[U-Boot-Users] [PATCH] TQM5200: Call usb_cpu_init() during board init
usb_cpu_init() configures GPS USB pins, clocks, etc. and is required for proper operation of kernel USB subsystem. This setup was previously done in the kernel by the fixup code which is being removed, thus low level init must be done by U-boot now.
Signed-off-by: Marian Balakowicz m8@semihalf.com ---
board/tqm5200/tqm5200.c | 10 ++++++++-- 1 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/tqm5200/tqm5200.c b/board/tqm5200/tqm5200.c index 29d6f00..9e24578 100644 --- a/board/tqm5200/tqm5200.c +++ b/board/tqm5200/tqm5200.c @@ -441,15 +441,21 @@ ulong post_word_load (void) } #endif /* CONFIG_POST || CONFIG_LOGBUFFER*/
-#ifdef CONFIG_PS2MULT #ifdef CONFIG_BOARD_EARLY_INIT_R int board_early_init_r (void) { +#ifdef CONFIG_PS2MULT ps2mult_early_init(); +#endif /* CONFIG_PS2MULT */ + +#if defined(CONFIG_USB_OHCI_NEW) && defined(CFG_USB_OHCI_CPU_INIT) + /* Low level USB init, required for proper kernel operation */ + usb_cpu_init(); +#endif + return (0); } #endif -#endif /* CONFIG_PS2MULT */
#ifdef CONFIG_FO300 int silent_boot (void)
Marian Balakowicz m8@semihalf.com writes:
Thanks, added to USB custodian repo.
Best regards
Markus Klotzbuecher
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Applied, thanks.
Marian Balakowicz
Markus Klotzbücher
