[U-Boot] Pull request: u-boot-arm
Hi Wolfgang,
Please pull from u-boot-arm/master to go into rc1 of upcoming release.
The following changes since commit 6f918bd46482f889f4d94623b09daf659a1974bd:
Merge branch 'master' of git://git.denx.de/u-boot-mpc85xx (2011-01-31 23:20:32 +0100)
git://www.denx.de/git/u-boot-arm.git master
Alexander Holler (1): ARM: Avoid compiler optimization for readb, writeb and friends.
Anatolij Gustschin (2): SPI: mxc_spi: fix swapping bug and add missing swapping in unaligned rx case SPI: mxc_spi: add SPI clock calculation and setup to the driver
Heiko Schocher (2): arm1136: timer: Replace bss variable by gd arm926ejs: timer: Replace bss variable by gdr
Jens Scharsig (1): remove (double) LED initialization in arm920t start.s
Liu Hui-R64343 (10): MX51EVK: UART does not print out the early information MX5: Add initial support for MX53 processor fec_mxc: add support for MX53 processor serial_mxc: add support for MX53 processor mxc_gpio: add support for MX53 processor mxc_i2c: add support for MX53 processor fsl_pmic: add I2C interface support MX5:MX53: add initial support for MX53EVK board imximage: Add MX53 boot image support ARM: */start.S: code cleanup
Marek Vasut (4): BLOCK: Add freescale IMX51 PATA driver MC13892: Add SWx buck switchers definitions MX51EVK: Use SWx macros in PMIC init iMX5: EfikaMX: Preliminary board support
Mike Rapoport (1): OMAP3: add CM-T35 board
Minkyu Kang (4): armv7: s5pc1xx: don't use function pointer for clock functions S5P: serial: Use the inline function instead of static value armv7: add support for S5PC210 SoC armv7: add support for s5pc210 universal board
Po-Yu Chuang (1): arm: a320evb: fixes for relocation support
Sandeep Paulraj (12): Davinci MMCSD Support DaVinci DM355: Adding MMC/SD support for DM355 EVM DaVinci DM365: Adding MMC/SD support for DM365 EVM DM365: Fix Build Error DaVinci EMAC: Fix davinci_eth_gigabit_enable DaVinci EMAC: Add name to Ethernet device DaVinci DM6467: Added ET1011C (LSI) PHY support ARM: Update mach types DaVinci DM6467: Enhance board Support DaVinci DM6467: Fix Build Error DaVinci Sonata: Fix Build Error DaVinci: Remove incorrect CONFIG option
Stefano Babic (13): mxc_nand: add support for i.MX35 processor Add support for MX35 processor serial_mxc: add support for Freescale's i.MX35 processor mxc_i2c: Add support for the i.MX35 processor I2C: mxc_i2c: get rid of __REG access I2C: mxc_i2c: address failure with mx35 processor Add basic support for Freescale's mc9sdz60 SPI: mxc_spi: add support for i.MX35 processor SPI: mxc_spi: replace fixed offsets with structures Add support for Freescale's mx35pdk board. MX5: Reuse the gd->tbl value for timestamp and add gd->lastinc for lastinc bss MXC: removed warnings from IMX51 ATA driver ARM: fix broken build of ARM
MAINTAINERS | 17 +- arch/arm/config.mk | 2 +- arch/arm/cpu/arm1136/mx31/timer.c | 19 +- arch/arm/cpu/arm1136/mx35/Makefile | 63 + arch/arm/cpu/arm1136/mx35/asm-offsets.c | 43 + arch/arm/cpu/arm1136/mx35/generic.c | 463 ++++ arch/arm/cpu/arm1136/mx35/iomux.c | 116 + arch/arm/cpu/arm1136/mx35/timer.c | 120 + arch/arm/cpu/arm1136/omap24xx/timer.c | 19 +- arch/arm/cpu/arm1136/start.S | 2 - arch/arm/cpu/arm1176/start.S | 2 - arch/arm/cpu/arm720t/start.S | 2 - arch/arm/cpu/arm920t/start.S | 5 - arch/arm/cpu/arm925t/start.S | 2 - arch/arm/cpu/arm926ejs/davinci/Makefile | 2 +- arch/arm/cpu/arm926ejs/davinci/cpu.c | 14 +- arch/arm/cpu/arm926ejs/davinci/et1011c.c | 55 + arch/arm/cpu/arm926ejs/kirkwood/timer.c | 6 +- arch/arm/cpu/arm926ejs/mb86r0x/timer.c | 6 +- arch/arm/cpu/arm926ejs/mx25/timer.c | 6 +- arch/arm/cpu/arm926ejs/mx27/timer.c | 6 +- arch/arm/cpu/arm926ejs/omap/timer.c | 6 +- arch/arm/cpu/arm926ejs/orion5x/timer.c | 6 +- arch/arm/cpu/arm926ejs/spear/timer.c | 6 +- arch/arm/cpu/arm926ejs/start.S | 2 - arch/arm/cpu/arm926ejs/versatile/timer.c | 6 +- arch/arm/cpu/arm946es/start.S | 2 - arch/arm/cpu/arm_intcm/start.S | 2 - arch/arm/cpu/armv7/mx5/iomux.c | 30 +- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 91 +- arch/arm/cpu/armv7/mx5/soc.c | 22 +- arch/arm/cpu/armv7/mx5/timer.c | 6 +- arch/arm/cpu/armv7/s5p-common/cpu_info.c | 2 - arch/arm/cpu/armv7/s5pc1xx/clock.c | 38 +- .../arm/cpu/armv7/s5pc2xx/Makefile | 37 +- arch/arm/cpu/armv7/s5pc2xx/clock.c | 220 ++ arch/arm/cpu/armv7/s5pc2xx/soc.c | 30 + arch/arm/cpu/armv7/start.S | 2 - arch/arm/cpu/ixp/start.S | 2 - arch/arm/cpu/lh7a40x/start.S | 2 - arch/arm/cpu/pxa/start.S | 2 - arch/arm/cpu/s3c44b0/start.S | 2 - arch/arm/cpu/sa1100/start.S | 2 - arch/arm/include/asm/arch-davinci/emac_defs.h | 3 + arch/arm/include/asm/arch-davinci/hardware.h | 1 + arch/arm/include/asm/arch-davinci/sdmmc_defs.h | 175 ++ arch/arm/include/asm/arch-mx31/mx31-regs.h | 11 + arch/arm/include/asm/arch-mx35/clock.h | 45 + arch/arm/include/asm/arch-mx35/crm_regs.h | 270 +++ arch/arm/include/asm/arch-mx35/imx-regs.h | 303 +++ arch/arm/include/asm/arch-mx35/iomux.h | 295 +++ arch/arm/include/asm/arch-mx35/mx35_pins.h | 355 +++ arch/arm/include/asm/arch-mx35/sys_proto.h | 31 + arch/arm/include/asm/arch-mx5/asm-offsets.h | 5 + arch/arm/include/asm/arch-mx5/imx-regs.h | 94 +- arch/arm/include/asm/arch-mx5/iomux.h | 102 - arch/arm/include/asm/arch-mx5/mx5x_pins.h | 469 ++++- arch/arm/include/asm/arch-s5pc1xx/clk.h | 10 +- arch/arm/include/asm/arch-s5pc1xx/uart.h | 5 +- arch/arm/include/asm/arch-s5pc2xx/adc.h | 42 + arch/arm/include/asm/arch-s5pc2xx/clk.h | 36 + arch/arm/include/asm/arch-s5pc2xx/clock.h | 255 +++ arch/arm/include/asm/arch-s5pc2xx/cpu.h | 103 + arch/arm/include/asm/arch-s5pc2xx/gpio.h | 112 + arch/arm/include/asm/arch-s5pc2xx/mmc.h | 71 + arch/arm/include/asm/arch-s5pc2xx/pwm.h | 55 + arch/arm/include/asm/arch-s5pc2xx/sys_proto.h | 32 + arch/arm/include/asm/arch-s5pc2xx/uart.h | 58 + arch/arm/include/asm/io.h | 32 +- arch/arm/include/asm/mach-types.h | 2305 +++++++++++++++++++- .../{faraday/a320evb/config.mk => cm_t35/Makefile} | 42 +- board/cm_t35/cm_t35.c | 371 ++++ board/davinci/common/misc.c | 2 +- board/davinci/dm355evm/dm355evm.c | 41 + board/davinci/dm365evm/dm365evm.c | 49 + board/davinci/dm6467evm/dm6467evm.c | 26 + board/efikamx/Makefile | 52 + board/{faraday/a320evb => efikamx}/config.mk | 24 +- board/efikamx/efikamx.c | 689 ++++++ board/efikamx/imximage.cfg | 122 + board/faraday/a320evb/a320evb.c | 3 +- board/freescale/mx35pdk/Makefile | 49 + board/freescale/mx35pdk/lowlevel_init.S | 363 +++ board/freescale/mx35pdk/mx35pdk.c | 297 +++ board/freescale/mx35pdk/mx35pdk.h | 101 + board/freescale/mx51evk/mx51evk.c | 17 +- .../config.mk => freescale/mx53evk/Makefile} | 43 +- .../a320evb => freescale/mx53evk}/config.mk | 23 +- board/freescale/mx53evk/imximage.cfg | 112 + board/freescale/mx53evk/mx53evk.c | 397 ++++ board/samsung/universal_c210/Makefile | 51 + board/samsung/universal_c210/lowlevel_init.S | 395 ++++ board/samsung/universal_c210/onenand.c | 34 + board/samsung/universal_c210/universal.c | 250 +++ boards.cfg | 5 + doc/README.imximage | 12 +- doc/README.mx35pdk | 188 ++ doc/README.omap3 | 16 +- drivers/block/Makefile | 1 + drivers/block/mxc_ata.c | 146 ++ drivers/gpio/mxc_gpio.c | 9 +- drivers/i2c/mxc_i2c.c | 172 ++- drivers/misc/Makefile | 5 +- drivers/misc/fsl_pmic.c | 45 +- drivers/misc/mc9sdz60.c | 51 + drivers/mmc/Makefile | 1 + drivers/mmc/davinci_mmc.c | 404 ++++ drivers/mtd/nand/mxc_nand.c | 6 +- drivers/net/davinci_emac.c | 15 +- drivers/net/fec_mxc.c | 2 +- drivers/net/fec_mxc.h | 4 +- drivers/serial/serial_mxc.c | 9 +- drivers/serial/serial_s5p.c | 2 +- drivers/spi/mxc_spi.c | 200 +- include/configs/a320evb.h | 14 +- include/configs/cm_t35.h | 352 +++ include/configs/davinci_dm355evm.h | 22 + include/configs/davinci_dm365evm.h | 22 + include/configs/davinci_dm6467evm.h | 30 +- include/configs/davinci_sonata.h | 1 + include/configs/efikamx.h | 232 ++ include/configs/mx35pdk.h | 303 +++ include/configs/mx51evk.h | 5 +- include/configs/mx53evk.h | 193 ++ include/configs/s5pc210_universal.h | 244 +++ include/configs/vision2.h | 3 +- include/mc13892.h | 44 + include/mc9sdz60.h | 84 + include/mmc.h | 3 + include/netdev.h | 1 + tools/imximage.c | 525 ++++-- tools/imximage.h | 110 +- 132 files changed, 13054 insertions(+), 743 deletions(-) create mode 100644 arch/arm/cpu/arm1136/mx35/Makefile create mode 100644 arch/arm/cpu/arm1136/mx35/asm-offsets.c create mode 100644 arch/arm/cpu/arm1136/mx35/generic.c create mode 100644 arch/arm/cpu/arm1136/mx35/iomux.c create mode 100644 arch/arm/cpu/arm1136/mx35/timer.c create mode 100644 arch/arm/cpu/arm926ejs/davinci/et1011c.c copy board/faraday/a320evb/config.mk => arch/arm/cpu/armv7/s5pc2xx/Makefile (56%) create mode 100644 arch/arm/cpu/armv7/s5pc2xx/clock.c create mode 100644 arch/arm/cpu/armv7/s5pc2xx/soc.c create mode 100644 arch/arm/include/asm/arch-davinci/sdmmc_defs.h create mode 100644 arch/arm/include/asm/arch-mx35/clock.h create mode 100644 arch/arm/include/asm/arch-mx35/crm_regs.h create mode 100644 arch/arm/include/asm/arch-mx35/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mx35/iomux.h create mode 100644 arch/arm/include/asm/arch-mx35/mx35_pins.h create mode 100644 arch/arm/include/asm/arch-mx35/sys_proto.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/adc.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/clk.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/clock.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/cpu.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/gpio.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/mmc.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/pwm.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/sys_proto.h create mode 100644 arch/arm/include/asm/arch-s5pc2xx/uart.h copy board/{faraday/a320evb/config.mk => cm_t35/Makefile} (54%) create mode 100644 board/cm_t35/cm_t35.c create mode 100644 board/efikamx/Makefile copy board/{faraday/a320evb => efikamx}/config.mk (62%) create mode 100644 board/efikamx/efikamx.c create mode 100644 board/efikamx/imximage.cfg create mode 100644 board/freescale/mx35pdk/Makefile create mode 100644 board/freescale/mx35pdk/lowlevel_init.S create mode 100644 board/freescale/mx35pdk/mx35pdk.c create mode 100644 board/freescale/mx35pdk/mx35pdk.h copy board/{faraday/a320evb/config.mk => freescale/mx53evk/Makefile} (50%) rename board/{faraday/a320evb => freescale/mx53evk}/config.mk (62%) create mode 100644 board/freescale/mx53evk/imximage.cfg create mode 100644 board/freescale/mx53evk/mx53evk.c create mode 100644 board/samsung/universal_c210/Makefile create mode 100644 board/samsung/universal_c210/lowlevel_init.S create mode 100644 board/samsung/universal_c210/onenand.c create mode 100644 board/samsung/universal_c210/universal.c create mode 100644 doc/README.mx35pdk create mode 100644 drivers/block/mxc_ata.c create mode 100644 drivers/misc/mc9sdz60.c create mode 100644 drivers/mmc/davinci_mmc.c create mode 100644 include/configs/cm_t35.h create mode 100644 include/configs/efikamx.h create mode 100644 include/configs/mx35pdk.h create mode 100644 include/configs/mx53evk.h create mode 100644 include/configs/s5pc210_universal.h create mode 100644 include/mc9sdz60.h
Amicalement,
Dear Albert ARIBAUD,
In message 4D48A0A0.8040904@free.fr you wrote:
Hi Wolfgang,
Applied, thanks.
Albert ARIBAUD
