[U-Boot-Users] [PATCH 2/4] [ARM] Added Artila M-501 config file
Signed-off-by: Timo Tuunainen timo.tuunainen@sysart.fi --- include/configs/m501sk.h | 220 ++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 220 insertions(+), 0 deletions(-) create mode 100644 include/configs/m501sk.h
diff --git a/include/configs/m501sk.h b/include/configs/m501sk.h new file mode 100644 index 0000000..aad99fd --- /dev/null +++ b/include/configs/m501sk.h @@ -0,0 +1,220 @@ +/* + * Based on Modifications by Alan Lu / Artila and + * Rick Bronson rick@efn.org + * + * Configuation settings for the Artila M-501 starter kit with V02 processor card. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* ARM asynchronous clock */ +#define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 39) */ +#define AT91C_MASTER_CLOCK 59904000 /* peripheral clock (AT91C_MASTER_CLOCK / 3) */ +#define AT91_SLOW_CLOCK 32768 /* slow clock */ + +#define CONFIG_AT91RM9200DK 1 /* on an AT91RM9200DK Board */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +/* define this to include the functionality of boot.bin in u-boot */ +#undef CONFIG_BOOTBINFUNC +#undef CONFIG_AUTOBOOT_PROMPT +#define CONFIG_MENUPROMPT "." + +/* + * Size of malloc() pool + */ +#define CFG_MALLOC_LEN (CFG_ENV_SIZE + 128*1024) +#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ + +#define CONFIG_BAUDRATE 115200 + +#define CFG_AT91C_BRGR_DIVISOR 33 /* hardcode so no __divsi3 : AT91C_MASTER_CLOCK / baudrate / 16 */ + +/* + * Hardware drivers + */ +#define CFG_FLASH_CFI 1 +#define CFG_FLASH_CFI_DRIVER 1 +#define CFG_ENV_SECT_SIZE 0x20000 +#define CFG_FLASH_USE_BUFFER_WRITE +#define CFG_FLASH_PROTECTION /*for Intel P30 Flash*/ +#define CONFIG_HARD_I2C +#define CFG_I2C_SPEED 100 +#define CFG_I2C_SLAVE 0 +#define CFG_CONSOLE_INFO_QUIET +#undef CFG_ENV_IS_IN_EEPROM +#define CFG_I2C_EEPROM_ADDR 0x50 +#define CFG_I2C_EEPROM_ADDR_LEN 1 +#define CFG_EEPROM_AT24C16 +#define CFG_I2C_RTC_ADDR 0x32 +#undef CONFIG_RTC_DS1338 +#define CONFIG_RTC_RS5C372A +#undef CONFIG_POST +#define CONFIG_M501SK +#define CONFIG_CMC_PU2 + +/* define one of these to choose the DBGU, USART0 or USART1 as console */ +#define CONFIG_DBGU +#undef CONFIG_USART0 +#undef CONFIG_USART1 + +#undef CONFIG_HWFLOW /* don't include RTS/CTS flow control support */ +#undef CONFIG_MODEM_SUPPORT /* disable modem initialization stuff */ + +#define CONFIG_BOOTARGS "mem=32M console=ttyS0,115200 initrd=0x20800000,8192000 ramdisk_size=15360 root=/dev/ram0 rw mtdparts=phys_mapped_flash:128k(loader)ro,128k(reserved)ro,1408k(linux)ro,2560k(ramdisk)ro,-(userdisk)" +#define CONFIG_BOOTCOMMAND "bootm 10040000 101a0000" +#define CONFIG_BOOTDELAY 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_IPADDR 192.168.1.100 +#define CONFIG_SERVERIP 192.168.1.1 +#define CONFIG_GATEWAYIP 192.168.1.254 +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_BOOTFILE uImage +#define CONFIG_ETHADDR 00:13:48:aa:bb:cc +#define CONFIG_ENV_OVERWRITE 1 +#define BOARD_LATE_INIT + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "unlock=yes\0" + +#define CFG_CMD_JFFS2 +#undef CONFIG_CMD_EEPROM +#define CONFIG_CMD_NET +#define CONFIG_CMD_RUN +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_PING +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DATE +#define CONFIG_CMD_POST +#define CONFIG_CMD_MISC +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_IMI +#define CONFIG_CMD_NFS +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_ENV + +#define CFG_HUSH_PARSER +#define CONFIG_AUTO_COMPLETE +#define CFG_PROMPT_HUSH_PS2 ">>" + +#define CFG_MAX_NAND_DEVICE 0 /* Max number of NAND devices */ +#define SECTORSIZE 512 + +#define ADDR_COLUMN 1 +#define ADDR_PAGE 2 +#define ADDR_COLUMN_PAGE 3 + +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x2000000 /* 32 megs */ + +#define CFG_MEMTEST_START 0x21000000 /* PHYS_SDRAM */ +#define CFG_MEMTEST_END 0x00100000 /* CFG_MEMTEST_START + PHYS_SDRAM_SIZE - 262144 */ + +#define CONFIG_DRIVER_ETHER +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_AT91C_USE_RMII + +#define PHYS_FLASH_1 0x10000000 +#define PHYS_FLASH_SIZE 0x800000 /* 8 megs main flash */ +#define CFG_FLASH_BASE PHYS_FLASH_1 +#define CFG_MAX_FLASH_BANKS 1 +#define CFG_MAX_FLASH_SECT 256 +#define CFG_FLASH_ERASE_TOUT (2*CFG_HZ) /* Timeout for Flash Erase */ +#define CFG_FLASH_WRITE_TOUT (2*CFG_HZ) /* Timeout for Flash Write */ + +#ifdef CFG_ENV_IS_IN_DATAFLASH +#define CFG_ENV_OFFSET 0x20000 +#define CFG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CFG_ENV_OFFSET) +#define CFG_ENV_SIZE 0x2000 +#else +#define CFG_ENV_IS_IN_FLASH +#ifdef CONFIG_BOOTBINFUNC +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) +#define CFG_ENV_SIZE 0x10000 +#else +#define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x00020000) +#define CFG_ENV_SIZE 2048 +#endif +#endif + +#ifdef CFG_ENV_IS_IN_EEPROM +#define CFG_ENV_OFFSET 1024 +#define CFG_ENV_SIZE 1024 +#endif + +#define CFG_LOAD_ADDR 0x21000000 /* default load address */ + +/* use for protect flash sectors */ +#ifdef CONFIG_BOOTBINFUNC +#define CFG_BOOT_SIZE 0x00 /* 0 KBytes */ +#define CFG_U_BOOT_BASE PHYS_FLASH_1 +#define CFG_U_BOOT_SIZE 0x60000 /* 384 KBytes */ +#else +#define CFG_BOOT_SIZE 0x6000 /* 24 KBytes */ +#define CFG_U_BOOT_BASE (PHYS_FLASH_1 + 0x10000) +#define CFG_U_BOOT_SIZE 0x10000 /* 64 KBytes */ +#endif + +#define CFG_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CFG_PROMPT "U-Boot> " /* Monitor Command Prompt */ +#define CFG_CBSIZE 512 /* Console I/O Buffer Size */ +#define CFG_MAXARGS 16 /* max number of command args */ +#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ + +#ifndef __ASSEMBLY__ +/*----------------------------------------------------------------------- + * Board specific extension for bd_info + * + * This structure is embedded in the global bd_info (bd_t) structure + * and can be used by the board specific code (eg board/...) + */ + +struct bd_info_ext { + /* helper variable for board environment handling + * + * env_crc_valid == 0 => uninitialised + * env_crc_valid > 0 => environment crc in flash is valid + * env_crc_valid < 0 => environment crc in flash is invalid + */ + int env_crc_valid; +}; +#endif + +#define CFG_HZ 1000 +#define CFG_HZ_CLOCK AT91C_MASTER_CLOCK/2 + /* AT91C_TC0_CMR is implicitly set to AT91C_TC_TIMER_DIV1_CLOCK */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Timo Tuunainen
