Hi Wolfgang, Please pull The following changes since commit 0b7c5639891f4103a0e31ec7ae0beb3e97ed3836: Heiko Schocher (1): muas3001: update BR4 settings
git://git.denx.de/u-boot-arm.git master
Adrian Filipi (1): Set up SD/MMC OCR as comment describes. i.e. 3.2-3.4v.
Andrew Dyer (3): arm920t fix constant error in start.S i.MX use u-boot baud rate and don't assume UART master clock i.mx change get_timer(base) to return time since base
Claudio Scordino (1): Fix MACH_TYPE for the AT91RM9200DK board.
Guennadi Liakhovetski (1): i.MX31: document timer precision option
Gururaja Hebbar K R (1): ARM OMAP : Correct Invalid Timer Register Field Declaration in omap1510.h & omap730.h
Hugo Villeneuve (1): ARM DaVinci: Remove duplicate code in cpu/arm926ejs/davinci/dp83848.c
Jean-Christophe PLAGNIOL-VILLARD (1): ARM: synchronize mach-types.h with linux 2.6.27-rc6
Jens Scharsig (1): at91rm9200: fix errors with CONFIG_CMD_I2C_TREE
Magnus Lilja (2): i.MX31: Add reset_timer() and modify get_timer_masked(). i.MX31: Make the SPI bus and chip select configurable for MC13783
Shinya Kuribayashi (1): make: Remove redundant __ARM__ addition when cross-compiling on *BSD
README.imx31 | 13 + board/atmel/at91rm9200dk/at91rm9200dk.c | 2 +- config.mk | 9 - cpu/arm1136/mx31/interrupts.c | 24 +- cpu/arm920t/at91rm9200/i2c.c | 10 + cpu/arm920t/imx/interrupts.c | 2 +- cpu/arm920t/imx/serial.c | 56 +- cpu/arm920t/start.S | 6 +- cpu/arm926ejs/davinci/dp83848.c | 27 +- cpu/pxa/mmc.c | 4 +- doc/README.mx31 | 19 + drivers/rtc/mc13783-rtc.c | 6 +- include/asm-arm/mach-types.h | 3645 +++++++++++++++++++++++++++++-- include/configs/imx31_litekit.h | 3 + include/configs/mx31ads.h | 3 + include/configs/omap1510.h | 2 +- include/configs/omap730.h | 2 +- 17 files changed, 3648 insertions(+), 185 deletions(-) create mode 100644 README.imx31 create mode 100644 doc/README.mx31 mode change 100644 => 100755 include/configs/omap1510.h mode change 100644 => 100755 include/configs/omap730.h
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
Best Regards,
Applied, thanks.
