[PATCH] sandbox: usb: Fix out-of-bounds read when fd=-1
sandbox_flash_bulk uses priv->read_len to determine if priv->buff contains the response data (such as from SCSI_INQUIRY). However, if priv->fd=-1 in handle_read, then priv->read_len is not set even though we are going to PHASE_DATA. This causes sandbox_flash_bulk to try and read len bytes from priv->buff, which likely goes past the end of the buffer. Fix this by always setting priv->read_len even if we aren't going to read anything.
Fixes: f4f715360c ("dm: usb: sandbox: Add an emulator for USB flash devices") Signed-off-by: Sean Anderson seanga2@gmail.com --- Is returning -EIO correct here? Should we return 0 (nothing read)? Or pretend to read the whole thing and then let the caller figure it out based on the status?
drivers/usb/emul/sandbox_flash.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/emul/sandbox_flash.c b/drivers/usb/emul/sandbox_flash.c index edabc1b3a7..f20c6ad754 100644 --- a/drivers/usb/emul/sandbox_flash.c +++ b/drivers/usb/emul/sandbox_flash.c @@ -228,9 +228,9 @@ static void handle_read(struct sandbox_flash_priv *priv, ulong lba, ulong transfer_len) { debug("%s: lba=%lx, transfer_len=%lx\n", __func__, lba, transfer_len); + priv->read_len = transfer_len; if (priv->fd != -1) { os_lseek(priv->fd, lba * SANDBOX_FLASH_BLOCK_LEN, OS_SEEK_SET); - priv->read_len = transfer_len; setup_response(priv, priv->buff, transfer_len * SANDBOX_FLASH_BLOCK_LEN); } else { @@ -336,6 +336,9 @@ static int sandbox_flash_bulk(struct udevice *dev, struct usb_device *udev, if (priv->read_len) { ulong bytes_read;
+ if (priv->fd == -1) + return -EIO; + bytes_read = os_read(priv->fd, buff, len); if (bytes_read != len) return -EIO;
Hi Sean,
It looks like returning an error makes sense, but Marek may know more.
if (priv->fd == -1)
return -EIO;
-- 2.35.1
Hi Sean,
Applied to u-boot-dm, thanks!
Sean Anderson
