[U-Boot] [PATCH 1/7] mx7ulp: Print the LDO mode status
As per the i.MX7ULP datasheet, it can boot in LDO enabled mode or LDO bypass mode.
Print the LDO mode status in the U-Boot log for convenience.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/mach-imx/mx7ulp/soc.c | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 127fcfeea1..b9a108a514 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -131,6 +131,21 @@ const char *get_imx_type(u32 imxtype) return "7ULP"; }
+#define PMC0_BASE_ADDR 0x410a1000 +#define PMC0_CTRL 0x28 +#define PMC0_CTRL_LDOEN BIT(31) + +static bool ldo_mode_is_enabled(void) +{ + unsigned int reg; + + reg = readl(PMC0_BASE_ADDR + PMC0_CTRL); + if (reg & PMC0_CTRL_LDOEN) + return true; + else + return false; +} + int print_cpuinfo(void) { u32 cpurev; @@ -159,6 +174,11 @@ int print_cpuinfo(void) break; }
+ if (ldo_mode_is_enabled()) + printf("PMC1: LDO enabled mode\n"); + else + printf("PMC1: LDO bypass mode\n"); + return 0; } #endif
Introduce the CONFIG_LDO_ENABLED_MODE option so that i.MX7ULP boards designed to operate with LDO enabled mode can work with 0.95V at LDO output in RUN mode as per the datasheet.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/mach-imx/mx7ulp/Kconfig | 5 +++ arch/arm/mach-imx/mx7ulp/soc.c | 58 ++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/arch/arm/mach-imx/mx7ulp/Kconfig b/arch/arm/mach-imx/mx7ulp/Kconfig index ed5f0aeb2d..138c58363f 100644 --- a/arch/arm/mach-imx/mx7ulp/Kconfig +++ b/arch/arm/mach-imx/mx7ulp/Kconfig @@ -3,6 +3,11 @@ if ARCH_MX7ULP config SYS_SOC default "mx7ulp"
+config LDO_ENABLED_MODE + bool "i.MX7ULP LDO Enabled Mode" + help + Select this option to enable the PMC1 LDO. + config MX7ULP bool
diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index b9a108a514..751575c95e 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -9,6 +9,22 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/hab.h>
+#define PMC0_BASE_ADDR 0x410a1000 +#define PMC0_CTRL 0x28 +#define PMC0_CTRL_LDOEN BIT(31) +#define PMC0_CTRL_LDOOKDIS BIT(30) +#define PMC0_CTRL_PMC1ON BIT(24) +#define PMC1_BASE_ADDR 0x40400000 +#define PMC1_RUN 0x8 +#define PMC1_STOP 0x10 +#define PMC1_VLPS 0x14 +#define PMC1_RUN_LDOVL_SHIFT 16 +#define PMC1_RUN_LDOVL_MASK (0x3f << PMC1_RUN_LDOVL_SHIFT) +#define PMC1_RUN_LDOVL_900 0x1e +#define PMC1_RUN_LDOVL_950 0x23 +#define PMC1_STATUS 0x20 +#define PMC1_STATUS_LDOVLF BIT(8) + static char *get_reset_cause(char *);
#if defined(CONFIG_IMX_HAB) @@ -100,6 +116,44 @@ void init_wdog(void) disable_wdog(WDG2_RBASE); }
+#if defined(CONFIG_LDO_ENABLED_MODE) +static void init_ldo_mode(void) +{ + unsigned int reg; + + /* Set LDOOKDIS */ + setbits_le32(PMC0_BASE_ADDR + PMC0_CTRL, PMC0_CTRL_LDOOKDIS); + + /* Set LDOVL to 0.95V in PMC1_RUN */ + reg = readl(PMC1_BASE_ADDR + PMC1_RUN); + reg &= ~PMC1_RUN_LDOVL_MASK; + reg |= (PMC1_RUN_LDOVL_950 << PMC1_RUN_LDOVL_SHIFT); + writel(PMC1_BASE_ADDR + PMC1_RUN, reg); + + /* Wait for LDOVLF to be cleared */ + reg = readl(PMC1_BASE_ADDR + PMC1_STATUS); + while (reg & PMC1_STATUS_LDOVLF) + ; + + /* Set LDOVL to 0.95V in PMC1_STOP */ + reg = readl(PMC1_BASE_ADDR + PMC1_STOP); + reg &= ~PMC1_RUN_LDOVL_MASK; + reg |= (PMC1_RUN_LDOVL_950 << PMC1_RUN_LDOVL_SHIFT); + writel(PMC1_BASE_ADDR + PMC1_STOP, reg); + + /* Set LDOVL to 0.90V in PMC1_VLPS */ + reg = readl(PMC1_BASE_ADDR + PMC1_VLPS); + reg &= ~PMC1_RUN_LDOVL_MASK; + reg |= (PMC1_RUN_LDOVL_900 << PMC1_RUN_LDOVL_SHIFT); + writel(PMC1_BASE_ADDR + PMC1_VLPS, reg); + + /* Set LDOEN bit */ + setbits_le32(PMC0_BASE_ADDR + PMC0_CTRL, PMC0_CTRL_LDOEN); + + /* Set the PMC1ON bit */ + setbits_le32(PMC0_BASE_ADDR + PMC0_CTRL, PMC0_CTRL_PMC1ON); +} +#endif
void s_init(void) { @@ -113,6 +167,10 @@ void s_init(void) /* enable dumb pmic */ writel((readl(SNVS_LP_LPCR) | SNVS_LPCR_DPEN), SNVS_LP_LPCR); } + +#if defined(CONFIG_LDO_ENABLED_MODE) + init_ldo_mode(); +#endif return; }
The LDOVL definitions is common to all the modes, not only RUN mode, so in order to avoid confusion, remove the _RUN notation from the PMC1 LDOVL definitions.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/mach-imx/mx7ulp/soc.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 751575c95e..4487fa61c0 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -18,10 +18,10 @@ #define PMC1_RUN 0x8 #define PMC1_STOP 0x10 #define PMC1_VLPS 0x14 -#define PMC1_RUN_LDOVL_SHIFT 16 -#define PMC1_RUN_LDOVL_MASK (0x3f << PMC1_RUN_LDOVL_SHIFT) -#define PMC1_RUN_LDOVL_900 0x1e -#define PMC1_RUN_LDOVL_950 0x23 +#define PMC1_LDOVL_SHIFT 16 +#define PMC1_LDOVL_MASK (0x3f << PMC1_LDOVL_SHIFT) +#define PMC1_LDOVL_900 0x1e +#define PMC1_LDOVL_950 0x23 #define PMC1_STATUS 0x20 #define PMC1_STATUS_LDOVLF BIT(8)
@@ -126,8 +126,8 @@ static void init_ldo_mode(void)
/* Set LDOVL to 0.95V in PMC1_RUN */ reg = readl(PMC1_BASE_ADDR + PMC1_RUN); - reg &= ~PMC1_RUN_LDOVL_MASK; - reg |= (PMC1_RUN_LDOVL_950 << PMC1_RUN_LDOVL_SHIFT); + reg &= ~PMC1_LDOVL_MASK; + reg |= (PMC1_LDOVL_950 << PMC1_LDOVL_SHIFT); writel(PMC1_BASE_ADDR + PMC1_RUN, reg);
/* Wait for LDOVLF to be cleared */ @@ -137,14 +137,14 @@ static void init_ldo_mode(void)
/* Set LDOVL to 0.95V in PMC1_STOP */ reg = readl(PMC1_BASE_ADDR + PMC1_STOP); - reg &= ~PMC1_RUN_LDOVL_MASK; - reg |= (PMC1_RUN_LDOVL_950 << PMC1_RUN_LDOVL_SHIFT); + reg &= ~PMC1_LDOVL_MASK; + reg |= (PMC1_LDOVL_950 << PMC1_LDOVL_SHIFT); writel(PMC1_BASE_ADDR + PMC1_STOP, reg);
/* Set LDOVL to 0.90V in PMC1_VLPS */ reg = readl(PMC1_BASE_ADDR + PMC1_VLPS); - reg &= ~PMC1_RUN_LDOVL_MASK; - reg |= (PMC1_RUN_LDOVL_900 << PMC1_RUN_LDOVL_SHIFT); + reg &= ~PMC1_LDOVL_MASK; + reg |= (PMC1_LDOVL_900 << PMC1_LDOVL_SHIFT); writel(PMC1_BASE_ADDR + PMC1_VLPS, reg);
/* Set LDOEN bit */
scg_a7_apll_init() is not called anywhere, so remove such dead code
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/include/asm/arch-mx7ulp/scg.h | 1 - arch/arm/mach-imx/mx7ulp/scg.c | 61 -------------------------- 2 files changed, 62 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx7ulp/scg.h b/arch/arm/include/asm/arch-mx7ulp/scg.h index 531d8f3a95..b79bde338f 100644 --- a/arch/arm/include/asm/arch-mx7ulp/scg.h +++ b/arch/arm/include/asm/arch-mx7ulp/scg.h @@ -331,7 +331,6 @@ u32 decode_pll(enum pll_clocks pll); void scg_a7_rccr_init(void); void scg_a7_spll_init(void); void scg_a7_ddrclk_init(void); -void scg_a7_apll_init(void); void scg_a7_firc_init(void); void scg_a7_nicclk_init(void); void scg_a7_sys_clk_sel(enum scg_sys_src clk); diff --git a/arch/arm/mach-imx/mx7ulp/scg.c b/arch/arm/mach-imx/mx7ulp/scg.c index 819c90af6c..c7bb7a1c66 100644 --- a/arch/arm/mach-imx/mx7ulp/scg.c +++ b/arch/arm/mach-imx/mx7ulp/scg.c @@ -949,67 +949,6 @@ void scg_a7_ddrclk_init(void) /* Clock source is System OSC <<0 */ #define SCG1_APLL_CFG_CLKSRC_NUM ((0x0) << SCG_PLL_CFG_CLKSRC_SHIFT)
-/* - * A7 APLL = 24MHz / 1 * 22 / 1 / 1 = 528MHz, - * system PLL is sourced from APLL, - * APLL clock source is system OSC (24MHz) - */ -#define SCG1_APLL_CFG_NUM_24M_OSC (SCG1_APLL_CFG_POSTDIV2_NUM | \ - SCG1_APLL_CFG_POSTDIV1_NUM | \ - (22 << SCG_PLL_CFG_MULT_SHIFT) | \ - SCG1_APLL_CFG_PFDSEL_NUM | \ - SCG1_APLL_CFG_PREDIV_NUM | \ - SCG1_APLL_CFG_BYPASS_NUM | \ - SCG1_APLL_CFG_PLLSEL_NUM | \ - SCG1_APLL_CFG_CLKSRC_NUM) - -/* PFD0 Freq = A7 APLL(528MHz) * 18 / 27 = 352MHz */ -#define SCG1_APLL_PFD0_FRAC_NUM (27) - - -void scg_a7_apll_init(void) -{ - u32 val = 0; - - /* Disable A7 Auxiliary PLL */ - val = readl(&scg1_regs->apllcsr); - val &= ~SCG_APLL_CSR_APLLEN_MASK; - writel(val, &scg1_regs->apllcsr); - - /* Gate off A7 APLL PFD0 ~ PDF4 */ - val = readl(&scg1_regs->apllpfd); - val |= 0x80808080; - writel(val, &scg1_regs->apllpfd); - - /* ================ A7 APLL Configuration Start ============== */ - /* Configure A7 Auxiliary PLL */ - writel(SCG1_APLL_CFG_NUM_24M_OSC, &scg1_regs->apllcfg); - - /* Enable A7 Auxiliary PLL */ - val = readl(&scg1_regs->apllcsr); - val |= SCG_APLL_CSR_APLLEN_MASK; - writel(val, &scg1_regs->apllcsr); - - /* Wait for A7 APLL clock ready */ - while (!(readl(&scg1_regs->apllcsr) & SCG_APLL_CSR_APLLVLD_MASK)) - ; - - /* Configure A7 APLL PFD0 */ - val = readl(&scg1_regs->apllpfd); - val &= ~SCG_PLL_PFD0_FRAC_MASK; - val |= SCG1_APLL_PFD0_FRAC_NUM; - writel(val, &scg1_regs->apllpfd); - - /* Un-gate A7 APLL PFD0 */ - val = readl(&scg1_regs->apllpfd); - val &= ~SCG_PLL_PFD0_GATE_MASK; - writel(val, &scg1_regs->apllpfd); - - /* Wait for A7 APLL PFD0 clock being valid */ - while (!(readl(&scg1_regs->apllpfd) & SCG_PLL_PFD0_VALID_MASK)) - ; -} - /* SCG1(A7) FIRC DIV configurations */ /* Disable FIRC DIV3 */ #define SCG1_FIRCDIV_DIV3_NUM ((0x0) << SCG_FIRCDIV_DIV3_SHIFT)
By default the i.MX7ULP DDR frequency runs at 352 MHz, but not all i.MX7ULP based systems are able to run at such frequency, such as the i.MX7ULP Embedded Artists board.
Introduce a CONFIG_IMX7ULP_LOWER_DDR_FREQUENCY option that allows running DDR at a lower frequency of 316.8MHz.
When such option is not selected DDR will run at the default 352MHz frequency.
Suggested-by: Bogdan Petru Chircu Mare bogdan-petru.chircu-mare@nxp.com Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/mach-imx/Kconfig | 7 +++++++ arch/arm/mach-imx/mx7ulp/clock.c | 27 +++++++++++++++++++++++++++ 2 files changed, 34 insertions(+)
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index b0b9d2c070..bb79734738 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -89,6 +89,13 @@ config CMD_NANDBCB This is similar to kobs-ng, which is used in Linux as separate rootfs package.
+config IMX7ULP_LOWER_DDR_FREQUENCY + bool "Use lower DDR Frequency for i.MX7ULP" + depends on ARCH_MX7ULP + help + Some systems can not run DDR frequency at 352MHz, so select + this option to run DDR frequency at 316.8MHz instead + config NXP_BOARD_REVISION bool "Read NXP board revision from fuses" depends on ARCH_MX6 || ARCH_MX7 diff --git a/arch/arm/mach-imx/mx7ulp/clock.c b/arch/arm/mach-imx/mx7ulp/clock.c index d3365dd411..c26dbd3781 100644 --- a/arch/arm/mach-imx/mx7ulp/clock.c +++ b/arch/arm/mach-imx/mx7ulp/clock.c @@ -274,6 +274,31 @@ static void init_clk_rgpio2p(void) writel(PCC_CGC_MASK, (PCC0_RBASE + 0x3C)); }
+/* + * Default PFD0 divide is 27, which generates: + * PFD0 Freq = A7 APLL(528MHz) * 18 / 27 = 352MHz + * + * As some systems can not run DDR at 352MHz, use a + * divider of 30, which gives: + * + * PFD0 Freq = A7 APLL(528MHz) * 18 / 30 = 316.8MHz + */ +#define SCG1_APLL_PFD0_FRAC_NUM 30 +static void scg_a7_apll_update_pfd0(void) +{ + scg_p scg1_regs = (scg_p)SCG1_RBASE; + u32 val; + + if (!IS_ENABLED(CONFIG_IMX7ULP_LOWER_DDR_FREQUENCY)) + return; + + /* Configure A7 APLL PFD0 */ + val = readl(&scg1_regs->apllpfd); + val &= ~SCG_PLL_PFD0_FRAC_MASK; + val |= SCG1_APLL_PFD0_FRAC_NUM; + writel(val, &scg1_regs->apllpfd); +} + /* Configure PLL/PFD freq */ void clock_init(void) { @@ -300,6 +325,8 @@ void clock_init(void)
scg_a7_soscdiv_init();
+ scg_a7_apll_update_pfd0(); + scg_a7_init_core_clk();
/* APLL PFD1 = 270Mhz, PFD2=345.6Mhz, PFD3=800Mhz */
Sync the mx7ulp device tree related files with the one from NXP U-Boot vendor tree (imx_v2019.04_4.19.35_1.0.0).
The mainline support for i.MX7ULP is very premature at this stage.
We should probably re-sync with mainline Linux dts when it gets in better shape, but for now sync with the U-Boot vendor code.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/imx7ulp-evk.dts | 157 ++- arch/arm/dts/imx7ulp-pinfunc.h | 1748 ++++++++++++++++---------------- arch/arm/dts/imx7ulp.dtsi | 28 +- 3 files changed, 969 insertions(+), 964 deletions(-)
diff --git a/arch/arm/dts/imx7ulp-evk.dts b/arch/arm/dts/imx7ulp-evk.dts index e56b7226e6..08a682f314 100644 --- a/arch/arm/dts/imx7ulp-evk.dts +++ b/arch/arm/dts/imx7ulp-evk.dts @@ -15,7 +15,7 @@ compatible = "fsl,imx7ulp-evk", "fsl,imx7ulp", "Generic DT based system";
chosen { - bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x402D0010,115200"; + bootargs = "console=ttyLP0,115200 earlycon=lpuart32,0x402D0000,115200"; stdout-path = &lpuart4; };
@@ -66,7 +66,7 @@ compatible = "regulator-fixed"; reg = <0>; pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb_otg1>; + pinctrl-0 = <&pinctrl_usbotg1_vbus>; regulator-name = "usb_otg1_vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; @@ -84,22 +84,6 @@ enable-active-high; };
- reg_vsd_3v3b: regulator@2 { - compatible = "regulator-fixed"; - reg = <2>; - regulator-name = "VSD_3V3B"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio2 11 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - }; - - extcon_usb1: extcon_usb1 { - compatible = "linux,extcon-usb-gpio"; - id-gpio = <&gpio0 8 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_extcon_usb1>; };
pf1550-rpmsg { @@ -166,134 +150,135 @@ imx7ulp-evk { pinctrl_hog_1: hoggrp-1 { fsl,pins = < - ULP1_PAD_PTC10__PTC10 0x30100 /* USDHC0 CD */ - ULP1_PAD_PTC1__PTC1 0x20100 - ULP1_PAD_PTD0__PTD0 0x30100 /* USDHC0 RST */ - ULP1_PAD_PTE13__PTE13 0x30103 /* USDHC1 CD */ - ULP1_PAD_PTE12__PTE12 0x30103 /* USDHC1 WP */ - ULP1_PAD_PTE14__SDHC1_VS 0x843 /* USDHC1 VSEL */ + IMX7ULP_PAD_PTC1__PTC1 0x20000 >; };
pinctrl_backlight: backlight_grp { fsl,pins = < - ULP1_PAD_PTF2__PTF2 0x20100 + IMX7ULP_PAD_PTF2__PTF2 0x20100 >; };
pinctrl_lpi2c5: lpi2c5grp { fsl,pins = < - ULP1_PAD_PTC4__LPI2C5_SCL 0x527 - ULP1_PAD_PTC5__LPI2C5_SDA 0x527 + IMX7ULP_PAD_PTC4__LPI2C5_SCL 0x27 + IMX7ULP_PAD_PTC5__LPI2C5_SDA 0x27 >; };
pinctrl_mipi_dsi_reset: mipi_dsi_reset_grp { fsl,pins = < - ULP1_PAD_PTC19__PTC19 0x20103 + IMX7ULP_PAD_PTC19__PTC19 0x20003 >; };
pinctrl_lpuart4: lpuart4grp { fsl,pins = < - ULP1_PAD_PTC3__LPUART4_RX 0x400 - ULP1_PAD_PTC2__LPUART4_TX 0x400 + IMX7ULP_PAD_PTC3__LPUART4_RX 0x3 + IMX7ULP_PAD_PTC2__LPUART4_TX 0x3 >; };
pinctrl_lpuart6: lpuart6grp { fsl,pins = < - ULP1_PAD_PTE10__LPUART6_TX 0x400 - ULP1_PAD_PTE11__LPUART6_RX 0x400 - ULP1_PAD_PTE9__LPUART6_RTS_B 0x400 - ULP1_PAD_PTE8__LPUART6_CTS_B 0x400 - ULP1_PAD_PTE7__PTE7 0x00 /* BT_REG_ON */ + IMX7ULP_PAD_PTE10__LPUART6_TX 0x3 + IMX7ULP_PAD_PTE11__LPUART6_RX 0x3 + IMX7ULP_PAD_PTE9__LPUART6_RTS_B 0x3 + IMX7ULP_PAD_PTE8__LPUART6_CTS_B 0x3 + IMX7ULP_PAD_PTE7__PTE7 0x20000 /* BT_REG_ON */ >; };
pinctrl_lpuart7: lpuart7grp { fsl,pins = < - ULP1_PAD_PTF14__LPUART7_TX 0x400 - ULP1_PAD_PTF15__LPUART7_RX 0x400 - ULP1_PAD_PTF13__LPUART7_RTS_B 0x400 - ULP1_PAD_PTF12__LPUART7_CTS_B 0x400 + IMX7ULP_PAD_PTF14__LPUART7_TX 0x3 + IMX7ULP_PAD_PTF15__LPUART7_RX 0x3 + IMX7ULP_PAD_PTF13__LPUART7_RTS_B 0x3 + IMX7ULP_PAD_PTF12__LPUART7_CTS_B 0x3 >; };
pinctrl_usdhc0: usdhc0grp { fsl,pins = < - ULP1_PAD_PTD1__SDHC0_CMD 0x843 - ULP1_PAD_PTD2__SDHC0_CLK 0x10843 - ULP1_PAD_PTD7__SDHC0_D3 0x843 - ULP1_PAD_PTD8__SDHC0_D2 0x843 - ULP1_PAD_PTD9__SDHC0_D1 0x843 - ULP1_PAD_PTD10__SDHC0_D0 0x843 + IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 + IMX7ULP_PAD_PTD2__SDHC0_CLK 0x10042 + IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 + IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 + IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 + IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 + IMX7ULP_PAD_PTC10__PTC10 0x10000 /* USDHC0 CD */ + IMX7ULP_PAD_PTD0__PTD0 0x20000 /* USDHC0 RST */ >; };
pinctrl_usdhc0_8bit: usdhc0grp_8bit { fsl,pins = < - ULP1_PAD_PTD1__SDHC0_CMD 0x843 - ULP1_PAD_PTD2__SDHC0_CLK 0x843 - ULP1_PAD_PTD3__SDHC0_D7 0x843 - ULP1_PAD_PTD4__SDHC0_D6 0x843 - ULP1_PAD_PTD5__SDHC0_D5 0x843 - ULP1_PAD_PTD6__SDHC0_D4 0x843 - ULP1_PAD_PTD7__SDHC0_D3 0x843 - ULP1_PAD_PTD8__SDHC0_D2 0x843 - ULP1_PAD_PTD9__SDHC0_D1 0x843 - ULP1_PAD_PTD10__SDHC0_D0 0x843 + IMX7ULP_PAD_PTD1__SDHC0_CMD 0x43 + IMX7ULP_PAD_PTD2__SDHC0_CLK 0x10042 + IMX7ULP_PAD_PTD3__SDHC0_D7 0x43 + IMX7ULP_PAD_PTD4__SDHC0_D6 0x43 + IMX7ULP_PAD_PTD5__SDHC0_D5 0x43 + IMX7ULP_PAD_PTD6__SDHC0_D4 0x43 + IMX7ULP_PAD_PTD7__SDHC0_D3 0x43 + IMX7ULP_PAD_PTD8__SDHC0_D2 0x43 + IMX7ULP_PAD_PTD9__SDHC0_D1 0x43 + IMX7ULP_PAD_PTD10__SDHC0_D0 0x43 + IMX7ULP_PAD_PTD11__SDHC0_DQS 0x42 >; };
pinctrl_lpi2c7: lpi2c7grp { fsl,pins = < - ULP1_PAD_PTF12__LPI2C7_SCL 0x527 - ULP1_PAD_PTF13__LPI2C7_SDA 0x527 + IMX7ULP_PAD_PTF12__LPI2C7_SCL 0x27 + IMX7ULP_PAD_PTF13__LPI2C7_SDA 0x27 >; };
pinctrl_lpspi3: lpspi3grp { fsl,pins = < - ULP1_PAD_PTF16__LPSPI3_SIN 0x300 - ULP1_PAD_PTF17__LPSPI3_SOUT 0x300 - ULP1_PAD_PTF18__LPSPI3_SCK 0x300 - ULP1_PAD_PTF19__LPSPI3_PCS0 0x300 + IMX7ULP_PAD_PTF16__LPSPI3_SIN 0x0 + IMX7ULP_PAD_PTF17__LPSPI3_SOUT 0x0 + IMX7ULP_PAD_PTF18__LPSPI3_SCK 0x0 + IMX7ULP_PAD_PTF19__LPSPI3_PCS0 0x0 >; };
- pinctrl_usb_otg1: usbotg1grp { + pinctrl_usbotg1_vbus: otg1vbusgrp { fsl,pins = < - ULP1_PAD_PTC0__PTC0 0x30100 + IMX7ULP_PAD_PTC0__PTC0 0x20000 >; };
- pinctrl_extcon_usb1: extcon1grp { + pinctrl_usbotg1_id: otg1idgrp { fsl,pins = < - ULP1_PAD_PTC8__PTC8 0x30103 + IMX7ULP_PAD_PTC13__USB0_ID 0x10003 >; };
pinctrl_usdhc1: usdhc1grp { fsl,pins = < - ULP1_PAD_PTE3__SDHC1_CMD 0x843 - ULP1_PAD_PTE2__SDHC1_CLK 0x843 - ULP1_PAD_PTE1__SDHC1_D0 0x843 - ULP1_PAD_PTE0__SDHC1_D1 0x843 - ULP1_PAD_PTE5__SDHC1_D2 0x843 - ULP1_PAD_PTE4__SDHC1_D3 0x843 + IMX7ULP_PAD_PTE3__SDHC1_CMD 0x43 + IMX7ULP_PAD_PTE2__SDHC1_CLK 0x10042 + IMX7ULP_PAD_PTE1__SDHC1_D0 0x43 + IMX7ULP_PAD_PTE0__SDHC1_D1 0x43 + IMX7ULP_PAD_PTE5__SDHC1_D2 0x43 + IMX7ULP_PAD_PTE4__SDHC1_D3 0x43 >; };
pinctrl_usdhc1_rst: usdhc1grp_rst { fsl,pins = < - ULP1_PAD_PTE11__PTE11 0x30100 /* USDHC1 RST */ + IMX7ULP_PAD_PTE11__PTE11 0x20000 /* USDHC1 RST */ + IMX7ULP_PAD_PTE13__PTE13 0x10003 /* USDHC1 CD */ + IMX7ULP_PAD_PTE12__PTE12 0x10003 /* USDHC1 WP */ + IMX7ULP_PAD_PTE14__SDHC1_VS 0x43 /* USDHC1 VSEL */ >; };
- pinctrl_wifi: wifigrp { + pinctrl_dsi_hdmi: dsi_hdmi_grp { fsl,pins = < - ULP1_PAD_PTE6__PTE6 0x43 /* WL_REG_ON */ + IMX7ULP_PAD_PTC18__PTC18 0x10003 /* DSI_HDMI_INT */ >; }; }; @@ -304,7 +289,7 @@ disp-dev = "mipi_dsi_northwest"; display = <&display0>;
- display0: display { + display0: display@0 { bits-per-pixel = <16>; bus-width = <24>;
@@ -343,21 +328,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_lpi2c5>; status = "okay"; - - fxas2100x@20 { - compatible = "fsl,fxas2100x"; - reg = <0x20>; - }; - - fxos8700@1e { - compatible = "fsl,fxos8700"; - reg = <0x1e>; - }; - - mpl3115@60 { - compatible = "fsl,mpl3115"; - reg = <0x60>; - }; };
&lpspi3 { @@ -406,13 +376,18 @@
&usbotg1 { vbus-supply = <®_usb_otg1_vbus>; - extcon = <0>, <&extcon_usb1>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg1_id>; srp-disable; hnp-disable; adp-disable; status = "okay"; };
+&usbphy1 { + fsl,tx-d-cal = <88>; +}; + &usdhc0 { pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; pinctrl-0 = <&pinctrl_usdhc0>; diff --git a/arch/arm/dts/imx7ulp-pinfunc.h b/arch/arm/dts/imx7ulp-pinfunc.h index b1b6a71f2c..777d7f0947 100644 --- a/arch/arm/dts/imx7ulp-pinfunc.h +++ b/arch/arm/dts/imx7ulp-pinfunc.h @@ -1,5 +1,6 @@ /* - * Copyright 2014 - 2015 Freescale Semiconductor, Inc. + * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2017 - 2018 NXP * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as @@ -7,876 +8,885 @@ * */
-#ifndef __DTS_ULP1_PINFUNC_H -#define __DTS_ULP1_PINFUNC_H +#ifndef __DTS_IMX7ULP_PINFUNC_H +#define __DTS_IMX7ULP_PINFUNC_H
/* * The pin function ID is a tuple of - * <mux_conf_reg mux2_reg mux_mode mux2_val> - * - * !!! IMPORTANT NOTE !!! - * - * There's common mux_reg & conf_reg register for each pad on ULP1 device, so the first - * two values are defined as same value. Extra non-zero mux2_reg value within the tuple - * means that there's additional mux2 control register that must be configured to - * mux2_val accordingly to fetch desired pin functionality on ULP1 device. - * + * <mux_conf_reg input_reg mux_mode input_val> */ +#define IMX7ULP_PAD_PTA0__CMP0_IN1_3V 0x0000 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA0__PTA0 0x0000 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA0__LPSPI0_PCS1 0x0000 0x0104 0x3 0x2 +#define IMX7ULP_PAD_PTA0__LPUART0_CTS_B 0x0000 0x01F8 0x4 0x2 +#define IMX7ULP_PAD_PTA0__LPI2C0_SCL 0x0000 0x017C 0x5 0x2 +#define IMX7ULP_PAD_PTA0__TPM0_CLKIN 0x0000 0x01A8 0x6 0x2 +#define IMX7ULP_PAD_PTA0__I2S0_RX_BCLK 0x0000 0x01B8 0x7 0x2 +#define IMX7ULP_PAD_PTA0__LLWU0_P0 0x0000 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA1__CMP0_IN2_3V 0x0004 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA1__PTA1 0x0004 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA1__LPSPI0_PCS2 0x0004 0x0108 0x3 0x1 +#define IMX7ULP_PAD_PTA1__LPUART0_RTS_B 0x0004 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA1__LPI2C0_SDA 0x0004 0x0180 0x5 0x1 +#define IMX7ULP_PAD_PTA1__TPM0_CH0 0x0004 0x0138 0x6 0x1 +#define IMX7ULP_PAD_PTA1__I2S0_RX_FS 0x0004 0x01BC 0x7 0x1 +#define IMX7ULP_PAD_PTA2__CMP1_IN2_3V 0x0008 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA2__PTA2 0x0008 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA2__LPSPI0_PCS3 0x0008 0x010C 0x3 0x1 +#define IMX7ULP_PAD_PTA2__LPUART0_TX 0x0008 0x0200 0x4 0x1 +#define IMX7ULP_PAD_PTA2__LPI2C0_HREQ 0x0008 0x0178 0x5 0x1 +#define IMX7ULP_PAD_PTA2__TPM0_CH1 0x0008 0x013C 0x6 0x1 +#define IMX7ULP_PAD_PTA2__I2S0_RXD0 0x0008 0x01DC 0x7 0x1 +#define IMX7ULP_PAD_PTA3__CMP1_IN4_3V 0x000C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA3__PTA3 0x000C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA3__LPSPI0_PCS0 0x000C 0x0100 0x3 0x1 +#define IMX7ULP_PAD_PTA3__LPUART0_RX 0x000C 0x01FC 0x4 0x1 +#define IMX7ULP_PAD_PTA3__TPM0_CH2 0x000C 0x0140 0x6 0x1 +#define IMX7ULP_PAD_PTA3__I2S0_RXD1 0x000C 0x01E0 0x7 0x1 +#define IMX7ULP_PAD_PTA3__CMP0_OUT 0x000C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA3__LLWU0_P1 0x000C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA4__ADC1_CH3A 0x0010 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA4__PTA4 0x0010 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA4__LPSPI0_SIN 0x0010 0x0114 0x3 0x1 +#define IMX7ULP_PAD_PTA4__LPUART1_CTS_B 0x0010 0x0204 0x4 0x1 +#define IMX7ULP_PAD_PTA4__LPI2C1_SCL 0x0010 0x0188 0x5 0x1 +#define IMX7ULP_PAD_PTA4__TPM0_CH3 0x0010 0x0144 0x6 0x1 +#define IMX7ULP_PAD_PTA4__I2S0_MCLK 0x0010 0x01B4 0x7 0x1 +#define IMX7ULP_PAD_PTA5__ADC1_CH3B 0x0014 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA5__PTA5 0x0014 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA5__LPSPI0_SOUT 0x0014 0x0118 0x3 0x1 +#define IMX7ULP_PAD_PTA5__LPUART1_RTS_B 0x0014 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA5__LPI2C1_SDA 0x0014 0x018C 0x5 0x1 +#define IMX7ULP_PAD_PTA5__TPM0_CH4 0x0014 0x0148 0x6 0x1 +#define IMX7ULP_PAD_PTA5__I2S0_TX_BCLK 0x0014 0x01C0 0x7 0x1 +#define IMX7ULP_PAD_PTA6__ADC1_CH4A 0x0018 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA6__PTA6 0x0018 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA6__LPSPI0_SCK 0x0018 0x0110 0x3 0x1 +#define IMX7ULP_PAD_PTA6__LPUART1_TX 0x0018 0x020C 0x4 0x1 +#define IMX7ULP_PAD_PTA6__LPI2C1_HREQ 0x0018 0x0184 0x5 0x1 +#define IMX7ULP_PAD_PTA6__TPM0_CH5 0x0018 0x014C 0x6 0x1 +#define IMX7ULP_PAD_PTA6__I2S0_TX_FS 0x0018 0x01C4 0x7 0x1 +#define IMX7ULP_PAD_PTA7__ADC1_CH4B 0x001C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA7__PTA7 0x001C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA7__LPUART1_RX 0x001C 0x0208 0x4 0x1 +#define IMX7ULP_PAD_PTA7__TPM1_CH1 0x001C 0x0154 0x6 0x1 +#define IMX7ULP_PAD_PTA7__I2S0_TXD0 0x001C 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA8__ADC1_CH5A 0x0020 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA8__PTA8 0x0020 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA8__LPSPI1_PCS1 0x0020 0x0120 0x3 0x1 +#define IMX7ULP_PAD_PTA8__LPUART2_CTS_B 0x0020 0x0210 0x4 0x1 +#define IMX7ULP_PAD_PTA8__LPI2C2_SCL 0x0020 0x0194 0x5 0x1 +#define IMX7ULP_PAD_PTA8__TPM1_CLKIN 0x0020 0x01AC 0x6 0x1 +#define IMX7ULP_PAD_PTA8__I2S0_TXD1 0x0020 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA9__ADC1_CH5B 0x0024 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA9__PTA9 0x0024 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA9__LPSPI1_PCS2 0x0024 0x0124 0x3 0x1 +#define IMX7ULP_PAD_PTA9__LPUART2_RTS_B 0x0024 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA9__LPI2C2_SDA 0x0024 0x0198 0x5 0x1 +#define IMX7ULP_PAD_PTA9__TPM1_CH0 0x0024 0x0150 0x6 0x1 +#define IMX7ULP_PAD_PTA9__NMI0_B 0x0024 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA10__ADC1_CH6A 0x0028 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA10__PTA10 0x0028 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA10__LPSPI1_PCS3 0x0028 0x0128 0x3 0x1 +#define IMX7ULP_PAD_PTA10__LPUART2_TX 0x0028 0x0218 0x4 0x1 +#define IMX7ULP_PAD_PTA10__LPI2C2_HREQ 0x0028 0x0190 0x5 0x1 +#define IMX7ULP_PAD_PTA10__TPM2_CLKIN 0x0028 0x01F4 0x6 0x1 +#define IMX7ULP_PAD_PTA10__I2S0_RX_BCLK 0x0028 0x01B8 0x7 0x1 +#define IMX7ULP_PAD_PTA11__ADC1_CH6B 0x002C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA11__PTA11 0x002C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA11__LPUART2_RX 0x002C 0x0214 0x4 0x1 +#define IMX7ULP_PAD_PTA11__TPM2_CH0 0x002C 0x0158 0x6 0x1 +#define IMX7ULP_PAD_PTA11__I2S0_RX_FS 0x002C 0x01BC 0x7 0x2 +#define IMX7ULP_PAD_PTA12__ADC1_CH7A 0x0030 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA12__PTA12 0x0030 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA12__LPSPI1_SIN 0x0030 0x0130 0x3 0x1 +#define IMX7ULP_PAD_PTA12__LPUART3_CTS_B 0x0030 0x021C 0x4 0x1 +#define IMX7ULP_PAD_PTA12__LPI2C3_SCL 0x0030 0x01A0 0x5 0x1 +#define IMX7ULP_PAD_PTA12__TPM2_CH1 0x0030 0x015C 0x6 0x1 +#define IMX7ULP_PAD_PTA12__I2S0_RXD0 0x0030 0x01DC 0x7 0x2 +#define IMX7ULP_PAD_PTA13__ADC1_CH7B 0x0034 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA13__PTA13 0x0034 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA13__LPSPI1_SOUT 0x0034 0x0134 0x3 0x2 +#define IMX7ULP_PAD_PTA13__LPUART3_RTS_B 0x0034 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA13__LPI2C3_SDA 0x0034 0x01A4 0x5 0x2 +#define IMX7ULP_PAD_PTA13__TPM3_CLKIN 0x0034 0x01B0 0x6 0x1 +#define IMX7ULP_PAD_PTA13__I2S0_RXD1 0x0034 0x01E0 0x7 0x2 +#define IMX7ULP_PAD_PTA13__CMP0_OUT 0x0034 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA13__LLWU0_P2 0x0034 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA14__ADC1_CH8A 0x0038 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA14__PTA14 0x0038 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA14__LPSPI1_SCK 0x0038 0x012C 0x3 0x2 +#define IMX7ULP_PAD_PTA14__LPUART3_TX 0x0038 0x0224 0x4 0x2 +#define IMX7ULP_PAD_PTA14__LPI2C3_HREQ 0x0038 0x019C 0x5 0x2 +#define IMX7ULP_PAD_PTA14__TPM3_CH0 0x0038 0x0160 0x6 0x1 +#define IMX7ULP_PAD_PTA14__I2S0_MCLK 0x0038 0x01B4 0x7 0x2 +#define IMX7ULP_PAD_PTA14__LLWU0_P3 0x0038 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA15__ADC1_CH8B 0x003C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA15__PTA15 0x003C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA15__LPSPI1_PCS0 0x003C 0x011C 0x3 0x1 +#define IMX7ULP_PAD_PTA15__LPUART3_RX 0x003C 0x0220 0x4 0x1 +#define IMX7ULP_PAD_PTA15__TPM3_CH1 0x003C 0x0164 0x6 0x1 +#define IMX7ULP_PAD_PTA15__I2S0_TX_BCLK 0x003C 0x01C0 0x7 0x2 +#define IMX7ULP_PAD_PTA16__CMP1_IN5_3V 0x0040 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA16__PTA16 0x0040 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA16__FXIO0_D0 0x0040 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA16__LPSPI0_SOUT 0x0040 0x0118 0x3 0x2 +#define IMX7ULP_PAD_PTA16__LPUART0_CTS_B 0x0040 0x01F8 0x4 0x1 +#define IMX7ULP_PAD_PTA16__LPI2C0_SCL 0x0040 0x017C 0x5 0x1 +#define IMX7ULP_PAD_PTA16__TPM3_CH2 0x0040 0x0168 0x6 0x1 +#define IMX7ULP_PAD_PTA16__I2S0_TX_FS 0x0040 0x01C4 0x7 0x2 +#define IMX7ULP_PAD_PTA17__CMP1_IN6_3V 0x0044 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA17__PTA17 0x0044 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA17__FXIO0_D1 0x0044 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA17__LPSPI0_SCK 0x0044 0x0110 0x3 0x2 +#define IMX7ULP_PAD_PTA17__LPUART0_RTS_B 0x0044 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA17__LPI2C0_SDA 0x0044 0x0180 0x5 0x2 +#define IMX7ULP_PAD_PTA17__TPM3_CH3 0x0044 0x016C 0x6 0x1 +#define IMX7ULP_PAD_PTA17__I2S0_TXD0 0x0044 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA18__CMP1_IN1_3V 0x0048 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA18__PTA18 0x0048 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA18__FXIO0_D2 0x0048 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA18__LPSPI0_PCS0 0x0048 0x0100 0x3 0x2 +#define IMX7ULP_PAD_PTA18__LPUART0_TX 0x0048 0x0200 0x4 0x2 +#define IMX7ULP_PAD_PTA18__LPI2C0_HREQ 0x0048 0x0178 0x5 0x2 +#define IMX7ULP_PAD_PTA18__TPM3_CH4 0x0048 0x0170 0x6 0x1 +#define IMX7ULP_PAD_PTA18__I2S0_TXD1 0x0048 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA18__LLWU0_P4 0x0048 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA19__CMP1_IN3_3V 0x004C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA19__PTA19 0x004C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA19__FXIO0_D3 0x004C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA19__LPUART0_RX 0x004C 0x01FC 0x4 0x2 +#define IMX7ULP_PAD_PTA19__TPM3_CH5 0x004C 0x0174 0x6 0x1 +#define IMX7ULP_PAD_PTA19__I2S1_RX_BCLK 0x004C 0x01CC 0x7 0x1 +#define IMX7ULP_PAD_PTA19__LPTMR0_ALT3 0x004C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA19__LLWU0_P5 0x004C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA20__ADC0_CH10A 0x0050 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA20__PTA20 0x0050 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA20__FXIO0_D4 0x0050 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA20__LPSPI0_SIN 0x0050 0x0114 0x3 0x2 +#define IMX7ULP_PAD_PTA20__LPUART1_CTS_B 0x0050 0x0204 0x4 0x2 +#define IMX7ULP_PAD_PTA20__LPI2C1_SCL 0x0050 0x0188 0x5 0x2 +#define IMX7ULP_PAD_PTA20__TPM0_CLKIN 0x0050 0x01A8 0x6 0x1 +#define IMX7ULP_PAD_PTA20__I2S1_RX_FS 0x0050 0x01D0 0x7 0x1 +#define IMX7ULP_PAD_PTA21__ADC0_CH10B 0x0054 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA21__PTA21 0x0054 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA21__FXIO0_D5 0x0054 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA21__LPSPI0_PCS1 0x0054 0x0104 0x3 0x1 +#define IMX7ULP_PAD_PTA21__LPUART1_RTS_B 0x0054 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA21__LPI2C1_SDA 0x0054 0x018C 0x5 0x2 +#define IMX7ULP_PAD_PTA21__TPM0_CH0 0x0054 0x0138 0x6 0x2 +#define IMX7ULP_PAD_PTA21__I2S1_RXD0 0x0054 0x01E4 0x7 0x1 +#define IMX7ULP_PAD_PTA22__ADC0_CH9A 0x0058 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA22__PTA22 0x0058 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA22__FXIO0_D6 0x0058 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA22__LPSPI0_PCS2 0x0058 0x0108 0x3 0x2 +#define IMX7ULP_PAD_PTA22__LPUART1_TX 0x0058 0x020C 0x4 0x2 +#define IMX7ULP_PAD_PTA22__LPI2C1_HREQ 0x0058 0x0184 0x5 0x2 +#define IMX7ULP_PAD_PTA22__TPM0_CH1 0x0058 0x013C 0x6 0x2 +#define IMX7ULP_PAD_PTA22__I2S1_RXD1 0x0058 0x01E8 0x7 0x1 +#define IMX7ULP_PAD_PTA22__LPTMR0_ALT2 0x0058 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA22__EWM_OUT_B 0x0058 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTA23__ADC0_CH9B 0x005C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA23__PTA23 0x005C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA23__FXIO0_D7 0x005C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA23__LPSPI0_PCS3 0x005C 0x010C 0x3 0x2 +#define IMX7ULP_PAD_PTA23__LPUART1_RX 0x005C 0x0208 0x4 0x2 +#define IMX7ULP_PAD_PTA23__TPM0_CH2 0x005C 0x0140 0x6 0x2 +#define IMX7ULP_PAD_PTA23__I2S1_MCLK 0x005C 0x01C8 0x7 0x1 +#define IMX7ULP_PAD_PTA23__LLWU0_P6 0x005C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTA24__ADC0_CH8A 0x0060 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA24__PTA24 0x0060 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA24__FXIO0_D8 0x0060 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA24__LPSPI1_PCS1 0x0060 0x0120 0x3 0x2 +#define IMX7ULP_PAD_PTA24__LPUART2_CTS_B 0x0060 0x0210 0x4 0x2 +#define IMX7ULP_PAD_PTA24__LPI2C2_SCL 0x0060 0x0194 0x5 0x2 +#define IMX7ULP_PAD_PTA24__TPM0_CH3 0x0060 0x0144 0x6 0x2 +#define IMX7ULP_PAD_PTA24__I2S1_TX_BCLK 0x0060 0x01D4 0x7 0x1 +#define IMX7ULP_PAD_PTA25__ADC0_CH8B 0x0064 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA25__PTA25 0x0064 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA25__FXIO0_D9 0x0064 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA25__LPSPI1_PCS2 0x0064 0x0124 0x3 0x2 +#define IMX7ULP_PAD_PTA25__LPUART2_RTS_B 0x0064 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA25__LPI2C2_SDA 0x0064 0x0198 0x5 0x2 +#define IMX7ULP_PAD_PTA25__TPM0_CH4 0x0064 0x0148 0x6 0x2 +#define IMX7ULP_PAD_PTA25__I2S1_TX_FS 0x0064 0x01D8 0x7 0x1 +#define IMX7ULP_PAD_PTA26__PTA26 0x0068 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA26__JTAG_TMS_SWD_DIO 0x0068 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTA26__FXIO0_D10 0x0068 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA26__LPSPI1_PCS3 0x0068 0x0128 0x3 0x2 +#define IMX7ULP_PAD_PTA26__LPUART2_TX 0x0068 0x0218 0x4 0x2 +#define IMX7ULP_PAD_PTA26__LPI2C2_HREQ 0x0068 0x0190 0x5 0x2 +#define IMX7ULP_PAD_PTA26__TPM0_CH5 0x0068 0x014C 0x6 0x2 +#define IMX7ULP_PAD_PTA26__I2S1_RXD2 0x0068 0x01EC 0x7 0x1 +#define IMX7ULP_PAD_PTA27__PTA27 0x006C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA27__JTAG_TDO 0x006C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTA27__FXIO0_D11 0x006C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA27__LPUART2_RX 0x006C 0x0214 0x4 0x2 +#define IMX7ULP_PAD_PTA27__TPM1_CH1 0x006C 0x0154 0x6 0x2 +#define IMX7ULP_PAD_PTA27__I2S1_RXD3 0x006C 0x01F0 0x7 0x1 +#define IMX7ULP_PAD_PTA28__PTA28 0x0070 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA28__JTAG_TDI 0x0070 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTA28__FXIO0_D12 0x0070 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA28__LPSPI1_SIN 0x0070 0x0130 0x3 0x2 +#define IMX7ULP_PAD_PTA28__LPUART3_CTS_B 0x0070 0x021C 0x4 0x2 +#define IMX7ULP_PAD_PTA28__LPI2C3_SCL 0x0070 0x01A0 0x5 0x2 +#define IMX7ULP_PAD_PTA28__TPM1_CLKIN 0x0070 0x01AC 0x6 0x2 +#define IMX7ULP_PAD_PTA28__I2S1_TXD2 0x0070 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA29__PTA29 0x0074 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA29__JTAG_TCLK_SWD_CLK 0x0074 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTA29__FXIO0_D13 0x0074 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA29__LPSPI1_SOUT 0x0074 0x0134 0x3 0x1 +#define IMX7ULP_PAD_PTA29__LPUART3_RTS_B 0x0074 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTA29__LPI2C3_SDA 0x0074 0x01A4 0x5 0x1 +#define IMX7ULP_PAD_PTA29__TPM1_CH0 0x0074 0x0150 0x6 0x2 +#define IMX7ULP_PAD_PTA29__I2S1_TXD3 0x0074 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA30__ADC0_CH1A 0x0078 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA30__PTA30 0x0078 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA30__FXIO0_D14 0x0078 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA30__LPSPI1_SCK 0x0078 0x012C 0x3 0x1 +#define IMX7ULP_PAD_PTA30__LPUART3_TX 0x0078 0x0224 0x4 0x1 +#define IMX7ULP_PAD_PTA30__LPI2C3_HREQ 0x0078 0x019C 0x5 0x1 +#define IMX7ULP_PAD_PTA30__TPM2_CLKIN 0x0078 0x01F4 0x6 0x2 +#define IMX7ULP_PAD_PTA30__I2S1_TXD0 0x0078 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA30__JTAG_TRST_B 0x0078 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTA31__ADC0_CH1B 0x007C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTA31__PTA31 0x007C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTA31__FXIO0_D15 0x007C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTA31__LPSPI1_PCS0 0x007C 0x011C 0x3 0x2 +#define IMX7ULP_PAD_PTA31__LPUART3_RX 0x007C 0x0220 0x4 0x2 +#define IMX7ULP_PAD_PTA31__TPM2_CH0 0x007C 0x0158 0x6 0x2 +#define IMX7ULP_PAD_PTA31__I2S1_TXD1 0x007C 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTA31__LPTMR0_ALT1 0x007C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTA31__EWM_IN 0x007C 0x0228 0xc 0x1 +#define IMX7ULP_PAD_PTA31__LLWU0_P7 0x007C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB0__ADC0_CH0A 0x0080 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB0__PTB0 0x0080 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB0__FXIO0_D16 0x0080 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB0__LPSPI0_SIN 0x0080 0x0114 0x3 0x3 +#define IMX7ULP_PAD_PTB0__LPUART0_TX 0x0080 0x0200 0x4 0x3 +#define IMX7ULP_PAD_PTB0__TPM2_CH1 0x0080 0x015C 0x6 0x2 +#define IMX7ULP_PAD_PTB0__CLKOUT0 0x0080 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTB0__CMP1_OUT 0x0080 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB0__EWM_OUT_B 0x0080 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTB1__ADC0_CH0B 0x0084 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB1__PTB1 0x0084 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB1__FXIO0_D17 0x0084 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB1__LPSPI0_SOUT 0x0084 0x0118 0x3 0x3 +#define IMX7ULP_PAD_PTB1__LPUART0_RX 0x0084 0x01FC 0x4 0x3 +#define IMX7ULP_PAD_PTB1__TPM3_CLKIN 0x0084 0x01B0 0x6 0x3 +#define IMX7ULP_PAD_PTB1__I2S1_TX_BCLK 0x0084 0x01D4 0x7 0x2 +#define IMX7ULP_PAD_PTB1__RTC_CLKOUT 0x0084 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB1__EWM_IN 0x0084 0x0228 0xc 0x2 +#define IMX7ULP_PAD_PTB1__LLWU0_P8 0x0084 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB2__ADC0_CH6A 0x0088 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB2__PTB2 0x0088 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB2__FXIO0_D18 0x0088 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB2__LPSPI0_SCK 0x0088 0x0110 0x3 0x3 +#define IMX7ULP_PAD_PTB2__LPUART1_TX 0x0088 0x020C 0x4 0x3 +#define IMX7ULP_PAD_PTB2__TPM3_CH0 0x0088 0x0160 0x6 0x2 +#define IMX7ULP_PAD_PTB2__I2S1_TX_FS 0x0088 0x01D8 0x7 0x2 +#define IMX7ULP_PAD_PTB2__TRACE_CLKOUT 0x0088 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB3__ADC0_CH6B 0x008C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB3__PTB3 0x008C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB3__FXIO0_D19 0x008C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB3__LPSPI0_PCS0 0x008C 0x0100 0x3 0x3 +#define IMX7ULP_PAD_PTB3__LPUART1_RX 0x008C 0x0208 0x4 0x3 +#define IMX7ULP_PAD_PTB3__TPM3_CH1 0x008C 0x0164 0x6 0x2 +#define IMX7ULP_PAD_PTB3__I2S1_TXD0 0x008C 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTB3__TRACE_D0 0x008C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB3__LPTMR1_ALT2 0x008C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB3__LLWU0_P9 0x008C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB4__PTB4 0x0090 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB4__FXIO0_D20 0x0090 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB4__LPSPI0_PCS1 0x0090 0x0104 0x3 0x3 +#define IMX7ULP_PAD_PTB4__LPUART2_TX 0x0090 0x0218 0x4 0x3 +#define IMX7ULP_PAD_PTB4__LPI2C0_HREQ 0x0090 0x0178 0x5 0x3 +#define IMX7ULP_PAD_PTB4__TPM3_CH2 0x0090 0x0168 0x6 0x2 +#define IMX7ULP_PAD_PTB4__I2S1_TXD1 0x0090 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTB4__QSPIA_DATA7 0x0090 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB4__TRACE_D1 0x0090 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB4__SEC_VIO_B 0x0090 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB5__PTB5 0x0094 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB5__FXIO0_D21 0x0094 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB5__LPSPI0_PCS2 0x0094 0x0108 0x3 0x3 +#define IMX7ULP_PAD_PTB5__LPUART2_RX 0x0094 0x0214 0x4 0x3 +#define IMX7ULP_PAD_PTB5__LPI2C1_HREQ 0x0094 0x0184 0x5 0x3 +#define IMX7ULP_PAD_PTB5__TPM3_CH3 0x0094 0x016C 0x6 0x2 +#define IMX7ULP_PAD_PTB5__I2S1_TXD2 0x0094 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTB5__QSPIA_DATA6 0x0094 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB5__TRACE_D2 0x0094 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB5__RTC_CLKOUT 0x0094 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB6__ADC1_CH1A 0x0098 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB6__PTB6 0x0098 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB6__FXIO0_D22 0x0098 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB6__LPSPI0_PCS3 0x0098 0x010C 0x3 0x3 +#define IMX7ULP_PAD_PTB6__LPUART3_TX 0x0098 0x0224 0x4 0x3 +#define IMX7ULP_PAD_PTB6__LPI2C0_SCL 0x0098 0x017C 0x5 0x3 +#define IMX7ULP_PAD_PTB6__TPM3_CH4 0x0098 0x0170 0x6 0x2 +#define IMX7ULP_PAD_PTB6__I2S1_TXD3 0x0098 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTB6__QSPIA_DATA5 0x0098 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB6__TRACE_D3 0x0098 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB6__LPTMR1_ALT3 0x0098 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB6__LLWU0_P10 0x0098 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB7__ADC1_CH1B 0x009C 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB7__PTB7 0x009C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB7__FXIO0_D23 0x009C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB7__LPSPI1_SIN 0x009C 0x0130 0x3 0x3 +#define IMX7ULP_PAD_PTB7__LPUART3_RX 0x009C 0x0220 0x4 0x3 +#define IMX7ULP_PAD_PTB7__LPI2C0_SDA 0x009C 0x0180 0x5 0x3 +#define IMX7ULP_PAD_PTB7__TPM3_CH5 0x009C 0x0174 0x6 0x2 +#define IMX7ULP_PAD_PTB7__I2S1_MCLK 0x009C 0x01C8 0x7 0x2 +#define IMX7ULP_PAD_PTB7__QSPIA_SS1_B 0x009C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB7__CMP1_OUT 0x009C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB7__LLWU0_P11 0x009C 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB8__ADC0_CH14A_CMP0_IN0 0x00A0 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB8__PTB8 0x00A0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB8__FXIO0_D24 0x00A0 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB8__LPSPI1_SOUT 0x00A0 0x0134 0x3 0x3 +#define IMX7ULP_PAD_PTB8__LPI2C1_SCL 0x00A0 0x0188 0x5 0x3 +#define IMX7ULP_PAD_PTB8__TPM0_CLKIN 0x00A0 0x01A8 0x6 0x3 +#define IMX7ULP_PAD_PTB8__I2S1_RX_BCLK 0x00A0 0x01CC 0x7 0x2 +#define IMX7ULP_PAD_PTB8__QSPIA_SS0_B 0x00A0 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB8__RTC_CLKOUT 0x00A0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB9__ADC0_CH14B_CMP0_IN2 0x00A4 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB9__PTB9 0x00A4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB9__FXIO0_D25 0x00A4 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB9__LPSPI1_SCK 0x00A4 0x012C 0x3 0x3 +#define IMX7ULP_PAD_PTB9__LPI2C1_SDA 0x00A4 0x018C 0x5 0x3 +#define IMX7ULP_PAD_PTB9__TPM0_CH0 0x00A4 0x0138 0x6 0x3 +#define IMX7ULP_PAD_PTB9__I2S1_RX_FS 0x00A4 0x01D0 0x7 0x2 +#define IMX7ULP_PAD_PTB9__QSPIA_DQS 0x00A4 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB9__LLWU0_P12 0x00A4 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB10__CMP0_IN1 0x00A8 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB10__PTB10 0x00A8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB10__FXIO0_D26 0x00A8 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB10__LPSPI1_PCS0 0x00A8 0x011C 0x3 0x3 +#define IMX7ULP_PAD_PTB10__LPI2C2_SCL 0x00A8 0x0194 0x5 0x3 +#define IMX7ULP_PAD_PTB10__TPM0_CH1 0x00A8 0x013C 0x6 0x3 +#define IMX7ULP_PAD_PTB10__I2S1_RXD0 0x00A8 0x01E4 0x7 0x2 +#define IMX7ULP_PAD_PTB10__TRACE_D4 0x00A8 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB11__CMP0_IN3 0x00AC 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB11__PTB11 0x00AC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB11__FXIO0_D27 0x00AC 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB11__LPSPI1_PCS1 0x00AC 0x0120 0x3 0x3 +#define IMX7ULP_PAD_PTB11__LPI2C2_SDA 0x00AC 0x0198 0x5 0x3 +#define IMX7ULP_PAD_PTB11__TPM1_CLKIN 0x00AC 0x01AC 0x6 0x3 +#define IMX7ULP_PAD_PTB11__I2S1_RXD1 0x00AC 0x01E8 0x7 0x2 +#define IMX7ULP_PAD_PTB11__TRACE_D5 0x00AC 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB12__ADC1_CH13A_CMP1_IN0 0x00B0 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB12__PTB12 0x00B0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB12__FXIO0_D28 0x00B0 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB12__LPSPI1_PCS2 0x00B0 0x0124 0x3 0x3 +#define IMX7ULP_PAD_PTB12__LPUART2_TX 0x00B0 0x0218 0x4 0x4 +#define IMX7ULP_PAD_PTB12__LPI2C3_SCL 0x00B0 0x01A0 0x5 0x3 +#define IMX7ULP_PAD_PTB12__TPM1_CH0 0x00B0 0x0150 0x6 0x3 +#define IMX7ULP_PAD_PTB12__I2S1_RXD2 0x00B0 0x01EC 0x7 0x2 +#define IMX7ULP_PAD_PTB12__TRACE_D6 0x00B0 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB13__ADC1_CH13B_CMP1_IN1 0x00B4 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB13__PTB13 0x00B4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB13__FXIO0_D29 0x00B4 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB13__LPSPI1_PCS3 0x00B4 0x0128 0x3 0x3 +#define IMX7ULP_PAD_PTB13__LPUART2_RX 0x00B4 0x0214 0x4 0x4 +#define IMX7ULP_PAD_PTB13__LPI2C3_SDA 0x00B4 0x01A4 0x5 0x3 +#define IMX7ULP_PAD_PTB13__TPM1_CH1 0x00B4 0x0154 0x6 0x3 +#define IMX7ULP_PAD_PTB13__I2S1_RXD3 0x00B4 0x01F0 0x7 0x2 +#define IMX7ULP_PAD_PTB13__QSPIA_DATA4 0x00B4 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB13__TRACE_D7 0x00B4 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTB14__ADC1_CH2A 0x00B8 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB14__PTB14 0x00B8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB14__FXIO0_D30 0x00B8 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB14__LPI2C2_HREQ 0x00B8 0x0190 0x5 0x3 +#define IMX7ULP_PAD_PTB14__TPM2_CLKIN 0x00B8 0x01F4 0x6 0x3 +#define IMX7ULP_PAD_PTB14__QSPIA_SS1_B 0x00B8 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB14__QSPIA_SCLK_B 0x00B8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTB14__RTC_CLKOUT 0x00B8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTB14__LLWU0_P13 0x00B8 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB15__ADC1_CH2B 0x00BC 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB15__PTB15 0x00BC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB15__FXIO0_D31 0x00BC 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTB15__LPI2C3_HREQ 0x00BC 0x019C 0x5 0x3 +#define IMX7ULP_PAD_PTB15__TPM2_CH0 0x00BC 0x0158 0x6 0x3 +#define IMX7ULP_PAD_PTB15__QSPIA_SCLK 0x00BC 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB16__ADC0_CH4A 0x00C0 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB16__PTB16 0x00C0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB16__TPM2_CH1 0x00C0 0x015C 0x6 0x3 +#define IMX7ULP_PAD_PTB16__QSPIA_DATA3 0x00C0 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB16__LLWU0_P14 0x00C0 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTB17__ADC0_CH4B 0x00C4 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB17__PTB17 0x00C4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB17__TPM3_CLKIN 0x00C4 0x01B0 0x6 0x2 +#define IMX7ULP_PAD_PTB17__QSPIA_DATA2 0x00C4 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB18__ADC0_CH5A 0x00C8 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB18__PTB18 0x00C8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB18__TPM3_CH0 0x00C8 0x0160 0x6 0x3 +#define IMX7ULP_PAD_PTB18__QSPIA_DATA1 0x00C8 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB19__ADC0_CH5B 0x00CC 0x0000 0x0 0x0 +#define IMX7ULP_PAD_PTB19__PTB19 0x00CC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTB19__TPM3_CH1 0x00CC 0x0164 0x6 0x3 +#define IMX7ULP_PAD_PTB19__QSPIA_DATA0 0x00CC 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTB19__USB0_ID 0x00CC 0x0338 0xa 0x0 +#define IMX7ULP_PAD_PTB19__LLWU0_P15 0x00CC 0x0000 0xd 0x0 +#define IMX7ULP_PAD_PTC0__PTC0 0x0000 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC0__LPUART4_CTS_B 0x0000 0x0244 0x4 0x1 +#define IMX7ULP_PAD_PTC0__LPI2C4_SCL 0x0000 0x0278 0x5 0x1 +#define IMX7ULP_PAD_PTC0__TPM4_CLKIN 0x0000 0x0298 0x6 0x1 +#define IMX7ULP_PAD_PTC0__FB_AD0 0x0000 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC0__TRACE_D15 0x0000 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC1__PTC1 0x0004 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC1__LPUART4_RTS_B 0x0004 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTC1__LPI2C4_SDA 0x0004 0x027C 0x5 0x1 +#define IMX7ULP_PAD_PTC1__TPM4_CH0 0x0004 0x0280 0x6 0x1 +#define IMX7ULP_PAD_PTC1__FB_AD1 0x0004 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC1__TRACE_D14 0x0004 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC2__PTC2 0x0008 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC2__LPUART4_TX 0x0008 0x024C 0x4 0x1 +#define IMX7ULP_PAD_PTC2__LPI2C4_HREQ 0x0008 0x0274 0x5 0x1 +#define IMX7ULP_PAD_PTC2__TPM4_CH1 0x0008 0x0284 0x6 0x1 +#define IMX7ULP_PAD_PTC2__FB_AD2 0x0008 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC2__TRACE_D13 0x0008 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC3__PTC3 0x000C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC3__LPUART4_RX 0x000C 0x0248 0x4 0x1 +#define IMX7ULP_PAD_PTC3__TPM4_CH2 0x000C 0x0288 0x6 0x1 +#define IMX7ULP_PAD_PTC3__FB_AD3 0x000C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC3__TRACE_D12 0x000C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC4__PTC4 0x0010 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC4__FXIO1_D0 0x0010 0x0204 0x2 0x1 +#define IMX7ULP_PAD_PTC4__LPSPI2_PCS1 0x0010 0x02A0 0x3 0x1 +#define IMX7ULP_PAD_PTC4__LPUART5_CTS_B 0x0010 0x0250 0x4 0x1 +#define IMX7ULP_PAD_PTC4__LPI2C5_SCL 0x0010 0x02BC 0x5 0x1 +#define IMX7ULP_PAD_PTC4__TPM4_CH3 0x0010 0x028C 0x6 0x1 +#define IMX7ULP_PAD_PTC4__FB_AD4 0x0010 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC4__TRACE_D11 0x0010 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC5__PTC5 0x0014 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC5__FXIO1_D1 0x0014 0x0208 0x2 0x1 +#define IMX7ULP_PAD_PTC5__LPSPI2_PCS2 0x0014 0x02A4 0x3 0x1 +#define IMX7ULP_PAD_PTC5__LPUART5_RTS_B 0x0014 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTC5__LPI2C5_SDA 0x0014 0x02C0 0x5 0x1 +#define IMX7ULP_PAD_PTC5__TPM4_CH4 0x0014 0x0290 0x6 0x1 +#define IMX7ULP_PAD_PTC5__FB_AD5 0x0014 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC5__TRACE_D10 0x0014 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC6__PTC6 0x0018 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC6__FXIO1_D2 0x0018 0x020C 0x2 0x1 +#define IMX7ULP_PAD_PTC6__LPSPI2_PCS3 0x0018 0x02A8 0x3 0x1 +#define IMX7ULP_PAD_PTC6__LPUART5_TX 0x0018 0x0258 0x4 0x1 +#define IMX7ULP_PAD_PTC6__LPI2C5_HREQ 0x0018 0x02B8 0x5 0x1 +#define IMX7ULP_PAD_PTC6__TPM4_CH5 0x0018 0x0294 0x6 0x1 +#define IMX7ULP_PAD_PTC6__FB_AD6 0x0018 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC6__TRACE_D9 0x0018 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC7__PTC7 0x001C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC7__FXIO1_D3 0x001C 0x0210 0x2 0x1 +#define IMX7ULP_PAD_PTC7__LPUART5_RX 0x001C 0x0254 0x4 0x1 +#define IMX7ULP_PAD_PTC7__TPM5_CH1 0x001C 0x02C8 0x6 0x1 +#define IMX7ULP_PAD_PTC7__FB_AD7 0x001C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC7__TRACE_D8 0x001C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC8__PTC8 0x0020 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC8__FXIO1_D4 0x0020 0x0214 0x2 0x1 +#define IMX7ULP_PAD_PTC8__LPSPI2_SIN 0x0020 0x02B0 0x3 0x1 +#define IMX7ULP_PAD_PTC8__LPUART6_CTS_B 0x0020 0x025C 0x4 0x1 +#define IMX7ULP_PAD_PTC8__LPI2C6_SCL 0x0020 0x02FC 0x5 0x1 +#define IMX7ULP_PAD_PTC8__TPM5_CLKIN 0x0020 0x02CC 0x6 0x1 +#define IMX7ULP_PAD_PTC8__FB_AD8 0x0020 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC8__TRACE_D7 0x0020 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC9__PTC9 0x0024 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC9__FXIO1_D5 0x0024 0x0218 0x2 0x1 +#define IMX7ULP_PAD_PTC9__LPSPI2_SOUT 0x0024 0x02B4 0x3 0x1 +#define IMX7ULP_PAD_PTC9__LPUART6_RTS_B 0x0024 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTC9__LPI2C6_SDA 0x0024 0x0300 0x5 0x1 +#define IMX7ULP_PAD_PTC9__TPM5_CH0 0x0024 0x02C4 0x6 0x1 +#define IMX7ULP_PAD_PTC9__FB_AD9 0x0024 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC9__TRACE_D6 0x0024 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC10__PTC10 0x0028 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC10__FXIO1_D6 0x0028 0x021C 0x2 0x1 +#define IMX7ULP_PAD_PTC10__LPSPI2_SCK 0x0028 0x02AC 0x3 0x1 +#define IMX7ULP_PAD_PTC10__LPUART6_TX 0x0028 0x0264 0x4 0x1 +#define IMX7ULP_PAD_PTC10__LPI2C6_HREQ 0x0028 0x02F8 0x5 0x1 +#define IMX7ULP_PAD_PTC10__TPM7_CH3 0x0028 0x02E8 0x6 0x1 +#define IMX7ULP_PAD_PTC10__FB_AD10 0x0028 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC10__TRACE_D5 0x0028 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC11__PTC11 0x002C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC11__FXIO1_D7 0x002C 0x0220 0x2 0x1 +#define IMX7ULP_PAD_PTC11__LPSPI2_PCS0 0x002C 0x029C 0x3 0x1 +#define IMX7ULP_PAD_PTC11__LPUART6_RX 0x002C 0x0260 0x4 0x1 +#define IMX7ULP_PAD_PTC11__TPM7_CH4 0x002C 0x02EC 0x6 0x1 +#define IMX7ULP_PAD_PTC11__FB_AD11 0x002C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC11__TRACE_D4 0x002C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC12__PTC12 0x0030 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC12__FXIO1_D8 0x0030 0x0224 0x2 0x1 +#define IMX7ULP_PAD_PTC12__LPSPI3_PCS1 0x0030 0x0314 0x3 0x1 +#define IMX7ULP_PAD_PTC12__LPUART7_CTS_B 0x0030 0x0268 0x4 0x1 +#define IMX7ULP_PAD_PTC12__LPI2C7_SCL 0x0030 0x0308 0x5 0x1 +#define IMX7ULP_PAD_PTC12__TPM7_CH5 0x0030 0x02F0 0x6 0x1 +#define IMX7ULP_PAD_PTC12__FB_AD12 0x0030 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC12__TRACE_D3 0x0030 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC13__PTC13 0x0034 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC13__FXIO1_D9 0x0034 0x0228 0x2 0x1 +#define IMX7ULP_PAD_PTC13__LPSPI3_PCS2 0x0034 0x0318 0x3 0x1 +#define IMX7ULP_PAD_PTC13__LPUART7_RTS_B 0x0034 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTC13__LPI2C7_SDA 0x0034 0x030C 0x5 0x1 +#define IMX7ULP_PAD_PTC13__TPM7_CLKIN 0x0034 0x02F4 0x6 0x1 +#define IMX7ULP_PAD_PTC13__FB_AD13 0x0034 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC13__TRACE_D2 0x0034 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC13__USB0_ID 0x0034 0x0338 0xb 0x1 +#define IMX7ULP_PAD_PTC14__PTC14 0x0038 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC14__FXIO1_D10 0x0038 0x022C 0x2 0x1 +#define IMX7ULP_PAD_PTC14__LPSPI3_PCS3 0x0038 0x031C 0x3 0x1 +#define IMX7ULP_PAD_PTC14__LPUART7_TX 0x0038 0x0270 0x4 0x1 +#define IMX7ULP_PAD_PTC14__LPI2C7_HREQ 0x0038 0x0304 0x5 0x1 +#define IMX7ULP_PAD_PTC14__TPM7_CH0 0x0038 0x02DC 0x6 0x1 +#define IMX7ULP_PAD_PTC14__FB_AD14 0x0038 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC14__TRACE_D1 0x0038 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC15__PTC15 0x003C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC15__FXIO1_D11 0x003C 0x0230 0x2 0x1 +#define IMX7ULP_PAD_PTC15__LPUART7_RX 0x003C 0x026C 0x4 0x1 +#define IMX7ULP_PAD_PTC15__TPM7_CH1 0x003C 0x02E0 0x6 0x1 +#define IMX7ULP_PAD_PTC15__FB_AD15 0x003C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC15__TRACE_D0 0x003C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC16__PTC16 0x0040 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC16__FXIO1_D12 0x0040 0x0234 0x2 0x1 +#define IMX7ULP_PAD_PTC16__LPSPI3_SIN 0x0040 0x0324 0x3 0x1 +#define IMX7ULP_PAD_PTC16__TPM7_CH2 0x0040 0x02E4 0x6 0x1 +#define IMX7ULP_PAD_PTC16__FB_ALE_FB_CS1_B_FB_TS_B 0x0040 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC16__TRACE_CLKOUT 0x0040 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTC16__USB1_OC2 0x0040 0x0334 0xb 0x1 +#define IMX7ULP_PAD_PTC17__PTC17 0x0044 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC17__FXIO1_D13 0x0044 0x0238 0x2 0x1 +#define IMX7ULP_PAD_PTC17__LPSPI3_SOUT 0x0044 0x0328 0x3 0x1 +#define IMX7ULP_PAD_PTC17__TPM6_CLKIN 0x0044 0x02D8 0x6 0x1 +#define IMX7ULP_PAD_PTC17__FB_CS0_B 0x0044 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC18__PTC18 0x0048 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC18__FXIO1_D14 0x0048 0x023C 0x2 0x1 +#define IMX7ULP_PAD_PTC18__LPSPI3_SCK 0x0048 0x0320 0x3 0x1 +#define IMX7ULP_PAD_PTC18__TPM6_CH0 0x0048 0x02D0 0x6 0x1 +#define IMX7ULP_PAD_PTC18__FB_OE_B 0x0048 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC18__USB0_ID 0x0048 0x0338 0xb 0x2 +#define IMX7ULP_PAD_PTC18__VIU_DE 0x0048 0x033C 0xc 0x1 +#define IMX7ULP_PAD_PTC19__PTC19 0x004C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTC19__FXIO1_D15 0x004C 0x0240 0x2 0x1 +#define IMX7ULP_PAD_PTC19__LPSPI3_PCS0 0x004C 0x0310 0x3 0x1 +#define IMX7ULP_PAD_PTC19__TPM6_CH1 0x004C 0x02D4 0x6 0x1 +#define IMX7ULP_PAD_PTC19__FB_A16 0x004C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTC19__USB0_ID 0x004C 0x0338 0xa 0x3 +#define IMX7ULP_PAD_PTC19__USB1_PWR2 0x004C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTC19__VIU_DE 0x004C 0x033C 0xc 0x3 +#define IMX7ULP_PAD_PTD0__PTD0 0x0080 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD0__SDHC0_RESET_B 0x0080 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD1__PTD1 0x0084 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD1__SDHC0_CMD 0x0084 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD2__PTD2 0x0088 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD2__SDHC0_CLK 0x0088 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD3__PTD3 0x008C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD3__SDHC0_D7 0x008C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD4__PTD4 0x0090 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD4__SDHC0_D6 0x0090 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD5__PTD5 0x0094 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD5__SDHC0_D5 0x0094 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD6__PTD6 0x0098 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD6__SDHC0_D4 0x0098 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD7__PTD7 0x009C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD7__SDHC0_D3 0x009C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD8__PTD8 0x00A0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD8__TPM4_CLKIN 0x00A0 0x0298 0x6 0x2 +#define IMX7ULP_PAD_PTD8__SDHC0_D2 0x00A0 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD9__PTD9 0x00A4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD9__TPM4_CH0 0x00A4 0x0280 0x6 0x2 +#define IMX7ULP_PAD_PTD9__SDHC0_D1 0x00A4 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD10__PTD10 0x00A8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD10__TPM4_CH1 0x00A8 0x0284 0x6 0x2 +#define IMX7ULP_PAD_PTD10__SDHC0_D0 0x00A8 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTD11__PTD11 0x00AC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTD11__TPM4_CH2 0x00AC 0x0288 0x6 0x2 +#define IMX7ULP_PAD_PTD11__SDHC0_DQS 0x00AC 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE0__PTE0 0x0100 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE0__FXIO1_D31 0x0100 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE0__LPSPI2_PCS1 0x0100 0x02A0 0x3 0x2 +#define IMX7ULP_PAD_PTE0__LPUART4_CTS_B 0x0100 0x0244 0x4 0x2 +#define IMX7ULP_PAD_PTE0__LPI2C4_SCL 0x0100 0x0278 0x5 0x2 +#define IMX7ULP_PAD_PTE0__SDHC1_D1 0x0100 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE0__FB_A25 0x0100 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE1__PTE1 0x0104 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE1__FXIO1_D30 0x0104 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE1__LPSPI2_PCS2 0x0104 0x02A4 0x3 0x2 +#define IMX7ULP_PAD_PTE1__LPUART4_RTS_B 0x0104 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTE1__LPI2C4_SDA 0x0104 0x027C 0x5 0x2 +#define IMX7ULP_PAD_PTE1__SDHC1_D0 0x0104 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE1__FB_A26 0x0104 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE2__PTE2 0x0108 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE2__FXIO1_D29 0x0108 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE2__LPSPI2_PCS3 0x0108 0x02A8 0x3 0x2 +#define IMX7ULP_PAD_PTE2__LPUART4_TX 0x0108 0x024C 0x4 0x2 +#define IMX7ULP_PAD_PTE2__LPI2C4_HREQ 0x0108 0x0274 0x5 0x2 +#define IMX7ULP_PAD_PTE2__SDHC1_CLK 0x0108 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE3__PTE3 0x010C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE3__FXIO1_D28 0x010C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE3__LPUART4_RX 0x010C 0x0248 0x4 0x2 +#define IMX7ULP_PAD_PTE3__TPM5_CH1 0x010C 0x02C8 0x6 0x2 +#define IMX7ULP_PAD_PTE3__SDHC1_CMD 0x010C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE4__PTE4 0x0110 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE4__FXIO1_D27 0x0110 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE4__LPSPI2_SIN 0x0110 0x02B0 0x3 0x2 +#define IMX7ULP_PAD_PTE4__LPUART5_CTS_B 0x0110 0x0250 0x4 0x2 +#define IMX7ULP_PAD_PTE4__LPI2C5_SCL 0x0110 0x02BC 0x5 0x2 +#define IMX7ULP_PAD_PTE4__TPM5_CLKIN 0x0110 0x02CC 0x6 0x2 +#define IMX7ULP_PAD_PTE4__SDHC1_D3 0x0110 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE5__PTE5 0x0114 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE5__FXIO1_D26 0x0114 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE5__LPSPI2_SOUT 0x0114 0x02B4 0x3 0x2 +#define IMX7ULP_PAD_PTE5__LPUART5_RTS_B 0x0114 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTE5__LPI2C5_SDA 0x0114 0x02C0 0x5 0x2 +#define IMX7ULP_PAD_PTE5__TPM5_CH0 0x0114 0x02C4 0x6 0x2 +#define IMX7ULP_PAD_PTE5__SDHC1_D2 0x0114 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE5__VIU_DE 0x0114 0x033C 0xc 0x2 +#define IMX7ULP_PAD_PTE6__PTE6 0x0118 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE6__FXIO1_D25 0x0118 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE6__LPSPI2_SCK 0x0118 0x02AC 0x3 0x2 +#define IMX7ULP_PAD_PTE6__LPUART5_TX 0x0118 0x0258 0x4 0x2 +#define IMX7ULP_PAD_PTE6__LPI2C5_HREQ 0x0118 0x02B8 0x5 0x2 +#define IMX7ULP_PAD_PTE6__TPM7_CH3 0x0118 0x02E8 0x6 0x2 +#define IMX7ULP_PAD_PTE6__SDHC1_D4 0x0118 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE6__FB_A17 0x0118 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE6__USB0_OC 0x0118 0x0330 0xb 0x1 +#define IMX7ULP_PAD_PTE7__PTE7 0x011C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE7__FXIO1_D24 0x011C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE7__LPSPI2_PCS0 0x011C 0x029C 0x3 0x2 +#define IMX7ULP_PAD_PTE7__LPUART5_RX 0x011C 0x0254 0x4 0x2 +#define IMX7ULP_PAD_PTE7__TPM7_CH4 0x011C 0x02EC 0x6 0x2 +#define IMX7ULP_PAD_PTE7__SDHC1_D5 0x011C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE7__FB_A18 0x011C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE7__TRACE_D7 0x011C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE7__USB0_PWR 0x011C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE7__VIU_FID 0x011C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE8__PTE8 0x0120 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE8__TRACE_D6 0x0120 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE8__VIU_D16 0x0120 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE8__FXIO1_D23 0x0120 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE8__LPSPI3_PCS1 0x0120 0x0314 0x3 0x2 +#define IMX7ULP_PAD_PTE8__LPUART6_CTS_B 0x0120 0x025C 0x4 0x2 +#define IMX7ULP_PAD_PTE8__LPI2C6_SCL 0x0120 0x02FC 0x5 0x2 +#define IMX7ULP_PAD_PTE8__TPM7_CH5 0x0120 0x02F0 0x6 0x2 +#define IMX7ULP_PAD_PTE8__SDHC1_WP 0x0120 0x0200 0x7 0x1 +#define IMX7ULP_PAD_PTE8__SDHC1_D6 0x0120 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE8__FB_CS3_B_FB_BE7_0_BLS31_24_B 0x0120 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE9__PTE9 0x0124 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE9__TRACE_D5 0x0124 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE9__VIU_D17 0x0124 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE9__FXIO1_D22 0x0124 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE9__LPSPI3_PCS2 0x0124 0x0318 0x3 0x2 +#define IMX7ULP_PAD_PTE9__LPUART6_RTS_B 0x0124 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTE9__LPI2C6_SDA 0x0124 0x0300 0x5 0x2 +#define IMX7ULP_PAD_PTE9__TPM7_CLKIN 0x0124 0x02F4 0x6 0x2 +#define IMX7ULP_PAD_PTE9__SDHC1_CD 0x0124 0x032C 0x7 0x1 +#define IMX7ULP_PAD_PTE9__SDHC1_D7 0x0124 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE9__FB_TBST_B_FB_CS2_B_FB_BE15_8_BLS23_16_B 0x0124 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE10__PTE10 0x0128 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE10__TRACE_D4 0x0128 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE10__VIU_D18 0x0128 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE10__FXIO1_D21 0x0128 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE10__LPSPI3_PCS3 0x0128 0x031C 0x3 0x2 +#define IMX7ULP_PAD_PTE10__LPUART6_TX 0x0128 0x0264 0x4 0x2 +#define IMX7ULP_PAD_PTE10__LPI2C6_HREQ 0x0128 0x02F8 0x5 0x2 +#define IMX7ULP_PAD_PTE10__TPM7_CH0 0x0128 0x02DC 0x6 0x2 +#define IMX7ULP_PAD_PTE10__SDHC1_VS 0x0128 0x0000 0x7 0x0 +#define IMX7ULP_PAD_PTE10__SDHC1_DQS 0x0128 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE10__FB_A19 0x0128 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE11__PTE11 0x012C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE11__TRACE_D3 0x012C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE11__VIU_D19 0x012C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE11__FXIO1_D20 0x012C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE11__LPUART6_RX 0x012C 0x0260 0x4 0x2 +#define IMX7ULP_PAD_PTE11__TPM7_CH1 0x012C 0x02E0 0x6 0x2 +#define IMX7ULP_PAD_PTE11__SDHC1_RESET_B 0x012C 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE11__FB_A20 0x012C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE12__PTE12 0x0130 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE12__FXIO1_D19 0x0130 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE12__LPSPI3_SIN 0x0130 0x0324 0x3 0x2 +#define IMX7ULP_PAD_PTE12__LPUART7_CTS_B 0x0130 0x0268 0x4 0x2 +#define IMX7ULP_PAD_PTE12__LPI2C7_SCL 0x0130 0x0308 0x5 0x2 +#define IMX7ULP_PAD_PTE12__TPM7_CH2 0x0130 0x02E4 0x6 0x2 +#define IMX7ULP_PAD_PTE12__SDHC1_WP 0x0130 0x0200 0x8 0x2 +#define IMX7ULP_PAD_PTE12__FB_A21 0x0130 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE12__TRACE_D2 0x0130 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE12__USB1_OC2 0x0130 0x0334 0xb 0x2 +#define IMX7ULP_PAD_PTE12__VIU_D20 0x0130 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE13__PTE13 0x0134 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE13__FXIO1_D18 0x0134 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE13__LPSPI3_SOUT 0x0134 0x0328 0x3 0x2 +#define IMX7ULP_PAD_PTE13__LPUART7_RTS_B 0x0134 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTE13__LPI2C7_SDA 0x0134 0x030C 0x5 0x2 +#define IMX7ULP_PAD_PTE13__TPM6_CLKIN 0x0134 0x02D8 0x6 0x2 +#define IMX7ULP_PAD_PTE13__SDHC1_CD 0x0134 0x032C 0x8 0x2 +#define IMX7ULP_PAD_PTE13__FB_A22 0x0134 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE13__TRACE_D1 0x0134 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE13__USB1_PWR2 0x0134 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE13__VIU_D21 0x0134 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE14__PTE14 0x0138 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE14__FXIO1_D17 0x0138 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE14__LPSPI3_SCK 0x0138 0x0320 0x3 0x2 +#define IMX7ULP_PAD_PTE14__LPUART7_TX 0x0138 0x0270 0x4 0x2 +#define IMX7ULP_PAD_PTE14__LPI2C7_HREQ 0x0138 0x0304 0x5 0x2 +#define IMX7ULP_PAD_PTE14__TPM6_CH0 0x0138 0x02D0 0x6 0x2 +#define IMX7ULP_PAD_PTE14__SDHC1_VS 0x0138 0x0000 0x8 0x0 +#define IMX7ULP_PAD_PTE14__FB_A23 0x0138 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE14__TRACE_D0 0x0138 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE14__USB0_OC 0x0138 0x0330 0xb 0x2 +#define IMX7ULP_PAD_PTE14__VIU_D22 0x0138 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTE15__PTE15 0x013C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTE15__FXIO1_D16 0x013C 0x0000 0x2 0x0 +#define IMX7ULP_PAD_PTE15__LPSPI3_PCS0 0x013C 0x0310 0x3 0x2 +#define IMX7ULP_PAD_PTE15__LPUART7_RX 0x013C 0x026C 0x4 0x2 +#define IMX7ULP_PAD_PTE15__TPM6_CH1 0x013C 0x02D4 0x6 0x2 +#define IMX7ULP_PAD_PTE15__FB_A24 0x013C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTE15__TRACE_CLKOUT 0x013C 0x0000 0xa 0x0 +#define IMX7ULP_PAD_PTE15__USB0_PWR 0x013C 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTE15__VIU_D23 0x013C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF0__PTF0 0x0180 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF0__LPUART4_CTS_B 0x0180 0x0244 0x4 0x3 +#define IMX7ULP_PAD_PTF0__LPI2C4_SCL 0x0180 0x0278 0x5 0x3 +#define IMX7ULP_PAD_PTF0__TPM4_CLKIN 0x0180 0x0298 0x6 0x3 +#define IMX7ULP_PAD_PTF0__FB_RW_B 0x0180 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF0__VIU_DE 0x0180 0x033C 0xc 0x0 +#define IMX7ULP_PAD_PTF1__PTF1 0x0184 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF1__LPUART4_RTS_B 0x0184 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF1__LPI2C4_SDA 0x0184 0x027C 0x5 0x3 +#define IMX7ULP_PAD_PTF1__TPM4_CH0 0x0184 0x0280 0x6 0x3 +#define IMX7ULP_PAD_PTF1__CLKOUT 0x0184 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF1__VIU_HSYNC 0x0184 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF2__PTF2 0x0188 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF2__LPUART4_TX 0x0188 0x024C 0x4 0x3 +#define IMX7ULP_PAD_PTF2__LPI2C4_HREQ 0x0188 0x0274 0x5 0x3 +#define IMX7ULP_PAD_PTF2__TPM4_CH1 0x0188 0x0284 0x6 0x3 +#define IMX7ULP_PAD_PTF2__FB_TSIZ1_FB_CS5_B_FB_BE23_16_BLS15_8_B 0x0188 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF2__VIU_VSYNC 0x0188 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF3__PTF3 0x018C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF3__LPUART4_RX 0x018C 0x0248 0x4 0x3 +#define IMX7ULP_PAD_PTF3__TPM4_CH2 0x018C 0x0288 0x6 0x3 +#define IMX7ULP_PAD_PTF3__FB_AD16 0x018C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF3__VIU_PCLK 0x018C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF4__PTF4 0x0190 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF4__FXIO1_D0 0x0190 0x0204 0x2 0x2 +#define IMX7ULP_PAD_PTF4__LPSPI2_PCS1 0x0190 0x02A0 0x3 0x3 +#define IMX7ULP_PAD_PTF4__LPUART5_CTS_B 0x0190 0x0250 0x4 0x3 +#define IMX7ULP_PAD_PTF4__LPI2C5_SCL 0x0190 0x02BC 0x5 0x3 +#define IMX7ULP_PAD_PTF4__TPM4_CH3 0x0190 0x028C 0x6 0x2 +#define IMX7ULP_PAD_PTF4__FB_AD17 0x0190 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF4__VIU_D0 0x0190 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF5__PTF5 0x0194 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF5__FXIO1_D1 0x0194 0x0208 0x2 0x2 +#define IMX7ULP_PAD_PTF5__LPSPI2_PCS2 0x0194 0x02A4 0x3 0x3 +#define IMX7ULP_PAD_PTF5__LPUART5_RTS_B 0x0194 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF5__LPI2C5_SDA 0x0194 0x02C0 0x5 0x3 +#define IMX7ULP_PAD_PTF5__TPM4_CH4 0x0194 0x0290 0x6 0x2 +#define IMX7ULP_PAD_PTF5__FB_AD18 0x0194 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF5__VIU_D1 0x0194 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF6__PTF6 0x0198 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF6__FXIO1_D2 0x0198 0x020C 0x2 0x2 +#define IMX7ULP_PAD_PTF6__LPSPI2_PCS3 0x0198 0x02A8 0x3 0x3 +#define IMX7ULP_PAD_PTF6__LPUART5_TX 0x0198 0x0258 0x4 0x3 +#define IMX7ULP_PAD_PTF6__LPI2C5_HREQ 0x0198 0x02B8 0x5 0x3 +#define IMX7ULP_PAD_PTF6__TPM4_CH5 0x0198 0x0294 0x6 0x2 +#define IMX7ULP_PAD_PTF6__FB_AD19 0x0198 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF6__VIU_D2 0x0198 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF7__PTF7 0x019C 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF7__FXIO1_D3 0x019C 0x0210 0x2 0x2 +#define IMX7ULP_PAD_PTF7__LPUART5_RX 0x019C 0x0254 0x4 0x3 +#define IMX7ULP_PAD_PTF7__TPM5_CH1 0x019C 0x02C8 0x6 0x3 +#define IMX7ULP_PAD_PTF7__FB_AD20 0x019C 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF7__VIU_D3 0x019C 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF8__PTF8 0x01A0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF8__FXIO1_D4 0x01A0 0x0214 0x2 0x2 +#define IMX7ULP_PAD_PTF8__LPSPI2_SIN 0x01A0 0x02B0 0x3 0x3 +#define IMX7ULP_PAD_PTF8__LPUART6_CTS_B 0x01A0 0x025C 0x4 0x3 +#define IMX7ULP_PAD_PTF8__LPI2C6_SCL 0x01A0 0x02FC 0x5 0x3 +#define IMX7ULP_PAD_PTF8__TPM5_CLKIN 0x01A0 0x02CC 0x6 0x3 +#define IMX7ULP_PAD_PTF8__FB_AD21 0x01A0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF8__USB1_CLK 0x01A0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF8__VIU_D4 0x01A0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF9__PTF9 0x01A4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF9__FXIO1_D5 0x01A4 0x0218 0x2 0x2 +#define IMX7ULP_PAD_PTF9__LPSPI2_SOUT 0x01A4 0x02B4 0x3 0x3 +#define IMX7ULP_PAD_PTF9__LPUART6_RTS_B 0x01A4 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF9__LPI2C6_SDA 0x01A4 0x0300 0x5 0x3 +#define IMX7ULP_PAD_PTF9__TPM5_CH0 0x01A4 0x02C4 0x6 0x3 +#define IMX7ULP_PAD_PTF9__FB_AD22 0x01A4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF9__USB1_NXT 0x01A4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF9__VIU_D5 0x01A4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF10__PTF10 0x01A8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF10__FXIO1_D6 0x01A8 0x021C 0x2 0x2 +#define IMX7ULP_PAD_PTF10__LPSPI2_SCK 0x01A8 0x02AC 0x3 0x3 +#define IMX7ULP_PAD_PTF10__LPUART6_TX 0x01A8 0x0264 0x4 0x3 +#define IMX7ULP_PAD_PTF10__LPI2C6_HREQ 0x01A8 0x02F8 0x5 0x3 +#define IMX7ULP_PAD_PTF10__TPM7_CH3 0x01A8 0x02E8 0x6 0x3 +#define IMX7ULP_PAD_PTF10__FB_AD23 0x01A8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF10__USB1_STP 0x01A8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF10__VIU_D6 0x01A8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF11__PTF11 0x01AC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF11__FXIO1_D7 0x01AC 0x0220 0x2 0x2 +#define IMX7ULP_PAD_PTF11__LPSPI2_PCS0 0x01AC 0x029C 0x3 0x3 +#define IMX7ULP_PAD_PTF11__LPUART6_RX 0x01AC 0x0260 0x4 0x3 +#define IMX7ULP_PAD_PTF11__TPM7_CH4 0x01AC 0x02EC 0x6 0x3 +#define IMX7ULP_PAD_PTF11__FB_CS4_B_FB_TSIZ0_FB_BE31_24_BLS7_0_B 0x01AC 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF11__USB1_DIR 0x01AC 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF11__VIU_D7 0x01AC 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF12__PTF12 0x01B0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF12__FXIO1_D8 0x01B0 0x0224 0x2 0x2 +#define IMX7ULP_PAD_PTF12__LPSPI3_PCS1 0x01B0 0x0314 0x3 0x3 +#define IMX7ULP_PAD_PTF12__LPUART7_CTS_B 0x01B0 0x0268 0x4 0x3 +#define IMX7ULP_PAD_PTF12__LPI2C7_SCL 0x01B0 0x0308 0x5 0x3 +#define IMX7ULP_PAD_PTF12__TPM7_CH5 0x01B0 0x02F0 0x6 0x3 +#define IMX7ULP_PAD_PTF12__FB_AD24 0x01B0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF12__USB1_DATA0 0x01B0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF12__VIU_D8 0x01B0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF13__PTF13 0x01B4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF13__FXIO1_D9 0x01B4 0x0228 0x2 0x2 +#define IMX7ULP_PAD_PTF13__LPSPI3_PCS2 0x01B4 0x0318 0x3 0x3 +#define IMX7ULP_PAD_PTF13__LPUART7_RTS_B 0x01B4 0x0000 0x4 0x0 +#define IMX7ULP_PAD_PTF13__LPI2C7_SDA 0x01B4 0x030C 0x5 0x3 +#define IMX7ULP_PAD_PTF13__TPM7_CLKIN 0x01B4 0x02F4 0x6 0x3 +#define IMX7ULP_PAD_PTF13__FB_AD25 0x01B4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF13__USB1_DATA1 0x01B4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF13__VIU_D9 0x01B4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF14__PTF14 0x01B8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF14__FXIO1_D10 0x01B8 0x022C 0x2 0x2 +#define IMX7ULP_PAD_PTF14__LPSPI3_PCS3 0x01B8 0x031C 0x3 0x3 +#define IMX7ULP_PAD_PTF14__LPUART7_TX 0x01B8 0x0270 0x4 0x3 +#define IMX7ULP_PAD_PTF14__LPI2C7_HREQ 0x01B8 0x0304 0x5 0x3 +#define IMX7ULP_PAD_PTF14__TPM7_CH0 0x01B8 0x02DC 0x6 0x3 +#define IMX7ULP_PAD_PTF14__FB_AD26 0x01B8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF14__USB1_DATA2 0x01B8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF14__VIU_D10 0x01B8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF15__PTF15 0x01BC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF15__FXIO1_D11 0x01BC 0x0230 0x2 0x2 +#define IMX7ULP_PAD_PTF15__LPUART7_RX 0x01BC 0x026C 0x4 0x3 +#define IMX7ULP_PAD_PTF15__TPM7_CH1 0x01BC 0x02E0 0x6 0x3 +#define IMX7ULP_PAD_PTF15__FB_AD27 0x01BC 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF15__USB1_DATA3 0x01BC 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF15__VIU_D11 0x01BC 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF16__PTF16 0x01C0 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF16__USB1_DATA4 0x01C0 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF16__VIU_D12 0x01C0 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF16__FXIO1_D12 0x01C0 0x0234 0x2 0x2 +#define IMX7ULP_PAD_PTF16__LPSPI3_SIN 0x01C0 0x0324 0x3 0x3 +#define IMX7ULP_PAD_PTF16__TPM7_CH2 0x01C0 0x02E4 0x6 0x3 +#define IMX7ULP_PAD_PTF16__FB_AD28 0x01C0 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF17__PTF17 0x01C4 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF17__USB1_DATA5 0x01C4 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF17__VIU_D13 0x01C4 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF17__FXIO1_D13 0x01C4 0x0238 0x2 0x2 +#define IMX7ULP_PAD_PTF17__LPSPI3_SOUT 0x01C4 0x0328 0x3 0x3 +#define IMX7ULP_PAD_PTF17__TPM6_CLKIN 0x01C4 0x02D8 0x6 0x3 +#define IMX7ULP_PAD_PTF17__FB_AD29 0x01C4 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF18__PTF18 0x01C8 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF18__USB1_DATA6 0x01C8 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF18__VIU_D14 0x01C8 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF18__FXIO1_D14 0x01C8 0x023C 0x2 0x2 +#define IMX7ULP_PAD_PTF18__LPSPI3_SCK 0x01C8 0x0320 0x3 0x3 +#define IMX7ULP_PAD_PTF18__TPM6_CH0 0x01C8 0x02D0 0x6 0x3 +#define IMX7ULP_PAD_PTF18__FB_AD30 0x01C8 0x0000 0x9 0x0 +#define IMX7ULP_PAD_PTF19__PTF19 0x01CC 0x0000 0x1 0x0 +#define IMX7ULP_PAD_PTF19__USB1_DATA7 0x01CC 0x0000 0xb 0x0 +#define IMX7ULP_PAD_PTF19__VIU_D15 0x01CC 0x0000 0xc 0x0 +#define IMX7ULP_PAD_PTF19__FXIO1_D15 0x01CC 0x0240 0x2 0x2 +#define IMX7ULP_PAD_PTF19__LPSPI3_PCS0 0x01CC 0x0310 0x3 0x3 +#define IMX7ULP_PAD_PTF19__TPM6_CH1 0x01CC 0x02D4 0x6 0x3 +#define IMX7ULP_PAD_PTF19__FB_AD31 0x01CC 0x0000 0x9 0x0
-#define ULP1_PAD_PTA0_LLWU0_P0__CMP0_IN2A 0x0000 0x0000 0x0 0x0 -#define ULP1_PAD_PTA0_LLWU0_P0__PTA0 0x0000 0x0000 0x1 0x0 -#define ULP1_PAD_PTA0_LLWU0_P0__LLWU0_P0 0x0000 0x0000 0xd 0x0 -#define ULP1_PAD_PTA0_LLWU0_P0__LPSPI0_PCS1 0x0000 0xd104 0x3 0x2 -#define ULP1_PAD_PTA0_LLWU0_P0__LPUART0_CTS_B 0x0000 0xd1f8 0x4 0x2 -#define ULP1_PAD_PTA0_LLWU0_P0__LPI2C0_SCL 0x0000 0xd17c 0x5 0x2 -#define ULP1_PAD_PTA0_LLWU0_P0__TPM0_CLKIN 0x0000 0xd1a8 0x6 0x2 -#define ULP1_PAD_PTA0_LLWU0_P0__I2S0_RX_BCLK 0x0000 0x01b8 0x7 0x2 -#define ULP1_PAD_PTA1__CMP0_IN2B 0x0004 0x0000 0x0 0x0 -#define ULP1_PAD_PTA1__PTA1 0x0004 0x0000 0x1 0x0 -#define ULP1_PAD_PTA1__LPSPI0_PCS2 0x0004 0xd108 0x3 0x1 -#define ULP1_PAD_PTA1__LPUART0_RTS_B 0x0004 0x0000 0x4 0x0 -#define ULP1_PAD_PTA1__LPI2C0_SDA 0x0004 0xd180 0x5 0x1 -#define ULP1_PAD_PTA1__TPM0_CH0 0x0004 0xd138 0x6 0x1 -#define ULP1_PAD_PTA1__I2S0_RX_FS 0x0004 0x01bc 0x7 0x1 -#define ULP1_PAD_PTA2__CMP1_IN2A 0x0008 0x0000 0x0 0x0 -#define ULP1_PAD_PTA2__PTA2 0x0008 0x0000 0x1 0x0 -#define ULP1_PAD_PTA2__LPSPI0_PCS3 0x0008 0xd10c 0x3 0x1 -#define ULP1_PAD_PTA2__LPUART0_TX 0x0008 0xd200 0x4 0x1 -#define ULP1_PAD_PTA2__LPI2C0_HREQ 0x0008 0xd178 0x5 0x1 -#define ULP1_PAD_PTA2__TPM0_CH1 0x0008 0xd13c 0x6 0x1 -#define ULP1_PAD_PTA2__I2S0_RXD0 0x0008 0x01dc 0x7 0x1 -#define ULP1_PAD_PTA3_LLWU0_P1__CMP1_IN2B 0x000c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA3_LLWU0_P1__PTA3 0x000c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA3_LLWU0_P1__CMP0_OUT 0x000c 0x0000 0xb 0x0 -#define ULP1_PAD_PTA3_LLWU0_P1__LLWU0_P1 0x000c 0x0000 0xd 0x0 -#define ULP1_PAD_PTA3_LLWU0_P1__LPUART0_RX 0x000c 0xd1fc 0x4 0x1 -#define ULP1_PAD_PTA3_LLWU0_P1__TPM0_CH2 0x000c 0xd140 0x6 0x1 -#define ULP1_PAD_PTA3_LLWU0_P1__I2S0_RXD1 0x000c 0x01e0 0x7 0x1 -#define ULP1_PAD_PTA4__ADC1_CH2A 0x0010 0x0000 0x0 0x0 -#define ULP1_PAD_PTA4__PTA4 0x0010 0x0000 0x1 0x0 -#define ULP1_PAD_PTA4__LPSPI0_SIN 0x0010 0xd114 0x3 0x1 -#define ULP1_PAD_PTA4__LPUART1_CTS_B 0x0010 0xd204 0x4 0x1 -#define ULP1_PAD_PTA4__LPI2C1_SCL 0x0010 0xd188 0x5 0x1 -#define ULP1_PAD_PTA4__TPM0_CH3 0x0010 0xd144 0x6 0x1 -#define ULP1_PAD_PTA4__I2S0_MCLK 0x0010 0x01b4 0x7 0x1 -#define ULP1_PAD_PTA5__ADC1_CH2B 0x0014 0x0000 0x0 0x0 -#define ULP1_PAD_PTA5__PTA5 0x0014 0x0000 0x1 0x0 -#define ULP1_PAD_PTA5__LPSPI0_SOUT 0x0014 0xd118 0x3 0x1 -#define ULP1_PAD_PTA5__LPUART1_RTS_B 0x0014 0x0000 0x4 0x0 -#define ULP1_PAD_PTA5__LPI2C1_SDA 0x0014 0xd18c 0x5 0x1 -#define ULP1_PAD_PTA5__TPM0_CH4 0x0014 0xd148 0x6 0x1 -#define ULP1_PAD_PTA5__I2S0_TX_BCLK 0x0014 0x01c0 0x7 0x1 -#define ULP1_PAD_PTA6__ADC1_CH3A 0x0018 0x0000 0x0 0x0 -#define ULP1_PAD_PTA6__PTA6 0x0018 0x0000 0x1 0x0 -#define ULP1_PAD_PTA6__LPSPI0_SCK 0x0018 0xd110 0x3 0x1 -#define ULP1_PAD_PTA6__LPUART1_TX 0x0018 0xd20c 0x4 0x1 -#define ULP1_PAD_PTA6__LPI2C1_HREQ 0x0018 0xd184 0x5 0x1 -#define ULP1_PAD_PTA6__TPM0_CH5 0x0018 0xd14c 0x6 0x1 -#define ULP1_PAD_PTA6__I2S0_TX_FS 0x0018 0x01c4 0x7 0x1 -#define ULP1_PAD_PTA7__ADC1_CH3B 0x001c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA7__PTA7 0x001c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA7__LPSPI0_PCS0 0x001c 0xd100 0x3 0x1 -#define ULP1_PAD_PTA7__LPUART1_RX 0x001c 0xd208 0x4 0x1 -#define ULP1_PAD_PTA7__TPM1_CH1 0x001c 0xd154 0x6 0x1 -#define ULP1_PAD_PTA7__I2S0_TXD0 0x001c 0x0000 0x7 0x0 -#define ULP1_PAD_PTA8__ADC1_CH7A 0x0020 0x0000 0x0 0x0 -#define ULP1_PAD_PTA8__PTA8 0x0020 0x0000 0x1 0x0 -#define ULP1_PAD_PTA8__LPSPI1_PCS1 0x0020 0xd120 0x3 0x1 -#define ULP1_PAD_PTA8__LPUART2_CTS_B 0x0020 0xd210 0x4 0x1 -#define ULP1_PAD_PTA8__LPI2C2_SCL 0x0020 0xd194 0x5 0x1 -#define ULP1_PAD_PTA8__TPM1_CLKIN 0x0020 0xd1ac 0x6 0x1 -#define ULP1_PAD_PTA8__I2S0_TXD1 0x0020 0x0000 0x7 0x0 -#define ULP1_PAD_PTA9__ADC1_CH7B 0x0024 0x0000 0x0 0x0 -#define ULP1_PAD_PTA9__PTA9 0x0024 0x0000 0x1 0x0 -#define ULP1_PAD_PTA9__NMI0_B 0x0024 0x0000 0xb 0x0 -#define ULP1_PAD_PTA9__LPSPI1_PCS2 0x0024 0xd124 0x3 0x1 -#define ULP1_PAD_PTA9__LPUART2_RTS_B 0x0024 0x0000 0x4 0x0 -#define ULP1_PAD_PTA9__LPI2C2_SDA 0x0024 0xd198 0x5 0x1 -#define ULP1_PAD_PTA9__TPM1_CH0 0x0024 0xd150 0x6 0x1 -#define ULP1_PAD_PTA10__ADC1_CH6A 0x0028 0x0000 0x0 0x0 -#define ULP1_PAD_PTA10__PTA10 0x0028 0x0000 0x1 0x0 -#define ULP1_PAD_PTA10__LPSPI1_PCS3 0x0028 0xd128 0x3 0x1 -#define ULP1_PAD_PTA10__LPUART2_TX 0x0028 0xd218 0x4 0x1 -#define ULP1_PAD_PTA10__LPI2C2_HREQ 0x0028 0xd190 0x5 0x1 -#define ULP1_PAD_PTA10__TPM2_CLKIN 0x0028 0xd1f4 0x6 0x1 -#define ULP1_PAD_PTA10__I2S0_RX_BCLK 0x0028 0x01b8 0x7 0x1 -#define ULP1_PAD_PTA11__ADC1_CH6B 0x002c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA11__PTA11 0x002c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA11__LPUART2_RX 0x002c 0xd214 0x4 0x1 -#define ULP1_PAD_PTA11__TPM2_CH0 0x002c 0xd158 0x6 0x1 -#define ULP1_PAD_PTA11__I2S0_RX_FS 0x002c 0x01bc 0x7 0x2 -#define ULP1_PAD_PTA12__ADC1_CH5A 0x0030 0x0000 0x0 0x0 -#define ULP1_PAD_PTA12__PTA12 0x0030 0x0000 0x1 0x0 -#define ULP1_PAD_PTA12__LPSPI1_SIN 0x0030 0xd130 0x3 0x1 -#define ULP1_PAD_PTA12__LPUART3_CTS_B 0x0030 0xd21c 0x4 0x1 -#define ULP1_PAD_PTA12__LPI2C3_SCL 0x0030 0xd1a0 0x5 0x1 -#define ULP1_PAD_PTA12__TPM2_CH1 0x0030 0xd15c 0x6 0x1 -#define ULP1_PAD_PTA12__I2S0_RXD0 0x0030 0x01dc 0x7 0x2 -#define ULP1_PAD_PTA13_LLWU0_P2__ADC1_CH5B 0x0034 0x0000 0x0 0x0 -#define ULP1_PAD_PTA13_LLWU0_P2__PTA13 0x0034 0x0000 0x1 0x0 -#define ULP1_PAD_PTA13_LLWU0_P2__CMP0_OUT 0x0034 0x0000 0xb 0x0 -#define ULP1_PAD_PTA13_LLWU0_P2__LLWU0_P2 0x0034 0x0000 0xd 0x0 -#define ULP1_PAD_PTA13_LLWU0_P2__LPSPI1_SOUT 0x0034 0xd134 0x3 0x2 -#define ULP1_PAD_PTA13_LLWU0_P2__LPUART3_RTS_B 0x0034 0x0000 0x4 0x0 -#define ULP1_PAD_PTA13_LLWU0_P2__LPI2C3_SDA 0x0034 0xd1a4 0x5 0x2 -#define ULP1_PAD_PTA13_LLWU0_P2__TPM3_CLKIN 0x0034 0xd1b0 0x6 0x1 -#define ULP1_PAD_PTA13_LLWU0_P2__I2S0_RXD1 0x0034 0x01e0 0x7 0x2 -#define ULP1_PAD_PTA14_LLWU0_P3__ADC1_CH4A 0x0038 0x0000 0x0 0x0 -#define ULP1_PAD_PTA14_LLWU0_P3__PTA14 0x0038 0x0000 0x1 0x0 -#define ULP1_PAD_PTA14_LLWU0_P3__LLWU0_P3 0x0038 0x0000 0xd 0x0 -#define ULP1_PAD_PTA14_LLWU0_P3__LPSPI1_SCK 0x0038 0xd12c 0x3 0x2 -#define ULP1_PAD_PTA14_LLWU0_P3__LPUART3_TX 0x0038 0xd224 0x4 0x2 -#define ULP1_PAD_PTA14_LLWU0_P3__LPI2C3_HREQ 0x0038 0xd19c 0x5 0x2 -#define ULP1_PAD_PTA14_LLWU0_P3__TPM3_CH0 0x0038 0xd160 0x6 0x1 -#define ULP1_PAD_PTA14_LLWU0_P3__I2S0_MCLK 0x0038 0x01b4 0x7 0x2 -#define ULP1_PAD_PTA15__ADC1_CH4B 0x003c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA15__PTA15 0x003c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA15__LPSPI1_PCS0 0x003c 0xd11c 0x3 0x1 -#define ULP1_PAD_PTA15__LPUART3_RX 0x003c 0xd220 0x4 0x1 -#define ULP1_PAD_PTA15__TPM3_CH1 0x003c 0xd164 0x6 0x1 -#define ULP1_PAD_PTA15__I2S0_TX_BCLK 0x003c 0x01c0 0x7 0x2 -#define ULP1_PAD_PTA16__CMP1_IN0A 0x0040 0x0000 0x0 0x0 -#define ULP1_PAD_PTA16__PTA16 0x0040 0x0000 0x1 0x0 -#define ULP1_PAD_PTA16__FXIO0_D0 0x0040 0x0000 0x2 0x0 -#define ULP1_PAD_PTA16__LPSPI0_PCS1 0x0040 0xd104 0x3 0x1 -#define ULP1_PAD_PTA16__LPUART0_CTS_B 0x0040 0xd1f8 0x4 0x1 -#define ULP1_PAD_PTA16__LPI2C0_SCL 0x0040 0xd17c 0x5 0x1 -#define ULP1_PAD_PTA16__TPM3_CH2 0x0040 0xd168 0x6 0x1 -#define ULP1_PAD_PTA16__I2S0_TX_FS 0x0040 0x01c4 0x7 0x2 -#define ULP1_PAD_PTA17__CMP1_IN0B 0x0044 0x0000 0x0 0x0 -#define ULP1_PAD_PTA17__PTA17 0x0044 0x0000 0x1 0x0 -#define ULP1_PAD_PTA17__FXIO0_D1 0x0044 0x0000 0x2 0x0 -#define ULP1_PAD_PTA17__LPSPI0_PCS2 0x0044 0xd108 0x3 0x2 -#define ULP1_PAD_PTA17__LPUART0_RTS_B 0x0044 0x0000 0x4 0x0 -#define ULP1_PAD_PTA17__LPI2C0_SDA 0x0044 0xd180 0x5 0x2 -#define ULP1_PAD_PTA17__TPM3_CH3 0x0044 0xd16c 0x6 0x1 -#define ULP1_PAD_PTA17__I2S0_TXD0 0x0044 0x0000 0x7 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__CMP1_IN1A 0x0048 0x0000 0x0 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__PTA18 0x0048 0x0000 0x1 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__NMI1_B 0x0048 0x0000 0xb 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__LLWU0_P4 0x0048 0x0000 0xd 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__FXIO0_D2 0x0048 0x0000 0x2 0x0 -#define ULP1_PAD_PTA18_LLWU0_P4__LPSPI0_PCS3 0x0048 0xd10c 0x3 0x2 -#define ULP1_PAD_PTA18_LLWU0_P4__LPUART0_TX 0x0048 0xd200 0x4 0x2 -#define ULP1_PAD_PTA18_LLWU0_P4__LPI2C0_HREQ 0x0048 0xd178 0x5 0x2 -#define ULP1_PAD_PTA18_LLWU0_P4__TPM3_CH4 0x0048 0xd170 0x6 0x1 -#define ULP1_PAD_PTA18_LLWU0_P4__I2S0_TXD1 0x0048 0x0000 0x7 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__CMP1_IN1B 0x004c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__PTA19 0x004c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__LPTMR0_ALT3 0x004c 0x0000 0xb 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__LLWU0_P5 0x004c 0x0000 0xd 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__FXIO0_D3 0x004c 0x0000 0x2 0x0 -#define ULP1_PAD_PTA19_LLWU0_P5__LPUART0_RX 0x004c 0xd1fc 0x4 0x2 -#define ULP1_PAD_PTA19_LLWU0_P5__TPM3_CH5 0x004c 0xd174 0x6 0x1 -#define ULP1_PAD_PTA19_LLWU0_P5__I2S1_RX_BCLK 0x004c 0xd1cc 0x7 0x1 -#define ULP1_PAD_PTA20__ADC0_CH7A 0x0050 0x0000 0x0 0x0 -#define ULP1_PAD_PTA20__PTA20 0x0050 0x0000 0x1 0x0 -#define ULP1_PAD_PTA20__FXIO0_D4 0x0050 0x0000 0x2 0x0 -#define ULP1_PAD_PTA20__LPSPI0_SIN 0x0050 0xd114 0x3 0x2 -#define ULP1_PAD_PTA20__LPUART1_CTS_B 0x0050 0xd204 0x4 0x2 -#define ULP1_PAD_PTA20__LPI2C1_SCL 0x0050 0xd188 0x5 0x2 -#define ULP1_PAD_PTA20__TPM0_CLKIN 0x0050 0xd1a8 0x6 0x1 -#define ULP1_PAD_PTA20__I2S1_RX_FS 0x0050 0xd1d0 0x7 0x1 -#define ULP1_PAD_PTA21__ADC0_CH7B 0x0054 0x0000 0x0 0x0 -#define ULP1_PAD_PTA21__PTA21 0x0054 0x0000 0x1 0x0 -#define ULP1_PAD_PTA21__FXIO0_D5 0x0054 0x0000 0x2 0x0 -#define ULP1_PAD_PTA21__LPSPI0_SOUT 0x0054 0xd118 0x3 0x2 -#define ULP1_PAD_PTA21__LPUART1_RTS_B 0x0054 0x0000 0x4 0x0 -#define ULP1_PAD_PTA21__LPI2C1_SDA 0x0054 0xd18c 0x5 0x2 -#define ULP1_PAD_PTA21__TPM0_CH0 0x0054 0xd138 0x6 0x2 -#define ULP1_PAD_PTA21__I2S1_RXD0 0x0054 0xd1e4 0x7 0x1 -#define ULP1_PAD_PTA22__ADC0_CH6A 0x0058 0x0000 0x0 0x0 -#define ULP1_PAD_PTA22__PTA22 0x0058 0x0000 0x1 0x0 -#define ULP1_PAD_PTA22__LPTMR0_ALT2 0x0058 0x0000 0xb 0x0 -#define ULP1_PAD_PTA22__EWM_OUT_B 0x0058 0x0000 0xc 0x0 -#define ULP1_PAD_PTA22__FXIO0_D6 0x0058 0x0000 0x2 0x0 -#define ULP1_PAD_PTA22__LPSPI0_SCK 0x0058 0xd110 0x3 0x2 -#define ULP1_PAD_PTA22__LPUART1_TX 0x0058 0xd20c 0x4 0x2 -#define ULP1_PAD_PTA22__LPI2C1_HREQ 0x0058 0xd184 0x5 0x2 -#define ULP1_PAD_PTA22__TPM0_CH1 0x0058 0xd13c 0x6 0x2 -#define ULP1_PAD_PTA22__I2S1_RXD1 0x0058 0xd1e8 0x7 0x1 -#define ULP1_PAD_PTA23_LLWU0_P6__ADC0_CH6B 0x005c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA23_LLWU0_P6__PTA23 0x005c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA23_LLWU0_P6__LLWU0_P6 0x005c 0x0000 0xd 0x0 -#define ULP1_PAD_PTA23_LLWU0_P6__FXIO0_D7 0x005c 0x0000 0x2 0x0 -#define ULP1_PAD_PTA23_LLWU0_P6__LPSPI0_PCS0 0x005c 0xd100 0x3 0x2 -#define ULP1_PAD_PTA23_LLWU0_P6__LPUART1_RX 0x005c 0xd208 0x4 0x2 -#define ULP1_PAD_PTA23_LLWU0_P6__TPM0_CH2 0x005c 0xd140 0x6 0x2 -#define ULP1_PAD_PTA23_LLWU0_P6__I2S1_MCLK 0x005c 0xd1c8 0x7 0x1 -#define ULP1_PAD_PTA24__ADC0_CH5A 0x0060 0x0000 0x0 0x0 -#define ULP1_PAD_PTA24__PTA24 0x0060 0x0000 0x1 0x0 -#define ULP1_PAD_PTA24__FXIO0_D8 0x0060 0x0000 0x2 0x0 -#define ULP1_PAD_PTA24__LPSPI1_PCS1 0x0060 0xd120 0x3 0x2 -#define ULP1_PAD_PTA24__LPUART2_CTS_B 0x0060 0xd210 0x4 0x2 -#define ULP1_PAD_PTA24__LPI2C2_SCL 0x0060 0xd194 0x5 0x2 -#define ULP1_PAD_PTA24__TPM0_CH3 0x0060 0xd144 0x6 0x2 -#define ULP1_PAD_PTA24__I2S1_TX_BCLK 0x0060 0xd1d4 0x7 0x1 -#define ULP1_PAD_PTA25__ADC0_CH5B 0x0064 0x0000 0x0 0x0 -#define ULP1_PAD_PTA25__PTA25 0x0064 0x0000 0x1 0x0 -#define ULP1_PAD_PTA25__FXIO0_D9 0x0064 0x0000 0x2 0x0 -#define ULP1_PAD_PTA25__LPSPI1_PCS2 0x0064 0xd124 0x3 0x2 -#define ULP1_PAD_PTA25__LPUART2_RTS_B 0x0064 0x0000 0x4 0x0 -#define ULP1_PAD_PTA25__LPI2C2_SDA 0x0064 0xd198 0x5 0x2 -#define ULP1_PAD_PTA25__TPM0_CH4 0x0064 0xd148 0x6 0x2 -#define ULP1_PAD_PTA25__I2S1_TX_FS 0x0064 0xd1d8 0x7 0x1 -#define ULP1_PAD_PTA26__PTA26 0x0068 0x0000 0x1 0x0 -#define ULP1_PAD_PTA26__JTAG_TMS_SWD_DIO 0x0068 0x0000 0xa 0x0 -#define ULP1_PAD_PTA26__FXIO0_D10 0x0068 0x0000 0x2 0x0 -#define ULP1_PAD_PTA26__LPSPI1_PCS3 0x0068 0xd128 0x3 0x2 -#define ULP1_PAD_PTA26__LPUART2_TX 0x0068 0xd218 0x4 0x2 -#define ULP1_PAD_PTA26__LPI2C2_HREQ 0x0068 0xd190 0x5 0x2 -#define ULP1_PAD_PTA26__TPM0_CH5 0x0068 0xd14c 0x6 0x2 -#define ULP1_PAD_PTA26__I2S1_RXD2 0x0068 0xd1ec 0x7 0x1 -#define ULP1_PAD_PTA27__PTA27 0x006c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA27__JTAG_TDO 0x006c 0x0000 0xa 0x0 -#define ULP1_PAD_PTA27__FXIO0_D11 0x006c 0x0000 0x2 0x0 -#define ULP1_PAD_PTA27__LPUART2_RX 0x006c 0xd214 0x4 0x2 -#define ULP1_PAD_PTA27__TPM1_CH1 0x006c 0xd154 0x6 0x2 -#define ULP1_PAD_PTA27__I2S1_RXD3 0x006c 0xd1f0 0x7 0x1 -#define ULP1_PAD_PTA28__PTA28 0x0070 0x0000 0x1 0x0 -#define ULP1_PAD_PTA28__JTAG_TDI 0x0070 0x0000 0xa 0x0 -#define ULP1_PAD_PTA28__FXIO0_D12 0x0070 0x0000 0x2 0x0 -#define ULP1_PAD_PTA28__LPSPI1_SIN 0x0070 0xd130 0x3 0x2 -#define ULP1_PAD_PTA28__LPUART3_CTS_B 0x0070 0xd21c 0x4 0x2 -#define ULP1_PAD_PTA28__LPI2C3_SCL 0x0070 0xd1a0 0x5 0x2 -#define ULP1_PAD_PTA28__TPM1_CLKIN 0x0070 0xd1ac 0x6 0x2 -#define ULP1_PAD_PTA28__I2S1_TXD2 0x0070 0x0000 0x7 0x0 -#define ULP1_PAD_PTA29__PTA29 0x0074 0x0000 0x1 0x0 -#define ULP1_PAD_PTA29__JTAG_TCLK_SWD_CLK 0x0074 0x0000 0xa 0x0 -#define ULP1_PAD_PTA29__FXIO0_D13 0x0074 0x0000 0x2 0x0 -#define ULP1_PAD_PTA29__LPSPI1_SOUT 0x0074 0xd134 0x3 0x1 -#define ULP1_PAD_PTA29__LPUART3_RTS_B 0x0074 0x0000 0x4 0x0 -#define ULP1_PAD_PTA29__LPI2C3_SDA 0x0074 0xd1a4 0x5 0x1 -#define ULP1_PAD_PTA29__TPM1_CH0 0x0074 0xd150 0x6 0x2 -#define ULP1_PAD_PTA29__I2S1_TXD3 0x0074 0x0000 0x7 0x0 -#define ULP1_PAD_PTA30__ADC0_CH4A 0x0078 0x0000 0x0 0x0 -#define ULP1_PAD_PTA30__PTA30 0x0078 0x0000 0x1 0x0 -#define ULP1_PAD_PTA30__JTAG_TRST_B 0x0078 0x0000 0xa 0x0 -#define ULP1_PAD_PTA30__FXIO0_D14 0x0078 0x0000 0x2 0x0 -#define ULP1_PAD_PTA30__LPSPI1_SCK 0x0078 0xd12c 0x3 0x1 -#define ULP1_PAD_PTA30__LPUART3_TX 0x0078 0xd224 0x4 0x1 -#define ULP1_PAD_PTA30__LPI2C3_HREQ 0x0078 0xd19c 0x5 0x1 -#define ULP1_PAD_PTA30__TPM2_CLKIN 0x0078 0xd1f4 0x6 0x2 -#define ULP1_PAD_PTA30__I2S1_TXD0 0x0078 0x0000 0x7 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__ADC0_CH4B 0x007c 0x0000 0x0 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__PTA31 0x007c 0x0000 0x1 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__LPTMR0_ALT1 0x007c 0x0000 0xb 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__EWM_IN 0x007c 0xd228 0xc 0x1 -#define ULP1_PAD_PTA31_LLWU0_P7__LLWU0_P7 0x007c 0x0000 0xd 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__FXIO0_D15 0x007c 0x0000 0x2 0x0 -#define ULP1_PAD_PTA31_LLWU0_P7__LPSPI1_PCS0 0x007c 0xd11c 0x3 0x2 -#define ULP1_PAD_PTA31_LLWU0_P7__LPUART3_RX 0x007c 0xd220 0x4 0x2 -#define ULP1_PAD_PTA31_LLWU0_P7__TPM2_CH0 0x007c 0xd158 0x6 0x2 -#define ULP1_PAD_PTA31_LLWU0_P7__I2S1_TXD1 0x007c 0x0000 0x7 0x0 -#define ULP1_PAD_PTB0__ADC0_CH0A 0x0080 0x0000 0x0 0x0 -#define ULP1_PAD_PTB0__PTB0 0x0080 0x0000 0x1 0x0 -#define ULP1_PAD_PTB0__CMP1_OUT 0x0080 0x0000 0xb 0x0 -#define ULP1_PAD_PTB0__EWM_OUT_B 0x0080 0x0000 0xc 0x0 -#define ULP1_PAD_PTB0__FXIO0_D16 0x0080 0x0000 0x2 0x0 -#define ULP1_PAD_PTB0__LPSPI0_SIN 0x0080 0xd114 0x3 0x3 -#define ULP1_PAD_PTB0__LPUART0_TX 0x0080 0xd200 0x4 0x3 -#define ULP1_PAD_PTB0__TPM2_CH1 0x0080 0xd15c 0x6 0x2 -#define ULP1_PAD_PTB0__CLKOUT 0x0080 0x0000 0x9 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__ADC0_CH0B 0x0084 0x0000 0x0 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__PTB1 0x0084 0x0000 0x1 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__RTC_CLKOUT 0x0084 0x0000 0xb 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__EWM_IN 0x0084 0xd228 0xc 0x2 -#define ULP1_PAD_PTB1_LLWU0_P8__LLWU0_P8 0x0084 0x0000 0xd 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__FXIO0_D17 0x0084 0x0000 0x2 0x0 -#define ULP1_PAD_PTB1_LLWU0_P8__LPSPI0_SOUT 0x0084 0xd118 0x3 0x3 -#define ULP1_PAD_PTB1_LLWU0_P8__LPUART0_RX 0x0084 0xd1fc 0x4 0x3 -#define ULP1_PAD_PTB1_LLWU0_P8__TPM3_CLKIN 0x0084 0xd1b0 0x6 0x3 -#define ULP1_PAD_PTB1_LLWU0_P8__I2S1_TX_BCLK 0x0084 0xd1d4 0x7 0x2 -#define ULP1_PAD_PTB2__ADC0_CH1A 0x0088 0x0000 0x0 0x0 -#define ULP1_PAD_PTB2__PTB2 0x0088 0x0000 0x1 0x0 -#define ULP1_PAD_PTB2__TRACE_CLKOUT 0x0088 0x0000 0xa 0x0 -#define ULP1_PAD_PTB2__FXIO0_D18 0x0088 0x0000 0x2 0x0 -#define ULP1_PAD_PTB2__LPSPI0_SCK 0x0088 0xd110 0x3 0x3 -#define ULP1_PAD_PTB2__LPUART1_TX 0x0088 0xd20c 0x4 0x3 -#define ULP1_PAD_PTB2__TPM3_CH0 0x0088 0xd160 0x6 0x2 -#define ULP1_PAD_PTB2__I2S1_TX_FS 0x0088 0xd1d8 0x7 0x2 -#define ULP1_PAD_PTB3_LLWU0_P9__ADC0_CH1B 0x008c 0x0000 0x0 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__PTB3 0x008c 0x0000 0x1 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__TRACE_D0 0x008c 0x0000 0xa 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__LPTMR1_ALT2 0x008c 0x0000 0xb 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__LLWU0_P9 0x008c 0x0000 0xd 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__FXIO0_D19 0x008c 0x0000 0x2 0x0 -#define ULP1_PAD_PTB3_LLWU0_P9__LPSPI0_PCS0 0x008c 0xd100 0x3 0x3 -#define ULP1_PAD_PTB3_LLWU0_P9__LPUART1_RX 0x008c 0xd208 0x4 0x3 -#define ULP1_PAD_PTB3_LLWU0_P9__TPM3_CH1 0x008c 0xd164 0x6 0x2 -#define ULP1_PAD_PTB3_LLWU0_P9__I2S1_TXD0 0x008c 0x0000 0x7 0x0 -#define ULP1_PAD_PTB4__PTB4 0x0090 0x0000 0x1 0x0 -#define ULP1_PAD_PTB4__TRACE_D1 0x0090 0x0000 0xa 0x0 -#define ULP1_PAD_PTB4__BOOTCFG0 0x0090 0x0000 0xd 0x0 -#define ULP1_PAD_PTB4__FXIO0_D20 0x0090 0x0000 0x2 0x0 -#define ULP1_PAD_PTB4__LPSPI0_PCS1 0x0090 0xd104 0x3 0x3 -#define ULP1_PAD_PTB4__LPUART2_TX 0x0090 0xd218 0x4 0x3 -#define ULP1_PAD_PTB4__LPI2C0_HREQ 0x0090 0xd178 0x5 0x3 -#define ULP1_PAD_PTB4__TPM3_CH2 0x0090 0xd168 0x6 0x2 -#define ULP1_PAD_PTB4__I2S1_TXD1 0x0090 0x0000 0x7 0x0 -#define ULP1_PAD_PTB5__PTB5 0x0094 0x0000 0x1 0x0 -#define ULP1_PAD_PTB5__TRACE_D2 0x0094 0x0000 0xa 0x0 -#define ULP1_PAD_PTB5__BOOTCFG1 0x0094 0x0000 0xd 0x0 -#define ULP1_PAD_PTB5__FXIO0_D21 0x0094 0x0000 0x2 0x0 -#define ULP1_PAD_PTB5__LPSPI0_PCS2 0x0094 0xd108 0x3 0x3 -#define ULP1_PAD_PTB5__LPUART2_RX 0x0094 0xd214 0x4 0x3 -#define ULP1_PAD_PTB5__LPI2C1_HREQ 0x0094 0xd184 0x5 0x3 -#define ULP1_PAD_PTB5__TPM3_CH3 0x0094 0xd16c 0x6 0x2 -#define ULP1_PAD_PTB5__I2S1_TXD2 0x0094 0x0000 0x7 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__PTB6 0x0098 0x0000 0x1 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__TRACE_D3 0x0098 0x0000 0xa 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__LPTMR1_ALT3 0x0098 0x0000 0xb 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__LLWU0_P10 0x0098 0x0000 0xd 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__FXIO0_D22 0x0098 0x0000 0x2 0x0 -#define ULP1_PAD_PTB6_LLWU0_P10__LPSPI0_PCS3 0x0098 0xd10c 0x3 0x3 -#define ULP1_PAD_PTB6_LLWU0_P10__LPUART3_TX 0x0098 0xd224 0x4 0x3 -#define ULP1_PAD_PTB6_LLWU0_P10__LPI2C0_SCL 0x0098 0xd17c 0x5 0x3 -#define ULP1_PAD_PTB6_LLWU0_P10__TPM3_CH4 0x0098 0xd170 0x6 0x2 -#define ULP1_PAD_PTB6_LLWU0_P10__I2S1_TXD3 0x0098 0x0000 0x7 0x0 -#define ULP1_PAD_PTB7_LLWU0_P11__PTB7 0x009c 0x0000 0x1 0x0 -#define ULP1_PAD_PTB7_LLWU0_P11__CMP1_OUT 0x009c 0x0000 0xb 0x0 -#define ULP1_PAD_PTB7_LLWU0_P11__LLWU0_P11 0x009c 0x0000 0xd 0x0 -#define ULP1_PAD_PTB7_LLWU0_P11__FXIO0_D23 0x009c 0x0000 0x2 0x0 -#define ULP1_PAD_PTB7_LLWU0_P11__LPSPI1_SIN 0x009c 0xd130 0x3 0x3 -#define ULP1_PAD_PTB7_LLWU0_P11__LPUART3_RX 0x009c 0xd220 0x4 0x3 -#define ULP1_PAD_PTB7_LLWU0_P11__LPI2C0_SDA 0x009c 0xd180 0x5 0x3 -#define ULP1_PAD_PTB7_LLWU0_P11__TPM3_CH5 0x009c 0xd174 0x6 0x2 -#define ULP1_PAD_PTB7_LLWU0_P11__I2S1_MCLK 0x009c 0xd1c8 0x7 0x2 -#define ULP1_PAD_PTB7_LLWU0_P11__QSPIA_SS1_B 0x009c 0x0000 0x8 0x0 -#define ULP1_PAD_PTB8__CMP0_IN0A 0x00a0 0x0000 0x0 0x0 -#define ULP1_PAD_PTB8__PTB8 0x00a0 0x0000 0x1 0x0 -#define ULP1_PAD_PTB8__RTC_CLKOUT 0x00a0 0x0000 0xb 0x0 -#define ULP1_PAD_PTB8__FXIO0_D24 0x00a0 0x0000 0x2 0x0 -#define ULP1_PAD_PTB8__LPSPI1_SOUT 0x00a0 0xd134 0x3 0x3 -#define ULP1_PAD_PTB8__LPI2C1_SCL 0x00a0 0xd188 0x5 0x3 -#define ULP1_PAD_PTB8__TPM0_CLKIN 0x00a0 0xd1a8 0x6 0x3 -#define ULP1_PAD_PTB8__I2S1_RX_BCLK 0x00a0 0xd1cc 0x7 0x2 -#define ULP1_PAD_PTB8__QSPIA_SS0_B 0x00a0 0x0000 0x8 0x0 -#define ULP1_PAD_PTB9_LLWU0_P12__CMP0_IN0B 0x00a4 0x0000 0x0 0x0 -#define ULP1_PAD_PTB9_LLWU0_P12__PTB9 0x00a4 0x0000 0x1 0x0 -#define ULP1_PAD_PTB9_LLWU0_P12__LLWU0_P12 0x00a4 0x0000 0xd 0x0 -#define ULP1_PAD_PTB9_LLWU0_P12__FXIO0_D25 0x00a4 0x0000 0x2 0x0 -#define ULP1_PAD_PTB9_LLWU0_P12__LPSPI1_SCK 0x00a4 0xd12c 0x3 0x3 -#define ULP1_PAD_PTB9_LLWU0_P12__LPI2C1_SDA 0x00a4 0xd18c 0x5 0x3 -#define ULP1_PAD_PTB9_LLWU0_P12__TPM0_CH0 0x00a4 0xd138 0x6 0x3 -#define ULP1_PAD_PTB9_LLWU0_P12__I2S1_RX_FS 0x00a4 0xd1d0 0x7 0x2 -#define ULP1_PAD_PTB9_LLWU0_P12__QSPIA_DQS 0x00a4 0x0000 0x8 0x0 -#define ULP1_PAD_PTB10__CMP0_IN1A 0x00a8 0x0000 0x0 0x0 -#define ULP1_PAD_PTB10__PTB10 0x00a8 0x0000 0x1 0x0 -#define ULP1_PAD_PTB10__TRACE_D4 0x00a8 0x0000 0xa 0x0 -#define ULP1_PAD_PTB10__FXIO0_D26 0x00a8 0x0000 0x2 0x0 -#define ULP1_PAD_PTB10__LPSPI1_PCS0 0x00a8 0xd11c 0x3 0x3 -#define ULP1_PAD_PTB10__LPI2C2_SCL 0x00a8 0xd194 0x5 0x3 -#define ULP1_PAD_PTB10__TPM0_CH1 0x00a8 0xd13c 0x6 0x3 -#define ULP1_PAD_PTB10__I2S1_RXD0 0x00a8 0xd1e4 0x7 0x2 -#define ULP1_PAD_PTB10__QSPIA_DATA7 0x00a8 0x0000 0x8 0x0 -#define ULP1_PAD_PTB11__CMP0_IN1B 0x00ac 0x0000 0x0 0x0 -#define ULP1_PAD_PTB11__PTB11 0x00ac 0x0000 0x1 0x0 -#define ULP1_PAD_PTB11__TRACE_D5 0x00ac 0x0000 0xa 0x0 -#define ULP1_PAD_PTB11__FXIO0_D27 0x00ac 0x0000 0x2 0x0 -#define ULP1_PAD_PTB11__LPSPI1_PCS1 0x00ac 0xd120 0x3 0x3 -#define ULP1_PAD_PTB11__LPI2C2_SDA 0x00ac 0xd198 0x5 0x3 -#define ULP1_PAD_PTB11__TPM1_CLKIN 0x00ac 0xd1ac 0x6 0x3 -#define ULP1_PAD_PTB11__I2S1_RXD1 0x00ac 0xd1e8 0x7 0x2 -#define ULP1_PAD_PTB11__QSPIA_DATA6 0x00ac 0x0000 0x8 0x0 -#define ULP1_PAD_PTB12__ADC1_CH0A 0x00b0 0x0000 0x0 0x0 -#define ULP1_PAD_PTB12__PTB12 0x00b0 0x0000 0x1 0x0 -#define ULP1_PAD_PTB12__TRACE_D6 0x00b0 0x0000 0xa 0x0 -#define ULP1_PAD_PTB12__FXIO0_D28 0x00b0 0x0000 0x2 0x0 -#define ULP1_PAD_PTB12__LPSPI1_PCS2 0x00b0 0xd124 0x3 0x3 -#define ULP1_PAD_PTB12__LPI2C3_SCL 0x00b0 0xd1a0 0x5 0x3 -#define ULP1_PAD_PTB12__TPM1_CH0 0x00b0 0xd150 0x6 0x3 -#define ULP1_PAD_PTB12__I2S1_RXD2 0x00b0 0xd1ec 0x7 0x2 -#define ULP1_PAD_PTB12__QSPIA_DATA5 0x00b0 0x0000 0x8 0x0 -#define ULP1_PAD_PTB13__ADC1_CH0B 0x00b4 0x0000 0x0 0x0 -#define ULP1_PAD_PTB13__PTB13 0x00b4 0x0000 0x1 0x0 -#define ULP1_PAD_PTB13__TRACE_D7 0x00b4 0x0000 0xa 0x0 -#define ULP1_PAD_PTB13__FXIO0_D29 0x00b4 0x0000 0x2 0x0 -#define ULP1_PAD_PTB13__LPSPI1_PCS3 0x00b4 0xd128 0x3 0x3 -#define ULP1_PAD_PTB13__LPI2C3_SDA 0x00b4 0xd1a4 0x5 0x3 -#define ULP1_PAD_PTB13__TPM1_CH1 0x00b4 0xd154 0x6 0x3 -#define ULP1_PAD_PTB13__I2S1_RXD3 0x00b4 0xd1f0 0x7 0x2 -#define ULP1_PAD_PTB13__QSPIA_DATA4 0x00b4 0x0000 0x8 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__ADC1_CH1A 0x00b8 0x0000 0x0 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__PTB14 0x00b8 0x0000 0x1 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__LLWU0_P13 0x00b8 0x0000 0xd 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__FXIO0_D30 0x00b8 0x0000 0x2 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__LPI2C2_HREQ 0x00b8 0xd190 0x5 0x3 -#define ULP1_PAD_PTB14_LLWU0_P13__TPM2_CLKIN 0x00b8 0xd1f4 0x6 0x3 -#define ULP1_PAD_PTB14_LLWU0_P13__QSPIA_SS0_B 0x00b8 0x0000 0x8 0x0 -#define ULP1_PAD_PTB14_LLWU0_P13__QSPIA_SCLK_B 0x00b8 0x0000 0x9 0x0 -#define ULP1_PAD_PTB15__ADC1_CH1B 0x00bc 0x0000 0x0 0x0 -#define ULP1_PAD_PTB15__PTB15 0x00bc 0x0000 0x1 0x0 -#define ULP1_PAD_PTB15__FXIO0_D31 0x00bc 0x0000 0x2 0x0 -#define ULP1_PAD_PTB15__LPI2C3_HREQ 0x00bc 0xd19c 0x5 0x3 -#define ULP1_PAD_PTB15__TPM2_CH0 0x00bc 0xd158 0x6 0x3 -#define ULP1_PAD_PTB15__QSPIA_SCLK 0x00bc 0x0000 0x8 0x0 -#define ULP1_PAD_PTB16_LLWU0_P14__ADC0_CH2A 0x00c0 0x0000 0x0 0x0 -#define ULP1_PAD_PTB16_LLWU0_P14__PTB16 0x00c0 0x0000 0x1 0x0 -#define ULP1_PAD_PTB16_LLWU0_P14__LLWU0_P14 0x00c0 0x0000 0xd 0x0 -#define ULP1_PAD_PTB16_LLWU0_P14__TPM2_CH1 0x00c0 0xd15c 0x6 0x3 -#define ULP1_PAD_PTB16_LLWU0_P14__QSPIA_DATA3 0x00c0 0x0000 0x8 0x0 -#define ULP1_PAD_PTB17__ADC0_CH2B 0x00c4 0x0000 0x0 0x0 -#define ULP1_PAD_PTB17__PTB17 0x00c4 0x0000 0x1 0x0 -#define ULP1_PAD_PTB17__TPM3_CLKIN 0x00c4 0xd1b0 0x6 0x2 -#define ULP1_PAD_PTB17__QSPIA_DATA2 0x00c4 0x0000 0x8 0x0 -#define ULP1_PAD_PTB18__ADC0_CH3A 0x00c8 0x0000 0x0 0x0 -#define ULP1_PAD_PTB18__PTB18 0x00c8 0x0000 0x1 0x0 -#define ULP1_PAD_PTB18__TPM3_CH0 0x00c8 0xd160 0x6 0x3 -#define ULP1_PAD_PTB18__QSPIA_DATA1 0x00c8 0x0000 0x8 0x0 -#define ULP1_PAD_PTB19_LLWU0_P15__ADC0_CH3B 0x00cc 0x0000 0x0 0x0 -#define ULP1_PAD_PTB19_LLWU0_P15__PTB19 0x00cc 0x0000 0x1 0x0 -#define ULP1_PAD_PTB19_LLWU0_P15__USB0_ID 0x00cc 0x0000 0xa 0x0 -#define ULP1_PAD_PTB19_LLWU0_P15__LLWU0_P15 0x00cc 0x0000 0xd 0x0 -#define ULP1_PAD_PTB19_LLWU0_P15__TPM3_CH1 0x00cc 0xd164 0x6 0x3 -#define ULP1_PAD_PTB19_LLWU0_P15__QSPIA_DATA0 0x00cc 0x0000 0x8 0x0 -#define ULP1_PAD_PTC0__PTC0 0x0000 0x0000 0x1 0x0 -#define ULP1_PAD_PTC0__TRACE_D15 0x0000 0x0000 0xa 0x0 -#define ULP1_PAD_PTC0__LPUART4_CTS_B 0x0000 0x0244 0x4 0x1 -#define ULP1_PAD_PTC0__LPI2C4_SCL 0x0000 0x0278 0x5 0x1 -#define ULP1_PAD_PTC0__TPM4_CLKIN 0x0000 0x0298 0x6 0x1 -#define ULP1_PAD_PTC0__FB_AD0 0x0000 0x0000 0x9 0x0 -#define ULP1_PAD_PTC1__PTC1 0x0004 0x0000 0x1 0x0 -#define ULP1_PAD_PTC1__TRACE_D14 0x0004 0x0000 0xa 0x0 -#define ULP1_PAD_PTC1__LPUART4_RTS_B 0x0004 0x0000 0x4 0x0 -#define ULP1_PAD_PTC1__LPI2C4_SDA 0x0004 0x027c 0x5 0x1 -#define ULP1_PAD_PTC1__TPM4_CH0 0x0004 0x0280 0x6 0x1 -#define ULP1_PAD_PTC1__FB_AD1 0x0004 0x0000 0x9 0x0 -#define ULP1_PAD_PTC2__PTC2 0x0008 0x0000 0x1 0x0 -#define ULP1_PAD_PTC2__TRACE_D13 0x0008 0x0000 0xa 0x0 -#define ULP1_PAD_PTC2__LPUART4_TX 0x0008 0x024c 0x4 0x1 -#define ULP1_PAD_PTC2__LPI2C4_HREQ 0x0008 0x0274 0x5 0x1 -#define ULP1_PAD_PTC2__TPM4_CH1 0x0008 0x0284 0x6 0x1 -#define ULP1_PAD_PTC2__FB_AD2 0x0008 0x0000 0x9 0x0 -#define ULP1_PAD_PTC3__PTC3 0x000c 0x0000 0x1 0x0 -#define ULP1_PAD_PTC3__TRACE_D12 0x000c 0x0000 0xa 0x0 -#define ULP1_PAD_PTC3__LPUART4_RX 0x000c 0x0248 0x4 0x1 -#define ULP1_PAD_PTC3__TPM4_CH2 0x000c 0x0288 0x6 0x1 -#define ULP1_PAD_PTC3__FB_AD3 0x000c 0x0000 0x9 0x0 -#define ULP1_PAD_PTC4__PTC4 0x0010 0x0000 0x1 0x0 -#define ULP1_PAD_PTC4__TRACE_D11 0x0010 0x0000 0xa 0x0 -#define ULP1_PAD_PTC4__FXIO1_D0 0x0010 0x0204 0x2 0x1 -#define ULP1_PAD_PTC4__LPSPI2_PCS1 0x0010 0x02a0 0x3 0x1 -#define ULP1_PAD_PTC4__LPUART5_CTS_B 0x0010 0x0250 0x4 0x1 -#define ULP1_PAD_PTC4__LPI2C5_SCL 0x0010 0x02bc 0x5 0x1 -#define ULP1_PAD_PTC4__TPM4_CH3 0x0010 0x028c 0x6 0x1 -#define ULP1_PAD_PTC4__FB_AD4 0x0010 0x0000 0x9 0x0 -#define ULP1_PAD_PTC5__PTC5 0x0014 0x0000 0x1 0x0 -#define ULP1_PAD_PTC5__TRACE_D10 0x0014 0x0000 0xa 0x0 -#define ULP1_PAD_PTC5__FXIO1_D1 0x0014 0x0208 0x2 0x1 -#define ULP1_PAD_PTC5__LPSPI2_PCS2 0x0014 0x02a4 0x3 0x1 -#define ULP1_PAD_PTC5__LPUART5_RTS_B 0x0014 0x0000 0x4 0x0 -#define ULP1_PAD_PTC5__LPI2C5_SDA 0x0014 0x02c0 0x5 0x1 -#define ULP1_PAD_PTC5__TPM4_CH4 0x0014 0x0290 0x6 0x1 -#define ULP1_PAD_PTC5__FB_AD5 0x0014 0x0000 0x9 0x0 -#define ULP1_PAD_PTC6__PTC6 0x0018 0x0000 0x1 0x0 -#define ULP1_PAD_PTC6__TRACE_D9 0x0018 0x0000 0xa 0x0 -#define ULP1_PAD_PTC6__FXIO1_D2 0x0018 0x020c 0x2 0x1 -#define ULP1_PAD_PTC6__LPSPI2_PCS3 0x0018 0x02a8 0x3 0x1 -#define ULP1_PAD_PTC6__LPUART5_TX 0x0018 0x0258 0x4 0x1 -#define ULP1_PAD_PTC6__LPI2C5_HREQ 0x0018 0x02b8 0x5 0x1 -#define ULP1_PAD_PTC6__TPM4_CH5 0x0018 0x0294 0x6 0x1 -#define ULP1_PAD_PTC6__FB_AD6 0x0018 0x0000 0x9 0x0 -#define ULP1_PAD_PTC7__PTC7 0x001c 0x0000 0x1 0x0 -#define ULP1_PAD_PTC7__TRACE_D8 0x001c 0x0000 0xa 0x0 -#define ULP1_PAD_PTC7__FXIO1_D3 0x001c 0x0210 0x2 0x1 -#define ULP1_PAD_PTC7__LPUART5_RX 0x001c 0x0254 0x4 0x1 -#define ULP1_PAD_PTC7__TPM5_CH1 0x001c 0x02c8 0x6 0x1 -#define ULP1_PAD_PTC7__FB_AD7 0x001c 0x0000 0x9 0x0 -#define ULP1_PAD_PTC8__PTC8 0x0020 0x0000 0x1 0x0 -#define ULP1_PAD_PTC8__TRACE_D7 0x0020 0x0000 0xa 0x0 -#define ULP1_PAD_PTC8__FXIO1_D4 0x0020 0x0214 0x2 0x1 -#define ULP1_PAD_PTC8__LPSPI2_SIN 0x0020 0x02b0 0x3 0x1 -#define ULP1_PAD_PTC8__LPUART6_CTS_B 0x0020 0x025c 0x4 0x1 -#define ULP1_PAD_PTC8__LPI2C6_SCL 0x0020 0x02fc 0x5 0x1 -#define ULP1_PAD_PTC8__TPM5_CLKIN 0x0020 0x02cc 0x6 0x1 -#define ULP1_PAD_PTC8__FB_AD8 0x0020 0x0000 0x9 0x0 -#define ULP1_PAD_PTC9__PTC9 0x0024 0x0000 0x1 0x0 -#define ULP1_PAD_PTC9__TRACE_D6 0x0024 0x0000 0xa 0x0 -#define ULP1_PAD_PTC9__FXIO1_D5 0x0024 0x0218 0x2 0x1 -#define ULP1_PAD_PTC9__LPSPI2_SOUT 0x0024 0x02b4 0x3 0x1 -#define ULP1_PAD_PTC9__LPUART6_RTS_B 0x0024 0x0000 0x4 0x0 -#define ULP1_PAD_PTC9__LPI2C6_SDA 0x0024 0x0300 0x5 0x1 -#define ULP1_PAD_PTC9__TPM5_CH0 0x0024 0x02c4 0x6 0x1 -#define ULP1_PAD_PTC9__FB_AD9 0x0024 0x0000 0x9 0x0 -#define ULP1_PAD_PTC10__PTC10 0x0028 0x0000 0x1 0x0 -#define ULP1_PAD_PTC10__TRACE_D5 0x0028 0x0000 0xa 0x0 -#define ULP1_PAD_PTC10__FXIO1_D6 0x0028 0x021c 0x2 0x1 -#define ULP1_PAD_PTC10__LPSPI2_SCK 0x0028 0x02ac 0x3 0x1 -#define ULP1_PAD_PTC10__LPUART6_TX 0x0028 0x0264 0x4 0x1 -#define ULP1_PAD_PTC10__LPI2C6_HREQ 0x0028 0x02f8 0x5 0x1 -#define ULP1_PAD_PTC10__TPM7_CH3 0x0028 0x02e8 0x6 0x1 -#define ULP1_PAD_PTC10__FB_AD10 0x0028 0x0000 0x9 0x0 -#define ULP1_PAD_PTC11__PTC11 0x002c 0x0000 0x1 0x0 -#define ULP1_PAD_PTC11__TRACE_D4 0x002c 0x0000 0xa 0x0 -#define ULP1_PAD_PTC11__FXIO1_D7 0x002c 0x0220 0x2 0x1 -#define ULP1_PAD_PTC11__LPSPI2_PCS0 0x002c 0x029c 0x3 0x1 -#define ULP1_PAD_PTC11__LPUART6_RX 0x002c 0x0260 0x4 0x1 -#define ULP1_PAD_PTC11__TPM7_CH4 0x002c 0x02ec 0x6 0x1 -#define ULP1_PAD_PTC11__FB_AD11 0x002c 0x0000 0x9 0x0 -#define ULP1_PAD_PTC12__PTC12 0x0030 0x0000 0x1 0x0 -#define ULP1_PAD_PTC12__TRACE_D3 0x0030 0x0000 0xa 0x0 -#define ULP1_PAD_PTC12__FXIO1_D8 0x0030 0x0224 0x2 0x1 -#define ULP1_PAD_PTC12__LPSPI3_PCS1 0x0030 0x0314 0x3 0x1 -#define ULP1_PAD_PTC12__LPUART7_CTS_B 0x0030 0x0268 0x4 0x1 -#define ULP1_PAD_PTC12__LPI2C7_SCL 0x0030 0x0308 0x5 0x1 -#define ULP1_PAD_PTC12__TPM7_CH5 0x0030 0x02f0 0x6 0x1 -#define ULP1_PAD_PTC12__FB_AD12 0x0030 0x0000 0x9 0x0 -#define ULP1_PAD_PTC13__PTC13 0x0034 0x0000 0x1 0x0 -#define ULP1_PAD_PTC13__TRACE_D2 0x0034 0x0000 0xa 0x0 -#define ULP1_PAD_PTC13__FXIO1_D9 0x0034 0x0228 0x2 0x1 -#define ULP1_PAD_PTC13__LPSPI3_PCS2 0x0034 0x0318 0x3 0x1 -#define ULP1_PAD_PTC13__LPUART7_RTS_B 0x0034 0x0000 0x4 0x0 -#define ULP1_PAD_PTC13__LPI2C7_SDA 0x0034 0x030c 0x5 0x1 -#define ULP1_PAD_PTC13__TPM7_CLKIN 0x0034 0x02f4 0x6 0x1 -#define ULP1_PAD_PTC13__FB_AD13 0x0034 0x0000 0x9 0x0 -#define ULP1_PAD_PTC14__PTC14 0x0038 0x0000 0x1 0x0 -#define ULP1_PAD_PTC14__TRACE_D1 0x0038 0x0000 0xa 0x0 -#define ULP1_PAD_PTC14__FXIO1_D10 0x0038 0x022c 0x2 0x1 -#define ULP1_PAD_PTC14__LPSPI3_PCS3 0x0038 0x031c 0x3 0x1 -#define ULP1_PAD_PTC14__LPUART7_TX 0x0038 0x0270 0x4 0x1 -#define ULP1_PAD_PTC14__LPI2C7_HREQ 0x0038 0x0304 0x5 0x1 -#define ULP1_PAD_PTC14__TPM7_CH0 0x0038 0x02dc 0x6 0x1 -#define ULP1_PAD_PTC14__FB_AD14 0x0038 0x0000 0x9 0x0 -#define ULP1_PAD_PTC15__PTC15 0x003c 0x0000 0x1 0x0 -#define ULP1_PAD_PTC15__TRACE_D0 0x003c 0x0000 0xa 0x0 -#define ULP1_PAD_PTC15__FXIO1_D11 0x003c 0x0230 0x2 0x1 -#define ULP1_PAD_PTC15__LPUART7_RX 0x003c 0x026c 0x4 0x1 -#define ULP1_PAD_PTC15__TPM7_CH1 0x003c 0x02e0 0x6 0x1 -#define ULP1_PAD_PTC15__FB_AD15 0x003c 0x0000 0x9 0x0 -#define ULP1_PAD_PTC16__PTC16 0x0040 0x0000 0x1 0x0 -#define ULP1_PAD_PTC16__TRACE_CLKOUT 0x0040 0x0000 0xa 0x0 -#define ULP1_PAD_PTC16__FXIO1_D12 0x0040 0x0234 0x2 0x1 -#define ULP1_PAD_PTC16__LPSPI3_SIN 0x0040 0x0324 0x3 0x1 -#define ULP1_PAD_PTC16__TPM7_CH2 0x0040 0x02e4 0x6 0x1 -#define ULP1_PAD_PTC16__FB_ALE_FB_CS1_B_FB_TS_B 0x0040 0x0000 0x9 0x0 -#define ULP1_PAD_PTC17__PTC17 0x0044 0x0000 0x1 0x0 -#define ULP1_PAD_PTC17__FXIO1_D13 0x0044 0x0238 0x2 0x1 -#define ULP1_PAD_PTC17__LPSPI3_SOUT 0x0044 0x0328 0x3 0x1 -#define ULP1_PAD_PTC17__TPM6_CLKIN 0x0044 0x02d8 0x6 0x1 -#define ULP1_PAD_PTC17__FB_CS0_B 0x0044 0x0000 0x9 0x0 -#define ULP1_PAD_PTC18__PTC18 0x0048 0x0000 0x1 0x0 -#define ULP1_PAD_PTC18__FXIO1_D14 0x0048 0x023c 0x2 0x1 -#define ULP1_PAD_PTC18__LPSPI3_SCK 0x0048 0x0320 0x3 0x1 -#define ULP1_PAD_PTC18__TPM6_CH0 0x0048 0x02d0 0x6 0x1 -#define ULP1_PAD_PTC18__FB_OE_B 0x0048 0x0000 0x9 0x0 -#define ULP1_PAD_PTC19__PTC19 0x004c 0x0000 0x1 0x0 -#define ULP1_PAD_PTC19__FXIO1_D15 0x004c 0x0240 0x2 0x1 -#define ULP1_PAD_PTC19__LPSPI3_PCS0 0x004c 0x0310 0x3 0x1 -#define ULP1_PAD_PTC19__TPM6_CH1 0x004c 0x02d4 0x6 0x1 -#define ULP1_PAD_PTC19__FB_A16 0x004c 0x0000 0x9 0x0 -#define ULP1_PAD_PTD0__PTD0 0x0080 0x0000 0x1 0x0 -#define ULP1_PAD_PTD0__SDHC0_RESET_B 0x0080 0x0000 0x8 0x0 -#define ULP1_PAD_PTD1__PTD1 0x0084 0x0000 0x1 0x0 -#define ULP1_PAD_PTD1__SDHC0_CMD 0x0084 0x0000 0x8 0x0 -#define ULP1_PAD_PTD2__PTD2 0x0088 0x0000 0x1 0x0 -#define ULP1_PAD_PTD2__SDHC0_CLK 0x0088 0x0000 0x8 0x0 -#define ULP1_PAD_PTD3__PTD3 0x008c 0x0000 0x1 0x0 -#define ULP1_PAD_PTD3__SDHC0_D7 0x008c 0x0000 0x8 0x0 -#define ULP1_PAD_PTD4__PTD4 0x0090 0x0000 0x1 0x0 -#define ULP1_PAD_PTD4__SDHC0_D6 0x0090 0x0000 0x8 0x0 -#define ULP1_PAD_PTD5__PTD5 0x0094 0x0000 0x1 0x0 -#define ULP1_PAD_PTD5__SDHC0_D5 0x0094 0x0000 0x8 0x0 -#define ULP1_PAD_PTD6__PTD6 0x0098 0x0000 0x1 0x0 -#define ULP1_PAD_PTD6__SDHC0_D4 0x0098 0x0000 0x8 0x0 -#define ULP1_PAD_PTD7__PTD7 0x009c 0x0000 0x1 0x0 -#define ULP1_PAD_PTD7__SDHC0_D3 0x009c 0x0000 0x8 0x0 -#define ULP1_PAD_PTD8__PTD8 0x00a0 0x0000 0x1 0x0 -#define ULP1_PAD_PTD8__TPM4_CLKIN 0x00a0 0x0298 0x6 0x2 -#define ULP1_PAD_PTD8__SDHC0_D2 0x00a0 0x0000 0x8 0x0 -#define ULP1_PAD_PTD9__PTD9 0x00a4 0x0000 0x1 0x0 -#define ULP1_PAD_PTD9__TPM4_CH0 0x00a4 0x0280 0x6 0x2 -#define ULP1_PAD_PTD9__SDHC0_D1 0x00a4 0x0000 0x8 0x0 -#define ULP1_PAD_PTD10__PTD10 0x00a8 0x0000 0x1 0x0 -#define ULP1_PAD_PTD10__TPM4_CH1 0x00a8 0x0284 0x6 0x2 -#define ULP1_PAD_PTD10__SDHC0_D0 0x00a8 0x0000 0x8 0x0 -#define ULP1_PAD_PTD11__PTD11 0x00ac 0x0000 0x1 0x0 -#define ULP1_PAD_PTD11__TPM4_CH2 0x00ac 0x0288 0x6 0x2 -#define ULP1_PAD_PTD11__SDHC0_DQS 0x00ac 0x0000 0x8 0x0 -#define ULP1_PAD_PTE0__PTE0 0x0100 0x0000 0x1 0x0 -#define ULP1_PAD_PTE0__FXIO1_D31 0x0100 0x0000 0x2 0x0 -#define ULP1_PAD_PTE0__LPSPI2_PCS1 0x0100 0x02a0 0x3 0x2 -#define ULP1_PAD_PTE0__LPUART4_CTS_B 0x0100 0x0244 0x4 0x2 -#define ULP1_PAD_PTE0__LPI2C4_SCL 0x0100 0x0278 0x5 0x2 -#define ULP1_PAD_PTE0__SDHC1_D1 0x0100 0x0000 0x8 0x0 -#define ULP1_PAD_PTE0__FB_A25 0x0100 0x0000 0x9 0x0 -#define ULP1_PAD_PTE1__PTE1 0x0104 0x0000 0x1 0x0 -#define ULP1_PAD_PTE1__FXIO1_D30 0x0104 0x0000 0x2 0x0 -#define ULP1_PAD_PTE1__LPSPI2_PCS2 0x0104 0x02a4 0x3 0x2 -#define ULP1_PAD_PTE1__LPUART4_RTS_B 0x0104 0x0000 0x4 0x0 -#define ULP1_PAD_PTE1__LPI2C4_SDA 0x0104 0x027c 0x5 0x2 -#define ULP1_PAD_PTE1__SDHC1_D0 0x0104 0x0000 0x8 0x0 -#define ULP1_PAD_PTE1__FB_A26 0x0104 0x0000 0x9 0x0 -#define ULP1_PAD_PTE2__PTE2 0x0108 0x0000 0x1 0x0 -#define ULP1_PAD_PTE2__FXIO1_D29 0x0108 0x0000 0x2 0x0 -#define ULP1_PAD_PTE2__LPSPI2_PCS3 0x0108 0x02a8 0x3 0x2 -#define ULP1_PAD_PTE2__LPUART4_TX 0x0108 0x024c 0x4 0x2 -#define ULP1_PAD_PTE2__LPI2C4_HREQ 0x0108 0x0274 0x5 0x2 -#define ULP1_PAD_PTE2__SDHC1_CLK 0x0108 0x0000 0x8 0x0 -#define ULP1_PAD_PTE3__PTE3 0x010c 0x0000 0x1 0x0 -#define ULP1_PAD_PTE3__FXIO1_D28 0x010c 0x0000 0x2 0x0 -#define ULP1_PAD_PTE3__LPUART4_RX 0x010c 0x0248 0x4 0x2 -#define ULP1_PAD_PTE3__TPM5_CH1 0x010c 0x02c8 0x6 0x2 -#define ULP1_PAD_PTE3__SDHC1_CMD 0x010c 0x0000 0x8 0x0 -#define ULP1_PAD_PTE4__PTE4 0x0110 0x0000 0x1 0x0 -#define ULP1_PAD_PTE4__FXIO1_D27 0x0110 0x0000 0x2 0x0 -#define ULP1_PAD_PTE4__LPSPI2_SIN 0x0110 0x02b0 0x3 0x2 -#define ULP1_PAD_PTE4__LPUART5_CTS_B 0x0110 0x0250 0x4 0x2 -#define ULP1_PAD_PTE4__LPI2C5_SCL 0x0110 0x02bc 0x5 0x2 -#define ULP1_PAD_PTE4__TPM5_CLKIN 0x0110 0x02cc 0x6 0x2 -#define ULP1_PAD_PTE4__SDHC1_D3 0x0110 0x0000 0x8 0x0 -#define ULP1_PAD_PTE5__PTE5 0x0114 0x0000 0x1 0x0 -#define ULP1_PAD_PTE5__FXIO1_D26 0x0114 0x0000 0x2 0x0 -#define ULP1_PAD_PTE5__LPSPI2_SOUT 0x0114 0x02b4 0x3 0x2 -#define ULP1_PAD_PTE5__LPUART5_RTS_B 0x0114 0x0000 0x4 0x0 -#define ULP1_PAD_PTE5__LPI2C5_SDA 0x0114 0x02c0 0x5 0x2 -#define ULP1_PAD_PTE5__TPM5_CH0 0x0114 0x02c4 0x6 0x2 -#define ULP1_PAD_PTE5__SDHC1_D2 0x0114 0x0000 0x8 0x0 -#define ULP1_PAD_PTE6__PTE6 0x0118 0x0000 0x1 0x0 -#define ULP1_PAD_PTE6__FXIO1_D25 0x0118 0x0000 0x2 0x0 -#define ULP1_PAD_PTE6__LPSPI2_SCK 0x0118 0x02ac 0x3 0x2 -#define ULP1_PAD_PTE6__LPUART5_TX 0x0118 0x0258 0x4 0x2 -#define ULP1_PAD_PTE6__LPI2C5_HREQ 0x0118 0x02b8 0x5 0x2 -#define ULP1_PAD_PTE6__TPM7_CH3 0x0118 0x02e8 0x6 0x2 -#define ULP1_PAD_PTE6__SDHC1_D4 0x0118 0x0000 0x8 0x0 -#define ULP1_PAD_PTE6__FB_A17 0x0118 0x0000 0x9 0x0 -#define ULP1_PAD_PTE7__PTE7 0x011c 0x0000 0x1 0x0 -#define ULP1_PAD_PTE7__TRACE_D7 0x011c 0x0000 0xa 0x0 -#define ULP1_PAD_PTE7__VIU_FID 0x011c 0x0000 0xc 0x0 -#define ULP1_PAD_PTE7__FXIO1_D24 0x011c 0x0000 0x2 0x0 -#define ULP1_PAD_PTE7__LPSPI2_PCS0 0x011c 0x029c 0x3 0x2 -#define ULP1_PAD_PTE7__LPUART5_RX 0x011c 0x0254 0x4 0x2 -#define ULP1_PAD_PTE7__TPM7_CH4 0x011c 0x02ec 0x6 0x2 -#define ULP1_PAD_PTE7__SDHC1_D5 0x011c 0x0000 0x8 0x0 -#define ULP1_PAD_PTE7__FB_A18 0x011c 0x0000 0x9 0x0 -#define ULP1_PAD_PTE8__PTE8 0x0120 0x0000 0x1 0x0 -#define ULP1_PAD_PTE8__TRACE_D6 0x0120 0x0000 0xa 0x0 -#define ULP1_PAD_PTE8__VIU_D16 0x0120 0x0000 0xc 0x0 -#define ULP1_PAD_PTE8__FXIO1_D23 0x0120 0x0000 0x2 0x0 -#define ULP1_PAD_PTE8__LPSPI3_PCS1 0x0120 0x0314 0x3 0x2 -#define ULP1_PAD_PTE8__LPUART6_CTS_B 0x0120 0x025c 0x4 0x2 -#define ULP1_PAD_PTE8__LPI2C6_SCL 0x0120 0x02fc 0x5 0x2 -#define ULP1_PAD_PTE8__TPM7_CH5 0x0120 0x02f0 0x6 0x2 -#define ULP1_PAD_PTE8__SDHC1_WP 0x0120 0x0200 0x7 0x1 -#define ULP1_PAD_PTE8__SDHC1_D6 0x0120 0x0000 0x8 0x0 -#define ULP1_PAD_PTE8__FB_CS3_B_FB_BE7_0_BLS31_24_B 0x0120 0x0000 0x9 0x0 -#define ULP1_PAD_PTE9__PTE9 0x0124 0x0000 0x1 0x0 -#define ULP1_PAD_PTE9__TRACE_D5 0x0124 0x0000 0xa 0x0 -#define ULP1_PAD_PTE9__VIU_D17 0x0124 0x0000 0xc 0x0 -#define ULP1_PAD_PTE9__FXIO1_D22 0x0124 0x0000 0x2 0x0 -#define ULP1_PAD_PTE9__LPSPI3_PCS2 0x0124 0x0318 0x3 0x2 -#define ULP1_PAD_PTE9__LPUART6_RTS_B 0x0124 0x0000 0x4 0x0 -#define ULP1_PAD_PTE9__LPI2C6_SDA 0x0124 0x0300 0x5 0x2 -#define ULP1_PAD_PTE9__TPM7_CLKIN 0x0124 0x02f4 0x6 0x2 -#define ULP1_PAD_PTE9__SDHC1_CD 0x0124 0x032c 0x7 0x1 -#define ULP1_PAD_PTE9__SDHC1_D7 0x0124 0x0000 0x8 0x0 -#define ULP1_PAD_PTE9__FB_TBST_B_FB_CS2_B_FB_BE15_8_BLS23_16_B 0x0124 0x0000 0x9 0x0 -#define ULP1_PAD_PTE10__PTE10 0x0128 0x0000 0x1 0x0 -#define ULP1_PAD_PTE10__TRACE_D4 0x0128 0x0000 0xa 0x0 -#define ULP1_PAD_PTE10__VIU_D18 0x0128 0x0000 0xc 0x0 -#define ULP1_PAD_PTE10__FXIO1_D21 0x0128 0x0000 0x2 0x0 -#define ULP1_PAD_PTE10__LPSPI3_PCS3 0x0128 0x031c 0x3 0x2 -#define ULP1_PAD_PTE10__LPUART6_TX 0x0128 0x0264 0x4 0x2 -#define ULP1_PAD_PTE10__LPI2C6_HREQ 0x0128 0x02f8 0x5 0x2 -#define ULP1_PAD_PTE10__TPM7_CH0 0x0128 0x02dc 0x6 0x2 -#define ULP1_PAD_PTE10__SDHC1_VS 0x0128 0x0000 0x7 0x0 -#define ULP1_PAD_PTE10__SDHC1_DQS 0x0128 0x0000 0x8 0x0 -#define ULP1_PAD_PTE10__FB_A19 0x0128 0x0000 0x9 0x0 -#define ULP1_PAD_PTE11__PTE11 0x012c 0x0000 0x1 0x0 -#define ULP1_PAD_PTE11__TRACE_D3 0x012c 0x0000 0xa 0x0 -#define ULP1_PAD_PTE11__VIU_D19 0x012c 0x0000 0xc 0x0 -#define ULP1_PAD_PTE11__FXIO1_D20 0x012c 0x0000 0x2 0x0 -#define ULP1_PAD_PTE11__LPUART6_RX 0x012c 0x0260 0x4 0x2 -#define ULP1_PAD_PTE11__TPM7_CH1 0x012c 0x02e0 0x6 0x2 -#define ULP1_PAD_PTE11__SDHC1_RESET_B 0x012c 0x0000 0x8 0x0 -#define ULP1_PAD_PTE11__FB_A20 0x012c 0x0000 0x9 0x0 -#define ULP1_PAD_PTE12__PTE12 0x0130 0x0000 0x1 0x0 -#define ULP1_PAD_PTE12__TRACE_D2 0x0130 0x0000 0xa 0x0 -#define ULP1_PAD_PTE12__VIU_D20 0x0130 0x0000 0xc 0x0 -#define ULP1_PAD_PTE12__FXIO1_D19 0x0130 0x0000 0x2 0x0 -#define ULP1_PAD_PTE12__LPSPI3_SIN 0x0130 0x0324 0x3 0x2 -#define ULP1_PAD_PTE12__LPUART7_CTS_B 0x0130 0x0268 0x4 0x2 -#define ULP1_PAD_PTE12__LPI2C7_SCL 0x0130 0x0308 0x5 0x2 -#define ULP1_PAD_PTE12__TPM7_CH2 0x0130 0x02e4 0x6 0x2 -#define ULP1_PAD_PTE12__SDHC1_WP 0x0130 0x0200 0x8 0x2 -#define ULP1_PAD_PTE12__FB_A21 0x0130 0x0000 0x9 0x0 -#define ULP1_PAD_PTE13__PTE13 0x0134 0x0000 0x1 0x0 -#define ULP1_PAD_PTE13__TRACE_D1 0x0134 0x0000 0xa 0x0 -#define ULP1_PAD_PTE13__VIU_D21 0x0134 0x0000 0xc 0x0 -#define ULP1_PAD_PTE13__FXIO1_D18 0x0134 0x0000 0x2 0x0 -#define ULP1_PAD_PTE13__LPSPI3_SOUT 0x0134 0x0328 0x3 0x2 -#define ULP1_PAD_PTE13__LPUART7_RTS_B 0x0134 0x0000 0x4 0x0 -#define ULP1_PAD_PTE13__LPI2C7_SDA 0x0134 0x030c 0x5 0x2 -#define ULP1_PAD_PTE13__TPM6_CLKIN 0x0134 0x02d8 0x6 0x2 -#define ULP1_PAD_PTE13__SDHC1_CD 0x0134 0x032c 0x8 0x2 -#define ULP1_PAD_PTE13__FB_A22 0x0134 0x0000 0x9 0x0 -#define ULP1_PAD_PTE14__PTE14 0x0138 0x0000 0x1 0x0 -#define ULP1_PAD_PTE14__TRACE_D0 0x0138 0x0000 0xa 0x0 -#define ULP1_PAD_PTE14__VIU_D22 0x0138 0x0000 0xc 0x0 -#define ULP1_PAD_PTE14__FXIO1_D17 0x0138 0x0000 0x2 0x0 -#define ULP1_PAD_PTE14__LPSPI3_SCK 0x0138 0x0320 0x3 0x2 -#define ULP1_PAD_PTE14__LPUART7_TX 0x0138 0x0270 0x4 0x2 -#define ULP1_PAD_PTE14__LPI2C7_HREQ 0x0138 0x0304 0x5 0x2 -#define ULP1_PAD_PTE14__TPM6_CH0 0x0138 0x02d0 0x6 0x2 -#define ULP1_PAD_PTE14__SDHC1_VS 0x0138 0x0000 0x8 0x0 -#define ULP1_PAD_PTE14__FB_A23 0x0138 0x0000 0x9 0x0 -#define ULP1_PAD_PTE15__PTE15 0x013c 0x0000 0x1 0x0 -#define ULP1_PAD_PTE15__TRACE_CLKOUT 0x013c 0x0000 0xa 0x0 -#define ULP1_PAD_PTE15__VIU_D23 0x013c 0x0000 0xc 0x0 -#define ULP1_PAD_PTE15__FXIO1_D16 0x013c 0x0000 0x2 0x0 -#define ULP1_PAD_PTE15__LPSPI3_PCS0 0x013c 0x0310 0x3 0x2 -#define ULP1_PAD_PTE15__LPUART7_RX 0x013c 0x026c 0x4 0x2 -#define ULP1_PAD_PTE15__TPM6_CH1 0x013c 0x02d4 0x6 0x2 -#define ULP1_PAD_PTE15__FB_A24 0x013c 0x0000 0x9 0x0 -#define ULP1_PAD_PTF0__PTF0 0x0180 0x0000 0x1 0x0 -#define ULP1_PAD_PTF0__VIU_DE 0x0180 0x0000 0xc 0x0 -#define ULP1_PAD_PTF0__LPUART4_CTS_B 0x0180 0x0244 0x4 0x3 -#define ULP1_PAD_PTF0__LPI2C4_SCL 0x0180 0x0278 0x5 0x3 -#define ULP1_PAD_PTF0__TPM4_CLKIN 0x0180 0x0298 0x6 0x3 -#define ULP1_PAD_PTF0__FB_RW_B 0x0180 0x0000 0x9 0x0 -#define ULP1_PAD_PTF1__PTF1 0x0184 0x0000 0x1 0x0 -#define ULP1_PAD_PTF1__VIU_HSYNC 0x0184 0x0000 0xc 0x0 -#define ULP1_PAD_PTF1__LPUART4_RTS_B 0x0184 0x0000 0x4 0x0 -#define ULP1_PAD_PTF1__LPI2C4_SDA 0x0184 0x027c 0x5 0x3 -#define ULP1_PAD_PTF1__TPM4_CH0 0x0184 0x0280 0x6 0x3 -#define ULP1_PAD_PTF1__CLKOUT 0x0184 0x0000 0x9 0x0 -#define ULP1_PAD_PTF2__PTF2 0x0188 0x0000 0x1 0x0 -#define ULP1_PAD_PTF2__VIU_VSYNC 0x0188 0x0000 0xc 0x0 -#define ULP1_PAD_PTF2__LPUART4_TX 0x0188 0x024c 0x4 0x3 -#define ULP1_PAD_PTF2__LPI2C4_HREQ 0x0188 0x0274 0x5 0x3 -#define ULP1_PAD_PTF2__TPM4_CH1 0x0188 0x0284 0x6 0x3 -#define ULP1_PAD_PTF2__FB_TSIZ1_FB_CS5_B_FB_BE23_16_BLS15_8_B 0x0188 0x0000 0x9 0x0 -#define ULP1_PAD_PTF3__PTF3 0x018c 0x0000 0x1 0x0 -#define ULP1_PAD_PTF3__VIU_PCLK 0x018c 0x0000 0xc 0x0 -#define ULP1_PAD_PTF3__LPUART4_RX 0x018c 0x0248 0x4 0x3 -#define ULP1_PAD_PTF3__TPM4_CH2 0x018c 0x0288 0x6 0x3 -#define ULP1_PAD_PTF3__FB_AD16 0x018c 0x0000 0x9 0x0 -#define ULP1_PAD_PTF4__PTF4 0x0190 0x0000 0x1 0x0 -#define ULP1_PAD_PTF4__VIU_D0 0x0190 0x0000 0xc 0x0 -#define ULP1_PAD_PTF4__FXIO1_D0 0x0190 0x0204 0x2 0x2 -#define ULP1_PAD_PTF4__LPSPI2_PCS1 0x0190 0x02a0 0x3 0x3 -#define ULP1_PAD_PTF4__LPUART5_CTS_B 0x0190 0x0250 0x4 0x3 -#define ULP1_PAD_PTF4__LPI2C5_SCL 0x0190 0x02bc 0x5 0x3 -#define ULP1_PAD_PTF4__TPM4_CH3 0x0190 0x028c 0x6 0x2 -#define ULP1_PAD_PTF4__FB_AD17 0x0190 0x0000 0x9 0x0 -#define ULP1_PAD_PTF5__PTF5 0x0194 0x0000 0x1 0x0 -#define ULP1_PAD_PTF5__VIU_D1 0x0194 0x0000 0xc 0x0 -#define ULP1_PAD_PTF5__FXIO1_D1 0x0194 0x0208 0x2 0x2 -#define ULP1_PAD_PTF5__LPSPI2_PCS2 0x0194 0x02a4 0x3 0x3 -#define ULP1_PAD_PTF5__LPUART5_RTS_B 0x0194 0x0000 0x4 0x0 -#define ULP1_PAD_PTF5__LPI2C5_SDA 0x0194 0x02c0 0x5 0x3 -#define ULP1_PAD_PTF5__TPM4_CH4 0x0194 0x0290 0x6 0x2 -#define ULP1_PAD_PTF5__FB_AD18 0x0194 0x0000 0x9 0x0 -#define ULP1_PAD_PTF6__PTF6 0x0198 0x0000 0x1 0x0 -#define ULP1_PAD_PTF6__VIU_D2 0x0198 0x0000 0xc 0x0 -#define ULP1_PAD_PTF6__FXIO1_D2 0x0198 0x020c 0x2 0x2 -#define ULP1_PAD_PTF6__LPSPI2_PCS3 0x0198 0x02a8 0x3 0x3 -#define ULP1_PAD_PTF6__LPUART5_TX 0x0198 0x0258 0x4 0x3 -#define ULP1_PAD_PTF6__LPI2C5_HREQ 0x0198 0x02b8 0x5 0x3 -#define ULP1_PAD_PTF6__TPM4_CH5 0x0198 0x0294 0x6 0x2 -#define ULP1_PAD_PTF6__FB_AD19 0x0198 0x0000 0x9 0x0 -#define ULP1_PAD_PTF7__PTF7 0x019c 0x0000 0x1 0x0 -#define ULP1_PAD_PTF7__VIU_D3 0x019c 0x0000 0xc 0x0 -#define ULP1_PAD_PTF7__FXIO1_D3 0x019c 0x0210 0x2 0x2 -#define ULP1_PAD_PTF7__LPUART5_RX 0x019c 0x0254 0x4 0x3 -#define ULP1_PAD_PTF7__TPM5_CH1 0x019c 0x02c8 0x6 0x3 -#define ULP1_PAD_PTF7__FB_AD20 0x019c 0x0000 0x9 0x0 -#define ULP1_PAD_PTF8__PTF8 0x01a0 0x0000 0x1 0x0 -#define ULP1_PAD_PTF8__USB1_ULPI_CLK 0x01a0 0x0000 0xb 0x0 -#define ULP1_PAD_PTF8__VIU_D4 0x01a0 0x0000 0xc 0x0 -#define ULP1_PAD_PTF8__FXIO1_D4 0x01a0 0x0214 0x2 0x2 -#define ULP1_PAD_PTF8__LPSPI2_SIN 0x01a0 0x02b0 0x3 0x3 -#define ULP1_PAD_PTF8__LPUART6_CTS_B 0x01a0 0x025c 0x4 0x3 -#define ULP1_PAD_PTF8__LPI2C6_SCL 0x01a0 0x02fc 0x5 0x3 -#define ULP1_PAD_PTF8__TPM5_CLKIN 0x01a0 0x02cc 0x6 0x3 -#define ULP1_PAD_PTF8__FB_AD21 0x01a0 0x0000 0x9 0x0 -#define ULP1_PAD_PTF9__PTF9 0x01a4 0x0000 0x1 0x0 -#define ULP1_PAD_PTF9__USB1_ULPI_NXT 0x01a4 0x0000 0xb 0x0 -#define ULP1_PAD_PTF9__VIU_D5 0x01a4 0x0000 0xc 0x0 -#define ULP1_PAD_PTF9__FXIO1_D5 0x01a4 0x0218 0x2 0x2 -#define ULP1_PAD_PTF9__LPSPI2_SOUT 0x01a4 0x02b4 0x3 0x3 -#define ULP1_PAD_PTF9__LPUART6_RTS_B 0x01a4 0x0000 0x4 0x0 -#define ULP1_PAD_PTF9__LPI2C6_SDA 0x01a4 0x0300 0x5 0x3 -#define ULP1_PAD_PTF9__TPM5_CH0 0x01a4 0x02c4 0x6 0x3 -#define ULP1_PAD_PTF9__FB_AD22 0x01a4 0x0000 0x9 0x0 -#define ULP1_PAD_PTF10__PTF10 0x01a8 0x0000 0x1 0x0 -#define ULP1_PAD_PTF10__USB1_ULPI_STP 0x01a8 0x0000 0xb 0x0 -#define ULP1_PAD_PTF10__VIU_D6 0x01a8 0x0000 0xc 0x0 -#define ULP1_PAD_PTF10__FXIO1_D6 0x01a8 0x021c 0x2 0x2 -#define ULP1_PAD_PTF10__LPSPI2_SCK 0x01a8 0x02ac 0x3 0x3 -#define ULP1_PAD_PTF10__LPUART6_TX 0x01a8 0x0264 0x4 0x3 -#define ULP1_PAD_PTF10__LPI2C6_HREQ 0x01a8 0x02f8 0x5 0x3 -#define ULP1_PAD_PTF10__TPM7_CH3 0x01a8 0x02e8 0x6 0x3 -#define ULP1_PAD_PTF10__FB_AD23 0x01a8 0x0000 0x9 0x0 -#define ULP1_PAD_PTF11__PTF11 0x01ac 0x0000 0x1 0x0 -#define ULP1_PAD_PTF11__USB1_ULPI_DIR 0x01ac 0x0000 0xb 0x0 -#define ULP1_PAD_PTF11__VIU_D7 0x01ac 0x0000 0xc 0x0 -#define ULP1_PAD_PTF11__FXIO1_D7 0x01ac 0x0220 0x2 0x2 -#define ULP1_PAD_PTF11__LPSPI2_PCS0 0x01ac 0x029c 0x3 0x3 -#define ULP1_PAD_PTF11__LPUART6_RX 0x01ac 0x0260 0x4 0x3 -#define ULP1_PAD_PTF11__TPM7_CH4 0x01ac 0x02ec 0x6 0x3 -#define ULP1_PAD_PTF11__FB_CS4_B_FB_TSIZ0_FB_BE31_24_BLS7_0_B 0x01ac 0x0000 0x9 0x0 -#define ULP1_PAD_PTF12__PTF12 0x01b0 0x0000 0x1 0x0 -#define ULP1_PAD_PTF12__USB1_ULPI_DATA0 0x01b0 0x0000 0xb 0x0 -#define ULP1_PAD_PTF12__VIU_D8 0x01b0 0x0000 0xc 0x0 -#define ULP1_PAD_PTF12__FXIO1_D8 0x01b0 0x0224 0x2 0x2 -#define ULP1_PAD_PTF12__LPSPI3_PCS1 0x01b0 0x0314 0x3 0x3 -#define ULP1_PAD_PTF12__LPUART7_CTS_B 0x01b0 0x0268 0x4 0x3 -#define ULP1_PAD_PTF12__LPI2C7_SCL 0x01b0 0x0308 0x5 0x3 -#define ULP1_PAD_PTF12__TPM7_CH5 0x01b0 0x02f0 0x6 0x3 -#define ULP1_PAD_PTF12__FB_AD24 0x01b0 0x0000 0x9 0x0 -#define ULP1_PAD_PTF13__PTF13 0x01b4 0x0000 0x1 0x0 -#define ULP1_PAD_PTF13__USB1_ULPI_DATA1 0x01b4 0x0000 0xb 0x0 -#define ULP1_PAD_PTF13__VIU_D9 0x01b4 0x0000 0xc 0x0 -#define ULP1_PAD_PTF13__FXIO1_D9 0x01b4 0x0228 0x2 0x2 -#define ULP1_PAD_PTF13__LPSPI3_PCS2 0x01b4 0x0318 0x3 0x3 -#define ULP1_PAD_PTF13__LPUART7_RTS_B 0x01b4 0x0000 0x4 0x0 -#define ULP1_PAD_PTF13__LPI2C7_SDA 0x01b4 0x030c 0x5 0x3 -#define ULP1_PAD_PTF13__TPM7_CLKIN 0x01b4 0x02f4 0x6 0x3 -#define ULP1_PAD_PTF13__FB_AD25 0x01b4 0x0000 0x9 0x0 -#define ULP1_PAD_PTF14__PTF14 0x01b8 0x0000 0x1 0x0 -#define ULP1_PAD_PTF14__USB1_ULPI_DATA2 0x01b8 0x0000 0xb 0x0 -#define ULP1_PAD_PTF14__VIU_D10 0x01b8 0x0000 0xc 0x0 -#define ULP1_PAD_PTF14__FXIO1_D10 0x01b8 0x022c 0x2 0x2 -#define ULP1_PAD_PTF14__LPSPI3_PCS3 0x01b8 0x031c 0x3 0x3 -#define ULP1_PAD_PTF14__LPUART7_TX 0x01b8 0x0270 0x4 0x3 -#define ULP1_PAD_PTF14__LPI2C7_HREQ 0x01b8 0x0304 0x5 0x3 -#define ULP1_PAD_PTF14__TPM7_CH0 0x01b8 0x02dc 0x6 0x3 -#define ULP1_PAD_PTF14__FB_AD26 0x01b8 0x0000 0x9 0x0 -#define ULP1_PAD_PTF15__PTF15 0x01bc 0x0000 0x1 0x0 -#define ULP1_PAD_PTF15__USB1_ULPI_DATA3 0x01bc 0x0000 0xb 0x0 -#define ULP1_PAD_PTF15__VIU_D11 0x01bc 0x0000 0xc 0x0 -#define ULP1_PAD_PTF15__FXIO1_D11 0x01bc 0x0230 0x2 0x2 -#define ULP1_PAD_PTF15__LPUART7_RX 0x01bc 0x026c 0x4 0x3 -#define ULP1_PAD_PTF15__TPM7_CH1 0x01bc 0x02e0 0x6 0x3 -#define ULP1_PAD_PTF15__FB_AD27 0x01bc 0x0000 0x9 0x0 -#define ULP1_PAD_PTF16__PTF16 0x01c0 0x0000 0x1 0x0 -#define ULP1_PAD_PTF16__USB1_ULPI_DATA4 0x01c0 0x0000 0xb 0x0 -#define ULP1_PAD_PTF16__VIU_D12 0x01c0 0x0000 0xc 0x0 -#define ULP1_PAD_PTF16__FXIO1_D12 0x01c0 0x0234 0x2 0x2 -#define ULP1_PAD_PTF16__LPSPI3_SIN 0x01c0 0x0324 0x3 0x3 -#define ULP1_PAD_PTF16__TPM7_CH2 0x01c0 0x02e4 0x6 0x3 -#define ULP1_PAD_PTF16__FB_AD28 0x01c0 0x0000 0x9 0x0 -#define ULP1_PAD_PTF17__PTF17 0x01c4 0x0000 0x1 0x0 -#define ULP1_PAD_PTF17__USB1_ULPI_DATA5 0x01c4 0x0000 0xb 0x0 -#define ULP1_PAD_PTF17__VIU_D13 0x01c4 0x0000 0xc 0x0 -#define ULP1_PAD_PTF17__FXIO1_D13 0x01c4 0x0238 0x2 0x2 -#define ULP1_PAD_PTF17__LPSPI3_SOUT 0x01c4 0x0328 0x3 0x3 -#define ULP1_PAD_PTF17__TPM6_CLKIN 0x01c4 0x02d8 0x6 0x3 -#define ULP1_PAD_PTF17__FB_AD29 0x01c4 0x0000 0x9 0x0 -#define ULP1_PAD_PTF18__PTF18 0x01c8 0x0000 0x1 0x0 -#define ULP1_PAD_PTF18__USB1_ULPI_DATA6 0x01c8 0x0000 0xb 0x0 -#define ULP1_PAD_PTF18__VIU_D14 0x01c8 0x0000 0xc 0x0 -#define ULP1_PAD_PTF18__FXIO1_D14 0x01c8 0x023c 0x2 0x2 -#define ULP1_PAD_PTF18__LPSPI3_SCK 0x01c8 0x0320 0x3 0x3 -#define ULP1_PAD_PTF18__TPM6_CH0 0x01c8 0x02d0 0x6 0x3 -#define ULP1_PAD_PTF18__FB_AD30 0x01c8 0x0000 0x9 0x0 -#define ULP1_PAD_PTF19__PTF19 0x01cc 0x0000 0x1 0x0 -#define ULP1_PAD_PTF19__USB1_ULPI_DATA7 0x01cc 0x0000 0xb 0x0 -#define ULP1_PAD_PTF19__VIU_D15 0x01cc 0x0000 0xc 0x0 -#define ULP1_PAD_PTF19__FXIO1_D15 0x01cc 0x0240 0x2 0x2 -#define ULP1_PAD_PTF19__LPSPI3_PCS0 0x01cc 0x0310 0x3 0x3 -#define ULP1_PAD_PTF19__TPM6_CH1 0x01cc 0x02d4 0x6 0x3 -#define ULP1_PAD_PTF19__FB_AD31 0x01cc 0x0000 0x9 0x0 - -#endif /* __DTS_ULP1_PINFUNC_H */ +#endif /* __DTS_IMX7ULP_PINFUNC_H */ diff --git a/arch/arm/dts/imx7ulp.dtsi b/arch/arm/dts/imx7ulp.dtsi index a8458f89d5..7bcd2cc346 100644 --- a/arch/arm/dts/imx7ulp.dtsi +++ b/arch/arm/dts/imx7ulp.dtsi @@ -16,10 +16,12 @@ interrupt-parent = <&intc>;
aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; + gpio0 = &gpio4; + gpio1 = &gpio5; + gpio2 = &gpio0; + gpio3 = &gpio1; + gpio4 = &gpio2; + gpio5 = &gpio3; mmc0 = &usdhc0; mmc1 = &usdhc1; serial0 = &lpuart4; @@ -27,10 +29,12 @@ serial2 = &lpuart6; serial3 = &lpuart7; usbphy0 = &usbphy1; + usb0 = &usbotg1; i2c4 = &lpi2c4; i2c5 = &lpi2c5; i2c6 = &lpi2c6; i2c7 = &lpi2c7; + spi0 = &qspi1; };
cpus { @@ -503,6 +507,22 @@ fsl,mux_mask = <0xf00>; };
+ gpio4: gpio@4103f000 { + compatible = "fsl,imx7ulp-gpio"; + reg = <0x4103f000 0x1000 0x4100F000 0x40>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&iomuxc 0 0 32>; + }; + + gpio5: gpio@41040000 { + compatible = "fsl,imx7ulp-gpio"; + reg = <0x41040000 0x1000 0x4100F040 0x40>; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&iomuxc 0 32 32>; + }; + gpio0: gpio@40ae0000 { compatible = "fsl,imx7ulp-gpio"; reg = <0x40ae0000 0x1000 0x400F0000 0x40>;
The Embedded Artists COM board is based on NXP i.MX7ULP.
It has a BD70528 PMIC from Rohm with discrete DCDC powering option and improved current observability (compared to the existing NXP i.MX7ULP EVK).
Add the initial support for the board.
Signed-off-by: Fabio Estevam festevam@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/mach-imx/mx7ulp/Kconfig | 6 ++ board/ea/mx7ulp_com/Kconfig | 12 +++ board/ea/mx7ulp_com/MAINTAINERS | 6 ++ board/ea/mx7ulp_com/Makefile | 6 ++ board/ea/mx7ulp_com/imximage.cfg | 128 ++++++++++++++++++++++ board/ea/mx7ulp_com/imximage.cfg.cfgtmp | 134 ++++++++++++++++++++++++ board/ea/mx7ulp_com/imximage.cfg.rej | 43 ++++++++ board/ea/mx7ulp_com/mx7ulp_com.c | 48 +++++++++ configs/mx7ulp_com_defconfig | 59 +++++++++++ include/configs/mx7ulp_com.h | 107 +++++++++++++++++++ 11 files changed, 551 insertions(+), 1 deletion(-) create mode 100644 board/ea/mx7ulp_com/Kconfig create mode 100644 board/ea/mx7ulp_com/MAINTAINERS create mode 100644 board/ea/mx7ulp_com/Makefile create mode 100644 board/ea/mx7ulp_com/imximage.cfg create mode 100644 board/ea/mx7ulp_com/imximage.cfg.cfgtmp create mode 100644 board/ea/mx7ulp_com/imximage.cfg.rej create mode 100644 board/ea/mx7ulp_com/mx7ulp_com.c create mode 100644 configs/mx7ulp_com_defconfig create mode 100644 include/configs/mx7ulp_com.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7d1de944e1..0d9945d716 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -639,7 +639,8 @@ dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \ imx7d-pico-hobbit.dtb
-dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb +dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-com.dtb \ + imx7ulp-evk.dtb
dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qm-apalis.dtb \ diff --git a/arch/arm/mach-imx/mx7ulp/Kconfig b/arch/arm/mach-imx/mx7ulp/Kconfig index 138c58363f..6680f856c5 100644 --- a/arch/arm/mach-imx/mx7ulp/Kconfig +++ b/arch/arm/mach-imx/mx7ulp/Kconfig @@ -15,6 +15,11 @@ choice prompt "MX7ULP board select" optional
+config TARGET_MX7ULP_COM + bool "Support MX7ULP COM board" + select MX7ULP + select SYS_ARCH_TIMER + config TARGET_MX7ULP_EVK bool "Support mx7ulp EVK board" select MX7ULP @@ -22,6 +27,7 @@ config TARGET_MX7ULP_EVK
endchoice
+source "board/ea/mx7ulp_com/Kconfig" source "board/freescale/mx7ulp_evk/Kconfig"
endif diff --git a/board/ea/mx7ulp_com/Kconfig b/board/ea/mx7ulp_com/Kconfig new file mode 100644 index 0000000000..90883aced4 --- /dev/null +++ b/board/ea/mx7ulp_com/Kconfig @@ -0,0 +1,12 @@ +if TARGET_MX7ULP_COM + +config SYS_BOARD + default "mx7ulp_com" + +config SYS_VENDOR + default "ea" + +config SYS_CONFIG_NAME + default "mx7ulp_com" + +endif diff --git a/board/ea/mx7ulp_com/MAINTAINERS b/board/ea/mx7ulp_com/MAINTAINERS new file mode 100644 index 0000000000..3f69511b1a --- /dev/null +++ b/board/ea/mx7ulp_com/MAINTAINERS @@ -0,0 +1,6 @@ +MX7ULPCOM BOARD +M: Fabio Estevam festevam@gmail.com +S: Maintained +F: board/ea/mx7ulp_com/ +F: include/configs/mx7ulp_com.h +F: configs/mx7ulp_com_defconfig diff --git a/board/ea/mx7ulp_com/Makefile b/board/ea/mx7ulp_com/Makefile new file mode 100644 index 0000000000..b3b230b172 --- /dev/null +++ b/board/ea/mx7ulp_com/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2016 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx7ulp_com.o diff --git a/board/ea/mx7ulp_com/imximage.cfg b/board/ea/mx7ulp_com/imximage.cfg new file mode 100644 index 0000000000..bda4acfd91 --- /dev/null +++ b/board/ea/mx7ulp_com/imximage.cfg @@ -0,0 +1,128 @@ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +BOOT_FROM sd + +#ifdef CONFIG_USE_IMXIMG_PLUGIN +/*PLUGIN plugin-binary-file IRAM_FREE_START_ADDR*/ +PLUGIN board/freescale/mx7ulp_evk/plugin.bin 0x2F020000 +#else + +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ +DATA 4 0x403f00dc 0x00000000 +DATA 4 0x403e0040 0x01000020 +DATA 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x80808080 +DATA 4 0x403e0508 0x00160002 +DATA 4 0x403E0510 0x00000001 +DATA 4 0x403E0514 0x00000014 +DATA 4 0x403e0500 0x00000001 +CHECK_BITS_SET 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x8080801B +CHECK_BITS_SET 4 0x403e050c 0x00000040 +DATA 4 0x403E0030 0x00000001 +DATA 4 0x403e0040 0x11000020 +DATA 4 0x403f00dc 0x42000000 + +DATA 4 0x40B300AC 0x40000000 + +DATA 4 0x40AD0128 0x00040000 +DATA 4 0x40AD00F8 0x00000000 +DATA 4 0x40AD00D8 0x00000180 +DATA 4 0x40AD0104 0x00000180 +DATA 4 0x40AD0108 0x00000180 +DATA 4 0x40AD0124 0x00010000 +DATA 4 0x40AD0080 0x0000018C +DATA 4 0x40AD0084 0x0000018C +DATA 4 0x40AD0088 0x0000018C +DATA 4 0x40AD008C 0x0000018C + +DATA 4 0x40AD0120 0x00010000 +DATA 4 0x40AD010C 0x00000180 +DATA 4 0x40AD0110 0x00000180 +DATA 4 0x40AD0114 0x00000180 +DATA 4 0x40AD0118 0x00000180 +DATA 4 0x40AD0090 0x00000180 +DATA 4 0x40AD0094 0x00000180 +DATA 4 0x40AD0098 0x00000180 +DATA 4 0x40AD009C 0x00000180 + +DATA 4 0x40AD00E0 0x00040000 +DATA 4 0x40AD00E4 0x00040000 + +DATA 4 0x40AB001C 0x00008000 +DATA 4 0x40AB085C 0x0D3900A0 +DATA 4 0x40AB0800 0xA1390003 +DATA 4 0x40AB0890 0x00400000 +DATA 4 0x40AB081C 0x33333333 +DATA 4 0x40AB0820 0x33333333 +DATA 4 0x40AB0824 0x33333333 +DATA 4 0x40AB0828 0x33333333 +DATA 4 0x40AB08C0 0x24922492 +DATA 4 0x40AB0848 0x3A3E3838 +DATA 4 0x40AB0850 0x28282C2A +DATA 4 0x40AB083C 0x20000000 +DATA 4 0x40AB0840 0x00000000 +DATA 4 0x40AB08B8 0x00000800 +DATA 4 0x40AB000C 0x292C40F5 +DATA 4 0x40AB0004 0x00020064 +DATA 4 0x40AB0010 0xB6AD0A83 +DATA 4 0x40AB0014 0x00C70093 +DATA 4 0x40AB0018 0x00211708 +DATA 4 0x40AB002C 0x0F9F26D2 +DATA 4 0x40AB0030 0x009F0E10 +DATA 4 0x40AB0038 0x00130556 +DATA 4 0x40AB0008 0x12272000 +DATA 4 0x40AB0040 0x0000003F +DATA 4 0x40AB0000 0xC3110000 +DATA 4 0x40AB001C 0x00008010 +DATA 4 0x40AB001C 0x00008018 +DATA 4 0x40AB001C 0x003F8030 +DATA 4 0x40AB001C 0xFF0A8030 +DATA 4 0x40AB001C 0x82018030 +DATA 4 0x40AB001C 0x06028030 +DATA 4 0x40AB001C 0x01038030 +DATA 4 0x40AB001C 0x003F8038 +DATA 4 0x40AB001C 0xFF0A8038 +DATA 4 0x40AB001C 0x82018038 +DATA 4 0x40AB001C 0x06028038 +DATA 4 0x40AB001C 0x01038038 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB0020 0x00001800 +DATA 4 0x40AB0800 0xA1310003 +DATA 4 0x40AB001C 0x00000000 +#endif diff --git a/board/ea/mx7ulp_com/imximage.cfg.cfgtmp b/board/ea/mx7ulp_com/imximage.cfg.cfgtmp new file mode 100644 index 0000000000..a5bcfe2fc4 --- /dev/null +++ b/board/ea/mx7ulp_com/imximage.cfg.cfgtmp @@ -0,0 +1,134 @@ +# 1 "board/ea/mx7ulp_com/imximage.cfg" +# 1 "<built-in>" +# 1 "<command-line>" +# 1 "././include/linux/kconfig.h" 1 + + + +# 1 "include/generated/autoconf.h" 1 +# 5 "././include/linux/kconfig.h" 2 +# 1 "<command-line>" 2 +# 1 "board/ea/mx7ulp_com/imximage.cfg" +# 13 "board/ea/mx7ulp_com/imximage.cfg" +# 1 "include/config.h" 1 + + + +# 1 "include/config_defaults.h" 1 +# 5 "include/config.h" 2 +# 1 "include/config_uncmd_spl.h" 1 +# 6 "include/config.h" 2 +# 1 "include/configs/mx7ulp_com.h" 1 +# 13 "include/configs/mx7ulp_com.h" +# 1 "include/linux/sizes.h" 1 +# 14 "include/configs/mx7ulp_com.h" 2 +# 1 "./arch/arm/include/asm/arch/imx-regs.h" 1 +# 970 "./arch/arm/include/asm/arch/imx-regs.h" +# 1 "./arch/arm/include/asm/mach-imx/regs-lcdif.h" 1 +# 971 "./arch/arm/include/asm/arch/imx-regs.h" 2 +# 15 "include/configs/mx7ulp_com.h" 2 +# 1 "include/configs/imx_env.h" 1 +# 16 "include/configs/mx7ulp_com.h" 2 +# 7 "include/config.h" 2 +# 1 "./arch/arm/include/asm/config.h" 1 +# 8 "include/config.h" 2 +# 1 "include/linux/kconfig.h" 1 +# 9 "include/config.h" 2 +# 1 "include/config_fallbacks.h" 1 +# 9 "include/config.h" 2 +# 14 "board/ea/mx7ulp_com/imximage.cfg" 2 + + + +IMAGE_VERSION 2 + + + + + + +BOOT_FROM sd +# 45 "board/ea/mx7ulp_com/imximage.cfg" +DATA 4 0x403f00dc 0x00000000 +DATA 4 0x403e0040 0x01000020 +DATA 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x80808080 +DATA 4 0x403e0508 0x00160002 +DATA 4 0x403E0510 0x00000001 +DATA 4 0x403E0514 0x00000014 +DATA 4 0x403e0500 0x00000001 +CHECK_BITS_SET 4 0x403e0500 0x01000000 +DATA 4 0x403e050c 0x8080801B +CHECK_BITS_SET 4 0x403e050c 0x00000040 +DATA 4 0x403E0030 0x00000001 +DATA 4 0x403e0040 0x11000020 +DATA 4 0x403f00dc 0x42000000 + +DATA 4 0x40B300AC 0x40000000 + +DATA 4 0x40AD0128 0x00040000 +DATA 4 0x40AD00F8 0x00000000 +DATA 4 0x40AD00D8 0x00000180 +DATA 4 0x40AD0104 0x00000180 +DATA 4 0x40AD0108 0x00000180 +DATA 4 0x40AD0124 0x00010000 +DATA 4 0x40AD0080 0x0000018C +DATA 4 0x40AD0084 0x0000018C +DATA 4 0x40AD0088 0x0000018C +DATA 4 0x40AD008C 0x0000018C + +DATA 4 0x40AD0120 0x00010000 +DATA 4 0x40AD010C 0x00000180 +DATA 4 0x40AD0110 0x00000180 +DATA 4 0x40AD0114 0x00000180 +DATA 4 0x40AD0118 0x00000180 +DATA 4 0x40AD0090 0x00000180 +DATA 4 0x40AD0094 0x00000180 +DATA 4 0x40AD0098 0x00000180 +DATA 4 0x40AD009C 0x00000180 + +DATA 4 0x40AD00E0 0x00040000 +DATA 4 0x40AD00E4 0x00040000 + +DATA 4 0x40AB001C 0x00008000 +DATA 4 0x40AB085C 0x0D3900A0 +DATA 4 0x40AB0800 0xA1390003 +DATA 4 0x40AB0890 0x00400000 +DATA 4 0x40AB081C 0x33333333 +DATA 4 0x40AB0820 0x33333333 +DATA 4 0x40AB0824 0x33333333 +DATA 4 0x40AB0828 0x33333333 +DATA 4 0x40AB08C0 0x24922492 +DATA 4 0x40AB0848 0x3A3E3838 +DATA 4 0x40AB0850 0x28282C2A +DATA 4 0x40AB083C 0x20000000 +DATA 4 0x40AB0840 0x00000000 +DATA 4 0x40AB08B8 0x00000800 +DATA 4 0x40AB000C 0x292C40F5 +DATA 4 0x40AB0004 0x00020064 +DATA 4 0x40AB0010 0xB6AD0A83 +DATA 4 0x40AB0014 0x00C70093 +DATA 4 0x40AB0018 0x00211708 +DATA 4 0x40AB002C 0x0F9F26D2 +DATA 4 0x40AB0030 0x009F0E10 +DATA 4 0x40AB0038 0x00130556 +DATA 4 0x40AB0008 0x12272000 +DATA 4 0x40AB0040 0x0000003F +DATA 4 0x40AB0000 0xC3110000 +DATA 4 0x40AB001C 0x00008010 +DATA 4 0x40AB001C 0x00008018 +DATA 4 0x40AB001C 0x003F8030 +DATA 4 0x40AB001C 0xFF0A8030 +DATA 4 0x40AB001C 0x82018030 +DATA 4 0x40AB001C 0x06028030 +DATA 4 0x40AB001C 0x01038030 +DATA 4 0x40AB001C 0x003F8038 +DATA 4 0x40AB001C 0xFF0A8038 +DATA 4 0x40AB001C 0x82018038 +DATA 4 0x40AB001C 0x06028038 +DATA 4 0x40AB001C 0x01038038 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB083C 0xA0000000 +DATA 4 0x40AB0020 0x00001800 +DATA 4 0x40AB0800 0xA1310003 +DATA 4 0x40AB001C 0x00000000 diff --git a/board/ea/mx7ulp_com/imximage.cfg.rej b/board/ea/mx7ulp_com/imximage.cfg.rej new file mode 100644 index 0000000000..b6fae6e13b --- /dev/null +++ b/board/ea/mx7ulp_com/imximage.cfg.rej @@ -0,0 +1,43 @@ +--- board/ea/mx7ulp_com/imximage.cfg ++++ board/ea/mx7ulp_com/imximage.cfg +@@ -92,32 +92,32 @@ DATA 4 0x40AB0820 0x33333333 + DATA 4 0x40AB0824 0x33333333 + DATA 4 0x40AB0828 0x33333333 + DATA 4 0x40AB08C0 0x24922492 +-DATA 4 0x40AB0848 0x3A383838 +-DATA 4 0x40AB0850 0x362E3636 ++DATA 4 0x40AB0848 0x3A3E3838 ++DATA 4 0x40AB0850 0x28282C2A + DATA 4 0x40AB0840 0x00000000 + DATA 4 0x40AB08B8 0x00000800 +-DATA 4 0x40AB000C 0x33374133 ++DATA 4 0x40AB000C 0x292C40F5 + DATA 4 0x40AB0004 0x00020064 +-DATA 4 0x40AB0010 0xB6B00A82 ++DATA 4 0x40AB0010 0xB6AD0A83 + DATA 4 0x40AB0014 0x00C70093 + DATA 4 0x40AB0018 0x00211708 + DATA 4 0x40AB002C 0x0F9F26D2 + DATA 4 0x40AB0030 0x009F0E10 +-DATA 4 0x40AB0038 0x00170778 ++DATA 4 0x40AB0038 0x00130556 + DATA 4 0x40AB0008 0x12272000 + DATA 4 0x40AB0040 0x0000003F +-DATA 4 0x40AB0000 0xC4110000 ++DATA 4 0x40AB0000 0xC3110000 + DATA 4 0x40AB001C 0x00008010 + DATA 4 0x40AB001C 0x00008018 + DATA 4 0x40AB001C 0x003F8030 + DATA 4 0x40AB001C 0xFF0A8030 + DATA 4 0x40AB001C 0x82018030 +-DATA 4 0x40AB001C 0x04028030 ++DATA 4 0x40AB001C 0x06028030 + DATA 4 0x40AB001C 0x01038030 + DATA 4 0x40AB001C 0x003F8038 + DATA 4 0x40AB001C 0xFF0A8038 + DATA 4 0x40AB001C 0x82018038 +-DATA 4 0x40AB001C 0x04028038 ++DATA 4 0x40AB001C 0x06028038 + DATA 4 0x40AB001C 0x01038038 + DATA 4 0x40AB083C 0xA0000000 + DATA 4 0x40AB083C 0xA0000000 diff --git a/board/ea/mx7ulp_com/mx7ulp_com.c b/board/ea/mx7ulp_com/mx7ulp_com.c new file mode 100644 index 0000000000..6fc1631bf7 --- /dev/null +++ b/board/ea/mx7ulp_com/mx7ulp_com.c @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mx7ulp-pins.h> +#include <asm/arch/iomux.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_UP) + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + + return 0; +} + +static iomux_cfg_t const lpuart4_pads[] = { + MX7ULP_PAD_PTC3__LPUART4_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7ULP_PAD_PTC2__LPUART4_TX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + mx7ulp_iomux_setup_multiple_pads(lpuart4_pads, + ARRAY_SIZE(lpuart4_pads)); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} diff --git a/configs/mx7ulp_com_defconfig b/configs/mx7ulp_com_defconfig new file mode 100644 index 0000000000..476504a813 --- /dev/null +++ b/configs/mx7ulp_com_defconfig @@ -0,0 +1,59 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX7ULP=y +CONFIG_SYS_TEXT_BASE=0x67800000 +CONFIG_LDO_ENABLED_MODE=y +CONFIG_TARGET_MX7ULP_COM=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_IMX7ULP_LOWER_DDR_FREQUENCY=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ea/mx7ulp_com/imximage.cfg" +CONFIG_DEFAULT_FDT_FILE="imx7ulp-com" +CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_READ=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx7ulp-com" +CONFIG_ENV_IS_IN_MMC=y +# CONFIG_NET is not set +CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_IMX_RGPIO2P=y +# CONFIG_MXC_GPIO is not set +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_IMX_LPI2C=y +CONFIG_DM_MMC=y +CONFIG_FSL_USDHC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7ULP=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y +CONFIG_FSL_LPUART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_ULP_WATCHDOG=y diff --git a/include/configs/mx7ulp_com.h b/include/configs/mx7ulp_com.h new file mode 100644 index 0000000000..ba32afde38 --- /dev/null +++ b/include/configs/mx7ulp_com.h @@ -0,0 +1,107 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2016 Freescale Semiconductor, Inc. + * + * Configuration settings for the Embedded Artists i.MX7ULP COM board. + */ + +#ifndef __MX7ULP_COM_CONFIG_H +#define __MX7ULP_COM_CONFIG_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_BOARD_POSTCLK_INIT +#define CONFIG_SYS_BOOTM_LEN 0x1000000 + +#define SRC_BASE_ADDR CMC1_RBASE +#define IRAM_BASE_ADDR OCRAM_0_BASE +#define IOMUXC_BASE_ADDR IOMUXC1_RBASE + +/* Environment starts at 768k = 768 * 1024 = 786432 */ +#define CONFIG_ENV_OFFSET 786432 +/* + * Detect overlap between U-Boot image and environment area in build-time + * + * CONFIG_BOARD_SIZE_LIMIT = CONFIG_ENV_OFFSET - u-boot-dtb.imx offset + * CONFIG_BOARD_SIZE_LIMIT = 768k - 1k = 767k = 785408 + * + * Currently CONFIG_BOARD_SIZE_LIMIT does not handle expressions, so + * write the direct value here + */ +#define CONFIG_BOARD_SIZE_LIMIT 785408 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_MMCROOT "/dev/mmcblk0p2" +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_ENV_SIZE SZ_8K + +/* Using ULP WDOG for reset */ +#define WDOG_BASE_ADDR WDG1_RBASE + +#define CONFIG_SYS_HZ_CLOCK 1000000 /* Fixed at 1MHz from TSTMR */ + +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (8 * SZ_1M) + +/* UART */ +#define LPUART_BASE LPUART4_RBASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Physical Memory Map */ + +#define PHYS_SDRAM 0x60000000 +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM + +#define CONFIG_LOADADDR 0x60800000 + +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + SZ_512M) + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "image=zImage\0" \ + "console=ttyLP0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx7ulp-com.dtb\0" \ + "fdt_addr=0x63000000\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "fi;\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if run loadimage; then " \ + "run mmcboot; " \ + "fi; " \ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE SZ_256K + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#if !CONFIG_IS_ENABLED(SYS_DCACHE_OFF) +#define CONFIG_CMD_CACHE +#endif + +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#endif /* __CONFIG_H */
Fabio Estevam
