[U-Boot] [PATCH] net: cpsw: am335x: Drop constant link checking from rx/tx path's
We noticed on the DXR2 platform (AM335x with a SMSC LAN9303 switch connected to the CPSW MAC) that the network performance in U-Boot is quite poor. Only when the transfer is started without a cable connected, and the cable is plugged after the first timeout "T" occured, an increased in performance can be seen. Debugging has revealed, that the cpsw driver has constant link checking builtin into the rx and tx functions. This results in the bad performance and seems to be unnecessary. The link has already been checked in the init function, before the transfer is started. This usually is sufficient.
BTW: I have seen no other network driver in U-Boot so far, that constantly checks for link in the rx / tx functions.
The performance numbers on the DXR2 board are:
0.56 MiB/s cpsw_check_link() in rx and tx path 0.87 MiB/s cpsw_check_link() only in tx path 1.0 MiB/s cpsw_check_link() only in rx path 2.7 MiB/s no cpsw_check_link() in rx and tx path
So with this patch the network performance on DXR2 increases from 0.56 to 2.7 MiB/s (nearly 5 times as fast).
Signed-off-by: Stefan Roese sr@denx.de Tested-by: Samuel Egli samuel.egli@siemens.com Tested-by: Heiko Schocher hs@denx.de Cc: Vladimir Koutny vladimir.koutny@streamunlimited.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Tom Rini trini@ti.com --- drivers/net/cpsw.c | 19 +------------------ 1 file changed, 1 insertion(+), 18 deletions(-)
diff --git a/drivers/net/cpsw.c b/drivers/net/cpsw.c index 8ec5161..52f8da6 100644 --- a/drivers/net/cpsw.c +++ b/drivers/net/cpsw.c @@ -235,7 +235,6 @@ struct cpsw_priv { struct phy_device *phydev; struct mii_dev *bus;
- u32 mdio_link; u32 phy_mask; };
@@ -613,19 +612,8 @@ static int cpsw_update_link(struct cpsw_priv *priv)
for_active_slave(slave, priv) cpsw_slave_update_link(slave, priv, &link); - priv->mdio_link = readl(&mdio_regs->link); - return link; -} - -static int cpsw_check_link(struct cpsw_priv *priv) -{ - u32 link = 0;
- link = __raw_readl(&mdio_regs->link) & priv->phy_mask; - if ((link) && (link == priv->mdio_link)) - return 1; - - return cpsw_update_link(priv); + return link; }
static inline u32 cpsw_get_slave_port(struct cpsw_priv *priv, u32 slave_num) @@ -891,9 +879,6 @@ static int cpsw_send(struct eth_device *dev, void *packet, int length) int len; int timeout = CPDMA_TIMEOUT;
- if (!cpsw_check_link(priv)) - return -EIO; - flush_dcache_range((unsigned long)packet, (unsigned long)packet + length);
@@ -916,8 +901,6 @@ static int cpsw_recv(struct eth_device *dev) void *buffer; int len;
- cpsw_check_link(priv); - while (cpdma_process(priv, &priv->rx_chan, &buffer, &len) >= 0) { invalidate_dcache_range((unsigned long)buffer, (unsigned long)buffer + PKTSIZE_ALIGN);
Yes, this strongly feels like a bring-up sanity check thing that was left in by accident.
Stefan Roese
