[U-Boot] [PATCH] sf: Adjust tab space's
Tab space's got adjusted on relevent files.
Signed-off-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com --- drivers/mtd/spi/sf_internal.h | 20 ++++++++++---------- include/spi.h | 12 ++++++------ include/spi_flash.h | 6 +++--- 3 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 785f7a9..58007de 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -31,9 +31,9 @@ enum spi_read_cmds { };
/* Normal - Extended - Full command set */ -#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) -#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) -#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST) +#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) +#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) +#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST)
/* sf param flags */ enum { @@ -67,12 +67,12 @@ enum { #define CMD_WRITE_STATUS 0x01 #define CMD_PAGE_PROGRAM 0x02 #define CMD_WRITE_DISABLE 0x04 -#define CMD_READ_STATUS 0x05 +#define CMD_READ_STATUS 0x05 #define CMD_QUAD_PAGE_PROGRAM 0x32 #define CMD_READ_STATUS1 0x35 #define CMD_WRITE_ENABLE 0x06 -#define CMD_READ_CONFIG 0x35 -#define CMD_FLAG_STATUS 0x70 +#define CMD_READ_CONFIG 0x35 +#define CMD_FLAG_STATUS 0x70
/* Read commands */ #define CMD_READ_ARRAY_SLOW 0x03 @@ -94,7 +94,7 @@ enum { /* Common status */ #define STATUS_WIP (1 << 0) #define STATUS_QEB_WINSPAN (1 << 1) -#define STATUS_QEB_MXIC (1 << 6) +#define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7)
#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN @@ -103,13 +103,13 @@ enum {
/* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) -#define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) +#define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) #define SPI_FLASH_SECTOR_ERASE_TIMEOUT (10 * CONFIG_SYS_HZ)
/* SST specific */ #ifdef CONFIG_SPI_FLASH_SST # define CMD_SST_BP 0x02 /* Byte Program */ -# define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */ +# define CMD_SST_AAI_WP 0xAD /* Auto Address Incr Word Program */
int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, const void *buf); @@ -124,7 +124,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) * @ext_jedec: Device ext_jedec ID * @sector_size: Sector size of this device - * @nr_sectors: No.of sectors on this device + * @nr_sectors: No.of sectors on this device * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour */ diff --git a/include/spi.h b/include/spi.h index 7829063..44abe68 100644 --- a/include/spi.h +++ b/include/spi.h @@ -30,7 +30,7 @@ #define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ #define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_U_PAGE (1 << 5) +#define SPI_XFER_U_PAGE (1 << 5)
/* SPI TX operation modes */ #define SPI_OPM_TX_QPP (1 << 0) @@ -43,18 +43,18 @@ #define SPI_OPM_RX_DIO (1 << 3) #define SPI_OPM_RX_QOF (1 << 4) #define SPI_OPM_RX_QIOF (1 << 5) -#define SPI_OPM_RX_EXTN (SPI_OPM_RX_AS | SPI_OPM_RX_AF | SPI_OPM_RX_DOUT | \ - SPI_OPM_RX_DIO | SPI_OPM_RX_QOF | \ - SPI_OPM_RX_QIOF) +#define SPI_OPM_RX_EXTN (SPI_OPM_RX_AS | SPI_OPM_RX_AF | \ + SPI_OPM_RX_DOUT | SPI_OPM_RX_DIO | \ + SPI_OPM_RX_QOF | SPI_OPM_RX_QIOF)
/* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0) -#define SPI_CONN_DUAL_SEPARATED (1 << 1) +#define SPI_CONN_DUAL_SEPARATED (1 << 1)
/* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec
-#define SPI_DEFAULT_WORDLEN 8 +#define SPI_DEFAULT_WORDLEN 8
#ifdef CONFIG_DM_SPI /* TODO(sjg@chromium.org): Remove this and use max_hz from struct spi_slave */ diff --git a/include/spi_flash.h b/include/spi_flash.h index 03f8306..481b4dd 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -43,7 +43,7 @@ struct spi_slave; * @size: Total flash size * @page_size: Write (page) size * @sector_size: Sector size - * @erase_size: Erase size + * @erase_size: Erase size * @bank_read_cmd: Bank read cmd * @bank_write_cmd: Bank write cmd * @bank_curr: Current flash bank @@ -51,8 +51,8 @@ struct spi_slave; * @erase_cmd: Erase cmd 4K, 32K, 64K * @read_cmd: Read cmd - Array Fast, Extn read and quad read. * @write_cmd: Write cmd - page and quad program. - * @dummy_byte: Dummy cycles for read operation. - * @memory_map: Address of read-only SPI flash access + * @dummy_byte: Dummy cycles for read operation. + * @memory_map: Address of read-only SPI flash access * @read: Flash read ops: Read len bytes at offset into buf * Supported cmds: Fast Array Read * @write: Flash write ops: Write len bytes from buf into offset
