How should I build u-boot for qemu_arm64_defconfig and run it on arm64 qemu virt machine?
Hello experts,
Today I tried this test from scratch.
In my environment, CROSS_COMPILE=aarch64-none-elf.
Under u-boot directory, when I do 'make CROSS_COMPILE=aarch64-none-elf- qemu_arm64_defconfig' and 'make -j28', I see this error at the end.
aarch64-none-elf-ld.bfd: invalid length for memory region .sram
after examining it, I added in include/configs/qemu-arm.h,
#define CONFIG_SPL_MAX_SIZE value to 0x400000
After fixing it, I got another similar error for .sdram and I added in include/configs/qemu-arm.h,
#define CONFIG_SPL_BSS_START_ADDR 0x40800000
#define CONFIG_SPL_BSS_MAX_SIZE 0x100000
Now I can do 'make -j28' with no error.
But I found I have both 'u-boot' and 'spl/u-boot-spl' generated and I realized for this qemu_arm64_defconfig, CONFIG_SPL=y and I get both u-boot proper and u-boot spl. (SPL: secondary program loader, proper: main bootloader. SPL runs first and the proper runs next).
Until now I did objcopy of the u-boot(proper) and then extended it to 0x400000 byte. (the pflash size of the virt machine which starts at address 0x00000000).
$ aarch64-none-elf-objcopy -O binary u-boot.v2022.07/u-boot pflashp.img
$ dd if=/dev/zero of=pflashp.img bs=1c count=1 seek=67108863
And the qemu command is :
$ qemu-6.2.0/build/aarch64-softmmu/qemu-system-aarch64 -machine virt,gic-version=max,secure=on,virtualization=true -cpu max -drive if=pflash,file=pflashp.img -m 2G -nographic -device loader,file=linux-5.15.68/arch/arm64/boot/Image,addr=0x80200000
The qemu virt machine has RAM from 0x40000000 until 0xbfffffff.
And I could see u-boot runs and it waits input for 3 seconds and outputs the u-boot prompt.
This is running u-boot (proper) from address 0 but since I have u-boot-spl too, I should run it from u-boot-spl first, shouldn't I?
How am I supposed to run u-boot-spl and u-boot on this qemu machine? (from lds files, it looks like they both start at address 0).
(qemu machine is arm64 virt machine, qemu 6.2.0).
Thank you.
Chan Kim
Hi Chan,
On Mon, 8 May 2023 at 03:41, Chan Kim ckim@etri.re.kr wrote:
Hello experts,
Have you tried the docs here?
https://u-boot.readthedocs.io/en/latest/board/emulation/qemu-arm.html
Why are you trying to run SPL?
Hi all,
Hope someone who know this top reads this. I made the pflashs.img with u-boot-spl and used it as the flash memory (from address 0x00000000 ~). So the u-boot-spl program runs. And I guess I have to load (using qemu command option) a kind of image that contains u-boot proper and make the u-boot-spl to load u-boot proper at another address from that image and jump to that address. How can I make that image using mkimage if I have the u-boot.bin file? I think the command should start like 'mkimage -O u-boot -T ... ' but I don't know what type I should give for -T option. I will be very much grateful If anyone tells me how to do it. By the way, I want to check pci_init function once u-boot proper runs and I found pci_init is called in board_init_r when u-boot proper runs.
Thank you! Chan Kim
-----Original Message----- From: "Chan Kim" ckim@etri.re.kr To: "U-Boot Mailing List" u-boot@lists.denx.de; qemu-discuss@nongnu.org; Cc: Sent: 2023-05-08 (월) 18:40:49 (UTC+09:00) Subject: How should I build u-boot for qemu_arm64_defconfig and run it on arm64 qemu virt machine?
Hello experts,
Thank you.
Chan Kim
Hello all,
I found by compiling u-boot-spl to start at 0x40200000 and using -kernel option, I can make u-boot-spl start loaded and started from 0x40200000. And then by loading the .itb file (FIT file) which contains u-boot proper binary at 0x40400000 using -device loader option, and setting CONFIG_SPL_LOAD_FIT_ADDERSS to 0x40400000 and I could make u-boot-spl execute u-boot at the end. To make .itb file, I used 'firmware = "uboot"' int the configuration, and 'type = "standalone"', 'os = "U-Boot"' and the 'uboot' image node. And I turned off SPL_BOOT_OS of course. I referenced the sample its files in u-boot. (I can't copy-paste the file now so I just tell you the key lines) Hope this helps someone layter. Thank you.
Chan Kim
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of 김찬 Sent: Tuesday, May 9, 2023 3:13 PM To: U-Boot Mailing List u-boot@lists.denx.de; qemu-discuss@nongnu.org Subject: RE: How should I build u-boot for qemu_arm64_defconfig and run it on arm64 qemu virt machine?
Hi all,
Thank you! Chan Kim
-----Original Message----- From: "Chan Kim" ckim@etri.re.kr To: "U-Boot Mailing List" u-boot@lists.denx.de; <qemu- discuss@nongnu.org>; Cc: Sent: 2023-05-08 (월) 18:40:49 (UTC+09:00) Subject: How should I build u-boot for qemu_arm64_defconfig and run it on arm64 qemu virt machine?
Hello experts,
$ qemu-6.2.0/build/aarch64-softmmu/qemu-system-aarch64 -machine virt,gic- version=max,secure=on,virtualization=true -cpu max -drive if=pflash,file=pflashp.img -m 2G -nographic -device loader,file=linux-5.15.68/arch/arm64/boot/Image,addr=0x80200000
Thank you.
Chan Kim
Chan Kim
김찬
