[PATCH 00/11] Enable DM_ETH for DPAA1 PowerPC T-series boards
This patch series enables DM_ETH and DM_MDIO on the T2080RDB, T4240RDB and T1042D4RDB DPAA1 PowerPC boards. The necessary FMan v3 Ethernet and MDIO nodes are added to each platform's SoC and board device tree.
On T2080RDB, fdt fixups are performed before booting into the OS using a simplified new routine in order to avoid the legacy code path.
Camelia Groza (11): powerpc: dts: t2080: add QorIQ DPAA 1 FMan v3 nodes powerpc: dts: t2080rdb: add FMan v3 nodes board: freescale: t208xrdb: fdt fixups under DM_ETH configs: T2080RDB: enable DM_ETH powerpc: dts: t4240: add QorIQ DPAA 1 FMan v3 nodes powerpc: dts: t4240rdb: add FMan v3 nodes powerpc: dts: qoriq: update the mdio offsets under the second FMan v3 configs: T4240RDB: enable DM_ETH powerpc: dts: t1042: add QorIQ DPAA 1 FMan v3 nodes powerpc: dts: t1042d4rdb: add FMan v3 nodes configs: T1042D4RDB: enable DM_ETH
arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1.dtsi | 4 +- arch/powerpc/dts/t1042d4rdb.dts | 55 ++++++++- arch/powerpc/dts/t1042si-post.dtsi | 46 +++++++ arch/powerpc/dts/t2080rdb.dts | 69 ++++++++++- arch/powerpc/dts/t2080si-post.dtsi | 51 ++++++++ arch/powerpc/dts/t4240rdb.dts | 142 +++++++++++++++++++++- arch/powerpc/dts/t4240si-post.dtsi | 101 +++++++++++++++ board/freescale/t208xrdb/eth_t208xrdb.c | 35 ++++++ board/freescale/t208xrdb/t208xrdb.c | 3 + board/freescale/t208xrdb/t208xrdb.h | 2 + configs/T1042D4RDB_NAND_defconfig | 3 + configs/T1042D4RDB_SDCARD_defconfig | 3 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 4 +- configs/T1042D4RDB_SPIFLASH_defconfig | 3 + configs/T1042D4RDB_defconfig | 3 + configs/T2080RDB_NAND_defconfig | 3 + configs/T2080RDB_SDCARD_defconfig | 3 + configs/T2080RDB_SPIFLASH_defconfig | 3 + configs/T2080RDB_defconfig | 3 + configs/T4240RDB_SDCARD_defconfig | 3 + configs/T4240RDB_defconfig | 3 + 29 files changed, 544 insertions(+), 14 deletions(-) create mode 100644 arch/powerpc/dts/t1042si-post.dtsi create mode 100644 arch/powerpc/dts/t2080si-post.dtsi create mode 100644 arch/powerpc/dts/t4240si-post.dtsi
-- 2.17.1
Add the QorIQ DPAA 1 FMan v3 device tree nodes for the T2080 SoC. The device tree nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t2080si-post.dtsi | 51 ++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+) create mode 100644 arch/powerpc/dts/t2080si-post.dtsi
diff --git a/arch/powerpc/dts/t2080si-post.dtsi b/arch/powerpc/dts/t2080si-post.dtsi new file mode 100644 index 000000000000..d8ef579cb7c0 --- /dev/null +++ b/arch/powerpc/dts/t2080si-post.dtsi @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * T2080 Silicon/SoC Device Tree Source (post include) + * + * Copyright 2013 Freescale Semiconductor Inc. + * Copyright 2021 NXP + * + */ +&soc { + +/include/ "qoriq-clockgen2.dtsi" +/include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-gpio-1.dtsi" +/include/ "qoriq-gpio-2.dtsi" +/include/ "qoriq-gpio-3.dtsi" + +/include/ "qoriq-fman3-0.dtsi" +/include/ "qoriq-fman3-0-10g-0-best-effort.dtsi" +/include/ "qoriq-fman3-0-10g-1-best-effort.dtsi" +/include/ "qoriq-fman3-0-1g-2.dtsi" +/include/ "qoriq-fman3-0-1g-3.dtsi" +/include/ "qoriq-fman3-0-10g-0.dtsi" +/include/ "qoriq-fman3-0-10g-1.dtsi" + fman@400000 { + enet0: ethernet@e0000 { + }; + + enet1: ethernet@e2000 { + }; + + enet2: ethernet@e4000 { + }; + + enet3: ethernet@e6000 { + }; + + enet6: ethernet@f0000 { + }; + + enet7: ethernet@f2000 { + }; + + mdio@fc000 { + interrupts = <100 1 0 0>; + }; + + mdio@fd000 { + interrupts = <101 1 0 0>; + }; + }; +};
Add the FMan v3 nodes for the T2080RDB. The nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t2080rdb.dts | 69 ++++++++++++++++++++++++++++++++++- 1 file changed, 68 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/dts/t2080rdb.dts b/arch/powerpc/dts/t2080rdb.dts index 74bbb20e2a1e..25f8c978c6d1 100644 --- a/arch/powerpc/dts/t2080rdb.dts +++ b/arch/powerpc/dts/t2080rdb.dts @@ -3,7 +3,7 @@ * T2080RDB Device Tree Source * * Copyright 2013 - 2015 Freescale Semiconductor Inc. - * Copyright 2019 NXP + * Copyright 2019-2021 NXP */
/include/ "t2080.dtsi" @@ -20,6 +20,71 @@ }; };
+&soc { + fman@400000 { + ethernet@e0000 { + phy-handle = <&xg_aq1202_phy3>; + phy-connection-type = "xgmii"; + }; + + ethernet@e2000 { + phy-handle = <&xg_aq1202_phy4>; + phy-connection-type = "xgmii"; + }; + + ethernet@e4000 { + phy-handle = <&rgmii_phy1>; + phy-connection-type = "rgmii"; + }; + + ethernet@e6000 { + phy-handle = <&rgmii_phy2>; + phy-connection-type = "rgmii"; + }; + + ethernet@f0000 { + phy-handle = <&xg_cs4315_phy2>; + phy-connection-type = "xgmii"; + }; + + ethernet@f2000 { + phy-handle = <&xg_cs4315_phy1>; + phy-connection-type = "xgmii"; + }; + + mdio@fc000 { + rgmii_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + rgmii_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + }; + + mdio@fd000 { + xg_cs4315_phy1: ethernet-phy@c { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0xc>; + }; + + xg_cs4315_phy2: ethernet-phy@d { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0xd>; + }; + + xg_aq1202_phy3: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x0>; + }; + + xg_aq1202_phy4: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c45"; + reg = <0x1>; + }; + }; + }; +}; + &espi0 { status = "okay"; flash@0 { @@ -38,3 +103,5 @@ reg = <0x68>; }; }; + +/include/ "t2080si-post.dtsi"
Disable the FMan mEMAC 5 and 6 nodes from the fdt since they are not available under the supported RCW. Also disable the associated "fsl,dpa-ethernet" nodes that reference them.
This is a simplified version of the fdt_fixup_fman_ethernet call for use under DM_ETH.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- board/freescale/t208xrdb/eth_t208xrdb.c | 35 +++++++++++++++++++++++++ board/freescale/t208xrdb/t208xrdb.c | 3 +++ board/freescale/t208xrdb/t208xrdb.h | 2 ++ 3 files changed, 40 insertions(+)
diff --git a/board/freescale/t208xrdb/eth_t208xrdb.c b/board/freescale/t208xrdb/eth_t208xrdb.c index e77f3f7146f7..b0ff4b1f375a 100644 --- a/board/freescale/t208xrdb/eth_t208xrdb.c +++ b/board/freescale/t208xrdb/eth_t208xrdb.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * * Shengzhou Liu Shengzhou.Liu@freescale.com */ @@ -104,6 +105,40 @@ int board_eth_init(struct bd_info *bis) return pci_eth_init(bis); }
+/* Disable the MAC5 and MAC6 "fsl,fman-memac" nodes and the two + * "fsl,dpa-ethernet" nodes that reference them. + */ +void fdt_fixup_board_fman_ethernet(void *fdt) +{ + int mac_off, eth_off, i; + char mac_path[2][42] = { + "/soc@ffe000000/fman@400000/ethernet@e8000", + "/soc@ffe000000/fman@400000/ethernet@ea000", + }; + u32 eth_ph; + + for (i = 0; i < 2; i++) { + /* Disable the MAC node */ + mac_off = fdt_path_offset(fdt, mac_path[i]); + if (mac_off < 0) + continue; + fdt_status_disabled(fdt, mac_off); + + /* Disable the fsl,dpa-ethernet node that points to the MAC. + * The fsl,fman-mac property refers to the MAC's phandle. + */ + eth_ph = fdt_get_phandle(fdt, mac_off); + if (eth_ph <= 0) + continue; + + eth_off = fdt_node_offset_by_prop_value(fdt, -1, "fsl,fman-mac", + ð_ph, + sizeof(eth_ph)); + if (eth_off >= 0) + fdt_status_disabled(fdt, eth_off); + } +} + void fdt_fixup_board_enet(void *fdt) { return; diff --git a/board/freescale/t208xrdb/t208xrdb.c b/board/freescale/t208xrdb/t208xrdb.c index a18459841c62..7ccb205c6473 100644 --- a/board/freescale/t208xrdb/t208xrdb.c +++ b/board/freescale/t208xrdb/t208xrdb.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2009-2013 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -137,6 +138,8 @@ int ft_board_setup(void *blob, struct bd_info *bd) #ifdef CONFIG_SYS_DPAA_FMAN #ifndef CONFIG_DM_ETH fdt_fixup_fman_ethernet(blob); +#else + fdt_fixup_board_fman_ethernet(blob); #endif fdt_fixup_board_enet(blob); #endif diff --git a/board/freescale/t208xrdb/t208xrdb.h b/board/freescale/t208xrdb/t208xrdb.h index 22a496fb8cf2..cd0a9f44da79 100644 --- a/board/freescale/t208xrdb/t208xrdb.h +++ b/board/freescale/t208xrdb/t208xrdb.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#ifndef __CORENET_DS_H__ @@ -8,5 +9,6 @@
void fdt_fixup_board_enet(void *blob); void pci_of_setup(void *blob, struct bd_info *bd); +void fdt_fixup_board_fman_ethernet(void *blob);
#endif
Enable DM_ETH and DM_MDIO for the T2080RDB.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- configs/T2080RDB_NAND_defconfig | 3 +++ configs/T2080RDB_SDCARD_defconfig | 3 +++ configs/T2080RDB_SPIFLASH_defconfig | 3 +++ configs/T2080RDB_defconfig | 3 +++ 4 files changed, 12 insertions(+)
diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 543d34e24988..3bb74335bb47 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -33,6 +33,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -70,6 +71,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_FW_IN_NAND=y CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index d947846e6458..bcd67a05764e 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -31,6 +31,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -67,6 +68,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_FW_IN_MMC=y CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 6f7b083bc623..198e926c32f6 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -33,6 +33,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -69,6 +70,8 @@ CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_SYS_CORTINA_FW_IN_SPIFLASH=y CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 9dd01bbe50a5..12aaccd1d509 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -18,6 +18,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -54,6 +55,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y CONFIG_PHY_CORTINA=y CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y
Add the QorIQ DPAA 1 FMan v3 device tree nodes for the T4240 SoC. The device tree nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t4240si-post.dtsi | 101 +++++++++++++++++++++++++++++ 1 file changed, 101 insertions(+) create mode 100644 arch/powerpc/dts/t4240si-post.dtsi
diff --git a/arch/powerpc/dts/t4240si-post.dtsi b/arch/powerpc/dts/t4240si-post.dtsi new file mode 100644 index 000000000000..f614d19965d3 --- /dev/null +++ b/arch/powerpc/dts/t4240si-post.dtsi @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * T4240 Silicon/SoC Device Tree Source (post include) + * + * Copyright 2012 - 2015 Freescale Semiconductor Inc. + * Copyright 2021 NXP + * + */ +&soc { +/include/ "qoriq-clockgen2.dtsi" +/include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-gpio-1.dtsi" +/include/ "qoriq-gpio-2.dtsi" +/include/ "qoriq-gpio-3.dtsi" + +/include/ "qoriq-fman3-0.dtsi" +/include/ "qoriq-fman3-0-1g-0.dtsi" +/include/ "qoriq-fman3-0-1g-1.dtsi" +/include/ "qoriq-fman3-0-1g-2.dtsi" +/include/ "qoriq-fman3-0-1g-3.dtsi" +/include/ "qoriq-fman3-0-1g-4.dtsi" +/include/ "qoriq-fman3-0-1g-5.dtsi" +/include/ "qoriq-fman3-0-10g-0.dtsi" +/include/ "qoriq-fman3-0-10g-1.dtsi" + fman@400000 { + enet0: ethernet@e0000 { + }; + + enet1: ethernet@e2000 { + }; + + enet2: ethernet@e4000 { + }; + + enet3: ethernet@e6000 { + }; + + enet4: ethernet@e8000 { + }; + + enet5: ethernet@ea000 { + }; + + enet6: ethernet@f0000 { + }; + + enet7: ethernet@f2000 { + }; + + mdio@fc000 { + status = "disabled"; + }; + + mdio@fd000 { + status = "disabled"; + }; + }; + +/include/ "qoriq-fman3-1.dtsi" +/include/ "qoriq-fman3-1-1g-0.dtsi" +/include/ "qoriq-fman3-1-1g-1.dtsi" +/include/ "qoriq-fman3-1-1g-2.dtsi" +/include/ "qoriq-fman3-1-1g-3.dtsi" +/include/ "qoriq-fman3-1-1g-4.dtsi" +/include/ "qoriq-fman3-1-1g-5.dtsi" +/include/ "qoriq-fman3-1-10g-0.dtsi" +/include/ "qoriq-fman3-1-10g-1.dtsi" + fman@500000 { + enet8: ethernet@e0000 { + }; + + enet9: ethernet@e2000 { + }; + + enet10: ethernet@e4000 { + }; + + enet11: ethernet@e6000 { + }; + + enet12: ethernet@e8000 { + }; + + enet13: ethernet@ea000 { + }; + + enet14: ethernet@f0000 { + }; + + enet15: ethernet@f2000 { + }; + + mdio@fc000 { + interrupts = <100 1 0 0>; + }; + + mdio@fd000 { + interrupts = <101 1 0 0>; + }; + }; +};
Add the FMan v3 nodes for the T4240RDB. The nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t4240rdb.dts | 142 +++++++++++++++++++++++++++++++++- 1 file changed, 141 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/dts/t4240rdb.dts b/arch/powerpc/dts/t4240rdb.dts index 635065a03685..6d31675c5ead 100644 --- a/arch/powerpc/dts/t4240rdb.dts +++ b/arch/powerpc/dts/t4240rdb.dts @@ -3,7 +3,7 @@ * T4240RDB Device Tree Source * * Copyright 2013 - 2015 Freescale Semiconductor Inc. - * Copyright 2019 NXP + * Copyright 2019-2021 NXP */
/include/ "t4240.dtsi" @@ -20,6 +20,144 @@ }; };
+&soc { + fman@400000 { + ethernet@e0000 { + phy-handle = <&sgmiiphy21>; + phy-connection-type = "sgmii"; + }; + + ethernet@e2000 { + phy-handle = <&sgmiiphy22>; + phy-connection-type = "sgmii"; + }; + + ethernet@e4000 { + phy-handle = <&sgmiiphy23>; + phy-connection-type = "sgmii"; + }; + + ethernet@e6000 { + phy-handle = <&sgmiiphy24>; + phy-connection-type = "sgmii"; + }; + + ethernet@e8000 { + status = "disabled"; + }; + + ethernet@ea000 { + status = "disabled"; + }; + + ethernet@f0000 { + phy-handle = <&xfiphy1>; + phy-connection-type = "xgmii"; + }; + + ethernet@f2000 { + phy-handle = <&xfiphy2>; + phy-connection-type = "xgmii"; + }; + }; + + fman@500000 { + ethernet@e0000 { + phy-handle = <&sgmiiphy41>; + phy-connection-type = "sgmii"; + }; + + ethernet@e2000 { + phy-handle = <&sgmiiphy42>; + phy-connection-type = "sgmii"; + }; + + ethernet@e4000 { + phy-handle = <&sgmiiphy43>; + phy-connection-type = "sgmii"; + }; + + ethernet@e6000 { + phy-handle = <&sgmiiphy44>; + phy-connection-type = "sgmii"; + }; + + ethernet@e8000 { + status = "disabled"; + }; + + ethernet@ea000 { + status = "disabled"; + }; + + ethernet@f0000 { + phy-handle = <&xfiphy3>; + phy-connection-type = "xgmii"; + }; + + ethernet@f2000 { + phy-handle = <&xfiphy4>; + phy-connection-type = "xgmii"; + }; + + mdio@fc000 { + sgmiiphy21: ethernet-phy@0 { + reg = <0x0>; + }; + + sgmiiphy22: ethernet-phy@1 { + reg = <0x1>; + }; + + sgmiiphy23: ethernet-phy@2 { + reg = <0x2>; + }; + + sgmiiphy24: ethernet-phy@3 { + reg = <0x3>; + }; + + sgmiiphy41: ethernet-phy@4 { + reg = <0x4>; + }; + + sgmiiphy42: ethernet-phy@5 { + reg = <0x5>; + }; + + sgmiiphy43: ethernet-phy@6 { + reg = <0x6>; + }; + + sgmiiphy44: ethernet-phy@7 { + reg = <0x7>; + }; + }; + + mdio@fd000 { + xfiphy1: ethernet-phy@10 { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0x10>; + }; + + xfiphy2: ethernet-phy@11 { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0x11>; + }; + + xfiphy3: ethernet-phy@13 { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0x13>; + }; + + xfiphy4: ethernet-phy@12 { + compatible = "ethernet-phy-id13e5.1002"; + reg = <0x12>; + }; + }; + }; +}; + &espi0 { status = "okay"; flash@0 { @@ -30,3 +168,5 @@ spi-max-frequency = <10000000>; /* input clock */ }; }; + +/include/ "t4240si-post.dtsi"
When two FMan's are present on a board, the MDIO nodes are found at the same offsets inside each FMan. This causes "non unique device name" errors when registering the MDIO nodes under the second FMan. Fix this by updating the offsets of the MDIO nodes to include the parent FMan's offset.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi | 2 +- arch/powerpc/dts/qoriq-fman3-1.dtsi | 4 ++-- arch/powerpc/dts/t4240rdb.dts | 4 ++-- arch/powerpc/dts/t4240si-post.dtsi | 4 ++-- 11 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi b/arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi index 889c8d450e09..65bb8a4b0b63 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-10g-0.dtsi @@ -30,7 +30,7 @@ fman@500000 { pcsphy-handle = <&pcsphy14>; };
- mdio@f1000 { + mdio@5f1000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi b/arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi index 2e456983372c..eb39d29b39fa 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-10g-1.dtsi @@ -30,7 +30,7 @@ fman@500000 { pcsphy-handle = <&pcsphy15>; };
- mdio@f3000 { + mdio@5f3000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi index b4ff19bf495a..2f2209dbc9bb 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-0.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy8>; };
- mdio@e1000 { + mdio@5e1000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi index 239c56ad1f62..11653c58b5f0 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-1.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy9>; };
- mdio@e3000 { + mdio@5e3000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi index 6e2bb009d9aa..ae27c7bc6df2 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-2.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy10>; };
- mdio@e5000 { + mdio@5e5000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi index 29dd94ba7498..55ae5499176e 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-3.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy11>; };
- mdio@e7000 { + mdio@5e7000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi index a5b493582703..833cf3e23d8e 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-4.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy12>; };
- mdio@e9000 { + mdio@5e9000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi b/arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi index 486c84bf9810..81da55dfbe26 100644 --- a/arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1-1g-5.dtsi @@ -29,7 +29,7 @@ fman@500000 { pcsphy-handle = <&pcsphy13>; };
- mdio@eb000 { + mdio@5eb000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/qoriq-fman3-1.dtsi b/arch/powerpc/dts/qoriq-fman3-1.dtsi index d8609c3ecfdb..9efcf26c4abc 100644 --- a/arch/powerpc/dts/qoriq-fman3-1.dtsi +++ b/arch/powerpc/dts/qoriq-fman3-1.dtsi @@ -61,14 +61,14 @@ fman1: fman@500000 { reg = <0x87000 0x1000>; };
- mdio1: mdio@fc000 { + mdio1: mdio@5fc000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; reg = <0xfc000 0x1000>; };
- mdio@fd000 { + mdio@5fd000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,fman-memac-mdio", "fsl,fman-xmdio"; diff --git a/arch/powerpc/dts/t4240rdb.dts b/arch/powerpc/dts/t4240rdb.dts index 6d31675c5ead..b3251e330de9 100644 --- a/arch/powerpc/dts/t4240rdb.dts +++ b/arch/powerpc/dts/t4240rdb.dts @@ -100,7 +100,7 @@ phy-connection-type = "xgmii"; };
- mdio@fc000 { + mdio@5fc000 { sgmiiphy21: ethernet-phy@0 { reg = <0x0>; }; @@ -134,7 +134,7 @@ }; };
- mdio@fd000 { + mdio@5fd000 { xfiphy1: ethernet-phy@10 { compatible = "ethernet-phy-id13e5.1002"; reg = <0x10>; diff --git a/arch/powerpc/dts/t4240si-post.dtsi b/arch/powerpc/dts/t4240si-post.dtsi index f614d19965d3..a596f48b54fe 100644 --- a/arch/powerpc/dts/t4240si-post.dtsi +++ b/arch/powerpc/dts/t4240si-post.dtsi @@ -90,11 +90,11 @@ enet15: ethernet@f2000 { };
- mdio@fc000 { + mdio@5fc000 { interrupts = <100 1 0 0>; };
- mdio@fd000 { + mdio@5fd000 { interrupts = <101 1 0 0>; }; };
Enable DM_ETH and DM_MDIO for the T4240RDB.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- configs/T4240RDB_SDCARD_defconfig | 3 +++ configs/T4240RDB_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 61670fa3d14d..2def90140f2e 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -59,6 +60,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_CORTINA=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 2c8a2f0ef271..8a0c122833f5 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -15,6 +15,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -47,6 +48,8 @@ CONFIG_PHYLIB_10G=y CONFIG_PHY_CORTINA=y CONFIG_PHY_TERANETICS=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y
Add the QorIQ DPAA 1 FMan v3 device tree nodes for the T1042 SoC. The device tree nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t1042si-post.dtsi | 46 ++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+) create mode 100644 arch/powerpc/dts/t1042si-post.dtsi
diff --git a/arch/powerpc/dts/t1042si-post.dtsi b/arch/powerpc/dts/t1042si-post.dtsi new file mode 100644 index 000000000000..5c60944e607b --- /dev/null +++ b/arch/powerpc/dts/t1042si-post.dtsi @@ -0,0 +1,46 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * T1042 Silicon/SoC Device Tree Source (post include) + * + * Copyright 2013 - 2014 Freescale Semiconductor Inc. + * Copyright 2021 NXP + * + */ +&soc { +/include/ "qoriq-clockgen2.dtsi" +/include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-gpio-1.dtsi" +/include/ "qoriq-gpio-2.dtsi" +/include/ "qoriq-gpio-3.dtsi" + +/include/ "qoriq-fman3l-0.dtsi" +/include/ "qoriq-fman3-0-1g-0.dtsi" +/include/ "qoriq-fman3-0-1g-1.dtsi" +/include/ "qoriq-fman3-0-1g-2.dtsi" +/include/ "qoriq-fman3-0-1g-3.dtsi" +/include/ "qoriq-fman3-0-1g-4.dtsi" + fman@400000 { + enet0: ethernet@e0000 { + }; + + enet1: ethernet@e2000 { + }; + + enet2: ethernet@e4000 { + }; + + enet3: ethernet@e6000 { + }; + + enet4: ethernet@e8000 { + }; + + mdio@fc000 { + interrupts = <100 1 0 0>; + }; + + mdio@fd000 { + status = "disabled"; + }; + }; +};
Add the FMan v3 nodes for the T1042D4RDB. The nodes are copied over with little modification from the Linux kernel source code.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/powerpc/dts/t1042d4rdb.dts | 55 ++++++++++++++++++++++++++++++++- 1 file changed, 54 insertions(+), 1 deletion(-)
diff --git a/arch/powerpc/dts/t1042d4rdb.dts b/arch/powerpc/dts/t1042d4rdb.dts index 3584c06aa8d6..5e9fab7a1057 100644 --- a/arch/powerpc/dts/t1042d4rdb.dts +++ b/arch/powerpc/dts/t1042d4rdb.dts @@ -3,7 +3,7 @@ * T1042D4RDB Device Tree Source * * Copyright 2013 - 2015 Freescale Semiconductor Inc. - * Copyright 2019 NXP + * Copyright 2019-2021 NXP */
/include/ "t104x.dtsi" @@ -20,6 +20,57 @@ }; };
+&soc { + fman0: fman@400000 { + ethernet@e0000 { + phy-handle = <&phy_sgmii_0>; + phy-connection-type = "sgmii"; + }; + + ethernet@e2000 { + phy-handle = <&phy_sgmii_1>; + phy-connection-type = "sgmii"; + }; + + ethernet@e4000 { + phy-handle = <&phy_sgmii_2>; + phy-connection-type = "sgmii"; + }; + + ethernet@e6000 { + phy-handle = <&phy_rgmii_0>; + phy-connection-type = "rgmii"; + }; + + ethernet@e8000 { + phy-handle = <&phy_rgmii_1>; + phy-connection-type = "rgmii"; + }; + + mdio0: mdio@fc000 { + phy_sgmii_0: ethernet-phy@2 { + reg = <0x02>; + }; + + phy_sgmii_1: ethernet-phy@3 { + reg = <0x03>; + }; + + phy_sgmii_2: ethernet-phy@1 { + reg = <0x01>; + }; + + phy_rgmii_0: ethernet-phy@4 { + reg = <0x04>; + }; + + phy_rgmii_1: ethernet-phy@5 { + reg = <0x05>; + }; + }; + }; +}; + &espi0 { status = "okay"; flash@0 { @@ -30,3 +81,5 @@ spi-max-frequency = <10000000>; /* input clock */ }; }; + +/include/ "t1042si-post.dtsi"
Enable DM_ETH and DM_MDIO for the T1042D4RDB.
Signed-off-by: Camelia Groza camelia.groza@nxp.com --- configs/T1042D4RDB_NAND_defconfig | 3 +++ configs/T1042D4RDB_SDCARD_defconfig | 3 +++ configs/T1042D4RDB_SECURE_BOOT_defconfig | 4 +++- configs/T1042D4RDB_SPIFLASH_defconfig | 3 +++ configs/T1042D4RDB_defconfig | 3 +++ 5 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index bdfd0ef71b71..54bcc2f0821c 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -66,6 +67,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 9094327edeaa..853a3d65ae1c 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -63,6 +64,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index ef097bab8979..a59082c49a16 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -17,6 +17,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y @@ -45,8 +46,9 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y -CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index bc59866b551e..cef5295748a1 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -65,6 +66,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index f968a448e927..85e2beab0200 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -18,6 +18,7 @@ CONFIG_BOARD_EARLY_INIT_R=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y +CONFIG_CMD_DM=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -51,6 +52,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y
Camelia Groza
