[U-Boot] [PATCH 1/2] arm: am437x: cm-t43: Add device tree, enable OF_CONTROL
Add device tree from Linux for driver model conversion and enable OF_CONTROL. This will remove the following compile warning: ================================================== Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument =================================================== Target was compile tested, build was clean.
Signed-off-by: Suniel Mahesh sunil.m@techveda.org --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/am437x-cm-t43.dts | 420 +++++++++++++++++++++++++++++++++++++++++ configs/cm_t43_defconfig | 2 + 3 files changed, 424 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/am437x-cm-t43.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aac1b83..62da168 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -302,7 +302,8 @@ dtb-$(CONFIG_AM33XX) += \ dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb \ - am4372-generic.dtb + am4372-generic.dtb \ + am437x-cm-t43.dtb dtb-$(CONFIG_TARGET_AM3517_EVM) += am3517-evm.dtb dtb-$(CONFIG_TI816X) += dm8168-evm.dtb dtb-$(CONFIG_THUNDERX) += thunderx-88xx.dtb diff --git a/arch/arm/dts/am437x-cm-t43.dts b/arch/arm/dts/am437x-cm-t43.dts new file mode 100644 index 0000000..063113a --- /dev/null +++ b/arch/arm/dts/am437x-cm-t43.dts @@ -0,0 +1,420 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2015 CompuLab, Ltd. - http://www.compulab.co.il/ + */ + +/dts-v1/; + +#include <dt-bindings/pinctrl/am43xx.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include "am4372.dtsi" + +/ { + model = "CompuLab CM-T43"; + compatible = "compulab,am437x-cm-t43", "ti,am4372", "ti,am43"; + + leds { + compatible = "gpio-leds"; + + ledb { + label = "cm-t43:green"; + gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + }; + + vmmc_3v3: fixedregulator-v3_3 { + compatible = "regulator-fixed"; + regulator-name = "vmmc_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + enable-active-high; + }; +}; + +&am43xx_pinmux { + pinctrl-names = "default"; + pinctrl-0 = <&cm_t43_led_pins>; + + cm_t43_led_pins: cm_t43_led_pins { + pinctrl-single,pins = < + AM4372_IOPAD(0xa78, MUX_MODE7) + >; + }; + + i2c0_pins: i2c0_pins { + pinctrl-single,pins = < + AM4372_IOPAD(0x988, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */ + AM4372_IOPAD(0x98c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */ + >; + }; + + emmc_pins: emmc_pins { + pinctrl-single,pins = < + AM4372_IOPAD(0x820, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad8.mmc1_dat0 */ + AM4372_IOPAD(0x824, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad9.mmc1_dat1 */ + AM4372_IOPAD(0x828, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad10.mmc1_dat2 */ + AM4372_IOPAD(0x82c, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad11.mmc1_dat3 */ + AM4372_IOPAD(0x830, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad12.mmc1_dat4 */ + AM4372_IOPAD(0x834, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad13.mmc1_dat5 */ + AM4372_IOPAD(0x838, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad14.mmc1_dat6 */ + AM4372_IOPAD(0x83c, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_ad15.mmc1_dat7 */ + AM4372_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ + AM4372_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ + >; + }; + + spi0_pins: pinmux_spi0_pins { + pinctrl-single,pins = < + AM4372_IOPAD(0x950, PIN_INPUT | MUX_MODE0) /* spi0_sclk.spi0_sclk */ + AM4372_IOPAD(0x954, PIN_INPUT | MUX_MODE0) /* spi0_d0.spi0_d0 */ + AM4372_IOPAD(0x958, PIN_OUTPUT | MUX_MODE0) /* spi0_d1.spi0_d1 */ + AM4372_IOPAD(0x95C, PIN_OUTPUT | MUX_MODE0) /* spi0_cs0.spi0_cs0 */ + >; + }; + + nand_flash_x8: nand_flash_x8 { + pinctrl-single,pins = < + AM4372_IOPAD(0x800, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x804, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x808, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x80c, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x810, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x814, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x818, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x81c, PIN_INPUT | PULL_DISABLE | MUX_MODE0) + AM4372_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE0) + AM4372_IOPAD(0x874, PIN_OUTPUT_PULLUP | MUX_MODE0) + AM4372_IOPAD(0x87c, PIN_OUTPUT_PULLUP | MUX_MODE0) + AM4372_IOPAD(0x898, PIN_OUTPUT_PULLDOWN | MUX_MODE0) + AM4372_IOPAD(0x894, PIN_OUTPUT_PULLDOWN | MUX_MODE0) + AM4372_IOPAD(0x890, PIN_OUTPUT_PULLDOWN | MUX_MODE0) + AM4372_IOPAD(0x89c, PIN_OUTPUT_PULLDOWN | MUX_MODE0) + >; + }; + + cpsw_default: cpsw_default { + pinctrl-single,pins = < + /* Slave 1 */ + AM4372_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_txen */ + AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rxctl */ + AM4372_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd3 */ + AM4372_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd2 */ + AM4372_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd1 */ + AM4372_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd0 */ + AM4372_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rmii1_tclk */ + AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rmii1_rclk */ + AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd3 */ + AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd2 */ + AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd1 */ + AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd0 */ + AM4372_IOPAD(0xa74, MUX_MODE3) + /* Slave 2 */ + AM4372_IOPAD(0x840, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a0.txen */ + AM4372_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a1.rxctl */ + AM4372_IOPAD(0x848, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a2.txd3 */ + AM4372_IOPAD(0x84c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a3.txd2 */ + AM4372_IOPAD(0x850, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a4.txd1 */ + AM4372_IOPAD(0x854, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a5.txd0 */ + AM4372_IOPAD(0x858, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a6.tclk */ + AM4372_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a7.rclk */ + AM4372_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a8.rxd3 */ + AM4372_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a9.rxd2 */ + AM4372_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a10.rxd1 */ + AM4372_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a11.rxd0 */ + AM4372_IOPAD(0xa38, MUX_MODE7) + >; + }; + + davinci_mdio_default: davinci_mdio_default { + pinctrl-single,pins = < + /* MDIO */ + AM4372_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ + AM4372_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ + >; + }; +}; + +&gpmc { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&nand_flash_x8>; + ranges = <0 0 0x08000000 0x1000000>; + nand@0,0 { + compatible = "ti,omap2-nand"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + interrupt-parent = <&gpmc>; + interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ + <1 IRQ_TYPE_NONE>; /* termcount */ + ti,nand-ecc-opt = "bch8"; + ti,elm-id = <&elm>; + + nand-bus-width = <8>; + gpmc,device-width = <1>; + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <44>; + gpmc,cs-wr-off-ns = <44>; + gpmc,adv-on-ns = <6>; + gpmc,adv-rd-off-ns = <34>; + gpmc,adv-wr-off-ns = <44>; + gpmc,we-on-ns = <0>; + gpmc,we-off-ns = <40>; + gpmc,oe-on-ns = <0>; + gpmc,oe-off-ns = <54>; + gpmc,access-ns = <64>; + gpmc,rd-cycle-ns = <82>; + gpmc,wr-cycle-ns = <82>; + gpmc,bus-turnaround-ns = <0>; + gpmc,cycle2cycle-delay-ns = <0>; + gpmc,clk-activation-ns = <0>; + gpmc,wr-access-ns = <40>; + gpmc,wr-data-mux-bus-ns = <0>; + + #address-cells = <1>; + #size-cells = <1>; + /* MTD partition table */ + partition@0 { + label = "kernel"; + reg = <0x0 0x00980000>; + }; + partition@980000 { + label = "dtb"; + reg = <0x00980000 0x00080000>; + }; + partition@a00000 { + label = "rootfs"; + reg = <0x00a00000 0x0>; + }; + }; +}; + +&i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + clock-frequency = <100000>; + + tps65218: tps65218@24 { + compatible = "ti,tps65218"; + reg = <0x24>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; /* NMIn */ + interrupt-parent = <&gic>; + interrupt-controller; + #interrupt-cells = <2>; + + dcdc1: regulator-dcdc1 { + regulator-name = "vdd_core"; + regulator-min-microvolt = <912000>; + regulator-max-microvolt = <1144000>; + regulator-boot-on; + regulator-always-on; + }; + + dcdc2: regulator-dcdc2 { + regulator-name = "vdd_mpu"; + regulator-min-microvolt = <912000>; + regulator-max-microvolt = <1378000>; + regulator-boot-on; + regulator-always-on; + }; + + dcdc3: regulator-dcdc3 { + regulator-name = "vdcdc3"; + regulator-suspend-enable; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-boot-on; + regulator-always-on; + }; + + dcdc5: regulator-dcdc5 { + regulator-name = "v1_0bat"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-boot-on; + regulator-always-on; + }; + + dcdc6: regulator-dcdc6 { + regulator-name = "v1_8bat"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: regulator-ldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + }; + + eeprom_module: at24@50 { + compatible = "atmel,24c02"; + reg = <0x50>; + pagesize = <16>; + }; +}; + +&gpio0 { + status = "okay"; +}; + +&gpio1 { + status = "okay"; +}; + +&gpio2 { + status = "okay"; +}; + +&gpio3 { + status = "okay"; +}; + +&gpio4 { + status = "okay"; +}; + +&gpio5 { + status = "okay"; +}; + +&mmc2 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins>; + vmmc-supply = <&vmmc_3v3>; + bus-width = <8>; + ti,non-removable; +}; + +&spi0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins>; + dmas = <&edma 16 0 + &edma 17 0>; + dma-names = "tx0", "rx0"; + + flash: w25q64cvzpig@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <20000000>; + partition@0 { + label = "uboot"; + reg = <0x0 0xc0000>; + }; + + partition@c0000 { + label = "uboot environment"; + reg = <0xc0000 0x40000>; + }; + + partition@100000 { + label = "reserved"; + reg = <0x100000 0x100000>; + }; + }; +}; + +&mac { + pinctrl-names = "default"; + pinctrl-0 = <&cpsw_default>; + dual_emac = <1>; + status = "okay"; +}; + +&davinci_mdio { + pinctrl-names = "default"; + pinctrl-0 = <&davinci_mdio_default>; + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; + + ethphy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&cpsw_emac0 { + phy-handle = <ðphy0>; + phy-mode = "rgmii-txid"; + dual_emac_res_vlan = <1>; +}; + +&cpsw_emac1 { + phy-handle = <ðphy1>; + phy-mode = "rgmii-txid"; + dual_emac_res_vlan = <2>; +}; + +&dwc3_1 { + status = "okay"; +}; + +&usb2_phy1 { + status = "okay"; +}; + +&usb1 { + dr_mode = "host"; + status = "okay"; +}; + +&dwc3_2 { + status = "okay"; +}; + +&usb2_phy2 { + status = "okay"; +}; + +&usb2 { + dr_mode = "host"; + status = "okay"; + interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "peripheral", "host", "otg"; +}; + +&elm { + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&tscadc { + status = "okay"; + tsc { + ti,wires = <4>; + ti,x-plate-resistance = <200>; + ti,coordiante-readouts = <5>; + ti,wire-config = <0x00 0x11 0x22 0x33>; + }; + + adc { + ti,adc-channels = <4 5 6 7>; + }; +}; + +&cpu { + cpu0-supply = <&dcdc2>; + operating-points = <1000000 1330000>, + <800000 1260000>, + <720000 1200000>, + <600000 1100000>, + <300000 950000>; +}; diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 214a054..dbc0f7e 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -32,6 +32,8 @@ CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x40000 CONFIG_SYS_PROMPT="CM-T43 # " +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am437x-cm-t43" CONFIG_CMD_ASKENV=y CONFIG_CMD_EEPROM=y CONFIG_CMD_EEPROM_LAYOUT=y
