[U-Boot] [PATCH] sunxi: imply CONFIG_OF_LIBFDT_OVERLAY
fdt overlay support is useful for all sunxi boards, enable per default and remove it from sunxi defconfigs.
Signed-off-by: Andre Heider a.heider@gmail.com ---
there're way too many sunxi boards so I'm not 100% sure this is the best approach...
Are there boards where enabling this is definitely not desired?
Thanks, Andre
arch/arm/Kconfig | 1 + configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - 3 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 73909952d0..25847b3aa1 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -715,6 +715,7 @@ config ARCH_SUNXI select USE_TINY_PRINTF imply CMD_GPT imply FAT_WRITE + imply OF_LIBFDT_OVERLAY imply PRE_CONSOLE_BUFFER imply SPL_GPIO_SUPPORT imply SPL_LIBCOMMON_SUPPORT diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index d057bee172..8b38ba450e 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -21,4 +21,3 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index fa572eac57..089152e9ff 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -26,4 +26,3 @@ CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y -CONFIG_OF_LIBFDT_OVERLAY=y
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks! Maxime
Thanks, Andre
It's increasing u-boot.itb size to 512KB (which is 508K earlier) and in either case the size moves on env side where env start 0x88000 (504KB)
Thanks, Andre
Right, so maybe we can make that conditional to ARM?
Maxime
Thanks, Andre
Maxime
From the 'we're out of space' thread: ...
So, with FIT_ENABLE_SHA256_SUPPORT, LZMADEC, ISO_PARTITION and the overlay support, we're at 500kB.
Again, tight, but under the limit.
If I understood correctly the issue will be solved without any requiring changes to this patch. Let me know if that is not the case.
Thanks, Andre
Andre Heider
Jagan Teki
Maxime Ripard
