0;
- do {
&tx_fsm_val);
break;
/* max. 200us */
udelay(200);
retry_count--;
- } while (retry_count != 0);
Is this some readx_poll_timeout() reimplementation ?
Add 'reset' controller node in Qualcomm SDM845 dtsi.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- arch/arm/dts/sdm845.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/sdm845.dtsi b/arch/arm/dts/sdm845.dtsi index 3b86b9328f..056a1674d5 100644 --- a/arch/arm/dts/sdm845.dtsi +++ b/arch/arm/dts/sdm845.dtsi @@ -26,6 +26,12 @@ #power-domain-cells = <1>; };
+ reset: gcc-reset@100000 { + compatible = "qcom,gcc-reset-sdm845"; + reg = <0x00100000 0x1f0000>; + #reset-cells = <1>; + }; + gpio_north: gpio_north@3900000 { #gpio-cells = <2>; compatible = "qcom,sdm845-pinctrl";
Add UFS HC and PHY nodes in Qualcomm SDM845 dtsi.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- arch/arm/dts/sdm845.dtsi | 62 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+)
diff --git a/arch/arm/dts/sdm845.dtsi b/arch/arm/dts/sdm845.dtsi index 056a1674d5..9ef41e3c84 100644 --- a/arch/arm/dts/sdm845.dtsi +++ b/arch/arm/dts/sdm845.dtsi @@ -30,6 +30,68 @@ compatible = "qcom,gcc-reset-sdm845"; reg = <0x00100000 0x1f0000>; #reset-cells = <1>; + + ufs_mem_hc: ufshc@1d84000 { + compatible = "qcom,sdm845-ufshc", "qcom,ufshc", + "jedec,ufs-2.0"; + reg = <0x01d84000 0x2500>; + phys = <&ufs_mem_phy_lanes>; + phy-names = "ufsphy"; + lanes-per-direction = <2>; + #reset-cells = <1>; + resets = <&reset GCC_UFS_PHY_BCR>; + reset-names = "rst"; + + power-domains = <&gcc UFS_PHY_GDSC>; + + clock-names = + "core_clk", + "bus_aggr_clk", + "iface_clk", + "core_clk_unipro", + "tx_lane0_sync_clk", + "rx_lane0_sync_clk", + "rx_lane1_sync_clk", + "ice_core_clk"; + clocks = + <&gcc GCC_UFS_PHY_AXI_CLK>, + <&gcc GCC_AGGRE_UFS_PHY_AXI_CLK>, + <&gcc GCC_UFS_PHY_AHB_CLK>, + <&gcc GCC_UFS_PHY_UNIPRO_CORE_CLK>, + <&gcc GCC_UFS_PHY_TX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_0_CLK>, + <&gcc GCC_UFS_PHY_RX_SYMBOL_1_CLK>, + <&gcc GCC_UFS_PHY_ICE_CORE_CLK>; + freq-table-hz = + <50000000 200000000>, + <0 0>, + <0 0>, + <37500000 150000000>, + <0 0>, + <0 0>, + <0 0>, + <0 300000000>; + }; + + ufs_mem_phy: phy@1d87000 { + compatible = "qcom,sdm845-qmp-ufs-phy"; + reg = <0x01d87000 0x18c>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + clock-names = "ref", + "ref_aux"; + clocks = <&gcc GCC_UFS_MEM_CLKREF_CLK>, + <&gcc GCC_UFS_PHY_PHY_AUX_CLK>; + + ufs_mem_phy_lanes: phy@1d87400 { + reg = <0x01d87400 0x108>, + <0x01d87600 0x1e0>, + <0x01d87c00 0x1dc>, + <0x01d87800 0x108>, + <0x01d87a00 0x1e0>; + #phy-cells = <0>; + }; };
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- configs/dragonboard845c_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/dragonboard845c_defconfig b/configs/dragonboard845c_defconfig index a69d82761a..e2676a37b5 100644 --- a/configs/dragonboard845c_defconfig +++ b/configs/dragonboard845c_defconfig @@ -4,6 +4,7 @@ CONFIG_COUNTER_FREQUENCY=19000000 CONFIG_POSITION_INDEPENDENT=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_DEFAULT_DEVICE_TREE="dragonboard845c" +CONFIG_DM_RESET=y CONFIG_TARGET_DRAGONBOARD845C=y CONFIG_IDENT_STRING="\nQualcomm-DragonBoard 845C" CONFIG_SYS_LOAD_ADDR=0x80000000
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- configs/dragonboard845c_defconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/configs/dragonboard845c_defconfig b/configs/dragonboard845c_defconfig index e2676a37b5..0dd5ce6159 100644 --- a/configs/dragonboard845c_defconfig +++ b/configs/dragonboard845c_defconfig @@ -18,13 +18,23 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=64 CONFIG_SYS_CBSIZE=512 CONFIG_CMD_GPIO=y +CONFIG_CMD_PART=y +CONFIG_CMD_UFS=y +CONFIG_DOS_PARTITION=y +CONFIG_EFI_PARTITION=y # CONFIG_NET is not set CONFIG_CLK=y CONFIG_MSM_GPIO=y CONFIG_QCOM_PMIC_GPIO=y +CONFIG_PHY=y +CONFIG_PHY_QCOM_QMP_UFS=y CONFIG_PINCTRL=y CONFIG_DM_PMIC=y CONFIG_PMIC_QCOM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_MSM_GENI_SERIAL=y CONFIG_SPMI_MSM=y +CONFIG_UFS=y +CONFIG_QCOM_UFS=y CONFIG_LMB_MAX_REGIONS=64
Since Faiz Abbas's email ID is no longer valid, drop him from UFS Maintainer list.
Since I am using the UFS framework now extensively on Qualcomm Snapdragon SoCs, so proposing myself as the new UFS maintainer.
I have also been sending out u-boot UFS fixes in the recent past.
Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org --- MAINTAINERS | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 2db052961b..3b2acb5167 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1584,7 +1584,7 @@ T: git https://source.denx.de/u-boot/custodians/u-boot-ubi.git F: drivers/mtd/ubi/
UFS -M: Faiz Abbas faiz_abbas@ti.com +M: Bhupesh Sharma bhupesh.sharma@linaro.org S: Maintained F: drivers/ufs/
I believe TI is working on something here, so please coordinate with them.
Ok, well I haven't seen any reply to my earlier UFS fix related emails from TI, so I thought maybe no one is actively looking into this area. But I would love to hear from TI on the same..
Anyways since I will be working on the Qualcomm UFS glue layer going forward, I can propose to either be a UFS maintainer or a reviewer for now to make sure that the subsystem patches are reviewed and tested .
Thanks, Bhupesh
This is why I CCed Vignesh and Nishanth , coordinate with them.
Hi Bhupesh, Marek
I'd like to propose myself as a UFS maintainer along with Bhupesh, can help with reviewing and testing starting with these patches. If all seems okay, I can send a MAINTAINERS patch adding both Bhupesh and me.
Hi Neha,
On Thu, 17 Aug 2023 at 10:26, Neha Malcom Francis n-francis@ti.com wrote:
Hi Bhupesh, Marek
Thanks for stepping in. The above proposal looks good to me - I can help to-maintain this u-boot framework and work closely with you for testing / reviewing patches related to this area.
Many thanks to Nishanth as well for his prompt response when I ping'ed him regarding this :)
Thanks, Bhupesh
On 15:40-20230817, Bhupesh Sharma wrote:
Hi Neha,
Hi Bhupesh, Marek
Thank you folks for volunteering and keeping our community vibrant.
Hi Neha,
Hi Bhupesh, Marek
On 8/14/23 23:54, Bhupesh Sharma wrote: > Since Faiz Abbas's email ID is no longer valid, > drop him from UFS Maintainer list. > > Since I am using the UFS framework now extensively > on Qualcomm Snapdragon SoCs, so proposing myself as > the new UFS maintainer. > > I have also been sending out u-boot UFS fixes in the > recent past. > > Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org
Sure, I will send a v2 to reflect the same shortly.
Thanks, Bhupesh
Hi all,
Hi Neha,
Hi Bhupesh, Marek
Have posted a patch to update the same here: https://lore.kernel.org/u-boot/20230817120914.144240-1-n-francis@ti.com/
On Thu, 17 Aug 2023 at 17:42, Neha Malcom Francis n-francis@ti.com wrote:
Hi all,
Hi Neha,
Hi Bhupesh, Marek
On Tue, 15 Aug 2023 at 04:01, Marek Vasut marek.vasut@mailbox.org wrote: > > On 8/14/23 23:54, Bhupesh Sharma wrote: >> Since Faiz Abbas's email ID is no longer valid, >> drop him from UFS Maintainer list. >> >> Since I am using the UFS framework now extensively >> on Qualcomm Snapdragon SoCs, so proposing myself as >> the new UFS maintainer. >> >> I have also been sending out u-boot UFS fixes in the >> recent past. >> >> Signed-off-by: Bhupesh Sharma bhupesh.sharma@linaro.org > > I believe TI is working on something here, so please coordinate with them.
Many thanks Neha - I will then drop this from my v2.
Thanks, Bhupesh
This patchset enables the UFS controller on DragonBoard845c board which houses Qualcomm SDM845 Snapdragon SoC.
In addition to enabling the UFS HC and UFS QMP PHY found on this SoC this patchset also contains:
- Patches to add 'reset' controller support for SDM845 SoC.
- Minor UFS core framework fixes.
- Patches to sync u-boot UFS driver flow with Linux UFS driver.
- Patches which enable RESET, UFS and SCSI config options for DragonBoard845c.
I submitted a couple of UFS related patches yesterday, they add handling for controllers which cannot handle 64bit memory and add support for cache management. Please rebase on top of those, otherwise there will be hard to resolve conflicts.
[PATCH 1/6] ufs: Add UFSHCD_QUIRK_BROKEN_64BIT_ADDRESS [PATCH 1/2] blk: Add bounce buffer support to read/write operations
Ok, let me rebase, do a quick check and resend the patchset.
Thanks, Bhupesh
Bhupesh Sharma
Neha Malcom Francis
Nishanth Menon
