[U-Boot] [PATCH] cmd: memio: Add support functions to read/write data
The existing source code (binop.c) includes read/write function to read/write data on DDR. To use these functions and avoid duplicate code, based on the existing functions, move and update the read/write function to a public file which is memio file. - New memio includes support functions to read/write data from/to DDR. - Update binop.c file to use read/write functions.
Signed-off-by: Dao Van Trung trungdv@vn.fujitsu.com Signed-off-by: Pham Duc Tung tungpd@vn.fujitsu.com Signed-off-by: kameyama eiji kameyama.eiji@fujitsu.com --- cmd/Makefile | 1 + cmd/binop.c | 24 +++--------------------- cmd/memio.c | 42 ++++++++++++++++++++++++++++++++++++++++++ include/memio.h | 16 ++++++++++++++++ 4 files changed, 62 insertions(+), 21 deletions(-) create mode 100644 cmd/memio.c create mode 100644 include/memio.h
diff --git a/cmd/Makefile b/cmd/Makefile index ac843b4b16..8c241b256e 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -86,6 +86,7 @@ obj-$(CONFIG_CMD_LOG) += log.o obj-$(CONFIG_ID_EEPROM) += mac.o obj-$(CONFIG_CMD_MD5SUM) += md5sum.o obj-$(CONFIG_CMD_MEMORY) += mem.o +obj-y += memio.o obj-$(CONFIG_CMD_IO) += io.o obj-$(CONFIG_CMD_MFSL) += mfsl.o obj-$(CONFIG_CMD_MII) += mii.o diff --git a/cmd/binop.c b/cmd/binop.c index 6d2df5f3dd..c14ca09fc3 100644 --- a/cmd/binop.c +++ b/cmd/binop.c @@ -7,6 +7,7 @@ #include <malloc.h> #include <mapmem.h> #include <linux/ctype.h> +#include <memio.h>
enum { OP_ID_XOR, @@ -44,26 +45,6 @@ void read_from_env_var(char *varname, u8 *result) hex2bin(result, varname, strlen(varname) / 2); }
-void read_from_mem(ulong addr, u8 *result, ulong len) -{ - u8 *src; - - src = map_sysmem(addr, len); - memcpy(result, src, len); - unmap_sysmem(src); -} - -void write_to_mem(char *varname, u8 *result, ulong len) -{ - ulong addr; - u8 *buf; - - addr = simple_strtoul(varname, NULL, 16); - buf = map_sysmem(addr, len); - memcpy(buf, result, len); - unmap_sysmem(buf); -} - static int do_binop(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong len; @@ -134,7 +115,8 @@ static int do_binop(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) destarg = argv[5];
if (*destarg == '*') - write_to_mem(destarg + 1, result, len); /* Skip asterisk */ + write_to_mem(simple_strtoul(destarg + 1, NULL, 16), + result, len); /* Skip asterisk */ else write_to_env_var(destarg, result, len); exit: diff --git a/cmd/memio.c b/cmd/memio.c new file mode 100644 index 0000000000..b9da5e5294 --- /dev/null +++ b/cmd/memio.c @@ -0,0 +1,42 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * cmd/memio.c + * Support functions to read/write data from/to DDR + * physical address. + * + * Copyright (C) 2019 FUJITSU VIETNAM LIMITED and FUJITSU COMPUTER + * TECHNOLOGIES LIMITED. All rights reserved. + */ +#include <common.h> +#include <mapmem.h> +#include <memio.h> + +/** + * read_from_mem() - Read data from DDR + * @addr: Physical address on DDR + * @result: Buffer for read data + * @len: Data length + */ +void read_from_mem(ulong addr, u8 *result, ulong len) +{ + u8 *src; + + src = map_sysmem(addr, len); + memcpy(result, src, len); + unmap_sysmem(src); +} + +/** + * write_to_mem() - Write data to DDR + * @addr: Physical address on DDR + * @result: Buffer of write data + * @len: Data length + */ +void write_to_mem(ulong addr, u8 *result, ulong len) +{ + u8 *buf; + + buf = map_sysmem(addr, len); + memcpy(buf, result, len); + unmap_sysmem(buf); +} diff --git a/include/memio.h b/include/memio.h new file mode 100644 index 0000000000..c5f397393b --- /dev/null +++ b/include/memio.h @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * include/memio.h + * This file declares support functions to read/write from/to + * DDR physical address. + * + * Copyright (C) 2019 FUJITSU VIETNAM LIMITED and FUJITSU COMPUTER + * TECHNOLOGIES LIMITED. All rights reserved. + */ +#ifndef _MEMIO_H_ +#define _MEMIO_H_ + +void read_from_mem(ulong addr, u8 *result, ulong len); +void write_to_mem(ulong addr, u8 *result, ulong len); + +#endif /* _MEMIO_H_ */
kameyama eiji
