[U-Boot-Users] Problems booting a uImage on sequoia (PPC440EPx with fdt/powerpc)
Hi
I would like to run the DENX-v2.6.23.1 linux kernel (ARCH=powerpc) as a base to run some tests with xenomai. I had no problem to create a git branch and to run git checkout -b sequoia-DENX-v2.6.23.1 DENX-v2.6.23.1 make ARCH=powerpc CROSS_COMPILE=ppc_4xx- O=../build sequoia_defconfig make ARCH=powerpc CROSS_COMPILE=ppc_4xx- O=../build uImage
As the resulting kernel could not be loaded with my 1.2.0 u-Boot I spent some time reading the linux/Documentation/powerpc/booting-without-of.txt, http://www.denx.de/wiki/UBoot/UBootFdtInfo http://www.denx.de/wiki/DULG/LinuxFDTBlob
Downloading the dtc and installing it was a snap. I used the arch/powerpc/boot/dts/sequoia.dts as contained DENX-v2.6.23.1 release.
I discovered in Stefan's Roese u-boot-ppc4xx his for-1.3.1 branch which contains some fdt patches (as of today).
I patched sequoia following the example of the kilauea board, enabled the debugging output in cpu/ppc4xx/fdt.c. The patch is attached.
Now I am stuck here:
Bytes transferred = 12288 (3000 hex) ## Booting image at 00200000 ... Image Name: Linux-2.6.23.1 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1461812 Bytes = 1.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Booting using the fdt at 0x400000 Updating property '/cpus/PowerPC,440EPx@0/timebase-frequency' = 1f 78 a4 08(528000008) Updating property '/cpus/PowerPC,440EPx@0/clock-frequency' = 1f 78 a4 08(528000008) Updating property '/plb/clock-frequency' = 07 de 29 02(132000002) Updating property '/plb/opb/clock-frequency' = 03 ef 14 81(66000001) Updating property '/plb/opb/ebc/clock-frequency' = 03 ef 14 81(66000001) Updating /memory node to 0:268435456 Updating node UART0: clock-frequency=11059200 Updating node UART1: clock-frequency=11059200 Updating node UART2: clock-frequency=11059200 Updating node UART3: clock-frequency=11059200 Updating node EMAC0 Updating node EMAC1
I would appreciate if somebody could point out where I made a mistake and what the next hurdle to tackle is.
Thanks in advance.
Dear Niklaus,
Version 1.2.0 on Sequoia? Ummm. Please try 1.3.0 instead.
Right, but this is still somewhat experimental.
The recommended way do far is to boot an ARCH=powerpc kernel on the Sequoia by using the boot wrapper (i. e. use cuImage instead of uImage).
Dear Wolfgang,
Wolfgang Denk wrote:
Dear Niklaus,
Thanks a lot for your answer. I just had to figure out that zImage is the name of the generated image (e.g. http://www.nabble.com/-PATCH--add-cuImage-comment-for-%27make-help%27-t47609...) Now my kernel boots!
Thanks a lot for your prompt answer! (Now, I owe you a beer)
Niklaus Giger
