[U-Boot] [PATCH 0/2] arm64: Setting up initrd_hi at run time
we are running one u-boot configurations on various boards with different amount of memory that setting up initrd_high is problematic. There shouldn't be a problem to setup initrd_high at run time based on DDR size detection. The same changes are done for ZynqMP and Versal.
Thanks, Michal
Siva Durga Prasad Paladugu (1): arm64: versal: Set initrd_high to as high as possible
T Karthik Reddy (1): arm64: zynqmp: Set initrd_high to as high as possible
arch/arm/Kconfig | 16 ++++++++++++++++ board/xilinx/versal/board.c | 6 ++++++ board/xilinx/zynqmp/zynqmp.c | 6 ++++++ include/configs/xilinx_versal.h | 1 - include/configs/xilinx_zynqmp.h | 1 - 5 files changed, 28 insertions(+), 2 deletions(-)
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch is setting up the initrd_high to as high as possible by leaving max stack size for u-boot so that bigger rootfs can also be loaded by u-boot for booting kernel.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/Kconfig | 16 ++++++++++++++++ board/xilinx/versal/board.c | 6 ++++++ include/configs/xilinx_versal.h | 1 - 3 files changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index a93138aa0ada..33cb3e065830 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -462,6 +462,22 @@ config TPL_USE_ARCH_MEMSET Such implementation may be faster under some conditions but may increase the binary size.
+config SET_STACK_SIZE + bool "Enable an option to set max stack size that can be used" + default y if ARCH_VERSAL + help + This will enable an option to set max stack size that can be + used by u-boot. + +config STACK_SIZE + hex "Define max stack size that can be used by u-boot" + depends on SET_STACK_SIZE + default 0x4000000 if ARCH_VERSAL + help + Defines Max stack size that can be used by u-boot so that the + initrd_high will be calculated as base stack pointer minus this + stack size. + config ARM64_SUPPORT_AARCH32 bool "ARM64 system support AArch32 execution state" depends on ARM64 diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index a2b00aa0b662..2b4edd8738b4 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -12,6 +12,7 @@ #include <dm/device.h> #include <dm/uclass.h> #include <versalpl.h> +#include <linux/sizes.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -88,6 +89,7 @@ int board_late_init(void) const char *mode; char *new_targets; char *env_targets; + ulong initrd_hi;
if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { debug("Saved variables - Skipping\n"); @@ -183,6 +185,10 @@ int board_late_init(void)
env_set("boot_targets", new_targets);
+ initrd_hi = gd->start_addr_sp - CONFIG_STACK_SIZE; + initrd_hi = round_down(initrd_hi, SZ_16M); + env_set_addr("initrd_high", (void *)initrd_hi); + return 0; }
diff --git a/include/configs/xilinx_versal.h b/include/configs/xilinx_versal.h index 296f4502c652..1e0951c1d92d 100644 --- a/include/configs/xilinx_versal.h +++ b/include/configs/xilinx_versal.h @@ -65,7 +65,6 @@
#define ENV_MEM_LAYOUT_SETTINGS \ "fdt_high=10000000\0" \ - "initrd_high=10000000\0" \ "fdt_addr_r=0x40000000\0" \ "pxefile_addr_r=0x10000000\0" \ "kernel_addr_r=0x18000000\0" \
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/Kconfig | 4 ++-- board/xilinx/zynqmp/zynqmp.c | 6 ++++++ include/configs/xilinx_zynqmp.h | 1 - 3 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 33cb3e065830..257a98d795e5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -464,7 +464,7 @@ config TPL_USE_ARCH_MEMSET
config SET_STACK_SIZE bool "Enable an option to set max stack size that can be used" - default y if ARCH_VERSAL + default y if ARCH_VERSAL || ARCH_ZYNQMP help This will enable an option to set max stack size that can be used by u-boot. @@ -472,7 +472,7 @@ config SET_STACK_SIZE config STACK_SIZE hex "Define max stack size that can be used by u-boot" depends on SET_STACK_SIZE - default 0x4000000 if ARCH_VERSAL + default 0x4000000 if ARCH_VERSAL || ARCH_ZYNQMP help Defines Max stack size that can be used by u-boot so that the initrd_high will be calculated as base stack pointer minus this diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index d649daba96d4..0c331e332230 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -22,6 +22,7 @@ #include <dwc3-uboot.h> #include <zynqmppl.h> #include <g_dnl.h> +#include <linux/sizes.h>
#include "pm_cfg_obj.h"
@@ -530,6 +531,7 @@ int board_late_init(void) char *new_targets; char *env_targets; int ret; + ulong initrd_hi;
#if defined(CONFIG_USB_ETHER) && !defined(CONFIG_USB_GADGET_DOWNLOAD) usb_ether_init(); @@ -647,6 +649,10 @@ int board_late_init(void)
+ initrd_hi = gd->start_addr_sp - CONFIG_STACK_SIZE; + initrd_hi = round_down(initrd_hi, SZ_16M); + env_set_addr("initrd_high", (void *)initrd_hi); + reset_reason();
return 0; diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index ddeb24a0af6e..cdcf853fceb3 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -109,7 +109,6 @@
st 11. 9. 2019 v 9:28 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.17.1
Applied. M
Michal Simek
Michal Simek
