[U-Boot] [PATCH v4 1/3] net: Adds Fast Ethernet Controller driver for Armada100
This patch adds support for Fast Ethernet Controller driver for Armada100 series.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- Changes for v2: - removed random MAC generation - driver init function changed to register as per new naming convention - code cleanup (Thanks to Wolfgang, Marek & Mike for tips) Changes for v3: - code cleanup Changes for v4: - Debug and Error messages updated - base_addr param for armada100_fec_register changed to unsigned long
arch/arm/include/asm/arch-armada100/armada100.h | 1 + drivers/net/Makefile | 1 + drivers/net/armada100_fec.c | 762 +++++++++++++++++++++++ drivers/net/armada100_fec.h | 232 +++++++ include/netdev.h | 1 + 5 files changed, 997 insertions(+), 0 deletions(-) create mode 100644 drivers/net/armada100_fec.c create mode 100644 drivers/net/armada100_fec.h
diff --git a/arch/arm/include/asm/arch-armada100/armada100.h b/arch/arm/include/asm/arch-armada100/armada100.h index d5d125a..3d567eb 100644 --- a/arch/arm/include/asm/arch-armada100/armada100.h +++ b/arch/arm/include/asm/arch-armada100/armada100.h @@ -59,6 +59,7 @@ #define ARMD1_MPMU_BASE 0xD4050000 #define ARMD1_APMU_BASE 0xD4282800 #define ARMD1_CPU_BASE 0xD4282C00 +#define ARMD1_FEC_BASE 0xC0800000
/* * Main Power Management (MPMU) Registers diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 819b197..34b4322 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -28,6 +28,7 @@ LIB := $(obj)libnet.o COBJS-$(CONFIG_DRIVER_3C589) += 3c589.o COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o COBJS-$(CONFIG_ALTERA_TSE) += altera_tse.o +COBJS-$(CONFIG_ARMADA100_FEC) += armada100_fec.o COBJS-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o COBJS-$(CONFIG_BCM570x) += bcm570x.o diff --git a/drivers/net/armada100_fec.c b/drivers/net/armada100_fec.c new file mode 100644 index 0000000..626b50c --- /dev/null +++ b/drivers/net/armada100_fec.c @@ -0,0 +1,762 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * Contributor: Mahavir Jain mjain@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <net.h> +#include <malloc.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/types.h> +#include <asm/byteorder.h> +#include <linux/err.h> +#include <linux/mii.h> +#include <asm/io.h> +#include <asm/arch/armada100.h> +#include "armada100_fec.h" + +#define PHY_ADR_REQ 0xFF /* Magic number to read/write PHY address */ + +#ifdef DEBUG +static int eth_dump_regs(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + unsigned int i = 0; + + printf("\noffset: phy_adr, value: 0x%x\n", readl(®s->phyadr)); + printf("offset: smi, value: 0x%x\n", readl(®s->smi)); + for (i = 0x400; i <= 0x4e4; i += 4) + printf("offset: 0x%x, value: 0x%x\n", + i, readl(ARMD1_FEC_BASE + i)); + return 0; +} +#endif + +static int armdfec_phy_timeout(u32 *reg, u32 flag, int cond) +{ + u32 timeout = PHY_WAIT_ITERATIONS; + u32 reg_val; + + while (--timeout) { + reg_val = readl(reg); + if (cond && (reg_val & flag)) + break; + else if (!cond && !(reg_val & flag)) + break; + udelay(PHY_WAIT_MICRO_SECONDS); + } + return !timeout; +} + +static int smi_reg_read(const char *devname, u8 phy_addr, u8 phy_reg, + u16 *value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + u32 val, reg_data; + + if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { + reg_data = readl(®s->phyadr); + *value = reg_data & 0x1f; + return 0; + } + + /* check parameters */ + if (phy_addr > PHY_MASK) { + printf("ARMD100 FEC: (%s) Invalid phy address: 0x%X\n", + __func__, phy_addr); + return -EINVAL; + } + if (phy_reg > PHY_MASK) { + printf("ARMD100 FEC: (%s) Invalid register offset: 0x%X\n", + __func__, phy_reg); + return -EINVAL; + } + + /* wait for the SMI register to become available */ + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); + return -1; + } + + writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi); + + /* now wait for the data to be valid */ + if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, TRUE)) { + val = readl(®s->smi); + printf("ARMD100 FEC: (%s) PHY Read timeout, val=0x%x\n", + __func__, val); + return -1; + } + val = readl(®s->smi); + *value = val & 0xffff; + + return 0; +} + +static int smi_reg_write(const char *devname, + u8 phy_addr, u8 phy_reg, u16 value) +{ + struct eth_device *dev = eth_get_dev_by_name(devname); + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + + if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) { + clrsetbits_le32(®s->phyadr, 0x1f, value & 0x1f); + return 0; + } + + /* check parameters */ + if (phy_addr > PHY_MASK) { + printf("ARMD100 FEC: (%s) Invalid phy address\n", __func__); + return -EINVAL; + } + if (phy_reg > PHY_MASK) { + printf("ARMD100 FEC: (%s) Invalid register offset\n", __func__); + return -EINVAL; + } + + /* wait for the SMI register to become available */ + if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) { + printf("ARMD100 FEC: (%s) PHY busy timeout\n", __func__); + return -1; + } + + writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_W | (value & 0xffff), + ®s->smi); + return 0; +} + +/* + * Abort any transmit and receive operations and put DMA + * in idle state. AT and AR bits are cleared upon entering + * in IDLE state. So poll those bits to verify operation. + */ +static void abortdma(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int delay; + int maxretries = 40; + u32 tmp; + + while (--maxretries) { + writel(SDMA_CMD_AR | SDMA_CMD_AT, ®s->sdma_cmd); + udelay(100); + + delay = 10; + while (--delay) { + tmp = readl(®s->sdma_cmd); + if (!(tmp & (SDMA_CMD_AR | SDMA_CMD_AT))) + break; + udelay(10); + } + if (delay) + break; + } + + if (!maxretries) + printf("ARMD100 FEC: (%s) DMA Stuck\n", __func__); +} + +static inline u32 nibble_swapping_32_bit(u32 x) +{ + return ((x & 0xf0f0f0f0) >> 4) | ((x & 0x0f0f0f0f) << 4); +} + +static inline u32 nibble_swapping_16_bit(u32 x) +{ + return ((x & 0x0000f0f0) >> 4) | ((x & 0x00000f0f) << 4); +} + +static inline u32 flip_4_bits(u32 x) +{ + return ((x & 0x01) << 3) | ((x & 0x002) << 1) + | ((x & 0x04) >> 1) | ((x & 0x008) >> 3); +} + +/* + * This function will calculate the hash function of the address. + * depends on the hash mode and hash size. + * Inputs + * mach - the 2 most significant bytes of the MAC address. + * macl - the 4 least significant bytes of the MAC address. + * Outputs + * return the calculated entry. + */ +static u32 hash_function(u32 mach, u32 macl) +{ + u32 hashresult; + u32 addrh; + u32 addrl; + u32 addr0; + u32 addr1; + u32 addr2; + u32 addr3; + u32 addrhswapped; + u32 addrlswapped; + + addrh = nibble_swapping_16_bit(mach); + addrl = nibble_swapping_32_bit(macl); + + addrhswapped = flip_4_bits(addrh & 0xf) + + ((flip_4_bits((addrh >> 4) & 0xf)) << 4) + + ((flip_4_bits((addrh >> 8) & 0xf)) << 8) + + ((flip_4_bits((addrh >> 12) & 0xf)) << 12); + + addrlswapped = flip_4_bits(addrl & 0xf) + + ((flip_4_bits((addrl >> 4) & 0xf)) << 4) + + ((flip_4_bits((addrl >> 8) & 0xf)) << 8) + + ((flip_4_bits((addrl >> 12) & 0xf)) << 12) + + ((flip_4_bits((addrl >> 16) & 0xf)) << 16) + + ((flip_4_bits((addrl >> 20) & 0xf)) << 20) + + ((flip_4_bits((addrl >> 24) & 0xf)) << 24) + + ((flip_4_bits((addrl >> 28) & 0xf)) << 28); + + addrh = addrhswapped; + addrl = addrlswapped; + + addr0 = (addrl >> 2) & 0x03f; + addr1 = (addrl & 0x003) | (((addrl >> 8) & 0x7f) << 2); + addr2 = (addrl >> 15) & 0x1ff; + addr3 = ((addrl >> 24) & 0x0ff) | ((addrh & 1) << 8); + + hashresult = (addr0 << 9) | (addr1 ^ addr2 ^ addr3); + hashresult = hashresult & 0x07ff; + return hashresult; +} + +/* + * This function will add an entry to the address table. + * depends on the hash mode and hash size that was initialized. + * Inputs + * mach - the 2 most significant bytes of the MAC address. + * macl - the 4 least significant bytes of the MAC address. + * skip - if 1, skip this address. + * rd - the RD field in the address table. + * Outputs + * address table entry is added. + * 0 if success. + * -ENOSPC if table full + */ +static int add_del_hash_entry(struct armdfec_device *darmdfec, u32 mach, + u32 macl, u32 rd, u32 skip, int del) +{ + struct addr_table_entry_t *entry, *start; + u32 newhi; + u32 newlo; + u32 i; + + newlo = (((mach >> 4) & 0xf) << 15) + | (((mach >> 0) & 0xf) << 11) + | (((mach >> 12) & 0xf) << 7) + | (((mach >> 8) & 0xf) << 3) + | (((macl >> 20) & 0x1) << 31) + | (((macl >> 16) & 0xf) << 27) + | (((macl >> 28) & 0xf) << 23) + | (((macl >> 24) & 0xf) << 19) + | (skip << HTESKIP) | (rd << HTERDBIT) + | HTEVALID; + + newhi = (((macl >> 4) & 0xf) << 15) + | (((macl >> 0) & 0xf) << 11) + | (((macl >> 12) & 0xf) << 7) + | (((macl >> 8) & 0xf) << 3) + | (((macl >> 21) & 0x7) << 0); + + /* + * Pick the appropriate table, start scanning for free/reusable + * entries at the index obtained by hashing the specified MAC address + */ + start = (struct addr_table_entry_t *) (darmdfec->htpr); + entry = start + hash_function(mach, macl); + for (i = 0; i < HOP_NUMBER; i++) { + if (!(entry->lo & HTEVALID)) { + break; + } else { + /* if same address put in same position */ + if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8)) + && (entry->hi == newhi)) + break; + } + if (entry == start + 0x7ff) + entry = start; + else + entry++; + } + + if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) && + (entry->hi != newhi) && del) + return 0; + + if (i == HOP_NUMBER) { + if (!del) { + printf("ARMD100 FEC: (%s) table section is full\n", + __func__); + return -ENOSPC; + } else { + return 0; + } + } + + /* + * Update the selected entry + */ + if (del) { + entry->hi = 0; + entry->lo = 0; + } else { + entry->hi = newhi; + entry->lo = newlo; + } + + return 0; +} + +/* + * Create an addressTable entry from MAC address info + * found in the specifed net_device struct + * + * Input : pointer to ethernet interface network device structure + * Output : N/A + */ +static void update_hash_table_mac_address(struct armdfec_device *darmdfec, + u8 *oaddr, u8 *addr) +{ + u32 mach; + u32 macl; + + /* Delete old entry */ + if (oaddr) { + mach = (oaddr[0] << 8) | oaddr[1]; + macl = (oaddr[2] << 24) | (oaddr[3] << 16) | + (oaddr[4] << 8) | oaddr[5]; + add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_DELETE); + } + + /* Add new entry */ + mach = (addr[0] << 8) | addr[1]; + macl = (addr[2] << 24) | (addr[3] << 16) | (addr[4] << 8) | addr[5]; + add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_ADD); +} + +/* Address Table Initialization */ +static void init_hashtable(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + memset(darmdfec->htpr, 0, HASH_ADDR_TABLE_SIZE); + writel((u32)darmdfec->htpr, ®s->htpr); +} + +static int setportconfigext(struct eth_device *dev, int mtu) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int mtusize; + + /* 64 should work but does not -- dhcp packets NEVER get transmitted. */ + if ((mtu > MAX_PKT_SIZE) || (mtu < 64)) + return -EINVAL; + + /* add source/dest mac addr (12) + pid (2) + crc (4) */ + mtu += ETH_EXTRA_HEADER; + if (mtu <= 1518) + mtusize = PCXR_MFL_1518; + else if (mtu <= 1536) + mtusize = PCXR_MFL_1536; + else if (mtu <= 2048) + mtusize = PCXR_MFL_2048; + else + mtusize = PCXR_MFL_64K; + + /* Extended Port Configuration */ + writel(PCXR_2BSM | /* Two byte suffix aligns IP hdr */ + PCXR_DSCP_EN | /* Enable DSCP in IP */ + mtusize | PCXR_FLP | /* do not force link pass */ + PCXR_TX_HIGH_PRI, /* Transmit - high priority queue */ + ®s->pconf_ext); + + /* subtract source/dest mac addr (12) + pid (2) + crc (4) */ + mtu -= ETH_EXTRA_HEADER; + return 0; +} + +/* + * This detects PHY chip from address 0-31 by reading PHY status + * registers. PHY chip can be connected at any of this address. + */ +static int ethernet_phy_detect(struct eth_device *dev) +{ + u32 val; + u16 tmp, mii_status; + u8 addr; + + for (addr = 0; addr < 32; addr++) { + if (miiphy_read(dev->name, addr, MII_BMSR, &mii_status) != 0) + /* try next phy */ + continue; + + /* invalid MII status. More validation required here... */ + if (mii_status == 0 || mii_status == 0xffff) + /* try next phy */ + continue; + + if (miiphy_read(dev->name, addr, MII_PHYSID1, &tmp) != 0) + /* try next phy */ + continue; + + val = tmp << 16; + if (miiphy_read(dev->name, addr, MII_PHYSID2, &tmp) != 0) + /* try next phy */ + continue; + + val |= tmp; + + if ((val & 0xfffffff0) != 0) + return addr; + } + return -1; +} + +static void armdfec_init_rx_desc_ring(struct armdfec_device *darmdfec) +{ + struct rx_desc *p_rx_desc; + int i; + + /* initialize the Rx descriptors ring */ + p_rx_desc = darmdfec->p_rxdesc; + for (i = 0; i < RINGSZ; i++) { + p_rx_desc->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; + p_rx_desc->buf_size = PKTSIZE_ALIGN; + p_rx_desc->byte_cnt = 0; + p_rx_desc->buf_ptr = darmdfec->p_rxbuf + i * PKTSIZE_ALIGN; + if (i == (RINGSZ - 1)) { + p_rx_desc->nxtdesc_p = darmdfec->p_rxdesc; + } else { + p_rx_desc->nxtdesc_p = (struct rx_desc *) + ((u32) p_rx_desc + ARMDFEC_RXQ_DESC_ALIGNED_SIZE); + p_rx_desc = p_rx_desc->nxtdesc_p; + } + } + darmdfec->p_rxdesc_curr = darmdfec->p_rxdesc; +} + +static int armdfec_init(struct eth_device *dev, bd_t *bd) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + int phy_adr; + + armdfec_init_rx_desc_ring(darmdfec); + + /* Disable interrupts */ + writel(0, ®s->im); + writel(0, ®s->ic); + /* Write to ICR to clear interrupts. */ + writel(0, ®s->iwc); + + /* + * Abort any transmit and receive operations and put DMA + * in idle state. + */ + abortdma(dev); + + /* Initialize address hash table */ + init_hashtable(dev); + + /* SDMA configuration */ + writel(SDCR_BSZ8 | /* Burst size = 32 bytes */ + SDCR_RIFB | /* Rx interrupt on frame */ + SDCR_BLMT | /* Little endian transmit */ + SDCR_BLMR | /* Little endian receive */ + SDCR_RC_MAX_RETRANS, /* Max retransmit count */ + ®s->sdma_conf); + /* Port Configuration */ + writel(PCR_HS, ®s->pconf); /* Hash size is 1/2kb */ + setportconfigext(dev, 1500); + + update_hash_table_mac_address(darmdfec, dev->enetaddr, dev->enetaddr); + + /* Update TX and RX queue descriptor register */ + writel((u32) darmdfec->p_txdesc, ®s->txcdp[TXQ]); + writel((u32) darmdfec->p_rxdesc, ®s->rxfdp[RXQ]); + writel((u32) darmdfec->p_rxdesc_curr, ®s->rxcdp[RXQ]); + + /* Enable Interrupts */ + writel(ALL_INTS, ®s->im); + + /* Enable Ethernet Port */ + setbits_le32(®s->pconf, PCR_EN); + + /* Enable RX DMA engine */ + setbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); + +#ifdef DEBUG + eth_dump_regs(dev); +#endif + +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) + +#if defined(CONFIG_PHY_BASE_ADR) + miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, CONFIG_PHY_BASE_ADR); +#else + /* Search phy address from range 0-31 */ + phy_adr = ethernet_phy_detect(dev); + if (phy_adr < 0) { + printf("ARMD100 FEC: PHY not detected at address range 0-31\n"); + return -1; + } else { + debug("ARMD100 FEC: PHY detected at addr %d\n", phy_adr); + miiphy_write(dev->name, PHY_ADR_REQ, PHY_ADR_REQ, (u16)phy_adr); + } +#endif + +#if defined(CONFIG_SYS_FAULT_ECHO_LINK_DOWN) + /* Wait up to 5s for the link status */ + for (i = 0; i < 5; i++) { + u16 phy_adr; + + miiphy_read(dev->name, 0xFF, 0xFF, &phy_adr); + /* Return if we get link up */ + if (miiphy_link(dev->name, phy_adr)) + return 0; + udelay(1000000); + } + + printf("ARMD100 FEC: No link on %s\n", dev->name); + return -1; +#endif +#endif + return 0; +} + +static void armdfec_halt(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + + /* Stop RX DMA */ + clrbits_le32(®s->sdma_cmd, SDMA_CMD_ERD); + + /* + * Abort any transmit and receive operations and put DMA + * in idle state. + */ + abortdma(dev); + + /* Disable interrupts */ + writel(0, ®s->im); + writel(0, ®s->ic); + writel(0, ®s->iwc); + + /* Disable Port */ + clrbits_le32(®s->pconf, PCR_EN); +} + +static int armdfec_send(struct eth_device *dev, volatile void *dataptr, + int datasize) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct armdfec_reg *regs = darmdfec->regs; + struct tx_desc *p_txdesc = darmdfec->p_txdesc; + void *p = (void *) dataptr; + int retry = PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS; + u32 cmd_sts; + + /* Copy buffer if it's misaligned */ + if ((u32) dataptr & 0x07) { + if (datasize > PKTSIZE_ALIGN) { + printf("ARMD100 FEC: Non-aligned data too large (%d)\n", + datasize); + return -1; + } + memcpy(darmdfec->p_aligned_txbuf, p, datasize); + p = darmdfec->p_aligned_txbuf; + } + + p_txdesc->cmd_sts = TX_ZERO_PADDING | TX_GEN_CRC; + p_txdesc->cmd_sts |= TX_FIRST_DESC | TX_LAST_DESC; + p_txdesc->cmd_sts |= BUF_OWNED_BY_DMA; + p_txdesc->cmd_sts |= TX_EN_INT; + p_txdesc->buf_ptr = p; + p_txdesc->byte_cnt = datasize; + + /* Apply send command using high priority TX queue */ + writel((u32) p_txdesc, ®s->txcdp[TXQ]); + writel(SDMA_CMD_TXDL | SDMA_CMD_TXDH | SDMA_CMD_ERD, ®s->sdma_cmd); + + /* + * wait for packet xmit completion + */ + cmd_sts = readl(&p_txdesc->cmd_sts); + while (cmd_sts & BUF_OWNED_BY_DMA) { + /* return fail if error is detected */ + if ((cmd_sts & (TX_ERROR | TX_LAST_DESC)) == + (TX_ERROR | TX_LAST_DESC)) { + printf("ARMD100 FEC: (%s) in xmit packet\n", __func__); + return -1; + } + cmd_sts = readl(&p_txdesc->cmd_sts); + if (!(retry--)) { + printf("ARMD100 FEC: (%s) xmit packet timeout!\n", + __func__); + return -1; + } + } + + return 0; +} + +static int armdfec_recv(struct eth_device *dev) +{ + struct armdfec_device *darmdfec = to_darmdfec(dev); + struct rx_desc *p_rxdesc_curr = darmdfec->p_rxdesc_curr; + u32 cmd_sts; + u32 timeout = 0; + + /* wait untill rx packet available or timeout */ + do { + if (timeout < PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS) { + timeout++; + } else { + debug("ARMD100 FEC: %s time out...\n", __func__); + return -1; + } + } while (readl(&p_rxdesc_curr->cmd_sts) & BUF_OWNED_BY_DMA); + + if (p_rxdesc_curr->byte_cnt != 0) { + debug("ARMD100 FEC: %s: Received %d byte Packet @ 0x%x" + "(cmd_sts= %08x)\n", __func__, + (u32) p_rxdesc_curr->byte_cnt, + (u32) p_rxdesc_curr->buf_ptr, + (u32) p_rxdesc_curr->cmd_sts); + } + + /* + * In case received a packet without first/last bits on + * OR the error summary bit is on, + * the packets needs to be dropeed. + */ + cmd_sts = readl(&p_rxdesc_curr->cmd_sts); + + if ((cmd_sts & (RX_FIRST_DESC | RX_LAST_DESC)) != + (RX_FIRST_DESC | RX_LAST_DESC)) { + printf("ARMD100 FEC: (%s) Dropping packet spread on" + " multiple descriptors\n", __func__); + } else if (cmd_sts & RX_ERROR) { + printf("ARMD100 FEC: (%s) Dropping packet with errors\n", + __func__); + } else { + /* !!! call higher layer processing */ + debug("ARMD100 FEC: (%s) Sending Received packet to" + " upper layer (NetReceive)\n", __func__); + + /* + * let the upper layer handle the packet, subtract offset + * as two dummy bytes are added in received buffer see + * PORT_CONFIG_EXT register bit TWO_Byte_Stuff_Mode bit. + */ + NetReceive((p_rxdesc_curr->buf_ptr + RX_BUF_OFFSET), + (int) (p_rxdesc_curr->byte_cnt - RX_BUF_OFFSET)); + } + /* + * free these descriptors and point next in the ring + */ + p_rxdesc_curr->cmd_sts = BUF_OWNED_BY_DMA | RX_EN_INT; + p_rxdesc_curr->buf_size = PKTSIZE_ALIGN; + p_rxdesc_curr->byte_cnt = 0; + + writel((u32) p_rxdesc_curr->nxtdesc_p, &darmdfec->p_rxdesc_curr); + + return 0; +} + +int armada100_fec_register(unsigned long base_addr) +{ + struct armdfec_device *darmdfec; + struct eth_device *dev; + + darmdfec = malloc(sizeof(struct armdfec_device)); + if (!darmdfec) + goto error; + + memset(darmdfec, 0, sizeof(struct armdfec_device)); + + darmdfec->htpr = memalign(8, HASH_ADDR_TABLE_SIZE); + if (!darmdfec->htpr) + goto error1; + + darmdfec->p_rxdesc = memalign(PKTALIGN, + ARMDFEC_RXQ_DESC_ALIGNED_SIZE * RINGSZ + 1); + + if (!darmdfec->p_rxdesc) + goto error1; + + darmdfec->p_rxbuf = memalign(PKTALIGN, RINGSZ * PKTSIZE_ALIGN + 1); + if (!darmdfec->p_rxbuf) + goto error1; + + darmdfec->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN); + if (!darmdfec->p_aligned_txbuf) + goto error1; + + darmdfec->p_txdesc = memalign(PKTALIGN, sizeof(struct tx_desc) + 1); + if (!darmdfec->p_txdesc) + goto error1; + + dev = &darmdfec->dev; + /* Assign ARMADA100 Fast Ethernet Controller Base Address */ + darmdfec->regs = (void *)base_addr; + + /* must be less than NAMESIZE (16) */ + strcpy(dev->name, "armd-fec0"); + + dev->init = armdfec_init; + dev->halt = armdfec_halt; + dev->send = armdfec_send; + dev->recv = armdfec_recv; + + eth_register(dev); + +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) + miiphy_register(dev->name, smi_reg_read, smi_reg_write); +#endif + return 0; + +error1: + free(darmdfec->p_aligned_txbuf); + free(darmdfec->p_rxbuf); + free(darmdfec->p_rxdesc); + free(darmdfec->htpr); +error: + free(darmdfec); + printf("AMD100 FEC: (%s) Failed to allocate memory\n", __func__); + return -1; +} diff --git a/drivers/net/armada100_fec.h b/drivers/net/armada100_fec.h new file mode 100644 index 0000000..e2df4fc --- /dev/null +++ b/drivers/net/armada100_fec.h @@ -0,0 +1,232 @@ +/* + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + * Contributor: Mahavir Jain mjain@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __ARMADA100_FEC_H__ +#define __ARMADA100_FEC_H__ + +#ifndef TRUE +#define TRUE 1 +#endif +#ifndef FALSE +#define FALSE 0 +#endif + +#define PORT_NUM 0x0 + +/* RX & TX descriptor command */ +#define BUF_OWNED_BY_DMA (1<<31) + +/* RX descriptor status */ +#define RX_EN_INT (1<<23) +#define RX_FIRST_DESC (1<<17) +#define RX_LAST_DESC (1<<16) +#define RX_ERROR (1<<15) + +/* TX descriptor command */ +#define TX_EN_INT (1<<23) +#define TX_GEN_CRC (1<<22) +#define TX_ZERO_PADDING (1<<18) +#define TX_FIRST_DESC (1<<17) +#define TX_LAST_DESC (1<<16) +#define TX_ERROR (1<<15) + +/* smi register */ +#define SMI_BUSY (1<<28) /* 0 - Write, 1 - Read */ +#define SMI_R_VALID (1<<27) /* 0 - Write, 1 - Read */ +#define SMI_OP_W (0<<26) /* Write operation */ +#define SMI_OP_R (1<<26) /* Read operation */ + +#define HASH_ADD 0 +#define HASH_DELETE 1 +#define HASH_ADDR_TABLE_SIZE 0x4000 /* 16K (1/2K address - PCR_HS == 1) */ +#define HOP_NUMBER 12 + +#define PHY_WAIT_ITERATIONS 1000 /* 1000 iterations * 10uS = 10mS max */ +#define PHY_WAIT_MICRO_SECONDS 10 + +#define ETH_HW_IP_ALIGN 2 /* hw aligns IP header */ +#define ETH_EXTRA_HEADER (6+6+2+4) + /* dest+src addr+protocol id+crc */ +#define MAX_PKT_SIZE 1536 + + +/* Bit definitions of the SDMA Config Reg */ +#define SDCR_BSZ_OFF 12 +#define SDCR_BSZ8 (3<<SDCR_BSZ_OFF) +#define SDCR_BSZ4 (2<<SDCR_BSZ_OFF) +#define SDCR_BSZ2 (1<<SDCR_BSZ_OFF) +#define SDCR_BSZ1 (0<<SDCR_BSZ_OFF) +#define SDCR_BLMR (1<<6) +#define SDCR_BLMT (1<<7) +#define SDCR_RIFB (1<<9) +#define SDCR_RC_OFF 2 +#define SDCR_RC_MAX_RETRANS (0xf << SDCR_RC_OFF) + +/* SDMA_CMD */ +#define SDMA_CMD_AT (1<<31) +#define SDMA_CMD_TXDL (1<<24) +#define SDMA_CMD_TXDH (1<<23) +#define SDMA_CMD_AR (1<<15) +#define SDMA_CMD_ERD (1<<7) + + +/* Bit definitions of the Port Config Reg */ +#define PCR_HS (1<<12) +#define PCR_EN (1<<7) +#define PCR_PM (1<<0) + +/* Bit definitions of the Port Config Extend Reg */ +#define PCXR_2BSM (1<<28) +#define PCXR_DSCP_EN (1<<21) +#define PCXR_MFL_1518 (0<<14) +#define PCXR_MFL_1536 (1<<14) +#define PCXR_MFL_2048 (2<<14) +#define PCXR_MFL_64K (3<<14) +#define PCXR_FLP (1<<11) +#define PCXR_PRIO_TX_OFF 3 +#define PCXR_TX_HIGH_PRI (7<<PCXR_PRIO_TX_OFF) + +/* + * * Bit definitions of the Interrupt Cause Reg + * * and Interrupt MASK Reg is the same + * */ +#define ICR_RXBUF (1<<0) +#define ICR_TXBUF_H (1<<2) +#define ICR_TXBUF_L (1<<3) +#define ICR_TXEND_H (1<<6) +#define ICR_TXEND_L (1<<7) +#define ICR_RXERR (1<<8) +#define ICR_TXERR_H (1<<10) +#define ICR_TXERR_L (1<<11) +#define ICR_TX_UDR (1<<13) +#define ICR_MII_CH (1<<28) + +#define ALL_INTS (ICR_TXBUF_H | ICR_TXBUF_L | ICR_TX_UDR |\ + ICR_TXERR_H | ICR_TXERR_L |\ + ICR_TXEND_H | ICR_TXEND_L |\ + ICR_RXBUF | ICR_RXERR | ICR_MII_CH) + +#define PHY_MASK 0x0000001f + +#define to_darmdfec(_kd) container_of(_kd, struct armdfec_device, dev) +/* Size of a Tx/Rx descriptor used in chain list data structure */ +#define ARMDFEC_RXQ_DESC_ALIGNED_SIZE \ + (((sizeof(struct rx_desc) / PKTALIGN) + 1) * PKTALIGN) + +#define RX_BUF_OFFSET 0x2 +#define RXQ 0x0 /* RX Queue 0 */ +#define TXQ 0x1 /* TX Queue 1 */ + +struct addr_table_entry_t { + u32 lo; + u32 hi; +}; + +/* Bit fields of a Hash Table Entry */ +enum hash_table_entry { + HTEVALID = 1, + HTESKIP = 2, + HTERD = 4, + HTERDBIT = 2 +}; + +struct tx_desc { + u32 cmd_sts; /* Command/status field */ + u16 reserved; + u16 byte_cnt; /* buffer byte count */ + u8 *buf_ptr; /* pointer to buffer for this descriptor */ + struct tx_desc *nextdesc_p; /* Pointer to next descriptor */ +}; + +struct rx_desc { + u32 cmd_sts; /* Descriptor command status */ + u16 byte_cnt; /* Descriptor buffer byte count */ + u16 buf_size; /* Buffer size */ + u8 *buf_ptr; /* Descriptor buffer pointer */ + struct rx_desc *nxtdesc_p; /* Next descriptor pointer */ +}; + +/* + * Armada100 Fast Ethernet controller Registers + * Refer Datasheet Appendix A.22 + */ +struct armdfec_reg { + u32 phyadr; /* PHY Address */ + u32 pad1[3]; + u32 smi; /* SMI */ + u32 pad2[0xFB]; + u32 pconf; /* Port configuration */ + u32 pad3; + u32 pconf_ext; /* Port configuration extend */ + u32 pad4; + u32 pcmd; /* Port Command */ + u32 pad5; + u32 pstatus; /* Port Status */ + u32 pad6; + u32 spar; /* Serial Parameters */ + u32 pad7; + u32 htpr; /* Hash table pointer */ + u32 pad8; + u32 fcsal; /* Flow control source address low */ + u32 pad9; + u32 fcsah; /* Flow control source address high */ + u32 pad10; + u32 sdma_conf; /* SDMA configuration */ + u32 pad11; + u32 sdma_cmd; /* SDMA command */ + u32 pad12; + u32 ic; /* Interrupt cause */ + u32 iwc; /* Interrupt write to clear */ + u32 im; /* Interrupt mask */ + u32 pad13; + u32 *eth_idscpp[4]; /* Eth0 IP Differentiated Services Code + Point to Priority 0 Low */ + u32 eth_vlan_p; /* Eth0 VLAN Priority Tag to Priority */ + u32 pad14[3]; + struct rx_desc *rxfdp[4]; /* Ethernet First Rx Descriptor + Pointer */ + u32 pad15[4]; + struct rx_desc *rxcdp[4]; /* Ethernet Current Rx Descriptor + Pointer */ + u32 pad16[0x0C]; + struct tx_desc *txcdp[2]; /* Ethernet Current Tx Descriptor + Pointer */ +}; + +struct armdfec_device { + struct eth_device dev; + struct armdfec_reg *regs; + struct tx_desc *p_txdesc; + struct rx_desc *p_rxdesc; + struct rx_desc *p_rxdesc_curr; + u8 *p_rxbuf; + u8 *p_aligned_txbuf; + u8 *htpr; /* hash pointer */ +}; + +#endif /* __ARMADA100_FEC_H__ */ diff --git a/include/netdev.h b/include/netdev.h index 6f0a971..2ec1e04 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -94,6 +94,7 @@ int xilinx_emaclite_initialize (bd_t *bis, int base_addr); int sh_eth_initialize(bd_t *bis); int dm9000_initialize(bd_t *bis); int fecmxc_initialize(bd_t *bis); +int armada100_fec_register(unsigned long base_addr);
/* Boards with PCI network controllers can call this from their board_eth_init() * function to initialize whatever's on board.
u16 *value)
- struct eth_device *dev = eth_get_dev_by_name(devname);
- struct armdfec_device *darmdfec = to_darmdfec(dev);
- struct armdfec_reg *regs = darmdfec->regs;
- u32 val, reg_data;
- if (phy_addr == PHY_ADR_REQ && phy_reg == PHY_ADR_REQ) {
You use "reg_data" here and "val" below ... can't you use just one variable?
- /* check parameters */
- if (phy_addr > PHY_MASK) {
return -EINVAL;
- if (phy_reg > PHY_MASK) {
__func__, phy_reg);
return -EINVAL;
- /* wait for the SMI register to become available */
- if (armdfec_phy_timeout(®s->smi, SMI_BUSY, FALSE)) {
return -1;
- writel((phy_addr << 16) | (phy_reg << 21) | SMI_OP_R, ®s->smi);
- /* now wait for the data to be valid */
- if (armdfec_phy_timeout(®s->smi, SMI_R_VALID, TRUE)) {
__func__, val);
return -1;
- val = readl(®s->smi);
- *value = val & 0xffff;
- struct addr_table_entry_t *entry, *start;
- u32 newhi;
- u32 newlo;
- u32 i;
- newlo = (((mach >> 4) & 0xf) << 15)
| HTEVALID;
- newhi = (((macl >> 4) & 0xf) << 15)
- start = (struct addr_table_entry_t *) (darmdfec->htpr);
- entry = start + hash_function(mach, macl);
- for (i = 0; i < HOP_NUMBER; i++) {
break;
} else {
break;
What about
if (!(entry->lo & HTEVALID)) break;
if (((entry->lo & 0xfffffff8) == (newlo & 0xfffffff8)) && (entry->hi == newhi)) { break; }
entry = start;
else
entry++;
- if (((entry->lo & 0xfffffff8) != (newlo & 0xfffffff8)) &&
Now thinking of it, are you sure about this condition ? Shouldn't the first && be || instead ? And there should be parenthesis around that ?
- if (i == HOP_NUMBER) {
if (!del) {
__func__);
return -ENOSPC;
} else {
- /* 64 should work but does not -- dhcp packets NEVER get transmitted. */
What's this about ?
- if ((mtu > MAX_PKT_SIZE) || (mtu < 64))
return -EINVAL;
int datasize)
- struct tx_desc *p_txdesc = darmdfec->p_txdesc;
- void *p = (void *) dataptr;
Is this needed?
- int retry = PHY_WAIT_ITERATIONS * PHY_WAIT_MICRO_SECONDS;
- u32 cmd_sts;
- /* Copy buffer if it's misaligned */
- if ((u32) dataptr & 0x07) {
Space after typecast. Please fix globally.
datasize);
return -1;
The rest is really good !
Thanks!
Cheers
- u32 mach;
- u32 macl;
- /* Delete old entry */
- if (oaddr) {
- /* Add new entry */
- mach = (addr[0] << 8) | addr[1];
- macl = (addr[2] << 24) | (addr[3] << 16) | (addr[4] << 8) | addr[5];
- add_del_hash_entry(darmdfec, mach, macl, 1, 0, HASH_ADD);
+} ... +static int armdfec_init(struct eth_device *dev, bd_t *bd) +{ ...
- update_hash_table_mac_address(darmdfec, dev->enetaddr, dev->enetaddr);
i think something got lost along the way here :)
you'll probably want to have oaddr[] be a static local in update_hash_table_mac_address and use that to delete the old one when it differs from the new one, and then copy the new one into the static local. -mike
*darmdfec,
- u32 mach;
- u32 macl;
- if (oaddr) {
addr[5];
dev->enetaddr);
You can have multiple entries in Hash table for different MAC addresses. The reason old entry is deleted because it may be possible that hash entry in the list is skipped but not invalidated so the same entry is made valid in the list after removing the old one and updating list with new entry. The calculated has for a particular MAC address is going to be same.
Thanks, Ajay Bhargav
*darmdfec,
- u32 mach;
- u32 macl;
- if (oaddr) {
addr[5];
dev->enetaddr);
when
Adding to this.. In my case, its the first entry in hash table so I do not need to delete it, I can simply pass NULL in place of oaddr. That change I will make in the updated patch I am going to submit.
Ajay Bhargav
Mike Frysinger
