[U-Boot] [PATCH] examples: delete unnecessary CPPFLAGS
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Note that adding CPPFLAGS locally in examples/{api,standalone}/Makefile is meaningless.
$(CPPFLAGS) is evaluated around line 260 of $(TOPDIR)/config.mk:
CFLAGS := $(CPPFLAGS) -Wall -Wstrict-prototypes
$(TOPDIR)/config.mk is included at the top of examples/{api,standalone}/Makefile, which is before adding CPPFLAGS locally.
Please be aware that GNU make has the two different flavor of substition operator, ":=" and "=".
examples/api/Makefile | 2 -- examples/standalone/Makefile | 2 -- 2 files changed, 4 deletions(-)
diff --git a/examples/api/Makefile b/examples/api/Makefile index 33cc91b..1cefbe7 100644 --- a/examples/api/Makefile +++ b/examples/api/Makefile @@ -46,8 +46,6 @@ OBJS += $(addprefix $(obj),$(COBJ_FILES-y)) OBJS += $(addprefix $(obj),$(notdir $(EXT_COBJ_FILES-y))) OBJS += $(addprefix $(obj),$(notdir $(EXT_SOBJ_FILES-y)))
-CPPFLAGS += -I.. - all: $(obj).depend $(OUTPUT)
######################################################################### diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 237b737..c9b2a27 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -52,8 +52,6 @@ SREC := $(addprefix $(obj),$(SREC))
gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`)
-CPPFLAGS += -I.. - # For PowerPC there's no need to compile standalone applications as a # relocatable executable. The relocation data is not needed, and # also causes the entry point of the standalone application to be
Masahiro Yamada
