[PATCH v3 0/3] Add StarFive JH7110 PCIe drvier support
This patchset needs to apply after patchset in [1]. These PCIe series patches are based on the JH7110 RISC-V SoC and VisionFive V2 board.
[1] https://patchwork.ozlabs.org/project/uboot/cover/20230329034224.26545-1-yanh...
The PCIe driver depends on gpio, pinctrl, clk and reset driver to do init. The PCIe dts configuation includes all these setting.
The PCIe drivers codes has been tested on the VisionFive V2 boards. The test devices includes M.2 NVMe SSD and Realtek 8169 Ethernet adapter.
previous patch version
v1: https://patchwork.ozlabs.org/project/uboot/cover/20230223105240.15180-1-mind... v2: https://patchwork.ozlabs.org/project/uboot/cover/20230308054833.95730-1-mind...
changes v2 1. remove clock commit. The pcie clocks change has been includeded in [1]. 2. Using GENMASK marco1 in patch1. 3. remove the syscon dts node in patch3. The syscon dts dts node has been included in [1].
v3 patch 1 1. remove the read vendor ID delay 2. remove starfive_pcie_hide_rc_bar function. do not hide host bridge BAR write. 3. Using PCIE_ECAM_OFFSET and PCI_CLASS_BRIDGE_PCI_NORMAL macros. 4. Add comments for bus and address limitation reason in function starfive_pcie_addr_valid 5. Change the multiple line comments in Line 373 6. Using gpio_request_by_name to get PCIe reset gpio,and using dm_gpio_set_value set GPIO value. patch 2 1. support PCIeboth 12a and 13b vf2 board. patch 3 1. reset dts change to reset-gpio.
The JH7110 minimal system patchset upstream is in progress. PCIe driver patches is based on this patchset.
The JH7110 minimal system patchset details are listed in [1].
For more JH7110 and visionFive v2 information and support, you can visit RVspace wiki[2].
Mason Huo (3): starfive: pci: Add StarFive JH7110 pcie driver configs: starfive-jh7110: Add support for PCIe host driver riscv: dts: starfive: Enable PCIe host controller
.../dts/jh7110-starfive-visionfive-2.dtsi | 11 + arch/riscv/dts/jh7110.dtsi | 74 +++ configs/starfive_visionfive2_12a_defconfig | 9 + configs/starfive_visionfive2_13b_defconfig | 9 + drivers/pci/Kconfig | 11 + drivers/pci/Makefile | 1 + drivers/pci/pcie_starfive_jh7110.c | 463 ++++++++++++++++++ 7 files changed, 578 insertions(+) create mode 100644 drivers/pci/pcie_starfive_jh7110.c
base-commit: 41a88ad529b3943b1e465846eb24fe2c29203e35 prerequisite-patch-id: a84452ba131408ff842b65ae19a3a05f64b3ff60 prerequisite-patch-id: 4abb46d56dbaf36017b2866688f31a73c2cacd0d prerequisite-patch-id: ef5e9d61f7392c7d2e5321aa8a10996ca8eae5fc prerequisite-patch-id: 26dfdb401d680ecd9449acf09131cf4790e987b7 prerequisite-patch-id: a0cfa5d8cdb49bbe9d4739afa90991f882950881 prerequisite-patch-id: 61ceecb41cfd9029bfb267f7b7c5330a2d7e5edc prerequisite-patch-id: d834ece14ffb525b8c3e661e78736692f33fca9b prerequisite-patch-id: 88c9f9637335fdc4107d42db67b9110c9b73ead3 prerequisite-patch-id: ebc26ed3f97f7babc0fc805152acb578f5eff922 prerequisite-patch-id: e85a9ca22facac4d5b5562a2708b7332478d6db4 prerequisite-patch-id: ff5bd799e4cb905fef6cf1cd0ce757980e1d34b7 prerequisite-patch-id: a341d4e8a8e25cb711309123939235fcb3c10c1a prerequisite-patch-id: 749e4eafb431857ee2bec4ac8e78a682f6a57588 prerequisite-patch-id: d4a3666ce2e7135402537cea60e9e6f0435230bf prerequisite-patch-id: fa8ad1bfce7d6ab74ad63ff8d31dff3c2ccb5e43 prerequisite-patch-id: cc352634b8dfaf2d4243819362326a579e010c94 prerequisite-patch-id: 8e0fa3d987020ca06e22401bc4c69f834c38c3dc
Add pcie driver for StarFive JH7110, the driver depends on starfive gpio, pinctrl, clk and reset driver to do init.
Several devices are tested: a) M.2 NVMe SSD b) Realtek 8169 Ethernet adapter.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- drivers/pci/Kconfig | 11 + drivers/pci/Makefile | 1 + drivers/pci/pcie_starfive_jh7110.c | 463 +++++++++++++++++++++++++++++ 3 files changed, 475 insertions(+) create mode 100644 drivers/pci/pcie_starfive_jh7110.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index ef328d2652..e7b0ff5bc3 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -374,4 +374,15 @@ config PCIE_UNIPHIER Say Y here if you want to enable PCIe controller support on UniPhier SoCs.
+config PCIE_STARFIVE_JH7110 + bool "Enable Starfive JH7110 PCIe driver" + depends on STARFIVE_JH7110 + depends on PINCTRL_STARFIVE_JH7110 + depends on CLK_JH7110 + depends on RESET_JH7110 + default y + help + Say Y here if you want to enable PCIe controller support on + StarFive JH7110 SoC. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 49506e7ba5..bbe3323bb5 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -49,3 +49,4 @@ obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o obj-$(CONFIG_PCIE_OCTEON) += pcie_octeon.o obj-$(CONFIG_PCIE_DW_SIFIVE) += pcie_dw_sifive.o obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o +obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o diff --git a/drivers/pci/pcie_starfive_jh7110.c b/drivers/pci/pcie_starfive_jh7110.c new file mode 100644 index 0000000000..1005ed9919 --- /dev/null +++ b/drivers/pci/pcie_starfive_jh7110.c @@ -0,0 +1,463 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * StarFive PLDA PCIe host controller driver + * + * Copyright (c) 2023 Starfive, Inc. + * Author: Mason Huo mason.huo@starfivetech.com + * + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <pci.h> +#include <pci_ids.h> +#include <power-domain.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <dm/device_compat.h> +#include <dm/pinctrl.h> +#include <linux/delay.h> +#include <linux/iopoll.h> +#include <power/regulator.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GEN_SETTINGS 0x80 +#define PCIE_PCI_IDS 0x9C +#define PCIE_WINROM 0xFC +#define PMSG_SUPPORT_RX 0x3F0 +#define PCI_MISC 0xB4 + +#define PLDA_EP_ENABLE 0 +#define PLDA_RP_ENABLE 1 + +#define IDS_REVISION_ID 0x02 +#define IDS_CLASS_CODE_SHIFT 8 + +#define PREF_MEM_WIN_64_SUPPORT BIT(3) +#define PMSG_LTR_SUPPORT BIT(2) +#define PLDA_FUNCTION_DIS BIT(15) +#define PLDA_FUNC_NUM 4 +#define PLDA_PHY_FUNC_SHIFT 9 + +#define XR3PCI_ATR_AXI4_SLV0 0x800 +#define XR3PCI_ATR_SRC_ADDR_LOW 0x0 +#define XR3PCI_ATR_SRC_ADDR_HIGH 0x4 +#define XR3PCI_ATR_TRSL_ADDR_LOW 0x8 +#define XR3PCI_ATR_TRSL_ADDR_HIGH 0xc +#define XR3PCI_ATR_TRSL_PARAM 0x10 +#define XR3PCI_ATR_TABLE_OFFSET 0x20 +#define XR3PCI_ATR_MAX_TABLE_NUM 8 + +#define XR3PCI_ATR_SRC_WIN_SIZE_SHIFT 1 +#define XR3PCI_ATR_SRC_ADDR_MASK GENMASK(31, 12) +#define XR3PCI_ATR_TRSL_ADDR_MASK GENMASK(31, 12) +#define XR3_PCI_ECAM_SIZE 28 +#define XR3PCI_ATR_TRSL_DIR BIT(22) +/* IDs used in the XR3PCI_ATR_TRSL_PARAM */ +#define XR3PCI_ATR_TRSLID_PCIE_MEMORY 0x0 +#define XR3PCI_ATR_TRSLID_PCIE_CONFIG 0x1 + +/* system control */ +#define STG_SYSCON_K_RP_NEP_MASK BIT(8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_MASK GENMASK(22, 8) +#define STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT 8 +#define STG_SYSCON_AXI4_SLVL_AWFUNC_MASK GENMASK(14, 0) +#define STG_SYSCON_CLKREQ_MASK BIT(22) +#define STG_SYSCON_CKREF_SRC_SHIFT 18 +#define STG_SYSCON_CKREF_SRC_MASK GENMASK(19, 18) + +struct starfive_pcie { + struct udevice *dev; + + void __iomem *reg_base; + void __iomem *cfg_base; + + struct regmap *regmap; + u32 stg_arfun; + u32 stg_awfun; + u32 stg_rp_nep; + + struct clk_bulk clks; + struct reset_ctl_bulk rsts; + struct gpio_desc reset_gpio; + + int atr_table_num; + int first_busno; +}; + +static int starfive_pcie_off_conf(pci_dev_t bdf, uint offset) +{ + unsigned int bus = PCI_BUS(bdf); + unsigned int dev = PCI_DEV(bdf); + unsigned int func = PCI_FUNC(bdf); + + return PCIE_ECAM_OFFSET(bus, dev, func, offset); +} + +static int starfive_pcie_addr_valid(pci_dev_t bdf, int first_busno) +{ + /* + * Single device limitation. + * For JH7110 SoC limitation, one bus can only connnect one device. + * And PCIe controller contain HW issue that non-root host bridge + * bus emumerate duplicate devices. + * Only can access device 0 in Bus 1 host bridge. + */ + if ((PCI_BUS(bdf) != first_busno) && (PCI_DEV(bdf) > 0)) + return 0; + return 1; +} + +static int starfive_pcie_conf_address(const struct udevice *udev, pci_dev_t bdf, + uint offset, void **paddr) +{ + struct starfive_pcie *priv = dev_get_priv(udev); + int where = starfive_pcie_off_conf(bdf, offset); + + if (!starfive_pcie_addr_valid(bdf, priv->first_busno)) + return -EINVAL; + + *paddr = (void *)(priv->cfg_base + where); + return 0; +} + +static int starfive_pcie_config_read(const struct udevice *udev, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + return pci_generic_mmap_read_config(udev, starfive_pcie_conf_address, + bdf, offset, valuep, size); +} + +int starfive_pcie_config_write(struct udevice *udev, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + return pci_generic_mmap_write_config(udev, starfive_pcie_conf_address, + bdf, offset, value, size); +} + +static int starfive_pcie_set_atr_entry(struct starfive_pcie *priv, phys_addr_t src_addr, + phys_addr_t trsl_addr, size_t window_size, + int trsl_param) +{ + void __iomem *base = + priv->reg_base + XR3PCI_ATR_AXI4_SLV0; + + /* Support AXI4 Slave 0 Address Translation Tables 0-7. */ + if (priv->atr_table_num >= XR3PCI_ATR_MAX_TABLE_NUM) { + dev_err(priv->dev, "ATR table number %d exceeds max num\n", + priv->atr_table_num); + return -EINVAL; + } + base += XR3PCI_ATR_TABLE_OFFSET * priv->atr_table_num; + priv->atr_table_num++; + + /* + * X3PCI_ATR_SRC_ADDR_LOW: + * - bit 0: enable entry, + * - bits 1-6: ATR window size: total size in bytes: 2^(ATR_WSIZE + 1) + * - bits 7-11: reserved + * - bits 12-31: start of source address + */ + writel((lower_32_bits(src_addr) & XR3PCI_ATR_SRC_ADDR_MASK) | + (fls(window_size) - 1) << XR3PCI_ATR_SRC_WIN_SIZE_SHIFT | 1, + base + XR3PCI_ATR_SRC_ADDR_LOW); + writel(upper_32_bits(src_addr), base + XR3PCI_ATR_SRC_ADDR_HIGH); + writel((lower_32_bits(trsl_addr) & XR3PCI_ATR_TRSL_ADDR_MASK), + base + XR3PCI_ATR_TRSL_ADDR_LOW); + writel(upper_32_bits(trsl_addr), base + XR3PCI_ATR_TRSL_ADDR_HIGH); + writel(trsl_param, base + XR3PCI_ATR_TRSL_PARAM); + + dev_dbg(priv->dev, "ATR entry: 0x%010llx %s 0x%010llx [0x%010llx] (param: 0x%06x)\n", + src_addr, (trsl_param & XR3PCI_ATR_TRSL_DIR) ? "<-" : "->", + trsl_addr, (u64)window_size, trsl_param); + return 0; +} + +static int starfive_pcie_atr_init(struct starfive_pcie *priv) +{ + struct udevice *ctlr = pci_get_controller(priv->dev); + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + int i, ret; + + /* + * As the two host bridges in JH7110 soc have the same default + * address translation table, this cause the second root port can't + * access it's host bridge config space correctly. + * To workaround, config the ATR of host bridge config space by SW. + */ + + ret = starfive_pcie_set_atr_entry(priv, + (phys_addr_t)priv->cfg_base, + 0, + 1 << XR3_PCI_ECAM_SIZE, + XR3PCI_ATR_TRSLID_PCIE_CONFIG); + if (ret) + return ret; + + for (i = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) + continue; + + /* Only support identity mappings. */ + if (hose->regions[i].bus_start != + hose->regions[i].phys_start) + return -EINVAL; + + ret = starfive_pcie_set_atr_entry(priv, + hose->regions[i].phys_start, + hose->regions[i].bus_start, + hose->regions[i].size, + XR3PCI_ATR_TRSLID_PCIE_MEMORY); + if (ret) + return ret; + } + + return 0; +} + +static int starfive_pcie_get_syscon(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + struct udevice *syscon; + struct ofnode_phandle_args syscfg_phandle; + u32 cells[4]; + int ret; + + /* get corresponding syscon phandle */ + ret = dev_read_phandle_with_args(dev, "starfive,stg-syscon", NULL, 0, 0, + &syscfg_phandle); + + if (ret < 0) { + dev_err(dev, "Can't get syscfg phandle: %d\n", ret); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_SYSCON, syscfg_phandle.node, + &syscon); + if (ret) { + dev_err(dev, "Unable to find syscon device (%d)\n", ret); + return ret; + } + + priv->regmap = syscon_get_regmap(syscon); + if (!priv->regmap) { + dev_err(dev, "Unable to find regmap\n"); + return -ENODEV; + } + + /* get syscon register offset */ + ret = dev_read_u32_array(dev, "starfive,stg-syscon", + cells, ARRAY_SIZE(cells)); + if (ret) { + dev_err(dev, "Get syscon register err %d\n", ret); + return -EINVAL; + } + + dev_dbg(dev, "Get syscon values: %x, %x, %x\n", + cells[1], cells[2], cells[3]); + priv->stg_arfun = cells[1]; + priv->stg_awfun = cells[2]; + priv->stg_rp_nep = cells[3]; + + return 0; +} + +static int starfive_pcie_parse_dt(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + int ret; + + priv->reg_base = (void *)dev_read_addr_name(dev, "reg"); + if (priv->reg_base == (void __iomem *)FDT_ADDR_T_NONE) { + dev_err(dev, "Missing required reg address range\n"); + return -EINVAL; + } + + priv->cfg_base = (void *)dev_read_addr_name(dev, "config"); + if (priv->cfg_base == (void __iomem *)FDT_ADDR_T_NONE) { + dev_err(dev, "Missing required config address range"); + return -EINVAL; + } + + ret = starfive_pcie_get_syscon(dev); + if (ret) { + dev_err(dev, "Can't get syscon: %d\n", ret); + return ret; + } + + ret = reset_get_bulk(dev, &priv->rsts); + if (ret) { + dev_err(dev, "Can't get reset: %d\n", ret); + return ret; + } + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) { + dev_err(dev, "Can't get clock: %d\n", ret); + return ret; + } + + ret = gpio_request_by_name(dev, "reset-gpios", 0, &priv->reset_gpio, + GPIOD_IS_OUT); + if (ret) { + dev_err(dev, "Can't get reset-gpio: %d\n", ret); + return ret; + } + + if (!dm_gpio_is_valid(&priv->reset_gpio)) { + dev_err(dev, "reset-gpio is not valid\n"); + return -EINVAL; + } + return 0; +} + +static int starfive_pcie_init_port(struct udevice *dev) +{ + int ret, i; + unsigned int value; + struct starfive_pcie *priv = dev_get_priv(dev); + + ret = clk_enable_bulk(&priv->clks); + if (ret) { + dev_err(dev, "Failed to enable clks (ret=%d)\n", ret); + return ret; + } + + ret = reset_deassert_bulk(&priv->rsts); + if (ret) { + dev_err(dev, "Failed to deassert resets (ret=%d)\n", ret); + goto err_deassert_clk; + } + + dm_gpio_set_value(&priv->reset_gpio, 1); + /* Disable physical functions except #0 */ + for (i = 1; i < PLDA_FUNC_NUM; i++) { + regmap_update_bits(priv->regmap, + priv->stg_arfun, + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, + (i << PLDA_PHY_FUNC_SHIFT) << + STG_SYSCON_AXI4_SLVL_ARFUNC_SHIFT); + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, + i << PLDA_PHY_FUNC_SHIFT); + + value = readl(priv->reg_base + PCI_MISC); + value |= PLDA_FUNCTION_DIS; + writel(value, priv->reg_base + PCI_MISC); + } + + /* Disable physical functions */ + regmap_update_bits(priv->regmap, + priv->stg_arfun, + STG_SYSCON_AXI4_SLVL_ARFUNC_MASK, + 0); + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_AXI4_SLVL_AWFUNC_MASK, + 0); + + /* Enable root port */ + value = readl(priv->reg_base + GEN_SETTINGS); + value |= PLDA_RP_ENABLE; + writel(value, priv->reg_base + GEN_SETTINGS); + + /* PCIe PCI Standard Configuration Identification Settings. */ + value = (PCI_CLASS_BRIDGE_PCI_NORMAL << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID; + writel(value, priv->reg_base + PCIE_PCI_IDS); + + /* + * The LTR message forwarding of PCIe Message Reception was set by core + * as default, but the forward id & addr are also need to be reset. + * If we do not disable LTR message forwarding here, or set a legal + * forwarding address, the kernel will get stuck after this driver probe. + * To workaround, disable the LTR message forwarding support on + * PCIe Message Reception. + */ + value = readl(priv->reg_base + PMSG_SUPPORT_RX); + value &= ~PMSG_LTR_SUPPORT; + writel(value, priv->reg_base + PMSG_SUPPORT_RX); + + /* Prefetchable memory window 64-bit addressing support */ + value = readl(priv->reg_base + PCIE_WINROM); + value |= PREF_MEM_WIN_64_SUPPORT; + writel(value, priv->reg_base + PCIE_WINROM); + + starfive_pcie_atr_init(priv); + + dm_gpio_set_value(&priv->reset_gpio, 0); + /* Ensure that PERST in default at least 300 ms */ + mdelay(300); + + return 0; + +err_deassert_clk: + clk_disable_bulk(&priv->clks); + return ret; +} + +static int starfive_pcie_probe(struct udevice *dev) +{ + struct starfive_pcie *priv = dev_get_priv(dev); + int ret; + + priv->atr_table_num = 0; + priv->dev = dev; + priv->first_busno = dev_seq(dev); + + ret = starfive_pcie_parse_dt(dev); + if (ret) + return ret; + + regmap_update_bits(priv->regmap, + priv->stg_rp_nep, + STG_SYSCON_K_RP_NEP_MASK, + STG_SYSCON_K_RP_NEP_MASK); + + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_CKREF_SRC_MASK, + 2 << STG_SYSCON_CKREF_SRC_SHIFT); + + regmap_update_bits(priv->regmap, + priv->stg_awfun, + STG_SYSCON_CLKREQ_MASK, + STG_SYSCON_CLKREQ_MASK); + + ret = starfive_pcie_init_port(dev); + if (ret) + return ret; + + dev_err(dev, "Starfive PCIe bus probed.\n"); + + return 0; +} + +static const struct dm_pci_ops starfive_pcie_ops = { + .read_config = starfive_pcie_config_read, + .write_config = starfive_pcie_config_write, +}; + +static const struct udevice_id starfive_pcie_ids[] = { + { .compatible = "starfive,jh7110-pcie" }, + { } +}; + +U_BOOT_DRIVER(starfive_pcie_drv) = { + .name = "starfive_7110_pcie", + .id = UCLASS_PCI, + .of_match = starfive_pcie_ids, + .ops = &starfive_pcie_ops, + .probe = starfive_pcie_probe, + .priv_auto = sizeof(struct starfive_pcie), +};
Hello!
- bool "Enable Starfive JH7110 PCIe driver"
- depends on STARFIVE_JH7110
- depends on PINCTRL_STARFIVE_JH7110
- depends on CLK_JH7110
- depends on RESET_JH7110
There is no direct hard dependency on on these 4 symbols (or at least I do not see any in include header files). So to allow compile time checks, change it to just soft dependency by switching from "depends" to "imply" keyword.
- default y
- help
endif
- unsigned int bus = PCI_BUS(bdf);
- unsigned int dev = PCI_DEV(bdf);
- unsigned int func = PCI_FUNC(bdf);
- return PCIE_ECAM_OFFSET(bus, dev, func, offset);
This function is used just on one place, it is pretty straightforward and nothing starfive_pcie-specific. Just directly inline it into starfive_pcie_conf_address() function?
int where = PCIE_ECAM_OFFSET(PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf), offset);
- if ((PCI_BUS(bdf) != first_busno) && (PCI_DEV(bdf) > 0))
In v2 discussion you wrote that the issue with duplicate devices is on the bus 1, which is secondary bus - the bus behind the root port.
So check against root port bus (first_busno) is not correct, you need to check it against bus behind the root port (secondary bus).
Current check completely filters all devices with numbers higher than 0 behind the secondary bus, which completely breaks support for PCIe switches. Moreover behind PCIe switch can be anything with more complicated topology.
That secondary bus number is dynamically allocated / assigned by U-Boot core code, so you need to check PCI_SECONDARY_BUS register of the root port.
In pci_mvebu.c is this value cached in "->sec_busno" member. You can reuse this pattern.
You probably want this kind of check:
if (PCI_BUS(bdf) == priv->sec_busno && PCI_DEV(bdf) > 0) return false; else return true;
Also comment "non-root host bridge bus" is strange. Bus of the host bridge is always the root one. You probably want to write the bus immediately behind the root bus / host bridge OR the secondary bus of the host bridge.
- return 1;
- struct starfive_pcie *priv = dev_get_priv(udev);
- int where = starfive_pcie_off_conf(bdf, offset);
- if (!starfive_pcie_addr_valid(bdf, priv->first_busno))
return -EINVAL;
Maybe better error code is -ENODEV? As technically access request is valid but there is no device on it.
- *paddr = (void *)(priv->cfg_base + where);
- int ret, i;
- unsigned int value;
- struct starfive_pcie *priv = dev_get_priv(dev);
- ret = clk_enable_bulk(&priv->clks);
- if (ret) {
return ret;
- ret = reset_deassert_bulk(&priv->rsts);
- if (ret) {
- dm_gpio_set_value(&priv->reset_gpio, 1);
- /* Disable physical functions except #0 */
- for (i = 1; i < PLDA_FUNC_NUM; i++) {
priv->stg_arfun,
priv->stg_awfun,
- /* Disable physical functions */
- regmap_update_bits(priv->regmap,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
- /* Enable root port */
- value = readl(priv->reg_base + GEN_SETTINGS);
- value |= PLDA_RP_ENABLE;
- writel(value, priv->reg_base + GEN_SETTINGS);
- /* PCIe PCI Standard Configuration Identification Settings. */
- value = (PCI_CLASS_BRIDGE_PCI_NORMAL << IDS_CLASS_CODE_SHIFT) | IDS_REVISION_ID;
- writel(value, priv->reg_base + PCIE_PCI_IDS);
This looks like configuration of the PCI_CLASS_REVISION read-only register. Is there any reason why you are removing the original "revision" information by hardcoded IDS_REVISION_ID constant?
- value = readl(priv->reg_base + PMSG_SUPPORT_RX);
- value &= ~PMSG_LTR_SUPPORT;
- writel(value, priv->reg_base + PMSG_SUPPORT_RX);
- /* Prefetchable memory window 64-bit addressing support */
- value = readl(priv->reg_base + PCIE_WINROM);
- value |= PREF_MEM_WIN_64_SUPPORT;
- writel(value, priv->reg_base + PCIE_WINROM);
- starfive_pcie_atr_init(priv);
This function may fail. But return value is ignored here.
- dm_gpio_set_value(&priv->reset_gpio, 0);
- /* Ensure that PERST in default at least 300 ms */
- mdelay(300);
+err_deassert_clk:
- clk_disable_bulk(&priv->clks);
- return ret;
On 2023/3/30 1:27, Pali Rohár wrote:
Hello!
ok, I will change this.
- default y
- help
endif
ok, thanks
OK, thanks, I will record secondary busno according PCI_SECONDARY_BUS register
ok
- return 1;
return -EINVAL;
ok
- int ret, i;
- if (ret) {
return ret;
- if (ret) {
priv->stg_arfun,
priv->stg_awfun,
priv->stg_arfun,
0);
priv->stg_awfun,
0);
This register is not read-only register, consist resion ID and class code. Bit [39:32]: Revision ID Bit [63:40]: Class code And the register reset value is zero, Our PCIe version is 2.0. So set value 2. Maybe I will add comment to this.
ok
- mdelay(300);
+err_deassert_clk:
- return ret;
Hello!
I mean that this "priv->reg_base + PCIE_PCI_IDS" read-write register configures what is visible when reading read-only standard PCI register PCI_CLASS_REVISION.
PCIe Root Port is by definition of PCI-to-PCI Bridge class and therefore reading from PCI_CLASS_REVISION must return PCI_CLASS_BRIDGE_PCI_* value. This is required by PCIe spec.
With above driver init code it looks like that your PCIe controller does not set correct value into PCI_CLASS_REVISION register after power-on and manually setting correct value via "priv->reg_base + PCIE_PCI_IDS" is a workaround.
Hopefully it is a more clear what I mean in my previous email.
Also mvebu controller has this issue and has similar workaround in pci_mvebu.c driver.
Well, Revision ID (low 8 bits of PCI_CLASS_REVISION) is the extension to the vendor / device id register. It is not version of PCIe standard.
I would expect that this Vendor ID, Device ID and Revision ID values are not being changed by the driver as they identify PCI and PCIe devices.
Hello!
I am sorry. It is PCIe controller IP revision ID. I have make a mistake for it. So zero value is correct. I will remove writing IDS_REVISION_ID value.
also add the nvme driver and rtl8169 support.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- configs/starfive_visionfive2_12a_defconfig | 9 +++++++++ configs/starfive_visionfive2_13b_defconfig | 9 +++++++++ 2 files changed, 18 insertions(+)
diff --git a/configs/starfive_visionfive2_12a_defconfig b/configs/starfive_visionfive2_12a_defconfig index e0f98292ff..2a7563743b 100644 --- a/configs/starfive_visionfive2_12a_defconfig +++ b/configs/starfive_visionfive2_12a_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_SYS_PCI_64BIT=y CONFIG_TARGET_STARFIVE_VISIONFIVE2=y CONFIG_SPL_OPENSBI_LOAD_ADDR=0x40000000 CONFIG_ARCH_RV64I=y @@ -49,9 +50,12 @@ CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 +CONFIG_CMD_PCI=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_TFTPPUT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_JH7110=y @@ -65,6 +69,11 @@ CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y diff --git a/configs/starfive_visionfive2_13b_defconfig b/configs/starfive_visionfive2_13b_defconfig index 550d0ff3ab..98d23d9461 100644 --- a/configs/starfive_visionfive2_13b_defconfig +++ b/configs/starfive_visionfive2_13b_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0x82000000 +CONFIG_SYS_PCI_64BIT=y CONFIG_TARGET_STARFIVE_VISIONFIVE2=y CONFIG_SPL_OPENSBI_LOAD_ADDR=0x40000000 CONFIG_ARCH_RV64I=y @@ -50,8 +51,11 @@ CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 CONFIG_SYS_BOOTM_LEN=0x4000000 CONFIG_CMD_MEMINFO=y +CONFIG_CMD_PCI=y CONFIG_CMD_TFTPPUT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_JH7110=y @@ -65,6 +69,11 @@ CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_GIGADEVICE=y CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_SPL_PINCTRL=y
Enable and add pinctrl configuration for PCIe host controller. Also add JH7110 stg syscon configuration.
Signed-off-by: Mason Huo mason.huo@starfivetech.com Signed-off-by: Minda Chen minda.chen@starfivetech.com --- .../dts/jh7110-starfive-visionfive-2.dtsi | 11 +++ arch/riscv/dts/jh7110.dtsi | 74 +++++++++++++++++++ 2 files changed, 85 insertions(+)
diff --git a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi index c6b6dfa940..12245576ac 100644 --- a/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi +++ b/arch/riscv/dts/jh7110-starfive-visionfive-2.dtsi @@ -7,6 +7,7 @@
#include "jh7110.dtsi" #include <dt-bindings/pinctrl/pinctrl-starfive-jh7110.h> +#include <dt-bindings/gpio/gpio.h> / { aliases { serial0 = &uart0; @@ -300,6 +301,16 @@ }; };
+&pcie0 { + reset-gpios = <&sysgpio 26 GPIO_ACTIVE_LOW>; + status = "disabled"; +}; + +&pcie1 { + reset-gpios = <&sysgpio 28 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + &syscrg { assigned-clocks = <&syscrg JH7110_SYSCLK_CPU_ROOT>, <&syscrg JH7110_SYSCLK_BUS_ROOT>, diff --git a/arch/riscv/dts/jh7110.dtsi b/arch/riscv/dts/jh7110.dtsi index bd60879615..eaf8035a61 100644 --- a/arch/riscv/dts/jh7110.dtsi +++ b/arch/riscv/dts/jh7110.dtsi @@ -569,5 +569,79 @@ gpio-controller; #gpio-cells = <2>; }; + + pcie0: pcie@2B000000 { + compatible = "starfive,jh7110-pcie"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + reg = <0x0 0x2B000000 0x0 0x1000000>, + <0x9 0x40000000 0x0 0x10000000>; + reg-names = "reg", "config"; + device_type = "pci"; + starfive,stg-syscon = <&stg_syscon 0xc0 0xc4 0x130>; + bus-range = <0x0 0xff>; + ranges = <0x82000000 0x0 0x30000000 0x0 0x30000000 0x0 0x08000000>, + <0xc3000000 0x9 0x00000000 0x9 0x00000000 0x0 0x40000000>; + msi-parent = <&plic>; + interrupts = <56>; + interrupt-controller; + interrupt-names = "msi"; + interrupt-parent = <&plic>; + interrupt-map-mask = <0x0 0x0 0x0 0x7>; + interrupt-map = <0x0 0x0 0x0 0x1 &plic 0x1>, + <0x0 0x0 0x0 0x2 &plic 0x2>, + <0x0 0x0 0x0 0x3 &plic 0x3>, + <0x0 0x0 0x0 0x4 &plic 0x4>; + resets = <&stgcrg JH7110_STGRST_PCIE0_MST0>, + <&stgcrg JH7110_STGRST_PCIE0_SLV0>, + <&stgcrg JH7110_STGRST_PCIE0_SLV>, + <&stgcrg JH7110_STGRST_PCIE0_BRG>, + <&stgcrg JH7110_STGRST_PCIE0_CORE>, + <&stgcrg JH7110_STGRST_PCIE0_APB>; + clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, + <&stgcrg JH7110_STGCLK_PCIE0_TL>, + <&stgcrg JH7110_STGCLK_PCIE0_AXI>, + <&stgcrg JH7110_STGCLK_PCIE0_APB>; + clock-names = "noc_bus_stg_axi", "pcie0_tl", "pcie0_axi", "pcie0_apb"; + status = "disabled"; + }; + + pcie1: pcie@2C000000 { + compatible = "starfive,jh7110-pcie"; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + reg = <0x0 0x2C000000 0x0 0x1000000>, + <0x9 0xc0000000 0x0 0x10000000>; + reg-names = "reg", "config"; + device_type = "pci"; + starfive,stg-syscon = <&stg_syscon 0x270 0x274 0x2e0>; + bus-range = <0x0 0xff>; + ranges = <0x82000000 0x0 0x38000000 0x0 0x38000000 0x0 0x08000000>, + <0xc3000000 0x9 0x80000000 0x9 0x80000000 0x0 0x40000000>; + msi-parent = <&plic>; + interrupts = <57>; + interrupt-controller; + interrupt-names = "msi"; + interrupt-parent = <&plic>; + interrupt-map-mask = <0x0 0x0 0x0 0x7>; + interrupt-map = <0x0 0x0 0x0 0x1 &plic 0x1>, + <0x0 0x0 0x0 0x2 &plic 0x2>, + <0x0 0x0 0x0 0x3 &plic 0x3>, + <0x0 0x0 0x0 0x4 &plic 0x4>; + resets = <&stgcrg JH7110_STGRST_PCIE1_MST0>, + <&stgcrg JH7110_STGRST_PCIE1_SLV0>, + <&stgcrg JH7110_STGRST_PCIE1_SLV>, + <&stgcrg JH7110_STGRST_PCIE1_BRG>, + <&stgcrg JH7110_STGRST_PCIE1_CORE>, + <&stgcrg JH7110_STGRST_PCIE1_APB>; + clocks = <&syscrg JH7110_SYSCLK_NOC_BUS_STG_AXI>, + <&stgcrg JH7110_STGCLK_PCIE1_TL>, + <&stgcrg JH7110_STGCLK_PCIE1_AXI>, + <&stgcrg JH7110_STGCLK_PCIE1_APB>; + clock-names = "noc_bus_stg_axi", "pcie1_tl", "pcie1_axi", "pcie1_apb"; + status = "disabled"; + }; }; };
Minda Chen
Pali Rohár
