[U-Boot] [PATCH] mtd: spi: winbond: add W25PXX support
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com --- drivers/mtd/spi/winbond.c | 17 ++++++++++++++++- 1 file changed, 16 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/winbond.c b/drivers/mtd/spi/winbond.c index 2716209..2a27837 100644 --- a/drivers/mtd/spi/winbond.c +++ b/drivers/mtd/spi/winbond.c @@ -18,6 +18,21 @@ struct winbond_spi_flash_params {
static const struct winbond_spi_flash_params winbond_spi_flash_table[] = { { + .id = 0x2014, + .nr_blocks = 16, + .name = "W25P80", + }, + { + .id = 0x2015, + .nr_blocks = 32, + .name = "W25P16", + }, + { + .id = 0x2016, + .nr_blocks = 64, + .name = "W25P32", + }, + { .id = 0x3013, .nr_blocks = 8, .name = "W25X40", @@ -104,7 +119,7 @@ struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode) }
flash->page_size = 256; - flash->sector_size = 4096; + flash->sector_size = (idcode[1] == 0x20) ? 65536 : 4096; flash->size = 4096 * 16 * params->nr_blocks;
return flash;
I have a simple question like these parts are legacy flashes i guess. Could you please tell me on which boards these were used?
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
flash->sector_size = (idcode[1] == 0x20) ? 65536 : 4096; flash->size = 4096 * 16 * params->nr_blocks; return flash;
-- 1.7.9.5
2013/5/22 Jagan Teki jagannadh.teki@gmail.com:
It's used on Faraday A369 evaluation board. However the u-boot source codes for A369 is still waiting for approval. Here is the link to u-boot patchwork:
http://patchwork.ozlabs.org/patch/242006/
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
-- 1.7.9.5
-- Best wishes, Kuo-Jung Su
Ok, Thanks for your information.
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
W25P80 is an 8Mbit flash right, is this name W25P80 or W25P08? ofcourse, I have seen the same on datasheet as well.
Thanks, Jagan.
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
-- 1.7.9.5
2013/5/23 Jagan Teki jagannadh.teki@gmail.com:
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
It's W25P80. They are formally NexFlash NX25P80, NX25P16 and NX25P32.
I've google for the W25P08, it looks like that Windond did have some legacy small SPI flash: W25P01, W25P02 .. W25P16. I guess it's a different production line...
BTW I don't have these chips and corresponding datasheet, too.
Thanks, Jagan.
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
-- 1.7.9.5
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
Ok.
Can you use the commit msg header as "sf: winbond: " Which is used for winbond mtd driver since from long, of-course not a big deal and also mentioned atleast single line message on body.
Simple recommendation here:. "Add support for Winbond's W25PXX SPI flash. These devices is used on Faraday A369 evaluation board"
Thanks, Jagan.
Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
Ok.
Sure, I'll re-format the patch and re-post again.
Thanks. It's pretty helpful to me, because my English is really terrible. :)
Thanks, Jagan.
Add support for Winbond's W25PXX SPI flash. These devices is used on Faraday A369 evaluation board.
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com CC: Jagan Teki jagannadh.teki@gmail.com CC: Tom Rini trini@ti.com --- Changes for v2: - Update commit message header - Add commit message body
return flash;
Changes for v2:
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
-- 1.7.9.5
Reviewed-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
-- Thanks, Jagan.
.id = 0x2014,
.nr_blocks = 16,
.name = "W25P80",
.id = 0x2015,
.nr_blocks = 32,
.name = "W25P16",
.id = 0x2016,
.nr_blocks = 64,
.name = "W25P32",
- { .id = 0x3013, .nr_blocks = 8, .name = "W25X40",
return flash;
Applied to u-boot-spi/master
-- Thanks, Jagan.
Jagan Teki
Kuo-Jung Su
