[U-Boot] SPI Changes
Hi Tom,
Re the SPI changes, I have put these in a patchwork bundle here:
http://patchwork.ozlabs.org/bundle/sjg/spi/
Also below is a pull request with the same FYI. I have run it through the builder and see no regressions.
The following changes since commit 0ce033d2582129243aca10d3072a221386bbba44:
Merge branch 'master' of git://git.denx.de/u-boot-arm (2013-03-18 14:37:18 -0400)
git://git.denx.de/u-boot-x86.git spi
for you to fetch changes up to 1e7133e99e27c4f02998e7eb87fa43424d48152b:
sf: Use unsigned type for buffers (2013-03-19 08:45:38 -0700)
---------------------------------------------------------------- Simon Glass (15): fdt: Add fdtdec_get_addr_size() to read reg properties spi: Add function to allocate a new SPI slave spi: Use spi_alloc_slave() in each SPI driver sf: Add spi_flash_alloc() to create a new SPI flash struct sf: Use spi_flash_alloc() in each SPI flash driver x86: spi: Add Intel ICH driver spi: Add parameter for maximum write size sf: Respect maximum SPI write size x86: spi: Set maximum write size for ICH sf: Enable FDT-based configuration and memory mapping x86: Move PCI init before SPI init x86: Add FDT SPI node for link x86: Enable SPI flash support for coreboot x86: Enable time command for coreboot sf: Use unsigned type for buffers
arch/x86/lib/board.c | 8 +- board/chromebook-x86/dts/link.dts | 11 + common/cmd_sf.c | 8 +- drivers/mtd/spi/atmel.c | 8 +- drivers/mtd/spi/eon.c | 8 +- drivers/mtd/spi/macronix.c | 8 +- drivers/mtd/spi/ramtron.c | 4 +- drivers/mtd/spi/spansion.c | 8 +- drivers/mtd/spi/spi_flash.c | 81 ++++- drivers/mtd/spi/sst.c | 8 +- drivers/mtd/spi/stmicro.c | 8 +- drivers/mtd/spi/winbond.c | 8 +- drivers/spi/Makefile | 4 + drivers/spi/altera_spi.c | 4 +- drivers/spi/andes_spi.c | 4 +- drivers/spi/armada100_spi.c | 4 +- drivers/spi/atmel_spi.c | 4 +- drivers/spi/bfin_spi.c | 4 +- drivers/spi/bfin_spi6xx.c | 4 +- drivers/spi/cf_qspi.c | 4 +- drivers/spi/cf_spi.c | 4 +- drivers/spi/davinci_spi.c | 4 +- drivers/spi/exynos_spi.c | 4 +- drivers/spi/fsl_espi.c | 4 +- drivers/spi/ich.c | 754 ++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/ich.h | 143 +++++++++ drivers/spi/kirkwood_spi.c | 5 +- drivers/spi/mpc52xx_spi.c | 5 +- drivers/spi/mpc8xxx_spi.c | 5 +- drivers/spi/mxc_spi.c | 4 +- drivers/spi/mxs_spi.c | 4 +- drivers/spi/oc_tiny_spi.c | 5 +- drivers/spi/omap3_spi.c | 27 +- drivers/spi/sh_spi.c | 4 +- drivers/spi/soft_spi.c | 4 +- drivers/spi/spi.c | 39 +++ drivers/spi/tegra_slink.c | 4 +- drivers/spi/tegra_spi.c | 4 +- drivers/spi/xilinx_spi.c | 4 +- include/configs/coreboot.h | 14 +- include/fdtdec.h | 16 + include/spi.h | 44 +++ include/spi_flash.h | 39 +++ lib/fdtdec.c | 28 +- 44 files changed, 1213 insertions(+), 155 deletions(-) create mode 100644 drivers/spi/ich.c create mode 100644 drivers/spi/ich.h create mode 100644 drivers/spi/spi.c
On Tue, Mar 19, 2013 at 12:00:22PM -0700, Simon Glass wrote:
Hi Tom,
