[PATCH v3] dt-bindings: riscv: deprecate riscv,isa
intro =====
When the RISC-V dt-bindings were accepted upstream in Linux, the base ISA etc had yet to be ratified. By the ratification of the base ISA, incompatible changes had snuck into the specifications - for example the Zicsr and Zifencei extensions were spun out of the base ISA.
Fast forward to today, and the reason for this patch. Currently the riscv,isa dt property permits only a specific subset of the ISA string - in particular it excludes version numbering. With the current constraints, it is not possible to discern whether "rv64i" means that the hart supports the fence.i instruction, for example. Future systems may choose to implement their own instruction fencing, perhaps using a vendor extension, or they may not implement the optional counter extensions. Software needs a way to determine this.
versioning schemes ==================
"Use the extension versions that are described in the ISA manual" you may say, and it's not like this has not been considered. Firstly, software that parses the riscv,isa property at runtime will need to contain a lookup table of some sort that maps arbitrary versions to versions it understands. There is not a consistent application of version number applied to extensions, with a higgledy-piggledy collection of tags, "bare" and versioned documents awaiting the reader on the "recently ratified extensions" page: https://wiki.riscv.org/display/HOME/Recently+Ratified+Extensions
As an aside, and this is reflected in the patch too, since many extensions have yet to appear in a release of the ISA specs, they are defined by commits in their respective "working draft" repositories.
Secondly, there is an issue of backwards compatibility, whereby allowing numbers in the ISA string, some parsers may be broken. This would require an additional property to be created to even use the versions in this manner.
~boolean properties~ string array property ==========================================
If a new property is needed, the whole approach may as well be looked at from the bottom up. A string with limited character choices etc is hardly the best approach for communicating extension information to software.
Switching to using properties that are defined on a per extension basis, allows us to define explicit meanings for the DT representation of each extension - rather than the current situation where different operating systems or other bits of software may impart different meanings to characters in the string. Clearly the best source of meanings is the specifications themselves, this just provides us the ability to choose at what point in time the meaning is set. If an extension changes incompatibility in the future, a new property will be required.
Off-list, some of the RVI folks have committed to shoring up the wording in either the ISA specifications, the riscv-isa-manual or so that in the future, modifications to and additions or removals of features will require a new extension. Codifying that assertion somewhere would make it quite unlikely that compatibility would be broken, but we have the tools required to deal with it, if & when it crops up. It is in our collective interest, as consumers of extension meanings, to define a scheme that enforces compatibility.
The use of individual properties, rather than elements in a single string, will also permit validation that the properties have a meaning, as well as potentially reject mutually exclusive combinations, or enforce dependencies between extensions. That would not have be possible with the current dt-schema infrastructure for arbitrary strings, as we would need to add a riscv,isa parser to dt-validate! That's not implemented in this patch, but rather left as future work (for the brave, or the foolish).
acpi ====
The current ACPI ECR is based on having a single ISA string unfortunately, but ideally ACPI will move to another method, perhaps GUIDs, that give explicit meaning to extensions.
parser simplicity =================
Many systems that parse DT at runtime already implement an function that can check for the presence of a string in an array of string, as it is similar to the process for parsing a list of compatible strings, so a bunch of new, custom, DT parsing should not be needed. Getting rid of "riscv,isa" parsing would be a nice simplification, but unfortunately for backwards compatibility with old dtbs, existing parsers may not be removable - which may greatly simplify dt parsing code. In Linux, for example, checking for whether a hart supports an extension becomes as simple as: of_property_match_string(node, "riscv,isa-extensions", "zicbom")
vendor extensions =================
Compared to riscv,isa, this proposed scheme promotes vendor extensions, oft touted as the strength of RISC-V, to first-class citizens. At present, extensions are defined as meaning what the RISC-V ISA specifications say they do. There is no realistic way of using that interface to provide cross-platform definitions for what vendor extensions mean. Vendor extensions may also have even less consistency than RVI do in terms of versioning, or no care about backwards compatibility. The new property allows us to assign explicit meanings on a per vendor extension basis, backed up by a description of their meanings.
fin ===
Create a new file to store the extension meanings and a new riscv,isa-base property to replace the aspect of riscv,isa that is not represented by the new property - the base ISA implemented by a hart.
As a starting point, add properties for extensions currently used in Linux.
Finally, mark riscv,isa as deprecated, as removing support for it in existing programs would be an ABI break.
CC: Palmer Dabbelt palmer@dabbelt.com CC: Paul Walmsley paul.walmsley@sifive.com CC: Rob Herring robh+dt@kernel.org CC: Krzysztof Kozlowski krzysztof.kozlowski+dt@linaro.org CC: Alistair Francis alistair.francis@wdc.com CC: Andrew Jones ajones@ventanamicro.com CC: Anup Patel apatel@ventanamicro.com CC: Atish Patra atishp@atishpatra.org CC: Jessica Clarke jrtc27@jrtc27.com CC: Rick Chen rick@andestech.com CC: Leo ycliang@andestech.com CC: Oleksii oleksii.kurochko@gmail.com CC: linux-riscv@lists.infradead.org CC: qemu-riscv@nongnu.org CC: u-boot@lists.denx.de CC: devicetree@vger.kernel.org CC: linux-kernel@vger.kernel.org Reviewed-by: Palmer Dabbelt palmer@rivosinc.com Acked-by: Palmer Dabbelt palmer@rivosinc.com Signed-off-by: Conor Dooley conor.dooley@microchip.com --- Changes in v3: - Per Rob's suggestion, switch to an array of strings. Cuts down on the size, compared to booleans. It has a standard mechanism for parsing (you need to parse arrays of strings for compatibles). It still allows for having a limited set of explicitly defined properties - so the advantages over a free-form string still apply. - Pick up Palmer's Ack and Review (although I expect that he will be the one to apply this). --- .../devicetree/bindings/riscv/cpus.yaml | 43 ++- .../devicetree/bindings/riscv/extensions.yaml | 245 ++++++++++++++++++ 2 files changed, 265 insertions(+), 23 deletions(-) create mode 100644 Documentation/devicetree/bindings/riscv/extensions.yaml
diff --git a/Documentation/devicetree/bindings/riscv/cpus.yaml b/Documentation/devicetree/bindings/riscv/cpus.yaml index 67bd239ead0b..74bc92591086 100644 --- a/Documentation/devicetree/bindings/riscv/cpus.yaml +++ b/Documentation/devicetree/bindings/riscv/cpus.yaml @@ -25,6 +25,7 @@ description: |
allOf: - $ref: /schemas/cpu.yaml# + - $ref: extensions.yaml
properties: compatible: @@ -82,25 +83,6 @@ properties: description: The blocksize in bytes for the Zicboz cache operations.
- riscv,isa: - description: - Identifies the specific RISC-V instruction set architecture - supported by the hart. These are documented in the RISC-V - User-Level ISA document, available from - https://riscv.org/specifications/ - - Due to revisions of the ISA specification, some deviations - have arisen over time. - Notably, riscv,isa was defined prior to the creation of the - Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" - implies "zicntr_zicsr_zifencei_zihpm". - - While the isa strings in ISA specification are case - insensitive, letters in the riscv,isa string must be all - lowercase. - $ref: /schemas/types.yaml#/definitions/string - pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ - # RISC-V has multiple properties for cache op block sizes as the sizes # differ between individual CBO extensions cache-op-block-size: false @@ -139,8 +121,17 @@ properties: DMIPS/MHz, relative to highest capacity-dmips-mhz in the system.
+oneOf: + - required: + - riscv,isa + - required: + - riscv,isa-base + +dependencies: + riscv,isa-base: [ "riscv,isa-extensions" ] + riscv,isa-extensions: [ "riscv,isa-base" ] + required: - - riscv,isa - interrupt-controller
unevaluatedProperties: false @@ -160,7 +151,9 @@ examples: i-cache-sets = <128>; i-cache-size = <16384>; reg = <0>; - riscv,isa = "rv64imac"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "c"; + cpu_intc0: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -183,8 +176,10 @@ examples: i-tlb-size = <32>; mmu-type = "riscv,sv39"; reg = <1>; - riscv,isa = "rv64imafdc"; tlb-split; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; + cpu_intc1: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc"; @@ -202,8 +197,10 @@ examples: device_type = "cpu"; reg = <0>; compatible = "riscv"; - riscv,isa = "rv64imafdc"; mmu-type = "riscv,sv48"; + riscv,isa-base = "rv64i"; + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; + interrupt-controller { #interrupt-cells = <1>; interrupt-controller; diff --git a/Documentation/devicetree/bindings/riscv/extensions.yaml b/Documentation/devicetree/bindings/riscv/extensions.yaml new file mode 100644 index 000000000000..af98307f2c2c --- /dev/null +++ b/Documentation/devicetree/bindings/riscv/extensions.yaml @@ -0,0 +1,245 @@ +# SPDX-License-Identifier: (GPL-2.0 OR MIT) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/riscv/extensions.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: RISC-V ISA extensions + +maintainers: + - Paul Walmsley paul.walmsley@sifive.com + - Palmer Dabbelt palmer@sifive.com + - Conor Dooley conor@kernel.org + +description: | + RISC-V has a large number of extensions, some of which are "standard" + extensions, meaning they are ratified by RISC-V International, and others + are "vendor" extensions. + This document defines properties that indicate whether a hart supports a + given extension. + + Once a standard extension has been ratified, no changes in behaviour can be + made without the creation of a new extension. + The properties for standard extensions therefore map to their originally + ratified states, with the exception of the I, Zicntr & Zihpm extensions. + See the "i" property for more information. + +select: + properties: + compatible: + contains: + const: riscv + +properties: + riscv,isa: + description: + Identifies the specific RISC-V instruction set architecture + supported by the hart. These are documented in the RISC-V + User-Level ISA document, available from + https://riscv.org/specifications/ + + Due to revisions of the ISA specification, some deviations + have arisen over time. + Notably, riscv,isa was defined prior to the creation of the + Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" + implies "zicntr_zicsr_zifencei_zihpm". + + While the isa strings in ISA specification are case + insensitive, letters in the riscv,isa string must be all + lowercase. + $ref: /schemas/types.yaml#/definitions/string + pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ + deprecated: true + + riscv,isa-base: + description: + The base ISA implemented by this hart, as described by the 20191213 + version of the unprivileged ISA specification. + enum: + - rv32i + - rv64i + + riscv,isa-extensions: + $ref: /schemas/types.yaml#/definitions/string-array + minItems: 1 + description: Extensions supported by the hart. + items: + anyOf: + # single letter extensions, in canonical order + - const: i + description: | + The base integer instruction set, as ratified in the 20191213 + version of the unprivileged ISA specification, with the exception of + counter access. + Counter access was removed after the ratification of the 20191213 + version of the unprivileged specification and shunted into the + Zicntr and Zihpm extensions. + + - const: m + description: + The standard M extension for integer multiplication and division, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: a + description: + The standard A extension for atomic instructions, as ratified in the + 20191213 version of the unprivileged ISA specification. + + - const: f + description: + The standard F extension for single-precision floating point, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: d + description: + The standard D extension for double-precision floating-point, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: q + description: + The standard Q extension for quad-precision floating-point, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: c + description: + The standard C extension for compressed instructions, as ratified in + the 20191213 version of the unprivileged ISA specification. + + - const: v + description: + The standard V extension for vector operations, as ratified + in-and-around commit 7a6c8ae ("Fix text that describes vfmv.v.f + encoding") of the riscv-v-spec. + + - const: h + description: + The standard H extension for hypervisors as ratified in the 20191213 + version of the privileged ISA specification. + + # multi-letter extensions, sorted alphanumerically + - const: smaia + description: | + The standard Smaia supervisor-level extension for the advanced + interrupt architecture for machine-mode-visible csr and behavioural + changes to interrupts as frozen at commit ccbddab ("Merge pull + request #42 from riscv/jhauser-2023-RC4") of riscv-aia. + + - const: ssaia + description: | + The standard Ssaia supervisor-level extension for the advanced + interrupt architecture for supervisor-mode-visible csr and + behavioural changes to interrupts as frozen at commit ccbddab + ("Merge pull request #42 from riscv/jhauser-2023-RC4") of riscv-aia. + + - const: sscofpmf + description: | + The standard Sscofpmf supervisor-level extension for count overflow + and mode-based filtering as ratified at commit 01d1df0 ("Add ability + to manually trigger workflow. (#2)") of riscv-count-overflow. + + - const: sstc + description: | + The standard Sstc supervisor-level extension for time compare as + ratified at commit 3f9ed34 ("Add ability to manually trigger + workflow. (#2)") of riscv-time-compare. + + - const: svinval + description: + The standard Svinval supervisor-level extension for fine-grained + address-translation cache invalidation as ratified in the 20191213 + version of the privileged ISA specification. + + - const: svnapot + description: + The standard Svnapot supervisor-level extensions for napot + translation contiguity as ratified in the 20191213 version of the + privileged ISA specification. + + - const: svpbmt + description: + The standard Svpbmt supervisor-level extensions for page-based + memory types as ratified in the 20191213 version of the privileged + ISA specification. + + - const: zba + description: | + The standard Zba bit-manipulation extension for address generation + acceleration instructions as ratified at commit 6d33919 ("Merge pull + request #158 from hirooih/clmul-fix-loop-end-condition") of + riscv-bitmanip. + + - const: zbb + description: | + The standard Zbb bit-manipulation extension for basic bit-manipulation + as ratified at commit 6d33919 ("Merge pull request #158 from + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + - const: zbc + description: | + The standard Zbc bit-manipulation extension for carry-less + multiplication as ratified at commit 6d33919 ("Merge pull request + #158 from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + - const: zbs + description: | + The standard Zbs bit-manipulation extension for single-bit + instructions as ratified at commit 6d33919 ("Merge pull request #158 + from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. + + - const: zicbom + description: + The standard Zicbom extension for base cache management operations as + ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. + + - const: zicbop + description: + The standard Zicbop extension for cache-block prefetch instructions + as ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of + riscv-CMOs. + + - const: zicboz + description: + The standard Zicboz extension for cache-block zeroing as ratified + in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. + + - const: zicntr + description: + The standard Zicntr extension for base counters and timers, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: zicsr + description: + The standard Zicsr extension for control and status register + instructions, as ratified in the 20191213 version of the + unprivileged ISA specification. + + - const: zifencei + description: + The standard Zifencei extension for instruction-fetch fence, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: zihintpause + description: + The standard Zihintpause extension for pause hints, as ratified in + commit d8ab5c7 ("Zihintpause is ratified") of the riscv-isa-manual. + + - const: zihpm + description: + The standard Zihpm extension for hardware performance counters, as + ratified in the 20191213 version of the unprivileged ISA + specification. + + - const: ztso + description: + The standard Ztso extension for total store ordering, as ratified + in commit 2e5236 ("Ztso is now ratified.") of the + riscv-isa-manual. + +additionalProperties: true +...
On Mon, 26 Jun 2023 11:10:46 +0100, Conor Dooley wrote:
intro
versioning schemes
acpi
parser simplicity
vendor extensions
fin
Changes in v3:
Reviewed-by: Rob Herring robh@kernel.org
On 26 Jun 2023, at 11:10, Conor Dooley conor.dooley@microchip.com wrote:
intro
versioning schemes
acpi
Who’s assigning GUIDs to extensions in that world? And I really don’t want to see DT and ACPI diverge in basics like _describing what ISA your processor has_.
As a non-Linux OS developer I am unhappy with this churn.
Jess
parser simplicity
vendor extensions
fin
Changes in v3:
one to apply this).
allOf:
- riscv,isa:
- description:
lowercase.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
- riscv,isa-base: [ "riscv,isa-extensions" ]
- riscv,isa-extensions: [ "riscv,isa-base" ]
required:
- riscv,isa
+maintainers:
+description: |
- RISC-V has a large number of extensions, some of which are "standard"
- extensions, meaning they are ratified by RISC-V International, and others
- are "vendor" extensions.
- This document defines properties that indicate whether a hart supports a
- given extension.
- Once a standard extension has been ratified, no changes in behaviour can be
- made without the creation of a new extension.
- The properties for standard extensions therefore map to their originally
- ratified states, with the exception of the I, Zicntr & Zihpm extensions.
- See the "i" property for more information.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- $ref: /schemas/types.yaml#/definitions/string-array
- minItems: 1
- description: Extensions supported by the hart.
- items:
anyOf:
- const: i
description: |
counter access.
- const: m
description:
specification.
- const: a
description:
- const: f
description:
specification.
- const: d
description:
specification.
- const: q
description:
specification.
- const: c
description:
- const: v
description:
- const: h
description:
- const: smaia
description: |
- const: ssaia
description: |
- const: sscofpmf
description: |
- const: sstc
description: |
- const: svinval
description:
- const: svnapot
description:
- const: svpbmt
description:
ISA specification.
- const: zba
description: |
riscv-bitmanip.
- const: zbb
description: |
- const: zbc
description: |
- const: zbs
description: |
- const: zicbom
description:
- const: zicbop
description:
riscv-CMOs.
- const: zicboz
description:
- const: zicntr
description:
specification.
- const: zicsr
description:
- const: zifencei
description:
specification.
description:
- const: zihpm
description:
specification.
- const: ztso
description:
riscv-isa-manual.
2.40.1
On Mon, Jun 26, 2023 at 3:42 PM Conor Dooley conor.dooley@microchip.com wrote:
intro
versioning schemes
acpi
Drop this paragraph on ACPI.
We clearly mentioned previously that ACPI will follow specs defined by RVI. There are scalability issues in using GUIDs for each ISA extension.
Regards, Anup
parser simplicity
vendor extensions
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
- given extension.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
counter access.
- const: m
description:
specification.
- const: a
description:
- const: f
description:
specification.
- const: d
description:
specification.
- const: q
description:
specification.
- const: c
description:
- const: v
description:
- const: h
description:
- const: smaia
description: |
- const: ssaia
description: |
- const: sscofpmf
description: |
- const: sstc
description: |
- const: svinval
description:
- const: svnapot
description:
- const: svpbmt
description:
ISA specification.
- const: zba
description: |
riscv-bitmanip.
- const: zbb
description: |
- const: zbc
description: |
- const: zbs
description: |
- const: zicbom
description:
- const: zicbop
description:
riscv-CMOs.
- const: zicboz
description:
- const: zicntr
description:
specification.
- const: zicsr
description:
- const: zifencei
description:
specification.
description:
- const: zihpm
description:
specification.
- const: ztso
description:
riscv-isa-manual.
2.40.1
acpi
Sure.
intro
versioning schemes
acpi
Which spec are we following for the ACPI ISA string?
Regards, Anup
parser simplicity
vendor extensions
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
- given extension.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
counter access.
- const: m
description:
specification.
- const: a
description:
- const: f
description:
specification.
- const: d
description:
specification.
- const: q
description:
specification.
- const: c
description:
- const: v
description:
- const: h
description:
- const: smaia
description: |
- const: ssaia
description: |
- const: sscofpmf
description: |
- const: sstc
description: |
- const: svinval
description:
- const: svnapot
description:
- const: svpbmt
description:
ISA specification.
- const: zba
description: |
riscv-bitmanip.
- const: zbb
description: |
- const: zbc
description: |
- const: zbs
description: |
- const: zicbom
description:
- const: zicbop
description:
riscv-CMOs.
- const: zicboz
description:
- const: zicntr
description:
specification.
- const: zicsr
description:
- const: zifencei
description:
specification.
description:
- const: zihpm
description:
specification.
- const: ztso
description:
riscv-isa-manual.
2.40.1
intro
versioning schemes
acpi
ACPI RHCT follows the "ISA Extension Naming Conventions" defined by the RISC-V unpriv spec. I understand that there are unresolved issues in the "ISA Extension Naming Conventions" which should be addressed by RVI and we should also try our best to have this fixed in the spec.
In any case, ACPI spec is owned by UEFI forum so it does not make sense to define/recommend anything for ACPI in DT bindings.
Regards, Anup
Regards, Anup
parser simplicity
vendor extensions
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
- given extension.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
counter access.
- const: m
description:
specification.
- const: a
description:
- const: f
description:
specification.
- const: d
description:
specification.
- const: q
description:
specification.
- const: c
description:
- const: v
description:
- const: h
description:
- const: smaia
description: |
- const: ssaia
description: |
- const: sscofpmf
description: |
- const: sstc
description: |
- const: svinval
description:
- const: svnapot
description:
- const: svpbmt
description:
ISA specification.
- const: zba
description: |
riscv-bitmanip.
- const: zbb
description: |
- const: zbc
description: |
- const: zbs
description: |
- const: zicbom
description:
- const: zicbop
description:
riscv-CMOs.
- const: zicboz
description:
- const: zicntr
description:
specification.
- const: zicsr
description:
- const: zifencei
description:
specification.
description:
- const: zihpm
description:
specification.
- const: ztso
description:
riscv-isa-manual.
2.40.1
On Mon, Jun 26, 2023, at 6:10 AM, Conor Dooley wrote:
intro
versioning schemes
no longer individual properties
Under what circumstances is a device tree which declares support for a superset extension (e.g. m) required to also declare support for its subsets (e.g. zmmul)? There are compatibility issues in both directions.
Proposal: If an extension X is a superset of an extension Y and X is present in riscv,isa-extensions, Y must also be present if Y was ratified or added to the schema before X, but need not also be present if Y was ratified after or at the same time as X. If X "depends on" Y, then Y must be present in riscv,isa-extensions even if X and Y were ratified at the same time.
acpi
parser simplicity
vendor extensions
How are vendor extension names allocated? Will any proposed name for a vendor extension pass through linux-riscv@ before it shows up in the wild, or are vendors expected to allocate extension names unilaterally? Is it worth creating an experimental-* namespace for prototype implementations of unreleased extensions?
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
- pattern:
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
others
supports a
- given extension.
can be
originally
extensions.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- pattern:
- deprecated: true
- riscv,isa-base:
- description:
20191213
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
20191213
exception of
counter access.
20191213
the
I think this may belong in the description of zicsr? rdcycle in 20191213 is a special case of csrrs, which is in zicsr not the base.
- const: m
description:
division, as
specification.
- const: a
description:
ratified in the
- const: f
description:
point, as
specification.
Do we want to be able to describe the K210 in the new schema? I believe that it implements the 2.0 F and D extensions, which are neither forward nor backward compatible with the ratified ones.
#include <stdio.h> int main() { long a,b; asm("fsub.s fa0,fa0,fa0\n" "fdiv.s fa0,fa0,fa0\n" "fmv.x.d %0,fa0\n" "fcvt.s.w fa1,x0\n" "fmax.s fa1,fa1,fa0\n" "fmv.x.d %1,fa1\n" : "=r" (a), "=r" (b)); printf("box(nan) = %lx\nmax(0,nan) = %lx\n", a, b); return 0; }
- const: d
description:
floating-point, as
specification.
- const: q
description:
floating-point, as
specification.
- const: c
description:
ratified in
- const: v
description:
vfmv.v.f
- const: h
description:
the 20191213
- const: smaia
description: |
advanced
behavioural
pull
- const: ssaia
description: |
advanced
ccbddab
riscv-aia.
- const: sscofpmf
description: |
overflow
("Add ability
- const: sstc
description: |
compare as
trigger
- const: svinval
description:
fine-grained
20191213
- const: svnapot
description:
of the
- const: svpbmt
description:
page-based
privileged
ISA specification.
- const: zba
description: |
generation
("Merge pull
riscv-bitmanip.
- const: zbb
description: |
bit-manipulation
from
- const: zbc
description: |
request
riscv-bitmanip.
- const: zbs
description: |
request #158
riscv-bitmanip.
- const: zicbom
description:
operations as
riscv-CMOs.
- const: zicbop
description:
instructions
of
riscv-CMOs.
- const: zicboz
description:
ratified
riscv-CMOs.
- const: zicntr
description:
timers, as
specification.
- const: zicsr
description:
register
- const: zifencei
description:
fence, as
specification.
description:
ratified in
riscv-isa-manual.
- const: zihpm
description:
counters, as
specification.
- const: ztso
description:
ratified
riscv-isa-manual.
There are quite a few extension names defined in ratified specifications that aren't in that list yet. Would there be interest in adding them or are we waiting for specific conditions to be met?
In particular several subsystems depend on "ziccif" from the profiles spec but we haven't previously had a way to check or document that dependency.
2.40.1
linux-riscv mailing list linux-riscv@lists.infradead.org http://lists.infradead.org/mailman/listinfo/linux-riscv
intro
versioning schemes
acpi
parser simplicity
vendor extensions
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
- pattern:
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
others
supports a
- given extension.
can be
originally
extensions.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- pattern:
- deprecated: true
- riscv,isa-base:
- description:
20191213
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
20191213
exception of
counter access.
20191213
the
- const: m
description:
division, as
specification.
- const: a
description:
ratified in the
- const: f
description:
point, as
specification.
- const: d
description:
floating-point, as
specification.
- const: q
description:
floating-point, as
specification.
- const: c
description:
ratified in
- const: v
description:
vfmv.v.f
- const: h
description:
the 20191213
The multi-letter extensions name should match(ignoring case) the name of the frozen/ratified or vendor specific extension name. Correct ?
- const: smaia
description: |
advanced
behavioural
pull
- const: ssaia
description: |
advanced
ccbddab
riscv-aia.
- const: sscofpmf
description: |
overflow
("Add ability
- const: sstc
description: |
compare as
trigger
- const: svinval
description:
fine-grained
20191213
- const: svnapot
description:
of the
- const: svpbmt
description:
page-based
privileged
ISA specification.
- const: zba
description: |
generation
("Merge pull
riscv-bitmanip.
- const: zbb
description: |
bit-manipulation
from
- const: zbc
description: |
request
riscv-bitmanip.
- const: zbs
description: |
request #158
riscv-bitmanip.
- const: zicbom
description:
operations as
riscv-CMOs.
- const: zicbop
description:
instructions
of
riscv-CMOs.
- const: zicboz
description:
ratified
riscv-CMOs.
- const: zicntr
description:
timers, as
specification.
- const: zicsr
description:
register
- const: zifencei
description:
fence, as
specification.
description:
ratified in
riscv-isa-manual.
- const: zihpm
description:
counters, as
specification.
- const: ztso
description:
ratified
riscv-isa-manual.
2.40.1
Hey Atish, Stefan,
Yes, I think that this all makes sense from a compatibility point of view. Splitting it up:
This makes total sense from a "being nice to" software point of view.
It may make sense to reduce this to only after, or not permit the supersets at all where they are ratified alongside their subsets. Cross that bridge when we come to it perhaps.
For Linux, this is already the case for F & D. I think that's a good policy to follow.
vendor extensions
The same way any other dt-binding works, it's no different in that respect to compatible strings.
IMO, people are free to do whatever they like in their own development trees. I don't really know why we'd introduce stuff in dt-bindings for things that are only in an experimental state.
- minItems: 1
- items:
anyOf:
- const: i
description: |
20191213
exception of
counter access.
20191213
the
Sorry, this is a bit unclear. Do you mean that the sentence you have provided here should be in the Zicsr entry?
- const: m
description:
division, as
specification.
- const: a
description:
ratified in the
- const: f
description:
point, as
specification.
If it is not compatible, then it should not claim to be :) We currently report the thing as implementing the same F extension as anything else that claims to support F, but I don't think we should be adding a new strictly defined property if it does not apply. Kinda defeats the purpose I think. I'm not sure whether it should get a new property, or continue (mis)using riscv,isa, in that case.
As an aside, if you are building software for a k210, you probably know pretty damn well what your target system is, given the constraints of the platform!
- const: h
description:
the 20191213
Iff it is the first time of appearance, yes.
I only added what was already in use, adding new stuff can be done subsequently.
Cheers, Conor.
Been implementing feedback, so going back through this
I ending up doing some proof of concept implementation of this for linux the other day, I think "at or at the same time" is the way to go. Up to me to enforce while reviewing binding patches I guess!
- const: i
description: |
20191213
exception of
counter access.
20191213
the
I went and checked this, rdcycle appears in chapter 10 "Counters", not chapter 9 "Zicsr". I'll slightly reword it & put it in both sections since the specs are (IMO) unclear in this regard.
Cheers, Conor.
participants (8)
Anup Patel
Atish Patra
Conor Dooley
Conor Dooley
Jessica Clarke
Palmer Dabbelt
Rob Herring
Stefan O'Rear
