[U-Boot] [PATCH v2 4/7] da850evm: setup NAND support under CONFIG_USE_NAND
The current da850evm config is missing the pieces for NAND support that can be found in Sandeep's u-boot-davinci tree [1].
This patch adds NAND support in the spirit of the support in the u-boot-davinci tree where NAND support for the da850evm can be enabled by putting a single '#define CONFIG_USE_NAND' at the top of the include/configs/da850evm.h file.
[1] http://arago-project.org/git/people/?p=sandeep/u-boot-davinci.git;a=tree
Signed-off-by: Ben Gardiner bengardiner@nanometrics.ca CC: Sandeep Paulraj s-paulraj@ti.com To: Sudhakar Rajashekhara sudhakar.raj@ti.com
V2: * Rebased to b69b02b92f59330be9d662110e202cfd3503eafa of u-boot-ti/master
--- include/configs/da850evm.h | 29 +++++++++++++++++++++++++++++ 1 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index e0a3bae..0320917 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -79,6 +79,29 @@ #define CONFIG_SYS_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */
/* + * Flash & Environment + */ +#ifdef CONFIG_USE_NAND +#undef CONFIG_ENV_IS_IN_FLASH +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ +#define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_SYS_CLE_MASK 0x10 +#define CONFIG_SYS_ALE_MASK 0x8 +#undef CONFIG_SYS_NAND_HW_ECC +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define NAND_MAX_CHIPS 1 +#define DEF_BOOTM "" +#endif + +/* * U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ @@ -127,6 +150,12 @@ #undef CONFIG_CMD_PING #endif
+#ifdef CONFIG_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#endif + #if !defined(CONFIG_USE_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH)
Ben Gardiner
