[U-Boot] [PATCH 1/3] Minor fixes for I2C address on MPC8572DS
MPC8572DS has two i2c buses. This patch moves the DDR SPD_EEPROM to i2c bus 1 according to the board spec, and adds the 2nd i2c bus offset.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- include/configs/MPC8572DS.h | 8 ++++++-- 1 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index d7e3a88..87b1011 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -108,6 +108,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CHIP_SELECTS_PER_CTRL 2
/* I2C addresses of SPD EEPROMs */ +#define CFG_SPD_BUS_NUM 1 /* SPD EEPROMS locate on I2C bus 1 */ #define SPD_EEPROM_ADDRESS1 0x51 /* CTLR 0 DIMM 0 */ #define SPD_EEPROM_ADDRESS2 0x52 /* CTLR 1 DIMM 0 */
@@ -293,11 +294,14 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_FSL_I2C /* Use FSL common I2C driver */ #define CONFIG_HARD_I2C /* I2C with hardware support */ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE #define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ #define CFG_I2C_EEPROM_ADDR 0x57 #define CFG_I2C_SLAVE 0x7F -#define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CFG_I2C_OFFSET 0x3100 +#define CFG_I2C_NOPROBES {0,0x29} /* Don't probe these addrs */ +#define CFG_I2C_OFFSET 0x3000 +#define CFG_I2C2_OFFSET 0x3100
/* * General PCI
Dear Haiying,
In message 1223048819-16850-1-git-send-email-Haiying.Wang@freescale.com you wrote:
I see "[PATCH 1/3] Minor fixes for I2C address on MPC8572DS" and "[PATCH 3/3] Remove redundant #define for MPC8536DS".
I cannot see a "[PATCH 2/3]" - am I missing something?
Dear Wolfgang,
On Sat, 2008-10-04 at 01:33 +0200, Wolfgang Denk wrote:
Dear Haiying,
The "[PATCH 2/3] Add ID EEPROM support for" MPC8572DS" was sent out between 1/3 and 3/3. I could see it from list. Anyway, I can re-send it to you.
Haiying
On Fri, Oct 3, 2008 at 10:46 AM, Haiying Wang Haiying.Wang@freescale.com wrote:
Applied 1-3, and they were pulled. :)
Thanks, Andy
Andy Fleming
Haiying Wang
