[PATCH 1/1] patch for OpenPiton SoC of RISC-V Architecture
This patch enables u-boot support for Openpiton SoC of RISC-V architecture
Signed-off-by: Tianrui Wei tianrui-wei@outlook.com Acked-by: Jonathan Balkind jbalkind@ucsb.edu --- arch/riscv/Kconfig | 4 + arch/riscv/dts/Makefile | 1 + arch/riscv/dts/openpiton-riscv64.dts | 149 +++++++++++++++++++ board/openpiton/riscv/Kconfig | 42 ++++++ board/openpiton/riscv/MAINTAINERS | 6 + board/openpiton/riscv/Makefile | 5 + board/openpiton/riscv/openpiton-riscv.c | 39 +++++ configs/openpiton_riscv64_defconfig | 132 +++++++++++++++++ drivers/mmc/Kconfig | 6 + drivers/mmc/Makefile | 1 + drivers/mmc/piton_mmc.c | 182 ++++++++++++++++++++++++ include/configs/openpiton-riscv.h | 58 ++++++++ 12 files changed, 625 insertions(+) create mode 100644 arch/riscv/dts/openpiton-riscv64.dts create mode 100644 board/openpiton/riscv/Kconfig create mode 100644 board/openpiton/riscv/MAINTAINERS create mode 100644 board/openpiton/riscv/Makefile create mode 100644 board/openpiton/riscv/openpiton-riscv.c create mode 100644 configs/openpiton_riscv64_defconfig create mode 100644 drivers/mmc/piton_mmc.c create mode 100644 include/configs/openpiton-riscv.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 30b05408..79f2b0b9 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -23,6 +23,9 @@ config TARGET_SIFIVE_FU540 config TARGET_SIPEED_MAIX bool "Support Sipeed Maix Board"
+config TARGET_OPENPITON_RISCV + bool "Support RISC-V cores on OpenPiton SoC" + endchoice
config SYS_ICACHE_OFF @@ -57,6 +60,7 @@ source "board/emulation/qemu-riscv/Kconfig" source "board/microchip/mpfs_icicle/Kconfig" source "board/sifive/fu540/Kconfig" source "board/sipeed/maix/Kconfig" +source "board/openpiton/riscv/Kconfig"
# platform-specific options below source "arch/riscv/cpu/ax25/Kconfig" diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 3a6f96c6..0eb8014b 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -3,6 +3,7 @@ dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_FU540) += hifive-unleashed-a00.dtb dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb +dtb-$(CONFIG_TARGET_OPENPITON_RISCV) += openpiton-riscv64.dtb
targets += $(dtb-y)
diff --git a/arch/riscv/dts/openpiton-riscv64.dts b/arch/riscv/dts/openpiton-riscv64.dts new file mode 100644 index 00000000..91c000c3 --- /dev/null +++ b/arch/riscv/dts/openpiton-riscv64.dts @@ -0,0 +1,149 @@ +// This dts is for a dual core instance of OpenPiton+Ariane built +// to run on a Digilent Genesys 2 FPGA at 66.67MHz. These files +// are automatically generated by the OpenPiton build system and +// this configuration may not be what you need if your configuration +// is different from the below. + +/dts-v1/; + +/ { + #address-cells = <2>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + compatible = "openpiton,ariane"; + + chosen { + u-boot,dm-pre-reloc; + bootargs = "debug loglevel=9"; + stdout-path = "uart0:115200"; + }; + + aliases { + u-boot,dm-pre-reloc; + console = &uart0; + serial0 = &uart0; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + u-boot,dm-pre-reloc; + timebase-frequency = <520835>; + + CPU0: cpu@0 { + clock-frequency = <66667000>; + u-boot,dm-pre-reloc; + device_type = "cpu"; + reg = <0>; + status = "okay"; + compatible = "eth, ariane", "riscv"; + riscv,isa = "rv64imafdc"; + mmu-type = "riscv,sv39"; + tlb-split; + // HLIC - hart local interrupt controller + CPU0_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + + CPU1: cpu@1 { + clock-frequency = <66667000>; + u-boot,dm-pre-reloc; + device_type = "cpu"; + reg = <1>; + status = "okay"; + compatible = "eth, ariane", "riscv"; + riscv,isa = "rv64imafdc"; + mmu-type = "riscv,sv39"; + tlb-split; + // HLIC - hart local interrupt controller + CPU1_intc: interrupt-controller { + #interrupt-cells = <1>; + interrupt-controller; + compatible = "riscv,cpu-intc"; + }; + }; + + }; + + memory@80000000 { + u-boot,dm-pre-reloc; + device_type = "memory"; + reg = < 0x00000000 0x80000000 0x00000000 0x40000000 >; + }; + + uart0: uart@fff0c2c000 { + u-boot,dm-pre-reloc; + compatible = "ns16550"; + reg = < 0x000000ff 0xf0c2c000 0x00000000 0x000d4000 >; + clock-frequency = <66667000>; + current-speed = <115200>; + interrupt-parent = <&PLIC0>; + interrupts = <1>; + reg-shift = <0>; // regs are spaced on 8 bit boundary (modified from Xilinx UART16550 to be ns16550 compatible) + }; + + eth: ethernet@fff0d00000 { + compatible = "xlnx,xps-ethernetlite-1.00.a"; + device_type = "network"; + reg = < 0x000000ff 0xf0d00000 0x00000000 0x00100000 >; + interrupt-parent = <&PLIC0>; + interrupts = <2>; + local-mac-address = [ 00 18 3E 02 E3 E5 ]; + phy-handle = <&phy0>; + xlnx,duplex = <0x1>; + xlnx,include-global-buffers = <0x1>; + xlnx,include-internal-loopback = <0x0>; + xlnx,include-mdio = <0x1>; + xlnx,rx-ping-pong = <0x1>; + xlnx,s-axi-id-width = <0x1>; + xlnx,tx-ping-pong = <0x1>; + xlnx,use-internal = <0x0>; + axi_ethernetlite_0_mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: phy@1 { + compatible = "ethernet-phy-id001C.C915"; + device_type = "ethernet-phy"; + reg = <1>; + }; + }; + }; + + debug-controller@fff1000000 { + compatible = "riscv,debug-013"; + interrupts-extended = <&CPU0_intc 65535 &CPU1_intc 65535 >; + reg = < 0x000000ff 0xf1000000 0x00000000 0x00001000 >; + reg-names = "control"; + }; + + sdhci_0: sdhci@0xf000000000 { + u-boot,dm-pre-reloc; + status = "okay"; + compatible = "openpiton,piton-mmc"; + reg = < 0x000000f0 0x00000000 0x00000000 0x00300000 >; + }; + clint@fff1020000 { + u-boot,dm-pre-reloc; + compatible = "riscv,clint0"; + interrupts-extended = <&CPU0_intc 3 &CPU0_intc 7 &CPU1_intc 3 &CPU1_intc 7 >; + reg = < 0x000000ff 0xf1020000 0x00000000 0x000c0000 >; + reg-names = "control"; + }; + + PLIC0: plic@fff1100000 { + u-boot,dm-pre-reloc; + #address-cells = <0>; + #interrupt-cells = <1>; + compatible = "riscv,plic0"; + interrupt-controller; + interrupts-extended = <&CPU0_intc 11 &CPU0_intc 9 &CPU1_intc 11 &CPU1_intc 9 >; + reg = < 0x000000ff 0xf1100000 0x00000000 0x04000000 >; + riscv,max-priority = <7>; + riscv,ndev = <2>; + }; + +}; + diff --git a/board/openpiton/riscv/Kconfig b/board/openpiton/riscv/Kconfig new file mode 100644 index 00000000..31ae44d5 --- /dev/null +++ b/board/openpiton/riscv/Kconfig @@ -0,0 +1,42 @@ +if TARGET_OPENPITON_RISCV + +config SYS_BOARD + default "riscv" + +config SYS_VENDOR + default "openpiton" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "openpiton-riscv" + +config SYS_TEXT_BASE + default 0x81000000 if SPL + default 0x80000000 if !RISCV_SMODE + default 0x81000000 if RISCV_SMODE + +config SPL_TEXT_BASE + default 0x80000000 + +config SPL_OPENSBI_LOAD_ADDR + default 0x81000000 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select ARCH_EARLY_INIT_R + select SUPPORT_SPL + imply CPU_RISCV + imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE) + imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE) + imply CMD_CPU + imply SPL_CPU_SUPPORT + imply SPL_OPENSBI + imply SPL_LOAD_FIT + imply SPL_SMP + imply SPL_MMC + imply SMP + imply SPL_RISCV_MMODE + +endif diff --git a/board/openpiton/riscv/MAINTAINERS b/board/openpiton/riscv/MAINTAINERS new file mode 100644 index 00000000..1db6fb60 --- /dev/null +++ b/board/openpiton/riscv/MAINTAINERS @@ -0,0 +1,6 @@ +Openpiton Riscv Bootloader +M: Tianrui Weitianrui-wei@outlook.com +S: Maintained +F: board/openpiton/riscv/ +F: include/configs/openpiton-riscv.h +F: configs/openpiton_riscv_defconfig diff --git a/board/openpiton/riscv/Makefile b/board/openpiton/riscv/Makefile new file mode 100644 index 00000000..8cc20e7c --- /dev/null +++ b/board/openpiton/riscv/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021 Tianrui Wei +# Tianrui Wei tianrui-wei@outlook.com +obj-y += openpiton-riscv.o diff --git a/board/openpiton/riscv/openpiton-riscv.c b/board/openpiton/riscv/openpiton-riscv.c new file mode 100644 index 00000000..7cc621bc --- /dev/null +++ b/board/openpiton/riscv/openpiton-riscv.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2019 SiFive, Inc + * Copyright (c) 2021 Tianrui Wei + * + * + * Authors: + * Pragnesh Patel pragnesh.patel@sifive.com + * Tianrui Wei tianrui-wei@outlook.com + */ +#include <common.h> +#include <init.h> +#include <configs/openpiton-riscv.h> +#include <dm.h> +#include <spl.h> + +#ifdef CONFIG_SPL +void board_boot_order(u32 *spl_boot_list) { + u8 i; + u32 boot_devices[] = { + BOOT_DEVICE_MMC1, + }; + + for (i = 0; i < ARRAY_SIZE(boot_devices); i++) + spl_boot_list[i] = boot_devices[i]; +} +#endif + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) { + /* boot using first FIT config */ + return 0; +} +#endif + +int board_init() +{ + return 0; +} diff --git a/configs/openpiton_riscv64_defconfig b/configs/openpiton_riscv64_defconfig new file mode 100644 index 00000000..37aa3c80 --- /dev/null +++ b/configs/openpiton_riscv64_defconfig @@ -0,0 +1,132 @@ +CONFIG_RISCV=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="openpiton-riscv64" +CONFIG_TARGET_OPENPITON_RISCV=y +CONFIG_ARCH_RV64I=y +CONFIG_RISCV_SMODE=y +CONFIG_MISC_INIT_R=n +CONFIG_SYS_MALLOC_F_LEN=0x1000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x100000 +CONFIG_SPL_PAYLOAD="" +CONFIG_LIBDISK_SUPPORT=y +CONFIG_NR_CPUS=32 +CONFIG_CMODEL_MEDANY=y +CONFIG_EXPORT=n +CONFIG_HASH=n +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_BANNER_PRINT=n +CONFIG_SPL_CRC32_SUPPORT=n +CONFIG_GENERATE_SMBIOS_TABLE=n +CONFIG_EFI_LOADER=n +CONFIG_LIB_DATA=y +CONFIG_SPL_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_FS_EXT4=y +CONFIG_DM_RTC=y +CONFIG_SYS_NS16550=y +CONFIG_SPL_OPENSBI=n +CONFIG_SPL_RTC_SUPPORT=y +CONFIG_SPL_FS_EXT4=y +CONFIG_SPL_LEGACY_IMAGE_SUPPORT=n +CONFIG_CMD_NET=n +CONFIG_EFI_PARTITION=y +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=128 +CONFIG_EFI_PARTITION_ENTRIES_OFF=0 +CONFIG_SPL_EFI_PARTITION=y +CONFIG_PARTITION_UUIDS=y +CONFIG_OF_EMBED=y +CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_CPU=y +CONFIG_CPU_RISCV=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +CONFIG_SPL_DM_MMC=y +CONFIG_MMC_PITON=y +CONFIG_MMC_QUIRKS=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_NS16550=y +CONFIG_DEBUG_UART_SHIFT=0 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_DEBUG_UART_BASE=0xfff0c2c000 +CONFIG_DEBUG_UART_CLOCK=66667000 +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_MMC_VERBOSE=n +CONFIG_MMC_WRITE=n +CONFIG_MMC_HW_PARTITIONING=n +CONFIG_SYS_RELOC_GD_ENV_ADDR=n +CONFIG_SAVEENV=n +CONFIG_NET=n +CONFIG_SPL_PARTITION_UUIDS=n +CONFIG_CMD_EXT4=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_READ=y +CONFIG_CMD_LSBLK=y +CONFIG_CMD_MMC=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MEMINFO=y +CONFIG_EXPERT=n +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_LEGACY_IMAGE_FORMAT=n +CONFIG_ARCH_FIXUP_FDT_MEMORY=n +CONFIG_MENU=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_PART=y +CONFIG_SHOW_REGS=y +CONFIG_LOG=y +CONFIG_LOGLEVEL=9 +CONFIG_SPL_LOGLEVEL=9 +CONFIG_TPL_LOGLEVEL=9 +CONFIG_SPL_LOG=y +CONFIG_SPL_LOG_MAX_LEVEL=9 +CONFIG_SPL_LOG_CONSOLE=y +CONFIG_LOG_ERROR_RETURN=y +CONFIG_CMD_CPU=n +CONFIG_BOOTM_NETBSD=n +CONFIG_BOOTM_PLAN9=n +CONFIG_BOOTM_RTEMS=n +CONFIG_BOOTM_VXWORKS=n +CONFIG_CMD_RUN=n +CONFIG_CMD_IMI=n +CONFIG_CMD_XIMG=n +CONFIG_CMD_EXPORTENV=n +CONFIG_CMD_IMPORTENV=n +CONFIG_CMD_EDITENV=n +CONFIG_CMD_SAVEENV=n +CONFIG_CMD_CRC32=n +CONFIG_CMD_RANDOM=n +CONFIG_CMD_LZMADEC=n +CONFIG_CMD_UNLZ4=n +CONFIG_CMD_UNZIP=n +CONFIG_CMD_FLASH=n +CONFIG_RANDOM_UUID=n +CONFIG_CMD_LOADB=n +CONFIG_CMD_LOADS=n +CONFIG_CMD_ECHO=n +CONFIG_CMD_ITEST=n +CONFIG_CMD_SOURCE=n +CONFIG_CMD_SETEXPR=n +CONFIG_CMD_BLOCK_CACHE=n +CONFIG_CMD_DATE=n +CONFIG_CMD_SLEEP=n +CONFIG_CMD_SYSBOOT=y +CONFIG_CMD_FAT=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_DM_ETH=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_FS_FAT=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=65536 +CONFIG_FS_SQUASHFS=y +CONFIG_SHA1=y +CONFIG_SHA256=y +CONFIG_MD5=y +CONFIG_ZLIB_UNCOMPRESS=y +CONFIG_SPL_GZIP=y +CONFIG_SPL_ZLIB=y +CONFIG_GETOPT=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_RAM_SIFIVE=n diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 14d79139..a3650211 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -707,6 +707,12 @@ config MMC_SUNXI_HAS_MODE_SWITCH bool depends on MMC_SUNXI
+config MMC_PITON + bool "MMC support for OpenPiton SoC" + default y + help + This driver enables mmc controller support in uboot port for OpenPiton + config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 1c849cba..698dfe05 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -71,6 +71,7 @@ obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o obj-$(CONFIG_MMC_SDHCI_ZYNQ) += zynq_sdhci.o
obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o +obj-$(CONFIG_MMC_PITON) += piton_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += tmio-common.o uniphier-sd.o obj-$(CONFIG_RENESAS_SDHI) += tmio-common.o renesas-sdhi.o obj-$(CONFIG_MMC_BCM2835) += bcm2835_sdhost.o diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c new file mode 100644 index 00000000..e54be447 --- /dev/null +++ b/drivers/mmc/piton_mmc.c @@ -0,0 +1,182 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2009 SAMSUNG Electronics + * Minkyu Kang mk7.kang@samsung.com + * Jaehoon Chung jh80.chung@samsung.com + * Portions Copyright 2011-2019 NVIDIA Corporation + * Portions Copyright 2021 Tianrui Wei + * Tianrui Wei tianrui-wei@outlook.com + */ + +#include <asm/gpio.h> +#include <asm/io.h> +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <linux/bitops.h> +#include <linux/types.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <log.h> +#include <div64.h> +#include <mmc.h> + +struct piton_mmc_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +struct piton_mmc_priv { + uint64_t piton_mmc_base_addr; /* peripheral id */ +}; + +// see mmc_read_blocks to see how it is used. +// start block is hidden at cmd->arg +// also, initialize the block size at init +static int piton_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) { + // check first if this is a pure command + if (data == NULL) { + return 0; + } + + // byte count counts all the bytes required for this command + uint64_t byte_cnt = data->blocks * data->blocksize; + // get which block in mmc card to start from + uint64_t start_block = cmd->cmdarg; + // buff points to the address we store the data stored at mmc card + unsigned *buff = (unsigned int *) data->dest; + + struct piton_mmc_priv *priv = dev_get_priv(dev); + // start address denotes the absolute address where the transmission start + uint64_t start_addr = priv->piton_mmc_base_addr + (start_block); + + /* if data is not empty*/ + if (data) { + + /* if there is a read */ + if (data->flags & MMC_DATA_READ) { + for (uint64_t i = 0; i < byte_cnt; i += 4) { + *(buff) = readl((void *)(start_addr + i)); + buff++; + } + } else { + /* else there is a write + * we don't handle write, so error right away + */ + return -ENODEV; + } + } + + return 0; +} + +static int piton_mmc_ofdata_to_platdata(struct udevice *dev) +{ + struct piton_mmc_priv *priv = dev_get_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg; + struct mmc *mmc; + + priv->piton_mmc_base_addr = dev_read_addr(dev); + cfg = &plat->cfg; + cfg->name = "PITON MMC"; + cfg->host_caps = MMC_MODE_8BIT; + cfg->f_max = 100000; + cfg->f_min = 400000; + cfg->voltages = MMC_VDD_21_22; + + mmc = &plat->mmc; + mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + mmc->capacity_user = 0x100000000ULL; + mmc->capacity_user *= mmc->read_bl_len; + mmc->capacity_boot = 0; + mmc->capacity_rpmb = 0; + for (int i = 0; i < 4; i++) + mmc->capacity_gp[i] = 0; + mmc->capacity = 0x800000000ULL; + mmc->has_init = 1; + + /* fill in device description */ + struct blk_desc *bdesc; + + bdesc = mmc_get_blk_desc(mmc); + bdesc->lun = 0; + bdesc->hwpart = 0; + bdesc->type = 0; + bdesc->blksz = mmc->read_bl_len; + bdesc->log2blksz = LOG2(bdesc->blksz); + bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len); + + return 0; +} +/* + * currently, this is ignored. we only use fixed speed + */ +static int piton_mmc_set_ios(struct udevice *dev) { return 0; } + +/* test if piton has the micro mmc card present + * always return 1, which means present + */ +static int piton_mmc_getcd(struct udevice *dev) { + + return 1; +} + +/* dummy function, piton_mmc don't need initialization in hw*/ +static int piton_mmc_init(struct udevice *dev) { + + return 0; +} + +static const struct dm_mmc_ops piton_mmc_ops = { + // send a command to mmc device + .send_cmd = piton_mmc_send_cmd, + // set iospeed + .set_ios = piton_mmc_set_ios, + // detect if card is present + .get_cd = piton_mmc_getcd, +}; + +static int piton_mmc_probe(struct udevice *dev) { + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + upriv->mmc = &plat->mmc; + upriv->mmc->has_init = 1; + upriv->mmc->capacity = 0x2000000000ULL; + upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + + return piton_mmc_init(dev); +} + +static int piton_mmc_bind(struct udevice *dev) { + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT; + cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; + cfg->f_min = 1000000; + cfg->f_max = 52000000; + cfg->b_max = U32_MAX; + + return mmc_bind(dev, &plat->mmc, cfg); +} + +static const struct udevice_id piton_mmc_ids[] = { + {.compatible = "openpiton,piton-mmc"}, {}}; + +U_BOOT_DRIVER(piton_mmc_drv) = { + .name = "piton_mmc", + .id = UCLASS_MMC, + .of_match = piton_mmc_ids, + .ofdata_to_platdata = piton_mmc_ofdata_to_platdata, + .bind = piton_mmc_bind, + .probe = piton_mmc_probe, + .ops = &piton_mmc_ops, + .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat), + .priv_auto_alloc_size = sizeof(struct piton_mmc_priv), +}; diff --git a/include/configs/openpiton-riscv.h b/include/configs/openpiton-riscv.h new file mode 100644 index 00000000..514edbc6 --- /dev/null +++ b/include/configs/openpiton-riscv.h @@ -0,0 +1,58 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2019 Western Digital Corporation or its affiliates. + * Copyright (c) 2021 Tianrui Wei + * + * Authors: + * Anup Patel anup.patel@wdc.com + * Tianrui Wei tianrui-wei@outlook.com + */ + +#ifndef __OPENPITON_RISCV_CONFIG_H +#define __OPENPITON_RISCV_CONFIG_H + +#include <linux/sizes.h> +#define DEBUG +#ifdef CONFIG_SPL +#define CONFIG_SPL_MAX_SIZE 0x00100000 +#define CONFIG_SPL_BSS_START_ADDR 0x82000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ + CONFIG_SPL_BSS_MAX_SIZE) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x0100000 +#define CONFIG_SPL_STACK (0x80000000 + 0x04000000 - \ + GENERATED_GBL_DATA_SIZE) + +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "boot/fw_payload.bin" +#define CONFIG_SPL_GD_ADDR 0x85000000 +#endif + +/* Environment options */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + SZ_2M) +#define CONFIG_SYS_MALLOC_LEN SZ_256M +#define CONFIG_SYS_BOOTM_LEN SZ_256M + +/* ------------------------------------------------- + * Environment + */ +//Disable persistent environment variable storage +#define CONFIG_ENV_IS_NOWHERE 1 + +/* --------------------------------------------------------------------- + * Board boot configuration + */ + +#define CONFIG_EXTRA_ENV_SETTINGS "\0" + +#define CONFIG_USE_BOOTCOMMAND +#define CONFIG_BOOTCOMMAND \ + "fdt addr ${fdtcontroladdr}; " \ + "fdt move ${fdtcontroladdr} 0x86000000; " \ + "ext4load mmc 0:1 0x80200000 boot/Image; " \ + "booti 0x80200000 - 0x86000000; " + +#define CONFIG_TIMESTAMP /* Print image info with timestamp */ + +#endif/* __CONFIG_H */
Hi Pantelis, Rick,
Sorry I didn't cc you before. I was wondering if you could take a look at this patch. Your comments would be most welcome. Thanks for your time!
Best regards, Tianrui
- bool "Support RISC-V cores on OpenPiton SoC"
endchoice
targets += $(dtb-y)
+/dts-v1/;
- #address-cells = <2>;
- #size-cells = <2>;
- u-boot,dm-pre-reloc;
- compatible = "openpiton,ariane";
- chosen {
- aliases {
console = &uart0;
serial0 = &uart0;
- cpus {
#size-cells = <0>;
CPU0: cpu@0 {
reg = <0>;
status = "okay";
tlb-split;
CPU1: cpu@1 {
reg = <1>;
status = "okay";
tlb-split;
- memory@80000000 {
interrupts = <1>;
compatible)
interrupts = <2>;
#size-cells = <0>;
phy0: phy@1 {
reg = <1>;
status = "okay";
clint@fff1020000 {
riscv,ndev = <2>;
+config SYS_BOARD
- default "riscv"
+config SYS_VENDOR
- default "openpiton"
+config SYS_CPU
- default "generic"
- default "openpiton-riscv"
- default 0x81000000 if SPL
- default 0x80000000 if !RISCV_SMODE
- default 0x81000000 if RISCV_SMODE
- def_bool y
- select ARCH_EARLY_INIT_R
- select SUPPORT_SPL
- imply CPU_RISCV
- imply RISCV_TIMER if (RISCV_SMODE || SPL_RISCV_SMODE)
- imply SIFIVE_CLINT if (RISCV_MMODE || SPL_RISCV_MMODE)
- imply CMD_CPU
- imply SPL_CPU_SUPPORT
- imply SPL_OPENSBI
- imply SPL_LOAD_FIT
- imply SPL_SMP
- imply SPL_MMC
- imply SMP
- imply SPL_RISCV_MMODE
- Copyright (c) 2019 SiFive, Inc
- Copyright (c) 2021 Tianrui Wei
- Authors:
- Pragnesh Patel pragnesh.patel@sifive.com
- Tianrui Wei tianrui-wei@outlook.com
- u8 i;
- u32 boot_devices[] = {
- BOOT_DEVICE_MMC1,
- for (i = 0; i < ARRAY_SIZE(boot_devices); i++)
- spl_boot_list[i] = boot_devices[i];
+} +#endif
- /* boot using first FIT config */
+} +#endif
+config MMC_PITON
- bool "MMC support for OpenPiton SoC"
- default y
- help
- This driver enables mmc controller support in uboot port for OpenPiton
- (C) Copyright 2009 SAMSUNG Electronics
- Minkyu Kang mk7.kang@samsung.com
- Jaehoon Chung jh80.chung@samsung.com
- Portions Copyright 2011-2019 NVIDIA Corporation
- Portions Copyright 2021 Tianrui Wei
- struct mmc_config cfg;
- struct mmc mmc;
- uint64_t piton_mmc_base_addr; /* peripheral id */
- // check first if this is a pure command
- if (data == NULL) {
- // byte count counts all the bytes required for this command
- uint64_t byte_cnt = data->blocks * data->blocksize;
- // get which block in mmc card to start from
- uint64_t start_block = cmd->cmdarg;
- // buff points to the address we store the data stored at mmc card
- unsigned *buff = (unsigned int *) data->dest;
- struct piton_mmc_priv *priv = dev_get_priv(dev);
- // start address denotes the absolute address where the transmission start
- uint64_t start_addr = priv->piton_mmc_base_addr + (start_block);
- /* if data is not empty*/
- if (data) {
- /* if there is a read */
- if (data->flags & MMC_DATA_READ) {
buff++;
- } else {
return -ENODEV;
- struct piton_mmc_plat *plat = dev_get_platdata(dev);
- struct mmc_config *cfg;
- struct mmc *mmc;
- priv->piton_mmc_base_addr = dev_read_addr(dev);
- cfg = &plat->cfg;
- cfg->name = "PITON MMC";
- cfg->host_caps = MMC_MODE_8BIT;
- cfg->f_max = 100000;
- cfg->f_min = 400000;
- cfg->voltages = MMC_VDD_21_22;
- mmc = &plat->mmc;
- mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
- mmc->capacity_user = 0x100000000ULL;
- mmc->capacity_user *= mmc->read_bl_len;
- mmc->capacity_boot = 0;
- mmc->capacity_rpmb = 0;
- for (int i = 0; i < 4; i++)
- mmc->capacity_gp[i] = 0;
- mmc->capacity = 0x800000000ULL;
- mmc->has_init = 1;
- /* fill in device description */
- struct blk_desc *bdesc;
- bdesc = mmc_get_blk_desc(mmc);
- bdesc->lun = 0;
- bdesc->hwpart = 0;
- bdesc->type = 0;
- bdesc->blksz = mmc->read_bl_len;
- bdesc->log2blksz = LOG2(bdesc->blksz);
- bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len);
- currently, this is ignored. we only use fixed speed
- always return 1, which means present
- return 1;
- // send a command to mmc device
- .send_cmd = piton_mmc_send_cmd,
- // set iospeed
- .set_ios = piton_mmc_set_ios,
- // detect if card is present
- .get_cd = piton_mmc_getcd,
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct mmc_config *cfg = &plat->cfg;
- cfg->name = dev->name;
- upriv->mmc = &plat->mmc;
- upriv->mmc->has_init = 1;
- upriv->mmc->capacity = 0x2000000000ULL;
- upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
- return piton_mmc_init(dev);
- cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT;
- cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34;
- cfg->f_min = 1000000;
- cfg->f_max = 52000000;
- cfg->b_max = U32_MAX;
- return mmc_bind(dev, &plat->mmc, cfg);
- {.compatible = "openpiton,piton-mmc"}, {}};
- .name = "piton_mmc",
- .id = UCLASS_MMC,
- .of_match = piton_mmc_ids,
- .ofdata_to_platdata = piton_mmc_ofdata_to_platdata,
- .bind = piton_mmc_bind,
- .probe = piton_mmc_probe,
- .ops = &piton_mmc_ops,
- .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat),
- .priv_auto_alloc_size = sizeof(struct piton_mmc_priv),
- Copyright (c) 2019 Western Digital Corporation or its affiliates.
- Authors:
- Anup Patel anup.patel@wdc.com
- Environment
- Board boot configuration
- "fdt addr ${fdtcontroladdr}; " \
- "fdt move ${fdtcontroladdr} 0x86000000; " \
- "ext4load mmc 0:1 0x80200000 boot/Image; " \
- "booti 0x80200000 - 0x86000000; "
Tianrui Wei
