[U-Boot] [PATCH] fs/fat: fix fatbuf leak
A new fatbuf was allocated by get_fs_info() (called by fat_itr_root()), but not freed, resulting in eventually running out of memory. Spotted by running 'ls -r' in a large FAT filesystem from Shell.efi.
fatbuf is mainly used to cache FAT entry lookups (get_fatent()).. possibly once fat_write.c it can move into the iterator to simplify this.
Signed-off-by: Rob Clark robdclark@gmail.com --- I can squash this back in to the earlier readdir patches and resend them if that is preferred.
fs/fat/fat.c | 23 ++++++++++++++++------- 1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/fs/fat/fat.c b/fs/fat/fat.c index f5f74c12ff..f0284398b4 100644 --- a/fs/fat/fat.c +++ b/fs/fat/fat.c @@ -1042,6 +1042,7 @@ int fat_exists(const char *filename) return 0;
ret = fat_itr_resolve(itr, filename, TYPE_ANY); + free(fsdata.fatbuf); return ret == 0; }
@@ -1061,17 +1062,19 @@ int fat_size(const char *filename, loff_t *size) * Directories don't have size, but fs_size() is not * expected to fail if passed a directory path: */ + free(fsdata.fatbuf); fat_itr_root(itr, &fsdata); if (!fat_itr_resolve(itr, filename, TYPE_DIR)) { *size = 0; - return 0; + ret = 0; } - return ret; + goto out; }
*size = FAT2CPU32(itr->dent->size); - - return 0; +out: + free(fsdata.fatbuf); + return ret; }
int file_fat_read_at(const char *filename, loff_t pos, void *buffer, @@ -1087,10 +1090,14 @@ int file_fat_read_at(const char *filename, loff_t pos, void *buffer,
ret = fat_itr_resolve(itr, filename, TYPE_FILE); if (ret) - return ret; + goto out;
printf("reading %s\n", filename); - return get_contents(&fsdata, itr->dent, pos, buffer, maxsize, actread); + ret = get_contents(&fsdata, itr->dent, pos, buffer, maxsize, actread); + +out: + free(fsdata.fatbuf); + return ret; }
int file_fat_read(const char *filename, void *buffer, int maxsize) @@ -1126,7 +1133,7 @@ typedef struct {
int fat_opendir(const char *filename, struct fs_dir_stream **dirsp) { - fat_dir *dir = malloc(sizeof(*dir)); + fat_dir *dir = calloc(1, sizeof(*dir)); int ret;
if (!dir) @@ -1144,6 +1151,7 @@ int fat_opendir(const char *filename, struct fs_dir_stream **dirsp) return 0;
fail: + free(dir->fsdata.fatbuf); free(dir); return ret; } @@ -1174,6 +1182,7 @@ int fat_readdir(struct fs_dir_stream *dirs, struct fs_dirent **dentp) void fat_closedir(struct fs_dir_stream *dirs) { fat_dir *dir = (fat_dir *)dirs; + free(dir->fsdata.fatbuf); free(dir); }
- free(fsdata.fatbuf); return ret == 0; }
fat_itr_root(itr, &fsdata); if (!fat_itr_resolve(itr, filename, TYPE_DIR)) { *size = 0;free(fsdata.fatbuf);
}ret = 0;
return ret;
goto out;
+out:
return ret; }
return ret;
goto out;
- ret = get_contents(&fsdata, itr->dent, pos, buffer, maxsize, actread);
+out:
return ret; }
if (!dir)
fail:
- free(dir->fsdata.fatbuf); free(dir); return ret; }
- free(dir->fsdata.fatbuf); free(dir); }
Reviewed-by: Łukasz Majewski lukma@denx.de
Separate is fine, thanks!
Signed-off-by: Rob Clark robdclark@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Łukasz Majewski lukma@denx.de
Rob Clark
Łukasz Majewski
